[U-Boot] [PATCH] omap3: spi: Correct ti, pindir-d0-out-d1-in parsing
The ti,pindir-d0-out-d1-in property is not expected to have a value according to the device-tree binding, so treat it as a boolean not a uint property.
Signed-off-by: Sjoerd Simons sjoerd.simons@collabora.co.uk ---
drivers/spi/omap3_spi.c | 6 ++++-- 1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/drivers/spi/omap3_spi.c b/drivers/spi/omap3_spi.c index 053a67bbe0..1ac691a68e 100644 --- a/drivers/spi/omap3_spi.c +++ b/drivers/spi/omap3_spi.c @@ -630,8 +630,10 @@ static int omap3_spi_probe(struct udevice *dev) (struct omap2_mcspi_platform_config*)dev_get_driver_data(dev);
priv->regs = (struct mcspi *)(devfdt_get_addr(dev) + data->regs_offset); - priv->pin_dir = fdtdec_get_uint(blob, node, "ti,pindir-d0-out-d1-in", - MCSPI_PINDIR_D0_IN_D1_OUT); + if (fdtdec_get_bool(blob, node, "ti,pindir-d0-out-d1-in")) + priv->pin_dir = MCSPI_PINDIR_D0_OUT_D1_IN; + else + priv->pin_dir = MCSPI_PINDIR_D0_IN_D1_OUT; priv->wordlen = SPI_DEFAULT_WORDLEN; return 0; }
On Fri, Mar 23, 2018 at 3:25 AM, Sjoerd Simons sjoerd.simons@collabora.co.uk wrote:
Applied to u-boot-spi/master
Jagan Teki
Sjoerd Simons
