[PATCH v2] usb: dwc3-meson-g12a: add power-on/off of the PHYs
Power on/off the PHYs to enable power to the USB ports, fixing USB support on Khadas VIM3/VIM3L boards.
The G12A USB complex has at least 2 USB2 PHYs, but one is muxed between the DWC2 and DWC3 controller and the other one directly connected to the DWC3 controller. The USB3+PCIe combo PHY is muxed between the DWC3 controller and a DW-PCIE controller. All PHYs are optional, but it's type (usb2/usb3) and position are important to determine it's capabilities, thus they are stored in a fixed size array and the phy-name determines it's position, it's position determining it's type and functionnalities. This is why we need to loop over the array to power on all the DT provided PHYs.
Signed-off-by: Neil Armstrong narmstrong@baylibre.com --- Changes since v1: - removed extra space before semicolon - added clarification in commit message
drivers/usb/dwc3/dwc3-meson-g12a.c | 16 ++++++++++++++++ 1 file changed, 16 insertions(+)
diff --git a/drivers/usb/dwc3/dwc3-meson-g12a.c b/drivers/usb/dwc3/dwc3-meson-g12a.c index d4453f8784..de964d6c10 100644 --- a/drivers/usb/dwc3/dwc3-meson-g12a.c +++ b/drivers/usb/dwc3/dwc3-meson-g12a.c @@ -408,6 +408,15 @@ static int dwc3_meson_g12a_probe(struct udevice *dev) goto err_phy_init; }
+ for (i = 0; i < PHY_COUNT; ++i) { + if (!priv->phys[i].dev) + continue; + + ret = generic_phy_power_on(&priv->phys[i]); + if (ret) + goto err_phy_init; + } + return 0;
err_phy_init: @@ -430,6 +439,13 @@ static int dwc3_meson_g12a_remove(struct udevice *dev)
clk_release_all(&priv->clk, 1);
+ for (i = 0; i < PHY_COUNT; ++i) { + if (!priv->phys[i].dev) + continue; + + generic_phy_power_off(&priv->phys[i]); + } + for (i = 0 ; i < PHY_COUNT ; ++i) { if (!priv->phys[i].dev) continue;
Changes since v1:
- for (i = 0; i < PHY_COUNT; ++i) {
i++ , unlike old c++ compilers, there's no difference here.
continue;
if (ret)
goto err_phy_init;
Neil Armstrong
