[U-Boot] [PATCH V4 1/3] arm: discard relocation entries for secure text
The code such as PSCI in section named secure is bundled with u-boot image, and when bootm, the code will be copied to their runtime address same to compliation/linking address - CONFIG_ARMV7_SECURE_BASE.
When compile the PSCI code and link it into the u-boot image, there will be relocation entries in .rel.dyn section for PSCI. Actually, we do not needs these relocation entries.
If still keep the relocation entries in .rel.dyn section, r0 at line 103 and 106 in arch/arm/lib/relocate.S may be an invalid address which may not support read/write for one SoC. 102 /* relative fix: increase location by offset */ 103 add r0, r0, r4 104 ldr r1, [r0] 105 add r1, r1, r4 106 str r1, [r0]
So discard them to avoid touching the relocation entry in arch/arm/lib/relocate.S.
Signed-off-by: Peng Fan Peng.Fan@freescale.com Cc: Tom Warren twarren@nvidia.com Cc: York Sun yorksun@freescale.com Cc: Hans De Goede hdegoede@redhat.com Cc: Ian Campbell ijc@hellion.org.uk Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Tom Rini trini@konsulko.com Cc: Jan Kiszka jan.kiszka@siemens.com Cc: Stefano Babic sbabic@denx.de ---
Changes v4: none
V2 thread: http://lists.denx.de/pipermail/u-boot/2015-October/230755.html Changes v3: Move the relocation entries to the very begining and discard them.
V1 thread: http://lists.denx.de/pipermail/u-boot/2015-October/229426.html Changes V2: Refine commit msg. Discard the relocation entry section for secure text.
arch/arm/cpu/u-boot.lds | 17 +++++++++++++++++ 1 file changed, 17 insertions(+)
diff --git a/arch/arm/cpu/u-boot.lds b/arch/arm/cpu/u-boot.lds index 03cd9f6..d48a905 100644 --- a/arch/arm/cpu/u-boot.lds +++ b/arch/arm/cpu/u-boot.lds @@ -14,6 +14,23 @@ OUTPUT_ARCH(arm) ENTRY(_start) SECTIONS { + /* + * Discard the relocation entries for secure text. + * The secure code is bundled with u-boot image, so there will + * be relocations entries for the secure code, since we use + * "-mword-relocations" to compile and "-pie" to link into the + * final image. We do not need the relocation entries for secure + * code, because secure code will not be relocated, it only needs + * to be copied from loading address to CONFIG_ARMV7_SECURE_BASE, + * which is the linking and running address for secure code. + * If keep the relocation entries in .rel.dyn section, + * "relocation offset + linking address" may locates into an + * address that is reserved by SoC, then will trigger data abort. + * + * The reason that move .rel._secure at the beginning, is to + * avoid hole in the final image. + */ + /DISCARD/ : { *(.rel._secure*) } . = 0x00000000;
. = ALIGN(4);
1. add basic psci support for imx7 chip. 2. support cpu_on and cpu_off. 3. switch to non-secure mode when boot linux kernel. 4. set csu allow accessing all peripherial register in non-secure mode.
Signed-off-by: Frank Li Frank.Li@freescale.com Signed-off-by: Peng Fan Peng.Fan@freescale.com Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam fabio.estevam@freescale.com ---
Changes V4: Use macros but not magic number for init CSU.
Changes V3: Addressed Fabio and Frank's comments. http://lists.denx.de/pipermail/u-boot/2015-October/230756.html
arch/arm/cpu/armv7/mx7/Makefile | 4 ++ arch/arm/cpu/armv7/mx7/psci-mx7.c | 69 ++++++++++++++++++++++++++++++++ arch/arm/cpu/armv7/mx7/psci.S | 54 +++++++++++++++++++++++++ arch/arm/cpu/armv7/mx7/soc.c | 9 +++++ arch/arm/include/asm/arch-mx7/imx-regs.h | 3 ++ 5 files changed, 139 insertions(+) create mode 100644 arch/arm/cpu/armv7/mx7/psci-mx7.c create mode 100644 arch/arm/cpu/armv7/mx7/psci.S
diff --git a/arch/arm/cpu/armv7/mx7/Makefile b/arch/arm/cpu/armv7/mx7/Makefile index e6ecef0..d21f87f 100644 --- a/arch/arm/cpu/armv7/mx7/Makefile +++ b/arch/arm/cpu/armv7/mx7/Makefile @@ -6,3 +6,7 @@ #
obj-y := soc.o clock.o clock_slice.o + +ifdef CONFIG_ARMV7_PSCI +obj-y += psci-mx7.o psci.o +endif diff --git a/arch/arm/cpu/armv7/mx7/psci-mx7.c b/arch/arm/cpu/armv7/mx7/psci-mx7.c new file mode 100644 index 0000000..9a33047 --- /dev/null +++ b/arch/arm/cpu/armv7/mx7/psci-mx7.c @@ -0,0 +1,69 @@ +#include <asm/io.h> +#include <asm/psci.h> +#include <asm/arch/imx-regs.h> +#include <common.h> + +#define __secure __attribute__((section("._secure.text"))) + +#define GPC_CPU_PGC_SW_PDN_REQ 0xfc +#define GPC_CPU_PGC_SW_PUP_REQ 0xf0 +#define GPC_PGC_C1 0x840 + +#define BM_CPU_PGC_SW_PDN_PUP_REQ_CORE1_A7 0x2 + +/* below is for i.MX7D */ +#define SRC_GPR1_MX7D 0x074 +#define SRC_A7RCR0 0x004 +#define SRC_A7RCR1 0x008 + +#define BP_SRC_A7RCR0_A7_CORE_RESET0 0 +#define BP_SRC_A7RCR1_A7_CORE1_ENABLE 1 + +static inline void imx_gpcv2_set_m_core_pgc(bool enable, u32 offset) +{ + writel(enable, GPC_IPS_BASE_ADDR + offset); +} + +__secure void imx_gpcv2_set_core1_power(bool pdn) +{ + u32 reg = pdn ? GPC_CPU_PGC_SW_PUP_REQ : GPC_CPU_PGC_SW_PDN_REQ; + u32 val; + + imx_gpcv2_set_m_core_pgc(true, GPC_PGC_C1); + + val = readl(GPC_IPS_BASE_ADDR + reg); + val |= BM_CPU_PGC_SW_PDN_PUP_REQ_CORE1_A7; + writel(val, GPC_IPS_BASE_ADDR + reg); + + while ((readl(GPC_IPS_BASE_ADDR + reg) & + BM_CPU_PGC_SW_PDN_PUP_REQ_CORE1_A7) != 0) + ; + + imx_gpcv2_set_m_core_pgc(false, GPC_PGC_C1); +} + +__secure void imx_enable_cpu_ca7(int cpu, bool enable) +{ + u32 mask, val; + + mask = 1 << (BP_SRC_A7RCR1_A7_CORE1_ENABLE + cpu - 1); + val = readl(SRC_BASE_ADDR + SRC_A7RCR1); + val = enable ? val | mask : val & ~mask; + writel(val, SRC_BASE_ADDR + SRC_A7RCR1); +} + +__secure int imx_cpu_on(int fn, int cpu, int pc) +{ + writel(pc, SRC_BASE_ADDR + cpu * 8 + SRC_GPR1_MX7D); + imx_gpcv2_set_core1_power(true); + imx_enable_cpu_ca7(cpu, true); + return 0; +} + +__secure int imx_cpu_off(int cpu) +{ + imx_enable_cpu_ca7(cpu, false); + imx_gpcv2_set_core1_power(false); + writel(0, SRC_BASE_ADDR + cpu * 8 + SRC_GPR1_MX7D + 4); + return 0; +} diff --git a/arch/arm/cpu/armv7/mx7/psci.S b/arch/arm/cpu/armv7/mx7/psci.S new file mode 100644 index 0000000..34c6ab3 --- /dev/null +++ b/arch/arm/cpu/armv7/mx7/psci.S @@ -0,0 +1,54 @@ +#include <config.h> +#include <linux/linkage.h> + +#include <asm/armv7.h> +#include <asm/arch-armv7/generictimer.h> +#include <asm/psci.h> + + .pushsection ._secure.text, "ax" + + .arch_extension sec + + @ r1 = target CPU + @ r2 = target PC + +.globl psci_arch_init +psci_arch_init: + mov r6, lr + + bl psci_get_cpu_id + bl psci_get_cpu_stack_top + mov sp, r0 + + bx r6 + + @ r1 = target CPU + @ r2 = target PC + +.globl psci_cpu_on +psci_cpu_on: + push {lr} + + mov r0, r1 + bl psci_get_cpu_stack_top + str r2, [r0] + dsb + + ldr r2, =psci_cpu_entry + bl imx_cpu_on + + pop {pc} + +.globl psci_cpu_off +psci_cpu_off: + + bl psci_cpu_off_common + bl psci_get_cpu_id + bl imx_cpu_off + +1: wfi + b 1b + + .globl psci_text_end +psci_text_end: + .popsection diff --git a/arch/arm/cpu/armv7/mx7/soc.c b/arch/arm/cpu/armv7/mx7/soc.c index 2ed05ea..dbae868 100644 --- a/arch/arm/cpu/armv7/mx7/soc.c +++ b/arch/arm/cpu/armv7/mx7/soc.c @@ -114,10 +114,19 @@ u32 __weak get_board_rev(void) } #endif
+/* enable all periherial can be accessed in nosec mode */ +static void init_csu(void) +{ + int i = 0; + for (i = 0; i < CSU_NUM_REGS; i++) + writel(CSU_INIT_SEC_LEVEL0, CSU_IPS_BASE_ADDR + i * 4); +} + int arch_cpu_init(void) { init_aips();
+ init_csu(); /* Disable PDE bit of WMCR register */ imx_set_wdog_powerdown(false);
diff --git a/arch/arm/include/asm/arch-mx7/imx-regs.h b/arch/arm/include/asm/arch-mx7/imx-regs.h index 4dc11ee..9213374 100644 --- a/arch/arm/include/asm/arch-mx7/imx-regs.h +++ b/arch/arm/include/asm/arch-mx7/imx-regs.h @@ -866,6 +866,9 @@ struct cspi_regs { ECSPI3_BASE_ADDR, \ ECSPI4_BASE_ADDR
+#define CSU_INIT_SEC_LEVEL0 0x00FF00FF +#define CSU_NUM_REGS 64 + struct ocotp_regs { u32 ctrl; u32 ctrl_set;
Hi all,
Sorry to revive an old thread but I have some questions about thit patch.
On Fri, Oct 23, 2015 at 10:13:04AM +0800, Peng Fan wrote:
- add basic psci support for imx7 chip.
- support cpu_on and cpu_off.
- switch to non-secure mode when boot linux kernel.
- set csu allow accessing all peripherial register in non-secure mode.
Signed-off-by: Frank Li <Frank.Li at freescale.com> Signed-off-by: Peng Fan <Peng.Fan at freescale.com> Cc: Stefano Babic <sbabic at denx.de> Cc: Fabio Estevam <fabio.estevam at freescale.com>
[snip] diff --git a/arch/arm/include/asm/arch-mx7/imx-regs.h b/arch/arm/include/asm/arch-mx7/imx-regs.h index 4dc11ee..9213374 100644 --- a/arch/arm/include/asm/arch-mx7/imx-regs.h +++ b/arch/arm/include/asm/arch-mx7/imx-regs.h @@ -866,6 +866,9 @@ struct cspi_regs { ECSPI3_BASE_ADDR, \ ECSPI4_BASE_ADDR
In the security documentation (revA) it is said that there are 40 CSL, why is it 64 here?
Also, although this seems to work, later on when the kernel boots I get the following CAAM errors: caam 30900000.caam: failed to acquire DECO 0 ... caam 30900000.caam: failed to acquire DECO 0 caam 30900000.caam: failed to instantiate RNG caam: probe of 30900000.caam failed with error -11
If I revert this patch and therefore leave the CSU to its default state at bootup the above CAAM issue disappears, do you have any idea why?
As a FYI, I am using U-Boot v2016.03 + a few patches that adds support for our i.MX7 Nitrogen7 board. You can find the repo here: https://github.com/boundarydevices/u-boot-imx6/tree/boundary-v2016.03
Also, if I base U-Boot on top of NXP repo it works too since this csu/psci support isn't there: http://git.freescale.com/git/cgit.cgi/imx/uboot-imx.git/tree/?id=rel_imx_3.1...
Regards, Gary
Hi Gary,
On Thu, Mar 31, 2016 at 01:17:07PM +0200, Gary Bisson wrote:
Hi all,
This patch will let SoC switch to non sec mode. I have little knowledge of CAAM, I guess it works in sec mode. So when kernel boots up, it will complains a lot...
Revert this patch, then all code runs in sec mode.
Yeah. NXP code not switch to non sec mode.
You can revert this patch in your vendor tree. I am not sure whether you have tested linux upstream tree, or you use caam code from NXP vendor tree. If you use NXP vendor tree, and use uboot upstream code, sure caam will complain errros. We would like to use PSCI and work in non-sec mode, but still some works need to be done.
Regards, Peng.
Regards, Gary _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Hi Peng,
On Thu, Mar 31, 2016 at 3:33 PM, Peng Fan van.freenix@gmail.com wrote:
Hi Gary,
Hi all,
Seems like a safe assumption to say CAAM requires to be run in secure mode.
Thanks for your feedback. We are using our own tree based on NXP vendor one (3.14.52_1.1.0_ga).
We usually use upstream U-Boot with this kernel tree. I guess the easiest option here is actually to add CONFIG_MX7_SEC to our board config, this avoids to revert the patches.
Thanks, Gary
Support PSCI and switch to non-secure mode when booting linux.
Signed-off-by: Peng Fan Peng.Fan@freescale.com Signed-off-by: Frank Li Frank.Li@freescale.com Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam fabio.estevam@freescale.com ---
Changes v4: Discard unused 1's when define macros.
Changes V3: none
Changes V2: default no enable CONFIG_ARMV7_VIRT
include/configs/mx7_common.h | 11 +++++++++++ 1 file changed, 11 insertions(+)
diff --git a/include/configs/mx7_common.h b/include/configs/mx7_common.h index ea2be49..508d1d3 100644 --- a/include/configs/mx7_common.h +++ b/include/configs/mx7_common.h @@ -92,4 +92,15 @@ #define CONFIG_CMD_FUSE #define CONFIG_MXC_OCOTP
+/* + * Default boot linux kernel in no secure mode. + * If want to boot kernel in secure mode, please define CONFIG_MX7_SEC + */ +#ifndef CONFIG_MX7_SEC +#define CONFIG_ARMV7_NONSEC +#define CONFIG_ARMV7_PSCI +#define CONFIG_ARMV7_PSCI_NR_CPUS 2 +#define CONFIG_ARMV7_SECURE_BASE 0x00900000 +#endif + #endif
Hi Albert,
Are you fine with this patch?
I'd like the patch go through i.MX tree, since the other two patches needs this patch to work.
Thanks, Peng.
Changes v4: none
. = ALIGN(4);
-- 1.8.4
On Fri, Oct 30, 2015 at 04:23:49PM +0800, Peng Fan wrote:
Hi Albert,
Ping..
Thanks, Peng.
Thanks, Peng.
Changes v4: none
. = ALIGN(4);
-- 1.8.4
Hello Peng,
Changes v4: none
. = ALIGN(4);
-- 1.8.4
Acked-by: Albert ARIBAUD albert.u.boot@aribaud.net
Amicalement,
Hi Stefano,
On Tue, Nov 10, 2015 at 02:14:10PM +0100, Albert ARIBAUD wrote:
Hello Peng,
Changes v4: none
. = ALIGN(4);
-- 1.8.4
Can you please take a look at the patch set and merge?
Thanks, Peng.
Amicalement,
Albert.
On 11/11/2015 02:14, Peng Fan wrote:
Hi Stefano,
Hello Peng,
Changes v4: none
. = ALIGN(4);
-- 1.8.4
I'll do
Best regards, Stefano Babic
Hi Stefano,
Hello Peng,
Changes v4: none
. = ALIGN(4);
-- 1.8.4
Applied (whole series) to u-boot-imx, thanks !
participants (6)
Albert ARIBAUD
Gary Bisson
Peng Fan
Peng Fan
Peng Fan
Stefano Babic
