[U-Boot] [PATCH] defconfigs: am335x_hs_evm: Sync HS and non-HS defconfigs
Sync new additions to non-HS defconfig with HS defconfig.
Signed-off-by: Andrew F. Davis afd@ti.com --- configs/am335x_hs_evm_defconfig | 8 +++----- configs/am335x_hs_evm_uart_defconfig | 13 +++++++++++-- 2 files changed, 14 insertions(+), 7 deletions(-)
diff --git a/configs/am335x_hs_evm_defconfig b/configs/am335x_hs_evm_defconfig index aa6e9665d2..1a7c5cfb17 100644 --- a/configs/am335x_hs_evm_defconfig +++ b/configs/am335x_hs_evm_defconfig @@ -1,6 +1,4 @@ CONFIG_ARM=y -# CONFIG_SPL_USE_ARCH_MEMCPY is not set -# CONFIG_SPL_USE_ARCH_MEMSET is not set CONFIG_ARCH_OMAP2PLUS=y CONFIG_TI_SECURE_DEVICE=y CONFIG_TI_COMMON_CMD_OPTIONS=y @@ -8,10 +6,11 @@ CONFIG_AM33XX=y CONFIG_ISW_ENTRY_ADDR=0x40300350 CONFIG_SPL=y CONFIG_DISTRO_DEFAULTS=y -CONFIG_ANDROID_BOOT_IMAGE=y CONFIG_FIT_IMAGE_POST_PROCESS=y CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_FIT_IMAGE_POST_PROCESS=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_BOOTCOMMAND="if test ${boot_fit} -eq 1; then run update_to_fit; fi; run findfdt; run init_console; run envboot; run distro_bootcmd" CONFIG_LOGLEVEL=3 CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y @@ -47,9 +46,9 @@ CONFIG_NAND=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_DM_ETH=y -CONFIG_DRIVER_TI_CPSW=y CONFIG_PHY_GIGE=y CONFIG_MII=y +CONFIG_DRIVER_TI_CPSW=y CONFIG_SPI=y CONFIG_OMAP3_SPI=y CONFIG_TIMER=y @@ -60,7 +59,6 @@ CONFIG_USB_MUSB_HOST=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_MUSB_TI=y CONFIG_USB_MUSB_DSPS=y -CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" CONFIG_USB_GADGET_VENDOR_NUM=0x0451 diff --git a/configs/am335x_hs_evm_uart_defconfig b/configs/am335x_hs_evm_uart_defconfig index 379b9580a2..7c36f2f4d0 100644 --- a/configs/am335x_hs_evm_uart_defconfig +++ b/configs/am335x_hs_evm_uart_defconfig @@ -12,9 +12,13 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_IMAGE_POST_PROCESS=y CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_FIT_IMAGE_POST_PROCESS=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_BOOTCOMMAND="if test ${boot_fit} -eq 1; then run update_to_fit; fi; run findfdt; run init_console; run envboot; run distro_bootcmd" +CONFIG_LOGLEVEL=3 CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y CONFIG_ARCH_MISC_INIT=y +CONFIG_SPL_FIT_IMAGE_TINY=y # CONFIG_SPL_ENV_SUPPORT is not set # CONFIG_SPL_EXT_SUPPORT is not set CONFIG_SPL_MTD_SUPPORT=y @@ -39,14 +43,15 @@ CONFIG_DFU_RAM=y CONFIG_DM_I2C=y CONFIG_MISC=y CONFIG_DM_MMC=y +# CONFIG_MMC_HW_PARTITIONING is not set CONFIG_MMC_OMAP_HS=y CONFIG_NAND=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_DM_ETH=y -CONFIG_DRIVER_TI_CPSW=y CONFIG_PHY_GIGE=y CONFIG_MII=y +CONFIG_DRIVER_TI_CPSW=y CONFIG_SPI=y CONFIG_OMAP3_SPI=y CONFIG_TIMER=y @@ -57,8 +62,12 @@ CONFIG_USB_MUSB_HOST=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_MUSB_TI=y CONFIG_USB_MUSB_DSPS=y -CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" +CONFIG_USB_GADGET_VENDOR_NUM=0x0451 +CONFIG_USB_GADGET_PRODUCT_NUM=0xd022 CONFIG_USB_GADGET_DOWNLOAD=y +CONFIG_USB_ETHER=y +CONFIG_SPL_TINY_MEMSET=y CONFIG_RSA=y CONFIG_LZO=y
Signed-off-by: Andrew F. Davis afd@ti.com Reviewed-by: Tom Rini trini@konsulko.com
Andrew F. Davis
