[U-Boot] [PATCH] powerpc/mpc85xx:Add BSC9131/BSC9130/BSC9231 Processor Support
- BSC9131 is integrated device that targets Femto base station market. It combines Power Architecture e500v2 and DSP StarCore SC3850 core technologies with MAPLE-B2F baseband acceleration processing elements. - BSC9130 is exactly same as BSC9131 except that the max e500v2 core and DSP core frequencies are 800M(these are 1G in case of 9131). - BSC9231 is similar to BSC9131 except no MAPLE
The BSC9131 SoC includes the following function and features: . Power Architecture subsystem including a e500 processor with 256-Kbyte shared L2 cache . StarCore SC3850 DSP subsystem with a 512-Kbyte private L2 cache . The Multi Accelerator Platform Engine for Femto BaseStation Baseband Processing (MAPLE-B2F) . A multi-standard baseband algorithm accelerator for Channel Decoding/Encoding, Fourier Transforms, UMTS chip rate processing, LTE UP/DL Channel processing, and CRC algorithms . Consists of accelerators for Convolution, Filtering, Turbo Encoding, Turbo Decoding, Viterbi decoding, Chiprate processing, and Matrix Inversion operations . DDR3/3L memory interface with 32-bit data width without ECC and 16-bit with ECC, up to 400-MHz clock/800 MHz data rate . Dedicated security engine featuring trusted boot . DMA controller . OCNDMA with four bidirectional channels . Interfaces . Two triple-speed Gigabit Ethernet controllers featuring network acceleration including IEEE 1588. v2 hardware support and virtualization (eTSEC) . eTSEC 1 supports RGMII/RMII . eTSEC 2 supports RGMII . High-speed USB 2.0 host and device controller with ULPI interface . Enhanced secure digital (SD/MMC) host controller (eSDHC) . Antenna interface controller (AIC), supporting three industry standard JESD207/three custom ADI RF interfaces (two dual port and one single port) and three MAXIM's MaxPHY serial interfaces . ADI lanes support both full duplex FDD support and half duplex TDD support . Universal Subscriber Identity Module (USIM) interface that facilitates communication to SIM cards or Eurochip pre-paid phone cards . TDM with one TDM port . Two DUART, four eSPI, and two I2C controllers . Integrated Flash memory controller (IFC) . TDM with 256 channels . GPIO . Sixteen 32-bit timers
The DSP portion of the SoC consists of DSP core (SC3850) and various accelerators pertaining to DSP operations.
This patch takes care of code pertaining to power side functionality only.
Signed-off-by: Ramneek Mehresh ramneek.mehresh@freescale.com Signed-off-by: Priyanka Jain Priyanka.Jain@freescale.com Signed-off-by: Akhil Goyal Akhil.Goyal@freescale.com Signed-off-by: Poonam Aggrwal poonam.aggrwal@freescale.com Signed-off-by: Rajan Srivastava rajan.srivastava@freescale.com Signed-off-by: Prabhakar Kushwaha prabhakar@freescale.com --- Note: Name of PSC9131 has been changed to BSC9131 because of new nomenclature. So please reject earlier patch: "PSC9131/PSC9130/PSC9231 Processor Support Added" http://patchwork.ozlabs.org/patch/141048/
arch/powerpc/cpu/mpc85xx/Makefile | 1 + arch/powerpc/cpu/mpc8xxx/cpu.c | 6 +- arch/powerpc/include/asm/config_mpc85xx.h | 14 +++- arch/powerpc/include/asm/immap_85xx.h | 117 ++++++++++++++++++++++++++++- arch/powerpc/include/asm/processor.h | 5 + 5 files changed, 140 insertions(+), 3 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/Makefile b/arch/powerpc/cpu/mpc85xx/Makefile index 058d609..e3a7c14 100644 --- a/arch/powerpc/cpu/mpc85xx/Makefile +++ b/arch/powerpc/cpu/mpc85xx/Makefile @@ -70,6 +70,7 @@ COBJS-$(CONFIG_PPC_P3041) += ddr-gen3.o COBJS-$(CONFIG_PPC_P3060) += ddr-gen3.o COBJS-$(CONFIG_PPC_P4080) += ddr-gen3.o COBJS-$(CONFIG_PPC_P5020) += ddr-gen3.o +COBJS-$(CONFIG_BSC9131) += ddr-gen3.o
COBJS-$(CONFIG_CPM2) += ether_fcc.o COBJS-$(CONFIG_OF_LIBFDT) += fdt.o diff --git a/arch/powerpc/cpu/mpc8xxx/cpu.c b/arch/powerpc/cpu/mpc8xxx/cpu.c index 0365ca8..7340f69 100644 --- a/arch/powerpc/cpu/mpc8xxx/cpu.c +++ b/arch/powerpc/cpu/mpc8xxx/cpu.c @@ -1,5 +1,5 @@ /* - * Copyright 2009-2011 Freescale Semiconductor, Inc. + * Copyright 2009-2012 Freescale Semiconductor, Inc. * * This file is derived from arch/powerpc/cpu/mpc85xx/cpu.c and * arch/powerpc/cpu/mpc86xx/cpu.c. Basically this file contains @@ -113,6 +113,10 @@ struct cpu_type cpu_type_list [] = { CPU_TYPE_ENTRY(P5010, P5010_E, 1), CPU_TYPE_ENTRY(P5020, P5020, 2), CPU_TYPE_ENTRY(P5020, P5020_E, 2), + CPU_TYPE_ENTRY(BSC9130, 9130, 1), + CPU_TYPE_ENTRY(BSC9130, 9130_E, 1), + CPU_TYPE_ENTRY(BSC9131, 9131, 1), + CPU_TYPE_ENTRY(BSC9131, 9131_E, 1), #elif defined(CONFIG_MPC86xx) CPU_TYPE_ENTRY(8610, 8610, 1), CPU_TYPE_ENTRY(8641, 8641, 2), diff --git a/arch/powerpc/include/asm/config_mpc85xx.h b/arch/powerpc/include/asm/config_mpc85xx.h index 8654625..d1b9d5b 100644 --- a/arch/powerpc/include/asm/config_mpc85xx.h +++ b/arch/powerpc/include/asm/config_mpc85xx.h @@ -1,5 +1,5 @@ /* - * Copyright 2011 Freescale Semiconductor, Inc. + * Copyright 2011-2012 Freescale Semiconductor, Inc. * * This program is free software; you can redistribute it and/or * modify it under the terms of the GNU General Public License as @@ -459,6 +459,18 @@ #define CONFIG_SYS_FSL_ERRATUM_ESDHC111 #define CONFIG_SYS_FSL_ERRATUM_DDR_A003474
+#elif defined(CONFIG_BSC9131) +#define CONFIG_MAX_CPUS 1 +#define CONFIG_FSL_SDHC_V2_3 +#define CONFIG_SYS_FSL_NUM_LAWS 12 +#define CONFIG_TSECV2 +#define CONFIG_SYS_FSL_SEC_COMPAT 4 +#define CONFIG_NUM_DDR_CONTROLLERS 1 +#define CONFIG_SYS_CCSRBAR_DEFAULT 0xff700000 +#define CONFIG_NAND_FSL_IFC +#define CONFIG_SYS_FSL_ERRATUM_IFC_A003399 +#define CONFIG_SYS_FSL_ERRATUM_ESDHC111 + #else #error Processor type not defined for this platform #endif diff --git a/arch/powerpc/include/asm/immap_85xx.h b/arch/powerpc/include/asm/immap_85xx.h index 9b08cb8..9e52705 100644 --- a/arch/powerpc/include/asm/immap_85xx.h +++ b/arch/powerpc/include/asm/immap_85xx.h @@ -1,7 +1,7 @@ /* * MPC85xx Internal Memory Map * - * Copyright 2007-2011 Freescale Semiconductor, Inc. + * Copyright 2007-2012 Freescale Semiconductor, Inc. * * Copyright(c) 2002,2003 Motorola Inc. * Xianghua Xiao (x.xiao@motorola.com) @@ -1870,7 +1870,11 @@ typedef struct ccsr_gur { #define MPC85xx_PORPLLSR_DDR_RATIO 0x3e000000 #define MPC85xx_PORPLLSR_DDR_RATIO_SHIFT 25 #else +#ifdef CONFIG_BSC9131 +#define MPC85xx_PORPLLSR_DDR_RATIO 0x00003f00 +#else #define MPC85xx_PORPLLSR_DDR_RATIO 0x00003e00 +#endif #define MPC85xx_PORPLLSR_DDR_RATIO_SHIFT 9 #endif #define MPC85xx_PORPLLSR_QE_RATIO 0x3e000000 @@ -2017,6 +2021,50 @@ typedef struct ccsr_gur { #define MPC85xx_PMUXCR_SPI_MASK 0x00600000 #define MPC85xx_PMUXCR_SPI 0x00000000 #endif +#if defined(CONFIG_BSC9131) +#define MPC85xx_PMUXCR_TSEC2_DMA_GPIO_IRQ 0x40000000 +#define MPC85xx_PMUXCR_TSEC2_USB 0xC0000000 +#define MPC85xx_PMUXCR_TSEC2_1588_PPS 0x10000000 +#define MPC85xx_PMUXCR_TSEC2_1588_RSVD 0x30000000 +#define MPC85xx_PMUXCR_IFC_AD_GPIO 0x04000000 +#define MPC85xx_PMUXCR_IFC_AD_GPIO_MASK 0x0C000000 +#define MPC85xx_PMUXCR_IFC_AD15_GPIO 0x01000000 +#define MPC85xx_PMUXCR_IFC_AD15_TIMER2 0x02000000 +#define MPC85xx_PMUXCR_IFC_AD16_GPO8 0x00400000 +#define MPC85xx_PMUXCR_IFC_AD16_MSRCID0 0x00800000 +#define MPC85xx_PMUXCR_IFC_AD17_GPO 0x00100000 +#define MPC85xx_PMUXCR_IFC_AD17_GPO_MASK 0x00300000 +#define MPC85xx_PMUXCR_IFC_AD17_MSRCID_DSP 0x00200000 +#define MPC85xx_PMUXCR_IFC_CS2_GPO65 0x00040000 +#define MPC85xx_PMUXCR_IFC_CS2_DSP_TDI 0x00080000 +#define MPC85xx_PMUXCR_SDHC_USIM 0x00010000 +#define MPC85xx_PMUXCR_SDHC_TDM_RFS_RCK 0x00020000 +#define MPC85xx_PMUXCR_SDHC_GPIO77 0x00030000 +#define MPC85xx_PMUXCR_SDHC_RESV 0x00004000 +#define MPC85xx_PMUXCR_SDHC_TDM_TXD_RXD 0x00008000 +#define MPC85xx_PMUXCR_SDHC_GPIO_TIMER4 0x0000C000 +#define MPC85xx_PMUXCR_USB_CLK_UART_SIN 0x00001000 +#define MPC85xx_PMUXCR_USB_CLK_GPIO69 0x00002000 +#define MPC85xx_PMUXCR_USB_CLK_TIMER3 0x00003000 +#define MPC85xx_PMUXCR_USB_UART_GPIO0 0x00000400 +#define MPC85xx_PMUXCR_USB_RSVD 0x00000C00 +#define MPC85xx_PMUXCR_USB_GPIO62_TRIG_IN 0x00000800 +#define MPC85xx_PMUXCR_USB_D1_2_IIC2_SDA_SCL 0x00000100 +#define MPC85xx_PMUXCR_USB_D1_2_GPIO71_72 0x00000200 +#define MPC85xx_PMUXCR_USB_D1_2_RSVD 0x00000300 +#define MPC85xx_PMUXCR_USB_DIR_GPIO2 0x00000040 +#define MPC85xx_PMUXCR_USB_DIR_TIMER1 0x00000080 +#define MPC85xx_PMUXCR_USB_DIR_MCP_B 0x000000C0 +#define MPC85xx_PMUXCR_SPI1_UART3 0x00000010 +#define MPC85xx_PMUXCR_SPI1_SIM 0x00000020 +#define MPC85xx_PMUXCR_SPI1_CKSTP_IN_GPO74 0x00000030 +#define MPC85xx_PMUXCR_SPI1_CS2_CKSTP_OUT_B 0x00000004 +#define MPC85xx_PMUXCR_SPI1_CS2_dbg_adi1_rxen 0x00000008 +#define MPC85xx_PMUXCR_SPI1_CS2_GPO75 0x0000000C +#define MPC85xx_PMUXCR_SPI1_CS3_ANT_TCXO_PWM 0x00000001 +#define MPC85xx_PMUXCR_SPI1_CS3_dbg_adi2_rxen 0x00000002 +#define MPC85xx_PMUXCR_SPI1_CS3_GPO76 0x00000003 +#endif u32 pmuxcr2; /* Alt. function signal multiplex control 2 */ #if defined(CONFIG_P1010) || defined(CONFIG_P1014) #define MPC85xx_PMUXCR2_UART_GPIO 0x40000000 @@ -2047,7 +2095,69 @@ typedef struct ccsr_gur { #define MPC85xx_PMUXCR2_ETSECUSB_MASK 0x001f8000 #define MPC85xx_PMUXCR2_USB 0x00150000 #endif +#if defined(CONFIG_BSC9131) +#define MPC85xx_PMUXCR2_UART_CTS_B0_SIM_PD 0X40000000 +#define MPC85xx_PMUXCR2_UART_CTS_B0_DSP_TMS 0X80000000 +#define MPC85xx_PMUXCR2_UART_CTS_B0_GPIO42 0xC0000000 +#define MPC85xx_PMUXCR2_UART_RTS_B0_PWM2 0x10000000 +#define MPC85xx_PMUXCR2_UART_RTS_B0_DSP_TCK 0x20000000 +#define MPC85xx_PMUXCR2_UART_RTS_B0_GPIO43 0x30000000 +#define MPC85xx_PMUXCR2_UART_CTS_B1_SIM_PD 0x04000000 +#define MPC85xx_PMUXCR2_UART_CTS_B1_SRESET_B 0x08000000 +#define MPC85xx_PMUXCR2_UART_CTS_B1_GPIO44 0x0C000000 +#define MPC85xx_PMUXCR2_UART_RTS_B1_PPS_LED 0x01000000 +#define MPC85xx_PMUXCR2_UART_RTS_B1_RSVD 0x02000000 +#define MPC85xx_PMUXCR2_UART_RTS_B1_GPIO45 0x03000000 +#define MPC85xx_PMUXCR2_TRIG_OUT_ASLEEP 0x00400000 +#define MPC85xx_PMUXCR2_TRIG_OUT_DSP_TRST_B 0x00800000 +#define MPC85xx_PMUXCR2_ANT1_TIMER5 0x00100000 +#define MPC85xx_PMUXCR2_ANT1_TSEC_1588 0x00200000 +#define MPC85xx_PMUXCR2_ANT1_GPIO95_19 0x00300000 +#define MPC85xx_PMUXCR2_ANT1_TX_RX_FRAME_MAX3_LOCK 0x00040000 +#define MPC85xx_PMUXCR2_ANT1_TX_RX_FRAME_RSVD 0x00080000 +#define MPC85xx_PMUXCR2_ANT1_TX_RX_FRAME_GPIO80_20 0x000C0000 +#define MPC85xx_PMUXCR2_ANT1_DIO0_3_SPI3_CS0 0x00010000 +#define MPC85xx_PMUXCR2_ANT1_DIO0_3_ANT2_DO_3 0x00020000 +#define MPC85xx_PMUXCR2_ANT1_DIO0_3_GPIO81_84 0x00030000 +#define MPC85xx_PMUXCR2_ANT1_DIO4_7_SPI4 0x00004000 +#define MPC85xx_PMUXCR2_ANT1_DIO4_7_ANT2_DO4_7 0x00008000 +#define MPC85xx_PMUXCR2_ANT1_DIO4_7_GPIO85_88 0x0000C000 +#define MPC85xx_PMUXCR2_ANT1_DIO8_9_MAX2_1_LOCK 0x00001000 +#define MPC85xx_PMUXCR2_ANT1_DIO8_9_ANT2_DO8_9 0x00002000 +#define MPC85xx_PMUXCR2_ANT1_DIO8_9_GPIO21_22 0x00003000 +#define MPC85xx_PMUXCR2_ANT1_DIO10_11_TIMER6_7 0x00000400 +#define MPC85xx_PMUXCR2_ANT1_DIO10_11_ANT2_DO10_11 0x00000800 +#define MPC85xx_PMUXCR2_ANT1_DIO10_11_GPIO23_24 0x00000C00 +#define MPC85xx_PMUXCR2_ANT2_RSVD 0x00000100 +#define MPC85xx_PMUXCR2_ANT2_GPO90_91_DMA 0x00000300 +#define MPC85xx_PMUXCR2_ANT2_ENABLE_DIO0_10_USB 0x00000040 +#define MPC85xx_PMUXCR2_ANT2_ENABLE_DIO0_10_GPIO 0x000000C0 +#define MPC85xx_PMUXCR2_ANT2_DIO11_RSVD 0x00000010 +#define MPC85xx_PMUXCR2_ANT2_DIO11_TIMER8 0x00000020 +#define MPC85xx_PMUXCR2_ANT2_DIO11_GPIO61 0x00000030 +#define MPC85xx_PMUXCR2_ANT3_AGC_GPO53 0x00000004 +#define MPC85xx_PMUXCR2_ANT3_DO_TDM 0x00000001 +#define MPC85xx_PMUXCR2_ANT3_DO_GPIO46_49 0x00000002 + u32 pmuxcr3; + +#define MPC85xx_PMUXCR3_ANT3_DO4_5_TDM 0x40000000 +#define MPC85xx_PMUXCR3_ANT3_DO4_5_GPIO_50_51 0x80000000 +#define MPC85xx_PMUXCR3_ANT3_DO6_7_TRIG_IN_SRESET_B 0x10000000 +#define MPC85xx_PMUXCR3_ANT3_DO6_7_GPIO_52_53 0x20000000 +#define MPC85xx_PMUXCR3_ANT3_DO8_MCP_B 0x04000000 +#define MPC85xx_PMUXCR3_ANT3_DO8_GPIO54 0x08000000 +#define MPC85xx_PMUXCR3_ANT3_DO9_10_CKSTP_IN_OUT 0x01000000 +#define MPC85xx_PMUXCR3_ANT3_DO9_10_GPIO55_56 0x02000000 +#define MPC85xx_PMUXCR3_ANT3_DO11_IRQ_OUT 0x00400000 +#define MPC85xx_PMUXCR3_ANT3_DO11_GPIO57 0x00800000 +#define MPC85xx_PMUXCR3_SPI2_CS2_GPO93 0x00100000 +#define MPC85xx_PMUXCR3_SPI2_CS3_GPO94 0x00040000 +#define MPC85xx_PMUXCR3_ANT2_AGC_RSVD 0x00010000 +#define MPC85xx_PMUXCR3_ANT2_GPO89 0x00030000 + u32 pmuxcr4; +#else u8 res6[8]; +#endif u32 devdisr; /* Device disable control */ #define MPC85xx_DEVDISR_PCI1 0x80000000 #define MPC85xx_DEVDISR_PCI2 0x40000000 @@ -2533,4 +2643,9 @@ struct ccsr_rman { #define TSEC_BASE_ADDR (CONFIG_SYS_IMMR + CONFIG_SYS_TSEC1_OFFSET) #define MDIO_BASE_ADDR (CONFIG_SYS_IMMR + CONFIG_SYS_MDIO1_OFFSET)
+#if defined(CONFIG_BSC9131) +#define HALTED_TO_HALT_REQ_MASK_REG 0xff7e0e30 +#define HALTED_TO_HALT_REQ_MASK_0 0x80000000 +#endif + #endif /*__IMMAP_85xx__*/ diff --git a/arch/powerpc/include/asm/processor.h b/arch/powerpc/include/asm/processor.h index 4e32639..c9e112c 100644 --- a/arch/powerpc/include/asm/processor.h +++ b/arch/powerpc/include/asm/processor.h @@ -1136,6 +1136,11 @@ #define SVR_8641 0x809000 #define SVR_8641D 0x809001
+#define SVR_9130 0x860001 +#define SVR_9130_E 0x860801 +#define SVR_9131 0x860000 +#define SVR_9131_E 0x860800 + #define SVR_Unknown 0xFFFFFF
#define _GLOBAL(n)\
On Thu, Mar 15, 2012 at 1:41 AM, Prabhakar Kushwaha prabhakar@freescale.com wrote:
- Copyright 2009-2011 Freescale Semiconductor, Inc.
- Copyright 2009-2012 Freescale Semiconductor, Inc.
- CPU_TYPE_ENTRY(BSC9130, 9130, 1),
- CPU_TYPE_ENTRY(BSC9130, 9130_E, 1),
- CPU_TYPE_ENTRY(BSC9131, 9131, 1),
- CPU_TYPE_ENTRY(BSC9131, 9131_E, 1),
- Copyright 2011 Freescale Semiconductor, Inc.
- Copyright 2011-2012 Freescale Semiconductor, Inc.
- Copyright 2007-2011 Freescale Semiconductor, Inc.
- Copyright 2007-2012 Freescale Semiconductor, Inc.
Do we have an understanding of why this changed? The definition of these fields is beginning to get arbitrarily complicated.
- u32 pmuxcr3;
- u32 pmuxcr4;
Why not just add this register to the ccsr_gur struct? If someone attempts to adopt this code, and changes the CCSR, this hard-coded address will break.
Andy
Hi Andy,
Thanks for reviewing this patch.
Please find my reply in-lined
Signed-off-by: Ramneek Mehreshramneek.mehresh@freescale.com Signed-off-by: Priyanka JainPriyanka.Jain@freescale.com Signed-off-by: Akhil GoyalAkhil.Goyal@freescale.com Signed-off-by: Poonam Aggrwalpoonam.aggrwal@freescale.com Signed-off-by: Rajan Srivastavarajan.srivastava@freescale.com Signed-off-by: Prabhakar Kushwahaprabhakar@freescale.com
- This file is derived from arch/powerpc/cpu/mpc85xx/cpu.c and
- arch/powerpc/cpu/mpc86xx/cpu.c. Basically this file contains
#elif defined(CONFIG_MPC86xx) CPU_TYPE_ENTRY(8610, 8610, 1), CPU_TYPE_ENTRY(8641, 8641, 2),CPU_TYPE_ENTRY(BSC9131, 9131_E, 1),
- #else #error Processor type not defined for this platform #endif
- MPC85xx Internal Memory Map
- Copyright(c) 2002,2003 Motorola Inc.
- Xianghua Xiao (x.xiao@motorola.com)
Yes i agree. It gets complicated. But unfortunately These changes are done as per BSC9131's Reference manual. Number of bits and definition for DDR PLL ratio has been changed.
u32 pmuxcr3;
u32 pmuxcr4;
I will do the change.
Regards, Prabhakar
Andy Fleming
Prabhakar Kushwaha
