[PATCH 06/18] mips: mtmips: add two reference boards for mt7620
The mt7620_rfb board supports integrated 10/100M PHYs plus two external giga PHYs. It also has 8MB SPI-NOR, mini PCI-e x1 slot, SDHC and USB.
The mt7620_mt7530_rfb boards supports an external MT7530 giga switch and a 16MB SPI-NOR flash.
Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- arch/mips/dts/Makefile | 2 + arch/mips/dts/mediatek,mt7620-mt7530-rfb.dts | 100 +++++++++++++++++++ arch/mips/dts/mediatek,mt7620-rfb.dts | 97 ++++++++++++++++++ arch/mips/mach-mtmips/mt7620/Kconfig | 17 ++++ board/mediatek/mt7620/Kconfig | 20 ++++ board/mediatek/mt7620/MAINTAINERS | 9 ++ board/mediatek/mt7620/Makefile | 3 + board/mediatek/mt7620/board.c | 8 ++ configs/mt7620_mt7530_rfb_defconfig | 52 ++++++++++ configs/mt7620_rfb_defconfig | 68 +++++++++++++ 10 files changed, 376 insertions(+) create mode 100644 arch/mips/dts/mediatek,mt7620-mt7530-rfb.dts create mode 100644 arch/mips/dts/mediatek,mt7620-rfb.dts create mode 100644 board/mediatek/mt7620/Kconfig create mode 100644 board/mediatek/mt7620/MAINTAINERS create mode 100644 board/mediatek/mt7620/Makefile create mode 100644 board/mediatek/mt7620/board.c create mode 100644 configs/mt7620_mt7530_rfb_defconfig create mode 100644 configs/mt7620_rfb_defconfig
diff --git a/arch/mips/dts/Makefile b/arch/mips/dts/Makefile index e82f96d4e4..7c42923134 100644 --- a/arch/mips/dts/Makefile +++ b/arch/mips/dts/Makefile @@ -14,6 +14,8 @@ dtb-$(CONFIG_BOARD_COMTREND_CT5361) += comtrend,ct-5361.dtb dtb-$(CONFIG_BOARD_COMTREND_VR3032U) += comtrend,vr-3032u.dtb dtb-$(CONFIG_BOARD_COMTREND_WAP5813N) += comtrend,wap-5813n.dtb dtb-$(CONFIG_BOARD_HUAWEI_HG556A) += huawei,hg556a.dtb +dtb-$(CONFIG_BOARD_MT7620_RFB) += mediatek,mt7620-rfb.dtb +dtb-$(CONFIG_BOARD_MT7620_MT7530_RFB) += mediatek,mt7620-mt7530-rfb.dtb dtb-$(CONFIG_BOARD_MT7628_RFB) += mediatek,mt7628-rfb.dtb dtb-$(CONFIG_BOARD_GARDENA_SMART_GATEWAY_MT7688) += gardena-smart-gateway-mt7688.dtb dtb-$(CONFIG_BOARD_LINKIT_SMART_7688) += linkit-smart-7688.dtb diff --git a/arch/mips/dts/mediatek,mt7620-mt7530-rfb.dts b/arch/mips/dts/mediatek,mt7620-mt7530-rfb.dts new file mode 100644 index 0000000000..8bc3b1673a --- /dev/null +++ b/arch/mips/dts/mediatek,mt7620-mt7530-rfb.dts @@ -0,0 +1,100 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2020 MediaTek Inc. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +/dts-v1/; + +#include <dt-bindings/gpio/gpio.h> +#include "mt7620.dtsi" + +/ { + compatible = "mediatek,mt7620-mt7530-rfb", "mediatek,mt7620-soc"; + model = "MediaTek MT7620-MT7530 RFB (MTKC712)"; + + aliases { + serial0 = &uartlite; + spi0 = &spi0; + }; + + chosen { + stdout-path = &uartlite; + }; +}; + +&uartlite { + status = "okay"; +}; + +&pinctrl { + state_default: pin_state { + pleds { + groups = "ephy led", "wled"; + function = "led"; + }; + + gpios { + groups = "pa", "uartf"; + function = "gpio"; + }; + }; + + gsw_pins: gsw_pins { + mdio { + groups = "mdio"; + function = "mdio"; + }; + + rgmii1 { + groups = "rgmii1"; + function = "rgmii1"; + }; + }; +}; + +&spi0 { + status = "okay"; + num-cs = <2>; + + spi-flash@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "jedec,spi-nor"; + spi-max-frequency = <25000000>; + reg = <0>; + }; +}; + +&gpio0 { + pa0_pull_low { + gpio-hog; + output-low; + gpios = <20 GPIO_ACTIVE_HIGH>; + }; + + pa1_pull_low { + gpio-hog; + output-low; + gpios = <21 GPIO_ACTIVE_HIGH>; + }; +}; + +ð { + status = "okay"; + + pinctrl-names = "default"; + pinctrl-0 = <&gsw_pins>; + + port5 { + phy-mode = "rgmii"; + phy-addr = <5>; + fixed-link { + full-duplex; + speed = <1000>; + mediatek,mt7530; + mediatek,mt7530-reset = <&gpio0 10 GPIO_ACTIVE_HIGH>; + }; + }; +}; diff --git a/arch/mips/dts/mediatek,mt7620-rfb.dts b/arch/mips/dts/mediatek,mt7620-rfb.dts new file mode 100644 index 0000000000..616903e554 --- /dev/null +++ b/arch/mips/dts/mediatek,mt7620-rfb.dts @@ -0,0 +1,97 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2020 MediaTek Inc. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +/dts-v1/; + +#include <dt-bindings/gpio/gpio.h> +#include "mt7620.dtsi" + +/ { + compatible = "mediatek,mt7620-rfb", "mediatek,mt7620-soc"; + model = "MediaTek MT7620 RFB (WS2120)"; + + aliases { + serial0 = &uartlite; + spi0 = &spi0; + }; + + chosen { + stdout-path = &uartlite; + }; +}; + +&uartlite { + status = "okay"; +}; + +&pinctrl { + state_default: pin_state { + pleds { + groups = "ephy led", "wled"; + function = "led"; + }; + + gpios { + groups = "uartf"; + function = "gpio"; + }; + }; + + gsw_pins: gsw_pins { + mdio { + groups = "mdio"; + function = "mdio"; + }; + + rgmii1 { + groups = "rgmii1"; + function = "rgmii1"; + }; + + rgmii2 { + groups = "rgmii2"; + function = "rgmii2"; + }; + }; +}; + +&spi0 { + status = "okay"; + num-cs = <2>; + + spi-flash@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "jedec,spi-nor"; + spi-max-frequency = <25000000>; + reg = <0>; + }; +}; + +ð { + status = "okay"; + + pinctrl-names = "default"; + pinctrl-0 = <&gsw_pins>; + + port4 { + phy-mode = "rgmii"; + phy-addr = <4>; + }; + + port5 { + phy-mode = "rgmii"; + phy-addr = <5>; + }; +}; + +&mmc { + bus-width = <4>; + cap-sd-highspeed; + + status = "okay"; +}; diff --git a/arch/mips/mach-mtmips/mt7620/Kconfig b/arch/mips/mach-mtmips/mt7620/Kconfig index aa7cf1d3c1..5db83eb9d9 100644 --- a/arch/mips/mach-mtmips/mt7620/Kconfig +++ b/arch/mips/mach-mtmips/mt7620/Kconfig @@ -7,6 +7,21 @@ config DEBUG_UART_BOARD_INIT choice prompt "Board select"
+config BOARD_MT7620_RFB + bool "MediaTek MT7620 RFB" + help + The reference design of MT7620A (WS2120). The board has 64 MiB DDR2, + 8 MiB SPI-NOR flash, 1 built-in 6 port switch (two GE PHYs and five + FE PHYs,one port can be configured to use either FE PHY or GE PHY), + 1 UART, 1 USB host, 1 SDXC, 1 PCIe socket and JTAG pins. + +config BOARD_MT7620_MT7530_RFB + bool "MediaTek MT7620-MT7530 RFB" + help + The reference design of MT7620DA (MTKC712). The board has 64 MiB + intergrated DDR2 KGD, 16 MiB SPI-NOR flash, an external 5-port giga + switch MT7530 and 1 UART. + endchoice
choice @@ -51,4 +66,6 @@ config CPU_FREQ_MULTI default 6 if CPU_FREQ_600MHZ default 7 if CPU_FREQ_620MHZ
+source "board/mediatek/mt7620/Kconfig" + endif diff --git a/board/mediatek/mt7620/Kconfig b/board/mediatek/mt7620/Kconfig new file mode 100644 index 0000000000..db72332cb4 --- /dev/null +++ b/board/mediatek/mt7620/Kconfig @@ -0,0 +1,20 @@ +if BOARD_MT7620_RFB || BOARD_MT7620_MT7530_RFB + +config SYS_BOARD + default "mt7620" + +config SYS_VENDOR + default "mediatek" + +config SYS_CONFIG_NAME + default "mt7620" + +config MT7620_UART1_BASE + hex + default 0xb0000c00 + +config MT7620_UART1_CLK + int + default 40000000 + +endif diff --git a/board/mediatek/mt7620/MAINTAINERS b/board/mediatek/mt7620/MAINTAINERS new file mode 100644 index 0000000000..05db777ced --- /dev/null +++ b/board/mediatek/mt7620/MAINTAINERS @@ -0,0 +1,9 @@ +MT7620_RFB BOARD +M: Weijie Gao weijie.gao@mediatek.com +S: Maintained +F: board/mediatek/mt7620 +F: include/configs/mt7620.h +F: configs/mt7620_rfb_defconfig +F: configs/mt7620_mt7530_rfb_defconfig +F: arch/mips/dts/mediatek,mt7620-rfb.dts +F: arch/mips/dts/mediatek,mt7620-mt7530-rfb.dts diff --git a/board/mediatek/mt7620/Makefile b/board/mediatek/mt7620/Makefile new file mode 100644 index 0000000000..db129c5aba --- /dev/null +++ b/board/mediatek/mt7620/Makefile @@ -0,0 +1,3 @@ +# SPDX-License-Identifier: GPL-2.0 + +obj-y += board.o diff --git a/board/mediatek/mt7620/board.c b/board/mediatek/mt7620/board.c new file mode 100644 index 0000000000..f837a06fbb --- /dev/null +++ b/board/mediatek/mt7620/board.c @@ -0,0 +1,8 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2020 MediaTek Inc. All Rights Reserved. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +#include <common.h> diff --git a/configs/mt7620_mt7530_rfb_defconfig b/configs/mt7620_mt7530_rfb_defconfig new file mode 100644 index 0000000000..ea10f5d5f3 --- /dev/null +++ b/configs/mt7620_mt7530_rfb_defconfig @@ -0,0 +1,52 @@ +CONFIG_MIPS=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SIZE=0x1000 +CONFIG_ENV_OFFSET=0x30000 +CONFIG_ENV_SECT_SIZE=0x10000 +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL_SYS_MALLOC_F_LEN=0x40000 +CONFIG_SPL=y +CONFIG_DEBUG_UART_BASE=0xb0000c00 +CONFIG_DEBUG_UART_CLOCK=40000000 +CONFIG_ARCH_MTMIPS=y +CONFIG_BOARD_MT7620_MT7530_RFB=y +CONFIG_DEFAULT_DEVICE_TREE="mediatek,mt7620-mt7530-rfb" +CONFIG_RESTORE_EXCEPTION_VECTOR_BASE=y +CONFIG_MIPS_BOOT_FDT=y +CONFIG_DEBUG_UART=y +CONFIG_FIT=y +# CONFIG_ARCH_FIXUP_FDT_MEMORY is not set +CONFIG_SPL_NOR_SUPPORT=y +# CONFIG_CMD_ELF is not set +# CONFIG_CMD_XIMG is not set +# CONFIG_CMD_CRC32 is not set +# CONFIG_CMD_DM is not set +CONFIG_CMD_GPIO=y +# CONFIG_CMD_LOADS is not set +CONFIG_CMD_SPI=y +# CONFIG_CMD_NFS is not set +CONFIG_CMD_MII=y +# CONFIG_CMD_MDIO is not set +# CONFIG_PARTITIONS is not set +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_GPIO_HOG=y +# CONFIG_INPUT is not set +CONFIG_SPI_FLASH_SFDP_SUPPORT=y +CONFIG_SPI_FLASH_EON=y +CONFIG_SPI_FLASH_GIGADEVICE=y +CONFIG_SPI_FLASH_ISSI=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_WINBOND=y +CONFIG_SPI_FLASH_XMC=y +CONFIG_MT7620_ETH=y +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SPI=y +CONFIG_MT7620_SPI=y +CONFIG_LZMA=y +CONFIG_SPL_LZMA=y diff --git a/configs/mt7620_rfb_defconfig b/configs/mt7620_rfb_defconfig new file mode 100644 index 0000000000..8cc82bc36b --- /dev/null +++ b/configs/mt7620_rfb_defconfig @@ -0,0 +1,68 @@ +CONFIG_MIPS=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SIZE=0x1000 +CONFIG_ENV_OFFSET=0x30000 +CONFIG_ENV_SECT_SIZE=0x10000 +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL_SYS_MALLOC_F_LEN=0x40000 +CONFIG_SPL=y +CONFIG_DEBUG_UART_BASE=0xb0000c00 +CONFIG_DEBUG_UART_CLOCK=40000000 +CONFIG_ARCH_MTMIPS=y +CONFIG_DEFAULT_DEVICE_TREE="mediatek,mt7620-rfb" +CONFIG_RESTORE_EXCEPTION_VECTOR_BASE=y +CONFIG_MIPS_BOOT_FDT=y +CONFIG_DEBUG_UART=y +CONFIG_FIT=y +# CONFIG_ARCH_FIXUP_FDT_MEMORY is not set +CONFIG_SPL_NOR_SUPPORT=y +# CONFIG_CMD_ELF is not set +# CONFIG_CMD_XIMG is not set +# CONFIG_CMD_CRC32 is not set +# CONFIG_CMD_DM is not set +CONFIG_CMD_GPIO=y +# CONFIG_CMD_LOADS is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y +# CONFIG_CMD_NFS is not set +CONFIG_CMD_MII=y +# CONFIG_CMD_MDIO is not set +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +# CONFIG_ISO_PARTITION is not set +CONFIG_EFI_PARTITION=y +# CONFIG_SPL_EFI_PARTITION is not set +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_GPIO_HOG=y +# CONFIG_INPUT is not set +CONFIG_MMC=y +CONFIG_DM_MMC=y +# CONFIG_MMC_QUIRKS is not set +# CONFIG_MMC_HW_PARTITIONING is not set +CONFIG_MMC_MTK=y +CONFIG_SPI_FLASH_SFDP_SUPPORT=y +CONFIG_SPI_FLASH_EON=y +CONFIG_SPI_FLASH_GIGADEVICE=y +CONFIG_SPI_FLASH_ISSI=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_WINBOND=y +CONFIG_SPI_FLASH_XMC=y +CONFIG_MT7620_ETH=y +CONFIG_PHY=y +CONFIG_MT7620_USB_PHY=y +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SPI=y +CONFIG_MT7620_SPI=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_GENERIC=y +CONFIG_LZMA=y +CONFIG_SPL_LZMA=y
Am Freitag, den 16.10.2020, 15:35 +0800 schrieb Weijie Gao:
- Copyright (C) 2020 MediaTek Inc.
- Author: Weijie Gao weijie.gao@mediatek.com
+/dts-v1/;
- compatible = "mediatek,mt7620-mt7530-rfb", "mediatek,mt7620-soc";
- model = "MediaTek MT7620-MT7530 RFB (MTKC712)";
- aliases {
spi0 = &spi0;
- chosen {
+&uartlite {
- status = "okay";
+&pinctrl {
- state_default: pin_state {
pleds {
function = "led";
gpios {
function = "gpio";
- gsw_pins: gsw_pins {
mdio {
groups = "mdio";
function = "mdio";
rgmii1 {
groups = "rgmii1";
+&spi0 {
- status = "okay";
- num-cs = <2>;
- spi-flash@0 {
#size-cells = <1>;
reg = <0>;
+&gpio0 {
- pa0_pull_low {
gpio-hog;
output-low;
- pa1_pull_low {
gpio-hog;
output-low;
+ð {
- status = "okay";
- pinctrl-names = "default";
- pinctrl-0 = <&gsw_pins>;
- port5 {
phy-mode = "rgmii";
phy-addr = <5>;
fixed-link {
full-duplex;
speed = <1000>;
mediatek,mt7530;
+/dts-v1/;
- compatible = "mediatek,mt7620-rfb", "mediatek,mt7620-soc";
- model = "MediaTek MT7620 RFB (WS2120)";
- aliases {
spi0 = &spi0;
- chosen {
+&uartlite {
- status = "okay";
+&pinctrl {
pleds {
function = "led";
gpios {
groups = "uartf";
function = "gpio";
mdio {
groups = "mdio";
function = "mdio";
rgmii1 {
groups = "rgmii1";
rgmii2 {
groups = "rgmii2";
+&spi0 {
- status = "okay";
- num-cs = <2>;
- spi-flash@0 {
#size-cells = <1>;
reg = <0>;
+ð {
- status = "okay";
- port4 {
phy-mode = "rgmii";
phy-addr = <4>;
- port5 {
phy-mode = "rgmii";
phy-addr = <5>;
+&mmc {
- bus-width = <4>;
- cap-sd-highspeed;
- status = "okay";
- bool "MediaTek MT7620 RFB"
- help
- bool "MediaTek MT7620-MT7530 RFB"
- help
endchoice
+config SYS_BOARD
- default "mt7620"
+config SYS_VENDOR
- default "mediatek"
- default "mt7620"
- hex
- default 0xb0000c00
- int
- default 40000000
why and where do you need those? This looks redundant CONFIG_DEBUG_UART_BASE and CONFIG_DEBUG_UART_CLOCK.
- Copyright (C) 2020 MediaTek Inc. All Rights Reserved.
+CONFIG_SPL_LZMA=y
2.17.1
+/dts-v1/;
- aliases {
spi0 = &spi0;
- chosen {
+&uartlite {
- status = "okay";
+&pinctrl {
pleds {
function = "led";
gpios {
function = "gpio";
mdio {
groups = "mdio";
function = "mdio";
rgmii1 {
groups = "rgmii1";
+&spi0 {
- status = "okay";
- num-cs = <2>;
- spi-flash@0 {
#size-cells = <1>;
reg = <0>;
+&gpio0 {
- pa0_pull_low {
gpio-hog;
output-low;
- pa1_pull_low {
gpio-hog;
output-low;
+ð {
- status = "okay";
- port5 {
phy-mode = "rgmii";
phy-addr = <5>;
fixed-link {
full-duplex;
speed = <1000>;
mediatek,mt7530;
+/dts-v1/;
- aliases {
spi0 = &spi0;
- chosen {
+&uartlite {
- status = "okay";
+&pinctrl {
pleds {
function = "led";
gpios {
groups = "uartf";
function = "gpio";
mdio {
groups = "mdio";
function = "mdio";
rgmii1 {
groups = "rgmii1";
rgmii2 {
groups = "rgmii2";
+&spi0 {
- status = "okay";
- num-cs = <2>;
- spi-flash@0 {
#size-cells = <1>;
reg = <0>;
+ð {
- status = "okay";
- port4 {
phy-mode = "rgmii";
phy-addr = <4>;
- port5 {
phy-mode = "rgmii";
phy-addr = <5>;
+&mmc {
- bus-width = <4>;
- cap-sd-highspeed;
- status = "okay";
- help
- help
endchoice
+config SYS_BOARD
- default "mt7620"
+config SYS_VENDOR
- default "mt7620"
- hex
- int
- default 40000000
This config is used for the mt7620 uart driver (non-DM mode) in SPL. This option is similar to the CONFIG_SYS_NS16550_CLK. But since mt7620 uart driver is not compatible with the ns16550a driver, I have to define new configs for it.
Please refer to [PATCH 08/18] serial: add uart driver for MediaTek MT7620 SoC
+CONFIG_SPL_LZMA=y
2.17.1
Daniel Schwierzeck
Weijie Gao
