[PATCH] image: Add support for ZSTD decompression
This patch adds support for ZSTD decompression of FIT images.
Signed-off-by: Robert Marko robert.marko@sartura.hr Cc: Luka Perkov luka.perkov@sartura.hr --- common/image.c | 52 +++++++++++++++++++++++++++++++++++++++++++++++++ include/image.h | 1 + 2 files changed, 53 insertions(+)
diff --git a/common/image.c b/common/image.c index 94873cb6ed..70ba0f4328 100644 --- a/common/image.c +++ b/common/image.c @@ -42,6 +42,7 @@ #include <lzma/LzmaTypes.h> #include <lzma/LzmaDec.h> #include <lzma/LzmaTools.h> +#include <linux/zstd.h>
#ifdef CONFIG_CMD_BDI extern int do_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]); @@ -193,6 +194,7 @@ static const table_entry_t uimage_comp[] = { { IH_COMP_LZMA, "lzma", "lzma compressed", }, { IH_COMP_LZO, "lzo", "lzo compressed", }, { IH_COMP_LZ4, "lz4", "lz4 compressed", }, + { IH_COMP_ZSTD, "zstd", "zstd compressed", }, { -1, "", "", }, };
@@ -480,6 +482,56 @@ int image_decomp(int comp, ulong load, ulong image_start, int type, break; } #endif /* CONFIG_LZ4 */ +#ifdef CONFIG_ZSTD + case IH_COMP_ZSTD: { + size_t size = unc_len; + ZSTD_DStream *dstream; + ZSTD_inBuffer in_buf; + ZSTD_outBuffer out_buf; + void *workspace; + size_t wsize; + + wsize = ZSTD_DStreamWorkspaceBound(image_len); + workspace = malloc(wsize); + if (!workspace) { + debug("%s: cannot allocate workspace of size %zu\n", __func__, + wsize); + return -1; + } + + dstream = ZSTD_initDStream(image_len, workspace, wsize); + if (!dstream) { + printf("%s: ZSTD_initDStream failed\n", __func__); + return ZSTD_getErrorCode(ret); + } + + in_buf.src = image_buf; + in_buf.pos = 0; + in_buf.size = image_len; + + out_buf.dst = load_buf; + out_buf.pos = 0; + out_buf.size = size; + + while (1) { + size_t ret; + + ret = ZSTD_decompressStream(dstream, &out_buf, &in_buf); + if (ZSTD_isError(ret)) { + printf("%s: ZSTD_decompressStream error %d\n", __func__, + ZSTD_getErrorCode(ret)); + return ZSTD_getErrorCode(ret); + } + + if (in_buf.pos >= image_len || !ret) + break; + } + + image_len = out_buf.pos; + + break; + } +#endif /* CONFIG_ZSTD */ default: printf("Unimplemented compression type %d\n", comp); return -ENOSYS; diff --git a/include/image.h b/include/image.h index 3ffc0fdd68..8c79f6df9e 100644 --- a/include/image.h +++ b/include/image.h @@ -308,6 +308,7 @@ enum { IH_COMP_LZMA, /* lzma Compression Used */ IH_COMP_LZO, /* lzo Compression Used */ IH_COMP_LZ4, /* lz4 Compression Used */ + IH_COMP_ZSTD, /* zstd Compression Used */
IH_COMP_COUNT, };
- { IH_COMP_ZSTD, "zstd", "zstd compressed", }, { -1, "", "", },
We need to add SPL_ZSTD as a symbol to lib/Kconfig and then use CONFIG_IS_ENABLED() tests here to avoid growth in SPL. Thanks!
Hi, is that something that I need to do or?
Thanks
-- Tom
Yes. You need to add the symbol, and then the code you're adding needs to make use of '#if CONFIG_IS_ENABLED(ZSTD)' rather than '#ifdef CONFIG_ZSTD'. Sorry for not being clear enough.
I checked and SPL_ZSTD symbol already exists. But trying to use #if CONFIG_IS_ENABLED(ZSTD) inside of the switch case will fail with the preprocessor error: In file included from tools/common/image.c:1:
./tools/../common/image.c: In function ‘image_decomp’: ./tools/../common/image.c:510:22: error: missing binary operator before token "(" 510 | #if CONFIG_IS_ENABLED(ZSTD)
Outside of the switch_case it works fine
common/image.c | 52
const argv[]);
{ -1, "", "",
break; }
-- Tom
Ah right, oops.
Sounds like <linux/kconfig.h> needs an explicit #include then.
common/image.c | 52
const argv[]);
{ -1, "", "",
break; }
-- Tom
Ah right, oops.
Unfortunately, it does not help. Preprocessor throws the same error
common/image.c | 52
const argv[]);
{ -1, "", "",
break; }
-- Tom
-- Tom
Tom, I have tried various things but CONFIG_IS_ENABLED won't work inside of switch case. It works fine outside of if though.
Ah right, oops.
> This patch adds support for ZSTD decompression of FIT images. > > Signed-off-by: Robert Marko robert.marko@sartura.hr > Cc: Luka Perkov luka.perkov@sartura.hr > --- > common/image.c | 52
> include/image.h | 1 + > 2 files changed, 53 insertions(+) > > diff --git a/common/image.c b/common/image.c > index 94873cb6ed..70ba0f4328 100644 > --- a/common/image.c > +++ b/common/image.c > @@ -42,6 +42,7 @@ > #include <lzma/LzmaTypes.h> > #include <lzma/LzmaDec.h> > #include <lzma/LzmaTools.h> > +#include <linux/zstd.h> > > #ifdef CONFIG_CMD_BDI > extern int do_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char *
const argv[]);
> @@ -193,6 +194,7 @@ static const table_entry_t uimage_comp[] = { > { IH_COMP_LZMA, "lzma", "lzma compressed",
> { -1, "", "",
> }; > > @@ -480,6 +482,56 @@ int image_decomp(int comp, ulong load, ulong
> break; > } > #endif /* CONFIG_LZ4 */ > +#ifdef CONFIG_ZSTD
-- Tom
-- Tom
On Wed, May 20, 2020 at 2:35 PM Tom Rini trini@konsulko.com wrote:
OK, thanks, I'll poke things more to make sure what I'm worried about doesn't happen.
Hi, were you able to test the commit?
Regards, Robert
-- Tom
So I took a look at this since I'm also interested in getting zstd support in. And the problem is that when building host tools, the IS_ENABLED / CONFIG_IS_ENABLED logic doesn't make much sense anyway - one can of course include the kconfig.h header that defines those macros to avoid the cpp error (one has to be careful, because the headers included vary wildly depending on USE_HOSTCC), but I don't think it's meaningful - the host tools should not depend on configuration for any specific board.
Nor do they currently; the use of ifdef CONFIG_GZIP for example just means that that part is ignored for the host tools - doing
--- a/common/image.c +++ b/common/image.c @@ -430,12 +430,12 @@ int image_decomp(int comp, ulong load, ulong image_start, int type, else ret = -ENOSPC; break; -#ifdef CONFIG_GZIP +//#ifdef CONFIG_GZIP case IH_COMP_GZIP: { ret = gunzip(load_buf, unc_len, image_buf, &image_len); break; } -#endif /* CONFIG_GZIP */ +//#endif /* CONFIG_GZIP */ #ifdef CONFIG_BZIP2 case IH_COMP_BZIP2: { uint size = unc_len;
should be a no-op when CONFIG_GZIP=y, but it breaks the build of the host tools.
That, in turn, means that the fit_check_sign tool (which AFAICT is the only host tool that actually care about this - we really should build host tools with the -ffunction-sections,-fdata-sections,-Wl,--gc-sections flags) currently "works" in the sense that it does check the signature, but it doesn't really check if the image(s) can be decompressed using the vendored copy of the decompression code; hidden in the output is
Unimplemented compression type 5
but for some reason that ends up being ok.
So, for now, I suggest simply surrounding all the CASE_IH_COMP_* (except NONE) by a #ifndef USE_HOSTCC - I don't think that will change anything at all for the existing host tools. Then you should be able to use the proper CONFIG_IS_ENABLED(ZSTD) to guard the IH_COMP_ZSTD case. Also, it would allow us to change the existing bare ifdefs to be SPL-aware, i.e. change #ifdef CONFIG_GZIP to #if CONFIG_IS_ENABLED(GZIP) [assuming the SPL_GZIP symbol actually exists].
Rasmus
Alright, so first thanks for digging here. Looking over the tools, for verifying the signature we don't need to decompress the contents as we are just checking the signature. For dumpimage it's also OK to dump a compressed file and leave it to regular tools to decompress. Do you want to make a patch to guard the existing section and CONFIG_IS_ENABLED it or should I and Suggested-by you? Thanks!
Rasmus Villemoes
Robert Marko
