[U-Boot] Please pull u-boot-atmel/master
The following changes since commit 8abcd8ab962cd5fb2a4c025e7c7b62a9faf4aa08:
DaVinci DA8xx: fix set_cpu_clk_info() (2012-08-05 22:02:40 +0200)
git://git.denx.de/u-boot-atmel.git master
for you to fetch changes up to 17cda15fa6fb3ab2433bed951dad5c4ab30d8cbc:
at91: Add support for taskit AT91SAM9G20 boards. (2012-08-07 23:47:29 +0200)
---------------------------------------------------------------- Andreas Bießmann (3): doc/git-mailrc: update at91 and avr32 MAINTAINERS: fix entry of Ilko Iliev MAINTAINERS: fix Andreas Bießmann AVR32 entry
Bo Shen (1): arm : Atmel : add at91sam9x5ek board support
Markus Hubig (2): Enable the EMAC clock in at91_macb_hw_init(). at91: Add support for taskit AT91SAM9G20 boards.
MAINTAINERS | 23 +- arch/arm/cpu/arm926ejs/at91/Makefile | 1 + arch/arm/cpu/arm926ejs/at91/at91sam9260_devices.c | 4 + arch/arm/cpu/arm926ejs/at91/at91sam9x5_devices.c | 232 ++++++++++++++++ arch/arm/cpu/arm926ejs/at91/clock.c | 12 +- arch/arm/include/asm/arch-at91/at91sam9_matrix.h | 2 + arch/arm/include/asm/arch-at91/at91sam9x5.h | 170 ++++++++++++ arch/arm/include/asm/arch-at91/at91sam9x5_matrix.h | 91 ++++++ arch/arm/include/asm/arch-at91/hardware.h | 2 + board/atmel/at91sam9x5ek/Makefile | 52 ++++ board/atmel/at91sam9x5ek/at91sam9x5ek.c | 293 ++++++++++++++++++++ board/atmel/at91sam9x5ek/config.mk | 1 + board/taskit/stamp9g20/Makefile | 53 ++++ board/taskit/stamp9g20/led.c | 138 +++++++++ board/taskit/stamp9g20/stamp9g20.c | 191 +++++++++++++ boards.cfg | 3 + doc/git-mailrc | 5 +- drivers/net/macb.c | 4 +- include/configs/at91sam9x5ek.h | 183 ++++++++++++ include/configs/stamp9g20.h | 266 ++++++++++++++++++ 20 files changed, 1713 insertions(+), 13 deletions(-) create mode 100644 arch/arm/cpu/arm926ejs/at91/at91sam9x5_devices.c create mode 100644 arch/arm/include/asm/arch-at91/at91sam9x5.h create mode 100644 arch/arm/include/asm/arch-at91/at91sam9x5_matrix.h create mode 100644 board/atmel/at91sam9x5ek/Makefile create mode 100644 board/atmel/at91sam9x5ek/at91sam9x5ek.c create mode 100644 board/atmel/at91sam9x5ek/config.mk create mode 100644 board/taskit/stamp9g20/Makefile create mode 100644 board/taskit/stamp9g20/led.c create mode 100644 board/taskit/stamp9g20/stamp9g20.c create mode 100644 include/configs/at91sam9x5ek.h create mode 100644 include/configs/stamp9g20.h
Hi Andreas,
On Wed, 8 Aug 2012 00:29:12 +0200, Andreas Bießmann andreas.devel@googlemail.com wrote:
Applied to u-boot-arm/master, thanks!
Amicalement,
Hi Andreas,
Amicalement,
Albert ARIBAUD
Andreas Bießmann
