[U-Boot] [PATCH v2] POST: Remove duplicated post_hotkey_pressed() functions
This patch introduces a weak default function for post_hotkey_pressed(), returning 0, for boards without hotkey support. The long-running tests won't be started on those boards. This default function was implemented in many board directories. By implementing this weak default we can remove all those duplicate versions.
Boards with hotkey support, can override this weak default function by defining one in their board specific code.
Signed-off-by: Stefan Roese sr@denx.de --- v2: - Rebased on next again
board/amcc/katmai/katmai.c | 11 ----------- board/amcc/kilauea/kilauea.c | 11 ----------- board/amcc/makalu/makalu.c | 11 ----------- board/amcc/ocotea/ocotea.c | 12 ------------ board/amcc/sequoia/sequoia.c | 11 ----------- board/amcc/taishan/taishan.c | 11 ----------- board/amcc/yucca/yucca.c | 11 ----------- board/cm5200/cm5200.c | 8 -------- board/esd/pmc440/pmc440.c | 11 ----------- board/gen860t/gen860t.c | 11 ----------- board/korat/korat.c | 11 ----------- board/kup/common/kup.c | 11 ----------- board/mpl/mip405/mip405.c | 11 ----------- board/netstal/hcu4/hcu4.c | 11 ----------- board/netstal/hcu5/hcu5.c | 11 ----------- board/netstal/mcu25/mcu25.c | 11 ----------- board/netta/netta.c | 11 ----------- board/prodrive/alpr/alpr.c | 12 ------------ board/sacsng/sacsng.c | 12 ------------ board/ssv/adnpesc1/adnpesc1.c | 11 ----------- board/uc100/uc100.c | 12 ------------ post/post.c | 16 ++++++++++++++++ 22 files changed, 16 insertions(+), 232 deletions(-)
diff --git a/board/amcc/katmai/katmai.c b/board/amcc/katmai/katmai.c index 86dc923..54e2a39 100644 --- a/board/amcc/katmai/katmai.c +++ b/board/amcc/katmai/katmai.c @@ -279,17 +279,6 @@ int board_pcie_card_present(int port) } #endif /* defined(CONFIG_PCI) */
-#ifdef CONFIG_POST -/* - * Returns 1 if keys pressed to start the power-on long-running tests - * Called from board_init_f(). - */ -int post_hotkeys_pressed(void) -{ - return (ctrlc()); -} -#endif - int board_eth_init(bd_t *bis) { cpu_eth_init(bis); diff --git a/board/amcc/kilauea/kilauea.c b/board/amcc/kilauea/kilauea.c index 2f99ea1..8ce2445 100644 --- a/board/amcc/kilauea/kilauea.c +++ b/board/amcc/kilauea/kilauea.c @@ -284,14 +284,3 @@ int checkboard (void)
return (0); } - -#if defined(CONFIG_POST) -/* - * Returns 1 if keys pressed to start the power-on long-running tests - * Called from board_init_f(). - */ -int post_hotkeys_pressed(void) -{ - return 0; /* No hotkeys supported */ -} -#endif /* CONFIG_POST */ diff --git a/board/amcc/makalu/makalu.c b/board/amcc/makalu/makalu.c index 3d860af..4afe091 100644 --- a/board/amcc/makalu/makalu.c +++ b/board/amcc/makalu/makalu.c @@ -236,14 +236,3 @@ int checkboard (void)
return (0); } - -#if defined(CONFIG_POST) -/* - * Returns 1 if keys pressed to start the power-on long-running tests - * Called from board_init_f(). - */ -int post_hotkeys_pressed(void) -{ - return 0; /* No hotkeys supported */ -} -#endif /* CONFIG_POST */ diff --git a/board/amcc/ocotea/ocotea.c b/board/amcc/ocotea/ocotea.c index 951a8b5..7bffa3c 100644 --- a/board/amcc/ocotea/ocotea.c +++ b/board/amcc/ocotea/ocotea.c @@ -400,15 +400,3 @@ void fpga_init(void)
return; } - -#ifdef CONFIG_POST -/* - * Returns 1 if keys pressed to start the power-on long-running tests - * Called from board_init_f(). - */ -int post_hotkeys_pressed(void) -{ - - return (ctrlc()); -} -#endif diff --git a/board/amcc/sequoia/sequoia.c b/board/amcc/sequoia/sequoia.c index cb34c9d..6756a27 100644 --- a/board/amcc/sequoia/sequoia.c +++ b/board/amcc/sequoia/sequoia.c @@ -370,17 +370,6 @@ void board_pci_fixup_irq(struct pci_controller *hose, pci_dev_t dev) } #endif
-#if defined(CONFIG_POST) -/* - * Returns 1 if keys pressed to start the power-on long-running tests - * Called from board_init_f(). - */ -int post_hotkeys_pressed(void) -{ - return 0; /* No hotkeys supported */ -} -#endif /* CONFIG_POST */ - #if defined(CONFIG_NAND_U_BOOT) || defined(CONFIG_SYS_RAMBOOT) /* * On NAND-booting sequoia, we need to patch the chips select numbers diff --git a/board/amcc/taishan/taishan.c b/board/amcc/taishan/taishan.c index 279fae2..cac7a78 100644 --- a/board/amcc/taishan/taishan.c +++ b/board/amcc/taishan/taishan.c @@ -209,17 +209,6 @@ int checkboard (void) return (0); }
-#ifdef CONFIG_POST -/* - * Returns 1 if keys pressed to start the power-on long-running tests - * Called from board_init_f(). - */ -int post_hotkeys_pressed(void) -{ - return (ctrlc()); -} -#endif - int board_eth_init(bd_t *bis) { cpu_eth_init(bis); diff --git a/board/amcc/yucca/yucca.c b/board/amcc/yucca/yucca.c index e0d19bc..67a0167 100644 --- a/board/amcc/yucca/yucca.c +++ b/board/amcc/yucca/yucca.c @@ -708,17 +708,6 @@ void fpga_init(void) return; }
-#ifdef CONFIG_POST -/* - * Returns 1 if keys pressed to start the power-on long-running tests - * Called from board_init_f(). - */ -int post_hotkeys_pressed(void) -{ - return (ctrlc()); -} -#endif - /*---------------------------------------------------------------------------+ | onboard_pci_arbiter_selected => from EPLD +---------------------------------------------------------------------------*/ diff --git a/board/cm5200/cm5200.c b/board/cm5200/cm5200.c index 9e2f1a5..0b5412b 100644 --- a/board/cm5200/cm5200.c +++ b/board/cm5200/cm5200.c @@ -330,14 +330,6 @@ int board_early_init_r(void) }
-#ifdef CONFIG_POST -int post_hotkeys_pressed(void) -{ - return 0; -} -#endif /* CONFIG_POST */ - - #if defined(CONFIG_POST) || defined(CONFIG_LOGBUFFER) void post_word_store(ulong a) { diff --git a/board/esd/pmc440/pmc440.c b/board/esd/pmc440/pmc440.c index d0ff080..bd43a9a 100644 --- a/board/esd/pmc440/pmc440.c +++ b/board/esd/pmc440/pmc440.c @@ -677,17 +677,6 @@ int is_pci_host(struct pci_controller *hose) } #endif /* defined(CONFIG_PCI) */
-#if defined(CONFIG_POST) -/* - * Returns 1 if keys pressed to start the power-on long-running tests - * Called from board_init_f(). - */ -int post_hotkeys_pressed(void) -{ - return 0; /* No hotkeys supported */ -} -#endif /* CONFIG_POST */ - #ifdef CONFIG_RESET_PHY_R void reset_phy(void) { diff --git a/board/gen860t/gen860t.c b/board/gen860t/gen860t.c index 008f765..b37a0f2 100644 --- a/board/gen860t/gen860t.c +++ b/board/gen860t/gen860t.c @@ -292,14 +292,3 @@ void board_poweroff (void) puts ("### Please power off the board ###\n"); while (1); } - -#ifdef CONFIG_POST -/* - * Returns 1 if keys pressed to start the power-on long-running tests - * Called from board_init_f(). - */ -int post_hotkeys_pressed (void) -{ - return 0; /* No hotkeys supported */ -} -#endif diff --git a/board/korat/korat.c b/board/korat/korat.c index f942052..d5260dc 100644 --- a/board/korat/korat.c +++ b/board/korat/korat.c @@ -622,17 +622,6 @@ void pci_target_init(struct pci_controller *hose) } #endif /* defined(CONFIG_PCI) && defined(CONFIG_SYS_PCI_TARGET_INIT) */
-#if defined(CONFIG_POST) -/* - * Returns 1 if keys pressed to start the power-on long-running tests - * Called from board_init_f(). - */ -int post_hotkeys_pressed(void) -{ - return 0; /* No hotkeys supported */ -} -#endif /* CONFIG_POST */ - #if defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) void ft_board_setup(void *blob, bd_t *bd) { diff --git a/board/kup/common/kup.c b/board/kup/common/kup.c index fec5407..2418d59 100644 --- a/board/kup/common/kup.c +++ b/board/kup/common/kup.c @@ -70,14 +70,3 @@ void poweron_key (void) else setenv ("key1", "on"); } - -#ifdef CONFIG_POST -/* - * Returns 1 if keys pressed to start the power-on long-running tests - * Called from board_init_f(). - */ -int post_hotkeys_pressed (void) -{ - return (0); -} -#endif diff --git a/board/mpl/mip405/mip405.c b/board/mpl/mip405/mip405.c index 495e9bd..af3a98a 100644 --- a/board/mpl/mip405/mip405.c +++ b/board/mpl/mip405/mip405.c @@ -706,17 +706,6 @@ void print_mip405_rev (void) }
-#ifdef CONFIG_POST -/* - * Returns 1 if keys pressed to start the power-on long-running tests - * Called from board_init_f(). - */ -int post_hotkeys_pressed(void) -{ - return 0; /* No hotkeys supported */ -} -#endif - extern int mk_date (char *, struct rtc_time *);
int last_stage_init (void) diff --git a/board/netstal/hcu4/hcu4.c b/board/netstal/hcu4/hcu4.c index ba3e9c3..8efbc23 100644 --- a/board/netstal/hcu4/hcu4.c +++ b/board/netstal/hcu4/hcu4.c @@ -174,17 +174,6 @@ phys_size_t initdram(int board_type) return dram_size; }
-#if defined(CONFIG_POST) -/* - * Returns 1 if keys pressed to start the power-on long-running tests - * Called from board_init_f(). - */ -int post_hotkeys_pressed(void) -{ - return 0; /* No hotkeys supported */ -} -#endif /* CONFIG_POST */ - #if defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) void ft_board_setup(void *blob, bd_t *bd) { diff --git a/board/netstal/hcu5/hcu5.c b/board/netstal/hcu5/hcu5.c index 8615645..c545cc0 100644 --- a/board/netstal/hcu5/hcu5.c +++ b/board/netstal/hcu5/hcu5.c @@ -390,17 +390,6 @@ void pci_master_init(struct pci_controller *hose) } #endif /* defined(CONFIG_PCI) */
-#if defined(CONFIG_POST) -/* - * Returns 1 if keys pressed to start the power-on long-running tests - * Called from board_init_f(). - */ -int post_hotkeys_pressed(void) -{ - return 0; /* No hotkeys supported */ -} -#endif /* CONFIG_POST */ - #if defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) void ft_board_setup(void *blob, bd_t *bd) { diff --git a/board/netstal/mcu25/mcu25.c b/board/netstal/mcu25/mcu25.c index 945d79a..c66ab97 100644 --- a/board/netstal/mcu25/mcu25.c +++ b/board/netstal/mcu25/mcu25.c @@ -173,17 +173,6 @@ phys_size_t initdram(int board_type) return dram_size; }
-#if defined(CONFIG_POST) -/* - * Returns 1 if keys pressed to start the power-on long-running tests - * Called from board_init_f(). - */ -int post_hotkeys_pressed(void) -{ - return 0; /* No hotkeys supported */ -} -#endif /* CONFIG_POST */ - #if defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) void ft_board_setup(void *blob, bd_t *bd) { diff --git a/board/netta/netta.c b/board/netta/netta.c index 38c9d89..5c935f4 100644 --- a/board/netta/netta.c +++ b/board/netta/netta.c @@ -564,17 +564,6 @@ int pcmcia_init(void)
#endif
-#ifdef CONFIG_POST -/* - * Returns 1 if keys pressed to start the power-on long-running tests - * Called from board_init_f(). - */ -int post_hotkeys_pressed(void) -{ - return 0; /* No hotkeys supported */ -} -#endif - #ifdef CONFIG_HW_WATCHDOG
void hw_watchdog_reset(void) diff --git a/board/prodrive/alpr/alpr.c b/board/prodrive/alpr/alpr.c index 6615327..060e7eb 100644 --- a/board/prodrive/alpr/alpr.c +++ b/board/prodrive/alpr/alpr.c @@ -228,15 +228,3 @@ void pci_master_init(struct pci_controller *hose) out32r(PCIL0_POM1SA, ~(0x10000000 - 1) | 1); /* 256MB + enable region */ } #endif /* defined(CONFIG_PCI) && defined(CONFIG_SYS_PCI_MASTER_INIT) */ - -#ifdef CONFIG_POST -/* - * Returns 1 if keys pressed to start the power-on long-running tests - * Called from board_init_f(). - */ -int post_hotkeys_pressed(void) -{ - - return (ctrlc()); -} -#endif diff --git a/board/sacsng/sacsng.c b/board/sacsng/sacsng.c index 2513937..49d8bba 100644 --- a/board/sacsng/sacsng.c +++ b/board/sacsng/sacsng.c @@ -869,15 +869,3 @@ void spi_cs_deactivate(struct spi_slave *slave) #endif
#endif /* CONFIG_MISC_INIT_R */ - -#ifdef CONFIG_POST -/* - * Returns 1 if keys pressed to start the power-on long-running tests - * Called from board_init_f(). - */ -int post_hotkeys_pressed(void) -{ - return 0; /* No hotkeys supported */ -} - -#endif diff --git a/board/ssv/adnpesc1/adnpesc1.c b/board/ssv/adnpesc1/adnpesc1.c index 72810d0..802bfba 100644 --- a/board/ssv/adnpesc1/adnpesc1.c +++ b/board/ssv/adnpesc1/adnpesc1.c @@ -91,17 +91,6 @@ void spi_cs_deactivate(struct spi_slave *slave)
#endif
-#if defined(CONFIG_POST) -/* - * Returns 1 if keys pressed to start the power-on long-running tests - * Called from board_init_f(). - */ -int post_hotkeys_pressed(void) -{ - return 0; /* No hotkeys supported */ -} -#endif /* CONFIG_POST */ - #ifdef CONFIG_CMD_NET int board_eth_init(bd_t *bis) { diff --git a/board/uc100/uc100.c b/board/uc100/uc100.c index 38c7be6..4dba290 100644 --- a/board/uc100/uc100.c +++ b/board/uc100/uc100.c @@ -268,15 +268,3 @@ int misc_init_r (void)
return 0; } - - -#ifdef CONFIG_POST -/* - * Returns 1 if keys pressed to start the power-on long-running tests - * Called from board_init_f(). - */ -int post_hotkeys_pressed (void) -{ - return 0; /* No hotkeys supported */ -} -#endif diff --git a/post/post.c b/post/post.c index b74e762..b29eb87 100644 --- a/post/post.c +++ b/post/post.c @@ -58,6 +58,22 @@ int post_init_f (void) return res; }
+/* + * Supply a default implementation for post_hotkeys_pressed() for boards + * without hotkey support. We always return 0 here, so that the + * long-running tests won't be started. + * + * Boards with hotkey support can override this weak default function + * by defining one in their board specific code. + */ +int __post_hotkeys_pressed(void) +{ + return 0; /* No hotkeys supported */ +} +int post_hotkeys_pressed(void) + __attribute__((weak, alias("__post_hotkeys_pressed"))); + + void post_bootmode_init (void) { int bootmode = post_bootmode_get (0);
Dear Stefan Roese,
v2:
Applied to "next", thanks.
Stefan Roese
