[U-Boot] [PATCH] driver: net: ldpaa: Update the lane number to DPMAC mapping
As of patch "http://patchwork.ozlabs.org/patch/539748/", serdes_init() is passing correct DPMAC id.
So Update the lane to DPMAC mapping.
Signed-off-by: Prabhakar Kushwaha prabhakar@freescale.com --- drivers/net/ldpaa_eth/ldpaa_wriop.c | 17 ++++++++--------- 1 file changed, 8 insertions(+), 9 deletions(-)
diff --git a/drivers/net/ldpaa_eth/ldpaa_wriop.c b/drivers/net/ldpaa_eth/ldpaa_wriop.c index 357b35a..f7f26c2 100644 --- a/drivers/net/ldpaa_eth/ldpaa_wriop.c +++ b/drivers/net/ldpaa_eth/ldpaa_wriop.c @@ -23,18 +23,17 @@ __weak phy_interface_t wriop_dpmac_enet_if(int dpmac_id, int lane_prtc) void wriop_init_dpmac(int sd, int dpmac_id, int lane_prtcl) { phy_interface_t enet_if; - int index = dpmac_id + sd * 8;
- dpmac_info[index].enabled = 0; - dpmac_info[index].id = 0; - dpmac_info[index].phy_addr = -1; - dpmac_info[index].enet_if = PHY_INTERFACE_MODE_NONE; + dpmac_info[dpmac_id].enabled = 0; + dpmac_info[dpmac_id].id = 0; + dpmac_info[dpmac_id].phy_addr = -1; + dpmac_info[dpmac_id].enet_if = PHY_INTERFACE_MODE_NONE;
- enet_if = wriop_dpmac_enet_if(index, lane_prtcl); + enet_if = wriop_dpmac_enet_if(dpmac_id, lane_prtcl); if (enet_if != PHY_INTERFACE_MODE_NONE) { - dpmac_info[index].enabled = 1; - dpmac_info[index].id = index; - dpmac_info[index].enet_if = enet_if; + dpmac_info[dpmac_id].enabled = 1; + dpmac_info[dpmac_id].id = dpmac_id; + dpmac_info[dpmac_id].enet_if = enet_if; } }
Squashed with patch "armv8: lsch3: Fix lane protocol parsing logic" http://patchwork.ozlabs.org/patch/539748/
York
Prabhakar Kushwaha
York Sun
