[U-Boot-Users] Uboot mpc8xx porting
As is understand by seeing the code, there is a bd_info structure that the U-boot sends to the kernel through registers. Now one of the main information that is passed on is the address of the start of the bd_info structure in the memory. At the end of the structure the last member is again a structure pointer that points to monitor routines.
I have a U-boot working fine, i have tested example applications on our target board and found everything is fine. Does this mean that the monitor routines are fine. When i try to load kernel, the kernel executes some code in head_8xx.S and hangs. As told in the Readme file i have checked with the IMMR start to be matching with ppcboot.h.
Why is the Kernel hanging? Will the Kernel use the getc,puts and other monitor functions of the U-boot for messages? How do i proceed? I have tried with both uclinux and linux kernels on the board.
Any information will be of great help
thanks
Vishwanath Patil
In message c0dc62120602051956y1cd7611dv184b1ca974e93a54@mail.gmail.com you wrote:
Right.
Not really. These pointers have been there historically, but they are not used normally. They'd be of limited use anyway.
Yes.
How do you know that the kernel is hanging in head_8xx.S ? Don't modify that file! Don't try adding random code there.
No, it will not. To proceed, try o find out where the kernel is hanging. Are there any messages in the log buffer? [Read the FAQ!] Then attach your BDI2000 and debug the kernel...
Vishwanath Patil
