Pull request: u-boot-spi/master
Hi Tom,
Please pull this PR.
Travis-CI: https://travis-ci.com/github/openedev/u-boot-amarula/builds/209599920
thanks, Jagan.
The following changes since commit a4391365995a00f196373cddd35d99f74a9e62ff:
configs: Resync with savedefconfig (2020-12-16 10:58:24 -0500)
https://gitlab.denx.de/u-boot/custodians/u-boot-spi master
for you to fetch changes up to 936a645609145363b9580adeda831ab3d9ac1d78:
mtd: spi-nor-ids: add Micron MT25QL01G flash (2020-12-18 16:19:33 +0530)
---------------------------------------------------------------- Biju Das (1): mtd: spi-nor-ids: Add Winbond W25M512JW flash entry
Frieder Schrempf (3): mtd: spinand: Stop using spinand->oobbuf for buffering bad block markers mtd: spinand: Explicitly use MTD_OPS_RAW to write the bad block marker to OOB mtd: spinand: Do not erase the block before writing a bad block marker
Hongwei Zhang (1): mtd: spi-nor-ids: add Micron MT25QL01G flash
Jagan Teki (3): cl-som-imx7: Switch to DM_SPI/DM_SPI_FLASH cm_fx6: Switch to full DM-aware dh_imx6: Switch to full DM-aware
Lad Prabhakar (1): mtd: spi-nor-ids: Add Winbond W25M512JV flash entry
Mikhail Kshevetskiy (1): mtd: spinand: enable erasing of bad mtd blocks
Patrick Delaunay (1): spi: migrate trace to dev and log macro in spi uclass
Pengpeng Chen (1): spi: ca_sflash: Add CAxxxx SPI Flash Controller
Robert Marko (1): mtd: spi-nor-ids: Add SECT_4K to mx25l12805d
Sean Anderson (14): doc: Fix typo in FIT documentation spi: Fix typo in header spi: dw: Fix driving MOSI low while recieving spi: dw: Convert calls to debug to dev_* spi: dw: Rename "cs-gpio" to "cs-gpios" spi: dw: Use generic function to read reg address spi: dw: Rename registers to match datasheet spi: dw: Remove spi_enable_chip spi: dw: Rearrange struct dw_spi_priv spi: dw: Add SoC-specific compatible strings spi: dw: Add support for multiple CTRLR0 layouts spi: dw: Document devicetree binding spi: dw: Add mem_ops riscv: Add device tree bindings for SPI
MAINTAINERS | 2 + arch/arc/dts/axs10x_mb.dtsi | 5 +- arch/arc/dts/hsdk-common.dtsi | 5 +- arch/arm/dts/socfpga.dtsi | 6 +- arch/arm/dts/socfpga_agilex.dtsi | 6 +- arch/arm/dts/socfpga_arria10.dtsi | 6 +- arch/arm/dts/socfpga_stratix10.dtsi | 6 +- arch/mips/dts/mscc,jr2.dtsi | 2 +- arch/mips/dts/mscc,ocelot.dtsi | 2 +- arch/riscv/dts/k210-maix-bit.dts | 46 +- arch/riscv/dts/k210.dtsi | 15 +- configs/cl-som-imx7_defconfig | 7 +- configs/cm_fx6_defconfig | 3 + configs/dh_imx6_defconfig | 3 + doc/device-tree-bindings/spi/snps,dw-apb-ssi.txt | 56 +++ doc/uImage.FIT/source_file_format.txt | 2 +- drivers/mtd/nand/core.c | 10 +- drivers/mtd/nand/spi/core.c | 24 +- drivers/mtd/spi/spi-nor-ids.c | 5 +- drivers/spi/Kconfig | 8 + drivers/spi/Makefile | 1 + drivers/spi/ca_sflash.c | 576 +++++++++++++++++++++++ drivers/spi/designware_spi.c | 405 ++++++++++++---- drivers/spi/spi-uclass.c | 51 +- include/configs/cm_fx6.h | 7 - include/configs/dh_imx6.h | 6 - include/spi.h | 2 +- 27 files changed, 1094 insertions(+), 173 deletions(-) create mode 100644 doc/device-tree-bindings/spi/snps,dw-apb-ssi.txt create mode 100644 drivers/spi/ca_sflash.c
On Fri, Dec 18, 2020 at 11:24:02PM +0530, Jagan Teki wrote:
Hi Tom,
thanks, Jagan.
Jagan Teki
