[U-Boot] [PATCH V2] i2c: mxs_i2c: Squash endless loop
The endless waiting for a bit to be set can cause a hang, add a timeout so we prevent such situation. A testcase for such a hang is below. The testcase assumes a device to be present at address 0x50 and a device to NOT be present at address 0x42 . Also note that the "sleep 1" induced delays are imperative for this bug to manifest .
i2c read 0x42 0x0.2 0x10 0x42000000 ; sleep 1 ; \ i2c read 0x50 0x0.2 0x10 0x42000000 ; sleep 1 ; \ i2c read 0x42 0x0.2 0x10 0x42000000
The expected result of the above command is:
Error reading the chip. Error reading the chip.
While without this patch, we observe a hang in the last read from 0x42 precisely when waiting for this bit to be set.
Signed-off-by: Marek Vasut marex@denx.de Cc: Fabio Estevam fabio.estevam@freescale.com Cc: Heiko Schocher hs@denx.de Cc: Stefano Babic sbabic@denx.de
--- drivers/i2c/mxs_i2c.c | 15 ++++++++++++--- 1 file changed, 12 insertions(+), 3 deletions(-)
V2: Replace -EINVAL with -ETIMEDOUT
diff --git a/drivers/i2c/mxs_i2c.c b/drivers/i2c/mxs_i2c.c index 46106b7..a298c95 100644 --- a/drivers/i2c/mxs_i2c.c +++ b/drivers/i2c/mxs_i2c.c @@ -150,6 +150,7 @@ int i2c_read(uchar chip, uint addr, int alen, uchar *buffer, int len) { struct mxs_i2c_regs *i2c_regs = (struct mxs_i2c_regs *)MXS_I2C0_BASE; uint32_t tmp = 0; + int timeout = MXS_I2C_MAX_TIMEOUT; int ret; int i;
@@ -169,9 +170,17 @@ int i2c_read(uchar chip, uint addr, int alen, uchar *buffer, int len)
for (i = 0; i < len; i++) { if (!(i & 3)) { - while (readl(&i2c_regs->hw_i2c_queuestat) & - I2C_QUEUESTAT_RD_QUEUE_EMPTY) - ; + while (--timeout) { + tmp = readl(&i2c_regs->hw_i2c_queuestat); + if (!(tmp & I2C_QUEUESTAT_RD_QUEUE_EMPTY)) + break; + } + + if (!timeout) { + debug("MXS I2C: Failed receiving data!\n"); + return -ETIMEDOUT; + } + tmp = readl(&i2c_regs->hw_i2c_queuedata); } buffer[i] = tmp & 0xff;
Hello Marek,
Am 04.11.2013 14:29, schrieb Marek Vasut:
Signed-off-by: Marek Vasutmarex@denx.de Cc: Fabio Estevamfabio.estevam@freescale.com Cc: Heiko Schocherhs@denx.de Cc: Stefano Babicsbabic@denx.de
Thanks!
Applied to u-boot-i2c.git
bye, Heiko
Heiko Schocher
