[PATCH v2] arm: mach-k3: am62a7: Provide a way to obtain boot device for non SPLs
Introduce get_boot_device() to obtain the booting device. Make it also available for non SPL builds so u-boot can also know the device it is booting from.
Signed-off-by: Garrett Giordano ggiordano@phytec.com Reviewed-by: Bryan Brattlof bb@ti.com --- v2: - Drop duplicate CONFIG_SOC_K3_AM62A7 entry from arch/arm/mach-k3/Makefile
arch/arm/mach-k3/am62ax/Makefile | 1 + arch/arm/mach-k3/am62ax/am62a7_init.c | 97 +---------------------- arch/arm/mach-k3/am62ax/boot.c | 106 ++++++++++++++++++++++++++ 3 files changed, 108 insertions(+), 96 deletions(-) create mode 100644 arch/arm/mach-k3/am62ax/boot.c
diff --git a/arch/arm/mach-k3/am62ax/Makefile b/arch/arm/mach-k3/am62ax/Makefile index e2ef88196f8..4e35e0c844d 100644 --- a/arch/arm/mach-k3/am62ax/Makefile +++ b/arch/arm/mach-k3/am62ax/Makefile @@ -5,3 +5,4 @@
obj-$(CONFIG_OF_SYSTEM_SETUP) += am62a7_fdt.o obj-$(CONFIG_XPL_BUILD) += am62a7_init.o +obj-y += boot.o diff --git a/arch/arm/mach-k3/am62ax/am62a7_init.c b/arch/arm/mach-k3/am62ax/am62a7_init.c index 0f62f39075b..5c0d3ee6869 100644 --- a/arch/arm/mach-k3/am62ax/am62a7_init.c +++ b/arch/arm/mach-k3/am62ax/am62a7_init.c @@ -171,102 +171,7 @@ void board_init_f(ulong dummy) debug("am62a_init: %s done\n", __func__); }
-static u32 __get_backup_bootmedia(u32 devstat) -{ - u32 bkup_bootmode = (devstat & MAIN_DEVSTAT_BACKUP_BOOTMODE_MASK) >> - MAIN_DEVSTAT_BACKUP_BOOTMODE_SHIFT; - u32 bkup_bootmode_cfg = - (devstat & MAIN_DEVSTAT_BACKUP_BOOTMODE_CFG_MASK) >> - MAIN_DEVSTAT_BACKUP_BOOTMODE_CFG_SHIFT; - - switch (bkup_bootmode) { - case BACKUP_BOOT_DEVICE_UART: - return BOOT_DEVICE_UART; - - case BACKUP_BOOT_DEVICE_USB: - return BOOT_DEVICE_USB; - - case BACKUP_BOOT_DEVICE_ETHERNET: - return BOOT_DEVICE_ETHERNET; - - case BACKUP_BOOT_DEVICE_MMC: - if (bkup_bootmode_cfg) - return BOOT_DEVICE_MMC2; - return BOOT_DEVICE_MMC1; - - case BACKUP_BOOT_DEVICE_SPI: - return BOOT_DEVICE_SPI; - - case BACKUP_BOOT_DEVICE_I2C: - return BOOT_DEVICE_I2C; - - case BACKUP_BOOT_DEVICE_DFU: - if (bkup_bootmode_cfg & MAIN_DEVSTAT_BACKUP_USB_MODE_MASK) - return BOOT_DEVICE_USB; - return BOOT_DEVICE_DFU; - }; - - return BOOT_DEVICE_RAM; -} - -static u32 __get_primary_bootmedia(u32 devstat) -{ - u32 bootmode = (devstat & MAIN_DEVSTAT_PRIMARY_BOOTMODE_MASK) >> - MAIN_DEVSTAT_PRIMARY_BOOTMODE_SHIFT; - u32 bootmode_cfg = (devstat & MAIN_DEVSTAT_PRIMARY_BOOTMODE_CFG_MASK) >> - MAIN_DEVSTAT_PRIMARY_BOOTMODE_CFG_SHIFT; - - switch (bootmode) { - case BOOT_DEVICE_OSPI: - fallthrough; - case BOOT_DEVICE_QSPI: - fallthrough; - case BOOT_DEVICE_XSPI: - fallthrough; - case BOOT_DEVICE_SPI: - return BOOT_DEVICE_SPI; - - case BOOT_DEVICE_ETHERNET_RGMII: - fallthrough; - case BOOT_DEVICE_ETHERNET_RMII: - return BOOT_DEVICE_ETHERNET; - - case BOOT_DEVICE_EMMC: - return BOOT_DEVICE_MMC1; - - case BOOT_DEVICE_SPI_NAND: - return BOOT_DEVICE_SPINAND; - - case BOOT_DEVICE_MMC: - if ((bootmode_cfg & MAIN_DEVSTAT_PRIMARY_MMC_PORT_MASK) >> - MAIN_DEVSTAT_PRIMARY_MMC_PORT_SHIFT) - return BOOT_DEVICE_MMC2; - return BOOT_DEVICE_MMC1; - - case BOOT_DEVICE_DFU: - if ((bootmode_cfg & MAIN_DEVSTAT_PRIMARY_USB_MODE_MASK) >> - MAIN_DEVSTAT_PRIMARY_USB_MODE_SHIFT) - return BOOT_DEVICE_USB; - return BOOT_DEVICE_DFU; - - case BOOT_DEVICE_NOBOOT: - return BOOT_DEVICE_RAM; - } - - return bootmode; -} - u32 spl_boot_device(void) { - u32 devstat = readl(CTRLMMR_MAIN_DEVSTAT); - u32 bootmedia; - - if (bootindex == K3_PRIMARY_BOOTMODE) - bootmedia = __get_primary_bootmedia(devstat); - else - bootmedia = __get_backup_bootmedia(devstat); - - debug("am62a_init: %s: devstat = 0x%x bootmedia = 0x%x bootindex = %d\n", - __func__, devstat, bootmedia, bootindex); - return bootmedia; + return get_boot_device(); } diff --git a/arch/arm/mach-k3/am62ax/boot.c b/arch/arm/mach-k3/am62ax/boot.c new file mode 100644 index 00000000000..af7fce1e5e9 --- /dev/null +++ b/arch/arm/mach-k3/am62ax/boot.c @@ -0,0 +1,106 @@ +// SPDX-License-Identifier: GPL-2.0+ +#include <asm/io.h> +#include <asm/arch/hardware.h> +#include <asm/arch/am62a_spl.h> + +static u32 __get_backup_bootmedia(u32 devstat) +{ + u32 bkup_bootmode = (devstat & MAIN_DEVSTAT_BACKUP_BOOTMODE_MASK) >> + MAIN_DEVSTAT_BACKUP_BOOTMODE_SHIFT; + u32 bkup_bootmode_cfg = + (devstat & MAIN_DEVSTAT_BACKUP_BOOTMODE_CFG_MASK) >> + MAIN_DEVSTAT_BACKUP_BOOTMODE_CFG_SHIFT; + + switch (bkup_bootmode) { + case BACKUP_BOOT_DEVICE_UART: + return BOOT_DEVICE_UART; + + case BACKUP_BOOT_DEVICE_USB: + return BOOT_DEVICE_USB; + + case BACKUP_BOOT_DEVICE_ETHERNET: + return BOOT_DEVICE_ETHERNET; + + case BACKUP_BOOT_DEVICE_MMC: + if (bkup_bootmode_cfg) + return BOOT_DEVICE_MMC2; + return BOOT_DEVICE_MMC1; + + case BACKUP_BOOT_DEVICE_SPI: + return BOOT_DEVICE_SPI; + + case BACKUP_BOOT_DEVICE_I2C: + return BOOT_DEVICE_I2C; + + case BACKUP_BOOT_DEVICE_DFU: + if (bkup_bootmode_cfg & MAIN_DEVSTAT_BACKUP_USB_MODE_MASK) + return BOOT_DEVICE_USB; + return BOOT_DEVICE_DFU; + }; + + return BOOT_DEVICE_RAM; +} + +static u32 __get_primary_bootmedia(u32 devstat) +{ + u32 bootmode = (devstat & MAIN_DEVSTAT_PRIMARY_BOOTMODE_MASK) >> + MAIN_DEVSTAT_PRIMARY_BOOTMODE_SHIFT; + u32 bootmode_cfg = (devstat & MAIN_DEVSTAT_PRIMARY_BOOTMODE_CFG_MASK) >> + MAIN_DEVSTAT_PRIMARY_BOOTMODE_CFG_SHIFT; + + switch (bootmode) { + case BOOT_DEVICE_OSPI: + fallthrough; + case BOOT_DEVICE_QSPI: + fallthrough; + case BOOT_DEVICE_XSPI: + fallthrough; + case BOOT_DEVICE_SPI: + return BOOT_DEVICE_SPI; + + case BOOT_DEVICE_ETHERNET_RGMII: + fallthrough; + case BOOT_DEVICE_ETHERNET_RMII: + return BOOT_DEVICE_ETHERNET; + + case BOOT_DEVICE_EMMC: + return BOOT_DEVICE_MMC1; + + case BOOT_DEVICE_SPI_NAND: + return BOOT_DEVICE_SPINAND; + + case BOOT_DEVICE_MMC: + if ((bootmode_cfg & MAIN_DEVSTAT_PRIMARY_MMC_PORT_MASK) >> + MAIN_DEVSTAT_PRIMARY_MMC_PORT_SHIFT) + return BOOT_DEVICE_MMC2; + return BOOT_DEVICE_MMC1; + + case BOOT_DEVICE_DFU: + if ((bootmode_cfg & MAIN_DEVSTAT_PRIMARY_USB_MODE_MASK) >> + MAIN_DEVSTAT_PRIMARY_USB_MODE_SHIFT) + return BOOT_DEVICE_USB; + return BOOT_DEVICE_DFU; + + case BOOT_DEVICE_NOBOOT: + return BOOT_DEVICE_RAM; + } + + return bootmode; +} + +u32 get_boot_device(void) +{ + u32 devstat = readl(CTRLMMR_MAIN_DEVSTAT); + u32 bootmode = *(u32 *)(K3_BOOT_PARAM_TABLE_INDEX_OCRAM); + u32 bootmedia; + + if (bootmode == K3_PRIMARY_BOOTMODE) + bootmedia = __get_primary_bootmedia(devstat); + else + bootmedia = __get_backup_bootmedia(devstat); + + debug("%s: devstat = 0x%x bootmedia = 0x%x bootmode = %d\n", + __func__, devstat, bootmedia, bootmode); + + return bootmedia; +} -- 2.25.1
Seems similar enough to what has been done already for AM64x, might be good at some point to just do this for all the K3 SoCs. I wonder how much of the contents of these functions are common across them all..
For now, LGTM,
Reviewed-by: Andrew Davis afd@ti.com
fallthrough;
fallthrough;
fallthrough;
fallthrough;
- return bootmode;
- u32 bootmedia;
- else
- return bootmedia;
- return get_boot_device(); }
fallthrough;
fallthrough;
fallthrough;
fallthrough;
- return bootmode;
- u32 bootmode = *(u32 *)(K3_BOOT_PARAM_TABLE_INDEX_OCRAM);
- u32 bootmedia;
- if (bootmode == K3_PRIMARY_BOOTMODE)
- else
- debug("%s: devstat = 0x%x bootmedia = 0x%x bootmode = %d\n",
- return bootmedia;
2.25.1
On October 31, 2024 thus sayeth Andrew Davis:
I was thinking the same thing. This will be helpful for all of the SoCs. The boodmode functions are very common however we'll most likely need to expand it to handle modes a specific SoC doesn't support.
~Bryan
Andrew Davis
Bryan Brattlof
Garrett Giordano
