[U-Boot] [PATCH] net: phy: Define init routine and register generic phy driver
From: Siva Durga Prasad Paladugu siva.durga.paladugu@xilinx.com
This patch define init routine for generic phy driver and registers it using phy_register as this generic phy driver also needs to be relocated incase of manual reloc.
Signed-off-by: Siva Durga Prasad Paladugu siva.durga.paladugu@xilinx.com Signed-off-by: Michal Simek michal.simek@xilinx.com ---
drivers/net/phy/phy.c | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/drivers/net/phy/phy.c b/drivers/net/phy/phy.c index ae37dd6c1e37..8c4043445e86 100644 --- a/drivers/net/phy/phy.c +++ b/drivers/net/phy/phy.c @@ -458,6 +458,11 @@ static struct phy_driver genphy_driver = { .shutdown = genphy_shutdown, };
+int genphy_init(void) +{ + return phy_register(&genphy_driver); +} + static LIST_HEAD(phy_drivers);
int phy_init(void) @@ -540,6 +545,8 @@ int phy_init(void) #ifdef CONFIG_PHY_FIXED phy_fixed_init(); #endif + genphy_init(); + return 0; }
st 11. 9. 2019 v 11:15 odesÃlatel Michal Simek michal.simek@xilinx.com napsal:
genphy_init();
-- 2.17.1
Applied. M
Michal Simek
Michal Simek
