[U-Boot-Users] [PATCH 0/1] vsprintf: add z and t options
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com --- lib_generic/vsprintf.c | 12 +++++++++--- 1 files changed, 9 insertions(+), 3 deletions(-)
diff --git a/lib_generic/vsprintf.c b/lib_generic/vsprintf.c index 3db6c3f..1d9b25b 100644 --- a/lib_generic/vsprintf.c +++ b/lib_generic/vsprintf.c @@ -262,7 +262,9 @@ int vsprintf(char *buf, const char *fmt, va_list args)
/* get the conversion qualifier */ qualifier = -1; - if (*fmt == 'h' || *fmt == 'l' || *fmt == 'q') { + if (*fmt == 'h' || *fmt == 'l' || *fmt == 'L' || + *fmt =='Z' || *fmt == 'z' || *fmt == 't' || + *fmt == 'q' ) { qualifier = *fmt; if (qualifier == 'l' && *(fmt+1) == 'l') { qualifier = 'q'; @@ -355,9 +357,13 @@ int vsprintf(char *buf, const char *fmt, va_list args) num = va_arg(args, unsigned long long); else #endif - if (qualifier == 'l') + if (qualifier == 'l') { num = va_arg(args, unsigned long); - else if (qualifier == 'h') { + } else if (qualifier == 'Z' || qualifier == 'z') { + num = va_arg(args, size_t); + } else if (qualifier == 't') { + num = va_arg(args, ptrdiff_t); + } else if (qualifier == 'h') { num = (unsigned short) va_arg(args, int); if (flags & SIGN) num = (short) num;
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com --- common/cmd_flash.c | 4 ++-- drivers/usb/usbdcore.c | 2 +- fs/jffs2/jffs2_1pass.c | 4 ++-- 3 files changed, 5 insertions(+), 5 deletions(-)
diff --git a/common/cmd_flash.c b/common/cmd_flash.c index 9bd8074..d959c3d 100644 --- a/common/cmd_flash.c +++ b/common/cmd_flash.c @@ -342,7 +342,7 @@ int do_flerase (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) puts ("Bad sector specification\n"); return 1; } - printf ("Erase Flash Sectors %d-%d in Bank # %d ", + printf ("Erase Flash Sectors %d-%d in Bank # %zu ", sect_first, sect_last, (info-flash_info)+1); rcode = flash_erase(info, sect_first, sect_last); return rcode; @@ -534,7 +534,7 @@ int do_protect (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) puts ("Bad sector specification\n"); return 1; } - printf("%sProtect Flash Sectors %d-%d in Bank # %d\n", + printf("%sProtect Flash Sectors %d-%d in Bank # %zu\n", p ? "" : "Un-", sect_first, sect_last, (info-flash_info)+1); for (i = sect_first; i <= sect_last; i++) { diff --git a/drivers/usb/usbdcore.c b/drivers/usb/usbdcore.c index 808da9f..53ed669 100644 --- a/drivers/usb/usbdcore.c +++ b/drivers/usb/usbdcore.c @@ -552,7 +552,7 @@ struct urb *usbd_alloc_urb (struct usb_device_instance *device, struct urb *urb;
if (!(urb = (struct urb *) malloc (sizeof (struct urb)))) { - usberr (" F A T A L: malloc(%u) FAILED!!!!", + usberr (" F A T A L: malloc(%zu) FAILED!!!!", sizeof (struct urb)); return NULL; } diff --git a/fs/jffs2/jffs2_1pass.c b/fs/jffs2/jffs2_1pass.c index 5c1d265..3c454f6 100644 --- a/fs/jffs2/jffs2_1pass.c +++ b/fs/jffs2/jffs2_1pass.c @@ -1213,12 +1213,12 @@ jffs2_1pass_build_lists(struct part_info * part) } else if (node->nodetype == JFFS2_NODETYPE_CLEANMARKER) { if (node->totlen != sizeof(struct jffs2_unknown_node)) printf("OOPS Cleanmarker has bad size " - "%d != %u\n", node->totlen, + "%d != %zu\n", node->totlen, sizeof(struct jffs2_unknown_node)); } else if (node->nodetype == JFFS2_NODETYPE_PADDING) { if (node->totlen < sizeof(struct jffs2_unknown_node)) printf("OOPS Padding has bad size " - "%d < %u\n", node->totlen, + "%d < %zu\n", node->totlen, sizeof(struct jffs2_unknown_node)); } else { printf("Unknown node type: %x len %d "
In message 1216037506-20460-2-git-send-email-plagnioj@jcrosoft.com you wrote:
Thanks, but your patch catches only a small part of all uses of sizeof_t in printf() and debug() calls. I tried to find and fix the other locations, too - see "[PATCH] Fix printf() format issues with sizeof_t types by using %zu"
In message 1216037506-20460-1-git-send-email-plagnioj@jcrosoft.com you wrote:
Applied, thanks.
