[U-Boot] [PATCH 1/2] powerpc/85xx: Add the workaround for erratum CPC-A002 (enable on P4080)
CoreNet Platform Cache single-bit tag error scrubbing will cause tag corruption. Disable the feature to workaround the issue.
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- arch/powerpc/cpu/mpc85xx/cmd_errata.c | 3 +++ arch/powerpc/cpu/mpc85xx/cpu_init.c | 4 ++++ arch/powerpc/include/asm/immap_85xx.h | 3 ++- include/configs/P4080DS.h | 1 + 4 files changed, 10 insertions(+), 1 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/cmd_errata.c b/arch/powerpc/cpu/mpc85xx/cmd_errata.c index 4c07d0c..3822cf0 100644 --- a/arch/powerpc/cpu/mpc85xx/cmd_errata.c +++ b/arch/powerpc/cpu/mpc85xx/cmd_errata.c @@ -62,6 +62,9 @@ static int do_errata(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) #ifdef CONFIG_SYS_FSL_ERRATUM_DDR_A003 puts("Work-around for Erratum DDR-A003 enabled\n"); #endif +#ifdef CONFIG_SYS_FSL_ERRATUM_CPC_A002 + puts("Work-around for Erratum CPC-A002 enabled\n"); +#endif
return 0; } diff --git a/arch/powerpc/cpu/mpc85xx/cpu_init.c b/arch/powerpc/cpu/mpc85xx/cpu_init.c index 354b222..c822d87 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu_init.c +++ b/arch/powerpc/cpu/mpc85xx/cpu_init.c @@ -142,6 +142,10 @@ static void enable_cpc(void) u32 cpccfg0 = in_be32(&cpc->cpccfg0); size += CPC_CFG0_SZ_K(cpccfg0);
+#ifdef CONFIG_SYS_FSL_ERRATUM_CPC_A002 + setbits_be32(&cpc->cpchdbcr0, CPC_HDBCR0_TAG_ECC_SCRUB_DIS); +#endif + out_be32(&cpc->cpccsr0, CPC_CSR0_CE | CPC_CSR0_PE); /* Read back to sync write */ in_be32(&cpc->cpccsr0); diff --git a/arch/powerpc/include/asm/immap_85xx.h b/arch/powerpc/include/asm/immap_85xx.h index 0069d50..ed36290 100644 --- a/arch/powerpc/include/asm/immap_85xx.h +++ b/arch/powerpc/include/asm/immap_85xx.h @@ -1,7 +1,7 @@ /* * MPC85xx Internal Memory Map * - * Copyright 2007-2010 Freescale Semiconductor, Inc. + * Copyright 2007-2011 Freescale Semiconductor, Inc. * * Copyright(c) 2002,2003 Motorola Inc. * Xianghua Xiao (x.xiao@motorola.com) @@ -1602,6 +1602,7 @@ typedef struct cpc_corenet { #define CPC_SRCR0_SRAMEN 0x00000001 #define CPC_ERRDIS_TMHITDIS 0x00000080 /* multi-way hit disable */ #define CPC_HDBCR0_CDQ_SPEC_DIS 0x08000000 +#define CPC_HDBCR0_TAG_ECC_SCRUB_DIS 0x01000000 #endif /* CONFIG_SYS_FSL_CPC */
/* Global Utilities Block */ diff --git a/include/configs/P4080DS.h b/include/configs/P4080DS.h index c398450..c269ddc 100644 --- a/include/configs/P4080DS.h +++ b/include/configs/P4080DS.h @@ -40,6 +40,7 @@ #define CONFIG_SYS_FSL_ERRATUM_ESDHC136
#define CONFIG_SYS_P4080_ERRATUM_CPU22 +#define CONFIG_SYS_FSL_ERRATUM_CPC_A002 #define CONFIG_SYS_P4080_ERRATUM_SERDES8 #define CONFIG_SYS_FSL_ERRATUM_DDR_A003
CoreNet Platform Cache single-bit data error scrubbing will cause data corruption. Disable the feature to workaround the issue.
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- arch/powerpc/cpu/mpc85xx/cmd_errata.c | 3 +++ arch/powerpc/cpu/mpc85xx/cpu_init.c | 3 +++ arch/powerpc/include/asm/immap_85xx.h | 1 + include/configs/P4080DS.h | 1 + 4 files changed, 8 insertions(+), 0 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/cmd_errata.c b/arch/powerpc/cpu/mpc85xx/cmd_errata.c index 3822cf0..e44a38f 100644 --- a/arch/powerpc/cpu/mpc85xx/cmd_errata.c +++ b/arch/powerpc/cpu/mpc85xx/cmd_errata.c @@ -65,6 +65,9 @@ static int do_errata(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) #ifdef CONFIG_SYS_FSL_ERRATUM_CPC_A002 puts("Work-around for Erratum CPC-A002 enabled\n"); #endif +#ifdef CONFIG_SYS_FSL_ERRATUM_CPC_A003 + puts("Work-around for Erratum CPC-A003 enabled\n"); +#endif
return 0; } diff --git a/arch/powerpc/cpu/mpc85xx/cpu_init.c b/arch/powerpc/cpu/mpc85xx/cpu_init.c index c822d87..8ece970 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu_init.c +++ b/arch/powerpc/cpu/mpc85xx/cpu_init.c @@ -145,6 +145,9 @@ static void enable_cpc(void) #ifdef CONFIG_SYS_FSL_ERRATUM_CPC_A002 setbits_be32(&cpc->cpchdbcr0, CPC_HDBCR0_TAG_ECC_SCRUB_DIS); #endif +#ifdef CONFIG_SYS_FSL_ERRATUM_CPC_A003 + setbits_be32(&cpc->cpchdbcr0, CPC_HDBCR0_DATA_ECC_SCRUB_DIS); +#endif
out_be32(&cpc->cpccsr0, CPC_CSR0_CE | CPC_CSR0_PE); /* Read back to sync write */ diff --git a/arch/powerpc/include/asm/immap_85xx.h b/arch/powerpc/include/asm/immap_85xx.h index ed36290..133b31f 100644 --- a/arch/powerpc/include/asm/immap_85xx.h +++ b/arch/powerpc/include/asm/immap_85xx.h @@ -1603,6 +1603,7 @@ typedef struct cpc_corenet { #define CPC_ERRDIS_TMHITDIS 0x00000080 /* multi-way hit disable */ #define CPC_HDBCR0_CDQ_SPEC_DIS 0x08000000 #define CPC_HDBCR0_TAG_ECC_SCRUB_DIS 0x01000000 +#define CPC_HDBCR0_DATA_ECC_SCRUB_DIS 0x00400000 #endif /* CONFIG_SYS_FSL_CPC */
/* Global Utilities Block */ diff --git a/include/configs/P4080DS.h b/include/configs/P4080DS.h index c269ddc..216f6fb 100644 --- a/include/configs/P4080DS.h +++ b/include/configs/P4080DS.h @@ -41,6 +41,7 @@
#define CONFIG_SYS_P4080_ERRATUM_CPU22 #define CONFIG_SYS_FSL_ERRATUM_CPC_A002 +#define CONFIG_SYS_FSL_ERRATUM_CPC_A003 #define CONFIG_SYS_P4080_ERRATUM_SERDES8 #define CONFIG_SYS_FSL_ERRATUM_DDR_A003
applied
- k
applied
- k
Kumar Gala
