[U-Boot] [PATCH] powerpc/85xx: Enable ESDHC111 erratum on P2040/P3041/P5010/P5020 SoCs
The workaround for ESDHC111 should also be applied on P2040/P3041/P5010/P5020 SoCs.
Signed-off-by: Lei Xu B33228@freescale.com Signed-off-by: Roy Zang tie-fei.zang@freescale.com Signed-off-by: Kumar Gala galak@kernel.crashing.org --- arch/powerpc/include/asm/config_mpc85xx.h | 4 ++++ 1 files changed, 4 insertions(+), 0 deletions(-)
diff --git a/arch/powerpc/include/asm/config_mpc85xx.h b/arch/powerpc/include/asm/config_mpc85xx.h index d93586a..da2e998 100644 --- a/arch/powerpc/include/asm/config_mpc85xx.h +++ b/arch/powerpc/include/asm/config_mpc85xx.h @@ -266,6 +266,7 @@ #define CONFIG_SYS_FM_MURAM_SIZE 0x28000 #define CONFIG_SYS_FSL_USB1_PHY_ENABLE #define CONFIG_SYS_FSL_USB2_PHY_ENABLE +#define CONFIG_SYS_FSL_ERRATUM_ESDHC111
#elif defined(CONFIG_PPC_P3041) #define CONFIG_MAX_CPUS 4 @@ -279,6 +280,7 @@ #define CONFIG_SYS_FM_MURAM_SIZE 0x28000 #define CONFIG_SYS_FSL_USB1_PHY_ENABLE #define CONFIG_SYS_FSL_USB2_PHY_ENABLE +#define CONFIG_SYS_FSL_ERRATUM_ESDHC111
#elif defined(CONFIG_PPC_P4040) #define CONFIG_MAX_CPUS 4 @@ -323,6 +325,7 @@ #define CONFIG_SYS_FM_MURAM_SIZE 0x28000 #define CONFIG_SYS_FSL_USB1_PHY_ENABLE #define CONFIG_SYS_FSL_USB2_PHY_ENABLE +#define CONFIG_SYS_FSL_ERRATUM_ESDHC111
#elif defined(CONFIG_PPC_P5020) #define CONFIG_MAX_CPUS 2 @@ -336,6 +339,7 @@ #define CONFIG_SYS_FM_MURAM_SIZE 0x28000 #define CONFIG_SYS_FSL_USB1_PHY_ENABLE #define CONFIG_SYS_FSL_USB2_PHY_ENABLE +#define CONFIG_SYS_FSL_ERRATUM_ESDHC111
#else #error Processor type not defined for this platform
applied to 85xx
- k
Kumar Gala
