[U-Boot] [PATCH 3/9 v3] integratorap: support relocation
The integrator board was apparently never converted over to support relocation until now. After this the integrator u-boot both compiles and boots on the Integrator AP.
Signed-off-by: Linus Walleij linus.walleij@linaro.org --- board/armltd/integrator/integrator.c | 14 ++++++++------ 1 files changed, 8 insertions(+), 6 deletions(-)
diff --git a/board/armltd/integrator/integrator.c b/board/armltd/integrator/integrator.c index 9bb56b5..a0d8de7 100644 --- a/board/armltd/integrator/integrator.c +++ b/board/armltd/integrator/integrator.c @@ -86,14 +86,16 @@ int misc_init_r (void) return (0); }
-/****************************** - Routine: - Description: -******************************/ -int dram_init (void) +void dram_init_banksize(void) { gd->bd->bi_dram[0].start = PHYS_SDRAM_1; - gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; + gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; +} + +int dram_init (void) +{ + gd->ram_size = get_ram_size((long *)CONFIG_SYS_SDRAM_BASE, + PHYS_SDRAM_1_SIZE);
#ifdef CONFIG_CM_SPD_DETECT {
Hello.
Signed-off-by: Linus Walleijlinus.walleij@linaro.org
- Routine:
- Description:
You're using spaces instead of tab here...
WBR, Sergei
On Mon, Jul 25, 2011 at 12:46 PM, Sergei Shtylyov sshtylyov@mvista.com wrote:
Oh man. I'll fix up. I re-ran all patches through checkpatch and this one seems to be the only one remaining with the problem, luckily.
Linus Walleij
On Mon, Jul 25, 2011 at 1:22 PM, Linus Walleij linus.walleij@linaro.org wrote:
Or well, patch [6/9] fixes the problem.
It's probably better that I squash patch 3 and 6.
This means the whole series need to be rebased again of course, so I'm resending the whole thing again.
Thanks, Linus Walleij
Linus Walleij
Sergei Shtylyov
