Re: [DNX#2006033142000294] [U-Boot-Users] [Patch] KVME080 Support
Hello list,
inside the automatic U-Boot patch tracking system a new ticket [DNX#2006033142000294] was created:
<snip>
Can you please split your patch into two?
I splited the patch and extracted KVME080 parts only.
And please cleanup your code before re-submitting:
- It violates the coding style requirements (trailing white space).
Sorry, I was suprised that my code had so many white spaces. I am sure I fixed all of it now.
- Using globally visible preprocessor defines like FLASH_WRITE64 is
not acceptable (you also forgot to document these, but that would help either), and defining such code in the board config file is the wrong way to implement it either. The board config file is - ummm, a _configuration_ file, but does not contain source code.
I deleted the 'source code' from the board configuration file. The current version of KVME080 board runs well without patching cfi_flash.c I'll find an alternative way and send the patch for cfi_flash.c later.
Also: please read the recent "U-Boot Developer's Information" posting; you are supposed to provide a "sign-off" line for all patches.
I added the "sign-off" line at the end of the patch.
Regards, Sangmoon Kim
</snip>
Your U-Boot support team
DENX Support System
