[PATCH] Fix Kconfig coding style from spaces to tab
Adjust indentation from spaces to tab (+optional two spaces) as in coding style with command like: $ sed -e 's/^ /\t/' -i */Kconfig
Signed-off-by: Anand Moon linux.amoon@gmail.com --- boot/Kconfig | 8 ++++---- cmd/Kconfig | 20 ++++++++++---------- disk/Kconfig | 2 +- lib/Kconfig | 2 +- net/Kconfig | 4 ++-- 5 files changed, 18 insertions(+), 18 deletions(-)
diff --git a/boot/Kconfig b/boot/Kconfig index 6f3096c15a..12148ac3f2 100644 --- a/boot/Kconfig +++ b/boot/Kconfig @@ -150,10 +150,10 @@ config FIT_IMAGE_POST_PROCESS processed before being added to the FIT image).
config FIT_PRINT - bool "Support FIT printing" - default y - help - Support printing the content of the fitImage in a verbose manner. + bool "Support FIT printing" + default y + help + Support printing the content of the fitImage in a verbose manner.
config SPL_FIT bool "Support Flattened Image Tree within SPL" diff --git a/cmd/Kconfig b/cmd/Kconfig index b026439c77..011f4ad429 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -271,7 +271,7 @@ config CMD_BOOTM_PRE_LOAD depends on CMD_BOOTM depends on IMAGE_PRE_LOAD help - Enable support of stage pre-load for the bootm command. + Enable support of stage pre-load for the bootm command. This stage allow to check or modify the image provided to the bootm command.
@@ -897,9 +897,9 @@ config CMD_MX_CYCLIC bool "Enable cyclic md/mw commands" depends on CMD_MEMORY help - Add the "mdc" and "mwc" memory commands. These are cyclic - "md/mw" commands. - Examples: + Add the "mdc" and "mwc" memory commands. These are cyclic + "md/mw" commands. + Examples:
=> mdc.b 10 4 500 This command will print 4 bytes (10,11,12,13) each 500 ms. @@ -2150,12 +2150,12 @@ config CMD_BLKMAP
Example use-cases: - Treat a region of RAM as a block device, i.e. a RAM disk. This let's - you extract files from filesystem images stored in RAM (perhaps as a - result of a TFTP transfer). + you extract files from filesystem images stored in RAM (perhaps as a + result of a TFTP transfer). - Create a virtual partition on an existing device. This let's you - access filesystems that aren't stored at an exact partition - boundary. A common example is a filesystem image embedded in an FIT - image. + access filesystems that aren't stored at an exact partition + boundary. A common example is a filesystem image embedded in an FIT + image.
config CMD_BUTTON bool "button" @@ -2934,7 +2934,7 @@ config CMD_UBI_RENAME bool "Enable rename" depends on CMD_UBI help - Enable a "ubi" command to rename ubi volume: + Enable a "ubi" command to rename ubi volume: ubi rename <oldname> <newname>
config CMD_UBIFS diff --git a/disk/Kconfig b/disk/Kconfig index 8549695807..ffa835eb35 100644 --- a/disk/Kconfig +++ b/disk/Kconfig @@ -116,7 +116,7 @@ config EFI_PARTITION_ENTRIES_NUMBERS number.
config EFI_PARTITION_ENTRIES_OFF - int "Offset (in bytes) of the EFI partition entries" + int "Offset (in bytes) of the EFI partition entries" depends on EFI_PARTITION default 0 help diff --git a/lib/Kconfig b/lib/Kconfig index 189e6eb31a..b8e4f516f9 100644 --- a/lib/Kconfig +++ b/lib/Kconfig @@ -1143,7 +1143,7 @@ config PHANDLE_CHECK_SEQ bool "Enable phandle check while getting sequence number" help When there are multiple device tree nodes with same name, - enable this config option to distinguish them using + enable this config option to distinguish them using phandles in fdtdec_get_alias_seq() function.
endmenu diff --git a/net/Kconfig b/net/Kconfig index 5dff633629..7cb80b880a 100644 --- a/net/Kconfig +++ b/net/Kconfig @@ -42,8 +42,8 @@ config BOOTP_SEND_HOSTNAME DNS server. To do this, they need the hostname of the DHCP requester. If CONFIG_BOOTP_SEND_HOSTNAME is defined, the content - of the "hostname" environment variable is passed as - option 12 to the DHCP server. + of the "hostname" environment variable is passed as + option 12 to the DHCP server.
config NET_RANDOM_ETHADDR bool "Random ethaddr if unset"
Anand Moon
