[U-Boot] [PATCH-V2 2/4] omap3: Consolidate SDRC related operations
Consolidated SDRC related functions into one file - sdrc.c
And also replaced sdrc_init with generic memory init function (mem_init), this generalization of omap memory setup is necessary to support the new emif4 interface introduced in AM3517.
Signed-off-by: Vaibhav Hiremath hvaibhav@ti.com Signed-off-by: Sanjeev Premi premi@ti.com --- arch/arm/cpu/arm_cortexa8/omap3/Makefile | 3 + arch/arm/cpu/arm_cortexa8/omap3/board.c | 35 +----- arch/arm/cpu/arm_cortexa8/omap3/mem.c | 90 ------------ arch/arm/cpu/arm_cortexa8/omap3/sdrc.c | 202 +++++++++++++++++++++++++++ arch/arm/cpu/arm_cortexa8/omap3/sys_info.c | 41 ------ arch/arm/include/asm/arch-omap3/cpu.h | 3 + arch/arm/include/asm/arch-omap3/mem.h | 13 ++ arch/arm/include/asm/arch-omap3/sys_proto.h | 4 +- include/configs/devkit8000.h | 2 + include/configs/omap3_beagle.h | 2 + include/configs/omap3_evm.h | 2 + include/configs/omap3_overo.h | 2 + include/configs/omap3_pandora.h | 2 + include/configs/omap3_sdp3430.h | 2 + include/configs/omap3_zoom1.h | 2 + include/configs/omap3_zoom2.h | 2 + 16 files changed, 240 insertions(+), 167 deletions(-) create mode 100644 arch/arm/cpu/arm_cortexa8/omap3/sdrc.c
diff --git a/arch/arm/cpu/arm_cortexa8/omap3/Makefile b/arch/arm/cpu/arm_cortexa8/omap3/Makefile index 136b163..8cc7802 100644 --- a/arch/arm/cpu/arm_cortexa8/omap3/Makefile +++ b/arch/arm/cpu/arm_cortexa8/omap3/Makefile @@ -33,6 +33,9 @@ COBJS += board.o COBJS += clock.o COBJS += gpio.o COBJS += mem.o +ifdef CONFIG_SDRC +COBJS += sdrc.o +endif COBJS += syslib.o COBJS += sys_info.o COBJS += timer.o diff --git a/arch/arm/cpu/arm_cortexa8/omap3/board.c b/arch/arm/cpu/arm_cortexa8/omap3/board.c index 69a08fd..d2500ca 100644 --- a/arch/arm/cpu/arm_cortexa8/omap3/board.c +++ b/arch/arm/cpu/arm_cortexa8/omap3/board.c @@ -40,8 +40,6 @@
extern omap3_sysinfo sysinfo;
-extern u32 is_mem_sdr(void); - /****************************************************************************** * Routine: delay * Description: spinning delay to use before udelay works @@ -233,7 +231,7 @@ void s_init(void) per_clocks_enable();
if (!in_sdram) - sdrc_init(); + mem_init(); }
/****************************************************************************** @@ -274,37 +272,6 @@ void watchdog_init(void) }
/****************************************************************************** - * Routine: dram_init - * Description: sets uboots idea of sdram size - *****************************************************************************/ -int dram_init(void) -{ - DECLARE_GLOBAL_DATA_PTR; - unsigned int size0 = 0, size1 = 0; - - size0 = get_sdr_cs_size(CS0); - - /* - * If a second bank of DDR is attached to CS1 this is - * where it can be started. Early init code will init - * memory on CS0. - */ - if ((sysinfo.mtype == DDR_COMBO) || (sysinfo.mtype == DDR_STACKED)) { - do_sdrc_init(CS1, NOT_EARLY); - make_cs1_contiguous(); - - size1 = get_sdr_cs_size(CS1); - } - - gd->bd->bi_dram[0].start = PHYS_SDRAM_1; - gd->bd->bi_dram[0].size = size0; - gd->bd->bi_dram[1].start = PHYS_SDRAM_1 + get_sdr_cs_offset(CS1); - gd->bd->bi_dram[1].size = size1; - - return 0; -} - -/****************************************************************************** * Dummy function to handle errors for EABI incompatibility *****************************************************************************/ void abort(void) diff --git a/arch/arm/cpu/arm_cortexa8/omap3/mem.c b/arch/arm/cpu/arm_cortexa8/omap3/mem.c index dfb7e4c..bd914b0 100644 --- a/arch/arm/cpu/arm_cortexa8/omap3/mem.c +++ b/arch/arm/cpu/arm_cortexa8/omap3/mem.c @@ -79,26 +79,6 @@ static const u32 gpmc_onenand[GPMC_MAX_REG] = {
#endif
-static struct sdrc *sdrc_base = (struct sdrc *)OMAP34XX_SDRC_BASE; - -/************************************************************************** - * make_cs1_contiguous() - for es2 and above remap cs1 behind cs0 to allow - * command line mem=xyz use all memory with out discontinuous support - * compiled in. Could do it at the ATAG, but there really is two banks... - * Called as part of 2nd phase DDR init. - **************************************************************************/ -void make_cs1_contiguous(void) -{ - u32 size, a_add_low, a_add_high; - - size = get_sdr_cs_size(CS0); - size >>= 25; /* divide by 32 MiB to find size to offset CS1 */ - a_add_high = (size & 3) << 8; /* set up low field */ - a_add_low = (size & 0x3C) >> 2; /* set up high field */ - writel((a_add_high | a_add_low), &sdrc_base->cs_cfg); - -} - /******************************************************** * mem_ok() - test used to see if timings are correct * for a part. Helps in guessing which part @@ -123,76 +103,6 @@ u32 mem_ok(u32 cs) return 1; }
-/******************************************************** - * sdrc_init() - init the sdrc chip selects CS0 and CS1 - * - early init routines, called from flash or - * SRAM. - *******************************************************/ -void sdrc_init(void) -{ - /* only init up first bank here */ - do_sdrc_init(CS0, EARLY_INIT); -} - -/************************************************************************* - * do_sdrc_init(): initialize the SDRAM for use. - * -code sets up SDRAM basic SDRC timings for CS0 - * -optimal settings can be placed here, or redone after i2c - * inspection of board info - * - * - code called once in C-Stack only context for CS0 and a possible 2nd - * time depending on memory configuration from stack+global context - **************************************************************************/ - -void do_sdrc_init(u32 cs, u32 early) -{ - struct sdrc_actim *sdrc_actim_base; - - if(cs) - sdrc_actim_base = (struct sdrc_actim *)SDRC_ACTIM_CTRL1_BASE; - else - sdrc_actim_base = (struct sdrc_actim *)SDRC_ACTIM_CTRL0_BASE; - - if (early) { - /* reset sdrc controller */ - writel(SOFTRESET, &sdrc_base->sysconfig); - wait_on_value(RESETDONE, RESETDONE, &sdrc_base->status, - 12000000); - writel(0, &sdrc_base->sysconfig); - - /* setup sdrc to ball mux */ - writel(SDRC_SHARING, &sdrc_base->sharing); - - /* Disable Power Down of CKE cuz of 1 CKE on combo part */ - writel(WAKEUPPROC | PWDNEN | SRFRONRESET | PAGEPOLICY_HIGH, - &sdrc_base->power); - - writel(ENADLL | DLLPHASE_90, &sdrc_base->dlla_ctrl); - sdelay(0x20000); - } - - writel(RASWIDTH_13BITS | CASWIDTH_10BITS | ADDRMUXLEGACY | - RAMSIZE_128 | BANKALLOCATION | B32NOT16 | B32NOT16 | - DEEPPD | DDR_SDRAM, &sdrc_base->cs[cs].mcfg); - writel(ARCV | ARE_ARCV_1, &sdrc_base->cs[cs].rfr_ctrl); - writel(V_ACTIMA_165, &sdrc_actim_base->ctrla); - writel(V_ACTIMB_165, &sdrc_actim_base->ctrlb); - - writel(CMD_NOP, &sdrc_base ->cs[cs].manual); - writel(CMD_PRECHARGE, &sdrc_base->cs[cs].manual); - writel(CMD_AUTOREFRESH, &sdrc_base->cs[cs].manual); - writel(CMD_AUTOREFRESH, &sdrc_base->cs[cs].manual); - - /* - * CAS latency 3, Write Burst = Read Burst, Serial Mode, - * Burst length = 4 - */ - writel(CASL3 | BURSTLENGTH4, &sdrc_base->cs[cs].mr); - - if (!mem_ok(cs)) - writel(0, &sdrc_base->cs[cs].mcfg); -} - void enable_gpmc_cs_config(const u32 *gpmc_config, struct gpmc_cs *cs, u32 base, u32 size) { diff --git a/arch/arm/cpu/arm_cortexa8/omap3/sdrc.c b/arch/arm/cpu/arm_cortexa8/omap3/sdrc.c new file mode 100644 index 0000000..96fd990 --- /dev/null +++ b/arch/arm/cpu/arm_cortexa8/omap3/sdrc.c @@ -0,0 +1,202 @@ +/* + * Functions related to OMAP3 SDRC. + * + * This file has been created after exctracting and consolidating + * the SDRC related content from mem.c and board.c, also created + * generic init function (mem_init). + * + * Copyright (C) 2004-2010 + * Texas Instruments Incorporated - http://www.ti.com/ + * + * Author : + * Vaibhav Hiremath hvaibhav@ti.com + * + * Original implementation by (mem.c, board.c) : + * Sunil Kumar sunilsaini05@gmail.com + * Shashi Ranjan shashiranjanmca05@gmail.com + * Manikandan Pillai mani.pillai@ti.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/mem.h> +#include <asm/arch/sys_proto.h> + +extern omap3_sysinfo sysinfo; + +static struct sdrc *sdrc_base = (struct sdrc *)OMAP34XX_SDRC_BASE; + +/* + * is_mem_sdr - + * - Return 1 if mem type in use is SDR + */ +u32 is_mem_sdr(void) +{ + if (readl(&sdrc_base->cs[CS0].mr) == SDRC_MR_0_SDR) + return 1; + return 0; +} + +/* + * make_cs1_contiguous - + * - For es2 and above remap cs1 behind cs0 to allow command line + * mem=xyz use all memory with out discontinuous support compiled in. + * Could do it at the ATAG, but there really is two banks... + * - Called as part of 2nd phase DDR init. + */ +void make_cs1_contiguous(void) +{ + u32 size, a_add_low, a_add_high; + + size = get_sdr_cs_size(CS0); + size >>= 25; /* divide by 32 MiB to find size to offset CS1 */ + a_add_high = (size & 3) << 8; /* set up low field */ + a_add_low = (size & 0x3C) >> 2; /* set up high field */ + writel((a_add_high | a_add_low), &sdrc_base->cs_cfg); + +} + + +/* + * get_sdr_cs_size - + * - Get size of chip select 0/1 + */ +u32 get_sdr_cs_size(u32 cs) +{ + u32 size; + + /* get ram size field */ + size = readl(&sdrc_base->cs[cs].mcfg) >> 8; + size &= 0x3FF; /* remove unwanted bits */ + size <<= 21; /* multiply by 2 MiB to find size in MB */ + return size; +} + +/* + * get_sdr_cs_offset - + * - Get offset of cs from cs0 start + */ +u32 get_sdr_cs_offset(u32 cs) +{ + u32 offset; + + if (!cs) + return 0; + + offset = readl(&sdrc_base->cs_cfg); + offset = (offset & 15) << 27 | (offset & 0x30) >> 17; + + return offset; +} + +/* + * do_sdrc_init - + * - Initialize the SDRAM for use. + * - Sets up SDRC timings for CS0 + * - code called once in C-Stack only context for CS0 and a possible 2nd + * time depending on memory configuration from stack+global context + */ +void do_sdrc_init(u32 cs, u32 early) +{ + struct sdrc_actim *sdrc_actim_base; + + if (cs) + sdrc_actim_base = (struct sdrc_actim *)SDRC_ACTIM_CTRL1_BASE; + else + sdrc_actim_base = (struct sdrc_actim *)SDRC_ACTIM_CTRL0_BASE; + + if (early) { + /* reset sdrc controller */ + writel(SOFTRESET, &sdrc_base->sysconfig); + wait_on_value(RESETDONE, RESETDONE, &sdrc_base->status, + 12000000); + writel(0, &sdrc_base->sysconfig); + + /* setup sdrc to ball mux */ + writel(SDRC_SHARING, &sdrc_base->sharing); + + /* Disable Power Down of CKE cuz of 1 CKE on combo part */ + writel(WAKEUPPROC | SRFRONRESET | PAGEPOLICY_HIGH, + &sdrc_base->power); + + writel(ENADLL | DLLPHASE_90, &sdrc_base->dlla_ctrl); + sdelay(0x20000); + } + + writel(RASWIDTH_13BITS | CASWIDTH_10BITS | ADDRMUXLEGACY | + RAMSIZE_128 | BANKALLOCATION | B32NOT16 | B32NOT16 | + DEEPPD | DDR_SDRAM, &sdrc_base->cs[cs].mcfg); + writel(ARCV | ARE_ARCV_1, &sdrc_base->cs[cs].rfr_ctrl); + writel(V_ACTIMA_165, &sdrc_actim_base->ctrla); + writel(V_ACTIMB_165, &sdrc_actim_base->ctrlb); + + writel(CMD_NOP, &sdrc_base->cs[cs].manual); + writel(CMD_PRECHARGE, &sdrc_base->cs[cs].manual); + writel(CMD_AUTOREFRESH, &sdrc_base->cs[cs].manual); + writel(CMD_AUTOREFRESH, &sdrc_base->cs[cs].manual); + + /* + * CAS latency 3, Write Burst = Read Burst, Serial Mode, + * Burst length = 4 + */ + writel(CASL3 | BURSTLENGTH4, &sdrc_base->cs[cs].mr); + + if (!mem_ok(cs)) + writel(0, &sdrc_base->cs[cs].mcfg); +} + +/* + * dram_init - + * - Sets uboots idea of sdram size + */ +int dram_init(void) +{ + DECLARE_GLOBAL_DATA_PTR; + unsigned int size0 = 0, size1 = 0; + + size0 = get_sdr_cs_size(CS0); + /* + * If a second bank of DDR is attached to CS1 this is + * where it can be started. Early init code will init + * memory on CS0. + */ + if ((sysinfo.mtype == DDR_COMBO) || (sysinfo.mtype == DDR_STACKED)) { + do_sdrc_init(CS1, NOT_EARLY); + make_cs1_contiguous(); + + size1 = get_sdr_cs_size(CS1); + } + + gd->bd->bi_dram[0].start = PHYS_SDRAM_1; + gd->bd->bi_dram[0].size = size0; + gd->bd->bi_dram[1].start = PHYS_SDRAM_1 + get_sdr_cs_offset(CS1); + gd->bd->bi_dram[1].size = size1; + + return 0; +} + +/* + * mem_init - + * - Init the sdrc chip, + * - Selects CS0 and CS1, + */ +void mem_init(void) +{ + /* only init up first bank here */ + do_sdrc_init(CS0, EARLY_INIT); +} diff --git a/arch/arm/cpu/arm_cortexa8/omap3/sys_info.c b/arch/arm/cpu/arm_cortexa8/omap3/sys_info.c index 08fb32e..1df4401 100644 --- a/arch/arm/cpu/arm_cortexa8/omap3/sys_info.c +++ b/arch/arm/cpu/arm_cortexa8/omap3/sys_info.c @@ -32,7 +32,6 @@ #include <i2c.h>
extern omap3_sysinfo sysinfo; -static struct sdrc *sdrc_base = (struct sdrc *)OMAP34XX_SDRC_BASE; static struct ctrl *ctrl_base = (struct ctrl *)OMAP34XX_CTRL_BASE; static char *rev_s[CPU_3XX_MAX_REV] = { "1.0", @@ -104,46 +103,6 @@ u32 get_cpu_rev(void) } }
-/**************************************************** - * is_mem_sdr() - return 1 if mem type in use is SDR - ****************************************************/ -u32 is_mem_sdr(void) -{ - if (readl(&sdrc_base->cs[CS0].mr) == SDRC_MR_0_SDR) - return 1; - return 0; -} - -/*********************************************************************** - * get_cs0_size() - get size of chip select 0/1 - ************************************************************************/ -u32 get_sdr_cs_size(u32 cs) -{ - u32 size; - - /* get ram size field */ - size = readl(&sdrc_base->cs[cs].mcfg) >> 8; - size &= 0x3FF; /* remove unwanted bits */ - size <<= 21; /* multiply by 2 MiB to find size in MB */ - return size; -} - -/*********************************************************************** - * get_sdr_cs_offset() - get offset of cs from cs0 start - ************************************************************************/ -u32 get_sdr_cs_offset(u32 cs) -{ - u32 offset; - - if (!cs) - return 0; - - offset = readl(&sdrc_base->cs_cfg); - offset = (offset & 15) << 27 | (offset & 0x30) >> 17; - - return offset; -} - /*************************************************************************** * get_gpmc0_base() - Return current address hardware will be * fetching from. The below effectively gives what is correct, its a bit diff --git a/arch/arm/include/asm/arch-omap3/cpu.h b/arch/arm/include/asm/arch-omap3/cpu.h index aa8de32..a49af10 100644 --- a/arch/arm/include/asm/arch-omap3/cpu.h +++ b/arch/arm/include/asm/arch-omap3/cpu.h @@ -183,6 +183,7 @@ struct sms { /* SDRC */ #ifndef __KERNEL_STRICT_NAMES #ifndef __ASSEMBLY__ +#if defined(CONFIG_SDRC) struct sdrc_cs { u32 mcfg; /* 0x80 || 0xB0 */ u32 mr; /* 0x84 || 0xB4 */ @@ -215,6 +216,8 @@ struct sdrc { u8 res4[0xC]; struct sdrc_cs cs[2]; /* 0x80 || 0xB0 */ }; + +#endif /* CONFIG_SDRC */ #endif /* __ASSEMBLY__ */ #endif /* __KERNEL_STRICT_NAMES */
diff --git a/arch/arm/include/asm/arch-omap3/mem.h b/arch/arm/include/asm/arch-omap3/mem.h index 9439758..a78cf9f 100644 --- a/arch/arm/include/asm/arch-omap3/mem.h +++ b/arch/arm/include/asm/arch-omap3/mem.h @@ -270,4 +270,17 @@ enum { #define PISMO1_ONEN_BASE ONENAND_MAP #define DBG_MPDB_BASE DEBUG_BASE
+#ifndef __ASSEMBLY__ + +/* Function prototypes */ +void mem_init(void); + +u32 is_mem_sdr(void); +u32 mem_ok(u32 cs); + +u32 get_sdr_cs_size(u32); +u32 get_sdr_cs_offset(u32); + +#endif /* __ASSEMBLY__ */ + #endif /* endif _MEM_H_ */ diff --git a/arch/arm/include/asm/arch-omap3/sys_proto.h b/arch/arm/include/asm/arch-omap3/sys_proto.h index 34bd515..34e4e0d 100644 --- a/arch/arm/include/asm/arch-omap3/sys_proto.h +++ b/arch/arm/include/asm/arch-omap3/sys_proto.h @@ -31,8 +31,10 @@ void prcm_init(void); void per_clocks_enable(void);
void memif_init(void); +#if defined(CONFIG_SDRC) void sdrc_init(void); void do_sdrc_init(u32, u32); +#endif void gpmc_init(void); void enable_gpmc_cs_config(const u32 *gpmc_config, struct gpmc_cs *cs, u32 base, u32 size); @@ -46,8 +48,6 @@ u32 get_sysboot_value(void); u32 is_gpmc_muxed(void); u32 get_gpmc0_type(void); u32 get_gpmc0_width(void); -u32 get_sdr_cs_size(u32); -u32 get_sdr_cs_offset(u32); u32 is_running_in_sdram(void); u32 is_running_in_sram(void); u32 is_running_in_flash(void); diff --git a/include/configs/devkit8000.h b/include/configs/devkit8000.h index 7d1332f..1798bc6 100644 --- a/include/configs/devkit8000.h +++ b/include/configs/devkit8000.h @@ -38,6 +38,8 @@ #define CONFIG_OMAP3430 1 /* which is in a 3430 */ #define CONFIG_OMAP3_DEVKIT8000 1 /* working with DevKit8000 */
+#define CONFIG_SDRC 1 /* The chip has SDRC controller */ + #include <asm/arch/cpu.h> /* get chip and board defs */ #include <asm/arch/omap3.h>
diff --git a/include/configs/omap3_beagle.h b/include/configs/omap3_beagle.h index 08d79ac..7584063 100644 --- a/include/configs/omap3_beagle.h +++ b/include/configs/omap3_beagle.h @@ -37,6 +37,8 @@ #define CONFIG_OMAP3430 1 /* which is in a 3430 */ #define CONFIG_OMAP3_BEAGLE 1 /* working with BEAGLE */
diff --git a/include/configs/omap3_evm.h b/include/configs/omap3_evm.h index 1d31731..8c17388 100644 --- a/include/configs/omap3_evm.h +++ b/include/configs/omap3_evm.h @@ -42,6 +42,8 @@ #define CONFIG_OMAP3430 1 /* which is in a 3430 */ #define CONFIG_OMAP3_EVM 1 /* working with EVM */
diff --git a/include/configs/omap3_overo.h b/include/configs/omap3_overo.h index a43500b..5ca9f3a 100644 --- a/include/configs/omap3_overo.h +++ b/include/configs/omap3_overo.h @@ -29,6 +29,8 @@ #define CONFIG_OMAP3430 1 /* which is in a 3430 */ #define CONFIG_OMAP3_OVERO 1 /* working with overo */
diff --git a/include/configs/omap3_pandora.h b/include/configs/omap3_pandora.h index 945c053..7c62685 100644 --- a/include/configs/omap3_pandora.h +++ b/include/configs/omap3_pandora.h @@ -32,6 +32,8 @@ #define CONFIG_OMAP3430 1 /* which is in a 3430 */ #define CONFIG_OMAP3_PANDORA 1 /* working with pandora */
diff --git a/include/configs/omap3_sdp3430.h b/include/configs/omap3_sdp3430.h index b4919db..f751592 100644 --- a/include/configs/omap3_sdp3430.h +++ b/include/configs/omap3_sdp3430.h @@ -42,6 +42,8 @@ #define CONFIG_OMAP3430 1 /* which is in a 3430 */ #define CONFIG_OMAP3_3430SDP 1 /* working with SDP Rev2 */
diff --git a/include/configs/omap3_zoom1.h b/include/configs/omap3_zoom1.h index ae7ebf9..30515b0 100644 --- a/include/configs/omap3_zoom1.h +++ b/include/configs/omap3_zoom1.h @@ -38,6 +38,8 @@ #define CONFIG_OMAP3430 1 /* which is in a 3430 */ #define CONFIG_OMAP3_ZOOM1 1 /* working with Zoom MDK Rev1 */
diff --git a/include/configs/omap3_zoom2.h b/include/configs/omap3_zoom2.h index c88c732..2861608 100644 --- a/include/configs/omap3_zoom2.h +++ b/include/configs/omap3_zoom2.h @@ -39,6 +39,8 @@ #define CONFIG_OMAP3430 1 /* which is in a 3430 */ #define CONFIG_OMAP3_ZOOM2 1 /* working with Zoom II */
-- 1.6.2.4
Dear hvaibhav@ti.com,
Please don't use 'ifdef" here; instead, use `COBJS-$(CONFIG_SDRC)'
I don't like such a #ifdef here - it is absolutely necessary? Why?
Ditto - please drop this #ifdef.
-----Original Message----- From: Wolfgang Denk [mailto:wd@denx.de] Sent: Thursday, May 06, 2010 1:38 AM To: Hiremath, Vaibhav Cc: u-boot@lists.denx.de Subject: Re: [U-Boot] [PATCH-V2 2/4] omap3: Consolidate SDRC related operations
[Hiremath, Vaibhav] Thanks Denk for your comments, see my response below -
[Hiremath, Vaibhav] ok, will incorporate in next version.
[Hiremath, Vaibhav] Denk,
This is common file being used for all OMAP series of devices (OMAP2, OMAP3 and AM35x family) and OMAP2/3 family supports SDRC controller and AM35x family support EMIF4.
And due to this difference we need to add this #ifdef.
[Hiremath, Vaibhav] Same as above.
Thanks, Vaibhav
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de People seldom know what they want until you give them what they ask for.
Dear "Hiremath, Vaibhav",
In message 19F8576C6E063C45BE387C64729E7394044E351BE0@dbde02.ent.ti.com you wrote:
This is common file being used for all OMAP series of devices (OMAP2, OMAP3 and AM35x family) and OMAP2/3 family supports SDRC controller and AM35x fa mily support EMIF4.
No. If different CPU fmilies need different versions of this struct then they should use separate header files for these.
Even less so here. The prototypes should not do any harm - just remove the #if/#endif
Hiremath, Vaibhav
hvaibhav@ti.com
