[U-Boot] some questions about u-boot
Hello, I am a newbie in the world of u-boot. There are three questions when I am using the u-boot. Can someone help me?
1. Before the u-boot enter the command line, some error like "Error: environment overflow " happens. The space in the ram used to save the environment variables are 0x2000. I think this is enough. I set this space in the head file like this: #define CONFIG_SYS_ENV_SIZE 0x2000.
2. Are there any commands in the u-boot to read and write the FRAM?
3. After the u-boot enter the command line, I enter the command "mii info". But nothing appears. If I enter the command "mii read 0x1 0x1", I can only see 0xFFFF. If I ping some address, I can see 32 lines if I use the "mii info" then. The address of the PHY is 0x1.
I have put a file in the following. It records all the words printed by the u-boot. Thanks.
U-Boot 2009.03 (Apr 05 2012 - 19:23:09) MPC512X CPU: MPC5125 rev. 1.0, Core e300c4 at 393.216 MHz, CSB at 196.608 MHz board: mpc5125_mpu I2C: ready DRAM: 256 MB Now running in RAM - U-Boot at: 0ff14000 NAND: 256 MiB In: serial Out: serial Err: serial ## Error: environment overflow, "stdin" deleted ## Error: environment overflow, "stdout" deleted ## Error: environment overflow, "stderr" deleted Net: ## Error: environment overflow, "ethact" deleted FEC ETHERNET## Error: environment overflow, "ethact" deleted
Type "run flash_nfs" to mount root filesystem over NFS Hit any key to stop autoboot: 2 0 => => mii info => ping 169.254.9. 89.102 ## Error: environment overflow, "ethact" deleted Using FEC ETHERNET device FEC ETHERNET tbd status: 0x0000 FEC ETHERNET tbd status: 0x0000 ping failed; host 169.254.89.102 is not alive => mii info PHY 0x00: OUI = 0x0000, Model = 0x00, Rev = 0x00, 10baseT, HDX PHY 0x01: OUI = 0x0000, Model = 0x00, Rev = 0x00, 10baseT, HDX PHY 0x02: OUI = 0x0000, Model = 0x00, Rev = 0x00, 10baseT, HDX PHY 0x03: OUI = 0x0000, Model = 0x00, Rev = 0x00, 10baseT, HDX PHY 0x04: OUI = 0x0000, Model = 0x00, Rev = 0x00, 10baseT, HDX PHY 0x05: OUI = 0x0000, Model = 0x00, Rev = 0x00, 10baseT, HDX PHY 0x06: OUI = 0x0000, Model = 0x00, Rev = 0x00, 10baseT, HDX PHY 0x07: OUI = 0x0000, Model = 0x00, Rev = 0x00, 10baseT, HDX PHY 0x08: OUI = 0x0000, Model = 0x00, Rev = 0x00, 10baseT, HDX PHY 0x09: OUI = 0x0000, Model = 0x00, Rev = 0x00, 10baseT, HDX PHY 0x0A: OUI = 0x0000, Model = 0x00, Rev = 0x00, 10baseT, HDX PHY 0x0B: OUI = 0x0000, Model = 0x00, Rev = 0x00, 10baseT, HDX PHY 0x0C: OUI = 0x0000, Model = 0x00, Rev = 0x00, 10baseT, HDX PHY 0x0D: OUI = 0x0000, Model = 0x00, Rev = 0x00, 10baseT, HDX PHY 0x0E: OUI = 0x0000, Model = 0x00, Rev = 0x00, 10baseT, HDX PHY 0x0F: OUI = 0x0000, Model = 0x00, Rev = 0x00, 10baseT, HDX PHY 0x10: OUI = 0x0000, Model = 0x00, Rev = 0x00, 10baseT, HDX PHY 0x11: OUI = 0x0000, Model = 0x00, Rev = 0x00, 10baseT, HDX PHY 0x12: OUI = 0x0000, Model = 0x00, Rev = 0x00, 10baseT, HDX PHY 0x13: OUI = 0x0000, Model = 0x00, Rev = 0x00, 10baseT, HDX PHY 0x14: OUI = 0x0000, Model = 0x00, Rev = 0x00, 10baseT, HDX PHY 0x15: OUI = 0x0000, Model = 0x00, Rev = 0x00, 10baseT, HDX PHY 0x16: OUI = 0x0000, Model = 0x00, Rev = 0x00, 10baseT, HDX PHY 0x17: OUI = 0x0000, Model = 0x00, Rev = 0x00, 10baseT, HDX PHY 0x18: OUI = 0x0000, Model = 0x00, Rev = 0x00, 10baseT, HDX PHY 0x19: OUI = 0x0000, Model = 0x00, Rev = 0x00, 10baseT, HDX PHY 0x1A: OUI = 0x0000, Model = 0x00, Rev = 0x00, 10baseT, HDX PHY 0x1B: OUI = 0x0000, Model = 0x00, Rev = 0x00, 10baseT, HDX PHY 0x1C: OUI = 0x0000, Model = 0x00, Rev = 0x00, 10baseT, HDX PHY 0x1D: OUI = 0x0000, Model = 0x00, Rev = 0x00, 10baseT, HDX PHY 0x1E: OUI = 0x0000, Model = 0x00, Rev = 0x00, 10baseT, HDX PHY 0x1F: OUI = 0x0000, Model = 0x00, Rev = 0x00, 10baseT, HDX =>
Dear li guohu,
Let's give it a try...
- Before the u-boot enter the command line, some error like "Error:
environment overflow " happens. The space in the ram used to save the environment variables are 0x2000. I think this is enough. I set this space in the head file like this: #define CON FIG_SYS_ENV_SIZE 0x2000.
There is no such error message as "environment overflow" in current mainline versions of U-Boot itself; only the "fw_setenv" user space command may issue such a warning. Maybe you are running ancient code?
- Are there any commands in the u-boot to read and write the FRAM?
FRAM? Which board is this? Usually things like FRAM or MRAM are simply memory-mapped devices, so you can use: md, mw, mm, cp.
- After the u-boot enter the command line, I enter the command "mii
info". But nothing appears. If I enter the command "mii read 0x1 0x1", I can only see 0xFFFF. If I ping some address, I can see 32 lines if I use the "mii info" then. The address of th e PHY is 0x1.
You probably have some misconfiguration in your port.
U-Boot 2009.03 is more than 3 years old. Please do yourself and us a favour and update to current code. Then try again.
li guohu
