[U-Boot] [PATCH v2 4/4] ARM: configs: cm_fx6: add mtd support
From: Christopher Spinrath christopher.spinrath@rwth-aachen.de
The cm-fx6 module has an on-board spi flash chip. Enable mtd support and the mtdparts command. Also define a default partitioning, add it to the default environment, and enable support to overwrite the partitioning defined in a device tree by it. Finally, probe for the chip on preboot to register the flash chip and, thus, establish the connection between the mtd environment settings and the actual device.
These changes move the effective default partitioning from the device tree shipped with the vendor kernels to U-Boot which becomes the single point of definition for the partitioning for all device tree based kernels (in particular, for the upstream Linux kernel which does not have a default partitioning defined in its device tree).
Signed-off-by: Christopher Spinrath christopher.spinrath@rwth-aachen.de ---
Notes: Changes since v1: - explain the "sf probe" command added to preboot in the commit message
include/configs/cm_fx6.h | 19 ++++++++++++++++++- 1 file changed, 18 insertions(+), 1 deletion(-)
diff --git a/include/configs/cm_fx6.h b/include/configs/cm_fx6.h index f054ca8..c839b03 100644 --- a/include/configs/cm_fx6.h +++ b/include/configs/cm_fx6.h @@ -18,6 +18,7 @@ #define CONFIG_MACH_TYPE 4273
/* CMD */ +#define CONFIG_CMD_MTDPARTS
/* MMC */ #define CONFIG_SYS_FSL_USDHC_NUM 3 @@ -53,6 +54,20 @@ #define CONFIG_SF_DEFAULT_SPEED 25000000 #define CONFIG_SF_DEFAULT_MODE (SPI_MODE_0)
+/* MTD support */ +#ifndef CONFIG_SPL_BUILD +#define CONFIG_FDT_FIXUP_PARTITIONS +#define CONFIG_MTD_DEVICE +#define CONFIG_MTD_PARTITIONS +#define CONFIG_SPI_FLASH_MTD +#endif + +#define MTDIDS_DEFAULT "nor0=spi0.0" +#define MTDPARTS_DEFAULT "mtdparts=spi0.0:" \ + "768k(uboot)," \ + "256k(uboot-environment)," \ + "-(reserved)" + /* Environment */ #define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED @@ -83,6 +98,8 @@ "video_dvi=mxcfb0:dev=dvi,1280x800M-32@50,if=RGB32\0" \ "doboot=bootm ${loadaddr}\0" \ "doloadfdt=false\0" \ + "mtdids=" MTDIDS_DEFAULT "\0" \ + "mtdparts=" MTDPARTS_DEFAULT "\0" \ "setboottypez=setenv kernel ${zImage};" \ "setenv doboot bootz ${loadaddr} - ${fdtaddr};" \ "setenv doloadfdt true;\0" \ @@ -157,7 +174,7 @@ "run setupnandboot;" \ "run nandboot;"
-#define CONFIG_PREBOOT "usb start" +#define CONFIG_PREBOOT "usb start;sf probe"
/* SPI */ #define CONFIG_SPI
"768k(uboot)," \
"-(reserved)"
- "mtdids=" MTDIDS_DEFAULT "\0" \
- "mtdparts=" MTDPARTS_DEFAULT "\0" \ "setboottypez=setenv kernel ${zImage};" \ "setenv doboot bootz ${loadaddr} - ${fdtaddr};" \ "setenv doloadfdt true;\0" \
I put these on my queue list to be apply - I wait just for Nikita's ACK as board's maintainer.
Reviewed-by: Stefano Babic sbabic@denx.de
Best regards, Stefano Babic
Acked-by: Igor Grinberg grinberg@compulab.co.il
Igor Grinberg
Stefano Babic
