[U-Boot-Users] [PATCH 2/2 (resubmit)] NET: Add Ethernet 1000BASE-X support for PPC4xx
This patch adds a new switch: "CONFIG_PHY_DYNAMIC_ANEG". When this symbol is defined, the PHY will advertise it's capabilities for autonegotiation based on the capabilities shown in the PHY's status registers, including 1000BASE-X. When "CONFIG_PHY_DYNAMIC_ANEG" is not defined, the PHY will advertise hard-coded capabilities, as before.
Signed-off-by: Larry Johnson lrj@acm.org ---
common/miiphyutil.c | 155 +++++++++++++++++++++++++++++++++------------------ include/miiphy.h | 21 +++++++ 2 files changed, 121 insertions(+), 55 deletions(-)
diff --git a/common/miiphyutil.c b/common/miiphyutil.c index 58ebc5e..b2f62d0 100644 --- a/common/miiphyutil.c +++ b/common/miiphyutil.c @@ -344,101 +344,146 @@ int miiphy_reset (char *devname, unsigned char addr)
/***************************************************************************** * - * Determine the ethernet speed (10/100). + * Determine the ethernet speed (10/100/1000). Return 10 on error. */ int miiphy_speed (char *devname, unsigned char addr) { - unsigned short reg; + u16 bmcr;
#if defined(CONFIG_PHY_GIGE) - if (miiphy_read (devname, addr, PHY_1000BTSR, ®)) { - printf ("PHY 1000BT Status read failed\n"); - } else { - if (reg != 0xFFFF) { - if ((reg & (PHY_1000BTSR_1000FD | PHY_1000BTSR_1000HD)) - != 0) { - return (_1000BASET); - } + u16 btsr; + +#if defined(CONFIG_PHY_DYNAMIC_ANEG) + u16 bmsr, exsr; + + /* Check for 1000BASE-X. */ + if (miiphy_read (devname, addr, PHY_BMSR, &bmsr)) { + printf ("PHY status"); + goto miiphy_read_failed; + } + if (bmsr & PHY_BMSR_EXT_STAT) { + + if (miiphy_read (devname, addr, PHY_EXSR, &exsr)) { + printf ("PHY extended status"); + goto miiphy_read_failed; + } + if (exsr & (PHY_EXSR_1000XF | PHY_EXSR_1000XH)) { + /* 1000BASE-X */ + return _1000BASET; } } +#endif /* defined(CONFIG_PHY_DYNAMIC_ANEG) */ + + /* Check for 1000BASE-T. */ + if (miiphy_read (devname, addr, PHY_1000BTSR, &btsr)) { + printf ("PHY 1000BT status"); + goto miiphy_read_failed; + } + if (btsr != 0xFFFF && + (btsr & (PHY_1000BTSR_1000FD | PHY_1000BTSR_1000HD))) { + return _1000BASET; + } #endif /* CONFIG_PHY_GIGE */
/* Check Basic Management Control Register first. */ - if (miiphy_read (devname, addr, PHY_BMCR, ®)) { - puts ("PHY speed read failed, assuming 10bT\n"); - return (_10BASET); + if (miiphy_read (devname, addr, PHY_BMCR, &bmcr)) { + printf ("PHY speed"); + goto miiphy_read_failed; } /* Check if auto-negotiation is on. */ - if ((reg & PHY_BMCR_AUTON) != 0) { + if (bmcr & PHY_BMCR_AUTON) { /* Get auto-negotiation results. */ - if (miiphy_read (devname, addr, PHY_ANLPAR, ®)) { - puts ("PHY AN speed read failed, assuming 10bT\n"); - return (_10BASET); - } - if ((reg & PHY_ANLPAR_100) != 0) { - return (_100BASET); - } else { - return (_10BASET); + u16 anlpar; + + if (miiphy_read (devname, addr, PHY_ANLPAR, &anlpar)) { + printf ("PHY AN speed"); + goto miiphy_read_failed; } + return (anlpar & PHY_ANLPAR_100) ? _100BASET : _10BASET; } /* Get speed from basic control settings. */ - else if (reg & PHY_BMCR_100MB) { - return (_100BASET); - } else { - return (_10BASET); - } + return (bmcr & PHY_BMCR_100MB) ? _100BASET : _10BASET;
+ miiphy_read_failed: + printf (" read failed, assuming 10BASE-T\n"); + return _10BASET; }
/***************************************************************************** * - * Determine full/half duplex. + * Determine full/half duplex. Return half on error. */ int miiphy_duplex (char *devname, unsigned char addr) { - unsigned short reg; + u16 bmcr;
#if defined(CONFIG_PHY_GIGE) - if (miiphy_read (devname, addr, PHY_1000BTSR, ®)) { - printf ("PHY 1000BT Status read failed\n"); - } else { - if ((reg != 0xFFFF) && - (reg & (PHY_1000BTSR_1000FD | PHY_1000BTSR_1000HD))) { - if ((reg & PHY_1000BTSR_1000FD) != 0) { - return (FULL); - } else { - return (HALF); + u16 btsr; + +#if defined(CONFIG_PHY_DYNAMIC_ANEG) + u16 bmsr, exsr; + + /* Check for 1000BASE-X. */ + if (miiphy_read (devname, addr, PHY_BMSR, &bmsr)) { + printf ("PHY status"); + goto miiphy_read_failed; + } + if (bmsr & PHY_BMSR_EXT_STAT) { + + if (miiphy_read (devname, addr, PHY_EXSR, &exsr)) { + printf ("PHY extended status"); + goto miiphy_read_failed; + } + if (exsr & (PHY_EXSR_1000XF | PHY_EXSR_1000XH)) { + /* 1000BASE-X */ + u16 anlpar; + + if (miiphy_read (devname, addr, PHY_ANLPAR, &anlpar)) { + printf ("1000BASE-X PHY AN duplex"); + goto miiphy_read_failed; } + return (anlpar & PHY_X_ANLPAR_FD) ? FULL : HALF; + } + } +#endif /* defined(CONFIG_PHY_DYNAMIC_ANEG) */ + + /* Check for 1000BASE-T. */ + if (miiphy_read (devname, addr, PHY_1000BTSR, &btsr)) { + printf ("PHY 1000BT status"); + goto miiphy_read_failed; + } + if (btsr != 0xFFFF) { + if (btsr & PHY_1000BTSR_1000FD) { + return FULL; + } else if (btsr & PHY_1000BTSR_1000HD) { + return HALF; } } #endif /* CONFIG_PHY_GIGE */
/* Check Basic Management Control Register first. */ - if (miiphy_read (devname, addr, PHY_BMCR, ®)) { - puts ("PHY duplex read failed, assuming half duplex\n"); - return (HALF); + if (miiphy_read (devname, addr, PHY_BMCR, &bmcr)) { + puts ("PHY duplex"); + goto miiphy_read_failed; } /* Check if auto-negotiation is on. */ - if ((reg & PHY_BMCR_AUTON) != 0) { + if (bmcr & PHY_BMCR_AUTON) { /* Get auto-negotiation results. */ - if (miiphy_read (devname, addr, PHY_ANLPAR, ®)) { - puts ("PHY AN duplex read failed, assuming half duplex\n"); - return (HALF); - } + u16 anlpar;
- if ((reg & (PHY_ANLPAR_10FD | PHY_ANLPAR_TXFD)) != 0) { - return (FULL); - } else { - return (HALF); + if (miiphy_read (devname, addr, PHY_ANLPAR, &anlpar)) { + puts ("PHY AN duplex"); + goto miiphy_read_failed; } + return (anlpar & (PHY_ANLPAR_10FD | PHY_ANLPAR_TXFD)) ? + FULL : HALF; } /* Get speed from basic control settings. */ - else if (reg & PHY_BMCR_DPLX) { - return (FULL); - } else { - return (HALF); - } + return (bmcr & PHY_BMCR_DPLX) ? FULL : HALF;
+ miiphy_read_failed: + printf (" read failed, assuming half duplex\n"); + return HALF; }
#ifdef CFG_FAULT_ECHO_LINK_DOWN diff --git a/include/miiphy.h b/include/miiphy.h index 42f2ad0..83234b9 100644 --- a/include/miiphy.h +++ b/include/miiphy.h @@ -85,6 +85,7 @@ int bb_miiphy_write (char *devname, unsigned char addr, #define PHY_ANLPNP 0x08 #define PHY_1000BTCR 0x09 #define PHY_1000BTSR 0x0A +#define PHY_EXSR 0x0F #define PHY_PHYSTS 0x10 #define PHY_MIPSCR 0x11 #define PHY_MIPGSR 0x12 @@ -118,6 +119,7 @@ int bb_miiphy_write (char *devname, unsigned char addr, #define PHY_BMSR_100TXH 0x2000 #define PHY_BMSR_10TF 0x1000 #define PHY_BMSR_10TH 0x0800 +#define PHY_BMSR_EXT_STAT 0x0100 #define PHY_BMSR_PRE_SUP 0x0040 #define PHY_BMSR_AUTN_COMP 0x0020 #define PHY_BMSR_RF 0x0010 @@ -130,17 +132,30 @@ int bb_miiphy_write (char *devname, unsigned char addr, #define PHY_ANLPAR_NP 0x8000 #define PHY_ANLPAR_ACK 0x4000 #define PHY_ANLPAR_RF 0x2000 +#define PHY_ANLPAR_ASYMP 0x0800 +#define PHY_ANLPAR_PAUSE 0x0400 #define PHY_ANLPAR_T4 0x0200 #define PHY_ANLPAR_TXFD 0x0100 #define PHY_ANLPAR_TX 0x0080 #define PHY_ANLPAR_10FD 0x0040 #define PHY_ANLPAR_10 0x0020 #define PHY_ANLPAR_100 0x0380 /* we can run at 100 */ +/* phy ANLPAR 1000BASE-X */ +#define PHY_X_ANLPAR_NP 0x8000 +#define PHY_X_ANLPAR_ACK 0x4000 +#define PHY_X_ANLPAR_RF_MASK 0x3000 +#define PHY_X_ANLPAR_PAUSE_MASK 0x0180 +#define PHY_X_ANLPAR_HD 0x0040 +#define PHY_X_ANLPAR_FD 0x0020
#define PHY_ANLPAR_PSB_MASK 0x001f #define PHY_ANLPAR_PSB_802_3 0x0001 #define PHY_ANLPAR_PSB_802_9 0x0002
+/* phy 1000BTCR */ +#define PHY_1000BTCR_1000FD 0x0200 +#define PHY_1000BTCR_1000HD 0x0100 + /* phy 1000BTSR */ #define PHY_1000BTSR_MSCF 0x8000 #define PHY_1000BTSR_MSCR 0x4000 @@ -149,4 +164,10 @@ int bb_miiphy_write (char *devname, unsigned char addr, #define PHY_1000BTSR_1000FD 0x0800 #define PHY_1000BTSR_1000HD 0x0400
+/* phy EXSR */ +#define PHY_EXSR_1000XF 0x8000 +#define PHY_EXSR_1000XH 0x4000 +#define PHY_EXSR_1000TF 0x2000 +#define PHY_EXSR_1000TH 0x1000 + #endif
Larry,
I think this can be simplified a bit. More later on...
- Determine the ethernet speed (10/100).
- Determine the ethernet speed (10/100/1000). Return 10 on error.
- u16 bmcr;
- } else {
!= 0) {
- u16 btsr;
I don't think you need this CONFIG. It doesn't really do anything.
- u16 bmsr, exsr;
- /* Check for 1000BASE-X. */
- if (miiphy_read (devname, addr, PHY_BMSR, &bmsr)) {
- if (bmsr & PHY_BMSR_EXT_STAT) {
/* 1000BASE-X */
return _1000BASET;
Per IEEE 802.3-2005, All PHYs with capabilities > 100Mbps must have PHY_MBSR_EXT_STAT set, and EXSR contains capability info for 1000BX and 1000BT, so you can check for all four here. Please correct me if I'm wrong.
- /* Check for 1000BASE-T. */
- if (miiphy_read (devname, addr, PHY_1000BTSR, &btsr)) {
- if (btsr != 0xFFFF &&
return _1000BASET;
And then you don't need to check 1000BTSR
return (_10BASET);
- if (miiphy_read (devname, addr, PHY_BMCR, &bmcr)) {
} /* Check if auto-negotiation is on. */goto miiphy_read_failed;
- if (bmcr & PHY_BMCR_AUTON) { /* Get auto-negotiation results. */
return (_10BASET);
return (_100BASET);
} else {
return (_10BASET);
u16 anlpar;
Please move the anlpar declaration to the top of the function
}goto miiphy_read_failed;
} /* Get speed from basic control settings. */return (anlpar & PHY_ANLPAR_100) ? _100BASET : _10BASET;
return (_100BASET);
- } else {
return (_10BASET);
miiphy_read_failed:
return _10BASET;
- Determine full/half duplex.
- Determine full/half duplex. Return half on error.
- u16 bmcr;
- } else {
return (FULL);
} else {
return (HALF);
- u16 btsr;
Same as above. Don't need it, I don't think.
- u16 bmsr, exsr;
/* 1000BASE-X */
u16 anlpar;
- if (btsr != 0xFFFF) {
return FULL;
}return HALF;
Same as above. All GigE capabilities are listed in EXSR
return (HALF);
return (HALF);
u16 anlpar;
See comment above
return (FULL);
} else {
return (HALF);
} /* Get speed from basic control settings. */FULL : HALF;
return (FULL);
- } else {
return (HALF);
miiphy_read_failed:
return HALF;
#endif
This SF.net email is sponsored by: Splunk Inc. Still grepping through log files to find problems? Stop. Now Search log events and configuration files using AJAX and a browser. Download your FREE copy of Splunk now >> http://get.splunk.com/ _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
Nice work.
regards, Ben
Hi Ben,
Thank you for your comments. See below...
Ben Warren wrote:
Larry,
- u16 bmcr;
- } else {
!= 0) {
- u16 btsr;
I only put it in to keep the footprint smaller for boards that aren't using fiber, so I'll get rid if it.
- u16 bmsr, exsr;
/* 1000BASE-X */
return _1000BASET;
Checking PHY_BMSR_EXT_STAT when CONIF_PHY_GIGE is defined does seem a bit paranoid, now that you mention it.
For the rest, let me explain my thinking. The board I'm writing for, named "Korat", has ethernet ports that are configurable for either 10BASE-T/100BASE-TX/1000BASE-T copper, or 1000BASE-X fiber. IEEE defines some registers differently depending on which is configured. To determine board-independently how the registers are to be interpreted, I look in the extended status register. If 1000BASE-X full or half duplex is listed as a capability, I assume fiber, otherwise copper. This works on the PHY I'm using, and I can't see it working differently on another PHY because some bits in some registers are used differently depending on the medium.
At this particular point in the code, if the PHY is configured for 1000BASE-X, then I report the speed as 1000 without checking for any autonegotiation results. If the PHY is configured for copper, then it is still necessary to check 1000BTSR (as in the original code) to see what speed was negotiated.
return _1000BASET;
See above.
return (_10BASET);
return (_10BASET);
return (_100BASET);
} else {
return (_10BASET);
u16 anlpar;
OK. (I missed the anlpar declarations. Sorry.)
return (_100BASET);
- } else {
return (_10BASET);
miiphy_read_failed:
return _10BASET;
- u16 bmcr;
- } else {
return (FULL);
} else {
return (HALF);
- u16 btsr;
Good.
- u16 bmsr, exsr;
/* 1000BASE-X */
u16 anlpar;
return FULL;
return HALF; }
See note above. Again it's not the capabilities, but the autonegotiation results that need to be checked. In this case, I cannot make any assumption based on being in 1000BASE-X mode, but must check the autonegotiation result, which is in ANLPAR, but with different bit definitions than for 10/100 Mbs.
return (HALF);
return (HALF);
u16 anlpar;
See comment above
Sorry, again.
[snip]
Nice work.
regards, Ben
Thank you. I'm thinking now that there should now be a function to report whether the PHY is in 1000BASE-X mode, to go along with the speed and duplex functions. I'd like to try that to see if it makes the code clearer. I'll post the revised patch after I've had a chance to test it to get your and others' opinions.
Best regards, Larry
Ben Warren
Larry Johnson
