[U-Boot] PXA patches
these are the patches I have prepared for u-boot-testing.git/Makefile-cleanup.
Also change the initializer style
Signed-off-by: Marek Vasut marek.vasut@gmail.com --- arch/arm/cpu/pxa/pxafb.c | 200 +++++++++++++++++++++++----------------------- 1 files changed, 100 insertions(+), 100 deletions(-)
diff --git a/arch/arm/cpu/pxa/pxafb.c b/arch/arm/cpu/pxa/pxafb.c index 0ee6a75..50e9cc0 100644 --- a/arch/arm/cpu/pxa/pxafb.c +++ b/arch/arm/cpu/pxa/pxafb.c @@ -56,26 +56,26 @@
/* 640x480x16 @ 61 Hz */ vidinfo_t panel_info = { - vl_col: 640, - vl_row: 480, - vl_width: 640, - vl_height: 480, - vl_clkp: CONFIG_SYS_HIGH, - vl_oep: CONFIG_SYS_HIGH, - vl_hsp: CONFIG_SYS_HIGH, - vl_vsp: CONFIG_SYS_HIGH, - vl_dp: CONFIG_SYS_HIGH, - vl_bpix: LCD_BPP, - vl_lbw: 0, - vl_splt: 0, - vl_clor: 0, - vl_tft: 1, - vl_hpw: 40, - vl_blw: 56, - vl_elw: 56, - vl_vpw: 20, - vl_bfw: 8, - vl_efw: 8, + .vl_col = 640, + .vl_row = 480, + .vl_width = 640, + .vl_height = 480, + .vl_clkp = CONFIG_SYS_HIGH, + .vl_oep = CONFIG_SYS_HIGH, + .vl_hsp = CONFIG_SYS_HIGH, + .vl_vsp = CONFIG_SYS_HIGH, + .vl_dp = CONFIG_SYS_HIGH, + .vl_bpix = LCD_BPP, + .vl_lbw = 0, + .vl_splt = 0, + .vl_clor = 0, + .vl_tft = 1, + .vl_hpw = 40, + .vl_blw = 56, + .vl_elw = 56, + .vl_vpw = 20, + .vl_bfw = 8, + .vl_efw = 8, }; #endif /* CONFIG_PXA_VIDEO */
@@ -90,26 +90,26 @@ vidinfo_t panel_info = { # define REG_LCCR3 0x0340FF08
vidinfo_t panel_info = { - vl_col: 640, - vl_row: 480, - vl_width: 157, - vl_height: 118, - vl_clkp: CONFIG_SYS_HIGH, - vl_oep: CONFIG_SYS_HIGH, - vl_hsp: CONFIG_SYS_HIGH, - vl_vsp: CONFIG_SYS_HIGH, - vl_dp: CONFIG_SYS_HIGH, - vl_bpix: LCD_BPP, - vl_lbw: 0, - vl_splt: 1, - vl_clor: 1, - vl_tft: 0, - vl_hpw: 1, - vl_blw: 3, - vl_elw: 3, - vl_vpw: 1, - vl_bfw: 0, - vl_efw: 0, + .vl_col = 640, + .vl_row = 480, + .vl_width = 157, + .vl_height = 118, + .vl_clkp = CONFIG_SYS_HIGH, + .vl_oep = CONFIG_SYS_HIGH, + .vl_hsp = CONFIG_SYS_HIGH, + .vl_vsp = CONFIG_SYS_HIGH, + .vl_dp = CONFIG_SYS_HIGH, + .vl_bpix = LCD_BPP, + .vl_lbw = 0, + .vl_splt = 1, + .vl_clor = 1, + .vl_tft = 0, + .vl_hpw = 1, + .vl_blw = 3, + .vl_elw = 3, + .vl_vpw = 1, + .vl_bfw = 0, + .vl_efw = 0, }; #endif /* CONFIG_SHARP_LM8V31 */ /*----------------------------------------------------------------------*/ @@ -123,26 +123,26 @@ vidinfo_t panel_info = { # define REG_LCCR3 0x0340FF08
vidinfo_t panel_info = { - vl_col: 640, - vl_row: 480, - vl_width: 157, - vl_height: 118, - vl_clkp: CONFIG_SYS_HIGH, - vl_oep: CONFIG_SYS_HIGH, - vl_hsp: CONFIG_SYS_HIGH, - vl_vsp: CONFIG_SYS_HIGH, - vl_dp: CONFIG_SYS_HIGH, - vl_bpix: LCD_BPP, - vl_lbw: 0, - vl_splt: 1, - vl_clor: 1, - vl_tft: 1, - vl_hpw: 32, - vl_blw: 144, - vl_elw: 32, - vl_vpw: 2, - vl_bfw: 13, - vl_efw: 30, + .vl_col = 640, + .vl_row = 480, + .vl_width = 157, + .vl_height = 118, + .vl_clkp = CONFIG_SYS_HIGH, + .vl_oep = CONFIG_SYS_HIGH, + .vl_hsp = CONFIG_SYS_HIGH, + .vl_vsp = CONFIG_SYS_HIGH, + .vl_dp = CONFIG_SYS_HIGH, + .vl_bpix = LCD_BPP, + .vl_lbw = 0, + .vl_splt = 1, + .vl_clor = 1, + .vl_tft = 1, + .vl_hpw = 32, + .vl_blw = 144, + .vl_elw = 32, + .vl_vpw = 2, + .vl_bfw = 13, + .vl_efw = 30, }; #endif /* CONFIG_VOIPAC_LCD */
@@ -156,26 +156,26 @@ vidinfo_t panel_info = { #define REG_LCCR3 0x0340FF20
vidinfo_t panel_info = { - vl_col: 320, - vl_row: 240, - vl_width: 167, - vl_height: 109, - vl_clkp: CONFIG_SYS_HIGH, - vl_oep: CONFIG_SYS_HIGH, - vl_hsp: CONFIG_SYS_HIGH, - vl_vsp: CONFIG_SYS_HIGH, - vl_dp: CONFIG_SYS_HIGH, - vl_bpix: LCD_BPP, - vl_lbw: 1, - vl_splt: 0, - vl_clor: 1, - vl_tft: 0, - vl_hpw: 1, - vl_blw: 1, - vl_elw: 1, - vl_vpw: 7, - vl_bfw: 0, - vl_efw: 0, + .vl_col = 320, + .vl_row = 240, + .vl_width = 167, + .vl_height = 109, + .vl_clkp = CONFIG_SYS_HIGH, + .vl_oep = CONFIG_SYS_HIGH, + .vl_hsp = CONFIG_SYS_HIGH, + .vl_vsp = CONFIG_SYS_HIGH, + .vl_dp = CONFIG_SYS_HIGH, + .vl_bpix = LCD_BPP, + .vl_lbw = 1, + .vl_splt = 0, + .vl_clor = 1, + .vl_tft = 0, + .vl_hpw = 1, + .vl_blw = 1, + .vl_elw = 1, + .vl_vpw = 7, + .vl_bfw = 0, + .vl_efw = 0, }; #endif /* CONFIG_HITACHI_SX14 */
@@ -190,26 +190,26 @@ vidinfo_t panel_info = { # define REG_LCCR3 0x03b00009
vidinfo_t panel_info = { - vl_col: 240, - vl_row: 320, - vl_width: 240, - vl_height: 320, - vl_clkp: CONFIG_SYS_HIGH, - vl_oep: CONFIG_SYS_LOW, - vl_hsp: CONFIG_SYS_LOW, - vl_vsp: CONFIG_SYS_LOW, - vl_dp: CONFIG_SYS_HIGH, - vl_bpix: LCD_BPP, - vl_lbw: 0, - vl_splt: 1, - vl_clor: 1, - vl_tft: 1, - vl_hpw: 4, - vl_blw: 4, - vl_elw: 8, - vl_vpw: 4, - vl_bfw: 4, - vl_efw: 8, + .vl_col = 240, + .vl_row = 320, + .vl_width = 240, + .vl_height = 320, + .vl_clkp = CONFIG_SYS_HIGH, + .vl_oep = CONFIG_SYS_LOW, + .vl_hsp = CONFIG_SYS_LOW, + .vl_vsp = CONFIG_SYS_LOW, + .vl_dp = CONFIG_SYS_HIGH, + .vl_bpix = LCD_BPP, + .vl_lbw = 0, + .vl_splt = 1, + .vl_clor = 1, + .vl_tft = 1, + .vl_hpw = 4, + .vl_blw = 4, + .vl_elw = 8, + .vl_vpw = 4, + .vl_bfw = 4, + .vl_efw = 8, }; #endif /* CONFIG_LMS283GF05 */
Signed-off-by: Marek Vasut marek.vasut@gmail.com --- arch/arm/cpu/pxa/cpu.c | 28 +- arch/arm/cpu/pxa/i2c.c | 69 +- arch/arm/cpu/pxa/pxafb.c | 64 +- arch/arm/cpu/pxa/timer.c | 7 +- arch/arm/cpu/pxa/usb.c | 61 +- arch/arm/include/asm/arch-pxa/hardware.h | 61 +- arch/arm/include/asm/arch-pxa/pxa-regs.h | 2688 ++++++++++++++++-------------- board/colibri_pxa270/colibri_pxa270.c | 33 +- board/cradle/cradle.c | 5 +- board/cradle/lowlevel_init.S | 4 +- board/csb226/csb226.c | 13 +- board/delta/delta.c | 37 +- board/delta/nand.c | 110 +- board/innokom/innokom.c | 14 +- board/pxa255_idp/pxa_idp.c | 27 +- board/trizepsiv/conxs.c | 33 +- board/vpac270/vpac270.c | 37 +- board/wepep250/wepep250.c | 11 +- board/zipitz2/zipitz2.c | 33 +- board/zylonite/nand.c | 110 +- drivers/mmc/pxa_mmc.c | 98 +- drivers/serial/serial_pxa.c | 94 +- include/configs/cradle.h | 2 - include/configs/delta.h | 1 + include/configs/zylonite.h | 1 + 25 files changed, 1911 insertions(+), 1730 deletions(-)
diff --git a/arch/arm/cpu/pxa/cpu.c b/arch/arm/cpu/pxa/cpu.c index 800d120..330d013 100644 --- a/arch/arm/cpu/pxa/cpu.c +++ b/arch/arm/cpu/pxa/cpu.c @@ -30,10 +30,11 @@ * CPU specific code */
-#include <common.h> -#include <command.h> #include <asm/arch/pxa-regs.h> +#include <asm/io.h> #include <asm/system.h> +#include <command.h> +#include <common.h>
static void cache_flush(void);
@@ -71,17 +72,22 @@ void set_GPIO_mode(int gpio_mode) { int gpio = gpio_mode & GPIO_MD_MASK_NR; int fn = (gpio_mode & GPIO_MD_MASK_FN) >> 8; - int gafr; + int val; + + /* This below changes direction setting of GPIO "gpio" */ + val = readl(GPDR(gpio));
if (gpio_mode & GPIO_MD_MASK_DIR) - { - GPDR(gpio) |= GPIO_bit(gpio); - } + val |= GPIO_bit(gpio); else - { - GPDR(gpio) &= ~GPIO_bit(gpio); - } - gafr = GAFR(gpio) & ~(0x3 << (((gpio) & 0xf)*2)); - GAFR(gpio) = gafr | (fn << (((gpio) & 0xf)*2)); + val &= ~GPIO_bit(gpio); + + writel(val, GPDR(gpio)); + + /* This below updates only AF of GPIO "gpio" */ + val = readl(GAFR(gpio)); + val &= ~(0x3 << (((gpio) & 0xf) * 2)); + val |= fn << (((gpio) & 0xf) * 2); + writel(val, GAFR(gpio)); } #endif /* CONFIG_CPU_MONAHANS */ diff --git a/arch/arm/cpu/pxa/i2c.c b/arch/arm/cpu/pxa/i2c.c index 6b72ba1..7aa49ae 100644 --- a/arch/arm/cpu/pxa/i2c.c +++ b/arch/arm/cpu/pxa/i2c.c @@ -33,6 +33,7 @@ /* FIXME: this file is PXA255 specific! What about other XScales? */
#include <common.h> +#include <asm/io.h>
#ifdef CONFIG_HARD_I2C
@@ -93,19 +94,21 @@ struct i2c_msg {
static void i2c_reset( void ) { - ICR &= ~ICR_IUE; /* disable unit */ - ICR |= ICR_UR; /* reset the unit */ + writel(readl(ICR) & ~ICR_IUE, ICR); /* disable unit */ + writel(readl(ICR) | ICR_UR, ICR); /* reset the unit */ udelay(100); - ICR &= ~ICR_IUE; /* disable unit */ + writel(readl(ICR) & ~ICR_IUE, ICR); /* disable unit */ #ifdef CONFIG_CPU_MONAHANS - CKENB |= (CKENB_4_I2C); /* | CKENB_1_PWM1 | CKENB_0_PWM0); */ + /* | CKENB_1_PWM1 | CKENB_0_PWM0); */ + writel(readl(CKENB) | (CKENB_4_I2C), CKENB); #else /* CONFIG_CPU_MONAHANS */ - CKEN |= CKEN14_I2C; /* set the global I2C clock on */ + /* set the global I2C clock on */ + writel(readl(CKEN) | CKEN14_I2C, CKEN); #endif - ISAR = I2C_PXA_SLAVE_ADDR; /* set our slave address */ - ICR = I2C_ICR_INIT; /* set control register values */ - ISR = I2C_ISR_INIT; /* set clear interrupt bits */ - ICR |= ICR_IUE; /* enable unit */ + writel(I2C_PXA_SLAVE_ADDR, ISAR); /* set our slave address */ + writel(I2C_ICR_INIT, ICR); /* set control reg values */ + writel(I2C_ISR_INIT, ISR); /* set clear interrupt bits */ + writel(readl(ICR) | ICR_IUE, ICR); /* enable unit */ udelay(100); }
@@ -159,22 +162,26 @@ int i2c_transfer(struct i2c_msg *msg) goto transfer_error_bus_busy;
/* start transmission */ - ICR &= ~ICR_START; - ICR &= ~ICR_STOP; - IDBR = msg->data; - if (msg->condition == I2C_COND_START) ICR |= ICR_START; - if (msg->condition == I2C_COND_STOP) ICR |= ICR_STOP; - if (msg->acknack == I2C_ACKNAK_SENDNAK) ICR |= ICR_ACKNAK; - if (msg->acknack == I2C_ACKNAK_SENDACK) ICR &= ~ICR_ACKNAK; - ICR &= ~ICR_ALDIE; - ICR |= ICR_TB; + writel(readl(ICR) & ~ICR_START, ICR); + writel(readl(ICR) & ~ICR_STOP, ICR); + writel(msg->data, IDBR); + if (msg->condition == I2C_COND_START) + writel(readl(ICR) | ICR_START, ICR); + if (msg->condition == I2C_COND_STOP) + writel(readl(ICR) | ICR_STOP, ICR); + if (msg->acknack == I2C_ACKNAK_SENDNAK) + writel(readl(ICR) | ICR_ACKNAK, ICR); + if (msg->acknack == I2C_ACKNAK_SENDACK) + writel(readl(ICR) & ~ICR_ACKNAK, ICR); + writel(readl(ICR) & ~ICR_ALDIE, ICR); + writel(readl(ICR) | ICR_TB, ICR);
/* transmit register empty? */ if (!i2c_isr_set_cleared(ISR_ITE,0)) goto transfer_error_transmit_timeout;
/* clear 'transmit empty' state */ - ISR |= ISR_ITE; + writel(readl(ISR) | ISR_ITE, ISR);
/* wait for ACK from slave */ if (msg->acknack == I2C_ACKNAK_WAITACK) @@ -189,23 +196,27 @@ int i2c_transfer(struct i2c_msg *msg) goto transfer_error_bus_busy;
/* start receive */ - ICR &= ~ICR_START; - ICR &= ~ICR_STOP; - if (msg->condition == I2C_COND_START) ICR |= ICR_START; - if (msg->condition == I2C_COND_STOP) ICR |= ICR_STOP; - if (msg->acknack == I2C_ACKNAK_SENDNAK) ICR |= ICR_ACKNAK; - if (msg->acknack == I2C_ACKNAK_SENDACK) ICR &= ~ICR_ACKNAK; - ICR &= ~ICR_ALDIE; - ICR |= ICR_TB; + writel(readl(ICR) & ~ICR_START, ICR); + writel(readl(ICR) & ~ICR_STOP, ICR); + if (msg->condition == I2C_COND_START) + writel(readl(ICR) | ICR_START, ICR); + if (msg->condition == I2C_COND_STOP) + writel(readl(ICR) | ICR_STOP, ICR); + if (msg->acknack == I2C_ACKNAK_SENDNAK) + writel(readl(ICR) | ICR_ACKNAK, ICR); + if (msg->acknack == I2C_ACKNAK_SENDACK) + writel(readl(ICR) & ~ICR_ACKNAK, ICR); + writel(readl(ICR) & ~ICR_ALDIE, ICR); + writel(readl(ICR) | ICR_TB, ICR);
/* receive register full? */ if (!i2c_isr_set_cleared(ISR_IRF,0)) goto transfer_error_receive_timeout;
- msg->data = IDBR; + msg->data = readl(IDBR);
/* clear 'receive empty' state */ - ISR |= ISR_IRF; + writel(readl(ISR) | ISR_IRF, ISR);
break;
diff --git a/arch/arm/cpu/pxa/pxafb.c b/arch/arm/cpu/pxa/pxafb.c index 50e9cc0..cb004b2 100644 --- a/arch/arm/cpu/pxa/pxafb.c +++ b/arch/arm/cpu/pxa/pxafb.c @@ -35,6 +35,7 @@ #include <stdio_dev.h> #include <lcd.h> #include <asm/arch/pxa-regs.h> +#include <asm/io.h>
/* #define DEBUG */
@@ -377,12 +378,14 @@ static void pxafb_setup_gpio (vidinfo_t *vid) { debug("Setting GPIO for 4 bit data\n"); /* bits 58-61 */ - GPDR1 |= (0xf << 26); - GAFR1_U = (GAFR1_U & ~(0xff << 20)) | (0xaa << 20); + writel(readl(GPDR1) | (0xf << 26), GPDR1); + writel((readl(GAFR1_U) & ~(0xff << 20)) | (0xaa << 20), + GAFR1_U);
/* bits 74-77 */ - GPDR2 |= (0xf << 10); - GAFR2_L = (GAFR2_L & ~(0xff << 20)) | (0xaa << 20); + writel(readl(GPDR2) | (0xf << 10), GPDR2); + writel((readl(GAFR2_L) & ~(0xff << 20)) | (0xaa << 20), + GAFR2_L); }
/* 8 bit interface */ @@ -391,15 +394,17 @@ static void pxafb_setup_gpio (vidinfo_t *vid) { debug("Setting GPIO for 8 bit data\n"); /* bits 58-65 */ - GPDR1 |= (0x3f << 26); - GPDR2 |= (0x3); + writel(readl(GPDR1) | (0x3f << 26), GPDR1); + writel(readl(GPDR2) | (0x3), GPDR2);
- GAFR1_U = (GAFR1_U & ~(0xfff << 20)) | (0xaaa << 20); - GAFR2_L = (GAFR2_L & ~0xf) | (0xa); + writel((readl(GAFR1_U) & ~(0xfff << 20)) | (0xaaa << 20), + GAFR1_U); + writel((readl(GAFR2_L) & ~0xf) | (0xa), GAFR2_L);
/* 16 bit interface */ @@ -407,11 +412,12 @@ static void pxafb_setup_gpio (vidinfo_t *vid) { debug("Setting GPIO for 16 bit data\n"); /* bits 58-77 */ - GPDR1 |= (0x3f << 26); - GPDR2 |= 0x00003fff; + writel(readl(GPDR1) | (0x3f << 26), GPDR1); + writel(readl(GPDR2) | 0x00003fff, GPDR2);
- GAFR1_U = (GAFR1_U & ~(0xfff << 20)) | (0xaaa << 20); - GAFR2_L = (GAFR2_L & 0xf0000000) | 0x0aaaaaaa; + writel((readl(GAFR1_U) & ~(0xfff << 20)) | (0xaaa << 20), + GAFR1_U); + writel((readl(GAFR2_L) & 0xf0000000) | 0x0aaaaaaa, GAFR2_L); } else { @@ -425,26 +431,26 @@ static void pxafb_enable_controller (vidinfo_t *vid) debug("Enabling LCD controller\n");
/* Sequence from 11.7.10 */ - LCCR3 = vid->pxa.reg_lccr3; - LCCR2 = vid->pxa.reg_lccr2; - LCCR1 = vid->pxa.reg_lccr1; - LCCR0 = vid->pxa.reg_lccr0 & ~LCCR0_ENB; - FDADR0 = vid->pxa.fdadr0; - FDADR1 = vid->pxa.fdadr1; - LCCR0 |= LCCR0_ENB; + writel(vid->pxa.reg_lccr3, LCCR3); + writel(vid->pxa.reg_lccr2, LCCR2); + writel(vid->pxa.reg_lccr1, LCCR1); + writel(vid->pxa.reg_lccr0 & ~LCCR0_ENB, LCCR0); + writel(vid->pxa.fdadr0, FDADR0); + writel(vid->pxa.fdadr1, FDADR1); + writel(readl(LCCR0) | LCCR0_ENB, LCCR0);
#ifdef CONFIG_CPU_MONAHANS - CKENA |= CKENA_1_LCD; + writel(readl(CKENA) | CKENA_1_LCD, CKENA); #else - CKEN |= CKEN16_LCD; + writel(readl(CKEN) | CKEN16_LCD, CKEN); #endif
- debug("FDADR0 = 0x%08x\n", (unsigned int)FDADR0); - debug("FDADR1 = 0x%08x\n", (unsigned int)FDADR1); - debug("LCCR0 = 0x%08x\n", (unsigned int)LCCR0); - debug("LCCR1 = 0x%08x\n", (unsigned int)LCCR1); - debug("LCCR2 = 0x%08x\n", (unsigned int)LCCR2); - debug("LCCR3 = 0x%08x\n", (unsigned int)LCCR3); + debug("FDADR0 = 0x%08x\n", readl(FDADR0)); + debug("FDADR1 = 0x%08x\n", readl(FDADR1)); + debug("LCCR0 = 0x%08x\n", readl(LCCR0)); + debug("LCCR1 = 0x%08x\n", readl(LCCR1)); + debug("LCCR2 = 0x%08x\n", readl(LCCR2)); + debug("LCCR3 = 0x%08x\n", readl(LCCR3)); }
static int pxafb_init (vidinfo_t *vid) diff --git a/arch/arm/cpu/pxa/timer.c b/arch/arm/cpu/pxa/timer.c index 8d0f826..ec950c7 100644 --- a/arch/arm/cpu/pxa/timer.c +++ b/arch/arm/cpu/pxa/timer.c @@ -26,8 +26,9 @@ * MA 02111-1307 USA */
-#include <common.h> #include <asm/arch/pxa-regs.h> +#include <asm/io.h> +#include <common.h> #include <div64.h>
#ifdef CONFIG_USE_IRQ @@ -86,7 +87,7 @@ void __udelay (unsigned long usec)
void reset_timer_masked (void) { - OSCR = 0; + writel(0, OSCR); }
ulong get_timer_masked (void) @@ -113,7 +114,7 @@ void udelay_masked (unsigned long usec) */ unsigned long long get_ticks(void) { - return OSCR; + return readl(OSCR); }
/* diff --git a/arch/arm/cpu/pxa/usb.c b/arch/arm/cpu/pxa/usb.c index bd718a6..0311d5e 100644 --- a/arch/arm/cpu/pxa/usb.c +++ b/arch/arm/cpu/pxa/usb.c @@ -27,86 +27,79 @@ # if defined(CONFIG_CPU_MONAHANS) || defined(CONFIG_PXA27X)
#include <asm/arch/pxa-regs.h> +#include <asm/io.h> #include <usb.h>
int usb_cpu_init(void) { #if defined(CONFIG_CPU_MONAHANS) /* Enable USB host clock. */ - CKENA |= (CKENA_2_USBHOST | CKENA_20_UDC); + writel(readl(CKENA) | CKENA_2_USBHOST | CKENA_20_UDC, CKENA); udelay(100); #endif #if defined(CONFIG_PXA27X) /* Enable USB host clock. */ - CKEN |= CKEN10_USBHOST; + writel(readl(CKEN) | CKEN10_USBHOST, CKEN); #endif
#if defined(CONFIG_CPU_MONAHANS) /* Configure Port 2 for Host (USB Client Registers) */ - UP2OCR = 0x3000c; + writel(0x3000c, UP2OCR); #endif
- UHCHR |= UHCHR_FHR; + writel(readl(UHCHR) | UHCHR_FHR, UHCHR); wait_ms(11); - UHCHR &= ~UHCHR_FHR; + writel(readl(UHCHR) & ~UHCHR_FHR, UHCHR);
- UHCHR |= UHCHR_FSBIR; - while (UHCHR & UHCHR_FSBIR) + writel(readl(UHCHR) | UHCHR_FSBIR, UHCHR); + while (readl(UHCHR) & UHCHR_FSBIR) udelay(1);
#if defined(CONFIG_CPU_MONAHANS) - UHCHR &= ~UHCHR_SSEP0; + writel(readl(UHCHR) & ~UHCHR_SSEP0, UHCHR); #endif #if defined(CONFIG_PXA27X) - UHCHR &= ~UHCHR_SSEP2; + writel(readl(UHCHR) & ~UHCHR_SSEP2, UHCHR); #endif - UHCHR &= ~UHCHR_SSEP1; - UHCHR &= ~UHCHR_SSE; + writel(readl(UHCHR) & ~(UHCHR_SSEP1 | UHCHR_SSE), UHCHR);
return 0; }
int usb_cpu_stop(void) { - UHCHR |= UHCHR_FHR; + writel(readl(UHCHR) | UHCHR_FHR, UHCHR); udelay(11); - UHCHR &= ~UHCHR_FHR; + writel(readl(UHCHR) & ~UHCHR_FHR, UHCHR);
- UHCCOMS |= 1; + writel(readl(UHCCOMS) | UHCHR_FHR, UHCCOMS); udelay(10);
#if defined(CONFIG_CPU_MONAHANS) - UHCHR |= UHCHR_SSEP0; + writel(readl(UHCHR) | UHCHR_SSEP0, UHCHR); #endif #if defined(CONFIG_PXA27X) - UHCHR |= UHCHR_SSEP2; + writel(readl(UHCHR) | UHCHR_SSEP2, UHCHR); #endif - UHCHR |= UHCHR_SSEP1; - UHCHR |= UHCHR_SSE; - - return 0; -} - -int usb_cpu_init_fail(void) -{ - UHCHR |= UHCHR_FHR; - udelay(11); - UHCHR &= ~UHCHR_FHR; - - UHCCOMS |= 1; - udelay(10); + writel(readl(UHCHR) | UHCHR_SSEP1 | UHCHR_SSE, UHCHR);
#if defined(CONFIG_CPU_MONAHANS) - UHCHR |= UHCHR_SSEP0; + /* Disable USB host clock. */ + writel(readl(CKENA) & ~(CKENA_2_USBHOST | CKENA_20_UDC), CKENA); + udelay(100); #endif #if defined(CONFIG_PXA27X) - UHCHR |= UHCHR_SSEP2; + /* Disable USB host clock. */ + writel(readl(CKEN) & ~CKEN10_USBHOST, CKEN); #endif - UHCHR |= UHCHR_SSEP1; - UHCHR |= UHCHR_SSE;
return 0; }
+int usb_cpu_init_fail(void) +{ + return usb_cpu_stop(); +} + # endif /* defined(CONFIG_CPU_MONAHANS) || defined(CONFIG_PXA27X) */ #endif /* defined(CONFIG_USB_OHCI) && defined(CONFIG_SYS_USB_OHCI_CPU_INIT) */ diff --git a/arch/arm/include/asm/arch-pxa/hardware.h b/arch/arm/include/asm/arch-pxa/hardware.h index c8c479a..44b800f 100644 --- a/arch/arm/include/asm/arch-pxa/hardware.h +++ b/arch/arm/include/asm/arch-pxa/hardware.h @@ -21,6 +21,19 @@ #include <linux/config.h> #include <asm/mach-types.h>
+/* + * Define CONFIG_CPU_MONAHANS in case some CPU of the PXA3xx family is selected. + * PXA300/310/320 all have distinct register mappings in some cases, that's why + * the exact CPU has to be selected. CONFIG_CPU_MONAHANS is a helper for common + * drivers and compatibility glue with old source then. + */ +#ifndef CONFIG_CPU_MONAHANS +#if defined(CONFIG_CPU_PXA300) || \ + defined(CONFIG_CPU_PXA310) || \ + defined(CONFIG_CPU_PXA320) +#define CONFIG_CPU_MONAHANS +#endif +#endif
/* * These are statically mapped PCMCIA IO space for designs using it as a @@ -51,54 +64,6 @@ * 0x48000000 - 0x49ffffff <--> 0xfc000000 - 0xfdffffff */
-/* FIXME: Only this does work for u-boot... find out why... [RS] */ -#define UBOOT_REG_FIX 1 - -#ifndef UBOOT_REG_FIX -#ifndef __ASSEMBLY__ - -#define io_p2v(x) ( ((x) | 0xbe000000) ^ (~((x) >> 1) & 0x06000000) ) -#define io_v2p( x ) ( ((x) & 0x41ffffff) ^ ( ((x) & 0x06000000) << 1) ) - -/* - * This __REG() version gives the same results as the one above, except - * that we are fooling gcc somehow so it generates far better and smaller - * assembly code for access to contigous registers. It's a shame that gcc - * doesn't guess this by itself. - */ -#include <asm/types.h> -typedef struct { volatile u32 offset[4096]; } __regbase; -# define __REGP(x) ((__regbase *)((x)&~4095))->offset[((x)&4095)>>2] -# define __REG(x) __REGP(io_p2v(x)) -#endif - -/* Let's kick gcc's ass again... */ -# define __REG2(x,y) \ - ( __builtin_constant_p(y) ? (__REG((x) + (y))) \ - : (*(volatile u32 *)((u32)&__REG(x) + (y))) ) - -# define __PREG(x) (io_v2p((u32)&(x))) - -#else - -# define __REG(x) io_p2v(x) -# define __PREG(x) io_v2p(x) - -# undef io_p2v -# undef __REG -# ifndef __ASSEMBLY__ -# define io_p2v(PhAdd) (PhAdd) -# define __REG(x) (*((volatile u32 *)io_p2v(x))) -# define __REG2(x,y) (*(volatile u32 *)((u32)&__REG(x) + (y))) -# else -# define __REG(x) (x) -# ifdef CONFIG_CPU_MONAHANS /* Hack to make this work with mona's pxa-regs.h */ -# define __REG_2(x) (x) -# define __REG_3(x) (x) -# endif -# endif -#endif /* UBOOT_REG_FIX */ - #include "pxa-regs.h"
#ifndef __ASSEMBLY__ diff --git a/arch/arm/include/asm/arch-pxa/pxa-regs.h b/arch/arm/include/asm/arch-pxa/pxa-regs.h index d442fb0..65a387f 100644 --- a/arch/arm/include/asm/arch-pxa/pxa-regs.h +++ b/arch/arm/include/asm/arch-pxa/pxa-regs.h @@ -93,42 +93,42 @@ typedef void (*ExcpHndlr) (void) ; /* * DMA Controller */ -#define DCSR0 __REG(0x40000000) /* DMA Control / Status Register for Channel 0 */ -#define DCSR1 __REG(0x40000004) /* DMA Control / Status Register for Channel 1 */ -#define DCSR2 __REG(0x40000008) /* DMA Control / Status Register for Channel 2 */ -#define DCSR3 __REG(0x4000000c) /* DMA Control / Status Register for Channel 3 */ -#define DCSR4 __REG(0x40000010) /* DMA Control / Status Register for Channel 4 */ -#define DCSR5 __REG(0x40000014) /* DMA Control / Status Register for Channel 5 */ -#define DCSR6 __REG(0x40000018) /* DMA Control / Status Register for Channel 6 */ -#define DCSR7 __REG(0x4000001c) /* DMA Control / Status Register for Channel 7 */ -#define DCSR8 __REG(0x40000020) /* DMA Control / Status Register for Channel 8 */ -#define DCSR9 __REG(0x40000024) /* DMA Control / Status Register for Channel 9 */ -#define DCSR10 __REG(0x40000028) /* DMA Control / Status Register for Channel 10 */ -#define DCSR11 __REG(0x4000002c) /* DMA Control / Status Register for Channel 11 */ -#define DCSR12 __REG(0x40000030) /* DMA Control / Status Register for Channel 12 */ -#define DCSR13 __REG(0x40000034) /* DMA Control / Status Register for Channel 13 */ -#define DCSR14 __REG(0x40000038) /* DMA Control / Status Register for Channel 14 */ -#define DCSR15 __REG(0x4000003c) /* DMA Control / Status Register for Channel 15 */ -#ifdef CONFIG_CPU_MONAHANS -#define DCSR16 __REG(0x40000040) /* DMA Control / Status Register for Channel 16 */ -#define DCSR17 __REG(0x40000044) /* DMA Control / Status Register for Channel 17 */ -#define DCSR18 __REG(0x40000048) /* DMA Control / Status Register for Channel 18 */ -#define DCSR19 __REG(0x4000004c) /* DMA Control / Status Register for Channel 19 */ -#define DCSR20 __REG(0x40000050) /* DMA Control / Status Register for Channel 20 */ -#define DCSR21 __REG(0x40000054) /* DMA Control / Status Register for Channel 21 */ -#define DCSR22 __REG(0x40000058) /* DMA Control / Status Register for Channel 22 */ -#define DCSR23 __REG(0x4000005c) /* DMA Control / Status Register for Channel 23 */ -#define DCSR24 __REG(0x40000060) /* DMA Control / Status Register for Channel 24 */ -#define DCSR25 __REG(0x40000064) /* DMA Control / Status Register for Channel 25 */ -#define DCSR26 __REG(0x40000068) /* DMA Control / Status Register for Channel 26 */ -#define DCSR27 __REG(0x4000006c) /* DMA Control / Status Register for Channel 27 */ -#define DCSR28 __REG(0x40000070) /* DMA Control / Status Register for Channel 28 */ -#define DCSR29 __REG(0x40000074) /* DMA Control / Status Register for Channel 29 */ -#define DCSR30 __REG(0x40000078) /* DMA Control / Status Register for Channel 30 */ -#define DCSR31 __REG(0x4000007c) /* DMA Control / Status Register for Channel 31 */ -#endif /* CONFIG_CPU_MONAHANS */ - -#define DCSR(x) __REG2(0x40000000, (x) << 2) +#define DCSR0 0x40000000 /* DMA Control / Status Register for Channel 0 */ +#define DCSR1 0x40000004 /* DMA Control / Status Register for Channel 1 */ +#define DCSR2 0x40000008 /* DMA Control / Status Register for Channel 2 */ +#define DCSR3 0x4000000c /* DMA Control / Status Register for Channel 3 */ +#define DCSR4 0x40000010 /* DMA Control / Status Register for Channel 4 */ +#define DCSR5 0x40000014 /* DMA Control / Status Register for Channel 5 */ +#define DCSR6 0x40000018 /* DMA Control / Status Register for Channel 6 */ +#define DCSR7 0x4000001c /* DMA Control / Status Register for Channel 7 */ +#define DCSR8 0x40000020 /* DMA Control / Status Register for Channel 8 */ +#define DCSR9 0x40000024 /* DMA Control / Status Register for Channel 9 */ +#define DCSR10 0x40000028 /* DMA Control / Status Register for Channel 10 */ +#define DCSR11 0x4000002c /* DMA Control / Status Register for Channel 11 */ +#define DCSR12 0x40000030 /* DMA Control / Status Register for Channel 12 */ +#define DCSR13 0x40000034 /* DMA Control / Status Register for Channel 13 */ +#define DCSR14 0x40000038 /* DMA Control / Status Register for Channel 14 */ +#define DCSR15 0x4000003c /* DMA Control / Status Register for Channel 15 */ +#if defined(CONFIG_PXA27X) || defined(CONFIG_CPU_MONAHANS) +#define DCSR16 0x40000040 /* DMA Control / Status Register for Channel 16 */ +#define DCSR17 0x40000044 /* DMA Control / Status Register for Channel 17 */ +#define DCSR18 0x40000048 /* DMA Control / Status Register for Channel 18 */ +#define DCSR19 0x4000004c /* DMA Control / Status Register for Channel 19 */ +#define DCSR20 0x40000050 /* DMA Control / Status Register for Channel 20 */ +#define DCSR21 0x40000054 /* DMA Control / Status Register for Channel 21 */ +#define DCSR22 0x40000058 /* DMA Control / Status Register for Channel 22 */ +#define DCSR23 0x4000005c /* DMA Control / Status Register for Channel 23 */ +#define DCSR24 0x40000060 /* DMA Control / Status Register for Channel 24 */ +#define DCSR25 0x40000064 /* DMA Control / Status Register for Channel 25 */ +#define DCSR26 0x40000068 /* DMA Control / Status Register for Channel 26 */ +#define DCSR27 0x4000006c /* DMA Control / Status Register for Channel 27 */ +#define DCSR28 0x40000070 /* DMA Control / Status Register for Channel 28 */ +#define DCSR29 0x40000074 /* DMA Control / Status Register for Channel 29 */ +#define DCSR30 0x40000078 /* DMA Control / Status Register for Channel 30 */ +#define DCSR31 0x4000007c /* DMA Control / Status Register for Channel 31 */ +#endif /* CONFIG_PXA27X || CONFIG_CPU_MONAHANS */ + +#define DCSR(x) (0x40000000 | ((x) << 2))
#define DCSR_RUN (1 << 31) /* Run Bit (read / write) */ #define DCSR_NODESC (1 << 30) /* No-Descriptor Fetch (read / write) */ @@ -150,52 +150,52 @@ typedef void (*ExcpHndlr) (void) ; #define DCSR_STARTINTR (1 << 1) /* Start Interrupt (read / write) */ #define DCSR_BUSERR (1 << 0) /* Bus Error Interrupt (read / write) */
-#define DINT __REG(0x400000f0) /* DMA Interrupt Register */ - -#define DRCMR0 __REG(0x40000100) /* Request to Channel Map Register for DREQ 0 */ -#define DRCMR1 __REG(0x40000104) /* Request to Channel Map Register for DREQ 1 */ -#define DRCMR2 __REG(0x40000108) /* Request to Channel Map Register for I2S receive Request */ -#define DRCMR3 __REG(0x4000010c) /* Request to Channel Map Register for I2S transmit Request */ -#define DRCMR4 __REG(0x40000110) /* Request to Channel Map Register for BTUART receive Request */ -#define DRCMR5 __REG(0x40000114) /* Request to Channel Map Register for BTUART transmit Request. */ -#define DRCMR6 __REG(0x40000118) /* Request to Channel Map Register for FFUART receive Request */ -#define DRCMR7 __REG(0x4000011c) /* Request to Channel Map Register for FFUART transmit Request */ -#define DRCMR8 __REG(0x40000120) /* Request to Channel Map Register for AC97 microphone Request */ -#define DRCMR9 __REG(0x40000124) /* Request to Channel Map Register for AC97 modem receive Request */ -#define DRCMR10 __REG(0x40000128) /* Request to Channel Map Register for AC97 modem transmit Request */ -#define DRCMR11 __REG(0x4000012c) /* Request to Channel Map Register for AC97 audio receive Request */ -#define DRCMR12 __REG(0x40000130) /* Request to Channel Map Register for AC97 audio transmit Request */ -#define DRCMR13 __REG(0x40000134) /* Request to Channel Map Register for SSP receive Request */ -#define DRCMR14 __REG(0x40000138) /* Request to Channel Map Register for SSP transmit Request */ -#define DRCMR15 __REG(0x4000013c) /* Reserved */ -#define DRCMR16 __REG(0x40000140) /* Reserved */ -#define DRCMR17 __REG(0x40000144) /* Request to Channel Map Register for ICP receive Request */ -#define DRCMR18 __REG(0x40000148) /* Request to Channel Map Register for ICP transmit Request */ -#define DRCMR19 __REG(0x4000014c) /* Request to Channel Map Register for STUART receive Request */ -#define DRCMR20 __REG(0x40000150) /* Request to Channel Map Register for STUART transmit Request */ -#define DRCMR21 __REG(0x40000154) /* Request to Channel Map Register for MMC receive Request */ -#define DRCMR22 __REG(0x40000158) /* Request to Channel Map Register for MMC transmit Request */ -#define DRCMR23 __REG(0x4000015c) /* Reserved */ -#define DRCMR24 __REG(0x40000160) /* Reserved */ -#define DRCMR25 __REG(0x40000164) /* Request to Channel Map Register for USB endpoint 1 Request */ -#define DRCMR26 __REG(0x40000168) /* Request to Channel Map Register for USB endpoint 2 Request */ -#define DRCMR27 __REG(0x4000016C) /* Request to Channel Map Register for USB endpoint 3 Request */ -#define DRCMR28 __REG(0x40000170) /* Request to Channel Map Register for USB endpoint 4 Request */ -#define DRCMR29 __REG(0x40000174) /* Reserved */ -#define DRCMR30 __REG(0x40000178) /* Request to Channel Map Register for USB endpoint 6 Request */ -#define DRCMR31 __REG(0x4000017C) /* Request to Channel Map Register for USB endpoint 7 Request */ -#define DRCMR32 __REG(0x40000180) /* Request to Channel Map Register for USB endpoint 8 Request */ -#define DRCMR33 __REG(0x40000184) /* Request to Channel Map Register for USB endpoint 9 Request */ -#define DRCMR34 __REG(0x40000188) /* Reserved */ -#define DRCMR35 __REG(0x4000018C) /* Request to Channel Map Register for USB endpoint 11 Request */ -#define DRCMR36 __REG(0x40000190) /* Request to Channel Map Register for USB endpoint 12 Request */ -#define DRCMR37 __REG(0x40000194) /* Request to Channel Map Register for USB endpoint 13 Request */ -#define DRCMR38 __REG(0x40000198) /* Request to Channel Map Register for USB endpoint 14 Request */ -#define DRCMR39 __REG(0x4000019C) /* Reserved */ - -#define DRCMR68 __REG(0x40001110) /* Request to Channel Map Register for Camera FIFO 0 Request */ -#define DRCMR69 __REG(0x40001114) /* Request to Channel Map Register for Camera FIFO 1 Request */ -#define DRCMR70 __REG(0x40001118) /* Request to Channel Map Register for Camera FIFO 2 Request */ +#define DINT 0x400000f0 /* DMA Interrupt Register */ + +#define DRCMR0 0x40000100 /* Request to Channel Map Register for DREQ 0 */ +#define DRCMR1 0x40000104 /* Request to Channel Map Register for DREQ 1 */ +#define DRCMR2 0x40000108 /* Request to Channel Map Register for I2S receive Request */ +#define DRCMR3 0x4000010c /* Request to Channel Map Register for I2S transmit Request */ +#define DRCMR4 0x40000110 /* Request to Channel Map Register for BTUART receive Request */ +#define DRCMR5 0x40000114 /* Request to Channel Map Register for BTUART transmit Request. */ +#define DRCMR6 0x40000118 /* Request to Channel Map Register for FFUART receive Request */ +#define DRCMR7 0x4000011c /* Request to Channel Map Register for FFUART transmit Request */ +#define DRCMR8 0x40000120 /* Request to Channel Map Register for AC97 microphone Request */ +#define DRCMR9 0x40000124 /* Request to Channel Map Register for AC97 modem receive Request */ +#define DRCMR10 0x40000128 /* Request to Channel Map Register for AC97 modem transmit Request */ +#define DRCMR11 0x4000012c /* Request to Channel Map Register for AC97 audio receive Request */ +#define DRCMR12 0x40000130 /* Request to Channel Map Register for AC97 audio transmit Request */ +#define DRCMR13 0x40000134 /* Request to Channel Map Register for SSP receive Request */ +#define DRCMR14 0x40000138 /* Request to Channel Map Register for SSP transmit Request */ +#define DRCMR15 0x4000013c /* Reserved */ +#define DRCMR16 0x40000140 /* Reserved */ +#define DRCMR17 0x40000144 /* Request to Channel Map Register for ICP receive Request */ +#define DRCMR18 0x40000148 /* Request to Channel Map Register for ICP transmit Request */ +#define DRCMR19 0x4000014c /* Request to Channel Map Register for STUART receive Request */ +#define DRCMR20 0x40000150 /* Request to Channel Map Register for STUART transmit Request */ +#define DRCMR21 0x40000154 /* Request to Channel Map Register for MMC receive Request */ +#define DRCMR22 0x40000158 /* Request to Channel Map Register for MMC transmit Request */ +#define DRCMR23 0x4000015c /* Reserved */ +#define DRCMR24 0x40000160 /* Reserved */ +#define DRCMR25 0x40000164 /* Request to Channel Map Register for USB endpoint 1 Request */ +#define DRCMR26 0x40000168 /* Request to Channel Map Register for USB endpoint 2 Request */ +#define DRCMR27 0x4000016C /* Request to Channel Map Register for USB endpoint 3 Request */ +#define DRCMR28 0x40000170 /* Request to Channel Map Register for USB endpoint 4 Request */ +#define DRCMR29 0x40000174 /* Reserved */ +#define DRCMR30 0x40000178 /* Request to Channel Map Register for USB endpoint 6 Request */ +#define DRCMR31 0x4000017C /* Request to Channel Map Register for USB endpoint 7 Request */ +#define DRCMR32 0x40000180 /* Request to Channel Map Register for USB endpoint 8 Request */ +#define DRCMR33 0x40000184 /* Request to Channel Map Register for USB endpoint 9 Request */ +#define DRCMR34 0x40000188 /* Reserved */ +#define DRCMR35 0x4000018C /* Request to Channel Map Register for USB endpoint 11 Request */ +#define DRCMR36 0x40000190 /* Request to Channel Map Register for USB endpoint 12 Request */ +#define DRCMR37 0x40000194 /* Request to Channel Map Register for USB endpoint 13 Request */ +#define DRCMR38 0x40000198 /* Request to Channel Map Register for USB endpoint 14 Request */ +#define DRCMR39 0x4000019C /* Reserved */ + +#define DRCMR68 0x40001110 /* Request to Channel Map Register for Camera FIFO 0 Request */ +#define DRCMR69 0x40001114 /* Request to Channel Map Register for Camera FIFO 1 Request */ +#define DRCMR70 0x40001118 /* Request to Channel Map Register for Camera FIFO 2 Request */
#define DRCMRRXSADR DRCMR2 #define DRCMRTXSADR DRCMR3 @@ -220,75 +220,75 @@ typedef void (*ExcpHndlr) (void) ; #define DRCMR_MAPVLD (1 << 7) /* Map Valid (read / write) */ #define DRCMR_CHLNUM 0x0f /* mask for Channel Number (read / write) */
-#define DDADR0 __REG(0x40000200) /* DMA Descriptor Address Register Channel 0 */ -#define DSADR0 __REG(0x40000204) /* DMA Source Address Register Channel 0 */ -#define DTADR0 __REG(0x40000208) /* DMA Target Address Register Channel 0 */ -#define DCMD0 __REG(0x4000020c) /* DMA Command Address Register Channel 0 */ -#define DDADR1 __REG(0x40000210) /* DMA Descriptor Address Register Channel 1 */ -#define DSADR1 __REG(0x40000214) /* DMA Source Address Register Channel 1 */ -#define DTADR1 __REG(0x40000218) /* DMA Target Address Register Channel 1 */ -#define DCMD1 __REG(0x4000021c) /* DMA Command Address Register Channel 1 */ -#define DDADR2 __REG(0x40000220) /* DMA Descriptor Address Register Channel 2 */ -#define DSADR2 __REG(0x40000224) /* DMA Source Address Register Channel 2 */ -#define DTADR2 __REG(0x40000228) /* DMA Target Address Register Channel 2 */ -#define DCMD2 __REG(0x4000022c) /* DMA Command Address Register Channel 2 */ -#define DDADR3 __REG(0x40000230) /* DMA Descriptor Address Register Channel 3 */ -#define DSADR3 __REG(0x40000234) /* DMA Source Address Register Channel 3 */ -#define DTADR3 __REG(0x40000238) /* DMA Target Address Register Channel 3 */ -#define DCMD3 __REG(0x4000023c) /* DMA Command Address Register Channel 3 */ -#define DDADR4 __REG(0x40000240) /* DMA Descriptor Address Register Channel 4 */ -#define DSADR4 __REG(0x40000244) /* DMA Source Address Register Channel 4 */ -#define DTADR4 __REG(0x40000248) /* DMA Target Address Register Channel 4 */ -#define DCMD4 __REG(0x4000024c) /* DMA Command Address Register Channel 4 */ -#define DDADR5 __REG(0x40000250) /* DMA Descriptor Address Register Channel 5 */ -#define DSADR5 __REG(0x40000254) /* DMA Source Address Register Channel 5 */ -#define DTADR5 __REG(0x40000258) /* DMA Target Address Register Channel 5 */ -#define DCMD5 __REG(0x4000025c) /* DMA Command Address Register Channel 5 */ -#define DDADR6 __REG(0x40000260) /* DMA Descriptor Address Register Channel 6 */ -#define DSADR6 __REG(0x40000264) /* DMA Source Address Register Channel 6 */ -#define DTADR6 __REG(0x40000268) /* DMA Target Address Register Channel 6 */ -#define DCMD6 __REG(0x4000026c) /* DMA Command Address Register Channel 6 */ -#define DDADR7 __REG(0x40000270) /* DMA Descriptor Address Register Channel 7 */ -#define DSADR7 __REG(0x40000274) /* DMA Source Address Register Channel 7 */ -#define DTADR7 __REG(0x40000278) /* DMA Target Address Register Channel 7 */ -#define DCMD7 __REG(0x4000027c) /* DMA Command Address Register Channel 7 */ -#define DDADR8 __REG(0x40000280) /* DMA Descriptor Address Register Channel 8 */ -#define DSADR8 __REG(0x40000284) /* DMA Source Address Register Channel 8 */ -#define DTADR8 __REG(0x40000288) /* DMA Target Address Register Channel 8 */ -#define DCMD8 __REG(0x4000028c) /* DMA Command Address Register Channel 8 */ -#define DDADR9 __REG(0x40000290) /* DMA Descriptor Address Register Channel 9 */ -#define DSADR9 __REG(0x40000294) /* DMA Source Address Register Channel 9 */ -#define DTADR9 __REG(0x40000298) /* DMA Target Address Register Channel 9 */ -#define DCMD9 __REG(0x4000029c) /* DMA Command Address Register Channel 9 */ -#define DDADR10 __REG(0x400002a0) /* DMA Descriptor Address Register Channel 10 */ -#define DSADR10 __REG(0x400002a4) /* DMA Source Address Register Channel 10 */ -#define DTADR10 __REG(0x400002a8) /* DMA Target Address Register Channel 10 */ -#define DCMD10 __REG(0x400002ac) /* DMA Command Address Register Channel 10 */ -#define DDADR11 __REG(0x400002b0) /* DMA Descriptor Address Register Channel 11 */ -#define DSADR11 __REG(0x400002b4) /* DMA Source Address Register Channel 11 */ -#define DTADR11 __REG(0x400002b8) /* DMA Target Address Register Channel 11 */ -#define DCMD11 __REG(0x400002bc) /* DMA Command Address Register Channel 11 */ -#define DDADR12 __REG(0x400002c0) /* DMA Descriptor Address Register Channel 12 */ -#define DSADR12 __REG(0x400002c4) /* DMA Source Address Register Channel 12 */ -#define DTADR12 __REG(0x400002c8) /* DMA Target Address Register Channel 12 */ -#define DCMD12 __REG(0x400002cc) /* DMA Command Address Register Channel 12 */ -#define DDADR13 __REG(0x400002d0) /* DMA Descriptor Address Register Channel 13 */ -#define DSADR13 __REG(0x400002d4) /* DMA Source Address Register Channel 13 */ -#define DTADR13 __REG(0x400002d8) /* DMA Target Address Register Channel 13 */ -#define DCMD13 __REG(0x400002dc) /* DMA Command Address Register Channel 13 */ -#define DDADR14 __REG(0x400002e0) /* DMA Descriptor Address Register Channel 14 */ -#define DSADR14 __REG(0x400002e4) /* DMA Source Address Register Channel 14 */ -#define DTADR14 __REG(0x400002e8) /* DMA Target Address Register Channel 14 */ -#define DCMD14 __REG(0x400002ec) /* DMA Command Address Register Channel 14 */ -#define DDADR15 __REG(0x400002f0) /* DMA Descriptor Address Register Channel 15 */ -#define DSADR15 __REG(0x400002f4) /* DMA Source Address Register Channel 15 */ -#define DTADR15 __REG(0x400002f8) /* DMA Target Address Register Channel 15 */ -#define DCMD15 __REG(0x400002fc) /* DMA Command Address Register Channel 15 */ - -#define DDADR(x) __REG2(0x40000200, (x) << 4) -#define DSADR(x) __REG2(0x40000204, (x) << 4) -#define DTADR(x) __REG2(0x40000208, (x) << 4) -#define DCMD(x) __REG2(0x4000020c, (x) << 4) +#define DDADR0 0x40000200 /* DMA Descriptor Address Register Channel 0 */ +#define DSADR0 0x40000204 /* DMA Source Address Register Channel 0 */ +#define DTADR0 0x40000208 /* DMA Target Address Register Channel 0 */ +#define DCMD0 0x4000020c /* DMA Command Address Register Channel 0 */ +#define DDADR1 0x40000210 /* DMA Descriptor Address Register Channel 1 */ +#define DSADR1 0x40000214 /* DMA Source Address Register Channel 1 */ +#define DTADR1 0x40000218 /* DMA Target Address Register Channel 1 */ +#define DCMD1 0x4000021c /* DMA Command Address Register Channel 1 */ +#define DDADR2 0x40000220 /* DMA Descriptor Address Register Channel 2 */ +#define DSADR2 0x40000224 /* DMA Source Address Register Channel 2 */ +#define DTADR2 0x40000228 /* DMA Target Address Register Channel 2 */ +#define DCMD2 0x4000022c /* DMA Command Address Register Channel 2 */ +#define DDADR3 0x40000230 /* DMA Descriptor Address Register Channel 3 */ +#define DSADR3 0x40000234 /* DMA Source Address Register Channel 3 */ +#define DTADR3 0x40000238 /* DMA Target Address Register Channel 3 */ +#define DCMD3 0x4000023c /* DMA Command Address Register Channel 3 */ +#define DDADR4 0x40000240 /* DMA Descriptor Address Register Channel 4 */ +#define DSADR4 0x40000244 /* DMA Source Address Register Channel 4 */ +#define DTADR4 0x40000248 /* DMA Target Address Register Channel 4 */ +#define DCMD4 0x4000024c /* DMA Command Address Register Channel 4 */ +#define DDADR5 0x40000250 /* DMA Descriptor Address Register Channel 5 */ +#define DSADR5 0x40000254 /* DMA Source Address Register Channel 5 */ +#define DTADR5 0x40000258 /* DMA Target Address Register Channel 5 */ +#define DCMD5 0x4000025c /* DMA Command Address Register Channel 5 */ +#define DDADR6 0x40000260 /* DMA Descriptor Address Register Channel 6 */ +#define DSADR6 0x40000264 /* DMA Source Address Register Channel 6 */ +#define DTADR6 0x40000268 /* DMA Target Address Register Channel 6 */ +#define DCMD6 0x4000026c /* DMA Command Address Register Channel 6 */ +#define DDADR7 0x40000270 /* DMA Descriptor Address Register Channel 7 */ +#define DSADR7 0x40000274 /* DMA Source Address Register Channel 7 */ +#define DTADR7 0x40000278 /* DMA Target Address Register Channel 7 */ +#define DCMD7 0x4000027c /* DMA Command Address Register Channel 7 */ +#define DDADR8 0x40000280 /* DMA Descriptor Address Register Channel 8 */ +#define DSADR8 0x40000284 /* DMA Source Address Register Channel 8 */ +#define DTADR8 0x40000288 /* DMA Target Address Register Channel 8 */ +#define DCMD8 0x4000028c /* DMA Command Address Register Channel 8 */ +#define DDADR9 0x40000290 /* DMA Descriptor Address Register Channel 9 */ +#define DSADR9 0x40000294 /* DMA Source Address Register Channel 9 */ +#define DTADR9 0x40000298 /* DMA Target Address Register Channel 9 */ +#define DCMD9 0x4000029c /* DMA Command Address Register Channel 9 */ +#define DDADR10 0x400002a0 /* DMA Descriptor Address Register Channel 10 */ +#define DSADR10 0x400002a4 /* DMA Source Address Register Channel 10 */ +#define DTADR10 0x400002a8 /* DMA Target Address Register Channel 10 */ +#define DCMD10 0x400002ac /* DMA Command Address Register Channel 10 */ +#define DDADR11 0x400002b0 /* DMA Descriptor Address Register Channel 11 */ +#define DSADR11 0x400002b4 /* DMA Source Address Register Channel 11 */ +#define DTADR11 0x400002b8 /* DMA Target Address Register Channel 11 */ +#define DCMD11 0x400002bc /* DMA Command Address Register Channel 11 */ +#define DDADR12 0x400002c0 /* DMA Descriptor Address Register Channel 12 */ +#define DSADR12 0x400002c4 /* DMA Source Address Register Channel 12 */ +#define DTADR12 0x400002c8 /* DMA Target Address Register Channel 12 */ +#define DCMD12 0x400002cc /* DMA Command Address Register Channel 12 */ +#define DDADR13 0x400002d0 /* DMA Descriptor Address Register Channel 13 */ +#define DSADR13 0x400002d4 /* DMA Source Address Register Channel 13 */ +#define DTADR13 0x400002d8 /* DMA Target Address Register Channel 13 */ +#define DCMD13 0x400002dc /* DMA Command Address Register Channel 13 */ +#define DDADR14 0x400002e0 /* DMA Descriptor Address Register Channel 14 */ +#define DSADR14 0x400002e4 /* DMA Source Address Register Channel 14 */ +#define DTADR14 0x400002e8 /* DMA Target Address Register Channel 14 */ +#define DCMD14 0x400002ec /* DMA Command Address Register Channel 14 */ +#define DDADR15 0x400002f0 /* DMA Descriptor Address Register Channel 15 */ +#define DSADR15 0x400002f4 /* DMA Source Address Register Channel 15 */ +#define DTADR15 0x400002f8 /* DMA Target Address Register Channel 15 */ +#define DCMD15 0x400002fc /* DMA Command Address Register Channel 15 */ + +#define DDADR(x) (0x40000200 | ((x) << 4)) +#define DSADR(x) (0x40000204 | ((x) << 4)) +#define DTADR(x) (0x40000208 | ((x) << 4)) +#define DCMD(x) (0x4000020c | ((x) << 4))
#define DDADR_DESCADDR 0xfffffff0 /* Address of next descriptor (mask) */ #define DDADR_STOP (1 << 0) /* Stop (read / write) */ @@ -313,56 +313,57 @@ typedef void (*ExcpHndlr) (void) ; #define DCMD_RXMCDR (DCMD_INCTRGADDR|DCMD_FLOWSRC|DCMD_BURST32|DCMD_WIDTH4) #define DCMD_TXPCDR (DCMD_INCSRCADDR|DCMD_FLOWTRG|DCMD_BURST32|DCMD_WIDTH4)
+/******************************************************************************/ /* * UARTs */ /* Full Function UART (FFUART) */ #define FFUART FFRBR -#define FFRBR __REG(0x40100000) /* Receive Buffer Register (read only) */ -#define FFTHR __REG(0x40100000) /* Transmit Holding Register (write only) */ -#define FFIER __REG(0x40100004) /* Interrupt Enable Register (read/write) */ -#define FFIIR __REG(0x40100008) /* Interrupt ID Register (read only) */ -#define FFFCR __REG(0x40100008) /* FIFO Control Register (write only) */ -#define FFLCR __REG(0x4010000C) /* Line Control Register (read/write) */ -#define FFMCR __REG(0x40100010) /* Modem Control Register (read/write) */ -#define FFLSR __REG(0x40100014) /* Line Status Register (read only) */ -#define FFMSR __REG(0x40100018) /* Modem Status Register (read only) */ -#define FFSPR __REG(0x4010001C) /* Scratch Pad Register (read/write) */ -#define FFISR __REG(0x40100020) /* Infrared Selection Register (read/write) */ -#define FFDLL __REG(0x40100000) /* Divisor Latch Low Register (DLAB = 1) (read/write) */ -#define FFDLH __REG(0x40100004) /* Divisor Latch High Register (DLAB = 1) (read/write) */ +#define FFRBR 0x40100000 /* Receive Buffer Register (read only) */ +#define FFTHR 0x40100000 /* Transmit Holding Register (write only) */ +#define FFIER 0x40100004 /* Interrupt Enable Register (read/write) */ +#define FFIIR 0x40100008 /* Interrupt ID Register (read only) */ +#define FFFCR 0x40100008 /* FIFO Control Register (write only) */ +#define FFLCR 0x4010000C /* Line Control Register (read/write) */ +#define FFMCR 0x40100010 /* Modem Control Register (read/write) */ +#define FFLSR 0x40100014 /* Line Status Register (read only) */ +#define FFMSR 0x40100018 /* Modem Status Register (read only) */ +#define FFSPR 0x4010001C /* Scratch Pad Register (read/write) */ +#define FFISR 0x40100020 /* Infrared Selection Register (read/write) */ +#define FFDLL 0x40100000 /* Divisor Latch Low Register (DLAB = 1) (read/write) */ +#define FFDLH 0x40100004 /* Divisor Latch High Register (DLAB = 1) (read/write) */
/* Bluetooth UART (BTUART) */ #define BTUART BTRBR -#define BTRBR __REG(0x40200000) /* Receive Buffer Register (read only) */ -#define BTTHR __REG(0x40200000) /* Transmit Holding Register (write only) */ -#define BTIER __REG(0x40200004) /* Interrupt Enable Register (read/write) */ -#define BTIIR __REG(0x40200008) /* Interrupt ID Register (read only) */ -#define BTFCR __REG(0x40200008) /* FIFO Control Register (write only) */ -#define BTLCR __REG(0x4020000C) /* Line Control Register (read/write) */ -#define BTMCR __REG(0x40200010) /* Modem Control Register (read/write) */ -#define BTLSR __REG(0x40200014) /* Line Status Register (read only) */ -#define BTMSR __REG(0x40200018) /* Modem Status Register (read only) */ -#define BTSPR __REG(0x4020001C) /* Scratch Pad Register (read/write) */ -#define BTISR __REG(0x40200020) /* Infrared Selection Register (read/write) */ -#define BTDLL __REG(0x40200000) /* Divisor Latch Low Register (DLAB = 1) (read/write) */ -#define BTDLH __REG(0x40200004) /* Divisor Latch High Register (DLAB = 1) (read/write) */ +#define BTRBR 0x40200000 /* Receive Buffer Register (read only) */ +#define BTTHR 0x40200000 /* Transmit Holding Register (write only) */ +#define BTIER 0x40200004 /* Interrupt Enable Register (read/write) */ +#define BTIIR 0x40200008 /* Interrupt ID Register (read only) */ +#define BTFCR 0x40200008 /* FIFO Control Register (write only) */ +#define BTLCR 0x4020000C /* Line Control Register (read/write) */ +#define BTMCR 0x40200010 /* Modem Control Register (read/write) */ +#define BTLSR 0x40200014 /* Line Status Register (read only) */ +#define BTMSR 0x40200018 /* Modem Status Register (read only) */ +#define BTSPR 0x4020001C /* Scratch Pad Register (read/write) */ +#define BTISR 0x40200020 /* Infrared Selection Register (read/write) */ +#define BTDLL 0x40200000 /* Divisor Latch Low Register (DLAB = 1) (read/write) */ +#define BTDLH 0x40200004 /* Divisor Latch High Register (DLAB = 1) (read/write) */
/* Standard UART (STUART) */ #define STUART STRBR -#define STRBR __REG(0x40700000) /* Receive Buffer Register (read only) */ -#define STTHR __REG(0x40700000) /* Transmit Holding Register (write only) */ -#define STIER __REG(0x40700004) /* Interrupt Enable Register (read/write) */ -#define STIIR __REG(0x40700008) /* Interrupt ID Register (read only) */ -#define STFCR __REG(0x40700008) /* FIFO Control Register (write only) */ -#define STLCR __REG(0x4070000C) /* Line Control Register (read/write) */ -#define STMCR __REG(0x40700010) /* Modem Control Register (read/write) */ -#define STLSR __REG(0x40700014) /* Line Status Register (read only) */ -#define STMSR __REG(0x40700018) /* Reserved */ -#define STSPR __REG(0x4070001C) /* Scratch Pad Register (read/write) */ -#define STISR __REG(0x40700020) /* Infrared Selection Register (read/write) */ -#define STDLL __REG(0x40700000) /* Divisor Latch Low Register (DLAB = 1) (read/write) */ -#define STDLH __REG(0x40700004) /* Divisor Latch High Register (DLAB = 1) (read/write) */ +#define STRBR 0x40700000 /* Receive Buffer Register (read only) */ +#define STTHR 0x40700000 /* Transmit Holding Register (write only) */ +#define STIER 0x40700004 /* Interrupt Enable Register (read/write) */ +#define STIIR 0x40700008 /* Interrupt ID Register (read only) */ +#define STFCR 0x40700008 /* FIFO Control Register (write only) */ +#define STLCR 0x4070000C /* Line Control Register (read/write) */ +#define STMCR 0x40700010 /* Modem Control Register (read/write) */ +#define STLSR 0x40700014 /* Line Status Register (read only) */ +#define STMSR 0x40700018 /* Reserved */ +#define STSPR 0x4070001C /* Scratch Pad Register (read/write) */ +#define STISR 0x40700020 /* Infrared Selection Register (read/write) */ +#define STDLL 0x40700000 /* Divisor Latch Low Register (DLAB = 1) (read/write) */ +#define STDLH 0x40700004 /* Divisor Latch High Register (DLAB = 1) (read/write) */
#define IER_DMAE (1 << 7) /* DMA Requests Enable */ #define IER_UUE (1 << 6) /* UART Unit Enable */ @@ -408,7 +409,7 @@ typedef void (*ExcpHndlr) (void) ; #define LSR_OE (1 << 1) /* Overrun Error */ #define LSR_DR (1 << 0) /* Data Ready */
-#define MCR_LOOP (1 << 4) */ +#define MCR_LOOP (1 << 4) /* */ #define MCR_OUT2 (1 << 3) /* force MSR_DCD in loopback mode */ #define MCR_OUT1 (1 << 2) /* force MSR_RI in loopback mode */ #define MCR_RTS (1 << 1) /* Request to Send */ @@ -423,6 +424,7 @@ typedef void (*ExcpHndlr) (void) ; #define MSR_DDSR (1 << 1) /* Delta Data Set Ready */ #define MSR_DCTS (1 << 0) /* Delta Clear To Send */
+/******************************************************************************/ /* * IrSR (Infrared Selection Register) */ @@ -456,17 +458,25 @@ typedef void (*ExcpHndlr) (void) ; /* * I2C registers */ -#define IBMR __REG(0x40301680) /* I2C Bus Monitor Register - IBMR */ -#define IDBR __REG(0x40301688) /* I2C Data Buffer Register - IDBR */ -#define ICR __REG(0x40301690) /* I2C Control Register - ICR */ -#define ISR __REG(0x40301698) /* I2C Status Register - ISR */ -#define ISAR __REG(0x403016A0) /* I2C Slave Address Register - ISAR */ - -#define PWRIBMR __REG(0x40f00180) /* Power I2C Bus Monitor Register-IBMR */ -#define PWRIDBR __REG(0x40f00188) /* Power I2C Data Buffer Register-IDBR */ -#define PWRICR __REG(0x40f00190) /* Power I2C Control Register - ICR */ -#define PWRISR __REG(0x40f00198) /* Power I2C Status Register - ISR */ -#define PWRISAR __REG(0x40f001A0) /* Power I2C Slave Address Register-ISAR */ +#define IBMR 0x40301680 /* I2C Bus Monitor Register - IBMR */ +#define IDBR 0x40301688 /* I2C Data Buffer Register - IDBR */ +#define ICR 0x40301690 /* I2C Control Register - ICR */ +#define ISR 0x40301698 /* I2C Status Register - ISR */ +#define ISAR 0x403016A0 /* I2C Slave Address Register - ISAR */ + +#ifdef CONFIG_CPU_MONAHANS +#define PWRIBMR 0x40f500C0 /* Power I2C Bus Monitor Register-IBMR */ +#define PWRIDBR 0x40f500C4 /* Power I2C Data Buffer Register-IDBR */ +#define PWRICR 0x40f500C8 /* Power I2C Control Register - ICR */ +#define PWRISR 0x40f500CC /* Power I2C Status Register - ISR */ +#define PWRISAR 0x40f500D0 /* Power I2C Slave Address Register-ISAR */ +#else +#define PWRIBMR 0x40f00180 /* Power I2C Bus Monitor Register-IBMR */ +#define PWRIDBR 0x40f00188 /* Power I2C Data Buffer Register-IDBR */ +#define PWRICR 0x40f00190 /* Power I2C Control Register - ICR */ +#define PWRISR 0x40f00198 /* Power I2C Status Register - ISR */ +#define PWRISAR 0x40f001A0 /* Power I2C Slave Address Register-ISAR */ +#endif
/* ----- Control register bits ---------------------------------------- */
@@ -507,28 +517,27 @@ typedef void (*ExcpHndlr) (void) ; /* FIXME the audio defines collide w/ the SA1111 defines. I don't like these * short defines because there is too much chance of namespace collision */ -/*#define SACR0 __REG(0x40400000) / Global Control Register */ -/*#define SACR1 __REG(0x40400004) / Serial Audio I 2 S/MSB-Justified Control Register */ -/*#define SASR0 __REG(0x4040000C) / Serial Audio I 2 S/MSB-Justified Interface and FIFO Status Register */ -/*#define SAIMR __REG(0x40400014) / Serial Audio Interrupt Mask Register */ -/*#define SAICR __REG(0x40400018) / Serial Audio Interrupt Clear Register */ -/*#define SADIV __REG(0x40400060) / Audio Clock Divider Register. */ -/*#define SADR __REG(0x40400080) / Serial Audio Data Register (TX and RX FIFO access Register). */ - +#define SACR0 0x40400000 /* Global Control Register */ +#define SACR1 0x40400004 /* Serial Audio I 2 S/MSB-Justified Control Register */ +#define SASR0 0x4040000C /* Serial Audio I 2 S/MSB-Justified Interface and FIFO Status Register */ +#define SAIMR 0x40400014 /* Serial Audio Interrupt Mask Register */ +#define SAICR 0x40400018 /* Serial Audio Interrupt Clear Register */ +#define SADIV 0x40400060 /* Audio Clock Divider Register. */ +#define SADR 0x40400080 /* Serial Audio Data Register (TX and RX FIFO access Register). */
/* * AC97 Controller registers */ -#define POCR __REG(0x40500000) /* PCM Out Control Register */ +#define POCR 0x40500000 /* PCM Out Control Register */ #define POCR_FEIE (1 << 3) /* FIFO Error Interrupt Enable */
-#define PICR __REG(0x40500004) /* PCM In Control Register */ +#define PICR 0x40500004 /* PCM In Control Register */ #define PICR_FEIE (1 << 3) /* FIFO Error Interrupt Enable */
-#define MCCR __REG(0x40500008) /* Mic In Control Register */ +#define MCCR 0x40500008 /* Mic In Control Register */ #define MCCR_FEIE (1 << 3) /* FIFO Error Interrupt Enable */
-#define GCR __REG(0x4050000C) /* Global Control Register */ +#define GCR 0x4050000C /* Global Control Register */ #define GCR_CDONE_IE (1 << 19) /* Command Done Interrupt Enable */ #define GCR_SDONE_IE (1 << 18) /* Status Done Interrupt Enable */ #define GCR_SECRDY_IEN (1 << 9) /* Secondary Ready Interrupt Enable */ @@ -540,16 +549,16 @@ typedef void (*ExcpHndlr) (void) ; #define GCR_COLD_RST (1 << 1) /* AC'97 Cold Reset (0 = active) */ #define GCR_GIE (1 << 0) /* Codec GPI Interrupt Enable */
-#define POSR __REG(0x40500010) /* PCM Out Status Register */ +#define POSR 0x40500010 /* PCM Out Status Register */ #define POSR_FIFOE (1 << 4) /* FIFO error */
-#define PISR __REG(0x40500014) /* PCM In Status Register */ +#define PISR 0x40500014 /* PCM In Status Register */ #define PISR_FIFOE (1 << 4) /* FIFO error */
-#define MCSR __REG(0x40500018) /* Mic In Status Register */ +#define MCSR 0x40500018 /* Mic In Status Register */ #define MCSR_FIFOE (1 << 4) /* FIFO error */
-#define GSR __REG(0x4050001C) /* Global Status Register */ +#define GSR 0x4050001C /* Global Status Register */ #define GSR_CDONE (1 << 19) /* Command Done */ #define GSR_SDONE (1 << 18) /* Status Done */ #define GSR_RDCS (1 << 15) /* Read Completion Status */ @@ -567,38 +576,38 @@ typedef void (*ExcpHndlr) (void) ; #define GSR_MIINT (1 << 1) /* Modem In Interrupt */ #define GSR_GSCI (1 << 0) /* Codec GPI Status Change Interrupt */
-#define CAR __REG(0x40500020) /* CODEC Access Register */ +#define CAR 0x40500020 /* CODEC Access Register */ #define CAR_CAIP (1 << 0) /* Codec Access In Progress */
-#define PCDR __REG(0x40500040) /* PCM FIFO Data Register */ -#define MCDR __REG(0x40500060) /* Mic-in FIFO Data Register */ +#define PCDR 0x40500040 /* PCM FIFO Data Register */ +#define MCDR 0x40500060 /* Mic-in FIFO Data Register */
-#define MOCR __REG(0x40500100) /* Modem Out Control Register */ +#define MOCR 0x40500100 /* Modem Out Control Register */ #define MOCR_FEIE (1 << 3) /* FIFO Error */
-#define MICR __REG(0x40500108) /* Modem In Control Register */ +#define MICR 0x40500108 /* Modem In Control Register */ #define MICR_FEIE (1 << 3) /* FIFO Error */
-#define MOSR __REG(0x40500110) /* Modem Out Status Register */ +#define MOSR 0x40500110 /* Modem Out Status Register */ #define MOSR_FIFOE (1 << 4) /* FIFO error */
-#define MISR __REG(0x40500118) /* Modem In Status Register */ +#define MISR 0x40500118 /* Modem In Status Register */ #define MISR_FIFOE (1 << 4) /* FIFO error */
-#define MODR __REG(0x40500140) /* Modem FIFO Data Register */ +#define MODR 0x40500140 /* Modem FIFO Data Register */
-#define PAC_REG_BASE __REG(0x40500200) /* Primary Audio Codec */ -#define SAC_REG_BASE __REG(0x40500300) /* Secondary Audio Codec */ -#define PMC_REG_BASE __REG(0x40500400) /* Primary Modem Codec */ -#define SMC_REG_BASE __REG(0x40500500) /* Secondary Modem Codec */ +#define PAC_REG_BASE 0x40500200 /* Primary Audio Codec */ +#define SAC_REG_BASE 0x40500300 /* Secondary Audio Codec */ +#define PMC_REG_BASE 0x40500400 /* Primary Modem Codec */ +#define SMC_REG_BASE 0x40500500 /* Secondary Modem Codec */
/* * USB Device Controller */ -#ifdef CONFIG_PXA27X +#if defined(CONFIG_PXA27X) || defined(CONFIG_CPU_MONAHANS)
-#define UDCCR __REG(0x40600000) /* UDC Control Register */ +#define UDCCR 0x40600000 /* UDC Control Register */ #define UDCCR_UDE (1 << 0) /* UDC enable */ #define UDCCR_UDA (1 << 1) /* UDC active */ #define UDCCR_RSM (1 << 2) /* Device resume */ @@ -623,7 +632,7 @@ typedef void (*ExcpHndlr) (void) ; #define UDCCR_AAISN (0x07 << 5) /* Active UDC Alternate Interface Setting Number */ #define UDCCR_AAISN_S 5
-#define UDCCS0 __REG(0x40600100) /* UDC Endpoint 0 Control/Status Register */ +#define UDCCS0 0x40600100 /* UDC Endpoint 0 Control/Status Register */ #define UDCCS0_OPR (1 << 0) /* OUT packet ready */ #define UDCCS0_IPR (1 << 1) /* IN packet ready */ #define UDCCS0_FTF (1 << 2) /* Flush Tx FIFO */ @@ -634,9 +643,9 @@ typedef void (*ExcpHndlr) (void) ; #define UDCCS0_SA (1 << 7) /* Setup active */
/* Bulk IN - Endpoint 1,6,11 */ -#define UDCCS1 __REG(0x40600104) /* UDC Endpoint 1 (IN) Control/Status Register */ -#define UDCCS6 __REG(0x40600028) /* UDC Endpoint 6 (IN) Control/Status Register */ -#define UDCCS11 __REG(0x4060003C) /* UDC Endpoint 11 (IN) Control/Status Register */ +#define UDCCS1 0x40600104 /* UDC Endpoint 1 (IN) Control/Status Register */ +#define UDCCS6 0x40600028 /* UDC Endpoint 6 (IN) Control/Status Register */ +#define UDCCS11 0x4060003C /* UDC Endpoint 11 (IN) Control/Status Register */
#define UDCCS_BI_TFS (1 << 0) /* Transmit FIFO service */ #define UDCCS_BI_TPC (1 << 1) /* Transmit packet complete */ @@ -647,9 +656,9 @@ typedef void (*ExcpHndlr) (void) ; #define UDCCS_BI_TSP (1 << 7) /* Transmit short packet */
/* Bulk OUT - Endpoint 2,7,12 */ -#define UDCCS2 __REG(0x40600108) /* UDC Endpoint 2 (OUT) Control/Status Register */ -#define UDCCS7 __REG(0x4060002C) /* UDC Endpoint 7 (OUT) Control/Status Register */ -#define UDCCS12 __REG(0x40600040) /* UDC Endpoint 12 (OUT) Control/Status Register */ +#define UDCCS2 0x40600108 /* UDC Endpoint 2 (OUT) Control/Status Register */ +#define UDCCS7 0x4060002C /* UDC Endpoint 7 (OUT) Control/Status Register */ +#define UDCCS12 0x40600040 /* UDC Endpoint 12 (OUT) Control/Status Register */
#define UDCCS_BO_RFS (1 << 0) /* Receive FIFO service */ #define UDCCS_BO_RPC (1 << 1) /* Receive packet complete */ @@ -660,9 +669,9 @@ typedef void (*ExcpHndlr) (void) ; #define UDCCS_BO_RSP (1 << 7) /* Receive short packet */
/* Isochronous IN - Endpoint 3,8,13 */ -#define UDCCS3 __REG(0x4060001C) /* UDC Endpoint 3 (IN) Control/Status Register */ -#define UDCCS8 __REG(0x40600030) /* UDC Endpoint 8 (IN) Control/Status Register */ -#define UDCCS13 __REG(0x40600044) /* UDC Endpoint 13 (IN) Control/Status Register */ +#define UDCCS3 0x4060001C /* UDC Endpoint 3 (IN) Control/Status Register */ +#define UDCCS8 0x40600030 /* UDC Endpoint 8 (IN) Control/Status Register */ +#define UDCCS13 0x40600044 /* UDC Endpoint 13 (IN) Control/Status Register */
#define UDCCS_II_TFS (1 << 0) /* Transmit FIFO service */ #define UDCCS_II_TPC (1 << 1) /* Transmit packet complete */ @@ -671,9 +680,9 @@ typedef void (*ExcpHndlr) (void) ; #define UDCCS_II_TSP (1 << 7) /* Transmit short packet */
/* Isochronous OUT - Endpoint 4,9,14 */ -#define UDCCS4 __REG(0x40600020) /* UDC Endpoint 4 (OUT) Control/Status Register */ -#define UDCCS9 __REG(0x40600034) /* UDC Endpoint 9 (OUT) Control/Status Register */ -#define UDCCS14 __REG(0x40600048) /* UDC Endpoint 14 (OUT) Control/Status Register */ +#define UDCCS4 0x40600020 /* UDC Endpoint 4 (OUT) Control/Status Register */ +#define UDCCS9 0x40600034 /* UDC Endpoint 9 (OUT) Control/Status Register */ +#define UDCCS14 0x40600048 /* UDC Endpoint 14 (OUT) Control/Status Register */
#define UDCCS_IO_RFS (1 << 0) /* Receive FIFO service */ #define UDCCS_IO_RPC (1 << 1) /* Receive packet complete */ @@ -683,9 +692,9 @@ typedef void (*ExcpHndlr) (void) ; #define UDCCS_IO_RSP (1 << 7) /* Receive short packet */
/* Interrupt IN - Endpoint 5,10,15 */ -#define UDCCS5 __REG(0x40600024) /* UDC Endpoint 5 (Interrupt) Control/Status Register */ -#define UDCCS10 __REG(0x40600038) /* UDC Endpoint 10 (Interrupt) Control/Status Register */ -#define UDCCS15 __REG(0x4060004C) /* UDC Endpoint 15 (Interrupt) Control/Status Register */ +#define UDCCS5 0x40600024 /* UDC Endpoint 5 (Interrupt) Control/Status Register */ +#define UDCCS10 0x40600038 /* UDC Endpoint 10 (Interrupt) Control/Status Register */ +#define UDCCS15 0x4060004C /* UDC Endpoint 15 (Interrupt) Control/Status Register */
#define UDCCS_INT_TFS (1 << 0) /* Transmit FIFO service */ #define UDCCS_INT_TPC (1 << 1) /* Transmit packet complete */ @@ -695,32 +704,32 @@ typedef void (*ExcpHndlr) (void) ; #define UDCCS_INT_FST (1 << 5) /* Force stall */ #define UDCCS_INT_TSP (1 << 7) /* Transmit short packet */
-#define UFNRH __REG(0x40600060) /* UDC Frame Number Register High */ -#define UFNRL __REG(0x40600014) /* UDC Frame Number Register Low */ -#define UBCR2 __REG(0x40600208) /* UDC Byte Count Reg 2 */ -#define UBCR4 __REG(0x4060006c) /* UDC Byte Count Reg 4 */ -#define UBCR7 __REG(0x40600070) /* UDC Byte Count Reg 7 */ -#define UBCR9 __REG(0x40600074) /* UDC Byte Count Reg 9 */ -#define UBCR12 __REG(0x40600078) /* UDC Byte Count Reg 12 */ -#define UBCR14 __REG(0x4060007c) /* UDC Byte Count Reg 14 */ -#define UDDR0 __REG(0x40600300) /* UDC Endpoint 0 Data Register */ -#define UDDR1 __REG(0x40600304) /* UDC Endpoint 1 Data Register */ -#define UDDR2 __REG(0x40600308) /* UDC Endpoint 2 Data Register */ -#define UDDR3 __REG(0x40600200) /* UDC Endpoint 3 Data Register */ -#define UDDR4 __REG(0x40600400) /* UDC Endpoint 4 Data Register */ -#define UDDR5 __REG(0x406000A0) /* UDC Endpoint 5 Data Register */ -#define UDDR6 __REG(0x40600600) /* UDC Endpoint 6 Data Register */ -#define UDDR7 __REG(0x40600680) /* UDC Endpoint 7 Data Register */ -#define UDDR8 __REG(0x40600700) /* UDC Endpoint 8 Data Register */ -#define UDDR9 __REG(0x40600900) /* UDC Endpoint 9 Data Register */ -#define UDDR10 __REG(0x406000C0) /* UDC Endpoint 10 Data Register */ -#define UDDR11 __REG(0x40600B00) /* UDC Endpoint 11 Data Register */ -#define UDDR12 __REG(0x40600B80) /* UDC Endpoint 12 Data Register */ -#define UDDR13 __REG(0x40600C00) /* UDC Endpoint 13 Data Register */ -#define UDDR14 __REG(0x40600E00) /* UDC Endpoint 14 Data Register */ -#define UDDR15 __REG(0x406000E0) /* UDC Endpoint 15 Data Register */ - -#define UICR0 __REG(0x40600004) /* UDC Interrupt Control Register 0 */ +#define UFNRH 0x40600060 /* UDC Frame Number Register High */ +#define UFNRL 0x40600014 /* UDC Frame Number Register Low */ +#define UBCR2 0x40600208 /* UDC Byte Count Reg 2 */ +#define UBCR4 0x4060006c /* UDC Byte Count Reg 4 */ +#define UBCR7 0x40600070 /* UDC Byte Count Reg 7 */ +#define UBCR9 0x40600074 /* UDC Byte Count Reg 9 */ +#define UBCR12 0x40600078 /* UDC Byte Count Reg 12 */ +#define UBCR14 0x4060007c /* UDC Byte Count Reg 14 */ +#define UDDR0 0x40600300 /* UDC Endpoint 0 Data Register */ +#define UDDR1 0x40600304 /* UDC Endpoint 1 Data Register */ +#define UDDR2 0x40600308 /* UDC Endpoint 2 Data Register */ +#define UDDR3 0x40600200 /* UDC Endpoint 3 Data Register */ +#define UDDR4 0x40600400 /* UDC Endpoint 4 Data Register */ +#define UDDR5 0x406000A0 /* UDC Endpoint 5 Data Register */ +#define UDDR6 0x40600600 /* UDC Endpoint 6 Data Register */ +#define UDDR7 0x40600680 /* UDC Endpoint 7 Data Register */ +#define UDDR8 0x40600700 /* UDC Endpoint 8 Data Register */ +#define UDDR9 0x40600900 /* UDC Endpoint 9 Data Register */ +#define UDDR10 0x406000C0 /* UDC Endpoint 10 Data Register */ +#define UDDR11 0x40600B00 /* UDC Endpoint 11 Data Register */ +#define UDDR12 0x40600B80 /* UDC Endpoint 12 Data Register */ +#define UDDR13 0x40600C00 /* UDC Endpoint 13 Data Register */ +#define UDDR14 0x40600E00 /* UDC Endpoint 14 Data Register */ +#define UDDR15 0x406000E0 /* UDC Endpoint 15 Data Register */ + +#define UICR0 0x40600004 /* UDC Interrupt Control Register 0 */
#define UICR0_IM0 (1 << 0) /* Interrupt mask ep 0 */ #define UICR0_IM1 (1 << 1) /* Interrupt mask ep 1 */ @@ -731,7 +740,7 @@ typedef void (*ExcpHndlr) (void) ; #define UICR0_IM6 (1 << 6) /* Interrupt mask ep 6 */ #define UICR0_IM7 (1 << 7) /* Interrupt mask ep 7 */
-#define UICR1 __REG(0x40600008) /* UDC Interrupt Control Register 1 */ +#define UICR1 0x40600008 /* UDC Interrupt Control Register 1 */
#define UICR1_IM8 (1 << 0) /* Interrupt mask ep 8 */ #define UICR1_IM9 (1 << 1) /* Interrupt mask ep 9 */ @@ -742,7 +751,7 @@ typedef void (*ExcpHndlr) (void) ; #define UICR1_IM14 (1 << 6) /* Interrupt mask ep 14 */ #define UICR1_IM15 (1 << 7) /* Interrupt mask ep 15 */
-#define USIR0 __REG(0x4060000C) /* UDC Status Interrupt Register 0 */ +#define USIR0 0x4060000C /* UDC Status Interrupt Register 0 */
#define USIR0_IR0 (1 << 0) /* Interrup request ep 0 */ #define USIR0_IR1 (1 << 2) /* Interrup request ep 1 */ @@ -753,7 +762,7 @@ typedef void (*ExcpHndlr) (void) ; #define USIR0_IR6 (1 << 6) /* Interrup request ep 6 */ #define USIR0_IR7 (1 << 7) /* Interrup request ep 7 */
-#define USIR1 __REG(0x40600010) /* UDC Status Interrupt Register 1 */ +#define USIR1 0x40600010 /* UDC Status Interrupt Register 1 */
#define USIR1_IR8 (1 << 0) /* Interrup request ep 8 */ #define USIR1_IR9 (1 << 1) /* Interrup request ep 9 */ @@ -765,8 +774,8 @@ typedef void (*ExcpHndlr) (void) ; #define USIR1_IR15 (1 << 7) /* Interrup request ep 15 */
-#define UDCICR0 __REG(0x40600004) /* UDC Interrupt Control Register0 */ -#define UDCICR1 __REG(0x40600008) /* UDC Interrupt Control Register1 */ +#define UDCICR0 0x40600004 /* UDC Interrupt Control Register0 */ +#define UDCICR1 0x40600008 /* UDC Interrupt Control Register1 */ #define UDCICR_FIFOERR (1 << 1) /* FIFO Error interrupt for EP */ #define UDCICR_PKTCOMPL (1 << 0) /* Packet Complete interrupt for EP */
@@ -777,8 +786,8 @@ typedef void (*ExcpHndlr) (void) ; #define UDCICR1_IESU (1 << 28) /* IntEn - Suspend */ #define UDCICR1_IERS (1 << 27) /* IntEn - Reset */
-#define UDCISR0 __REG(0x4060000C) /* UDC Interrupt Status Register 0 */ -#define UDCISR1 __REG(0x40600010) /* UDC Interrupt Status Register 1 */ +#define UDCISR0 0x4060000C /* UDC Interrupt Status Register 0 */ +#define UDCISR1 0x40600010 /* UDC Interrupt Status Register 1 */ #define UDCISR_INT(n, intr) (((intr) & 0x03) << (((n) & 0x0F) * 2)) #define UDCISR1_IRCC (1 << 31) /* IntEn - Configuration Change */ #define UDCISR1_IRSOF (1 << 30) /* IntEn - Start of Frame */ @@ -787,8 +796,8 @@ typedef void (*ExcpHndlr) (void) ; #define UDCISR1_IRRS (1 << 27) /* IntEn - Reset */
-#define UDCFNR __REG(0x40600014) /* UDC Frame Number Register */ -#define UDCOTGICR __REG(0x40600018) /* UDC On-The-Go interrupt control */ +#define UDCFNR 0x40600014 /* UDC Frame Number Register */ +#define UDCOTGICR 0x40600018 /* UDC On-The-Go interrupt control */ #define UDCOTGICR_IESF (1 << 24) /* OTG SET_FEATURE command recvd */ #define UDCOTGICR_IEXR (1 << 17) /* Extra Transciever Interrupt Rising Edge Interrupt Enable */ #define UDCOTGICR_IEXF (1 << 16) /* Extra Transciever Interrupt Falling Edge Interrupt Enable */ @@ -804,7 +813,7 @@ typedef void (*ExcpHndlr) (void) ; #define UDCOTGICR_IEIDF (1 << 0) /* OTG ID Change Falling Edge Interrupt Enable */
#define UDCCSN(x) __REG2(0x40600100, (x) << 2) -#define UDCCSR0 __REG(0x40600100) /* UDC Control/Status register - Endpoint 0 */ +#define UDCCSR0 0x40600100 /* UDC Control/Status register - Endpoint 0 */
#define UDCCSR0_SA (1 << 7) /* Setup Active */ #define UDCCSR0_RNE (1 << 6) /* Receive FIFO Not Empty */ @@ -815,29 +824,29 @@ typedef void (*ExcpHndlr) (void) ; #define UDCCSR0_IPR (1 << 1) /* IN Packet Ready */ #define UDCCSR0_OPC (1 << 0) /* OUT Packet Complete */
-#define UDCCSRA __REG(0x40600104) /* UDC Control/Status register - Endpoint A */ -#define UDCCSRB __REG(0x40600108) /* UDC Control/Status register - Endpoint B */ -#define UDCCSRC __REG(0x4060010C) /* UDC Control/Status register - Endpoint C */ -#define UDCCSRD __REG(0x40600110) /* UDC Control/Status register - Endpoint D */ -#define UDCCSRE __REG(0x40600114) /* UDC Control/Status register - Endpoint E */ -#define UDCCSRF __REG(0x40600118) /* UDC Control/Status register - Endpoint F */ -#define UDCCSRG __REG(0x4060011C) /* UDC Control/Status register - Endpoint G */ -#define UDCCSRH __REG(0x40600120) /* UDC Control/Status register - Endpoint H */ -#define UDCCSRI __REG(0x40600124) /* UDC Control/Status register - Endpoint I */ -#define UDCCSRJ __REG(0x40600128) /* UDC Control/Status register - Endpoint J */ -#define UDCCSRK __REG(0x4060012C) /* UDC Control/Status register - Endpoint K */ -#define UDCCSRL __REG(0x40600130) /* UDC Control/Status register - Endpoint L */ -#define UDCCSRM __REG(0x40600134) /* UDC Control/Status register - Endpoint M */ -#define UDCCSRN __REG(0x40600138) /* UDC Control/Status register - Endpoint N */ -#define UDCCSRP __REG(0x4060013C) /* UDC Control/Status register - Endpoint P */ -#define UDCCSRQ __REG(0x40600140) /* UDC Control/Status register - Endpoint Q */ -#define UDCCSRR __REG(0x40600144) /* UDC Control/Status register - Endpoint R */ -#define UDCCSRS __REG(0x40600148) /* UDC Control/Status register - Endpoint S */ -#define UDCCSRT __REG(0x4060014C) /* UDC Control/Status register - Endpoint T */ -#define UDCCSRU __REG(0x40600150) /* UDC Control/Status register - Endpoint U */ -#define UDCCSRV __REG(0x40600154) /* UDC Control/Status register - Endpoint V */ -#define UDCCSRW __REG(0x40600158) /* UDC Control/Status register - Endpoint W */ -#define UDCCSRX __REG(0x4060015C) /* UDC Control/Status register - Endpoint X */ +#define UDCCSRA 0x40600104 /* UDC Control/Status register - Endpoint A */ +#define UDCCSRB 0x40600108 /* UDC Control/Status register - Endpoint B */ +#define UDCCSRC 0x4060010C /* UDC Control/Status register - Endpoint C */ +#define UDCCSRD 0x40600110 /* UDC Control/Status register - Endpoint D */ +#define UDCCSRE 0x40600114 /* UDC Control/Status register - Endpoint E */ +#define UDCCSRF 0x40600118 /* UDC Control/Status register - Endpoint F */ +#define UDCCSRG 0x4060011C /* UDC Control/Status register - Endpoint G */ +#define UDCCSRH 0x40600120 /* UDC Control/Status register - Endpoint H */ +#define UDCCSRI 0x40600124 /* UDC Control/Status register - Endpoint I */ +#define UDCCSRJ 0x40600128 /* UDC Control/Status register - Endpoint J */ +#define UDCCSRK 0x4060012C /* UDC Control/Status register - Endpoint K */ +#define UDCCSRL 0x40600130 /* UDC Control/Status register - Endpoint L */ +#define UDCCSRM 0x40600134 /* UDC Control/Status register - Endpoint M */ +#define UDCCSRN 0x40600138 /* UDC Control/Status register - Endpoint N */ +#define UDCCSRP 0x4060013C /* UDC Control/Status register - Endpoint P */ +#define UDCCSRQ 0x40600140 /* UDC Control/Status register - Endpoint Q */ +#define UDCCSRR 0x40600144 /* UDC Control/Status register - Endpoint R */ +#define UDCCSRS 0x40600148 /* UDC Control/Status register - Endpoint S */ +#define UDCCSRT 0x4060014C /* UDC Control/Status register - Endpoint T */ +#define UDCCSRU 0x40600150 /* UDC Control/Status register - Endpoint U */ +#define UDCCSRV 0x40600154 /* UDC Control/Status register - Endpoint V */ +#define UDCCSRW 0x40600158 /* UDC Control/Status register - Endpoint W */ +#define UDCCSRX 0x4060015C /* UDC Control/Status register - Endpoint X */
#define UDCCSR_DPE (1 << 9) /* Data Packet Error */ #define UDCCSR_FEF (1 << 8) /* Flush Endpoint FIFO */ @@ -852,81 +861,81 @@ typedef void (*ExcpHndlr) (void) ; #define UDCCSR_FS (1 << 0) /* FIFO needs service */
#define UDCBCN(x) __REG2(0x40600200, (x)<<2) -#define UDCBCR0 __REG(0x40600200) /* Byte Count Register - EP0 */ -#define UDCBCRA __REG(0x40600204) /* Byte Count Register - EPA */ -#define UDCBCRB __REG(0x40600208) /* Byte Count Register - EPB */ -#define UDCBCRC __REG(0x4060020C) /* Byte Count Register - EPC */ -#define UDCBCRD __REG(0x40600210) /* Byte Count Register - EPD */ -#define UDCBCRE __REG(0x40600214) /* Byte Count Register - EPE */ -#define UDCBCRF __REG(0x40600218) /* Byte Count Register - EPF */ -#define UDCBCRG __REG(0x4060021C) /* Byte Count Register - EPG */ -#define UDCBCRH __REG(0x40600220) /* Byte Count Register - EPH */ -#define UDCBCRI __REG(0x40600224) /* Byte Count Register - EPI */ -#define UDCBCRJ __REG(0x40600228) /* Byte Count Register - EPJ */ -#define UDCBCRK __REG(0x4060022C) /* Byte Count Register - EPK */ -#define UDCBCRL __REG(0x40600230) /* Byte Count Register - EPL */ -#define UDCBCRM __REG(0x40600234) /* Byte Count Register - EPM */ -#define UDCBCRN __REG(0x40600238) /* Byte Count Register - EPN */ -#define UDCBCRP __REG(0x4060023C) /* Byte Count Register - EPP */ -#define UDCBCRQ __REG(0x40600240) /* Byte Count Register - EPQ */ -#define UDCBCRR __REG(0x40600244) /* Byte Count Register - EPR */ -#define UDCBCRS __REG(0x40600248) /* Byte Count Register - EPS */ -#define UDCBCRT __REG(0x4060024C) /* Byte Count Register - EPT */ -#define UDCBCRU __REG(0x40600250) /* Byte Count Register - EPU */ -#define UDCBCRV __REG(0x40600254) /* Byte Count Register - EPV */ -#define UDCBCRW __REG(0x40600258) /* Byte Count Register - EPW */ -#define UDCBCRX __REG(0x4060025C) /* Byte Count Register - EPX */ +#define UDCBCR0 0x40600200 /* Byte Count Register - EP0 */ +#define UDCBCRA 0x40600204 /* Byte Count Register - EPA */ +#define UDCBCRB 0x40600208 /* Byte Count Register - EPB */ +#define UDCBCRC 0x4060020C /* Byte Count Register - EPC */ +#define UDCBCRD 0x40600210 /* Byte Count Register - EPD */ +#define UDCBCRE 0x40600214 /* Byte Count Register - EPE */ +#define UDCBCRF 0x40600218 /* Byte Count Register - EPF */ +#define UDCBCRG 0x4060021C /* Byte Count Register - EPG */ +#define UDCBCRH 0x40600220 /* Byte Count Register - EPH */ +#define UDCBCRI 0x40600224 /* Byte Count Register - EPI */ +#define UDCBCRJ 0x40600228 /* Byte Count Register - EPJ */ +#define UDCBCRK 0x4060022C /* Byte Count Register - EPK */ +#define UDCBCRL 0x40600230 /* Byte Count Register - EPL */ +#define UDCBCRM 0x40600234 /* Byte Count Register - EPM */ +#define UDCBCRN 0x40600238 /* Byte Count Register - EPN */ +#define UDCBCRP 0x4060023C /* Byte Count Register - EPP */ +#define UDCBCRQ 0x40600240 /* Byte Count Register - EPQ */ +#define UDCBCRR 0x40600244 /* Byte Count Register - EPR */ +#define UDCBCRS 0x40600248 /* Byte Count Register - EPS */ +#define UDCBCRT 0x4060024C /* Byte Count Register - EPT */ +#define UDCBCRU 0x40600250 /* Byte Count Register - EPU */ +#define UDCBCRV 0x40600254 /* Byte Count Register - EPV */ +#define UDCBCRW 0x40600258 /* Byte Count Register - EPW */ +#define UDCBCRX 0x4060025C /* Byte Count Register - EPX */
#define UDCDN(x) __REG2(0x40600300, (x)<<2) -#define UDCDR0 __REG(0x40600300) /* Data Register - EP0 */ -#define UDCDRA __REG(0x40600304) /* Data Register - EPA */ -#define UDCDRB __REG(0x40600308) /* Data Register - EPB */ -#define UDCDRC __REG(0x4060030C) /* Data Register - EPC */ -#define UDCDRD __REG(0x40600310) /* Data Register - EPD */ -#define UDCDRE __REG(0x40600314) /* Data Register - EPE */ -#define UDCDRF __REG(0x40600318) /* Data Register - EPF */ -#define UDCDRG __REG(0x4060031C) /* Data Register - EPG */ -#define UDCDRH __REG(0x40600320) /* Data Register - EPH */ -#define UDCDRI __REG(0x40600324) /* Data Register - EPI */ -#define UDCDRJ __REG(0x40600328) /* Data Register - EPJ */ -#define UDCDRK __REG(0x4060032C) /* Data Register - EPK */ -#define UDCDRL __REG(0x40600330) /* Data Register - EPL */ -#define UDCDRM __REG(0x40600334) /* Data Register - EPM */ -#define UDCDRN __REG(0x40600338) /* Data Register - EPN */ -#define UDCDRP __REG(0x4060033C) /* Data Register - EPP */ -#define UDCDRQ __REG(0x40600340) /* Data Register - EPQ */ -#define UDCDRR __REG(0x40600344) /* Data Register - EPR */ -#define UDCDRS __REG(0x40600348) /* Data Register - EPS */ -#define UDCDRT __REG(0x4060034C) /* Data Register - EPT */ -#define UDCDRU __REG(0x40600350) /* Data Register - EPU */ -#define UDCDRV __REG(0x40600354) /* Data Register - EPV */ -#define UDCDRW __REG(0x40600358) /* Data Register - EPW */ -#define UDCDRX __REG(0x4060035C) /* Data Register - EPX */ +#define UDCDR0 0x40600300 /* Data Register - EP0 */ +#define UDCDRA 0x40600304 /* Data Register - EPA */ +#define UDCDRB 0x40600308 /* Data Register - EPB */ +#define UDCDRC 0x4060030C /* Data Register - EPC */ +#define UDCDRD 0x40600310 /* Data Register - EPD */ +#define UDCDRE 0x40600314 /* Data Register - EPE */ +#define UDCDRF 0x40600318 /* Data Register - EPF */ +#define UDCDRG 0x4060031C /* Data Register - EPG */ +#define UDCDRH 0x40600320 /* Data Register - EPH */ +#define UDCDRI 0x40600324 /* Data Register - EPI */ +#define UDCDRJ 0x40600328 /* Data Register - EPJ */ +#define UDCDRK 0x4060032C /* Data Register - EPK */ +#define UDCDRL 0x40600330 /* Data Register - EPL */ +#define UDCDRM 0x40600334 /* Data Register - EPM */ +#define UDCDRN 0x40600338 /* Data Register - EPN */ +#define UDCDRP 0x4060033C /* Data Register - EPP */ +#define UDCDRQ 0x40600340 /* Data Register - EPQ */ +#define UDCDRR 0x40600344 /* Data Register - EPR */ +#define UDCDRS 0x40600348 /* Data Register - EPS */ +#define UDCDRT 0x4060034C /* Data Register - EPT */ +#define UDCDRU 0x40600350 /* Data Register - EPU */ +#define UDCDRV 0x40600354 /* Data Register - EPV */ +#define UDCDRW 0x40600358 /* Data Register - EPW */ +#define UDCDRX 0x4060035C /* Data Register - EPX */
#define UDCCN(x) __REG2(0x40600400, (x)<<2) -#define UDCCRA __REG(0x40600404) /* Configuration register EPA */ -#define UDCCRB __REG(0x40600408) /* Configuration register EPB */ -#define UDCCRC __REG(0x4060040C) /* Configuration register EPC */ -#define UDCCRD __REG(0x40600410) /* Configuration register EPD */ -#define UDCCRE __REG(0x40600414) /* Configuration register EPE */ -#define UDCCRF __REG(0x40600418) /* Configuration register EPF */ -#define UDCCRG __REG(0x4060041C) /* Configuration register EPG */ -#define UDCCRH __REG(0x40600420) /* Configuration register EPH */ -#define UDCCRI __REG(0x40600424) /* Configuration register EPI */ -#define UDCCRJ __REG(0x40600428) /* Configuration register EPJ */ -#define UDCCRK __REG(0x4060042C) /* Configuration register EPK */ -#define UDCCRL __REG(0x40600430) /* Configuration register EPL */ -#define UDCCRM __REG(0x40600434) /* Configuration register EPM */ -#define UDCCRN __REG(0x40600438) /* Configuration register EPN */ -#define UDCCRP __REG(0x4060043C) /* Configuration register EPP */ -#define UDCCRQ __REG(0x40600440) /* Configuration register EPQ */ -#define UDCCRR __REG(0x40600444) /* Configuration register EPR */ -#define UDCCRS __REG(0x40600448) /* Configuration register EPS */ -#define UDCCRT __REG(0x4060044C) /* Configuration register EPT */ -#define UDCCRU __REG(0x40600450) /* Configuration register EPU */ -#define UDCCRV __REG(0x40600454) /* Configuration register EPV */ -#define UDCCRW __REG(0x40600458) /* Configuration register EPW */ -#define UDCCRX __REG(0x4060045C) /* Configuration register EPX */ +#define UDCCRA 0x40600404 /* Configuration register EPA */ +#define UDCCRB 0x40600408 /* Configuration register EPB */ +#define UDCCRC 0x4060040C /* Configuration register EPC */ +#define UDCCRD 0x40600410 /* Configuration register EPD */ +#define UDCCRE 0x40600414 /* Configuration register EPE */ +#define UDCCRF 0x40600418 /* Configuration register EPF */ +#define UDCCRG 0x4060041C /* Configuration register EPG */ +#define UDCCRH 0x40600420 /* Configuration register EPH */ +#define UDCCRI 0x40600424 /* Configuration register EPI */ +#define UDCCRJ 0x40600428 /* Configuration register EPJ */ +#define UDCCRK 0x4060042C /* Configuration register EPK */ +#define UDCCRL 0x40600430 /* Configuration register EPL */ +#define UDCCRM 0x40600434 /* Configuration register EPM */ +#define UDCCRN 0x40600438 /* Configuration register EPN */ +#define UDCCRP 0x4060043C /* Configuration register EPP */ +#define UDCCRQ 0x40600440 /* Configuration register EPQ */ +#define UDCCRR 0x40600444 /* Configuration register EPR */ +#define UDCCRS 0x40600448 /* Configuration register EPS */ +#define UDCCRT 0x4060044C /* Configuration register EPT */ +#define UDCCRU 0x40600450 /* Configuration register EPU */ +#define UDCCRV 0x40600454 /* Configuration register EPV */ +#define UDCCRW 0x40600458 /* Configuration register EPW */ +#define UDCCRX 0x4060045C /* Configuration register EPX */
#define UDCCONR_CN (0x03 << 25) /* Configuration Number */ #define UDCCONR_CN_S (25) @@ -959,38 +968,39 @@ typedef void (*ExcpHndlr) (void) ;
+/******************************************************************************/ /* * USB Host Controller */ #define OHCI_REGS_BASE 0x4C000000 /* required for ohci driver */ -#define UHCREV __REG(0x4C000000) -#define UHCHCON __REG(0x4C000004) -#define UHCCOMS __REG(0x4C000008) -#define UHCINTS __REG(0x4C00000C) -#define UHCINTE __REG(0x4C000010) -#define UHCINTD __REG(0x4C000014) -#define UHCHCCA __REG(0x4C000018) -#define UHCPCED __REG(0x4C00001C) -#define UHCCHED __REG(0x4C000020) -#define UHCCCED __REG(0x4C000024) -#define UHCBHED __REG(0x4C000028) -#define UHCBCED __REG(0x4C00002C) -#define UHCDHEAD __REG(0x4C000030) -#define UHCFMI __REG(0x4C000034) -#define UHCFMR __REG(0x4C000038) -#define UHCFMN __REG(0x4C00003C) -#define UHCPERS __REG(0x4C000040) -#define UHCLST __REG(0x4C000044) -#define UHCRHDA __REG(0x4C000048) -#define UHCRHDB __REG(0x4C00004C) -#define UHCRHS __REG(0x4C000050) -#define UHCRHPS1 __REG(0x4C000054) -#define UHCRHPS2 __REG(0x4C000058) -#define UHCRHPS3 __REG(0x4C00005C) -#define UHCSTAT __REG(0x4C000060) -#define UHCHR __REG(0x4C000064) -#define UHCHIE __REG(0x4C000068) -#define UHCHIT __REG(0x4C00006C) +#define UHCREV 0x4C000000 +#define UHCHCON 0x4C000004 +#define UHCCOMS 0x4C000008 +#define UHCINTS 0x4C00000C +#define UHCINTE 0x4C000010 +#define UHCINTD 0x4C000014 +#define UHCHCCA 0x4C000018 +#define UHCPCED 0x4C00001C +#define UHCCHED 0x4C000020 +#define UHCCCED 0x4C000024 +#define UHCBHED 0x4C000028 +#define UHCBCED 0x4C00002C +#define UHCDHEAD 0x4C000030 +#define UHCFMI 0x4C000034 +#define UHCFMR 0x4C000038 +#define UHCFMN 0x4C00003C +#define UHCPERS 0x4C000040 +#define UHCLST 0x4C000044 +#define UHCRHDA 0x4C000048 +#define UHCRHDB 0x4C00004C +#define UHCRHS 0x4C000050 +#define UHCRHPS1 0x4C000054 +#define UHCRHPS2 0x4C000058 +#define UHCRHPS3 0x4C00005C +#define UHCSTAT 0x4C000060 +#define UHCHR 0x4C000064 +#define UHCHIE 0x4C000068 +#define UHCHIT 0x4C00006C
#define UHCHR_FSBIR (1<<0) #define UHCHR_FHR (1<<1) @@ -1011,9 +1021,7 @@ typedef void (*ExcpHndlr) (void) ; #define UHCHIE_HBAIE (1<<8) #define UHCHIE_RWIE (1<<7)
-#if defined(CONFIG_CPU_MONAHANS) || defined(CONFIG_PXA27X) -#define UP2OCR __REG(0x40600020) -#endif +#define UP2OCR 0x40600020
#define UP2OCR_HXOE (1<<17) #define UP2OCR_HXS (1<<16) @@ -1029,36 +1037,37 @@ typedef void (*ExcpHndlr) (void) ; #define UP2OCR_CPVPE (1<<1) #define UP2OCR_CPVEN (1<<0)
-#endif +#endif /* CONFIG_PXA27X || CONFIG_CPU_MONAHANS */
+/******************************************************************************/ /* * Fast Infrared Communication Port */ -#define ICCR0 __REG(0x40800000) /* ICP Control Register 0 */ -#define ICCR1 __REG(0x40800004) /* ICP Control Register 1 */ -#define ICCR2 __REG(0x40800008) /* ICP Control Register 2 */ -#define ICDR __REG(0x4080000c) /* ICP Data Register */ -#define ICSR0 __REG(0x40800014) /* ICP Status Register 0 */ -#define ICSR1 __REG(0x40800018) /* ICP Status Register 1 */ +#define ICCR0 0x40800000 /* ICP Control Register 0 */ +#define ICCR1 0x40800004 /* ICP Control Register 1 */ +#define ICCR2 0x40800008 /* ICP Control Register 2 */ +#define ICDR 0x4080000c /* ICP Data Register */ +#define ICSR0 0x40800014 /* ICP Status Register 0 */ +#define ICSR1 0x40800018 /* ICP Status Register 1 */
/* * Real Time Clock */ -#define RCNR __REG(0x40900000) /* RTC Count Register */ -#define RTAR __REG(0x40900004) /* RTC Alarm Register */ -#define RTSR __REG(0x40900008) /* RTC Status Register */ -#define RTTR __REG(0x4090000C) /* RTC Timer Trim Register */ -#define RDAR1 __REG(0x40900018) /* Wristwatch Day Alarm Reg 1 */ -#define RDAR2 __REG(0x40900020) /* Wristwatch Day Alarm Reg 2 */ -#define RYAR1 __REG(0x4090001C) /* Wristwatch Year Alarm Reg 1 */ -#define RYAR2 __REG(0x40900024) /* Wristwatch Year Alarm Reg 2 */ -#define SWAR1 __REG(0x4090002C) /* Stopwatch Alarm Register 1 */ -#define SWAR2 __REG(0x40900030) /* Stopwatch Alarm Register 2 */ -#define PIAR __REG(0x40900038) /* Periodic Interrupt Alarm Register */ -#define RDCR __REG(0x40900010) /* RTC Day Count Register. */ -#define RYCR __REG(0x40900014) /* RTC Year Count Register. */ -#define SWCR __REG(0x40900028) /* Stopwatch Count Register */ -#define RTCPICR __REG(0x40900034) /* Periodic Interrupt Counter Register */ +#define RCNR 0x40900000 /* RTC Count Register */ +#define RTAR 0x40900004 /* RTC Alarm Register */ +#define RTSR 0x40900008 /* RTC Status Register */ +#define RTTR 0x4090000C /* RTC Timer Trim Register */ +#define RDAR1 0x40900018 /* Wristwatch Day Alarm Reg 1 */ +#define RDAR2 0x40900020 /* Wristwatch Day Alarm Reg 2 */ +#define RYAR1 0x4090001C /* Wristwatch Year Alarm Reg 1 */ +#define RYAR2 0x40900024 /* Wristwatch Year Alarm Reg 2 */ +#define SWAR1 0x4090002C /* Stopwatch Alarm Register 1 */ +#define SWAR2 0x40900030 /* Stopwatch Alarm Register 2 */ +#define PIAR 0x40900038 /* Periodic Interrupt Alarm Register */ +#define RDCR 0x40900010 /* RTC Day Count Register. */ +#define RYCR 0x40900014 /* RTC Year Count Register. */ +#define SWCR 0x40900028 /* Stopwatch Count Register */ +#define RTCPICR 0x40900034 /* Periodic Interrupt Counter Register */
#define RTSR_PICE (1 << 15) /* Peridoc interrupt count enable */ #define RTSR_PIALE (1 << 14) /* Peridoc interrupt Alarm enable */ @@ -1068,48 +1077,48 @@ typedef void (*ExcpHndlr) (void) ; #define RTSR_HZ (1 << 1) /* HZ rising-edge detected */ #define RTSR_AL (1 << 0) /* RTC alarm detected */
+/******************************************************************************/ /* * OS Timer & Match Registers */ -#define OSMR0 __REG(0x40A00000) /* OS Timer Match Register 0 */ -#define OSMR1 __REG(0x40A00004) /* OS Timer Match Register 1 */ -#define OSMR2 __REG(0x40A00008) /* OS Timer Match Register 2 */ -#define OSMR3 __REG(0x40A0000C) /* OS Timer Match Register 3 */ -#define OSCR __REG(0x40A00010) /* OS Timer Counter Register */ -#define OSSR __REG(0x40A00014) /* OS Timer Status Register */ -#define OWER __REG(0x40A00018) /* OS Timer Watchdog Enable Register */ -#define OIER __REG(0x40A0001C) /* OS Timer Interrupt Enable Register */ +#define OSMR0 0x40A00000 /* OS Timer Match Register 0 */ +#define OSMR1 0x40A00004 /* OS Timer Match Register 1 */ +#define OSMR2 0x40A00008 /* OS Timer Match Register 2 */ +#define OSMR3 0x40A0000C /* OS Timer Match Register 3 */ +#define OSCR 0x40A00010 /* OS Timer Counter Register */ +#define OSSR 0x40A00014 /* OS Timer Status Register */ +#define OWER 0x40A00018 /* OS Timer Watchdog Enable Register */ +#define OIER 0x40A0001C /* OS Timer Interrupt Enable Register */
-#ifdef CONFIG_CPU_MONAHANS -#define OSCR4 __REG(0x40A00040) /* OS Timer Counter Register 4 */ -#define OSCR5 __REG(0x40A00044) /* OS Timer Counter Register 5 */ -#define OSCR6 __REG(0x40A00048) /* OS Timer Counter Register 6 */ -#define OSCR7 __REG(0x40A0004C) /* OS Timer Counter Register 7 */ -#define OSCR8 __REG(0x40A00050) /* OS Timer Counter Register 8 */ -#define OSCR9 __REG(0x40A00054) /* OS Timer Counter Register 9 */ -#define OSCR10 __REG(0x40A00058) /* OS Timer Counter Register 10 */ -#define OSCR11 __REG(0x40A0005C) /* OS Timer Counter Register 11 */ - -#define OSMR4 __REG(0x40A00080) /* OS Timer Match Register 4 */ -#define OSMR5 __REG(0x40A00084) /* OS Timer Match Register 5 */ -#define OSMR6 __REG(0x40A00088) /* OS Timer Match Register 6 */ -#define OSMR7 __REG(0x40A0008C) /* OS Timer Match Register 7 */ -#define OSMR8 __REG(0x40A00090) /* OS Timer Match Register 8 */ -#define OSMR9 __REG(0x40A00094) /* OS Timer Match Register 9 */ -#define OSMR10 __REG(0x40A00098) /* OS Timer Match Register 10 */ -#define OSMR11 __REG(0x40A0009C) /* OS Timer Match Register 11 */ - -#define OMCR4 __REG(0x40A000C0) /* OS Match Control Register 4 */ -#define OMCR5 __REG(0x40A000C4) /* OS Match Control Register 5 */ -#define OMCR6 __REG(0x40A000C8) /* OS Match Control Register 6 */ -#define OMCR7 __REG(0x40A000CC) /* OS Match Control Register 7 */ -#define OMCR8 __REG(0x40A000D0) /* OS Match Control Register 8 */ -#define OMCR9 __REG(0x40A000D4) /* OS Match Control Register 9 */ -#define OMCR10 __REG(0x40A000D8) /* OS Match Control Register 10 */ -#define OMCR11 __REG(0x40A000DC) /* OS Match Control Register 11 */ - -#define OSCR_CLK_FREQ 3250 /* kHz = 3.25 MHz */ -#endif /* CONFIG_CPU_MONAHANS */ +#if defined(CONFIG_PXA27X) || defined(CONFIG_CPU_MONAHANS) +#define OSCR4 0x40A00040 /* OS Timer Counter Register 4 */ +#define OSCR5 0x40A00044 /* OS Timer Counter Register 5 */ +#define OSCR6 0x40A00048 /* OS Timer Counter Register 6 */ +#define OSCR7 0x40A0004C /* OS Timer Counter Register 7 */ +#define OSCR8 0x40A00050 /* OS Timer Counter Register 8 */ +#define OSCR9 0x40A00054 /* OS Timer Counter Register 9 */ +#define OSCR10 0x40A00058 /* OS Timer Counter Register 10 */ +#define OSCR11 0x40A0005C /* OS Timer Counter Register 11 */ + +#define OSMR4 0x40A00080 /* OS Timer Match Register 4 */ +#define OSMR5 0x40A00084 /* OS Timer Match Register 5 */ +#define OSMR6 0x40A00088 /* OS Timer Match Register 6 */ +#define OSMR7 0x40A0008C /* OS Timer Match Register 7 */ +#define OSMR8 0x40A00090 /* OS Timer Match Register 8 */ +#define OSMR9 0x40A00094 /* OS Timer Match Register 9 */ +#define OSMR10 0x40A00098 /* OS Timer Match Register 10 */ +#define OSMR11 0x40A0009C /* OS Timer Match Register 11 */ + +#define OMCR4 0x40A000C0 /* OS Match Control Register 4 */ +#define OMCR5 0x40A000C4 /* OS Match Control Register 5 */ +#define OMCR6 0x40A000C8 /* OS Match Control Register 6 */ +#define OMCR7 0x40A000CC /* OS Match Control Register 7 */ +#define OMCR8 0x40A000D0 /* OS Match Control Register 8 */ +#define OMCR9 0x40A000D4 /* OS Match Control Register 9 */ +#define OMCR10 0x40A000D8 /* OS Match Control Register 10 */ +#define OMCR11 0x40A000DC /* OS Match Control Register 11 */ + +#endif /* CONFIG_PXA27X || CONFIG_CPU_MONAHANS */
#define OSSR_M4 (1 << 4) /* Match status channel 4 */ #define OSSR_M3 (1 << 3) /* Match status channel 3 */ @@ -1125,321 +1134,696 @@ typedef void (*ExcpHndlr) (void) ; #define OIER_E1 (1 << 1) /* Interrupt enable channel 1 */ #define OIER_E0 (1 << 0) /* Interrupt enable channel 0 */
+#define OSCR_CLK_FREQ 3250 + +/******************************************************************************/ /* - * Pulse Width Modulator + * Core Clock */ -#define PWM_CTRL0 __REG(0x40B00000) /* PWM 0 Control Register */ -#define PWM_PWDUTY0 __REG(0x40B00004) /* PWM 0 Duty Cycle Register */ -#define PWM_PERVAL0 __REG(0x40B00008) /* PWM 0 Period Control Register */
-#define PWM_CTRL1 __REG(0x40C00000) /* PWM 1 Control Register */ -#define PWM_PWDUTY1 __REG(0x40C00004) /* PWM 1 Duty Cycle Register */ -#define PWM_PERVAL1 __REG(0x40C00008) /* PWM 1 Period Control Register */ +#if defined(CONFIG_CPU_MONAHANS) +#define ACCR 0x41340000 /* Application Subsystem Clock Configuration Register */ +#define ACSR 0x41340004 /* Application Subsystem Clock Status Register */ +#define AICSR 0x41340008 /* Application Subsystem Interrupt Control/Status Register */ +#define CKENA 0x4134000C /* A Clock Enable Register */ +#define CKENB 0x41340010 /* B Clock Enable Register */ +#define AC97_DIV 0x41340014 /* AC97 clock divisor value register */ + +#define ACCR_SMC_MASK 0x03800000 /* Static Memory Controller Frequency Select */ +#define ACCR_SRAM_MASK 0x000c0000 /* SRAM Controller Frequency Select */ +#define ACCR_FC_MASK 0x00030000 /* Frequency Change Frequency Select */ +#define ACCR_HSIO_MASK 0x0000c000 /* High Speed IO Frequency Select */ +#define ACCR_DDR_MASK 0x00003000 /* DDR Memory Controller Frequency Select */ +#define ACCR_XN_MASK 0x00000700 /* Run Mode Frequency to Turbo Mode Frequency Multiplier */ +#define ACCR_XL_MASK 0x0000001f /* Crystal Frequency to Memory Frequency Multiplier */ +#define ACCR_XPDIS (1 << 31) +#define ACCR_SPDIS (1 << 30) +#define ACCR_13MEND1 (1 << 27) +#define ACCR_D0CS (1 << 26) +#define ACCR_13MEND2 (1 << 21) +#define ACCR_PCCE (1 << 11) + +#define CKENA_30_MSL0 (1 << 30) /* MSL0 Interface Unit Clock Enable */ +#define CKENA_29_SSP4 (1 << 29) /* SSP3 Unit Clock Enable */ +#define CKENA_28_SSP3 (1 << 28) /* SSP2 Unit Clock Enable */ +#define CKENA_27_SSP2 (1 << 27) /* SSP1 Unit Clock Enable */ +#define CKENA_26_SSP1 (1 << 26) /* SSP0 Unit Clock Enable */ +#define CKENA_25_TSI (1 << 25) /* TSI Clock Enable */ +#define CKENA_24_AC97 (1 << 24) /* AC97 Unit Clock Enable */ +#define CKENA_23_STUART (1 << 23) /* STUART Unit Clock Enable */ +#define CKENA_22_FFUART (1 << 22) /* FFUART Unit Clock Enable */ +#define CKENA_21_BTUART (1 << 21) /* BTUART Unit Clock Enable */ +#define CKENA_20_UDC (1 << 20) /* UDC Clock Enable */ +#define CKENA_19_TPM (1 << 19) /* TPM Unit Clock Enable */ +#define CKENA_18_USIM1 (1 << 18) /* USIM1 Unit Clock Enable */ +#define CKENA_17_USIM0 (1 << 17) /* USIM0 Unit Clock Enable */ +#define CKENA_15_CIR (1 << 15) /* Consumer IR Clock Enable */ +#define CKENA_14_KEY (1 << 14) /* Keypad Controller Clock Enable */ +#define CKENA_13_MMC1 (1 << 13) /* MMC1 Clock Enable */ +#define CKENA_12_MMC0 (1 << 12) /* MMC0 Clock Enable */ +#define CKENA_11_FLASH (1 << 11) /* Boot ROM Clock Enable */ +#define CKENA_10_SRAM (1 << 10) /* SRAM Controller Clock Enable */ +#define CKENA_9_SMC (1 << 9) /* Static Memory Controller */ +#define CKENA_8_DMC (1 << 8) /* Dynamic Memory Controller */ +#define CKENA_7_GRAPHICS (1 << 7) /* 2D Graphics Clock Enable */ +#define CKENA_6_USBCLI (1 << 6) /* USB Client Unit Clock Enable */ +#define CKENA_4_NAND (1 << 4) /* NAND Flash Controller Clock Enable */ +#define CKENA_3_CAMERA (1 << 3) /* Camera Interface Clock Enable */ +#define CKENA_2_USBHOST (1 << 2) /* USB Host Unit Clock Enable */ +#define CKENA_1_LCD (1 << 1) /* LCD Unit Clock Enable */ + +#define CKENB_9_SYSBUS2 (1 << 9) /* System bus 2 */ +#define CKENB_8_1WIRE (1 << 8) /* One Wire Interface Unit Clock Enable */ +#define CKENB_7_GPIO (1 << 7) /* GPIO Clock Enable */ +#define CKENB_6_IRQ (1 << 6) /* Interrupt Controller Clock Enable */ +#define CKENB_4_I2C (1 << 4) /* I2C Unit Clock Enable */ +#define CKENB_1_PWM1 (1 << 1) /* PWM2 & PWM3 Clock Enable */ +#define CKENB_0_PWM0 (1 << 0) /* PWM0 & PWM1 Clock Enable */ + +#else /* if defined CONFIG_CPU_MONAHANS */ + +#define CCCR 0x41300000 /* Core Clock Configuration Register */ +#define CKEN 0x41300004 /* Clock Enable Register */ +#define OSCC 0x41300008 /* Oscillator Configuration Register */ +#define CCSR 0x4130000C /* Core Clock Status Register */ + +#define CKEN23_SSP1 (1 << 23) /* SSP1 Unit Clock Enable */ +#define CKEN22_MEMC (1 << 22) /* Memory Controler */ +#define CKEN21_MSHC (1 << 21) /* Memery Stick Host Controller */ +#define CKEN20_IM (1 << 20) /* Internal Memory Clock Enable */ +#define CKEN19_KEYPAD (1 << 19) /* Keypad Interface Clock Enable */ +#define CKEN18_USIM (1 << 18) /* USIM Unit Clock Enable */ +#define CKEN17_MSL (1 << 17) /* MSL Interface Unit Clock Enable */ +#define CKEN15_PWR_I2C (1 << 15) /* PWR_I2C Unit Clock Enable */ +#define CKEN9_OST (1 << 9) /* OS Timer Unit Clock Enable */ +#define CKEN4_SSP3 (1 << 4) /* SSP3 Unit Clock Enable */ + +#define CCCR_N_MASK 0x0380 /* Run Mode Frequency to Turbo Mode Frequency Multiplier */ +#if !defined(CONFIG_PXA27X) +#define CCCR_M_MASK 0x0060 /* Memory Frequency to Run Mode Frequency Multiplier */ +#endif +#define CCCR_L_MASK 0x001f /* Crystal Frequency to Memory Frequency Multiplier */ + +#define CKEN24_CAMERA (1 << 24) /* Camera Interface Clock Enable */ +#define CKEN23_SSP1 (1 << 23) /* SSP1 Unit Clock Enable */ +#define CKEN22_MEMC (1 << 22) /* Memory Controller Clock Enable */ +#define CKEN21_MEMSTK (1 << 21) /* Memory Stick Host Controller */ +#define CKEN20_IM (1 << 20) /* Internal Memory Clock Enable */ +#define CKEN19_KEYPAD (1 << 19) /* Keypad Interface Clock Enable */ +#define CKEN18_USIM (1 << 18) /* USIM Unit Clock Enable */ +#define CKEN17_MSL (1 << 17) /* MSL Unit Clock Enable */ +#define CKEN16_LCD (1 << 16) /* LCD Unit Clock Enable */ +#define CKEN15_PWRI2C (1 << 15) /* PWR I2C Unit Clock Enable */ +#define CKEN14_I2C (1 << 14) /* I2C Unit Clock Enable */ +#define CKEN13_FICP (1 << 13) /* FICP Unit Clock Enable */ +#define CKEN12_MMC (1 << 12) /* MMC Unit Clock Enable */ +#define CKEN11_USB (1 << 11) /* USB Unit Clock Enable */ +#if defined(CONFIG_PXA27X) +#define CKEN10_USBHOST (1 << 10) /* USB Host Unit Clock Enable */ +#define CKEN24_CAMERA (1 << 24) /* Camera Unit Clock Enable */ +#endif +#define CKEN8_I2S (1 << 8) /* I2S Unit Clock Enable */ +#define CKEN7_BTUART (1 << 7) /* BTUART Unit Clock Enable */ +#define CKEN6_FFUART (1 << 6) /* FFUART Unit Clock Enable */ +#define CKEN5_STUART (1 << 5) /* STUART Unit Clock Enable */ +#define CKEN3_SSP (1 << 3) /* SSP Unit Clock Enable */ +#define CKEN2_AC97 (1 << 2) /* AC97 Unit Clock Enable */ +#define CKEN1_PWM1 (1 << 1) /* PWM1 Clock Enable */ +#define CKEN0_PWM0 (1 << 0) /* PWM0 Clock Enable */ + +#define OSCC_OON (1 << 1) /* 32.768kHz OON (write-once only bit) */ +#define OSCC_OOK (1 << 0) /* 32.768kHz OOK (read-only bit) */ + +#if !defined(CONFIG_PXA27X) +#define CCCR_L09 (0x1F) +#define CCCR_L27 (0x1) +#define CCCR_L32 (0x2) +#define CCCR_L36 (0x3) +#define CCCR_L40 (0x4) +#define CCCR_L45 (0x5) + +#define CCCR_M1 (0x1 << 5) +#define CCCR_M2 (0x2 << 5) +#define CCCR_M4 (0x3 << 5)
-#define PWM_CTRL2 __REG(0x40B00010) /* PWM 2 Control Register */ -#define PWM_PWDUTY2 __REG(0x40B00014) /* PWM 2 Duty Cycle Register */ -#define PWM_PERVAL2 __REG(0x40B00018) /* PWM 2 Period Control Register */ +#define CCCR_N10 (0x2 << 7) +#define CCCR_N15 (0x3 << 7) +#define CCCR_N20 (0x4 << 7) +#define CCCR_N25 (0x5 << 7) +#define CCCR_N30 (0x6 << 7) +#endif
-#define PWM_CTRL3 __REG(0x40C00010) /* PWM 3 Control Register */ -#define PWM_PWDUTY3 __REG(0x40C00014) /* PWM 3 Duty Cycle Register */ -#define PWM_PERVAL3 __REG(0x40C00018) /* PWM 3 Period Control Register */ +#endif /* CONFIG_CPU_MONAHANS */
+/******************************************************************************/ /* - * Interrupt Controller + * Pulse Width Modulator */ -#define ICIP __REG(0x40D00000) /* Interrupt Controller IRQ Pending Register */ -#define ICMR __REG(0x40D00004) /* Interrupt Controller Mask Register */ -#define ICLR __REG(0x40D00008) /* Interrupt Controller Level Register */ -#define ICFP __REG(0x40D0000C) /* Interrupt Controller FIQ Pending Register */ -#define ICPR __REG(0x40D00010) /* Interrupt Controller Pending Register */ -#define ICCR __REG(0x40D00014) /* Interrupt Controller Control Register */ +#define PWM_CTRL0 0x40B00000 /* PWM 0 Control Register */ +#define PWM_PWDUTY0 0x40B00004 /* PWM 0 Duty Cycle Register */ +#define PWM_PERVAL0 0x40B00008 /* PWM 0 Period Control Register */
-#ifdef CONFIG_CPU_MONAHANS -#define ICHP __REG(0x40D00018) /* Interrupt Controller Highest Priority Register */ -/* Missing: 32 Interrupt priority registers - * These are the same as beneath for PXA27x: maybe can be merged if - * GPIO Stuff is same too. +#define PWM_CTRL1 0x40C00000 /* PWM 1 Control Register */ +#define PWM_PWDUTY1 0x40C00004 /* PWM 1 Duty Cycle Register */ +#define PWM_PERVAL1 0x40C00008 /* PWM 1 Period Control Register */ + +#if defined(CONFIG_PXA27X) || defined(CONFIG_CPU_MONAHANS) +#define PWM_CTRL2 0x40B00010 /* PWM 2 Control Register */ +#define PWM_PWDUTY2 0x40B00014 /* PWM 2 Duty Cycle Register */ +#define PWM_PERVAL2 0x40B00018 /* PWM 2 Period Control Register */ + +#define PWM_CTRL3 0x40C00010 /* PWM 3 Control Register */ +#define PWM_PWDUTY3 0x40C00014 /* PWM 3 Duty Cycle Register */ +#define PWM_PERVAL3 0x40C00018 /* PWM 3 Period Control Register */ +#endif /* CONFIG_PXA27X || CONFIG_CPU_MONAHANS */ + +/* + * Interrupt Controller */ -#define ICIP2 __REG(0x40D0009C) /* Interrupt Controller IRQ Pending Register 2 */ -#define ICMR2 __REG(0x40D000A0) /* Interrupt Controller Mask Register 2 */ -#define ICLR2 __REG(0x40D000A4) /* Interrupt Controller Level Register 2 */ -#define ICFP2 __REG(0x40D000A8) /* Interrupt Controller FIQ Pending Register 2 */ -#define ICPR2 __REG(0x40D000AC) /* Interrupt Controller Pending Register 2 */ -/* Missing: 2 Interrupt priority registers */ -#endif /* CONFIG_CPU_MONAHANS */ +#define ICIP 0x40D00000 /* Interrupt Controller IRQ Pending Register */ +#define ICMR 0x40D00004 /* Interrupt Controller Mask Register */ +#define ICLR 0x40D00008 /* Interrupt Controller Level Register */ +#define ICFP 0x40D0000C /* Interrupt Controller FIQ Pending Register */ +#define ICPR 0x40D00010 /* Interrupt Controller Pending Register */ +#define ICCR 0x40D00014 /* Interrupt Controller Control Register */
+#if defined(CONFIG_PXA27X) || defined(CONFIG_CPU_MONAHANS) +#define ICHP 0x40D00018 /* Interrupt Controller Highest Priority Register */ +#define ICIP2 0x40D0009C /* Interrupt Controller IRQ Pending Register 2 */ +#define ICMR2 0x40D000A0 /* Interrupt Controller Mask Register 2 */ +#define ICLR2 0x40D000A4 /* Interrupt Controller Level Register 2 */ +#define ICFP2 0x40D000A8 /* Interrupt Controller FIQ Pending Register 2 */ +#define ICPR2 0x40D000AC /* Interrupt Controller Pending Register 2 */ +#endif /* CONFIG_PXA27X || CONFIG_CPU_MONAHANS */ + +/******************************************************************************/ /* * General Purpose I/O */ -#define GPLR0 __REG(0x40E00000) /* GPIO Pin-Level Register GPIO<31:0> */ -#define GPLR1 __REG(0x40E00004) /* GPIO Pin-Level Register GPIO<63:32> */ -#define GPLR2 __REG(0x40E00008) /* GPIO Pin-Level Register GPIO<80:64> */ +#define GPLR0 0x40E00000 /* GPIO Pin-Level Register GPIO<31:0> */ +#define GPLR1 0x40E00004 /* GPIO Pin-Level Register GPIO<63:32> */ +#define GPLR2 0x40E00008 /* GPIO Pin-Level Register GPIO<80:64> */
-#define GPDR0 __REG(0x40E0000C) /* GPIO Pin Direction Register GPIO<31:0> */ -#define GPDR1 __REG(0x40E00010) /* GPIO Pin Direction Register GPIO<63:32> */ -#define GPDR2 __REG(0x40E00014) /* GPIO Pin Direction Register GPIO<80:64> */ +#define GPDR0 0x40E0000C /* GPIO Pin Direction Register GPIO<31:0> */ +#define GPDR1 0x40E00010 /* GPIO Pin Direction Register GPIO<63:32> */ +#define GPDR2 0x40E00014 /* GPIO Pin Direction Register GPIO<80:64> */
-#define GPSR0 __REG(0x40E00018) /* GPIO Pin Output Set Register GPIO<31:0> */ -#define GPSR1 __REG(0x40E0001C) /* GPIO Pin Output Set Register GPIO<63:32> */ -#define GPSR2 __REG(0x40E00020) /* GPIO Pin Output Set Register GPIO<80:64> */ +#define GPSR0 0x40E00018 /* GPIO Pin Output Set Register GPIO<31:0> */ +#define GPSR1 0x40E0001C /* GPIO Pin Output Set Register GPIO<63:32> */ +#define GPSR2 0x40E00020 /* GPIO Pin Output Set Register GPIO<80:64> */
-#define GPCR0 __REG(0x40E00024) /* GPIO Pin Output Clear Register GPIO<31:0> */ -#define GPCR1 __REG(0x40E00028) /* GPIO Pin Output Clear Register GPIO <63:32> */ -#define GPCR2 __REG(0x40E0002C) /* GPIO Pin Output Clear Register GPIO <80:64> */ +#define GPCR0 0x40E00024 /* GPIO Pin Output Clear Register GPIO<31:0> */ +#define GPCR1 0x40E00028 /* GPIO Pin Output Clear Register GPIO <63:32> */ +#define GPCR2 0x40E0002C /* GPIO Pin Output Clear Register GPIO <80:64> */
-#define GRER0 __REG(0x40E00030) /* GPIO Rising-Edge Detect Register GPIO<31:0> */ -#define GRER1 __REG(0x40E00034) /* GPIO Rising-Edge Detect Register GPIO<63:32> */ -#define GRER2 __REG(0x40E00038) /* GPIO Rising-Edge Detect Register GPIO<80:64> */ +#define GRER0 0x40E00030 /* GPIO Rising-Edge Detect Register GPIO<31:0> */ +#define GRER1 0x40E00034 /* GPIO Rising-Edge Detect Register GPIO<63:32> */ +#define GRER2 0x40E00038 /* GPIO Rising-Edge Detect Register GPIO<80:64> */
-#define GFER0 __REG(0x40E0003C) /* GPIO Falling-Edge Detect Register GPIO<31:0> */ -#define GFER1 __REG(0x40E00040) /* GPIO Falling-Edge Detect Register GPIO<63:32> */ -#define GFER2 __REG(0x40E00044) /* GPIO Falling-Edge Detect Register GPIO<80:64> */ +#define GFER0 0x40E0003C /* GPIO Falling-Edge Detect Register GPIO<31:0> */ +#define GFER1 0x40E00040 /* GPIO Falling-Edge Detect Register GPIO<63:32> */ +#define GFER2 0x40E00044 /* GPIO Falling-Edge Detect Register GPIO<80:64> */
-#define GEDR0 __REG(0x40E00048) /* GPIO Edge Detect Status Register GPIO<31:0> */ -#define GEDR1 __REG(0x40E0004C) /* GPIO Edge Detect Status Register GPIO<63:32> */ -#define GEDR2 __REG(0x40E00050) /* GPIO Edge Detect Status Register GPIO<80:64> */ +#define GEDR0 0x40E00048 /* GPIO Edge Detect Status Register GPIO<31:0> */ +#define GEDR1 0x40E0004C /* GPIO Edge Detect Status Register GPIO<63:32> */ +#define GEDR2 0x40E00050 /* GPIO Edge Detect Status Register GPIO<80:64> */ + +#define GAFR0_L 0x40E00054 /* GPIO Alternate Function Select Register GPIO<15:0> */ +#define GAFR0_U 0x40E00058 /* GPIO Alternate Function Select Register GPIO<31:16> */ +#define GAFR1_L 0x40E0005C /* GPIO Alternate Function Select Register GPIO<47:32> */ +#define GAFR1_U 0x40E00060 /* GPIO Alternate Function Select Register GPIO<63:48> */ +#define GAFR2_L 0x40E00064 /* GPIO Alternate Function Select Register GPIO<79:64> */ +#define GAFR2_U 0x40E00068 /* GPIO Alternate Function Select Register GPIO 80 */ + +#if defined(CONFIG_PXA27X) || defined(CONFIG_CPU_MONAHANS) +#define GPLR3 0x40E00100 /* GPIO Pin-Level Register GPIO<127:96> */ +#define GPDR3 0x40E0010C /* GPIO Pin Direction Register GPIO<127:96> */ +#define GPSR3 0x40E00118 /* GPIO Pin Output Set Register GPIO<127:96> */ +#define GPCR3 0x40E00124 /* GPIO Pin Output Clear Register GPIO<127:96> */ +#define GRER3 0x40E00130 /* GPIO Rising-Edge Detect Register GPIO<127:96> */ +#define GFER3 0x40E0013C /* GPIO Falling-Edge Detect Register GPIO<127:96> */ +#define GEDR3 0x40E00148 /* GPIO Edge Detect Status Register GPIO<127:96> */ +#define GAFR3_L 0x40E0006C /* GPIO Alternate Function Select Register GPIO<111:96> */ +#define GAFR3_U 0x40E00070 /* GPIO Alternate Function Select Register GPIO<127:112> */ +#endif /* CONFIG_PXA27X || CONFIG_CPU_MONAHANS */
#ifdef CONFIG_CPU_MONAHANS -#define GPLR3 __REG(0x40E00100) /* GPIO Pin-Level Register GPIO<127:96> */ -#define GPDR3 __REG(0x40E0010C) /* GPIO Pin Direction Register GPIO<127:96> */ -#define GPSR3 __REG(0x40E00118) /* GPIO Pin Output Set Register GPIO<127:96> */ -#define GPCR3 __REG(0x40E00124) /* GPIO Pin Output Clear Register GPIO<127:96> */ -#define GRER3 __REG(0x40E00130) /* GPIO Rising-Edge Detect Register GPIO<127:96> */ -#define GFER3 __REG(0x40E0013C) /* GPIO Falling-Edge Detect Register GPIO<127:96> */ -#define GEDR3 __REG(0x40E00148) /* GPIO Edge Detect Status Register GPIO<127:96> */ - -#define GSDR0 __REG(0x40E00400) /* Bit-wise Set of GPDR[31:0] */ -#define GSDR1 __REG(0x40E00404) /* Bit-wise Set of GPDR[63:32] */ -#define GSDR2 __REG(0x40E00408) /* Bit-wise Set of GPDR[95:64] */ -#define GSDR3 __REG(0x40E0040C) /* Bit-wise Set of GPDR[127:96] */ - -#define GCDR0 __REG(0x40E00420) /* Bit-wise Clear of GPDR[31:0] */ -#define GCDR1 __REG(0x40E00424) /* Bit-wise Clear of GPDR[63:32] */ -#define GCDR2 __REG(0x40E00428) /* Bit-wise Clear of GPDR[95:64] */ -#define GCDR3 __REG(0x40E0042C) /* Bit-wise Clear of GPDR[127:96] */ - -#define GSRER0 __REG(0x40E00440) /* Set Rising Edge Det. Enable [31:0] */ -#define GSRER1 __REG(0x40E00444) /* Set Rising Edge Det. Enable [63:32] */ -#define GSRER2 __REG(0x40E00448) /* Set Rising Edge Det. Enable [95:64] */ -#define GSRER3 __REG(0x40E0044C) /* Set Rising Edge Det. Enable [127:96] */ - -#define GCRER0 __REG(0x40E00460) /* Clear Rising Edge Det. Enable [31:0] */ -#define GCRER1 __REG(0x40E00464) /* Clear Rising Edge Det. Enable [63:32] */ -#define GCRER2 __REG(0x40E00468) /* Clear Rising Edge Det. Enable [95:64] */ -#define GCRER3 __REG(0x40E0046C) /* Clear Rising Edge Det. Enable[127:96] */ - -#define GSFER0 __REG(0x40E00480) /* Set Falling Edge Det. Enable [31:0] */ -#define GSFER1 __REG(0x40E00484) /* Set Falling Edge Det. Enable [63:32] */ -#define GSFER2 __REG(0x40E00488) /* Set Falling Edge Det. Enable [95:64] */ -#define GSFER3 __REG(0x40E0048C) /* Set Falling Edge Det. Enable[127:96] */ - -#define GCFER0 __REG(0x40E004A0) /* Clr Falling Edge Det. Enable [31:0] */ -#define GCFER1 __REG(0x40E004A4) /* Clr Falling Edge Det. Enable [63:32] */ -#define GCFER2 __REG(0x40E004A8) /* Clr Falling Edge Det. Enable [95:64] */ -#define GCFER3 __REG(0x40E004AC) /* Clr Falling Edge Det. Enable[127:96] */ - -#define GSDR(x) __REG2(0x40E00400, ((x) & 0x60) >> 3) -#define GCDR(x) __REG2(0x40E00420, ((x) & 0x60) >> 3) - -/* Multi-funktion Pin Registers, uncomplete, only: - * - GPIO - * - Data Flash DF_* pins defined. +#define GSDR0 0x40E00400 /* Bit-wise Set of GPDR[31:0] */ +#define GSDR1 0x40E00404 /* Bit-wise Set of GPDR[63:32] */ +#define GSDR2 0x40E00408 /* Bit-wise Set of GPDR[95:64] */ +#define GSDR3 0x40E0040C /* Bit-wise Set of GPDR[127:96] */ + +#define GCDR0 0x40E00420 /* Bit-wise Clear of GPDR[31:0] */ +#define GCDR1 0x40E00424 /* Bit-wise Clear of GPDR[63:32] */ +#define GCDR2 0x40E00428 /* Bit-wise Clear of GPDR[95:64] */ +#define GCDR3 0x40E0042C /* Bit-wise Clear of GPDR[127:96] */ + +#define GSRER0 0x40E00440 /* Set Rising Edge Det. Enable [31:0] */ +#define GSRER1 0x40E00444 /* Set Rising Edge Det. Enable [63:32] */ +#define GSRER2 0x40E00448 /* Set Rising Edge Det. Enable [95:64] */ +#define GSRER3 0x40E0044C /* Set Rising Edge Det. Enable [127:96] */ + +#define GCRER0 0x40E00460 /* Clear Rising Edge Det. Enable [31:0] */ +#define GCRER1 0x40E00464 /* Clear Rising Edge Det. Enable [63:32] */ +#define GCRER2 0x40E00468 /* Clear Rising Edge Det. Enable [95:64] */ +#define GCRER3 0x40E0046C /* Clear Rising Edge Det. Enable[127:96] */ + +#define GSFER0 0x40E00480 /* Set Falling Edge Det. Enable [31:0] */ +#define GSFER1 0x40E00484 /* Set Falling Edge Det. Enable [63:32] */ +#define GSFER2 0x40E00488 /* Set Falling Edge Det. Enable [95:64] */ +#define GSFER3 0x40E0048C /* Set Falling Edge Det. Enable[127:96] */ + +#define GCFER0 0x40E004A0 /* Clr Falling Edge Det. Enable [31:0] */ +#define GCFER1 0x40E004A4 /* Clr Falling Edge Det. Enable [63:32] */ +#define GCFER2 0x40E004A8 /* Clr Falling Edge Det. Enable [95:64] */ +#define GCFER3 0x40E004AC /* Clr Falling Edge Det. Enable[127:96] */ + +#define GSDR(x) (0x40E00400 | ((x) & 0x60) >> 3) +#define GCDR(x) (0x40E00420 | ((x) & 0x60) >> 3) +#endif + +#define _GPLR(x) (0x40E00000 + (((x) & 0x60) >> 3)) +#define _GPDR(x) (0x40E0000C + (((x) & 0x60) >> 3)) +#define _GPSR(x) (0x40E00018 + (((x) & 0x60) >> 3)) +#define _GPCR(x) (0x40E00024 + (((x) & 0x60) >> 3)) +#define _GRER(x) (0x40E00030 + (((x) & 0x60) >> 3)) +#define _GFER(x) (0x40E0003C + (((x) & 0x60) >> 3)) +#define _GEDR(x) (0x40E00048 + (((x) & 0x60) >> 3)) +#define _GAFR(x) (0x40E00054 + (((x) & 0x70) >> 2)) + +#if defined(CONFIG_PXA27X) || defined(CONFIG_CPU_MONAHANS) +#define GPLR(x) (((((x) & 0x7f) < 96) ? _GPLR(x) : GPLR3)) +#define GPDR(x) (((((x) & 0x7f) < 96) ? _GPDR(x) : GPDR3)) +#define GPSR(x) (((((x) & 0x7f) < 96) ? _GPSR(x) : GPSR3)) +#define GPCR(x) (((((x) & 0x7f) < 96) ? _GPCR(x) : GPCR3)) +#define GRER(x) (((((x) & 0x7f) < 96) ? _GRER(x) : GRER3)) +#define GFER(x) (((((x) & 0x7f) < 96) ? _GFER(x) : GFER3)) +#define GEDR(x) (((((x) & 0x7f) < 96) ? _GEDR(x) : GEDR3)) +#define GAFR(x) (((((x) & 0x7f) < 96) ? _GAFR(x) : \ + ((((x) & 0x7f) < 112) ? GAFR3_L : GAFR3_U))) +#else +#define GPLR(x) _GPLR(x) +#define GPDR(x) _GPDR(x) +#define GPSR(x) _GPSR(x) +#define GPCR(x) _GPCR(x) +#define GRER(x) _GRER(x) +#define GFER(x) _GFER(x) +#define GEDR(x) _GEDR(x) +#define GAFR(x) _GAFR(x) +#endif + +#define GPIO_bit(x) (1 << ((x) & 0x1f)) + +/******************************************************************************/ +/* + * Multi-function Pin Registers: */ -#define GPIO0 __REG(0x40e10124) -#define GPIO1 __REG(0x40e10128) -#define GPIO2 __REG(0x40e1012c) -#define GPIO3 __REG(0x40e10130) -#define GPIO4 __REG(0x40e10134) -#define nXCVREN __REG(0x40e10138) - -#define DF_CLE_NOE __REG(0x40e10204) -#define DF_ALE_WE1 __REG(0x40e10208) - -#define DF_SCLK_E __REG(0x40e10210) -#define nBE0 __REG(0x40e10214) -#define nBE1 __REG(0x40e10218) -#define DF_ALE_WE2 __REG(0x40e1021c) -#define DF_INT_RnB __REG(0x40e10220) -#define DF_nCS0 __REG(0x40e10224) -#define DF_nCS1 __REG(0x40e10228) -#define DF_nWE __REG(0x40e1022c) -#define DF_nRE __REG(0x40e10230) -#define nLUA __REG(0x40e10234) -#define nLLA __REG(0x40e10238) -#define DF_ADDR0 __REG(0x40e1023c) -#define DF_ADDR1 __REG(0x40e10240) -#define DF_ADDR2 __REG(0x40e10244) -#define DF_ADDR3 __REG(0x40e10248) -#define DF_IO0 __REG(0x40e1024c) -#define DF_IO8 __REG(0x40e10250) -#define DF_IO1 __REG(0x40e10254) -#define DF_IO9 __REG(0x40e10258) -#define DF_IO2 __REG(0x40e1025c) -#define DF_IO10 __REG(0x40e10260) -#define DF_IO3 __REG(0x40e10264) -#define DF_IO11 __REG(0x40e10268) -#define DF_IO4 __REG(0x40e1026c) -#define DF_IO12 __REG(0x40e10270) -#define DF_IO5 __REG(0x40e10274) -#define DF_IO13 __REG(0x40e10278) -#define DF_IO6 __REG(0x40e1027c) -#define DF_IO14 __REG(0x40e10280) -#define DF_IO7 __REG(0x40e10284) -#define DF_IO15 __REG(0x40e10288) - -#define GPIO5 __REG(0x40e1028c) -#define GPIO6 __REG(0x40e10290) -#define GPIO7 __REG(0x40e10294) -#define GPIO8 __REG(0x40e10298) -#define GPIO9 __REG(0x40e1029c) - -#define GPIO11 __REG(0x40e102a0) -#define GPIO12 __REG(0x40e102a4) -#define GPIO13 __REG(0x40e102a8) -#define GPIO14 __REG(0x40e102ac) -#define GPIO15 __REG(0x40e102b0) -#define GPIO16 __REG(0x40e102b4) -#define GPIO17 __REG(0x40e102b8) -#define GPIO18 __REG(0x40e102bc) -#define GPIO19 __REG(0x40e102c0) -#define GPIO20 __REG(0x40e102c4) -#define GPIO21 __REG(0x40e102c8) -#define GPIO22 __REG(0x40e102cc) -#define GPIO23 __REG(0x40e102d0) -#define GPIO24 __REG(0x40e102d4) -#define GPIO25 __REG(0x40e102d8) -#define GPIO26 __REG(0x40e102dc) - -#define GPIO27 __REG(0x40e10400) -#define GPIO28 __REG(0x40e10404) -#define GPIO29 __REG(0x40e10408) -#define GPIO30 __REG(0x40e1040c) -#define GPIO31 __REG(0x40e10410) -#define GPIO32 __REG(0x40e10414) -#define GPIO33 __REG(0x40e10418) -#define GPIO34 __REG(0x40e1041c) -#define GPIO35 __REG(0x40e10420) -#define GPIO36 __REG(0x40e10424) -#define GPIO37 __REG(0x40e10428) -#define GPIO38 __REG(0x40e1042c) -#define GPIO39 __REG(0x40e10430) -#define GPIO40 __REG(0x40e10434) -#define GPIO41 __REG(0x40e10438) -#define GPIO42 __REG(0x40e1043c) -#define GPIO43 __REG(0x40e10440) -#define GPIO44 __REG(0x40e10444) -#define GPIO45 __REG(0x40e10448) -#define GPIO46 __REG(0x40e1044c) -#define GPIO47 __REG(0x40e10450) -#define GPIO48 __REG(0x40e10454) - -#define GPIO10 __REG(0x40e10458) - -#define GPIO49 __REG(0x40e1045c) -#define GPIO50 __REG(0x40e10460) -#define GPIO51 __REG(0x40e10464) -#define GPIO52 __REG(0x40e10468) -#define GPIO53 __REG(0x40e1046c) -#define GPIO54 __REG(0x40e10470) -#define GPIO55 __REG(0x40e10474) -#define GPIO56 __REG(0x40e10478) -#define GPIO57 __REG(0x40e1047c) -#define GPIO58 __REG(0x40e10480) -#define GPIO59 __REG(0x40e10484) -#define GPIO60 __REG(0x40e10488) -#define GPIO61 __REG(0x40e1048c) -#define GPIO62 __REG(0x40e10490) - -#define GPIO6_2 __REG(0x40e10494) -#define GPIO7_2 __REG(0x40e10498) -#define GPIO8_2 __REG(0x40e1049c) -#define GPIO9_2 __REG(0x40e104a0) -#define GPIO10_2 __REG(0x40e104a4) -#define GPIO11_2 __REG(0x40e104a8) -#define GPIO12_2 __REG(0x40e104ac) -#define GPIO13_2 __REG(0x40e104b0) - -#define GPIO63 __REG(0x40e104b4) -#define GPIO64 __REG(0x40e104b8) -#define GPIO65 __REG(0x40e104bc) -#define GPIO66 __REG(0x40e104c0) -#define GPIO67 __REG(0x40e104c4) -#define GPIO68 __REG(0x40e104c8) -#define GPIO69 __REG(0x40e104cc) -#define GPIO70 __REG(0x40e104d0) -#define GPIO71 __REG(0x40e104d4) -#define GPIO72 __REG(0x40e104d8) -#define GPIO73 __REG(0x40e104dc) - -#define GPIO14_2 __REG(0x40e104e0) -#define GPIO15_2 __REG(0x40e104e4) -#define GPIO16_2 __REG(0x40e104e8) -#define GPIO17_2 __REG(0x40e104ec) - -#define GPIO74 __REG(0x40e104f0) -#define GPIO75 __REG(0x40e104f4) -#define GPIO76 __REG(0x40e104f8) -#define GPIO77 __REG(0x40e104fc) -#define GPIO78 __REG(0x40e10500) -#define GPIO79 __REG(0x40e10504) -#define GPIO80 __REG(0x40e10508) -#define GPIO81 __REG(0x40e1050c) -#define GPIO82 __REG(0x40e10510) -#define GPIO83 __REG(0x40e10514) -#define GPIO84 __REG(0x40e10518) -#define GPIO85 __REG(0x40e1051c) -#define GPIO86 __REG(0x40e10520) -#define GPIO87 __REG(0x40e10524) -#define GPIO88 __REG(0x40e10528) -#define GPIO89 __REG(0x40e1052c) -#define GPIO90 __REG(0x40e10530) -#define GPIO91 __REG(0x40e10534) -#define GPIO92 __REG(0x40e10538) -#define GPIO93 __REG(0x40e1053c) -#define GPIO94 __REG(0x40e10540) -#define GPIO95 __REG(0x40e10544) -#define GPIO96 __REG(0x40e10548) -#define GPIO97 __REG(0x40e1054c) -#define GPIO98 __REG(0x40e10550) - -#define GPIO99 __REG(0x40e10600) -#define GPIO100 __REG(0x40e10604) -#define GPIO101 __REG(0x40e10608) -#define GPIO102 __REG(0x40e1060c) -#define GPIO103 __REG(0x40e10610) -#define GPIO104 __REG(0x40e10614) -#define GPIO105 __REG(0x40e10618) -#define GPIO106 __REG(0x40e1061c) -#define GPIO107 __REG(0x40e10620) -#define GPIO108 __REG(0x40e10624) -#define GPIO109 __REG(0x40e10628) -#define GPIO110 __REG(0x40e1062c) -#define GPIO111 __REG(0x40e10630) -#define GPIO112 __REG(0x40e10634) - -#define GPIO113 __REG(0x40e10638) -#define GPIO114 __REG(0x40e1063c) -#define GPIO115 __REG(0x40e10640) -#define GPIO116 __REG(0x40e10644) -#define GPIO117 __REG(0x40e10648) -#define GPIO118 __REG(0x40e1064c) -#define GPIO119 __REG(0x40e10650) -#define GPIO120 __REG(0x40e10654) -#define GPIO121 __REG(0x40e10658) -#define GPIO122 __REG(0x40e1065c) -#define GPIO123 __REG(0x40e10660) -#define GPIO124 __REG(0x40e10664) -#define GPIO125 __REG(0x40e10668) -#define GPIO126 __REG(0x40e1066c) -#define GPIO127 __REG(0x40e10670) - -#define GPIO0_2 __REG(0x40e10674) -#define GPIO1_2 __REG(0x40e10678) -#define GPIO2_2 __REG(0x40e1067c) -#define GPIO3_2 __REG(0x40e10680) -#define GPIO4_2 __REG(0x40e10684) -#define GPIO5_2 __REG(0x40e10688) +/* PXA320 */ +#if defined(CONFIG_CPU_PXA320) +#define DF_IO0 0x40e1024c +#define DF_IO1 0x40e10254 +#define DF_IO2 0x40e1025c +#define DF_IO3 0x40e10264 +#define DF_IO4 0x40e1026c +#define DF_IO5 0x40e10274 +#define DF_IO6 0x40e1027c +#define DF_IO7 0x40e10284 +#define DF_IO8 0x40e10250 +#define DF_IO9 0x40e10258 +#define DF_IO10 0x40e10260 +#define DF_IO11 0x40e10268 +#define DF_IO12 0x40e10270 +#define DF_IO13 0x40e10278 +#define DF_IO14 0x40e10280 +#define DF_IO15 0x40e10288 +#define DF_CLE_nOE 0x40e10204 +#define DF_ALE_nWE1 0x40e10208 +#define DF_ALE_nWE2 0x40e1021c +#define DF_SCLK_E 0x40e10210 +#define DF_nCS0 0x40e10224 +#define DF_nCS1 0x40e10228 +#define nBE0 0x40e10214 +#define nBE1 0x40e10218 +#define nLUA 0x40e10234 +#define nLLA 0x40e10238 +#define DF_ADDR0 0x40e1023c +#define DF_ADDR1 0x40e10240 +#define DF_ADDR2 0x40e10244 +#define DF_ADDR3 0x40e10248 +#define DF_INT_RnB 0x40e10220 +#define DF_nCS0 0x40e10224 +#define DF_nCS1 0x40e10228 +#define DF_nWE 0x40e1022c +#define DF_nRE 0x40e10230 + +#define nXCVREN 0x40e10138 + +#define GPIO0 0x40e10124 +#define GPIO1 0x40e10128 +#define GPIO2 0x40e1012c +#define GPIO3 0x40e10130 +#define GPIO4 0x40e10134 +#define GPIO5 0x40e1028c +#define GPIO6 0x40e10290 +#define GPIO7 0x40e10294 +#define GPIO8 0x40e10298 +#define GPIO9 0x40e1029c +#define GPIO10 0x40e10458 +#define GPIO11 0x40e102a0 +#define GPIO12 0x40e102a4 +#define GPIO13 0x40e102a8 +#define GPIO14 0x40e102ac +#define GPIO15 0x40e102b0 +#define GPIO16 0x40e102b4 +#define GPIO17 0x40e102b8 +#define GPIO18 0x40e102bc +#define GPIO19 0x40e102c0 +#define GPIO20 0x40e102c4 +#define GPIO21 0x40e102c8 +#define GPIO22 0x40e102cc +#define GPIO23 0x40e102d0 +#define GPIO24 0x40e102d4 +#define GPIO25 0x40e102d8 +#define GPIO26 0x40e102dc + +#define GPIO27 0x40e10400 +#define GPIO28 0x40e10404 +#define GPIO29 0x40e10408 +#define GPIO30 0x40e1040c +#define GPIO31 0x40e10410 +#define GPIO32 0x40e10414 +#define GPIO33 0x40e10418 +#define GPIO34 0x40e1041c +#define GPIO35 0x40e10420 +#define GPIO36 0x40e10424 +#define GPIO37 0x40e10428 +#define GPIO38 0x40e1042c +#define GPIO39 0x40e10430 +#define GPIO40 0x40e10434 +#define GPIO41 0x40e10438 +#define GPIO42 0x40e1043c +#define GPIO43 0x40e10440 +#define GPIO44 0x40e10444 +#define GPIO45 0x40e10448 +#define GPIO46 0x40e1044c +#define GPIO47 0x40e10450 +#define GPIO48 0x40e10454 +#define GPIO49 0x40e1045c +#define GPIO50 0x40e10460 +#define GPIO51 0x40e10464 +#define GPIO52 0x40e10468 +#define GPIO53 0x40e1046c +#define GPIO54 0x40e10470 +#define GPIO55 0x40e10474 +#define GPIO56 0x40e10478 +#define GPIO57 0x40e1047c +#define GPIO58 0x40e10480 +#define GPIO59 0x40e10484 +#define GPIO60 0x40e10488 +#define GPIO61 0x40e1048c +#define GPIO62 0x40e10490 + +#define GPIO6_2 0x40e10494 +#define GPIO7_2 0x40e10498 +#define GPIO8_2 0x40e1049c +#define GPIO9_2 0x40e104a0 +#define GPIO10_2 0x40e104a4 +#define GPIO11_2 0x40e104a8 +#define GPIO12_2 0x40e104ac +#define GPIO13_2 0x40e104b0 + +#define GPIO63 0x40e104b4 +#define GPIO64 0x40e104b8 +#define GPIO65 0x40e104bc +#define GPIO66 0x40e104c0 +#define GPIO67 0x40e104c4 +#define GPIO68 0x40e104c8 +#define GPIO69 0x40e104cc +#define GPIO70 0x40e104d0 +#define GPIO71 0x40e104d4 +#define GPIO72 0x40e104d8 +#define GPIO73 0x40e104dc + +#define GPIO14_2 0x40e104e0 +#define GPIO15_2 0x40e104e4 +#define GPIO16_2 0x40e104e8 +#define GPIO17_2 0x40e104ec + +#define GPIO74 0x40e104f0 +#define GPIO75 0x40e104f4 +#define GPIO76 0x40e104f8 +#define GPIO77 0x40e104fc +#define GPIO78 0x40e10500 +#define GPIO79 0x40e10504 +#define GPIO80 0x40e10508 +#define GPIO81 0x40e1050c +#define GPIO82 0x40e10510 +#define GPIO83 0x40e10514 +#define GPIO84 0x40e10518 +#define GPIO85 0x40e1051c +#define GPIO86 0x40e10520 +#define GPIO87 0x40e10524 +#define GPIO88 0x40e10528 +#define GPIO89 0x40e1052c +#define GPIO90 0x40e10530 +#define GPIO91 0x40e10534 +#define GPIO92 0x40e10538 +#define GPIO93 0x40e1053c +#define GPIO94 0x40e10540 +#define GPIO95 0x40e10544 +#define GPIO96 0x40e10548 +#define GPIO97 0x40e1054c +#define GPIO98 0x40e10550 + +#define GPIO99 0x40e10600 +#define GPIO100 0x40e10604 +#define GPIO101 0x40e10608 +#define GPIO102 0x40e1060c +#define GPIO103 0x40e10610 +#define GPIO104 0x40e10614 +#define GPIO105 0x40e10618 +#define GPIO106 0x40e1061c +#define GPIO107 0x40e10620 +#define GPIO108 0x40e10624 +#define GPIO109 0x40e10628 +#define GPIO110 0x40e1062c +#define GPIO111 0x40e10630 +#define GPIO112 0x40e10634 + +#define GPIO113 0x40e10638 +#define GPIO114 0x40e1063c +#define GPIO115 0x40e10640 +#define GPIO116 0x40e10644 +#define GPIO117 0x40e10648 +#define GPIO118 0x40e1064c +#define GPIO119 0x40e10650 +#define GPIO120 0x40e10654 +#define GPIO121 0x40e10658 +#define GPIO122 0x40e1065c +#define GPIO123 0x40e10660 +#define GPIO124 0x40e10664 +#define GPIO125 0x40e10668 +#define GPIO126 0x40e1066c +#define GPIO127 0x40e10670 + +#define GPIO0_2 0x40e10674 +#define GPIO1_2 0x40e10678 +#define GPIO2_2 0x40e1067c +#define GPIO3_2 0x40e10680 +#define GPIO4_2 0x40e10684 +#define GPIO5_2 0x40e10688 + +/* PXA300 and PXA310 */ +#elif defined(CONFIG_CPU_PXA300) || defined(CONFIG_CPU_PXA310) +#define DF_IO0 0x40e10220 +#define DF_IO1 0x40e10228 +#define DF_IO2 0x40e10230 +#define DF_IO3 0x40e10238 +#define DF_IO4 0x40e10258 +#define DF_IO5 0x40e10260 +#define DF_IO7 0x40e10270 +#define DF_IO6 0x40e10268 +#define DF_IO8 0x40e10224 +#define DF_IO9 0x40e1022c +#define DF_IO10 0x40e10234 +#define DF_IO11 0x40e1023c +#define DF_IO12 0x40e1025c +#define DF_IO13 0x40e10264 +#define DF_IO14 0x40e1026c +#define DF_IO15 0x40e10274 +#define DF_CLE_NOE 0x40e10240 +#define DF_ALE_nWE 0x40e1020c +#define DF_SCLK_E 0x40e10250 +#define nCS0 0x40e100c4 +#define nCS1 0x40e100c0 +#define nBE0 0x40e10204 +#define nBE1 0x40e10208 +#define nLUA 0x40e10244 +#define nLLA 0x40e10254 +#define DF_ADDR0 0x40e10210 +#define DF_ADDR1 0x40e10214 +#define DF_ADDR2 0x40e10218 +#define DF_ADDR3 0x40e1021c +#define DF_INT_RnB 0x40e100c8 +#define DF_nCS0 0x40e10248 +#define DF_nCS1 0x40e10278 +#define DF_nWE 0x40e100cc +#define DF_nRE 0x40e10200 + +#define GPIO0 0x40e100b4 +#define GPIO1 0x40e100b8 +#define GPIO2 0x40e100bc +#define GPIO3 0x40e1027c +#define GPIO4 0x40e10280 + +#define GPIO5 0x40e10284 +#define GPIO6 0x40e10288 +#define GPIO7 0x40e1028c +#define GPIO8 0x40e10290 +#define GPIO9 0x40e10294 +#define GPIO10 0x40e10298 +#define GPIO11 0x40e1029c +#define GPIO12 0x40e102a0 +#define GPIO13 0x40e102a4 +#define GPIO14 0x40e102a8 +#define GPIO15 0x40e102ac +#define GPIO16 0x40e102b0 +#define GPIO17 0x40e102b4 +#define GPIO18 0x40e102b8 +#define GPIO19 0x40e102bc +#define GPIO20 0x40e102c0 +#define GPIO21 0x40e102c4 +#define GPIO22 0x40e102c8 +#define GPIO23 0x40e102cc +#define GPIO24 0x40e102d0 +#define GPIO25 0x40e102d4 +#define GPIO26 0x40e102d8 + +#define GPIO27 0x40e10400 +#define GPIO28 0x40e10404 +#define GPIO29 0x40e10408 +#define ULPI_STP 0x40e1040c +#define ULPI_NXT 0x40e10410 +#define ULPI_DIR 0x40e10414 +#define GPIO30 0x40e10418 +#define GPIO31 0x40e1041c +#define GPIO32 0x40e10420 +#define GPIO33 0x40e10424 +#define GPIO34 0x40e10428 +#define GPIO35 0x40e1042c +#define GPIO36 0x40e10430 +#define GPIO37 0x40e10434 +#define GPIO38 0x40e10438 +#define GPIO39 0x40e1043c +#define GPIO40 0x40e10440 +#define GPIO41 0x40e10444 +#define GPIO42 0x40e10448 +#define GPIO43 0x40e1044c +#define GPIO44 0x40e10450 +#define GPIO45 0x40e10454 +#define GPIO46 0x40e10458 +#define GPIO47 0x40e1045c +#define GPIO48 0x40e10460 + +#define GPIO49 0x40e10464 +#define GPIO50 0x40e10468 +#define GPIO51 0x40e1046c +#define GPIO52 0x40e10470 +#define GPIO53 0x40e10474 +#define GPIO54 0x40e10478 +#define GPIO55 0x40e1047c +#define GPIO56 0x40e10480 +#define GPIO57 0x40e10484 +#define GPIO58 0x40e10488 +#define GPIO59 0x40e1048c +#define GPIO60 0x40e10490 +#define GPIO61 0x40e10494 +#define GPIO62 0x40e10498 +#define GPIO63 0x40e1049c +#define GPIO64 0x40e104a0 +#define GPIO65 0x40e104a4 +#define GPIO66 0x40e104a8 +#define GPIO67 0x40e104ac +#define GPIO68 0x40e104b0 +#define GPIO69 0x40e104b4 +#define GPIO70 0x40e104b8 +#define GPIO71 0x40e104bc +#define GPIO72 0x40e104c0 +#define GPIO73 0x40e104c4 +#define GPIO74 0x40e104c8 +#define GPIO75 0x40e104cc +#define GPIO76 0x40e104d0 +#define GPIO77 0x40e104d4 +#define GPIO78 0x40e104d8 +#define GPIO79 0x40e104dc +#define GPIO80 0x40e104e0 +#define GPIO81 0x40e104e4 +#define GPIO82 0x40e104e8 +#define GPIO83 0x40e104ec +#define GPIO84 0x40e104f0 +#define GPIO85 0x40e104f4 +#define GPIO86 0x40e104f8 +#define GPIO87 0x40e104fc +#define GPIO88 0x40e10500 +#define GPIO89 0x40e10504 +#define GPIO90 0x40e10508 +#define GPIO91 0x40e1050c +#define GPIO92 0x40e10510 +#define GPIO93 0x40e10514 +#define GPIO94 0x40e10518 +#define GPIO95 0x40e1051c +#define GPIO96 0x40e10520 +#define GPIO97 0x40e10524 +#define GPIO98 0x40e10528 + +#define GPIO99 0x40e10600 +#define GPIO100 0x40e10604 +#define GPIO101 0x40e10608 +#define GPIO102 0x40e1060c +#define GPIO103 0x40e10610 +#define GPIO104 0x40e10614 +#define GPIO105 0x40e10618 +#define GPIO106 0x40e1061c +#define GPIO107 0x40e10620 +#define GPIO108 0x40e10624 +#define GPIO109 0x40e10628 +#define GPIO110 0x40e1062c +#define GPIO111 0x40e10630 +#define GPIO112 0x40e10634 + +#define GPIO113 0x40e10638 +#define GPIO114 0x40e1063c +#define GPIO115 0x40e10640 +#define GPIO116 0x40e10644 +#define GPIO117 0x40e10648 +#define GPIO118 0x40e1064c +#define GPIO119 0x40e10650 +#define GPIO120 0x40e10654 +#define GPIO121 0x40e10658 +#define GPIO122 0x40e1065c +#define GPIO123 0x40e10660 +#define GPIO124 0x40e10664 +#define GPIO125 0x40e10668 +#define GPIO126 0x40e1066c +#define GPIO127 0x40e10670 + +#define GPIO0_2 0x40e10674 +#define GPIO1_2 0x40e10678 +#define GPIO2_2 0x40e102dc +#define GPIO3_2 0x40e102e0 +#define GPIO4_2 0x40e102e4 +#define GPIO5_2 0x40e102e8 +#define GPIO6_2 0x40e102ec + +#ifndef CONFIG_CPU_PXA300 /* PXA310 only */ +#define GPIO7_2 0x40e1052c +#define GPIO8_2 0x40e10530 +#define GPIO9_2 0x40e10534 +#define GPIO10_2 0x40e10538 +#endif +#endif
+#ifdef CONFIG_CPU_MONAHANS /* MFPR Bit Definitions, see 4-10, Vol. 1 */ #define PULL_SEL 0x8000 #define PULLUP_EN 0x4000 @@ -1470,62 +1854,8 @@ typedef void (*ExcpHndlr) (void) ; #define AF_SEL_6 0x6 /* Alternate function 6 */ #define AF_SEL_7 0x7 /* Alternate function 7 */
- -#else /* CONFIG_CPU_MONAHANS */ - -#define GAFR0_L __REG(0x40E00054) /* GPIO Alternate Function Select Register GPIO<15:0> */ -#define GAFR0_U __REG(0x40E00058) /* GPIO Alternate Function Select Register GPIO<31:16> */ -#define GAFR1_L __REG(0x40E0005C) /* GPIO Alternate Function Select Register GPIO<47:32> */ -#define GAFR1_U __REG(0x40E00060) /* GPIO Alternate Function Select Register GPIO<63:48> */ -#define GAFR2_L __REG(0x40E00064) /* GPIO Alternate Function Select Register GPIO<79:64> */ -#define GAFR2_U __REG(0x40E00068) /* GPIO Alternate Function Select Register GPIO 80 */ #endif /* CONFIG_CPU_MONAHANS */
-/* More handy macros. The argument is a literal GPIO number. */ - -#define GPIO_bit(x) (1 << ((x) & 0x1f)) - -#ifdef CONFIG_PXA27X - -/* Interrupt Controller */ - -#define ICIP2 __REG(0x40D0009C) /* Interrupt Controller IRQ Pending Register 2 */ -#define ICMR2 __REG(0x40D000A0) /* Interrupt Controller Mask Register 2 */ -#define ICLR2 __REG(0x40D000A4) /* Interrupt Controller Level Register 2 */ -#define ICFP2 __REG(0x40D000A8) /* Interrupt Controller FIQ Pending Register 2 */ -#define ICPR2 __REG(0x40D000AC) /* Interrupt Controller Pending Register 2 */ - -#define _GPLR(x) __REG2(0x40E00000, ((x) & 0x60) >> 3) -#define _GPDR(x) __REG2(0x40E0000C, ((x) & 0x60) >> 3) -#define _GPSR(x) __REG2(0x40E00018, ((x) & 0x60) >> 3) -#define _GPCR(x) __REG2(0x40E00024, ((x) & 0x60) >> 3) -#define _GRER(x) __REG2(0x40E00030, ((x) & 0x60) >> 3) -#define _GFER(x) __REG2(0x40E0003C, ((x) & 0x60) >> 3) -#define _GEDR(x) __REG2(0x40E00048, ((x) & 0x60) >> 3) -#define _GAFR(x) __REG2(0x40E00054, ((x) & 0x70) >> 2) - -#define GPLR(x) (*((((x) & 0x7f) < 96) ? &_GPLR(x) : &GPLR3)) -#define GPDR(x) (*((((x) & 0x7f) < 96) ? &_GPDR(x) : &GPDR3)) -#define GPSR(x) (*((((x) & 0x7f) < 96) ? &_GPSR(x) : &GPSR3)) -#define GPCR(x) (*((((x) & 0x7f) < 96) ? &_GPCR(x) : &GPCR3)) -#define GRER(x) (*((((x) & 0x7f) < 96) ? &_GRER(x) : &GRER3)) -#define GFER(x) (*((((x) & 0x7f) < 96) ? &_GFER(x) : &GFER3)) -#define GEDR(x) (*((((x) & 0x7f) < 96) ? &_GEDR(x) : &GEDR3)) -#define GAFR(x) (*((((x) & 0x7f) < 96) ? &_GAFR(x) : \ - ((((x) & 0x7f) < 112) ? &GAFR3_L : &GAFR3_U))) -#else - -#define GPLR(x) __REG2(0x40E00000, ((x) & 0x60) >> 3) -#define GPDR(x) __REG2(0x40E0000C, ((x) & 0x60) >> 3) -#define GPSR(x) __REG2(0x40E00018, ((x) & 0x60) >> 3) -#define GPCR(x) __REG2(0x40E00024, ((x) & 0x60) >> 3) -#define GRER(x) __REG2(0x40E00030, ((x) & 0x60) >> 3) -#define GFER(x) __REG2(0x40E0003C, ((x) & 0x60) >> 3) -#define GEDR(x) __REG2(0x40E00048, ((x) & 0x60) >> 3) -#define GAFR(x) __REG2(0x40E00054, ((x) & 0x70) >> 2) - -#endif - /* GPIO alternate function assignments */
#define GPIO1_RST 1 /* reset */ @@ -1732,63 +2062,63 @@ typedef void (*ExcpHndlr) (void) ; */ #ifdef CONFIG_CPU_MONAHANS
-#define ASCR __REG(0x40F40000) /* Application Subsystem Power Status/Control Register */ -#define ARSR __REG(0x40F40004) /* Application Subsystem Reset Status Register */ -#define AD3ER __REG(0x40F40008) /* Application Subsystem D3 state Wakeup Enable Register */ -#define AD3SR __REG(0x40F4000C) /* Application Subsystem D3 state Wakeup Status Register */ -#define AD2D0ER __REG(0x40F40010) /* Application Subsystem D2 to D0 state Wakeup Enable Register */ -#define AD2D0SR __REG(0x40F40014) /* Application Subsystem D2 to D0 state Wakeup Status Register */ -#define AD2D1ER __REG(0x40F40018) /* Application Subsystem D2 to D1 state Wakeup Enable Register */ -#define AD2D1SR __REG(0x40F4001C) /* Application Subsystem D2 to D1 state Wakeup Status Register */ -#define AD1D0ER __REG(0x40F40020) /* Application Subsystem D1 to D0 state Wakeup Enable Register */ -#define AD1D0SR __REG(0x40F40024) /* Application Subsystem D1 to D0 state Wakeup Status Register */ -#define ASDCNT __REG(0x40F40028) /* Application Subsystem SRAM Drowsy Count Register */ -#define AD3R __REG(0x40F40030) /* Application Subsystem D3 State Configuration Register */ -#define AD2R __REG(0x40F40034) /* Application Subsystem D2 State Configuration Register */ -#define AD1R __REG(0x40F40038) /* Application Subsystem D1 State Configuration Register */ - -#define PMCR __REG(0x40F50000) /* Power Manager Control Register */ -#define PSR __REG(0x40F50004) /* Power Manager S2 Status Register */ -#define PSPR __REG(0x40F50008) /* Power Manager Scratch Pad Register */ -#define PCFR __REG(0x40F5000C) /* Power Manager General Configuration Register */ -#define PWER __REG(0x40F50010) /* Power Manager Wake-up Enable Register */ -#define PWSR __REG(0x40F50014) /* Power Manager Wake-up Status Register */ -#define PECR __REG(0x40F50018) /* Power Manager EXT_WAKEUP[1:0] Control Register */ -#define DCDCSR __REG(0x40F50080) /* DC-DC Controller Status Register */ -#define PVCR __REG(0x40F50100) /* Power Manager Voltage Change Control Register */ -#define PCMD(x) __REG(0x40F50110 + x*4) -#define PCMD0 __REG(0x40F50110 + 0 * 4) -#define PCMD1 __REG(0x40F50110 + 1 * 4) -#define PCMD2 __REG(0x40F50110 + 2 * 4) -#define PCMD3 __REG(0x40F50110 + 3 * 4) -#define PCMD4 __REG(0x40F50110 + 4 * 4) -#define PCMD5 __REG(0x40F50110 + 5 * 4) -#define PCMD6 __REG(0x40F50110 + 6 * 4) -#define PCMD7 __REG(0x40F50110 + 7 * 4) -#define PCMD8 __REG(0x40F50110 + 8 * 4) -#define PCMD9 __REG(0x40F50110 + 9 * 4) -#define PCMD10 __REG(0x40F50110 + 10 * 4) -#define PCMD11 __REG(0x40F50110 + 11 * 4) -#define PCMD12 __REG(0x40F50110 + 12 * 4) -#define PCMD13 __REG(0x40F50110 + 13 * 4) -#define PCMD14 __REG(0x40F50110 + 14 * 4) -#define PCMD15 __REG(0x40F50110 + 15 * 4) -#define PCMD16 __REG(0x40F50110 + 16 * 4) -#define PCMD17 __REG(0x40F50110 + 17 * 4) -#define PCMD18 __REG(0x40F50110 + 18 * 4) -#define PCMD19 __REG(0x40F50110 + 19 * 4) -#define PCMD20 __REG(0x40F50110 + 20 * 4) -#define PCMD21 __REG(0x40F50110 + 21 * 4) -#define PCMD22 __REG(0x40F50110 + 22 * 4) -#define PCMD23 __REG(0x40F50110 + 23 * 4) -#define PCMD24 __REG(0x40F50110 + 24 * 4) -#define PCMD25 __REG(0x40F50110 + 25 * 4) -#define PCMD26 __REG(0x40F50110 + 26 * 4) -#define PCMD27 __REG(0x40F50110 + 27 * 4) -#define PCMD28 __REG(0x40F50110 + 28 * 4) -#define PCMD29 __REG(0x40F50110 + 29 * 4) -#define PCMD30 __REG(0x40F50110 + 30 * 4) -#define PCMD31 __REG(0x40F50110 + 31 * 4) +#define ASCR 0x40F40000 /* Application Subsystem Power Status/Control Register */ +#define ARSR 0x40F40004 /* Application Subsystem Reset Status Register */ +#define AD3ER 0x40F40008 /* Application Subsystem D3 state Wakeup Enable Register */ +#define AD3SR 0x40F4000C /* Application Subsystem D3 state Wakeup Status Register */ +#define AD2D0ER 0x40F40010 /* Application Subsystem D2 to D0 state Wakeup Enable Register */ +#define AD2D0SR 0x40F40014 /* Application Subsystem D2 to D0 state Wakeup Status Register */ +#define AD2D1ER 0x40F40018 /* Application Subsystem D2 to D1 state Wakeup Enable Register */ +#define AD2D1SR 0x40F4001C /* Application Subsystem D2 to D1 state Wakeup Status Register */ +#define AD1D0ER 0x40F40020 /* Application Subsystem D1 to D0 state Wakeup Enable Register */ +#define AD1D0SR 0x40F40024 /* Application Subsystem D1 to D0 state Wakeup Status Register */ +#define ASDCNT 0x40F40028 /* Application Subsystem SRAM Drowsy Count Register */ +#define AD3R 0x40F40030 /* Application Subsystem D3 State Configuration Register */ +#define AD2R 0x40F40034 /* Application Subsystem D2 State Configuration Register */ +#define AD1R 0x40F40038 /* Application Subsystem D1 State Configuration Register */ + +#define PMCR 0x40F50000 /* Power Manager Control Register */ +#define PSR 0x40F50004 /* Power Manager S2 Status Register */ +#define PSPR 0x40F50008 /* Power Manager Scratch Pad Register */ +#define PCFR 0x40F5000C /* Power Manager General Configuration Register */ +#define PWER 0x40F50010 /* Power Manager Wake-up Enable Register */ +#define PWSR 0x40F50014 /* Power Manager Wake-up Status Register */ +#define PECR 0x40F50018 /* Power Manager EXT_WAKEUP[1:0] Control Register */ +#define DCDCSR 0x40F50080 /* DC-DC Controller Status Register */ +#define PVCR 0x40F50100 /* Power Manager Voltage Change Control Register */ +#define PCMD(x) (0x40F50110 + x*4) +#define PCMD0 (0x40F50110 + 0 * 4) +#define PCMD1 (0x40F50110 + 1 * 4) +#define PCMD2 (0x40F50110 + 2 * 4) +#define PCMD3 (0x40F50110 + 3 * 4) +#define PCMD4 (0x40F50110 + 4 * 4) +#define PCMD5 (0x40F50110 + 5 * 4) +#define PCMD6 (0x40F50110 + 6 * 4) +#define PCMD7 (0x40F50110 + 7 * 4) +#define PCMD8 (0x40F50110 + 8 * 4) +#define PCMD9 (0x40F50110 + 9 * 4) +#define PCMD10 (0x40F50110 + 10 * 4) +#define PCMD11 (0x40F50110 + 11 * 4) +#define PCMD12 (0x40F50110 + 12 * 4) +#define PCMD13 (0x40F50110 + 13 * 4) +#define PCMD14 (0x40F50110 + 14 * 4) +#define PCMD15 (0x40F50110 + 15 * 4) +#define PCMD16 (0x40F50110 + 16 * 4) +#define PCMD17 (0x40F50110 + 17 * 4) +#define PCMD18 (0x40F50110 + 18 * 4) +#define PCMD19 (0x40F50110 + 19 * 4) +#define PCMD20 (0x40F50110 + 20 * 4) +#define PCMD21 (0x40F50110 + 21 * 4) +#define PCMD22 (0x40F50110 + 22 * 4) +#define PCMD23 (0x40F50110 + 23 * 4) +#define PCMD24 (0x40F50110 + 24 * 4) +#define PCMD25 (0x40F50110 + 25 * 4) +#define PCMD26 (0x40F50110 + 26 * 4) +#define PCMD27 (0x40F50110 + 27 * 4) +#define PCMD28 (0x40F50110 + 28 * 4) +#define PCMD29 (0x40F50110 + 29 * 4) +#define PCMD30 (0x40F50110 + 30 * 4) +#define PCMD31 (0x40F50110 + 31 * 4)
#define PCMD_MBC (1<<12) #define PCMD_DCE (1<<11) @@ -1798,64 +2128,64 @@ typedef void (*ExcpHndlr) (void) ; #define PVCR_FVC (0x1 << 28) #define PVCR_VCSA (0x1<<14) #define PVCR_CommandDelay (0xf80) -#define PVCR_ReadPointer (0x01f00000) +#define PVCR_ReadPointer 0x01f00000 #define PVCR_SlaveAddress (0x7f)
#else /* ifdef CONFIG_CPU_MONAHANS */
-#define PMCR __REG(0x40F00000) /* Power Manager Control Register */ -#define PSSR __REG(0x40F00004) /* Power Manager Sleep Status Register */ -#define PSPR __REG(0x40F00008) /* Power Manager Scratch Pad Register */ -#define PWER __REG(0x40F0000C) /* Power Manager Wake-up Enable Register */ -#define PRER __REG(0x40F00010) /* Power Manager GPIO Rising-Edge Detect Enable Register */ -#define PFER __REG(0x40F00014) /* Power Manager GPIO Falling-Edge Detect Enable Register */ -#define PEDR __REG(0x40F00018) /* Power Manager GPIO Edge Detect Status Register */ -#define PCFR __REG(0x40F0001C) /* Power Manager General Configuration Register */ -#define PGSR0 __REG(0x40F00020) /* Power Manager GPIO Sleep State Register for GP[31-0] */ -#define PGSR1 __REG(0x40F00024) /* Power Manager GPIO Sleep State Register for GP[63-32] */ -#define PGSR2 __REG(0x40F00028) /* Power Manager GPIO Sleep State Register for GP[84-64] */ -#define PGSR3 __REG(0x40F0002C) /* Power Manager GPIO Sleep State Register for GP[118-96] */ -#define RCSR __REG(0x40F00030) /* Reset Controller Status Register */ - -#define PSLR __REG(0x40F00034) /* Power Manager Sleep Config Register */ -#define PSTR __REG(0x40F00038) /* Power Manager Standby Config Register */ -#define PSNR __REG(0x40F0003C) /* Power Manager Sense Config Register */ -#define PVCR __REG(0x40F00040) /* Power Manager VoltageControl Register */ -#define PKWR __REG(0x40F00050) /* Power Manager KB Wake-up Enable Reg */ -#define PKSR __REG(0x40F00054) /* Power Manager KB Level-Detect Register */ -#define PCMD(x) __REG(0x40F00080 + x*4) -#define PCMD0 __REG(0x40F00080 + 0 * 4) -#define PCMD1 __REG(0x40F00080 + 1 * 4) -#define PCMD2 __REG(0x40F00080 + 2 * 4) -#define PCMD3 __REG(0x40F00080 + 3 * 4) -#define PCMD4 __REG(0x40F00080 + 4 * 4) -#define PCMD5 __REG(0x40F00080 + 5 * 4) -#define PCMD6 __REG(0x40F00080 + 6 * 4) -#define PCMD7 __REG(0x40F00080 + 7 * 4) -#define PCMD8 __REG(0x40F00080 + 8 * 4) -#define PCMD9 __REG(0x40F00080 + 9 * 4) -#define PCMD10 __REG(0x40F00080 + 10 * 4) -#define PCMD11 __REG(0x40F00080 + 11 * 4) -#define PCMD12 __REG(0x40F00080 + 12 * 4) -#define PCMD13 __REG(0x40F00080 + 13 * 4) -#define PCMD14 __REG(0x40F00080 + 14 * 4) -#define PCMD15 __REG(0x40F00080 + 15 * 4) -#define PCMD16 __REG(0x40F00080 + 16 * 4) -#define PCMD17 __REG(0x40F00080 + 17 * 4) -#define PCMD18 __REG(0x40F00080 + 18 * 4) -#define PCMD19 __REG(0x40F00080 + 19 * 4) -#define PCMD20 __REG(0x40F00080 + 20 * 4) -#define PCMD21 __REG(0x40F00080 + 21 * 4) -#define PCMD22 __REG(0x40F00080 + 22 * 4) -#define PCMD23 __REG(0x40F00080 + 23 * 4) -#define PCMD24 __REG(0x40F00080 + 24 * 4) -#define PCMD25 __REG(0x40F00080 + 25 * 4) -#define PCMD26 __REG(0x40F00080 + 26 * 4) -#define PCMD27 __REG(0x40F00080 + 27 * 4) -#define PCMD28 __REG(0x40F00080 + 28 * 4) -#define PCMD29 __REG(0x40F00080 + 29 * 4) -#define PCMD30 __REG(0x40F00080 + 30 * 4) -#define PCMD31 __REG(0x40F00080 + 31 * 4) +#define PMCR 0x40F00000 /* Power Manager Control Register */ +#define PSSR 0x40F00004 /* Power Manager Sleep Status Register */ +#define PSPR 0x40F00008 /* Power Manager Scratch Pad Register */ +#define PWER 0x40F0000C /* Power Manager Wake-up Enable Register */ +#define PRER 0x40F00010 /* Power Manager GPIO Rising-Edge Detect Enable Register */ +#define PFER 0x40F00014 /* Power Manager GPIO Falling-Edge Detect Enable Register */ +#define PEDR 0x40F00018 /* Power Manager GPIO Edge Detect Status Register */ +#define PCFR 0x40F0001C /* Power Manager General Configuration Register */ +#define PGSR0 0x40F00020 /* Power Manager GPIO Sleep State Register for GP[31-0] */ +#define PGSR1 0x40F00024 /* Power Manager GPIO Sleep State Register for GP[63-32] */ +#define PGSR2 0x40F00028 /* Power Manager GPIO Sleep State Register for GP[84-64] */ +#define PGSR3 0x40F0002C /* Power Manager GPIO Sleep State Register for GP[118-96] */ +#define RCSR 0x40F00030 /* Reset Controller Status Register */ + +#define PSLR 0x40F00034 /* Power Manager Sleep Config Register */ +#define PSTR 0x40F00038 /* Power Manager Standby Config Register */ +#define PSNR 0x40F0003C /* Power Manager Sense Config Register */ +#define PVCR 0x40F00040 /* Power Manager VoltageControl Register */ +#define PKWR 0x40F00050 /* Power Manager KB Wake-up Enable Reg */ +#define PKSR 0x40F00054 /* Power Manager KB Level-Detect Register */ +#define PCMD(x) (0x40F00080 + x*4) +#define PCMD0 (0x40F00080 + 0 * 4) +#define PCMD1 (0x40F00080 + 1 * 4) +#define PCMD2 (0x40F00080 + 2 * 4) +#define PCMD3 (0x40F00080 + 3 * 4) +#define PCMD4 (0x40F00080 + 4 * 4) +#define PCMD5 (0x40F00080 + 5 * 4) +#define PCMD6 (0x40F00080 + 6 * 4) +#define PCMD7 (0x40F00080 + 7 * 4) +#define PCMD8 (0x40F00080 + 8 * 4) +#define PCMD9 (0x40F00080 + 9 * 4) +#define PCMD10 (0x40F00080 + 10 * 4) +#define PCMD11 (0x40F00080 + 11 * 4) +#define PCMD12 (0x40F00080 + 12 * 4) +#define PCMD13 (0x40F00080 + 13 * 4) +#define PCMD14 (0x40F00080 + 14 * 4) +#define PCMD15 (0x40F00080 + 15 * 4) +#define PCMD16 (0x40F00080 + 16 * 4) +#define PCMD17 (0x40F00080 + 17 * 4) +#define PCMD18 (0x40F00080 + 18 * 4) +#define PCMD19 (0x40F00080 + 19 * 4) +#define PCMD20 (0x40F00080 + 20 * 4) +#define PCMD21 (0x40F00080 + 21 * 4) +#define PCMD22 (0x40F00080 + 22 * 4) +#define PCMD23 (0x40F00080 + 23 * 4) +#define PCMD24 (0x40F00080 + 24 * 4) +#define PCMD25 (0x40F00080 + 25 * 4) +#define PCMD26 (0x40F00080 + 26 * 4) +#define PCMD27 (0x40F00080 + 27 * 4) +#define PCMD28 (0x40F00080 + 28 * 4) +#define PCMD29 (0x40F00080 + 29 * 4) +#define PCMD30 (0x40F00080 + 30 * 4) +#define PCMD31 (0x40F00080 + 31 * 4)
#define PCMD_MBC (1<<12) #define PCMD_DCE (1<<11) @@ -1891,183 +2221,58 @@ typedef void (*ExcpHndlr) (void) ; /* * SSP Serial Port Registers */ -#define SSCR0 __REG(0x41000000) /* SSP Control Register 0 */ -#define SSCR1 __REG(0x41000004) /* SSP Control Register 1 */ -#define SSSR __REG(0x41000008) /* SSP Status Register */ -#define SSITR __REG(0x4100000C) /* SSP Interrupt Test Register */ -#define SSDR __REG(0x41000010) /* (Write / Read) SSP Data Write Register/SSP Data Read Register */ +#define SSCR0 0x41000000 /* SSP Control Register 0 */ +#define SSCR1 0x41000004 /* SSP Control Register 1 */ +#define SSSR 0x41000008 /* SSP Status Register */ +#define SSITR 0x4100000C /* SSP Interrupt Test Register */ +#define SSDR 0x41000010 /* (Write / Read) SSP Data Write Register/SSP Data Read Register */
/* * MultiMediaCard (MMC) controller */ -#define MMC_STRPCL __REG(0x41100000) /* Control to start and stop MMC clock */ -#define MMC_STAT __REG(0x41100004) /* MMC Status Register (read only) */ -#define MMC_CLKRT __REG(0x41100008) /* MMC clock rate */ -#define MMC_SPI __REG(0x4110000c) /* SPI mode control bits */ -#define MMC_CMDAT __REG(0x41100010) /* Command/response/data sequence control */ -#define MMC_RESTO __REG(0x41100014) /* Expected response time out */ -#define MMC_RDTO __REG(0x41100018) /* Expected data read time out */ -#define MMC_BLKLEN __REG(0x4110001c) /* Block length of data transaction */ -#define MMC_NOB __REG(0x41100020) /* Number of blocks, for block mode */ -#define MMC_PRTBUF __REG(0x41100024) /* Partial MMC_TXFIFO FIFO written */ -#define MMC_I_MASK __REG(0x41100028) /* Interrupt Mask */ -#define MMC_I_REG __REG(0x4110002c) /* Interrupt Register (read only) */ -#define MMC_CMD __REG(0x41100030) /* Index of current command */ -#define MMC_ARGH __REG(0x41100034) /* MSW part of the current command argument */ -#define MMC_ARGL __REG(0x41100038) /* LSW part of the current command argument */ -#define MMC_RES __REG(0x4110003c) /* Response FIFO (read only) */ -#define MMC_RXFIFO __REG(0x41100040) /* Receive FIFO (read only) */ -#define MMC_TXFIFO __REG(0x41100044) /* Transmit FIFO (write only) */ - -/* - * Core Clock - */ - -#if defined(CONFIG_CPU_MONAHANS) -#define ACCR __REG(0x41340000) /* Application Subsystem Clock Configuration Register */ -#define ACSR __REG(0x41340004) /* Application Subsystem Clock Status Register */ -#define AICSR __REG(0x41340008) /* Application Subsystem Interrupt Control/Status Register */ -#define CKENA __REG(0x4134000C) /* A Clock Enable Register */ -#define CKENB __REG(0x41340010) /* B Clock Enable Register */ -#define AC97_DIV __REG(0x41340014) /* AC97 clock divisor value register */ - -#define ACCR_SMC_MASK 0x03800000 /* Static Memory Controller Frequency Select */ -#define ACCR_SRAM_MASK 0x000c0000 /* SRAM Controller Frequency Select */ -#define ACCR_FC_MASK 0x00030000 /* Frequency Change Frequency Select */ -#define ACCR_HSIO_MASK 0x0000c000 /* High Speed IO Frequency Select */ -#define ACCR_DDR_MASK 0x00003000 /* DDR Memory Controller Frequency Select */ -#define ACCR_XN_MASK 0x00000700 /* Run Mode Frequency to Turbo Mode Frequency Multiplier */ -#define ACCR_XL_MASK 0x0000001f /* Crystal Frequency to Memory Frequency Multiplier */ -#define ACCR_XPDIS (1 << 31) -#define ACCR_SPDIS (1 << 30) -#define ACCR_13MEND1 (1 << 27) -#define ACCR_D0CS (1 << 26) -#define ACCR_13MEND2 (1 << 21) -#define ACCR_PCCE (1 << 11) - -#define CKENA_30_MSL0 (1 << 30) /* MSL0 Interface Unit Clock Enable */ -#define CKENA_29_SSP4 (1 << 29) /* SSP3 Unit Clock Enable */ -#define CKENA_28_SSP3 (1 << 28) /* SSP2 Unit Clock Enable */ -#define CKENA_27_SSP2 (1 << 27) /* SSP1 Unit Clock Enable */ -#define CKENA_26_SSP1 (1 << 26) /* SSP0 Unit Clock Enable */ -#define CKENA_25_TSI (1 << 25) /* TSI Clock Enable */ -#define CKENA_24_AC97 (1 << 24) /* AC97 Unit Clock Enable */ -#define CKENA_23_STUART (1 << 23) /* STUART Unit Clock Enable */ -#define CKENA_22_FFUART (1 << 22) /* FFUART Unit Clock Enable */ -#define CKENA_21_BTUART (1 << 21) /* BTUART Unit Clock Enable */ -#define CKENA_20_UDC (1 << 20) /* UDC Clock Enable */ -#define CKENA_19_TPM (1 << 19) /* TPM Unit Clock Enable */ -#define CKENA_18_USIM1 (1 << 18) /* USIM1 Unit Clock Enable */ -#define CKENA_17_USIM0 (1 << 17) /* USIM0 Unit Clock Enable */ -#define CKENA_15_CIR (1 << 15) /* Consumer IR Clock Enable */ -#define CKENA_14_KEY (1 << 14) /* Keypad Controller Clock Enable */ -#define CKENA_13_MMC1 (1 << 13) /* MMC1 Clock Enable */ -#define CKENA_12_MMC0 (1 << 12) /* MMC0 Clock Enable */ -#define CKENA_11_FLASH (1 << 11) /* Boot ROM Clock Enable */ -#define CKENA_10_SRAM (1 << 10) /* SRAM Controller Clock Enable */ -#define CKENA_9_SMC (1 << 9) /* Static Memory Controller */ -#define CKENA_8_DMC (1 << 8) /* Dynamic Memory Controller */ -#define CKENA_7_GRAPHICS (1 << 7) /* 2D Graphics Clock Enable */ -#define CKENA_6_USBCLI (1 << 6) /* USB Client Unit Clock Enable */ -#define CKENA_4_NAND (1 << 4) /* NAND Flash Controller Clock Enable */ -#define CKENA_3_CAMERA (1 << 3) /* Camera Interface Clock Enable */ -#define CKENA_2_USBHOST (1 << 2) /* USB Host Unit Clock Enable */ -#define CKENA_1_LCD (1 << 1) /* LCD Unit Clock Enable */ - -#define CKENB_9_SYSBUS2 (1 << 9) /* System bus 2 */ -#define CKENB_8_1WIRE (1 << 8) /* One Wire Interface Unit Clock Enable */ -#define CKENB_7_GPIO (1 << 7) /* GPIO Clock Enable */ -#define CKENB_6_IRQ (1 << 6) /* Interrupt Controller Clock Enable */ -#define CKENB_4_I2C (1 << 4) /* I2C Unit Clock Enable */ -#define CKENB_1_PWM1 (1 << 1) /* PWM2 & PWM3 Clock Enable */ -#define CKENB_0_PWM0 (1 << 0) /* PWM0 & PWM1 Clock Enable */ - -#else /* if defined CONFIG_CPU_MONAHANS */ - -#define CCCR __REG(0x41300000) /* Core Clock Configuration Register */ -#define CKEN __REG(0x41300004) /* Clock Enable Register */ -#define OSCC __REG(0x41300008) /* Oscillator Configuration Register */ - -#define CCCR_N_MASK 0x0380 /* Run Mode Frequency to Turbo Mode Frequency Multiplier */ -#if !defined(CONFIG_PXA27X) -#define CCCR_M_MASK 0x0060 /* Memory Frequency to Run Mode Frequency Multiplier */ -#endif -#define CCCR_L_MASK 0x001f /* Crystal Frequency to Memory Frequency Multiplier */ - -#define CKEN24_CAMERA (1 << 24) /* Camera Interface Clock Enable */ -#define CKEN23_SSP1 (1 << 23) /* SSP1 Unit Clock Enable */ -#define CKEN22_MEMC (1 << 22) /* Memory Controller Clock Enable */ -#define CKEN21_MEMSTK (1 << 21) /* Memory Stick Host Controller */ -#define CKEN20_IM (1 << 20) /* Internal Memory Clock Enable */ -#define CKEN19_KEYPAD (1 << 19) /* Keypad Interface Clock Enable */ -#define CKEN18_USIM (1 << 18) /* USIM Unit Clock Enable */ -#define CKEN17_MSL (1 << 17) /* MSL Unit Clock Enable */ -#define CKEN16_LCD (1 << 16) /* LCD Unit Clock Enable */ -#define CKEN15_PWRI2C (1 << 15) /* PWR I2C Unit Clock Enable */ -#define CKEN14_I2C (1 << 14) /* I2C Unit Clock Enable */ -#define CKEN13_FICP (1 << 13) /* FICP Unit Clock Enable */ -#define CKEN12_MMC (1 << 12) /* MMC Unit Clock Enable */ -#define CKEN11_USB (1 << 11) /* USB Unit Clock Enable */ -#if defined(CONFIG_PXA27X) -#define CKEN10_USBHOST (1 << 10) /* USB Host Unit Clock Enable */ -#define CKEN24_CAMERA (1 << 24) /* Camera Unit Clock Enable */ -#endif -#define CKEN8_I2S (1 << 8) /* I2S Unit Clock Enable */ -#define CKEN7_BTUART (1 << 7) /* BTUART Unit Clock Enable */ -#define CKEN6_FFUART (1 << 6) /* FFUART Unit Clock Enable */ -#define CKEN5_STUART (1 << 5) /* STUART Unit Clock Enable */ -#define CKEN3_SSP (1 << 3) /* SSP Unit Clock Enable */ -#define CKEN2_AC97 (1 << 2) /* AC97 Unit Clock Enable */ -#define CKEN1_PWM1 (1 << 1) /* PWM1 Clock Enable */ -#define CKEN0_PWM0 (1 << 0) /* PWM0 Clock Enable */ - -#define OSCC_OON (1 << 1) /* 32.768kHz OON (write-once only bit) */ -#define OSCC_OOK (1 << 0) /* 32.768kHz OOK (read-only bit) */ - -#if !defined(CONFIG_PXA27X) -#define CCCR_L09 (0x1F) -#define CCCR_L27 (0x1) -#define CCCR_L32 (0x2) -#define CCCR_L36 (0x3) -#define CCCR_L40 (0x4) -#define CCCR_L45 (0x5) - -#define CCCR_M1 (0x1 << 5) -#define CCCR_M2 (0x2 << 5) -#define CCCR_M4 (0x3 << 5) - -#define CCCR_N10 (0x2 << 7) -#define CCCR_N15 (0x3 << 7) -#define CCCR_N20 (0x4 << 7) -#define CCCR_N25 (0x5 << 7) -#define CCCR_N30 (0x6 << 7) -#endif +#define MMC_STRPCL 0x41100000 /* Control to start and stop MMC clock */ +#define MMC_STAT 0x41100004 /* MMC Status Register (read only) */ +#define MMC_CLKRT 0x41100008 /* MMC clock rate */ +#define MMC_SPI 0x4110000c /* SPI mode control bits */ +#define MMC_CMDAT 0x41100010 /* Command/response/data sequence control */ +#define MMC_RESTO 0x41100014 /* Expected response time out */ +#define MMC_RDTO 0x41100018 /* Expected data read time out */ +#define MMC_BLKLEN 0x4110001c /* Block length of data transaction */ +#define MMC_NOB 0x41100020 /* Number of blocks, for block mode */ +#define MMC_PRTBUF 0x41100024 /* Partial MMC_TXFIFO FIFO written */ +#define MMC_I_MASK 0x41100028 /* Interrupt Mask */ +#define MMC_I_REG 0x4110002c /* Interrupt Register (read only) */ +#define MMC_CMD 0x41100030 /* Index of current command */ +#define MMC_ARGH 0x41100034 /* MSW part of the current command argument */ +#define MMC_ARGL 0x41100038 /* LSW part of the current command argument */ +#define MMC_RES 0x4110003c /* Response FIFO (read only) */ +#define MMC_RXFIFO 0x41100040 /* Receive FIFO (read only) */ +#define MMC_TXFIFO 0x41100044 /* Transmit FIFO (write only) */
/* * LCD */ -#define LCCR0 __REG(0x44000000) /* LCD Controller Control Register 0 */ -#define LCCR1 __REG(0x44000004) /* LCD Controller Control Register 1 */ -#define LCCR2 __REG(0x44000008) /* LCD Controller Control Register 2 */ -#define LCCR3 __REG(0x4400000C) /* LCD Controller Control Register 3 */ -#define DFBR0 __REG(0x44000020) /* DMA Channel 0 Frame Branch Register */ -#define DFBR1 __REG(0x44000024) /* DMA Channel 1 Frame Branch Register */ -#define LCSR0 __REG(0x44000038) /* LCD Controller Status Register */ -#define LCSR1 __REG(0x44000034) /* LCD Controller Status Register */ -#define LIIDR __REG(0x4400003C) /* LCD Controller Interrupt ID Register */ -#define TMEDRGBR __REG(0x44000040) /* TMED RGB Seed Register */ -#define TMEDCR __REG(0x44000044) /* TMED Control Register */ - -#define FDADR0 __REG(0x44000200) /* DMA Channel 0 Frame Descriptor Address Register */ -#define FSADR0 __REG(0x44000204) /* DMA Channel 0 Frame Source Address Register */ -#define FIDR0 __REG(0x44000208) /* DMA Channel 0 Frame ID Register */ -#define LDCMD0 __REG(0x4400020C) /* DMA Channel 0 Command Register */ -#define FDADR1 __REG(0x44000210) /* DMA Channel 1 Frame Descriptor Address Register */ -#define FSADR1 __REG(0x44000214) /* DMA Channel 1 Frame Source Address Register */ -#define FIDR1 __REG(0x44000218) /* DMA Channel 1 Frame ID Register */ -#define LDCMD1 __REG(0x4400021C) /* DMA Channel 1 Command Register */ +#define LCCR0 0x44000000 /* LCD Controller Control Register 0 */ +#define LCCR1 0x44000004 /* LCD Controller Control Register 1 */ +#define LCCR2 0x44000008 /* LCD Controller Control Register 2 */ +#define LCCR3 0x4400000C /* LCD Controller Control Register 3 */ +#define DFBR0 0x44000020 /* DMA Channel 0 Frame Branch Register */ +#define DFBR1 0x44000024 /* DMA Channel 1 Frame Branch Register */ +#define LCSR0 0x44000038 /* LCD Controller Status Register */ +#define LCSR1 0x44000034 /* LCD Controller Status Register */ +#define LIIDR 0x4400003C /* LCD Controller Interrupt ID Register */ +#define TMEDRGBR 0x44000040 /* TMED RGB Seed Register */ +#define TMEDCR 0x44000044 /* TMED Control Register */ + +#define FDADR0 0x44000200 /* DMA Channel 0 Frame Descriptor Address Register */ +#define FSADR0 0x44000204 /* DMA Channel 0 Frame Source Address Register */ +#define FIDR0 0x44000208 /* DMA Channel 0 Frame ID Register */ +#define LDCMD0 0x4400020C /* DMA Channel 0 Command Register */ +#define FDADR1 0x44000210 /* DMA Channel 1 Frame Descriptor Address Register */ +#define FSADR1 0x44000214 /* DMA Channel 1 Frame Source Address Register */ +#define FIDR1 0x44000218 /* DMA Channel 1 Frame ID Register */ +#define LDCMD1 0x4400021C /* DMA Channel 1 Command Register */
#define LCCR0_ENB (1 << 0) /* LCD Controller enable */ #define LCCR0_CMS (1 << 1) /* Color = 0, Monochrome = 1 */ @@ -2135,22 +2340,12 @@ typedef void (*ExcpHndlr) (void) ; /* [0..255 Tln] */ \ ((Tln) << FShft (LCCR2_BFW))
-#if 0 -#define LCCR3_PCD (0xff) /* Pixel clock divisor */ -#define LCCR3_ACB (0xff << 8) /* AC Bias pin frequency */ -#define LCCR3_ACB_S 8 -#endif - #define LCCR3_API (0xf << 16) /* AC Bias pin trasitions per interrupt */ #define LCCR3_API_S 16 #define LCCR3_VSP (1 << 20) /* vertical sync polarity */ #define LCCR3_HSP (1 << 21) /* horizontal sync polarity */ #define LCCR3_PCP (1 << 22) /* pixel clock polarity */ #define LCCR3_OEP (1 << 23) /* output enable polarity */ -#if 0 -#define LCCR3_BPP (7 << 24) /* bits per pixel */ -#define LCCR3_BPP_S 24 -#endif #define LCCR3_DPC (1 << 27) /* double pixel clock mode */
#define LCCR3_PDFOR_0 (0 << 30) @@ -2231,46 +2426,49 @@ typedef void (*ExcpHndlr) (void) ; */
#ifdef CONFIG_CPU_MONAHANS + +/* PXA3xx */ + /* Static Memory Controller Registers */ -#define MSC0 __REG_2(0x4A000008) /* Static Memory Control Register 0 */ -#define MSC1 __REG_2(0x4A00000C) /* Static Memory Control Register 1 */ -#define MECR __REG_2(0x4A000014) /* Expansion Memory (PCMCIA/Compact Flash) Bus Configuration */ -#define SXCNFG __REG_2(0x4A00001C) /* Synchronous Static Memory Control Register */ -#define MCMEM0 __REG_2(0x4A000028) /* Card interface Common Memory Space Socket 0 Timing */ -#define MCATT0 __REG_2(0x4A000030) /* Card interface Attribute Space Socket 0 Timing Configuration */ -#define MCIO0 __REG_2(0x4A000038) /* Card interface I/O Space Socket 0 Timing Configuration */ -#define MEMCLKCFG __REG_2(0x4A000068) /* SCLK speed configuration */ -#define CSADRCFG0 __REG_2(0x4A000080) /* Address Configuration for chip select 0 */ -#define CSADRCFG1 __REG_2(0x4A000084) /* Address Configuration for chip select 1 */ -#define CSADRCFG2 __REG_2(0x4A000088) /* Address Configuration for chip select 2 */ -#define CSADRCFG3 __REG_2(0x4A00008C) /* Address Configuration for chip select 3 */ -#define CSADRCFG_P __REG_2(0x4A000090) /* Address Configuration for pcmcia card interface */ -#define CSMSADRCFG __REG_2(0x4A0000A0) /* Master Address Configuration Register */ -#define CLK_RET_DEL __REG_2(0x4A0000B0) /* Delay line and mux selects for return data latching for sync. flash */ -#define ADV_RET_DEL __REG_2(0x4A0000B4) /* Delay line and mux selects for return data latching for sync. flash */ +#define MSC0 0x4A000008 /* Static Memory Control Register 0 */ +#define MSC1 0x4A00000C /* Static Memory Control Register 1 */ +#define MECR 0x4A000014 /* Expansion Memory (PCMCIA/Compact Flash) Bus Configuration */ +#define SXCNFG 0x4A00001C /* Synchronous Static Memory Control Register */ +#define MCMEM0 0x4A000028 /* Card interface Common Memory Space Socket 0 Timing */ +#define MCATT0 0x4A000030 /* Card interface Attribute Space Socket 0 Timing Configuration */ +#define MCIO0 0x4A000038 /* Card interface I/O Space Socket 0 Timing Configuration */ +#define MEMCLKCFG 0x4A000068 /* SCLK speed configuration */ +#define CSADRCFG0 0x4A000080 /* Address Configuration for chip select 0 */ +#define CSADRCFG1 0x4A000084 /* Address Configuration for chip select 1 */ +#define CSADRCFG2 0x4A000088 /* Address Configuration for chip select 2 */ +#define CSADRCFG3 0x4A00008C /* Address Configuration for chip select 3 */ +#define CSADRCFG_P 0x4A000090 /* Address Configuration for pcmcia card interface */ +#define CSMSADRCFG 0x4A0000A0 /* Master Address Configuration Register */ +#define CLK_RET_DEL 0x4A0000B0 /* Delay line and mux selects for return data latching for sync. flash */ +#define ADV_RET_DEL 0x4A0000B4 /* Delay line and mux selects for return data latching for sync. flash */
/* Dynamic Memory Controller Registers */ -#define MDCNFG __REG_2(0x48100000) /* SDRAM Configuration Register 0 */ -#define MDREFR __REG_2(0x48100004) /* SDRAM Refresh Control Register */ -#define FLYCNFG __REG_2(0x48100020) /* Fly-by DMA DVAL[1:0] polarities */ -#define MDMRS __REG_2(0x48100040) /* MRS value to be written to SDRAM */ -#define DDR_SCAL __REG_2(0x48100050) /* Software Delay Line Calibration/Configuration for external DDR memory. */ -#define DDR_HCAL __REG_2(0x48100060) /* Hardware Delay Line Calibration/Configuration for external DDR memory. */ -#define DDR_WCAL __REG_2(0x48100068) /* DDR Write Strobe Calibration Register */ -#define DMCIER __REG_2(0x48100070) /* Dynamic MC Interrupt Enable Register. */ -#define DMCISR __REG_2(0x48100078) /* Dynamic MC Interrupt Status Register. */ -#define DDR_DLS __REG_2(0x48100080) /* DDR Delay Line Value Status register for external DDR memory. */ -#define EMPI __REG_2(0x48100090) /* EMPI Control Register */ -#define RCOMP __REG_2(0x48100100) -#define PAD_MA __REG_2(0x48100110) -#define PAD_MDMSB __REG_2(0x48100114) -#define PAD_MDLSB __REG_2(0x48100118) -#define PAD_DMEM __REG_2(0x4810011c) -#define PAD_SDCLK __REG_2(0x48100120) -#define PAD_SDCS __REG_2(0x48100124) -#define PAD_SMEM __REG_2(0x48100128) -#define PAD_SCLK __REG_2(0x4810012C) -#define TAI __REG_2(0x48100F00) /* TAI Tavor Address Isolation Register */ +#define MDCNFG 0x48100000 /* SDRAM Configuration Register 0 */ +#define MDREFR 0x48100004 /* SDRAM Refresh Control Register */ +#define FLYCNFG 0x48100020 /* Fly-by DMA DVAL[1:0] polarities */ +#define MDMRS 0x48100040 /* MRS value to be written to SDRAM */ +#define DDR_SCAL 0x48100050 /* Software Delay Line Calibration/Configuration for external DDR memory. */ +#define DDR_HCAL 0x48100060 /* Hardware Delay Line Calibration/Configuration for external DDR memory. */ +#define DDR_WCAL 0x48100068 /* DDR Write Strobe Calibration Register */ +#define DMCIER 0x48100070 /* Dynamic MC Interrupt Enable Register. */ +#define DMCISR 0x48100078 /* Dynamic MC Interrupt Status Register. */ +#define DDR_DLS 0x48100080 /* DDR Delay Line Value Status register for external DDR memory. */ +#define EMPI 0x48100090 /* EMPI Control Register */ +#define RCOMP 0x48100100 +#define PAD_MA 0x48100110 +#define PAD_MDMSB 0x48100114 +#define PAD_MDLSB 0x48100118 +#define PAD_DMEM 0x4810011c +#define PAD_SDCLK 0x48100120 +#define PAD_SDCS 0x48100124 +#define PAD_SMEM 0x48100128 +#define PAD_SCLK 0x4810012C +#define TAI 0x48100F00 /* TAI Tavor Address Isolation Register */
/* Some frequently used bits */ #define MDCNFG_DMAP 0x80000000 /* SDRAM 1GB Memory Map Enable */ @@ -2298,19 +2496,19 @@ typedef void (*ExcpHndlr) (void) ;
/* Data Flash Controller Registers */
-#define NDCR __REG(0x43100000) /* Data Flash Control register */ -#define NDTR0CS0 __REG(0x43100004) /* Data Controller Timing Parameter 0 Register for ND_nCS0 */ -/* #define NDTR0CS1 __REG(0x43100008) /* Data Controller Timing Parameter 0 Register for ND_nCS1 */ */ -#define NDTR1CS0 __REG(0x4310000C) /* Data Controller Timing Parameter 1 Register for ND_nCS0 */ -/* #define NDTR1CS1 __REG(0x43100010) /* Data Controller Timing Parameter 1 Register for ND_nCS1 */ */ -#define NDSR __REG(0x43100014) /* Data Controller Status Register */ -#define NDPCR __REG(0x43100018) /* Data Controller Page Count Register */ -#define NDBDR0 __REG(0x4310001C) /* Data Controller Bad Block Register 0 */ -#define NDBDR1 __REG(0x43100020) /* Data Controller Bad Block Register 1 */ -#define NDDB __REG(0x43100040) /* Data Controller Data Buffer */ -#define NDCB0 __REG(0x43100048) /* Data Controller Command Buffer0 */ -#define NDCB1 __REG(0x4310004C) /* Data Controller Command Buffer1 */ -#define NDCB2 __REG(0x43100050) /* Data Controller Command Buffer2 */ +#define NDCR 0x43100000 /* Data Flash Control register */ +#define NDTR0CS0 0x43100004 /* Data Controller Timing Parameter 0 Register for ND_nCS0 */ +/* #define NDTR0CS1 0x43100008 /* Data Controller Timing Parameter 0 Register for ND_nCS1 */ */ +#define NDTR1CS0 0x4310000C /* Data Controller Timing Parameter 1 Register for ND_nCS0 */ +/* #define NDTR1CS1 0x43100010 /* Data Controller Timing Parameter 1 Register for ND_nCS1 */ */ +#define NDSR 0x43100014 /* Data Controller Status Register */ +#define NDPCR 0x43100018 /* Data Controller Page Count Register */ +#define NDBDR0 0x4310001C /* Data Controller Bad Block Register 0 */ +#define NDBDR1 0x43100020 /* Data Controller Bad Block Register 1 */ +#define NDDB 0x43100040 /* Data Controller Data Buffer */ +#define NDCB0 0x43100048 /* Data Controller Command Buffer0 */ +#define NDCB1 0x4310004C /* Data Controller Command Buffer1 */ +#define NDCB2 0x43100050 /* Data Controller Command Buffer2 */
#define NDCR_SPARE_EN (0x1<<31) #define NDCR_ECC_EN (0x1<<30) @@ -2386,7 +2584,9 @@ typedef void (*ExcpHndlr) (void) ;
-#define MEMC_BASE __REG(0x48000000) /* Base of Memory Controller */ +/* PXA2xx */ + +#define MEMC_BASE 0x48000000 /* Base of Memory Controller */ #define MDCNFG_OFFSET 0x0 #define MDREFR_OFFSET 0x4 #define MSC0_OFFSET 0x8 @@ -2405,29 +2605,30 @@ typedef void (*ExcpHndlr) (void) ; #define MCIO1_OFFSET 0x3C #define MDMRS_OFFSET 0x40
-#define MDCNFG __REG(0x48000000) /* SDRAM Configuration Register 0 */ +#define MDCNFG 0x48000000 /* SDRAM Configuration Register 0 */ #define MDCNFG_DE0 0x00000001 #define MDCNFG_DE1 0x00000002 #define MDCNFG_DE2 0x00010000 #define MDCNFG_DE3 0x00020000 #define MDCNFG_DWID0 0x00000004
-#define MDREFR __REG(0x48000004) /* SDRAM Refresh Control Register */ -#define MSC0 __REG(0x48000008) /* Static Memory Control Register 0 */ -#define MSC1 __REG(0x4800000C) /* Static Memory Control Register 1 */ -#define MSC2 __REG(0x48000010) /* Static Memory Control Register 2 */ -#define MECR __REG(0x48000014) /* Expansion Memory (PCMCIA/Compact Flash) Bus Configuration */ -#define SXLCR __REG(0x48000018) /* LCR value to be written to SDRAM-Timing Synchronous Flash */ -#define SXCNFG __REG(0x4800001C) /* Synchronous Static Memory Control Register */ -#define SXMRS __REG(0x48000024) /* MRS value to be written to Synchronous Flash or SMROM */ -#define MCMEM0 __REG(0x48000028) /* Card interface Common Memory Space Socket 0 Timing */ -#define MCMEM1 __REG(0x4800002C) /* Card interface Common Memory Space Socket 1 Timing */ -#define MCATT0 __REG(0x48000030) /* Card interface Attribute Space Socket 0 Timing Configuration */ -#define MCATT1 __REG(0x48000034) /* Card interface Attribute Space Socket 1 Timing Configuration */ -#define MCIO0 __REG(0x48000038) /* Card interface I/O Space Socket 0 Timing Configuration */ -#define MCIO1 __REG(0x4800003C) /* Card interface I/O Space Socket 1 Timing Configuration */ -#define MDMRS __REG(0x48000040) /* MRS value to be written to SDRAM */ -#define BOOT_DEF __REG(0x48000044) /* Read-Only Boot-Time Register. Contains BOOT_SEL and PKG_SEL */ +#define MDREFR 0x48000004 /* SDRAM Refresh Control Register */ +#define MSC0 0x48000008 /* Static Memory Control Register 0 */ +#define MSC1 0x4800000C /* Static Memory Control Register 1 */ +#define MSC2 0x48000010 /* Static Memory Control Register 2 */ +#define MECR 0x48000014 /* Expansion Memory (PCMCIA/Compact Flash) Bus Configuration */ +#define SXLCR 0x48000018 /* LCR value to be written to SDRAM-Timing Synchronous Flash */ +#define SXCNFG 0x4800001C /* Synchronous Static Memory Control Register */ +#define FLYCNFG 0x48000020 +#define SXMRS 0x48000024 /* MRS value to be written to Synchronous Flash or SMROM */ +#define MCMEM0 0x48000028 /* Card interface Common Memory Space Socket 0 Timing */ +#define MCMEM1 0x4800002C /* Card interface Common Memory Space Socket 1 Timing */ +#define MCATT0 0x48000030 /* Card interface Attribute Space Socket 0 Timing Configuration */ +#define MCATT1 0x48000034 /* Card interface Attribute Space Socket 1 Timing Configuration */ +#define MCIO0 0x48000038 /* Card interface I/O Space Socket 0 Timing Configuration */ +#define MCIO1 0x4800003C /* Card interface I/O Space Socket 1 Timing Configuration */ +#define MDMRS 0x48000040 /* MRS value to be written to SDRAM */ +#define BOOT_DEF 0x48000044 /* Read-Only Boot-Time Register. Contains BOOT_SEL and PKG_SEL */
#define MDREFR_ALTREFA (1 << 31) /* Exiting Alternate Bus Master Mode Refresh Control */ #define MDREFR_ALTREFB (1 << 30) /* Entering Alternate Bus Master Mode Refresh Control */ @@ -2448,7 +2649,7 @@ typedef void (*ExcpHndlr) (void) ;
-#define ARB_CNTRL __REG(0x48000048) /* Arbiter Control Register */ +#define ARB_CNTRL 0x48000048 /* Arbiter Control Register */
#define ARB_DMA_SLV_PARK (1<<31) /* Be parked with DMA slave when idle */ #define ARB_CI_PARK (1<<30) /* Be parked with Camera Interface when idle */ @@ -2460,80 +2661,41 @@ typedef void (*ExcpHndlr) (void) ; #define ARB_CORE_PARK (1<<24) /* Be parked with core when idle */ #define ARB_LOCK_FLAG (1<<23) /* Only Locking masters gain access to the bus */
-#endif /* CONFIG_CPU_MONAHANS */ - -/* Interrupt Controller */ - -#define ICIP2 __REG(0x40D0009C) /* Interrupt Controller IRQ Pending Register 2 */ -#define ICMR2 __REG(0x40D000A0) /* Interrupt Controller Mask Register 2 */ -#define ICLR2 __REG(0x40D000A4) /* Interrupt Controller Level Register 2 */ -#define ICFP2 __REG(0x40D000A8) /* Interrupt Controller FIQ Pending Register 2 */ -#define ICPR2 __REG(0x40D000AC) /* Interrupt Controller Pending Register 2 */ - -/* General Purpose I/O */ - -#define GAFR3_L __REG(0x40E0006C) /* GPIO Alternate Function Select Register GPIO<111:96> */ -#define GAFR3_U __REG(0x40E00070) /* GPIO Alternate Function Select Register GPIO<127:112> */ -#define GPLR3 __REG(0x40E00100) /* GPIO Pin-Level Register GPIO<127:96> */ -#define GPDR3 __REG(0x40E0010C) /* GPIO Pin Direction Register GPIO<127:96> */ -#define GPSR3 __REG(0x40E00118) /* GPIO Pin Output Set Register GPIO<127:96> */ -#define GPCR3 __REG(0x40E00124) /* GPIO Pin Output Clear Register GPIO <127:96> */ -#define GRER3 __REG(0x40E00130) /* GPIO Rising-Edge Detect Register GPIO<127:96> */ -#define GFER3 __REG(0x40E0013C) /* GPIO Falling-Edge Detect Register GPIO<31:0> */ -#define GEDR3 __REG(0x40E00148) /* GPIO Edge Detect Status Register GPIO<127:96> */ - -/* Core Clock */ - -#define CCSR __REG(0x4130000C) /* Core Clock Status Register */ - -#define CKEN23_SSP1 (1 << 23) /* SSP1 Unit Clock Enable */ -#define CKEN22_MEMC (1 << 22) /* Memory Controler */ -#define CKEN21_MSHC (1 << 21) /* Memery Stick Host Controller */ -#define CKEN20_IM (1 << 20) /* Internal Memory Clock Enable */ -#define CKEN19_KEYPAD (1 << 19) /* Keypad Interface Clock Enable */ -#define CKEN18_USIM (1 << 18) /* USIM Unit Clock Enable */ -#define CKEN17_MSL (1 << 17) /* MSL Interface Unit Clock Enable */ -#define CKEN15_PWR_I2C (1 << 15) /* PWR_I2C Unit Clock Enable */ -#define CKEN9_OST (1 << 9) /* OS Timer Unit Clock Enable */ -#define CKEN4_SSP3 (1 << 4) /* SSP3 Unit Clock Enable */ - -/* Memory controller */ - -#define MDREFR_K0DB4 (1 << 29) /* SDCLK[0] divide by 4 */ +#endif /* CONFIG_PXA27X */
/* LCD registers */ -#define LCCR4 __REG(0x44000010) /* LCD Controller Control Register 4 */ -#define LCCR5 __REG(0x44000014) /* LCD Controller Control Register 5 */ -#define FBR0 __REG(0x44000020) /* DMA Channel 0 Frame Branch Register */ -#define FBR1 __REG(0x44000024) /* DMA Channel 1 Frame Branch Register */ -#define FBR2 __REG(0x44000028) /* DMA Channel 2 Frame Branch Register */ -#define FBR3 __REG(0x4400002C) /* DMA Channel 3 Frame Branch Register */ -#define FBR4 __REG(0x44000030) /* DMA Channel 4 Frame Branch Register */ -#define FDADR2 __REG(0x44000220) /* DMA Channel 2 Frame Descriptor Address Register */ -#define FSADR2 __REG(0x44000224) /* DMA Channel 2 Frame Source Address Register */ -#define FIDR2 __REG(0x44000228) /* DMA Channel 2 Frame ID Register */ -#define LDCMD2 __REG(0x4400022C) /* DMA Channel 2 Command Register */ -#define FDADR3 __REG(0x44000230) /* DMA Channel 3 Frame Descriptor Address Register */ -#define FSADR3 __REG(0x44000234) /* DMA Channel 3 Frame Source Address Register */ -#define FIDR3 __REG(0x44000238) /* DMA Channel 3 Frame ID Register */ -#define LDCMD3 __REG(0x4400023C) /* DMA Channel 3 Command Register */ -#define FDADR4 __REG(0x44000240) /* DMA Channel 4 Frame Descriptor Address Register */ -#define FSADR4 __REG(0x44000244) /* DMA Channel 4 Frame Source Address Register */ -#define FIDR4 __REG(0x44000248) /* DMA Channel 4 Frame ID Register */ -#define LDCMD4 __REG(0x4400024C) /* DMA Channel 4 Command Register */ -#define FDADR5 __REG(0x44000250) /* DMA Channel 5 Frame Descriptor Address Register */ -#define FSADR5 __REG(0x44000254) /* DMA Channel 5 Frame Source Address Register */ -#define FIDR5 __REG(0x44000258) /* DMA Channel 5 Frame ID Register */ -#define LDCMD5 __REG(0x4400025C) /* DMA Channel 5 Command Register */ - -#define OVL1C1 __REG(0x44000050) /* Overlay 1 Control Register 1 */ -#define OVL1C2 __REG(0x44000060) /* Overlay 1 Control Register 2 */ -#define OVL2C1 __REG(0x44000070) /* Overlay 2 Control Register 1 */ -#define OVL2C2 __REG(0x44000080) /* Overlay 2 Control Register 2 */ -#define CCR __REG(0x44000090) /* Cursor Control Register */ - -#define FBR5 __REG(0x44000110) /* DMA Channel 5 Frame Branch Register */ -#define FBR6 __REG(0x44000114) /* DMA Channel 6 Frame Branch Register */ +#define LCCR4 0x44000010 /* LCD Controller Control Register 4 */ +#define LCCR5 0x44000014 /* LCD Controller Control Register 5 */ +#define FBR0 0x44000020 /* DMA Channel 0 Frame Branch Register */ +#define FBR1 0x44000024 /* DMA Channel 1 Frame Branch Register */ +#define FBR2 0x44000028 /* DMA Channel 2 Frame Branch Register */ +#define FBR3 0x4400002C /* DMA Channel 3 Frame Branch Register */ +#define FBR4 0x44000030 /* DMA Channel 4 Frame Branch Register */ +#define FDADR2 0x44000220 /* DMA Channel 2 Frame Descriptor Address Register */ +#define FSADR2 0x44000224 /* DMA Channel 2 Frame Source Address Register */ +#define FIDR2 0x44000228 /* DMA Channel 2 Frame ID Register */ +#define LDCMD2 0x4400022C /* DMA Channel 2 Command Register */ +#define FDADR3 0x44000230 /* DMA Channel 3 Frame Descriptor Address Register */ +#define FSADR3 0x44000234 /* DMA Channel 3 Frame Source Address Register */ +#define FIDR3 0x44000238 /* DMA Channel 3 Frame ID Register */ +#define LDCMD3 0x4400023C /* DMA Channel 3 Command Register */ +#define FDADR4 0x44000240 /* DMA Channel 4 Frame Descriptor Address Register */ +#define FSADR4 0x44000244 /* DMA Channel 4 Frame Source Address Register */ +#define FIDR4 0x44000248 /* DMA Channel 4 Frame ID Register */ +#define LDCMD4 0x4400024C /* DMA Channel 4 Command Register */ +#define FDADR5 0x44000250 /* DMA Channel 5 Frame Descriptor Address Register */ +#define FSADR5 0x44000254 /* DMA Channel 5 Frame Source Address Register */ +#define FIDR5 0x44000258 /* DMA Channel 5 Frame ID Register */ +#define LDCMD5 0x4400025C /* DMA Channel 5 Command Register */ + +#define OVL1C1 0x44000050 /* Overlay 1 Control Register 1 */ +#define OVL1C2 0x44000060 /* Overlay 1 Control Register 2 */ +#define OVL2C1 0x44000070 /* Overlay 2 Control Register 1 */ +#define OVL2C2 0x44000080 /* Overlay 2 Control Register 2 */ +#define CCR 0x44000090 /* Cursor Control Register */ + +#define FBR5 0x44000110 /* DMA Channel 5 Frame Branch Register */ +#define FBR6 0x44000114 /* DMA Channel 6 Frame Branch Register */
#define LCCR0_LDDALT (1<<26) /* LDD Alternate mapping bit when base pixel is RGBT16 */ #define LCCR0_OUC (1<<25) /* Overlay Underlay Control Bit */ @@ -2572,16 +2734,16 @@ typedef void (*ExcpHndlr) (void) ;
/* Keypad controller */
-#define KPC __REG(0x41500000) /* Keypad Interface Control register */ -#define KPDK __REG(0x41500008) /* Keypad Interface Direct Key register */ -#define KPREC __REG(0x41500010) /* Keypad Intefcace Rotary Encoder register */ -#define KPMK __REG(0x41500018) /* Keypad Intefcace Matrix Key register */ -#define KPAS __REG(0x41500020) /* Keypad Interface Automatic Scan register */ -#define KPASMKP0 __REG(0x41500028) /* Keypad Interface Automatic Scan Multiple Key Presser register 0 */ -#define KPASMKP1 __REG(0x41500030) /* Keypad Interface Automatic Scan Multiple Key Presser register 1 */ -#define KPASMKP2 __REG(0x41500038) /* Keypad Interface Automatic Scan Multiple Key Presser register 2 */ -#define KPASMKP3 __REG(0x41500040) /* Keypad Interface Automatic Scan Multiple Key Presser register 3 */ -#define KPKDI __REG(0x41500048) /* Keypad Interface Key Debounce Interval register */ +#define KPC 0x41500000 /* Keypad Interface Control register */ +#define KPDK 0x41500008 /* Keypad Interface Direct Key register */ +#define KPREC 0x41500010 /* Keypad Intefcace Rotary Encoder register */ +#define KPMK 0x41500018 /* Keypad Intefcace Matrix Key register */ +#define KPAS 0x41500020 /* Keypad Interface Automatic Scan register */ +#define KPASMKP0 0x41500028 /* Keypad Interface Automatic Scan Multiple Key Presser register 0 */ +#define KPASMKP1 0x41500030 /* Keypad Interface Automatic Scan Multiple Key Presser register 1 */ +#define KPASMKP2 0x41500038 /* Keypad Interface Automatic Scan Multiple Key Presser register 2 */ +#define KPASMKP3 0x41500040 /* Keypad Interface Automatic Scan Multiple Key Presser register 3 */ +#define KPKDI 0x41500048 /* Keypad Interface Key Debounce Interval register */
#define KPC_AS (0x1 << 30) /* Automatic Scan bit */ #define KPC_ASACT (0x1 << 29) /* Automatic Scan on Activity */ @@ -2623,15 +2785,15 @@ typedef void (*ExcpHndlr) (void) ; #define KPASMKPx_SO (0x1 << 31)
#define GPIO113_BIT (1 << 17)/* GPIO113 in GPSR, GPCR, bit 17 */ -#define PSLR __REG(0x40F00034) -#define PSTR __REG(0x40F00038) /* Power Manager Standby Configuration Reg */ -#define PSNR __REG(0x40F0003C) /* Power Manager Sense Configuration Reg */ -#define PVCR __REG(0x40F00040) /* Power Manager Voltage Change Control Reg */ -#define PKWR __REG(0x40F00050) /* Power Manager KB Wake-Up Enable Reg */ -#define PKSR __REG(0x40F00054) /* Power Manager KB Level-Detect Status Reg */ -#define OSMR4 __REG(0x40A00080) /* */ -#define OSCR4 __REG(0x40A00040) /* OS Timer Counter Register */ -#define OMCR4 __REG(0x40A000C0) /* */ +#define PSLR 0x40F00034 +#define PSTR 0x40F00038 /* Power Manager Standby Configuration Reg */ +#define PSNR 0x40F0003C /* Power Manager Sense Configuration Reg */ +#define PVCR 0x40F00040 /* Power Manager Voltage Change Control Reg */ +#define PKWR 0x40F00050 /* Power Manager KB Wake-Up Enable Reg */ +#define PKSR 0x40F00054 /* Power Manager KB Level-Detect Status Reg */ +#define OSMR4 0x40A00080 /* */ +#define OSCR4 0x40A00040 /* OS Timer Counter Register */ +#define OMCR4 0x40A000C0 /* */
diff --git a/board/colibri_pxa270/colibri_pxa270.c b/board/colibri_pxa270/colibri_pxa270.c index 84ec38e..8aa7067 100644 --- a/board/colibri_pxa270/colibri_pxa270.c +++ b/board/colibri_pxa270/colibri_pxa270.c @@ -22,6 +22,7 @@ #include <common.h> #include <asm/arch/hardware.h> #include <netdev.h> +#include <asm/io.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -65,28 +66,30 @@ int dram_init (void) #ifdef CONFIG_CMD_USB int usb_board_init(void) { - UHCHR = (UHCHR | UHCHR_PCPL | UHCHR_PSPL) & - ~(UHCHR_SSEP0 | UHCHR_SSEP1 | UHCHR_SSEP2 | UHCHR_SSE); + writel((readl(UHCHR) | UHCHR_PCPL | UHCHR_PSPL) & + ~(UHCHR_SSEP0 | UHCHR_SSEP1 | UHCHR_SSEP2 | UHCHR_SSE), + UHCHR);
- UHCHR |= UHCHR_FSBIR; + writel(readl(UHCHR) | UHCHR_FSBIR, UHCHR);
while (UHCHR & UHCHR_FSBIR);
- UHCHR &= ~UHCHR_SSE; - UHCHIE = (UHCHIE_UPRIE | UHCHIE_RWIE); + writel(readl(UHCHR) & ~UHCHR_SSE, UHCHR); + writel((UHCHIE_UPRIE | UHCHIE_RWIE), UHCHIE);
/* Clear any OTG Pin Hold */ - if (PSSR & PSSR_OTGPH) - PSSR |= PSSR_OTGPH; + if (readl(PSSR) & PSSR_OTGPH) + writel(readl(PSSR) | PSSR_OTGPH, PSSR);
- UHCRHDA &= ~(0x200); - UHCRHDA |= 0x100; + writel(readl(UHCRHDA) & ~(0x200), UHCRHDA); + writel(readl(UHCRHDA) | 0x100, UHCRHDA);
/* Set port power control mask bits, only 3 ports. */ - UHCRHDB |= (0x7<<17); + writel(readl(UHCRHDB) | (0x7<<17), UHCRHDB);
/* enable port 2 */ - UP2OCR |= UP2OCR_HXOE | UP2OCR_HXS | UP2OCR_DMPDE | UP2OCR_DPPDE; + writel(readl(UP2OCR) | UP2OCR_HXOE | UP2OCR_HXS | + UP2OCR_DMPDE | UP2OCR_DPPDE, UP2OCR);
return 0; } @@ -98,14 +101,14 @@ void usb_board_init_fail(void)
void usb_board_stop(void) { - UHCHR |= UHCHR_FHR; + writel(readl(UHCHR) | UHCHR_FHR, UHCHR); udelay(11); - UHCHR &= ~UHCHR_FHR; + writel(readl(UHCHR) & ~UHCHR_FHR, UHCHR);
- UHCCOMS |= 1; + writel(readl(UHCCOMS) | 1, UHCCOMS); udelay(10);
- CKEN &= ~CKEN10_USBHOST; + writel(readl(CKEN) & ~CKEN10_USBHOST, CKEN);
return; } diff --git a/board/cradle/cradle.c b/board/cradle/cradle.c index 21eb655..c4a93f9 100644 --- a/board/cradle/cradle.c +++ b/board/cradle/cradle.c @@ -28,6 +28,7 @@ #include <asm/arch/pxa-regs.h> #include <common.h> #include <netdev.h> +#include <asm/io.h>
@@ -92,8 +93,8 @@ set_led (int led, int color) int shift = led * 2; unsigned long mask = 0x3 << shift;
- CRADLE_LED_CLR_REG = mask; /* clear bits */ - CRADLE_LED_SET_REG = (color << shift); /* set bits */ + writel(mask, GPCR2); /* clear bits */ + writel((color << shift), GPSR2); /* set bits */ udelay (5000); }
diff --git a/board/cradle/lowlevel_init.S b/board/cradle/lowlevel_init.S index 6b5cfb9..39964b6 100644 --- a/board/cradle/lowlevel_init.S +++ b/board/cradle/lowlevel_init.S @@ -34,10 +34,10 @@ DRAM_SIZE: .long CONFIG_SYS_DRAM_SIZE .endm
.macro SET_LED val - ldr r6, =CRADLE_LED_CLR_REG + ldr r6, =GPCR2 ldr r7, =0 str r7, [r6] - ldr r6, =CRADLE_LED_SET_REG + ldr r6, =GPSR2 ldr r7, =\val str r7, [r6] .endm diff --git a/board/csb226/csb226.c b/board/csb226/csb226.c index 0a6c13d..6eed9ad 100644 --- a/board/csb226/csb226.c +++ b/board/csb226/csb226.c @@ -26,6 +26,7 @@ #include <common.h> #include <netdev.h> #include <asm/arch/pxa-regs.h> +#include <asm/io.h>
@@ -108,23 +109,23 @@ void csb226_set_led(int led, int state) switch(led) {
case 0: if (state==1) { - GPCR0 |= CSB226_USER_LED0; + writel(readl(GPCR0) | CSB226_USER_LED0, GPCR0); } else if (state==0) { - GPSR0 |= CSB226_USER_LED0; + writel(readl(GPSR0) | CSB226_USER_LED0, GPSR0); } break;
case 1: if (state==1) { - GPCR0 |= CSB226_USER_LED1; + writel(readl(GPCR0) | CSB226_USER_LED1, GPCR0); } else if (state==0) { - GPSR0 |= CSB226_USER_LED1; + writel(readl(GPSR0) | CSB226_USER_LED1, GPSR0); } break;
case 2: if (state==1) { - GPCR0 |= CSB226_USER_LED2; + writel(readl(GPCR0) | CSB226_USER_LED2, GPCR0); } else if (state==0) { - GPSR0 |= CSB226_USER_LED2; + writel(readl(GPSR0) | CSB226_USER_LED2, GPSR0); } break; } diff --git a/board/delta/delta.c b/board/delta/delta.c index 68c39d2..df23076 100644 --- a/board/delta/delta.c +++ b/board/delta/delta.c @@ -28,6 +28,7 @@ #include <malloc.h> #include <command.h> #include <asm/arch/pxa-regs.h> +#include <asm/io.h>
@@ -110,7 +111,7 @@ static uchar kbd_command_prefix[] = "key_cmd"; static void get_pressed_keys(uchar *s) { unsigned long val; - val = GPLR3; + val = readl(GPLR3);
if(val & (1<<31)) *s++ = KEYBD_KP_DKIN0; @@ -124,18 +125,18 @@ static void get_pressed_keys(uchar *s)
static void keys_init() { - CKENB |= CKENB_7_GPIO; + writel(readl(CKENB) | CKENB_7_GPIO, CKENB); udelay(100);
/* Configure GPIOs */ - GPIO127 = 0xa840; /* KP_DKIN0 */ - GPIO114 = 0xa840; /* KP_DKIN1 */ - GPIO125 = 0xa840; /* KP_DKIN2 */ - GPIO118 = 0xa840; /* KP_DKIN5 */ + writel(0xa840, GPIO127); /* KP_DKIN0 */ + writel(0xa840, GPIO114); /* KP_DKIN1 */ + writel(0xa840, GPIO125); /* KP_DKIN2 */ + writel(0xa840, GPIO118); /* KP_DKIN5 */
/* Configure GPIOs as inputs */ - GPDR3 &= ~(1<<31 | 1<<18 | 1<<29 | 1<<22); - GCDR3 = (1<<31 | 1<<18 | 1<<29 | 1<<22); + writel(readl(GPDR3) & ~(1<<31 | 1<<18 | 1<<29 | 1<<22), GPDR3); + writel((1<<31 | 1<<18 | 1<<29 | 1<<22), GCDR3);
udelay(100); } @@ -283,11 +284,11 @@ int dram_init (void)
void i2c_init_board() { - CKENB |= (CKENB_4_I2C); + writel(readl(CKENB) | (CKENB_4_I2C), CKENB);
/* setup I2C GPIO's */ - GPIO32 = 0x801; /* SCL = Alt. Fkt. 1 */ - GPIO33 = 0x801; /* SDA = Alt. Fkt. 1 */ + writel(0x801, GPIO32); /* SCL = Alt. Fkt. 1 */ + writel(0x801, GPIO33); /* SDA = Alt. Fkt. 1 */ }
/* initialize the DA9030 Power Controller */ @@ -295,20 +296,20 @@ static void init_DA9030() { uchar addr = (uchar) DA9030_I2C_ADDR, val = 0;
/* Rising Edge on EXTON to reset DA9030 */ - GPIO17 = 0x8800; /* configure GPIO17, no pullup, -down */ - GPDR0 |= (1<<17); /* GPIO17 is output */ - GSDR0 = (1<<17); - GPCR0 = (1<<17); /* drive GPIO17 low */ - GPSR0 = (1<<17); /* drive GPIO17 high */ + writel(0x8800, GPIO17); /* configure GPIO17, no pullup, -down */ + writel(readl(GPDR0) | (1<<17), GPDR0); /* GPIO17 is output */ + writel((1<<17), GSDR0); + writel((1<<17), GPCR0); /* drive GPIO17 low */ + writel((1<<17), GPSR0); /* drive GPIO17 high */
#if CONFIG_SYS_DA9030_EXTON_DELAY udelay((unsigned long) CONFIG_SYS_DA9030_EXTON_DELAY); /* wait for DA9030 */ #endif - GPCR0 = (1<<17); /* drive GPIO17 low */ + writel((1<<17), GPCR0); /* drive GPIO17 low */
/* reset the watchdog and go active (0xec) */ val = (SYS_CONTROL_A_HWRES_ENABLE | diff --git a/board/delta/nand.c b/board/delta/nand.c index 85a6ba2..119a587 100644 --- a/board/delta/nand.c +++ b/board/delta/nand.c @@ -26,6 +26,7 @@
#include <nand.h> #include <asm/arch/pxa-regs.h> +#include <asm/io.h>
#ifdef CONFIG_SYS_DFC_DEBUG1 # define DFC_DEBUG1(fmt, args...) printf(fmt, ##args) @@ -95,7 +96,7 @@ static void dfc_write_buf(struct mtd_info *mtd, const u_char *buf, int len) if(bytes_multi) { for(i=0; i<bytes_multi; i+=4) { long_buf = (unsigned long*) &buf[i]; - NDDB = *long_buf; + writel(*long_buf, NDDB); } } if(rest) { @@ -120,7 +121,7 @@ static void dfc_read_buf(struct mtd_info *mtd, u_char* const buf, int len) if(bytes_multi) { for(i=0; i<bytes_multi; i+=4) { long_buf = (unsigned long*) &buf[i]; - *long_buf = NDDB; + *long_buf = readl(NDDB); } }
@@ -166,8 +167,8 @@ static u_char dfc_read_byte(struct mtd_info *mtd) unsigned long dummy;
if(bytes_read < 0) { - read_buf = NDDB; - dummy = NDDB; + read_buf = readl(NDDB); + dummy = readl(NDDB); bytes_read = 0; } byte = (unsigned char) (read_buf>>(8 * bytes_read++)); @@ -181,7 +182,7 @@ static u_char dfc_read_byte(struct mtd_info *mtd) /* calculate delta between OSCR values start and now */ static unsigned long get_delta(unsigned long start) { - unsigned long cur = OSCR; + unsigned long cur = readl(OSCR);
if(cur < start) /* OSCR overflowed */ return (cur + (start^0xffffffff)); @@ -192,7 +193,7 @@ static unsigned long get_delta(unsigned long start) /* delay function, this doesn't belong here */ static void wait_us(unsigned long us) { - unsigned long start = OSCR; + unsigned long start = readl(OSCR); us = DIV_ROUND_UP(us * OSCR_CLK_FREQ, 1000);
while (get_delta(start) < us) { @@ -202,14 +203,14 @@ static void wait_us(unsigned long us)
static void dfc_clear_nddb(void) { - NDCR &= ~NDCR_ND_RUN; + writel(readl(NDCR) & ~NDCR_ND_RUN, NDCR); wait_us(CONFIG_SYS_NAND_OTHER_TO); }
/* wait_event with timeout */ static unsigned long dfc_wait_event(unsigned long event) { - unsigned long ndsr, timeout, start = OSCR; + unsigned long ndsr, timeout, start = readl(OSCR);
if(!event) return 0xff000000; @@ -221,9 +222,9 @@ static unsigned long dfc_wait_event(unsigned long event) * OSCR_CLK_FREQ, 1000);
while(1) { - ndsr = NDSR; + ndsr = readl(NDSR); if(ndsr & event) { - NDSR |= event; + writel(readl(NDSR) | event, NDSR); break; } if(get_delta(start) > timeout) { @@ -243,11 +244,11 @@ static void dfc_new_cmd(void)
while(retry++ <= CONFIG_SYS_NAND_SENDCMD_RETRY) { /* Clear NDSR */ - NDSR = 0xFFF; + writel(0xfff, NDSR);
/* set NDCR[NDRUN] */ - if(!(NDCR & NDCR_ND_RUN)) - NDCR |= NDCR_ND_RUN; + if (!(readl(NDCR) & NDCR_ND_RUN)) + writel(readl(NDCR) | NDCR_ND_RUN, NDCR);
status = dfc_wait_event(NDSR_WRCMDREQ);
@@ -357,9 +358,9 @@ static void dfc_cmdfunc(struct mtd_info *mtd, unsigned command, }
write_cmd: - NDCB0 = ndcb0; - NDCB0 = ndcb1; - NDCB0 = ndcb2; + writel(ndcb0, NDCB0); + writel(ndcb1, NDCB0); + writel(ndcb2, NDCB0);
/* wait_event: */ dfc_wait_event(event); @@ -372,36 +373,36 @@ static void dfc_gpio_init(void) DFC_DEBUG2("Setting up DFC GPIO's.\n");
/* no idea what is done here, see zylonite.c */ - GPIO4 = 0x1; - - DF_ALE_WE1 = 0x00000001; - DF_ALE_WE2 = 0x00000001; - DF_nCS0 = 0x00000001; - DF_nCS1 = 0x00000001; - DF_nWE = 0x00000001; - DF_nRE = 0x00000001; - DF_IO0 = 0x00000001; - DF_IO8 = 0x00000001; - DF_IO1 = 0x00000001; - DF_IO9 = 0x00000001; - DF_IO2 = 0x00000001; - DF_IO10 = 0x00000001; - DF_IO3 = 0x00000001; - DF_IO11 = 0x00000001; - DF_IO4 = 0x00000001; - DF_IO12 = 0x00000001; - DF_IO5 = 0x00000001; - DF_IO13 = 0x00000001; - DF_IO6 = 0x00000001; - DF_IO14 = 0x00000001; - DF_IO7 = 0x00000001; - DF_IO15 = 0x00000001; - - DF_nWE = 0x1901; - DF_nRE = 0x1901; - DF_CLE_NOE = 0x1900; - DF_ALE_WE1 = 0x1901; - DF_INT_RnB = 0x1900; + writel(0x1, GPIO4); + + writel(0x00000001, DF_ALE_nWE1); + writel(0x00000001, DF_ALE_nWE2); + writel(0x00000001, DF_nCS0); + writel(0x00000001, DF_nCS1); + writel(0x00000001, DF_nWE); + writel(0x00000001, DF_nRE); + writel(0x00000001, DF_IO0); + writel(0x00000001, DF_IO8); + writel(0x00000001, DF_IO1); + writel(0x00000001, DF_IO9); + writel(0x00000001, DF_IO2); + writel(0x00000001, DF_IO10); + writel(0x00000001, DF_IO3); + writel(0x00000001, DF_IO11); + writel(0x00000001, DF_IO4); + writel(0x00000001, DF_IO12); + writel(0x00000001, DF_IO5); + writel(0x00000001, DF_IO13); + writel(0x00000001, DF_IO6); + writel(0x00000001, DF_IO14); + writel(0x00000001, DF_IO7); + writel(0x00000001, DF_IO15); + + writel(0x1901, DF_nWE); + writel(0x1901, DF_nRE); + writel(0x1900, DF_CLE_nOE); + writel(0x1901, DF_ALE_nWE1); + writel(0x1900, DF_INT_RnB); }
/* @@ -430,7 +431,7 @@ int board_nand_init(struct nand_chip *nand) dfc_gpio_init();
/* turn on the NAND Controller Clock (104 MHz @ D0) */ - CKENA |= (CKENA_4_NAND | CKENA_9_SMC); + writel(readl(CKENA) | (CKENA_4_NAND | CKENA_9_SMC), CKENA);
#undef CONFIG_SYS_TIMING_TIGHT #ifndef CONFIG_SYS_TIMING_TIGHT @@ -485,17 +486,19 @@ int board_nand_init(struct nand_chip *nand) tRP_high = 0; }
- NDTR0CS0 = (tCH << 19) | + writel((tCH << 19) | (tCS << 16) | (tWH << 11) | (tWP << 8) | (tRP_high << 6) | (tRH << 3) | - (tRP << 0); + (tRP << 0), + NDTR0CS0);
- NDTR1CS0 = (tR << 16) | + writel((tR << 16) | (tWHR << 4) | - (tAR << 0); + (tAR << 0), + NDTR1CS0);
/* If it doesn't work (unlikely) think about: * - ecc enable @@ -512,7 +515,7 @@ int board_nand_init(struct nand_chip *nand) */ /* NDCR_NCSX | /* Chip select busy don't care */ */
- NDCR = (NDCR_SPARE_EN | /* use the spare area */ + writel(NDCR_SPARE_EN | /* use the spare area */ NDCR_DWIDTH_C | /* 16bit DFC data bus width */ NDCR_DWIDTH_M | /* 16 bit Flash device data bus width */ (2 << 16) | /* read id count = 7 ???? mk@tbd */ @@ -528,7 +531,8 @@ int board_nand_init(struct nand_chip *nand) NDCR_SBERRM | /* single bit error ir masked */ NDCR_WRDREQM | /* write data request ir masked */ NDCR_RDDREQM | /* read data request ir masked */ - NDCR_WRCMDREQM); /* write command request ir masked */ + NDCR_WRCMDREQM, /* write command request ir masked */ + NDCR);
/* wait 10 us due to cmd buffer clear reset */ diff --git a/board/innokom/innokom.c b/board/innokom/innokom.c index 3412f10..2c51125 100644 --- a/board/innokom/innokom.c +++ b/board/innokom/innokom.c @@ -27,6 +27,7 @@ #include <netdev.h> #include <asm/arch/pxa-regs.h> #include <asm/mach-types.h> +#include <asm/io.h>
@@ -48,20 +49,21 @@ int i2c_init_board(void)
/* disable I2C controller first, otherwhise it thinks we want to */ /* talk to the slave port... */ - icr = ICR; ICR &= ~(ICR_SCLE | ICR_IUE); + icr = readl(ICR); + writel(readl(ICR) & ~(ICR_SCLE | ICR_IUE), ICR);
/* set gpio pin low _before_ we change direction to output */ - GPCR(70) = GPIO_bit(70); + writel(GPIO_bit(70), GPCR(70));
/* now toggle between output=low and high-impedance */ for (i = 0; i < 20; i++) { - GPDR(70) |= GPIO_bit(70); /* output */ + writel(readl(GPDR(70)) | GPIO_bit(70), GPDR(70)); /* output */ udelay(10); - GPDR(70) &= ~GPIO_bit(70); /* input */ + writel(readl(GPDR(70)) & ~GPIO_bit(70), GPDR(70)); /* input */ udelay(10); }
- ICR = icr; + writel(icr, ICR);
return 0; } @@ -76,7 +78,7 @@ int misc_init_r(void) char *str;
/* determine if the software update key is pressed during startup */ - if (GPLR0 & 0x00000800) { + if (readl(GPLR0) & 0x00000800) { printf("using bootcmd_normal (sw-update button not pressed)\n"); str = getenv("bootcmd_normal"); } else { diff --git a/board/pxa255_idp/pxa_idp.c b/board/pxa255_idp/pxa_idp.c index a54a95d..4ab8bd4 100644 --- a/board/pxa255_idp/pxa_idp.c +++ b/board/pxa255_idp/pxa_idp.c @@ -33,6 +33,7 @@ #include <common.h> #include <netdev.h> #include <command.h> +#include <asm/io.h>
@@ -56,14 +57,14 @@ int board_init (void)
/* set PWM for LCD */ /* a value that works is 60Hz, 77% duty cycle */ - CKEN |= CKEN0_PWM0; - PWM_CTRL0 = 0x3f; - PWM_PERVAL0 = 0x3ff; - PWM_PWDUTY0 = 792; + writel(readl(CKEN) | CKEN0_PWM0, CKEN); + writel(0x3f, PWM_CTRL0); + writel(0x3ff, PWM_PERVAL0); + writel(792, PWM_PWDUTY0);
/* clear reset to AC97 codec */ - CKEN |= CKEN2_AC97; - GCR = GCR_COLD_RST; + writel(readl(CKEN) | CKEN2_AC97, CKEN); + writel(GCR_COLD_RST, GCR);
/* enable LCD backlight */ /* *(volatile unsigned int *)(PXA_CS5_PHYS + 0x03C00030) = 0x7; */ @@ -102,11 +103,11 @@ int dram_init (void) void delay_c(void) { /* reset OSCR to 0 */ - OSCR = 0; - while(OSCR > 0x10000) + writel(0, OSCR); + while (readl(OSCR) > 0x10000) ;
- while(OSCR < 0xd4000) + while (readl(OSCR) < 0xd4000) ; }
@@ -114,12 +115,12 @@ void blink_c(void) { int led_bit = (1<<10);
- GPDR0 = led_bit; - GPCR0 = led_bit; + writel(led_bit, GPDR0); + writel(led_bit, GPCR0); delay_c(); - GPSR0 = led_bit; + writel(led_bit, GPSR0); delay_c(); - GPCR0 = led_bit; + writel(led_bit, GPCR0); }
int do_idpcmd(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) diff --git a/board/trizepsiv/conxs.c b/board/trizepsiv/conxs.c index 8c11456..7fac73d 100644 --- a/board/trizepsiv/conxs.c +++ b/board/trizepsiv/conxs.c @@ -34,6 +34,7 @@ #include <common.h> #include <asm/arch/pxa-regs.h> #include <netdev.h> +#include <asm/io.h>
@@ -57,25 +58,27 @@ extern struct serial_device serial_stuart_device;
- while (UHCHR & UHCHR_FSBIR); + while (readl(UHCHR) & UHCHR_FSBIR) + ;
- UHCRHDA &= ~(RH_A_NPS); - UHCRHDA |= RH_A_PSM; + writel(readl(UHCRHDA) & ~(RH_A_NPS), UHCRHDA); + writel(readl(UHCRHDA) | RH_A_PSM, UHCRHDA);
return 0; } @@ -87,14 +90,14 @@ void usb_board_init_fail(void)
return; } diff --git a/board/vpac270/vpac270.c b/board/vpac270/vpac270.c index 18e47e2..f792298 100644 --- a/board/vpac270/vpac270.c +++ b/board/vpac270/vpac270.c @@ -31,6 +31,8 @@ #include <common.h> #include <asm/arch/hardware.h> #include <netdev.h> +#include <serial.h> +#include <asm/io.h>
@@ -75,28 +77,31 @@ int dram_init (void)
int usb_board_init(void) { - UHCHR = (UHCHR | UHCHR_PCPL | UHCHR_PSPL) & - ~(UHCHR_SSEP0 | UHCHR_SSEP1 | UHCHR_SSEP2 | UHCHR_SSE); + writel((UHCHR | UHCHR_PCPL | UHCHR_PSPL) & + ~(UHCHR_SSEP0 | UHCHR_SSEP1 | UHCHR_SSEP2 | UHCHR_SSE), + UHCHR);
return 0; } @@ -108,14 +113,14 @@ void usb_board_init_fail(void)
return; } diff --git a/board/wepep250/wepep250.c b/board/wepep250/wepep250.c index fe4b6a9..6e41ea6 100644 --- a/board/wepep250/wepep250.c +++ b/board/wepep250/wepep250.c @@ -22,6 +22,7 @@
#include <common.h> #include <asm/arch/pxa-regs.h> +#include <asm/io.h>
@@ -33,13 +34,13 @@ int board_init (void) * Setup GPIO stuff to get serial working */ #if defined( CONFIG_FFUART ) - GPDR1 = 0x80; - GAFR1_L = 0x8010; + writel(0x80, GPDR1); + writel(0x8010, GAFR1_L); #elif defined( CONFIG_BTUART ) - GPDR1 = 0x800; - GAFR1_L = 0x900000; + writel(0x800, GPDR1); + writel(0x900000, GAFR1_L); #endif - PSSR = 0x20; + writel(0x20, PSSR);
return 0; } diff --git a/board/zipitz2/zipitz2.c b/board/zipitz2/zipitz2.c index 14d1d76..f7edc4c 100644 --- a/board/zipitz2/zipitz2.c +++ b/board/zipitz2/zipitz2.c @@ -28,6 +28,7 @@ #include <serial.h> #include <asm/arch/hardware.h> #include <spi.h> +#include <asm/io.h>
@@ -129,24 +130,24 @@ void zipitz2_spi_sda(int set) { /* GPIO 13 */ if (set) - GPSR0 = (1 << 13); + writel((1 << 13), GPSR0); else - GPCR0 = (1 << 13); + writel((1 << 13), GPCR0); }
void zipitz2_spi_scl(int set) { /* GPIO 22 */ if (set) - GPCR0 = (1 << 22); + writel((1 << 22), GPCR0); else - GPSR0 = (1 << 22); + writel((1 << 22), GPSR0); }
unsigned char zipitz2_spi_read(void) { /* GPIO 40 */ - return !!(GPLR1 & (1 << 8)); + return !!(readl(GPLR1) & (1 << 8)); }
int spi_cs_is_valid(unsigned int bus, unsigned int cs) @@ -158,13 +159,13 @@ int spi_cs_is_valid(unsigned int bus, unsigned int cs) void spi_cs_activate(struct spi_slave *slave) { /* GPIO 88 low */ - GPCR2 = (1 << 24); + writel((1 << 24), GPCR2); }
void spi_cs_deactivate(struct spi_slave *slave) { /* GPIO 88 high */ - GPSR2 = (1 << 24); + writel((1 << 24), GPSR2);
@@ -176,20 +177,20 @@ void lcd_start(void) unsigned char dummy[3] = { 0, 0, 0 };
/* PWM2 AF */ - GAFR0_L |= 0x00800000; + writel(readl(GAFR0_L) | 0x00800000, GAFR0_L); /* Enable clock to all PWM */ - CKEN |= 0x3; + writel(readl(CKEN) | 0x3, CKEN); /* Configure PWM2 */ - PWM_CTRL2 = 0x4f; - PWM_PWDUTY2 = 0x2ff; - PWM_PERVAL2 = 792; + writel(0x4f, PWM_CTRL2); + writel(0x2ff, PWM_PWDUTY2); + writel(792, PWM_PERVAL2);
/* Toggle the reset pin to reset the LCD */ - GPSR0 = (1 << 19); + writel((1 << 19), GPSR0); udelay(100000); - GPCR0 = (1 << 19); + writel((1 << 19), GPCR0); udelay(20000); - GPSR0 = (1 << 19); + writel((1 << 19), GPSR0); udelay(20000);
/* Program the LCD init sequence */ @@ -208,6 +209,6 @@ void lcd_start(void) udelay(lcd_data[i].mdelay * 1000); }
- GPSR0 = (1 << 11); + writel((1 << 11), GPSR0); } #endif diff --git a/board/zylonite/nand.c b/board/zylonite/nand.c index 7cad1ac..71d18a6 100644 --- a/board/zylonite/nand.c +++ b/board/zylonite/nand.c @@ -21,6 +21,7 @@ */
#include <common.h> +#include <asm/io.h>
#if defined(CONFIG_CMD_NAND)
@@ -95,7 +96,7 @@ static void dfc_write_buf(struct mtd_info *mtd, const u_char *buf, int len) if(bytes_multi) { for(i=0; i<bytes_multi; i+=4) { long_buf = (unsigned long*) &buf[i]; - NDDB = *long_buf; + writel(*long_buf, NDDB); } } if(rest) { @@ -125,7 +126,7 @@ static void dfc_read_buf(struct mtd_info *mtd, u_char* const buf, int len) if(bytes_multi) { for(i=0; i<bytes_multi; i+=4) { long_buf = (unsigned long*) &buf[i]; - *long_buf = NDDB; + *long_buf = readl(NDDB); } }
@@ -171,8 +172,8 @@ static u_char dfc_read_byte(struct mtd_info *mtd) unsigned long dummy;
if(bytes_read < 0) { - read_buf = NDDB; - dummy = NDDB; + read_buf = readl(NDDB); + dummy = readl(NDDB); bytes_read = 0; } byte = (unsigned char) (read_buf>>(8 * bytes_read++)); @@ -186,7 +187,7 @@ static u_char dfc_read_byte(struct mtd_info *mtd) /* calculate delta between OSCR values start and now */ static unsigned long get_delta(unsigned long start) { - unsigned long cur = OSCR; + unsigned long cur = readl(OSCR);
if(cur < start) /* OSCR overflowed */ return (cur + (start^0xffffffff)); @@ -197,7 +198,7 @@ static unsigned long get_delta(unsigned long start) /* delay function, this doesn't belong here */ static void wait_us(unsigned long us) { - unsigned long start = OSCR; + unsigned long start = readl(OSCR); us = DIV_ROUND_UP(us * OSCR_CLK_FREQ, 1000);
while (get_delta(start) < us) { @@ -207,14 +208,14 @@ static void wait_us(unsigned long us)
if(!event) return 0xff000000; @@ -226,9 +227,9 @@ static unsigned long dfc_wait_event(unsigned long event) * OSCR_CLK_FREQ, 1000);
while(1) { - ndsr = NDSR; + ndsr = readl(NDSR); if(ndsr & event) { - NDSR |= event; + writel(readl(NDSR) | event, NDSR); break; } if(get_delta(start) > timeout) { @@ -248,11 +249,11 @@ static void dfc_new_cmd(void)
while(retry++ <= CONFIG_SYS_NAND_SENDCMD_RETRY) { /* Clear NDSR */ - NDSR = 0xFFF; + writel(0xFFF, NDSR);
@@ -362,9 +363,9 @@ static void dfc_cmdfunc(struct mtd_info *mtd, unsigned command, }
/* wait_event: */ dfc_wait_event(event); @@ -377,36 +378,36 @@ static void dfc_gpio_init(void) DFC_DEBUG2("Setting up DFC GPIO's.\n");
/* @@ -435,7 +436,7 @@ int board_nand_init(struct nand_chip *nand) dfc_gpio_init();
#undef CONFIG_SYS_TIMING_TIGHT #ifndef CONFIG_SYS_TIMING_TIGHT @@ -490,17 +491,19 @@ int board_nand_init(struct nand_chip *nand) tRP_high = 0; }
/* If it doesn't work (unlikely) think about: * - ecc enable @@ -517,7 +520,7 @@ int board_nand_init(struct nand_chip *nand) */ /* NDCR_NCSX | /* Chip select busy don't care */ */
- NDCR = (NDCR_SPARE_EN | /* use the spare area */ + writel(NDCR_SPARE_EN | /* use the spare area */ NDCR_DWIDTH_C | /* 16bit DFC data bus width */ NDCR_DWIDTH_M | /* 16 bit Flash device data bus width */ (2 << 16) | /* read id count = 7 ???? mk@tbd */ @@ -533,7 +536,8 @@ int board_nand_init(struct nand_chip *nand) NDCR_SBERRM | /* single bit error ir masked */ NDCR_WRDREQM | /* write data request ir masked */ NDCR_RDDREQM | /* read data request ir masked */ - NDCR_WRCMDREQM); /* write command request ir masked */ + NDCR_WRCMDREQM, /* write command request ir masked */ + NDCR);
/* wait 10 us due to cmd buffer clear reset */ diff --git a/drivers/mmc/pxa_mmc.c b/drivers/mmc/pxa_mmc.c index 8776903..48e21ef 100644 --- a/drivers/mmc/pxa_mmc.c +++ b/drivers/mmc/pxa_mmc.c @@ -27,6 +27,7 @@ #include <asm/errno.h> #include <asm/arch/hardware.h> #include <part.h> +#include <asm/io.h>
#include "pxa_mmc.h"
@@ -59,18 +60,20 @@ mmc_cmd(ushort cmd, ushort argh, ushort argl, ushort cmdat)
debug("mmc_cmd %u 0x%04x 0x%04x 0x%04x\n", cmd, argh, argl, cmdat | wide); - MMC_STRPCL = MMC_STRPCL_STOP_CLK; - MMC_I_MASK = ~MMC_I_MASK_CLK_IS_OFF; - while (!(MMC_I_REG & MMC_I_REG_CLK_IS_OFF)) ; - MMC_CMD = cmd; - MMC_ARGH = argh; - MMC_ARGL = argl; - MMC_CMDAT = cmdat | wide; - MMC_I_MASK = ~MMC_I_MASK_END_CMD_RES; - MMC_STRPCL = MMC_STRPCL_START_CLK; - while (!(MMC_I_REG & MMC_I_REG_END_CMD_RES)) ; - - status = MMC_STAT; + writel(MMC_STRPCL_STOP_CLK, MMC_STRPCL); + writel(~MMC_I_MASK_CLK_IS_OFF, MMC_I_MASK); + while (!(readl(MMC_I_REG) & MMC_I_REG_CLK_IS_OFF)) + ; + writel(cmd, MMC_CMD); + writel(argh, MMC_ARGH); + writel(argl, MMC_ARGL); + writel(cmdat | wide, MMC_CMDAT); + writel(~MMC_I_MASK_END_CMD_RES, MMC_I_MASK); + writel(MMC_STRPCL_START_CLK, MMC_STRPCL); + while (!(readl(MMC_I_REG) & MMC_I_REG_END_CMD_RES)) + ; + + status = readl(MMC_STAT); debug("MMC status 0x%08x\n", status); if (status & MMC_STAT_TIME_OUT_RESPONSE) { return 0; @@ -80,10 +83,10 @@ mmc_cmd(ushort cmd, ushort argh, ushort argl, ushort cmdat) * Did I mention this is Sick. We always need to * discard the upper 8 bits of the first 16-bit word. */ - a = (MMC_RES & 0xffff); + a = (readl(MMC_RES) & 0xffff); for (i = 0; i < 4; i++) { - b = (MMC_RES & 0xffff); - c = (MMC_RES & 0xffff); + b = (readl(MMC_RES) & 0xffff); + c = (readl(MMC_RES) & 0xffff); resp[i] = (a << 24) | (b << 8) | (c >> 8); a = c; debug("MMC resp[%d] = %#08x\n", i, resp[i]); @@ -115,37 +118,38 @@ mmc_block_read(uchar * dst, ulong src, ulong len) /* send read command */ argh = src >> 16; argl = src & 0xffff; - MMC_STRPCL = MMC_STRPCL_STOP_CLK; - MMC_RDTO = 0xffff; - MMC_NOB = 1; - MMC_BLKLEN = len; + writel(MMC_STRPCL_STOP_CLK, MMC_STRPCL); + writel(0xffff, MMC_RDTO); + writel(1, MMC_NOB); + writel(len, MMC_BLKLEN); mmc_cmd(MMC_CMD_READ_SINGLE_BLOCK, argh, argl, MMC_CMDAT_R1 | MMC_CMDAT_READ | MMC_CMDAT_BLOCK | MMC_CMDAT_DATA_EN);
- MMC_I_MASK = ~MMC_I_MASK_RXFIFO_RD_REQ; + writel(~MMC_I_MASK_RXFIFO_RD_REQ, MMC_I_MASK); while (len) { - if (MMC_I_REG & MMC_I_REG_RXFIFO_RD_REQ) { + if (readl(MMC_I_REG) & MMC_I_REG_RXFIFO_RD_REQ) { #if defined(CONFIG_PXA27X) || defined(CONFIG_CPU_MONAHANS) int i; for (i = min(len, 32); i; i--) { - *dst++ = *((volatile uchar *)&MMC_RXFIFO); + *dst++ = readb(MMC_RXFIFO); len--; } #else - *dst++ = MMC_RXFIFO; + *dst++ = readb(MMC_RXFIFO); len--; #endif } - status = MMC_STAT; + status = readl(MMC_STAT); if (status & MMC_STAT_ERRORS) { printf("MMC_STAT error %lx\n", status); return -1; } } - MMC_I_MASK = ~MMC_I_MASK_DATA_TRAN_DONE; - while (!(MMC_I_REG & MMC_I_REG_DATA_TRAN_DONE)) ; - status = MMC_STAT; + writel(~MMC_I_MASK_DATA_TRAN_DONE, MMC_I_MASK); + while (!(readl(MMC_I_REG) & MMC_I_REG_DATA_TRAN_DONE)) + ; + status = readl(MMC_STAT); if (status & MMC_STAT_ERRORS) { printf("MMC_STAT error %lx\n", status); return -1; @@ -176,37 +180,39 @@ mmc_block_write(ulong dst, uchar * src, int len) /* send write command */ argh = dst >> 16; argl = dst & 0xffff; - MMC_STRPCL = MMC_STRPCL_STOP_CLK; - MMC_NOB = 1; - MMC_BLKLEN = len; + writel(MMC_STRPCL_STOP_CLK, MMC_STRPCL); + writel(1, MMC_NOB); + writel(len, MMC_BLKLEN); mmc_cmd(MMC_CMD_WRITE_SINGLE_BLOCK, argh, argl, MMC_CMDAT_R1 | MMC_CMDAT_WRITE | MMC_CMDAT_BLOCK | MMC_CMDAT_DATA_EN);
- MMC_I_MASK = ~MMC_I_MASK_TXFIFO_WR_REQ; + writel(~MMC_I_MASK_TXFIFO_WR_REQ, MMC_I_MASK); while (len) { - if (MMC_I_REG & MMC_I_REG_TXFIFO_WR_REQ) { + if (readl(MMC_I_REG) & MMC_I_REG_TXFIFO_WR_REQ) { int i, bytes = min(32, len);
for (i = 0; i < bytes; i++) { - MMC_TXFIFO = *src++; + writel(*src++, MMC_TXFIFO); } if (bytes < 32) { - MMC_PRTBUF = MMC_PRTBUF_BUF_PART_FULL; + writel(MMC_PRTBUF_BUF_PART_FULL, MMC_PRTBUF); } len -= bytes; } - status = MMC_STAT; + status = readl(MMC_STAT); if (status & MMC_STAT_ERRORS) { printf("MMC_STAT error %lx\n", status); return -1; } } - MMC_I_MASK = ~MMC_I_MASK_DATA_TRAN_DONE; - while (!(MMC_I_REG & MMC_I_REG_DATA_TRAN_DONE)) ; - MMC_I_MASK = ~MMC_I_MASK_PRG_DONE; - while (!(MMC_I_REG & MMC_I_REG_PRG_DONE)) ; - status = MMC_STAT; + writel(~MMC_I_MASK_DATA_TRAN_DONE, MMC_I_MASK); + while (!(readl(MMC_I_REG) & MMC_I_REG_DATA_TRAN_DONE)) + ; + writel(~MMC_I_MASK_PRG_DONE, MMC_I_MASK); + while (!(readl(MMC_I_REG) & MMC_I_REG_PRG_DONE)) + ; + status = readl(MMC_STAT); if (status & MMC_STAT_ERRORS) { printf("MMC_STAT error %lx\n", status); return -1; @@ -559,13 +565,13 @@ mmc_legacy_init(int verbose) set_GPIO_mode(GPIO8_MMCCS0_MD); #endif #ifdef CONFIG_CPU_MONAHANS /* pxa3xx */ - CKENA |= CKENA_12_MMC0 | CKENA_13_MMC1; + writel(readl(CKENA) | CKENA_12_MMC0 | CKENA_13_MMC1, CKENA); #else /* pxa2xx */ - CKEN |= CKEN12_MMC; /* enable MMC unit clock */ + writel(readl(CKEN) | CKEN12_MMC, CKEN); /* enable MMC unit clock */ #endif - MMC_CLKRT = MMC_CLKRT_0_3125MHZ; - MMC_RESTO = MMC_RES_TO_MAX; - MMC_SPI = MMC_SPI_DISABLE; + writel(MMC_CLKRT_0_3125MHZ, MMC_CLKRT); + writel(MMC_RES_TO_MAX, MMC_RESTO); + writel(MMC_SPI_DISABLE, MMC_SPI);
/* reset */ mmc_cmd(MMC_CMD_GO_IDLE_STATE, 0, 0, MMC_CMDAT_INIT | MMC_CMDAT_R0); @@ -624,7 +630,7 @@ mmc_legacy_init(int verbose) mmc_decode_cid(cid_resp); }
- MMC_CLKRT = 0; /* 20 MHz */ + writel(0, MMC_CLKRT); /* 20 MHz */ resp = mmc_cmd(MMC_CMD_SELECT_CARD, rca, 0, MMC_CMDAT_R1);
#if defined(CONFIG_PXA27X) || defined(CONFIG_CPU_MONAHANS) diff --git a/drivers/serial/serial_pxa.c b/drivers/serial/serial_pxa.c index b74e439..e457980 100644 --- a/drivers/serial/serial_pxa.c +++ b/drivers/serial/serial_pxa.c @@ -32,6 +32,7 @@ #include <watchdog.h> #include <serial.h> #include <asm/arch/pxa-regs.h> +#include <asm/io.h>
@@ -73,60 +74,60 @@ void pxa_setbrg_dev (unsigned int uart_index) switch (uart_index) { case FFUART_INDEX: #ifdef CONFIG_CPU_MONAHANS - CKENA |= CKENA_22_FFUART; + writel(readl(CKENA) | CKENA_22_FFUART, CKENA); #else - CKEN |= CKEN6_FFUART; + writel(readl(CKEN) | CKEN6_FFUART, CKEN); #endif /* CONFIG_CPU_MONAHANS */
- FFIER = 0; /* Disable for now */ - FFFCR = 0; /* No fifos enabled */ + writel(0, FFIER); /* Disable for now */ + writel(0, FFFCR); /* No fifos enabled */
/* set baud rate */ - FFLCR = LCR_WLS0 | LCR_WLS1 | LCR_DLAB; - FFDLL = quot & 0xff; - FFDLH = quot >> 8; - FFLCR = LCR_WLS0 | LCR_WLS1; + writel(LCR_WLS0 | LCR_WLS1 | LCR_DLAB, FFLCR); + writel(quot & 0xff, FFDLL); + writel(quot >> 8, FFDLH); + writel(LCR_WLS0 | LCR_WLS1, FFLCR);
- FFIER = IER_UUE; /* Enable FFUART */ + writel(IER_UUE, FFIER); /* Enable FFUART */ break;
case BTUART_INDEX: #ifdef CONFIG_CPU_MONAHANS - CKENA |= CKENA_21_BTUART; + writel(readl(CKENA) | CKENA_21_BTUART, CKENA); #else - CKEN |= CKEN7_BTUART; + writel(readl(CKEN) | CKEN7_BTUART, CKEN); #endif /* CONFIG_CPU_MONAHANS */
- BTIER = 0; - BTFCR = 0; + writel(0, BTIER); + writel(0, BTFCR);
/* set baud rate */ - BTLCR = LCR_DLAB; - BTDLL = quot & 0xff; - BTDLH = quot >> 8; - BTLCR = LCR_WLS0 | LCR_WLS1; + writel(LCR_DLAB, BTLCR); + writel(quot & 0xff, BTDLL); + writel(quot >> 8, BTDLH); + writel(LCR_WLS0 | LCR_WLS1, BTLCR);
- BTIER = IER_UUE; /* Enable BFUART */ + writel(IER_UUE, BTIER); /* Enable BFUART */
break;
case STUART_INDEX: #ifdef CONFIG_CPU_MONAHANS - CKENA |= CKENA_23_STUART; + writel(readl(CKENA) | CKENA_23_STUART, CKENA); #else - CKEN |= CKEN5_STUART; + writel(readl(CKEN) | CKEN5_STUART, CKEN); #endif /* CONFIG_CPU_MONAHANS */
- STIER = 0; - STFCR = 0; + writel(0, STIER); + writel(0, STFCR);
/* set baud rate */ - STLCR = LCR_DLAB; - STDLL = quot & 0xff; - STDLH = quot >> 8; - STLCR = LCR_WLS0 | LCR_WLS1; + writel(LCR_DLAB, STLCR); + writel(quot & 0xff, STDLL); + writel(quot >> 8, STDLH); + writel(LCR_WLS0 | LCR_WLS1, STLCR);
- STIER = IER_UUE; /* Enable STUART */ + writel(IER_UUE, STIER); /* Enable STUART */ break;
default: @@ -156,21 +157,21 @@ void pxa_putc_dev (unsigned int uart_index,const char c) switch (uart_index) { case FFUART_INDEX: /* wait for room in the tx FIFO on FFUART */ - while ((FFLSR & LSR_TEMT) == 0) + while ((readl(FFLSR) & LSR_TEMT) == 0) WATCHDOG_RESET (); /* Reset HW Watchdog, if needed */ - FFTHR = c; + writel(c, FFTHR); break;
case BTUART_INDEX: - while ((BTLSR & LSR_TEMT ) == 0 ) + while ((readl(BTLSR) & LSR_TEMT) == 0) WATCHDOG_RESET (); /* Reset HW Watchdog, if needed */ - BTTHR = c; + writel(c, BTTHR); break;
case STUART_INDEX: - while ((STLSR & LSR_TEMT ) == 0 ) + while ((readl(STLSR) & LSR_TEMT) == 0) WATCHDOG_RESET (); /* Reset HW Watchdog, if needed */ - STTHR = c; + writel(c, STTHR); break; }
@@ -188,11 +189,11 @@ int pxa_tstc_dev (unsigned int uart_index) { switch (uart_index) { case FFUART_INDEX: - return FFLSR & LSR_DR; + return readl(FFLSR) & LSR_DR; case BTUART_INDEX: - return BTLSR & LSR_DR; + return readl(BTLSR) & LSR_DR; case STUART_INDEX: - return STLSR & LSR_DR; + return readl(STLSR) & LSR_DR; } return -1; } @@ -206,18 +207,21 @@ int pxa_getc_dev (unsigned int uart_index) { switch (uart_index) { case FFUART_INDEX: - while (!(FFLSR & LSR_DR)) - WATCHDOG_RESET (); /* Reset HW Watchdog, if needed */ - return (char) FFRBR & 0xff; + while (!(readl(FFLSR) & LSR_DR)) + /* Reset HW Watchdog, if needed */ + WATCHDOG_RESET(); + return (char) readl(FFRBR) & 0xff;
case BTUART_INDEX: - while (!(BTLSR & LSR_DR)) - WATCHDOG_RESET (); /* Reset HW Watchdog, if needed */ - return (char) BTRBR & 0xff; + while (!(readl(BTLSR) & LSR_DR)) + /* Reset HW Watchdog, if needed */ + WATCHDOG_RESET(); + return (char) readl(BTRBR) & 0xff; case STUART_INDEX: - while (!(STLSR & LSR_DR)) - WATCHDOG_RESET (); /* Reset HW Watchdog, if needed */ - return (char) STRBR & 0xff; + while (!(readl(STLSR) & LSR_DR)) + /* Reset HW Watchdog, if needed */ + WATCHDOG_RESET(); + return (char) readl(STRBR) & 0xff; } return -1; } diff --git a/include/configs/cradle.h b/include/configs/cradle.h index 200b61e..998e179 100644 --- a/include/configs/cradle.h +++ b/include/configs/cradle.h @@ -339,8 +339,6 @@ #define LED_IRDA1 2 #define LED_IRDA2 4 #define LED_IRDA3 6 -#define CRADLE_LED_SET_REG GPSR2 -#define CRADLE_LED_CLR_REG GPCR2
/* SuperIO defines */ #define CRADLE_SIO_INDEX 0x2e diff --git a/include/configs/delta.h b/include/configs/delta.h index 9c46c5b..d930fb4 100644 --- a/include/configs/delta.h +++ b/include/configs/delta.h @@ -28,6 +28,7 @@ * (easy to change) */ #define CONFIG_CPU_MONAHANS 1 /* Intel Monahan CPU */ +#define CONFIG_CPU_PXA320 #define CONFIG_DELTA 1 /* Delta board */
/* #define CONFIG_LCD 1 */ diff --git a/include/configs/zylonite.h b/include/configs/zylonite.h index d0fc138..c8aa046 100644 --- a/include/configs/zylonite.h +++ b/include/configs/zylonite.h @@ -35,6 +35,7 @@ * (easy to change) */ #define CONFIG_CPU_MONAHANS 1 /* Intel Monahan CPU */ +#define CONFIG_CPU_PXA320 #define CONFIG_ZYLONITE 1 /* Zylonite board */
ACX517AKN LCD panel is found in Palm Tungsten|C
Signed-off-by: Marek Vasut marek.vasut@gmail.com --- arch/arm/cpu/pxa/pxafb.c | 34 ++++++++++++++++++++++++++++++++++ 1 files changed, 34 insertions(+), 0 deletions(-)
diff --git a/arch/arm/cpu/pxa/pxafb.c b/arch/arm/cpu/pxa/pxafb.c index cb004b2..d698395 100644 --- a/arch/arm/cpu/pxa/pxafb.c +++ b/arch/arm/cpu/pxa/pxafb.c @@ -216,6 +216,40 @@ vidinfo_t panel_info = {
+#ifdef CONFIG_ACX517AKN + +# define LCD_BPP LCD_COLOR8 + +/* you have to set lccr0 and lccr3 (including pcd) */ +# define REG_LCCR0 0x003008f9 +# define REG_LCCR3 0x03700006 + +vidinfo_t panel_info = { + .vl_col = 320, + .vl_row = 320, + .vl_width = 320, + .vl_height = 320, + .vl_clkp = CONFIG_SYS_HIGH, + .vl_oep = CONFIG_SYS_LOW, + .vl_hsp = CONFIG_SYS_LOW, + .vl_vsp = CONFIG_SYS_LOW, + .vl_dp = CONFIG_SYS_HIGH, + .vl_bpix = LCD_BPP, + .vl_lbw = 0, + .vl_splt = 1, + .vl_clor = 1, + .vl_tft = 1, + .vl_hpw = 0x04, + .vl_blw = 0x1c, + .vl_elw = 0x08, + .vl_vpw = 0x01, + .vl_bfw = 0x07, + .vl_efw = 0x08, +}; +#endif /* CONFIG_ACX517AKN */ + +/*----------------------------------------------------------------------*/ + #if LCD_BPP == LCD_COLOR8 void lcd_setcolreg (ushort regno, ushort red, ushort green, ushort blue); #endif
This LCD panel is found in Palm LifeDrive handheld
diff --git a/arch/arm/cpu/pxa/pxafb.c b/arch/arm/cpu/pxa/pxafb.c index d698395..2f0f707 100644 --- a/arch/arm/cpu/pxa/pxafb.c +++ b/arch/arm/cpu/pxa/pxafb.c @@ -250,6 +250,40 @@ vidinfo_t panel_info = {
+#ifdef CONFIG_LQ038J7DH53 + +# define LCD_BPP LCD_COLOR8 + +/* you have to set lccr0 and lccr3 (including pcd) */ +# define REG_LCCR0 0x003008f9 +# define REG_LCCR3 0x03700004 + +vidinfo_t panel_info = { + .vl_col = 320, + .vl_row = 480, + .vl_width = 320, + .vl_height = 480, + .vl_clkp = CONFIG_SYS_HIGH, + .vl_oep = CONFIG_SYS_LOW, + .vl_hsp = CONFIG_SYS_LOW, + .vl_vsp = CONFIG_SYS_LOW, + .vl_dp = CONFIG_SYS_HIGH, + .vl_bpix = LCD_BPP, + .vl_lbw = 0, + .vl_splt = 1, + .vl_clor = 1, + .vl_tft = 1, + .vl_hpw = 0x04, + .vl_blw = 0x20, + .vl_elw = 0x01, + .vl_vpw = 0x01, + .vl_bfw = 0x04, + .vl_efw = 0x01, +}; +#endif /* CONFIG_ACX517AKN */ + +/*----------------------------------------------------------------------*/ + #if LCD_BPP == LCD_COLOR8 void lcd_setcolreg (ushort regno, ushort red, ushort green, ushort blue); #endif
Signed-off-by: Marek Vasut marek.vasut@gmail.com --- arch/arm/cpu/pxa/pxafb.c | 33 +++++++++++++++++++++++++++++++++ 1 files changed, 33 insertions(+), 0 deletions(-)
diff --git a/arch/arm/cpu/pxa/pxafb.c b/arch/arm/cpu/pxa/pxafb.c index 2f0f707..987fa06 100644 --- a/arch/arm/cpu/pxa/pxafb.c +++ b/arch/arm/cpu/pxa/pxafb.c @@ -284,6 +284,39 @@ vidinfo_t panel_info = {
+#ifdef CONFIG_LITTLETON_LCD +# define LCD_BPP LCD_COLOR8 + +/* you have to set lccr0 and lccr3 (including pcd) */ +# define REG_LCCR0 0x003008f8 +# define REG_LCCR3 0x0300FF04 + +vidinfo_t panel_info = { + .vl_col = 480, + .vl_row = 640, + .vl_width = 480, + .vl_height = 640, + .vl_clkp = CONFIG_SYS_HIGH, + .vl_oep = CONFIG_SYS_HIGH, + .vl_hsp = CONFIG_SYS_HIGH, + .vl_vsp = CONFIG_SYS_HIGH, + .vl_dp = CONFIG_SYS_HIGH, + .vl_bpix = LCD_BPP, + .vl_lbw = 0, + .vl_splt = 0, + .vl_clor = 0, + .vl_tft = 1, + .vl_hpw = 9, + .vl_blw = 8, + .vl_elw = 24, + .vl_vpw = 2, + .vl_bfw = 2, + .vl_efw = 4, +}; +#endif /* CONFIG_LITTLETON_LCD */ + +/*----------------------------------------------------------------------*/ + #if LCD_BPP == LCD_COLOR8 void lcd_setcolreg (ushort regno, ushort red, ushort green, ushort blue); #endif
Signed-off-by: Marek Vasut marek.vasut@gmail.com --- common/serial.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/common/serial.c b/common/serial.c index 7bebc12..c3323ea 100644 --- a/common/serial.c +++ b/common/serial.c @@ -30,7 +30,7 @@ DECLARE_GLOBAL_DATA_PTR; static struct serial_device *serial_devices = NULL; static struct serial_device *serial_current = NULL;
-#if !defined(CONFIG_LWMON) && !defined(CONFIG_PXA27X) +#if !defined(CONFIG_LWMON) && !defined(CONFIG_PXA250) && !defined(CONFIG_PXA27X) struct serial_device *__default_serial_console (void) { #if defined(CONFIG_8xx_CONS_SMC1) || defined(CONFIG_8xx_CONS_SMC2)
Dear Marek Vasut,
In message 1287257810-23609-7-git-send-email-marek.vasut@gmail.com you wrote:
Acked-by: Wolfgang Denk wd@denx.de
This patch adds support for the Palm Tungsten|C PXA255 board. The support includes: - LCD - MMC - UART - NOR
Signed-off-by: Marek Vasut marek.vasut@gmail.com --- MAINTAINERS | 4 + board/palmtc/Makefile | 49 +++++++++ board/palmtc/config.mk | 1 + board/palmtc/lowlevel_init.S | 39 +++++++ board/palmtc/palmtc.c | 59 ++++++++++ board/palmtc/u-boot.lds | 56 ++++++++++ boards.cfg | 1 + include/configs/palmtc.h | 245 ++++++++++++++++++++++++++++++++++++++++++ 8 files changed, 454 insertions(+), 0 deletions(-) create mode 100644 board/palmtc/Makefile create mode 100644 board/palmtc/config.mk create mode 100644 board/palmtc/lowlevel_init.S create mode 100644 board/palmtc/palmtc.c create mode 100644 board/palmtc/u-boot.lds create mode 100644 include/configs/palmtc.h
diff --git a/MAINTAINERS b/MAINTAINERS index e003226..a7ee984 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -795,6 +795,10 @@ Greg Ungerer greg.ungerer@opengear.com cm4116 ks8695p cm4148 ks8695p
+Marek Vasut marek.vasut@gmail.com + + palmtc xscale + Hugo Villeneuve hugo.villeneuve@lyrtech.com
SFFSDR ARM926EJS diff --git a/board/palmtc/Makefile b/board/palmtc/Makefile new file mode 100644 index 0000000..20ac4e1 --- /dev/null +++ b/board/palmtc/Makefile @@ -0,0 +1,49 @@ +# +# Palm Tungsten|C Support +# +# Copyright (C) 2009-2010 Marek Vasut marek.vasut@gmail.com +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS := palmtc.o +SOBJS := lowlevel_init.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) $(SOBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak $(obj).depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/palmtc/config.mk b/board/palmtc/config.mk new file mode 100644 index 0000000..1d650ac --- /dev/null +++ b/board/palmtc/config.mk @@ -0,0 +1 @@ +TEXT_BASE = 0xa1000000 diff --git a/board/palmtc/lowlevel_init.S b/board/palmtc/lowlevel_init.S new file mode 100644 index 0000000..74050dc --- /dev/null +++ b/board/palmtc/lowlevel_init.S @@ -0,0 +1,39 @@ +/* + * Palm Tungsten|C Lowlevel Hardware Initialization + * + * Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> +#include <version.h> +#include <asm/arch/pxa-regs.h> +#include <asm/arch/macro.h> + +.globl lowlevel_init +lowlevel_init: + pxa_gpio_setup + pxa_wait_ticks 0x8000 + pxa_mem_setup + pxa_wakeup + pxa_intr_setup + pxa_clock_setup + + mov pc, lr diff --git a/board/palmtc/palmtc.c b/board/palmtc/palmtc.c new file mode 100644 index 0000000..04cb33e --- /dev/null +++ b/board/palmtc/palmtc.c @@ -0,0 +1,59 @@ +/* + * Palm Tungsten|C Support + * + * Copyright (C) 2009-2010 Marek Vasut marek.vasut@gmail.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <command.h> +#include <serial.h> +#include <asm/io.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* + * Miscelaneous platform dependent initialisations + */ + +int board_init(void) +{ + /* Arch number of Palm Tungsten|C */ + gd->bd->bi_arch_number = MACH_TYPE_PALMTC; + + /* Adress of boot parameters */ + gd->bd->bi_boot_params = 0xa0000100; + + /* Set PWM for LCD */ + writel(0x5f, PWM_CTRL1); + writel(0x3ff, PWM_PERVAL1); + writel(892, PWM_PWDUTY1); + + return 0; +} + +struct serial_device *default_serial_console(void) +{ + return &serial_ffuart_device; +} + +int dram_init(void) +{ + gd->bd->bi_dram[0].start = PHYS_SDRAM_1; + gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; + return 0; +} diff --git a/board/palmtc/u-boot.lds b/board/palmtc/u-boot.lds new file mode 100644 index 0000000..fb4358b --- /dev/null +++ b/board/palmtc/u-boot.lds @@ -0,0 +1,56 @@ +/* + * (C) Copyright 2000-2005 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") +OUTPUT_ARCH(arm) +ENTRY(_start) +SECTIONS +{ + . = 0x00000000; + + . = ALIGN(4); + .text : + { + cpu/pxa/start.o (.text) + *(.text) + } + + . = ALIGN(4); + .rodata : { *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) } + + . = ALIGN(4); + .data : { *(.data) } + + . = ALIGN(4); + .got : { *(.got) } + + . = .; + __u_boot_cmd_start = .; + .u_boot_cmd : { *(.u_boot_cmd) } + __u_boot_cmd_end = .; + + . = ALIGN(4); + __bss_start = .; + .bss (NOLOAD) : { *(.bss) . = ALIGN(4); } + _end = .; +} diff --git a/boards.cfg b/boards.cfg index 9207254..60d8d0f 100644 --- a/boards.cfg +++ b/boards.cfg @@ -58,6 +58,7 @@ csb226 arm pxa delta arm pxa innokom arm pxa lubbock arm pxa +palmtc arm pxa pleb2 arm pxa xaeniax arm pxa xm250 arm pxa diff --git a/include/configs/palmtc.h b/include/configs/palmtc.h new file mode 100644 index 0000000..f4fc9cd --- /dev/null +++ b/include/configs/palmtc.h @@ -0,0 +1,245 @@ +/* + * Palm Tungsten|C configuration file + * + * Copyright (C) 2009-2010 Marek Vasut marek.vasut@gmail.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#include <asm/arch/pxa-regs.h> + +/* + * High Level Board Configuration Options + */ +#define CONFIG_PXA250 1 /* Intel PXA255 CPU */ +#define CONFIG_PALMTC 1 /* Palm Tungsten|C board */ + +/* + * Environment settings + */ +#define CONFIG_ENV_OVERWRITE +#define CONFIG_SYS_MALLOC_LEN (128*1024) +#define CONFIG_SYS_GBL_DATA_SIZE 128 + +#define CONFIG_BOOTCOMMAND \ + "if mmc init && fatload mmc 0 0xa0000000 uboot.script ; then " \ + "source 0xa0000000; " \ + "else " \ + "bootm 0x80000; " \ + "fi; " +#define CONFIG_BOOTARGS \ + "console=tty0 console=ttyS0,115200" +#define CONFIG_TIMESTAMP +#define CONFIG_BOOTDELAY 2 /* Autoboot delay */ +#define CONFIG_CMDLINE_TAG +#define CONFIG_SETUP_MEMORY_TAGS + +#define CONFIG_LZMA /* LZMA compression support */ + +/* + * Serial Console Configuration + * STUART - the lower serial port on Colibri board + */ +#define CONFIG_PXA_SERIAL +#define CONFIG_FFUART 1 +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } + +/* + * Bootloader Components Configuration + */ +#include <config_cmd_default.h> + +#undef CONFIG_CMD_NET +#define CONFIG_CMD_ENV +#define CONFIG_CMD_MMC +#define CONFIG_LCD + +/* + * MMC Card Configuration + */ +#ifdef CONFIG_CMD_MMC +#define CONFIG_MMC +#define CONFIG_PXA_MMC +#define CONFIG_SYS_MMC_BASE 0xF0000000 +#define CONFIG_CMD_FAT +#define CONFIG_CMD_EXT2 +#define CONFIG_DOS_PARTITION +#endif + +/* + * LCD + */ +#ifdef CONFIG_LCD +#define CONFIG_ACX517AKN +#define CONFIG_VIDEO_LOGO +#define CONFIG_CMD_BMP +#define CONFIG_SPLASH_SCREEN +#define CONFIG_SPLASH_SCREEN_ALIGN +#define CONFIG_VIDEO_BMP_GZIP +#define CONFIG_VIDEO_BMP_RLE8 +#define CONFIG_SYS_VIDEO_LOGO_MAX_SIZE (2 << 20) +#endif + +/* + * KGDB + */ +#ifdef CONFIG_CMD_KGDB +#define CONFIG_KGDB_BAUDRATE 230400 /* kgdb serial port speed */ +#define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ +#endif + +/* + * HUSH Shell Configuration + */ +#define CONFIG_SYS_HUSH_PARSER 1 +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " + +#define CONFIG_SYS_LONGHELP +#ifdef CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT "$ " +#else +#define CONFIG_SYS_PROMPT "=> " +#endif +#define CONFIG_SYS_CBSIZE 256 +#define CONFIG_SYS_PBSIZE \ + (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE +#define CONFIG_SYS_DEVICE_NULLDEV 1 + +/* + * Clock Configuration + */ +#undef CONFIG_SYS_CLKS_IN_HZ +#define CONFIG_SYS_HZ 3686400 /* Timer @ 3686400 Hz */ +#define CONFIG_SYS_CPUSPEED 0x161 /* 400MHz;L=1 M=3 T=1 */ + +/* + * Stack sizes + */ +#define CONFIG_STACKSIZE (128*1024) /* regular stack */ +#ifdef CONFIG_USE_IRQ +#define CONFIG_STACKSIZE_IRQ (4*1024) /* IRQ stack */ +#define CONFIG_STACKSIZE_FIQ (4*1024) /* FIQ stack */ +#endif + +/* + * DRAM Map + */ +#define CONFIG_NR_DRAM_BANKS 1 /* 1 bank of DRAM */ +#define PHYS_SDRAM_1 0xa0000000 /* SDRAM Bank #1 */ +#define PHYS_SDRAM_1_SIZE 0x04000000 /* 64 MB */ + +#define CONFIG_SYS_DRAM_BASE 0xa0000000 /* CS0 */ +#define CONFIG_SYS_DRAM_SIZE 0x04000000 /* 64 MB DRAM */ + +#define CONFIG_SYS_MEMTEST_START 0xa0400000 /* memtest works on */ +#define CONFIG_SYS_MEMTEST_END 0xa0800000 /* 4 ... 8 MB in DRAM */ + +#define CONFIG_SYS_LOAD_ADDR CONFIG_SYS_DRAM_BASE + +/* + * NOR FLASH + */ +#ifdef CONFIG_CMD_FLASH +#define PHYS_FLASH_1 0x00000000 /* Flash Bank #1 */ +#define PHYS_FLASH_SIZE 0x01000000 /* 16 MB */ +#define CONFIG_SYS_FLASH_BASE PHYS_FLASH_1 + +#define CONFIG_SYS_FLASH_CFI +#define CONFIG_FLASH_CFI_DRIVER 1 +#define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_32BIT + +#define CONFIG_SYS_MAX_FLASH_BANKS 1 +#define CONFIG_SYS_MAX_FLASH_SECT 64 + +#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE 1 + +#define CONFIG_SYS_FLASH_ERASE_TOUT (2*CONFIG_SYS_HZ) +#define CONFIG_SYS_FLASH_WRITE_TOUT (2*CONFIG_SYS_HZ) +#define CONFIG_SYS_FLASH_LOCK_TOUT (2*CONFIG_SYS_HZ) +#define CONFIG_SYS_FLASH_UNLOCK_TOUT (2*CONFIG_SYS_HZ) +#define CONFIG_SYS_FLASH_PROTECTION + +#define CONFIG_ENV_IS_IN_FLASH 1 +#define CONFIG_ENV_SECT_SIZE 0x40000 +#else +#define CONFIG_SYS_NO_FLASH +#define CONFIG_ENV_IS_NOWHERE +#endif + +#define CONFIG_SYS_MONITOR_BASE 0x0 +#define CONFIG_SYS_MONITOR_LEN 0x40000 + +#define CONFIG_ENV_SIZE 0x4000 +#define CONFIG_ENV_ADDR 0x40000 + +/* + * GPIO settings + */ +#define CONFIG_SYS_GAFR0_L_VAL 0x00011004 +#define CONFIG_SYS_GAFR0_U_VAL 0xa5000008 +#define CONFIG_SYS_GAFR1_L_VAL 0x60888050 +#define CONFIG_SYS_GAFR1_U_VAL 0xaaa50aaa +#define CONFIG_SYS_GAFR2_L_VAL 0x0aaaaaaa +#define CONFIG_SYS_GAFR2_U_VAL 0x00000000 +#define CONFIG_SYS_GPCR0_VAL 0x0 +#define CONFIG_SYS_GPCR1_VAL 0x0 +#define CONFIG_SYS_GPCR2_VAL 0x0 +#define CONFIG_SYS_GPDR0_VAL 0xcfff8140 +#define CONFIG_SYS_GPDR1_VAL 0xfcbfbef3 +#define CONFIG_SYS_GPDR2_VAL 0x0001ffff +#define CONFIG_SYS_GPSR0_VAL 0x00010f8f +#define CONFIG_SYS_GPSR1_VAL 0x00bf5de5 +#define CONFIG_SYS_GPSR2_VAL 0x03fe0800 + +#define CONFIG_SYS_PSSR_VAL PSSR_RDH + +/* Clock setup: + * CKEN[1] - PWM1 ; CKEN[6] - FFUART + * CKEN[12] - MMC ; CKEN[16] - LCD + */ +#define CONFIG_SYS_CKEN 0x00011042 +#define CONFIG_SYS_CCCR 0x00000161 + +/* + * Memory settings + */ +#define CONFIG_SYS_MSC0_VAL 0x800092c2 +#define CONFIG_SYS_MSC1_VAL 0x80008000 +#define CONFIG_SYS_MSC2_VAL 0x80008000 +#define CONFIG_SYS_MDCNFG_VAL 0x00001ac9 +#define CONFIG_SYS_MDREFR_VAL 0x00118018 +#define CONFIG_SYS_MDMRS_VAL 0x00220032 +#define CONFIG_SYS_FLYCNFG_VAL 0x01fe01fe +#define CONFIG_SYS_SXCNFG_VAL 0x00000000 + +/* + * PCMCIA and CF Interfaces + */ +#define CONFIG_SYS_MECR_VAL 0x00000000 +#define CONFIG_SYS_MCMEM0_VAL 0x00010504 +#define CONFIG_SYS_MCMEM1_VAL 0x00010504 +#define CONFIG_SYS_MCATT0_VAL 0x00010504 +#define CONFIG_SYS_MCATT1_VAL 0x00010504 +#define CONFIG_SYS_MCIO0_VAL 0x00010e04 +#define CONFIG_SYS_MCIO1_VAL 0x00010e04 + +#endif /* __CONFIG_H */
Signed-off-by: Marek Vasut marek.vasut@gmail.com --- MAINTAINERS | 1 + board/palmld/Makefile | 49 ++++++++ board/palmld/config.mk | 1 + board/palmld/lowlevel_init.S | 45 +++++++ board/palmld/palmld.c | 69 +++++++++++ board/palmld/u-boot.lds | 56 +++++++++ boards.cfg | 1 + include/configs/palmld.h | 273 ++++++++++++++++++++++++++++++++++++++++++ 8 files changed, 495 insertions(+), 0 deletions(-) create mode 100644 board/palmld/Makefile create mode 100644 board/palmld/config.mk create mode 100644 board/palmld/lowlevel_init.S create mode 100644 board/palmld/palmld.c create mode 100644 board/palmld/u-boot.lds create mode 100644 include/configs/palmld.h
diff --git a/MAINTAINERS b/MAINTAINERS index a7ee984..6571139 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -797,6 +797,7 @@ Greg Ungerer greg.ungerer@opengear.com
+ palmld xscale palmtc xscale
Hugo Villeneuve hugo.villeneuve@lyrtech.com diff --git a/board/palmld/Makefile b/board/palmld/Makefile new file mode 100644 index 0000000..bcb014d --- /dev/null +++ b/board/palmld/Makefile @@ -0,0 +1,49 @@ +# +# Palm LifeDrive Support +# +# Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS := palmld.o +SOBJS := lowlevel_init.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) $(SOBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak $(obj).depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/palmld/config.mk b/board/palmld/config.mk new file mode 100644 index 0000000..1d650ac --- /dev/null +++ b/board/palmld/config.mk @@ -0,0 +1 @@ +TEXT_BASE = 0xa1000000 diff --git a/board/palmld/lowlevel_init.S b/board/palmld/lowlevel_init.S new file mode 100644 index 0000000..e3382ee --- /dev/null +++ b/board/palmld/lowlevel_init.S @@ -0,0 +1,45 @@ +/* + * Palm LifeDrive Lowlevel Hardware Initialization + * + * Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> +#include <version.h> +#include <asm/arch/pxa-regs.h> +#include <asm/arch/macro.h> + +.globl lowlevel_init +lowlevel_init: + pxa_gpio_setup + + /* Enable GPIO reset */ + ldr r0, =PCFR + mov r1, #0x30 + str r1, [r0] + + pxa_wait_ticks 0x8000 + pxa_mem_setup + pxa_wakeup + pxa_intr_setup + pxa_clock_setup + + mov pc, lr diff --git a/board/palmld/palmld.c b/board/palmld/palmld.c new file mode 100644 index 0000000..4f0087e --- /dev/null +++ b/board/palmld/palmld.c @@ -0,0 +1,69 @@ +/* + * Palm LifeDrive Support + * + * Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <command.h> +#include <serial.h> +#include <asm/arch/pxa-regs.h> +#include <asm/io.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* + * Miscelaneous platform dependent initialisations + */ + +int board_init(void) +{ + /* arch number of Lubbock-Board */ + gd->bd->bi_arch_number = MACH_TYPE_PALMLD; + + /* adress of boot parameters */ + gd->bd->bi_boot_params = 0xa0000100; + + /* Set PWM for LCD */ + writel(0x7, PWM_CTRL0); + writel(0x16c, PWM_PERVAL0); + writel(0x11a, PWM_PWDUTY0); + + return 0; +} + +struct serial_device *default_serial_console(void) +{ + return &serial_ffuart_device; +} + +int dram_init(void) +{ + gd->bd->bi_dram[0].start = PHYS_SDRAM_1; + gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; + + return 0; +} + +ulong board_flash_get_legacy(ulong base, int banknum, flash_info_t *info) +{ + info->portwidth = FLASH_CFI_16BIT; + info->chipwidth = FLASH_CFI_BY16; + info->interface = FLASH_CFI_X16; + return 1; +} diff --git a/board/palmld/u-boot.lds b/board/palmld/u-boot.lds new file mode 100644 index 0000000..fb4358b --- /dev/null +++ b/board/palmld/u-boot.lds @@ -0,0 +1,56 @@ +/* + * (C) Copyright 2000-2005 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") +OUTPUT_ARCH(arm) +ENTRY(_start) +SECTIONS +{ + . = 0x00000000; + + . = ALIGN(4); + .text : + { + cpu/pxa/start.o (.text) + *(.text) + } + + . = ALIGN(4); + .rodata : { *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) } + + . = ALIGN(4); + .data : { *(.data) } + + . = ALIGN(4); + .got : { *(.got) } + + . = .; + __u_boot_cmd_start = .; + .u_boot_cmd : { *(.u_boot_cmd) } + __u_boot_cmd_end = .; + + . = ALIGN(4); + __bss_start = .; + .bss (NOLOAD) : { *(.bss) . = ALIGN(4); } + _end = .; +} diff --git a/boards.cfg b/boards.cfg index 60d8d0f..fc4083e 100644 --- a/boards.cfg +++ b/boards.cfg @@ -58,6 +58,7 @@ csb226 arm pxa delta arm pxa innokom arm pxa lubbock arm pxa +palmld arm pxa palmtc arm pxa pleb2 arm pxa xaeniax arm pxa diff --git a/include/configs/palmld.h b/include/configs/palmld.h new file mode 100644 index 0000000..affc116 --- /dev/null +++ b/include/configs/palmld.h @@ -0,0 +1,273 @@ +/* + * Palm LifeDrive configuration file + * + * Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* + * High Level Board Configuration Options + */ +#define CONFIG_PXA27X 1 /* Marvell PXA270 CPU */ +#define CONFIG_PALMLD 1 /* Palm LifeDrive board */ + +/* + * Environment settings + */ +#define CONFIG_ENV_OVERWRITE +#define CONFIG_SYS_MALLOC_LEN (128*1024) +#define CONFIG_SYS_GBL_DATA_SIZE 128 + +#define CONFIG_BOOTCOMMAND \ + "if mmcinfo && fatload mmc 0 0xa0000000 uboot.script ; then " \ + "source 0xa0000000; " \ + "else " \ + "bootm 0x0x60000; " \ + "fi; " +#define CONFIG_BOOTARGS "console=tty0 console=ttyS0,9600" +#define CONFIG_TIMESTAMP +#define CONFIG_BOOTDELAY 2 /* Autoboot delay */ +#define CONFIG_CMDLINE_TAG +#define CONFIG_SETUP_MEMORY_TAGS + +#define CONFIG_LZMA /* LZMA compression support */ + +/* + * Serial Console Configuration + */ +#define CONFIG_PXA_SERIAL +#define CONFIG_FFUART 1 +#define CONFIG_BAUDRATE 9600 +#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } + +/* + * Bootloader Components Configuration + */ +#include <config_cmd_default.h> + +#undef CONFIG_CMD_NET +#define CONFIG_CMD_ENV +#undef CONFIG_CMD_IMLS +#define CONFIG_CMD_MMC +#define CONFIG_CMD_IDE +#define CONFIG_LCD + +/* + * MMC Card Configuration + */ +#ifdef CONFIG_CMD_MMC +#define CONFIG_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_PXA_MMC_GENERIC +#define CONFIG_SYS_MMC_BASE 0xF0000000 +#define CONFIG_CMD_FAT +#define CONFIG_CMD_EXT2 +#define CONFIG_DOS_PARTITION +#endif + +/* + * LCD + */ +#ifdef CONFIG_LCD +#define CONFIG_LQ038J7DH53 +#define CONFIG_VIDEO_LOGO +#define CONFIG_CMD_BMP +#define CONFIG_SPLASH_SCREEN +#define CONFIG_SPLASH_SCREEN_ALIGN +#define CONFIG_VIDEO_BMP_GZIP +#define CONFIG_VIDEO_BMP_RLE8 +#define CONFIG_SYS_VIDEO_LOGO_MAX_SIZE (2 << 20) +#endif + +/* + * KGDB + */ +#ifdef CONFIG_CMD_KGDB +#define CONFIG_KGDB_BAUDRATE 230400 /* kgdb serial port speed */ +#define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ +#endif + +/* + * HUSH Shell Configuration + */ +#define CONFIG_SYS_HUSH_PARSER 1 +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " + +#define CONFIG_SYS_LONGHELP +#ifdef CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT "$ " +#else +#define CONFIG_SYS_PROMPT "=> " +#endif +#define CONFIG_SYS_CBSIZE 256 +#define CONFIG_SYS_PBSIZE \ + (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE +#define CONFIG_SYS_DEVICE_NULLDEV 1 + +/* + * Clock Configuration + */ +#undef CONFIG_SYS_CLKS_IN_HZ +#define CONFIG_SYS_HZ 3250000 /* Timer @ 3250000 Hz */ +#define CONFIG_SYS_CPUSPEED 0x210 /* 416MHz ; N=2,L=16 */ + +/* + * Stack sizes + */ +#define CONFIG_STACKSIZE (128*1024) /* regular stack */ +#ifdef CONFIG_USE_IRQ +#define CONFIG_STACKSIZE_IRQ (4*1024) /* IRQ stack */ +#define CONFIG_STACKSIZE_FIQ (4*1024) /* FIQ stack */ +#endif + +/* + * DRAM Map + */ +#define CONFIG_NR_DRAM_BANKS 1 /* 1 bank of DRAM */ +#define PHYS_SDRAM_1 0xa0000000 /* SDRAM Bank #1 */ +#define PHYS_SDRAM_1_SIZE 0x02000000 /* 32 MB */ + +#define CONFIG_SYS_DRAM_BASE 0xa0000000 /* CS0 */ +#define CONFIG_SYS_DRAM_SIZE 0x02000000 /* 32 MB DRAM */ + +#define CONFIG_SYS_MEMTEST_START 0xa0400000 /* memtest works on */ +#define CONFIG_SYS_MEMTEST_END 0xa0800000 /* 4 ... 8 MB in DRAM */ + +#define CONFIG_SYS_LOAD_ADDR CONFIG_SYS_DRAM_BASE + +/* + * NOR FLASH + */ +#ifdef CONFIG_CMD_FLASH +#define PHYS_FLASH_1 0x00000000 /* Flash Bank #1 */ +#define PHYS_FLASH_SIZE 0x00080000 /* 512 KB */ +#define CONFIG_SYS_FLASH_BASE PHYS_FLASH_1 + +#define CONFIG_SYS_FLASH_CFI +#define CONFIG_FLASH_CFI_DRIVER 1 + +#define CONFIG_FLASH_CFI_LEGACY +#define CONFIG_SYS_FLASH_LEGACY_512Kx16 + +#define CONFIG_SYS_MONITOR_BASE 0 +#define CONFIG_SYS_MONITOR_LEN 0x40000 + +#define CONFIG_SYS_MAX_FLASH_BANKS 1 +#define CONFIG_SYS_MAX_FLASH_SECT 256 + +#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE 1 + +#define CONFIG_SYS_FLASH_ERASE_TOUT (25*CONFIG_SYS_HZ) +#define CONFIG_SYS_FLASH_WRITE_TOUT (25*CONFIG_SYS_HZ) +#define CONFIG_SYS_FLASH_LOCK_TOUT (25*CONFIG_SYS_HZ) +#define CONFIG_SYS_FLASH_UNLOCK_TOUT (25*CONFIG_SYS_HZ) +#define CONFIG_SYS_FLASH_PROTECTION + +#define CONFIG_ENV_IS_IN_FLASH 1 +#define CONFIG_ENV_SECT_SIZE 0x10000 +#else +#define CONFIG_SYS_NO_FLASH +#define CONFIG_ENV_IS_NOWHERE +#endif + +#define CONFIG_ENV_ADDR 0x40000 +#define CONFIG_ENV_SIZE 0x4000 + +/* + * IDE + */ +#ifdef CONFIG_CMD_IDE +#define CONFIG_LBA48 +#undef CONFIG_IDE_LED +#undef CONFIG_IDE_RESET + +#define __io + +#define CONFIG_SYS_IDE_MAXBUS 1 +#define CONFIG_SYS_IDE_MAXDEVICE 1 + +#define CONFIG_SYS_ATA_BASE_ADDR 0x20000000 +#define CONFIG_SYS_ATA_IDE0_OFFSET 0x0 + +#define CONFIG_SYS_ATA_DATA_OFFSET 0x10 +#define CONFIG_SYS_ATA_REG_OFFSET 0x10 +#define CONFIG_SYS_ATA_ALT_OFFSET 0x10 + +#define CONFIG_SYS_ATA_STRIDE 1 +#endif + +/* + * GPIO settings + */ +#define CONFIG_SYS_GAFR0_L_VAL 0x00000000 +#define CONFIG_SYS_GAFR0_U_VAL 0xa5180012 +#define CONFIG_SYS_GAFR1_L_VAL 0x69988056 +#define CONFIG_SYS_GAFR1_U_VAL 0xaaa580aa +#define CONFIG_SYS_GAFR2_L_VAL 0x6aaaaaaa +#define CONFIG_SYS_GAFR2_U_VAL 0x01040001 +#define CONFIG_SYS_GAFR3_L_VAL 0x540a950c +#define CONFIG_SYS_GAFR3_U_VAL 0x00000009 +#define CONFIG_SYS_GPCR0_VAL 0x00000000 +#define CONFIG_SYS_GPCR1_VAL 0x00000000 +#define CONFIG_SYS_GPCR2_VAL 0x00000000 +#define CONFIG_SYS_GPCR3_VAL 0x00000000 +#define CONFIG_SYS_GPDR0_VAL 0xc26b0000 +#define CONFIG_SYS_GPDR1_VAL 0xfcdfaa93 +#define CONFIG_SYS_GPDR2_VAL 0x7bbaffff +#define CONFIG_SYS_GPDR3_VAL 0x006ff38d +#define CONFIG_SYS_GPSR0_VAL 0x0d9e45ee +#define CONFIG_SYS_GPSR1_VAL 0x03affdae +#define CONFIG_SYS_GPSR2_VAL 0x07554000 +#define CONFIG_SYS_GPSR3_VAL 0x01bc0785 + +#define CONFIG_SYS_PSSR_VAL 0x30 + +/* + * Clock settings + */ +#define CONFIG_SYS_CKEN 0x01ffffff +#define CONFIG_SYS_CCCR 0x02000210 + +/* + * Memory settings + */ +#define CONFIG_SYS_MSC0_VAL 0x7ff844c8 +#define CONFIG_SYS_MSC1_VAL 0x7ff86ab4 +#define CONFIG_SYS_MSC2_VAL 0x7ff87ff8 +#define CONFIG_SYS_MDCNFG_VAL 0x0B880acd +#define CONFIG_SYS_MDREFR_VAL 0x201fa031 +#define CONFIG_SYS_MDMRS_VAL 0x00320032 +#define CONFIG_SYS_FLYCNFG_VAL 0x00000000 +#define CONFIG_SYS_SXCNFG_VAL 0x40044004 + +/* + * PCMCIA and CF Interfaces + */ +#define CONFIG_SYS_MECR_VAL 0x00000003 +#define CONFIG_SYS_MCMEM0_VAL 0x0001c391 +#define CONFIG_SYS_MCMEM1_VAL 0x0001c391 +#define CONFIG_SYS_MCATT0_VAL 0x0001c391 +#define CONFIG_SYS_MCATT1_VAL 0x0001c391 +#define CONFIG_SYS_MCIO0_VAL 0x00014611 +#define CONFIG_SYS_MCIO1_VAL 0x0001c391 + +#endif /* __CONFIG_H */
128MB NOR module support. Define __io to get harddrive working. Fix saving of environment into OneNAND. Boot from harddrive when possible. Add missing MAINTAINERS entry.
Signed-off-by: Marek Vasut marek.vasut@gmail.com --- MAINTAINERS | 1 + MAKEALL | 3 +- Makefile | 7 ++- board/vpac270/Makefile | 7 +-- board/vpac270/lowlevel_init.S | 1 - board/vpac270/vpac270.c | 44 ++++++----------- include/configs/vpac270.h | 106 +++++++++++++++++++++++----------------- 7 files changed, 88 insertions(+), 81 deletions(-)
diff --git a/MAINTAINERS b/MAINTAINERS index 6571139..f7e2027 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -799,6 +799,7 @@ Marek Vasut marek.vasut@gmail.com
palmld xscale palmtc xscale + vpac270 xscale
diff --git a/MAKEALL b/MAKEALL index 1b506d6..9dd3636 100755 --- a/MAKEALL +++ b/MAKEALL @@ -546,7 +546,8 @@ LIST_at91=" \ LIST_pxa="$(boards_by_cpu pxa) polaris \ trizepsiv \ - vpac270_nor \ + vpac270_nor_128M\ + vpac270_nor_256M\ vpac270_onenand \ "
diff --git a/Makefile b/Makefile index 000ad56..0d2d34a 100644 --- a/Makefile +++ b/Makefile @@ -1020,13 +1020,18 @@ trizepsiv_config : unconfig fi; @$(MKCONFIG) -n $@ -a trizepsiv arm pxa trizepsiv
-vpac270_nor_config \ +vpac270_nor_256M_config \ +vpac270_nor_128M_config \ vpac270_onenand_config : unconfig @mkdir -p $(obj)include @if [ "$(findstring onenand,$@)" ] ; then \ echo "#define CONFIG_ONENAND_U_BOOT" \ >>$(obj)include/config.h ; \ fi; + @if [ "$(findstring 256M,$@)" ] ; then \ + echo "#define CONFIG_256M_U_BOOT" \ + >>$(obj)include/config.h ; \ + fi; @$(MKCONFIG) -n $@ -a vpac270 arm pxa vpac270
######################################################################### diff --git a/board/vpac270/Makefile b/board/vpac270/Makefile index c6f4c7c..f5014fc 100644 --- a/board/vpac270/Makefile +++ b/board/vpac270/Makefile @@ -1,10 +1,7 @@ - # -# (C) Copyright 2000 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# Voipac PXA270 Support # -# See file CREDITS for list of people who contributed to this -# project. +# Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com # # This program is free software; you can redistribute it and/or # modify it under the terms of the GNU General Public License as diff --git a/board/vpac270/lowlevel_init.S b/board/vpac270/lowlevel_init.S index ec0d12c..c40d12f 100644 --- a/board/vpac270/lowlevel_init.S +++ b/board/vpac270/lowlevel_init.S @@ -3,7 +3,6 @@ * * Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com * - * * See file CREDITS for list of people who contributed to this * project. * diff --git a/board/vpac270/vpac270.c b/board/vpac270/vpac270.c index f792298..1557d1b 100644 --- a/board/vpac270/vpac270.c +++ b/board/vpac270/vpac270.c @@ -1,16 +1,7 @@ /* - * (C) Copyright 2004 - * Robert Whaley, Applied Data Systems, Inc. rwhaley@applieddata.net + * Voipac PXA270 Support * - * (C) Copyright 2002 - * Kyle Harris, Nexus Technologies, Inc. kharris@nexus-tech.net - * - * (C) Copyright 2002 - * Sysgo Real-Time Solutions, GmbH <www.elinos.com> - * Marius Groeger mgroeger@sysgo.de - * - * See file CREDITS for list of people who contributed to this - * project. + * Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com * * This program is free software; you can redistribute it and/or * modify it under the terms of the GNU General Public License as @@ -36,26 +27,15 @@
-/* ------------------------------------------------------------------------- */ - /* * Miscelaneous platform dependent initialisations */ -extern struct serial_device serial_ffuart_device; -extern struct serial_device serial_btuart_device; -extern struct serial_device serial_stuart_device; - -struct serial_device *default_serial_console (void) -{ - return &serial_ffuart_device; -} - -int board_init (void) +int board_init(void) { /* memory and cpu-speed are setup before relocation */ /* so we do _nothing_ here */
- /* arch number of vpac270 */ + /* Arch number of vpac270 */ gd->bd->bi_arch_number = MACH_TYPE_VPAC270;
/* adress of boot parameters */ @@ -64,17 +44,24 @@ int board_init (void) return 0; }
-int dram_init (void) +struct serial_device *default_serial_console(void) { - gd->bd->bi_dram[0].start = PHYS_SDRAM_1; - gd->bd->bi_dram[1].start = PHYS_SDRAM_2; + return &serial_ffuart_device; +}
+int dram_init(void) +{ + gd->bd->bi_dram[0].start = PHYS_SDRAM_1; gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; - gd->bd->bi_dram[1].size = PHYS_SDRAM_2_SIZE;
+#ifdef CONFIG_256M_U_BOOT + gd->bd->bi_dram[1].start = PHYS_SDRAM_2; + gd->bd->bi_dram[1].size = PHYS_SDRAM_2_SIZE; +#endif return 0; }
+#ifdef CONFIG_CMD_USB int usb_board_init(void) { writel((UHCHR | UHCHR_PCPL | UHCHR_PSPL) & @@ -124,6 +111,7 @@ void usb_board_stop(void)
return; } +#endif
#ifdef CONFIG_DRIVER_DM9000 int board_eth_init(bd_t *bis) diff --git a/include/configs/vpac270.h b/include/configs/vpac270.h index d3e22d9..694a8f9 100644 --- a/include/configs/vpac270.h +++ b/include/configs/vpac270.h @@ -10,7 +10,7 @@ * * This program is distributed in the hope that it will be useful, * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the * GNU General Public License for more details. * * You should have received a copy of the GNU General Public License @@ -19,8 +19,8 @@ * MA 02111-1307 USA */
-#ifndef __CONFIG_H -#define __CONFIG_H +#ifndef __CONFIG_H +#define __CONFIG_H
/* * High Level Board Configuration Options @@ -28,20 +28,13 @@ #define CONFIG_PXA27X 1 /* Marvell PXA270 CPU */ #define CONFIG_VPAC270 1 /* Voipac PXA270 board */
-#undef BOARD_LATE_INIT -#undef CONFIG_SKIP_RELOCATE_UBOOT -#undef CONFIG_USE_IRQ -#undef CONFIG_SKIP_LOWLEVEL_INIT - /* * Environment settings */ -#define CONFIG_ENV_SIZE 0x4000 -#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024) +#define CONFIG_ENV_OVERWRITE +#define CONFIG_SYS_MALLOC_LEN (128*1024) #define CONFIG_SYS_GBL_DATA_SIZE 128
-#define CONFIG_ENV_OVERWRITE /* override default environment */ - #define CONFIG_BOOTCOMMAND \ "if mmc init && fatload mmc 0 0xa4000000 uImage; then " \ "bootm 0xa4000000; " \ @@ -49,6 +42,9 @@ "if usb reset && fatload usb 0 0xa4000000 uImage; then " \ "bootm 0xa4000000; " \ "fi; " \ + "if ide reset && fatload ide 0 0xa4000000 uImage; then " \ + "bootm 0xa4000000; " \ + "fi; " \ "bootm 0x40000;" #define CONFIG_BOOTARGS "console=tty0 console=ttyS0,115200" #define CONFIG_TIMESTAMP @@ -97,9 +93,9 @@
#define CONFIG_NET_MULTI 1 #define CONFIG_DRIVER_DM9000 1 -#define CONFIG_DM9000_BASE 0x08000300 /* CS2 */ -#define DM9000_IO (CONFIG_DM9000_BASE) -#define DM9000_DATA (CONFIG_DM9000_BASE + 4) +#define CONFIG_DM9000_BASE 0x08000300 /* CS2 */ +#define DM9000_IO (CONFIG_DM9000_BASE) +#define DM9000_DATA (CONFIG_DM9000_BASE + 4) #define CONFIG_NET_RETRY_COUNT 10
#define CONFIG_BOOTP_BOOTFILESIZE @@ -116,6 +112,7 @@ #define CONFIG_PXA_MMC #define CONFIG_SYS_MMC_BASE 0xF0000000 #define CONFIG_CMD_FAT +#define CONFIG_CMD_EXT2 #define CONFIG_DOS_PARTITION #endif
@@ -123,8 +120,8 @@ * KGDB */ #ifdef CONFIG_CMD_KGDB -#define CONFIG_KGDB_BAUDRATE 230400 /* speed to run kgdb serial port */ -#define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ +#define CONFIG_KGDB_BAUDRATE 230400 /* kgdb serial port speed */ +#define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ #endif
/* @@ -133,16 +130,17 @@ #define CONFIG_SYS_HUSH_PARSER 1 #define CONFIG_SYS_PROMPT_HUSH_PS2 "> "
-#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_SYS_LONGHELP #ifdef CONFIG_SYS_HUSH_PARSER -#define CONFIG_SYS_PROMPT "$ " /* Monitor Command Prompt */ +#define CONFIG_SYS_PROMPT "$ " #else -#define CONFIG_SYS_PROMPT "=> " /* Monitor Command Prompt */ +#define CONFIG_SYS_PROMPT "=> " #endif -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ +#define CONFIG_SYS_CBSIZE 256 +#define CONFIG_SYS_PBSIZE \ + (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE #define CONFIG_SYS_DEVICE_NULLDEV 1
/* @@ -150,12 +148,10 @@ */ #undef CONFIG_SYS_CLKS_IN_HZ #define CONFIG_SYS_HZ 3250000 /* Timer @ 3250000 Hz */ -#define CONFIG_SYS_CPUSPEED 0x190 /* standard setting for 312MHz; L=16, N=1.5, A=0, SDCLK!=SystemBus */ +#define CONFIG_SYS_CPUSPEED 0x190 /* 312MHz */
/* * Stack sizes - * - * The stack sizes are set up in start.S using the settings below */ #define CONFIG_STACKSIZE (128*1024) /* regular stack */ #ifdef CONFIG_USE_IRQ @@ -166,17 +162,24 @@ /* * DRAM Map */ -#define CONFIG_NR_DRAM_BANKS 2 /* We have 2 banks of DRAM */ +#define CONFIG_NR_DRAM_BANKS 2 /* 2 banks of DRAM */ #define PHYS_SDRAM_1 0xa0000000 /* SDRAM Bank #1 */ #define PHYS_SDRAM_1_SIZE 0x08000000 /* 128 MB */ + +#ifdef CONFIG_256M_U_BOOT #define PHYS_SDRAM_2 0x80000000 /* SDRAM Bank #2 */ #define PHYS_SDRAM_2_SIZE 0x08000000 /* 128 MB */ +#endif
#define CONFIG_SYS_DRAM_BASE 0xa0000000 /* CS0 */ +#ifdef CONFIG_256M_U_BOOT #define CONFIG_SYS_DRAM_SIZE 0x10000000 /* 256 MB DRAM */ +#else +#define CONFIG_SYS_DRAM_SIZE 0x08000000 /* 128 MB DRAM */ +#endif
-#define CONFIG_SYS_MEMTEST_START 0xa0400000 /* memtest works on */ -#define CONFIG_SYS_MEMTEST_END 0xa0800000 /* 4 ... 8 MB in DRAM */ +#define CONFIG_SYS_MEMTEST_START 0xa0400000 /* memtest works on */ +#define CONFIG_SYS_MEMTEST_END 0xa0800000 /* 4 ... 8 MB in DRAM */
#define CONFIG_SYS_LOAD_ADDR (0x5c000000)
@@ -185,14 +188,22 @@ */ #if defined(CONFIG_CMD_FLASH) /* NOR */ #define PHYS_FLASH_1 0x00000000 /* Flash Bank #1 */ + +#ifdef CONFIG_256M_U_BOOT #define PHYS_FLASH_2 0x02000000 /* Flash Bank #2 */ +#endif
#define CONFIG_SYS_FLASH_CFI #define CONFIG_FLASH_CFI_DRIVER 1
#define CONFIG_SYS_MAX_FLASH_SECT (4 + 255) +#ifdef CONFIG_256M_U_BOOT #define CONFIG_SYS_MAX_FLASH_BANKS 2 #define CONFIG_SYS_FLASH_BANKS_LIST { PHYS_FLASH_1, PHYS_FLASH_2 } +#else +#define CONFIG_SYS_MAX_FLASH_BANKS 1 +#define CONFIG_SYS_FLASH_BASE PHYS_FLASH_1 +#endif
#define CONFIG_SYS_FLASH_ERASE_TOUT (25*CONFIG_SYS_HZ) #define CONFIG_SYS_FLASH_WRITE_TOUT (25*CONFIG_SYS_HZ) @@ -200,25 +211,26 @@ #define CONFIG_SYS_FLASH_USE_BUFFER_WRITE 1 #define CONFIG_SYS_FLASH_PROTECTION 1
-#define CONFIG_ENV_IS_IN_FLASH 1 +#define CONFIG_ENV_IS_IN_FLASH 1 +#define CONFIG_ENV_SECT_SIZE 0x4000
#elif defined(CONFIG_CMD_ONENAND) /* OneNAND */ #define CONFIG_SYS_NO_FLASH #define CONFIG_SYS_ONENAND_BASE 0x00000000 + #define CONFIG_ENV_IS_IN_ONENAND 1 +#define CONFIG_ENV_SECT_SIZE 0x20000
#else /* No flash */ #define CONFIG_SYS_NO_FLASH #define CONFIG_SYS_ENV_IS_NOWHERE #endif
-#define CONFIG_SYS_MONITOR_BASE 0x000000 +#define CONFIG_SYS_MONITOR_BASE 0x0 #define CONFIG_SYS_MONITOR_LEN 0x40000
-#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_LEN) -#define CONFIG_ENV_SECT_SIZE 0x40000 -#define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR + CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SIZE) +#define CONFIG_ENV_ADDR 0x40000 +#define CONFIG_ENV_SIZE 0x4000
/* * IDE @@ -230,15 +242,15 @@
#define __io
-#define CONFIG_SYS_IDE_MAXBUS 1 -#define CONFIG_SYS_IDE_MAXDEVICE 1 +#define CONFIG_SYS_IDE_MAXBUS 1 +#define CONFIG_SYS_IDE_MAXDEVICE 1
-#define CONFIG_SYS_ATA_BASE_ADDR 0x0c000000 -#define CONFIG_SYS_ATA_IDE0_OFFSET 0x0 +#define CONFIG_SYS_ATA_BASE_ADDR 0x0c000000 +#define CONFIG_SYS_ATA_IDE0_OFFSET 0x0
-#define CONFIG_SYS_ATA_DATA_OFFSET 0x120 -#define CONFIG_SYS_ATA_REG_OFFSET 0x120 -#define CONFIG_SYS_ATA_ALT_OFFSET 0x120 +#define CONFIG_SYS_ATA_DATA_OFFSET 0x120 +#define CONFIG_SYS_ATA_REG_OFFSET 0x120 +#define CONFIG_SYS_ATA_ALT_OFFSET 0x120
#define CONFIG_SYS_ATA_STRIDE 2 #endif @@ -284,7 +296,11 @@ #define CONFIG_SYS_MSC0_VAL 0x3ffc95fa #define CONFIG_SYS_MSC1_VAL 0x02ccf974 #define CONFIG_SYS_MSC2_VAL 0x00000000 +#ifdef CONFIG_256M_U_BOOT #define CONFIG_SYS_MDCNFG_VAL 0x8ad30ad3 +#else +#define CONFIG_SYS_MDCNFG_VAL 0x88000ad3 +#endif #define CONFIG_SYS_MDREFR_VAL 0x201fe01e #define CONFIG_SYS_MDMRS_VAL 0x00000000 #define CONFIG_SYS_FLYCNFG_VAL 0x00000000 @@ -306,13 +322,13 @@ * LCD */ #ifdef CONFIG_LCD -#define CONFIG_VOIPAC_LCD +#define CONFIG_VOIPAC_LCD #endif
/* * USB */ -#ifdef CONFIG_CMD_USB +#ifdef CONFIG_CMD_USB #define CONFIG_USB_OHCI_NEW #define CONFIG_SYS_USB_OHCI_CPU_INIT #define CONFIG_SYS_USB_OHCI_BOARD_INIT
Dear Marek Vasut,
In message 1287257810-23609-10-git-send-email-marek.vasut@gmail.com you wrote:
- @if [ "$(findstring 256M,$@)" ] ; then \
- fi; @$(MKCONFIG) -n $@ -a vpac270 arm pxa vpac270
As discussed before: please don't. Use the new options column in boards.cfg that was added for this very purpose by your own patch.
While doing that, you might want to rebase (as discussed in private communication) against the Makefile-cleanup branch. Basicly this means:
- Rename "TEXT_BASE" into "CONFIG_SYS_TEXT_BASE" - Move the definition of CONFIG_SYS_TEXT_BASE from board/*/config.mk to include/configs/*.h - Remove the (now empty) board/*/config.mk files.
[Note: this applies to the other patches as well.]
The following hardware is currently supported: - UART - USB Host - FPGA
Signed-off-by: Marek Vasut marek.vasut@gmail.com --- MAINTAINERS | 1 + board/balloon3/Makefile | 49 +++++++ board/balloon3/balloon3.c | 228 ++++++++++++++++++++++++++++++++++ board/balloon3/config.mk | 1 + board/balloon3/lowlevel_init.S | 36 ++++++ board/balloon3/u-boot.lds | 55 ++++++++ boards.cfg | 1 + include/configs/balloon3.h | 269 ++++++++++++++++++++++++++++++++++++++++ 8 files changed, 640 insertions(+), 0 deletions(-) create mode 100644 board/balloon3/Makefile create mode 100644 board/balloon3/balloon3.c create mode 100644 board/balloon3/config.mk create mode 100644 board/balloon3/lowlevel_init.S create mode 100644 board/balloon3/u-boot.lds create mode 100644 include/configs/balloon3.h
diff --git a/MAINTAINERS b/MAINTAINERS index f7e2027..7aa4e4b 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -797,6 +797,7 @@ Greg Ungerer greg.ungerer@opengear.com
+ balloon3 xscale palmld xscale palmtc xscale vpac270 xscale diff --git a/board/balloon3/Makefile b/board/balloon3/Makefile new file mode 100644 index 0000000..3928e1f --- /dev/null +++ b/board/balloon3/Makefile @@ -0,0 +1,49 @@ +# +# Balloon3 Support +# +# Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS := balloon3.o +SOBJS := lowlevel_init.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) $(SOBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak $(obj).depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/balloon3/balloon3.c b/board/balloon3/balloon3.c new file mode 100644 index 0000000..2d6eabe --- /dev/null +++ b/board/balloon3/balloon3.c @@ -0,0 +1,228 @@ +/* + * Balloon3 Support + * + * Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/arch/hardware.h> +#include <serial.h> +#include <asm/io.h> +#include <spartan3.h> +#include <command.h> + +DECLARE_GLOBAL_DATA_PTR; + +void balloon3_init_fpga(void); + +/* + * Miscelaneous platform dependent initialisations + */ + +int board_init(void) +{ + /* arch number of vpac270 */ + gd->bd->bi_arch_number = MACH_TYPE_BALLOON3; + + /* adress of boot parameters */ + gd->bd->bi_boot_params = 0xa0000100; + + /* Init the FPGA */ + balloon3_init_fpga(); + + return 0; +} + +struct serial_device *default_serial_console(void) +{ + return &serial_stuart_device; +} + +int dram_init(void) +{ + gd->bd->bi_dram[0].start = PHYS_SDRAM_1; + gd->bd->bi_dram[1].start = PHYS_SDRAM_2; + gd->bd->bi_dram[2].start = PHYS_SDRAM_3; + + gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; + gd->bd->bi_dram[1].size = PHYS_SDRAM_2_SIZE; + gd->bd->bi_dram[2].size = PHYS_SDRAM_3_SIZE; + + return 0; +} + +#ifdef CONFIG_CMD_USB +int usb_board_init(void) +{ + writel((readl(UHCHR) | UHCHR_PCPL | UHCHR_PSPL) & + ~(UHCHR_SSEP0 | UHCHR_SSEP1 | UHCHR_SSEP2 | UHCHR_SSE), + UHCHR); + + writel(readl(UHCHR) | UHCHR_FSBIR, UHCHR); + + while (readl(UHCHR) & UHCHR_FSBIR) + ; + + writel(readl(UHCHR) & ~UHCHR_SSE, UHCHR); + writel((UHCHIE_UPRIE | UHCHIE_RWIE), UHCHIE); + + /* Clear any OTG Pin Hold */ + if (readl(PSSR) & PSSR_OTGPH) + writel(readl(PSSR) | PSSR_OTGPH, PSSR); + + writel(readl(UHCRHDA) & ~(0x200), UHCRHDA); + writel(readl(UHCRHDA) | 0x100, UHCRHDA); + + /* Set port power control mask bits, only 3 ports. */ + writel(readl(UHCRHDB) | (0x7<<17), UHCRHDB); + + /* enable port 2 */ + writel(readl(UP2OCR) | UP2OCR_HXOE | UP2OCR_HXS | + UP2OCR_DMPDE | UP2OCR_DPPDE, UP2OCR); + + return 0; +} + +void usb_board_init_fail(void) +{ + return; +} + +void usb_board_stop(void) +{ + writel(readl(UHCHR) | UHCHR_FHR, UHCHR); + udelay(11); + writel(readl(UHCHR) & ~UHCHR_FHR, UHCHR); + + writel(readl(UHCCOMS) | 1, UHCCOMS); + udelay(10); + + writel(readl(CKEN) & ~CKEN10_USBHOST, CKEN); + + return; +} +#endif + +#if defined(CONFIG_FPGA) +/* Toggle GPIO103 and GPIO104 -- PROGB and RDnWR */ +int fpga_pgm_fn(int nassert, int nflush, int cookie) +{ + if (nassert) + writel(0x80, GPCR3); + else + writel(0x80, GPSR3); + if (nflush) + writel(0x100, GPCR3); + else + writel(0x100, GPSR3); + return nassert; +} + +/* Check GPIO83 -- INITB */ +int fpga_init_fn(int cookie) +{ + return !(readl(GPLR2) & 0x80000); +} + +/* Check GPIO84 -- BUSY */ +int fpga_busy_fn(int cookie) +{ + return !(readl(GPLR2) & 0x100000); +} + +/* Check GPIO111 -- DONE */ +int fpga_done_fn(int cookie) +{ + return readl(GPLR3) & 0x8000; +} + +/* Configure GPIO104 as GPIO and deassert it */ +int fpga_pre_config_fn(int cookie) +{ + writel(readl(GAFR3_L) & ~0x30000, GAFR3_L); + writel(0x100, GPCR3); + return 0; +} + +/* Configure GPIO104 as nSKTSEL */ +int fpga_post_config_fn(int cookie) +{ + writel(readl(GAFR3_L) | 0x10000, GAFR3_L); + return 0; +} + +/* Toggle RDnWR */ +int fpga_wr_fn(int nassert_write, int flush, int cookie) +{ + udelay(1000); + + if (nassert_write) + writel(0x100, GPCR3); + else + writel(0x100, GPSR3); + + return nassert_write; +} + +/* Write program to the FPGA */ +int fpga_wdata_fn(uchar data, int flush, int cookie) +{ + writeb(data, 0x10f00000); + return 0; +} + +/* Toggle Clock pin -- NO-OP */ +int fpga_clk_fn(int assert_clk, int flush, int cookie) +{ + return assert_clk; +} + +/* Toggle ChipSelect pin -- NO-OP */ +int fpga_cs_fn(int assert_clk, int flush, int cookie) +{ + return assert_clk; +} + +Xilinx_Spartan3_Slave_Parallel_fns balloon3_fpga_fns = { + fpga_pre_config_fn, + fpga_pgm_fn, + fpga_init_fn, + NULL, /* err */ + fpga_done_fn, + fpga_clk_fn, + fpga_cs_fn, + fpga_wr_fn, + NULL, /* rdata */ + fpga_wdata_fn, + fpga_busy_fn, + NULL, /* abort */ + fpga_post_config_fn, +}; + +Xilinx_desc fpga = XILINX_XC3S1000_DESC(slave_parallel, + (void *)&balloon3_fpga_fns, 0); + +/* Initialize the FPGA */ +void balloon3_init_fpga(void) +{ + fpga_init(); + fpga_add(fpga_xilinx, &fpga); +} +#else +void balloon3_init_fpga(void) {} +#endif /* CONFIG_FPGA */ diff --git a/board/balloon3/config.mk b/board/balloon3/config.mk new file mode 100644 index 0000000..1d650ac --- /dev/null +++ b/board/balloon3/config.mk @@ -0,0 +1 @@ +TEXT_BASE = 0xa1000000 diff --git a/board/balloon3/lowlevel_init.S b/board/balloon3/lowlevel_init.S new file mode 100644 index 0000000..d7b5be6 --- /dev/null +++ b/board/balloon3/lowlevel_init.S @@ -0,0 +1,36 @@ +/* + * Balloon3 Lowlevel Hardware Initialization + * + * Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> +#include <version.h> +#include <asm/arch/pxa-regs.h> +#include <asm/arch/macro.h> + +.globl lowlevel_init +lowlevel_init: + pxa_gpio_setup + pxa_wait_ticks 0x8000 + pxa_mem_setup + pxa_wakeup + pxa_intr_setup + pxa_clock_setup + + mov pc, lr diff --git a/board/balloon3/u-boot.lds b/board/balloon3/u-boot.lds new file mode 100644 index 0000000..58c371d --- /dev/null +++ b/board/balloon3/u-boot.lds @@ -0,0 +1,55 @@ +/* + * (C) Copyright 2000 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") +OUTPUT_ARCH(arm) +ENTRY(_start) +SECTIONS +{ + . = 0x00000000; + + . = ALIGN(4); + .text : + { + cpu/pxa/start.o (.text) + *(.text) + } + + . = ALIGN(4); + .rodata : { *(.rodata) } + + . = ALIGN(4); + .data : { *(.data) } + + . = ALIGN(4); + .got : { *(.got) } + + __u_boot_cmd_start = .; + .u_boot_cmd : { *(.u_boot_cmd) } + __u_boot_cmd_end = .; + + . = ALIGN(4); + __bss_start = .; + .bss : { *(.bss) } + _end = .; +} diff --git a/boards.cfg b/boards.cfg index fc4083e..8d97117 100644 --- a/boards.cfg +++ b/boards.cfg @@ -52,6 +52,7 @@ actux2 arm ixp actux3 arm ixp actux4 arm ixp ixdp425 arm ixp +balloon3 arm pxa cerf250 arm pxa cradle arm pxa csb226 arm pxa diff --git a/include/configs/balloon3.h b/include/configs/balloon3.h new file mode 100644 index 0000000..9066a24 --- /dev/null +++ b/include/configs/balloon3.h @@ -0,0 +1,269 @@ +/* + * Balloon3 configuration file + * + * Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* + * High Level Board Configuration Options + */ +#define CONFIG_PXA27X 1 /* Marvell PXA270 CPU */ +#define CONFIG_BALLOON3 1 /* Balloon3 board */ + +/* + * Environment settings + */ +#define CONFIG_ENV_OVERWRITE +#define CONFIG_SYS_MALLOC_LEN (128*1024) +#define CONFIG_SYS_GBL_DATA_SIZE 128 + +#define CONFIG_BOOTCOMMAND \ + "if usb reset && fatload usb 0 0xa4000000 uImage; then " \ + "bootm 0xa4000000; " \ + "fi; " \ + "bootm 0x40000;" +#define CONFIG_BOOTARGS "console=tty0 console=ttyS2,115200" +#define CONFIG_TIMESTAMP +#define CONFIG_BOOTDELAY 2 /* Autoboot delay */ +#define CONFIG_CMDLINE_TAG +#define CONFIG_SETUP_MEMORY_TAGS + +#define CONFIG_LZMA /* LZMA compression support */ + +/* + * Serial Console Configuration + */ +#define CONFIG_PXA_SERIAL +#define CONFIG_STUART 1 +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } + +/* + * Bootloader Components Configuration + */ +#include <config_cmd_default.h> + +#undef CONFIG_CMD_NET +#undef CONFIG_CMD_ENV +#undef CONFIG_CMD_IMLS +#define CONFIG_CMD_USB +#define CONFIG_CMD_FPGA +#undef CONFIG_LCD + +/* + * KGDB + */ +#ifdef CONFIG_CMD_KGDB +#define CONFIG_KGDB_BAUDRATE 230400 /* kgdb serial port speed */ +#define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ +#endif + +/* + * HUSH Shell Configuration + */ +#define CONFIG_SYS_HUSH_PARSER 1 +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " + +#define CONFIG_SYS_LONGHELP +#ifdef CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT "$ " +#else +#define CONFIG_SYS_PROMPT "=> " +#endif +#define CONFIG_SYS_CBSIZE 256 +#define CONFIG_SYS_PBSIZE \ + (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE +#define CONFIG_SYS_DEVICE_NULLDEV 1 + +/* + * Clock Configuration + */ +#undef CONFIG_SYS_CLKS_IN_HZ +#define CONFIG_SYS_HZ 3250000 /* Timer @ 3250000 Hz */ +#define CONFIG_SYS_CPUSPEED 0x290 /* 520MHz */ + +/* + * Stack sizes + */ +#define CONFIG_STACKSIZE (128*1024) /* regular stack */ +#ifdef CONFIG_USE_IRQ +#define CONFIG_STACKSIZE_IRQ (4*1024) /* IRQ stack */ +#define CONFIG_STACKSIZE_FIQ (4*1024) /* FIQ stack */ +#endif + +/* + * DRAM Map + */ +#define CONFIG_NR_DRAM_BANKS 3 /* 2 banks of DRAM */ +#define PHYS_SDRAM_1 0xa0000000 /* SDRAM Bank #1 */ +#define PHYS_SDRAM_1_SIZE 0x08000000 /* 128 MB */ +#define PHYS_SDRAM_2 0xb0000000 /* SDRAM Bank #2 */ +#define PHYS_SDRAM_2_SIZE 0x08000000 /* 128 MB */ +#define PHYS_SDRAM_3 0x80000000 /* SDRAM Bank #2 */ +#define PHYS_SDRAM_3_SIZE 0x08000000 /* 128 MB */ + +#define CONFIG_SYS_DRAM_BASE 0xa0000000 /* CS0 */ +#define CONFIG_SYS_DRAM_SIZE 0x18000000 /* 384 MB DRAM */ + +#define CONFIG_SYS_MEMTEST_START 0xa0400000 /* memtest works on */ +#define CONFIG_SYS_MEMTEST_END 0xa0800000 /* 4 ... 8 MB in DRAM */ + +#define CONFIG_SYS_LOAD_ADDR 0xa1000000 + +/* + * NOR FLASH + */ +#ifdef CONFIG_CMD_FLASH +#define PHYS_FLASH_1 0x00000000 /* Flash Bank #1 */ +#define PHYS_FLASH_SIZE 0x00800000 /* 8 MB */ +#define CONFIG_SYS_FLASH_BASE PHYS_FLASH_1 + +#define CONFIG_SYS_FLASH_CFI +#define CONFIG_FLASH_CFI_DRIVER 1 +#define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_16BIT + +#define CONFIG_SYS_MAX_FLASH_BANKS 1 +#define CONFIG_SYS_MAX_FLASH_SECT 256 + +#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE 1 + +#define CONFIG_SYS_FLASH_ERASE_TOUT (2*CONFIG_SYS_HZ) +#define CONFIG_SYS_FLASH_WRITE_TOUT (2*CONFIG_SYS_HZ) +#define CONFIG_SYS_FLASH_LOCK_TOUT (2*CONFIG_SYS_HZ) +#define CONFIG_SYS_FLASH_UNLOCK_TOUT (2*CONFIG_SYS_HZ) +#define CONFIG_SYS_FLASH_PROTECTION +#define CONFIG_ENV_IS_IN_FLASH +#else +#define CONFIG_SYS_NO_FLASH +#define CONFIG_SYS_ENV_IS_NOWHERE +#endif + +#define CONFIG_SYS_MONITOR_BASE 0x000000 +#define CONFIG_SYS_MONITOR_LEN 0x40000 + +#define CONFIG_ENV_SIZE 0x2000 +#define CONFIG_ENV_ADDR 0x40000 +#define CONFIG_ENV_SECT_SIZE 0x10000 + +/* + * GPIO settings + */ +#define CONFIG_SYS_GPSR0_VAL 0x307dc7fd +#define CONFIG_SYS_GPSR1_VAL 0x03cffa4e +#define CONFIG_SYS_GPSR2_VAL 0x7131c000 +#define CONFIG_SYS_GPSR3_VAL 0x01e1f3ff + +#define CONFIG_SYS_GPCR0_VAL 0x0 +#define CONFIG_SYS_GPCR1_VAL 0x0 +#define CONFIG_SYS_GPCR2_VAL 0x0 +#define CONFIG_SYS_GPCR3_VAL 0x0 + +#define CONFIG_SYS_GPDR0_VAL 0xc0f98e02 +#define CONFIG_SYS_GPDR1_VAL 0xfcffa8b7 +#define CONFIG_SYS_GPDR2_VAL 0x22e3ffff +#define CONFIG_SYS_GPDR3_VAL 0x000201fe + +#define CONFIG_SYS_GAFR0_L_VAL 0x96c00000 +#define CONFIG_SYS_GAFR0_U_VAL 0xa5e5459b +#define CONFIG_SYS_GAFR1_L_VAL 0x699b759a +#define CONFIG_SYS_GAFR1_U_VAL 0xaaa5a5aa +#define CONFIG_SYS_GAFR2_L_VAL 0xaaaaaaaa +#define CONFIG_SYS_GAFR2_U_VAL 0x01f9a6aa +#define CONFIG_SYS_GAFR3_L_VAL 0x54510003 +#define CONFIG_SYS_GAFR3_U_VAL 0x00001599 + +#define CONFIG_SYS_PSSR_VAL 0x30 + +/* + * Clock settings + */ +#define CONFIG_SYS_CKEN 0xffffffff +#define CONFIG_SYS_CCCR 0x00000290 + +/* + * Memory settings + */ +#define CONFIG_SYS_MSC0_VAL 0x7ff07ff8 +#define CONFIG_SYS_MSC1_VAL 0x7ff07ff0 +#define CONFIG_SYS_MSC2_VAL 0x74a42491 +#define CONFIG_SYS_MDCNFG_VAL 0x89d309d3 +#define CONFIG_SYS_MDREFR_VAL 0x001d8018 +#define CONFIG_SYS_MDMRS_VAL 0x00220022 +#define CONFIG_SYS_FLYCNFG_VAL 0x00000000 +#define CONFIG_SYS_SXCNFG_VAL 0x00000000 +#define CONFIG_SYS_MEM_BUF_IMP 0x0f + +/* + * PCMCIA and CF Interfaces + */ +#define CONFIG_SYS_MECR_VAL 0x00000000 +#define CONFIG_SYS_MCMEM0_VAL 0x00014307 +#define CONFIG_SYS_MCMEM1_VAL 0x00014307 +#define CONFIG_SYS_MCATT0_VAL 0x0001c787 +#define CONFIG_SYS_MCATT1_VAL 0x0001c787 +#define CONFIG_SYS_MCIO0_VAL 0x0001430f +#define CONFIG_SYS_MCIO1_VAL 0x0001430f + +/* + * LCD + */ +#ifdef CONFIG_LCD +#define CONFIG_BALLOON3LCD +#define CONFIG_VIDEO_LOGO +#define CONFIG_CMD_BMP +#define CONFIG_SPLASH_SCREEN +#define CONFIG_SPLASH_SCREEN_ALIGN +#define CONFIG_VIDEO_BMP_GZIP +#define CONFIG_VIDEO_BMP_RLE8 +#define CONFIG_SYS_VIDEO_LOGO_MAX_SIZE (2 << 20) +#endif + +/* + * USB + */ +#ifdef CONFIG_CMD_USB +#define CONFIG_USB_OHCI_NEW +#define CONFIG_SYS_USB_OHCI_CPU_INIT +#define CONFIG_SYS_USB_OHCI_BOARD_INIT +#define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 2 +#define CONFIG_SYS_USB_OHCI_REGS_BASE 0x4C000000 +#define CONFIG_SYS_USB_OHCI_SLOT_NAME "balloon3" +#define CONFIG_USB_STORAGE +#define CONFIG_DOS_PARTITION +#define CONFIG_CMD_FAT +#define CONFIG_CMD_EXT2 +#endif + +/* + * FPGA + */ +#ifdef CONFIG_CMD_FPGA +#define CONFIG_FPGA +#define CONFIG_FPGA_XILINX +#define CONFIG_FPGA_SPARTAN3 +#define CONFIG_SYS_FPGA_PROG_FEEDBACK +#define CONFIG_SYS_FPGA_WAIT 1000 +#define CONFIG_MAX_FPGA_DEVICES 1 +#endif + +#endif /* __CONFIG_H */
Signed-off-by: Marek Vasut marek.vasut@gmail.com --- MAINTAINERS | 2 ++ 1 files changed, 2 insertions(+), 0 deletions(-)
diff --git a/MAINTAINERS b/MAINTAINERS index 7aa4e4b..a003dda 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -798,9 +798,11 @@ Greg Ungerer greg.ungerer@opengear.com Marek Vasut marek.vasut@gmail.com
balloon3 xscale + colibri_pxa270 xscale palmld xscale palmtc xscale vpac270 xscale + zipitz2 xscale
From: Mikhail Kshevetskiy mikhail.kshevetskiy@gmail.com
This file is not used, automatically generated u-boot.lds is used instead
Signed-off-by: Mikhail Kshevetskiy mikhail.kshevetskiy@gmail.com --- board/vpac270/u-boot.lds | 55 ---------------------------------------------- 1 files changed, 0 insertions(+), 55 deletions(-) delete mode 100644 board/vpac270/u-boot.lds
diff --git a/board/vpac270/u-boot.lds b/board/vpac270/u-boot.lds deleted file mode 100644 index 58c371d..0000000 --- a/board/vpac270/u-boot.lds +++ /dev/null @@ -1,55 +0,0 @@ -/* - * (C) Copyright 2000 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") -OUTPUT_ARCH(arm) -ENTRY(_start) -SECTIONS -{ - . = 0x00000000; - - . = ALIGN(4); - .text : - { - cpu/pxa/start.o (.text) - *(.text) - } - - . = ALIGN(4); - .rodata : { *(.rodata) } - - . = ALIGN(4); - .data : { *(.data) } - - . = ALIGN(4); - .got : { *(.got) } - - __u_boot_cmd_start = .; - .u_boot_cmd : { *(.u_boot_cmd) } - __u_boot_cmd_end = .; - - . = ALIGN(4); - __bss_start = .; - .bss : { *(.bss) } - _end = .; -}
* CONFIG_SYS_CLKS_IN_HZ is not used anywhere, so removing it * CONFIG_SYS_HZ is set to 1000 on most architectures, so it seems to be the safe default
Signed-off-by: Mikhail Kshevetskiy mikhail.kshevetskiy@gmail.com --- include/configs/vpac270.h | 3 +-- 1 files changed, 1 insertions(+), 2 deletions(-)
diff --git a/include/configs/vpac270.h b/include/configs/vpac270.h index 694a8f9..4c18d3a 100644 --- a/include/configs/vpac270.h +++ b/include/configs/vpac270.h @@ -146,8 +146,7 @@ /* * Clock Configuration */ -#undef CONFIG_SYS_CLKS_IN_HZ -#define CONFIG_SYS_HZ 3250000 /* Timer @ 3250000 Hz */ +#define CONFIG_SYS_HZ 1000 /* Timer @ 3250000 Hz */ #define CONFIG_SYS_CPUSPEED 0x190 /* 312MHz */
Define ENV_ADDR as MONITOR_BASE + MONITOR_LEN. Fix environment sector size (NOR: 32Kb for first four sectors and 128Kb for other; OneNAND: 128Kb).
Last but not least: we have MONITOR_LEN = 0x40000 and one sector for environment (size = 0x20000), so the kernel may start from 0x00060000 only.
Signed-off-by: Mikhail Kshevetskiy mikhail.kshevetskiy@gmail.com --- include/configs/vpac270.h | 25 +++++++++++++++++-------- 1 files changed, 17 insertions(+), 8 deletions(-)
diff --git a/include/configs/vpac270.h b/include/configs/vpac270.h index 4c18d3a..b8440a1 100644 --- a/include/configs/vpac270.h +++ b/include/configs/vpac270.h @@ -45,7 +45,7 @@ "if ide reset && fatload ide 0 0xa4000000 uImage; then " \ "bootm 0xa4000000; " \ "fi; " \ - "bootm 0x40000;" + "bootm 0x60000;" #define CONFIG_BOOTARGS "console=tty0 console=ttyS0,115200" #define CONFIG_TIMESTAMP #define CONFIG_BOOTDELAY 2 /* Autoboot delay */ @@ -185,6 +185,12 @@ /* * NOR FLASH */ +#define CONFIG_SYS_MONITOR_BASE 0x0 +#define CONFIG_SYS_MONITOR_LEN 0x40000 +#define CONFIG_ENV_ADDR \ + (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) +#define CONFIG_ENV_SIZE 0x4000 + #if defined(CONFIG_CMD_FLASH) /* NOR */ #define PHYS_FLASH_1 0x00000000 /* Flash Bank #1 */
@@ -211,7 +217,16 @@ #define CONFIG_SYS_FLASH_PROTECTION 1
#define CONFIG_ENV_IS_IN_FLASH 1 -#define CONFIG_ENV_SECT_SIZE 0x4000 + +/* + * The first four sectors of the NOR flash are 0x8000 bytes big, the rest of the + * flash consists of 0x20000 bytes big sectors. + */ +#if (CONFIG_ENV_ADDR <= 0x18000) +#define CONFIG_ENV_SECT_SIZE 0x8000 +#else +#define CONFIG_ENV_SECT_SIZE 0x20000 +#endif
#elif defined(CONFIG_CMD_ONENAND) /* OneNAND */ #define CONFIG_SYS_NO_FLASH @@ -225,12 +240,6 @@ #define CONFIG_SYS_ENV_IS_NOWHERE #endif
-#define CONFIG_SYS_MONITOR_BASE 0x0 -#define CONFIG_SYS_MONITOR_LEN 0x40000 - -#define CONFIG_ENV_ADDR 0x40000 -#define CONFIG_ENV_SIZE 0x4000 - /* * IDE */
pxa_mem_setup macro use r6 to store CONFIG_SYS_MDREFR_VAL during memory initialization. This reg is modified during execution of pxa_wait_ticks. Later we use r6 to setup MDREFR[APD] bit. As result MDREFR[APD] is always zero.
Signed-off-by: Mikhail Kshevetskiy mikhail.kshevetskiy@gmail.com --- arch/arm/include/asm/arch-pxa/macro.h | 20 ++++++++++++-------- 1 files changed, 12 insertions(+), 8 deletions(-)
diff --git a/arch/arm/include/asm/arch-pxa/macro.h b/arch/arm/include/asm/arch-pxa/macro.h index 035a57e..85958dd 100644 --- a/arch/arm/include/asm/arch-pxa/macro.h +++ b/arch/arm/include/asm/arch-pxa/macro.h @@ -102,7 +102,11 @@ /* * This macro sets up the Memory controller of the PXA2xx CPU * - * Clobbered regs: r3, r4, r5 + * WARNING: This macro uses internally r3 and r7 regs for MEMC_BASE + * and CONFIG_SYS_MDREFR_VAL correspondingly. Please do not + * use this regs for other purpose inside this macro. + * + * Clobbered regs: r3, r4, r5, r6, r7 */ .macro pxa_mem_setup /* This comes handy when setting MDREFR */ @@ -157,7 +161,7 @@ bic r5, r5, #0xf00 /* MDREFR user config with zeroed DRI */
ldr r4, =CONFIG_SYS_MDREFR_VAL - mov r6, r4 + mov r7, r4 lsl r4, #20 lsr r4, #20 /* Get a valid DRI field */
@@ -187,12 +191,12 @@ * 6) Initialize SDRAM */
- bic r6, #MDREFR_SLFRSH - str r6, [r3, #MDREFR_OFFSET] + bic r7, #MDREFR_SLFRSH + str r7, [r3, #MDREFR_OFFSET] ldr r4, [r3, #MDREFR_OFFSET]
- orr r6, #MDREFR_E1PIN - str r6, [r3, #MDREFR_OFFSET] + orr r7, #MDREFR_E1PIN + str r7, [r3, #MDREFR_OFFSET] ldr r4, [r3, #MDREFR_OFFSET]
/* @@ -250,8 +254,8 @@ */
ldr r4, [r3, #MDREFR_OFFSET] - and r6, r6, #MDREFR_APD - orr r4, r4, r6 + and r7, r7, #MDREFR_APD + orr r4, r4, r7 str r4, [r3, #MDREFR_OFFSET] ldr r4, [r3, #MDREFR_OFFSET] .endm
Signed-off-by: Marek Vasut marek.vasut@gmail.com --- board/vpac270/vpac270.c | 11 ++++++++++- include/configs/balloon3.h | 3 +++ include/configs/cerf250.h | 3 +++ include/configs/colibri_pxa270.h | 3 +++ include/configs/cradle.h | 3 +++ include/configs/csb226.h | 3 +++ include/configs/delta.h | 3 +++ include/configs/innokom.h | 3 +++ include/configs/lubbock.h | 3 +++ include/configs/palmld.h | 3 +++ include/configs/palmtc.h | 3 +++ include/configs/pleb2.h | 3 +++ include/configs/pxa255_idp.h | 3 +++ include/configs/trizepsiv.h | 3 +++ include/configs/vpac270.h | 3 +++ include/configs/wepep250.h | 4 ++++ include/configs/xaeniax.h | 3 +++ include/configs/xm250.h | 3 +++ include/configs/xsengine.h | 3 +++ include/configs/zipitz2.h | 3 +++ include/configs/zylonite.h | 2 ++ 21 files changed, 70 insertions(+), 1 deletions(-)
diff --git a/board/vpac270/vpac270.c b/board/vpac270/vpac270.c index 1557d1b..f91ff97 100644 --- a/board/vpac270/vpac270.c +++ b/board/vpac270/vpac270.c @@ -49,8 +49,18 @@ struct serial_device *default_serial_console(void) return &serial_ffuart_device; }
+ int dram_init(void) { + gd->ram_size = PHYS_SDRAM_1_SIZE; +#ifdef CONFIG_256M_U_BOOT + gd->ram_size += PHYS_SDRAM_2_SIZE; +#endif + return 0; +} + +void dram_init_banksize(void) +{ gd->bd->bi_dram[0].start = PHYS_SDRAM_1; gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE;
@@ -58,7 +68,6 @@ int dram_init(void) gd->bd->bi_dram[1].start = PHYS_SDRAM_2; gd->bd->bi_dram[1].size = PHYS_SDRAM_2_SIZE; #endif - return 0; }
#ifdef CONFIG_CMD_USB diff --git a/include/configs/balloon3.h b/include/configs/balloon3.h index 9066a24..5e2a285 100644 --- a/include/configs/balloon3.h +++ b/include/configs/balloon3.h @@ -130,6 +130,9 @@
+#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_GBL_DATA_SIZE + PHYS_SDRAM_1) + /* * NOR FLASH */ diff --git a/include/configs/cerf250.h b/include/configs/cerf250.h index 477b94a..98b69e3 100644 --- a/include/configs/cerf250.h +++ b/include/configs/cerf250.h @@ -161,6 +161,9 @@
+#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_GBL_DATA_SIZE + PHYS_SDRAM_1) + /* * GPIO settings */ diff --git a/include/configs/colibri_pxa270.h b/include/configs/colibri_pxa270.h index 277ff67..5f457f8 100644 --- a/include/configs/colibri_pxa270.h +++ b/include/configs/colibri_pxa270.h @@ -169,6 +169,9 @@
#define CONFIG_SYS_LOAD_ADDR (0xa1000000)
+#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_GBL_DATA_SIZE + PHYS_SDRAM_1) + /* * NOR FLASH */ diff --git a/include/configs/cradle.h b/include/configs/cradle.h index 998e179..d1c1a48 100644 --- a/include/configs/cradle.h +++ b/include/configs/cradle.h @@ -145,6 +145,9 @@
+#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_GBL_DATA_SIZE + PHYS_SDRAM_1) + /* * FLASH and environment organization */ diff --git a/include/configs/csb226.h b/include/configs/csb226.h index 0661d65..ae05734 100644 --- a/include/configs/csb226.h +++ b/include/configs/csb226.h @@ -181,6 +181,9 @@
+#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_GBL_DATA_SIZE + PHYS_SDRAM_1) + # if 0 /* FIXME: switch to _documented_ registers */ /* diff --git a/include/configs/delta.h b/include/configs/delta.h index d930fb4..d53acbf 100644 --- a/include/configs/delta.h +++ b/include/configs/delta.h @@ -218,6 +218,9 @@
#undef CONFIG_SYS_SKIP_DRAM_SCRUB
+#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_GBL_DATA_SIZE + PHYS_SDRAM_1) + /* * NAND Flash */ diff --git a/include/configs/innokom.h b/include/configs/innokom.h index 9cb0d42..007cceb 100644 --- a/include/configs/innokom.h +++ b/include/configs/innokom.h @@ -192,6 +192,9 @@
+#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_GBL_DATA_SIZE + PHYS_SDRAM_1) + /* * JFFS2 partitions * diff --git a/include/configs/lubbock.h b/include/configs/lubbock.h index 0a69210..3a99ec2 100644 --- a/include/configs/lubbock.h +++ b/include/configs/lubbock.h @@ -176,6 +176,9 @@
+#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_GBL_DATA_SIZE + PHYS_SDRAM_1) + #define FPGA_REGS_BASE_PHYSICAL 0x08000000
/* diff --git a/include/configs/palmld.h b/include/configs/palmld.h index affc116..926728b 100644 --- a/include/configs/palmld.h +++ b/include/configs/palmld.h @@ -154,6 +154,9 @@
+#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_GBL_DATA_SIZE + PHYS_SDRAM_1) + /* * NOR FLASH */ diff --git a/include/configs/palmtc.h b/include/configs/palmtc.h index f4fc9cd..fe87648 100644 --- a/include/configs/palmtc.h +++ b/include/configs/palmtc.h @@ -155,6 +155,9 @@
+#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_GBL_DATA_SIZE + PHYS_SDRAM_1) + /* * NOR FLASH */ diff --git a/include/configs/pleb2.h b/include/configs/pleb2.h index 9e69411..3b6e60a 100644 --- a/include/configs/pleb2.h +++ b/include/configs/pleb2.h @@ -179,6 +179,9 @@ #define CONFIG_SYS_FLASH_BASE PHYS_FLASH_1 #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE
+#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_GBL_DATA_SIZE + PHYS_SDRAM_1) + /* * GPIO settings */ diff --git a/include/configs/pxa255_idp.h b/include/configs/pxa255_idp.h index 6c1defc..4581674 100644 --- a/include/configs/pxa255_idp.h +++ b/include/configs/pxa255_idp.h @@ -292,6 +292,9 @@
+#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_GBL_DATA_SIZE + PHYS_SDRAM_1) + /* * GPIO settings */ diff --git a/include/configs/trizepsiv.h b/include/configs/trizepsiv.h index fa5aae8..4743495 100644 --- a/include/configs/trizepsiv.h +++ b/include/configs/trizepsiv.h @@ -212,6 +212,9 @@
+#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_GBL_DATA_SIZE + PHYS_SDRAM_1) + /* * GPIO settings */ diff --git a/include/configs/vpac270.h b/include/configs/vpac270.h index b8440a1..1bcd2f3 100644 --- a/include/configs/vpac270.h +++ b/include/configs/vpac270.h @@ -181,6 +181,9 @@ #define CONFIG_SYS_MEMTEST_END 0xa0800000 /* 4 ... 8 MB in DRAM */
#define CONFIG_SYS_LOAD_ADDR (0x5c000000) +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_GBL_DATA_SIZE + CONFIG_STACKSIZE + PHYS_SDRAM_1)
/* * NOR FLASH diff --git a/include/configs/wepep250.h b/include/configs/wepep250.h index 9a20cce..a961a27 100644 --- a/include/configs/wepep250.h +++ b/include/configs/wepep250.h @@ -183,6 +183,10 @@ #define CONFIG_ENV_ADDR 0x20000 /* absolute address for now */ #define CONFIG_ENV_SIZE 0x2000
+#define PHYS_SDRAM_1 WEP_SDRAM_1 +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_GBL_DATA_SIZE + PHYS_SDRAM_1) + #undef CONFIG_ENV_OVERWRITE /* env is not writable now */
/* diff --git a/include/configs/xaeniax.h b/include/configs/xaeniax.h index 1329f0f..67d4106 100644 --- a/include/configs/xaeniax.h +++ b/include/configs/xaeniax.h @@ -167,6 +167,9 @@
+#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_GBL_DATA_SIZE + PHYS_SDRAM_1) + /* * FLASH and environment organization */ diff --git a/include/configs/xm250.h b/include/configs/xm250.h index cd56ce7..2ff9a28 100644 --- a/include/configs/xm250.h +++ b/include/configs/xm250.h @@ -174,6 +174,9 @@
+#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_GBL_DATA_SIZE + PHYS_SDRAM_1) + /* * FLASH and environment organization */ diff --git a/include/configs/xsengine.h b/include/configs/xsengine.h index f68461b..9606b53 100644 --- a/include/configs/xsengine.h +++ b/include/configs/xsengine.h @@ -53,6 +53,9 @@ #define CONFIG_SYS_DRAM_BASE 0xa0000000 #define CONFIG_SYS_DRAM_SIZE 0x04000000
+#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_GBL_DATA_SIZE + PHYS_SDRAM_1) + /* FLASH organization */ #define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max number of memory banks */ #define CONFIG_SYS_MAX_FLASH_SECT 128 /* max number of sectors on one chip */ diff --git a/include/configs/zipitz2.h b/include/configs/zipitz2.h index a5a873b..642c575 100644 --- a/include/configs/zipitz2.h +++ b/include/configs/zipitz2.h @@ -175,6 +175,9 @@ unsigned char zipitz2_spi_read(void);
+#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_GBL_DATA_SIZE + PHYS_SDRAM_1) + /* * NOR FLASH */ diff --git a/include/configs/zylonite.h b/include/configs/zylonite.h index c8aa046..c33ca2d 100644 --- a/include/configs/zylonite.h +++ b/include/configs/zylonite.h @@ -190,6 +190,8 @@
/* * NAND Flash
Firstly, this fixes relocation issues. I had to use part of Dcache as RAM for a while. I also moved around the lowlevel init code. It turned out so most of the lowlevel init code ended in cpu.c (and eventually was rewritten into C).
This will also allow easier operation with FDT, multi-CPU-model support etc. in later releases.
NOTE: This breaks most of the PXA boards (actually, the reloc stuff did already, this only finishes the doom).
Signed-off-by: Marek Vasut marek.vasut@gmail.com --- arch/arm/cpu/pxa/cpu.c | 229 ++++++++++++++++++++++++++++++- arch/arm/cpu/pxa/start.S | 346 ++++++++++++++++++---------------------------- 2 files changed, 360 insertions(+), 215 deletions(-)
diff --git a/arch/arm/cpu/pxa/cpu.c b/arch/arm/cpu/pxa/cpu.c index 330d013..3ea3458 100644 --- a/arch/arm/cpu/pxa/cpu.c +++ b/arch/arm/cpu/pxa/cpu.c @@ -30,11 +30,11 @@ * CPU specific code */
-#include <asm/arch/pxa-regs.h> #include <asm/io.h> #include <asm/system.h> #include <command.h> #include <common.h> +#include <asm/arch/pxa-regs.h>
static void cache_flush(void);
@@ -91,3 +91,230 @@ void set_GPIO_mode(int gpio_mode) writel(val, GAFR(gpio)); } #endif /* CONFIG_CPU_MONAHANS */ + +void pxa_wait_ticks(int ticks) +{ + writel(0, OSCR); + while (readl(OSCR) < ticks) + asm volatile("":::"memory"); +} + +inline void writelrb(uint32_t val, uint32_t addr) +{ + writel(val, addr); + asm volatile("":::"memory"); + readl(addr); + asm volatile("":::"memory"); +} + +void pxa_dram_init(void) +{ + uint32_t tmp; + int i; + /* + * 1) Initialize Asynchronous static memory controller + */ + + writelrb(CONFIG_SYS_MSC0_VAL, MSC0); + writelrb(CONFIG_SYS_MSC1_VAL, MSC1); + writelrb(CONFIG_SYS_MSC2_VAL, MSC2); + /* + * 2) Initialize Card Interface + */ + + /* MECR: Memory Expansion Card Register */ + writelrb(CONFIG_SYS_MECR_VAL, MECR); + /* MCMEM0: Card Interface slot 0 timing */ + writelrb(CONFIG_SYS_MCMEM0_VAL, MCMEM0); + /* MCMEM1: Card Interface slot 1 timing */ + writelrb(CONFIG_SYS_MCMEM1_VAL, MCMEM1); + /* MCATT0: Card Interface Attribute Space Timing, slot 0 */ + writelrb(CONFIG_SYS_MCATT0_VAL, MCATT0); + /* MCATT1: Card Interface Attribute Space Timing, slot 1 */ + writelrb(CONFIG_SYS_MCATT1_VAL, MCATT1); + /* MCIO0: Card Interface I/O Space Timing, slot 0 */ + writelrb(CONFIG_SYS_MCIO0_VAL, MCIO0); + /* MCIO1: Card Interface I/O Space Timing, slot 1 */ + writelrb(CONFIG_SYS_MCIO1_VAL, MCIO1); + + /* + * 3) Configure Fly-By DMA register + */ + + writelrb(CONFIG_SYS_FLYCNFG_VAL, FLYCNFG); + + /* + * 4) Initialize Timing for Sync Memory (SDCLK0) + */ + + /* + * Before accessing MDREFR we need a valid DRI field, so we set + * this to power on defaults + DRI field. + */ + + /* Read current MDREFR config and zero out DRI */ + tmp = readl(MDREFR) & ~0xfff; + /* Add user-specified DRI */ + tmp |= CONFIG_SYS_MDREFR_VAL & 0xfff; + /* Configure important bits */ + tmp |= MDREFR_K0RUN | MDREFR_SLFRSH; + tmp &= ~(MDREFR_APD | MDREFR_E1PIN); + + /* Write MDREFR back */ + writelrb(tmp, MDREFR); + + /* + * 5) Initialize Synchronous Static Memory (Flash/Peripherals) + */ + + /* Initialize SXCNFG register. Assert the enable bits. + * + * Write SXMRS to cause an MRS command to all enabled banks of + * synchronous static memory. Note that SXLCR need not be written + * at this time. + */ + writelrb(CONFIG_SYS_SXCNFG_VAL, SXCNFG); + + /* + * 6) Initialize SDRAM + */ + + writelrb(CONFIG_SYS_MDREFR_VAL & ~MDREFR_SLFRSH, MDREFR); + writelrb(CONFIG_SYS_MDREFR_VAL | MDREFR_E1PIN, MDREFR); + + /* + * 7) Write MDCNFG with MDCNFG:DEx deasserted (set to 0), to configure + * but not enable each SDRAM partition pair. + */ + + writelrb(CONFIG_SYS_MDCNFG_VAL & + ~(MDCNFG_DE0 | MDCNFG_DE1 | MDCNFG_DE2 | MDCNFG_DE3), MDCNFG); + /* Wait for the clock to the SDRAMs to stabilize, 100..200 usec. */ + pxa_wait_ticks(0x300); + + /* + * 8) Trigger a number (usually 8) refresh cycles by attempting + * non-burst read or write accesses to disabled SDRAM, as commonly + * specified in the power up sequence documented in SDRAM data + * sheets. The address(es) used for this purpose must not be + * cacheable. + */ + for (i = 9; i >= 0; i--) { + writel(i, 0xa0000000); + asm volatile("":::"memory"); + } + /* + * 9) Write MDCNFG with enable bits asserted (MDCNFG:DEx set to 1). + */ + + tmp = CONFIG_SYS_MDCNFG_VAL & + (MDCNFG_DE0 | MDCNFG_DE1 | MDCNFG_DE2 | MDCNFG_DE3); + tmp |= readl(MDCNFG); + writelrb(tmp, MDCNFG); + + /* + * 10) Write MDMRS. + */ + + writelrb(CONFIG_SYS_MDMRS_VAL, MDMRS); + + /* + * 11) Enable APD + */ + + if (CONFIG_SYS_MDREFR_VAL & MDREFR_APD) { + tmp = readl(MDREFR); + tmp |= MDREFR_APD; + writelrb(tmp, MDREFR); + } +} + +void pxa_gpio_setup(void) +{ + writel(CONFIG_SYS_GPSR0_VAL, GPSR0); + writel(CONFIG_SYS_GPSR1_VAL, GPSR1); + writel(CONFIG_SYS_GPSR2_VAL, GPSR2); +#if defined(CONFIG_PXA27X) || defined(CONFIG_CPU_MONAHANS) + writel(CONFIG_SYS_GPSR3_VAL, GPSR3); +#endif + + writel(CONFIG_SYS_GPCR0_VAL, GPCR0); + writel(CONFIG_SYS_GPCR1_VAL, GPCR1); + writel(CONFIG_SYS_GPCR2_VAL, GPCR2); +#if defined(CONFIG_PXA27X) || defined(CONFIG_CPU_MONAHANS) + writel(CONFIG_SYS_GPCR3_VAL, GPCR3); +#endif + + writel(CONFIG_SYS_GPDR0_VAL, GPDR0); + writel(CONFIG_SYS_GPDR1_VAL, GPDR1); + writel(CONFIG_SYS_GPDR2_VAL, GPDR2); +#if defined(CONFIG_PXA27X) || defined(CONFIG_CPU_MONAHANS) + writel(CONFIG_SYS_GPDR3_VAL, GPDR3); +#endif + + writel(CONFIG_SYS_GAFR0_L_VAL, GAFR0_L); + writel(CONFIG_SYS_GAFR0_U_VAL, GAFR0_U); + writel(CONFIG_SYS_GAFR1_L_VAL, GAFR1_L); + writel(CONFIG_SYS_GAFR1_U_VAL, GAFR1_U); + writel(CONFIG_SYS_GAFR2_L_VAL, GAFR2_L); + writel(CONFIG_SYS_GAFR2_U_VAL, GAFR2_U); +#if defined(CONFIG_PXA27X) || defined(CONFIG_CPU_MONAHANS) + writel(CONFIG_SYS_GAFR3_L_VAL, GAFR3_L); + writel(CONFIG_SYS_GAFR3_U_VAL, GAFR3_U); +#endif + + writel(CONFIG_SYS_PSSR_VAL, PSSR); +} + +void pxa_interrupt_setup(void) +{ + writel(0, ICLR); + writel(0, ICMR); +#if defined(CONFIG_PXA27X) || defined(CONFIG_CPU_MONAHANS) + writel(0, ICLR2); + writel(0, ICMR2); +#endif +} + +void pxa_clock_setup(void) +{ +#ifndef CONFIG_CPU_MONAHANS + writel(CONFIG_SYS_CKEN, CKEN); + writel(CONFIG_SYS_CCCR, CCCR); + asm volatile("mcr p14, 0, %0, c6, c0, 0"::"r"(2)); +#else +/* Set CKENA/CKENB/ACCR for MH */ +#endif + + /* enable the 32Khz oscillator for RTC and PowerManager */ + writel(OSCC_OON, OSCC); + while(!(readl(OSCC) & OSCC_OOK)) + asm volatile("":::"memory"); +} + +void pxa_wakeup(void) +{ + uint32_t rcsr; + + rcsr = readl(RCSR); + writel(rcsr & (RCSR_GPR | RCSR_SMR | RCSR_WDR | RCSR_HWR), RCSR); + + /* Wakeup */ + if (rcsr & RCSR_SMR) { + writel(PSSR_PH, PSSR); + pxa_dram_init(); + icache_disable(); + dcache_disable(); + asm volatile("mov pc, %0"::"r"(readl(PSSR))); + } +} + +int arch_cpu_init(void) +{ + pxa_gpio_setup(); +// pxa_wait_ticks(0x8000); + pxa_wakeup(); + pxa_interrupt_setup(); + pxa_clock_setup(); + return 0; +} diff --git a/arch/arm/cpu/pxa/start.S b/arch/arm/cpu/pxa/start.S index de6d2dd..836299c 100644 --- a/arch/arm/cpu/pxa/start.S +++ b/arch/arm/cpu/pxa/start.S @@ -31,6 +31,14 @@ #include <config.h> #include <version.h> #include <asm/arch/pxa-regs.h> +#include <asm/arch/macro.h> + +/* takes care the CP15 update has taken place */ +.macro CPWAIT reg +mrc p15,0,\reg,c2,c0,0 +mov \reg,\reg +sub pc,pc,#4 +.endm
.globl _start _start: b reset @@ -86,11 +94,9 @@ _fiq: .word fiq _TEXT_BASE: .word CONFIG_SYS_TEXT_BASE
-#if defined(CONFIG_SYS_ARM_WITHOUT_RELOC) .globl _armboot_start _armboot_start: .word _start -#endif
/* * These are defined in the board-specific linker script. @@ -115,7 +121,7 @@ FIQ_STACK_START: .word 0x0badc0de #endif /* CONFIG_USE_IRQ */
-#if !defined(CONFIG_SYS_ARM_WITHOUT_RELOC) +#ifndef CONFIG_PRELOADER /* IRQ stack memory (calculated at run-time) + 8 bytes */ .globl IRQ_STACK_START_IN IRQ_STACK_START_IN: @@ -159,12 +165,84 @@ reset: msr cpsr,r0
/* - * we do sys-critical inits only at reboot, - * not when booting from ram! + * Enable MMU to use DCache as DRAM */ -#ifndef CONFIG_SKIP_LOWLEVEL_INIT - bl cpu_init_crit -#endif + /* Domain access -- enable for all CPs */ + ldr r0, =0x0000ffff + mcr p15, 0, r0, c3, c0, 0 + + /* Point TTBR to MMU table */ + ldr r0, =mmu_table + adr r2, _start + orr r0, r2 + mcr p15, 0, r0, c2, c0, 0 + +/* !!! Hereby, check if the code is running from SRAM !!! */ +/* If the code is running from SRAM, alias SRAM to 0x0 to simulate NOR. The code + * is linked to 0x0 too, so this makes things easier. */ + cmp r2, #0x5c000000 + + ldreq r1, [r0] + orreq r1, r2 + streq r1, [r0] + + /* Kick in MMU, ICache, DCache, BTB */ + mrc p15, 0, r0, c1, c0, 0 + bic r0, #0x1b00 + bic r0, #0x0087 + orr r0, #0x1800 + orr r0, #0x0005 + mcr p15, 0, r0, c1, c0, 0 + CPWAIT r0 + + /* Unlock Icache, Dcache */ + mcr p15, 0, r0, c9, c1, 1 + mcr p15, 0, r0, c9, c2, 1 + + /* Flush Icache, Dcache, BTB */ + mcr p15, 0, r0, c7, c7, 0 + + /* Unlock I-TLB, D-TLB */ + mcr p15, 0, r0, c10, c4, 1 + mcr p15, 0, r0, c10, c8, 1 + + /* Flush TLB */ + mcr p15, 0, r0, c8, c7, 0 + /* Allocate 4096 bytes of Dcache as RAM */ + + /* Drain pending loads and stores */ + mcr p15, 0, r0, c7, c10, 4 + + mov r4, #0x00 + mov r5, #0x00 + mov r2, #0x01 + mcr p15, 0, r0, c9, c2, 0 + CPWAIT r0 + + /* 128 lines reserved (128 x 32bytes = 4096 bytes total) */ + mov r0, #128 + mov r1, #0xa0000000 +alloc: + mcr p15, 0, r1, c7, c2, 5 + /* Drain pending loads and stores */ + mcr p15, 0, r0, c7, c10, 4 + strd r4, [r1], #8 + strd r4, [r1], #8 + strd r4, [r1], #8 + strd r4, [r1], #8 + subs r0, #0x01 + bne alloc + /* Drain pending loads and stores */ + mcr p15, 0, r0, c7, c10, 4 + mov r2, #0x00 + mcr p15, 0, r2, c9, c2, 0 + CPWAIT r0 + + /* Jump to 0x0 ( + offset) if running from SRAM */ + adr r0, zerojmp + bic r0, #0x5c000000 + mov pc, r0 +zerojmp:
/* Set stackpointer in internal RAM to call board_init_f */ call_board_init_f: @@ -201,11 +279,13 @@ stack_setup: beq clear_bss
#ifndef CONFIG_SKIP_RELOCATE_UBOOT + stmfd sp!, {r0-r12} copy_loop: - ldmia r0!, {r9-r10} /* copy from source address [r0] */ - stmia r6!, {r9-r10} /* copy to target address [r1] */ - cmp r0, r2 /* until source end addreee [r2] */ + ldmia r0!, {r3-r5, r7-r11} /* copy from source address [r0] */ + stmia r6!, {r3-r5, r7-r11} /* copy to target address [r1] */ + cmp r0, r2 /* until source end address [r2] */ ble copy_loop + ldmfd sp!, {r0-r12}
#ifndef CONFIG_PRELOADER /* fix got entries */ @@ -274,218 +354,28 @@ _board_init_r: .word board_init_r
/****************************************************************************/ /* */ -/* the actual reset code */ +/* the actual reset code for OneNAND IPL */ /* */ /****************************************************************************/
+#ifndef CONFIG_PXA27X +#error OneNAND IPL is not supported on PXA25x and 26x due to lack of SRAM +#endif + reset: - mrs r0,cpsr /* set the CPU to SVC32 mode */ - bic r0,r0,#0x1f /* (superviser mode, M=10011) */ + /* Set CPU to SVC32 mode */ + mrs r0,cpsr + bic r0,r0,#0x1f orr r0,r0,#0x13 msr cpsr,r0
- /* - * we do sys-critical inits only at reboot, - * not when booting from RAM! - */ -#ifndef CONFIG_SKIP_LOWLEVEL_INIT - bl cpu_init_crit /* we do sys-critical inits */ -#endif /* !CONFIG_SKIP_LOWLEVEL_INIT */ - -#ifndef CONFIG_SKIP_RELOCATE_UBOOT -relocate: /* relocate U-Boot to RAM */ - adr r0, _start /* r0 <- current position of code */ - ldr r1, _TEXT_BASE /* test if we run from flash or RAM */ -#ifndef CONFIG_PRELOADER - cmp r0, r1 /* don't reloc during debug */ - beq stack_setup -#endif - - ldr r2, _armboot_start - ldr r3, _bss_start - sub r2, r3, r2 /* r2 <- size of armboot */ - add r2, r0, r2 /* r2 <- source end address */ - -copy_loop: - ldmia r0!, {r3-r10} /* copy from source address [r0] */ - stmia r1!, {r3-r10} /* copy to target address [r1] */ - cmp r0, r2 /* until source end address [r2] */ - ble copy_loop -#endif /* !CONFIG_SKIP_RELOCATE_UBOOT */ - - /* Set up the stack */ -stack_setup: - ldr r0, _TEXT_BASE /* upper 128 KiB: relocated uboot */ -#ifdef CONFIG_PRELOADER - sub sp, r0, #128 /* leave 32 words for abort-stack */ -#else - sub r0, r0, #CONFIG_SYS_MALLOC_LEN /* malloc area */ - sub r0, r0, #CONFIG_SYS_GBL_DATA_SIZE /* bdinfo */ -#ifdef CONFIG_USE_IRQ - sub r0, r0, #(CONFIG_STACKSIZE_IRQ+CONFIG_STACKSIZE_FIQ) -#endif /* CONFIG_USE_IRQ */ - sub sp, r0, #12 /* leave 3 words for abort-stack */ - bic sp, sp, #7 /* 8-byte alignment for ABI compliance */ -#endif - -clear_bss: - ldr r0, _bss_start /* find start of bss segment */ - ldr r1, _bss_end /* stop here */ - mov r2, #0x00000000 /* clear */ - -#ifndef CONFIG_PRELOADER -clbss_l:str r2, [r0] /* clear loop... */ - add r0, r0, #4 - cmp r0, r1 - ble clbss_l -#endif - - ldr pc, _start_armboot - -#ifdef CONFIG_ONENAND_IPL -_start_armboot: .word start_oneboot -#else -_start_armboot: .word start_armboot -#endif -#endif /* #if !defined(CONFIG_SYS_ARM_WITHOUT_RELOC) */ - -/****************************************************************************/ -/* */ -/* CPU_init_critical registers */ -/* */ -/* - setup important registers */ -/* - setup memory timing */ -/* */ -/****************************************************************************/ -/* mk@tbd: Fix this! */ -#undef RCSR -#undef ICMR -#undef OSMR3 -#undef OSCR -#undef OWER -#undef OIER -#undef CCCR - -/* Interrupt-Controller base address */ -IC_BASE: .word 0x40d00000 -#define ICMR 0x04 - -/* Reset-Controller */ -RST_BASE: .word 0x40f00030 -#define RCSR 0x00 - -/* Operating System Timer */ -OSTIMER_BASE: .word 0x40a00000 -#define OSMR3 0x0C -#define OSCR 0x10 -#define OWER 0x18 -#define OIER 0x1C - -/* Clock Manager Registers */ -#ifdef CONFIG_CPU_MONAHANS -# ifndef CONFIG_SYS_MONAHANS_RUN_MODE_OSC_RATIO -# error "You have to define CONFIG_SYS_MONAHANS_RUN_MODE_OSC_RATIO!!" -# endif /* !CONFIG_SYS_MONAHANS_RUN_MODE_OSC_RATIO */ -# ifndef CONFIG_SYS_MONAHANS_TURBO_RUN_MODE_RATIO -# define CONFIG_SYS_MONAHANS_TURBO_RUN_MODE_RATIO 0x1 -# endif /* !CONFIG_SYS_MONAHANS_TURBO_RUN_MODE_RATIO */ -#else /* !CONFIG_CPU_MONAHANS */ -#ifdef CONFIG_SYS_CPUSPEED -CC_BASE: .word 0x41300000 -#define CCCR 0x00 -cpuspeed: .word CONFIG_SYS_CPUSPEED -#else /* !CONFIG_SYS_CPUSPEED */ -#error "You have to define CONFIG_SYS_CPUSPEED!!" -#endif /* CONFIG_SYS_CPUSPEED */ -#endif /* CONFIG_CPU_MONAHANS */ - - /* takes care the CP15 update has taken place */ - .macro CPWAIT reg - mrc p15,0,\reg,c2,c0,0 - mov \reg,\reg - sub pc,pc,#4 - .endm - -cpu_init_crit: - - /* mask all IRQs */ -#ifndef CONFIG_CPU_MONAHANS - ldr r0, IC_BASE - mov r1, #0x00 - str r1, [r0, #ICMR] -#else /* CONFIG_CPU_MONAHANS */ - /* Step 1 - Enable CP6 permission */ - mrc p15, 0, r1, c15, c1, 0 @ read CPAR - orr r1, r1, #0x40 - mcr p15, 0, r1, c15, c1, 0 - CPWAIT r1 - - /* Step 2 - Mask ICMR & ICMR2 */ - mov r1, #0 - mcr p6, 0, r1, c1, c0, 0 @ ICMR - mcr p6, 0, r1, c7, c0, 0 @ ICMR2 - - /* turn off all clocks but the ones we will definitly require */ - ldr r1, =CKENA - ldr r2, =(CKENA_22_FFUART | CKENA_10_SRAM | CKENA_9_SMC | CKENA_8_DMC) - str r2, [r1] - ldr r1, =CKENB - ldr r2, =(CKENB_6_IRQ) - str r2, [r1] -#endif /* !CONFIG_CPU_MONAHANS */ - - /* set clock speed */ -#ifdef CONFIG_CPU_MONAHANS - ldr r0, =ACCR - ldr r1, =(((CONFIG_SYS_MONAHANS_TURBO_RUN_MODE_RATIO<<8) & ACCR_XN_MASK) | (CONFIG_SYS_MONAHANS_RUN_MODE_OSC_RATIO & ACCR_XL_MASK)) - str r1, [r0] -#else /* !CONFIG_CPU_MONAHANS */ -#ifdef CONFIG_SYS_CPUSPEED - ldr r0, CC_BASE - ldr r1, cpuspeed - str r1, [r0, #CCCR] - mov r0, #2 - mcr p14, 0, r0, c6, c0, 0 - -setspeed_done: - -#endif /* CONFIG_SYS_CPUSPEED */ -#endif /* CONFIG_CPU_MONAHANS */ - - /* - * before relocating, we have to setup RAM timing - * because memory timing is board-dependend, you will - * find a lowlevel_init.S in your board directory. - */ - mov ip, lr - bl lowlevel_init - mov lr, ip - - /* Memory interfaces are working. Disable MMU and enable I-cache. */ - /* mk: hmm, this is not in the monahans docs, leave it now but - * check here if it doesn't work :-) */ - - ldr r0, =0x2001 /* enable access to all coproc. */ - mcr p15, 0, r0, c15, c1, 0 - CPWAIT r0 + /* Point stack at the end of SRAM and leave 32 words for abort-stack */ + ldr sp, =0x5c03ff80
- mcr p15, 0, r0, c7, c10, 4 /* drain the write & fill buffers */ - CPWAIT r0 + /* Start OneNAND IPL */ + ldr pc, =start_oneboot
- mcr p15, 0, r0, c7, c7, 0 /* flush Icache, Dcache and BTB */ - CPWAIT r0 - - mcr p15, 0, r0, c8, c7, 0 /* flush instuction and data TLBs */ - CPWAIT r0 - - /* Enable the Icache */ -/* - mrc p15, 0, r0, c1, c0, 0 - orr r0, r0, #0x1800 - mcr p15, 0, r0, c1, c0, 0 - CPWAIT -*/ - mov pc, lr +#endif /* #if !defined(CONFIG_ONENAND_IPL) */
#ifndef CONFIG_PRELOADER /****************************************************************************/ @@ -676,6 +566,12 @@ fiq: /* perform a watchdog timeout for a soft reset. */ /* */ /****************************************************************************/ +/* Operating System Timer */ +OSTIMER_BASE: .word 0x40a00000 +#define OSMR3 0x0C +#define OSCR 0x10 +#define OWER 0x18 +#define OIER 0x1C
.align 5 .globl reset_cpu @@ -703,3 +599,25 @@ reset_cpu: reset_endless:
b reset_endless + +#ifndef CONFIG_PRELOADER +.section .mmudata, "a" + .align 14 + .globl mmu_table +mmu_table: + /* 0x00000000 - 0xa0000000 : 1:1, uncached mapping */ + .set __base, 0 + .rept 0xa00 + .word (__base << 20) | 0xc12 + .set __base, __base + 1 + .endr + + /* 0xa0000000 - 0xa0100000 : 1:1, cached mapping */ + .word (0xa00 << 20) | 0x1c1e + + .set __base, 0xa01 + .rept 0x1000 - 0xa01 + .word (__base << 20) | 0xc12 + .set __base, __base + 1 + .endr +#endif
Signed-off-by: Marek Vasut marek.vasut@gmail.com --- board/vpac270/Makefile | 10 ++++------ board/vpac270/config.mk | 1 - board/vpac270/lowlevel_init.S | 39 --------------------------------------- board/vpac270/vpac270.c | 10 ++++++---- include/configs/vpac270.h | 6 +++--- 5 files changed, 13 insertions(+), 53 deletions(-) delete mode 100644 board/vpac270/config.mk delete mode 100644 board/vpac270/lowlevel_init.S
diff --git a/board/vpac270/Makefile b/board/vpac270/Makefile index f5014fc..c359917 100644 --- a/board/vpac270/Makefile +++ b/board/vpac270/Makefile @@ -24,17 +24,15 @@ include $(TOPDIR)/config.mk LIB = $(obj)lib$(BOARD).a
COBJS := vpac270.o -SOBJS := lowlevel_init.o
-SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +SRCS := $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS))
-$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(AR) $(ARFLAGS) $@ $(OBJS) $(SOBJS) +$(LIB): $(obj).depend $(OBJS) + $(AR) $(ARFLAGS) $@ $(OBJS)
clean: - rm -f $(SOBJS) $(OBJS) + rm -f $(OBJS)
distclean: clean rm -f $(LIB) core *.bak $(obj).depend diff --git a/board/vpac270/config.mk b/board/vpac270/config.mk deleted file mode 100644 index 0f10662..0000000 --- a/board/vpac270/config.mk +++ /dev/null @@ -1 +0,0 @@ -CONFIG_SYS_TEXT_BASE = 0xa1000000 diff --git a/board/vpac270/lowlevel_init.S b/board/vpac270/lowlevel_init.S deleted file mode 100644 index c40d12f..0000000 --- a/board/vpac270/lowlevel_init.S +++ /dev/null @@ -1,39 +0,0 @@ -/* - * Voipac PXA270 Lowlevel Hardware Initialization - * - * Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <config.h> -#include <version.h> -#include <asm/arch/pxa-regs.h> -#include <asm/arch/macro.h> - -.globl lowlevel_init -lowlevel_init: - pxa_gpio_setup - pxa_wait_ticks 0x8000 - pxa_mem_setup - pxa_wakeup - pxa_intr_setup - pxa_clock_setup - - mov pc, lr diff --git a/board/vpac270/vpac270.c b/board/vpac270/vpac270.c index f91ff97..91d8580 100644 --- a/board/vpac270/vpac270.c +++ b/board/vpac270/vpac270.c @@ -32,6 +32,10 @@ DECLARE_GLOBAL_DATA_PTR; */ int board_init(void) { + /* We have RAM, disable cache */ + dcache_disable(); + icache_disable(); + /* memory and cpu-speed are setup before relocation */ /* so we do _nothing_ here */
@@ -49,13 +53,11 @@ struct serial_device *default_serial_console(void) return &serial_ffuart_device; }
- +extern void pxa_dram_init(void); int dram_init(void) { + pxa_dram_init(); gd->ram_size = PHYS_SDRAM_1_SIZE; -#ifdef CONFIG_256M_U_BOOT - gd->ram_size += PHYS_SDRAM_2_SIZE; -#endif return 0; }
diff --git a/include/configs/vpac270.h b/include/configs/vpac270.h index 1bcd2f3..1923a17 100644 --- a/include/configs/vpac270.h +++ b/include/configs/vpac270.h @@ -34,7 +34,7 @@ #define CONFIG_ENV_OVERWRITE #define CONFIG_SYS_MALLOC_LEN (128*1024) #define CONFIG_SYS_GBL_DATA_SIZE 128 - +#define CONFIG_ARCH_CPU_INIT #define CONFIG_BOOTCOMMAND \ "if mmc init && fatload mmc 0 0xa4000000 uImage; then " \ "bootm 0xa4000000; " \ @@ -51,7 +51,7 @@ #define CONFIG_BOOTDELAY 2 /* Autoboot delay */ #define CONFIG_CMDLINE_TAG #define CONFIG_SETUP_MEMORY_TAGS - +#define CONFIG_SYS_TEXT_BASE 0x0 #define CONFIG_LZMA /* LZMA compression support */
/* @@ -183,7 +183,7 @@ #define CONFIG_SYS_LOAD_ADDR (0x5c000000) #define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 #define CONFIG_SYS_INIT_SP_ADDR \ - (CONFIG_SYS_GBL_DATA_SIZE + CONFIG_STACKSIZE + PHYS_SDRAM_1) + (PHYS_SDRAM_1 + CONFIG_SYS_GBL_DATA_SIZE + 2048)
/* * NOR FLASH
Signed-off-by: Marek Vasut marek.vasut@gmail.com --- board/zipitz2/Makefile | 10 ++++------ board/zipitz2/config.mk | 1 - board/zipitz2/lowlevel_init.S | 40 ---------------------------------------- board/zipitz2/zipitz2.c | 24 ++++++++++++------------ include/configs/zipitz2.h | 9 +++++---- 5 files changed, 21 insertions(+), 63 deletions(-) delete mode 100644 board/zipitz2/config.mk delete mode 100644 board/zipitz2/lowlevel_init.S
diff --git a/board/zipitz2/Makefile b/board/zipitz2/Makefile index 2673835..8d452de 100644 --- a/board/zipitz2/Makefile +++ b/board/zipitz2/Makefile @@ -29,17 +29,15 @@ include $(TOPDIR)/config.mk LIB = $(obj)lib$(BOARD).a
COBJS := zipitz2.o -SOBJS := lowlevel_init.o
distclean: clean rm -f $(LIB) core *.bak $(obj).depend diff --git a/board/zipitz2/config.mk b/board/zipitz2/config.mk deleted file mode 100644 index 0f10662..0000000 --- a/board/zipitz2/config.mk +++ /dev/null @@ -1 +0,0 @@ -CONFIG_SYS_TEXT_BASE = 0xa1000000 diff --git a/board/zipitz2/lowlevel_init.S b/board/zipitz2/lowlevel_init.S deleted file mode 100644 index 82a52e8..0000000 --- a/board/zipitz2/lowlevel_init.S +++ /dev/null @@ -1,40 +0,0 @@ -/* - * Aeronix Zipit Z2 Lowlevel Hardware Initialization - * - * Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com - * - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <config.h> -#include <version.h> -#include <asm/arch/pxa-regs.h> -#include <asm/arch/macro.h> - -.globl lowlevel_init -lowlevel_init: - pxa_gpio_setup - pxa_wait_ticks 0x8000 - pxa_mem_setup - pxa_wakeup - pxa_intr_setup - pxa_clock_setup - - mov pc, lr diff --git a/board/zipitz2/zipitz2.c b/board/zipitz2/zipitz2.c index f7edc4c..9e6a0d5 100644 --- a/board/zipitz2/zipitz2.c +++ b/board/zipitz2/zipitz2.c @@ -44,10 +44,11 @@ inline void lcd_start(void) {};
int board_init (void) { - /* memory and cpu-speed are setup before relocation */ - /* so we do _nothing_ here */ + /* We have RAM, disable cache */ + dcache_disable(); + icache_disable();
- /* arch number of Lubbock-Board */ + /* arch number of Z2 */ gd->bd->bi_arch_number = MACH_TYPE_ZIPIT2;
/* adress of boot parameters */ @@ -59,24 +60,23 @@ int board_init (void) return 0; }
-int board_late_init(void) +struct serial_device *default_serial_console (void) { - setenv("stdout", "serial"); - setenv("stderr", "serial"); - return 0; + return &serial_stuart_device; }
-struct serial_device *default_serial_console (void) +extern void pxa_dram_init(void); +int dram_init(void) { - return &serial_stuart_device; + pxa_dram_init(); + gd->ram_size = PHYS_SDRAM_1_SIZE; + return 0; }
-int dram_init (void) +void dram_init_banksize(void) { gd->bd->bi_dram[0].start = PHYS_SDRAM_1; gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; - - return 0; }
#ifdef CONFIG_CMD_SPI diff --git a/include/configs/zipitz2.h b/include/configs/zipitz2.h index 642c575..ce65d1f 100644 --- a/include/configs/zipitz2.h +++ b/include/configs/zipitz2.h @@ -41,8 +41,9 @@ #define CONFIG_ENV_ADDR 0x40000 #define CONFIG_ENV_SIZE 0x20000
-#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + CONFIG_STACKSIZE) +#define CONFIG_SYS_MALLOC_LEN (128*1024) #define CONFIG_SYS_GBL_DATA_SIZE 512 +#define CONFIG_ARCH_CPU_INIT
#define CONFIG_BOOTCOMMAND \ "if mmc init && fatload mmc 0 0xa0000000 uboot.script ; then " \ @@ -56,7 +57,7 @@ #define CONFIG_BOOTDELAY 2 /* Autoboot delay */ #define CONFIG_CMDLINE_TAG #define CONFIG_SETUP_MEMORY_TAGS - +#define CONFIG_SYS_TEXT_BASE 0x0 #define CONFIG_LZMA /* LZMA compression support */
/* @@ -176,7 +177,7 @@ unsigned char zipitz2_spi_read(void); #define CONFIG_SYS_LOAD_ADDR CONFIG_SYS_DRAM_BASE
#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 -#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_GBL_DATA_SIZE + PHYS_SDRAM_1) +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_GBL_DATA_SIZE + PHYS_SDRAM_1 + 2048)
/* * NOR FLASH @@ -221,7 +222,7 @@ unsigned char zipitz2_spi_read(void); #define CONFIG_SYS_GPCR3_VAL 0x00000000 #define CONFIG_SYS_GPDR0_VAL 0xdafcee00 #define CONFIG_SYS_GPDR1_VAL 0xffa3aaab -#define CONFIG_SYS_GPDR2_VAL 0x8fe1ffff +#define CONFIG_SYS_GPDR2_VAL 0x8fe9ffff #define CONFIG_SYS_GPDR3_VAL 0x001b1f8a #define CONFIG_SYS_GPSR0_VAL 0x06080400 #define CONFIG_SYS_GPSR1_VAL 0x007f0000
Signed-off-by: Marek Vasut marek.vasut@gmail.com --- board/balloon3/Makefile | 10 +++---- board/balloon3/balloon3.c | 14 ++++++++- board/balloon3/config.mk | 1 - board/balloon3/lowlevel_init.S | 36 -------------------------- board/balloon3/u-boot.lds | 55 ---------------------------------------- include/configs/balloon3.h | 10 ++++--- 6 files changed, 22 insertions(+), 104 deletions(-) delete mode 100644 board/balloon3/config.mk delete mode 100644 board/balloon3/lowlevel_init.S delete mode 100644 board/balloon3/u-boot.lds
diff --git a/board/balloon3/Makefile b/board/balloon3/Makefile index 3928e1f..7db615e 100644 --- a/board/balloon3/Makefile +++ b/board/balloon3/Makefile @@ -24,17 +24,15 @@ include $(TOPDIR)/config.mk LIB = $(obj)lib$(BOARD).a
COBJS := balloon3.o -SOBJS := lowlevel_init.o
distclean: clean rm -f $(LIB) core *.bak $(obj).depend diff --git a/board/balloon3/balloon3.c b/board/balloon3/balloon3.c index 2d6eabe..26e34e9 100644 --- a/board/balloon3/balloon3.c +++ b/board/balloon3/balloon3.c @@ -36,6 +36,10 @@ void balloon3_init_fpga(void);
int board_init(void) { + /* We have RAM, disable cache */ + dcache_disable(); + icache_disable(); + /* arch number of vpac270 */ gd->bd->bi_arch_number = MACH_TYPE_BALLOON3;
@@ -53,8 +57,16 @@ struct serial_device *default_serial_console(void) return &serial_stuart_device; }
+extern void pxa_dram_init(void); int dram_init(void) { + pxa_dram_init(); + gd->ram_size = PHYS_SDRAM_1_SIZE; + return 0; +} + +void dram_init_banksize(void) +{ gd->bd->bi_dram[0].start = PHYS_SDRAM_1; gd->bd->bi_dram[1].start = PHYS_SDRAM_2; gd->bd->bi_dram[2].start = PHYS_SDRAM_3; @@ -62,8 +74,6 @@ int dram_init(void) gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; gd->bd->bi_dram[1].size = PHYS_SDRAM_2_SIZE; gd->bd->bi_dram[2].size = PHYS_SDRAM_3_SIZE; - - return 0; }
#ifdef CONFIG_CMD_USB diff --git a/board/balloon3/config.mk b/board/balloon3/config.mk deleted file mode 100644 index 1d650ac..0000000 --- a/board/balloon3/config.mk +++ /dev/null @@ -1 +0,0 @@ -TEXT_BASE = 0xa1000000 diff --git a/board/balloon3/lowlevel_init.S b/board/balloon3/lowlevel_init.S deleted file mode 100644 index d7b5be6..0000000 --- a/board/balloon3/lowlevel_init.S +++ /dev/null @@ -1,36 +0,0 @@ -/* - * Balloon3 Lowlevel Hardware Initialization - * - * Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <config.h> -#include <version.h> -#include <asm/arch/pxa-regs.h> -#include <asm/arch/macro.h> - -.globl lowlevel_init -lowlevel_init: - pxa_gpio_setup - pxa_wait_ticks 0x8000 - pxa_mem_setup - pxa_wakeup - pxa_intr_setup - pxa_clock_setup - - mov pc, lr diff --git a/board/balloon3/u-boot.lds b/board/balloon3/u-boot.lds deleted file mode 100644 index 58c371d..0000000 --- a/board/balloon3/u-boot.lds +++ /dev/null @@ -1,55 +0,0 @@ -/* - * (C) Copyright 2000 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") -OUTPUT_ARCH(arm) -ENTRY(_start) -SECTIONS -{ - . = 0x00000000; - - . = ALIGN(4); - .text : - { - cpu/pxa/start.o (.text) - *(.text) - } - - . = ALIGN(4); - .rodata : { *(.rodata) } - - . = ALIGN(4); - .data : { *(.data) } - - . = ALIGN(4); - .got : { *(.got) } - - __u_boot_cmd_start = .; - .u_boot_cmd : { *(.u_boot_cmd) } - __u_boot_cmd_end = .; - - . = ALIGN(4); - __bss_start = .; - .bss : { *(.bss) } - _end = .; -} diff --git a/include/configs/balloon3.h b/include/configs/balloon3.h index 5e2a285..ae60f2e 100644 --- a/include/configs/balloon3.h +++ b/include/configs/balloon3.h @@ -34,18 +34,19 @@ #define CONFIG_ENV_OVERWRITE #define CONFIG_SYS_MALLOC_LEN (128*1024) #define CONFIG_SYS_GBL_DATA_SIZE 128 - +#define CONFIG_ARCH_CPU_INIT #define CONFIG_BOOTCOMMAND \ + "fpga load 0x0 0x50000 0x62638; " \ "if usb reset && fatload usb 0 0xa4000000 uImage; then " \ "bootm 0xa4000000; " \ "fi; " \ - "bootm 0x40000;" + "bootm 0xd0000;" #define CONFIG_BOOTARGS "console=tty0 console=ttyS2,115200" #define CONFIG_TIMESTAMP #define CONFIG_BOOTDELAY 2 /* Autoboot delay */ #define CONFIG_CMDLINE_TAG #define CONFIG_SETUP_MEMORY_TAGS - +#define CONFIG_SYS_TEXT_BASE 0x0 #define CONFIG_LZMA /* LZMA compression support */
/* @@ -131,7 +132,8 @@ #define CONFIG_SYS_LOAD_ADDR 0xa1000000
#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 -#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_GBL_DATA_SIZE + PHYS_SDRAM_1) +#define CONFIG_SYS_INIT_SP_ADDR \ + (PHYS_SDRAM_1 + CONFIG_SYS_GBL_DATA_SIZE + 2048)
/* * NOR FLASH
NOTE: The modification in Makefile will be superseded by a pending patch!
Signed-off-by: Marek Vasut marek.vasut@gmail.com --- Makefile | 2 ++ include/configs/vpac270.h | 3 ++- onenand_ipl/board/vpac270/Makefile | 5 +++-- 3 files changed, 7 insertions(+), 3 deletions(-)
diff --git a/Makefile b/Makefile index 0d2d34a..47e9057 100644 --- a/Makefile +++ b/Makefile @@ -1027,6 +1027,8 @@ vpac270_onenand_config : unconfig @if [ "$(findstring onenand,$@)" ] ; then \ echo "#define CONFIG_ONENAND_U_BOOT" \ >>$(obj)include/config.h ; \ + echo "#define CONFIG_256M_U_BOOT" \ + >>$(obj)include/config.h ; \ fi; @if [ "$(findstring 256M,$@)" ] ; then \ echo "#define CONFIG_256M_U_BOOT" \ diff --git a/include/configs/vpac270.h b/include/configs/vpac270.h index 1923a17..fc680fc 100644 --- a/include/configs/vpac270.h +++ b/include/configs/vpac270.h @@ -180,7 +180,8 @@ #define CONFIG_SYS_MEMTEST_START 0xa0400000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0xa0800000 /* 4 ... 8 MB in DRAM */
-#define CONFIG_SYS_LOAD_ADDR (0x5c000000) +#define CONFIG_SYS_LOAD_ADDR PHYS_SDRAM_1 +#define CONFIG_SYS_IPL_LOAD_ADDR (0x5c000000) #define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 #define CONFIG_SYS_INIT_SP_ADDR \ (PHYS_SDRAM_1 + CONFIG_SYS_GBL_DATA_SIZE + 2048) diff --git a/onenand_ipl/board/vpac270/Makefile b/onenand_ipl/board/vpac270/Makefile index ac7a8f0..a86bc00 100644 --- a/onenand_ipl/board/vpac270/Makefile +++ b/onenand_ipl/board/vpac270/Makefile @@ -1,5 +1,6 @@ -IPL =onenand_ipl + include $(TOPDIR)/config.mk +include $(TOPDIR)/board/$(BOARDDIR)/config.mk
LDSCRIPT= $(TOPDIR)/onenand_ipl/board/$(BOARDDIR)/u-boot.onenand.lds LDFLAGS = -Bstatic -T $(onenandobj)u-boot.lds -Ttext $(CONFIG_SYS_TEXT_BASE) $(PLATFORM_LDFLAGS) @@ -25,7 +26,7 @@ ALL = $(onenandobj)onenand-ipl $(onenandobj)onenand-ipl.bin $(onenandobj)onenand all: $(obj).depend $(ALL)
$(onenandobj)onenand-ipl-2k.bin: $(onenandobj)onenand-ipl - $(OBJCOPY) ${OBJCFLAGS} --pad-to=0x5c040400 -O binary $< $@ + $(OBJCOPY) ${OBJCFLAGS} --pad-to=0x0800 -O binary $< $@
$(onenandobj)onenand-ipl.bin: $(onenandobj)onenand-ipl $(OBJCOPY) ${OBJCFLAGS} -O binary $< $@
Dear Marek Vasut,
In message 1287257810-23609-22-git-send-email-marek.vasut@gmail.com you wrote:
I think you're calling for a merge conflict here, but if you want it that way...
Dear Marek Vasut,
In message 1287257810-23609-1-git-send-email-marek.vasut@gmail.com you wrote:
these are the patches I have prepared for u-boot-testing.git/Makefile-cleanup.
General note: most of the patches affect only PXA. They look OK to me, but I don;t knowmuch about these systems; if you like feel free to add my Acked-by: Wolfgang Denk wd@denx.de
There is one commit that affects common code which I explicitely ACKed.
There are a number of places where lists of register declarations should be replaced by C structs, but this is existing code and (as discussed before) I understand that this is stuff for later work.
You mention above that the patches are "for ... Makefile-cleanu", but it seems you missed most of the relevant changes, so you might want to rebase (as discussed in private communication) against the Makefile-cleanup branch. Basicly this means:
- Rename "TEXT_BASE" into "CONFIG_SYS_TEXT_BASE" - Move the definition of CONFIG_SYS_TEXT_BASE from board/*/config.mk to include/configs/*.h - Remove the (now empty) board/*/config.mk files.
