[U-Boot] [PATCH v2 0/6] arm: am335x: Enable SPL_DM
Enable SPL_DM on all AM335x based TI platforms.
Using board-data way instead of using DT as suggested by Tom here[1], mainly due to space constraints. This series depends on Adam Ford's patch[2].
Link to travis-ci build tests: https://travis-ci.org/lokeshvutla/u-boot/builds/225872244
[1] https://www.mail-archive.com/u-boot@lists.denx.de/msg238483.html [2] http://patchwork.ozlabs.org/patch/751300/
Lokesh Vutla (6): dm: mmc: omap_hsmmc: Update to support of-platdata dm: mmc: omap_hsmmc: Add pre-reloc flag to the driver configs: am335x_evm: Use omap2 generic spl load script am33xx: Provide platform data for mmc configs: am335x_evm: Enable SPL_DM arm: am335x: Enable tiny printf in SPL
arch/arm/Kconfig | 1 + arch/arm/include/asm/omap_mmc.h | 9 +++++ arch/arm/mach-omap2/am33xx/Kconfig | 5 +++ arch/arm/mach-omap2/am33xx/u-boot-spl.lds | 56 ------------------------------- board/ti/am335x/board.c | 32 ++++++++++++++++++ drivers/mmc/omap_hsmmc.c | 25 ++++++++------ include/configs/am335x_evm.h | 3 +- include/configs/am335x_igep0033.h | 2 +- include/configs/am335x_shc.h | 2 +- include/configs/am335x_sl50.h | 2 +- include/configs/baltos.h | 2 +- include/configs/bav335x.h | 2 +- include/configs/bur_am335x_common.h | 2 +- include/configs/chiliboard.h | 2 +- include/configs/cm_t335.h | 2 +- include/configs/pcm051.h | 2 +- include/configs/pengwyn.h | 2 +- include/configs/pepper.h | 2 +- include/configs/siemens-am33x-common.h | 2 +- include/configs/ti_am335x_common.h | 2 ++ 20 files changed, 77 insertions(+), 80 deletions(-) delete mode 100644 arch/arm/mach-omap2/am33xx/u-boot-spl.lds
This is to aid platforms that uses OF_PLATDATA.
Reviewed-by: Tom Rini trini@konsulko.com Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- Changes since v1: - Rebased on top of Adam's patch http://patchwork.ozlabs.org/patch/751300/ arch/arm/include/asm/omap_mmc.h | 9 +++++++++ drivers/mmc/omap_hsmmc.c | 24 ++++++++++++++---------- 2 files changed, 23 insertions(+), 10 deletions(-)
diff --git a/arch/arm/include/asm/omap_mmc.h b/arch/arm/include/asm/omap_mmc.h index 93e003a368..f6eb51ee3c 100644 --- a/arch/arm/include/asm/omap_mmc.h +++ b/arch/arm/include/asm/omap_mmc.h @@ -25,6 +25,8 @@ #ifndef OMAP_MMC_H_ #define OMAP_MMC_H_
+#include <mmc.h> + struct hsmmc { unsigned char res1[0x10]; unsigned int sysconfig; /* 0x10 */ @@ -49,6 +51,13 @@ struct hsmmc { unsigned int capa; /* 0x140 */ };
+struct omap_hsmmc_plat { + struct mmc_config cfg; + struct hsmmc *base_addr; + struct mmc mmc; + bool cd_inverted; +}; + /* * OMAP HS MMC Bit definitions */ diff --git a/drivers/mmc/omap_hsmmc.c b/drivers/mmc/omap_hsmmc.c index d151fe7266..f422ed5532 100644 --- a/drivers/mmc/omap_hsmmc.c +++ b/drivers/mmc/omap_hsmmc.c @@ -56,11 +56,6 @@ DECLARE_GLOBAL_DATA_PTR; #define SYSCTL_SRC (1 << 25) #define SYSCTL_SRD (1 << 26)
-struct omap_hsmmc_plat { - struct mmc_config cfg; - struct mmc mmc; -}; - struct omap2_mmc_platform_config { u32 reg_offset; }; @@ -777,9 +772,9 @@ int omap_mmc_init(int dev_index, uint host_caps_mask, uint f_max, int cd_gpio, return 0; } #else +#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) static int omap_hsmmc_ofdata_to_platdata(struct udevice *dev) { - struct omap_hsmmc_data *priv = dev_get_priv(dev); struct omap_hsmmc_plat *plat = dev_get_platdata(dev); struct mmc_config *cfg = &plat->cfg; struct omap2_mmc_platform_config *data = @@ -788,7 +783,7 @@ static int omap_hsmmc_ofdata_to_platdata(struct udevice *dev) int node = dev_of_offset(dev); int val;
- priv->base_addr = map_physmem(dev_get_addr(dev), sizeof(struct hsmmc *), + plat->base_addr = map_physmem(dev_get_addr(dev), sizeof(struct hsmmc *), MAP_NOCACHE) + data->reg_offset;
cfg->host_caps = MMC_MODE_HS_52MHz | MMC_MODE_HS; @@ -815,11 +810,12 @@ static int omap_hsmmc_ofdata_to_platdata(struct udevice *dev) cfg->b_max = CONFIG_SYS_MMC_MAX_BLK_COUNT;
#ifdef OMAP_HSMMC_USE_GPIO - priv->cd_inverted = fdtdec_get_bool(fdt, node, "cd-inverted"); + plat->cd_inverted = fdtdec_get_bool(fdt, node, "cd-inverted"); #endif
return 0; } +#endif
#ifdef CONFIG_BLK
@@ -840,6 +836,10 @@ static int omap_hsmmc_probe(struct udevice *dev)
cfg->name = "OMAP SD/MMC"; cfg->ops = &omap_hsmmc_ops; + priv->base_addr = plat->base_addr; +#ifdef OMAP_HSMMC_USE_GPIO + priv->cd_inverted = plat->cd_inverted; +#endif
#ifdef CONFIG_BLK mmc = &plat->mmc; @@ -849,7 +849,7 @@ static int omap_hsmmc_probe(struct udevice *dev) return -1; #endif
-#ifdef OMAP_HSMMC_USE_GPIO +#if defined(OMAP_HSMMC_USE_GPIO) && CONFIG_IS_ENABLED(OF_CONTROL) gpio_request_by_name(dev, "cd-gpios", 0, &priv->cd_gpio, GPIOD_IS_IN); gpio_request_by_name(dev, "wp-gpios", 0, &priv->wp_gpio, GPIOD_IS_IN); #endif @@ -860,6 +860,7 @@ static int omap_hsmmc_probe(struct udevice *dev) return 0; }
+#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) static const struct omap2_mmc_platform_config omap3_mmc_pdata = { .reg_offset = 0, }; @@ -887,17 +888,20 @@ static const struct udevice_id omap_hsmmc_ids[] = { }, { } }; +#endif
U_BOOT_DRIVER(omap_hsmmc) = { .name = "omap_hsmmc", .id = UCLASS_MMC, +#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) .of_match = omap_hsmmc_ids, .ofdata_to_platdata = omap_hsmmc_ofdata_to_platdata, + .platdata_auto_alloc_size = sizeof(struct omap_hsmmc_plat), +#endif #ifdef CONFIG_BLK .bind = omap_hsmmc_bind, #endif .probe = omap_hsmmc_probe, .priv_auto_alloc_size = sizeof(struct omap_hsmmc_data), - .platdata_auto_alloc_size = sizeof(struct omap_hsmmc_plat), }; #endif
For platforms that don't use device tree in SPL the only way to mark this driver as 'required by relocation' is with the DM_FLAG_PRE_RELOC flag. Add this to ensure that the driver is bound.
Reviewed-by: Tom Rini trini@konsulko.com Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- Changes since v2: - None drivers/mmc/omap_hsmmc.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/mmc/omap_hsmmc.c b/drivers/mmc/omap_hsmmc.c index f422ed5532..c136ab0ec8 100644 --- a/drivers/mmc/omap_hsmmc.c +++ b/drivers/mmc/omap_hsmmc.c @@ -903,5 +903,6 @@ U_BOOT_DRIVER(omap_hsmmc) = { #endif .probe = omap_hsmmc_probe, .priv_auto_alloc_size = sizeof(struct omap_hsmmc_data), + .flags = DM_FLAG_PRE_RELOC, }; #endif
No reason to use a separate load script for am33xx than using omap-common load script.
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- Changes since v1: - Removed am33xx specific u-boot-spl.lds
arch/arm/mach-omap2/am33xx/u-boot-spl.lds | 56 ------------------------------- include/configs/am335x_evm.h | 2 +- include/configs/am335x_igep0033.h | 2 +- include/configs/am335x_shc.h | 2 +- include/configs/am335x_sl50.h | 2 +- include/configs/baltos.h | 2 +- include/configs/bav335x.h | 2 +- include/configs/bur_am335x_common.h | 2 +- include/configs/chiliboard.h | 2 +- include/configs/cm_t335.h | 2 +- include/configs/pcm051.h | 2 +- include/configs/pengwyn.h | 2 +- include/configs/pepper.h | 2 +- include/configs/siemens-am33x-common.h | 2 +- 14 files changed, 13 insertions(+), 69 deletions(-) delete mode 100644 arch/arm/mach-omap2/am33xx/u-boot-spl.lds
diff --git a/arch/arm/mach-omap2/am33xx/u-boot-spl.lds b/arch/arm/mach-omap2/am33xx/u-boot-spl.lds deleted file mode 100644 index 07cf267878..0000000000 --- a/arch/arm/mach-omap2/am33xx/u-boot-spl.lds +++ /dev/null @@ -1,56 +0,0 @@ -/* - * (C) Copyright 2002 - * Gary Jennejohn, DENX Software Engineering, garyj@denx.de - * - * (C) Copyright 2010 - * Texas Instruments, <www.ti.com> - * Aneesh V aneesh@ti.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -MEMORY { .sram : ORIGIN = CONFIG_SPL_TEXT_BASE,\ - LENGTH = CONFIG_SPL_MAX_SIZE } -MEMORY { .sdram : ORIGIN = CONFIG_SPL_BSS_START_ADDR, \ - LENGTH = CONFIG_SPL_BSS_MAX_SIZE } - -OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") -OUTPUT_ARCH(arm) -ENTRY(_start) -SECTIONS -{ - .text : - { - __start = .; - *(.vectors) - arch/arm/cpu/armv7/start.o (.text) - *(.text*) - } >.sram - - . = ALIGN(4); - .rodata : { *(SORT_BY_ALIGNMENT(.rodata*)) } >.sram - - . = ALIGN(4); - .data : { *(SORT_BY_ALIGNMENT(.data*)) } >.sram - - .u_boot_list : { - KEEP(*(SORT(.u_boot_list*))); - } >.sram - - . = ALIGN(4); - __image_copy_end = .; - - .end : - { - *(.__end) - } >.sram - - .bss : - { - . = ALIGN(4); - __bss_start = .; - *(.bss*) - . = ALIGN(4); - __bss_end = .; - } >.sdram -} diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index fc8a08f5b7..796d5c32e9 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -194,7 +194,7 @@
/* USB gadget RNDIS */
-#define CONFIG_SPL_LDSCRIPT "arch/arm/mach-omap2/am33xx/u-boot-spl.lds" +#define CONFIG_SPL_LDSCRIPT "arch/arm/mach-omap2/u-boot-spl.lds" #endif
#ifdef CONFIG_NAND diff --git a/include/configs/am335x_igep0033.h b/include/configs/am335x_igep0033.h index 7ee8ea7975..fbedbf25ad 100644 --- a/include/configs/am335x_igep0033.h +++ b/include/configs/am335x_igep0033.h @@ -118,7 +118,7 @@ "-(filesystem)"
/* SPL */ -#define CONFIG_SPL_LDSCRIPT "arch/arm/mach-omap2/am33xx/u-boot-spl.lds" +#define CONFIG_SPL_LDSCRIPT "arch/arm/mach-omap2/u-boot-spl.lds"
#define CONFIG_SYS_NAND_5_ADDR_CYCLE #define CONFIG_SYS_NAND_PAGE_COUNT (CONFIG_SYS_NAND_BLOCK_SIZE / \ diff --git a/include/configs/am335x_shc.h b/include/configs/am335x_shc.h index c100fbc533..bc0943fdfd 100644 --- a/include/configs/am335x_shc.h +++ b/include/configs/am335x_shc.h @@ -250,7 +250,7 @@
/* SPL */
#ifndef CONFIG_SPL_USBETH_SUPPORT #define CONFIG_FASTBOOT_FLASH_MMC_DEV 1 diff --git a/include/configs/am335x_sl50.h b/include/configs/am335x_sl50.h index 710dac269c..6855f62865 100644 --- a/include/configs/am335x_sl50.h +++ b/include/configs/am335x_sl50.h @@ -80,7 +80,7 @@ #define CONFIG_BOOTCOUNT_AM33XX #define CONFIG_SYS_BOOTCOUNT_BE
#ifndef CONFIG_SPL_USBETH_SUPPORT #define CONFIG_FASTBOOT_FLASH_MMC_DEV 1 diff --git a/include/configs/baltos.h b/include/configs/baltos.h index 37c71bb433..c65eeedb53 100644 --- a/include/configs/baltos.h +++ b/include/configs/baltos.h @@ -248,7 +248,7 @@ /* General network SPL, both CPSW and USB gadget RNDIS */ #define CONFIG_SPL_NET_VCI_STRING "AM335x U-Boot SPL"*/
#ifdef CONFIG_NAND #define CONFIG_NAND_OMAP_GPMC diff --git a/include/configs/bav335x.h b/include/configs/bav335x.h index d5347e626f..924a351c38 100644 --- a/include/configs/bav335x.h +++ b/include/configs/bav335x.h @@ -348,7 +348,7 @@ DEFAULT_LINUX_BOOT_ENV \
#ifdef CONFIG_NAND diff --git a/include/configs/bur_am335x_common.h b/include/configs/bur_am335x_common.h index e2da016f47..3742514a6e 100644 --- a/include/configs/bur_am335x_common.h +++ b/include/configs/bur_am335x_common.h @@ -109,6 +109,6 @@
/* General parts of the framework, required. */ #define CONFIG_SPL_BOARD_INIT -#define CONFIG_SPL_LDSCRIPT "arch/arm/mach-omap2/am33xx/u-boot-spl.lds" +#define CONFIG_SPL_LDSCRIPT "arch/arm/mach-omap2/u-boot-spl.lds"
#endif /* ! __BUR_AM335X_COMMON_H__ */ diff --git a/include/configs/chiliboard.h b/include/configs/chiliboard.h index c1669fa788..f515db038d 100644 --- a/include/configs/chiliboard.h +++ b/include/configs/chiliboard.h @@ -130,7 +130,7 @@ #define CONFIG_BOOTCOUNT_AM33XX #define CONFIG_SYS_BOOTCOUNT_BE
/* NAND: device related configs */ #define CONFIG_SYS_NAND_5_ADDR_CYCLE diff --git a/include/configs/cm_t335.h b/include/configs/cm_t335.h index 69137bc6e8..9a8e1302c5 100644 --- a/include/configs/cm_t335.h +++ b/include/configs/cm_t335.h @@ -99,7 +99,7 @@ #define CONFIG_SYS_I2C_EEPROM_BUS 0
/* Network. */ #define CONFIG_PHY_GIGE diff --git a/include/configs/pcm051.h b/include/configs/pcm051.h index 9ce976ce43..ea3872f5c9 100644 --- a/include/configs/pcm051.h +++ b/include/configs/pcm051.h @@ -119,7 +119,7 @@ /* CPU */ #define CONFIG_ENV_IS_NOWHERE
#ifdef CONFIG_SPI_BOOT #define CONFIG_SPL_SPI_LOAD diff --git a/include/configs/pengwyn.h b/include/configs/pengwyn.h index b8fb371827..9c99aa106d 100644 --- a/include/configs/pengwyn.h +++ b/include/configs/pengwyn.h @@ -205,6 +205,6 @@
/* CPSW support */
#endif /* ! __CONFIG_PENGWYN_H */ diff --git a/include/configs/pepper.h b/include/configs/pepper.h index 9552dd1bcb..5abeffbade 100644 --- a/include/configs/pepper.h +++ b/include/configs/pepper.h @@ -86,6 +86,6 @@ #define CONFIG_PHY_RESET_DELAY 1000
#endif /* __CONFIG_PEPPER_H */ diff --git a/include/configs/siemens-am33x-common.h b/include/configs/siemens-am33x-common.h index d69f513c65..508b849472 100644 --- a/include/configs/siemens-am33x-common.h +++ b/include/configs/siemens-am33x-common.h @@ -126,7 +126,7 @@ #define CONFIG_SPL_SPI_LOAD #define CONFIG_SYS_SPI_U_BOOT_OFFS 0x20000
#define CONFIG_SPL_BOARD_INIT #define CONFIG_SPL_NAND_AM33XX_BCH
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com Reviewed-by: Tom Rini trini@konsulko.com
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- Changes since v1: - Update base addresses for MMC0 and MMC1 board/ti/am335x/board.c | 32 ++++++++++++++++++++++++++++++++ 1 file changed, 32 insertions(+)
diff --git a/board/ti/am335x/board.c b/board/ti/am335x/board.c index 3e842d3187..6786229680 100644 --- a/board/ti/am335x/board.c +++ b/board/ti/am335x/board.c @@ -9,6 +9,7 @@ */
#include <common.h> +#include <dm.h> #include <errno.h> #include <spl.h> #include <serial.h> @@ -26,6 +27,7 @@ #include <asm/emif.h> #include <asm/gpio.h> #include <asm/omap_sec_common.h> +#include <asm/omap_mmc.h> #include <i2c.h> #include <miiphy.h> #include <cpsw.h> @@ -892,3 +894,33 @@ void board_fit_image_post_process(void **p_image, size_t *p_size) secure_boot_verify_image(p_image, p_size); } #endif + +#if !CONFIG_IS_ENABLED(OF_CONTROL) +static const struct omap_hsmmc_plat am335x_mmc0_platdata = { + .base_addr = (struct hsmmc *)OMAP_HSMMC1_BASE, + .cfg.host_caps = MMC_MODE_HS_52MHz | MMC_MODE_HS | MMC_MODE_4BIT, + .cfg.f_min = 400000, + .cfg.f_max = 52000000, + .cfg.voltages = MMC_VDD_32_33 | MMC_VDD_33_34 | MMC_VDD_165_195, + .cfg.b_max = CONFIG_SYS_MMC_MAX_BLK_COUNT, +}; + +U_BOOT_DEVICE(am335x_mmc0) = { + .name = "omap_hsmmc", + .platdata = &am335x_mmc0_platdata, +}; + +static const struct omap_hsmmc_plat am335x_mmc1_platdata = { + .base_addr = (struct hsmmc *)OMAP_HSMMC2_BASE, + .cfg.host_caps = MMC_MODE_HS_52MHz | MMC_MODE_HS | MMC_MODE_8BIT, + .cfg.f_min = 400000, + .cfg.f_max = 52000000, + .cfg.voltages = MMC_VDD_32_33 | MMC_VDD_33_34 | MMC_VDD_165_195, + .cfg.b_max = CONFIG_SYS_MMC_MAX_BLK_COUNT, +}; + +U_BOOT_DEVICE(am335x_mmc1) = { + .name = "omap_hsmmc", + .platdata = &am335x_mmc1_platdata, +}; +#endif
Changes since v1:
Do you need to address the offset factor here if you're going to rebase from my series? My series removed the offset from struct hsmmc because I assummed (maybe wrongly) that everyone who was using DM_MMC was using OF_CONFIG. Since I assumed that people where using OF_CONFIG, I removed the offset from the structure and moved it elsewhere.
struct hsmmc { -#ifdef CONFIG_DM_MMC - unsigned char res0[0x100]; -#endif
If you're going under the assumption that people might use DM_MMC and without OF_CONTROL, I am concerned this may break because the offset was removed. I think that may be what Tony was trying to say.
If we update my patch to put the offset back, when OF_CONTROL is not present, then it may break the functionality of OMAP3 users want to use DM_MMC without OF_CONTROL which means, then the ifdef would grow.
struct hsmmc { #if (defined(CONFIG_DM_MMC) && !defined(CONFIG_OF_CONTROL) && !defined(CONFIG_OMAP34XX)) unsigned char res0[0x100]; #endif
And that gets really ugly and part of what I was trying to avoid.
I wonder if we can somehow add the appropriate offset here like
.base_addr = (struct hsmmc *) (OMAP_HSMMC1_BASE + 0x100)
I am just thinking out loud, so forgive the excessive chatter, but since I don't have am33xx hardware, I can only give my ideas without testing.
See above on base_addr.
2.11.0
Changes since v1:
OMAP_HSMMC1_BASE includes the offset. This is currently being used in driver as well for non-DM cases.
Thanks and regards, Lokesh
Changes since v1:
Great!
thanks
-- Tom
Tom - Do you know if his series and/or my OMAP3 device tree series with MMC changes will be accepted? I haven't heard or seen any feedback on either other than that's already been in here.
adam
I think we'll take these in with the next release (v2017.07).
OK. Cool. Thanks
-- Tom
http://patchwork.ozlabs.org/patch/751300/ Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- Changes since v1: - None arch/arm/mach-omap2/am33xx/Kconfig | 5 +++++ include/configs/am335x_evm.h | 1 - include/configs/ti_am335x_common.h | 2 ++ 3 files changed, 7 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-omap2/am33xx/Kconfig b/arch/arm/mach-omap2/am33xx/Kconfig index cf5d95a26d..acdb88a702 100644 --- a/arch/arm/mach-omap2/am33xx/Kconfig +++ b/arch/arm/mach-omap2/am33xx/Kconfig @@ -29,6 +29,11 @@ config TARGET_AM335X_EVM imply SPL_SERIAL_SUPPORT imply SPL_WATCHDOG_SUPPORT imply SPL_YMODEM_SUPPORT + imply SPL_SYS_MALLOC_SIMPLE + imply SPL_SEPARATE_BSS + imply SPL_DM + imply SPL_DM_SEQ_ALIAS + imply SPL_OF_LIBFDT help This option specifies support for the AM335x GP and HS EVM development platforms. The AM335x diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index 796d5c32e9..51c3d493c8 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -291,7 +291,6 @@ * DM support in SPL */ #ifdef CONFIG_SPL_BUILD -#undef CONFIG_DM_MMC #undef CONFIG_TIMER #undef CONFIG_DM_USB #endif diff --git a/include/configs/ti_am335x_common.h b/include/configs/ti_am335x_common.h index c0e4336eb0..e4c3c807f2 100644 --- a/include/configs/ti_am335x_common.h +++ b/include/configs/ti_am335x_common.h @@ -22,8 +22,10 @@ /* NS16550 Configuration */ #ifdef CONFIG_SPL_BUILD #define CONFIG_SYS_NS16550_SERIAL +#ifndef CONFIG_DM_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE (-4) #endif +#endif #define CONFIG_SYS_NS16550_CLK 48000000
#ifndef CONFIG_SPL_BUILD
am335x_evm SPL is very close to its limit in SRAM space. Switch to use tiny printf to reclaim some size.
Reviewed-by: Tom Rini trini@konsulko.com Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- Changes since v1: - None arch/arm/Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 7812f21f36..7368f6b95c 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -761,6 +761,7 @@ config AM33XX bool "AM33XX SoC" select ARCH_OMAP2 imply SYS_THUMB_BUILD + imply USE_TINY_PRINTF help Support for AM335x SOC from Texas Instruments. The AM335x high performance SOC features a Cortex-A8
Adam Ford
Lokesh Vutla
