[U-Boot] [PATCH v2][ARM][AT91] Build fix/update of AFEB9260
Make AFEB9260 build again. Based on fix for AT91SAM9260EK.
Signed-off-by: Sergey Lapin slapin@ossfans.org --- Cleaned-up a bit
board/afeb9260/afeb9260.c | 103 ++++++++++++++++++++++++------------------- boards.cfg | 2 +- include/configs/afeb9260.h | 28 +++++++++--- 3 files changed, 79 insertions(+), 54 deletions(-)
diff --git a/board/afeb9260/afeb9260.c b/board/afeb9260/afeb9260.c index 3c37557..0269140 100644 --- a/board/afeb9260/afeb9260.c +++ b/board/afeb9260/afeb9260.c @@ -31,7 +31,7 @@ #include <asm/arch/at91_pmc.h> #include <asm/arch/at91_rstc.h> #include <asm/arch/gpio.h> -#include <asm/arch/io.h> +#include <asm/io.h> #include <asm/arch/hardware.h> #if defined(CONFIG_RESET_PHY_R) && defined(CONFIG_MACB) #include <netdev.h> @@ -48,29 +48,29 @@ DECLARE_GLOBAL_DATA_PTR; static void afeb9260_nand_hw_init(void) { unsigned long csa; + struct at91_smc *smc = (struct at91_smc *)ATMEL_BASE_SMC; + struct at91_matrix *matrix = (struct at91_matrix *)ATMEL_BASE_MATRIX;
- /* Enable CS3 */ - csa = at91_sys_read(AT91_MATRIX_EBICSA); - at91_sys_write(AT91_MATRIX_EBICSA, - csa | AT91_MATRIX_CS3A_SMC_SMARTMEDIA); + /* Assign CS3 to NAND/SmartMedia Interface */ + csa = readl(&matrix->ebicsa); + csa |= AT91_MATRIX_CS3A_SMC_SMARTMEDIA; + writel(csa, &matrix->ebicsa);
/* Configure SMC CS3 for NAND/SmartMedia */ - at91_sys_write(AT91_SMC_SETUP(3), - AT91_SMC_NWESETUP_(0) | AT91_SMC_NCS_WRSETUP_(0) | - AT91_SMC_NRDSETUP_(0) | AT91_SMC_NCS_RDSETUP_(0)); - at91_sys_write(AT91_SMC_PULSE(3), - AT91_SMC_NWEPULSE_(3) | AT91_SMC_NCS_WRPULSE_(3) | - AT91_SMC_NRDPULSE_(3) | AT91_SMC_NCS_RDPULSE_(3)); - at91_sys_write(AT91_SMC_CYCLE(3), - AT91_SMC_NWECYCLE_(5) | AT91_SMC_NRDCYCLE_(5)); - at91_sys_write(AT91_SMC_MODE(3), - AT91_SMC_READMODE | AT91_SMC_WRITEMODE | - AT91_SMC_EXNWMODE_DISABLE | - AT91_SMC_DBW_8 | - AT91_SMC_TDF_(2)); - - at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9260_ID_PIOC); - + writel(AT91_SMC_SETUP_NWE(1) | AT91_SMC_SETUP_NCS_WR(0) | + AT91_SMC_SETUP_NRD(1) | AT91_SMC_SETUP_NCS_RD(0), + &smc->cs[3].setup); + writel(AT91_SMC_PULSE_NWE(3) | AT91_SMC_PULSE_NCS_WR(3) | + AT91_SMC_PULSE_NRD(3) | AT91_SMC_PULSE_NCS_RD(3), + &smc->cs[3].pulse); + writel(AT91_SMC_CYCLE_NWE(5) | AT91_SMC_CYCLE_NRD(5), + &smc->cs[3].cycle); + writel(AT91_SMC_MODE_RM_NRD | AT91_SMC_MODE_WM_NWE | + AT91_SMC_MODE_EXNW_DISABLE | + AT91_SMC_MODE_DBW_8 | + AT91_SMC_MODE_TDF_CYCLE(2), + &smc->cs[3].mode); + /* Configure RDY/BSY */ at91_set_gpio_input(CONFIG_SYS_NAND_READY_PIN, 1);
@@ -81,10 +81,15 @@ static void afeb9260_nand_hw_init(void) #ifdef CONFIG_MACB static void afeb9260_macb_hw_init(void) { - unsigned long rstc; + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; + struct at91_port *pioa = (struct at91_port *)ATMEL_BASE_PIOA; + struct at91_rstc *rstc = (struct at91_rstc *)ATMEL_BASE_RSTC; + unsigned long erstl; + + + /* Enable EMAC clock */ + writel(1 << ATMEL_ID_EMAC0, &pmc->pcer);
- /* Enable clock */ - at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9260_ID_EMAC);
/* * Disable pull-up on: @@ -103,24 +108,22 @@ static void afeb9260_macb_hw_init(void) pin_to_mask(AT91_PIN_PA25) | pin_to_mask(AT91_PIN_PA26) | pin_to_mask(AT91_PIN_PA28), - pin_to_controller(AT91_PIN_PA0) + PIO_PUDR); + &pioa->pudr);
- rstc = at91_sys_read(AT91_RSTC_MR) & AT91_RSTC_ERSTL; + erstl = readl(&rstc->mr) & AT91_RSTC_MR_ERSTL_MASK;
/* Need to reset PHY -> 500ms reset */ - at91_sys_write(AT91_RSTC_MR, AT91_RSTC_KEY | - AT91_RSTC_ERSTL | (0x0D << 8) | - AT91_RSTC_URSTEN); - - at91_sys_write(AT91_RSTC_CR, AT91_RSTC_KEY | AT91_RSTC_EXTRST); + writel(AT91_RSTC_KEY | AT91_RSTC_MR_ERSTL(13) | + AT91_RSTC_MR_URSTEN, &rstc->mr); + writel(AT91_RSTC_KEY | AT91_RSTC_CR_EXTRST, &rstc->cr);
/* Wait for end hardware reset */ - while (!(at91_sys_read(AT91_RSTC_SR) & AT91_RSTC_NRSTL)); - + while (!(readl(&rstc->sr) & AT91_RSTC_SR_NRSTL)) + ; /* Restore NRST value */ - at91_sys_write(AT91_RSTC_MR, AT91_RSTC_KEY | - (rstc) | - AT91_RSTC_URSTEN); + writel(AT91_RSTC_KEY | erstl | AT91_RSTC_MR_URSTEN, + &rstc->mr); +
/* Re-enable pull-up */ writel(pin_to_mask(AT91_PIN_PA14) | @@ -129,23 +132,29 @@ static void afeb9260_macb_hw_init(void) pin_to_mask(AT91_PIN_PA25) | pin_to_mask(AT91_PIN_PA26) | pin_to_mask(AT91_PIN_PA28), - pin_to_controller(AT91_PIN_PA0) + PIO_PUER); + &pioa->puer);
at91_macb_hw_init(); } #endif - +int board_early_init_f(void) +{ + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; + /* Enable clocks for all PIOs */ + writel((1 << ATMEL_ID_PIOA) | + (1 << ATMEL_ID_PIOB) | + (1 << ATMEL_ID_PIOC), + &pmc->pcer); + return 0; +} int board_init(void) { - /* Enable Ctrlc */ - console_init_f(); - /* arch number of AT91SAM9260EK-Board */ gd->bd->bi_arch_number = MACH_TYPE_AFEB9260; /* adress of boot parameters */ - gd->bd->bi_boot_params = PHYS_SDRAM + 0x100; + gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x100;
- at91_serial_hw_init(); + at91_seriald_hw_init(); #ifdef CONFIG_CMD_NAND afeb9260_nand_hw_init(); #endif @@ -159,8 +168,10 @@ int board_init(void)
int dram_init(void) { - gd->bd->bi_dram[0].start = PHYS_SDRAM; - gd->bd->bi_dram[0].size = PHYS_SDRAM_SIZE; + gd->ram_size = get_ram_size( + (void *)CONFIG_SYS_SDRAM_BASE, + CONFIG_SYS_SDRAM_SIZE); + return 0; }
@@ -174,7 +185,7 @@ int board_eth_init(bd_t *bis) { int rc = 0; #ifdef CONFIG_MACB - rc = macb_eth_initialize(0, (void *)AT91SAM9260_BASE_EMAC, 0x01); + rc = macb_eth_initialize(0, (void *)ATMEL_BASE_EMAC0, 0x01); #endif return rc; } diff --git a/boards.cfg b/boards.cfg index ac20c81..a187a9f 100644 --- a/boards.cfg +++ b/boards.cfg @@ -72,7 +72,7 @@ netstar arm arm925t voiceblue arm arm925t omap1510inn arm arm925t - ti aspenite arm arm926ejs - Marvell armada100 -afeb9260 arm arm926ejs - - at91 +afeb9260 arm arm926ejs - - at91 afeb9260:AT91SAM9260 at91cap9adk arm arm926ejs - atmel at91 at91sam9260ek_nandflash arm arm926ejs at91sam9260ek atmel at91 at91sam9260ek:AT91SAM9260,SYS_USE_NANDFLASH at91sam9260ek_dataflash_cs0 arm arm926ejs at91sam9260ek atmel at91 at91sam9260ek:AT91SAM9260,SYS_USE_DATAFLASH_CS0 diff --git a/include/configs/afeb9260.h b/include/configs/afeb9260.h index 36a2a46..9114a52 100644 --- a/include/configs/afeb9260.h +++ b/include/configs/afeb9260.h @@ -25,12 +25,19 @@
#ifndef __CONFIG_H #define __CONFIG_H +#include <asm/arch/hardware.h>
-#define CONFIG_AT91_LEGACY +#define CONFIG_SYS_TEXT_BASE 0x21f00000
/* ARM asynchronous clock */ #define CONFIG_SYS_AT91_MAIN_CLOCK 18429952 /* from 18.432 MHz crystal */ -#define CONFIG_SYS_HZ 1000 +#define CONFIG_SYS_AT91_SLOW_CLOCK 32768 +#define CONFIG_SYS_HZ 1000 + +#define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_DISPLAY_CPUINFO + +
#define CONFIG_AT91SAM9260 1 /* It's an Atmel AT91SAM9260 SoC*/ #define CONFIG_AFEB9260 1 /* on an AFEB9260 Board */ @@ -46,8 +53,14 @@ /* * Hardware drivers */ +#define CONFIG_ATMEL_LEGACY #define CONFIG_AT91_GPIO 1 +#define CONFIG_AT91_PULLUP 1 + + #define CONFIG_ATMEL_USART 1 +#define CONFIG_USART_BASE ATMEL_BASE_DBGU +#define CONFIG_USART_ID ATMEL_ID_SYS #undef CONFIG_USART0 #undef CONFIG_USART1 #undef CONFIG_USART2 @@ -82,8 +95,8 @@
/* SDRAM */ #define CONFIG_NR_DRAM_BANKS 1 -#define PHYS_SDRAM 0x20000000 -#define PHYS_SDRAM_SIZE 0x04000000 /* 64 megs */ +#define CONFIG_SYS_SDRAM_BASE ATMEL_BASE_CS1 +#define CONFIG_SYS_SDRAM_SIZE 0x04000000 /* 64 megs */
/* DataFlash */ #define CONFIG_ATMEL_DATAFLASH_SPI @@ -100,7 +113,7 @@ #ifdef CONFIG_CMD_NAND #define CONFIG_NAND_ATMEL #define CONFIG_SYS_MAX_NAND_DEVICE 1 -#define CONFIG_SYS_NAND_BASE 0x40000000 +#define CONFIG_SYS_NAND_BASE ATMEL_BASE_CS3 #define CONFIG_SYS_NAND_DBW_8 1 /* our ALE is AD21 */ #define CONFIG_SYS_NAND_MASK_ALE (1 << 21) @@ -134,12 +147,14 @@
#define CONFIG_SYS_LOAD_ADDR 0x21000000 /* load address */
-#define CONFIG_SYS_MEMTEST_START PHYS_SDRAM +#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE #define CONFIG_SYS_MEMTEST_END 0x21e00000
#undef CONFIG_SYS_USE_DATAFLASH_CS0 #define CONFIG_SYS_USE_DATAFLASH_CS1 1 #undef CONFIG_SYS_USE_NANDFLASH +#define CONFIG_SYS_INIT_SP_ADDR (ATMEL_BASE_SRAM1 + 0x1000 -\ + GENERATED_GBL_DATA_SIZE)
/* bootstrap + u-boot + env + linux in dataflash on CS1 */ #define CONFIG_ENV_IS_IN_DATAFLASH 1
Dear Sergey Lapin,
Cleaned-up a bit
Does not the afeb9260 have a manufacturer? And if it is not planned to be available with other Atmel SoCs, it is not necessary to have the "AT91SAM9260" in the boards.cfg file. See also below.
This should lead to a double definition warning. See above. Also, please do not use "1" if no numerical value is intended for the define. Important: if you define the SoC type in this file, it must be before "hardware.h" is included.
Please remove the "1" here. Fix further down as well.
- Hardware drivers
No "1" here.
This "1" is required. OK.
Avoid double empty lines.
No "1" here.
Please, no #undef's. Fix further down as well.
@@ -82,8 +95,8 @@
Best Regards, Reinhard
On Thu, Jun 09, 2011 at 11:13:25AM +0200, Reinhard Meyer wrote:
Dear Sergey Lapin,
Cleaned-up a bit
It have, but no established name. This is volunteer project.
Fixed this.
Fixed.
Done
- Hardware drivers
No "1" here.
Done
Fixed
No "1" here.
Removed these.
About section below: #include <config_cmd_default.h> #undef CONFIG_CMD_BDI #undef CONFIG_CMD_FPGA #undef CONFIG_CMD_IMI #undef CONFIG_CMD_IMLS #undef CONFIG_CMD_LOADS #undef CONFIG_CMD_SOURCE
Is it ok or should I have to change it? If I need to change it, then I'd like to know how to do it right way.
All the best, S.
Signed-off-by: Sergey Lapin slapin@ossfans.org --- Fixed unneeded 1s in defines in config .h Removed most undefs. Setting SoC name in config .h board/afeb9260/afeb9260.c | 103 ++++++++++++++++++++++++------------------- include/configs/afeb9260.h | 46 ++++++++++++-------- 2 files changed, 85 insertions(+), 64 deletions(-)
@@ -174,7 +185,7 @@ int board_eth_init(bd_t *bis) { int rc = 0; #ifdef CONFIG_MACB - rc = macb_eth_initialize(0, (void *)AT91SAM9260_BASE_EMAC, 0x01); + rc = macb_eth_initialize(0, (void *)ATMEL_BASE_EMAC0, 0x01); #endif return rc; } diff --git a/include/configs/afeb9260.h b/include/configs/afeb9260.h index 36a2a46..0a7bd75 100644 --- a/include/configs/afeb9260.h +++ b/include/configs/afeb9260.h @@ -25,17 +25,23 @@
#ifndef __CONFIG_H #define __CONFIG_H +#define CONFIG_AT91SAM9260 /* Atmel AT91SAM9260 SoC*/ +#include <asm/arch/hardware.h>
-#define CONFIG_AT91SAM9260 1 /* It's an Atmel AT91SAM9260 SoC*/ -#define CONFIG_AFEB9260 1 /* on an AFEB9260 Board */ +#define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_DISPLAY_CPUINFO + + + +#define CONFIG_AFEB9260 /* AFEB9260 Board */ #define CONFIG_ARCH_CPU_INIT -#undef CONFIG_USE_IRQ /* we don't need IRQ/FIQ stuff */
#define CONFIG_CMDLINE_TAG 1 /* enable passing of ATAGs */ #define CONFIG_SETUP_MEMORY_TAGS 1 @@ -46,12 +52,15 @@ /* * Hardware drivers */ -#define CONFIG_AT91_GPIO 1 +#define CONFIG_ATMEL_LEGACY +#define CONFIG_AT91_GPIO +#define CONFIG_AT91_PULLUP 1 + + #define CONFIG_ATMEL_USART 1 -#undef CONFIG_USART0 -#undef CONFIG_USART1 -#undef CONFIG_USART2 -#define CONFIG_USART3 1 /* USART 3 is DBGU */ +#define CONFIG_USART_BASE ATMEL_BASE_DBGU +#define CONFIG_USART_ID ATMEL_ID_SYS +#define CONFIG_USART3 /* USART 3 is DBGU */
#define CONFIG_BOOTDELAY 3
@@ -82,8 +91,8 @@
/* DataFlash */ #define CONFIG_ATMEL_DATAFLASH_SPI @@ -100,7 +109,7 @@ #ifdef CONFIG_CMD_NAND #define CONFIG_NAND_ATMEL #define CONFIG_SYS_MAX_NAND_DEVICE 1 -#define CONFIG_SYS_NAND_BASE 0x40000000 +#define CONFIG_SYS_NAND_BASE ATMEL_BASE_CS3 #define CONFIG_SYS_NAND_DBW_8 1 /* our ALE is AD21 */ #define CONFIG_SYS_NAND_MASK_ALE (1 << 21) @@ -116,7 +125,9 @@
/* Ethernet */ #define CONFIG_MACB 1 -#undef CONFIG_RMII /* We have full MII there */ +#ifdef CONFIG_RMII +#error fuck +#endif #define CONFIG_RESET_PHY_R 1
#define CONFIG_NET_MULTI 1 @@ -134,12 +145,12 @@
-#undef CONFIG_SYS_USE_DATAFLASH_CS0 #define CONFIG_SYS_USE_DATAFLASH_CS1 1 -#undef CONFIG_SYS_USE_NANDFLASH +#define CONFIG_SYS_INIT_SP_ADDR (ATMEL_BASE_SRAM1 + 0x1000 -\ + GENERATED_GBL_DATA_SIZE)
/* bootstrap + u-boot + env + linux in dataflash on CS1 */ #define CONFIG_ENV_IS_IN_DATAFLASH 1 @@ -172,5 +183,4 @@ #ifdef CONFIG_USE_IRQ #error CONFIG_USE_IRQ not supported #endif - #endif
I'm really sorry for this uncleaned patch. Please ignore it - I've sent wrong version. I'm really sorry for its content. Clean version will follow.
All the best, S.
Signed-off-by: Sergey Lapin slapin@ossfans.org --- Fixed unneeded 1s in defines in board configuration Removed most undefs in board configuration Setting SoC name in board configuration
board/afeb9260/afeb9260.c | 101 ++++++++++++++++++++++++------------------- include/configs/afeb9260.h | 78 ++++++++++++++++++---------------- 2 files changed, 97 insertions(+), 82 deletions(-)
diff --git a/board/afeb9260/afeb9260.c b/board/afeb9260/afeb9260.c index 3c37557..f0e2e80 100644 --- a/board/afeb9260/afeb9260.c +++ b/board/afeb9260/afeb9260.c @@ -31,7 +31,7 @@ #include <asm/arch/at91_pmc.h> #include <asm/arch/at91_rstc.h> #include <asm/arch/gpio.h> -#include <asm/arch/io.h> +#include <asm/io.h> #include <asm/arch/hardware.h> #if defined(CONFIG_RESET_PHY_R) && defined(CONFIG_MACB) #include <netdev.h> @@ -48,28 +48,28 @@ DECLARE_GLOBAL_DATA_PTR; static void afeb9260_nand_hw_init(void) { unsigned long csa; + struct at91_smc *smc = (struct at91_smc *)ATMEL_BASE_SMC; + struct at91_matrix *matrix = (struct at91_matrix *)ATMEL_BASE_MATRIX;
/* Configure SMC CS3 for NAND/SmartMedia */ - at91_sys_write(AT91_SMC_SETUP(3), - AT91_SMC_NWESETUP_(0) | AT91_SMC_NCS_WRSETUP_(0) | - AT91_SMC_NRDSETUP_(0) | AT91_SMC_NCS_RDSETUP_(0)); - at91_sys_write(AT91_SMC_PULSE(3), - AT91_SMC_NWEPULSE_(3) | AT91_SMC_NCS_WRPULSE_(3) | - AT91_SMC_NRDPULSE_(3) | AT91_SMC_NCS_RDPULSE_(3)); - at91_sys_write(AT91_SMC_CYCLE(3), - AT91_SMC_NWECYCLE_(5) | AT91_SMC_NRDCYCLE_(5)); - at91_sys_write(AT91_SMC_MODE(3), - AT91_SMC_READMODE | AT91_SMC_WRITEMODE | - AT91_SMC_EXNWMODE_DISABLE | - AT91_SMC_DBW_8 | - AT91_SMC_TDF_(2)); - - at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9260_ID_PIOC); + writel(AT91_SMC_SETUP_NWE(1) | AT91_SMC_SETUP_NCS_WR(0) | + AT91_SMC_SETUP_NRD(1) | AT91_SMC_SETUP_NCS_RD(0), + &smc->cs[3].setup); + writel(AT91_SMC_PULSE_NWE(3) | AT91_SMC_PULSE_NCS_WR(3) | + AT91_SMC_PULSE_NRD(3) | AT91_SMC_PULSE_NCS_RD(3), + &smc->cs[3].pulse); + writel(AT91_SMC_CYCLE_NWE(5) | AT91_SMC_CYCLE_NRD(5), + &smc->cs[3].cycle); + writel(AT91_SMC_MODE_RM_NRD | AT91_SMC_MODE_WM_NWE | + AT91_SMC_MODE_EXNW_DISABLE | + AT91_SMC_MODE_DBW_8 | + AT91_SMC_MODE_TDF_CYCLE(2), + &smc->cs[3].mode);
/* Configure RDY/BSY */ at91_set_gpio_input(CONFIG_SYS_NAND_READY_PIN, 1); @@ -81,10 +81,15 @@ static void afeb9260_nand_hw_init(void) #ifdef CONFIG_MACB static void afeb9260_macb_hw_init(void) { - unsigned long rstc; + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; + struct at91_port *pioa = (struct at91_port *)ATMEL_BASE_PIOA; + struct at91_rstc *rstc = (struct at91_rstc *)ATMEL_BASE_RSTC; + unsigned long erstl; + + + /* Enable EMAC clock */ + writel(1 << ATMEL_ID_EMAC0, &pmc->pcer);
@@ -174,7 +185,7 @@ int board_eth_init(bd_t *bis) { int rc = 0; #ifdef CONFIG_MACB - rc = macb_eth_initialize(0, (void *)AT91SAM9260_BASE_EMAC, 0x01); + rc = macb_eth_initialize(0, (void *)ATMEL_BASE_EMAC0, 0x01); #endif return rc; } diff --git a/include/configs/afeb9260.h b/include/configs/afeb9260.h index 36a2a46..2c2c077 100644 --- a/include/configs/afeb9260.h +++ b/include/configs/afeb9260.h @@ -25,17 +25,21 @@
-#define CONFIG_AT91SAM9260 1 /* It's an Atmel AT91SAM9260 SoC*/ -#define CONFIG_AFEB9260 1 /* on an AFEB9260 Board */ +#define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_DISPLAY_CPUINFO + +#define CONFIG_AFEB9260 /* AFEB9260 Board */ #define CONFIG_ARCH_CPU_INIT -#undef CONFIG_USE_IRQ /* we don't need IRQ/FIQ stuff */
#define CONFIG_CMDLINE_TAG 1 /* enable passing of ATAGs */ #define CONFIG_SETUP_MEMORY_TAGS 1 @@ -46,12 +50,14 @@ /* * Hardware drivers */ -#define CONFIG_AT91_GPIO 1 -#define CONFIG_ATMEL_USART 1 -#undef CONFIG_USART0 -#undef CONFIG_USART1 -#undef CONFIG_USART2 -#define CONFIG_USART3 1 /* USART 3 is DBGU */ +#define CONFIG_ATMEL_LEGACY +#define CONFIG_AT91_GPIO +#define CONFIG_AT91_PULLUP 1 + +#define CONFIG_ATMEL_USART +#define CONFIG_USART_BASE ATMEL_BASE_DBGU +#define CONFIG_USART_ID ATMEL_ID_SYS +#define CONFIG_USART3 /* USART 3 is DBGU */
@@ -74,20 +80,20 @@ #undef CONFIG_CMD_LOADS #undef CONFIG_CMD_SOURCE
-#define CONFIG_CMD_PING 1 -#define CONFIG_CMD_DHCP 1 +#define CONFIG_CMD_PING +#define CONFIG_CMD_DHCP
-#define CONFIG_CMD_NAND 1 -#define CONFIG_CMD_USB 1 +#define CONFIG_CMD_NAND +#define CONFIG_CMD_USB
/* DataFlash */ #define CONFIG_ATMEL_DATAFLASH_SPI -#define CONFIG_HAS_DATAFLASH 1 +#define CONFIG_HAS_DATAFLASH #define CONFIG_SYS_SPI_WRITE_TOUT (5 * CONFIG_SYS_HZ) #define CONFIG_SYS_MAX_DATAFLASH_BANKS 2 #define CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 0xC0000000 /* CS0 */ @@ -100,8 +106,8 @@ #ifdef CONFIG_CMD_NAND #define CONFIG_NAND_ATMEL #define CONFIG_SYS_MAX_NAND_DEVICE 1 -#define CONFIG_SYS_NAND_BASE 0x40000000 -#define CONFIG_SYS_NAND_DBW_8 1 +#define CONFIG_SYS_NAND_BASE ATMEL_BASE_CS3 +#define CONFIG_SYS_NAND_DBW_8 /* our ALE is AD21 */ #define CONFIG_SYS_NAND_MASK_ALE (1 << 21) /* our CLE is AD22 */ @@ -112,37 +118,36 @@ #endif
/* NOR flash - no real flash on this board */ -#define CONFIG_SYS_NO_FLASH 1 +#define CONFIG_SYS_NO_FLASH
/* Ethernet */ -#define CONFIG_MACB 1 -#undef CONFIG_RMII /* We have full MII there */ -#define CONFIG_RESET_PHY_R 1 +#define CONFIG_MACB +#define CONFIG_RESET_PHY_R
-#define CONFIG_NET_MULTI 1 +#define CONFIG_NET_MULTI #define CONFIG_NET_RETRY_COUNT 20
/* USB */ #define CONFIG_USB_ATMEL -#define CONFIG_USB_OHCI_NEW 1 -#define CONFIG_DOS_PARTITION 1 -#define CONFIG_SYS_USB_OHCI_CPU_INIT 1 +#define CONFIG_USB_OHCI_NEW +#define CONFIG_DOS_PARTITION +#define CONFIG_SYS_USB_OHCI_CPU_INIT #define CONFIG_SYS_USB_OHCI_REGS_BASE 0x00500000 /* AT91SAM9260_UHP_BASE */ #define CONFIG_SYS_USB_OHCI_SLOT_NAME "at91sam9260" #define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 1 -#define CONFIG_USB_STORAGE 1 +#define CONFIG_USB_STORAGE
-#undef CONFIG_SYS_USE_DATAFLASH_CS0 -#define CONFIG_SYS_USE_DATAFLASH_CS1 1 -#undef CONFIG_SYS_USE_NANDFLASH +#define CONFIG_SYS_USE_DATAFLASH_CS1 +#define CONFIG_SYS_INIT_SP_ADDR (ATMEL_BASE_SRAM1 + 0x1000 -\ + GENERATED_GBL_DATA_SIZE)
/* bootstrap + u-boot + env + linux in dataflash on CS1 */ -#define CONFIG_ENV_IS_IN_DATAFLASH 1 +#define CONFIG_ENV_IS_IN_DATAFLASH #define CONFIG_SYS_MONITOR_BASE (CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS1 + 0x8400) #define CONFIG_ENV_OFFSET 0x4200 #define CONFIG_ENV_ADDR (CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS1 + CONFIG_ENV_OFFSET) @@ -159,8 +164,8 @@ #define CONFIG_SYS_CBSIZE 256 #define CONFIG_SYS_MAXARGS 16 #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) -#define CONFIG_SYS_LONGHELP 1 -#define CONFIG_CMDLINE_EDITING 1 +#define CONFIG_SYS_LONGHELP +#define CONFIG_CMDLINE_EDITING
/* * Size of malloc() pool @@ -172,5 +177,4 @@ #ifdef CONFIG_USE_IRQ #error CONFIG_USE_IRQ not supported #endif - #endif
Hi, Reinhard!
Any updates regarding this patch? (I just care for board to stay in tree and not being removed)
Dear Sergey Lapin,
Applied to u-boot-atmel/master, Thanks, Reinhard
Reinhard Meyer
Sergey Lapin
