[U-Boot] recommended action for bootloaders regarding modifying device-tree nodes
Greetings,
I develop the boot-loader and kernel for a family of boards that have an on-board EEPROM which contains information as to what options are physically loaded on the board such as memory size/config, and peripheral IC's. We allow customers to create special builds of our standard products with sub-loaded components and while each combination of options ends up with a unique model number, it seems silly to create a different static device-trees for each possible option (not to mention we don't create the unique model number until an order is placed).
My approach has been to define a per-baseboard device-tree in Linux for a 'fully loaded' board, then remove nodes which the EEPROM claims are not present in the bootloader before it passes the DTB to the kernel. I do this by defining aliases in the device-tree for the peripherals that are 'optional' so that the bootloader itself does not need to know the details about how the device is connected.
Is it more appropriate for the bootloader to 'remove' nodes for devices that are not physically present or should I be setting their status property to 'disabled' instead? I'm not clear if either option really has any pros or cons.
Thanks for any suggestions or comments,
Tim
Tim Harvey - Principal Software Engineer Gateworks Corporation 3026 S. Higuera St. San Luis Obispo CA 93401 805-781-2000
Hello,
On 30 January 2014 10:11, Tim Harvey tharvey@gateworks.com wrote:
Greetings,
I am not a DT or u-boot developer but I observe these things:
1) DT include for a SoC has all supported devices. Some which require external parts (eg. physical connectors, extra PHY, ...) are listed as disabled and particular board DT enables them.
2) there is code for setting mac address on ethernet nodes with a specific alias so you could perhaps reuse this code to set disabled option on particular nodes.
Thanks
Michal
Hi Tim,
This is more of a process question: Is there any information captured in your EEPROM that can't be represented in the dtb? iow, at the point when you write the EEPROM, why not write the dtb to it as configured?
You could have pre-configured dtsi fragments for each config option, and then dynamically create the board dts from the order.
I only ask because it would solve the problem below. However, there's a lot more to changing a manufacturing process than meets the eye. :)
That depends on how you have it structured. Is it a valid dtb? Meaning, do you have four nodes all at the same register address? Perhaps you could provide an example dts?
thx,
Jason.
btw - one of my first embedded projects was on one of your boards. An ixp425 with 4 mini-pci slots.
I can share what we do here.. In our systems the serial EEPROM is only 256 bytes, so storing things in DT format would be challenging.
What we do is have a master DTB that has the union of all our configurations. The boot process has a very simple bit of code that runs down the DTB in binary format and replaces entire OF_DT_BEGIN_NODE->OF_DT_END_NODE regions with OF_DT_NOP.
The NOP approach is very simple, no other changes (eg offset recalculation) needs to be done to the DT, so we can do this process with a very small code footprint and without libfdt.
Choosing which sections to drop is done with some combination of hardwired code and searching for specific property patterns. There are also a few places where placeholder sections are directly fixed up, eg a mac address is written into a placeholder of 0s, etc.
So an example might be
optional_peripheral@10000 { orc,board-style = <1>; [..] }
Eg The board-style number comes from the EEPROM and if board-style != 1 then the entire stanza is replaced with NOP.
Jason
On Thu, Jan 30, 2014 at 1:15 PM, Jason Gunthorpe jgunthorpe@obsidianresearch.com wrote:
Jason
Jason,
Sounds pretty much like what we are doing. I am using u-boot and my current code looks like this:
/* * Peripheral Config: * remove nodes by alias path if EEPROM config tells us the * peripheral is not loaded on the board. */ if (!test_bit(EECONFIG_ETH0, info->config)) fdt_del_node_and_alias(blob, "ethernet0"); if (!test_bit(EECONFIG_ETH1, info->config)) fdt_del_node_and_alias(blob, "ethernet1"); if (!test_bit(EECONFIG_HDMI_OUT, info->config)) fdt_del_node_and_alias(blob, "hdmi_out"); if (!test_bit(EECONFIG_SATA, info->config)) fdt_del_node_and_alias(blob, "ahci0"); if (!test_bit(EECONFIG_PCIE, info->config)) fdt_del_node_and_alias(blob, "pcie"); if (!test_bit(EECONFIG_SSI0, info->config)) fdt_del_node_and_alias(blob, "ssi0"); if (!test_bit(EECONFIG_SSI1, info->config)) fdt_del_node_and_alias(blob, "ssi1"); ...
I've submitted my code to u-boot and have been asked if its more appropriate to remove nodes as I'm doing above or to mark them as 'disabled'. From what I can tell there really isn't a rule or recommendation for this so I think I'll keep doing what I'm doing above.
Thanks!
Tim
On Thu, Jan 30, 2014 at 12:45 PM, Jason Cooper jason@lakedaemon.net wrote:
Hi Tim,
our eeprom config section is only 40 bytes. It contains a SKU string, mac addrs, and some bitwise fields for the various optional components that we can subload.
yes its a valid dtb - it is just the superset of everything the baseboard (ie schematic design) can support.
A good example is a custom SKU of a baseboard with ethernet subloaded. If the EEPROM says there is no ethernet mac or phy, I would want to remove or disable the ethernet node from the devicetree.
Another example would be a node for 'gpio-pps' (GPIO based pulse-per-second) support. A baseboard design that has a GPS with its PPS signal tied to a GPIO would define this in the device-tree, but if the EEPROM says the GPS isn't loaded, I would want to remove or disable the gps-pps node.
Tim
thx,
Jason.
Hi Tim,
Ok.
I think JasonG's approach is the way to go (inserting nops). But it's a matter of preference as long as the output is a valid dtb.
on a side note: Do you still have to tie your dtb to a version of the kernel?
thx,
Jason.
Jason Cooper
Jason Gunthorpe
Michal Suchanek
Tim Harvey
