[U-Boot] [PATCH 1/2] Convert CONFIG_PHY_CORTINA to Kconfig
This converts the following to Kconfig: CONFIG_PHY_CORTINA
Signed-off-by: Tom Rini trini@konsulko.com --- configs/T2080RDB_NAND_defconfig | 1 + configs/T2080RDB_SDCARD_defconfig | 1 + configs/T2080RDB_SECURE_BOOT_defconfig | 1 + configs/T2080RDB_SPIFLASH_defconfig | 1 + configs/T2080RDB_SRIO_PCIE_BOOT_defconfig | 1 + configs/T2080RDB_defconfig | 1 + configs/T4160RDB_defconfig | 1 + configs/T4240RDB_SDCARD_defconfig | 1 + configs/T4240RDB_defconfig | 1 + configs/ls2080ardb_SECURE_BOOT_defconfig | 1 + configs/ls2080ardb_defconfig | 1 + configs/ls2080ardb_nand_defconfig | 1 + configs/ls2081ardb_defconfig | 1 + configs/ls2088ardb_qspi_SECURE_BOOT_defconfig | 1 + configs/ls2088ardb_qspi_defconfig | 1 + configs/ls2088ardb_tfa_SECURE_BOOT_defconfig | 1 + configs/ls2088ardb_tfa_defconfig | 1 + include/configs/T208xRDB.h | 1 - include/configs/T4240RDB.h | 1 - include/configs/ls2080ardb.h | 1 - 20 files changed, 17 insertions(+), 3 deletions(-)
diff --git a/configs/T2080RDB_NAND_defconfig b/configs/T2080RDB_NAND_defconfig index 3d4e0eb397fb..a8fc78850eeb 100644 --- a/configs/T2080RDB_NAND_defconfig +++ b/configs/T2080RDB_NAND_defconfig @@ -62,6 +62,7 @@ CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y +CONFIG_PHY_CORTINA=y CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_MII=y diff --git a/configs/T2080RDB_SDCARD_defconfig b/configs/T2080RDB_SDCARD_defconfig index 1a3a6a37334e..97043dcab60f 100644 --- a/configs/T2080RDB_SDCARD_defconfig +++ b/configs/T2080RDB_SDCARD_defconfig @@ -59,6 +59,7 @@ CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y +CONFIG_PHY_CORTINA=y CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_MII=y diff --git a/configs/T2080RDB_SECURE_BOOT_defconfig b/configs/T2080RDB_SECURE_BOOT_defconfig index 5c256f8261ec..65522f79391f 100644 --- a/configs/T2080RDB_SECURE_BOOT_defconfig +++ b/configs/T2080RDB_SECURE_BOOT_defconfig @@ -43,6 +43,7 @@ CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y +CONFIG_PHY_CORTINA=y CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_MII=y diff --git a/configs/T2080RDB_SPIFLASH_defconfig b/configs/T2080RDB_SPIFLASH_defconfig index 01723c63d00e..380037ff017e 100644 --- a/configs/T2080RDB_SPIFLASH_defconfig +++ b/configs/T2080RDB_SPIFLASH_defconfig @@ -62,6 +62,7 @@ CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y +CONFIG_PHY_CORTINA=y CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_MII=y diff --git a/configs/T2080RDB_SRIO_PCIE_BOOT_defconfig b/configs/T2080RDB_SRIO_PCIE_BOOT_defconfig index d29c147ece15..838d12515dcb 100644 --- a/configs/T2080RDB_SRIO_PCIE_BOOT_defconfig +++ b/configs/T2080RDB_SRIO_PCIE_BOOT_defconfig @@ -35,6 +35,7 @@ CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y +CONFIG_PHY_CORTINA=y CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_MII=y diff --git a/configs/T2080RDB_defconfig b/configs/T2080RDB_defconfig index 71a95599d11a..400c4c18101f 100644 --- a/configs/T2080RDB_defconfig +++ b/configs/T2080RDB_defconfig @@ -47,6 +47,7 @@ CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y +CONFIG_PHY_CORTINA=y CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_MII=y diff --git a/configs/T4160RDB_defconfig b/configs/T4160RDB_defconfig index 986539ad8454..b0a661bfa853 100644 --- a/configs/T4160RDB_defconfig +++ b/configs/T4160RDB_defconfig @@ -36,6 +36,7 @@ CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SST=y CONFIG_PHYLIB=y +CONFIG_PHY_CORTINA=y CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_FMAN_ENET=y diff --git a/configs/T4240RDB_SDCARD_defconfig b/configs/T4240RDB_SDCARD_defconfig index b5d306171044..15ecd01a6783 100644 --- a/configs/T4240RDB_SDCARD_defconfig +++ b/configs/T4240RDB_SDCARD_defconfig @@ -52,6 +52,7 @@ CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SST=y CONFIG_PHYLIB=y +CONFIG_PHY_CORTINA=y CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_FMAN_ENET=y diff --git a/configs/T4240RDB_defconfig b/configs/T4240RDB_defconfig index 0e926df4fad7..3b3f86a8b796 100644 --- a/configs/T4240RDB_defconfig +++ b/configs/T4240RDB_defconfig @@ -40,6 +40,7 @@ CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SST=y CONFIG_PHYLIB=y +CONFIG_PHY_CORTINA=y CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_FMAN_ENET=y diff --git a/configs/ls2080ardb_SECURE_BOOT_defconfig b/configs/ls2080ardb_SECURE_BOOT_defconfig index d231c235f023..bc42a542290e 100644 --- a/configs/ls2080ardb_SECURE_BOOT_defconfig +++ b/configs/ls2080ardb_SECURE_BOOT_defconfig @@ -42,6 +42,7 @@ CONFIG_SYS_FLASH_CFI=y CONFIG_DM_SPI_FLASH=y CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y +CONFIG_PHY_CORTINA=y CONFIG_E1000=y CONFIG_MII=y CONFIG_PCI=y diff --git a/configs/ls2080ardb_defconfig b/configs/ls2080ardb_defconfig index 484030495506..be06206fbe6d 100644 --- a/configs/ls2080ardb_defconfig +++ b/configs/ls2080ardb_defconfig @@ -45,6 +45,7 @@ CONFIG_SYS_FLASH_CFI=y CONFIG_DM_SPI_FLASH=y CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y +CONFIG_PHY_CORTINA=y CONFIG_E1000=y CONFIG_MII=y CONFIG_PCI=y diff --git a/configs/ls2080ardb_nand_defconfig b/configs/ls2080ardb_nand_defconfig index 49bdd587ac84..bd5a953182c7 100644 --- a/configs/ls2080ardb_nand_defconfig +++ b/configs/ls2080ardb_nand_defconfig @@ -54,6 +54,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y +CONFIG_PHY_CORTINA=y CONFIG_E1000=y CONFIG_MII=y CONFIG_PCI=y diff --git a/configs/ls2081ardb_defconfig b/configs/ls2081ardb_defconfig index 01288a7be7f3..d8204f16db92 100644 --- a/configs/ls2081ardb_defconfig +++ b/configs/ls2081ardb_defconfig @@ -41,6 +41,7 @@ CONFIG_FSL_ESDHC=y CONFIG_DM_SPI_FLASH=y CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y +CONFIG_PHY_CORTINA=y CONFIG_E1000=y CONFIG_MII=y CONFIG_PCI=y diff --git a/configs/ls2088ardb_qspi_SECURE_BOOT_defconfig b/configs/ls2088ardb_qspi_SECURE_BOOT_defconfig index 8894df5d31b0..c6327e4bd510 100644 --- a/configs/ls2088ardb_qspi_SECURE_BOOT_defconfig +++ b/configs/ls2088ardb_qspi_SECURE_BOOT_defconfig @@ -37,6 +37,7 @@ CONFIG_SPI_FLASH_SPANSION=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y +CONFIG_PHY_CORTINA=y CONFIG_E1000=y CONFIG_MII=y CONFIG_PCI=y diff --git a/configs/ls2088ardb_qspi_defconfig b/configs/ls2088ardb_qspi_defconfig index d230000e1925..ae7700610305 100644 --- a/configs/ls2088ardb_qspi_defconfig +++ b/configs/ls2088ardb_qspi_defconfig @@ -43,6 +43,7 @@ CONFIG_SPI_FLASH_SPANSION=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y +CONFIG_PHY_CORTINA=y CONFIG_E1000=y CONFIG_MII=y CONFIG_PCI=y diff --git a/configs/ls2088ardb_tfa_SECURE_BOOT_defconfig b/configs/ls2088ardb_tfa_SECURE_BOOT_defconfig index db253d1ce957..c5339e50ba7e 100644 --- a/configs/ls2088ardb_tfa_SECURE_BOOT_defconfig +++ b/configs/ls2088ardb_tfa_SECURE_BOOT_defconfig @@ -52,6 +52,7 @@ CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y +CONFIG_PHY_CORTINA=y CONFIG_E1000=y CONFIG_MII=y CONFIG_PCI=y diff --git a/configs/ls2088ardb_tfa_defconfig b/configs/ls2088ardb_tfa_defconfig index 1730c9a5eab1..ed7ef439af63 100644 --- a/configs/ls2088ardb_tfa_defconfig +++ b/configs/ls2088ardb_tfa_defconfig @@ -59,6 +59,7 @@ CONFIG_SPI_FLASH_SPANSION=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y +CONFIG_PHY_CORTINA=y CONFIG_E1000=y CONFIG_MII=y CONFIG_PCI=y diff --git a/include/configs/T208xRDB.h b/include/configs/T208xRDB.h index b64bafdb330e..748a7a0afe0b 100644 --- a/include/configs/T208xRDB.h +++ b/include/configs/T208xRDB.h @@ -541,7 +541,6 @@ unsigned long get_board_ddr_clk(void); #endif /* CONFIG_NOBQFMAN */
#ifdef CONFIG_SYS_DPAA_FMAN -#define CONFIG_PHY_CORTINA #define CONFIG_PHY_REALTEK #define CONFIG_CORTINA_FW_LENGTH 0x40000 #define RGMII_PHY1_ADDR 0x01 /* RealTek RTL8211E */ diff --git a/include/configs/T4240RDB.h b/include/configs/T4240RDB.h index fc2aed335688..bbb4ca9b906b 100644 --- a/include/configs/T4240RDB.h +++ b/include/configs/T4240RDB.h @@ -548,7 +548,6 @@ unsigned long get_board_ddr_clk(void); #ifdef CONFIG_SYS_DPAA_FMAN #define CONFIG_PHYLIB_10G #define CONFIG_PHY_VITESSE -#define CONFIG_PHY_CORTINA #define CONFIG_SYS_CORTINA_FW_IN_NOR #define CONFIG_CORTINA_FW_ADDR 0xefe00000 #define CONFIG_CORTINA_FW_LENGTH 0x40000 diff --git a/include/configs/ls2080ardb.h b/include/configs/ls2080ardb.h index c5d57cfdd43b..02f6cd43d3b1 100644 --- a/include/configs/ls2080ardb.h +++ b/include/configs/ls2080ardb.h @@ -560,7 +560,6 @@ unsigned long get_board_sys_clk(void);
/* MAC/PHY configuration */ #ifdef CONFIG_FSL_MC_ENET -#define CONFIG_PHY_CORTINA #define CONFIG_SYS_CORTINA_FW_IN_NOR #ifdef CONFIG_QSPI_BOOT #define CONFIG_CORTINA_FW_ADDR 0x20980000
This converts the following to Kconfig: CONFIG_SYS_CORTINA_FW_IN_MMC CONFIG_SYS_CORTINA_FW_IN_NAND CONFIG_SYS_CORTINA_FW_IN_NOR CONFIG_SYS_CORTINA_FW_IN_REMOTE CONFIG_SYS_CORTINA_FW_IN_SPIFLASH
Signed-off-by: Tom Rini trini@konsulko.com --- configs/T2080RDB_NAND_defconfig | 1 + configs/T2080RDB_SDCARD_defconfig | 1 + configs/T2080RDB_SPIFLASH_defconfig | 1 + configs/T2080RDB_SRIO_PCIE_BOOT_defconfig | 1 + drivers/net/phy/Kconfig | 22 ++++++++++++++++++++++ include/configs/T208xRDB.h | 5 ----- include/configs/T4240RDB.h | 1 - include/configs/ls2080ardb.h | 1 - scripts/config_whitelist.txt | 5 ----- 9 files changed, 26 insertions(+), 12 deletions(-)
diff --git a/configs/T2080RDB_NAND_defconfig b/configs/T2080RDB_NAND_defconfig index a8fc78850eeb..1b6d15e279aa 100644 --- a/configs/T2080RDB_NAND_defconfig +++ b/configs/T2080RDB_NAND_defconfig @@ -63,6 +63,7 @@ CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y CONFIG_PHY_CORTINA=y +CONFIG_SYS_CORTINA_FW_IN_NAND=y CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_MII=y diff --git a/configs/T2080RDB_SDCARD_defconfig b/configs/T2080RDB_SDCARD_defconfig index 97043dcab60f..2e89beb45a34 100644 --- a/configs/T2080RDB_SDCARD_defconfig +++ b/configs/T2080RDB_SDCARD_defconfig @@ -60,6 +60,7 @@ CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y CONFIG_PHY_CORTINA=y +CONFIG_SYS_CORTINA_FW_IN_MMC=y CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_MII=y diff --git a/configs/T2080RDB_SPIFLASH_defconfig b/configs/T2080RDB_SPIFLASH_defconfig index 380037ff017e..d78f009b1166 100644 --- a/configs/T2080RDB_SPIFLASH_defconfig +++ b/configs/T2080RDB_SPIFLASH_defconfig @@ -63,6 +63,7 @@ CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y CONFIG_PHY_CORTINA=y +CONFIG_SYS_CORTINA_FW_IN_SPIFLASH=y CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_MII=y diff --git a/configs/T2080RDB_SRIO_PCIE_BOOT_defconfig b/configs/T2080RDB_SRIO_PCIE_BOOT_defconfig index 838d12515dcb..8f6a5ced2246 100644 --- a/configs/T2080RDB_SRIO_PCIE_BOOT_defconfig +++ b/configs/T2080RDB_SRIO_PCIE_BOOT_defconfig @@ -36,6 +36,7 @@ CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y CONFIG_PHY_CORTINA=y +CONFIG_SYS_CORTINA_FW_IN_REMOTE=y CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_MII=y diff --git a/drivers/net/phy/Kconfig b/drivers/net/phy/Kconfig index 30bd8e765304..bcea8a0c3e6c 100644 --- a/drivers/net/phy/Kconfig +++ b/drivers/net/phy/Kconfig @@ -100,6 +100,28 @@ config PHY_BROADCOM config PHY_CORTINA bool "Cortina Ethernet PHYs support"
+choice + prompt "Location of the Cortina firmware" + default SYS_CORTINA_FW_IN_NOR + depends on PHY_CORTINA + +config SYS_CORTINA_FW_IN_MMC + bool "Cortina firmware in MMC" + +config SYS_CORTINA_FW_IN_NAND + bool "Cortina firmware in NAND flash" + +config SYS_CORTINA_FW_IN_NOR + bool "Cortina firmware in NOR flash" + +config SYS_CORTINA_FW_IN_REMOTE + bool "Cortina firmware in remote device" + +config SYS_CORTINA_FW_IN_SPIFLASH + bool "Cortina firmware in SPI flash" + +endchoice + config PHY_DAVICOM bool "Davicom Ethernet PHYs support"
diff --git a/include/configs/T208xRDB.h b/include/configs/T208xRDB.h index 748a7a0afe0b..8c0b81adfd11 100644 --- a/include/configs/T208xRDB.h +++ b/include/configs/T208xRDB.h @@ -502,7 +502,6 @@ unsigned long get_board_ddr_clk(void); * env is stored at 0x100000, sector size is 0x10000, ucode is stored after * env, so we got 0x110000. */ -#define CONFIG_SYS_CORTINA_FW_IN_SPIFLASH #define CONFIG_SYS_FMAN_FW_ADDR 0x110000 #define CONFIG_CORTINA_FW_ADDR 0x120000
@@ -512,12 +511,10 @@ unsigned long get_board_ddr_clk(void); * about 1MB (2048 blocks), Env is stored after the image, and the env size is * 0x2000 (16 blocks), 8 + 2048 + 16 = 2072, enlarge it to 2080. */ -#define CONFIG_SYS_CORTINA_FW_IN_MMC #define CONFIG_SYS_FMAN_FW_ADDR (512 * 0x820) #define CONFIG_CORTINA_FW_ADDR (512 * 0x8a0)
#elif defined(CONFIG_NAND) -#define CONFIG_SYS_CORTINA_FW_IN_NAND #define CONFIG_SYS_FMAN_FW_ADDR (3 * CONFIG_SYS_NAND_BLOCK_SIZE) #define CONFIG_CORTINA_FW_ADDR (4 * CONFIG_SYS_NAND_BLOCK_SIZE) #elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) @@ -528,11 +525,9 @@ unsigned long get_board_ddr_clk(void); * slave SRIO or PCIE outbound window->master inbound window-> * master LAW->the ucode address in master's memory space. */ -#define CONFIG_SYS_CORTINA_FW_IN_REMOTE #define CONFIG_SYS_FMAN_FW_ADDR 0xFFE00000 #define CONFIG_CORTINA_FW_ADDR 0xFFE10000 #else -#define CONFIG_SYS_CORTINA_FW_IN_NOR #define CONFIG_SYS_FMAN_FW_ADDR 0xEFF00000 #define CONFIG_CORTINA_FW_ADDR 0xEFE00000 #endif diff --git a/include/configs/T4240RDB.h b/include/configs/T4240RDB.h index bbb4ca9b906b..493da70f669e 100644 --- a/include/configs/T4240RDB.h +++ b/include/configs/T4240RDB.h @@ -548,7 +548,6 @@ unsigned long get_board_ddr_clk(void); #ifdef CONFIG_SYS_DPAA_FMAN #define CONFIG_PHYLIB_10G #define CONFIG_PHY_VITESSE -#define CONFIG_SYS_CORTINA_FW_IN_NOR #define CONFIG_CORTINA_FW_ADDR 0xefe00000 #define CONFIG_CORTINA_FW_LENGTH 0x40000 #define CONFIG_PHY_TERANETICS diff --git a/include/configs/ls2080ardb.h b/include/configs/ls2080ardb.h index 02f6cd43d3b1..926239a58834 100644 --- a/include/configs/ls2080ardb.h +++ b/include/configs/ls2080ardb.h @@ -560,7 +560,6 @@ unsigned long get_board_sys_clk(void);
/* MAC/PHY configuration */ #ifdef CONFIG_FSL_MC_ENET -#define CONFIG_SYS_CORTINA_FW_IN_NOR #ifdef CONFIG_QSPI_BOOT #define CONFIG_CORTINA_FW_ADDR 0x20980000 #else diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 7784922693bf..14627f83a68e 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -1919,11 +1919,6 @@ CONFIG_SYS_CMXFCR_VALUE2 CONFIG_SYS_CMXFCR_VALUE3 CONFIG_SYS_CORE_SRAM CONFIG_SYS_CORE_SRAM_SIZE -CONFIG_SYS_CORTINA_FW_IN_MMC -CONFIG_SYS_CORTINA_FW_IN_NAND -CONFIG_SYS_CORTINA_FW_IN_NOR -CONFIG_SYS_CORTINA_FW_IN_REMOTE -CONFIG_SYS_CORTINA_FW_IN_SPIFLASH CONFIG_SYS_CPC_REINIT_F CONFIG_SYS_CPLD_AMASK CONFIG_SYS_CPLD_BASE
