[U-Boot] hush while confusion
thanks to everyone I have a working bootcmd which stops if the mmc card is extracted.
what I'd like to do is put it in a while loop - this is an embedded system and it has nothing better to do than to try again.
but if I set up
bootcmd=while [ .... ]; do ; mmcinit && ext2load mmc 0:1 0x10400000 /boot/uImage && bootm 0x10400000 ; done
no matter what I have put in or around the [..] area, it barfs.
Could anyone show me a working example of a hush while loop please? Or tell me what I'm doing wrong :-)
David Collier
www.dexdyne.com
Dear "David Collier",
In message <memo.20091022093854.2092B@postmaster+dexdyne.com.cix.co.uk> you wrote:
but if I set up
Did you understand why it barfs? The '[' is actually a command name, which usually is a synonym for the 'test' command. U-Boot does not provide such a coimmand, and the hush shell does not provide it as shell builtin either, so this _must_ fail.
I am surprised that you did not find this out yourself - U-Boot should issue a pretty clear error message, something like
Unknown command '[' - try 'help'
Here is a (tested and working) example:
=> mw 200000 0 => while itest *200000 == 0 ; do > tftp 200000 tqm5200/uImage > echo === done ==== > done Using FEC ETHERNET device TFTP from server 192.168.1.1; our IP address is 192.168.160.4 Filename 'tqm5200/uImage'. Load address: 0x200000 Loading: ################################################################# ############################################################ done Bytes transferred = 1830503 (1bee67 hex) === done ==== =>
OK I have changed it to
while 1==1 ; do ; mmcinit && ext2load mmc 0:1 0x10400000 /boot/uImage && bootm 0x10400000 ; done
and if I do run bootcmd it simply says "unknown command 1==1"
so I'm still lost....
I know I have hush installed, cosz if I do your multi-line-version I get the prompt.
All I saw about hush was "bourne-compatible", and "provides while...do..done" scripting.
I failed to find a proper manual... probably for lack of effort, but I've just googled again and nothing springs up..
Could you possibly point me at any hush documentation ?
Many thanks
David
In article 20091022113139.DB6961A00B@gemini.denx.de, wd@denx.de (Wolfgang Denk) wrote:
*From:* Wolfgang Denk wd@denx.de *To:* from_denx_uboot@dexdyne.com *CC:* u-boot@lists.denx.de *Date:* Thu, 22 Oct 2009 13:31:39 +0200
but if I set up
tftp 200000 tqm5200/uImage echo === done ==== done
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de "Where shall I begin, please your Majesty?" he asked. "Begin at the beginning," the King said, gravely, "and go on till you come to the end: then stop." - Alice's Adventures in Wonderland, Lewis Carroll
Collier
www.dexdyne.com
-----Original Message----- From: u-boot-bounces@lists.denx.de [mailto:u-boot- bounces@lists.denx.de] On Behalf Of David Collier Sent: den 22 oktober 2009 15:22 To: u-boot@lists.denx.de Subject: Re: [U-Boot] hush while confusion
Replace the "1==1" with ":" and skip the ";" after "do"
/Orjan
Dear =?iso-8859-1?Q?=D6rjan_Friberg?=,
In message A646FE253FDF3D4F9742732015311CD44F7E10@fg-server.flatfrog.local you wrote:
I recommend to try things out before posting:
=> while : ; do echo foo ; done Unknown command ':' - try 'help' =>
U-Boot does not know (yet) about the ':' command.
-----Original Message----- From: Wolfgang Denk [mailto:wd@denx.de] Sent: den 22 oktober 2009 20:07 To: Örjan Friberg Cc: from_denx_uboot@dexdyne.com; u-boot@lists.denx.de Subject: Re: [U-Boot] hush while confusion
In message <A646FE253FDF3D4F9742732015311CD44F7E10@fg- server.flatfrog.local> you wrote:
Apologies, should have known better. I meant to say "try replacing..." but didn't.
/Orjan
sorry - my fault - I failed to grasp the meaning of itest
This now works
while itest 1 == 1 ; do ; mmcinit && ext2load mmc 0:1 0x10400000 /boot/uImage && bootm 0x10400000 ; done
I could do with a literal "true" - I tried 'true' but that wasn't right - is there a suitable constant value?
I'd still love to find some teaching stuff on this - I can't keep bothering important people like you :-)
David
In article <memo.20091022142208.2092E@postmaster+dexdyne.com.cix.co.uk>, from_denx_uboot@dexdyne.com (David Collier) wrote:
*From:* "David Collier" from_denx_uboot@dexdyne.com *To:* u-boot@lists.denx.de *Date:* Thu, 22 Oct 2009 14:22 +0100 (BST)
Many thanks
David
but if I set up
Collier
www.dexdyne.com _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Collier
www.dexdyne.com
In message <memo.20091022142824.2092F@postmaster+dexdyne.com.cix.co.uk> you wrote:
This now works
Not yet - a patch to add "true" and "false" commands was submitted a week ago and will make it into the next release - see http://thread.gmane.org/gmane.comp.boot-loaders.u-boot/69887/focus=69886
Try: "man sh" :-)
Not yet - a patch to add "true" and "false" commands was submitted a week ago and will make it into the next release - see http://thread.gmane.org/gmane.comp.boot-loaders.u-boot/69887/focus=6 9886
excellent - I'll keep the clumsy-but-working version then.
Try: "man sh" :-)
OK... TVM
I've worked with bash, and naively assumed that that syntax was standard.
David
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de News is what a chap who doesn't care much about anything wants to read. And it's only news until he's read it. After that it's dead. - Evelyn Waugh _Scoop_ (1938) bk. 1, ch. 5
David Collier
www.dexdyne.com
In message <memo.20091023095756.2092H@postmaster+dexdyne.com.cix.co.uk> you wrote:
Try: "man sh" :-)
OK... TVM
Bash is bash and not standard. And hush is hush and not standard either. But all things you tried so far are covered by bash, hush, and the POSIX standard ;-)
In message <memo.20091022142208.2092E@postmaster+dexdyne.com.cix.co.uk> you wrote:
Well, this is not valid shell syntax. Bash will reject this, too:
bash: 1==1: command not found
[after correcting the other syntax errors, or course(
So just use standard POSIX scripting, and/or try the syntax in a real shell.
I'm afraid there ain't any. But - what for? It's just a shell ;-)
David Collier
Örjan Friberg
