[PATCH] efi_loader : Suppress error print message
Currently, on certain Xilinx platforms, an issue has been identified, manifesting as follows:
Starting kernel ...
efi_free_pool: illegal free 0x0000000077830040 efi_free_pool: illegal free 0x000000007782d040 efi_free_pool: illegal free 0x000000007782c040
The issue arises when the ramdisk image is relocated, placing it within the previously allocated EFI memory region( as EFI is established quite early in U-Boot). Consequently, when attempting to release memory in the EFI memory region during the handover process to the kernel,we encounter memory violations.
Highlighting that EFI remains active primarily during the booting of an EFI application, and the lmb persists while configuring images for the boot process. Since we aren't utilizing the EFI memory region during the boot process, there is no adverse impact even in the event of a violation.
Currently, there is an ongoing discussion regarding the handling strategies of three memory allocators: malloc, lmb, and EFI. This discussion is documented in the email chain titled "Proposal: U-Boot memory management."
Therefore, it is advisable to suppress the print message during the boot process for now.
Signed-off-by: Tejas Bhumkar tejas.arvind.bhumkar@amd.com --- lib/efi_loader/efi_memory.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/lib/efi_loader/efi_memory.c b/lib/efi_loader/efi_memory.c index edfad2d95a..821fe7616e 100644 --- a/lib/efi_loader/efi_memory.c +++ b/lib/efi_loader/efi_memory.c @@ -713,7 +713,7 @@ efi_status_t efi_free_pool(void *buffer) /* Check that this memory was allocated by efi_allocate_pool() */ if (((uintptr_t)alloc & EFI_PAGE_MASK) || alloc->checksum != checksum(alloc)) { - printf("%s: illegal free 0x%p\n", __func__, buffer); + debug("%s: illegal free 0x%p\n", __func__, buffer); return EFI_INVALID_PARAMETER; } /* Avoid double free */
Hi Tejas,
On Mon, 22 Jan 2024 at 21:12, Tejas Bhumkar tejas.arvind.bhumkar@amd.com wrote:
Starting kernel ...
I don't mind suppressing the print for some time, but out of curiosity, how is the ramdisk relocated? LMB should be aware of the EFI regions by then, so I assume the relocation code doesn't check those?
Thanks /Ilias
-- 2.27.0
On 1/23/24 09:33, Ilias Apalodimas wrote:
Hi Tejas,
Hello Tejas,
thank you for bringing forward this issue.
Which defconfig are you relating to?
Starting kernel ...
Which version of U-Boot are you on? Commit 06d514d77c37 ("lmb: consider EFI memory map") was meant to avoid such a situation.
The indicated situation is serious. If the EFI sub-system is using the same memory area as the ramdisk, this may lead to corruption of the ramdisk. Suppressing the messages is by no means adequate to solve the problem.
Best regards
Heinrich
Thanks /Ilias
-- 2.27.0
[AMD Official Use Only - General]
Hi Ilias & Heinrich,
-----Original Message----- From: Heinrich Schuchardt xypron.glpk@gmx.de Sent: Tuesday, January 23, 2024 3:30 PM To: Ilias Apalodimas ilias.apalodimas@linaro.org; Bhumkar, Tejas Arvind tejas.arvind.bhumkar@amd.com Cc: u-boot@lists.denx.de; xypron.glpk@gmx.de; trini@konsulko.com; sjg@chromium.org; Simek, Michal michal.simek@amd.com; Abbarapu, Venkatesh venkatesh.abbarapu@amd.com; git@xilinx.com Subject: Re: [PATCH] efi_loader : Suppress error print message
Caution: This message originated from an External Source. Use proper caution when opening attachments, clicking links, or responding.
Hi Tejas,
Hello Tejas,
[Tejas]: Checking with xilinx_zynqmp_virt_defconfig
Starting kernel ...
[Tejas] : I'm verifying against the latest changes in the master branch. The introduction of commit 06d514d77c37 ("lmb: consider EFI memory map") has resolved the occurrence of the "efi_free_pool: illegal free" error. but, it leads to a new error, as detailed in the following patch: https://lore.kernel.org/all/20230212150706.2967007-1-sjoerd@collabora.com/
[Tejas] : I observe that the relocation of the RAM disk is taking place in the line below. https://github.com/u-boot/u-boot/blob/master/lib/lmb.c#L480-L491 Yes, the relocated code specifically examines the LMB region and does not consider the EFI region.
[Tejas] : The challenge arises when relocating the ramdisk image, inserting it into the previously assigned EFI memory region, established early in U-Boot. Consequently, when attempting to release memory in the EFI region during the handover process to the kernel in the efi_free_pool function, we first verify if the memory was allocated by efi_allocate_pool(). The issue originates from a checksum mismatch because, during the ramdisk relocation, we overwrite memory allocated by EFI. This leads to the appearance of the error message: efi_free_pool: illegal free 0x0000000077830040. Crucially, there is no corruption of the ramdisk seen since we do not actually releasing memory due to the checksum mismatch. In our testing, this issue was observed only when the ramdisk size exceeded approximately 24 MB.
Best regards
Heinrich
Thanks /Ilias
-- 2.27.0
Hi Tejas,
Hello Tejas,
Starting kernel ...
Could you, please, try to reproduce your issues with origin/master as of today and provide the full boot log. Please, also provide the output of the bdinfo and the printenv command as well as the sizes of the kernel and the RAM disk.
Best regards
Heinrich
Best regards
Heinrich
Thanks /Ilias
-- 2.27.0
Hi Heinrich,
-----Original Message----- From: Heinrich Schuchardt xypron.glpk@gmx.de Sent: Wednesday, January 24, 2024 2:09 AM To: Bhumkar, Tejas Arvind tejas.arvind.bhumkar@amd.com Cc: u-boot@lists.denx.de; trini@konsulko.com; sjg@chromium.org; Simek, Michal michal.simek@amd.com; Abbarapu, Venkatesh venkatesh.abbarapu@amd.com; git@xilinx.com; Ilias Apalodimas ilias.apalodimas@linaro.org Subject: Re: [PATCH] efi_loader : Suppress error print message
Hi Tejas,
Hello Tejas,
Starting kernel ...
[Tejas] : I'm verifying against the latest changes in the master branch. The introduction of commit 06d514d77c37 ("lmb: consider EFI memory map") has resolved the occurrence of the "efi_free_pool: illegal free" error. but, it leads to a new error, as detailed in the following patch: https://lore.kernel.org/all/20230212150706.2967007-1-sjoerd@collabora. com/
[Tejas]: I've provided two logs: one obtained from the latest u-boot origin/master, resulting in the "ERROR: reserving fdt memory region failed" error, and the other from reverting commit 06d514d77c37 ("lmb: consider EFI memory map"), which leads to the "efi_free_pool: illegal free" error.
Thank You, Tejas.
Best regards
Heinrich
below.
problem.
0x0000000077830040.
Best regards
Heinrich
Thanks /Ilias
-- 2.27.0
Hi Heinrich,
Hi Tejas,
Hello Tejas,
Starting kernel ...
Thank You, Tejas.
Where can I find these logs?
Best regards
Heinrich
Best regards
Heinrich
below.
problem.
0x0000000077830040.
Best regards
Heinrich
Thanks /Ilias
-- 2.27.0
Hi Heinrich,
Hi Tejas,
On Mon, 22 Jan 2024 at 21:12, Tejas Bhumkar tejas.arvind.bhumkar@amd.com wrote: > > Currently, on certain Xilinx platforms, an issue has been > identified, manifesting as follows:
Hello Tejas,
> > Starting kernel ... > > efi_free_pool: illegal free 0x0000000077830040 > efi_free_pool: illegal free 0x000000007782d040 > efi_free_pool: illegal free 0x000000007782c040 > > The issue arises when the ramdisk image is relocated, placing it > within the previously allocated EFI memory region( as EFI is > established quite early in U-Boot).
Thank You, Tejas.
They were attached but you can see them for example here. https://lore.kernel.org/all/BL3PR12MB645027991850D2C0887FA80DD87F2@BL3PR12MB...
Thanks, Michal
participants (5)
Ilias Apalodimas
Michal Simek
Tejas Bhumkar
