[U-Boot] [PATCH] Fix building for mx51evk board
Fix: mx51evk.c:206:6: error: conflicting types for 'board_ehci_hcd_init' /u-boot/include/usb/ehci-fsl.h:254:5: note: previous declaration of 'board_ehci_hcd_init' was here
We also fix board_ehci_hcd_init() for mx53loco board. Building for mx53loco worked since <usb/ehci-fsl.h> is not included here.
Signed-off-by: Anatolij Gustschin agust@denx.de --- board/freescale/mx51evk/mx51evk.c | 3 ++- board/freescale/mx53loco/mx53loco.c | 3 ++- 2 files changed, 4 insertions(+), 2 deletions(-)
diff --git a/board/freescale/mx51evk/mx51evk.c b/board/freescale/mx51evk/mx51evk.c index 13c5941..e43aaf7 100644 --- a/board/freescale/mx51evk/mx51evk.c +++ b/board/freescale/mx51evk/mx51evk.c @@ -203,7 +203,7 @@ static void setup_usb_h1(void) mxc_iomux_set_pad(MX51_PIN_EIM_D21, GPIO_PAD); }
-void board_ehci_hcd_init(int port) +int board_ehci_hcd_init(int port) { /* Set USBH1_STP to GPIO and toggle it */ mxc_request_iomux(MX51_PIN_USBH1_STP, IOMUX_CONFIG_GPIO); @@ -228,6 +228,7 @@ void board_ehci_hcd_init(int port) gpio_direction_output(MX51EVK_USBH1_HUB_RST, 0); mdelay(2); gpio_set_value(MX51EVK_USBH1_HUB_RST, 1); + return 0; } #endif
diff --git a/board/freescale/mx53loco/mx53loco.c b/board/freescale/mx53loco/mx53loco.c index 57170ce..ea4d354 100644 --- a/board/freescale/mx53loco/mx53loco.c +++ b/board/freescale/mx53loco/mx53loco.c @@ -79,12 +79,13 @@ static void setup_iomux_uart(void) }
#ifdef CONFIG_USB_EHCI_MX5 -void board_ehci_hcd_init(int port) +int board_ehci_hcd_init(int port) { /* request VBUS power enable pin, GPIO[8}, gpio7 */ mxc_request_iomux(MX53_PIN_ATA_DA_2, IOMUX_CONFIG_ALT1); gpio_direction_output(IOMUX_TO_GPIO(MX53_PIN_ATA_DA_2), 0); gpio_set_value(IOMUX_TO_GPIO(MX53_PIN_ATA_DA_2), 1); + return 0; } #endif
Applied to u-boot-imx (fix), thanks.
Best regards, Stefano Babic
Anatolij Gustschin
Stefano Babic
