[U-Boot] [PATCH] FIX for dcache_disable() for ARM926ej-s
the cache also needs to be invalidated, not just flushed, Since re-enabling it, can cause inconsistent data without invalidation. See example below.
in c-file: static int num = 1;
void test() { num = 1; dcache_enable(); printf("Cache on, num=%d\n", num); num = 2; dcache_disable(); printf("Cache off, num=%d\n", num); num = 1; dcache_enable(); printf("Cache on, num=%d\n", num); // -> prints 2 instead of 1!! dcache_disable(); printf("Cache off, num=%d\n", num); } --- arch/arm/lib/cache.c | 2 ++ 1 files changed, 2 insertions(+), 0 deletions(-)
diff --git a/arch/arm/lib/cache.c b/arch/arm/lib/cache.c index b545fb7..10eb8c9 100644 --- a/arch/arm/lib/cache.c +++ b/arch/arm/lib/cache.c @@ -37,6 +37,8 @@ void __flush_cache(unsigned long start, unsigned long size) asm("0: mrc p15, 0, r15, c7, c10, 3\n\t" "bne 0b\n" : : : "memory"); /* disable write buffer as well (page 2-22) */ asm("mcr p15, 0, %0, c7, c10, 4" : : "r" (0)); + /* Invalidate dcache as well */ + asm("mcr p15, 0, %0, c7, c6, 0" : : "r" (0)); #endif return; }
Hello.
- /* Invalidate dcache as well */
- asm("mcr p15, 0, %0, c7, c6, 0" : : "r" (0));
Please indent with tabs as above.
WBR, Sergei
Hi Bas,
This part of the patch is what will stay in the GIT tree as the commit message. Here it is too verbose. Remove useless example.
Amicalement,
Albert ARIBAUD
Bas van den Berg
Sergei Shtylyov
