[PATCH 0/3] eficonfig: add vertical scroll support
This series aims to add the vertical scroll for the eficonfig menu. Before adding scroll support, this series does the refactoring of change boot order implementation since it has own menu handling and it should be removed to improve maintenanceability.
The eficonfig menu handles file selection for EFI load option and secure boot keys, it likely to enumerate tens of files. User can not select the file without scroll if theare are many files under the target directory.
This series only modifies the eficonfig menus. Other menus such as bootmenu is not yet done. We need to enhance the U-Boot menu framework itself if we support other menus.
Masahisa Kojima (3): eficonfig: refactor eficonfig_process_common function eficonfig: refactor change boot order implementation eficonfig: add vertical scroll support
cmd/eficonfig.c | 374 +++++++++++++++++++++++++++++------------- cmd/eficonfig_sbkey.c | 18 +- include/efi_config.h | 17 +- include/efi_loader.h | 1 + 4 files changed, 289 insertions(+), 121 deletions(-)
Current change boot order implementation does not call eficonfig_process_common() and call own menu functions for display_statusline, item_data_print and item_choice. Change boot order functionality should call eficonfig_process_common() to improve maintenanceability.
This commit is a preparation to remove the change boot order specific implementation. The menu functions (display_statusline, item_data_print and item_choice) are added as argument of eficonfig_process_common(). The menu description string displayed at the bottom of the menu is also added as argument.
Signed-off-by: Masahisa Kojima masahisa.kojima@linaro.org --- cmd/eficonfig.c | 69 +++++++++++++++++++++++++++++++++---------- cmd/eficonfig_sbkey.c | 18 +++++++++-- include/efi_config.h | 13 +++++++- 3 files changed, 81 insertions(+), 19 deletions(-)
diff --git a/cmd/eficonfig.c b/cmd/eficonfig.c index ce7175a566..39ee766a7b 100644 --- a/cmd/eficonfig.c +++ b/cmd/eficonfig.c @@ -21,6 +21,8 @@ #include <linux/delay.h>
static struct efi_simple_text_input_protocol *cin; +char eficonfig_menu_desc[] = + " Press UP/DOWN to move, ENTER to select, ESC/CTRL+C to quit";
#define EFICONFIG_DESCRIPTION_MAX 32 #define EFICONFIG_OPTIONAL_DATA_MAX 64 @@ -133,7 +135,7 @@ void eficonfig_print_msg(char *msg) * * @data: pointer to the data associated with each menu entry */ -static void eficonfig_print_entry(void *data) +void eficonfig_print_entry(void *data) { struct eficonfig_entry *entry = data; int reverse = (entry->efi_menu->active == entry->num); @@ -160,7 +162,7 @@ static void eficonfig_print_entry(void *data) * * @m: pointer to the menu structure */ -static void eficonfig_display_statusline(struct menu *m) +void eficonfig_display_statusline(struct menu *m) { struct eficonfig_entry *entry;
@@ -170,10 +172,11 @@ static void eficonfig_display_statusline(struct menu *m) printf(ANSI_CURSOR_POSITION "\n%s\n" ANSI_CURSOR_POSITION ANSI_CLEAR_LINE ANSI_CURSOR_POSITION - " Press UP/DOWN to move, ENTER to select, ESC/CTRL+C to quit" + "%s" ANSI_CLEAR_LINE_TO_END ANSI_CURSOR_POSITION ANSI_CLEAR_LINE, 1, 1, entry->efi_menu->menu_header, entry->efi_menu->count + 5, 1, - entry->efi_menu->count + 6, 1, entry->efi_menu->count + 7, 1); + entry->efi_menu->count + 6, 1, entry->efi_menu->menu_desc, + entry->efi_menu->count + 7, 1); }
/** @@ -182,7 +185,7 @@ static void eficonfig_display_statusline(struct menu *m) * @data: pointer to the efimenu structure * Return: key string to identify the selected entry */ -static char *eficonfig_choice_entry(void *data) +char *eficonfig_choice_entry(void *data) { int esc = 0; struct list_head *pos, *n; @@ -358,9 +361,17 @@ out: * * @efi_menu: pointer to the efimenu structure * @menu_header: pointer to the menu header string + * @menu_desc: pointer to the menu description + * @display_statusline: function pointer to draw statusline + * @item_data_print: function pointer to draw the menu item + * @item_choice: function pointer to handle the key press * Return: status code */ -efi_status_t eficonfig_process_common(struct efimenu *efi_menu, char *menu_header) +efi_status_t eficonfig_process_common(struct efimenu *efi_menu, + char *menu_header, char *menu_desc, + void (*display_statusline)(struct menu *), + void (*item_data_print)(void *), + char *(*item_choice)(void *)) { struct menu *menu; void *choice = NULL; @@ -379,10 +390,11 @@ efi_status_t eficonfig_process_common(struct efimenu *efi_menu, char *menu_heade if (!efi_menu->menu_header) return EFI_OUT_OF_RESOURCES; } + if (menu_desc) + efi_menu->menu_desc = menu_desc;
- menu = menu_create(NULL, 0, 1, eficonfig_display_statusline, - eficonfig_print_entry, eficonfig_choice_entry, - efi_menu); + menu = menu_create(NULL, 0, 1, display_statusline, item_data_print, + item_choice, efi_menu); if (!menu) return EFI_INVALID_PARAMETER;
@@ -641,7 +653,12 @@ static efi_status_t eficonfig_select_volume(struct eficonfig_select_file_info *f if (ret != EFI_SUCCESS) goto out;
- ret = eficonfig_process_common(efi_menu, " ** Select Volume **"); + ret = eficonfig_process_common(efi_menu, " ** Select Volume **", + eficonfig_menu_desc, + eficonfig_display_statusline, + eficonfig_print_entry, + eficonfig_choice_entry); + out: efi_free_pool(volume_handles); list_for_each_safe(pos, n, &efi_menu->list) { @@ -816,7 +833,11 @@ static efi_status_t eficonfig_show_file_selection(struct eficonfig_select_file_i if (ret != EFI_SUCCESS) goto err;
- ret = eficonfig_process_common(efi_menu, " ** Select File **"); + ret = eficonfig_process_common(efi_menu, " ** Select File **", + eficonfig_menu_desc, + eficonfig_display_statusline, + eficonfig_print_entry, + eficonfig_choice_entry); err: EFI_CALL(f->close(f)); eficonfig_destroy(efi_menu); @@ -977,7 +998,11 @@ efi_status_t eficonfig_process_show_file_option(void *data) if (!efi_menu) return EFI_OUT_OF_RESOURCES;
- ret = eficonfig_process_common(efi_menu, " ** Update File **"); + ret = eficonfig_process_common(efi_menu, " ** Update File **", + eficonfig_menu_desc, + eficonfig_display_statusline, + eficonfig_print_entry, + eficonfig_choice_entry); if (ret != EFI_SUCCESS) /* User selects "Clear" or "Quit" */ ret = EFI_NOT_READY;
@@ -1323,7 +1348,12 @@ static efi_status_t eficonfig_show_boot_option(struct eficonfig_boot_option *bo, if (ret != EFI_SUCCESS) goto out;
- ret = eficonfig_process_common(efi_menu, header_str); + ret = eficonfig_process_common(efi_menu, header_str, + eficonfig_menu_desc, + eficonfig_display_statusline, + eficonfig_print_entry, + eficonfig_choice_entry); + out: eficonfig_destroy(efi_menu);
@@ -1742,7 +1772,11 @@ static efi_status_t eficonfig_show_boot_selection(unsigned int *selected) if (ret != EFI_SUCCESS) goto out;
- ret = eficonfig_process_common(efi_menu, " ** Select Boot Option **"); + ret = eficonfig_process_common(efi_menu, " ** Select Boot Option **", + eficonfig_menu_desc, + eficonfig_display_statusline, + eficonfig_print_entry, + eficonfig_choice_entry); out: list_for_each_safe(pos, n, &efi_menu->list) { entry = list_entry(pos, struct eficonfig_entry, list); @@ -2563,7 +2597,12 @@ static int do_eficonfig(struct cmd_tbl *cmdtp, int flag, int argc, char *const a if (!efi_menu) return CMD_RET_FAILURE;
- ret = eficonfig_process_common(efi_menu, " ** UEFI Maintenance Menu **"); + ret = eficonfig_process_common(efi_menu, + " ** UEFI Maintenance Menu **", + eficonfig_menu_desc, + eficonfig_display_statusline, + eficonfig_print_entry, + eficonfig_choice_entry); eficonfig_destroy(efi_menu);
if (ret == EFI_ABORTED) diff --git a/cmd/eficonfig_sbkey.c b/cmd/eficonfig_sbkey.c index ed39aab081..caca27495e 100644 --- a/cmd/eficonfig_sbkey.c +++ b/cmd/eficonfig_sbkey.c @@ -410,7 +410,10 @@ static efi_status_t enumerate_and_show_signature_database(void *varname) goto out;
snprintf(buf, sizeof(buf), " ** Show Signature Database (%ls) **", (u16 *)varname); - ret = eficonfig_process_common(efi_menu, buf); + ret = eficonfig_process_common(efi_menu, buf, eficonfig_menu_desc, + eficonfig_display_statusline, + eficonfig_print_entry, + eficonfig_choice_entry); out: list_for_each_safe(pos, n, &efi_menu->list) { entry = list_entry(pos, struct eficonfig_entry, list); @@ -472,7 +475,11 @@ static efi_status_t eficonfig_process_set_secure_boot_key(void *data) efi_menu = eficonfig_create_fixed_menu(key_config_menu_items, ARRAY_SIZE(key_config_menu_items));
- ret = eficonfig_process_common(efi_menu, header_str); + ret = eficonfig_process_common(efi_menu, header_str, + eficonfig_menu_desc, + eficonfig_display_statusline, + eficonfig_print_entry, + eficonfig_choice_entry); eficonfig_destroy(efi_menu);
if (ret == EFI_ABORTED) @@ -518,7 +525,12 @@ efi_status_t eficonfig_process_secure_boot_config(void *data) break; }
- ret = eficonfig_process_common(efi_menu, header_str); + ret = eficonfig_process_common(efi_menu, header_str, + eficonfig_menu_desc, + eficonfig_display_statusline, + eficonfig_print_entry, + eficonfig_choice_entry); + eficonfig_destroy(efi_menu);
if (ret == EFI_ABORTED) diff --git a/include/efi_config.h b/include/efi_config.h index fd69926343..9432d13f2e 100644 --- a/include/efi_config.h +++ b/include/efi_config.h @@ -9,12 +9,14 @@ #define _EFI_CONFIG_H
#include <efi_loader.h> +#include <menu.h>
#define EFICONFIG_ENTRY_NUM_MAX 99 #define EFICONFIG_VOLUME_PATH_MAX 512 #define EFICONFIG_FILE_PATH_MAX 512 #define EFICONFIG_FILE_PATH_BUF_SIZE (EFICONFIG_FILE_PATH_MAX * sizeof(u16))
+extern char eficonfig_menu_desc[]; typedef efi_status_t (*eficonfig_entry_func)(void *data);
/** @@ -45,6 +47,7 @@ struct eficonfig_entry { * @active: active menu entry index * @count: total count of menu entry * @menu_header: menu header string + * @menu_desc: menu description string * @list: menu entry list structure */ struct efimenu { @@ -52,6 +55,7 @@ struct efimenu { int active; int count; char *menu_header; + char *menu_desc; struct list_head list; };
@@ -86,9 +90,16 @@ struct eficonfig_select_file_info { };
void eficonfig_print_msg(char *msg); +void eficonfig_print_entry(void *data); +void eficonfig_display_statusline(struct menu *m); +char *eficonfig_choice_entry(void *data); void eficonfig_destroy(struct efimenu *efi_menu); efi_status_t eficonfig_process_quit(void *data); -efi_status_t eficonfig_process_common(struct efimenu *efi_menu, char *menu_header); +efi_status_t eficonfig_process_common(struct efimenu *efi_menu, + char *menu_header, char *menu_desc, + void (*display_statusline)(struct menu *), + void (*item_data_print)(void *), + char *(*item_choice)(void *)); efi_status_t eficonfig_process_select_file(void *data); efi_status_t eficonfig_get_unused_bootoption(u16 *buf, efi_uintn_t buf_size, u32 *index);
Hi Kojima-san
- " Press UP/DOWN to move, ENTER to select, ESC/CTRL+C to quit";
Is this text supposed to change? If not we should define it as const
- @data: pointer to the data associated with each menu entry
- @m: pointer to the menu structure
Thanks /Ilias
Hi Ilias,
On Thu, 22 Dec 2022 at 18:59, Ilias Apalodimas ilias.apalodimas@linaro.org wrote:
Hi Kojima-san
No, it should be defined as const. I will fix it.
Thanks, Masahisa Kojima
Thanks /Ilias
This commit removes the change boot order specific menu implementation. The change boot order implementation calls eficonfig_process_common() same as other menus.
The change boot order menu requires own item_data_print and item_choice implementation, but display_statusline function can be a same function as other menus.
Signed-off-by: Masahisa Kojima masahisa.kojima@linaro.org --- cmd/eficonfig.c | 236 +++++++++++++++++++++++++++++------------------- 1 file changed, 143 insertions(+), 93 deletions(-)
diff --git a/cmd/eficonfig.c b/cmd/eficonfig.c index 39ee766a7b..c2c6c01c3b 100644 --- a/cmd/eficonfig.c +++ b/cmd/eficonfig.c @@ -24,6 +24,11 @@ static struct efi_simple_text_input_protocol *cin; char eficonfig_menu_desc[] = " Press UP/DOWN to move, ENTER to select, ESC/CTRL+C to quit";
+static char eficonfig_change_boot_order_desc[] = + " Press UP/DOWN to move, +/- to change orde\n" + " Press SPACE to activate or deactivate the entry\n" + " Select [Save] to complete, ESC/CTRL+C to quit"; + #define EFICONFIG_DESCRIPTION_MAX 32 #define EFICONFIG_OPTIONAL_DATA_MAX 64
@@ -105,6 +110,17 @@ struct eficonfig_boot_order_data { bool active; };
+/** + * struct eficonfig_save_boot_order_data - structure to be used to change boot order + * + * @efi_menu: pointer to efimenu structure + * @selected: flag to indicate user selects "Save" entry + */ +struct eficonfig_save_boot_order_data { + struct efimenu *efi_menu; + bool selected; +}; + /** * eficonfig_print_msg() - print message * @@ -173,10 +189,9 @@ void eficonfig_display_statusline(struct menu *m) "\n%s\n" ANSI_CURSOR_POSITION ANSI_CLEAR_LINE ANSI_CURSOR_POSITION "%s" - ANSI_CLEAR_LINE_TO_END ANSI_CURSOR_POSITION ANSI_CLEAR_LINE, + ANSI_CLEAR_LINE_TO_END, 1, 1, entry->efi_menu->menu_header, entry->efi_menu->count + 5, 1, - entry->efi_menu->count + 6, 1, entry->efi_menu->menu_desc, - entry->efi_menu->count + 7, 1); + entry->efi_menu->count + 6, 1, entry->efi_menu->menu_desc); }
/** @@ -1841,63 +1856,44 @@ out: }
/** - * eficonfig_display_change_boot_order() - display the BootOrder list + * eficonfig_print_change_boot_order_entry() - print the boot option entry * - * @efi_menu: pointer to the efimenu structure - * Return: status code + * @data: pointer to the data associated with each menu entry */ -static void eficonfig_display_change_boot_order(struct efimenu *efi_menu) +static void eficonfig_print_change_boot_order_entry(void *data) { - bool reverse; - struct list_head *pos, *n; - struct eficonfig_entry *entry; - - printf(ANSI_CLEAR_CONSOLE ANSI_CURSOR_POSITION - "\n ** Change Boot Order **\n" - ANSI_CURSOR_POSITION - " Press UP/DOWN to move, +/- to change order" - ANSI_CURSOR_POSITION - " Press SPACE to activate or deactivate the entry" - ANSI_CURSOR_POSITION - " Select [Save] to complete, ESC/CTRL+C to quit" - ANSI_CURSOR_POSITION ANSI_CLEAR_LINE, - 1, 1, efi_menu->count + 5, 1, efi_menu->count + 6, 1, - efi_menu->count + 7, 1, efi_menu->count + 8, 1); - - /* draw boot option list */ - list_for_each_safe(pos, n, &efi_menu->list) { - entry = list_entry(pos, struct eficonfig_entry, list); - reverse = (entry->num == efi_menu->active); + struct eficonfig_entry *entry = data; + int reverse = (entry->efi_menu->active == entry->num);
- printf(ANSI_CURSOR_POSITION, entry->num + 4, 7); + printf(ANSI_CURSOR_POSITION, entry->num + 4, 7);
- if (reverse) - puts(ANSI_COLOR_REVERSE); + if (reverse) + puts(ANSI_COLOR_REVERSE);
- if (entry->num < efi_menu->count - 2) { - if (((struct eficonfig_boot_order_data *)entry->data)->active) - printf("[*] "); - else - printf("[ ] "); - } + if (entry->num < entry->efi_menu->count - 2) { + if (((struct eficonfig_boot_order_data *)entry->data)->active) + printf("[*] "); + else + printf("[ ] "); + }
- printf("%s", entry->title); + printf("%s", entry->title);
- if (reverse) - puts(ANSI_COLOR_RESET); - } + if (reverse) + puts(ANSI_COLOR_RESET); }
/** - * eficonfig_choice_change_boot_order() - handle the BootOrder update + * eficonfig_choice_change_boot_order() - user key input handler * - * @efi_menu: pointer to the efimenu structure - * Return: status code + * @data: pointer to the menu entry + * Return: key string to identify the selected entry */ -static efi_status_t eficonfig_choice_change_boot_order(struct efimenu *efi_menu) +char *eficonfig_choice_change_boot_order(void *data) { int esc = 0; struct list_head *pos, *n; + struct efimenu *efi_menu = data; enum bootmenu_key key = KEY_NONE; struct eficonfig_entry *entry, *tmp;
@@ -1922,7 +1918,7 @@ static efi_status_t eficonfig_choice_change_boot_order(struct efimenu *efi_menu) case KEY_UP: if (efi_menu->active > 0) --efi_menu->active; - return EFI_NOT_READY; + return NULL; case KEY_MINUS: if (efi_menu->active < efi_menu->count - 3) { list_for_each_safe(pos, n, &efi_menu->list) { @@ -1938,19 +1934,28 @@ static efi_status_t eficonfig_choice_change_boot_order(struct efimenu *efi_menu)
++efi_menu->active; } - return EFI_NOT_READY; + return NULL; case KEY_DOWN: if (efi_menu->active < efi_menu->count - 1) ++efi_menu->active; - return EFI_NOT_READY; + return NULL; case KEY_SELECT: /* "Save" */ - if (efi_menu->active == efi_menu->count - 2) - return EFI_SUCCESS; - + if (efi_menu->active == efi_menu->count - 2) { + list_for_each_prev_safe(pos, n, &efi_menu->list) { + entry = list_entry(pos, struct eficonfig_entry, list); + if (entry->num == efi_menu->active) + break; + } + return entry->key; + } /* "Quit" */ - if (efi_menu->active == efi_menu->count - 1) - return EFI_ABORTED; + if (efi_menu->active == efi_menu->count - 1) { + entry = list_last_entry(&efi_menu->list, + struct eficonfig_entry, + list); + return entry->key; + }
break; case KEY_SPACE: @@ -1961,13 +1966,15 @@ static efi_status_t eficonfig_choice_change_boot_order(struct efimenu *efi_menu) struct eficonfig_boot_order_data *data = entry->data;
data->active = !data->active; - return EFI_NOT_READY; + return NULL; } } } break; case KEY_QUIT: - return EFI_ABORTED; + entry = list_last_entry(&efi_menu->list, + struct eficonfig_entry, list); + return entry->key; default: /* Pressed key is not valid, no need to regenerate the menu */ break; @@ -2034,6 +2041,62 @@ out: return ret; }
+/** + * eficonfig_process_save_boot_order() - callback function for "Save" entry + * + * @data: pointer to the data + * Return: status code + */ +static efi_status_t eficonfig_process_save_boot_order(void *data) +{ + u32 count = 0; + efi_status_t ret; + efi_uintn_t size; + struct list_head *pos, *n; + u16 *new_bootorder; + struct efimenu *efi_menu; + struct eficonfig_entry *entry; + struct eficonfig_save_boot_order_data *save_data = data; + + efi_menu = save_data->efi_menu; + + if (!(efi_menu->count - 2)) /* no user defined boot option */ + return EFI_SUCCESS; + + new_bootorder = calloc(1, (efi_menu->count - 2) * sizeof(u16)); + if (!new_bootorder) { + ret = EFI_OUT_OF_RESOURCES; + goto out; + } + + /* create new BootOrder */ + count = 0; + list_for_each_safe(pos, n, &efi_menu->list) { + struct eficonfig_boot_order_data *data; + + entry = list_entry(pos, struct eficonfig_entry, list); + /* exit the loop when iteration reaches "Save" */ + if (!strncmp(entry->title, "Save", strlen("Save"))) + break; + + data = entry->data; + if (data->active) + new_bootorder[count++] = data->boot_index; + } + + size = count * sizeof(u16); + ret = efi_set_variable_int(u"BootOrder", &efi_global_variable_guid, + EFI_VARIABLE_NON_VOLATILE | + EFI_VARIABLE_BOOTSERVICE_ACCESS | + EFI_VARIABLE_RUNTIME_ACCESS, + size, new_bootorder, false); + + save_data->selected = true; +out: + free(new_bootorder); + + return ret; +} /** * eficonfig_create_change_boot_order_entry() - create boot order entry * @@ -2050,6 +2113,7 @@ static efi_status_t eficonfig_create_change_boot_order_entry(struct efimenu *efi efi_status_t ret; u16 *var_name16 = NULL; efi_uintn_t size, buf_size; + struct eficonfig_save_boot_order_data *save_data;
/* list the load option in the order of BootOrder variable */ for (i = 0; i < num; i++) { @@ -2100,7 +2164,17 @@ static efi_status_t eficonfig_create_change_boot_order_entry(struct efimenu *efi goto out; }
- ret = eficonfig_append_menu_entry(efi_menu, title, NULL, NULL); + save_data = malloc(sizeof(struct eficonfig_save_boot_order_data)); + if (!save_data) { + ret = EFI_OUT_OF_RESOURCES; + goto out; + } + save_data->efi_menu = efi_menu; + save_data->selected = false; + + ret = eficonfig_append_menu_entry(efi_menu, title, + eficonfig_process_save_boot_order, + save_data); if (ret != EFI_SUCCESS) goto out;
@@ -2123,7 +2197,6 @@ out: */ static efi_status_t eficonfig_process_change_boot_order(void *data) { - u32 count; u16 *bootorder; efi_status_t ret; efi_uintn_t num, size; @@ -2144,47 +2217,24 @@ static efi_status_t eficonfig_process_change_boot_order(void *data) goto out;
while (1) { - eficonfig_display_change_boot_order(efi_menu); - - ret = eficonfig_choice_change_boot_order(efi_menu); - if (ret == EFI_SUCCESS) { - u16 *new_bootorder; - - new_bootorder = calloc(1, (efi_menu->count - 2) * sizeof(u16)); - if (!new_bootorder) { - ret = EFI_OUT_OF_RESOURCES; - goto out; - } - - /* create new BootOrder */ - count = 0; - list_for_each_safe(pos, n, &efi_menu->list) { - struct eficonfig_boot_order_data *data; - + ret = eficonfig_process_common(efi_menu, + " ** Change Boot Order **", + eficonfig_change_boot_order_desc, + eficonfig_display_statusline, + eficonfig_print_change_boot_order_entry, + eficonfig_choice_change_boot_order); + /* exit from the menu if user selects the "Save" entry. */ + if (ret == EFI_SUCCESS && efi_menu->active == (efi_menu->count - 2)) { + list_for_each_prev_safe(pos, n, &efi_menu->list) { entry = list_entry(pos, struct eficonfig_entry, list); - /* exit the loop when iteration reaches "Save" */ - if (!strncmp(entry->title, "Save", strlen("Save"))) + if (entry->num == efi_menu->active) break; - - data = entry->data; - if (data->active) - new_bootorder[count++] = data->boot_index; } - - size = count * sizeof(u16); - ret = efi_set_variable_int(u"BootOrder", &efi_global_variable_guid, - EFI_VARIABLE_NON_VOLATILE | - EFI_VARIABLE_BOOTSERVICE_ACCESS | - EFI_VARIABLE_RUNTIME_ACCESS, - size, new_bootorder, false); - - free(new_bootorder); - goto out; - } else if (ret == EFI_NOT_READY) { - continue; - } else { - goto out; + if (((struct eficonfig_save_boot_order_data *)entry->data)->selected) + break; } + if (ret != EFI_SUCCESS) + break; } out: free(bootorder);
- " Press UP/DOWN to move, +/- to change orde\n"
- " Press SPACE to activate or deactivate the entry\n"
- " Select [Save] to complete, ESC/CTRL+C to quit";
static const
- struct eficonfig_save_boot_order_data - structure to be used to change boot order
- @efi_menu: pointer to efimenu structure
- @selected: flag to indicate user selects "Save" entry
- struct efimenu *efi_menu;
- bool selected;
- eficonfig_print_msg() - print message
- eficonfig_display_change_boot_order() - display the BootOrder list
- eficonfig_print_change_boot_order_entry() - print the boot option entry
- @efi_menu: pointer to the efimenu structure
- Return: status code
- bool reverse;
So this prints one option every time now instead of all the entries?
- struct eficonfig_entry *entry = data;
- int reverse = (entry->efi_menu->active == entry->num);
if (reverse)
- if (reverse)
printf("[*] ");
else
printf("[ ] ");
- if (entry->num < entry->efi_menu->count - 2) {
printf("[*] ");
else
printf("[ ] ");
if (reverse)
- if (reverse)
- eficonfig_choice_change_boot_order() - handle the BootOrder update
- eficonfig_choice_change_boot_order() - user key input handler
- @data: pointer to the menu entry
- Return: key string to identify the selected entry
- struct efimenu *efi_menu = data; enum bootmenu_key key = KEY_NONE; struct eficonfig_entry *entry, *tmp;
case KEY_MINUS: if (efi_menu->active < efi_menu->count - 3) { list_for_each_safe(pos, n, &efi_menu->list) {return NULL;
case KEY_DOWN: if (efi_menu->active < efi_menu->count - 1) ++efi_menu->active;return NULL;
case KEY_SELECT: /* "Save" */return NULL;
return EFI_SUCCESS;
break;
return entry->key;
} /* "Quit" */
return EFI_ABORTED;
list);
return entry->key;
} break;
I think I've asked about this in the past, but don't we have to return something here?
case KEY_SPACE:
case KEY_QUIT:return NULL; } } } break;
return EFI_ABORTED;
default: /* Pressed key is not valid, no need to regenerate the menu */ break;return entry->key;
- eficonfig_process_save_boot_order() - callback function for "Save" entry
- u32 count = 0;
- efi_status_t ret;
- efi_uintn_t size;
- struct eficonfig_save_boot_order_data *save_data = data;
- efi_menu = save_data->efi_menu;
- if (!(efi_menu->count - 2)) /* no user defined boot option */
return EFI_SUCCESS;
goto out;
- count = 0;
break;
data = entry->data;
if (data->active)
The new_bootorder variable is allocated with the size of 'efi_menu->count - 2'. Should we add a check for count < efi_menu->count - 2 or are we always safe?
- save_data->selected = true;
+out:
- return ret;
Thanks /Ilias
On Thu, 22 Dec 2022 at 20:54, Ilias Apalodimas ilias.apalodimas@linaro.org wrote:
static const
OK.
bool selected;
bool reverse;
Yes, it is the same behavior as other menus and U-Boot menu framework expects.
if (reverse)
if (reverse)
printf("[*] ");
else
printf("[ ] ");
printf("[*] ");
else
printf("[ ] ");
if (reverse)
if (reverse)
return EFI_SUCCESS;
break;
return entry->key;
} /* "Quit" */
return EFI_ABORTED;
list);
return entry->key;
} break;
Reaching here means the user key press is not valid and no need to re-draw the menu, it is the same as 'default' case. I will add a comment for this case.
case KEY_SPACE:
I also add the same comment for this case.
case KEY_QUIT:
return EFI_ABORTED;
u32 count = 0;
efi_status_t ret;
efi_uintn_t size;
u16 *new_bootorder;
return EFI_SUCCESS;
goto out;
count = 0;
break;
data = entry->data;
if (data->active)
At the beginning of this function, there is a check.
if (!(efi_menu->count - 2)) /* no user defined boot option */ return EFI_SUCCESS;
The change boot order menu always has at least "Save" and "Quit" menu entries, count < efi_menu->count - 2 is always safe here. I will add a comment on this.
+out:
return ret;
Thanks /Ilias
The current eficonfig menu does not support vertical scroll, so it can not display the menu entries greater than the console row size.
This commit add the vertial scroll support. The console size is retrieved by SIMPLE_TEXT_OUTPUT_PROTOCOL.QueryMode() service, then calculates the row size for menu entry by subtracting menu header and description row size from the console row size. "start" and "end" are added in the efimenu structure. "start" keeps the menu entry index at the top, "end" keeps the bottom menu entry index. item_data_print() menu function only draws the menu entry between "start" and "end".
Signed-off-by: Masahisa Kojima masahisa.kojima@linaro.org --- cmd/eficonfig.c | 79 ++++++++++++++++++++++++++++++++++++-------- include/efi_config.h | 4 +++ include/efi_loader.h | 1 + 3 files changed, 70 insertions(+), 14 deletions(-)
diff --git a/cmd/eficonfig.c b/cmd/eficonfig.c index c2c6c01c3b..9b64fc4826 100644 --- a/cmd/eficonfig.c +++ b/cmd/eficonfig.c @@ -29,8 +29,13 @@ static char eficonfig_change_boot_order_desc[] = " Press SPACE to activate or deactivate the entry\n" " Select [Save] to complete, ESC/CTRL+C to quit";
+static struct efi_simple_text_output_protocol *cout; +static int avail_row; + #define EFICONFIG_DESCRIPTION_MAX 32 #define EFICONFIG_OPTIONAL_DATA_MAX 64 +#define EFICONFIG_MENU_HEADER_ROW_NUM 3 +#define EFICONFIG_MENU_DESC_ROW_NUM 5
/** * struct eficonfig_filepath_info - structure to be used to store file path @@ -156,18 +161,16 @@ void eficonfig_print_entry(void *data) struct eficonfig_entry *entry = data; int reverse = (entry->efi_menu->active == entry->num);
- /* TODO: support scroll or page for many entries */ + if (entry->efi_menu->start > entry->num || entry->efi_menu->end < entry->num) + return;
- /* - * Move cursor to line where the entry will be drawn (entry->num) - * First 3 lines(menu header) + 1 empty line - */ - printf(ANSI_CURSOR_POSITION, entry->num + 4, 7); + printf(ANSI_CURSOR_POSITION, (entry->num - entry->efi_menu->start) + + EFICONFIG_MENU_HEADER_ROW_NUM + 1, 7);
if (reverse) puts(ANSI_COLOR_REVERSE);
- printf("%s", entry->title); + printf(ANSI_CLEAR_LINE "%s", entry->title);
if (reverse) puts(ANSI_COLOR_RESET); @@ -190,8 +193,8 @@ void eficonfig_display_statusline(struct menu *m) ANSI_CURSOR_POSITION ANSI_CLEAR_LINE ANSI_CURSOR_POSITION "%s" ANSI_CLEAR_LINE_TO_END, - 1, 1, entry->efi_menu->menu_header, entry->efi_menu->count + 5, 1, - entry->efi_menu->count + 6, 1, entry->efi_menu->menu_desc); + 1, 1, entry->efi_menu->menu_header, avail_row + 4, 1, + avail_row + 5, 1, entry->efi_menu->menu_desc); }
/** @@ -213,13 +216,23 @@ char *eficonfig_choice_entry(void *data)
switch (key) { case KEY_UP: - if (efi_menu->active > 0) + if (efi_menu->active > 0) { --efi_menu->active; + if (efi_menu->start > efi_menu->active) { + efi_menu->start--; + efi_menu->end--; + } + } /* no menu key selected, regenerate menu */ return NULL; case KEY_DOWN: - if (efi_menu->active < efi_menu->count - 1) + if (efi_menu->active < efi_menu->count - 1) { ++efi_menu->active; + if (efi_menu->end < efi_menu->active) { + efi_menu->start++; + efi_menu->end++; + } + } /* no menu key selected, regenerate menu */ return NULL; case KEY_SELECT: @@ -399,6 +412,8 @@ efi_status_t eficonfig_process_common(struct efimenu *efi_menu,
efi_menu->delay = -1; efi_menu->active = 0; + efi_menu->start = 0; + efi_menu->end = avail_row - 1;
if (menu_header) { efi_menu->menu_header = strdup(menu_header); @@ -1865,7 +1880,11 @@ static void eficonfig_print_change_boot_order_entry(void *data) struct eficonfig_entry *entry = data; int reverse = (entry->efi_menu->active == entry->num);
- printf(ANSI_CURSOR_POSITION, entry->num + 4, 7); + if (entry->efi_menu->start > entry->num || entry->efi_menu->end < entry->num) + return; + + printf(ANSI_CURSOR_POSITION ANSI_CLEAR_LINE, + (entry->num - entry->efi_menu->start) + EFICONFIG_MENU_HEADER_ROW_NUM + 1, 7);
if (reverse) puts(ANSI_COLOR_REVERSE); @@ -1916,8 +1935,13 @@ char *eficonfig_choice_change_boot_order(void *data) } fallthrough; case KEY_UP: - if (efi_menu->active > 0) + if (efi_menu->active > 0) { --efi_menu->active; + if (efi_menu->start > efi_menu->active) { + efi_menu->start--; + efi_menu->end--; + } + } return NULL; case KEY_MINUS: if (efi_menu->active < efi_menu->count - 3) { @@ -1933,11 +1957,20 @@ char *eficonfig_choice_change_boot_order(void *data) list_add(&entry->list, &tmp->list);
++efi_menu->active; + if (efi_menu->end < efi_menu->active) { + efi_menu->start++; + efi_menu->end++; + } } return NULL; case KEY_DOWN: - if (efi_menu->active < efi_menu->count - 1) + if (efi_menu->active < efi_menu->count - 1) { ++efi_menu->active; + if (efi_menu->end < efi_menu->active) { + efi_menu->start++; + efi_menu->end++; + } + } return NULL; case KEY_SELECT: /* "Save" */ @@ -2580,6 +2613,7 @@ static efi_status_t eficonfig_init(void) efi_status_t ret = EFI_SUCCESS; static bool init; struct efi_handler *handler; + unsigned long columns, rows;
if (!init) { ret = efi_search_protocol(efi_root, &efi_guid_text_input_protocol, &handler); @@ -2590,6 +2624,23 @@ static efi_status_t eficonfig_init(void) EFI_OPEN_PROTOCOL_GET_PROTOCOL); if (ret != EFI_SUCCESS) return ret; + ret = efi_search_protocol(efi_root, &efi_guid_text_output_protocol, &handler); + if (ret != EFI_SUCCESS) + return ret; + + ret = efi_protocol_open(handler, (void **)&cout, efi_root, NULL, + EFI_OPEN_PROTOCOL_GET_PROTOCOL); + if (ret != EFI_SUCCESS) + return ret; + + cout->query_mode(cout, cout->mode->mode, &columns, &rows); + avail_row = rows - (EFICONFIG_MENU_HEADER_ROW_NUM + + EFICONFIG_MENU_DESC_ROW_NUM); + if (avail_row <= 0) { + eficonfig_print_msg("Console size is too small!"); + return EFI_INVALID_PARAMETER; + } + /* TODO: Should we check the minimum column size? */ }
init = true; diff --git a/include/efi_config.h b/include/efi_config.h index 9432d13f2e..fa5f2ce090 100644 --- a/include/efi_config.h +++ b/include/efi_config.h @@ -49,6 +49,8 @@ struct eficonfig_entry { * @menu_header: menu header string * @menu_desc: menu description string * @list: menu entry list structure + * @start: top menu index to draw + * @end: bottom menu index to draw */ struct efimenu { int delay; @@ -57,6 +59,8 @@ struct efimenu { char *menu_header; char *menu_desc; struct list_head list; + int start; + int end; };
/** diff --git a/include/efi_loader.h b/include/efi_loader.h index 699176872d..91d8a5ef0c 100644 --- a/include/efi_loader.h +++ b/include/efi_loader.h @@ -328,6 +328,7 @@ extern const efi_guid_t efi_esrt_guid; extern const efi_guid_t smbios_guid; /*GUID of console */ extern const efi_guid_t efi_guid_text_input_protocol; +extern const efi_guid_t efi_guid_text_output_protocol;
extern char __efi_runtime_start[], __efi_runtime_stop[]; extern char __efi_runtime_rel_start[], __efi_runtime_rel_stop[];
Ilias Apalodimas
Masahisa Kojima
