[U-Boot] [PATCH] do_reset: unify duplicate prototypes
The duplication of the do_reset prototype has gotten out of hand, and they're not all in sync. Unify them all in command.h.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- api/api.c | 3 --- arch/m68k/cpu/mcf5227x/cpu.c | 2 +- arch/m68k/cpu/mcf523x/cpu.c | 2 +- arch/m68k/cpu/mcf52x2/cpu.c | 14 +++++++------- arch/m68k/cpu/mcf532x/cpu.c | 2 +- arch/m68k/cpu/mcf5445x/cpu.c | 2 +- arch/m68k/cpu/mcf547x_8x/cpu.c | 2 +- arch/nios2/cpu/cpu.c | 2 +- arch/powerpc/cpu/mpc85xx/cpu.c | 2 +- arch/powerpc/cpu/ppc4xx/44x_spd_ddr2.c | 1 - arch/powerpc/lib/bootm.c | 1 - board/eltec/bab7xx/bab7xx.c | 3 ++- board/esd/apc405/apc405.c | 1 - board/esd/ar405/ar405.c | 2 -- board/esd/ash405/ash405.c | 1 - board/esd/canbt/canbt.c | 4 ---- board/esd/cpci405/cpci405.c | 1 - board/esd/cpciiser4/cpciiser4.c | 3 --- board/esd/du405/du405.c | 3 --- board/esd/hh405/hh405.c | 1 - board/esd/pci405/pci405.c | 1 - board/esd/plu405/plu405.c | 1 - board/esd/tasreg/tasreg.c | 1 - board/esd/voh405/voh405.c | 1 - board/esd/wuh405/wuh405.c | 2 -- board/freescale/m5249evb/m5249evb.c | 4 ---- board/funkwerk/vovpn-gw/vovpn-gw.c | 2 +- board/prodrive/pdnb3/pdnb3.c | 3 --- board/sacsng/sacsng.c | 2 -- .../xilinx/microblaze-generic/microblaze-generic.c | 3 ++- board/zeus/zeus.c | 1 - common/cmd_boot.c | 2 -- common/cmd_bootm.c | 1 - common/hush.c | 4 +--- common/main.c | 4 ---- include/command.h | 1 + include/exports.h | 1 - lib/vsprintf.c | 2 -- 38 files changed, 21 insertions(+), 67 deletions(-)
diff --git a/api/api.c b/api/api.c index 190ee6a..853f010 100644 --- a/api/api.c +++ b/api/api.c @@ -36,9 +36,6 @@ #define DEBUG #undef DEBUG
-/* U-Boot routines needed */ -extern int do_reset (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]); - /***************************************************************************** * * This is the API core. diff --git a/arch/m68k/cpu/mcf5227x/cpu.c b/arch/m68k/cpu/mcf5227x/cpu.c index 5129a03..09ef1d2 100644 --- a/arch/m68k/cpu/mcf5227x/cpu.c +++ b/arch/m68k/cpu/mcf5227x/cpu.c @@ -33,7 +33,7 @@
DECLARE_GLOBAL_DATA_PTR;
-int do_reset(cmd_tbl_t * cmdtp, bd_t * bd, int flag, int argc, char * const argv[]) +int do_reset(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { volatile rcm_t *rcm = (rcm_t *) (MMAP_RCM); udelay(1000); diff --git a/arch/m68k/cpu/mcf523x/cpu.c b/arch/m68k/cpu/mcf523x/cpu.c index 582aec9..2376f97 100644 --- a/arch/m68k/cpu/mcf523x/cpu.c +++ b/arch/m68k/cpu/mcf523x/cpu.c @@ -34,7 +34,7 @@
-int do_reset(cmd_tbl_t * cmdtp, bd_t * bd, int flag, int argc, char * const argv[]) +int do_reset(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { volatile ccm_t *ccm = (ccm_t *) MMAP_CCM;
diff --git a/arch/m68k/cpu/mcf52x2/cpu.c b/arch/m68k/cpu/mcf52x2/cpu.c index 9fb717c..d43ef2a 100644 --- a/arch/m68k/cpu/mcf52x2/cpu.c +++ b/arch/m68k/cpu/mcf52x2/cpu.c @@ -38,7 +38,7 @@ DECLARE_GLOBAL_DATA_PTR;
#ifdef CONFIG_M5208 -int do_reset(cmd_tbl_t *cmdtp, bd_t *bd, int flag, int argc, char * const argv[]) +int do_reset(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { volatile rcm_t *rcm = (rcm_t *)(MMAP_RCM);
@@ -142,7 +142,7 @@ int checkcpu(void) return 0; }
-int do_reset(cmd_tbl_t * cmdtp, bd_t * bd, int flag, int argc, char * const argv[]) +int do_reset(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { /* Call the board specific reset actions first. */ if(board_reset) { @@ -177,7 +177,7 @@ int watchdog_init(void) #endif
#ifdef CONFIG_M5272 -int do_reset(cmd_tbl_t * cmdtp, bd_t * bd, int flag, int argc, char * const argv[]) +int do_reset(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { volatile wdog_t *wdp = (wdog_t *) (MMAP_WDOG);
@@ -257,7 +257,7 @@ int watchdog_init(void) #endif /* #ifdef CONFIG_M5272 */
#ifdef CONFIG_M5275 -int do_reset(cmd_tbl_t *cmdtp, bd_t *bd, int flag, int argc, char * const argv[]) +int do_reset(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { volatile rcm_t *rcm = (rcm_t *)(MMAP_RCM);
@@ -337,7 +337,7 @@ int checkcpu(void) return 0; }
-int do_reset(cmd_tbl_t * cmdtp, bd_t * bd, int flag, int argc, char * const argv[]) +int do_reset(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { MCFRESET_RCR = MCFRESET_RCR_SOFTRST; return 0; @@ -354,7 +354,7 @@ int checkcpu(void) return 0; }
-int do_reset(cmd_tbl_t * cmdtp, bd_t * bd, int flag, int argc, char * const argv[]) +int do_reset(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { /* enable watchdog, set timeout to 0 and wait */ mbar_writeByte(MCFSIM_SYPCR, 0xc0); @@ -384,7 +384,7 @@ int checkcpu(void) return 0; }
-int do_reset(cmd_tbl_t * cmdtp, bd_t * bd, int flag, int argc, char * const argv[]) +int do_reset(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { /* enable watchdog, set timeout to 0 and wait */ mbar_writeByte(SIM_SYPCR, 0xc0); diff --git a/arch/m68k/cpu/mcf532x/cpu.c b/arch/m68k/cpu/mcf532x/cpu.c index 0af4969..3346784 100644 --- a/arch/m68k/cpu/mcf532x/cpu.c +++ b/arch/m68k/cpu/mcf532x/cpu.c @@ -34,7 +34,7 @@
diff --git a/arch/m68k/cpu/mcf5445x/cpu.c b/arch/m68k/cpu/mcf5445x/cpu.c index 182521c..323a54e 100644 --- a/arch/m68k/cpu/mcf5445x/cpu.c +++ b/arch/m68k/cpu/mcf5445x/cpu.c @@ -34,7 +34,7 @@
-int do_reset(cmd_tbl_t * cmdtp, bd_t * bd, int flag, int argc, char * const argv[]) +int do_reset(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { volatile rcm_t *rcm = (rcm_t *) (MMAP_RCM); udelay(1000); diff --git a/arch/m68k/cpu/mcf547x_8x/cpu.c b/arch/m68k/cpu/mcf547x_8x/cpu.c index f9a4b64..7590f2c 100644 --- a/arch/m68k/cpu/mcf547x_8x/cpu.c +++ b/arch/m68k/cpu/mcf547x_8x/cpu.c @@ -34,7 +34,7 @@
-int do_reset(cmd_tbl_t * cmdtp, bd_t * bd, int flag, int argc, char * const argv[]) +int do_reset(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { volatile gptmr_t *gptmr = (gptmr_t *) (MMAP_GPTMR);
diff --git a/arch/nios2/cpu/cpu.c b/arch/nios2/cpu/cpu.c index d9c6544..ef360ee 100644 --- a/arch/nios2/cpu/cpu.c +++ b/arch/nios2/cpu/cpu.c @@ -40,7 +40,7 @@ int checkcpu (void) return (0); }
-int do_reset(void) +int do_reset(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { disable_interrupts(); /* indirect call to go beyond 256MB limitation of toolchain */ diff --git a/arch/powerpc/cpu/mpc85xx/cpu.c b/arch/powerpc/cpu/mpc85xx/cpu.c index 3f80700..84363a9 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu.c +++ b/arch/powerpc/cpu/mpc85xx/cpu.c @@ -196,7 +196,7 @@ int checkcpu (void)
-int do_reset (cmd_tbl_t *cmdtp, bd_t *bd, int flag, int argc, char * const argv[]) +int do_reset (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { /* Everything after the first generation of PQ3 parts has RSTCR */ #if defined(CONFIG_MPC8540) || defined(CONFIG_MPC8541) || \ diff --git a/arch/powerpc/cpu/ppc4xx/44x_spd_ddr2.c b/arch/powerpc/cpu/ppc4xx/44x_spd_ddr2.c index cf9d66d..3f62e3c 100644 --- a/arch/powerpc/cpu/ppc4xx/44x_spd_ddr2.c +++ b/arch/powerpc/cpu/ppc4xx/44x_spd_ddr2.c @@ -418,7 +418,6 @@ static void test(void); static void DQS_calibration_process(void); #endif #endif -int do_reset (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]);
static unsigned char spd_read(uchar chip, uint addr) { diff --git a/arch/powerpc/lib/bootm.c b/arch/powerpc/lib/bootm.c index 4c3e2fe..116d81b 100644 --- a/arch/powerpc/lib/bootm.c +++ b/arch/powerpc/lib/bootm.c @@ -47,7 +47,6 @@
-extern int do_reset (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]); extern ulong get_effective_memsize(void); static ulong get_sp (void); static void set_clocks_in_mhz (bd_t *kbd); diff --git a/board/eltec/bab7xx/bab7xx.c b/board/eltec/bab7xx/bab7xx.c index f5c9777..ea4897b 100644 --- a/board/eltec/bab7xx/bab7xx.c +++ b/board/eltec/bab7xx/bab7xx.c @@ -184,7 +184,7 @@ void after_reloc (ulong dest_addr) * do_reset is done here because in this case it is board specific, since the * 7xx CPUs can only be reset by external HW (the RTC in this case). */ -void do_reset (cmd_tbl_t * cmdtp, bd_t * bd, int flag, int argc, char * const argv[]) +int do_reset(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { #if defined(CONFIG_RTC_MK48T59) /* trigger watchdog immediately */ @@ -192,6 +192,7 @@ void do_reset (cmd_tbl_t * cmdtp, bd_t * bd, int flag, int argc, char * const ar #else #error "You must define the macro CONFIG_RTC_MK48T59." #endif + return 0; }
/* ------------------------------------------------------------------------- */ diff --git a/board/esd/apc405/apc405.c b/board/esd/apc405/apc405.c index 52477d7..def8a4f 100644 --- a/board/esd/apc405/apc405.c +++ b/board/esd/apc405/apc405.c @@ -38,7 +38,6 @@ DECLARE_GLOBAL_DATA_PTR;
#undef FPGA_DEBUG
-extern int do_reset (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]); extern void lxt971_no_sleep(void);
/* fpga configuration data - gzip compressed and generated by bin2c */ diff --git a/board/esd/ar405/ar405.c b/board/esd/ar405/ar405.c index 8879faf..6ec507f 100644 --- a/board/esd/ar405/ar405.c +++ b/board/esd/ar405/ar405.c @@ -29,8 +29,6 @@
-/*cmd_boot.c*/ -extern int do_reset (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]); extern void lxt971_no_sleep(void);
/* ------------------------------------------------------------------------- */ diff --git a/board/esd/ash405/ash405.c b/board/esd/ash405/ash405.c index ea28090..1b0365e 100644 --- a/board/esd/ash405/ash405.c +++ b/board/esd/ash405/ash405.c @@ -33,7 +33,6 @@ #define FPGA_DEBUG #endif
/* fpga configuration data - gzip compressed and generated by bin2c */ diff --git a/board/esd/canbt/canbt.c b/board/esd/canbt/canbt.c index 0d2d7f1..cc537f2 100644 --- a/board/esd/canbt/canbt.c +++ b/board/esd/canbt/canbt.c @@ -29,10 +29,6 @@
-/*cmd_boot.c*/ -extern int do_reset (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]); - - /* ------------------------------------------------------------------------- */
#if 0 diff --git a/board/esd/cpci405/cpci405.c b/board/esd/cpci405/cpci405.c index 51e10fd..98a8584 100644 --- a/board/esd/cpci405/cpci405.c +++ b/board/esd/cpci405/cpci405.c @@ -32,7 +32,6 @@
-extern int do_reset (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]); extern void __ft_board_setup(void *blob, bd_t *bd);
#undef FPGA_DEBUG diff --git a/board/esd/cpciiser4/cpciiser4.c b/board/esd/cpciiser4/cpciiser4.c index 10a40be..8afc50d 100644 --- a/board/esd/cpciiser4/cpciiser4.c +++ b/board/esd/cpciiser4/cpciiser4.c @@ -28,9 +28,6 @@
-/*cmd_boot.c*/ - -extern int do_reset (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]); extern void lxt971_no_sleep(void);
diff --git a/board/esd/du405/du405.c b/board/esd/du405/du405.c index b1362a8..c32d333 100644 --- a/board/esd/du405/du405.c +++ b/board/esd/du405/du405.c @@ -30,9 +30,6 @@
diff --git a/board/esd/hh405/hh405.c b/board/esd/hh405/hh405.c index c5e9514..e9d2d36 100644 --- a/board/esd/hh405/hh405.c +++ b/board/esd/hh405/hh405.c @@ -236,7 +236,6 @@ static const SMI_REGS init_regs_1024x768 [] = #define FPGA_DEBUG #endif
/* fpga configuration data - gzip compressed and generated by bin2c */ diff --git a/board/esd/pci405/pci405.c b/board/esd/pci405/pci405.c index 4018a7d..c1bac6a 100644 --- a/board/esd/pci405/pci405.c +++ b/board/esd/pci405/pci405.c @@ -34,7 +34,6 @@ DECLARE_GLOBAL_DATA_PTR;
/* Prototypes */ -int do_reset (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]); unsigned long fpga_done_state(void); unsigned long fpga_init_state(void);
diff --git a/board/esd/plu405/plu405.c b/board/esd/plu405/plu405.c index b68ffaf..109d2dc 100644 --- a/board/esd/plu405/plu405.c +++ b/board/esd/plu405/plu405.c @@ -32,7 +32,6 @@
/* fpga configuration data - gzip compressed and generated by bin2c */ diff --git a/board/esd/tasreg/tasreg.c b/board/esd/tasreg/tasreg.c index 270caac..d2488b8 100644 --- a/board/esd/tasreg/tasreg.c +++ b/board/esd/tasreg/tasreg.c @@ -29,7 +29,6 @@
/* Prototypes */ -int do_reset (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]); int i2c_write(uchar chip, uint addr, int alen, uchar *buffer, int len); int i2c_read(uchar chip, uint addr, int alen, uchar *buffer, int len);
diff --git a/board/esd/voh405/voh405.c b/board/esd/voh405/voh405.c index da25212..5f28a48 100644 --- a/board/esd/voh405/voh405.c +++ b/board/esd/voh405/voh405.c @@ -33,7 +33,6 @@ #define FPGA_DEBUG #endif
/* fpga configuration data - gzip compressed and generated by bin2c */ diff --git a/board/esd/wuh405/wuh405.c b/board/esd/wuh405/wuh405.c index 5a65133..d8d4bb5 100644 --- a/board/esd/wuh405/wuh405.c +++ b/board/esd/wuh405/wuh405.c @@ -32,8 +32,6 @@ #define FPGA_DEBUG #endif
-extern int do_reset (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]); - /* fpga configuration data - gzip compressed and generated by bin2c */ const unsigned char fpgadata[] = { diff --git a/board/freescale/m5249evb/m5249evb.c b/board/freescale/m5249evb/m5249evb.c index ac1937b..894873b 100644 --- a/board/freescale/m5249evb/m5249evb.c +++ b/board/freescale/m5249evb/m5249evb.c @@ -26,10 +26,6 @@ #include <malloc.h> #include <asm/immap.h>
- -/* Prototypes */ -int do_reset (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]); - int checkboard (void) { ulong val; uchar val8; diff --git a/board/funkwerk/vovpn-gw/vovpn-gw.c b/board/funkwerk/vovpn-gw/vovpn-gw.c index e856ada..a4bfbc9 100644 --- a/board/funkwerk/vovpn-gw/vovpn-gw.c +++ b/board/funkwerk/vovpn-gw/vovpn-gw.c @@ -306,7 +306,7 @@ int misc_init_r (void)
#if defined(CONFIG_HAVE_OWN_RESET) int -do_reset (void *cmdtp, int flag, int argc, char * const argv[]) +do_reset(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { volatile ioport_t *iop;
diff --git a/board/prodrive/pdnb3/pdnb3.c b/board/prodrive/pdnb3/pdnb3.c index 83b7914..928dd22 100644 --- a/board/prodrive/pdnb3/pdnb3.c +++ b/board/prodrive/pdnb3/pdnb3.c @@ -28,9 +28,6 @@
-/* Prototypes */ -int do_reset(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]); - /* predefine these here for FPGA programming (before including fpga.c) */ #define SET_FPGA(data) *IXP425_GPIO_GPOUTR = (data) #define FPGA_DONE_STATE (*IXP425_GPIO_GPINR & CONFIG_SYS_FPGA_DONE) diff --git a/board/sacsng/sacsng.c b/board/sacsng/sacsng.c index 8edca59..61cab87 100644 --- a/board/sacsng/sacsng.c +++ b/board/sacsng/sacsng.c @@ -38,8 +38,6 @@ extern void eth_loopback_test(void); #endif /* CONFIG_ETHER_LOOPBACK_TEST */
-extern int do_reset(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]); - #include "clkinit.h" #include "ioconfig.h" /* I/O configuration table */
diff --git a/board/xilinx/microblaze-generic/microblaze-generic.c b/board/xilinx/microblaze-generic/microblaze-generic.c index 744384c..183e4dc 100644 --- a/board/xilinx/microblaze-generic/microblaze-generic.c +++ b/board/xilinx/microblaze-generic/microblaze-generic.c @@ -31,7 +31,7 @@ #include <asm/microblaze_intc.h> #include <asm/asm.h>
-void do_reset (void) +int do_reset(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { #ifdef CONFIG_SYS_GPIO_0 *((unsigned long *)(CONFIG_SYS_GPIO_0_ADDR)) = @@ -41,6 +41,7 @@ void do_reset (void) puts ("Reseting board\n"); asm ("bra r0"); #endif + return 0; }
int gpio_init (void) diff --git a/board/zeus/zeus.c b/board/zeus/zeus.c index a29e518..7e33d3f 100644 --- a/board/zeus/zeus.c +++ b/board/zeus/zeus.c @@ -44,7 +44,6 @@ extern uchar default_environment[];
ulong flash_get_size(ulong base, int banknum); void env_crc_update(void); -int do_reset (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]);
static u32 start_time;
diff --git a/common/cmd_boot.c b/common/cmd_boot.c index 72dacaa..7b603d3 100644 --- a/common/cmd_boot.c +++ b/common/cmd_boot.c @@ -67,8 +67,6 @@ U_BOOT_CMD( " passing 'arg' as arguments" );
-extern int do_reset (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]); - U_BOOT_CMD( reset, 1, 0, do_reset, "Perform RESET of the CPU", diff --git a/common/cmd_bootm.c b/common/cmd_bootm.c index db59e6f..ab61eb3 100644 --- a/common/cmd_bootm.c +++ b/common/cmd_bootm.c @@ -93,7 +93,6 @@ static int fit_check_kernel (const void *fit, int os_noffset, int verify);
static void *boot_get_kernel (cmd_tbl_t *cmdtp, int flag,int argc, char * const argv[], bootm_headers_t *images, ulong *os_data, ulong *os_len); -extern int do_reset (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]);
/* * Continue booting an OS image; caller already has: diff --git a/common/hush.c b/common/hush.c index 2482506..e6518c1 100644 --- a/common/hush.c +++ b/common/hush.c @@ -1021,9 +1021,7 @@ static void get_user_input(struct in_str *i) static char the_command[CONFIG_SYS_CBSIZE];
#ifdef CONFIG_BOOT_RETRY_TIME -# ifdef CONFIG_RESET_TO_RETRY - extern int do_reset (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]); -# else +# ifndef CONFIG_RESET_TO_RETRY # error "This currently only works with CONFIG_RESET_TO_RETRY enabled" # endif reset_cmd_timeout(); diff --git a/common/main.c b/common/main.c index bbb208b..878cffd 100644 --- a/common/main.c +++ b/common/main.c @@ -50,10 +50,6 @@ DECLARE_GLOBAL_DATA_PTR; void inline __show_boot_progress (int val) {} void show_boot_progress (int val) __attribute__((weak, alias("__show_boot_progress")));
-#if defined(CONFIG_BOOT_RETRY_TIME) && defined(CONFIG_RESET_TO_RETRY) -extern int do_reset (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]); /* for do_reset() prototype */ -#endif - #if defined(CONFIG_UPDATE_TFTP) void update_tftp (void); #endif /* CONFIG_UPDATE_TFTP */ diff --git a/include/command.h b/include/command.h index 72eab9d..81aa019 100644 --- a/include/command.h +++ b/include/command.h @@ -99,6 +99,7 @@ extern int cmd_get_data_size(char* arg, int default_size); extern int do_bootd(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]); #endif extern int do_bootm(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]); +extern int do_reset(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]);
#endif /* __ASSEMBLY__ */
diff --git a/include/exports.h b/include/exports.h index 7404a7c..6382311 100644 --- a/include/exports.h +++ b/include/exports.h @@ -19,7 +19,6 @@ void free(void*); void __udelay(unsigned long); unsigned long get_timer(unsigned long); int vprintf(const char *, va_list); -void do_reset (void); unsigned long simple_strtoul(const char *cp,char **endp,unsigned int base); char *getenv (char *name); int setenv (char *varname, char *varvalue); diff --git a/lib/vsprintf.c b/lib/vsprintf.c index aa214dd..61e6f0d 100644 --- a/lib/vsprintf.c +++ b/lib/vsprintf.c @@ -17,8 +17,6 @@ #include <common.h> #if !defined (CONFIG_PANIC_HANG) #include <command.h> -/*cmd_boot.c*/ -extern int do_reset (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]); #endif
#include <div64.h>
Dear Mike Frysinger,
Applied to "next" branch, thanks.
Mike Frysinger
