[U-Boot] [GIT PULL] Please pull u-boot-mmc master
Dear Tom,
Could you pull these patches to u-boot/master? To develop the supporting HS200 mode, each host driver also needs to implement something. First step is the applying JJ's patches.
If there is a problem, let me know, plz.
The following changes since commit 0def58f7fd26a237bb08cfbd58ec53372b1ad06b:
Merge git://git.denx.de/u-boot-x86 (2017-10-19 11:19:38 -0400)
git://git.denx.de/u-boot-mmc.git master
for you to fetch changes up to f58da60cfdbe896d62a0ec61cd41a52cfc82c526:
mmc: replace the printf() instead of error() (2017-10-23 13:48:39 +0900)
---------------------------------------------------------------- Jaehoon Chung (1): mmc: replace the printf() instead of error()
Jean-Jacques Hiblot (17): mmc: dm: get the IO-line and main voltage regulators from the dts mmc: split mmc_startup() mmc: move the MMC startup for version above v4.0 in a separate function mmc: make ext_csd part of struct mmc mmc: add a function to read and test the ext csd (mmc >= 4) mmc: introduce mmc modes mmc: Add a function to dump the mmc capabilities mmc: use mmc modes to select the correct bus speed cmd: mmc: display the mode name and current bus speed in the mmc info mmc: refactor SD startup to make it easier to support new modes mmc: refactor MMC startup to make it easier to support new modes mmc: Add a new callback function to perform the 74 clocks cycle sequence mmc: Add support for UHS modes mmc: disable UHS modes if Vcc cannot be switched on and off mmc: Change mode when switching to a boot partition mmc: use the right voltage level for MMC DDR and HS200 modes mmc: add a library function to send tuning command
Kishon Vijay Abraham I (9): mmc: make mmc_set_ios() return status mmc: Enable signal voltage to be selected from mmc core mmc: add power cyle support in mmc core mmc: add a new mmc parameter to disable mmc clock mmc: disable the mmc clock during power off mmc: Add a execute_tuning() callback to the mmc operations. mmc: add HS200 support in MMC core mmc: Retry some MMC cmds on failure dm: mmc: Add a library function to parse generic dt binding
Suniel Mahesh (2): drivers: mmc: Change buffer type in ALLOC_CACHE_ALIGN_BUFFER macro drivers: mmc: Avoid memory leak in case of failure
cmd/mmc.c | 3 +- drivers/mmc/Kconfig | 23 + drivers/mmc/exynos_dw_mmc.c | 3 + drivers/mmc/fsl_esdhc.c | 2 +- drivers/mmc/mmc-uclass.c | 87 +++ drivers/mmc/mmc.c | 1517 ++++++++++++++++++++++++++++++++----------- include/mmc.h | 176 ++++- 7 files changed, 1423 insertions(+), 388 deletions(-)
Dear Tom,
On 10/23/2017 01:54 PM, Jaehoon Chung wrote:
Dear Tom,
Discard this PR. After checking more, i will resend the PR.
Best Regards, Jaehoon Chung
cmd/mmc.c | 3 +- drivers/mmc/Kconfig | 23 + drivers/mmc/exynos_dw_mmc.c | 3 + drivers/mmc/fsl_esdhc.c | 2 +- drivers/mmc/mmc-uclass.c | 87 +++ drivers/mmc/mmc.c | 1517 ++++++++++++++++++++++++++++++++----------- include/mmc.h | 176 ++++- 7 files changed, 1423 insertions(+), 388 deletions(-) _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de https://lists.denx.de/listinfo/u-boot
Jaehoon Chung
