[U-Boot] [PATCH 1/1] efi_loader: environment variables for terminal size
Correct scrolling in EFI applications like the EFI Shell requires correct setting of the terminal size. Detecting the terminal size over the serial interface is often not supported. The patch introduces the environment variables LINES and COLUMNS to set the terminal size manually.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- doc/README.uefi | 14 ++++++++++++++ lib/efi_loader/efi_console.c | 15 ++++++++++++++- 2 files changed, 28 insertions(+), 1 deletion(-)
diff --git a/doc/README.uefi b/doc/README.uefi index 6b9759cfed..df0cf5b7ce 100644 --- a/doc/README.uefi +++ b/doc/README.uefi @@ -299,6 +299,20 @@ This driver is only available if U-Boot is configured with CONFIG_BLK=y CONFIG_PARTITIONS=y
+## Setting the terminal size + +For correct scrolling the terminal size has to be known. + +The default terminal size is 80x25. + +If the environment variable 'stdout' has the value 'vidconsole', the terminal +size is determined by querying the video console driver. Else it is tried to +determine the terminal size by sending ESC '[18t' to the console which may +reply with an escape sequence indicating the terminal size. + +It is possible to override the terminal size by setting the environment +variables 'LINES' and 'COLUMNS'. + ## TODOs as of U-Boot 2018.07
* unimplemented or incompletely implemented boot services diff --git a/lib/efi_loader/efi_console.c b/lib/efi_loader/efi_console.c index 73f7ecf919..40e33f9fd3 100644 --- a/lib/efi_loader/efi_console.c +++ b/lib/efi_loader/efi_console.c @@ -224,6 +224,7 @@ static void query_console_size(void) { const char *stdout_name = env_get("stdout"); int rows = 25, cols = 80; + char *value;
if (stdout_name && !strcmp(stdout_name, "vidconsole") && IS_ENABLED(CONFIG_DM_VIDEO)) { @@ -235,9 +236,21 @@ static void query_console_size(void) rows = priv->rows; cols = priv->cols; } else if (query_console_serial(&rows, &cols)) { - return; + rows = 25; + cols = 80; }
+ value = env_get("LINES"); + if (value) + rows = simple_strtoul(value, NULL, 10); + value = env_get("COLUMNS"); + if (value) + cols = simple_strtoul(value, NULL, 10); + if (rows <= 0) + rows = 25; + if (cols <= 0) + cols = 80; + /* Test if we can have Mode 1 */ if (cols >= 80 && rows >= 50) { efi_cout_modes[1].present = 1;
Can you give examples on when it's not supported? I think most cases I've encountered in the last 10 years do support just reading them via escape sequences.
Alex
- unimplemented or incompletely implemented boot services
char *value;
return;
rows = 25;
cols = 80;
if (value)
if (value)
if (rows <= 0)
rows = 25;
if (cols <= 0)
cols = 80;
I am using KDE. When running qemu-system-aarch64 in konsole or xterm U-Boot never receives a response to the request.
Best regards
Heinrich
Alex
char *value;
return;
rows = 25;
cols = 80;
if (value)
if (value)
if (rows <= 0)
rows = 25;
if (cols <= 0)
cols = 80;
From: Alexander Graf agraf@suse.de Date: Fri, 14 Sep 2018 07:21:56 +0200
There are multiple "standards" for these escape sequences so you can't use them without knowing the terminal type. So unless you implement a way to set the terminal type in U-Boot that is a bad idea as sending random control characters to a terminal that doesn't understand them you invariably make it unusable. This should then also include a "dumb" setting since users may want to redirected the serial line output to something that isn't a terminal at all. At that point I think Heinrich's solution is much simpler and better.
char *value;
return;
rows = 25;
cols = 80;
if (value)
if (value)
if (rows <= 0)
rows = 25;
if (cols <= 0)
cols = 80;
Alexander Graf
Mark Kettenis
