[U-Boot] [PATCH] Update aristainetos board to Kconfig
aristainetos board was merged in u-boot-imx before Kconfig was integrated, but it is not yet mainline.
Signed-off-by: Stefano Babic sbabic@denx.de CC: Heiko Schocher hs@denx.de --- arch/arm/Kconfig | 4 ++++ board/aristainetos/Kconfig | 19 +++++++++++++++++++ board/aristainetos/MAINTAINERS | 6 ++++++ configs/aristainetos_defconfig | 3 +++ 4 files changed, 32 insertions(+) create mode 100644 board/aristainetos/Kconfig create mode 100644 board/aristainetos/MAINTAINERS create mode 100644 configs/aristainetos_defconfig
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index e385eda..63f8576 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -512,6 +512,9 @@ config TARGET_CGTQMX6EVAL config TARGET_EMBESTMX6BOARDS bool "Support embestmx6boards"
+config TARGET_ARISTAINETOS + bool "Support aristainetos" + config TARGET_MX6QARM2 bool "Support mx6qarm2"
@@ -773,6 +776,7 @@ config TARGET_JORNADA endchoice
source "board/8dtech/eco5pk/Kconfig" +source "board/aristainetos/Kconfig" source "board/Barix/ipam390/Kconfig" source "board/BuR/kwb/Kconfig" source "board/BuR/tseries/Kconfig" diff --git a/board/aristainetos/Kconfig b/board/aristainetos/Kconfig new file mode 100644 index 0000000..58078ea --- /dev/null +++ b/board/aristainetos/Kconfig @@ -0,0 +1,19 @@ +if TARGET_ARISTAINETOS + +config SYS_CPU + string + default "armv7" + +config SYS_BOARD + string + default "aristainetos" + +config SYS_SOC + string + default "mx6" + +config SYS_CONFIG_NAME + string + default "aristainetos" + +endif diff --git a/board/aristainetos/MAINTAINERS b/board/aristainetos/MAINTAINERS new file mode 100644 index 0000000..d45d423 --- /dev/null +++ b/board/aristainetos/MAINTAINERS @@ -0,0 +1,6 @@ +ARISTAINETOS BOARD +M: Heiko Schocher hs@denx.de +S: Maintained +F: board/aristainetos/ +F: include/configs/aristainetos.h +F: configs/aristainetos_defconfig diff --git a/configs/aristainetos_defconfig b/configs/aristainetos_defconfig new file mode 100644 index 0000000..6541865 --- /dev/null +++ b/configs/aristainetos_defconfig @@ -0,0 +1,3 @@ +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/aristainetos/aristainetos.cfg,MX6DL" +CONFIG_ARM=y +CONFIG_TARGET_ARISTAINETOS=y
Hello Stefano,
Am 11.08.2014 10:24, schrieb Stefano Babic:
Signed-off-by: Stefano Babicsbabic@denx.de CC: Heiko Schocherhs@denx.de
Thanks!
Acked-by: Heiko Schocher hs@denx.de
bye, Heiko
Heiko Schocher
Stefano Babic
