[PATCH v2 1/8] lpc32xx: Kconfig: switch to CONFIG_CONS_INDEX
There's nothing special or unique to the lpc32xx that requires its own config parameter for specifying the console uart index. Therefore instead of using the lpc32xx-specific CONFIG_SYS_LPC32XX_UART include parameter, use the already-available CONFIG_CONS_INDEX from Kconfig.
Signed-off-by: Trevor Woerner twoerner@gmail.com ---
(no changes since v1)
arch/arm/include/asm/arch-lpc32xx/config.h | 4 ++-- arch/arm/mach-lpc32xx/devices.c | 3 +-- board/timll/devkit3250/devkit3250.c | 2 +- board/timll/devkit3250/devkit3250_spl.c | 2 +- board/work-microwave/work_92105/work_92105.c | 2 +- board/work-microwave/work_92105/work_92105_spl.c | 2 +- configs/devkit3250_defconfig | 2 ++ configs/work_92105_defconfig | 2 ++ include/configs/devkit3250.h | 5 ----- include/configs/work_92105.h | 5 ----- scripts/config_whitelist.txt | 1 - 11 files changed, 11 insertions(+), 19 deletions(-)
diff --git a/arch/arm/include/asm/arch-lpc32xx/config.h b/arch/arm/include/asm/arch-lpc32xx/config.h index 0836091af2..45e46f9946 100644 --- a/arch/arm/include/asm/arch-lpc32xx/config.h +++ b/arch/arm/include/asm/arch-lpc32xx/config.h @@ -12,8 +12,8 @@ /* Basic CPU architecture */
/* UART configuration */ -#if (CONFIG_SYS_LPC32XX_UART == 1) || (CONFIG_SYS_LPC32XX_UART == 2) || \ - (CONFIG_SYS_LPC32XX_UART == 7) +#if (CONFIG_CONS_INDEX == 1) || (CONFIG_CONS_INDEX == 2) || \ + (CONFIG_CONS_INDEX == 7) #if !defined(CONFIG_LPC32XX_HSUART) #define CONFIG_LPC32XX_HSUART #endif diff --git a/arch/arm/mach-lpc32xx/devices.c b/arch/arm/mach-lpc32xx/devices.c index e1e2e0d094..0a4fef295a 100644 --- a/arch/arm/mach-lpc32xx/devices.c +++ b/arch/arm/mach-lpc32xx/devices.c @@ -23,8 +23,7 @@ void lpc32xx_uart_init(unsigned int uart_id) return;
/* Disable loopback mode, if it is set by S1L bootloader */ - clrbits_le32(&ctrl->loop, - UART_LOOPBACK(CONFIG_SYS_LPC32XX_UART)); + clrbits_le32(&ctrl->loop, UART_LOOPBACK(uart_id));
if (uart_id < 3 || uart_id > 6) return; diff --git a/board/timll/devkit3250/devkit3250.c b/board/timll/devkit3250/devkit3250.c index 3c744b943f..9d4ffb0f97 100644 --- a/board/timll/devkit3250/devkit3250.c +++ b/board/timll/devkit3250/devkit3250.c @@ -38,7 +38,7 @@ void reset_periph(void)
int board_early_init_f(void) { - lpc32xx_uart_init(CONFIG_SYS_LPC32XX_UART); + lpc32xx_uart_init(CONFIG_CONS_INDEX); lpc32xx_i2c_init(1); lpc32xx_i2c_init(2); lpc32xx_ssp_init(); diff --git a/board/timll/devkit3250/devkit3250_spl.c b/board/timll/devkit3250/devkit3250_spl.c index 47af78ae0b..12e8ae9c39 100644 --- a/board/timll/devkit3250/devkit3250_spl.c +++ b/board/timll/devkit3250/devkit3250_spl.c @@ -49,7 +49,7 @@ void spl_board_init(void) /* First of all silence buzzer controlled by GPO_20 */ writel((1 << 20), &gpio->p3_outp_clr);
- lpc32xx_uart_init(CONFIG_SYS_LPC32XX_UART); + lpc32xx_uart_init(CONFIG_CONS_INDEX); preloader_console_init();
ddr_init(&dram_64mb); diff --git a/board/work-microwave/work_92105/work_92105.c b/board/work-microwave/work_92105/work_92105.c index bdcecff730..5d12f84cfe 100644 --- a/board/work-microwave/work_92105/work_92105.c +++ b/board/work-microwave/work_92105/work_92105.c @@ -37,7 +37,7 @@ void reset_periph(void) int board_early_init_f(void) { /* initialize serial port for console */ - lpc32xx_uart_init(CONFIG_SYS_LPC32XX_UART); + lpc32xx_uart_init(CONFIG_CONS_INDEX); /* enable I2C, SSP, MAC, NAND */ lpc32xx_i2c_init(1); /* only I2C1 has devices, I2C2 has none */ lpc32xx_ssp_init(); diff --git a/board/work-microwave/work_92105/work_92105_spl.c b/board/work-microwave/work_92105/work_92105_spl.c index a31553a2d2..d9401145f2 100644 --- a/board/work-microwave/work_92105/work_92105_spl.c +++ b/board/work-microwave/work_92105/work_92105_spl.c @@ -58,7 +58,7 @@ const struct emc_dram_settings dram_128mb = { void spl_board_init(void) { /* initialize serial port for console */ - lpc32xx_uart_init(CONFIG_SYS_LPC32XX_UART); + lpc32xx_uart_init(CONFIG_CONS_INDEX); /* initialize console */ preloader_console_init(); /* init DDR and NAND to chainload U-Boot */ diff --git a/configs/devkit3250_defconfig b/configs/devkit3250_defconfig index 93c048cee8..9ae70f7d46 100644 --- a/configs/devkit3250_defconfig +++ b/configs/devkit3250_defconfig @@ -51,6 +51,8 @@ CONFIG_PHYLIB=y CONFIG_PHY_ADDR_ENABLE=y CONFIG_PHY_ADDR=31 CONFIG_PHY_SMSC=y +CONFIG_SPECIFY_CONSOLE_INDEX=y +CONFIG_CONS_INDEX=5 CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_USB=y diff --git a/configs/work_92105_defconfig b/configs/work_92105_defconfig index c3f666dcfe..e9605adedd 100644 --- a/configs/work_92105_defconfig +++ b/configs/work_92105_defconfig @@ -48,5 +48,7 @@ CONFIG_MTD_RAW_NAND=y CONFIG_PHYLIB=y CONFIG_PHY_ADDR_ENABLE=y CONFIG_PHY_SMSC=y +CONFIG_SPECIFY_CONSOLE_INDEX=y +CONFIG_CONS_INDEX=5 CONFIG_SYS_NS16550=y CONFIG_SPI=y diff --git a/include/configs/devkit3250.h b/include/configs/devkit3250.h index 5d2b77b4a3..921a38c01e 100644 --- a/include/configs/devkit3250.h +++ b/include/configs/devkit3250.h @@ -30,11 +30,6 @@ #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_SDRAM_BASE + SZ_4K \ - GENERATED_GBL_DATA_SIZE)
-/* - * Serial Driver - */ -#define CONFIG_SYS_LPC32XX_UART 5 /* UART5 */ - /* * DMA */ diff --git a/include/configs/work_92105.h b/include/configs/work_92105.h index 7874b77f3f..076a1b065e 100644 --- a/include/configs/work_92105.h +++ b/include/configs/work_92105.h @@ -35,11 +35,6 @@ #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_SDRAM_BASE + SZ_512K \ - GENERATED_GBL_DATA_SIZE)
-/* - * Serial Driver - */ -#define CONFIG_SYS_LPC32XX_UART 5 /* UART5 - NS16550 */ - /* * Ethernet Driver */ diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 0f5ac8ff52..13281bf6b1 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -2735,7 +2735,6 @@ CONFIG_SYS_LOW CONFIG_SYS_LOWMEM_BASE CONFIG_SYS_LOW_RES_TIMER CONFIG_SYS_LPAE_SDRAM_BASE -CONFIG_SYS_LPC32XX_UART CONFIG_SYS_LS1_DDR_BLOCK1_SIZE CONFIG_SYS_LS_MC_AIOP_IMG_MAX_LENGTH CONFIG_SYS_LS_MC_BOOT_TIMEOUT_MS
Import the dtsi, dts, and clock binding files for the lpc32xx ea3250 board directly and unmodified from the latest Linux kernel.
arch/arm/dts/lpc3250-ea3250.dts | 273 ++++++++++++ arch/arm/dts/lpc32xx.dtsi | 508 ++++++++++++++++++++++ include/dt-bindings/clock/lpc32xx-clock.h | 58 +++ 3 files changed, 839 insertions(+) create mode 100644 arch/arm/dts/lpc3250-ea3250.dts create mode 100644 arch/arm/dts/lpc32xx.dtsi create mode 100644 include/dt-bindings/clock/lpc32xx-clock.h
diff --git a/arch/arm/dts/lpc3250-ea3250.dts b/arch/arm/dts/lpc3250-ea3250.dts new file mode 100644 index 0000000000..63c6f17bb7 --- /dev/null +++ b/arch/arm/dts/lpc3250-ea3250.dts @@ -0,0 +1,273 @@ +// SPDX-License-Identifier: GPL-2.0-or-later +/* + * Embedded Artists LPC3250 board + * + * Copyright 2012 Roland Stigge stigge@antcom.de + */ + +/dts-v1/; +#include "lpc32xx.dtsi" + +/ { + model = "Embedded Artists LPC3250 board based on NXP LPC3250"; + compatible = "ea,ea3250", "nxp,lpc3250"; + + memory@80000000 { + device_type = "memory"; + reg = <0x80000000 0x4000000>; + }; + + gpio-keys { + compatible = "gpio-keys"; + autorepeat; + + button { + label = "Interrupt Key"; + linux,code = <103>; + gpios = <&gpio 4 1 0>; /* GPI_P3 1 */ + }; + + key1 { + label = "KEY1"; + linux,code = <1>; + gpios = <&pca9532 0 0>; + }; + + key2 { + label = "KEY2"; + linux,code = <2>; + gpios = <&pca9532 1 0>; + }; + + key3 { + label = "KEY3"; + linux,code = <3>; + gpios = <&pca9532 2 0>; + }; + + key4 { + label = "KEY4"; + linux,code = <4>; + gpios = <&pca9532 3 0>; + }; + + joy0 { + label = "Joystick Key 0"; + linux,code = <10>; + gpios = <&gpio 2 0 0>; /* P2.0 */ + }; + + joy1 { + label = "Joystick Key 1"; + linux,code = <11>; + gpios = <&gpio 2 1 0>; /* P2.1 */ + }; + + joy2 { + label = "Joystick Key 2"; + linux,code = <12>; + gpios = <&gpio 2 2 0>; /* P2.2 */ + }; + + joy3 { + label = "Joystick Key 3"; + linux,code = <13>; + gpios = <&gpio 2 3 0>; /* P2.3 */ + }; + + joy4 { + label = "Joystick Key 4"; + linux,code = <14>; + gpios = <&gpio 2 4 0>; /* P2.4 */ + }; + }; + + leds { + compatible = "gpio-leds"; + + /* LEDs on OEM Board */ + + led1 { + gpios = <&gpio 5 14 1>; /* GPO_P3 14, GPIO 93, active low */ + linux,default-trigger = "timer"; + default-state = "off"; + }; + + led2 { + gpios = <&gpio 2 10 1>; /* P2.10, active low */ + default-state = "off"; + }; + + led3 { + gpios = <&gpio 2 11 1>; /* P2.11, active low */ + default-state = "off"; + }; + + led4 { + gpios = <&gpio 2 12 1>; /* P2.12, active low */ + default-state = "off"; + }; + + /* LEDs on Base Board */ + + lede1 { + gpios = <&pca9532 8 0>; + default-state = "off"; + }; + lede2 { + gpios = <&pca9532 9 0>; + default-state = "off"; + }; + lede3 { + gpios = <&pca9532 10 0>; + default-state = "off"; + }; + lede4 { + gpios = <&pca9532 11 0>; + default-state = "off"; + }; + lede5 { + gpios = <&pca9532 12 0>; + default-state = "off"; + }; + lede6 { + gpios = <&pca9532 13 0>; + default-state = "off"; + }; + lede7 { + gpios = <&pca9532 14 0>; + default-state = "off"; + }; + lede8 { + gpios = <&pca9532 15 0>; + default-state = "off"; + }; + }; +}; + +/* 3-axis accelerometer X,Y,Z (or AD-IN instead of Z) */ +&adc { + status = "okay"; +}; + +&i2c1 { + clock-frequency = <100000>; + + uda1380: uda1380@18 { + compatible = "nxp,uda1380"; + reg = <0x18>; + power-gpio = <&gpio 3 10 0>; + reset-gpio = <&gpio 3 2 0>; + dac-clk = "wspll"; + }; + + eeprom@50 { + compatible = "atmel,24c256"; + reg = <0x50>; + }; + + eeprom@57 { + compatible = "atmel,24c64"; + reg = <0x57>; + }; + + pca9532: pca9532@60 { + compatible = "nxp,pca9532"; + gpio-controller; + #gpio-cells = <2>; + reg = <0x60>; + }; +}; + +&i2c2 { + clock-frequency = <100000>; +}; + +&i2cusb { + clock-frequency = <100000>; + + isp1301: usb-transceiver@2d { + compatible = "nxp,isp1301"; + reg = <0x2d>; + }; +}; + +&mac { + phy-mode = "rmii"; + use-iram; + status = "okay"; +}; + +/* Here, choose exactly one from: ohci, usbd */ +&ohci /* &usbd */ { + transceiver = <&isp1301>; + status = "okay"; +}; + +&sd { + wp-gpios = <&pca9532 5 0>; + cd-gpios = <&pca9532 4 0>; + cd-inverted; + bus-width = <4>; + status = "okay"; +}; + +/* 128MB Flash via SLC NAND controller */ +&slc { + status = "okay"; + + nxp,wdr-clks = <14>; + nxp,wwidth = <260000000>; + nxp,whold = <104000000>; + nxp,wsetup = <200000000>; + nxp,rdr-clks = <14>; + nxp,rwidth = <34666666>; + nxp,rhold = <104000000>; + nxp,rsetup = <200000000>; + nand-on-flash-bbt; + gpios = <&gpio 5 19 1>; /* GPO_P3 19, active low */ + + partitions { + compatible = "fixed-partitions"; + #address-cells = <1>; + #size-cells = <1>; + + mtd0@0 { + label = "ea3250-boot"; + reg = <0x00000000 0x00080000>; + read-only; + }; + + mtd1@80000 { + label = "ea3250-uboot"; + reg = <0x00080000 0x000c0000>; + read-only; + }; + + mtd2@140000 { + label = "ea3250-kernel"; + reg = <0x00140000 0x00400000>; + }; + + mtd3@540000 { + label = "ea3250-rootfs"; + reg = <0x00540000 0x07ac0000>; + }; + }; +}; + +&uart1 { + status = "okay"; +}; + +&uart3 { + status = "okay"; +}; + +&uart5 { + status = "okay"; +}; + +&uart6 { + status = "okay"; +}; diff --git a/arch/arm/dts/lpc32xx.dtsi b/arch/arm/dts/lpc32xx.dtsi new file mode 100644 index 0000000000..c87066d6c9 --- /dev/null +++ b/arch/arm/dts/lpc32xx.dtsi @@ -0,0 +1,508 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * NXP LPC32xx SoC + * + * Copyright (C) 2015-2019 Vladimir Zapolskiy vz@mleia.com + * Copyright 2012 Roland Stigge stigge@antcom.de + */ + +#include <dt-bindings/clock/lpc32xx-clock.h> +#include <dt-bindings/interrupt-controller/irq.h> + +/ { + #address-cells = <1>; + #size-cells = <1>; + compatible = "nxp,lpc3220"; + interrupt-parent = <&mic>; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + + cpu@0 { + compatible = "arm,arm926ej-s"; + device_type = "cpu"; + reg = <0x0>; + }; + }; + + clocks { + xtal_32k: xtal_32k { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <32768>; + clock-output-names = "xtal_32k"; + }; + + xtal: xtal { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <13000000>; + clock-output-names = "xtal"; + }; + }; + + ahb { + #address-cells = <1>; + #size-cells = <1>; + compatible = "simple-bus"; + ranges = <0x00000000 0x00000000 0x10000000>, + <0x20000000 0x20000000 0x30000000>, + <0xe0000000 0xe0000000 0x04000000>; + + iram: sram@8000000 { + compatible = "mmio-sram"; + reg = <0x08000000 0x20000>; + + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x00000000 0x08000000 0x20000>; + }; + + /* + * Enable either SLC or MLC + */ + slc: flash@20020000 { + compatible = "nxp,lpc3220-slc"; + reg = <0x20020000 0x1000>; + clocks = <&clk LPC32XX_CLK_SLC>; + status = "disabled"; + }; + + mlc: flash@200a8000 { + compatible = "nxp,lpc3220-mlc"; + reg = <0x200a8000 0x11000>; + interrupts = <11 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk LPC32XX_CLK_MLC>; + status = "disabled"; + }; + + dma: dma@31000000 { + compatible = "arm,pl080", "arm,primecell"; + reg = <0x31000000 0x1000>; + interrupts = <28 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk LPC32XX_CLK_DMA>; + clock-names = "apb_pclk"; + }; + + usb { + #address-cells = <1>; + #size-cells = <1>; + compatible = "simple-bus"; + ranges = <0x0 0x31020000 0x00001000>; + + /* + * Enable either ohci or usbd (gadget)! + */ + ohci: ohci@0 { + compatible = "nxp,ohci-nxp", "usb-ohci"; + reg = <0x0 0x300>; + interrupt-parent = <&sic1>; + interrupts = <27 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&usbclk LPC32XX_USB_CLK_HOST>; + status = "disabled"; + }; + + usbd: usbd@0 { + compatible = "nxp,lpc3220-udc"; + reg = <0x0 0x300>; + interrupt-parent = <&sic1>; + interrupts = <29 IRQ_TYPE_LEVEL_HIGH>, + <30 IRQ_TYPE_LEVEL_HIGH>, + <28 IRQ_TYPE_LEVEL_HIGH>, + <26 IRQ_TYPE_LEVEL_LOW>; + clocks = <&usbclk LPC32XX_USB_CLK_DEVICE>; + status = "disabled"; + }; + + i2cusb: i2c@300 { + compatible = "nxp,pnx-i2c"; + reg = <0x300 0x100>; + interrupt-parent = <&sic1>; + interrupts = <31 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&usbclk LPC32XX_USB_CLK_I2C>; + #address-cells = <1>; + #size-cells = <0>; + }; + + usbclk: clock-controller@f00 { + compatible = "nxp,lpc3220-usb-clk"; + reg = <0xf00 0x100>; + #clock-cells = <1>; + }; + }; + + clcd: clcd@31040000 { + compatible = "arm,pl111", "arm,primecell"; + reg = <0x31040000 0x1000>; + interrupts = <14 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk LPC32XX_CLK_LCD>, <&clk LPC32XX_CLK_LCD>; + clock-names = "clcdclk", "apb_pclk"; + status = "disabled"; + }; + + mac: ethernet@31060000 { + compatible = "nxp,lpc-eth"; + reg = <0x31060000 0x1000>; + interrupts = <29 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk LPC32XX_CLK_MAC>; + status = "disabled"; + }; + + emc: memory-controller@31080000 { + compatible = "arm,pl175", "arm,primecell"; + reg = <0x31080000 0x1000>; + clocks = <&clk LPC32XX_CLK_DDRAM>, <&clk LPC32XX_CLK_DDRAM>; + clock-names = "mpmcclk", "apb_pclk"; + #address-cells = <1>; + #size-cells = <1>; + + ranges = <0 0xe0000000 0x01000000>, + <1 0xe1000000 0x01000000>, + <2 0xe2000000 0x01000000>, + <3 0xe3000000 0x01000000>; + status = "disabled"; + }; + + apb { + #address-cells = <1>; + #size-cells = <1>; + compatible = "simple-bus"; + ranges = <0x20000000 0x20000000 0x30000000>; + + /* + * ssp0 and spi1 are shared pins; + * enable one in your board dts, as needed. + */ + ssp0: spi@20084000 { + compatible = "arm,pl022", "arm,primecell"; + reg = <0x20084000 0x1000>; + interrupts = <20 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk LPC32XX_CLK_SSP0>; + clock-names = "apb_pclk"; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + spi1: spi@20088000 { + compatible = "nxp,lpc3220-spi"; + reg = <0x20088000 0x1000>; + clocks = <&clk LPC32XX_CLK_SPI1>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + /* + * ssp1 and spi2 are shared pins; + * enable one in your board dts, as needed. + */ + ssp1: spi@2008c000 { + compatible = "arm,pl022", "arm,primecell"; + reg = <0x2008c000 0x1000>; + interrupts = <21 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk LPC32XX_CLK_SSP1>; + clock-names = "apb_pclk"; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + spi2: spi@20090000 { + compatible = "nxp,lpc3220-spi"; + reg = <0x20090000 0x1000>; + clocks = <&clk LPC32XX_CLK_SPI2>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + i2s0: i2s@20094000 { + compatible = "nxp,lpc3220-i2s"; + reg = <0x20094000 0x1000>; + status = "disabled"; + }; + + sd: sd@20098000 { + compatible = "arm,pl18x", "arm,primecell"; + reg = <0x20098000 0x1000>; + interrupts = <15 IRQ_TYPE_LEVEL_HIGH>, + <13 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk LPC32XX_CLK_SD>; + clock-names = "apb_pclk"; + status = "disabled"; + }; + + i2s1: i2s@2009c000 { + compatible = "nxp,lpc3220-i2s"; + reg = <0x2009c000 0x1000>; + status = "disabled"; + }; + + /* UART5 first since it is the default console, ttyS0 */ + uart5: serial@40090000 { + /* actually, ns16550a w/ 64 byte fifos! */ + compatible = "nxp,lpc3220-uart"; + reg = <0x40090000 0x1000>; + interrupts = <9 IRQ_TYPE_LEVEL_HIGH>; + reg-shift = <2>; + clocks = <&clk LPC32XX_CLK_UART5>; + status = "disabled"; + }; + + uart3: serial@40080000 { + compatible = "nxp,lpc3220-uart"; + reg = <0x40080000 0x1000>; + interrupts = <7 IRQ_TYPE_LEVEL_HIGH>; + reg-shift = <2>; + clocks = <&clk LPC32XX_CLK_UART3>; + status = "disabled"; + }; + + uart4: serial@40088000 { + compatible = "nxp,lpc3220-uart"; + reg = <0x40088000 0x1000>; + interrupts = <8 IRQ_TYPE_LEVEL_HIGH>; + reg-shift = <2>; + clocks = <&clk LPC32XX_CLK_UART4>; + status = "disabled"; + }; + + uart6: serial@40098000 { + compatible = "nxp,lpc3220-uart"; + reg = <0x40098000 0x1000>; + interrupts = <10 IRQ_TYPE_LEVEL_HIGH>; + reg-shift = <2>; + clocks = <&clk LPC32XX_CLK_UART6>; + status = "disabled"; + }; + + i2c1: i2c@400a0000 { + compatible = "nxp,pnx-i2c"; + reg = <0x400a0000 0x100>; + interrupt-parent = <&sic1>; + interrupts = <19 IRQ_TYPE_LEVEL_LOW>; + #address-cells = <1>; + #size-cells = <0>; + clocks = <&clk LPC32XX_CLK_I2C1>; + }; + + i2c2: i2c@400a8000 { + compatible = "nxp,pnx-i2c"; + reg = <0x400a8000 0x100>; + interrupt-parent = <&sic1>; + interrupts = <18 IRQ_TYPE_LEVEL_LOW>; + #address-cells = <1>; + #size-cells = <0>; + clocks = <&clk LPC32XX_CLK_I2C2>; + }; + + mpwm: mpwm@400e8000 { + compatible = "nxp,lpc3220-motor-pwm"; + reg = <0x400e8000 0x78>; + status = "disabled"; + #pwm-cells = <2>; + }; + }; + + fab { + #address-cells = <1>; + #size-cells = <1>; + compatible = "simple-bus"; + ranges = <0x20000000 0x20000000 0x30000000>; + + /* System Control Block */ + scb { + compatible = "simple-bus"; + ranges = <0x0 0x040004000 0x00001000>; + #address-cells = <1>; + #size-cells = <1>; + + clk: clock-controller@0 { + compatible = "nxp,lpc3220-clk"; + reg = <0x00 0x114>; + #clock-cells = <1>; + + clocks = <&xtal_32k>, <&xtal>; + clock-names = "xtal_32k", "xtal"; + }; + }; + + mic: interrupt-controller@40008000 { + compatible = "nxp,lpc3220-mic"; + reg = <0x40008000 0x4000>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + sic1: interrupt-controller@4000c000 { + compatible = "nxp,lpc3220-sic"; + reg = <0x4000c000 0x4000>; + interrupt-controller; + #interrupt-cells = <2>; + + interrupt-parent = <&mic>; + interrupts = <0 IRQ_TYPE_LEVEL_LOW>, + <30 IRQ_TYPE_LEVEL_LOW>; + }; + + sic2: interrupt-controller@40010000 { + compatible = "nxp,lpc3220-sic"; + reg = <0x40010000 0x4000>; + interrupt-controller; + #interrupt-cells = <2>; + + interrupt-parent = <&mic>; + interrupts = <1 IRQ_TYPE_LEVEL_LOW>, + <31 IRQ_TYPE_LEVEL_LOW>; + }; + + uart1: serial@40014000 { + compatible = "nxp,lpc3220-hsuart"; + reg = <0x40014000 0x1000>; + interrupts = <26 IRQ_TYPE_LEVEL_HIGH>; + status = "disabled"; + }; + + uart2: serial@40018000 { + compatible = "nxp,lpc3220-hsuart"; + reg = <0x40018000 0x1000>; + interrupts = <25 IRQ_TYPE_LEVEL_HIGH>; + status = "disabled"; + }; + + uart7: serial@4001c000 { + compatible = "nxp,lpc3220-hsuart"; + reg = <0x4001c000 0x1000>; + interrupts = <24 IRQ_TYPE_LEVEL_HIGH>; + status = "disabled"; + }; + + rtc: rtc@40024000 { + compatible = "nxp,lpc3220-rtc"; + reg = <0x40024000 0x1000>; + interrupt-parent = <&sic1>; + interrupts = <20 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk LPC32XX_CLK_RTC>; + }; + + gpio: gpio@40028000 { + compatible = "nxp,lpc3220-gpio"; + reg = <0x40028000 0x1000>; + gpio-controller; + #gpio-cells = <3>; /* bank, pin, flags */ + }; + + timer4: timer@4002c000 { + compatible = "nxp,lpc3220-timer"; + reg = <0x4002c000 0x1000>; + interrupts = <3 IRQ_TYPE_LEVEL_LOW>; + clocks = <&clk LPC32XX_CLK_TIMER4>; + clock-names = "timerclk"; + status = "disabled"; + }; + + timer5: timer@40030000 { + compatible = "nxp,lpc3220-timer"; + reg = <0x40030000 0x1000>; + interrupts = <4 IRQ_TYPE_LEVEL_LOW>; + clocks = <&clk LPC32XX_CLK_TIMER5>; + clock-names = "timerclk"; + status = "disabled"; + }; + + watchdog: watchdog@4003c000 { + compatible = "nxp,pnx4008-wdt"; + reg = <0x4003c000 0x1000>; + clocks = <&clk LPC32XX_CLK_WDOG>; + }; + + timer0: timer@40044000 { + compatible = "nxp,lpc3220-timer"; + reg = <0x40044000 0x1000>; + clocks = <&clk LPC32XX_CLK_TIMER0>; + clock-names = "timerclk"; + interrupts = <16 IRQ_TYPE_LEVEL_LOW>; + }; + + /* + * TSC vs. ADC: Since those two share the same + * hardware, you need to choose from one of the + * following two and do 'status = "okay";' for one of + * them + */ + + adc: adc@40048000 { + compatible = "nxp,lpc3220-adc"; + reg = <0x40048000 0x1000>; + interrupt-parent = <&sic1>; + interrupts = <7 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk LPC32XX_CLK_ADC>; + status = "disabled"; + }; + + tsc: tsc@40048000 { + compatible = "nxp,lpc3220-tsc"; + reg = <0x40048000 0x1000>; + interrupt-parent = <&sic1>; + interrupts = <7 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk LPC32XX_CLK_ADC>; + status = "disabled"; + }; + + timer1: timer@4004c000 { + compatible = "nxp,lpc3220-timer"; + reg = <0x4004c000 0x1000>; + interrupts = <17 IRQ_TYPE_LEVEL_LOW>; + clocks = <&clk LPC32XX_CLK_TIMER1>; + clock-names = "timerclk"; + }; + + key: key@40050000 { + compatible = "nxp,lpc3220-key"; + reg = <0x40050000 0x1000>; + clocks = <&clk LPC32XX_CLK_KEY>; + interrupt-parent = <&sic1>; + interrupts = <22 IRQ_TYPE_LEVEL_HIGH>; + status = "disabled"; + }; + + timer2: timer@40058000 { + compatible = "nxp,lpc3220-timer"; + reg = <0x40058000 0x1000>; + interrupts = <18 IRQ_TYPE_LEVEL_LOW>; + clocks = <&clk LPC32XX_CLK_TIMER2>; + clock-names = "timerclk"; + status = "disabled"; + }; + + pwm1: pwm@4005c000 { + compatible = "nxp,lpc3220-pwm"; + reg = <0x4005c000 0x4>; + clocks = <&clk LPC32XX_CLK_PWM1>; + assigned-clocks = <&clk LPC32XX_CLK_PWM1>; + assigned-clock-parents = <&clk LPC32XX_CLK_PERIPH>; + status = "disabled"; + }; + + pwm2: pwm@4005c004 { + compatible = "nxp,lpc3220-pwm"; + reg = <0x4005c004 0x4>; + clocks = <&clk LPC32XX_CLK_PWM2>; + assigned-clocks = <&clk LPC32XX_CLK_PWM2>; + assigned-clock-parents = <&clk LPC32XX_CLK_PERIPH>; + status = "disabled"; + }; + + timer3: timer@40060000 { + compatible = "nxp,lpc3220-timer"; + reg = <0x40060000 0x1000>; + interrupts = <19 IRQ_TYPE_LEVEL_LOW>; + clocks = <&clk LPC32XX_CLK_TIMER3>; + clock-names = "timerclk"; + status = "disabled"; + }; + }; + }; +}; diff --git a/include/dt-bindings/clock/lpc32xx-clock.h b/include/dt-bindings/clock/lpc32xx-clock.h new file mode 100644 index 0000000000..e624d3a527 --- /dev/null +++ b/include/dt-bindings/clock/lpc32xx-clock.h @@ -0,0 +1,58 @@ +/* + * Copyright (c) 2015 Vladimir Zapolskiy vz@mleia.com + * + * This code is released using a dual license strategy: BSD/GPL + * You can choose the licence that better fits your requirements. + * + * Released under the terms of 3-clause BSD License + * Released under the terms of GNU General Public License Version 2.0 + * + */ + +#ifndef __DT_BINDINGS_LPC32XX_CLOCK_H +#define __DT_BINDINGS_LPC32XX_CLOCK_H + +/* LPC32XX System Control Block clocks */ +#define LPC32XX_CLK_RTC 1 +#define LPC32XX_CLK_DMA 2 +#define LPC32XX_CLK_MLC 3 +#define LPC32XX_CLK_SLC 4 +#define LPC32XX_CLK_LCD 5 +#define LPC32XX_CLK_MAC 6 +#define LPC32XX_CLK_SD 7 +#define LPC32XX_CLK_DDRAM 8 +#define LPC32XX_CLK_SSP0 9 +#define LPC32XX_CLK_SSP1 10 +#define LPC32XX_CLK_UART3 11 +#define LPC32XX_CLK_UART4 12 +#define LPC32XX_CLK_UART5 13 +#define LPC32XX_CLK_UART6 14 +#define LPC32XX_CLK_IRDA 15 +#define LPC32XX_CLK_I2C1 16 +#define LPC32XX_CLK_I2C2 17 +#define LPC32XX_CLK_TIMER0 18 +#define LPC32XX_CLK_TIMER1 19 +#define LPC32XX_CLK_TIMER2 20 +#define LPC32XX_CLK_TIMER3 21 +#define LPC32XX_CLK_TIMER4 22 +#define LPC32XX_CLK_TIMER5 23 +#define LPC32XX_CLK_WDOG 24 +#define LPC32XX_CLK_I2S0 25 +#define LPC32XX_CLK_I2S1 26 +#define LPC32XX_CLK_SPI1 27 +#define LPC32XX_CLK_SPI2 28 +#define LPC32XX_CLK_MCPWM 29 +#define LPC32XX_CLK_HSTIMER 30 +#define LPC32XX_CLK_KEY 31 +#define LPC32XX_CLK_PWM1 32 +#define LPC32XX_CLK_PWM2 33 +#define LPC32XX_CLK_ADC 34 +#define LPC32XX_CLK_HCLK_PLL 35 +#define LPC32XX_CLK_PERIPH 36 + +/* LPC32XX USB clocks */ +#define LPC32XX_USB_CLK_I2C 1 +#define LPC32XX_USB_CLK_DEVICE 2 +#define LPC32XX_USB_CLK_HOST 3 + +#endif /* __DT_BINDINGS_LPC32XX_CLOCK_H */
Add basic support for running U-Boot on the Embedded Artists LPC3250 Developer's Kit v2 board by launching U-Boot from the board's s1l loader (which comes pre-installed on the board).
arch/arm/dts/Makefile | 2 + arch/arm/dts/lpc3250-ea3250-u-boot.dtsi | 15 ++ arch/arm/mach-lpc32xx/Kconfig | 4 + board/ea/ea-lpc3250devkitv2/Kconfig | 15 ++ board/ea/ea-lpc3250devkitv2/MAINTAINERS | 9 ++ board/ea/ea-lpc3250devkitv2/Makefile | 4 + board/ea/ea-lpc3250devkitv2/README.rst | 132 ++++++++++++++++++ .../ea-lpc3250devkitv2/ea-lpc3250devkitv2.c | 37 +++++ configs/ea-lpc3250devkitv2_defconfig | 23 +++ include/configs/ea-lpc3250devkitv2.h | 37 +++++ 10 files changed, 278 insertions(+) create mode 100644 arch/arm/dts/lpc3250-ea3250-u-boot.dtsi create mode 100644 board/ea/ea-lpc3250devkitv2/Kconfig create mode 100644 board/ea/ea-lpc3250devkitv2/MAINTAINERS create mode 100644 board/ea/ea-lpc3250devkitv2/Makefile create mode 100644 board/ea/ea-lpc3250devkitv2/README.rst create mode 100644 board/ea/ea-lpc3250devkitv2/ea-lpc3250devkitv2.c create mode 100644 configs/ea-lpc3250devkitv2_defconfig create mode 100644 include/configs/ea-lpc3250devkitv2.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 096068261d..134108f14e 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -1103,6 +1103,8 @@ dtb-$(CONFIG_TARGET_PRESIDIO_ASIC) += ca-presidio-engboard.dtb
dtb-$(CONFIG_TARGET_IMX8MM_CL_IOT_GATE) += imx8mm-cl-iot-gate.dtb
+dtb-$(CONFIG_TARGET_EA_LPC3250DEVKITV2) += lpc3250-ea3250.dtb + targets += $(dtb-y)
# Add any required device tree compiler flags here diff --git a/arch/arm/dts/lpc3250-ea3250-u-boot.dtsi b/arch/arm/dts/lpc3250-ea3250-u-boot.dtsi new file mode 100644 index 0000000000..0c82e512c6 --- /dev/null +++ b/arch/arm/dts/lpc3250-ea3250-u-boot.dtsi @@ -0,0 +1,15 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2021 Trevor Woerner twoerner@gmail.com + */ + +/{ + model = "Embedded Artists LPC3250 DevKit v2 board based on the NXP LPC3250 SoC"; + chosen { + stdout-path = &uart5; + }; +}; + +&uart5 { + compatible = "nxp,lpc3220-uart", "ns16550a"; +}; diff --git a/arch/arm/mach-lpc32xx/Kconfig b/arch/arm/mach-lpc32xx/Kconfig index 986ad738ac..185bda41c2 100644 --- a/arch/arm/mach-lpc32xx/Kconfig +++ b/arch/arm/mach-lpc32xx/Kconfig @@ -12,9 +12,13 @@ config TARGET_DEVKIT3250 config TARGET_WORK_92105 bool "Work Microwave Work_92105"
+config TARGET_EA_LPC3250DEVKITV2 + bool "Embedded Artists LPC3250 Developer's Kit v2" + endchoice
source "board/timll/devkit3250/Kconfig" source "board/work-microwave/work_92105/Kconfig" +source "board/ea/ea-lpc3250devkitv2/Kconfig"
endif diff --git a/board/ea/ea-lpc3250devkitv2/Kconfig b/board/ea/ea-lpc3250devkitv2/Kconfig new file mode 100644 index 0000000000..368ce027e6 --- /dev/null +++ b/board/ea/ea-lpc3250devkitv2/Kconfig @@ -0,0 +1,15 @@ +if TARGET_EA_LPC3250DEVKITV2 + +config SYS_BOARD + default "ea-lpc3250devkitv2" + +config SYS_VENDOR + default "ea" + +config SYS_SOC + default "lpc32xx" + +config SYS_CONFIG_NAME + default "ea-lpc3250devkitv2" + +endif diff --git a/board/ea/ea-lpc3250devkitv2/MAINTAINERS b/board/ea/ea-lpc3250devkitv2/MAINTAINERS new file mode 100644 index 0000000000..b4b9362f5b --- /dev/null +++ b/board/ea/ea-lpc3250devkitv2/MAINTAINERS @@ -0,0 +1,9 @@ +EMBEDDED ARTISTS LPC3250 DEVKIT v2 +M: Trevor Woerner twoerner@gmail.com +S: Maintained +F: board/ea/ea-lpc3250devkitv2 +F: include/configs/ea-lpc3250devkitv2.h +F: configs/ea-lpc3250devkitv2_defconfig +F: arch/arm/dts/lpc32xx.dtsi +F: arch/arm/dts/lpc3250-ea3250.dts +F: arch/arm/dts/lpc3250-ea3250-u-boot.dtsi diff --git a/board/ea/ea-lpc3250devkitv2/Makefile b/board/ea/ea-lpc3250devkitv2/Makefile new file mode 100644 index 0000000000..a4a40b6d4f --- /dev/null +++ b/board/ea/ea-lpc3250devkitv2/Makefile @@ -0,0 +1,4 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2021 Trevor Woerner twoerner@gmail.com + +obj-y += ea-lpc3250devkitv2.o diff --git a/board/ea/ea-lpc3250devkitv2/README.rst b/board/ea/ea-lpc3250devkitv2/README.rst new file mode 100644 index 0000000000..56b5d0dbb1 --- /dev/null +++ b/board/ea/ea-lpc3250devkitv2/README.rst @@ -0,0 +1,132 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +ToC: +- Introduction +- Booting +- Debugging + + +Introduction +============ +The Embedded Artists LPC3250 Developer's Kit v2 features the LPC3250 SoC +which is based on the ARM926EJ-S CPU. The kit features a base board and +a removable OEM board which features the SoC. Details, schematics, and +documentation are available from the Embedded Artists product website: + + https://www.embeddedartists.com/products/lpc3250-developers-kit-v2/ + +The base board includes:: +- 200 pos, 0.6mm pitch SODIMM connector for OEM Board +- LCD expansion connector with control signals for touch screen interface +- Expansion connector with all OEM Board signals +- Ethernet connector (RJ45) +- CAN interface & connector (provision for second CAN interface, but not mounted) +- MMC/SD interface & connector +- USB1: OTG or Host interface & connector +- USB2: Device or Host interface & connector +- Provision for NXP JN5148 RF module (former Jennic) interface (RF module not included) +- Full modem RS232 (cannot be fully used on 32-bit databus OEM boards) +- RS422/485 interface & connector +- Provision for IrDA transceiver interface (transceiver not mounted) +- I2S audio codec (mic in, line in, line out, headphone out) +- SWD/JTAG connector +- Trace connector and pads for ETM connector +- Serial Expansion Connector, 14-pos connector with UART/I2C/SPI/GPIO pins +- Power supply, either via USB or external 5V DC +- Optional coin cell battery for RTC and LED on ALARM output (coin cell not included) +- OEM Board current measuring +- Parallel NOR flash on external memory bus +- 16-bit register and LEDs on external memory bus +- 5-key joystick +- LM75 temperature sensor (I2C connected) +- 5 push-button keys (four via I2C and one on ISP-ENABLE) +- 9 LEDs (8 via I2C and one on ISP-ENABLE) +- Trimming potentiometer to analog input +- USB-to-serial bridge on UART #0 (FT232R) and ISP functionality +- Reset push-button and LED +- Speaker output on analog output from OEM Board, or from I2S audio codec +- 160x150 mm in size + +The OEM board:: +- ARMv5 ARM926EJ-S @ 266 MHz with hard-float VFPv2 +- 256 KByte IRAM, 64 MByte SDRAM +- 128 MByte NAND flash +- 4 MByte NOR Flash +- Graphics Output: Parallel RGB +- Hardware 2D/3D Graphic: No +- Hardware Video: SW only +- Graphics input: No +- Audio: I2S +- Ethernet: 10/100 Mbps +- USB: 1x FS USB 2.0 OTG +- Wi-Fi: No +- FlexIO: No +- Serial: 2x I2C, 2x SPI, 7x UART +- ADC/PWM: 3 ch (10-bit) / 2 ch +- SD: MCI +- PCIe: No +- Serial ATA: No +- Size: 68 x 48 mm +- Connector: 200 pos SODIMM + + +Booting +======= +The processor will start its code execution from an internal ROM, +containing the boot code. This boot loader can load code from one of four +external sources to internal RAM (IRAM) at address 0x0:: +- UART5 +- SSP0 (in SPI mode) +- EMC Static CS0 memory +- NAND FLASH + +The ROM boot loader loads code as a single contiguous block at a maximum +size of 56 kByte. Programs larger than this size must be loaded in more +steps, for example, by a secondary boot loader. + +Kickstart Loader +---------------- +By default the Embedded Artists LPC3250 OEM Board is programmed with the +kickstart loader in block 0 of the NAND flash. The responsibility of this +loader is to load an application stored in block 1 and onwards of the NAND +flash. The kickstart loader will load the application into internal RAM +(IRAM) at address 0x0. + +Stage 1 Loader (s1l) +-------------------- +By default the Embedded Artists LPC3250 OEM Board is programmed with the +stage 1 loader (s1l) in block 1 of the NAND flash. This application will be +loaded by the kickstart loader when the LPC3250 OEM Board powers up. The +S1L loader will initialize the board, such as clocks and external memory +and then start a console where you can give input commands to the loader. +S1L offers the following booting options:: +- MMC/SD card +- UART5 +- NAND Flash + +U-Boot with kickstart+s1l +------------------------- +Out of the box, the easiest way to get U-Boot running on the EA LPC3250 +DevKit v2 board is to build the ea-lpc3250devkitv2_defconfig, copy the +resulting u-boot.bin to a vfat-formatted MMC/SD card, insert the MMC/SD card +into the MMC/SD card slot on the board, reset the board (SW1), and:: + + Embedded Artist 3250 Board (S1L 2.0) + Build date: Oct 31 2016 13:00:37 + + EA3250>load blk u-boot.bin raw 0x83000000 + File loaded successfully + + EA3250>exec 0x83000000 + + +Debugging +========= +JTAG debugging of the Embedded Artists LPC3250 Developer's Kit v2 board is +easy thanks to the included/populated 20-pin JTAG port on the main board (J8). +openocd 0.11 has been used with this board along with the ARM-USB-OCD-H JTAG +dongle from Olimex successfully as follows: + + # openocd \ + -f interface/ftdi/olimex-arm-usb-ocd-h.cfg \ + -f board/phytec_lpc3250.cfg diff --git a/board/ea/ea-lpc3250devkitv2/ea-lpc3250devkitv2.c b/board/ea/ea-lpc3250devkitv2/ea-lpc3250devkitv2.c new file mode 100644 index 0000000000..7a19400041 --- /dev/null +++ b/board/ea/ea-lpc3250devkitv2/ea-lpc3250devkitv2.c @@ -0,0 +1,37 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Board init file for Embedded Artists LPC3250 DevKit v2 + * Copyright (C) 2021 Trevor Woerner twoerner@gmail.com + */ + +#include <init.h> +#include <common.h> +#include <asm/io.h> +#include <asm/global_data.h> + +#include <asm/arch/clk.h> +#include <asm/arch/wdt.h> +#include <asm/arch/sys_proto.h> + +DECLARE_GLOBAL_DATA_PTR; + +int +board_early_init_f(void) +{ + lpc32xx_uart_init(CONFIG_CONS_INDEX); + return 0; +} + +int +board_init(void) +{ + gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x2000; + return 0; +} + +int +dram_init(void) +{ + gd->ram_size = get_ram_size((void *)CONFIG_SYS_SDRAM_BASE, SZ_64M); + return 0; +} diff --git a/configs/ea-lpc3250devkitv2_defconfig b/configs/ea-lpc3250devkitv2_defconfig new file mode 100644 index 0000000000..dc90e16475 --- /dev/null +++ b/configs/ea-lpc3250devkitv2_defconfig @@ -0,0 +1,23 @@ +CONFIG_ARM=y +CONFIG_SYS_ICACHE_OFF=y +CONFIG_SYS_DCACHE_OFF=y +CONFIG_ARCH_CPU_INIT=y +CONFIG_ARCH_LPC32XX=y +CONFIG_SYS_TEXT_BASE=0x83000000 +CONFIG_NR_DRAM_BANKS=1 +CONFIG_TARGET_EA_LPC3250DEVKITV2=y +CONFIG_DEFAULT_DEVICE_TREE="lpc3250-ea3250" +CONFIG_DISTRO_DEFAULTS=y +# CONFIG_ARCH_FIXUP_FDT_MEMORY is not set +# CONFIG_AUTOBOOT is not set +# CONFIG_USE_BOOTCOMMAND is not set +CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SYS_PROMPT="EA-LPC3250v2=> " +CONFIG_CMD_GPIO=y +CONFIG_OF_CONTROL=y +# CONFIG_NET is not set +CONFIG_LPC32XX_GPIO=y +CONFIG_SPECIFY_CONSOLE_INDEX=y +CONFIG_CONS_INDEX=5 +CONFIG_SYS_NS16550=y +CONFIG_PANIC_HANG=y diff --git a/include/configs/ea-lpc3250devkitv2.h b/include/configs/ea-lpc3250devkitv2.h new file mode 100644 index 0000000000..c1a37c8a79 --- /dev/null +++ b/include/configs/ea-lpc3250devkitv2.h @@ -0,0 +1,37 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Embedded Artists LPC3250 DevKit v2 + * Copyright (C) 2021 Trevor Woerner twoerner@gmail.com + */ + +#ifndef __CONFIG_EA_LPC3250DEVKITV2_H__ +#define __CONFIG_EA_LPC3250DEVKITV2_H__ + +#include <linux/sizes.h> +#include <asm/arch/cpu.h> + +/* + * SoC and board defines + */ +#define CONFIG_MACH_TYPE MACH_TYPE_LPC3XXX +#define CONFIG_SKIP_LOWLEVEL_INIT +#define CONFIG_BOARD_SIZE_LIMIT 0x000fffff /* maximum allowable size for full U-Boot binary */ + +/* + * RAM + */ +#define CONFIG_SYS_MALLOC_LEN SZ_4M +#define CONFIG_SYS_SDRAM_BASE EMC_DYCS0_BASE + +/* + * cmd + */ +#define CONFIG_SYS_LOAD_ADDR 0x80100000 +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_SDRAM_BASE + SZ_4K - GENERATED_GBL_DATA_SIZE) + +/* + * SoC-specific config + */ +#include <asm/arch/config.h> + +#endif
The LPC32XX_I2C_STAT_DRMI is not used anywhere so remove it.
Changes in v2: - added
drivers/i2c/lpc32xx_i2c.c | 1 - 1 file changed, 1 deletion(-)
diff --git a/drivers/i2c/lpc32xx_i2c.c b/drivers/i2c/lpc32xx_i2c.c index f89f7955e4..0ae116617c 100644 --- a/drivers/i2c/lpc32xx_i2c.c +++ b/drivers/i2c/lpc32xx_i2c.c @@ -38,7 +38,6 @@ /* Status register values */ #define LPC32XX_I2C_STAT_TFF 0x00000400 #define LPC32XX_I2C_STAT_RFE 0x00000200 -#define LPC32XX_I2C_STAT_DRMI 0x00000008 #define LPC32XX_I2C_STAT_NAI 0x00000004 #define LPC32XX_I2C_STAT_TDI 0x00000001
The lpc32xx driver was not obtaining the per-device base address correctly from the device tree. Fix the FIXME in order to get the correct base address.
drivers/i2c/lpc32xx_i2c.c | 6 +----- 1 file changed, 1 insertion(+), 5 deletions(-)
diff --git a/drivers/i2c/lpc32xx_i2c.c b/drivers/i2c/lpc32xx_i2c.c index 0ae116617c..6abff263bd 100644 --- a/drivers/i2c/lpc32xx_i2c.c +++ b/drivers/i2c/lpc32xx_i2c.c @@ -282,11 +282,7 @@ static int lpc32xx_i2c_probe(struct udevice *bus) { struct lpc32xx_i2c_dev *dev = dev_get_plat(bus);
- /* - * FIXME: This is not permitted - * dev_seq(bus) = dev->index; - */ - + dev->base = dev_read_addr_ptr(bus); __i2c_init(dev->base, dev->speed, 0, dev->index); return 0; }
Add the of_match/compatible string to the lpc32xx i2c driver so it works correctly with device-tree.
drivers/i2c/lpc32xx_i2c.c | 8 +++++++- 1 file changed, 7 insertions(+), 1 deletion(-)
diff --git a/drivers/i2c/lpc32xx_i2c.c b/drivers/i2c/lpc32xx_i2c.c index 6abff263bd..774129ad8e 100644 --- a/drivers/i2c/lpc32xx_i2c.c +++ b/drivers/i2c/lpc32xx_i2c.c @@ -348,9 +348,15 @@ static const struct dm_i2c_ops lpc32xx_i2c_ops = { .set_bus_speed = lpc32xx_i2c_set_bus_speed, };
+static const struct udevice_id lpc32xx_i2c_ids[] = { + { .compatible = "nxp,pnx-i2c" }, + { } +}; + U_BOOT_DRIVER(i2c_lpc32xx) = { - .id = UCLASS_I2C, .name = "i2c_lpc32xx", + .id = UCLASS_I2C, + .of_match = lpc32xx_i2c_ids, .probe = lpc32xx_i2c_probe, .ops = &lpc32xx_i2c_ops, };
Convert the CONFIG_SYS_I2C_LPC32XX configuration symbol from an include directive to a Kconfig value.
configs/devkit3250_defconfig | 1 + configs/work_92105_defconfig | 1 + drivers/i2c/Kconfig | 6 ++++++ include/configs/devkit3250.h | 1 - include/configs/work_92105.h | 1 - scripts/config_whitelist.txt | 1 - 6 files changed, 8 insertions(+), 3 deletions(-)
diff --git a/configs/devkit3250_defconfig b/configs/devkit3250_defconfig index 9ae70f7d46..c0354bce1a 100644 --- a/configs/devkit3250_defconfig +++ b/configs/devkit3250_defconfig @@ -38,6 +38,7 @@ CONFIG_CMD_JFFS2=y CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_VERSION_VARIABLE=y +CONFIG_SYS_I2C_LPC32XX=y # CONFIG_MMC is not set CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/work_92105_defconfig b/configs/work_92105_defconfig index e9605adedd..507f24fc37 100644 --- a/configs/work_92105_defconfig +++ b/configs/work_92105_defconfig @@ -42,6 +42,7 @@ CONFIG_DOS_PARTITION=y CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_VERSION_VARIABLE=y +CONFIG_SYS_I2C_LPC32XX=y # CONFIG_MMC is not set CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y diff --git a/drivers/i2c/Kconfig b/drivers/i2c/Kconfig index 57a4efb88e..674faddfa4 100644 --- a/drivers/i2c/Kconfig +++ b/drivers/i2c/Kconfig @@ -169,6 +169,12 @@ config SYS_I2C_IMX_LPI2C help Add support for the NXP i.MX LPI2C driver.
+config SYS_I2C_LPC32XX + bool "LPC32XX I2C driver" + depends on ARCH_LPC32XX + help + Enable support for the LPC32xx I2C driver. + config SYS_I2C_MESON bool "Amlogic Meson I2C driver" depends on DM_I2C && ARCH_MESON diff --git a/include/configs/devkit3250.h b/include/configs/devkit3250.h index 921a38c01e..465d9ce8e9 100644 --- a/include/configs/devkit3250.h +++ b/include/configs/devkit3250.h @@ -41,7 +41,6 @@ * I2C */ #define CONFIG_SYS_I2C -#define CONFIG_SYS_I2C_LPC32XX #define CONFIG_SYS_I2C_SPEED 100000
/* diff --git a/include/configs/work_92105.h b/include/configs/work_92105.h index 076a1b065e..d498c8f3bc 100644 --- a/include/configs/work_92105.h +++ b/include/configs/work_92105.h @@ -47,7 +47,6 @@ * I2C driver */
-#define CONFIG_SYS_I2C_LPC32XX #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_SPEED 350000
diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 13281bf6b1..60ec9834f9 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -2543,7 +2543,6 @@ CONFIG_SYS_I2C_INIT_BOARD CONFIG_SYS_I2C_LDI_ADDR CONFIG_SYS_I2C_LM75_ADDR CONFIG_SYS_I2C_LM90_ADDR -CONFIG_SYS_I2C_LPC32XX CONFIG_SYS_I2C_LPC32XX_SLAVE CONFIG_SYS_I2C_LPC32XX_SPEED CONFIG_SYS_I2C_MAC1_BUS
Changes in v2:
- added
Could use more help on the Kconfig though
Enable a DMed i2c driver for the ea-lpc3250devkitv2 board. Include some sample commands/output for testing.
board/ea/ea-lpc3250devkitv2/README.rst | 54 +++++++++++++++++++ .../ea-lpc3250devkitv2/ea-lpc3250devkitv2.c | 4 ++ configs/ea-lpc3250devkitv2_defconfig | 3 ++ 3 files changed, 61 insertions(+)
diff --git a/board/ea/ea-lpc3250devkitv2/README.rst b/board/ea/ea-lpc3250devkitv2/README.rst index 56b5d0dbb1..1b78000331 100644 --- a/board/ea/ea-lpc3250devkitv2/README.rst +++ b/board/ea/ea-lpc3250devkitv2/README.rst @@ -4,6 +4,7 @@ ToC: - Introduction - Booting - Debugging +- i2c
Introduction @@ -130,3 +131,56 @@ dongle from Olimex successfully as follows: # openocd \ -f interface/ftdi/olimex-arm-usb-ocd-h.cfg \ -f board/phytec_lpc3250.cfg + + +i2c +=== +Some of the LEDs on the board are connected via an I/O Expander (PCA9532) that +is attached to the i2c1 bus. Here is a sample session of toggling some of +these LEDs via i2c in U-Boot: + +show the existing i2c busses: + EA-LPC3250v2=> i2c bus + Bus 0: i2c@300 + Bus 1: i2c@400a0000 + Bus 2: i2c@400a8000 + +set i2c1 as the current bus: + EA-LPC3250v2=> i2c dev 1 + Setting bus to 1 + +see what potential devices are found with rudimentary probing on i2c1: + EA-LPC3250v2=> i2c probe + Valid chip addresses: 1A 1D 48 50 57 60 66 6E + +According to the schematics the i2c slave address of the PCA9532 is 0x60. + +dump all of the 10 registers from the I/O Expander; NOTE that the 0x10 in the +command specifies the self-incrementing mode of the PCA9532; also NOTE that +the values repeat themseves to fill out a full 16 bytes: + EA-LPC3250v2=> i2c md 0x60 0x10 10 + 0010: 00 ff 00 80 00 80 00 00 00 00 4f ff 00 80 00 80 ..........O..... + +turn on LEDs 23, 25, 27, and 29 (green): + EA-LPC3250v2=> i2c mw 0x60 9 0x55 + +turn on LEDs 22, 24, 26, and 28 (red): + EA-LPC3250v2=> i2c mw 0x60 8 0x55 + +dim the green LEDs (23, 25, 27, 29): + EA-LPC3250v2=> i2c mw 0x60 3 0x20 + EA-LPC3250v2=> i2c mw 0x60 9 0xaa + +turn off all LEDs (23-29): + EA-LPC3250v2=> i2c mw 0x60 8 0 + EA-LPC3250v2=> i2c mw 0x60 9 0 + +read value of switches (input): + EA-LPC3250v2=> i2c md 0x60 0 1 + 0000: 4f O +[none are pressed] + +press and hold SW2 while running the following: + EA-LPC3250v2=> i2c md 0x60 0 1 + 0000: 4e N +[SW2 is pressed] diff --git a/board/ea/ea-lpc3250devkitv2/ea-lpc3250devkitv2.c b/board/ea/ea-lpc3250devkitv2/ea-lpc3250devkitv2.c index 7a19400041..72cf46c749 100644 --- a/board/ea/ea-lpc3250devkitv2/ea-lpc3250devkitv2.c +++ b/board/ea/ea-lpc3250devkitv2/ea-lpc3250devkitv2.c @@ -19,6 +19,10 @@ int board_early_init_f(void) { lpc32xx_uart_init(CONFIG_CONS_INDEX); + if (IS_ENABLED(CONFIG_SYS_I2C_LPC32XX)) { + lpc32xx_i2c_init(1); + lpc32xx_i2c_init(2); + } return 0; }
diff --git a/configs/ea-lpc3250devkitv2_defconfig b/configs/ea-lpc3250devkitv2_defconfig index dc90e16475..e8d60b573e 100644 --- a/configs/ea-lpc3250devkitv2_defconfig +++ b/configs/ea-lpc3250devkitv2_defconfig @@ -14,9 +14,12 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SYS_PROMPT="EA-LPC3250v2=> " CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y CONFIG_OF_CONTROL=y # CONFIG_NET is not set CONFIG_LPC32XX_GPIO=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_LPC32XX=y CONFIG_SPECIFY_CONSOLE_INDEX=y CONFIG_CONS_INDEX=5 CONFIG_SYS_NS16550=y
Signed-off-by: Trevor Woerner twoerner@gmail.com Reviewed-by: Simon Glass sjg@chromium.org
For the series, applied to u-boot/master, thanks!
Trevor Woerner
