[U-Boot-Users] [PATCH 1/3] mpc83xx: unreinvent mem_clk
delete ddr_clk and use mem_clk instead. Rename other ddr_*_clk to mem_*_clk for consistency's sake.
Signed-off-by: Kim Phillips kim.phillips@freescale.com --- cpu/mpc83xx/spd_sdram.c | 10 +++++----- cpu/mpc83xx/speed.c | 16 ++++++++-------- include/asm-ppc/global_data.h | 3 +-- 3 files changed, 14 insertions(+), 15 deletions(-)
diff --git a/cpu/mpc83xx/spd_sdram.c b/cpu/mpc83xx/spd_sdram.c index 0acca47..c9151d7 100644 --- a/cpu/mpc83xx/spd_sdram.c +++ b/cpu/mpc83xx/spd_sdram.c @@ -78,12 +78,12 @@ extern int dma_xfer(void *dest, uint count, void *src); int picos_to_clk(int picos) { - unsigned int ddr_bus_clk; + unsigned int mem_bus_clk; int clks;
- ddr_bus_clk = gd->ddr_clk >> 1; - clks = picos / (1000000000 / (ddr_bus_clk / 1000)); - if (picos % (1000000000 / (ddr_bus_clk / 1000)) != 0) + mem_bus_clk = gd->mem_clk >> 1; + clks = picos / (1000000000 / (mem_bus_clk / 1000)); + if (picos % (1000000000 / (mem_bus_clk / 1000)) != 0) clks++;
return clks; @@ -313,7 +313,7 @@ long int spd_sdram()
debug("DDR:Module maximum data rate is: %dMhz\n", max_data_rate);
- ddrc_clk = gd->ddr_clk / 1000000; + ddrc_clk = gd->mem_clk / 1000000; effective_data_rate = 0;
if (max_data_rate >= 390 && max_data_rate < 460) { /* it is DDR 400 */ diff --git a/cpu/mpc83xx/speed.c b/cpu/mpc83xx/speed.c index f598699..16145dd 100644 --- a/cpu/mpc83xx/speed.c +++ b/cpu/mpc83xx/speed.c @@ -122,9 +122,9 @@ int get_clocks(void) u32 enc_clk; u32 lbiu_clk; u32 lclk_clk; - u32 ddr_clk; + u32 mem_clk; #if defined(CONFIG_MPC8360) - u32 ddr_sec_clk; + u32 mem_sec_clk; #endif #if defined(CONFIG_MPC8360) || defined(CONFIG_MPC832X) u32 qepmf; @@ -400,11 +400,11 @@ int get_clocks(void) return -12; }
- ddr_clk = csb_clk * + mem_clk = csb_clk * (1 + ((im->reset.rcwl & HRCWL_DDRCM) >> HRCWL_DDRCM_SHIFT)); corepll = (im->reset.rcwl & HRCWL_COREPLL) >> HRCWL_COREPLL_SHIFT; #if defined(CONFIG_MPC8360) - ddr_sec_clk = csb_clk * (1 + + mem_sec_clk = csb_clk * (1 + ((im->reset.rcwl & HRCWL_LBIUCM) >> HRCWL_LBIUCM_SHIFT)); #endif
@@ -466,9 +466,9 @@ int get_clocks(void) gd->enc_clk = enc_clk; gd->lbiu_clk = lbiu_clk; gd->lclk_clk = lclk_clk; - gd->ddr_clk = ddr_clk; + gd->mem_clk = mem_clk; #if defined(CONFIG_MPC8360) - gd->ddr_sec_clk = ddr_sec_clk; + gd->mem_sec_clk = mem_sec_clk; #endif #if defined(CONFIG_MPC8360) || defined(CONFIG_MPC832X) gd->qe_clk = qe_clk; @@ -508,9 +508,9 @@ int do_clocks (cmd_tbl_t * cmdtp, int flag, int argc, char *argv[]) #endif printf(" Local Bus Controller:%4d MHz\n", gd->lbiu_clk / 1000000); printf(" Local Bus: %4d MHz\n", gd->lclk_clk / 1000000); - printf(" DDR: %4d MHz\n", gd->ddr_clk / 1000000); + printf(" DDR: %4d MHz\n", gd->mem_clk / 1000000); #if defined(CONFIG_MPC8360) - printf(" DDR Secondary: %4d MHz\n", gd->ddr_sec_clk / 1000000); + printf(" DDR Secondary: %4d MHz\n", gd->mem_sec_clk / 1000000); #endif printf(" SEC: %4d MHz\n", gd->enc_clk / 1000000); printf(" I2C1: %4d MHz\n", gd->i2c1_clk / 1000000); diff --git a/include/asm-ppc/global_data.h b/include/asm-ppc/global_data.h index b43dba3..9ccf7d6 100644 --- a/include/asm-ppc/global_data.h +++ b/include/asm-ppc/global_data.h @@ -74,7 +74,6 @@ typedef struct global_data { u32 enc_clk; u32 lbiu_clk; u32 lclk_clk; - u32 ddr_clk; u32 pci_clk; #if defined(CONFIG_MPC837X) u32 pciexp1_clk; @@ -84,7 +83,7 @@ typedef struct global_data { u32 sata_clk; #endif #if defined(CONFIG_MPC8360) - u32 ddr_sec_clk; + u32 mem_sec_clk; #endif /* CONFIG_MPC8360 */ #endif #if defined(CONFIG_MPC83XX) || defined(CONFIG_MPC85xx) || defined(CONFIG_MPC86xx)
Kim Phillips
