[PATCH 1/2] imx: imx8mm-beacon: Enable FlexSPI in U-Boot
In order to use the FlexSPI interface in U-Boot, configure the alias to make spi0 point to flexspi.
With that enabled, sf probe detects the QSPI part as: SF: Detected n25q256ax1 with page size 256 Bytes, erase size 4 KiB, total 32 MiB
Signed-off-by: Adam Ford aford173@gmail.com
diff --git a/arch/arm/dts/imx8mm-beacon-kit-u-boot.dtsi b/arch/arm/dts/imx8mm-beacon-kit-u-boot.dtsi index 00ac413f36..4f5b9cd23c 100644 --- a/arch/arm/dts/imx8mm-beacon-kit-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-beacon-kit-u-boot.dtsi @@ -6,6 +6,10 @@ #include "imx8mm-u-boot.dtsi"
/ { + aliases { + spi0 = &flexspi; + }; + wdt-reboot { compatible = "wdt-reboot"; wdt = <&wdog1>;
The imx8mm_beacon SOM has a QSPI part attached to the FSPI controller. Update the header and spl files to support booting from NOR flash and add imx8mm_beacon_fspi_defconfig to support this configuration.
diff --git a/board/beacon/imx8mm/spl.c b/board/beacon/imx8mm/spl.c index a5f337aa17..4beda0c62d 100644 --- a/board/beacon/imx8mm/spl.c +++ b/board/beacon/imx8mm/spl.c @@ -36,6 +36,8 @@ int spl_board_boot_device(enum boot_device boot_dev_spl) return BOOT_DEVICE_MMC2; case USB_BOOT: return BOOT_DEVICE_BOARD; + case QSPI_BOOT: + return BOOT_DEVICE_NOR; default: return BOOT_DEVICE_NONE; } diff --git a/configs/imx8mm_beacon_fspi_defconfig b/configs/imx8mm_beacon_fspi_defconfig new file mode 100644 index 0000000000..805fd3f671 --- /dev/null +++ b/configs/imx8mm_beacon_fspi_defconfig @@ -0,0 +1,155 @@ +CONFIG_ARM=y +CONFIG_ARCH_IMX8M=y +CONFIG_TEXT_BASE=0x40200000 +CONFIG_SYS_MALLOC_LEN=0x2000000 +CONFIG_SPL_GPIO=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xFFFFDE00 +CONFIG_IMX_CONFIG="board/freescale/imx8mm_evk/imximage-8mm-lpddr4-fspi.cfg" +CONFIG_DM_GPIO=y +CONFIG_DEFAULT_DEVICE_TREE="imx8mm-beacon-kit" +CONFIG_SPL_TEXT_BASE=0x7E2000 +CONFIG_TARGET_IMX8MM_BEACON=y +CONFIG_SYS_PROMPT="u-boot=> " +CONFIG_SPL_SERIAL=y +CONFIG_SPL_DRIVERS_MISC=y +CONFIG_SPL=y +CONFIG_SYS_LOAD_ADDR=0x40480000 +CONFIG_LTO=y +CONFIG_SYS_MONITOR_LEN=524288 +CONFIG_FIT=y +CONFIG_FIT_EXTERNAL_OFFSET=0x3000 +CONFIG_SPL_LOAD_FIT=y +# CONFIG_USE_SPL_FIT_GENERATOR is not set +CONFIG_OF_SYSTEM_SETUP=y +CONFIG_USE_BOOTCOMMAND=y +CONFIG_BOOTCOMMAND="mmc dev ${mmcdev}; if mmc rescan; then if run loadbootscript; then run bootscript; else if run loadimage; then run mmcboot; else run netboot; fi; fi; fi;" +CONFIG_DEFAULT_FDT_FILE="imx8mm-beacon-kit.dtb" +CONFIG_SPL_MAX_SIZE=0x25000 +CONFIG_SPL_PAD_TO=0x0 +CONFIG_SPL_HAS_BSS_LINKER_SECTION=y +CONFIG_SPL_BSS_START_ADDR=0x910000 +CONFIG_SPL_BSS_MAX_SIZE=0x2000 +CONFIG_SPL_BOARD_INIT=y +# CONFIG_SPL_SHARES_INIT_SP_ADDR is not set +CONFIG_SPL_STACK=0x920000 +CONFIG_SYS_SPL_MALLOC=y +CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y +CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x42200000 +CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 +CONFIG_SPL_CRC32=y +CONFIG_SPL_I2C=y +CONFIG_SPL_NOR_SUPPORT=y +CONFIG_SPL_POWER=y +CONFIG_SPL_USB_HOST=y +CONFIG_SPL_USB_GADGET=y +CONFIG_SPL_USB_SDP_SUPPORT=y +CONFIG_SPL_WATCHDOG=y +CONFIG_HUSH_PARSER=y +CONFIG_SYS_MAXARGS=64 +CONFIG_SYS_CBSIZE=2048 +CONFIG_SYS_PBSIZE=2074 +CONFIG_SYS_BOOTM_LEN=0x800000 +# CONFIG_CMD_EXPORTENV is not set +# CONFIG_CMD_IMPORTENV is not set +# CONFIG_CMD_CRC32 is not set +CONFIG_CMD_CLK=y +CONFIG_CMD_FUSE=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_PART=y +CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_SDP=y +CONFIG_CMD_USB_MASS_STORAGE=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_PMIC=y +CONFIG_CMD_REGULATOR=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_ENV_OVERWRITE=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_SYS_MMC_ENV_DEV=2 +CONFIG_SYS_MMC_ENV_PART=2 +CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_USE_ETHPRIME=y +CONFIG_ETHPRIME="FEC" +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_SPL_DM=y +CONFIG_SPL_CLK_COMPOSITE_CCF=y +CONFIG_CLK_COMPOSITE_CCF=y +CONFIG_SPL_CLK_IMX8MM=y +CONFIG_CLK_IMX8MM=y +CONFIG_MXC_GPIO=y +CONFIG_DM_PCA953X=y +CONFIG_DM_I2C=y +CONFIG_SUPPORT_EMMC_BOOT=y +CONFIG_MMC_IO_VOLTAGE=y +CONFIG_MMC_UHS_SUPPORT=y +CONFIG_MMC_HS400_ES_SUPPORT=y +CONFIG_MMC_HS400_SUPPORT=y +CONFIG_FSL_USDHC=y +CONFIG_MTD=y +CONFIG_DM_MTD=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=40000000 +CONFIG_SPI_FLASH_BAR=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_MTD=y +CONFIG_PHYLIB=y +CONFIG_PHY_ATHEROS=y +CONFIG_PHY_GIGE=y +CONFIG_FEC_MXC=y +CONFIG_MII=y +CONFIG_SPL_PHY=y +CONFIG_SPL_NOP_PHY=y +CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y +CONFIG_PINCTRL_IMX8M=y +CONFIG_POWER_DOMAIN=y +CONFIG_IMX8M_POWER_DOMAIN=y +CONFIG_DM_PMIC=y +# CONFIG_SPL_PMIC_CHILDREN is not set +CONFIG_DM_PMIC_BD71837=y +CONFIG_SPL_DM_PMIC_BD71837=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_BD71837=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_DM_SERIAL=y +CONFIG_MXC_UART=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_NXP_FSPI=y +CONFIG_SYSRESET=y +CONFIG_SPL_SYSRESET=y +CONFIG_SYSRESET_PSCI=y +CONFIG_SYSRESET_WATCHDOG=y +CONFIG_DM_THERMAL=y +CONFIG_USB=y +CONFIG_USB_EHCI_HCD=y +CONFIG_MXC_USB_OTG_HACTIVE=y +CONFIG_USB_STORAGE=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_VENDOR_NUM=0x0525 +CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 +CONFIG_CI_UDC=y +CONFIG_SDP_LOADADDR=0x40400000 +CONFIG_USB_GADGET_DOWNLOAD=y +CONFIG_IMX_WATCHDOG=y +CONFIG_FSPI_CONF_HEADER=y +CONFIG_FSPI_CONF_FILE="fspi_header.bin" diff --git a/include/configs/imx8mm_beacon.h b/include/configs/imx8mm_beacon.h index 8e08899458..cab4a02c18 100644 --- a/include/configs/imx8mm_beacon.h +++ b/include/configs/imx8mm_beacon.h @@ -9,8 +9,17 @@ #include <linux/sizes.h> #include <asm/arch/imx-regs.h>
+#define UBOOT_ITB_OFFSET 0x57C00 +#define FSPI_CONF_BLOCK_SIZE 0x1000 +#define UBOOT_ITB_OFFSET_FSPI \ + (UBOOT_ITB_OFFSET + FSPI_CONF_BLOCK_SIZE) +#ifdef CONFIG_FSPI_CONF_HEADER +#define CONFIG_SYS_UBOOT_BASE \ + (QSPI0_AMBA_BASE + UBOOT_ITB_OFFSET_FSPI) +#else #define CONFIG_SYS_UBOOT_BASE \ (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512) +#endif
#ifdef CONFIG_SPL_BUILD /* malloc f used before GD_FLG_FULL_MALLOC_INIT set */
Hi Adam,
I haven't picked up these two patches in my PR due to a small thing (at least, what I could see). There are a couple of new CONFIG_ in header (CONFIG_SYS_UBOOT_BASE, CFG_ as now is okay), but new CONFIG_ should be managed only by Kbuild and are not allowed.
My pipeline failed, see here:
https://source.denx.de/u-boot/custodians/u-boot-imx/-/jobs/566141
- case QSPI_BOOT:
default: return BOOT_DEVICE_NONE; }return BOOT_DEVICE_NOR;
- (UBOOT_ITB_OFFSET + FSPI_CONF_BLOCK_SIZE)
See here, it was renamed as CFG_SYS_UBOOT_BASE
- (QSPI0_AMBA_BASE + UBOOT_ITB_OFFSET_FSPI)
Best regards, Stefano
On Wed, Feb 1, 2023 at 7:06 AM Stefano Babic sbabic@denx.de wrote:
Hi Adam,
The initial submission was back in November, and I know the Kconfig has undergone some updates and migrations since then, so I'll rebase and send a V2 later tonight.
thanks
adam
case QSPI_BOOT:
DENX Software Engineering GmbH, Managing Director: Erika Unter HRB 165235 Munich, Office: Kirchenstr.5, 82194 Groebenzell, Germany Phone: +49-8142-66989-53 Fax: +49-8142-66989-80 Email: sbabic@denx.de =====================================================================
Hi Adam,
Yes, that the reason, patch was just in my queue...
Thanks again - I will then submit in a further PR for 2022.04, there are a few pacthes missing.
Stefano
thanks
adam
case QSPI_BOOT:
Adam Ford
Stefano Babic
