Re: [U-Boot] [PATCH 1/3] armv8/cache: Consolidate setting for MAIR and TCR
hi York,
-----Original Messages----- From: "York Sun" yorksun@freescale.com Sent Time: 2014-02-11 05:55:52 (Tuesday) To: albert.u.boot@aribaud.net Cc: scottwood@freescale.com, "York Sun" yorksun@freescale.com, "David Feng" fenghua@phytium.com.cn Subject: [PATCH 1/3] armv8/cache: Consolidate setting for MAIR and TCR
Move setting for MAIR and TCR to cache_v8.c, to avoid conflict with sub-architecture.
Signed-off-by: York Sun yorksun@freescale.com CC: David Feng fenghua@phytium.com.cn
arch/arm/cpu/armv8/cache_v8.c | 22 +++++++++++++++++++--- arch/arm/cpu/armv8/start.S | 22 ---------------------- 2 files changed, 19 insertions(+), 25 deletions(-)
diff --git a/arch/arm/cpu/armv8/cache_v8.c b/arch/arm/cpu/armv8/cache_v8.c index 131fdab..7acae1b 100644 --- a/arch/arm/cpu/armv8/cache_v8.c +++ b/arch/arm/cpu/armv8/cache_v8.c @@ -45,15 +45,31 @@ static void mmu_setup(void)
/* load TTBR0 */ el = current_el();
- if (el == 1)
- if (el == 1) { asm volatile("msr ttbr0_el1, %0" : : "r" (gd->arch.tlb_addr) : "memory");
- else if (el == 2)
asm volatile("msr tcr_el1, %0"
: : "r" (TCR_FLAGS | TCR_EL1_IPS_BITS)
: "memory");
asm volatile("msr mair_el1, %0"
: : "r" (MEMORY_ATTRIBUTES) : "memory");
- } else if (el == 2) { asm volatile("msr ttbr0_el2, %0" : : "r" (gd->arch.tlb_addr) : "memory");
- else
asm volatile("msr tcr_el2, %0"
: : "r" (TCR_FLAGS | TCR_EL2_IPS_BITS)
: "memory");
asm volatile("msr mair_el2, %0"
} else { asm volatile("msr ttbr0_el3, %0" : : "r" (gd->arch.tlb_addr) : "memory");
asm volatile("msr tcr_el3, %0"
: "memory");
asm volatile("msr mair_el3, %0"
/* enable the mmu */ set_sctlr(get_sctlr() | CR_M);
diff --git a/arch/arm/cpu/armv8/start.S b/arch/arm/cpu/armv8/start.S index bcc2603..90daa4d 100644 --- a/arch/arm/cpu/armv8/start.S +++ b/arch/arm/cpu/armv8/start.S @@ -128,28 +128,6 @@ ENTRY(c_runtime_cpu_setup) isb sy #endif
-#ifndef CONFIG_SYS_DCACHE_OFF
* Setup MAIR and TCR.
- ldr x0, =MEMORY_ATTRIBUTES
- ldr x1, =TCR_FLAGS
- switch_el x2, 3f, 2f, 1f
-3: orr x1, x1, TCR_EL3_IPS_BITS
- msr mair_el3, x0
- msr tcr_el3, x1
- b 0f
-2: orr x1, x1, TCR_EL2_IPS_BITS
- msr mair_el2, x0
- msr tcr_el2, x1
- b 0f
-1: orr x1, x1, TCR_EL1_IPS_BITS
- msr mair_el1, x0
- msr tcr_el1, x1
-0: -#endif
- /* Relocate vBAR */ adr x0, vectors switch_el x1, 3f, 2f, 1f
-- 1.7.9.5
This will be better. Acked.
FengHua
