[PATCH 1/1] Squashed 'dts/upstream/' changes from aaba2d45dc2a..b35b9bd1d4ee
b35b9bd1d4ee Merge tag 'v6.8-dts-raw' 1f50937554b4 Merge tag 'sound-6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound 576ba37bcbf9 Merge tag 'net-6.8-rc8' of git://git.kernel.org/pub/scm/linux/kernel/git/netdev/net c83dc02bae3e Merge tag 'qcom-arm64-fixes-for-6.8-2' of https://git.kernel.org/pub/scm/linux/kernel/git/qcom/linux into arm/fixes fb254675a395 ASoC: dt-bindings: nvidia: Fix 'lge' vendor prefix c748b8a7dbe8 Merge tag 'tegra-for-6.8-arm64-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/tegra/linux into arm/fixes a2e893adde74 Merge tag 'imx-fixes-6.8-2' of git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux into arm/fixes abb0f1b369e4 Merge tag 'qcom-arm64-fixes-for-6.8' of https://git.kernel.org/pub/scm/linux/kernel/git/qcom/linux into arm/fixes f143aa9a89ec Revert "arm64: dts: qcom: msm8996: Hook up MPM" 9a5690b7be49 arm64: dts: qcom: sc8280xp-x13s: limit pcie4 link speed ca6dcb63bd34 arm64: dts: qcom: sc8280xp-crd: limit pcie4 link speed 8532bb680bd0 dt-bindings: net: renesas,ethertsn: Document default for delays 42569705a4a0 Merge tag 'v6.8-rc6-dts-raw' 06c62487a0b4 arm64: dts: imx8mp: Fix LDB clocks property 7c93039778e4 arm64: dts: imx8mp: Fix TC9595 reset GPIO on DH i.MX8M Plus DHCOM SoM 7f9a36c5ce39 ARM: dts: imx7: remove DSI port endpoints 87ea8526eaf3 Merge tag 'loongarch-fixes-6.8-3' of git://git.kernel.org/pub/scm/linux/kernel/git/chenhuacai/linux-loongson d4a4b892cd33 Merge tag 'arm-fixes-6.8-2' of git://git.kernel.org/pub/scm/linux/kernel/git/soc/soc 4faf103c7468 Merge tag 'renesas-fixes-for-v6.8-tag1' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/renesas-devel into arm/fixes c1858748b935 Merge tag 'riscv-dt-fixes-for-v6.8-rc6' of https://git.kernel.org/pub/scm/linux/kernel/git/conor/linux into arm/fixes f1bb487d660f LoongArch: dts: Minor whitespace cleanup b60485a78d66 Merge tag 'clk-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/clk/linux d641a222a5d4 arm64: tegra: Fix Tegra234 MGBE power-domains 31aeabc2669e ARM: dts: renesas: rcar-gen2: Add missing #interrupt-cells to DA9063 nodes 8c5d69d4f1e9 arm64: dts: qcom: Fix interrupt-map cell sizes 43b35c5b7347 arm: dts: Fix dtc interrupt_map warnings f00ce91341b9 arm64: dts: Fix dtc interrupt_provider warnings c21ad68d3254 arm: dts: Fix dtc interrupt_provider warnings 20a9f605f025 Merge tag 'v6.8-rockchip-dtsfixes1' of git://git.kernel.org/pub/scm/linux/kernel/git/mmind/linux-rockchip into arm/fixes 1d9be1dcae7c Merge tag 'imx-fixes-6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux into arm/fixes c27426925b7b Merge tag 'v6.8-rc5-dts-raw' 582c3e28f603 Merge tag 'sound-6.8-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound 81da29f3007e arm64: tegra: Set the correct PHY mode for MGBE 30e4bc5d76ff Merge tag 'devicetree-fixes-for-6.8-1' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux f0c34a9f448e riscv: dts: sifive: add missing #interrupt-cells to pmic db36be2a8839 arm64: dts: rockchip: Correct Indiedroid Nova GPIO Names ec7d411e57d6 arm64: dts: rockchip: Drop interrupts property from rk3328 pwm-rockchip node 105b1e4e5e28 arm64: dts: rockchip: set num-cs property for spi on px30 a05f0ca9a008 arm64: dts: rockchip: minor rk3588 whitespace cleanup 41d6b3786aa9 riscv: dts: starfive: replace underscores in node names 910c8965eb0c dt-bindings: ufs: samsung,exynos-ufs: Add size constraints on "samsung,sysreg" d78e8a541b0a net: marvell,prestera: Fix example PCI bus addressing b40e56bea854 ASoC: dt-bindings: google,sc7280-herobrine: Drop bouncing @codeaurora 48b3246a26fe Revert "arm64: dts: imx8mn-var-som-symphony: Describe the USB-C connector" a1c414f8f89a Revert "arm64: dts: imx8mp-dhcom-pdk3: Describe the USB-C connector" 768ad06f1efa arm64: dts: tqma8mpql: fix audio codec iov-supply 77040f90f388 Merge tag 'v6.8-rc3-dts-raw' 65143ffc8608 arm64: dts: rockchip: drop unneeded status from rk3588-jaguar gpio-leds 39497955d1c0 ARM: dts: rockchip: Drop interrupts property from pwm-rockchip nodes 610e244453be arm64: dts: rockchip: Fix the num-lanes of pcie3x4 on Cool Pi CM5 EVB d6e600aea013 arm64: dts: rockchip: rename vcc5v0_usb30_host regulator for Cool Pi CM5 EVB 6be17990ec10 arm64: dts: rockchip: aliase sdmmc as mmc1 for Cool Pi CM5 EVB 77765eecb670 arm64: dts: rockchip: aliase sdmmc as mmc1 for Cool Pi 4B 7bca62b5ae66 arm64: dts: qcom: sm6115: Fix missing interconnect-names b2bc58ba4504 arm64: dts: imx8mp: Disable UART4 by default on Data Modul i.MX8M Plus eDM SBC 9474eb5c3d86 ALSA: Various fixes for Cirrus Logic CS35L56 support 1e8df48d4da1 dt-bindings: tpm: Drop type from "resets" 4d5c46ab184f dt-bindings: display: nxp,tda998x: Fix 'audio-ports' constraints fede8bd8306c dt-bindings: xilinx: replace Piyush Mehta maintainership eb691d1ece78 Merge tag 'v6.8-rc2-dts-raw' 5b093a56e797 ASoC: sun4i-spdif: Add Allwinner H616 compatible f2ce9dca7322 ASoC: sun4i-spdif: Fix requirements for H6 fd23c7505f20 arm64: dts: qcom: sm8650-mtp: add gpio74 as reserved gpio cfbd9243ac13 arm64: dts: qcom: sm8650-qrd: add gpio74 as reserved gpio 101ce3470b0e Merge tag 'drm-fixes-2024-01-27' of git://anongit.freedesktop.org/drm/drm 71ca3bf1c96e Merge tag 'arm-fixes-6.8-1' of git://git.kernel.org/pub/scm/linux/kernel/git/soc/soc 74c898882ebb riscv: dts: sophgo: separate sg2042 mtime and mtimecmp to fit aclint format 28b77b56d972 arm64: dts: rockchip: mark system power controller on rk3588-evb1 986a9f1778ef Merge tag 'samsung-fixes-6.8' of https://git.kernel.org/pub/scm/linux/kernel/git/krzk/linux into arm/fixes 6cf0227916ec arm64: dts: Fix TPM schema violations 60245a9006e9 ARM: dts: Fix TPM schema violations 92924d8db61a Merge tag 'exynos-drm-fixes-for-v6.8-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/daeinki/drm-exynos into drm-fixes 3b240d0d94a9 dt-bindings: media: Remove K3 Family Prefix from Compatible 186b38b97035 ARM: dts: exynos4212-tab3: add samsung,invert-vclk flag to fimd c4f0c99dffb8 arm64: dts: exynos: gs101: comply with the new cmu_misc clock names 429796fee0f1 dt-bindings: clock: gs101: rename cmu_misc clock-names 80d76b25d32f Merge tag 'v6.8-rc1-dts-raw' 339d8d1caab5 Merge tag 'timers-core-2024-01-21' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip df1980733ce9 Merge tag 'dmaengine-fix-6.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/vkoul/dmaengine 8c23badf69c3 Merge tag 'riscv-for-linus-6.8-mw4' of git://git.kernel.org/pub/scm/linux/kernel/git/riscv/linux d5a95e32a555 Merge tag 'loongarch-6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/chenhuacai/linux-loongson 815e38060bf4 Merge tag 'sound-fix-6.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound f07a1b362766 Merge tag 'for-v6.8-v2' of git://git.kernel.org/pub/scm/linux/kernel/git/sre/linux-power-supply 9411a3099e9c Merge tag 'i2c-for-6.8-rc1-rebased' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux fcb7108dc362 Merge tag 'rtc-6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/abelloni/linux 8e06ce5908ff Merge tag 'input-for-v6.8-rc0' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input 7b18579c0bef Merge tag 'phy-for-6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/phy/linux-phy dd4871a00012 Merge tag 'gpio-fixes-for-v6.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/brgl/linux 8dfd2acd2c0c Merge tag 'backlight-next-6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/backlight 736ecd5cf03c Merge tag 'iommu-updates-v6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu 7d29a06cb311 dt-bindings: i2c: document st,stm32mp25-i2c compatible 365a95704e98 dt-bindings: at24: add ROHM BR24G04 05d2a9834fd6 Merge tag 'usb-6.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb 70a7bee43907 Merge tag 'tty-6.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty 6a04bf7a4f07 Merge tag 'char-misc-6.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc e0c35697cd80 Merge tag 'pci-v6.8-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/pci/pci cf29a14b0a23 Merge tag 'pinctrl-v6.8-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl 902219ef9ed0 Merge tag 'mailbox-v6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/jassibrar/mailbox c437f65015a8 Merge tag 'leds-next-6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/leds d0902d05b4a0 Merge tag 'mfd-next-6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd 8be1d4636d32 Merge tag 'rproc-v6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/remoteproc/linux 6eaaddf12639 Merge tag 'riscv-for-linus-6.8-mw1' of git://git.kernel.org/pub/scm/linux/kernel/git/riscv/linux 2cb012b6fe68 LoongArch: dts: DeviceTree for Loongson-2K2000 6ab0a6f08b83 LoongArch: dts: DeviceTree for Loongson-2K1000 491426707de1 LoongArch: dts: DeviceTree for Loongson-2K0500 c007f27059d1 dt-bindings: interrupt-controller: loongson,liointc: Fix dtbs_check warning for interrupt-names d9a3ae336ecb dt-bindings: interrupt-controller: loongson,liointc: Fix dtbs_check warning for reg-names 4ee19a9d7583 dt-bindings: loongarch: Add Loongson SoC boards compatibles 3e99ee3f7c53 dt-bindings: loongarch: Add CPU bindings for LoongArch e8bc7c9c625e dt-bindings: don't anchor DT_SCHEMA_FILES to bindings directory f5918b47370e dt-bindings: rtc: max31335: add max31335 bindings 7e34d7b53615 rtc: rv8803: add wakeup-source support 81d186f05921 Merge branch 'pci/dt-bindings' 8bd798490681 Merge branch 'pci/controller/rcar' e166e5aad3b0 Merge branch 'pci/controller/cadence' 9de355a75fde dt-bindings: gpio: xilinx: Fix node address in gpio 28bf1e4e9775 dt-bindings: mailbox: qcom-ipcc: document the X1E80100 Inter-Processor Communication Controller f6b31bdd3c60 dt-bindings: mailbox: add Versal IPI bindings c3301d070937 dt-bindings: mailbox: zynqmp: extend required list 6bf977408719 dt-bindings: mailbox: qcom,apcs-kpss-global: use fallbacks b9ea63718a7e dt-bindings: mailbox: qcom,apcs-kpss-global: drop duplicated qcom,ipq8074-apcs-apps-global e485b251a3a4 Merge tag 'devicetree-for-6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux 60edd8755b1b Merge tag 'pwm/for-6.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/thierry.reding/linux-pwm f946a0610062 Merge tag 'hid-for-linus-2024010801' of git://git.kernel.org/pub/scm/linux/kernel/git/hid/hid 5a9222178c60 Merge tag 'media/v6.8-2' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media 0c57fa00ac11 Merge tag 'mmc-v6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/ulfh/mmc 120152dd192c Merge tag 'pmdomain-v6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/ulfh/linux-pm f25acec1f182 Merge tag 'gnss-6.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/johan/gnss 040b6611cd72 Merge tag 'clk-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/clk/linux 432f2b929aa4 Merge tag 'gpio-updates-for-v6.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/brgl/linux 5df1a59e6086 Merge tag 'linux-watchdog-6.8-rc1' of git://www.linux-watchdog.org/linux-watchdog 1d81fba29be6 Merge tag 'hwmon-for-v6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging dd7110d3d5d1 Merge tag 'sound-6.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound c916bd7a1d38 Merge tag 'drm-next-2024-01-10' of git://anongit.freedesktop.org/drm/drm 32704b03c7ec Merge tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi c0d1d21fe5ff dt-bindings: fpga: altera: Convert bridge bindings to yaml 86986ec77fc7 dt-bindings: fpga: Convert bridge binding to yaml 149beabce38e dt-bindings: vendor-prefixes: Add smi da831df01407 Merge tag 'soc-drivers-6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/soc/soc d0949aef9e29 Merge tag 'soc-dt-6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/soc/soc c5ee04d9a430 Merge tag 'net-next-6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/netdev/net-next 17d4b2f2c7c6 dt-bindings: riscv: Document cbop-block-size 6361e08793d7 dt-bindings: riscv: permit numbers in "riscv,isa" 99f0fa81f51f dt-bindings: riscv: cpus: Clarify mmu-type interpretation 5744984c407c ARM: dts: usr8200: Fix phy registers fd6e692990ee dt-bindings: PCI: brcmstb: Add property "brcm,clkreq-mode" db07ea081cee dt-bindings: power: Clarify wording for wakeup-source property 9deb5d7e7649 Merge tag 'v6.8-p1' of git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6 f412e763e552 dt-bindings: mfd: sprd: Add support for UMS9620 b50b2489e1a2 dt-bindings: input: bindings for Adafruit Seesaw Gamepad 9fcf5401177c Merge patch series "riscv: hwprobe: add Zicond, Zacas and Ztso support" 6b479ffcb9ed dt-bindings: riscv: add Zacas ISA extension description 45e895d242d0 Merge remote-tracking branch 'palmer/fixes' into for-next 129abc9e5b89 Merge tag 'thermal-6.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm 72e795875f31 Merge tag 'mtd/for-6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/mtd/linux a0d6ec02f5dd Merge tag 'spi-v6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi 092d72f89f32 Merge tag 'regulator-v6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator f19bbcb501a1 Merge branch 'clk-rs9' into clk-next 6c5ff3361f38 Merge branches 'clk-zynq', 'clk-xilinx' and 'clk-stm' into clk-next 5348f28123c3 Merge branches 'clk-imx', 'clk-qcom', 'clk-amlogic' and 'clk-mediatek' into clk-next dde8a0d89600 Merge branches 'clk-versa', 'clk-silabs', 'clk-samsung', 'clk-starfive' and 'clk-sophgo' into clk-next 147299598f64 dt-bindings: ignore paths outside kernel for DT_SCHEMA_FILES 5e8ad2415574 dt-bindings: tpm: Document Microsoft fTPM bindings 4446def763e6 dt-bindings: tpm: Convert IBM vTPM bindings to DT schema d46251bba773 dt-bindings: tpm: Convert Google Cr50 bindings to DT schema 4c0c46fcf77f dt-bindings: tpm: Consolidate TCG TIS bindings fc825b2e9d71 dt-bindings: display: rockchip,inno-hdmi: Document RK3128 compatible 5d51cf126484 dt-bindings: arm: Add remote etm dt-binding 32c458bd3442 dt-bindings: mmc: sdhci-pxa: Fix 'regs' typo c9ab453dff7c media: dt-bindings: samsung,s5p-mfc: Fix iommu properties schemas 481554b6b752 dt-bindings: display: panel: Add synaptics r63353 panel controller e04e21bef16e dt-bindings: arm: merge qcom,idle-state with idle-state 452e35e6ff26 Merge tag 'irq-core-2024-01-08' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip d35742374b96 dt-bindings: display: samsung,exynos-mixer: Fix 'regs' typo ac8ffc6d0764 Merge tag 'arm64-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux daf5be0b133e Merge tag 'powerpc-6.8-1' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux b633610fad05 Revert "net: stmmac: Enable Per DMA Channel interrupt" fc2b6856183b dt-bindings: rtc: qcom-pm8xxx: fix inconsistent example 5c111c61a49a dt-bindings: net: snps,dwmac: per channel irq 94d319464237 ASoC: dt-bindings: move tas2563 from tas2562.yaml to tas2781.yaml 8fbbcaccc3ff Merge tag 'socfpga_dts_updates_for_v6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/dinguyen/linux into soc/dt 1161aaee27ae dt-bindings: mmc: add Marvell ac5 e9a747531a5d dt-bindings: mmc: brcm,sdhci-brcmstb: Add support for 74165b0 57b4e3b1199f Merge git://git.kernel.org/pub/scm/linux/kernel/git/netdev/net cab393f5e80d dt-bindings: serial: Describe ARM dcc interface 1d92607a561e dt-bindings: usb: dwc3: Limit num-hc-interrupters definition cee9797861a0 dt-bindings: usb: xhci: Add num-hc-interrupters definition 4823f8dd230f arm64: dts: mediatek: mt8195: Add 'rx-fifo-depth' for cherry 4a4f48930e20 dt-bindings: usb: mtk-xhci: add a property for Gen1 isoc-in transfer issue 4ddd871b77e8 arm64: dts: qcom: msm8996: Remove PNoC clock from MSS 5598c7c58459 arm64: dts: qcom: msm8996: Remove AGGRE2 clock from SLPI a06133f3b90d arm64: dts: qcom: msm8998: Remove AGGRE2 clock from SLPI 0e31729b965a arm64: dts: qcom: msm8939: Drop RPM bus clocks a9231f1fa44d arm64: dts: qcom: sdm630: Drop RPM bus clocks 7806d0946f48 arm64: dts: qcom: qcs404: Drop RPM bus clocks 6bbd4a339ffd arm64: dts: qcom: msm8996: Drop RPM bus clocks 6c5785d4dec0 arm64: dts: qcom: msm8916: Drop RPM bus clocks d99558e0d6ba dt-bindings: usb: qcom,dwc3: Fix SDM660 clock description 0e7834fa9ba2 dt-bindings: usb: dwc3: Clean up hs_phy_irq in binding f7405c1062e5 dt-bindings: connector: Add child nodes for multiple PD capabilities a2f2b957f7b0 arm64: dts: intel: minor whitespace cleanup around '=' a21ad91a14ac arm64: dts: socfpga: agilex: drop redundant status c64326a0161d arm64: dts: socfpga: agilex: add unit address to soc node 70eea150a8db arm64: dts: socfpga: agilex: move firmware out of soc node 056acfded5ce arm64: dts: socfpga: agilex: move FPGA region out of soc node 8e373ef160c7 arm64: dts: socfpga: agilex: align pin-controller name with bindings 56a65e118b36 arm64: dts: socfpga: stratix10_swvp: drop unsupported DW MSHC properties 5ea405da6608 arm64: dts: socfpga: stratix10_socdk: align NAND chip name with bindings 0bc2b8deec9a arm64: dts: socfpga: stratix10: add unit address to soc node 3932c6fc63c2 arm64: dts: socfpga: stratix10: move firmware out of soc node 174dfac57ae2 arm64: dts: socfpga: stratix10: move FPGA region out of soc node e63c11b1c86c arm64: dts: socfpga: stratix10: align pincfg nodes with bindings 5ad3116fb135 arm64: dts: socfpga: stratix10: add clock-names to DWC2 USB 9185b800f9c3 arm64: dts: socfpga: drop unsupported cdns,page-size and cdns,block-size b3832f4d101c ARM: dts: socfpga: align NAND controller name with bindings 7772fcc4eef4 ARM: dts: socfpga: drop unsupported cdns,page-size and cdns,block-size f466442c93ff dt-bindings: clock: mediatek: add clock controllers of MT7988 967ed08fdbd4 dt-bindings: reset: mediatek: add MT7988 ethwarp reset IDs 8bb435f3ea7d dt-bindings: clock: mediatek: add MT7988 clock IDs 8b8c659b2121 dt-bindings: clock: sophgo: Add clock controller of CV1800 series SoC b822e804fd2c dt-bindings: gpio: add NPCM sgpio driver bindings f4c19e862d2b dt-bindings: gpio: realtek: Add realtek,rtd-gpio 6690161ed7a9 Merge branches 'apple/dart', 'arm/rockchip', 'arm/smmu', 'virtio', 'x86/vt-d', 'x86/amd' and 'core' into next 7382fa53a648 dt-bindings: net: renesas,etheravb: Document RZ/G3S support 247b8886892f dt-bindings: hwmon: (lm75) Add AMS AS6200 temperature sensor fec847c57a81 dt-bindings: Add MP2856/MP2857 voltage regulator device 42c42ff6c177 dt-bindings: hwmon: gpio-fan: Convert txt bindings to yaml 6c13c9d07051 dt-bindings: mmc: sdhci-msm: document dedicated IPQ4019 and IPQ8074 1e934476b96c dt-bindings: mmc: synopsys-dw-mshc: add iommus for Intel SocFPGA 82a434279c9e dt-bindings: HID: i2c-hid: elan: Introduce Ilitek ili2901 5fa4567d6c4f Merge tag 'v6.8-rockchip-dts32-2' of git://git.kernel.org/pub/scm/linux/kernel/git/mmind/linux-rockchip into soc/dt a04786e0b7e0 Merge tag 'v6.8-rockchip-dts64-2' of git://git.kernel.org/pub/scm/linux/kernel/git/mmind/linux-rockchip into soc/dt 0bf9a2425459 Merge tag 'qcom-arm64-for-6.8-2' of https://git.kernel.org/pub/scm/linux/kernel/git/qcom/linux into soc/dt a3fde0732d5b Merge tag 'qcom-arm32-for-6.8-2' of https://git.kernel.org/pub/scm/linux/kernel/git/qcom/linux into soc/dt 62073621d812 Merge tag 'arm-soc/for-6.8/devicetree' of https://github.com/Broadcom/stblinux into soc/dt 4cfe8fd4e2b4 Merge tag 'sprd-dt-6.8-rc1' of https://github.com/lyrazhang/linux into soc/dt a355b8e8cbdd dt-bindings: thermal: qcom-spmi-adc-tm5/hc: Clean up examples 36a030b546d0 dt-bindings: thermal: qcom-spmi-adc-tm5/hc: Fix example node names ca1c0a8c8091 dt-bindings: thermal: sun8i: Add binding for D1/T113s THS controller 7123707b90de dt-bindings: thermal-zones: Document critical-action c29ec9b83fd7 dt-bindings: thermal: qcom-tsens: document the SM8650 Temperature Sensor 5a12787401b5 dt-bindings: thermal: loongson,ls2k-thermal: Fix binding check issues 0a6d923c5231 dt-bindings: thermal: convert Mediatek Thermal to the json-schema dc5dd3862b77 dt-bindings: input: iqs269a: Add bindings for OTP variants 5aa00301cee3 dt-bindings: input: iqs269a: Add bindings for slider gestures c4635c803af3 Merge tag 'iio-for-6.8b' of https://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into char-misc-next 571d91b8d8df arm64: dts: rockchip: Fix led pinctrl of lubancat 1 548cbdf62c21 arm64: dts: rockchip: correct gpio_pwrctrl1 typo on nanopc-t6 86c28823371d arm64: dts: rockchip: correct gpio_pwrctrl1 typo on rock-5b 275bc737b480 arm64: dts: rockchip: support poweroff on the rock-5b e4f7332bb7f8 arm64: dts: rockchip: Support poweroff on Orange Pi 5 d0c46aeba839 arm64: dts: rockchip: nanopc-t6 sdmmc beautification df73c00bc509 arm64: dts: sprd: Change UMS512 idle-state nodename to match bindings 12243eba2b74 arm64: dts: sprd: Add clock reference for pll2 on UMS512 af72bfcc73f3 arm64: dts: sprd: Removed unused clock references from etm nodes d8f5562e697b arm64: dts: sprd: Add support for Unisoc's UMS9620 bd8f67f82f65 dt-bindings: arm: Add compatible strings for Unisoc's UMS9620 9da3db96fae0 arm64: dts: sprd: fix the cpu node for UMS512 3ebc08960525 Merge tag 'v6.7-rc7' into gpio/for-next cb90fcbed71e dt-bindings: timer: Add StarFive JH8100 clint 6f2b19f4df72 dt-bindings: timer: thead,c900-aclint-mtimer: separate mtime and mtimecmp regs 4421b3e3124f dt-bindings: iio: Add AD7091R-8 51a0454cffd6 dt-bindings: power: supply: bq24190: Add BQ24296 compatible 4639caeeab2f dt-bindings: power: reset: xilinx: Rename node names in examples c873132667ed dt-bindings: power: reset: qcom-pon: fix inconsistent example 64cf7a912b11 arm64: dts: rockchip: Fix rk3588 USB power-domain clocks 815a2542ad42 arm64: dts: rockchip: configure eth pad driver strength for orangepi r1 plus lts 9df823a6207b arm64: dts: rockchip: Support poweroff on NanoPC-T6 78bd00069022 arm64: dts: rockchip: rk3308-rock-pi-s gpio-line-names cleanup 9d6e0741ae7c arm64: dts: rockchip: Add support for rk3588 based board Cool Pi CM5 EVB a64a2e009e21 dt-bindings: arm: rockchip: Add Cool Pi CM5 4397d62daec8 arm64: dts: rockchip: Add support for rk3588s based board Cool Pi 4B f1a9c321e26f dt-bindings: arm: rockchip: Add Cool Pi 4B 1e413c69529f dt-bindings: vendor-prefixes: Add Cool Pi a67ded35095e arm64: dts: rockchip: add gpio-line-names to rk3328-rock-pi-e e0ec5767b690 ARM: dts: rockchip: Remove rockchip,default-sample-phase from rk3036.dtsi 75e0afe6681c ARM: dts: rockchip: Add stdout-path for rk3036 kylin 5b38dc06a1e9 dt-bindings: watchdog: qcom,pm8916-wdt: add parent spmi node to example d2f78877f2ea dt-bindings: watchdog: nxp,pnx4008-wdt: convert txt to yaml af1fdc5cd02d dt-bindings: watchdog: qca,ar7130-wdt: convert txt to yaml 5c3d9631b9ac dt-bindings: watchdog: intel,keembay: reference common watchdog schema 6d86f883fd9c dt-bindings: watchdog: re-order entries to match coding convention e28051167c06 dt-bindings: touchscreen: neonode,zforce: Use standard properties 3119a224ac1c dt-bindings: touchscreen: convert neonode,zforce to json-schema 15bf36928144 Merge tag 'icc-6.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/djakov/icc into char-misc-next dd37eb39a550 dt-bindings: input: convert drv266x to json-schema 795f4eddfec7 Merge tag 'qcom-arm64-for-6.8' of https://git.kernel.org/pub/scm/linux/kernel/git/qcom/linux into soc/dt 991ab34b2120 Merge tag 'reset-for-v6.8' of git://git.pengutronix.de/pza/linux into soc/drivers 4e7b4659bc67 dt-bindings: mtd: partitions: u-boot: Fix typo 35dd951a7fd5 Merge tag 'riscv-cache-for-v6.8' of https://git.kernel.org/pub/scm/linux/kernel/git/conor/linux into soc/drivers 69b18d58cc6d Merge tag 'riscv-soc-drivers-for-v6.8' of https://git.kernel.org/pub/scm/linux/kernel/git/conor/linux into soc/drivers fc5aa9bf69fd Merge tag 'samsung-drivers-6.8' of https://git.kernel.org/pub/scm/linux/kernel/git/krzk/linux into soc/drivers 84c9739eb5b5 Merge tag 'qcom-drivers-for-6.8' of https://git.kernel.org/pub/scm/linux/kernel/git/qcom/linux into soc/drivers 0ef14d7a1f46 dt-bindings: crypto: qcom-qce: document the SC7280 crypto engine 2fd8394e6d9f dt-bindings: crypto: qcom-qce: constrain clocks for SM8150-compatible QCE 40fd9d4f3234 dt-bindings: crypto: qcom-qce: constrain clocks for IPQ9574 QCE 30960ac02d6e dt-bindings: rng: starfive: Add jh8100 compatible string e6272a79f69c Merge git://git.kernel.org/pub/scm/linux/kernel/git/netdev/net dcd8ac1c5dd8 dt-bindings: spi: stm32: add st,stm32mp25-spi compatible 87166d1d3f3f Merge tag 'riscv-dt-for-v6.8' of https://git.kernel.org/pub/scm/linux/kernel/git/conor/linux into soc/dt 69abc2365d38 dt-bindings: phy: qcom,sc8280xp-qmp-usb3-uni: Add X1E80100 USB PHY binding 822a13d2bf90 dt-bindings: phy: qcom,sc8280xp-qmp-usb43dp-phy: Document X1E80100 compatible 6722c7fe2a57 dt-bindings: phy: qcom: snps-eusb2: Document the X1E80100 compatible a38a399bccf1 dt-bindings: phy: mediatek: tphy: add a property for force-mode switch ca521e2ecf25 dt-bindings: phy: qcom,sc8280xp-qmp-usb43dp-phy: fix path to header aa156a9707ec Merge tag 'amlogic-arm64-dt-for-v6.8' of https://git.kernel.org/pub/scm/linux/kernel/git/amlogic/linux into soc/dt e6127e00f352 Merge tag 'mvebu-dt64-6.8-1' of git://git.kernel.org/pub/scm/linux/kernel/git/gclement/mvebu into soc/dt aad08c0a0671 Merge tag 'mvebu-dt-6.8-1' of git://git.kernel.org/pub/scm/linux/kernel/git/gclement/mvebu into soc/dt e4320c558711 Merge tag 'samsung-dt64-6.8-2' of https://git.kernel.org/pub/scm/linux/kernel/git/krzk/linux into soc/dt 077793e138f6 Merge tag 'qcom-arm32-for-6.8' of https://git.kernel.org/pub/scm/linux/kernel/git/qcom/linux into soc/dt 7ff5e1692425 Merge tag 'ti-k3-dt-for-v6.8' of https://git.kernel.org/pub/scm/linux/kernel/git/ti/linux into soc/dt f009c98b2a3f dt-bindings: iio: dac: add MCP4821 e46c2c536959 Merge tag 'ti-keystone-dt-for-v6.8' of https://git.kernel.org/pub/scm/linux/kernel/git/ti/linux into soc/dt edeab43af36b Merge tag 'zynqmp-dt-for-6.8' of https://github.com/Xilinx/linux-xlnx into soc/dt 4e78ad68f722 Merge tag 'imx-dt64-6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux into soc/dt f4ece4b3d883 Merge tag 'imx-dt-6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux into soc/dt 1a2b6b1db701 Merge tag 'imx-bindgins-6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux into soc/dt 71e20fbc3d5b Merge tag 'ux500-dts-soc-for-v6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-integrator into soc/dt 056c9efa37c5 Merge tag 'renesas-dts-for-v6.8-tag2' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/renesas-devel into soc/dt 339491d0999f Merge tag 'stm32-dt-for-v6.8-1' of git://git.kernel.org/pub/scm/linux/kernel/git/atorgue/stm32 into soc/dt 06086605676a dt-bindings: dma: fsl-edma: Add fsl-edma.h to prevent hardcoding in dts 640904451ab8 dt-bindings: dmaengine: Add Loongson LS2X APB DMA controller f88d59ec5d12 Merge tag 'sunxi-dt-for-6.8-1' of https://git.kernel.org/pub/scm/linux/kernel/git/sunxi/linux into soc/dt e833ff47f9b9 Merge tag 'at91-dt-6.8' of https://git.kernel.org/pub/scm/linux/kernel/git/at91/linux into soc/dt 9f821c027b01 Merge tag 'juno-update-6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/sudeep.holla/linux into soc/dt 4bab8a451f49 Merge tag 'v6.8-rockchip-dts32-1' of git://git.kernel.org/pub/scm/linux/kernel/git/mmind/linux-rockchip into soc/dt a4789dd06449 Merge tag 'v6.8-rockchip-dts64-1' of git://git.kernel.org/pub/scm/linux/kernel/git/mmind/linux-rockchip into soc/dt 5045526f0b7c Merge tag 'mtk-dts64-for-v6.8' of https://git.kernel.org/pub/scm/linux/kernel/git/mediatek/linux into soc/dt a7603f8260b8 Merge tag 'samsung-dt-6.8' of https://git.kernel.org/pub/scm/linux/kernel/git/krzk/linux into soc/dt 16a1d6e0b098 Merge tag 'samsung-dt64-6.8' of https://git.kernel.org/pub/scm/linux/kernel/git/krzk/linux into soc/dt 0f1f66f39700 ARM: dts: ste: minor whitespace cleanup around '=' 22532c5d3f4a Merge tag 'omap-for-v6.8/dt-signed' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into soc/dt 5288e13a2ad4 Merge tag 'hisi-arm64-dt-for-6.8' of https://github.com/hisilicon/linux-hisi into soc/dt f44f238cabce Merge tag 'w1-drv-6.8' of https://git.kernel.org/pub/scm/linux/kernel/git/krzk/linux-w1 into char-misc-next 61f41fa45eaf Merge tag 'iio-for-6.8a' of https://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into char-misc-next 07d575b06ff9 dt-bindings: pwm: ti,pwm-omap-dmtimer: Update binding for yaml fc02de1f5dc0 dt-bindings: riscv: cpus: Add AMD MicroBlaze V compatible 780449a81d3c dt-bindings: pwm: remove Xinlei's mail f96dd7edb887 arm64: dts: qcom: sc8180x: Fix up PCIe nodes b1ecf20e17e0 arm64: dts: qcom: sc8180x: Mark PCIe hosts cache-coherent eeed8f113289 dt-bindings: pinctrl: xilinx: Rename *gpio to *gpio-grp 2ef9211e8711 dt-bindings: pinctrl: qcom: drop common properties and allow wakeup-parent 188c161805d3 dt-bindings: pinctrl: qcom: drop common properties 7834682c0d2c dt-bindings: pinctrl: qcom,ipq5018-tlmm: use common TLMM bindings c31ea3c9600f dt-bindings: pinctrl: qcom,x1e80100-tlmm: restrict number of interrupts 6cec6f6f090c dt-bindings: pinctrl: qcom,sm8650-tlmm: restrict number of interrupts ef7b1c134921 dt-bindings: pinctrl: qcom,sm8550-tlmm: restrict number of interrupts a3abecdd0e2e dt-bindings: pinctrl: qcom,sdx75-tlmm: restrict number of interrupts 2b1d1c0dd621 dt-bindings: pinctrl: qcom,sa8775p-tlmm: restrict number of interrupts 36f8bb953634 dt-bindings: pinctrl: qcom,qdu1000-tlmm: restrict number of interrupts 670ced18d87f dt-bindings: pinctrl: qcom: create common LPASS LPI schema 5ca197c58799 dt-bindings: pinctrl: qcom: Add SM4450 pinctrl 8d27a131f7ad dt-bindings: pinctrl: qcom,pmic-mpp: clean up example 6674c2217ce1 Merge tag 'mediatek-drm-next-6.8' of https://git.kernel.org/pub/scm/linux/kernel/git/chunkuang.hu/linux into drm-next d7dde4a72dfa Merge tag 'drm-msm-next-2023-12-15' of https://gitlab.freedesktop.org/drm/msm into drm-next 64ddcb330a18 arm64: dts: qcom: x1e80100-qcp: Fix supplies for some LDOs in PM8550 206ab99c38ce arm64: dts: qcom: sm8550: Update idle state time requirements 319f395fbc2a arm64: dts: qcom: sm8550: Separate out X3 idle state af2f75b56294 ARM: dts: qcom: sdx55: Fix the base address of PCIe PHY 4a72661b117b arm64: dts: qcom: ipq6018: fix clock rates for GCC_USB0_MOCK_UTMI_CLK 5b72e989a37a arm64: dts: qcom: x1e80100: align mem timer size cells with bindings b17d7383c10f arm64: dts: qcom: sc7280: Mark SDHCI hosts as cache-coherent 3840ead2163a ARM: dts: qcom: sdx55: fix USB SS wakeup 9e773fad2487 ARM: dts: qcom: sdx55: fix USB DP/DM HS PHY interrupts d0728def7588 ARM: dts: qcom: sdx55: fix pdc '#interrupt-cells' 0ee9dac79d46 ASoC: qcom: add sound card support for SM8650 345b970f1857 add es8326 dt-bindings, commonize headset codec 85a45459eeed GPIO inclusion fixes to misc sound drivers 616e88e1109d arm64: dts: qcom: sc8180x: fix USB SS wakeup f3d1b2acf659 arm64: dts: qcom: sdm670: fix USB SS wakeup 987f42804a25 arm64: dts: qcom: sdm670: fix USB DP/DM HS PHY interrupts 2e58236aa851 ASoC: dt-bindings: qcom,lpass-va-macro: remove spurious contains in if statement bded77d8cc7b dt-bindings: regulator: qcom,usb-vbus-regulator: clean up example e1481a467961 powerpc/fsl: Fix fsl,tmu-calibration to match the schema 26e2fad496d4 arm64: dts: amlogic: fix format for s4 uart node 8a5115be3855 arm64: dts: amlogic: drop redundant status=okay 799049c22bf2 arm64: dts: amlogic: enable some nodes for board AQ222 3fea93dcdd73 arm64: dts: amlogic: add some device nodes for S4 44721ac7f4da Merge tag 'drm-misc-next-2023-12-14' of git://anongit.freedesktop.org/drm/drm-misc into drm-next d623bb97a280 Merge tag 'samsung-pinctrl-6.8' of https://git.kernel.org/pub/scm/linux/kernel/git/pinctrl/samsung into devel 81d84dd62616 ASoC: dt-bindings: qcom,lpass-rx-macro: Add X1E80100 LPASS WSA 4f673348bd77 ASoC: dt-bindings: qcom,lpass-rx-macro: Add X1E80100 LPASS VA d5b1bc404268 ASoC: dt-bindings: qcom,lpass-rx-macro: Add X1E80100 LPASS TX 40420db77069 ASoC: dt-bindings: qcom,lpass-rx-macro: Add X1E80100 LPASS RX 605001444f21 ASoC: dt-bindings: qcom,sm8250: Add X1E80100 sound card 4e179f2c3905 ASoC: dt-bindings: mt8188-mt6359: add es8326 support 0c819517fcb2 ASoC: dt-bindings: qcom,sm8250: document SM8650 sound card 0292b51ac8c4 ASoC: tegra: tegra20_ac97: Convert to use GPIO descriptors 4c6bc6503e5e Merge tag 'device_is_big_endian-6.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core into gpio/for-next 31d8096d43a1 dt-bindings: gpio: dwapb: allow gpio-ranges 873d4c02bbfa dt-bindings: clock: google,gs101: rename CMU_TOP gate defines bfc73914844a dt-bindings: clock: si5351: add PLL reset mode property af0493badd9d dt-bindings: clock: si5351: convert to yaml d1a5fb288be1 dt-bindings: stm32: add clocks and reset binding for stm32mp25 platform ee353e29bfb4 dt-bindings: clk: rs9: Add 9FGV0841 48b20705829d dt-bindings: clock: brcm,kona-ccu: convert to YAML b2b282bb3ba9 dt-bindings: arm: mediatek: move ethsys controller & convert to DT schema e35ce136c12f dt-bindings: clock: xilinx: add versal compatible 746818ace7a3 dt-bindings: rtc: Add Nuvoton ma35d1 rtc d8c717fd9bc8 dt-bindings: Remove alt_ref from versal e9caccbf099c arm64: dts: qcom: sc8180x-primus: Allow UFS regulators load/mode setting b616df631790 arm64: dts: qcom: sc8180x: Describe the GIC redistributor ae7e39a80f0f arm64: dts: qcom: sc8180x: Add interconnects to UFS 0f32e7aa54e0 arm64: dts: qcom: sc8180x: Add missing MDP clocks 3641f17d731d arm64: dts: qcom: sc8180x: Add UFS GDSC 2bbb23973697 arm64: dts: qcom: sc7280*: move MPSS and WPSS memory to dtsi a5b4605b6fc6 ARM: dts: qcom: msm8974*: Re-enable remoteprocs on various boards f1ecb44efc55 ARM: dts: qcom: msm8974: Remove bogus cd-gpio pinctrl 9dd85d38d004 ARM: dts: qcom: msm8974-klte: Remove unused property 34c2fdcebf94 arm64: dts: qcom: sc7280: Rename reserved-memory nodes 84a50703ca7d dt-bindings: remoteproc: qcom: sc7180-pas: Add SC7280 compatibles 47f83514132e dt-bindings: remoteproc: qcom: sc7180-pas: Fix SC7280 MPSS PD-names 1dce719ef64f arm64: dts: qcom: sc7280: Remove unused second MPSS reg afedac693f18 arm64: dts: qcom: sdm670: add display subsystem 1d8d2d147ea5 dt-bindings: soc: qcom,aoss-qmp: document the X1E80100 Always-On Subsystem side channel 3ea56a52a7c2 dt-bindings: wdt: Add ts72xx 18522cdf3ec6 dt-bindings: watchdog: dlg,da9062-watchdog: Document DA9063 watchdog 688fe0bdd724 dt-bindings: watchdog: dlg,da9062-watchdog: Add fallback for DA9061 watchdog 9054003bb13e dt-bindings: watchdog: mediatek,mtk-wdt: add MT7988 watchdog and toprgu 63d466a6e3b3 dt-bindings: watchdog: realtek,rtd1295-watchdog: convert txt to yaml 5b6c41392896 dt-bindings: watchdog: qcom-wdt: Make the interrupt example edge triggered 4f8423c375eb dt-bindings: iio: chemical: add aosong,ags02ma 766801c2fc4b dt-bindings: vendor-prefixes: add aosong 530dcc2cff54 arm64: dts: qcom: sm8150-hdk: enable DisplayPort and USB-C altmode a63d7ac5c9ca arm64: dts: qcom: sm8150: add USB-C ports to the OTG USB host 6177bf5ba3b4 arm64: dts: qcom: sm8150: add USB-C ports to the USB+DP QMP PHY cccb449ab331 arm64: dts: qcom: sm8150: add DisplayPort controller 414013ad4921 arm64: dts: qcom: sm8150-hdk: fix SS USB regulators 94e5a8422a14 arm64: dts: qcom: sm8150-hdk: enable HDMI output 94cd2b0ff062 arm64: dts: qcom: sm8150: make dispcc cast minimal vote on MMCX d8577fce5e20 arm64: dts: qcom: sm8650: add fastrpc-compute-cb nodes e14f9c1044bd arm64: dts: qcom: sm8550-qrd: add PM8010 regulators 66e97e0962a7 arm64: dts: qcom: sm8550-mtp: Add pm8010 regulators 6437200479ec arm64: dts: qcom: qcm2290: Hook up MPM 75b87eb7e3ee arm64: dts: qcom: msm8996: Hook up MPM e043072a3a33 arm64: dts: qcom: sm6375: Hook up MPM 623a6180066f dt-bindings: arm: qcom: Add Motorola Moto G 4G (2013) 030e5c73208a arm64: dts: qcom: x1e80100-crd: Fix supplies for some LDOs in PM8550 58e87053c1f0 arm64: dts: qcom: sc7280: add QCrypto nodes 6d138c9b4127 arm64: dts: qcom: sc7180: Switch pompom to the generic edp-panel 9248e79cd654 arm64: dts: qcom: sm8150: fix USB SS wakeup 8143f0f67202 arm64: dts: qcom: sm8150: fix USB DP/DM HS PHY interrupts 1d46c82d351b arm64: dts: qcom: sdm845: fix USB SS wakeup 5c261eb8cd11 arm64: dts: qcom: sdm845: fix USB DP/DM HS PHY interrupts 2998fdbc15fe arm64: dts: qcom: sc8180x: fix USB DP/DM HS PHY interrupts 220ee261025f arm64: dts: qcom: sm8550: drop unneeded assigned-clocks from codec macros ef2823c0a498 arm64: dts: qcom: sm8550: move Soundwire pinctrl to its nodes 611112fa3972 arm64: dts: qcom: sm8450: drop unneeded assigned-clocks from codec macros 7fe6ee08b28c arm64: dts: qcom: sm8450: move Soundwire pinctrl to its nodes eb6e95625c03 arm64: dts: qcom: sm8550: add missing two RX Soundwire ports in configuration 6f45533e32ad arm64: dts: qcom: sm8650: drop unneeded assigned-clocks from WSA macro 108c60eb7746 dt-bindings: arm: qcom: Fix up htc-memul compatible c493fe546f0a arm64: dts: qcom: sm6115: Hook up interconnects fd22f3a58a9e Merge branch 'icc-sm6115' of https://git.kernel.org/pub/scm/linux/kernel/git/djakov/icc into HEAD 85a531800a07 ARM: dts: qcom: msm8926-motorola-peregrine: Add initial device tree 9c323b20cda8 ARM: dts: qcom: ipq4019: add dedicated SDHCI compatible 2fcaa70bfc3c arm64: dts: qcom: ipq8074: add dedicated SDHCI compatible 757c981838e3 arm64: dts: qcom: Fix coresight warnings in in-ports and out-ports 34e4f27862d1 arm64: dts: qcom: msm8998: Fix 'out-ports' is a required property 61e7df01e058 arm64: dts: qcom: msm8996: Fix 'in-ports' is a required property 786be94e8465 arm64: dts: qcom: qrb5165-rb5: add the Bluetooth node fe9d727180d2 arm64: dts: qcom: sa8775p: Add missing space between node name and braces 8df2548eb151 arm64: dts: qcom: Use "pcie" as the node name instead of "pci" 756ec289cf35 ARM: dts: qcom: Use "pcie" as the node name instead of "pci" 2066a55949a7 arm64: dts: qcom: acer-aspire1: Add sound 90485d1f88ce arm64: dts: qcom: acer-aspire1: Correct audio codec definition 3d97796b14f9 arm64: dts: qcom: acer-aspire1: Enable RTC 5d870a6a209b arm64: dts: qcom: sm8450: switch UFS QMP PHY to new style of bindings 1e57f262d57c arm64: dts: qcom: sm8350: switch UFS QMP PHY to new style of bindings 731a9974488a arm64: dts: qcom: sm8250: switch UFS QMP PHY to new style of bindings 8a512baad9fa arm64: dts: qcom: sm8150: switch UFS QMP PHY to new style of bindings 9c4063711b1f arm64: dts: qcom: sm6350: switch UFS QMP PHY to new style of bindings 79c130d88048 arm64: dts: qcom: sm6115: switch UFS QMP PHY to new style of bindings 65d88afa8518 arm64: dts: qcom: sdm845: switch UFS QMP PHY to new style of bindings fa34450ebcf9 arm64: dts: qcom: msm8998: switch UFS QMP PHY to new style of bindings 2d00768d0566 arm64: dts: qcom: msm8996: switch UFS QMP PHY to new style of bindings 6d501541ab8b arm64: dts: qcom: sm8450-hdk: Enable the A730 GPU 9999a06044c2 arm64: dts: qcom: sm8550-mtp: Enable the A740 GPU 1c8862cd1be0 arm64: dts: qcom: sm8550-qrd: Enable the A740 GPU db2dd74a4321 arm64: dts: qcom: sm8550: Add GPU nodes 41411e46e180 arm64: dts: qcom: sm8450: Add GPU nodes 67082abed4d1 arm64: dts: qcom: msm8939: Make blsp_dma controlled-remotely b0768548dacf arm64: dts: qcom: msm8916: Make blsp_dma controlled-remotely e529c8cd00c4 arm64: dts: qcom: msm8939: Add clock-frequency for broadcast timer dc95d696633b arm64: dts: qcom: Add missing vio-supply for AW2013 ce476167f046 arm64: dts: qcom: ipq6018: Add QUP5 SPI node 4723cf41be1a arm64: dts: qcom: ipq6018: Add remaining QUP UART node af3ecf0ef5eb Merge branch '20231201-videocc-8150-v3-1-56bec3a5e443@quicinc.com' into clk-for-6.8 eeb32e2a4dbd dt-bindings: clock: Update the videocc resets for sm8150 c591d3616c87 arm64: dts: qcom: qrb4210-rb2: Enable MPSS and Wi-Fi 479632ff42dd arm64: dts: freescale: fix the schema check errors for fsl,tmu-calibration 4c12613ce6e0 ARM: dts: imx27-phytec-phycore-som: Use 'rtc' as node name e55cb89e6ef8 ARM: dts: imx25: Remove unneeded keypad properties 610b835be6b9 dt-bindings: net: marvell,orion-mdio: Drop "reg" sizes schema 5605354f949e arm64: dts: freescale: imx8qxp: Disable dsp reserved memory by default bb83d09752aa arm64: dts: imx8qxp: Add VPU subsystem file 11f5b7454c94 arm64: dts: imx8qxp-mek: Move port under USB connector f6d6c203902d arm64: dts: imx8mn-bsh-smm-s2/pro: add display setup 643674137f59 dt-bindings: PCI: qcom: Document the SM8650 PCIe Controller ddec040496f1 dt-bindings: PCI: dwc: rockchip: Document optional PCIe reference clock input 2d8a490fd767 dt-bindings: PCI: qcom: Correct reset-names property 2bdefbbe9381 dt-bindings: PCI: qcom: Correct clocks for SM8150 01ce80af6cc2 dt-bindings: PCI: qcom: Correct clocks for SC8180x 9c60f1faccc9 dt-bindings: PCI: qcom: Adjust iommu-map for different SoC c78e4dd9c7c0 arm64: dts: rockchip: make use gpio-keys for buttons on puma-haikou 146cf4124863 arm64: dts: rockchip: expose BIOS Disable feedback pin on rk3399-puma 26575df71b2d arm64: dts: rockchip: fix misleading comment in rk3399-puma-haikou.dts 93c2098cfa35 ARM: dts: ux500-href: Switch HREF520 to AB8505 488dc522177c ARM: dts: ux500-href: Push AB8500 config out 7acade644174 ARM: dts: ux500-href: Push AB8500 inclusion to the top 0043c908a991 dt-bindings: connector: usb: add accessory mode description 7b7f80d863a5 arm64: dts: rockchip: Add vop on rk3588 ef9ea9ea51ca arm64: dts: ti: k3-j784s4-main: Add Itap Delay Value For DDR50 speed mode a843a4a028e7 arm64: dts: ti: k3-j721s2-main: Add Itap Delay Value For DDR50 speed mode 83869275890f arm64: dts: ti: k3-j7200-main: Add Itap Delay Value For DDR52 speed mode 237d1d3aa847 arm64: dts: ti: k3-am6*: Add additional regs for DMA components 6540bf190683 arm64: dts: ti: k3-j7*: Add additional regs for DMA components f584859d0f96 arm64: dts: ti: k3-am65: Add additional regs for DMA components e76881a36a46 arm64: dts: cn913x: add device trees for COM Express boards a57b87e79272 dt-bindings: arm64: add Marvell COM Express boards 22b670935a1f arm64: dts: armada-3720-turris-mox: set irq type for RTC 6b8494ce5492 ARM64: dts: Add special compatibles for the Turris Mox 8fcbbd77bc4f ARM64: dts: marvell: Fix some common switch mistakes 61b4fbe68e70 ARM: dts: marvell: make dts use gpio-fan matrix instead of array 1a025bb583e1 ARM: dts: marvell: Fix some common switch mistakes 283f9ebb847c dt-bindings: serial: Add a new compatible string for UMS9620 42414ddb491a dt-bindings: serial: imx: Properly describe the i.MX1 interrupts a5b226724ae1 dt-bindings: usb: qcom,dwc3: Add X1E80100 binding a94c79572ac2 dt-bindings: usb: Document WCD939x USB SubSystem Altmode/Analog Audio Switch 6c2112d5f3f3 arm64: dts: qcom: qrb5165-rb5: use u16 for DP altmode svid 79493bc9fc10 dt-bindings: connector: usb: add altmodes description a98f9ad936ee dt-bindings: usb: nxp,ptn5110: Fix typos in the title da44f4e15545 dt-bindings: usb: genesys,gl850g: Document 'peer-hub' c32fd07e4010 dt-bindings: nvmem: add new stm32mp25 compatible for stm32-romem cc8835249ffb ARM: dts: stm32: add dcmipp support to stm32mp135 dc483bc0495b dt-bindings: gnss: u-blox: add "reset-gpios" binding 82239f64506f dt-bindings: iommu: rockchip: Add Rockchip RK3588 b10f7d79bc86 Merge git://git.kernel.org/pub/scm/linux/kernel/git/netdev/net e39b04bbed6e Merge branch 'icc-qcm2290' into icc-next c95f389c0366 Merge branch 'icc-sm6115' into icc-next b1f1b32e611b dt-bindings: PCI: rcar-pci-host: Add optional regulators 51eab76bc15c arm64: dts: allwinner: h618: add Transpeed 8K618-T TV box 8f65017d5eb4 dt-bindings: arm: sunxi: document Transpeed 8K618-T board name a043657dff28 dt-bindings: vendor-prefixes: add Transpeed b9b13eec182f arm64: dts: st: add bsec support to stm32mp25 4ba9da13226a ARM: dts: stm32: Consolidate usbh_[eo]hci phy properties on stm32mp15 3cd8f921b287 ARM: dts: stm32: don't mix SCMI and non-SCMI board compatibles 9d7cd7004fbc dt-bindings: arm: stm32: don't mix SCMI and non-SCMI board compatibles 3409584c8b1b ARM: dts: stm32: minor whitespace cleanup around '=' 46d3a566ba35 regulator: dt-bindings: qcom,rpmh: add compatible for pm8010 b876feae34ef ASoC: dt-bindings: audio-graph-port: Document new DAI link flags playback-only/capture-only b0c246496fbc dt-bindings: display: msm: dp: declare compatible string for sm8150 363bcab6054e scsi: ufs: qcom: dt-bindings: Add SC7280 compatible string 3d1e051b5db8 arm64: dts: imx8mp-dhcom-pdk3: Describe the USB-C connector ef545aff5ca3 arm64: dts: imx8mn-var-som-symphony: Describe the USB-C connector 13069c168986 arm64: dts: imx8mp-tqma8mpql-mba8mpxl: Fix USB connector description c92840a54a7a arm64: dts: imx8mp-venice: Fix USB connector description d0235ca7db0f arm64: dts: imx8mp-verdin: Fix USB connector description 8e6a721ca452 arm64: dts: imx8dxl-ss-conn: Move clk_dummy out of USB node 7662ace2b978 arm64: dts: imx8mn-evk: Move port under USB connector 92576b82f349 arm64: dts: imx8mm-evk: Move port under USB connector 91c629656840 arm64: dts: freescale: introduce dimonoff-gateway-evk board 8b75c148251b dt-bindings: arm: fsl: add Dimonoff gateway EVK board 192ca710eafd dt-bindings: vendor-prefixes: add dimonoff edc62a2939e3 arm64: dts: imx8m*-tqma8m*: Add chassis-type d35e9fd630d7 arm64: dts: imx8mn-beacon: Support overdrive mode a684f6ef9a40 arm64: dts: imx8mn: Enable Overdrive mode 0c6ce8fb001d arm64: dts: imx8mm-beacon: Enable overdrive mode 42e3d3eaa3cb arm64: dts: imx8mm: Add optional overdrive DTSI f9b749293626 arm64: dts: imx8mm: Reduce GPU to nominal speed aadc35d489bd arm64: dts: imx93: Fix the micfil clock-names entries f8b732c140f6 ARM: dts: imx23/28: Fix the DMA controller node name 9697ec153a9c ARM: dts: imx23-sansa: Use preferred i2c-gpios properties 62875ee7373e ARM: dts: imx27-apf27dev: Fix LED name 6bd0d6d0fb3d ARM: dts: imx25/27: Pass timing0 3cd4341f361d ARM: dts: imx25: Fix the iim compatible string 52eef6a12e21 arm64: dts: exynos: google: Add initial Oriole/pixel 6 board support b0f009ddef83 arm64: dts: exynos: google: Add initial Google gs101 SoC support 7932b36aab04 dt-bindings: arm: google: Add bindings for Google ARM platforms c439b1ecd46b dt-bindings: PCI: ti,j721e-pci-*: Add j784s4-pci-* compatible strings 5114ddf2754e dt-bindings: PCI: ti,j721e-pci-*: Add checks for num-lanes 5142777cc846 arm64: dts: renesas: white-hawk-cpu: Fix missing serial console pin control 9c5b72f0dbf7 arm64: dts: renesas: rzg3s-smarc-som: Enable the Ethernet interfaces c20cd1060c83 arm64: dts: renesas: rzg3s-smarc-som: Use switches' names to select on-board functionalities d1702886b9b1 arm64: dts: renesas: r9a08g045: Add Ethernet nodes c8bc29914258 arm64: dts: renesas: r9a08g045: Add IA55 interrupt controller node 2ac19b878bcd arm64: zynqmp: Add missing destination mailbox compatible bfda609d3986 arm64: zynqmp: Fix clock node name in kv260 cards bf79a715a44c arm64: zynqmp: Move fixed clock to / for kv260 067130bf35dd dt-bindings: soc: Add new board description for MicroBlaze V 3909199b5365 dt-bindings: soc: xilinx: Move xilinx.yaml from arm to soc 5a30f0c409d5 arm64: xilinx: Remove address/size-cells from gem nodes c7afa96873c9 arm64: xilinx: Remove address/size-cells from flash node e3a99f7f8d11 arm64: xilinx: Put ethernet phys to mdio node 6f4a9a0c8df9 arm64: xilinx: Remove mt25qu512a compatible string from SOM e3823e6a85e8 arm64: xilinx: Use lower case for partition address ee878ab978b7 arm64: xilinx: Do not use '_' in DT node names edb56e5ac871 riscv: dts: starfive: Enable SDIO wifi on JH7100 boards 738fd2fd6271 riscv: dts: starfive: Enable SD-card on JH7100 boards 4a3456d5f756 riscv: dts: starfive: Add JH7100 MMC nodes 0b98a998f256 riscv: dts: starfive: Add pool for coherent DMA memory on JH7100 boards b7e59570a83e riscv: dts: starfive: Add JH7100 cache controller 0e3644417255 riscv: dts: starfive: Mark the JH7100 as having non-coherent DMAs 2ce3980ca0ba riscv: dts: starfive: Group tuples in interrupt properties 21bb4608c1f4 arm64: dts: ti: k3-am62-main: Add GPU device node 21dbc3bb6085 dt-bindings: interconnect: qcom,msm8998-bwmon: Add QCM2290 bwmon instance 0a5288800340 dt-bindings: rockchip,vop2: Add more endpoint definition 689213783aed dt-bindings: display: vop2: Add rk3588 support d06f02a431a5 dt-bindings: interconnect: qcom,msm8998-bwmon: Add SM6115 bwmon instance a67732e07f79 arm64: dts: fsd: Add MFC related DT enteries a8f325704092 arm64: dts: ti: k3-j721s2-evm: Add overlay for PCIE1 Endpoint Mode c33d48e723e9 arm64: dts: ti: k3-j721e-evm: Add overlay for PCIE0 Endpoint Mode 411f344456e4 arm64: dts: ti: k3-j721e-sk: Add TPS6594 family PMICs e88109a7ea70 arm64: dts: ti: k3-am69-sk: Add support for TPS6594 PMIC 8203df16463f arm64: dts: ti: k3-j784s4-evm: Add support for TPS6594 PMIC 12693cd3a151 arm64: dts: ti: k3-j721e-som-p0: Add TP6594 family PMICs 022683d6bab2 arm64: dts: ti: k3-j721s2-som-p0: Add TP6594 family PMICs b13637076b0a arm64: dts: ti: k3-j7200-som-p0: Add TP6594 family PMICs 073920a8e469 spi: dw: Remove Intel Thunder Bay SOC support 853b38b4ccbe dt-bindings: media: s5p-mfc: Add mfcv12 variant af1444135df0 dt-bindings: soc: rockchip: add rk3588 vop/vo syscon ea9d3ade1f63 media: dt-bindings: Add OmniVision OV64A40 eac07152e0b8 media: dt-bindings: media: imx335: Add supply bindings 37535c00a2ec media: dt-bindings: gc0308: add binding 9be8a81b5d55 media: dt-bindings: ov8856: decouple lanes and link frequency from driver e78a33d58798 media: dt-bindings: alvium: add document YAML binding 123e53dddda5 dt-bindings: vendor-prefixes: Add prefix alliedvision 5367c47d39ee media: dt-bindings: ak7375: Add ak7345 support 33368f1c353f dt-bindings: mfd: pm8008: Clean up example node names 2ab5a6b315e7 dt-bindings: leds: qcom,spmi-flash-led: Fix example node name fa6a05463677 dt-bindings: leds: aw200xx: Fix led pattern and add reg constraints 44e89edff478 dt-bindings: leds: awinic,aw200xx: Add AW20108 device 6cd025d35790 dt-bindings: leds: aw200xx: Remove property "awinic,display-rows" 65b3a1cec5b9 dt-bindings: leds: aw200xx: Introduce optional enable-gpios property 48e46bb513fb dt-bindings: leds: Add Allwinner A100 LED controller 193b43eae00d dt-bindings: leds: Fix JSON pointer in max-brightness ac28e493721a ARM: dts: imx25: Move usbphy nodes out of simple-bus 90f8840e451d ARM: dts: imx1: Use 'bus' for AIPI bus dfc79426f635 ARM: dts: imx27-phytec-phycore-rdk: Move usbphy nodes out of simple-bus 92c19f27621f ARM: dts: imx27-pdk: Move usbphy0 out of simple-bus 09cddc0d2c3d ARM: dts: imx27: Use 'bus' for EMI bus e7cd1893e9ea ARM: dts: imx27: Use 'bus' for AIPI bus 81e952ba68c6 media: dt-bindings: media: i2c: Add bindings for TW9900 2ed7758d7c0a dt-bindings: vendor-prefixes: Add techwell vendor prefix 9b5febaeea2a arm64: dts: freescale: add fsl-lx2160a-mblx2160a board c763b70a3ecc dt-bindings: arm: fsl: Add TQ-Systems LX2160A based boards 6c6fc780325f ARM: dts: imx27-phytec-phycore-som: Use the mux- prefix 2571ab1025eb ARM: dts: imx1: Fix sram node c64c46277345 ARM: dts: imx27: Fix sram node 4606862f29a7 ARM: dts: imx: Use flash@0,0 pattern e9c196aff7af ARM: dts: imx25/27-eukrea: Fix RTC node name 34087a021485 ARM: dts: imx25-pdk: Pass #sound-dai-cells f91e9208f059 ARM: dts: imx25: Pass I2C clock-names property cb93e178f443 arm64: dts: freescale: imx93: add i3c1 and i3c2 3b2d451cf59f arm64: dts: ls1012a: Remove big-endian from thermal 25e47251c772 dt-bindings: input: microchip,cap11xx: add advanced sensitivity settings a0fb1bc7fd22 Merge tag 'exynos-drm-next-for-v6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/daeinki/drm-exynos into drm-next aae3e1a63026 dt-bindings: riscv: add Zfa ISA extension description ab9eea090f24 dt-bindings: riscv: add Zvfh[min] ISA extension description 7a64028da27c dt-bindings: riscv: add Zihintntl ISA extension description f4789213e5b6 dt-bindings: riscv: add Zfh[min] ISA extensions description c5de05064f79 dt-bindings: riscv: add vector crypto ISA extensions description 215c236fe6da dt-bindings: riscv: add scalar crypto ISA extensions description 1a96ef0c118a Merge tag 'pef2256-framer' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl 6dbce6382acc Merge tag 'pef2256-framer' into devel 1c566bdd0e0f dt-bindings: net: Add the Lantiq PEF2256 E1/T1/J1 framer 0e2e3f19a42d arm64: dts: rockchip: Add Anbernic RG351V aa1c981f085f arm64: dts: rockchip: Split RG351M from Odroid Go Advance 5985d0436d7f dt-bindings: arm: rockchip: Add Anbernic RG351V dddd8bf614e2 arm64: dts: rockchip: Add ethernet0 alias to the dts for RK3588(S) boards e79626358af1 arm64: dts: rockchip: Add ethernet0 alias to the dts for RK3566 boards c2bbb4cb37ce arm64: dts: rockchip: Remove ethernet0 alias from the SoC dtsi for PX30 5df2cd229ef2 arm64: dts: rockchip: Remove ethernetX aliases from the SoC dtsi for RK3328 773747ea9224 arm64: dts: rockchip: Remove ethernet0 alias from the SoC dtsi for RK3368 c47780f2190d arm64: dts: rockchip: Remove ethernet0 alias from the SoC dtsi for RK3399 0e5a28940713 arm64: dts: rockchip: make dts use gpio-fan matrix instead of array 51d3d03836a0 arm64: dts: rockchip: add gpio alias for gpio dt nodes 5fcf2d67aa35 arm64: dts: rockchip: Add dynamic-power-coefficient to rk3399 GPU 80e922961b8e arm64: dts: rockchip: add rk3588 spi aliases to soc dtsi 8f3fbd13ee16 arm64: dts: rockchip: add rk3588 gpio aliases to soc dtsi 15b3dffcbe21 arm64: dts: rockchip: add rk3588 i2c aliases to soc dtsi 095c6f3ed2af arm64: dts: rockchip: move rk3588 serial aliases to soc dtsi 5dc789289ead arm64: dts: rockchip: add Theobroma Jaguar SBC bc75d639d8bd dt-bindings: arm: rockchip: Add Theobroma-Systems Jaguar SBC 3c240c87c027 arm64: dts: rockchip: Add Powkiddy X55 2496d275584a dt-bindings: arm: rockchip: Add Powkiddy X55 517f4adf026d arm64: dts: rockchip: add USB3 host to rock-5a d474a82f6b8f arm64: dts: rockchip: add USB3 host to rock-5b 4bf4fdf576e0 arm64: dts: rockchip: add missing tx/rx-fifo-depth for rk3328 gmac 56e0ff652ec1 arm64: dts: rockchip: add gpio-line-names to rk3308-rock-pi-s 36bdcd2e79dd ARM: dts: rockchip: add hdmi-connector node to rk3036-kylin bd117185d559 ARM: dts: rockchip: fix rk3036 hdmi ports node 2127f8eafedb dt-bindings: clock: google,gs101: fix incorrect numbering and DGB suffix fff73dbf51fc dt-bindings: soc: samsung: usi: add google,gs101-usi compatible 37ffa8542576 dt-bindings: serial: samsung: Make samsung,uart-fifosize a required property fd8ed4626aeb dt-bindings: serial: samsung: Add google-gs101-uart compatible 33bfe5e1dc68 dt-bindings: watchdog: Document Google gs101 watchdog bindings e6381c01b68b riscv: dts: thead: Enable LicheePi 4A eMMC and microSD 3bd0505c030a riscv: dts: thead: Enable BeagleV Ahead eMMC and microSD a53de85228bf riscv: dts: thead: Add TH1520 mmc controllers and sdhci clock fd1214b13ed4 ARM: dts: microchip: sama5d27_som1_ek: Remove mmc-ddr-3_3v property from sdmmc0 node 5d2956b92dea dt-bindings: interrupt-controller: mpm: Pass MSG RAM slice through phandle 402b4259739c dt-bindings: interrupt-controller: renesas,rzg2l-irqc: Document RZ/G3S 150ddb24b2f0 Merge tag 'coresight-next-v6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/coresight/linux into char-misc-next 64011b700499 dt-bindings: arm-smmu: Document SM8[45]50 GPU SMMU a5ab14d25e79 dt-bindings: arm-smmu: Add compatible for X1E80100 SoC aaa9819e17c5 dt-bindings: iommu: arm,smmu: document the SM8650 System MMU c04ccbbeb58a dt-bindings: iommu: arm,smmu: document clocks for the SM8350 GPU SMMU b73f681e020f arm64: dts: juno: Align thermal zone names with bindings 8762e182cc34 dt-bindings: hwmon: Add lltc ltc4286 driver bindings 7711cd743748 Merge tag 'exynos-drm-next-for-v6.7-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/daeinki/drm-exynos into exynos-drm-next 0c9c816dddb4 Backmerge tag 'v6.7-rc5' into drm-next cc330eac5dd3 dt-bindings: iio: humidity: Add TI HDC302x support 07a88600291a dt-bindings: iio: light: add ltr390 a803f8c65ec8 dt-bindings: iio: pressure: add honeywell,hsc030 49600f0eeb26 dt-bindings: iio: temperature: add MLX90635 device 5f69a9e8d3dd dt-bindings: hwmon: Increase max number of io-channels 565f404ae838 dt-bindings: hwmon: Add mps mp5990 driver bindings ad5cba1ee29a ASoC: dt-bindings: qcom,lpass-wsa-macro: Add SM8650 LPASS WSA 880126e66fb3 ASoC: dt-bindings: qcom,lpass-va-macro: Add SM8650 LPASS VA 19ed8a218bd9 ASoC: dt-bindings: qcom,lpass-tx-macro: Add SM8650 LPASS TX 322423704418 ASoC: dt-bindings: qcom,lpass-rx-macro: Add SM8650 LPASS RX f09397ff6cbf dt-bindings: dma: Add dma-channel-mask to nvidia,tegra210-adma 6263d2ffbb0f dt-bindings: dma: sf-pdma: add new compatible name 7581e8bd108d arm64: dts: mediatek: mt8192: Add Smart Voltage Scaling node de53c9a33f27 arm64: dts: mediatek: mt8195: Add SVS node and reduce LVTS_AP iospace 53ceb33cc2de arm64: dts: mediatek: mt8183: Change iospaces for thermal and svs d305525393a4 arm64: dts: mediatek: mt8186: fix address warning for ADSP mailboxes d4dbd2b56a9f arm64: dts: mediatek: mt8186: Fix alias prefix for ovl_2l0 209e23166717 arm64: dts: mt6358: Drop bogus "regulator-fixed" compatible properties b5aaf3dc3cc4 arm64: dts: mt8183: kukui-jacuzzi: Drop bogus anx7625 panel_flag property aef30bad7a04 arm64: dts: Add MediaTek MT8188 dts and evaluation board and Makefile c8d764a0bbc6 dt-bindings: soc: mediatek: pwrap: Modify compatible for MT8188 1b35e3cf8066 dt-bindings: arm: mediatek: Add mt8188 pericfg compatible 7e4914880550 dt-bindings: arm: Add compatible for MediaTek MT8188 c4c85ca7297e arm64: dts: mediatek: mt8195: add DSI and MIPI DPHY nodes e7300ae6b913 dt-bindings: display: mediatek: dsi: add compatible for MediaTek MT8195 cebba0dd1a01 arm64: dts: mediatek: mt6358: Merge ldo_vcn33_* regulators 8ac8be12ac45 dt-bindings: arm: mediatek: convert audsys and mt2701-afe-pcm to yaml 275042f3fe7b arm64: dts: mediatek: mt8195: add MDP3 nodes aba1f17e7acc arm64: dts: mediatek: mt8195: revise VDOSYS RDMA node name 7032d5f144c2 arm64: dts: mediatek: mt8183: correct MDP3 DMA-related nodes 22bae315e031 dt-bindings: display: mediatek: padding: add compatible for MT8195 751c1a1076cb dt-bindings: display: mediatek: split: add compatible for MT8195 e2f195c9941b dt-bindings: display: mediatek: ovl: add compatible for MT8195 98aa994aefee dt-bindings: display: mediatek: merge: add compatible for MT8195 6f5d6cbaa3f9 dt-bindings: display: mediatek: color: add compatible for MT8195 ef86984ae659 dt-bindings: display: mediatek: aal: add compatible for MT8195 8f6efe19695a dt-bindings: media: mediatek: mdp3: add component TDSHP for MT8195 f3a2d9b01651 dt-bindings: media: mediatek: mdp3: add component TCC for MT8195 9952a02bb5ee dt-bindings: media: mediatek: mdp3: add component STITCH for MT8195 6c49acbc4134 dt-bindings: media: mediatek: mdp3: add component HDR for MT8195 d6fdbfb3b4ad dt-bindings: media: mediatek: mdp3: add component FG for MT8195 a7d6e829425b dt-bindings: media: mediatek: mdp3: add compatible for MT8195 WROT 7db0370c2d66 dt-bindings: media: mediatek: mdp3: add compatible for MT8195 RSZ 5620ceb8b6ca dt-bindings: media: mediatek: mdp3: add config for MT8195 RDMA 8f056e0ef45c dt-bindings: media: mediatek: mdp3: merge the indentical RDMA under display c2d8940ef6fd dt-bindings: media: mediatek: mdp3: correct RDMA and WROT node with generic names 4347ab16a815 media: dt-bindings: mediatek: Add phandle to mediatek,scp on MDP3 RDMA e14664bd10f6 arm64: dts: mediatek: mt8195-cherry: Assign sram supply to MFG1 pd 0561502a0693 arm64: dts: mediatek: mt8195-cherry: Add MFG0 domain supply 08b52bb4b076 dt-bindings: reset: mt8188: Add VDOSYS reset control bits 10fbcb9df4e2 dt-bindings: arm: mediatek: Add compatible for MT8188 88c996595db3 dt-bindings: display: mediatek: padding: Add MT8188 ca5643fef42b dt-bindings: display: mediatek: merge: Add compatible for MT8188 ae3b78a94c61 dt-bindings: display: mediatek: mdp-rdma: Add compatible for MT8188 744464b66c7e dt-bindings: display: mediatek: ethdr: Add compatible for MT8188 01b1569a2d88 dt-bindings: thermal: convert Mediatek Thermal to the json-schema 90d08ec14e3c arm64: dts: mt8183: Add jacuzzi pico/pico6 board 5df3f176b5bf dt-bindings: arm64: mediatek: Add mt8183-kukui-jacuzzi-pico 281ab3bf124c arm64: dts: mt8183: Add jacuzzi makomo board 52cfc0fd5dd9 dt-bindings: arm64: mediatek: Add mt8183-kukui-jacuzzi-makomo 19dd875d8e0a arm64: dts: mt8183: Add kukui katsu board b8dd2f8c3e1c dt-bindings: arm64: mediatek: Add mt8183-kukui-katsu 9a6a916f0bc6 arm64: dts: mediatek: Move MT6358 PMIC interrupts to MT8183 boards 3f27ea46dc3d arm64: dts: mediatek: Use interrupts-extended where possible ad0c69fd2fa3 arm64: dts: mediatek: mt8173: Use interrupts-extended where possible c82e8139aeaa arm64: dts: mediatek: mt8183: Use interrupts-extended where possible d8a485fe96f7 dt-bindings: soc: mediatek: add mt8186 and mt8195 svs dt-bindings e66d619c0c3a dt-bindings: arm: mediatek: mmsys: Add VPPSYS compatible for MT8188 5e6b938fc74f arm64: dts: mediatek: mt8192: Add thermal nodes and thermal zones e90ef555e054 arm64: dts: mediatek: mt8183: Add decoder 0f0ccec6cc8d arm64: dts: mediatek: mt8173: Drop VDEC_SYS reg from decoder b6aed11d9548 arm64: dts: mediatek: cherry: Add platform thermal configuration 86760b83d52b dt-bindings: display: simple: Add AUO G156HAN04.0 LVDS display a9ddc30ef584 dt-bindings: display: panel: Add Ilitek ili9805 panel controller defac25462fb dt-bindings: display: st7701: Add Anbernic RG-ARC panel 336bc0e68db2 dt-bindings: display: panel: add Fascontek FS035VG158 panel 955ce81826fb dt-bindings: vendor-prefixes: Add fascontek 752a79b7aaef dt-bindings: display: panel: Clean up leadtek,ltk035c5444t properties 770aea203c16 Merge 6.7-rc5 into tty-next 34ef5edc5b88 Merge 6.7-rc5 into usb-next 621073890e71 Merge branch 'for-v6.8/samsung-bindings-compatibles' into next/dt64 bf94b2d5359e arm64: dts: exynos: add minimal support for exynosautov920 sadk board e9fd8cf1d2d8 arm64: dts: exynos: add initial support for exynosautov920 SoC d0863d30608a dt-bindings: pinctrl: samsung: correct ExynosAutov920 wake-up compatibles 9bdf0db8ae4b dt-bindings: samsung: exynos-sysreg: combine exynosautov920 with other enum 5b54324e6d5b dt-bindings: dma: Drop undocumented examples e2fd1a08fd82 Merge remote-tracking branch 'drm-misc/drm-misc-next' into msm-next a04c2351b389 dt-bindings: soc: google: exynos-sysreg: add dedicated SYSREG compatibles to GS101 9b3c118b3d19 dt-bindings: clock: Add Google gs101 clock management unit bindings d97b5e938286 dt-bindings: soc: samsung: exynos-pmu: Add gs101 compatible 6a5a439c0701 dt-bindings: pinctrl: samsung: add gs101-wakeup-eint compatible 10422d721886 dt-bindings: pinctrl: samsung: add google,gs101-pinctrl compatible 3a5cb767f670 media: dt-bindings: media: rkisp1: Fix the port description for the parallel interface 1da803cb7af8 arm64: dts: qcom: qcm6490-fairphone-fp5: Enable WiFi 8da528961e4e arm64: dts: qcom: qcm6490-fairphone-fp5: Enable various remoteprocs e6fa65e6d152 arm64: dts: qcom: sc7280: Add CDSP node fc9753f721c5 arm64: dts: qcom: sc7280: Add ADSP node c8ee1d58df76 arm64: dts: qcom: sc7280: Use WPSS PAS instead of PIL 52f7c413fda4 arm64: dts: qcom: qcm6490-fairphone-fp5: Enable UFS 4df3a7b5d504 arm64: dts: qcom: msm8953: Set initial address for memory 423afe7e3dcb ARM: dts: qcom: msm8226: Add GPU bba409f9c339 ARM: dts: qcom: Disable pm8941 & pm8226 smbb charger by default 7e9db953a623 arm64: dts: qcom: sc7280: Add UFS nodes for sc7280 IDP board 4e3613f89c7f arm64: dts: qcom: sc7280: Add UFS nodes for sc7280 soc d8bfc2581200 dt-bindings: input: gpio-mouse: Convert to json-schema 2691fb7a0b13 dt-bindings: drm: rockchip: convert inno_hdmi-rockchip.txt to yaml 2dc455b73efa ARM: dts: samsung: exynos4210-i9100: Add accelerometer node 0fab2792a476 ARM: dts: samsung: exynos4210-i9100: Add node for touch keys 7ea4a30a8fd6 ARM: dts: samsung: exynos4210-i9100: Unconditionally enable LDO12 4cee9945012b ARM: dts: microchip: sama5d27_wlsom1_ek: Remove mmc-ddr-3_3v property from sdmmc0 node e76f84dfaedb arm64: dts: qcom: sm8650: Add DisplayPort device nodes 2cfe9148e611 arm64: dts: qcom: pm8550: drop PWM address/size cells 49e3d2a63a49 dt-bindings: display: mediatek: padding: Add MT8188 8c1a5538e89b dt-bindings: display: mediatek: merge: Add compatible for MT8188 29025812d6c3 dt-bindings: cache: qcom,llcc: correct QDU1000 reg entries 3e60d5b58b7d dt-bindings: gpu: samsung-scaler: constrain iommus and power-domains 1d6aee346b02 dt-bindings: gpu: samsung-g2d: constrain iommus and power-domains d4a84a84e922 dt-bindings: gpu: samsung: constrain clocks in top-level properties 1e0b14dc8237 dt-bindings: gpu: samsung: re-order entries to match coding convention ba50ff463c59 dt-bindings: gpu: samsung-rotator: drop redundant quotes 1a3c1bf5b141 dt-bindings: display: mediatek: mdp-rdma: Add compatible for MT8188 0a16c7e2c414 dt-bindings: display: mediatek: ethdr: Add compatible for MT8188 925f69a6cc7d dt-bindings: serial: qcom,msm-uartdm: Vote for shared resources 44f4478aa927 dt-bindings: serial: snps-dw-apb-uart: include rs485 schema fad4b52a0fdb arm64: dts: hisilicon: hikey970-pmic: clean up SPMI node 051c12eb5d46 arm64: dts: hisilicon: hikey970-pmic: fix regulator cells properties e567127bd619 dt-bindings: hisilicon: Merge hi3620-clock into hisilicon,sysctrl binding 4b823f7042ef arm64: dts: qcom: x1e80100: Add Compute Reference Device f51679f0f817 arm64: dts: qcom: Add base X1E80100 dtsi and the QCP dts ca121fc146b2 dt-bindings: arm: qcom: Document X1E80100 SoC and boards c53c3b8c12a4 dt-bindings: arm: cpus: Add qcom,oryon compatible aa432318faa9 Merge branch 'icc-x1e80100' of https://git.kernel.org/pub/scm/linux/kernel/git/djakov/icc into arm64-for-6.8 9eba2f2fb214 Merge branch '20231205061002.30759-4-quic_sibis@quicinc.com' into arm64-for-6.8 f213e67c84b7 Merge branch '20231205061002.30759-4-quic_sibis@quicinc.com' into clk-for-6.8 ecc521e21905 dt-bindings: clock: qcom-rpmhcc: Add RPMHCC bindings for X1E80100 079af735ef3c dt-bindings: clock: qcom: Add X1E80100 GCC clocks 8f4495322f78 arm64: dts: qcom: sm8650-mtp: add WSA8845 speakers 02b73ff63440 arm64: dts: qcom: sm8650: add Soundwire controllers e6679602ac09 arm64: dts: qcom: sm8650: add ADSP audio codec macros 5c0a5d9640c3 arm64: dts: qcom: sm8650: add LPASS LPI pin controller 7f6211cc8e63 arm64: dts: qcom: sm8650: add ADSP GPR b72a9e98977b arm64: dts: qcom: sm8650-qrd: enable IPA 13bdc41575ab arm64: dts: qcom: sm8650: add IPA information 0fd767d395a1 arm64: dts: qcom: sm8650-qrd: add interconnect dependent device nodes d68c8f7f237a arm64: dts: qcom: sm8650-mtp: add interconnect dependent device nodes 900a28b939d2 arm64: dts: qcom: sm8650: add interconnect dependent device nodes ff01973261d0 arm64: dts: qcom: sm8650: add initial SM8650 QRD dts 185ce15a620b arm64: dts: qcom: sm8650: add initial SM8650 MTP dts 487b5dde17e2 arm64: dts: qcom: pm8550ve: make PMK8550VE SID configurable 61ff00c8e1de arm64: dts: qcom: add initial SM8650 dtsi 7266e49a2f3e dt-bindings: arm: qcom: document SM8650 and the reference boards 34a104c65fa9 Merge branch 'icc-sm8650' of https://git.kernel.org/pub/scm/linux/kernel/git/djakov/icc into arm64-for-6.8 dc9c79dc36cc Merge branch '20231106-topic-sm8650-upstream-clocks-v3-5-761a6fadb4c0@linaro.org' into arm64-for-6.8 482bf7559678 Merge git://git.kernel.org/pub/scm/linux/kernel/git/netdev/net 89cdcbe73e3a dt-bindings: display: msm: dp-controller: document SM8650 compatible 6457d6362b66 docs: dt-bindings: add DTS Coding Style document 17bd76b0dcba ARM: dts: rockchip: add gpio alias for gpio dt nodes 1e3bf6cdb555 dt-bindings: mfd: hisilicon,hi6421-spmi-pmic: Clean up example ebf62e0e08ff dt-bindings: mfd: hisilicon,hi6421-spmi-pmic: Fix regulator binding ff778a37f71a dt-bindings: mfd: hisilicon,hi6421-spmi-pmic: Fix up binding reference 60bfc8c9aef9 dt-bindings: firmware: qcom,scm: Allow interconnect for everyone ae3daad140cd arm64: dts: qcom: sm8250-xiaomi-pipa: Add initial device tree 3ab4a6461f9d dt-bindings: arm: qcom: Add Xiaomi Pad 6 (xiaomi-pipa) a4229e4b1bf7 arm64: dts: qcom: sm8550-qrd: enable IPA 0b02bd1a7f8b arm64: dts: qcom: sm8550: add IPA information 1d704f347212 dt-bindings: firmware: qcom,scm: document SCM on X1E80100 SoCs a07e2c07074c dt-bindings: arm: qcom-soc: extend pattern matching for X1E80100 SoC 190053cb1ce8 arm64: dts: qcom: minor whitespace cleanup around '=' e5d9eb69d255 ARM: dts: qcom: minor whitespace cleanup around '=' a12829c0d5ea arm64: dts: qcom: ipq8074: Add QUP4 SPI node 81c5f29af493 arm64: dts: qcom: qdu1000: Add ECPRI clock controller 7f8d2a160503 Merge branch '20231123064735.2979802-2-quic_imrashai@quicinc.com' into clk-for-6.8 a7b1e49f140b dt-bindings: clock: qcom: Add ECPRICC clocks for QDU1000 and QRU1000 0d8365b85a68 ARM: dts: qcom: sdx55: fix USB wakeup interrupt types 4e5dc5d2a1e5 arm64: dts: qcom: sm8550: fix USB wakeup interrupt types b0dd9226dd63 arm64: dts: qcom: sm8150: fix USB wakeup interrupt types 301d240b276b arm64: dts: qcom: sm6375: fix USB wakeup interrupt types bcfa8e3ed274 arm64: dts: qcom: sdm845: fix USB wakeup interrupt types 20a6fe5d28b2 arm64: dts: qcom: sdm670: fix USB wakeup interrupt types d2c7cfd6cfc3 arm64: dts: qcom: sc8180x: fix USB wakeup interrupt types 6f29d799b7cf arm64: dts: qcom: sc7280: fix usb_2 wakeup interrupt types ca84d4480b44 arm64: dts: qcom: sc7280: fix usb_1 wakeup interrupt types 096085135fda arm64: dts: qcom: sc7180: fix USB wakeup interrupt types 6c1f003cc9a1 arm64: dts: qcom: sa8775p: fix USB wakeup interrupt types 45bd09d633c8 arm64: dts: qcom: msm8916-longcheer-l8150: Add battery and charger 195857e6f299 arm64: dts: qcom: pm8916: Add BMS and charger 6caacf1f1bd3 arm64: dts: qcom: sc7280: Add 0xac Adreno speed bin 3ddcb3a31e24 arm64: dts: qcom: sc7280: Mark Adreno SMMU as DMA coherent b8bf84b9efc0 arm64: dts: qcom: sc7280: Fix up GPU SIDs 0830942e59a4 arm64: dts: qcom: sc7280: Add ZAP shader support 6a2b85d201c9 dt-bindings: arm: qcom-soc: extend pattern for matching existing SoCs ddd782c9e1e9 dt-bindings: cache: qcom,llcc: Add X1E80100 compatible 573141bcc2f7 arm64: dts: qcom: sdx75-idp: Enable USB3 and PHY support 93789523f679 arm64: dts: qcom: Add USB3 and PHY support on SDX75 ddc8552a97e0 arm64: dts: qcom: Add interconnect nodes for SDX75 2f6480d75792 arm64: dts: qcom: sm8350: Fix remoteproc interrupt type 22ab1e4b96e5 arm64: dts: qcom: pm8350k: Remove hanging whitespace 648dd7cb906d arm64: dts: qcom: sm8350: Fix DMA0 address aa5e755d7246 dt-bindings: iio: adc: qcom: Add Qualcomm smb139x aee24a669374 arm64: dts: qcom: sc8180x: align APSS with bindings c51b52a3c7aa arm64: dts: qcom: sm6375-pdx225: add fixed touchscreen AVDD regulator 714c2d01cb79 arm64: dts: qcom: sm6125: add interrupts to DWC3 USB controller 869ed2bf0b06 arm64: dts: qcom: sm6115: align mem timer size cells with bindings 5b01a3bc4e38 arm64: dts: qcom: sm8150: use 'gpios' suffix for PCI GPIOs abcbd3630645 arm64: dts: qcom: sc8180x-primus: use 'gpios' suffix for PCI GPIOs 5281b1e2c756 arm64: dts: qcom: sc8180x-flex-5g: use 'gpios' suffix for PCI GPIOs dbf927ecfde3 arm64: dts: qcom: sdm845: correct Soundwire node name 27d49e38f5d4 arm64: dts: qcom: sdm845-db845c: correct LED panic indicator 85591f38ba27 arm64: dts: qcom: qrb5165-rb5: correct LED panic indicator 65b61add6d70 arm64: dts: qcom: sm8250: Add wakeup-source to usb_1 and usb_2 343c9084fd53 arm64: dts: qcom: sdm850-lenovo-yoga: Add wakeup-sources eb9d72ac20a4 arm64: dts: qcom: sa8775p-ride: enable pmm8654au_0_pon_resin e4828a6315b4 arm64: dts: qcom: sm8350: move DPU opp-table to its node cfa2fb4b7f5b arm64: dts: qcom: sc8280xp-x13s: drop sound-dai-cells from eDisplayPort 927e9926b48f arm64: dts: qcom: sc8180x-primus: drop sound-dai-cells from eDisplayPort ca8a02834a8f arm64: dts: qcom: sm8250: correct Soundwire node name 682a341c0cdc arm64: dts: qcom: sc8280xp: correct Soundwire node name 13f2dbc0a9cb arm64: dts: qcom: qdu1000-idp: drop unused LLCC multi-ch-bit-off 6cda67d14000 arm64: dts: qcom: qdu1000: correct LLCC reg entries 208a56e344a2 arm64: dts: qcom: sm8450: fix soundwire controllers node name c7bee631d3e9 arm64: dts: qcom: sm8550: fix soundwire controllers node name 255ca7c95406 Merge branch '20231106-topic-sm8650-upstream-clocks-v3-5-761a6fadb4c0@linaro.org' into clk-for-6.8 52721c372031 dt-bindings: clock: qcom: Document the SM8650 RPMH Clock Controller a8430c36d8bc dt-bindings: clock: qcom: document the SM8650 GPU Clock Controller e39f08bf115a dt-bindings: clock: qcom: document the SM8650 Display Clock Controller 076aa9fc05f3 dt-bindings: clock: qcom: document the SM8650 General Clock Controller abeff2c9f476 dt-bindings: clock: qcom: document the SM8650 TCSR Clock Controller 3714369ceebb dt-bindings: cache: qcom,llcc: Document the SM8650 Last Level Cache Controller cb0f1e272d52 dt-bindings: clock: qcom,gcc-msm8939: Add CSI2 related clocks 7ee4127b7a3f arm64: dts: qcom: sc8280xp: Add in CAMCC for sc8280xp d380ef670205 Merge branch '20231026105345.3376-3-bryan.odonoghue@linaro.org' into arm64-for-6.8 30a292de3f9a Merge branch '20231026105345.3376-3-bryan.odonoghue@linaro.org' into clk-for-6.8 f007e023cbd5 dt-bindings: clock: Add SC8280XP CAMCC aec8967c6dce dt-bindings: clock: Use gcc.yaml for common clock properties 7c1eb93bd0d3 dt-bindings: clock: qcom,gcc-ipq6018: split to separate schema b6364ec8f82d dt-bindings: arm: qcom,ids: Add SoC ID for SM8650 3f482ad7991e arm64: dts: qcom: sm8550: Enable download mode register write fe077e894545 arm64: dts: qcom: sm8350: Add TCSR halt register space 956699ec82d4 arm64: dts: qcom: sm8250: Add TCSR halt register space e0bd046de230 arm64: dts: qcom: ipq5018: add few more reserved memory regions c38c43d3b995 arm64: dts: qcom: ipq5332: add missing properties to the GPIO LED node 0390c1ee5e11 arm64: dts: qcom: ipq9574: enable GPIO based LED 2f9b91c0cf6d arm64: dts: qcom: qrb2210-rb1: use USB host mode 2196010939c0 dt-bindings: firmware: qcom,scm: document SM8650 SCM Firmware Interface ae8a176c474a dt-bindings: soc: qcom: pmic-glink: document SM8650 compatible c3cb68af1e5d dt-bindings: soc: qcom,aoss-qmp: document the SM8560 Always-On Subsystem side channel a6ea4114f911 dt-bindings: mmc: mtk-sd: add tuning steps related property 30e4bc60ac6d dt-bindings: mfd: ti,am3359-tscadc: Allow dmas property to be optional 5c51588d48df dt-bindings: mfd: qcom,spmi-pmic: Add pm8916 vm-bms and lbc a03962f53dbd dt-bindings: mfd: qcom-spmi-pmic: Document PM8937 PMIC 81a2c830f173 dt-bindings: mfd: qcom,tcsr: Add compatible for sm8250/sm8350 fe50e0fb05fc dt-bindings: mfd: ams,as3711: Convert to json-schema 197c27b6cfaa arm64: dts: fsd: add specific compatibles for Tesla FSD 395fa67b6b72 Merge branch 'for-v6.8/samsung-bindings-compatibles' into next/dt64 5927c83d20c8 dt-bindings: watchdog: samsung: add specific compatible for Tesla FSD 78e4ed4670d7 dt-bindings: samsung: exynos-pmu: add specific compatible for Tesla FSD c168df69f5a1 dt-bindings: serial: samsung: add specific compatible for Tesla FSD 6dedf66f0e8b dt-bindings: pwm: samsung: add specific compatible for Tesla FSD 457e5d03f14d dt-bindings: i2c: exynos5: add specific compatible for Tesla FSD 4b7a14529669 dt-bindings: mmc: renesas,sdhi: Document RZ/Five SoC a135e0045af7 dt-bindings: mmc: arasan,sdci: Add gate property for Xilinx platforms d0ed6c92c98e dt-bindings: mmc: sdhci-of-dwcmhsc: Add T-Head TH1520 support f7a9df14027b dt-bindings: net: microchip,ksz: document microchip,rmii-clk-internal b81aa4a5992d media: dt-bindings: mediatek: Add phandle to mediatek,scp on MDP3 RDMA b80f939c4051 dt-bindings: iio/adc: qcom,spmi-vadc: clean up examples 44c4f2c40551 dt-bindings: iio/adc: qcom,spmi-vadc: fix example node names c57fab0a68f9 dt-bindings: iio/adc: qcom,spmi-rradc: clean up example f330b6a06a10 dt-bindings: iio/adc: qcom,spmi-iadc: clean up example d089bb38e3f6 dt-bindings: iio/adc: qcom,spmi-iadc: fix example node name d92310a0b805 dt-bindings: iio/adc: qcom,spmi-iadc: fix reg description 6afb70912c0a Merge tag 'renesas-dts-for-v6.8-tag1' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/renesas-devel into soc/dt 77be7b2ec3d6 arm64: dts: ti: Add verdin am62 mallow board 5fe3785a98a1 dt-bindings: arm: ti: Add verdin am62 mallow board 7bf01a4e3239 ASoC: dt-bindings: fsl,xcvr: Adjust the number of interrupts 568ee5fdf77d dt-bindings: interconnect: Add Qualcomm SM6115 NoC 7549b7adec53 arm64: dts: ti: verdin-am62: Improve spi1 chip-select pinctrl 0b160138fdcc arm64: dts: ti: k3-am625-phyboard-lyra-rdk: Remove HDMI Reset Line Name 42aed107725d arm64: dts: ti: k3-am625-phyboard-lyra-rdk: Add HDMI support 766ac2241c85 arm64: dts: ti: k3-am625-phyboard-lyra-rdk: Lower I2C1 frequency bcf7dd5b8b09 arm64: dts: ti: phycore-am64: Add R5F DMA Region and Mailboxes e1dfb1eb87a4 riscv: dts: microchip: add the mpfs' system controller qspi & associated flash 59d2f723c14b dt-bindings: soc: microchip: add a property for system controller flash 4b452a4cfa9e ARM: dts: imx23/28: Remove undocumented "fsl,clkctrl" 485e1601cd25 ARM: dts: bcm2711: Add BCM2711 xHCI support 439353e944b0 dt-bindings: usb: xhci: Add support for BCM2711 4b95e8b40522 ARM: dts: imx28-lwe: Pass device_type to the memory node ea0431aa1757 ARM: dts: imx23/28: Remove unneeded "fsl,mxs-gpio" e63738dd96c8 ARM: dts: imx28-tx28: Pass #sound-dai-cells fc88878c01c0 arm64: dts: imx8mq-phanbell: make dts use gpio-fan matrix instead of array e21fe3809cd3 arm64: dts: freescale: verdin-imx8mp: add support to mallow board a75cfdc4a966 arm64: dts: freescale: verdin-imx8mm: add support to mallow board 3b7bee60295f arm64: dts: imx8mm-venice-gw7: Adjust PCI Ethernet nodes 5241ecb06203 dt-bindings: arm: fsl: add verdin imx8mp mallow board b80ecc880136 dt-bindings: arm: fsl: add verdin imx8mm mallow board ad1ae2498610 arm64: dts: imx8mm: Slow default video_pll1 clock rate 5aa830cec5a3 arm64: dts: imx8mm: Remove video_pll1 clock rate from clk node 110274d03548 arm64: dts: imx8mm: Simplify mipi_dsi clocks 99d898689e0b ARM: dts: imx7s: Add on-chip memory 29d17af3b09b ARM: dts: imx7: add MIPI-DSI support d9c25edf04ae scsi: ufs: dt-bindings: Add msi-parent for UFS MCQ dba1025f17d0 ARM: dts: nxp: Fix some common switch mistakes 4ea7b578957d arm64: dts: freescale: minor whitespace cleanup around '=' dbb52d93894b arm64: dts: imx8dxl-ss-ddr: change ddr_pmu0 compatible 941d70d2ae55 arm64: dts: tqma8mpql: Remove invalid/unused property ec00a410133c arm64: dts: imx8-ss-audio: Remove unexistent'shared-interrupt' 604139ed79f6 arm64: dts: imx93: Remove unexistent 'shared-interrupt' 7a445842e287 arm64: dts: imx8qxp-mek: Fix gpio-sbu-mux compatible 0c2122b767be arm64: dts: imx8mp-debix-model-a: Use phy-mode 2e9827c5e054 arm64: dts: imx8mm-nitrogen-r2: Fix I2C mux subnode name d1e22a0dfb43 arm64: dts: imx8dxl-ss-conn: Fix Ethernet interrupt-names order 6299d7ae35e5 arm64: dts: imx8mm-emcon-avari: Fix gpio-cells 9de3f32f3c7d arm64: dts: imx8qm-ss-dma: Pass lpuart dma-names 6905c613057b arm64: dts: freescale: Add SKOV IMX8MP CPU revB board b20a05f3b464 arm64: dts: imx8mn-var-som-symphony: add vcc supply for PCA9534 a5a6af3c0bdd arm64: dts: freescale: introduce rve-gateway board 83600000758e arm64: dts: freescale: debix-som-a-bmb-08: Add CSI Power Regulators b5e632bcd082 arm64: dts: imx8-apalis: add can power-up delay on ixora board 9804057f0f96 arm64: dts: imx8mn-var-som: add fixed 3.3V regulator for EEPROM e3c93255cfdb arm64: dts: imx8mm-venice-gw7: Fix pci sub-nodes 8357f0b7ae64 arm64: dts: imx8mp: Disable dsp reserved memory by default 3b2b78d127df arm64: dts: imx8mp: Add NPU Node b13969aeeefc arm64: dts: freescale: debix-som: Add heartbeat LED 5c6068a3aecc arm64: dts: freescale: Add dual-channel LVDS overlay for TQMa8MPxL 37dbfb74c066 arm64: dts: imx8mp-venice-gw74xx: remove unecessary propreties in tpm node 12f50b18b3a5 ARM: dts: nxp: minor whitespace cleanup around '=' 7e4a296e0073 ARM: dts: imx7d-colibri-emmc: Add usdhc aliases aac483d2d190 ARM: dts: imx6qdl-colibri: Add usdhc aliases 534d21c04c41 ARM: dts: imx6qdl-apalis: Add usdhc aliases 4105f51d0c63 ARM: dts: nxp: imx7d-pico: add cpu-supply nodes 4a5f36c1120b dt-bindings: arm: Add compatible for SKOV i.MX8MP RevB board 7efe4371f644 dt-bindings: arm: fsl: add RVE gateway board 3c86e357feb0 dt-bindings: vendor-prefixes: add rve 04660a3dbd9f ARM: dts: broadcom: Add BCM63138's high speed UART 2e36ee7e60cd arm64: dts: ti: k3-am62x: Add overlay for IMX219 8478bfdedc00 arm64: dts: ti: k3-am62a7-sk: Enable camera peripherals a361c10e44cc arm64: dts: ti: k3-am62x: Add overlays for OV5640 820399f7bf0f arm64: dts: ti: k3-am62x-sk: Enable camera peripherals 4de948eeb982 arm64: dts: ti: k3-am625-beagleplay: Add overlays for OV5640 8d6be01e5e7c arm64: dts: ti: k3-am62a-main: Enable CSI2-RX d52951f9d78a arm64: dts: ti: k3-am62-main: Enable CSI2-RX 4d667e27b3fd arm64: dts: ti: k3-am65: Add AM652 dtsi file 3d2161ed0c2b dt-bindings: perf: fsl-imx-ddr: Add i.MX8DXL compatible 189fe310f16e dt-bindings: clock: support i.MX93 ANATOP clock module b44d3f817227 ARM: dts: imx: tqma7: add lm75a sensor (rev. 01xxx) b654e96c546e dt-bindings: display: simple: add Evervision VGG644804 panel 05a02c1a58e1 dt-bindings: ili9881c: Add Ampire AM8001280G LCD panel 96be0427a528 ARM: dts: rockchip: Move uart aliases to SoC dtsi for RK3128 18c0b8b47af4 ARM: dts: rockchip: Move i2c aliases to SoC dtsi for RK3128 0191774d40bb ARM: dts: rockchip: Move gpio aliases to SoC dtsi for RK3128 4b6344ed1b32 ARM: dts: rockchip: Add Sonoff iHost Smart Home Hub 3cbab293b053 dt-bindings: arm: rockchip: Add Sonoff iHost afacdf8be4db ARM: dts: rockchip: Add rv1109 SoC ad1e5ad721a5 ARM: dts: rockchip: Split up rgmii1 pinctrl on rv1126 fc0ef88ee0a1 ARM: dts: rockchip: Add i2c2 node to rv1126 bf739d2f67ae ARM: dts: rockchip: Serial aliases for rv1126 049605e5080d ARM: dts: rockchip: Add alternate UART pins to rv1126 59e8d345382e ARM: dts: rockchip: Enable GPU for XPI-3128 464bddcf0726 ARM: dts: rockchip: Add GPU node for RK3128 8af06043d850 ARM: dts: rockchip: Add power-controller for RK3128 8f65bb97112e dt-bindings: display: himax-hx8394: Add Powkiddy X55 panel ed2d8407a82d dt-bindings: display: Document Himax HX8394 panel rotation 5319f5062c10 dt-bindings: display: simple: Add boe,bp101wx1-100 panel db09be0ff97b ARM: dts: imx6q-apalis: add can power-up delay on ixora board 31fdbd1cd6c6 dt-bindings: display: msm: document the SM8650 Mobile Display Subsystem 52e16372d1c6 dt-bindings: display: msm: document the SM8650 DPU 258f55b8a6c7 dt-bindings: display: msm-dsi-controller-main: document the SM8650 DSI Controller f06034e33173 dt-bindings: display: msm-dsi-phy-7nm: document the SM8650 DSI PHY e7cafbdafccf dt-bindings: display: msm: Add SDM670 MDSS 58504ed9c645 dt-bindings: display/msm: sdm845-dpu: Describe SDM670 d8b80f6fd0c5 dt-bindings: display/msm: dsi-controller-main: add SDM670 compatible 0c71ce621111 arm64: dts: ti: k3-am625-beagleplay: Use UART name in pinmux name 0895f560a171 arm64: dts: ti: k3-am62a7-sk: Add interrupt support for IO Expander 696f6e8d6176 arm64: dts: ti: k3-am625-verdin: Enable Verdin UART2 145b9a5ffb00 arm64: dts: ti: k3-am62-main: Add gpio-ranges properties 0d95f5e22dde arm64: dts: ti: k3-am64: Enable SDHCI nodes at the board level 8ccabbb5322f arm64: dts: ti: k3-am65: Enable SDHCI nodes at the board level 4b9d0ee63df8 arm64: dts: ti: k3-am65: Add full compatible to dss-oldi-io-ctrl node b64af72b8e7b arm64: dts: ti: k3-j784s4: Add chipid node to wkup_conf bus a70ca898f980 arm64: dts: ti: k3-j721s2: Add chipid node to wkup_conf bus 638e0242808a arm64: dts: ti: k3-j721e: Add chipid node to wkup_conf bus 0b0e18c3dce2 arm64: dts: ti: k3-j7200: Add chipid node to wkup_conf bus 16b21e3cf2ea arm64: dts: ti: k3-am65: Add chipid node to wkup_conf bus ba6541592794 dt-bindings: iio: light: isl76682: Document ISL76682 3678e1e114f2 dt-bindings: pinctrl: qcom,sm8550-lpass-lpi: add X1E80100 LPASS LPI 4854bb4b43e2 dt-bindings: pinctrl: pinctrl-single: add ti,j7200-padconf compatible 062b01e5c736 dt-bindings: iio: light: add support for Vishay VEML6075 3f170ed89d6f dt-bindings: usb: tps6598x: add reset-gpios property 69a424bfd498 dt-bindings: iio/adc: ti,palmas-gpadc: Drop incomplete example 5cf3c6e7327b dt-bindings: adi,ad5791: Add support for controlling RBUF 7a11d1470ed1 dt-bindings: display: bridge: lt8912b: Add power supplies 562bb8392ec6 spi: spl022: fix sleeping in interrupt context 83c535a1ec6b dt-bindings: iio: honeywell,mprls0025pa: drop ref from pressure properties 7cb202a1a899 dt-bindings: media: add bindings for stm32 dcmipp fce776c784a0 dt-bindings: media: Add bindings for THine THP7312 ISP 23c5bf41000e dt-bindings: media: i2c: add galaxycore,gc2145 dt-bindings e6429afd32f1 dt-bindings: vendor-prefixes: Add prefix for GalaxyCore Inc. d1287a3d111f dt-bindings: gpio: rockchip: add a pattern for gpio hogs e08aefe3ce14 Merge tag 'qcom-dts-for-6.7-2' into arm32-for-6.8 66862cc676b1 ARM: dts: qcom: Add support for HTC One Mini 2 ac27d4b5eaa6 Merge tag 'v6.7-rc4' into media_stage 8a745825682b arm64: dts: qcom: sm6350: Make watchdog bark interrupt edge triggered 4de273b8d5cf arm64: dts: qcom: sc8280xp: Make watchdog bark interrupt edge triggered 94d4ed6b0efb arm64: dts: qcom: sa8775p: Make watchdog bark interrupt edge triggered 9e80723d8b4f arm64: dts: qcom: sm8250: Make watchdog bark interrupt edge triggered ef5fa5d97caa arm64: dts: qcom: sm8150: Make watchdog bark interrupt edge triggered 3879bc4c1c04 arm64: dts: qcom: sdm845: Make watchdog bark interrupt edge triggered 8e7e69e2041a arm64: dts: qcom: sc7280: Make watchdog bark interrupt edge triggered 6584d8b4799e arm64: dts: qcom: sc7180: Make watchdog bark interrupt edge triggered 04f80707bc19 arm64: dts: qcom: sc8180x: drop duplicated PCI iommus property 04597b9d0b6f dt-bindings: arm: qcom: Add HTC One Mini 2 7ff927ff9139 dt-bindings: vendor-prefixes: document HTC Corporation fa70da0426ea arm64: dts: qcom: sm8550: correct TX Soundwire clock ed7e07a029d6 arm64: dts: qcom: sm8450: correct TX Soundwire clock 541ded0776d2 arm64: dts: qcom: sc8180x-primus: Fix HALL_INT polarity 39c752cf5603 arm64: dts: qcom: sc8280xp-crd: fix eDP phy compatible e5319a1187df arm64: dts: qcom: sdm632-fairphone-fp3: Enable LPASS daf6cf6a007f arm64: dts: qcom: msm8916-acer-a1-724: Add notification LED 2a186fbc9370 arm64: dts: qcom: ipq6018: use CPUFreq NVMEM 91d98fe1640a arm64: dts: qcom: msm8939-huawei-kiwi: Add initial device tree 6718a893d987 dt-bindings: arm: qcom: Add Huawei Honor 5X / GR5 (2016) f36c60304a90 arm64: dts: qcom: msm8953: Use non-deprecated qcom,domain in LPASS fa91149122fc arm64: dts: qcom: qrb2210-rb1: add wifi variant property 9862c76b6484 arm64: dts: qcom: qrb2210-rb1: Enable CAN bus controller 90510995b456 arm64: dts: qcom: qrb2210-rb1: Set up HDMI f168a1f5fd2a arm64: dts: qcom: qcm2290: Hook up interconnects a66c95bb5052 arm64: dts: qcom: qcm2290: Add display nodes 1b3d99e8ad9d arm64: dts: qcom: sc7280: Add the missing MDSS icc path 463b9cc7faa3 arm64: dts: qcom: sc7180: Add the missing MDSS icc path a2b32f52593b arm64: dts: qcom: sc8280xp: Add QMP handle to RPMh stats 0541077473ea dt-bindings: soc: qcom: stats: Add QMP handle 46fd383def7f arm64: dts: qcom: sm8250-xiaomi-elish: Add pm8150b type-c node and enable usb otg 45ca7aacee21 arm64: dts: qcom: sm8250-xiaomi-elish: Fix typos 9dee357f1ff5 arm64: dts: qcom: msm8939-longcheer-l9100: Add proximity-near-level d6b8367dbb65 arm64: dts: qcom: qrb4210-rb2: Enable bluetooth 9e8fcdbc4d75 arm64: dts: qcom: sm6115: Add UART3 e88a0c4a9117 arm64: dts: qcom: sdm632-fairphone-fp3: Enable WiFi/Bluetooth a808b8c6d7f4 dt-bindings: arm: qcom: Fix html link 004244e4cbd5 arm64: dts: qcom: Add base qcs6490-rb3gen2 board dts 3f55e77ebc86 arm64: dts: qcom: Add base qcm6490 idp board dts 9e08836a864f dt-bindings: arm: qcom: Add QCM6490 IDP and QCS6490 RB3Gen2 board c538a9224903 arm64: dts: qcom: sm4450-qrd: mark QRD4450 reserved gpios 34764956c2e4 arm64: dts: qcom: sm4450-qrd: add QRD4450 uart support b5fe030e21e0 arm64: dts: qcom: sm4450: add uart console support 76478ce29df3 arm64: dts: qcom: sm4450: Add RPMH and Global clock 52ea11ee57e9 arm64: dts: qcom: sm4450: Add apps_rsc and cmd_db node d42f9497ccad arm64: dts: qcom: ipq8074: pass QMP PCI PHY PIPE clocks to GCC 9b98d0a1718e dt-bindings: clocks: qcom,gcc-ipq8074: allow QMP PCI PHY PIPE clocks 2417b30e3609 arm64: dts: qcom: msm8953: add SPI interfaces 66dd2b49a0b3 arm64: dts: qcom: qcm6490-fairphone-fp5: Add PM7325 thermals 0b651704285a arm64: dts: qcom: qcm6490-fairphone-fp5: Add PMK7325 thermals 8630d7baedf5 arm64: dts: qcom: qcm6490-fairphone-fp5: Add PM7250B thermals 959371b1b650 iio: adc: Add PM7325 PMIC7 ADC bindings b1e6472aae24 arm64: dts: qcom: sm8250: Add OPP table support to UFSHC 6aeff20d0bd6 arm64: dts: qcom: sdm845: Add OPP table support to UFSHC e8d1d500097e ARM: dts: qcom: msm8974: Add watchdog node 615027dbbe1d dt-bindings: arm: qcom: drop the IPQ board types ebb3e763ee5b arm64: dts: qcom: ipq5018: enable the CPUFreq support 3ca74e9810cf dt-bindings: clock: qcom,a53pll: add IPQ5018 compatible dcbafe8963f4 ARM: dts: qcom: sdx65: correct SPMI node name 98b030d58c93 ARM: dts: qcom: sdx65: add missing GCC clocks 07a16205d0e0 ARM: dts: qcom: sdx65: correct PCIe EP phy-names fe48cd5331dc dt-bindings: display: msm: Add reg bus and rotator interconnects 8c1892c5f696 dt-bindings: display: msm: qcm2290-mdss: Use the non-deprecated DSI compat 7cfd5769a991 dt-bindings: display/msm: qcom, sm8150-mdss: correct DSI PHY compatible 91abf991ed4a dt-bindings: display/msm: qcom, sm8250-mdss: add DisplayPort controller node c203dee53e38 ARM: dts: rockchip: Enable gmac for XPI-3128 a31102a06882 ARM: dts: rockchip: Add gmac node for RK3128 d02bab784773 dt-bindings: gpu: mali-utgard: Add Rockchip RK3128 compatible 61b6b8e5340b dt-bindings: net: qcom,ipa: document SM8650 compatible a0fa8df10233 Merge tag 'renesas-pinctrl-for-v6.8-tag1' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/renesas-drivers into devel 6c58c6977828 dt-bindings: gpio: modepin: Describe label property 7f00d1c96321 dt-bindings: display: ti: Add support for am62a7 dss 6bed64726635 arm64: dts: ti: k3-am68-sk-base-board: Add alias for MCU CPSW2G f494c9948974 arm64: dts: ti: iot2050: Add icssg-prueth nodes for PG2 devices 403938b5222f arm64: dts: ti: iot2050: Refactor the m.2 and minipcie power pin 45e3b6aa9185 arm64: dts: ti: iot2050: Definitions for runtime pinmuxing b14c51a347fb arm64: dts: ti: iot2050: Drop unused ecap0 PWM 38f52ad2cea9 arm64: dts: ti: iot2050: Re-add aliases a84e54a6c2a0 arm64: dts: ti: k3-am62x-sk-common: Mark mcu gpio and mcu_gpio_intr as reserved 0baa456c51ce arm64: dts: ti: k3-am62p5-sk: Mark mcu gpio and mcu_gpio_intr as reserved 131aadfec025 arm64: dts: ti: k3-am642-evm/sk: Mark mcu_gpio_intr as reserved bbda0d8be30e arm64: dts: ti: k3-am64-main: Fix typo in epwm_tbclk node name 5e8876dba890 arm64: dts: ti: k3-am65-main: Fix DSS irq trigger type fd78a91dedf3 arm64: dts: ti: k3-am62a-main: Fix GPIO pin count in DT nodes 05614d5b4f00 arm64: dts: ti: minor whitespace cleanup around '=' ca6dff24071e ARM: dts: omap4-embt2ws: Add Bluetooth cff0864e2eea Merge git://git.kernel.org/pub/scm/linux/kernel/git/netdev/net 2a2ae1545117 dt-bindings: input: gpio-keys: Allow optional dedicated wakeirq aed93474ebc0 Merge patch series "Add Huashan Pi board support" 318917bad2c6 riscv: dts: sophgo: add Huashan Pi board device tree 8a2824be66df riscv: dts: sophgo: add initial CV1812H SoC device tree 3ff295494c04 riscv: dts: sophgo: cv18xx: Add gpio devices dfcd3e4c81d9 riscv: dts: sophgo: Separate compatible specific for CV1800B soc 8c5d4ad957fa dt-bindings: riscv: Add SOPHGO Huashan Pi board compatibles e393d2e6705e dt-bindings: timer: Add SOPHGO CV1812H clint 65cc6be0d442 dt-bindings: interrupt-controller: Add SOPHGO CV1812H plic dce8266bb548 ARM: dts: omap: logicpd-torpedo: do not disguise GNSS device 0f0cee70a881 ARM: dts: omap4-embt2ws: enable 32K clock on WLAN 33dfdcf03832 ARM: dts: ti/omap: Replace deprecated extcon-usb-gpio id-gpio/vbus-gpio properties aa5a9a109405 dt-bindings: power: meson-g12a-power: document ISP power domain a9f86a1f45b5 dt-bindings: marvell: Add Marvell MV88E6060 DSA schema 5024553a10f5 dt-bindings: marvell: Rewrite MV88E6xxx in schema ad4c44e96eec dt-bindings: net: ethernet-switch: Accept special variants 17baedd697fb dt-bindings: net: mvusb: Fix up DSA example 9c7ccdf2dc30 dt-bindings: net: dsa: Require ports or ethernet-ports 8adbf64f3cdd dt-bindings: input: mediatek,pmic-keys: Drop incomplete example cdc098b167e1 dt-bindings: input: sprd,sc27xx-vibrator: Drop incomplete example 0629a76a9d04 dt-bindings: correct white-spaces in examples 2f78b6dd5c42 dt-bindings: reset: hisilicon,hi3660-reset: Drop providers and consumers from example f835598ebf60 dt-bindings: arm/calxeda: drop unneeded quotes 0d2567437a54 dt-bindings: fsl,dpaa2-console: drop unneeded quotes 352ed027a423 dt-bindings: interrupt-controller: qcom,pdc: document pdc on X1E80100 df641036bac4 dt-bindings: qcom,pdc: document the SM8650 Power Domain Controller 1e17b2ba4499 dt-bindings: interrupt-controller: Add SDX75 PDC compatible c0aff4abb03a dt-bindings: reset: imx-src: Simplify compatible schema and drop unneeded quotes df20c9f94014 dt-bindings: reset: qcom: drop unneeded quotes 1516b28c7069 dt-bindings: reset: renesas,rzg2l-usbphy-ctrl: Document RZ/Five SoC a80bc27a0fe8 dt-bindings: reset: Add compatible and DT bindings for Amlogic C3 Reset Controller 0b8db84ecfc4 ASoC: Intel: Soundwire related board and match updates 303600aff1ef Merge v6.7-rc3 into drm-next d03f6dca688d arm64: dts: rockchip: Use NCM6A-IO board for edgeble-neu6b 2dcf7dbe2812 dt-bindings: arm: rockchip: Update edgeble-neu6 bindings b2a45d98f95b arm64: dts: rockchip: add USB3 host on rk3588s-orangepi-5 766aa3119c2f ARM: dts: motorola-mapphone: Add basic support for mz609 and mz617 3ea15a23d9c7 ARM: dts: motorola-mapphone: Move handset devices to a common file 5127524f7e6f ARM: dts: motorola-mapphone: Move LCD to common file for xt875 and xt894 7e16bd264a3a dt-bindings: omap: Add Motorola mapphone mz609 and mz617 tablets 7d420d843f98 ARM: dts: renesas: r9a06g032: Add missing space in compatible 0faa59be192f arm64: dts: renesas: r9a09g011: Add missing space in compatible 807cfe5cde5c dt-bindings: phy: add compatible for Mediatek MT8195 c52707b1bf77 dt-bindings: phy: amlogic,g12a-mipi-dphy-analog: drop unneeded reg property and example 34ec5dda2a01 dt-bindings: phy: amlogic,meson-axg-mipi-pcie-analog: drop text about parent syscon and drop example f738d7a9dfab dt-bindings: iommu: dart: Add t8103-usb4-dart compatible 2c963cfa7e8e ARM: dts: renesas: armadillo800eva: Add LCD panel a35135dad31c dt-bindings: pinctrl: renesas: Drop unneeded quotes d5212619f0a0 ARM: dts: renesas: r8a7740: Add LCDC nodes 048bdb67a0f6 arm64: dts: renesas: draak: Move HDMI bus properties to correct node ab52a67f9767 arm64: dts: renesas: draak: Make HDMI the default video input dab3ba03f28c Merge 6.7-rc3 into usb-next ec6cd76a8793 arm64: dts: meson-axg: jethub-jxx add support for EEPROM 2da076589eac arm64: dts: amlogic: meson-axg: pinctrl node for NAND cdc5df918882 arm64: dts: amlogic: minor whitespace cleanup around '=' a5dead35fc4b arm64: dts: Add watchdog node for Amlogic S4 SoCs 37c5369b4667 arm64: dts: Add watchdog node for Amlogic C3 SoCs 1d8b2a265b81 dt-bindings: soc: amlogic,meson-gx-hhi-sysctrl: add example covering meson-axg-hhi-sysctrl 9556e1708419 ARM: dts: imx7s: Add DMA channels for CSPI peripherals c1e5b6c6855f arm64: dts: imx8mp-venice-gw72xx: add TPM device fc1ee0050ce4 arm64: dts: imx8mm-venice-gw72xx: add TPM device 5a125bf20bf1 arm64: dts: imx93: update anatop node 292fc296ecdd arm64: dts: imx93-11x11-evk: add 12 ms delay to make sure the VDD_SD power off b81451d8d4d3 arm64: dts: imx93: change tuning start to get a large scan range for standard tuning 7ee940495143 arm64: dts: imx93-11x11-evk: set SION for cmd and data pad of USDHC 1b2037987962 arm64: dts: imx8mp: Describe M24C32-D write-lockable page in DH i.MX8MP DHCOM DT 94d5d7d36ba8 ARM: dts: imx6ul: mba6ulx: fix typo in comments cbbed6036bfe ARM: dts: imx6qdl: mba6: fix typo in comments e6c50d6fd99e arm64: dts: imx8mp-beacon-kit: Enable DSI to HDMI Bridge 3743277142d0 arm64: dts: imx8mm: Add CCM interrupts 663758efb819 arm64: dts: imx8mn: Add CCM interrupts 88774bafda13 arm64: dts: imx8mp: Add CCM interrupts e4d9f4208c6c ARM: dts: imx7s: Add missing #thermal-sensor-cells e4c3f040fee6 ARM: dts: imx7s: Fix nand-controller #size-cells 62a7c97c7c3f ARM: dts: imx7s: Fix lcdif compatible 9f3037b332bf ARM: dts: imx7d: Fix coresight funnel ports d844fe5270b1 arm64: dts: freescale: add initial device tree for MBa93xxCA starter kit ad161fbd54ca arm64: dts: freescale: tqma9352-mba93xxla: add 'chassis-type' property 8ec09c8f530c arm64: dts: imx93: Configure clock rate for audio PLL 9d7ba48273ea arm64: dts: imx93: Add audio device nodes b1553710809c dt-bindings: iio: hmc425a: add entry for ADRF5740 Attenuator 471ace1f09be dt-bindings: gpio: brcmstb: drop unneeded quotes f8159413e6f1 ARM: dts: ti: keystone: minor whitespace cleanup around '=' 381a63044158 dt-bindings: clock: g12a-clkc: add MIPI ISP & CSI PHY clock ids c1ad3e49f07c dt-bindings: clk: g12a-clkc: add CTS_ENCL clock ids c8fb56a76774 dt-bindings: dma: qcom,gpi: document the SM8650 GPI DMA Engine 8e868f10ea21 dt-bindings: dma: rz-dmac: Document RZ/Five SoC e1504d7602c0 dt-bindings: net: qcom,ipa: add SM8550 compatible f118e169a194 dt-bindings: dma: qcom: gpi: add compatible for X1E80100 11518ff4d13c dt-bindings: pinctrl: qcom: Add X1E80100 pinctrl d3fe1008f0c8 ASoC: dt-bindings: correct white-spaces in examples f9b11918132f dt-bindings: crypto: convert Inside Secure SafeXcel to the json-schema 52b8a84c5283 dt-bindings: dma: ti: k3-udma: Describe cfg register regions 9b2e4fa1e7f2 dt-bindings: dma: ti: k3-pktdma: Describe cfg register regions 6d91e2a3766b dt-bindings: dma: ti: k3-bcdma: Describe cfg register regions ea1d92699d2a dt-bindings: dma: ti: k3-*: Add descriptions for register regions 7cf45f021d31 arm64: dts: exynosautov9: use Exynos7 fallbacks for pin wake-up controller dc0e2a7e69c2 arm64: dts: exynos850: use Exynos7 fallbacks for pin wake-up controllers 185cc3e40c9f dt-bindings: pinctrl: samsung: use Exynos7 fallbacks for newer wake-up controllers 54829849af39 Merge branch 'icc-x1e80100' into icc-next 8e2202f335a4 dt-bindings: interconnect: Add Qualcomm X1E80100 SoC 54f1f68e019b dt-bindings: interconnect: qcom-bwmon: document SM8650 BWMONs 4e7bf80ce812 dt-bindings: interconnect: document the RPMh Network-On-Chip Interconnect in Qualcomm SM8650 SoC 615397ecb02b Merge git://git.kernel.org/pub/scm/linux/kernel/git/netdev/net e673bd9cbb13 dt-bindings: serial: fsl-linflexuart: change the maintainer email address f79b00fe4cab dt-bindings: serial: renesas,sci: Document RZ/Five SoC 911d5cce2a4e Merge tag 'drm-misc-next-2023-11-23' of git://anongit.freedesktop.org/drm/drm-misc into drm-next ab1f350663b1 dt-bindings: power: rpmpd: Update part number to X1E80100 6fe8e1a8dc99 dt-bindings: backlight: mp3309c: Remove two required properties cc4e22233cb5 dt-bindings: usb: qcom,dwc3: adjust number of interrupts on SM6125 9161184d7271 dt-bindings: net: renesas,ethertsn: Add Ethernet TSN 788d52642da4 Merge tag 'v6.7-rc2' into media_stage d2975fb00035 dt-bindings: gpu: Add Imagination Technologies PowerVR/IMG GPU 59078ccb21d1 dt-bindings: usb: qcom,dwc3: document the SM8560 SuperSpeed DWC3 USB controller 627316c016dd dt-bindings: usb: renesas,usbhs: Document RZ/Five SoC 99b07ecabc3d dt-bindings: cache: sifive,ccache0: Add StarFive JH7100 compatible 0118ff6d8abd ASoC: dt-bindings: fsl,mqs: Convert format to json-schema 0a9a12593184 ASoC: dt-bindings: sound-card-common: List sound widgets ignoring system suspend 165648aad162 ARM: dts: stm32: add SPI support on STM32F746 8f3fa20269a0 ARM: dts: stm32: add STM32F746 syscfg clock dc50601ba2d8 dt-bindings: net: xlnx,axi-ethernet: Introduce DMA support 72d23e1de1b0 arm64: dts: imx8mp: Add reserve-memory nodes for DSP 9bab315d31f8 spi: axi-spi-engine improvements 23a75f159231 ARM: dts: stm32: use the same 3v3 for SD and DSI nodes on stm32f469-disco 4656437906e9 ARM: dts: rockchip: Make usbphy the parent of SCLK_USB480M for RK3128 25251d661471 ARM: dts: rockchip: Add dwc2 otg fifo siztes for RK3128 2d36fa2aa286 ARM: dts: rockchip: Add USB host clocks for RK3128 4e1bd401bbe3 ARM: dts: rockchip: Add Geniatech XPI-3128 RK3128 board 7e6458d9a7f3 ARM: dts: rockchip: Add sdmmc_det pinctrl for RK3128 12867f1ccb42 dt-bindings: arm: rockchip: Add Geniatech XPI-3128 fda729bcbd69 arm64: dts: rockchip: Add Powkiddy RK2023 317a36f59e1b arm64: dts: rockchip: Update powkiddy,rgb30 include to rk2023 DTSI dc9a81379af6 dt-bindings: arm: rockchip: Add Powkiddy RK2023 70a31fd9ffa3 dt-bindings: spi: axi-spi-engine: convert to yaml b68504144dbe Merge tag 'drm-misc-next-2023-11-17' of git://anongit.freedesktop.org/drm/drm-misc into drm-next 8260e721d1b5 dt-bindings: display: nv3051d: Update NewVision NV3051D compatibles 0a502f9716cc arm64: dts: renesas: rzg3s-smarc: Enable SDHI1 eccf7ee1aefe arm64: dts: renesas: rzg3s-smarc-som: Enable SDHI2 fbd14cd9ff35 ARM: dts: microchip: sam9x60ek: Add IRQ support for ethernet PHY c86d9749ca2a ARM: dts: microchip: sam9x60_curiosity: Add IRQ support for ethernet PHY 1e1f6887a01b arm64: dts: allwinner: h616: add Orange Pi Zero 2W support 5795c68b5edc dt-bindings: arm: sunxi: add Orange Pi Zero 2W a5b7fa02fbde dt-bindings: crypto: qcom,prng: document SM8650 53be5450f8ac dt-bindings: crypto: qcom-qce: document the SM8650 crypto engine e65dc233e98b dt-bindings: crypto: qcom,inline-crypto-engine: document the SM8650 ICE d2a2bd80cca6 dt-bindings: net: renesas,etheravb: Document RZ/Five SoC f491b5315b58 dt-bindings: Document Marvell Aquantia PHY 7b52e889e53f arm64: dts: rockchip: add analog audio to RK3588 EVB1 92de4720f37c spi: dt-bindings: renesas,rspi: Document RZ/Five SoC 6e54c4bd7590 ASoC: dt-bindings: renesas,rz-ssi: Document RZ/Five SoC 87bb03481662 dt-bindings: adis16460: Add 'spi-cs-inactive-delay-ns' property 91e2c8ceb4de dt-bindings: adis16475: Add 'spi-cs-inactive-delay-ns' property f9fe5526efd5 dt-bindings: iio: Add MCP9600 thermocouple EMF converter 9942ece9d870 dt-bindings: iio: imu: Add Bosch BMI323 49d380d6e152 dt-bindings: adc: provide max34408/9 device tree binding document 895869158303 dt-bindings: media: wave5: add yaml devicetree bindings 77bf61c28407 dt-bindings: arm: Add support for DSB MSR register 18adf91da0ca dt-bindings: arm: Add support for DSB element size 075ac55ca93b dt-bindings: phy: qcom,snps-eusb2: document the SM8650 Synopsys eUSB2 PHY fda8409f7058 dt-bindings: phy: qcom,sc8280xp-qmp-usb43dp-phy: document the SM8650 QMP USB/DP Combo PHY b0b6815d9143 dt-bindings: phy: qcom,sc8280xp-qmp-pcie-phy: document the SM8650 QMP PCIe PHYs db24b834638a dt-bindings: phy: qcom,sc8280xp-qmp-ufs-phy: document the SM8650 QMP UFS PHY 6a737e056a8b media: dt-bindings: Add JH7110 Camera Subsystem 716cbea9d35a dt-bindings: power: reset: $ref reboot-mode in nvmem-reboot-mode c8dedfdf167b dt-bindings: power: reset: $ref reboot-mode in syscon-reboot-mode 6c14a95472bb ARM: dts: samsung: s5pv210: fix camera unit addresses/ranges 866767db6bbb ARM: dts: samsung: exynos4: fix camera unit addresses/ranges f0d3848e2cef ARM: dts: samsung: exynos4x12: replace duplicate pmu node with phandle dc6ff9889013 dt-bindings: w1: Add AMD AXI w1 host and MAINTAINERS entry a8a9188e96a6 dt-bindings: power: fsl,scu-pd: Document imx8dl f06b78172daa dt-bindings: qcom,pdc: Add compatible for SM8550 7a87643120eb dt-bindings: input: samsung,s6sy761: convert to DT schema e4ccdd770c53 Merge branch 'for-v6.8/samsung-bindings-compatibles' into next/dt64 7b213bd80e13 dt-bindings: hwinfo: samsung,exynos-chipid: add exynosautov920 compatible 892b87e000d2 dt-bindings: arm: samsung: Document exynosautov920 SADK board binding ce1b89aee7ea dt-bindings: pwm: samsung: add exynosautov920 compatible 5e6bd42714ad dt-bindings: serial: samsung: add exynosautov920-uart compatible 3ea12f0eff84 dt-bindings: samsung: usi: add exynosautov920-usi compatible 5b6e042a72b8 dt-bindings: samsung: exynos-pmu: add exynosautov920 compatible 2dff85192843 dt-bindings: samsung: exynos-sysreg: add exynosautov920 sysreg 3123103c12c0 dt-bindings: pinctrl: samsung: add exynosautov920 5b929ffdc9be arm64: dts: exynos: add gpio-key node for exynosautov9-sadk 6bc5effbe8dd arm64: dts: exynosautov9: add specific compatibles to several blocks 25addf827769 arm64: dts: exynos850: add specific compatibles to several blocks 5ab70c11f08f arm64: dts: exynos7885: add specific compatibles to several blocks f7c77a1ea95a arm64: dts: exynos7: add specific compatibles to several blocks 56493af64c01 arm64: dts: exynos5433: add specific compatibles to several blocks 3530786802b6 dt-bindings: pwm: samsung: add specific compatibles for existing SoC 97419692fe3c ASoC: dt-bindings: samsung-i2s: add specific compatibles for existing SoC 7081448ca2cf dt-bindings: iio: samsung,exynos-adc: add specific compatibles for existing SoC 973115e1f51f dt-bindings: gpu: arm,mali-midgard: add specific compatibles for existing Exynos SoC 6b99281097f0 dt-bindings: samsung: exynos-pmu: add specific compatibles for existing SoC a893a294345b dt-bindings: serial: samsung: add specific compatibles for existing SoC 2a3d0691d56f dt-bindings: rtc: s3c-rtc: add specific compatibles for existing SoC 7e49408d51e6 dt-bindings: pinctrl: samsung: add specific compatibles for existing SoC 1bb1eca74ad5 Merge drm/drm-next into drm-misc-next e9731895ee20 dt-bindings: mmc: samsung,exynos-dw-mshc: add specific compatibles for existing SoC 33b5aa8f7d9a ARM: dts: qcom: mdm9615: drop qcom, prefix from SSBI node name fa1f536e3df0 ARM: dts: qcom: ipq8064: drop qcom, prefix from SSBI node name 4e5382dc8820 ARM: dts: qcom: apq8060-dragonboard: rename mpp ADC channels to adc-channel 6be6ba7888ef ARM: dts: qcom: pm8921: Disable keypad by default 5917ae72cd70 ARM: dts: qcom: msm8974: move regulators to board files 551cbcd2547c ARM: dts: qcom: msm8960: drop useless rpm regulators node 6d9878cc6a6a ARM: dts: qcom: msm8660: move RPM regulators to board files d0ed11e33ba0 ARM: dts: qcom: mdm9615: move RPM regulators to board files 1c636116afea ARM: dts: qcom: apq8064: move RPM regulators to board files b9d11fecae9e ARM: dts: qcom: pm8058: switch to interrupts-extended e8a26b432fd4 ARM: dts: qcom: pm8018: switch to interrupts-extended 86831cb445f6 ARM: dts: qcom: pm8921: switch to interrupts-extended 6d6c0b95e077 ARM: dts: qcom: pm8058: use defined IRQ flags 9d0903209824 ARM: dts: qcom: pm8921: move reg property 6a63db48b660 ARM: dts: qcom: pm8018: move reg property 9d6af1dd4790 ARM: dts: qcom: pm8921: reorder nodes 5db5515193a6 ARM: dts: qcom: pm8058: reorder nodes d4df6f1babb5 ARM: dts: qcom: msm8660: split PMIC to separate dtsi files c56480ffb4b8 ARM: dts: qcom: mdm9615: split PMIC to separate dtsi files f8574d2c7c62 ARM: dts: qcom: apq8064: split PMICs to separate dtsi files 298695290d90 ARM: dts: qcom: msm8960: split PMIC to separate dtsi files 1c3c930ec46c ARM: dts: qcom: msm8960: move PMIC interrupts to the board files 7f5541db889f ARM: dts: qcom: msm8660: move PMIC interrupts to the board files 812cfe71b26a ARM: dts: qcom: mdm9615: move PMIC interrupts to the board files f5c8a18b7116 ARM: dts: qcom: apq8064: move PMIC interrupts to the board files b7510b8da2f6 ARM: dts: qcom: msm8960: fix PMIC node labels 6475671dcca1 ARM: dts: qcom: msm8660: fix PMIC node labels 4dfac4d841ef ARM: dts: qcom: mdm9615: fix PMIC node labels 07091c1b87fb ARM: dts: qcom: apq8064: fix PMIC node labels 155004433670 ARM: dts: qcom: strip prefix from PMIC files 21220b16b281 ARM: dts: qcom: mdm9615-wp8548-mangoh-green: group include clauses 3d3f8059a9f6 ARM: dts: qcom: apq8064-nexus7: move sdcc1 node to proper place b9d136b033b8 ARM: dts: qcom: msm8660-surf: use keypad label directly fc4f79da1abe ARM: dts: qcom: msm8960: introduce label for PMIC keypad 0e33f3448e7c ARM: dts: qcom: apq8064: correct XOADC register address 9bed8b24890a ARM: dts: qcom-sdx65: switch USB QMP PHY to new style of bindings edfbe32172f4 ARM: dts: qcom-sdx55: switch USB QMP PHY to new style of bindings c709366fb89e arm64: dts: qcom: sm8350: switch USB QMP PHY to new style of bindings 29a99a6d955d arm64: dts: qcom: sm8250: switch USB QMP PHY to new style of bindings e13f8dc0ea91 arm64: dts: qcom: sm8150: switch USB QMP PHY to new style of bindings bed6aed8ceec arm64: dts: qcom: sdm845: switch USB QMP PHY to new style of bindings 7cb8dff829b0 arm64: dts: qcom: msm8998: switch USB QMP PHY to new style of bindings 77a8ce42cb30 arm64: dts: qcom: msm8996: switch USB QMP PHY to new style of bindings b92a18870b3e arm64: dts: qcom: ipq8074: switch USB QMP PHY to new style of bindings 18dd153b1c8f arm64: dts: qcom: ipq6018: switch USB QMP PHY to new style of bindings ad3769d7933c Merge tag 'qcom-arm64-for-6.7-2' into arm64-for-6.8 8088e683c89b dt-bindings: i2c: samsung,s3c2410-i2c: add specific compatibles for existing SoC c15df41a0c35 dt-bindings: i2c: exynos5: add specific compatibles for existing SoC d755df63e9df dt-bindings: hwinfo: samsung,exynos-chipid: add specific compatibles for existing SoC 6f4cb3f40711 arm64: dts: renesas: rzg2lc-smarc-som: Enable 4-bit tx support 5ddba1791b2b arm64: dts: renesas: rzg2l-smarc-som: Enable 4-bit tx support 75b8e7f58abe regulator: add under-voltage support (part 2) 791f1550a798 Add DMIC slew rate controls e128625eb7cb dt-bindings: pinctrl: document the SM8650 Top Level Mode Multiplexer c3c85cc965c8 dt-bindings: pinctrl: qcom,sm8650-lpass-lpi-pinctrl: add SM8650 LPASS 6da3c9fd1509 ARM: dts: renesas: marzen: Rename keyboard nodes 2d7a77894ba8 ARM: dts: renesas: iwg22d-sodimm: Fix stmpe node names f4c62eb4fbd6 arm64: dts: renesas: Add missing ADV751[13] power supply properties a94c426db9b8 ARM: dts: renesas: Add missing ADV751[13] power supply properties f213adc3b192 ARM: dts: renesas: rcar-gen2: Fix I2C bus demux node names 127c56414e9f riscv: dts: renesas: Convert isa detection to new properties 9836c1c69324 ARM: dts: renesas: blanche: Add FLASH node d446795daa00 ARM: dts: renesas: marzen: Add FLASH node 9a4a8a78013a spi: add stm32f7-spi compatible e74e9793f9c7 regulator: dt-bindings: Add 'regulator-uv-less-critical-window-ms' property eafbf4f37d51 regulator: dt-bindings: Allow system-critical marking for fixed-regulator 52381ed5b4ac regulator: dt-bindings: Add system-critical-regulator property ec8f058714a6 dt-bindings: regulator: qcom,smd-rpm-regulator: Document PM8937 IC cf118cc80e89 dt-bindings: regulator: qcom,spmi-regulator: Document PM8937 PMIC 2ae471b5eeb2 ASoC: dt-bindings: use "soundwire" as controller's node name in examples caa17228e281 ASoC: dt-bindings: qcom,sm8250: add SM8550 sound card 2d2f997a2bdc dt-bindings: es8328: convert to DT schema format 68e113702391 ASoC: dt-bindings: Simplify port schema eac536a576c7 ASoC: dt-bindings: nau8821: Add DMIC slew rate. 409f501ee9b2 dt-bindings: gpu: v3d: Add BCM2712's compatible 22f7441e8685 dt-bindings: display: ssd132x: Remove '-' before compatible enum a3de98e60ec5 ARM: dts: qcom: add device tree for Nokia Lumia 830 9ad6bcd4499d ARM: dts: qcom: add device tree for Nokia Lumia 735 41ee9ea2aefd ARM: dts: qcom: add device tree for Microsoft Lumia 640 XL 0dc127c0d612 ARM: dts: qcom: add device tree for Microsoft Lumia 640 d30c995f440e ARM: dts: qcom: add common dt for MSM8x26 Lumias along with Nokia Lumia 630 ed92546211d5 dt-bindings: arm: qcom: Document MSM8x26-based Lumia phones d783936fa1dc arm64: dts: qcom: msm8939-longcheer-l9100: Enable RGB LED b14cb550d720 arm64: dts: qcom: msm8916-longcheer-l8910: Enable RGB LED 183a2f447424 arm64: dts: qcom: msm8939-samsung-a7: Add sound and modem 9b7d68606781 arm64: dts: qcom: msm8916-samsung-j5: Add sound and modem f382f197e0c5 arm64: dts: qcom: msm8916-samsung-gt5: Add sound and modem 59a815c1572d arm64: dts: qcom: msm8916-longcheer-l8910: Add sound and modem 582b4cfec9a9 ARM: dts: qcom: msm8226: provide dsi phy clocks to mmcc 1703230be2a6 ARM: dts: qcom: msm8974: sort nodes by reg e23f302820cb ARM: dts: qcom: msm8974: replace incorrect indentation in interconnect 373015625e6b arm64: dts: qcom: msm8916-longcheer-l8150: Add sound and modem c1a66861dc32 arm64: dts: qcom: msm8916-asus-z00l: Add sound and modem 489f91f0dfcc arm64: dts: qcom: msm8916-alcatel-idol347: Add sound and modem 2f81e02a3b04 arm64: dts: qcom: msm8916-wingtech-wt88047: Add sound and modem 07047876d71e arm64: dts: qcom: msm8916-samsung-serranove: Add sound and modem 1d94420f32b0 arm64: dts: qcom: msm8916-samsung-a2015: Add sound and modem 9334b10d351c arm64: dts: qcom: msm8916: Add common msm8916-modem-qdsp6.dtsi 30b857e0f639 arm64: dts: qcom: msm8939: Add QDSP6 5b210c47425a arm64: dts: qcom: msm8916: Add QDSP6 f1aed61c2c48 arm64: dts: qcom: msm8939: Add BAM-DMUX WWAN 702f57c12856 arm64: dts: qcom: sc8280xp-x13s: add missing camera LED pin config d21fc2d89cfd arm64: dts: qcom: pm7250b: Use correct node name for gpios ecc4cb08c0f3 arm64: dts: qcom: sc7280: Add Camera Control Interface busses c01ef95e3aa7 arm64: dts: qcom: sdm845-xiaomi-beryllium: enable flash led fe3ccb41dafa arm64: dts: qcom: sdm845-oneplus: enable flash LED 0f6538f89c64 arm64: dts: qcom: sc8280xp-x13s: Use the correct DP PHY compatible c9e8e85b1afd arm64: dts: qcom: msm8916-*: Fix alphabetic node order 9e38e840740d arm64: dts: qcom: msm8939-longcheer-l9100: Enable wcnss_mem 5cdb05e593ef arm64: dts: qcom: msm8916-samsung-gt5: Enable GPU 0d72dfbbf352 arm64: dts: qcom: ipq5332: include the GPLL0 as clock provider for mailbox 13c545bfe884 arm64: dts: qcom: ipq9574: include the GPLL0 as clock provider for mailbox 8b57686e7ad0 arm64: dts: qcom: ipq6018: include the GPLL0 as clock provider for mailbox 11d8f7a1bf44 arm64: dts: qcom: ipq8074: include the GPLL0 as clock provider for mailbox 9b0b036ea0de arm64: dts: qcom: ipq9574: populate the opp table based on the eFuse f3636ba1edce arm64: dts: qcom: ipq5332: populate the opp table based on the eFuse 8831b26a6579 arm64: dts: qcom: sdm670: add specific cpufreq compatible 8ce87f299cdb arm64: dts: qcom: sm8150: extend the size of the PDC resource b3cbe4ff9c30 arm64: dts: qcom: ipq5018: add QUP1 SPI controller f330c2991aa0 arm64: dts: qcom: qrb4210-rb2: don't force usb peripheral mode daa68cbafb06 arm64: dts: qcom: Enable tsens and thermal for sa8775p SoC 6232143457ae arm64: dts: qcom: sa8775p: Add RPMh sleep stats 973959c2edf1 arm64: dts: qcom: sc7280: Add ports subnodes in usb/dp qmpphy node 4c021a56b758 arm64: dts: qcom: sm6375-pdx225: Add USBPHY regulators 6fb033b4f60e arm64: dts: qcom: sm6375-pdx225: Enable ATH10K WiFi fa14ce25949b arm64: dts: qcom: sm6375-pdx225: Enable MSS e77ac5cceb8e arm64: dts: qcom: sm6375: Add UART1 dec2e7998de5 arm64: dts: qcom: ipq9574: Enable WPS buttons d3619641203e arm64: dts: qcom: ipq9574: Add common RDP dtsi file 9faa71835343 arm64: dts: qcom: ipq5018: Enable USB 71275274da1f arm64: dts: qcom: ipq5018: Add USB related nodes af8b25f21479 arm64: dts: qcom: sc7280: add TRNG node 00e1b06bb47a arm64: dts: qcom: sa8775p: add TRNG node ac7c5d2655a7 arm64: dts: qcom: sm8450: add TRNG node 0087dcd6513a arm64: dts: qcom: sm8550: add TRNG node
git-subtree-dir: dts/upstream git-subtree-split: b35b9bd1d4eed2acf8bc38ec5b1b6eef6261b4f0 --- Cc: Apurva Nandan a-nandan@ti.com Cc: Beniamino Galvani b.galvani@gmail.com Cc: Bryan Brattlof bb@ti.com Cc: Neil Armstrong neil.armstrong@linaro.org Cc: Tim Harvey tharvey@gateworks.com Cc: Vignesh Raghavendra vigneshr@ti.com Cc: u-boot-amlogic@groups.io
This commit moves OF_UPSTREAM platforms to the v6.8-dts tag. The patch itself isn't directly testable I think, and too huge to email regardless. The tree exists at: https://github.com/trini/u-boot/tree/WIP/29Mar2024-next and will for at least a few days before I merge this, if anyone wants to run-time test the changes. I'm still doing a world build before/after to see if any changes are visible that way. The CC list here was made by using "tools/qconfig.py -b" and then "tools/qconfig.py -f OF_UPSTREAM" and get_maintainer.pl on the defconfigs for the platforms that listed. If I'm missing maintainers of platforms using OF_UPSTREAM, I'm open to ideas on what to do next go-round.
Bindings/Makefile | 5 +- Bindings/arm/calxeda/l2ecc.yaml | 2 +- Bindings/arm/cpus.yaml | 1 + Bindings/arm/fsl.yaml | 22 +- Bindings/arm/google.yaml | 53 + .../arm/hisilicon/controller/sysctrl.yaml | 17 + Bindings/arm/marvell/armada-7k-8k.yaml | 22 + Bindings/arm/mediatek.yaml | 25 + Bindings/arm/mediatek/mediatek,audsys.txt | 39 - Bindings/arm/mediatek/mediatek,audsys.yaml | 153 + Bindings/arm/mediatek/mediatek,ethsys.txt | 29 - Bindings/arm/mediatek/mediatek,infracfg.yaml | 1 + Bindings/arm/mediatek/mediatek,mmsys.yaml | 3 + Bindings/arm/mediatek/mediatek,pericfg.yaml | 1 + Bindings/arm/msm/qcom,idle-state.txt | 84 - Bindings/arm/qcom,coresight-remote-etm.yaml | 51 + Bindings/arm/qcom,coresight-tpdm.yaml | 20 + Bindings/arm/qcom-soc.yaml | 16 +- Bindings/arm/qcom.yaml | 47 +- Bindings/arm/rockchip.yaml | 56 +- Bindings/arm/samsung/samsung-boards.yaml | 6 + Bindings/arm/sprd/sprd.yaml | 5 + Bindings/arm/stm32/stm32.yaml | 16 +- Bindings/arm/sunxi.yaml | 10 + Bindings/arm/ti/k3.yaml | 2 + Bindings/arm/ti/omap.yaml | 2 + Bindings/ata/ceva,ahci-1v84.yaml | 3 +- Bindings/auxdisplay/hit,hd44780.yaml | 2 +- Bindings/cache/qcom,llcc.yaml | 5 +- Bindings/cache/sifive,ccache0.yaml | 6 +- Bindings/clock/baikal,bt1-ccu-pll.yaml | 2 +- Bindings/clock/brcm,kona-ccu.txt | 138 - Bindings/clock/brcm,kona-ccu.yaml | 181 + Bindings/clock/fsl,imx93-anatop.yaml | 42 + Bindings/clock/google,gs101-clock.yaml | 106 + Bindings/clock/hi3620-clock.txt | 20 - Bindings/clock/mediatek,apmixedsys.yaml | 1 + Bindings/clock/mediatek,ethsys.yaml | 55 + Bindings/clock/mediatek,mt7988-ethwarp.yaml | 52 + Bindings/clock/mediatek,mt7988-xfi-pll.yaml | 48 + Bindings/clock/mediatek,mt8188-clock.yaml | 2 - Bindings/clock/mediatek,topckgen.yaml | 2 + Bindings/clock/qcom,a53pll.yaml | 1 + Bindings/clock/qcom,camcc-sm8250.yaml | 18 +- Bindings/clock/qcom,gcc-ipq6018.yaml | 57 + Bindings/clock/qcom,gcc-ipq8074.yaml | 4 + Bindings/clock/qcom,gcc-other.yaml | 3 - Bindings/clock/qcom,qdu1000-ecpricc.yaml | 68 + Bindings/clock/qcom,rpmhcc.yaml | 2 + Bindings/clock/qcom,sc7180-camcc.yaml | 18 +- Bindings/clock/qcom,sc7280-camcc.yaml | 18 +- Bindings/clock/qcom,sdm845-camcc.yaml | 18 +- Bindings/clock/qcom,sm8450-camcc.yaml | 20 +- Bindings/clock/qcom,sm8450-gpucc.yaml | 2 + Bindings/clock/qcom,sm8550-tcsr.yaml | 8 +- Bindings/clock/qcom,sm8650-dispcc.yaml | 106 + Bindings/clock/qcom,sm8650-gcc.yaml | 65 + Bindings/clock/qcom,x1e80100-gcc.yaml | 72 + Bindings/clock/renesas,9series.yaml | 10 + Bindings/clock/silabs,si5351.txt | 126 - Bindings/clock/silabs,si5351.yaml | 265 + Bindings/clock/sophgo,cv1800-clk.yaml | 46 + Bindings/clock/st,stm32mp25-rcc.yaml | 76 + Bindings/clock/xlnx,clocking-wizard.yaml | 1 + Bindings/clock/xlnx,versal-clk.yaml | 31 +- Bindings/connector/usb-connector.yaml | 124 +- Bindings/cpu/idle-states.yaml | 81 +- Bindings/crypto/inside-secure,safexcel.yaml | 86 + Bindings/crypto/inside-secure-safexcel.txt | 40 - .../crypto/qcom,inline-crypto-engine.yaml | 1 + Bindings/crypto/qcom,prng.yaml | 1 + Bindings/crypto/qcom-qce.yaml | 14 + Bindings/display/bridge/lontium,lt8912b.yaml | 21 + Bindings/display/bridge/nxp,tda998x.yaml | 7 +- Bindings/display/mediatek/mediatek,aal.yaml | 1 + Bindings/display/mediatek/mediatek,color.yaml | 1 + Bindings/display/mediatek/mediatek,dsi.yaml | 4 + Bindings/display/mediatek/mediatek,ethdr.yaml | 6 +- .../display/mediatek/mediatek,mdp-rdma.yaml | 88 - Bindings/display/mediatek/mediatek,merge.yaml | 4 + Bindings/display/mediatek/mediatek,ovl.yaml | 1 + .../display/mediatek/mediatek,padding.yaml | 83 + Bindings/display/mediatek/mediatek,split.yaml | 27 + Bindings/display/msm/dp-controller.yaml | 2 + Bindings/display/msm/dsi-controller-main.yaml | 3 + Bindings/display/msm/dsi-phy-7nm.yaml | 1 + Bindings/display/msm/mdss-common.yaml | 18 +- Bindings/display/msm/qcom,qcm2290-mdss.yaml | 21 +- Bindings/display/msm/qcom,sc7180-mdss.yaml | 14 +- Bindings/display/msm/qcom,sc7280-mdss.yaml | 14 +- Bindings/display/msm/qcom,sdm670-mdss.yaml | 292 + Bindings/display/msm/qcom,sdm845-dpu.yaml | 4 +- Bindings/display/msm/qcom,sm6115-mdss.yaml | 10 + Bindings/display/msm/qcom,sm6125-mdss.yaml | 8 +- Bindings/display/msm/qcom,sm6350-mdss.yaml | 8 +- Bindings/display/msm/qcom,sm6375-mdss.yaml | 8 +- Bindings/display/msm/qcom,sm8150-mdss.yaml | 6 +- Bindings/display/msm/qcom,sm8250-mdss.yaml | 10 + Bindings/display/msm/qcom,sm8450-mdss.yaml | 13 +- Bindings/display/msm/qcom,sm8650-dpu.yaml | 127 + Bindings/display/msm/qcom,sm8650-mdss.yaml | 328 + .../display/panel/fascontek,fs035vg158.yaml | 56 + Bindings/display/panel/himax,hx8394.yaml | 3 + Bindings/display/panel/ilitek,ili9805.yaml | 62 + Bindings/display/panel/ilitek,ili9881c.yaml | 1 + .../display/panel/leadtek,ltk035c5444t.yaml | 8 +- Bindings/display/panel/newvision,nv3051d.yaml | 2 +- .../panel/panel-simple-lvds-dual-ports.yaml | 2 + Bindings/display/panel/panel-simple.yaml | 4 + Bindings/display/panel/sitronix,st7701.yaml | 1 + Bindings/display/panel/synaptics,r63353.yaml | 61 + .../display/rockchip/inno_hdmi-rockchip.txt | 49 - .../display/rockchip/rockchip,inno-hdmi.yaml | 139 + Bindings/display/rockchip/rockchip-vop2.yaml | 100 +- .../display/samsung/samsung,exynos-mixer.yaml | 6 +- Bindings/display/ti/ti,am65x-dss.yaml | 14 + Bindings/dma/dma-controller.yaml | 15 - Bindings/dma/dma-router.yaml | 11 - Bindings/dma/loongson,ls2x-apbdma.yaml | 62 + Bindings/dma/nvidia,tegra210-adma.yaml | 3 + Bindings/dma/qcom,gpi.yaml | 2 + Bindings/dma/renesas,rz-dmac.yaml | 2 +- Bindings/dma/sifive,fu540-c000-pdma.yaml | 1 + Bindings/dma/ti/k3-bcdma.yaml | 39 +- Bindings/dma/ti/k3-pktdma.yaml | 26 +- Bindings/dma/ti/k3-udma.yaml | 20 +- Bindings/dts-coding-style.rst | 196 + Bindings/eeprom/at24.yaml | 1 + Bindings/firmware/qcom,scm.yaml | 18 +- .../firmware/xilinx/xlnx,zynqmp-firmware.yaml | 4 +- Bindings/fpga/altera-fpga2sdram-bridge.txt | 13 - Bindings/fpga/altera-freeze-bridge.txt | 20 - Bindings/fpga/altera-hps2fpga-bridge.txt | 36 - .../fpga/altr,freeze-bridge-controller.yaml | 41 + .../fpga/altr,socfpga-fpga2sdram-bridge.yaml | 33 + .../fpga/altr,socfpga-hps2fpga-bridge.yaml | 49 + Bindings/fpga/fpga-bridge.txt | 13 - Bindings/fpga/fpga-bridge.yaml | 30 + Bindings/fpga/xlnx,pr-decoupler.yaml | 5 +- Bindings/gnss/u-blox,neo-6m.yaml | 6 + Bindings/gpio/brcm,brcmstb-gpio.yaml | 2 +- Bindings/gpio/nuvoton,sgpio.yaml | 87 + Bindings/gpio/realtek,rtd-gpio.yaml | 69 + Bindings/gpio/rockchip,gpio-bank.yaml | 7 + Bindings/gpio/snps,dw-apb-gpio.yaml | 2 + Bindings/gpio/xlnx,gpio-xilinx.yaml | 2 +- Bindings/gpio/xlnx,zynqmp-gpio-modepin.yaml | 6 +- Bindings/gpu/arm,mali-midgard.yaml | 5 + Bindings/gpu/arm,mali-utgard.yaml | 1 + Bindings/gpu/brcm,bcm-v3d.yaml | 1 + Bindings/gpu/img,powervr.yaml | 73 + Bindings/gpu/samsung-g2d.yaml | 71 +- Bindings/gpu/samsung-rotator.yaml | 9 +- Bindings/gpu/samsung-scaler.yaml | 81 +- Bindings/hwinfo/samsung,exynos-chipid.yaml | 18 +- Bindings/hwmon/gpio-fan.txt | 41 - Bindings/hwmon/gpio-fan.yaml | 60 + Bindings/hwmon/iio-hwmon.yaml | 2 +- Bindings/hwmon/lltc,ltc4286.yaml | 50 + Bindings/hwmon/lm75.yaml | 33 + Bindings/i2c/i2c-exynos5.yaml | 11 +- Bindings/i2c/samsung,s3c2410-i2c.yaml | 22 +- Bindings/i2c/st,stm32-i2c.yaml | 28 + Bindings/iio/adc/adi,ad7091r5.yaml | 82 +- Bindings/iio/adc/adi,ad7780.yaml | 6 +- Bindings/iio/adc/maxim,max34408.yaml | 139 + Bindings/iio/adc/qcom,spmi-iadc.yaml | 10 +- Bindings/iio/adc/qcom,spmi-rradc.yaml | 4 +- Bindings/iio/adc/qcom,spmi-vadc.yaml | 9 +- Bindings/iio/adc/samsung,exynos-adc.yaml | 29 +- Bindings/iio/adc/ti,palmas-gpadc.yaml | 15 - Bindings/iio/amplifiers/adi,hmc425a.yaml | 4 + Bindings/iio/chemical/aosong,ags02ma.yaml | 47 + Bindings/iio/dac/adi,ad5791.yaml | 5 + Bindings/iio/dac/microchip,mcp4821.yaml | 86 + Bindings/iio/humidity/ti,hdc3020.yaml | 55 + Bindings/iio/imu/adi,adis16460.yaml | 4 + Bindings/iio/imu/adi,adis16475.yaml | 4 + Bindings/iio/imu/bosch,bmi323.yaml | 77 + Bindings/iio/light/liteon,ltr390.yaml | 56 + Bindings/iio/light/vishay,veml6075.yaml | 39 + Bindings/iio/pressure/honeywell,hsc030pa.yaml | 142 + .../iio/pressure/honeywell,mprls0025pa.yaml | 2 - .../iio/temperature/melexis,mlx90632.yaml | 19 +- .../iio/temperature/microchip,mcp9600.yaml | 70 + Bindings/index.rst | 1 + Bindings/input/adafruit,seesaw-gamepad.yaml | 63 + Bindings/input/elan,ekth6915.yaml | 5 +- Bindings/input/gpio-keys.yaml | 41 +- Bindings/input/gpio-mouse.txt | 32 - Bindings/input/gpio-mouse.yaml | 68 + Bindings/input/iqs269a.yaml | 98 +- Bindings/input/mediatek,pmic-keys.yaml | 24 +- Bindings/input/microchip,cap11xx.yaml | 80 +- Bindings/input/sprd,sc27xx-vibrator.yaml | 19 +- Bindings/input/ti,drv2665.txt | 17 - Bindings/input/ti,drv2667.txt | 17 - Bindings/input/ti,drv266x.yaml | 50 + .../input/touchscreen/neonode,zforce.yaml | 72 + .../input/touchscreen/samsung,s6sy761.txt | 32 - .../input/touchscreen/samsung,s6sy761.yaml | 54 + Bindings/input/touchscreen/zforce_ts.txt | 34 - Bindings/interconnect/qcom,msm8998-bwmon.yaml | 4 + Bindings/interconnect/qcom,sm6115.yaml | 152 + Bindings/interconnect/qcom,sm8650-rpmh.yaml | 136 + Bindings/interconnect/qcom,x1e80100-rpmh.yaml | 83 + .../loongson,liointc.yaml | 18 +- Bindings/interrupt-controller/qcom,mpm.yaml | 54 +- Bindings/interrupt-controller/qcom,pdc.yaml | 4 + .../renesas,rzg2l-irqc.yaml | 5 +- .../sifive,plic-1.0.0.yaml | 1 + .../st,stih407-irq-syscfg.yaml | 4 +- Bindings/iommu/apple,dart.yaml | 1 + Bindings/iommu/arm,smmu.yaml | 77 +- Bindings/iommu/rockchip,iommu.yaml | 11 +- Bindings/leds/allwinner,sun50i-a100-ledc.yaml | 137 + Bindings/leds/awinic,aw200xx.yaml | 95 +- Bindings/leds/backlight/mps,mp3309c.yaml | 10 +- Bindings/leds/common.yaml | 2 +- Bindings/leds/qcom,spmi-flash-led.yaml | 4 +- Bindings/loongarch/cpus.yaml | 61 + Bindings/loongarch/loongson.yaml | 34 + Bindings/mailbox/qcom,apcs-kpss-global.yaml | 62 +- Bindings/mailbox/qcom-ipcc.yaml | 1 + Bindings/mailbox/xlnx,zynqmp-ipi-mailbox.yaml | 132 +- Bindings/media/cnm,wave521c.yaml | 61 + .../media/i2c/alliedvision,alvium-csi2.yaml | 81 + Bindings/media/i2c/asahi-kasei,ak7375.yaml | 4 +- Bindings/media/i2c/galaxycore,gc0308.yaml | 108 + Bindings/media/i2c/galaxycore,gc2145.yaml | 113 + Bindings/media/i2c/ov8856.yaml | 24 +- Bindings/media/i2c/ovti,ov64a40.yaml | 103 + Bindings/media/i2c/sony,imx335.yaml | 13 + Bindings/media/i2c/techwell,tw9900.yaml | 137 + Bindings/media/i2c/thine,thp7312.yaml | 224 + Bindings/media/mediatek,mdp3-fg.yaml | 61 + Bindings/media/mediatek,mdp3-hdr.yaml | 61 + Bindings/media/mediatek,mdp3-rdma.yaml | 104 +- Bindings/media/mediatek,mdp3-rsz.yaml | 6 +- Bindings/media/mediatek,mdp3-stitch.yaml | 61 + Bindings/media/mediatek,mdp3-tcc.yaml | 62 + Bindings/media/mediatek,mdp3-tdshp.yaml | 61 + Bindings/media/mediatek,mdp3-wrot.yaml | 29 +- Bindings/media/rockchip-isp1.yaml | 11 +- Bindings/media/samsung,s5p-mfc.yaml | 47 +- Bindings/media/st,stm32-dcmipp.yaml | 89 + Bindings/media/starfive,jh7110-camss.yaml | 180 + Bindings/mfd/ams,as3711.yaml | 223 + Bindings/mfd/as3711.txt | 73 - Bindings/mfd/hisilicon,hi6421-spmi-pmic.yaml | 140 +- Bindings/mfd/qcom,pm8008.yaml | 6 +- Bindings/mfd/qcom,spmi-pmic.yaml | 7 + Bindings/mfd/qcom,tcsr.yaml | 2 + Bindings/mfd/samsung,exynos5433-lpass.yaml | 2 +- Bindings/mfd/sprd,ums512-glbreg.yaml | 4 +- Bindings/mfd/ti,am3359-tscadc.yaml | 2 - Bindings/misc/fsl,dpaa2-console.yaml | 2 +- Bindings/mmc/arasan,sdhci.yaml | 8 +- Bindings/mmc/arm,pl18x.yaml | 2 +- Bindings/mmc/brcm,sdhci-brcmstb.yaml | 4 +- Bindings/mmc/marvell,xenon-sdhci.yaml | 4 +- Bindings/mmc/mtk-sd.yaml | 9 + Bindings/mmc/renesas,sdhi.yaml | 2 +- Bindings/mmc/samsung,exynos-dw-mshc.yaml | 25 +- Bindings/mmc/sdhci-msm.yaml | 2 + Bindings/mmc/sdhci-pxa.yaml | 4 +- Bindings/mmc/snps,dwcmshc-sdhci.yaml | 1 + Bindings/mmc/synopsys-dw-mshc.yaml | 4 + Bindings/mtd/partitions/u-boot.yaml | 2 +- Bindings/net/dsa/dsa.yaml | 6 + Bindings/net/dsa/marvell,mv88e6060.yaml | 88 + Bindings/net/dsa/marvell,mv88e6xxx.yaml | 337 + Bindings/net/dsa/marvell.txt | 109 - Bindings/net/dsa/microchip,ksz.yaml | 34 +- Bindings/net/ethernet-switch.yaml | 23 +- Bindings/net/lantiq,pef2256.yaml | 213 + Bindings/net/marvell,aquantia.yaml | 116 + Bindings/net/marvell,mvusb.yaml | 7 +- Bindings/net/marvell,orion-mdio.yaml | 22 - Bindings/net/marvell,prestera.yaml | 4 +- Bindings/net/pcs/mediatek,sgmiisys.yaml | 65 +- Bindings/net/qcom,ipa.yaml | 24 +- Bindings/net/renesas,etheravb.yaml | 3 +- Bindings/net/renesas,ethertsn.yaml | 135 + Bindings/net/sff,sfp.yaml | 2 +- Bindings/net/xlnx,axi-ethernet.yaml | 16 + Bindings/nvmem/st,stm32-romem.yaml | 1 + Bindings/pci/brcm,stb-pcie.yaml | 18 + Bindings/pci/qcom,pcie.yaml | 63 +- Bindings/pci/rcar-pci-host.yaml | 11 + Bindings/pci/rockchip-dw-pcie.yaml | 2 + Bindings/pci/ti,j721e-pci-ep.yaml | 39 +- Bindings/pci/ti,j721e-pci-host.yaml | 39 +- Bindings/pci/toshiba,visconti-pcie.yaml | 2 +- Bindings/perf/fsl-imx-ddr.yaml | 3 + .../phy/amlogic,g12a-mipi-dphy-analog.yaml | 12 - .../amlogic,meson-axg-mipi-pcie-analog.yaml | 17 - Bindings/phy/mediatek,dsi-phy.yaml | 1 + Bindings/phy/mediatek,tphy.yaml | 9 + Bindings/phy/qcom,sc8280xp-qmp-pcie-phy.yaml | 5 + Bindings/phy/qcom,sc8280xp-qmp-ufs-phy.yaml | 2 + .../phy/qcom,sc8280xp-qmp-usb3-uni-phy.yaml | 3 + .../phy/qcom,sc8280xp-qmp-usb43dp-phy.yaml | 8 +- Bindings/phy/qcom,snps-eusb2-phy.yaml | 2 + Bindings/pinctrl/pinctrl-single.yaml | 1 + Bindings/pinctrl/qcom,ipq5018-tlmm.yaml | 12 +- Bindings/pinctrl/qcom,ipq5332-tlmm.yaml | 9 +- Bindings/pinctrl/qcom,ipq6018-pinctrl.yaml | 8 +- Bindings/pinctrl/qcom,ipq8074-pinctrl.yaml | 9 +- Bindings/pinctrl/qcom,ipq9574-tlmm.yaml | 9 +- Bindings/pinctrl/qcom,lpass-lpi-common.yaml | 75 + Bindings/pinctrl/qcom,mdm9607-tlmm.yaml | 18 +- Bindings/pinctrl/qcom,mdm9615-pinctrl.yaml | 18 +- Bindings/pinctrl/qcom,msm8226-pinctrl.yaml | 8 +- Bindings/pinctrl/qcom,msm8660-pinctrl.yaml | 9 +- Bindings/pinctrl/qcom,msm8909-tlmm.yaml | 18 +- Bindings/pinctrl/qcom,msm8916-pinctrl.yaml | 9 +- Bindings/pinctrl/qcom,msm8953-pinctrl.yaml | 7 +- Bindings/pinctrl/qcom,msm8960-pinctrl.yaml | 9 +- Bindings/pinctrl/qcom,msm8974-pinctrl.yaml | 9 +- Bindings/pinctrl/qcom,msm8976-pinctrl.yaml | 9 +- Bindings/pinctrl/qcom,msm8994-pinctrl.yaml | 9 +- Bindings/pinctrl/qcom,msm8996-pinctrl.yaml | 9 +- Bindings/pinctrl/qcom,msm8998-pinctrl.yaml | 9 +- Bindings/pinctrl/qcom,pmic-mpp.yaml | 62 +- Bindings/pinctrl/qcom,qcm2290-tlmm.yaml | 9 +- Bindings/pinctrl/qcom,qcs404-pinctrl.yaml | 9 +- Bindings/pinctrl/qcom,qdu1000-tlmm.yaml | 12 +- Bindings/pinctrl/qcom,sa8775p-tlmm.yaml | 21 +- Bindings/pinctrl/qcom,sc7180-pinctrl.yaml | 9 +- .../qcom,sc7280-lpass-lpi-pinctrl.yaml | 49 +- Bindings/pinctrl/qcom,sc7280-pinctrl.yaml | 30 +- Bindings/pinctrl/qcom,sc8180x-tlmm.yaml | 20 +- .../qcom,sc8280xp-lpass-lpi-pinctrl.yaml | 49 +- Bindings/pinctrl/qcom,sc8280xp-tlmm.yaml | 18 +- Bindings/pinctrl/qcom,sdm630-pinctrl.yaml | 10 +- Bindings/pinctrl/qcom,sdm670-tlmm.yaml | 19 +- Bindings/pinctrl/qcom,sdm845-pinctrl.yaml | 10 +- Bindings/pinctrl/qcom,sdx55-pinctrl.yaml | 8 +- Bindings/pinctrl/qcom,sdx65-tlmm.yaml | 8 +- Bindings/pinctrl/qcom,sdx75-tlmm.yaml | 12 +- Bindings/pinctrl/qcom,sm4450-tlmm.yaml | 151 + .../qcom,sm6115-lpass-lpi-pinctrl.yaml | 48 +- Bindings/pinctrl/qcom,sm6115-tlmm.yaml | 8 +- Bindings/pinctrl/qcom,sm6125-tlmm.yaml | 20 +- Bindings/pinctrl/qcom,sm6350-tlmm.yaml | 20 +- Bindings/pinctrl/qcom,sm6375-tlmm.yaml | 18 +- Bindings/pinctrl/qcom,sm7150-tlmm.yaml | 9 +- Bindings/pinctrl/qcom,sm8150-pinctrl.yaml | 9 +- .../qcom,sm8250-lpass-lpi-pinctrl.yaml | 49 +- Bindings/pinctrl/qcom,sm8250-pinctrl.yaml | 9 +- .../qcom,sm8350-lpass-lpi-pinctrl.yaml | 49 +- Bindings/pinctrl/qcom,sm8350-tlmm.yaml | 20 +- .../qcom,sm8450-lpass-lpi-pinctrl.yaml | 49 +- Bindings/pinctrl/qcom,sm8450-tlmm.yaml | 20 +- .../qcom,sm8550-lpass-lpi-pinctrl.yaml | 55 +- Bindings/pinctrl/qcom,sm8550-tlmm.yaml | 12 +- .../qcom,sm8650-lpass-lpi-pinctrl.yaml | 107 + Bindings/pinctrl/qcom,sm8650-tlmm.yaml | 141 + Bindings/pinctrl/qcom,x1e80100-tlmm.yaml | 137 + Bindings/pinctrl/renesas,rza2-pinctrl.yaml | 2 +- Bindings/pinctrl/renesas,rzg2l-pinctrl.yaml | 6 +- .../samsung,pinctrl-wakeup-interrupt.yaml | 45 +- Bindings/pinctrl/samsung,pinctrl.yaml | 5 +- Bindings/pinctrl/xlnx,zynq-pinctrl.yaml | 2 +- Bindings/pinctrl/xlnx,zynqmp-pinctrl.yaml | 2 +- Bindings/power/fsl,scu-pd.yaml | 1 + Bindings/power/qcom,rpmpd.yaml | 2 +- Bindings/power/reset/nvmem-reboot-mode.yaml | 8 +- Bindings/power/reset/qcom,pon.yaml | 13 +- Bindings/power/reset/syscon-reboot-mode.yaml | 8 +- Bindings/power/reset/xlnx,zynqmp-power.yaml | 4 +- Bindings/power/supply/bq24190.yaml | 1 + Bindings/power/supply/richtek,rt9455.yaml | 8 +- Bindings/power/wakeup-source.txt | 18 +- Bindings/pwm/mediatek,pwm-disp.yaml | 1 - Bindings/pwm/pwm-omap-dmtimer.txt | 22 - Bindings/pwm/pwm-samsung.yaml | 4 + Bindings/pwm/ti,omap-dmtimer-pwm.yaml | 59 + Bindings/regulator/fixed-regulator.yaml | 2 + Bindings/regulator/mps,mp5416.yaml | 4 +- Bindings/regulator/mps,mpq7920.yaml | 4 +- Bindings/regulator/qcom,rpmh-regulator.yaml | 14 + .../regulator/qcom,smd-rpm-regulator.yaml | 4 + Bindings/regulator/qcom,spmi-regulator.yaml | 19 + .../regulator/qcom,usb-vbus-regulator.yaml | 5 +- Bindings/regulator/regulator.yaml | 13 + Bindings/remoteproc/fsl,imx-rproc.yaml | 8 +- Bindings/remoteproc/qcom,sc7180-pas.yaml | 21 + Bindings/reset/amlogic,meson-reset.yaml | 1 + Bindings/reset/fsl,imx-src.yaml | 31 +- Bindings/reset/hisilicon,hi3660-reset.yaml | 25 +- Bindings/reset/qcom,aoss-reset.yaml | 10 +- Bindings/reset/qcom,pdc-global.yaml | 8 +- Bindings/reset/renesas,rzg2l-usbphy-ctrl.yaml | 2 +- Bindings/reset/xlnx,zynqmp-reset.yaml | 3 +- Bindings/riscv/cpus.yaml | 10 +- Bindings/riscv/extensions.yaml | 221 +- Bindings/riscv/sophgo.yaml | 4 + Bindings/rng/starfive,jh7110-trng.yaml | 6 +- Bindings/rtc/adi,max31335.yaml | 70 + Bindings/rtc/epson,rx8900.yaml | 2 + Bindings/rtc/nuvoton,ma35d1-rtc.yaml | 48 + Bindings/rtc/qcom-pm8xxx-rtc.yaml | 36 +- Bindings/rtc/s3c-rtc.yaml | 5 + Bindings/security/tpm/google,cr50.txt | 19 - Bindings/security/tpm/ibmvtpm.txt | 41 - Bindings/security/tpm/st33zp24-i2c.txt | 34 - Bindings/security/tpm/st33zp24-spi.txt | 32 - Bindings/security/tpm/tpm-i2c.txt | 26 - Bindings/security/tpm/tpm_tis_mmio.txt | 25 - Bindings/security/tpm/tpm_tis_spi.txt | 23 - Bindings/serial/arm,dcc.yaml | 30 + Bindings/serial/fsl,s32-linflexuart.yaml | 2 +- Bindings/serial/fsl-imx-uart.yaml | 29 +- Bindings/serial/qcom,msm-uartdm.yaml | 13 + Bindings/serial/renesas,sci.yaml | 2 +- Bindings/serial/samsung_uart.yaml | 28 +- Bindings/serial/snps-dw-apb-uart.yaml | 1 + Bindings/serial/sprd-uart.yaml | 1 + .../amlogic/amlogic,meson-gx-hhi-sysctrl.yaml | 33 + Bindings/soc/mediatek/mediatek,pwrap.yaml | 6 +- Bindings/soc/mediatek/mtk-svs.yaml | 2 + .../microchip,mpfs-sys-controller.yaml | 10 + Bindings/soc/qcom/qcom,aoss-qmp.yaml | 2 + Bindings/soc/qcom/qcom,pmic-glink.yaml | 22 +- Bindings/soc/qcom/qcom-stats.yaml | 14 + Bindings/soc/rockchip/grf.yaml | 2 + Bindings/soc/samsung/exynos-pmu.yaml | 10 + Bindings/soc/samsung/exynos-usi.yaml | 7 +- .../soc/samsung/samsung,exynos-sysreg.yaml | 5 + Bindings/{arm => soc/xilinx}/xilinx.yaml | 7 +- Bindings/sound/adi,max98363.yaml | 2 +- Bindings/sound/allwinner,sun4i-a10-spdif.yaml | 5 +- Bindings/sound/audio-graph-port.yaml | 6 + Bindings/sound/es8328.txt | 38 - Bindings/sound/everest,es8328.yaml | 77 + Bindings/sound/fsl,mqs.txt | 36 - Bindings/sound/fsl,mqs.yaml | 105 + Bindings/sound/fsl,xcvr.yaml | 22 +- Bindings/sound/google,sc7280-herobrine.yaml | 1 - Bindings/sound/mediatek,mt2701-audio.yaml | 116 + Bindings/sound/mediatek,mt8188-mt6359.yaml | 1 + Bindings/sound/mt2701-afe-pcm.txt | 146 - Bindings/sound/nuvoton,nau8821.yaml | 9 + .../sound/nvidia,tegra-audio-max9808x.yaml | 2 +- Bindings/sound/qcom,lpass-rx-macro.yaml | 23 +- Bindings/sound/qcom,lpass-tx-macro.yaml | 25 +- Bindings/sound/qcom,lpass-va-macro.yaml | 18 +- Bindings/sound/qcom,lpass-wsa-macro.yaml | 23 +- Bindings/sound/qcom,sm8250.yaml | 6 + Bindings/sound/qcom,wcd934x.yaml | 4 +- Bindings/sound/qcom,wcd938x-sdw.yaml | 4 +- Bindings/sound/qcom,wcd938x.yaml | 4 +- Bindings/sound/qcom,wsa883x.yaml | 2 +- Bindings/sound/qcom,wsa8840.yaml | 2 +- Bindings/sound/renesas,rsnd.yaml | 36 +- Bindings/sound/renesas,rz-ssi.yaml | 2 +- Bindings/sound/samsung-i2s.yaml | 19 +- Bindings/sound/sound-card-common.yaml | 7 + Bindings/sound/tas2562.yaml | 2 - Bindings/sound/ti,tas2781.yaml | 78 +- Bindings/sound/ti,tlv320aic32x4.yaml | 2 +- Bindings/spi/adi,axi-spi-engine.txt | 31 - Bindings/spi/adi,axi-spi-engine.yaml | 66 + Bindings/spi/renesas,rspi.yaml | 2 +- Bindings/spi/snps,dw-apb-ssi.yaml | 2 - Bindings/spi/st,stm32-spi.yaml | 2 + .../thermal/allwinner,sun8i-a83t-ths.yaml | 7 +- Bindings/thermal/loongson,ls2k-thermal.yaml | 10 +- Bindings/thermal/mediatek,thermal.yaml | 99 + Bindings/thermal/mediatek-thermal.txt | 52 - Bindings/thermal/qcom-spmi-adc-tm-hc.yaml | 8 +- Bindings/thermal/qcom-spmi-adc-tm5.yaml | 16 +- Bindings/thermal/qcom-tsens.yaml | 1 + Bindings/thermal/thermal-zones.yaml | 16 + Bindings/timer/sifive,clint.yaml | 2 + Bindings/timer/thead,c900-aclint-mtimer.yaml | 9 +- Bindings/tpm/google,cr50.yaml | 65 + Bindings/tpm/ibm,vtpm.yaml | 104 + Bindings/tpm/microsoft,ftpm.yaml | 47 + Bindings/tpm/tcg,tpm-tis-i2c.yaml | 90 + Bindings/tpm/tcg,tpm-tis-mmio.yaml | 49 + Bindings/tpm/tcg,tpm_tis-spi.yaml | 75 + Bindings/tpm/tpm-common.yaml | 87 + Bindings/trivial-devices.yaml | 24 +- Bindings/ufs/qcom,ufs.yaml | 2 + Bindings/ufs/samsung,exynos-ufs.yaml | 9 +- Bindings/ufs/ufs-common.yaml | 2 + Bindings/usb/dwc3-xilinx.yaml | 3 +- Bindings/usb/generic-xhci.yaml | 25 +- Bindings/usb/genesys,gl850g.yaml | 5 + Bindings/usb/mediatek,mtk-xhci.yaml | 11 + Bindings/usb/microchip,usb5744.yaml | 3 +- Bindings/usb/nxp,ptn5110.yaml | 2 +- Bindings/usb/qcom,dwc3.yaml | 151 +- Bindings/usb/qcom,wcd939x-usbss.yaml | 102 + Bindings/usb/renesas,usbhs.yaml | 2 +- Bindings/usb/snps,dwc3.yaml | 4 + Bindings/usb/ti,tps6598x.yaml | 6 + Bindings/usb/usb-xhci.yaml | 6 + Bindings/usb/xlnx,usb2.yaml | 3 +- Bindings/vendor-prefixes.yaml | 22 + Bindings/w1/amd,axi-1wire-host.yaml | 44 + .../watchdog/allwinner,sun4i-a10-wdt.yaml | 6 +- Bindings/watchdog/alphascale,asm9260-wdt.yaml | 6 +- Bindings/watchdog/apple,wdt.yaml | 6 +- Bindings/watchdog/arm-smc-wdt.yaml | 6 +- Bindings/watchdog/brcm,bcm7038-wdt.yaml | 10 +- Bindings/watchdog/cnxt,cx92755-wdt.yaml | 6 +- Bindings/watchdog/dlg,da9062-watchdog.yaml | 12 +- Bindings/watchdog/intel,keembay-wdt.yaml | 5 +- Bindings/watchdog/maxim,max63xx.yaml | 8 +- Bindings/watchdog/mediatek,mtk-wdt.yaml | 1 + Bindings/watchdog/nxp,pnx4008-wdt.yaml | 34 + Bindings/watchdog/pnx4008-wdt.txt | 17 - Bindings/watchdog/qca,ar7130-wdt.yaml | 33 + Bindings/watchdog/qca-ar7130-wdt.txt | 13 - Bindings/watchdog/qcom,pm8916-wdt.yaml | 33 +- Bindings/watchdog/qcom-wdt.yaml | 2 +- Bindings/watchdog/realtek,rtd119x.txt | 17 - .../watchdog/realtek,rtd1295-watchdog.yaml | 38 + Bindings/watchdog/samsung-wdt.yaml | 29 +- Bindings/watchdog/snps,dw-wdt.yaml | 10 +- Bindings/watchdog/technologic,ts7200-wdt.yaml | 45 + include/dt-bindings/arm/qcom,ids.h | 1 + include/dt-bindings/clock/g12a-clkc.h | 8 + include/dt-bindings/clock/google,gs101.h | 392 ++ .../dt-bindings/clock/mediatek,mt7988-clk.h | 280 + include/dt-bindings/clock/qcom,gcc-msm8939.h | 6 + .../dt-bindings/clock/qcom,qdu1000-ecpricc.h | 147 + .../dt-bindings/clock/qcom,sc8280xp-camcc.h | 179 + .../dt-bindings/clock/qcom,sm8650-dispcc.h | 102 + include/dt-bindings/clock/qcom,sm8650-gcc.h | 254 + include/dt-bindings/clock/qcom,sm8650-gpucc.h | 43 + include/dt-bindings/clock/qcom,sm8650-tcsr.h | 18 + .../dt-bindings/clock/qcom,videocc-sm8150.h | 4 + include/dt-bindings/clock/qcom,x1e80100-gcc.h | 485 ++ include/dt-bindings/clock/sophgo,cv1800.h | 176 + include/dt-bindings/clock/st,stm32mp25-rcc.h | 492 ++ include/dt-bindings/dma/fsl-edma.h | 21 + .../dt-bindings/iio/qcom,spmi-adc7-pm7325.h | 69 + .../dt-bindings/iio/qcom,spmi-adc7-smb139x.h | 19 + include/dt-bindings/iio/qcom,spmi-vadc.h | 3 + .../dt-bindings/interconnect/qcom,sm6115.h | 111 + .../interconnect/qcom,sm8650-rpmh.h | 154 + .../interconnect/qcom,x1e80100-rpmh.h | 207 + include/dt-bindings/power/meson-g12a-power.h | 1 + include/dt-bindings/reset/amlogic,c3-reset.h | 119 + .../reset/mediatek,mt7988-resets.h | 13 + include/dt-bindings/reset/mt8188-resets.h | 75 + include/dt-bindings/reset/qcom,sm8650-gpucc.h | 20 + include/dt-bindings/reset/st,stm32mp25-rcc.h | 167 + include/dt-bindings/soc/rockchip,vop2.h | 4 + src/arm/amazon/alpine.dtsi | 1 - .../aspeed/aspeed-bmc-facebook-bletchley.dts | 4 +- .../aspeed/aspeed-bmc-facebook-wedge400.dts | 4 +- src/arm/aspeed/aspeed-bmc-opp-tacoma.dts | 2 +- src/arm/aspeed/aspeed-g4.dtsi | 14 - src/arm/aspeed/aspeed-g5.dtsi | 15 +- src/arm/aspeed/aspeed-g6.dtsi | 18 +- .../ast2600-facebook-netbmc-common.dtsi | 4 +- src/arm/broadcom/bcm-cygnus.dtsi | 3 + src/arm/broadcom/bcm-hr2.dtsi | 1 + src/arm/broadcom/bcm-nsp.dtsi | 2 + src/arm/broadcom/bcm2711-rpi.dtsi | 5 + src/arm/broadcom/bcm2711.dtsi | 14 + src/arm/broadcom/bcm63138.dtsi | 6 + .../intel/ixp/intel-ixp42x-gateway-7001.dts | 2 + .../ixp/intel-ixp42x-goramo-multilink.dts | 2 + .../ixp/intel-ixp42x-usrobotics-usr8200.dts | 22 + src/arm/intel/socfpga/socfpga.dtsi | 2 +- src/arm/intel/socfpga/socfpga_arria10.dtsi | 2 +- .../socfpga/socfpga_arria10_socdk_qspi.dts | 2 - .../intel/socfpga/socfpga_arria5_socdk.dts | 2 - .../intel/socfpga/socfpga_cyclone5_socdk.dts | 2 - .../intel/socfpga/socfpga_cyclone5_sockit.dts | 2 - .../intel/socfpga/socfpga_cyclone5_sodia.dts | 2 - .../socfpga/socfpga_cyclone5_vining_fpga.dts | 4 - src/arm/marvell/armada-370-rd.dts | 26 +- .../marvell/armada-370-seagate-nas-2bay.dts | 8 +- .../marvell/armada-370-seagate-nas-4bay.dts | 8 +- .../marvell/armada-370-synology-ds213j.dts | 16 +- .../marvell/armada-381-netgear-gs110emx.dts | 44 +- .../marvell/armada-385-clearfog-gtr-l8.dts | 38 +- .../marvell/armada-385-clearfog-gtr-s4.dts | 22 +- src/arm/marvell/armada-385-linksys.dtsi | 18 +- src/arm/marvell/armada-385-synology-ds116.dts | 16 +- src/arm/marvell/armada-385-turris-omnia.dts | 20 +- src/arm/marvell/armada-388-clearfog.dts | 20 +- src/arm/marvell/armada-388-gp.dts | 4 +- src/arm/marvell/armada-xp-linksys-mamba.dts | 18 +- src/arm/marvell/kirkwood-dnskw.dtsi | 6 +- src/arm/marvell/kirkwood-l-50.dts | 2 + .../marvell/kirkwood-linkstation-6282.dtsi | 9 +- .../marvell/kirkwood-linkstation-lswxl.dts | 9 +- src/arm/marvell/kirkwood-lsxl.dtsi | 9 +- src/arm/marvell/kirkwood-ns2max.dts | 18 +- src/arm/marvell/kirkwood-ns2mini.dts | 18 +- src/arm/marvell/kirkwood-synology.dtsi | 102 +- src/arm/marvell/mvebu-linkstation-fan.dtsi | 8 +- src/arm/microchip/at91-sam9x60_curiosity.dts | 3 + src/arm/microchip/at91-sam9x60ek.dts | 3 + src/arm/microchip/at91-sama5d27_som1_ek.dts | 1 - src/arm/microchip/at91-sama5d27_wlsom1_ek.dts | 1 - src/arm/nuvoton/nuvoton-wpcm450.dtsi | 2 + src/arm/nvidia/tegra20-colibri.dtsi | 2 +- src/arm/nvidia/tegra30-apalis-v1.1.dtsi | 1 - src/arm/nvidia/tegra30-apalis.dtsi | 1 - src/arm/nvidia/tegra30-colibri.dtsi | 1 - src/arm/nxp/imx/imx1-ads.dts | 2 +- src/arm/nxp/imx/imx1-apf9328.dts | 2 +- src/arm/nxp/imx/imx1.dtsi | 9 +- src/arm/nxp/imx/imx25-eukrea-cpuimx25.dtsi | 2 +- ...25-eukrea-mbimxsd25-baseboard-cmo-qvga.dts | 2 +- ...25-eukrea-mbimxsd25-baseboard-dvi-svga.dts | 2 +- ...x25-eukrea-mbimxsd25-baseboard-dvi-vga.dts | 2 +- src/arm/nxp/imx/imx25-pdk.dts | 3 +- src/arm/nxp/imx/imx25.dtsi | 41 +- src/arm/nxp/imx/imx27-apf27dev.dts | 4 +- src/arm/nxp/imx/imx27-eukrea-cpuimx27.dtsi | 4 +- .../imx/imx27-eukrea-mbimxsd27-baseboard.dts | 2 +- src/arm/nxp/imx/imx27-pdk.dts | 18 +- .../nxp/imx/imx27-phytec-phycard-s-rdk.dts | 2 +- src/arm/nxp/imx/imx27-phytec-phycore-rdk.dts | 17 +- src/arm/nxp/imx/imx27-phytec-phycore-som.dtsi | 28 +- src/arm/nxp/imx/imx27.dtsi | 7 +- src/arm/nxp/imx/imx53-cx9020.dts | 2 +- src/arm/nxp/imx/imx6dl-b105pv2.dts | 2 +- src/arm/nxp/imx/imx6dl-b105v2.dts | 2 +- src/arm/nxp/imx/imx6dl-b125pv2.dts | 2 +- src/arm/nxp/imx/imx6dl-b125v2.dts | 2 +- src/arm/nxp/imx/imx6dl-b155v2.dts | 2 +- src/arm/nxp/imx/imx6q-apalis-ixora-v1.2.dts | 2 + src/arm/nxp/imx/imx6q-b850v3.dts | 3 - src/arm/nxp/imx/imx6q-bx50v3.dtsi | 2 +- src/arm/nxp/imx/imx6q-var-mx6customboard.dts | 4 +- src/arm/nxp/imx/imx6qdl-apalis.dtsi | 10 +- src/arm/nxp/imx/imx6qdl-colibri.dtsi | 8 +- src/arm/nxp/imx/imx6qdl-emcon-avari.dtsi | 2 +- src/arm/nxp/imx/imx6qdl-emcon.dtsi | 1 - src/arm/nxp/imx/imx6qdl-mba6.dtsi | 6 +- src/arm/nxp/imx/imx6qdl-phytec-pfla02.dtsi | 1 + .../nxp/imx/imx6qdl-phytec-phycore-som.dtsi | 1 + src/arm/nxp/imx/imx6qdl-skov-cpu-revc.dtsi | 2 +- src/arm/nxp/imx/imx6qdl.dtsi | 2 +- src/arm/nxp/imx/imx6sx.dtsi | 8 +- src/arm/nxp/imx/imx6ul.dtsi | 2 +- src/arm/nxp/imx/imx6ull-phytec-tauri.dtsi | 2 +- src/arm/nxp/imx/imx7-tqma7.dtsi | 9 +- src/arm/nxp/imx/imx7d-colibri-emmc.dtsi | 4 + src/arm/nxp/imx/imx7d-flex-concentrator.dts | 2 +- src/arm/nxp/imx/imx7d-meerkat96.dts | 2 +- src/arm/nxp/imx/imx7d-pico-dwarf.dts | 1 + src/arm/nxp/imx/imx7d-pico.dtsi | 8 + src/arm/nxp/imx/imx7d-smegw01.dts | 2 +- src/arm/nxp/imx/imx7d.dtsi | 3 - src/arm/nxp/imx/imx7s.dtsi | 48 +- src/arm/nxp/imx/mba6ulx.dtsi | 2 +- src/arm/nxp/lpc/lpc18xx.dtsi | 2 +- src/arm/nxp/ls/ls1021a.dtsi | 2 +- src/arm/nxp/mxs/imx23-sansa.dts | 12 +- src/arm/nxp/mxs/imx23.dtsi | 10 +- src/arm/nxp/mxs/imx28-lwe.dtsi | 1 + src/arm/nxp/mxs/imx28-tx28.dts | 1 + src/arm/nxp/mxs/imx28.dtsi | 14 +- src/arm/nxp/vf/vf-colibri-eval-v3.dtsi | 2 +- src/arm/nxp/vf/vf610-bk4.dts | 4 +- src/arm/nxp/vf/vf610-zii-cfu1.dts | 14 +- src/arm/nxp/vf/vf610-zii-dev-rev-b.dts | 7 +- src/arm/nxp/vf/vf610-zii-scu4-aib.dts | 70 +- src/arm/nxp/vf/vf610-zii-spb4.dts | 18 +- src/arm/nxp/vf/vf610-zii-ssmb-dtu.dts | 20 +- src/arm/nxp/vf/vf610-zii-ssmb-spu3.dts | 18 +- src/arm/qcom/pm8018.dtsi | 55 + src/arm/qcom/pm8058.dtsi | 159 + .../qcom/{qcom-pm8226.dtsi => pm8226.dtsi} | 2 + src/arm/qcom/pm8821.dtsi | 22 + .../qcom/{qcom-pm8841.dtsi => pm8841.dtsi} | 0 src/arm/qcom/pm8921.dtsi | 137 + .../qcom/{qcom-pm8941.dtsi => pm8941.dtsi} | 2 + .../qcom/{qcom-pma8084.dtsi => pma8084.dtsi} | 0 src/arm/qcom/{qcom-pmx55.dtsi => pmx55.dtsi} | 0 src/arm/qcom/{qcom-pmx65.dtsi => pmx65.dtsi} | 0 src/arm/qcom/qcom-apq8026-asus-sparrow.dts | 4 +- src/arm/qcom/qcom-apq8026-huawei-sturgeon.dts | 4 +- src/arm/qcom/qcom-apq8026-lg-lenok.dts | 4 +- .../qcom-apq8026-samsung-matisse-wifi.dts | 2 +- src/arm/qcom/qcom-apq8060-dragonboard.dts | 164 +- src/arm/qcom/qcom-apq8064-asus-nexus7-flo.dts | 70 +- src/arm/qcom/qcom-apq8064-cm-qs600.dts | 35 +- src/arm/qcom/qcom-apq8064-ifc6410.dts | 42 +- .../qcom-apq8064-sony-xperia-lagan-yuga.dts | 111 +- src/arm/qcom/qcom-apq8064.dtsi | 203 +- src/arm/qcom/qcom-apq8074-dragonboard.dts | 35 +- src/arm/qcom/qcom-apq8084-ifc6540.dts | 2 +- src/arm/qcom/qcom-apq8084-mtp.dts | 2 +- src/arm/qcom/qcom-ipq4019-ap.dk04.1.dtsi | 2 +- src/arm/qcom/qcom-ipq4019.dtsi | 4 +- src/arm/qcom/qcom-ipq8064.dtsi | 8 +- .../qcom/qcom-mdm9615-wp8548-mangoh-green.dts | 4 +- src/arm/qcom/qcom-mdm9615-wp8548.dtsi | 143 +- src/arm/qcom/qcom-mdm9615.dtsi | 183 +- .../qcom/qcom-msm8226-microsoft-common.dtsi | 327 + .../qcom/qcom-msm8226-microsoft-dempsey.dts | 17 + .../qcom/qcom-msm8226-microsoft-makepeace.dts | 17 + .../qcom-msm8226-microsoft-moneypenny.dts | 23 + src/arm/qcom/qcom-msm8226.dtsi | 48 +- src/arm/qcom/qcom-msm8660-surf.dts | 61 +- src/arm/qcom/qcom-msm8660.dtsi | 217 +- src/arm/qcom/qcom-msm8926-htc-memul.dts | 372 + .../qcom-msm8926-microsoft-superman-lte.dts | 53 + src/arm/qcom/qcom-msm8926-microsoft-tesla.dts | 67 + .../qcom/qcom-msm8926-motorola-peregrine.dts | 291 + src/arm/qcom/qcom-msm8960-cdp.dts | 27 +- .../qcom/qcom-msm8960-samsung-expressatt.dts | 7 +- src/arm/qcom/qcom-msm8960.dtsi | 45 +- .../qcom-msm8974-lge-nexus5-hammerhead.dts | 33 +- .../qcom/qcom-msm8974-sony-xperia-rhine.dtsi | 35 +- src/arm/qcom/qcom-msm8974.dtsi | 122 +- .../qcom/qcom-msm8974pro-fairphone-fp2.dts | 33 +- .../qcom/qcom-msm8974pro-oneplus-bacon.dts | 35 +- src/arm/qcom/qcom-msm8974pro-samsung-klte.dts | 13 +- ...-msm8974pro-sony-xperia-shinano-castor.dts | 35 +- src/arm/qcom/qcom-sdx55-mtp.dts | 2 +- src/arm/qcom/qcom-sdx55-t55.dts | 2 +- src/arm/qcom/qcom-sdx55-telit-fn980-tlb.dts | 2 +- src/arm/qcom/qcom-sdx55.dtsi | 63 +- src/arm/qcom/qcom-sdx65-mtp.dts | 2 +- src/arm/qcom/qcom-sdx65.dtsi | 51 +- src/arm/renesas/iwg20d-q7-dbcm-ca.dtsi | 15 + src/arm/renesas/r8a7740-armadillo800eva.dts | 28 +- src/arm/renesas/r8a7740.dtsi | 65 + .../renesas/r8a7745-iwg22d-sodimm-dbhd-ca.dts | 15 + src/arm/renesas/r8a7745-iwg22d-sodimm.dts | 4 +- src/arm/renesas/r8a7779-marzen.dts | 48 +- src/arm/renesas/r8a7790-lager.dts | 24 +- src/arm/renesas/r8a7790-stout.dts | 16 + src/arm/renesas/r8a7791-koelsch.dts | 31 +- src/arm/renesas/r8a7791-porter.dts | 27 +- src/arm/renesas/r8a7792-blanche.dts | 50 + src/arm/renesas/r8a7792-wheat.dts | 21 + src/arm/renesas/r8a7793-gose.dts | 29 +- src/arm/renesas/r8a7794-alt.dts | 5 +- src/arm/renesas/r8a7794-silk.dts | 18 +- src/arm/renesas/r9a06g032.dtsi | 2 +- src/arm/rockchip/rk3036-kylin.dts | 21 + src/arm/rockchip/rk3036.dtsi | 18 +- src/arm/rockchip/rk3066a.dtsi | 5 + src/arm/rockchip/rk3128-evb.dts | 5 - src/arm/rockchip/rk3128-xpi-3128.dts | 425 ++ src/arm/rockchip/rk3128.dtsi | 185 + src/arm/rockchip/rk322x.dtsi | 4 + src/arm/rockchip/rk3288.dtsi | 9 + src/arm/rockchip/rk3xxx.dtsi | 4 + src/arm/rockchip/rv1108.dtsi | 8 - src/arm/rockchip/rv1109-sonoff-ihost.dts | 21 + src/arm/rockchip/rv1109.dtsi | 23 + src/arm/rockchip/rv1126-edgeble-neu2-io.dts | 2 +- src/arm/rockchip/rv1126-pinctrl.dtsi | 72 +- src/arm/rockchip/rv1126-sonoff-ihost.dts | 29 + src/arm/rockchip/rv1126-sonoff-ihost.dtsi | 404 ++ src/arm/rockchip/rv1126.dtsi | 21 + src/arm/samsung/exynos4.dtsi | 26 +- src/arm/samsung/exynos4210-i9100.dts | 48 +- src/arm/samsung/exynos4212-tab3.dtsi | 1 + src/arm/samsung/exynos4x12.dtsi | 22 +- src/arm/samsung/s5pv210.dtsi | 18 +- src/arm/st/ste-dbx5x0.dtsi | 18 +- src/arm/st/ste-href-ab8500.dtsi | 48 + src/arm/st/ste-href-ab8505.dtsi | 490 ++ src/arm/st/ste-href.dtsi | 55 - src/arm/st/ste-href520-tvk.dts | 1 + src/arm/st/ste-hrefprev60-stuib.dts | 1 + src/arm/st/ste-hrefprev60-tvk.dts | 1 + src/arm/st/ste-hrefprev60.dtsi | 2 +- src/arm/st/ste-hrefv60plus-stuib.dts | 1 + src/arm/st/ste-hrefv60plus-tvk.dts | 1 + src/arm/st/ste-hrefv60plus.dtsi | 3 +- src/arm/st/ste-nomadik-stn8815.dtsi | 8 +- src/arm/st/ste-snowball.dts | 2 +- src/arm/st/ste-ux500-samsung-codina-tmo.dts | 2 +- src/arm/st/ste-ux500-samsung-codina.dts | 2 +- src/arm/st/ste-ux500-samsung-gavini.dts | 2 +- src/arm/st/ste-ux500-samsung-janice.dts | 2 +- src/arm/st/ste-ux500-samsung-kyle.dts | 2 +- src/arm/st/stm32429i-eval.dts | 1 - src/arm/st/stm32f469-disco.dts | 15 +- src/arm/st/stm32f746.dtsi | 61 + src/arm/st/stm32mp135.dtsi | 11 + src/arm/st/stm32mp151.dtsi | 4 + src/arm/st/stm32mp151a-prtt1l.dtsi | 2 - src/arm/st/stm32mp157a-dk1-scmi.dts | 4 +- src/arm/st/stm32mp157a-stinger96.dtsi | 2 - src/arm/st/stm32mp157c-dk2-scmi.dts | 4 +- src/arm/st/stm32mp157c-dk2.dts | 1 - src/arm/st/stm32mp157c-ed1-scmi.dts | 4 +- src/arm/st/stm32mp157c-emstamp-argon.dtsi | 4 - src/arm/st/stm32mp157c-ev1-scmi.dts | 5 +- src/arm/st/stm32mp157c-ev1.dts | 1 - src/arm/st/stm32mp157c-osd32mp1-red.dts | 4 - .../st/stm32mp157c-phycore-stm32mp15-som.dtsi | 4 - src/arm/st/stm32mp15xc-lxa-tac.dtsi | 3 - src/arm/st/stm32mp15xx-dhcom-drc02.dtsi | 1 - src/arm/st/stm32mp15xx-dhcom-pdk2.dtsi | 1 - src/arm/st/stm32mp15xx-dhcom-picoitx.dtsi | 2 - src/arm/st/stm32mp15xx-dhcor-avenger96.dtsi | 2 - src/arm/st/stm32mp15xx-dhcor-drc-compact.dtsi | 2 - src/arm/st/stm32mp15xx-dhcor-testbench.dtsi | 2 - src/arm/st/stm32mp15xx-dkx.dtsi | 1 - src/arm/ti/keystone/keystone-k2e-netcp.dtsi | 6 +- src/arm/ti/keystone/keystone-k2g-evm.dts | 2 +- src/arm/ti/keystone/keystone-k2g-netcp.dtsi | 6 +- src/arm/ti/keystone/keystone-k2hk-evm.dts | 2 +- src/arm/ti/keystone/keystone-k2hk-netcp.dtsi | 6 +- src/arm/ti/keystone/keystone-k2l-netcp.dtsi | 6 +- .../ti/omap/am335x-moxa-uc-2100-common.dtsi | 2 +- src/arm/ti/omap/am571x-idk.dts | 4 +- src/arm/ti/omap/am5729-beagleboneai.dts | 3 +- src/arm/ti/omap/am572x-idk-common.dtsi | 4 +- src/arm/ti/omap/dra7-evm-common.dtsi | 4 +- src/arm/ti/omap/dra71-evm.dts | 4 +- src/arm/ti/omap/dra72-evm-common.dtsi | 4 +- src/arm/ti/omap/dra76-evm.dts | 4 +- .../ti/omap/logicpd-torpedo-37xx-devkit.dts | 2 +- src/arm/ti/omap/motorola-mapphone-common.dtsi | 298 - .../ti/omap/motorola-mapphone-handset.dtsi | 234 + .../omap/motorola-mapphone-mz607-mz617.dtsi | 21 + src/arm/ti/omap/motorola-mapphone-xt8xx.dtsi | 75 + src/arm/ti/omap/omap4-droid-bionic-xt875.dts | 11 +- src/arm/ti/omap/omap4-droid4-xt894.dts | 19 +- src/arm/ti/omap/omap4-epson-embt2ws.dts | 18 +- src/arm/ti/omap/omap4-xyboard-mz609.dts | 46 + src/arm/ti/omap/omap4-xyboard-mz617.dts | 17 + .../allwinner/sun50i-h618-orangepi-zero2w.dts | 176 + .../sun50i-h618-transpeed-8k618-t.dts | 161 + src/arm64/altera/socfpga_stratix10.dtsi | 41 +- src/arm64/altera/socfpga_stratix10_socdk.dts | 8 +- .../altera/socfpga_stratix10_socdk_nand.dts | 6 +- src/arm64/altera/socfpga_stratix10_swvp.dts | 2 - src/arm64/amazon/alpine-v2.dtsi | 1 - src/arm64/amazon/alpine-v3.dtsi | 1 - src/arm64/amlogic/amlogic-c3.dtsi | 6 + .../meson-axg-jethome-jethub-j110-rev-2.dts | 14 +- .../meson-axg-jethome-jethub-j110-rev-3.dts | 12 + src/arm64/amlogic/meson-axg-s400.dts | 5 - src/arm64/amlogic/meson-axg.dtsi | 23 + src/arm64/amlogic/meson-g12a-sei510.dts | 1 - src/arm64/amlogic/meson-g12a-x96-max.dts | 1 - .../amlogic/meson-g12b-bananapi-cm4.dtsi | 2 +- src/arm64/amlogic/meson-g12b-bananapi.dtsi | 2 +- src/arm64/amlogic/meson-g12b-gtking.dts | 1 - src/arm64/amlogic/meson-g12b-ugoos-am6.dts | 1 - src/arm64/amlogic/meson-gx-p23x-q20x.dtsi | 1 - src/arm64/amlogic/meson-gxbb-kii-pro.dts | 1 - src/arm64/amlogic/meson-gxbb-p200.dts | 1 - src/arm64/amlogic/meson-gxbb-vega-s95.dtsi | 1 - src/arm64/amlogic/meson-gxbb-wetek-play2.dts | 1 - src/arm64/amlogic/meson-gxm-nexbox-a1.dts | 1 - src/arm64/amlogic/meson-gxm-rbox-pro.dts | 1 - src/arm64/amlogic/meson-s4-s805x2-aq222.dts | 60 +- src/arm64/amlogic/meson-s4.dtsi | 360 +- src/arm64/amlogic/meson-sm1-sei610.dts | 1 - src/arm64/arm/juno-base.dtsi | 12 +- src/arm64/arm/juno-scmi.dtsi | 12 +- src/arm64/broadcom/northstar2/ns2.dtsi | 1 + src/arm64/broadcom/stingray/stingray.dtsi | 1 + src/arm64/exynos/exynos5433.dtsi | 60 +- src/arm64/exynos/exynos7.dtsi | 18 +- src/arm64/exynos/exynos7885.dtsi | 45 +- src/arm64/exynos/exynos850.dtsi | 40 +- src/arm64/exynos/exynosautov9-sadk.dts | 51 + src/arm64/exynos/exynosautov9.dtsi | 10 +- src/arm64/exynos/exynosautov920-pinctrl.dtsi | 1266 ++++ src/arm64/exynos/exynosautov920-sadk.dts | 88 + src/arm64/exynos/exynosautov920.dtsi | 312 + src/arm64/exynos/google/gs101-oriole.dts | 105 + src/arm64/exynos/google/gs101-pinctrl.dtsi | 1249 ++++ src/arm64/exynos/google/gs101-pinctrl.h | 33 + src/arm64/exynos/google/gs101.dtsi | 473 ++ src/arm64/freescale/fsl-ls1012a.dtsi | 80 +- src/arm64/freescale/fsl-ls1028a.dtsi | 87 +- src/arm64/freescale/fsl-ls1043a.dtsi | 81 +- src/arm64/freescale/fsl-ls1046a.dtsi | 74 +- src/arm64/freescale/fsl-ls1088a.dtsi | 74 +- src/arm64/freescale/fsl-ls208xa.dtsi | 73 +- .../fsl-lx2160a-tqmlx2160a-mblx2160a.dts | 338 + ...l-lx2160a-tqmlx2160a-mblx2160a_12_x_x.dtso | 29 + ...l-lx2160a-tqmlx2160a-mblx2160a_14_x_x.dtso | 17 + ...l-lx2160a-tqmlx2160a-mblx2160a_x_11_x.dtso | 49 + ...sl-lx2160a-tqmlx2160a-mblx2160a_x_7_x.dtso | 55 + ...sl-lx2160a-tqmlx2160a-mblx2160a_x_8_x.dtso | 47 + .../freescale/fsl-lx2160a-tqmlx2160a.dtsi | 97 + src/arm64/freescale/fsl-lx2160a.dtsi | 4 +- .../freescale/imx8-apalis-ixora-v1.2.dtsi | 2 + src/arm64/freescale/imx8-ss-audio.dtsi | 2 - src/arm64/freescale/imx8dxl-ss-conn.dtsi | 16 +- src/arm64/freescale/imx8dxl-ss-ddr.dtsi | 2 +- src/arm64/freescale/imx8mm-beacon-som.dtsi | 2 + src/arm64/freescale/imx8mm-emcon-avari.dtsi | 2 +- src/arm64/freescale/imx8mm-evk.dtsi | 12 +- src/arm64/freescale/imx8mm-nitrogen-r2.dts | 2 +- src/arm64/freescale/imx8mm-overdrive.dtsi | 29 + .../freescale/imx8mm-phygate-tauri-l.dts | 2 +- .../freescale/imx8mm-tqma8mqml-mba8mx.dts | 1 + src/arm64/freescale/imx8mm-venice-gw72xx.dtsi | 39 +- src/arm64/freescale/imx8mm-venice-gw73xx.dtsi | 31 +- src/arm64/freescale/imx8mm-venice-gw7902.dts | 13 +- src/arm64/freescale/imx8mm-verdin-mallow.dtsi | 173 + .../imx8mm-verdin-nonwifi-mallow.dts | 18 + .../freescale/imx8mm-verdin-wifi-mallow.dts | 18 + src/arm64/freescale/imx8mm.dtsi | 18 +- src/arm64/freescale/imx8mn-beacon-som.dtsi | 2 + .../freescale/imx8mn-bsh-smm-s2-common.dtsi | 1 + .../freescale/imx8mn-bsh-smm-s2-display.dtsi | 121 + .../freescale/imx8mn-dimonoff-gateway-evk.dts | 160 + src/arm64/freescale/imx8mn-evk.dtsi | 12 +- src/arm64/freescale/imx8mn-overdrive.dtsi | 18 + src/arm64/freescale/imx8mn-rve-gateway.dts | 285 + .../freescale/imx8mn-tqma8mqnl-mba8mx.dts | 1 + .../freescale/imx8mn-var-som-symphony.dts | 10 + src/arm64/freescale/imx8mn-var-som.dtsi | 9 + src/arm64/freescale/imx8mn.dtsi | 2 + src/arm64/freescale/imx8mp-beacon-kit.dts | 94 +- .../freescale/imx8mp-data-modul-edm-sbc.dts | 2 +- src/arm64/freescale/imx8mp-debix-model-a.dts | 2 +- .../freescale/imx8mp-debix-som-a-bmb-08.dts | 56 + src/arm64/freescale/imx8mp-debix-som-a.dtsi | 22 + src/arm64/freescale/imx8mp-dhcom-som.dtsi | 14 +- src/arm64/freescale/imx8mp-evk.dts | 22 + src/arm64/freescale/imx8mp-msc-sm2s-ep1.dts | 4 +- src/arm64/freescale/imx8mp-skov-reva.dtsi | 711 ++ src/arm64/freescale/imx8mp-skov-revb-hdmi.dts | 20 + src/arm64/freescale/imx8mp-skov-revb-lt6.dts | 101 + .../imx8mp-skov-revb-mi1010ait-1cp1.dts | 100 + ...8mp-tqma8mpql-mba8mpxl-lvds-g133han01.dtso | 77 + .../freescale/imx8mp-tqma8mpql-mba8mpxl.dts | 37 +- src/arm64/freescale/imx8mp-venice-gw71xx.dtsi | 26 +- src/arm64/freescale/imx8mp-venice-gw72xx.dtsi | 36 +- src/arm64/freescale/imx8mp-venice-gw73xx.dtsi | 28 +- src/arm64/freescale/imx8mp-venice-gw74xx.dts | 30 +- src/arm64/freescale/imx8mp-verdin-mallow.dtsi | 199 + .../imx8mp-verdin-nonwifi-mallow.dts | 18 + .../freescale/imx8mp-verdin-wifi-mallow.dts | 18 + src/arm64/freescale/imx8mp-verdin.dtsi | 30 +- src/arm64/freescale/imx8mp.dtsi | 30 +- .../freescale/imx8mq-kontron-pitx-imx8m.dts | 2 +- src/arm64/freescale/imx8mq-phanbell.dts | 2 +- src/arm64/freescale/imx8mq-tqma8mq-mba8mx.dts | 1 + src/arm64/freescale/imx8qm-ss-dma.dtsi | 4 + src/arm64/freescale/imx8qxp-mek.dts | 21 +- src/arm64/freescale/imx8qxp-ss-vpu.dtsi | 17 + src/arm64/freescale/imx8qxp.dtsi | 3 +- src/arm64/freescale/imx93-11x11-evk.dts | 31 +- .../freescale/imx93-tqma9352-mba93xxca.dts | 709 ++ .../freescale/imx93-tqma9352-mba93xxla.dts | 1 + src/arm64/freescale/imx93.dtsi | 127 +- src/arm64/hisilicon/hikey970-pmic.dtsi | 6 +- src/arm64/intel/socfpga_agilex.dtsi | 42 +- src/arm64/intel/socfpga_agilex5.dtsi | 4 +- src/arm64/intel/socfpga_agilex_n6000.dts | 2 +- src/arm64/intel/socfpga_agilex_socdk.dts | 2 - src/arm64/intel/socfpga_n5x_socdk.dts | 5 +- src/arm64/lg/lg1312.dtsi | 1 - src/arm64/lg/lg1313.dtsi | 1 - src/arm64/marvell/ac5x-rd-carrier-cn9131.dts | 44 + src/arm64/marvell/ac5x-rd-carrier.dtsi | 34 + .../marvell/armada-3720-espressobin-ultra.dts | 14 +- .../marvell/armada-3720-espressobin.dtsi | 20 +- src/arm64/marvell/armada-3720-gl-mv1000.dts | 20 +- src/arm64/marvell/armada-3720-turris-mox.dts | 99 +- src/arm64/marvell/armada-7040-mochabin.dts | 24 +- .../marvell/armada-8040-clearfog-gt-8k.dts | 22 +- src/arm64/marvell/armada-ap80x.dtsi | 1 - src/arm64/marvell/cn9130-crb.dtsi | 42 +- src/arm64/marvell/cn9130-db-comexpress.dtsi | 96 + src/arm64/marvell/cn9131-db-comexpress.dtsi | 108 + src/arm64/mediatek/mt6358.dtsi | 26 +- .../mediatek/mt7622-bananapi-bpi-r64.dts | 3 +- .../mediatek/mt7986a-bananapi-bpi-r3.dts | 3 +- src/arm64/mediatek/mt8173-elm-hana.dtsi | 9 +- src/arm64/mediatek/mt8173-elm.dtsi | 24 +- src/arm64/mediatek/mt8173-evb.dts | 3 +- src/arm64/mediatek/mt8173.dtsi | 8 +- src/arm64/mediatek/mt8183-evb.dts | 4 + .../mediatek/mt8183-kukui-audio-da7219.dtsi | 3 +- .../mediatek/mt8183-kukui-audio-ts3a227e.dtsi | 3 +- .../mediatek/mt8183-kukui-jacuzzi-damu.dts | 3 +- .../mt8183-kukui-jacuzzi-fennel-sku1.dts | 3 +- .../mt8183-kukui-jacuzzi-fennel-sku6.dts | 3 +- .../mt8183-kukui-jacuzzi-fennel-sku7.dts | 3 +- .../mt8183-kukui-jacuzzi-makomo-sku0.dts | 24 + .../mt8183-kukui-jacuzzi-makomo-sku1.dts | 24 + .../mediatek/mt8183-kukui-jacuzzi-pico.dts | 35 + .../mediatek/mt8183-kukui-jacuzzi-pico6.dts | 110 + src/arm64/mediatek/mt8183-kukui-jacuzzi.dtsi | 1 - .../mediatek/mt8183-kukui-kakadu-sku22.dts | 18 + src/arm64/mediatek/mt8183-kukui-kakadu.dts | 18 + src/arm64/mediatek/mt8183-kukui-kakadu.dtsi | 15 +- .../mediatek/mt8183-kukui-katsu-sku32.dts | 36 + .../mediatek/mt8183-kukui-katsu-sku38.dts | 40 + src/arm64/mediatek/mt8183-kukui-kodama.dtsi | 3 +- src/arm64/mediatek/mt8183-kukui-krane.dtsi | 3 +- src/arm64/mediatek/mt8183-kukui.dtsi | 12 +- src/arm64/mediatek/mt8183-pumpkin.dts | 4 + src/arm64/mediatek/mt8183.dtsi | 62 +- src/arm64/mediatek/mt8186.dtsi | 6 +- src/arm64/mediatek/mt8188-evb.dts | 387 ++ src/arm64/mediatek/mt8188.dtsi | 956 +++ src/arm64/mediatek/mt8192-asurada.dtsi | 2 +- src/arm64/mediatek/mt8192.dtsi | 466 ++ src/arm64/mediatek/mt8195-cherry.dtsi | 117 +- src/arm64/mediatek/mt8195-demo.dts | 1 + src/arm64/mediatek/mt8195.dtsi | 483 +- src/arm64/mediatek/mt8395-genio-1200-evk.dts | 6 +- .../nvidia/tegra234-p3737-0000+p3701-0000.dts | 2 +- src/arm64/nvidia/tegra234.dtsi | 6 +- src/arm64/qcom/ipq5018-rdp432-c2.dts | 12 + src/arm64/qcom/ipq5018.dtsi | 142 + src/arm64/qcom/ipq5332-rdp-common.dtsi | 3 + src/arm64/qcom/ipq5332-rdp441.dts | 2 +- src/arm64/qcom/ipq5332-rdp442.dts | 2 +- src/arm64/qcom/ipq5332-rdp474.dts | 2 +- src/arm64/qcom/ipq5332.dtsi | 23 +- src/arm64/qcom/ipq6018.dtsi | 129 +- src/arm64/qcom/ipq8074.dtsi | 126 +- src/arm64/qcom/ipq9574-rdp-common.dtsi | 169 + src/arm64/qcom/ipq9574-rdp418.dts | 63 +- src/arm64/qcom/ipq9574-rdp433.dts | 91 +- src/arm64/qcom/ipq9574-rdp449.dts | 65 +- src/arm64/qcom/ipq9574-rdp453.dts | 65 +- src/arm64/qcom/ipq9574-rdp454.dts | 66 +- src/arm64/qcom/ipq9574.dtsi | 25 +- src/arm64/qcom/msm8916-acer-a1-724.dts | 24 + src/arm64/qcom/msm8916-alcatel-idol347.dts | 173 +- src/arm64/qcom/msm8916-asus-z00l.dts | 21 + src/arm64/qcom/msm8916-longcheer-l8150.dts | 75 +- src/arm64/qcom/msm8916-longcheer-l8910.dts | 103 + src/arm64/qcom/msm8916-modem-qdsp6.dtsi | 148 + .../qcom/msm8916-samsung-a2015-common.dtsi | 71 + src/arm64/qcom/msm8916-samsung-a3u-eur.dts | 10 +- .../qcom/msm8916-samsung-e2015-common.dtsi | 4 + src/arm64/qcom/msm8916-samsung-grandmax.dts | 4 + .../qcom/msm8916-samsung-gt5-common.dtsi | 92 +- src/arm64/qcom/msm8916-samsung-gt510.dts | 26 + src/arm64/qcom/msm8916-samsung-gt58.dts | 46 + src/arm64/qcom/msm8916-samsung-j5-common.dtsi | 14 + src/arm64/qcom/msm8916-samsung-j5.dts | 4 + src/arm64/qcom/msm8916-samsung-serranove.dts | 13 + src/arm64/qcom/msm8916-thwc-uf896.dts | 8 +- src/arm64/qcom/msm8916-thwc-ufi001c.dts | 8 +- src/arm64/qcom/msm8916-wingtech-wt88047.dts | 75 + src/arm64/qcom/msm8916-yiming-uz801v3.dts | 8 +- src/arm64/qcom/msm8916.dtsi | 59 +- src/arm64/qcom/msm8939-huawei-kiwi.dts | 242 + src/arm64/qcom/msm8939-longcheer-l9100.dts | 56 + src/arm64/qcom/msm8939-samsung-a7.dts | 70 + src/arm64/qcom/msm8939.dtsi | 94 +- src/arm64/qcom/msm8953-xiaomi-mido.dts | 1 + src/arm64/qcom/msm8953-xiaomi-tissot.dts | 1 + src/arm64/qcom/msm8953-xiaomi-vince.dts | 1 + src/arm64/qcom/msm8953.dtsi | 110 +- src/arm64/qcom/msm8996.dtsi | 129 +- src/arm64/qcom/msm8998.dtsi | 92 +- src/arm64/qcom/pm7250b.dtsi | 2 +- src/arm64/qcom/pm8550.dtsi | 3 - src/arm64/qcom/pm8550ve.dtsi | 6 +- src/arm64/qcom/pm8916.dtsi | 48 + src/arm64/qcom/pmk8350.dtsi | 2 +- src/arm64/qcom/qcm2290.dtsi | 504 +- src/arm64/qcom/qcm6490-fairphone-fp5.dts | 288 +- src/arm64/qcom/qcm6490-idp.dts | 468 ++ src/arm64/qcom/qcs404.dtsi | 11 +- src/arm64/qcom/qcs6490-rb3gen2.dts | 455 ++ src/arm64/qcom/qdu1000.dtsi | 23 +- src/arm64/qcom/qrb2210-rb1.dts | 113 + src/arm64/qcom/qrb4210-rb2.dts | 112 +- .../qcom/qrb5165-rb5-vision-mezzanine.dts | 2 +- src/arm64/qcom/qrb5165-rb5.dts | 33 +- src/arm64/qcom/sa8775p-ride.dts | 5 + src/arm64/qcom/sa8775p.dtsi | 1124 ++- src/arm64/qcom/sc7180-acer-aspire1.dts | 174 +- src/arm64/qcom/sc7180-trogdor-pompom.dtsi | 2 +- src/arm64/qcom/sc7180.dtsi | 14 +- src/arm64/qcom/sc7280-chrome-common.dtsi | 37 +- src/arm64/qcom/sc7280-herobrine-lte-sku.dtsi | 7 +- src/arm64/qcom/sc7280-herobrine-wifi-sku.dtsi | 1 + src/arm64/qcom/sc7280-idp.dtsi | 19 + src/arm64/qcom/sc7280.dtsi | 581 +- src/arm64/qcom/sc8180x-lenovo-flex-5g.dts | 4 +- src/arm64/qcom/sc8180x-primus.dts | 12 +- src/arm64/qcom/sc8180x.dtsi | 61 +- src/arm64/qcom/sc8280xp-crd.dts | 4 + .../qcom/sc8280xp-lenovo-thinkpad-x13s.dts | 14 + src/arm64/qcom/sc8280xp.dtsi | 24 +- src/arm64/qcom/sdm630.dtsi | 53 +- src/arm64/qcom/sdm632-fairphone-fp3.dts | 19 + src/arm64/qcom/sdm670.dtsi | 302 +- src/arm64/qcom/sdm845-db845c.dts | 4 +- src/arm64/qcom/sdm845-oneplus-common.dtsi | 23 + src/arm64/qcom/sdm845-wcd9340.dtsi | 2 +- .../qcom/sdm845-xiaomi-beryllium-common.dtsi | 22 + src/arm64/qcom/sdm845.dtsi | 127 +- src/arm64/qcom/sdm850-lenovo-yoga-c630.dts | 8 +- src/arm64/qcom/sdm850-samsung-w737.dts | 2 +- src/arm64/qcom/sdx75-idp.dts | 29 + src/arm64/qcom/sdx75.dtsi | 170 + src/arm64/qcom/sm4450-qrd.dts | 18 +- src/arm64/qcom/sm4450.dtsi | 107 + src/arm64/qcom/sm6115.dtsi | 345 +- src/arm64/qcom/sm6125.dtsi | 4 + src/arm64/qcom/sm6350.dtsi | 20 +- .../qcom/sm6375-sony-xperia-murray-pdx225.dts | 43 +- src/arm64/qcom/sm6375.dtsi | 84 +- src/arm64/qcom/sm8150-hdk.dts | 264 +- src/arm64/qcom/sm8150.dtsi | 223 +- .../qcom/sm8250-xiaomi-elish-common.dtsi | 47 +- src/arm64/qcom/sm8250-xiaomi-pipa.dts | 623 ++ src/arm64/qcom/sm8250.dtsi | 143 +- src/arm64/qcom/sm8350.dtsi | 147 +- src/arm64/qcom/sm8450-hdk.dts | 8 + src/arm64/qcom/sm8450.dtsi | 285 +- src/arm64/qcom/sm8550-mtp.dts | 129 + src/arm64/qcom/sm8550-qrd.dts | 136 + src/arm64/qcom/sm8550.dtsi | 317 +- src/arm64/qcom/sm8650-mtp.dts | 727 ++ src/arm64/qcom/sm8650-qrd.dts | 811 +++ src/arm64/qcom/sm8650.dtsi | 6013 +++++++++++++++++ src/arm64/qcom/x1e80100-crd.dts | 424 ++ src/arm64/qcom/x1e80100-qcp.dts | 399 ++ src/arm64/qcom/x1e80100.dtsi | 3527 ++++++++++ src/arm64/renesas/draak.dtsi | 32 +- src/arm64/renesas/ebisu.dtsi | 6 + src/arm64/renesas/r8a77970-eagle.dts | 15 + .../renesas/r8a779g0-white-hawk-cpu.dtsi | 3 + src/arm64/renesas/r9a08g045.dtsi | 106 + src/arm64/renesas/r9a09g011.dtsi | 2 +- src/arm64/renesas/rzg2l-smarc-som.dtsi | 1 + src/arm64/renesas/rzg2lc-smarc-som.dtsi | 1 + src/arm64/renesas/rzg3s-smarc-som.dtsi | 210 +- src/arm64/renesas/rzg3s-smarc.dtsi | 65 + src/arm64/renesas/ulcb-kf.dtsi | 4 + src/arm64/rockchip/px30-engicam-common.dtsi | 1 + src/arm64/rockchip/px30-evb.dts | 1 + src/arm64/rockchip/px30-ringneck-haikou.dts | 1 + src/arm64/rockchip/px30.dtsi | 3 +- src/arm64/rockchip/rk3308-rock-pi-s.dts | 62 + src/arm64/rockchip/rk3308.dtsi | 5 + src/arm64/rockchip/rk3318-a95x-z2.dts | 1 + src/arm64/rockchip/rk3326-anbernic-rg351m.dts | 18 +- .../rockchip/rk3326-anbernic-rg351m.dtsi | 478 ++ src/arm64/rockchip/rk3326-anbernic-rg351v.dts | 44 + src/arm64/rockchip/rk3328-a1.dts | 1 + src/arm64/rockchip/rk3328-evb.dts | 1 + src/arm64/rockchip/rk3328-nanopi-r2s.dts | 1 + .../rockchip/rk3328-orangepi-r1-plus-lts.dts | 4 +- .../rockchip/rk3328-orangepi-r1-plus.dts | 1 + src/arm64/rockchip/rk3328-roc-cc.dts | 1 + src/arm64/rockchip/rk3328-rock-pi-e.dts | 55 + src/arm64/rockchip/rk3328-rock64.dts | 1 + src/arm64/rockchip/rk3328.dtsi | 11 +- src/arm64/rockchip/rk3368-evb.dtsi | 1 + src/arm64/rockchip/rk3368-geekbox.dts | 1 + src/arm64/rockchip/rk3368-lion.dtsi | 1 + src/arm64/rockchip/rk3368-orion-r68-meta.dts | 1 + src/arm64/rockchip/rk3368-r88.dts | 1 + src/arm64/rockchip/rk3368.dtsi | 5 +- src/arm64/rockchip/rk3399-eaidk-610.dts | 1 + src/arm64/rockchip/rk3399-evb.dts | 1 + src/arm64/rockchip/rk3399-ficus.dts | 4 + src/arm64/rockchip/rk3399-firefly.dts | 1 + src/arm64/rockchip/rk3399-gru-bob.dts | 2 +- src/arm64/rockchip/rk3399-gru-scarlet.dtsi | 2 +- src/arm64/rockchip/rk3399-hugsun-x99.dts | 1 + .../rockchip/rk3399-khadas-edge-captain.dts | 4 + src/arm64/rockchip/rk3399-khadas-edge-v.dts | 4 + src/arm64/rockchip/rk3399-kobol-helios64.dts | 1 + src/arm64/rockchip/rk3399-leez-p710.dts | 1 + src/arm64/rockchip/rk3399-nanopi4.dtsi | 1 + src/arm64/rockchip/rk3399-orangepi.dts | 1 + src/arm64/rockchip/rk3399-puma-haikou.dts | 42 +- src/arm64/rockchip/rk3399-puma.dtsi | 15 + src/arm64/rockchip/rk3399-roc-pc.dtsi | 1 + src/arm64/rockchip/rk3399-rock-4c-plus.dts | 1 + src/arm64/rockchip/rk3399-rock-pi-4.dtsi | 1 + src/arm64/rockchip/rk3399-rockpro64.dtsi | 1 + src/arm64/rockchip/rk3399-sapphire.dtsi | 3 +- src/arm64/rockchip/rk3399.dtsi | 7 +- src/arm64/rockchip/rk3399pro-vmarc-som.dtsi | 1 + src/arm64/rockchip/rk3566-lubancat-1.dts | 2 +- src/arm64/rockchip/rk3566-powkiddy-rgb30.dts | 154 +- src/arm64/rockchip/rk3566-powkiddy-rk2023.dts | 38 + .../rockchip/rk3566-powkiddy-rk2023.dtsi | 875 +++ src/arm64/rockchip/rk3566-powkiddy-x55.dts | 926 +++ src/arm64/rockchip/rk3566-quartz64-a.dts | 5 +- src/arm64/rockchip/rk3566-radxa-cm3-io.dts | 1 + src/arm64/rockchip/rk3566-roc-pc.dts | 1 + src/arm64/rockchip/rk3566-soquartz-blade.dts | 4 + src/arm64/rockchip/rk3566-soquartz-cm4.dts | 4 + .../rockchip/rk3566-soquartz-model-a.dts | 4 + src/arm64/rockchip/rk3566-soquartz.dtsi | 1 - src/arm64/rockchip/rk3588-coolpi-cm5-evb.dts | 216 + src/arm64/rockchip/rk3588-coolpi-cm5.dtsi | 650 ++ .../rockchip/rk3588-edgeble-neu6a-io.dts | 4 - .../rockchip/rk3588-edgeble-neu6b-io.dts | 6 +- src/arm64/rockchip/rk3588-evb1-v10.dts | 100 +- src/arm64/rockchip/rk3588-jaguar.dts | 802 +++ src/arm64/rockchip/rk3588-nanopc-t6.dts | 18 +- src/arm64/rockchip/rk3588-orangepi-5-plus.dts | 1 - src/arm64/rockchip/rk3588-quartzpro64.dts | 2 +- src/arm64/rockchip/rk3588-rock-5b.dts | 13 +- src/arm64/rockchip/rk3588-turing-rk1.dtsi | 2 - src/arm64/rockchip/rk3588s-coolpi-4b.dts | 812 +++ .../rockchip/rk3588s-indiedroid-nova.dts | 11 +- src/arm64/rockchip/rk3588s-khadas-edge2.dts | 1 - src/arm64/rockchip/rk3588s-orangepi-5.dts | 7 +- src/arm64/rockchip/rk3588s-rock-5a.dts | 10 +- src/arm64/rockchip/rk3588s.dtsi | 116 + src/arm64/sprd/ums512.dtsi | 39 +- src/arm64/sprd/ums9620-2h10.dts | 38 + src/arm64/sprd/ums9620.dtsi | 245 + src/arm64/st/stm32mp251.dtsi | 16 + src/arm64/tesla/fsd.dtsi | 53 +- src/arm64/ti/k3-am62-main.dtsi | 96 +- src/arm64/ti/k3-am62-verdin-dahlia.dtsi | 3 +- src/arm64/ti/k3-am62-verdin-dev.dtsi | 3 +- src/arm64/ti/k3-am62-verdin-mallow.dtsi | 188 + src/arm64/ti/k3-am62-verdin-yavia.dtsi | 3 +- src/arm64/ti/k3-am62-verdin.dtsi | 17 +- .../ti/k3-am625-beagleplay-csi2-ov5640.dtso | 77 + .../k3-am625-beagleplay-csi2-tevi-ov5640.dtso | 77 + src/arm64/ti/k3-am625-beagleplay.dts | 4 +- src/arm64/ti/k3-am625-phyboard-lyra-rdk.dts | 98 +- .../ti/k3-am625-verdin-nonwifi-mallow.dts | 22 + src/arm64/ti/k3-am625-verdin-wifi-mallow.dts | 22 + src/arm64/ti/k3-am62a-main.dtsi | 121 +- src/arm64/ti/k3-am62a7-sk.dts | 39 + src/arm64/ti/k3-am62p-main.dtsi | 18 +- src/arm64/ti/k3-am62p5-sk.dts | 9 + src/arm64/ti/k3-am62x-sk-common.dtsi | 16 + src/arm64/ti/k3-am62x-sk-csi2-imx219.dtso | 84 + src/arm64/ti/k3-am62x-sk-csi2-ov5640.dtso | 82 + .../ti/k3-am62x-sk-csi2-tevi-ov5640.dtso | 82 + src/arm64/ti/k3-am64-main.dtsi | 22 +- src/arm64/ti/k3-am64-phycore-som.dtsi | 103 +- src/arm64/ti/k3-am642-evm.dts | 12 +- .../ti/k3-am642-phyboard-electra-rdk.dts | 1 + src/arm64/ti/k3-am642-sk.dts | 10 +- src/arm64/ti/k3-am642-tqma64xxl-mbax4xxl.dts | 1 - src/arm64/ti/k3-am642-tqma64xxl.dtsi | 1 + src/arm64/ti/k3-am65-iot2050-common-pg1.dtsi | 10 +- src/arm64/ti/k3-am65-iot2050-common-pg2.dtsi | 4 +- src/arm64/ti/k3-am65-iot2050-common.dtsi | 826 ++- src/arm64/ti/k3-am65-main.dtsi | 16 +- src/arm64/ti/k3-am65-mcu.dtsi | 8 +- src/arm64/ti/k3-am65-wakeup.dtsi | 13 +- src/arm64/ti/k3-am652.dtsi | 74 + .../ti/k3-am6528-iot2050-basic-common.dtsi | 16 +- src/arm64/ti/k3-am654-base-board.dts | 2 + .../ti/k3-am6548-iot2050-advanced-common.dtsi | 2 + .../ti/k3-am6548-iot2050-advanced-m2.dts | 12 +- src/arm64/ti/k3-am68-sk-base-board.dts | 1 + src/arm64/ti/k3-am69-sk.dts | 96 +- src/arm64/ti/k3-j7200-main.dtsi | 9 +- src/arm64/ti/k3-j7200-mcu-wakeup.dtsi | 21 +- src/arm64/ti/k3-j7200-som-p0.dtsi | 153 + src/arm64/ti/k3-j721e-evm-pcie0-ep.dtso | 53 + src/arm64/ti/k3-j721e-main.dtsi | 8 +- src/arm64/ti/k3-j721e-mcu-wakeup.dtsi | 21 +- src/arm64/ti/k3-j721e-sk.dts | 151 + src/arm64/ti/k3-j721e-som-p0.dtsi | 160 + src/arm64/ti/k3-j721s2-evm-pcie1-ep.dtso | 53 + src/arm64/ti/k3-j721s2-main.dtsi | 9 +- src/arm64/ti/k3-j721s2-mcu-wakeup.dtsi | 21 +- src/arm64/ti/k3-j721s2-som-p0.dtsi | 193 + src/arm64/ti/k3-j784s4-evm.dts | 102 + src/arm64/ti/k3-j784s4-main.dtsi | 9 +- src/arm64/ti/k3-j784s4-mcu-wakeup.dtsi | 22 +- src/arm64/xilinx/zynqmp-sck-kv-g-revA.dtso | 40 +- src/arm64/xilinx/zynqmp-sck-kv-g-revB.dtso | 42 +- src/arm64/xilinx/zynqmp-sm-k26-revA.dts | 8 +- src/arm64/xilinx/zynqmp-zc1751-xm015-dc1.dts | 8 +- src/arm64/xilinx/zynqmp-zc1751-xm016-dc2.dts | 16 +- src/arm64/xilinx/zynqmp-zc1751-xm017-dc3.dts | 8 +- src/arm64/xilinx/zynqmp-zc1751-xm018-dc4.dts | 26 +- src/arm64/xilinx/zynqmp-zc1751-xm019-dc5.dts | 8 +- src/arm64/xilinx/zynqmp-zcu100-revC.dts | 4 +- src/arm64/xilinx/zynqmp.dtsi | 15 +- src/loongarch/loongson-2k0500-ref.dts | 88 + src/loongarch/loongson-2k0500.dtsi | 266 + src/loongarch/loongson-2k1000-ref.dts | 183 + src/loongarch/loongson-2k1000.dtsi | 492 ++ src/loongarch/loongson-2k2000-ref.dts | 72 + src/loongarch/loongson-2k2000.dtsi | 300 + src/powerpc/fsl/t1023si-post.dtsi | 79 +- src/powerpc/fsl/t1040si-post.dtsi | 71 +- src/riscv/microchip/mpfs-icicle-kit.dts | 21 + src/riscv/microchip/mpfs.dtsi | 17 + src/riscv/renesas/r9a07g043f.dtsi | 4 + src/riscv/sifive/hifive-unmatched-a00.dts | 1 + src/riscv/sophgo/cv1800b.dtsi | 118 +- src/riscv/sophgo/cv1812h-huashan-pi.dts | 48 + src/riscv/sophgo/cv1812h.dtsi | 24 + src/riscv/sophgo/cv18xx.dtsi | 192 + src/riscv/sophgo/sg2042.dtsi | 80 +- src/riscv/starfive/jh7100-common.dtsi | 131 + src/riscv/starfive/jh7100.dtsi | 60 +- src/riscv/starfive/jh7110.dtsi | 4 +- src/riscv/thead/th1520-beaglev-ahead.dts | 20 + src/riscv/thead/th1520-lichee-module-4a.dtsi | 20 + src/riscv/thead/th1520.dtsi | 34 + 1311 files changed, 67670 insertions(+), 8539 deletions(-) create mode 100644 Bindings/arm/google.yaml delete mode 100644 Bindings/arm/mediatek/mediatek,audsys.txt create mode 100644 Bindings/arm/mediatek/mediatek,audsys.yaml delete mode 100644 Bindings/arm/mediatek/mediatek,ethsys.txt delete mode 100644 Bindings/arm/msm/qcom,idle-state.txt create mode 100644 Bindings/arm/qcom,coresight-remote-etm.yaml delete mode 100644 Bindings/clock/brcm,kona-ccu.txt create mode 100644 Bindings/clock/brcm,kona-ccu.yaml create mode 100644 Bindings/clock/fsl,imx93-anatop.yaml create mode 100644 Bindings/clock/google,gs101-clock.yaml delete mode 100644 Bindings/clock/hi3620-clock.txt create mode 100644 Bindings/clock/mediatek,ethsys.yaml create mode 100644 Bindings/clock/mediatek,mt7988-ethwarp.yaml create mode 100644 Bindings/clock/mediatek,mt7988-xfi-pll.yaml create mode 100644 Bindings/clock/qcom,gcc-ipq6018.yaml create mode 100644 Bindings/clock/qcom,qdu1000-ecpricc.yaml create mode 100644 Bindings/clock/qcom,sm8650-dispcc.yaml create mode 100644 Bindings/clock/qcom,sm8650-gcc.yaml create mode 100644 Bindings/clock/qcom,x1e80100-gcc.yaml delete mode 100644 Bindings/clock/silabs,si5351.txt create mode 100644 Bindings/clock/silabs,si5351.yaml create mode 100644 Bindings/clock/sophgo,cv1800-clk.yaml create mode 100644 Bindings/clock/st,stm32mp25-rcc.yaml create mode 100644 Bindings/crypto/inside-secure,safexcel.yaml delete mode 100644 Bindings/crypto/inside-secure-safexcel.txt delete mode 100644 Bindings/display/mediatek/mediatek,mdp-rdma.yaml create mode 100644 Bindings/display/mediatek/mediatek,padding.yaml create mode 100644 Bindings/display/msm/qcom,sdm670-mdss.yaml create mode 100644 Bindings/display/msm/qcom,sm8650-dpu.yaml create mode 100644 Bindings/display/msm/qcom,sm8650-mdss.yaml create mode 100644 Bindings/display/panel/fascontek,fs035vg158.yaml create mode 100644 Bindings/display/panel/ilitek,ili9805.yaml create mode 100644 Bindings/display/panel/synaptics,r63353.yaml delete mode 100644 Bindings/display/rockchip/inno_hdmi-rockchip.txt create mode 100644 Bindings/display/rockchip/rockchip,inno-hdmi.yaml create mode 100644 Bindings/dma/loongson,ls2x-apbdma.yaml create mode 100644 Bindings/dts-coding-style.rst delete mode 100644 Bindings/fpga/altera-fpga2sdram-bridge.txt delete mode 100644 Bindings/fpga/altera-freeze-bridge.txt delete mode 100644 Bindings/fpga/altera-hps2fpga-bridge.txt create mode 100644 Bindings/fpga/altr,freeze-bridge-controller.yaml create mode 100644 Bindings/fpga/altr,socfpga-fpga2sdram-bridge.yaml create mode 100644 Bindings/fpga/altr,socfpga-hps2fpga-bridge.yaml delete mode 100644 Bindings/fpga/fpga-bridge.txt create mode 100644 Bindings/fpga/fpga-bridge.yaml create mode 100644 Bindings/gpio/nuvoton,sgpio.yaml create mode 100644 Bindings/gpio/realtek,rtd-gpio.yaml create mode 100644 Bindings/gpu/img,powervr.yaml delete mode 100644 Bindings/hwmon/gpio-fan.txt create mode 100644 Bindings/hwmon/gpio-fan.yaml create mode 100644 Bindings/hwmon/lltc,ltc4286.yaml create mode 100644 Bindings/iio/adc/maxim,max34408.yaml create mode 100644 Bindings/iio/chemical/aosong,ags02ma.yaml create mode 100644 Bindings/iio/dac/microchip,mcp4821.yaml create mode 100644 Bindings/iio/humidity/ti,hdc3020.yaml create mode 100644 Bindings/iio/imu/bosch,bmi323.yaml create mode 100644 Bindings/iio/light/liteon,ltr390.yaml create mode 100644 Bindings/iio/light/vishay,veml6075.yaml create mode 100644 Bindings/iio/pressure/honeywell,hsc030pa.yaml create mode 100644 Bindings/iio/temperature/microchip,mcp9600.yaml create mode 100644 Bindings/input/adafruit,seesaw-gamepad.yaml delete mode 100644 Bindings/input/gpio-mouse.txt create mode 100644 Bindings/input/gpio-mouse.yaml delete mode 100644 Bindings/input/ti,drv2665.txt delete mode 100644 Bindings/input/ti,drv2667.txt create mode 100644 Bindings/input/ti,drv266x.yaml create mode 100644 Bindings/input/touchscreen/neonode,zforce.yaml delete mode 100644 Bindings/input/touchscreen/samsung,s6sy761.txt create mode 100644 Bindings/input/touchscreen/samsung,s6sy761.yaml delete mode 100644 Bindings/input/touchscreen/zforce_ts.txt create mode 100644 Bindings/interconnect/qcom,sm6115.yaml create mode 100644 Bindings/interconnect/qcom,sm8650-rpmh.yaml create mode 100644 Bindings/interconnect/qcom,x1e80100-rpmh.yaml create mode 100644 Bindings/leds/allwinner,sun50i-a100-ledc.yaml create mode 100644 Bindings/loongarch/cpus.yaml create mode 100644 Bindings/loongarch/loongson.yaml create mode 100644 Bindings/media/cnm,wave521c.yaml create mode 100644 Bindings/media/i2c/alliedvision,alvium-csi2.yaml create mode 100644 Bindings/media/i2c/galaxycore,gc0308.yaml create mode 100644 Bindings/media/i2c/galaxycore,gc2145.yaml create mode 100644 Bindings/media/i2c/ovti,ov64a40.yaml create mode 100644 Bindings/media/i2c/techwell,tw9900.yaml create mode 100644 Bindings/media/i2c/thine,thp7312.yaml create mode 100644 Bindings/media/mediatek,mdp3-fg.yaml create mode 100644 Bindings/media/mediatek,mdp3-hdr.yaml create mode 100644 Bindings/media/mediatek,mdp3-stitch.yaml create mode 100644 Bindings/media/mediatek,mdp3-tcc.yaml create mode 100644 Bindings/media/mediatek,mdp3-tdshp.yaml create mode 100644 Bindings/media/st,stm32-dcmipp.yaml create mode 100644 Bindings/media/starfive,jh7110-camss.yaml create mode 100644 Bindings/mfd/ams,as3711.yaml delete mode 100644 Bindings/mfd/as3711.txt create mode 100644 Bindings/net/dsa/marvell,mv88e6060.yaml create mode 100644 Bindings/net/dsa/marvell,mv88e6xxx.yaml delete mode 100644 Bindings/net/dsa/marvell.txt create mode 100644 Bindings/net/lantiq,pef2256.yaml create mode 100644 Bindings/net/marvell,aquantia.yaml create mode 100644 Bindings/net/renesas,ethertsn.yaml create mode 100644 Bindings/pinctrl/qcom,lpass-lpi-common.yaml create mode 100644 Bindings/pinctrl/qcom,sm4450-tlmm.yaml create mode 100644 Bindings/pinctrl/qcom,sm8650-lpass-lpi-pinctrl.yaml create mode 100644 Bindings/pinctrl/qcom,sm8650-tlmm.yaml create mode 100644 Bindings/pinctrl/qcom,x1e80100-tlmm.yaml delete mode 100644 Bindings/pwm/pwm-omap-dmtimer.txt create mode 100644 Bindings/pwm/ti,omap-dmtimer-pwm.yaml create mode 100644 Bindings/rtc/adi,max31335.yaml create mode 100644 Bindings/rtc/nuvoton,ma35d1-rtc.yaml delete mode 100644 Bindings/security/tpm/google,cr50.txt delete mode 100644 Bindings/security/tpm/ibmvtpm.txt delete mode 100644 Bindings/security/tpm/st33zp24-i2c.txt delete mode 100644 Bindings/security/tpm/st33zp24-spi.txt delete mode 100644 Bindings/security/tpm/tpm-i2c.txt delete mode 100644 Bindings/security/tpm/tpm_tis_mmio.txt delete mode 100644 Bindings/security/tpm/tpm_tis_spi.txt create mode 100644 Bindings/serial/arm,dcc.yaml rename Bindings/{arm => soc/xilinx}/xilinx.yaml (95%) delete mode 100644 Bindings/sound/es8328.txt create mode 100644 Bindings/sound/everest,es8328.yaml delete mode 100644 Bindings/sound/fsl,mqs.txt create mode 100644 Bindings/sound/fsl,mqs.yaml create mode 100644 Bindings/sound/mediatek,mt2701-audio.yaml delete mode 100644 Bindings/sound/mt2701-afe-pcm.txt delete mode 100644 Bindings/spi/adi,axi-spi-engine.txt create mode 100644 Bindings/spi/adi,axi-spi-engine.yaml create mode 100644 Bindings/thermal/mediatek,thermal.yaml delete mode 100644 Bindings/thermal/mediatek-thermal.txt create mode 100644 Bindings/tpm/google,cr50.yaml create mode 100644 Bindings/tpm/ibm,vtpm.yaml create mode 100644 Bindings/tpm/microsoft,ftpm.yaml create mode 100644 Bindings/tpm/tcg,tpm-tis-i2c.yaml create mode 100644 Bindings/tpm/tcg,tpm-tis-mmio.yaml create mode 100644 Bindings/tpm/tcg,tpm_tis-spi.yaml create mode 100644 Bindings/tpm/tpm-common.yaml create mode 100644 Bindings/usb/qcom,wcd939x-usbss.yaml create mode 100644 Bindings/w1/amd,axi-1wire-host.yaml create mode 100644 Bindings/watchdog/nxp,pnx4008-wdt.yaml delete mode 100644 Bindings/watchdog/pnx4008-wdt.txt create mode 100644 Bindings/watchdog/qca,ar7130-wdt.yaml delete mode 100644 Bindings/watchdog/qca-ar7130-wdt.txt delete mode 100644 Bindings/watchdog/realtek,rtd119x.txt create mode 100644 Bindings/watchdog/realtek,rtd1295-watchdog.yaml create mode 100644 Bindings/watchdog/technologic,ts7200-wdt.yaml create mode 100644 include/dt-bindings/clock/google,gs101.h create mode 100644 include/dt-bindings/clock/mediatek,mt7988-clk.h create mode 100644 include/dt-bindings/clock/qcom,qdu1000-ecpricc.h create mode 100644 include/dt-bindings/clock/qcom,sc8280xp-camcc.h create mode 100644 include/dt-bindings/clock/qcom,sm8650-dispcc.h create mode 100644 include/dt-bindings/clock/qcom,sm8650-gcc.h create mode 100644 include/dt-bindings/clock/qcom,sm8650-gpucc.h create mode 100644 include/dt-bindings/clock/qcom,sm8650-tcsr.h create mode 100644 include/dt-bindings/clock/qcom,x1e80100-gcc.h create mode 100644 include/dt-bindings/clock/sophgo,cv1800.h create mode 100644 include/dt-bindings/clock/st,stm32mp25-rcc.h create mode 100644 include/dt-bindings/dma/fsl-edma.h create mode 100644 include/dt-bindings/iio/qcom,spmi-adc7-pm7325.h create mode 100644 include/dt-bindings/iio/qcom,spmi-adc7-smb139x.h create mode 100644 include/dt-bindings/interconnect/qcom,sm6115.h create mode 100644 include/dt-bindings/interconnect/qcom,sm8650-rpmh.h create mode 100644 include/dt-bindings/interconnect/qcom,x1e80100-rpmh.h create mode 100644 include/dt-bindings/reset/amlogic,c3-reset.h create mode 100644 include/dt-bindings/reset/mediatek,mt7988-resets.h create mode 100644 include/dt-bindings/reset/qcom,sm8650-gpucc.h create mode 100644 include/dt-bindings/reset/st,stm32mp25-rcc.h create mode 100644 src/arm/qcom/pm8018.dtsi create mode 100644 src/arm/qcom/pm8058.dtsi rename src/arm/qcom/{qcom-pm8226.dtsi => pm8226.dtsi} (99%) create mode 100644 src/arm/qcom/pm8821.dtsi rename src/arm/qcom/{qcom-pm8841.dtsi => pm8841.dtsi} (100%) create mode 100644 src/arm/qcom/pm8921.dtsi rename src/arm/qcom/{qcom-pm8941.dtsi => pm8941.dtsi} (99%) rename src/arm/qcom/{qcom-pma8084.dtsi => pma8084.dtsi} (100%) rename src/arm/qcom/{qcom-pmx55.dtsi => pmx55.dtsi} (100%) rename src/arm/qcom/{qcom-pmx65.dtsi => pmx65.dtsi} (100%) create mode 100644 src/arm/qcom/qcom-msm8226-microsoft-common.dtsi create mode 100644 src/arm/qcom/qcom-msm8226-microsoft-dempsey.dts create mode 100644 src/arm/qcom/qcom-msm8226-microsoft-makepeace.dts create mode 100644 src/arm/qcom/qcom-msm8226-microsoft-moneypenny.dts create mode 100644 src/arm/qcom/qcom-msm8926-htc-memul.dts create mode 100644 src/arm/qcom/qcom-msm8926-microsoft-superman-lte.dts create mode 100644 src/arm/qcom/qcom-msm8926-microsoft-tesla.dts create mode 100644 src/arm/qcom/qcom-msm8926-motorola-peregrine.dts create mode 100644 src/arm/rockchip/rk3128-xpi-3128.dts create mode 100644 src/arm/rockchip/rv1109-sonoff-ihost.dts create mode 100644 src/arm/rockchip/rv1109.dtsi create mode 100644 src/arm/rockchip/rv1126-sonoff-ihost.dts create mode 100644 src/arm/rockchip/rv1126-sonoff-ihost.dtsi create mode 100644 src/arm/st/ste-href-ab8505.dtsi create mode 100644 src/arm/ti/omap/motorola-mapphone-handset.dtsi create mode 100644 src/arm/ti/omap/motorola-mapphone-mz607-mz617.dtsi create mode 100644 src/arm/ti/omap/motorola-mapphone-xt8xx.dtsi create mode 100644 src/arm/ti/omap/omap4-xyboard-mz609.dts create mode 100644 src/arm/ti/omap/omap4-xyboard-mz617.dts create mode 100644 src/arm64/allwinner/sun50i-h618-orangepi-zero2w.dts create mode 100644 src/arm64/allwinner/sun50i-h618-transpeed-8k618-t.dts create mode 100644 src/arm64/exynos/exynosautov920-pinctrl.dtsi create mode 100644 src/arm64/exynos/exynosautov920-sadk.dts create mode 100644 src/arm64/exynos/exynosautov920.dtsi create mode 100644 src/arm64/exynos/google/gs101-oriole.dts create mode 100644 src/arm64/exynos/google/gs101-pinctrl.dtsi create mode 100644 src/arm64/exynos/google/gs101-pinctrl.h create mode 100644 src/arm64/exynos/google/gs101.dtsi create mode 100644 src/arm64/freescale/fsl-lx2160a-tqmlx2160a-mblx2160a.dts create mode 100644 src/arm64/freescale/fsl-lx2160a-tqmlx2160a-mblx2160a_12_x_x.dtso create mode 100644 src/arm64/freescale/fsl-lx2160a-tqmlx2160a-mblx2160a_14_x_x.dtso create mode 100644 src/arm64/freescale/fsl-lx2160a-tqmlx2160a-mblx2160a_x_11_x.dtso create mode 100644 src/arm64/freescale/fsl-lx2160a-tqmlx2160a-mblx2160a_x_7_x.dtso create mode 100644 src/arm64/freescale/fsl-lx2160a-tqmlx2160a-mblx2160a_x_8_x.dtso create mode 100644 src/arm64/freescale/fsl-lx2160a-tqmlx2160a.dtsi create mode 100644 src/arm64/freescale/imx8mm-overdrive.dtsi create mode 100644 src/arm64/freescale/imx8mm-verdin-mallow.dtsi create mode 100644 src/arm64/freescale/imx8mm-verdin-nonwifi-mallow.dts create mode 100644 src/arm64/freescale/imx8mm-verdin-wifi-mallow.dts create mode 100644 src/arm64/freescale/imx8mn-bsh-smm-s2-display.dtsi create mode 100644 src/arm64/freescale/imx8mn-dimonoff-gateway-evk.dts create mode 100644 src/arm64/freescale/imx8mn-overdrive.dtsi create mode 100644 src/arm64/freescale/imx8mn-rve-gateway.dts create mode 100644 src/arm64/freescale/imx8mp-skov-reva.dtsi create mode 100644 src/arm64/freescale/imx8mp-skov-revb-hdmi.dts create mode 100644 src/arm64/freescale/imx8mp-skov-revb-lt6.dts create mode 100644 src/arm64/freescale/imx8mp-skov-revb-mi1010ait-1cp1.dts create mode 100644 src/arm64/freescale/imx8mp-tqma8mpql-mba8mpxl-lvds-g133han01.dtso create mode 100644 src/arm64/freescale/imx8mp-verdin-mallow.dtsi create mode 100644 src/arm64/freescale/imx8mp-verdin-nonwifi-mallow.dts create mode 100644 src/arm64/freescale/imx8mp-verdin-wifi-mallow.dts create mode 100644 src/arm64/freescale/imx8qxp-ss-vpu.dtsi create mode 100644 src/arm64/freescale/imx93-tqma9352-mba93xxca.dts create mode 100644 src/arm64/marvell/ac5x-rd-carrier-cn9131.dts create mode 100644 src/arm64/marvell/ac5x-rd-carrier.dtsi create mode 100644 src/arm64/marvell/cn9130-db-comexpress.dtsi create mode 100644 src/arm64/marvell/cn9131-db-comexpress.dtsi create mode 100644 src/arm64/mediatek/mt8183-kukui-jacuzzi-makomo-sku0.dts create mode 100644 src/arm64/mediatek/mt8183-kukui-jacuzzi-makomo-sku1.dts create mode 100644 src/arm64/mediatek/mt8183-kukui-jacuzzi-pico.dts create mode 100644 src/arm64/mediatek/mt8183-kukui-jacuzzi-pico6.dts create mode 100644 src/arm64/mediatek/mt8183-kukui-katsu-sku32.dts create mode 100644 src/arm64/mediatek/mt8183-kukui-katsu-sku38.dts create mode 100644 src/arm64/mediatek/mt8188-evb.dts create mode 100644 src/arm64/mediatek/mt8188.dtsi create mode 100644 src/arm64/qcom/ipq9574-rdp-common.dtsi create mode 100644 src/arm64/qcom/msm8916-modem-qdsp6.dtsi create mode 100644 src/arm64/qcom/msm8939-huawei-kiwi.dts create mode 100644 src/arm64/qcom/qcm6490-idp.dts create mode 100644 src/arm64/qcom/qcs6490-rb3gen2.dts create mode 100644 src/arm64/qcom/sm8250-xiaomi-pipa.dts create mode 100644 src/arm64/qcom/sm8650-mtp.dts create mode 100644 src/arm64/qcom/sm8650-qrd.dts create mode 100644 src/arm64/qcom/sm8650.dtsi create mode 100644 src/arm64/qcom/x1e80100-crd.dts create mode 100644 src/arm64/qcom/x1e80100-qcp.dts create mode 100644 src/arm64/qcom/x1e80100.dtsi create mode 100644 src/arm64/rockchip/rk3326-anbernic-rg351m.dtsi create mode 100644 src/arm64/rockchip/rk3326-anbernic-rg351v.dts create mode 100644 src/arm64/rockchip/rk3566-powkiddy-rk2023.dts create mode 100644 src/arm64/rockchip/rk3566-powkiddy-rk2023.dtsi create mode 100644 src/arm64/rockchip/rk3566-powkiddy-x55.dts create mode 100644 src/arm64/rockchip/rk3588-coolpi-cm5-evb.dts create mode 100644 src/arm64/rockchip/rk3588-coolpi-cm5.dtsi create mode 100644 src/arm64/rockchip/rk3588-jaguar.dts create mode 100644 src/arm64/rockchip/rk3588s-coolpi-4b.dts create mode 100644 src/arm64/sprd/ums9620-2h10.dts create mode 100644 src/arm64/sprd/ums9620.dtsi create mode 100644 src/arm64/ti/k3-am62-verdin-mallow.dtsi create mode 100644 src/arm64/ti/k3-am625-beagleplay-csi2-ov5640.dtso create mode 100644 src/arm64/ti/k3-am625-beagleplay-csi2-tevi-ov5640.dtso create mode 100644 src/arm64/ti/k3-am625-verdin-nonwifi-mallow.dts create mode 100644 src/arm64/ti/k3-am625-verdin-wifi-mallow.dts create mode 100644 src/arm64/ti/k3-am62x-sk-csi2-imx219.dtso create mode 100644 src/arm64/ti/k3-am62x-sk-csi2-ov5640.dtso create mode 100644 src/arm64/ti/k3-am62x-sk-csi2-tevi-ov5640.dtso create mode 100644 src/arm64/ti/k3-am652.dtsi create mode 100644 src/arm64/ti/k3-j721e-evm-pcie0-ep.dtso create mode 100644 src/arm64/ti/k3-j721s2-evm-pcie1-ep.dtso create mode 100644 src/loongarch/loongson-2k0500-ref.dts create mode 100644 src/loongarch/loongson-2k0500.dtsi create mode 100644 src/loongarch/loongson-2k1000-ref.dts create mode 100644 src/loongarch/loongson-2k1000.dtsi create mode 100644 src/loongarch/loongson-2k2000-ref.dts create mode 100644 src/loongarch/loongson-2k2000.dtsi create mode 100644 src/riscv/sophgo/cv1812h-huashan-pi.dts create mode 100644 src/riscv/sophgo/cv1812h.dtsi create mode 100644 src/riscv/sophgo/cv18xx.dtsi
Hi Tom,
On Fri, 29 Mar 2024 at 18:53, Tom Rini trini@konsulko.com wrote:
b35b9bd1d4ee Merge tag 'v6.8-dts-raw'
Glad to see this coming up. I hope it goes smoothly as expected.
-Sumit
1f50937554b4 Merge tag 'sound-6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound 576ba37bcbf9 Merge tag 'net-6.8-rc8' of git://git.kernel.org/pub/scm/linux/kernel/git/netdev/net c83dc02bae3e Merge tag 'qcom-arm64-fixes-for-6.8-2' of https://git.kernel.org/pub/scm/linux/kernel/git/qcom/linux into arm/fixes fb254675a395 ASoC: dt-bindings: nvidia: Fix 'lge' vendor prefix c748b8a7dbe8 Merge tag 'tegra-for-6.8-arm64-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/tegra/linux into arm/fixes a2e893adde74 Merge tag 'imx-fixes-6.8-2' of git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux into arm/fixes abb0f1b369e4 Merge tag 'qcom-arm64-fixes-for-6.8' of https://git.kernel.org/pub/scm/linux/kernel/git/qcom/linux into arm/fixes f143aa9a89ec Revert "arm64: dts: qcom: msm8996: Hook up MPM" 9a5690b7be49 arm64: dts: qcom: sc8280xp-x13s: limit pcie4 link speed ca6dcb63bd34 arm64: dts: qcom: sc8280xp-crd: limit pcie4 link speed 8532bb680bd0 dt-bindings: net: renesas,ethertsn: Document default for delays 42569705a4a0 Merge tag 'v6.8-rc6-dts-raw' 06c62487a0b4 arm64: dts: imx8mp: Fix LDB clocks property 7c93039778e4 arm64: dts: imx8mp: Fix TC9595 reset GPIO on DH i.MX8M Plus DHCOM SoM 7f9a36c5ce39 ARM: dts: imx7: remove DSI port endpoints 87ea8526eaf3 Merge tag 'loongarch-fixes-6.8-3' of git://git.kernel.org/pub/scm/linux/kernel/git/chenhuacai/linux-loongson d4a4b892cd33 Merge tag 'arm-fixes-6.8-2' of git://git.kernel.org/pub/scm/linux/kernel/git/soc/soc 4faf103c7468 Merge tag 'renesas-fixes-for-v6.8-tag1' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/renesas-devel into arm/fixes c1858748b935 Merge tag 'riscv-dt-fixes-for-v6.8-rc6' of https://git.kernel.org/pub/scm/linux/kernel/git/conor/linux into arm/fixes f1bb487d660f LoongArch: dts: Minor whitespace cleanup b60485a78d66 Merge tag 'clk-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/clk/linux d641a222a5d4 arm64: tegra: Fix Tegra234 MGBE power-domains 31aeabc2669e ARM: dts: renesas: rcar-gen2: Add missing #interrupt-cells to DA9063 nodes 8c5d69d4f1e9 arm64: dts: qcom: Fix interrupt-map cell sizes 43b35c5b7347 arm: dts: Fix dtc interrupt_map warnings f00ce91341b9 arm64: dts: Fix dtc interrupt_provider warnings c21ad68d3254 arm: dts: Fix dtc interrupt_provider warnings 20a9f605f025 Merge tag 'v6.8-rockchip-dtsfixes1' of git://git.kernel.org/pub/scm/linux/kernel/git/mmind/linux-rockchip into arm/fixes 1d9be1dcae7c Merge tag 'imx-fixes-6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux into arm/fixes c27426925b7b Merge tag 'v6.8-rc5-dts-raw' 582c3e28f603 Merge tag 'sound-6.8-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound 81da29f3007e arm64: tegra: Set the correct PHY mode for MGBE 30e4bc5d76ff Merge tag 'devicetree-fixes-for-6.8-1' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux f0c34a9f448e riscv: dts: sifive: add missing #interrupt-cells to pmic db36be2a8839 arm64: dts: rockchip: Correct Indiedroid Nova GPIO Names ec7d411e57d6 arm64: dts: rockchip: Drop interrupts property from rk3328 pwm-rockchip node 105b1e4e5e28 arm64: dts: rockchip: set num-cs property for spi on px30 a05f0ca9a008 arm64: dts: rockchip: minor rk3588 whitespace cleanup 41d6b3786aa9 riscv: dts: starfive: replace underscores in node names 910c8965eb0c dt-bindings: ufs: samsung,exynos-ufs: Add size constraints on "samsung,sysreg" d78e8a541b0a net: marvell,prestera: Fix example PCI bus addressing b40e56bea854 ASoC: dt-bindings: google,sc7280-herobrine: Drop bouncing @codeaurora 48b3246a26fe Revert "arm64: dts: imx8mn-var-som-symphony: Describe the USB-C connector" a1c414f8f89a Revert "arm64: dts: imx8mp-dhcom-pdk3: Describe the USB-C connector" 768ad06f1efa arm64: dts: tqma8mpql: fix audio codec iov-supply 77040f90f388 Merge tag 'v6.8-rc3-dts-raw' 65143ffc8608 arm64: dts: rockchip: drop unneeded status from rk3588-jaguar gpio-leds 39497955d1c0 ARM: dts: rockchip: Drop interrupts property from pwm-rockchip nodes 610e244453be arm64: dts: rockchip: Fix the num-lanes of pcie3x4 on Cool Pi CM5 EVB d6e600aea013 arm64: dts: rockchip: rename vcc5v0_usb30_host regulator for Cool Pi CM5 EVB 6be17990ec10 arm64: dts: rockchip: aliase sdmmc as mmc1 for Cool Pi CM5 EVB 77765eecb670 arm64: dts: rockchip: aliase sdmmc as mmc1 for Cool Pi 4B 7bca62b5ae66 arm64: dts: qcom: sm6115: Fix missing interconnect-names b2bc58ba4504 arm64: dts: imx8mp: Disable UART4 by default on Data Modul i.MX8M Plus eDM SBC 9474eb5c3d86 ALSA: Various fixes for Cirrus Logic CS35L56 support 1e8df48d4da1 dt-bindings: tpm: Drop type from "resets" 4d5c46ab184f dt-bindings: display: nxp,tda998x: Fix 'audio-ports' constraints fede8bd8306c dt-bindings: xilinx: replace Piyush Mehta maintainership eb691d1ece78 Merge tag 'v6.8-rc2-dts-raw' 5b093a56e797 ASoC: sun4i-spdif: Add Allwinner H616 compatible f2ce9dca7322 ASoC: sun4i-spdif: Fix requirements for H6 fd23c7505f20 arm64: dts: qcom: sm8650-mtp: add gpio74 as reserved gpio cfbd9243ac13 arm64: dts: qcom: sm8650-qrd: add gpio74 as reserved gpio 101ce3470b0e Merge tag 'drm-fixes-2024-01-27' of git://anongit.freedesktop.org/drm/drm 71ca3bf1c96e Merge tag 'arm-fixes-6.8-1' of git://git.kernel.org/pub/scm/linux/kernel/git/soc/soc 74c898882ebb riscv: dts: sophgo: separate sg2042 mtime and mtimecmp to fit aclint format 28b77b56d972 arm64: dts: rockchip: mark system power controller on rk3588-evb1 986a9f1778ef Merge tag 'samsung-fixes-6.8' of https://git.kernel.org/pub/scm/linux/kernel/git/krzk/linux into arm/fixes 6cf0227916ec arm64: dts: Fix TPM schema violations 60245a9006e9 ARM: dts: Fix TPM schema violations 92924d8db61a Merge tag 'exynos-drm-fixes-for-v6.8-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/daeinki/drm-exynos into drm-fixes 3b240d0d94a9 dt-bindings: media: Remove K3 Family Prefix from Compatible 186b38b97035 ARM: dts: exynos4212-tab3: add samsung,invert-vclk flag to fimd c4f0c99dffb8 arm64: dts: exynos: gs101: comply with the new cmu_misc clock names 429796fee0f1 dt-bindings: clock: gs101: rename cmu_misc clock-names 80d76b25d32f Merge tag 'v6.8-rc1-dts-raw' 339d8d1caab5 Merge tag 'timers-core-2024-01-21' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip df1980733ce9 Merge tag 'dmaengine-fix-6.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/vkoul/dmaengine 8c23badf69c3 Merge tag 'riscv-for-linus-6.8-mw4' of git://git.kernel.org/pub/scm/linux/kernel/git/riscv/linux d5a95e32a555 Merge tag 'loongarch-6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/chenhuacai/linux-loongson 815e38060bf4 Merge tag 'sound-fix-6.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound f07a1b362766 Merge tag 'for-v6.8-v2' of git://git.kernel.org/pub/scm/linux/kernel/git/sre/linux-power-supply 9411a3099e9c Merge tag 'i2c-for-6.8-rc1-rebased' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux fcb7108dc362 Merge tag 'rtc-6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/abelloni/linux 8e06ce5908ff Merge tag 'input-for-v6.8-rc0' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input 7b18579c0bef Merge tag 'phy-for-6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/phy/linux-phy dd4871a00012 Merge tag 'gpio-fixes-for-v6.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/brgl/linux 8dfd2acd2c0c Merge tag 'backlight-next-6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/backlight 736ecd5cf03c Merge tag 'iommu-updates-v6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu 7d29a06cb311 dt-bindings: i2c: document st,stm32mp25-i2c compatible 365a95704e98 dt-bindings: at24: add ROHM BR24G04 05d2a9834fd6 Merge tag 'usb-6.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb 70a7bee43907 Merge tag 'tty-6.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty 6a04bf7a4f07 Merge tag 'char-misc-6.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc e0c35697cd80 Merge tag 'pci-v6.8-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/pci/pci cf29a14b0a23 Merge tag 'pinctrl-v6.8-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl 902219ef9ed0 Merge tag 'mailbox-v6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/jassibrar/mailbox c437f65015a8 Merge tag 'leds-next-6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/leds d0902d05b4a0 Merge tag 'mfd-next-6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd 8be1d4636d32 Merge tag 'rproc-v6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/remoteproc/linux 6eaaddf12639 Merge tag 'riscv-for-linus-6.8-mw1' of git://git.kernel.org/pub/scm/linux/kernel/git/riscv/linux 2cb012b6fe68 LoongArch: dts: DeviceTree for Loongson-2K2000 6ab0a6f08b83 LoongArch: dts: DeviceTree for Loongson-2K1000 491426707de1 LoongArch: dts: DeviceTree for Loongson-2K0500 c007f27059d1 dt-bindings: interrupt-controller: loongson,liointc: Fix dtbs_check warning for interrupt-names d9a3ae336ecb dt-bindings: interrupt-controller: loongson,liointc: Fix dtbs_check warning for reg-names 4ee19a9d7583 dt-bindings: loongarch: Add Loongson SoC boards compatibles 3e99ee3f7c53 dt-bindings: loongarch: Add CPU bindings for LoongArch e8bc7c9c625e dt-bindings: don't anchor DT_SCHEMA_FILES to bindings directory f5918b47370e dt-bindings: rtc: max31335: add max31335 bindings 7e34d7b53615 rtc: rv8803: add wakeup-source support 81d186f05921 Merge branch 'pci/dt-bindings' 8bd798490681 Merge branch 'pci/controller/rcar' e166e5aad3b0 Merge branch 'pci/controller/cadence' 9de355a75fde dt-bindings: gpio: xilinx: Fix node address in gpio 28bf1e4e9775 dt-bindings: mailbox: qcom-ipcc: document the X1E80100 Inter-Processor Communication Controller f6b31bdd3c60 dt-bindings: mailbox: add Versal IPI bindings c3301d070937 dt-bindings: mailbox: zynqmp: extend required list 6bf977408719 dt-bindings: mailbox: qcom,apcs-kpss-global: use fallbacks b9ea63718a7e dt-bindings: mailbox: qcom,apcs-kpss-global: drop duplicated qcom,ipq8074-apcs-apps-global e485b251a3a4 Merge tag 'devicetree-for-6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux 60edd8755b1b Merge tag 'pwm/for-6.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/thierry.reding/linux-pwm f946a0610062 Merge tag 'hid-for-linus-2024010801' of git://git.kernel.org/pub/scm/linux/kernel/git/hid/hid 5a9222178c60 Merge tag 'media/v6.8-2' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media 0c57fa00ac11 Merge tag 'mmc-v6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/ulfh/mmc 120152dd192c Merge tag 'pmdomain-v6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/ulfh/linux-pm f25acec1f182 Merge tag 'gnss-6.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/johan/gnss 040b6611cd72 Merge tag 'clk-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/clk/linux 432f2b929aa4 Merge tag 'gpio-updates-for-v6.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/brgl/linux 5df1a59e6086 Merge tag 'linux-watchdog-6.8-rc1' of git://www.linux-watchdog.org/linux-watchdog 1d81fba29be6 Merge tag 'hwmon-for-v6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging dd7110d3d5d1 Merge tag 'sound-6.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound c916bd7a1d38 Merge tag 'drm-next-2024-01-10' of git://anongit.freedesktop.org/drm/drm 32704b03c7ec Merge tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi c0d1d21fe5ff dt-bindings: fpga: altera: Convert bridge bindings to yaml 86986ec77fc7 dt-bindings: fpga: Convert bridge binding to yaml 149beabce38e dt-bindings: vendor-prefixes: Add smi da831df01407 Merge tag 'soc-drivers-6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/soc/soc d0949aef9e29 Merge tag 'soc-dt-6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/soc/soc c5ee04d9a430 Merge tag 'net-next-6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/netdev/net-next 17d4b2f2c7c6 dt-bindings: riscv: Document cbop-block-size 6361e08793d7 dt-bindings: riscv: permit numbers in "riscv,isa" 99f0fa81f51f dt-bindings: riscv: cpus: Clarify mmu-type interpretation 5744984c407c ARM: dts: usr8200: Fix phy registers fd6e692990ee dt-bindings: PCI: brcmstb: Add property "brcm,clkreq-mode" db07ea081cee dt-bindings: power: Clarify wording for wakeup-source property 9deb5d7e7649 Merge tag 'v6.8-p1' of git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6 f412e763e552 dt-bindings: mfd: sprd: Add support for UMS9620 b50b2489e1a2 dt-bindings: input: bindings for Adafruit Seesaw Gamepad 9fcf5401177c Merge patch series "riscv: hwprobe: add Zicond, Zacas and Ztso support" 6b479ffcb9ed dt-bindings: riscv: add Zacas ISA extension description 45e895d242d0 Merge remote-tracking branch 'palmer/fixes' into for-next 129abc9e5b89 Merge tag 'thermal-6.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm 72e795875f31 Merge tag 'mtd/for-6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/mtd/linux a0d6ec02f5dd Merge tag 'spi-v6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi 092d72f89f32 Merge tag 'regulator-v6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator f19bbcb501a1 Merge branch 'clk-rs9' into clk-next 6c5ff3361f38 Merge branches 'clk-zynq', 'clk-xilinx' and 'clk-stm' into clk-next 5348f28123c3 Merge branches 'clk-imx', 'clk-qcom', 'clk-amlogic' and 'clk-mediatek' into clk-next dde8a0d89600 Merge branches 'clk-versa', 'clk-silabs', 'clk-samsung', 'clk-starfive' and 'clk-sophgo' into clk-next 147299598f64 dt-bindings: ignore paths outside kernel for DT_SCHEMA_FILES 5e8ad2415574 dt-bindings: tpm: Document Microsoft fTPM bindings 4446def763e6 dt-bindings: tpm: Convert IBM vTPM bindings to DT schema d46251bba773 dt-bindings: tpm: Convert Google Cr50 bindings to DT schema 4c0c46fcf77f dt-bindings: tpm: Consolidate TCG TIS bindings fc825b2e9d71 dt-bindings: display: rockchip,inno-hdmi: Document RK3128 compatible 5d51cf126484 dt-bindings: arm: Add remote etm dt-binding 32c458bd3442 dt-bindings: mmc: sdhci-pxa: Fix 'regs' typo c9ab453dff7c media: dt-bindings: samsung,s5p-mfc: Fix iommu properties schemas 481554b6b752 dt-bindings: display: panel: Add synaptics r63353 panel controller e04e21bef16e dt-bindings: arm: merge qcom,idle-state with idle-state 452e35e6ff26 Merge tag 'irq-core-2024-01-08' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip d35742374b96 dt-bindings: display: samsung,exynos-mixer: Fix 'regs' typo ac8ffc6d0764 Merge tag 'arm64-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux daf5be0b133e Merge tag 'powerpc-6.8-1' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux b633610fad05 Revert "net: stmmac: Enable Per DMA Channel interrupt" fc2b6856183b dt-bindings: rtc: qcom-pm8xxx: fix inconsistent example 5c111c61a49a dt-bindings: net: snps,dwmac: per channel irq 94d319464237 ASoC: dt-bindings: move tas2563 from tas2562.yaml to tas2781.yaml 8fbbcaccc3ff Merge tag 'socfpga_dts_updates_for_v6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/dinguyen/linux into soc/dt 1161aaee27ae dt-bindings: mmc: add Marvell ac5 e9a747531a5d dt-bindings: mmc: brcm,sdhci-brcmstb: Add support for 74165b0 57b4e3b1199f Merge git://git.kernel.org/pub/scm/linux/kernel/git/netdev/net cab393f5e80d dt-bindings: serial: Describe ARM dcc interface 1d92607a561e dt-bindings: usb: dwc3: Limit num-hc-interrupters definition cee9797861a0 dt-bindings: usb: xhci: Add num-hc-interrupters definition 4823f8dd230f arm64: dts: mediatek: mt8195: Add 'rx-fifo-depth' for cherry 4a4f48930e20 dt-bindings: usb: mtk-xhci: add a property for Gen1 isoc-in transfer issue 4ddd871b77e8 arm64: dts: qcom: msm8996: Remove PNoC clock from MSS 5598c7c58459 arm64: dts: qcom: msm8996: Remove AGGRE2 clock from SLPI a06133f3b90d arm64: dts: qcom: msm8998: Remove AGGRE2 clock from SLPI 0e31729b965a arm64: dts: qcom: msm8939: Drop RPM bus clocks a9231f1fa44d arm64: dts: qcom: sdm630: Drop RPM bus clocks 7806d0946f48 arm64: dts: qcom: qcs404: Drop RPM bus clocks 6bbd4a339ffd arm64: dts: qcom: msm8996: Drop RPM bus clocks 6c5785d4dec0 arm64: dts: qcom: msm8916: Drop RPM bus clocks d99558e0d6ba dt-bindings: usb: qcom,dwc3: Fix SDM660 clock description 0e7834fa9ba2 dt-bindings: usb: dwc3: Clean up hs_phy_irq in binding f7405c1062e5 dt-bindings: connector: Add child nodes for multiple PD capabilities a2f2b957f7b0 arm64: dts: intel: minor whitespace cleanup around '=' a21ad91a14ac arm64: dts: socfpga: agilex: drop redundant status c64326a0161d arm64: dts: socfpga: agilex: add unit address to soc node 70eea150a8db arm64: dts: socfpga: agilex: move firmware out of soc node 056acfded5ce arm64: dts: socfpga: agilex: move FPGA region out of soc node 8e373ef160c7 arm64: dts: socfpga: agilex: align pin-controller name with bindings 56a65e118b36 arm64: dts: socfpga: stratix10_swvp: drop unsupported DW MSHC properties 5ea405da6608 arm64: dts: socfpga: stratix10_socdk: align NAND chip name with bindings 0bc2b8deec9a arm64: dts: socfpga: stratix10: add unit address to soc node 3932c6fc63c2 arm64: dts: socfpga: stratix10: move firmware out of soc node 174dfac57ae2 arm64: dts: socfpga: stratix10: move FPGA region out of soc node e63c11b1c86c arm64: dts: socfpga: stratix10: align pincfg nodes with bindings 5ad3116fb135 arm64: dts: socfpga: stratix10: add clock-names to DWC2 USB 9185b800f9c3 arm64: dts: socfpga: drop unsupported cdns,page-size and cdns,block-size b3832f4d101c ARM: dts: socfpga: align NAND controller name with bindings 7772fcc4eef4 ARM: dts: socfpga: drop unsupported cdns,page-size and cdns,block-size f466442c93ff dt-bindings: clock: mediatek: add clock controllers of MT7988 967ed08fdbd4 dt-bindings: reset: mediatek: add MT7988 ethwarp reset IDs 8bb435f3ea7d dt-bindings: clock: mediatek: add MT7988 clock IDs 8b8c659b2121 dt-bindings: clock: sophgo: Add clock controller of CV1800 series SoC b822e804fd2c dt-bindings: gpio: add NPCM sgpio driver bindings f4c19e862d2b dt-bindings: gpio: realtek: Add realtek,rtd-gpio 6690161ed7a9 Merge branches 'apple/dart', 'arm/rockchip', 'arm/smmu', 'virtio', 'x86/vt-d', 'x86/amd' and 'core' into next 7382fa53a648 dt-bindings: net: renesas,etheravb: Document RZ/G3S support 247b8886892f dt-bindings: hwmon: (lm75) Add AMS AS6200 temperature sensor fec847c57a81 dt-bindings: Add MP2856/MP2857 voltage regulator device 42c42ff6c177 dt-bindings: hwmon: gpio-fan: Convert txt bindings to yaml 6c13c9d07051 dt-bindings: mmc: sdhci-msm: document dedicated IPQ4019 and IPQ8074 1e934476b96c dt-bindings: mmc: synopsys-dw-mshc: add iommus for Intel SocFPGA 82a434279c9e dt-bindings: HID: i2c-hid: elan: Introduce Ilitek ili2901 5fa4567d6c4f Merge tag 'v6.8-rockchip-dts32-2' of git://git.kernel.org/pub/scm/linux/kernel/git/mmind/linux-rockchip into soc/dt a04786e0b7e0 Merge tag 'v6.8-rockchip-dts64-2' of git://git.kernel.org/pub/scm/linux/kernel/git/mmind/linux-rockchip into soc/dt 0bf9a2425459 Merge tag 'qcom-arm64-for-6.8-2' of https://git.kernel.org/pub/scm/linux/kernel/git/qcom/linux into soc/dt a3fde0732d5b Merge tag 'qcom-arm32-for-6.8-2' of https://git.kernel.org/pub/scm/linux/kernel/git/qcom/linux into soc/dt 62073621d812 Merge tag 'arm-soc/for-6.8/devicetree' of https://github.com/Broadcom/stblinux into soc/dt 4cfe8fd4e2b4 Merge tag 'sprd-dt-6.8-rc1' of https://github.com/lyrazhang/linux into soc/dt a355b8e8cbdd dt-bindings: thermal: qcom-spmi-adc-tm5/hc: Clean up examples 36a030b546d0 dt-bindings: thermal: qcom-spmi-adc-tm5/hc: Fix example node names ca1c0a8c8091 dt-bindings: thermal: sun8i: Add binding for D1/T113s THS controller 7123707b90de dt-bindings: thermal-zones: Document critical-action c29ec9b83fd7 dt-bindings: thermal: qcom-tsens: document the SM8650 Temperature Sensor 5a12787401b5 dt-bindings: thermal: loongson,ls2k-thermal: Fix binding check issues 0a6d923c5231 dt-bindings: thermal: convert Mediatek Thermal to the json-schema dc5dd3862b77 dt-bindings: input: iqs269a: Add bindings for OTP variants 5aa00301cee3 dt-bindings: input: iqs269a: Add bindings for slider gestures c4635c803af3 Merge tag 'iio-for-6.8b' of https://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into char-misc-next 571d91b8d8df arm64: dts: rockchip: Fix led pinctrl of lubancat 1 548cbdf62c21 arm64: dts: rockchip: correct gpio_pwrctrl1 typo on nanopc-t6 86c28823371d arm64: dts: rockchip: correct gpio_pwrctrl1 typo on rock-5b 275bc737b480 arm64: dts: rockchip: support poweroff on the rock-5b e4f7332bb7f8 arm64: dts: rockchip: Support poweroff on Orange Pi 5 d0c46aeba839 arm64: dts: rockchip: nanopc-t6 sdmmc beautification df73c00bc509 arm64: dts: sprd: Change UMS512 idle-state nodename to match bindings 12243eba2b74 arm64: dts: sprd: Add clock reference for pll2 on UMS512 af72bfcc73f3 arm64: dts: sprd: Removed unused clock references from etm nodes d8f5562e697b arm64: dts: sprd: Add support for Unisoc's UMS9620 bd8f67f82f65 dt-bindings: arm: Add compatible strings for Unisoc's UMS9620 9da3db96fae0 arm64: dts: sprd: fix the cpu node for UMS512 3ebc08960525 Merge tag 'v6.7-rc7' into gpio/for-next cb90fcbed71e dt-bindings: timer: Add StarFive JH8100 clint 6f2b19f4df72 dt-bindings: timer: thead,c900-aclint-mtimer: separate mtime and mtimecmp regs 4421b3e3124f dt-bindings: iio: Add AD7091R-8 51a0454cffd6 dt-bindings: power: supply: bq24190: Add BQ24296 compatible 4639caeeab2f dt-bindings: power: reset: xilinx: Rename node names in examples c873132667ed dt-bindings: power: reset: qcom-pon: fix inconsistent example 64cf7a912b11 arm64: dts: rockchip: Fix rk3588 USB power-domain clocks 815a2542ad42 arm64: dts: rockchip: configure eth pad driver strength for orangepi r1 plus lts 9df823a6207b arm64: dts: rockchip: Support poweroff on NanoPC-T6 78bd00069022 arm64: dts: rockchip: rk3308-rock-pi-s gpio-line-names cleanup 9d6e0741ae7c arm64: dts: rockchip: Add support for rk3588 based board Cool Pi CM5 EVB a64a2e009e21 dt-bindings: arm: rockchip: Add Cool Pi CM5 4397d62daec8 arm64: dts: rockchip: Add support for rk3588s based board Cool Pi 4B f1a9c321e26f dt-bindings: arm: rockchip: Add Cool Pi 4B 1e413c69529f dt-bindings: vendor-prefixes: Add Cool Pi a67ded35095e arm64: dts: rockchip: add gpio-line-names to rk3328-rock-pi-e e0ec5767b690 ARM: dts: rockchip: Remove rockchip,default-sample-phase from rk3036.dtsi 75e0afe6681c ARM: dts: rockchip: Add stdout-path for rk3036 kylin 5b38dc06a1e9 dt-bindings: watchdog: qcom,pm8916-wdt: add parent spmi node to example d2f78877f2ea dt-bindings: watchdog: nxp,pnx4008-wdt: convert txt to yaml af1fdc5cd02d dt-bindings: watchdog: qca,ar7130-wdt: convert txt to yaml 5c3d9631b9ac dt-bindings: watchdog: intel,keembay: reference common watchdog schema 6d86f883fd9c dt-bindings: watchdog: re-order entries to match coding convention e28051167c06 dt-bindings: touchscreen: neonode,zforce: Use standard properties 3119a224ac1c dt-bindings: touchscreen: convert neonode,zforce to json-schema 15bf36928144 Merge tag 'icc-6.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/djakov/icc into char-misc-next dd37eb39a550 dt-bindings: input: convert drv266x to json-schema 795f4eddfec7 Merge tag 'qcom-arm64-for-6.8' of https://git.kernel.org/pub/scm/linux/kernel/git/qcom/linux into soc/dt 991ab34b2120 Merge tag 'reset-for-v6.8' of git://git.pengutronix.de/pza/linux into soc/drivers 4e7b4659bc67 dt-bindings: mtd: partitions: u-boot: Fix typo 35dd951a7fd5 Merge tag 'riscv-cache-for-v6.8' of https://git.kernel.org/pub/scm/linux/kernel/git/conor/linux into soc/drivers 69b18d58cc6d Merge tag 'riscv-soc-drivers-for-v6.8' of https://git.kernel.org/pub/scm/linux/kernel/git/conor/linux into soc/drivers fc5aa9bf69fd Merge tag 'samsung-drivers-6.8' of https://git.kernel.org/pub/scm/linux/kernel/git/krzk/linux into soc/drivers 84c9739eb5b5 Merge tag 'qcom-drivers-for-6.8' of https://git.kernel.org/pub/scm/linux/kernel/git/qcom/linux into soc/drivers 0ef14d7a1f46 dt-bindings: crypto: qcom-qce: document the SC7280 crypto engine 2fd8394e6d9f dt-bindings: crypto: qcom-qce: constrain clocks for SM8150-compatible QCE 40fd9d4f3234 dt-bindings: crypto: qcom-qce: constrain clocks for IPQ9574 QCE 30960ac02d6e dt-bindings: rng: starfive: Add jh8100 compatible string e6272a79f69c Merge git://git.kernel.org/pub/scm/linux/kernel/git/netdev/net dcd8ac1c5dd8 dt-bindings: spi: stm32: add st,stm32mp25-spi compatible 87166d1d3f3f Merge tag 'riscv-dt-for-v6.8' of https://git.kernel.org/pub/scm/linux/kernel/git/conor/linux into soc/dt 69abc2365d38 dt-bindings: phy: qcom,sc8280xp-qmp-usb3-uni: Add X1E80100 USB PHY binding 822a13d2bf90 dt-bindings: phy: qcom,sc8280xp-qmp-usb43dp-phy: Document X1E80100 compatible 6722c7fe2a57 dt-bindings: phy: qcom: snps-eusb2: Document the X1E80100 compatible a38a399bccf1 dt-bindings: phy: mediatek: tphy: add a property for force-mode switch ca521e2ecf25 dt-bindings: phy: qcom,sc8280xp-qmp-usb43dp-phy: fix path to header aa156a9707ec Merge tag 'amlogic-arm64-dt-for-v6.8' of https://git.kernel.org/pub/scm/linux/kernel/git/amlogic/linux into soc/dt e6127e00f352 Merge tag 'mvebu-dt64-6.8-1' of git://git.kernel.org/pub/scm/linux/kernel/git/gclement/mvebu into soc/dt aad08c0a0671 Merge tag 'mvebu-dt-6.8-1' of git://git.kernel.org/pub/scm/linux/kernel/git/gclement/mvebu into soc/dt e4320c558711 Merge tag 'samsung-dt64-6.8-2' of https://git.kernel.org/pub/scm/linux/kernel/git/krzk/linux into soc/dt 077793e138f6 Merge tag 'qcom-arm32-for-6.8' of https://git.kernel.org/pub/scm/linux/kernel/git/qcom/linux into soc/dt 7ff5e1692425 Merge tag 'ti-k3-dt-for-v6.8' of https://git.kernel.org/pub/scm/linux/kernel/git/ti/linux into soc/dt f009c98b2a3f dt-bindings: iio: dac: add MCP4821 e46c2c536959 Merge tag 'ti-keystone-dt-for-v6.8' of https://git.kernel.org/pub/scm/linux/kernel/git/ti/linux into soc/dt edeab43af36b Merge tag 'zynqmp-dt-for-6.8' of https://github.com/Xilinx/linux-xlnx into soc/dt 4e78ad68f722 Merge tag 'imx-dt64-6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux into soc/dt f4ece4b3d883 Merge tag 'imx-dt-6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux into soc/dt 1a2b6b1db701 Merge tag 'imx-bindgins-6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux into soc/dt 71e20fbc3d5b Merge tag 'ux500-dts-soc-for-v6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-integrator into soc/dt 056c9efa37c5 Merge tag 'renesas-dts-for-v6.8-tag2' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/renesas-devel into soc/dt 339491d0999f Merge tag 'stm32-dt-for-v6.8-1' of git://git.kernel.org/pub/scm/linux/kernel/git/atorgue/stm32 into soc/dt 06086605676a dt-bindings: dma: fsl-edma: Add fsl-edma.h to prevent hardcoding in dts 640904451ab8 dt-bindings: dmaengine: Add Loongson LS2X APB DMA controller f88d59ec5d12 Merge tag 'sunxi-dt-for-6.8-1' of https://git.kernel.org/pub/scm/linux/kernel/git/sunxi/linux into soc/dt e833ff47f9b9 Merge tag 'at91-dt-6.8' of https://git.kernel.org/pub/scm/linux/kernel/git/at91/linux into soc/dt 9f821c027b01 Merge tag 'juno-update-6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/sudeep.holla/linux into soc/dt 4bab8a451f49 Merge tag 'v6.8-rockchip-dts32-1' of git://git.kernel.org/pub/scm/linux/kernel/git/mmind/linux-rockchip into soc/dt a4789dd06449 Merge tag 'v6.8-rockchip-dts64-1' of git://git.kernel.org/pub/scm/linux/kernel/git/mmind/linux-rockchip into soc/dt 5045526f0b7c Merge tag 'mtk-dts64-for-v6.8' of https://git.kernel.org/pub/scm/linux/kernel/git/mediatek/linux into soc/dt a7603f8260b8 Merge tag 'samsung-dt-6.8' of https://git.kernel.org/pub/scm/linux/kernel/git/krzk/linux into soc/dt 16a1d6e0b098 Merge tag 'samsung-dt64-6.8' of https://git.kernel.org/pub/scm/linux/kernel/git/krzk/linux into soc/dt 0f1f66f39700 ARM: dts: ste: minor whitespace cleanup around '=' 22532c5d3f4a Merge tag 'omap-for-v6.8/dt-signed' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into soc/dt 5288e13a2ad4 Merge tag 'hisi-arm64-dt-for-6.8' of https://github.com/hisilicon/linux-hisi into soc/dt f44f238cabce Merge tag 'w1-drv-6.8' of https://git.kernel.org/pub/scm/linux/kernel/git/krzk/linux-w1 into char-misc-next 61f41fa45eaf Merge tag 'iio-for-6.8a' of https://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into char-misc-next 07d575b06ff9 dt-bindings: pwm: ti,pwm-omap-dmtimer: Update binding for yaml fc02de1f5dc0 dt-bindings: riscv: cpus: Add AMD MicroBlaze V compatible 780449a81d3c dt-bindings: pwm: remove Xinlei's mail f96dd7edb887 arm64: dts: qcom: sc8180x: Fix up PCIe nodes b1ecf20e17e0 arm64: dts: qcom: sc8180x: Mark PCIe hosts cache-coherent eeed8f113289 dt-bindings: pinctrl: xilinx: Rename *gpio to *gpio-grp 2ef9211e8711 dt-bindings: pinctrl: qcom: drop common properties and allow wakeup-parent 188c161805d3 dt-bindings: pinctrl: qcom: drop common properties 7834682c0d2c dt-bindings: pinctrl: qcom,ipq5018-tlmm: use common TLMM bindings c31ea3c9600f dt-bindings: pinctrl: qcom,x1e80100-tlmm: restrict number of interrupts 6cec6f6f090c dt-bindings: pinctrl: qcom,sm8650-tlmm: restrict number of interrupts ef7b1c134921 dt-bindings: pinctrl: qcom,sm8550-tlmm: restrict number of interrupts a3abecdd0e2e dt-bindings: pinctrl: qcom,sdx75-tlmm: restrict number of interrupts 2b1d1c0dd621 dt-bindings: pinctrl: qcom,sa8775p-tlmm: restrict number of interrupts 36f8bb953634 dt-bindings: pinctrl: qcom,qdu1000-tlmm: restrict number of interrupts 670ced18d87f dt-bindings: pinctrl: qcom: create common LPASS LPI schema 5ca197c58799 dt-bindings: pinctrl: qcom: Add SM4450 pinctrl 8d27a131f7ad dt-bindings: pinctrl: qcom,pmic-mpp: clean up example 6674c2217ce1 Merge tag 'mediatek-drm-next-6.8' of https://git.kernel.org/pub/scm/linux/kernel/git/chunkuang.hu/linux into drm-next d7dde4a72dfa Merge tag 'drm-msm-next-2023-12-15' of https://gitlab.freedesktop.org/drm/msm into drm-next 64ddcb330a18 arm64: dts: qcom: x1e80100-qcp: Fix supplies for some LDOs in PM8550 206ab99c38ce arm64: dts: qcom: sm8550: Update idle state time requirements 319f395fbc2a arm64: dts: qcom: sm8550: Separate out X3 idle state af2f75b56294 ARM: dts: qcom: sdx55: Fix the base address of PCIe PHY 4a72661b117b arm64: dts: qcom: ipq6018: fix clock rates for GCC_USB0_MOCK_UTMI_CLK 5b72e989a37a arm64: dts: qcom: x1e80100: align mem timer size cells with bindings b17d7383c10f arm64: dts: qcom: sc7280: Mark SDHCI hosts as cache-coherent 3840ead2163a ARM: dts: qcom: sdx55: fix USB SS wakeup 9e773fad2487 ARM: dts: qcom: sdx55: fix USB DP/DM HS PHY interrupts d0728def7588 ARM: dts: qcom: sdx55: fix pdc '#interrupt-cells' 0ee9dac79d46 ASoC: qcom: add sound card support for SM8650 345b970f1857 add es8326 dt-bindings, commonize headset codec 85a45459eeed GPIO inclusion fixes to misc sound drivers 616e88e1109d arm64: dts: qcom: sc8180x: fix USB SS wakeup f3d1b2acf659 arm64: dts: qcom: sdm670: fix USB SS wakeup 987f42804a25 arm64: dts: qcom: sdm670: fix USB DP/DM HS PHY interrupts 2e58236aa851 ASoC: dt-bindings: qcom,lpass-va-macro: remove spurious contains in if statement bded77d8cc7b dt-bindings: regulator: qcom,usb-vbus-regulator: clean up example e1481a467961 powerpc/fsl: Fix fsl,tmu-calibration to match the schema 26e2fad496d4 arm64: dts: amlogic: fix format for s4 uart node 8a5115be3855 arm64: dts: amlogic: drop redundant status=okay 799049c22bf2 arm64: dts: amlogic: enable some nodes for board AQ222 3fea93dcdd73 arm64: dts: amlogic: add some device nodes for S4 44721ac7f4da Merge tag 'drm-misc-next-2023-12-14' of git://anongit.freedesktop.org/drm/drm-misc into drm-next d623bb97a280 Merge tag 'samsung-pinctrl-6.8' of https://git.kernel.org/pub/scm/linux/kernel/git/pinctrl/samsung into devel 81d84dd62616 ASoC: dt-bindings: qcom,lpass-rx-macro: Add X1E80100 LPASS WSA 4f673348bd77 ASoC: dt-bindings: qcom,lpass-rx-macro: Add X1E80100 LPASS VA d5b1bc404268 ASoC: dt-bindings: qcom,lpass-rx-macro: Add X1E80100 LPASS TX 40420db77069 ASoC: dt-bindings: qcom,lpass-rx-macro: Add X1E80100 LPASS RX 605001444f21 ASoC: dt-bindings: qcom,sm8250: Add X1E80100 sound card 4e179f2c3905 ASoC: dt-bindings: mt8188-mt6359: add es8326 support 0c819517fcb2 ASoC: dt-bindings: qcom,sm8250: document SM8650 sound card 0292b51ac8c4 ASoC: tegra: tegra20_ac97: Convert to use GPIO descriptors 4c6bc6503e5e Merge tag 'device_is_big_endian-6.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core into gpio/for-next 31d8096d43a1 dt-bindings: gpio: dwapb: allow gpio-ranges 873d4c02bbfa dt-bindings: clock: google,gs101: rename CMU_TOP gate defines bfc73914844a dt-bindings: clock: si5351: add PLL reset mode property af0493badd9d dt-bindings: clock: si5351: convert to yaml d1a5fb288be1 dt-bindings: stm32: add clocks and reset binding for stm32mp25 platform ee353e29bfb4 dt-bindings: clk: rs9: Add 9FGV0841 48b20705829d dt-bindings: clock: brcm,kona-ccu: convert to YAML b2b282bb3ba9 dt-bindings: arm: mediatek: move ethsys controller & convert to DT schema e35ce136c12f dt-bindings: clock: xilinx: add versal compatible 746818ace7a3 dt-bindings: rtc: Add Nuvoton ma35d1 rtc d8c717fd9bc8 dt-bindings: Remove alt_ref from versal e9caccbf099c arm64: dts: qcom: sc8180x-primus: Allow UFS regulators load/mode setting b616df631790 arm64: dts: qcom: sc8180x: Describe the GIC redistributor ae7e39a80f0f arm64: dts: qcom: sc8180x: Add interconnects to UFS 0f32e7aa54e0 arm64: dts: qcom: sc8180x: Add missing MDP clocks 3641f17d731d arm64: dts: qcom: sc8180x: Add UFS GDSC 2bbb23973697 arm64: dts: qcom: sc7280*: move MPSS and WPSS memory to dtsi a5b4605b6fc6 ARM: dts: qcom: msm8974*: Re-enable remoteprocs on various boards f1ecb44efc55 ARM: dts: qcom: msm8974: Remove bogus cd-gpio pinctrl 9dd85d38d004 ARM: dts: qcom: msm8974-klte: Remove unused property 34c2fdcebf94 arm64: dts: qcom: sc7280: Rename reserved-memory nodes 84a50703ca7d dt-bindings: remoteproc: qcom: sc7180-pas: Add SC7280 compatibles 47f83514132e dt-bindings: remoteproc: qcom: sc7180-pas: Fix SC7280 MPSS PD-names 1dce719ef64f arm64: dts: qcom: sc7280: Remove unused second MPSS reg afedac693f18 arm64: dts: qcom: sdm670: add display subsystem 1d8d2d147ea5 dt-bindings: soc: qcom,aoss-qmp: document the X1E80100 Always-On Subsystem side channel 3ea56a52a7c2 dt-bindings: wdt: Add ts72xx 18522cdf3ec6 dt-bindings: watchdog: dlg,da9062-watchdog: Document DA9063 watchdog 688fe0bdd724 dt-bindings: watchdog: dlg,da9062-watchdog: Add fallback for DA9061 watchdog 9054003bb13e dt-bindings: watchdog: mediatek,mtk-wdt: add MT7988 watchdog and toprgu 63d466a6e3b3 dt-bindings: watchdog: realtek,rtd1295-watchdog: convert txt to yaml 5b6c41392896 dt-bindings: watchdog: qcom-wdt: Make the interrupt example edge triggered 4f8423c375eb dt-bindings: iio: chemical: add aosong,ags02ma 766801c2fc4b dt-bindings: vendor-prefixes: add aosong 530dcc2cff54 arm64: dts: qcom: sm8150-hdk: enable DisplayPort and USB-C altmode a63d7ac5c9ca arm64: dts: qcom: sm8150: add USB-C ports to the OTG USB host 6177bf5ba3b4 arm64: dts: qcom: sm8150: add USB-C ports to the USB+DP QMP PHY cccb449ab331 arm64: dts: qcom: sm8150: add DisplayPort controller 414013ad4921 arm64: dts: qcom: sm8150-hdk: fix SS USB regulators 94e5a8422a14 arm64: dts: qcom: sm8150-hdk: enable HDMI output 94cd2b0ff062 arm64: dts: qcom: sm8150: make dispcc cast minimal vote on MMCX d8577fce5e20 arm64: dts: qcom: sm8650: add fastrpc-compute-cb nodes e14f9c1044bd arm64: dts: qcom: sm8550-qrd: add PM8010 regulators 66e97e0962a7 arm64: dts: qcom: sm8550-mtp: Add pm8010 regulators 6437200479ec arm64: dts: qcom: qcm2290: Hook up MPM 75b87eb7e3ee arm64: dts: qcom: msm8996: Hook up MPM e043072a3a33 arm64: dts: qcom: sm6375: Hook up MPM 623a6180066f dt-bindings: arm: qcom: Add Motorola Moto G 4G (2013) 030e5c73208a arm64: dts: qcom: x1e80100-crd: Fix supplies for some LDOs in PM8550 58e87053c1f0 arm64: dts: qcom: sc7280: add QCrypto nodes 6d138c9b4127 arm64: dts: qcom: sc7180: Switch pompom to the generic edp-panel 9248e79cd654 arm64: dts: qcom: sm8150: fix USB SS wakeup 8143f0f67202 arm64: dts: qcom: sm8150: fix USB DP/DM HS PHY interrupts 1d46c82d351b arm64: dts: qcom: sdm845: fix USB SS wakeup 5c261eb8cd11 arm64: dts: qcom: sdm845: fix USB DP/DM HS PHY interrupts 2998fdbc15fe arm64: dts: qcom: sc8180x: fix USB DP/DM HS PHY interrupts 220ee261025f arm64: dts: qcom: sm8550: drop unneeded assigned-clocks from codec macros ef2823c0a498 arm64: dts: qcom: sm8550: move Soundwire pinctrl to its nodes 611112fa3972 arm64: dts: qcom: sm8450: drop unneeded assigned-clocks from codec macros 7fe6ee08b28c arm64: dts: qcom: sm8450: move Soundwire pinctrl to its nodes eb6e95625c03 arm64: dts: qcom: sm8550: add missing two RX Soundwire ports in configuration 6f45533e32ad arm64: dts: qcom: sm8650: drop unneeded assigned-clocks from WSA macro 108c60eb7746 dt-bindings: arm: qcom: Fix up htc-memul compatible c493fe546f0a arm64: dts: qcom: sm6115: Hook up interconnects fd22f3a58a9e Merge branch 'icc-sm6115' of https://git.kernel.org/pub/scm/linux/kernel/git/djakov/icc into HEAD 85a531800a07 ARM: dts: qcom: msm8926-motorola-peregrine: Add initial device tree 9c323b20cda8 ARM: dts: qcom: ipq4019: add dedicated SDHCI compatible 2fcaa70bfc3c arm64: dts: qcom: ipq8074: add dedicated SDHCI compatible 757c981838e3 arm64: dts: qcom: Fix coresight warnings in in-ports and out-ports 34e4f27862d1 arm64: dts: qcom: msm8998: Fix 'out-ports' is a required property 61e7df01e058 arm64: dts: qcom: msm8996: Fix 'in-ports' is a required property 786be94e8465 arm64: dts: qcom: qrb5165-rb5: add the Bluetooth node fe9d727180d2 arm64: dts: qcom: sa8775p: Add missing space between node name and braces 8df2548eb151 arm64: dts: qcom: Use "pcie" as the node name instead of "pci" 756ec289cf35 ARM: dts: qcom: Use "pcie" as the node name instead of "pci" 2066a55949a7 arm64: dts: qcom: acer-aspire1: Add sound 90485d1f88ce arm64: dts: qcom: acer-aspire1: Correct audio codec definition 3d97796b14f9 arm64: dts: qcom: acer-aspire1: Enable RTC 5d870a6a209b arm64: dts: qcom: sm8450: switch UFS QMP PHY to new style of bindings 1e57f262d57c arm64: dts: qcom: sm8350: switch UFS QMP PHY to new style of bindings 731a9974488a arm64: dts: qcom: sm8250: switch UFS QMP PHY to new style of bindings 8a512baad9fa arm64: dts: qcom: sm8150: switch UFS QMP PHY to new style of bindings 9c4063711b1f arm64: dts: qcom: sm6350: switch UFS QMP PHY to new style of bindings 79c130d88048 arm64: dts: qcom: sm6115: switch UFS QMP PHY to new style of bindings 65d88afa8518 arm64: dts: qcom: sdm845: switch UFS QMP PHY to new style of bindings fa34450ebcf9 arm64: dts: qcom: msm8998: switch UFS QMP PHY to new style of bindings 2d00768d0566 arm64: dts: qcom: msm8996: switch UFS QMP PHY to new style of bindings 6d501541ab8b arm64: dts: qcom: sm8450-hdk: Enable the A730 GPU 9999a06044c2 arm64: dts: qcom: sm8550-mtp: Enable the A740 GPU 1c8862cd1be0 arm64: dts: qcom: sm8550-qrd: Enable the A740 GPU db2dd74a4321 arm64: dts: qcom: sm8550: Add GPU nodes 41411e46e180 arm64: dts: qcom: sm8450: Add GPU nodes 67082abed4d1 arm64: dts: qcom: msm8939: Make blsp_dma controlled-remotely b0768548dacf arm64: dts: qcom: msm8916: Make blsp_dma controlled-remotely e529c8cd00c4 arm64: dts: qcom: msm8939: Add clock-frequency for broadcast timer dc95d696633b arm64: dts: qcom: Add missing vio-supply for AW2013 ce476167f046 arm64: dts: qcom: ipq6018: Add QUP5 SPI node 4723cf41be1a arm64: dts: qcom: ipq6018: Add remaining QUP UART node af3ecf0ef5eb Merge branch '20231201-videocc-8150-v3-1-56bec3a5e443@quicinc.com' into clk-for-6.8 eeb32e2a4dbd dt-bindings: clock: Update the videocc resets for sm8150 c591d3616c87 arm64: dts: qcom: qrb4210-rb2: Enable MPSS and Wi-Fi 479632ff42dd arm64: dts: freescale: fix the schema check errors for fsl,tmu-calibration 4c12613ce6e0 ARM: dts: imx27-phytec-phycore-som: Use 'rtc' as node name e55cb89e6ef8 ARM: dts: imx25: Remove unneeded keypad properties 610b835be6b9 dt-bindings: net: marvell,orion-mdio: Drop "reg" sizes schema 5605354f949e arm64: dts: freescale: imx8qxp: Disable dsp reserved memory by default bb83d09752aa arm64: dts: imx8qxp: Add VPU subsystem file 11f5b7454c94 arm64: dts: imx8qxp-mek: Move port under USB connector f6d6c203902d arm64: dts: imx8mn-bsh-smm-s2/pro: add display setup 643674137f59 dt-bindings: PCI: qcom: Document the SM8650 PCIe Controller ddec040496f1 dt-bindings: PCI: dwc: rockchip: Document optional PCIe reference clock input 2d8a490fd767 dt-bindings: PCI: qcom: Correct reset-names property 2bdefbbe9381 dt-bindings: PCI: qcom: Correct clocks for SM8150 01ce80af6cc2 dt-bindings: PCI: qcom: Correct clocks for SC8180x 9c60f1faccc9 dt-bindings: PCI: qcom: Adjust iommu-map for different SoC c78e4dd9c7c0 arm64: dts: rockchip: make use gpio-keys for buttons on puma-haikou 146cf4124863 arm64: dts: rockchip: expose BIOS Disable feedback pin on rk3399-puma 26575df71b2d arm64: dts: rockchip: fix misleading comment in rk3399-puma-haikou.dts 93c2098cfa35 ARM: dts: ux500-href: Switch HREF520 to AB8505 488dc522177c ARM: dts: ux500-href: Push AB8500 config out 7acade644174 ARM: dts: ux500-href: Push AB8500 inclusion to the top 0043c908a991 dt-bindings: connector: usb: add accessory mode description 7b7f80d863a5 arm64: dts: rockchip: Add vop on rk3588 ef9ea9ea51ca arm64: dts: ti: k3-j784s4-main: Add Itap Delay Value For DDR50 speed mode a843a4a028e7 arm64: dts: ti: k3-j721s2-main: Add Itap Delay Value For DDR50 speed mode 83869275890f arm64: dts: ti: k3-j7200-main: Add Itap Delay Value For DDR52 speed mode 237d1d3aa847 arm64: dts: ti: k3-am6*: Add additional regs for DMA components 6540bf190683 arm64: dts: ti: k3-j7*: Add additional regs for DMA components f584859d0f96 arm64: dts: ti: k3-am65: Add additional regs for DMA components e76881a36a46 arm64: dts: cn913x: add device trees for COM Express boards a57b87e79272 dt-bindings: arm64: add Marvell COM Express boards 22b670935a1f arm64: dts: armada-3720-turris-mox: set irq type for RTC 6b8494ce5492 ARM64: dts: Add special compatibles for the Turris Mox 8fcbbd77bc4f ARM64: dts: marvell: Fix some common switch mistakes 61b4fbe68e70 ARM: dts: marvell: make dts use gpio-fan matrix instead of array 1a025bb583e1 ARM: dts: marvell: Fix some common switch mistakes 283f9ebb847c dt-bindings: serial: Add a new compatible string for UMS9620 42414ddb491a dt-bindings: serial: imx: Properly describe the i.MX1 interrupts a5b226724ae1 dt-bindings: usb: qcom,dwc3: Add X1E80100 binding a94c79572ac2 dt-bindings: usb: Document WCD939x USB SubSystem Altmode/Analog Audio Switch 6c2112d5f3f3 arm64: dts: qcom: qrb5165-rb5: use u16 for DP altmode svid 79493bc9fc10 dt-bindings: connector: usb: add altmodes description a98f9ad936ee dt-bindings: usb: nxp,ptn5110: Fix typos in the title da44f4e15545 dt-bindings: usb: genesys,gl850g: Document 'peer-hub' c32fd07e4010 dt-bindings: nvmem: add new stm32mp25 compatible for stm32-romem cc8835249ffb ARM: dts: stm32: add dcmipp support to stm32mp135 dc483bc0495b dt-bindings: gnss: u-blox: add "reset-gpios" binding 82239f64506f dt-bindings: iommu: rockchip: Add Rockchip RK3588 b10f7d79bc86 Merge git://git.kernel.org/pub/scm/linux/kernel/git/netdev/net e39b04bbed6e Merge branch 'icc-qcm2290' into icc-next c95f389c0366 Merge branch 'icc-sm6115' into icc-next b1f1b32e611b dt-bindings: PCI: rcar-pci-host: Add optional regulators 51eab76bc15c arm64: dts: allwinner: h618: add Transpeed 8K618-T TV box 8f65017d5eb4 dt-bindings: arm: sunxi: document Transpeed 8K618-T board name a043657dff28 dt-bindings: vendor-prefixes: add Transpeed b9b13eec182f arm64: dts: st: add bsec support to stm32mp25 4ba9da13226a ARM: dts: stm32: Consolidate usbh_[eo]hci phy properties on stm32mp15 3cd8f921b287 ARM: dts: stm32: don't mix SCMI and non-SCMI board compatibles 9d7cd7004fbc dt-bindings: arm: stm32: don't mix SCMI and non-SCMI board compatibles 3409584c8b1b ARM: dts: stm32: minor whitespace cleanup around '=' 46d3a566ba35 regulator: dt-bindings: qcom,rpmh: add compatible for pm8010 b876feae34ef ASoC: dt-bindings: audio-graph-port: Document new DAI link flags playback-only/capture-only b0c246496fbc dt-bindings: display: msm: dp: declare compatible string for sm8150 363bcab6054e scsi: ufs: qcom: dt-bindings: Add SC7280 compatible string 3d1e051b5db8 arm64: dts: imx8mp-dhcom-pdk3: Describe the USB-C connector ef545aff5ca3 arm64: dts: imx8mn-var-som-symphony: Describe the USB-C connector 13069c168986 arm64: dts: imx8mp-tqma8mpql-mba8mpxl: Fix USB connector description c92840a54a7a arm64: dts: imx8mp-venice: Fix USB connector description d0235ca7db0f arm64: dts: imx8mp-verdin: Fix USB connector description 8e6a721ca452 arm64: dts: imx8dxl-ss-conn: Move clk_dummy out of USB node 7662ace2b978 arm64: dts: imx8mn-evk: Move port under USB connector 92576b82f349 arm64: dts: imx8mm-evk: Move port under USB connector 91c629656840 arm64: dts: freescale: introduce dimonoff-gateway-evk board 8b75c148251b dt-bindings: arm: fsl: add Dimonoff gateway EVK board 192ca710eafd dt-bindings: vendor-prefixes: add dimonoff edc62a2939e3 arm64: dts: imx8m*-tqma8m*: Add chassis-type d35e9fd630d7 arm64: dts: imx8mn-beacon: Support overdrive mode a684f6ef9a40 arm64: dts: imx8mn: Enable Overdrive mode 0c6ce8fb001d arm64: dts: imx8mm-beacon: Enable overdrive mode 42e3d3eaa3cb arm64: dts: imx8mm: Add optional overdrive DTSI f9b749293626 arm64: dts: imx8mm: Reduce GPU to nominal speed aadc35d489bd arm64: dts: imx93: Fix the micfil clock-names entries f8b732c140f6 ARM: dts: imx23/28: Fix the DMA controller node name 9697ec153a9c ARM: dts: imx23-sansa: Use preferred i2c-gpios properties 62875ee7373e ARM: dts: imx27-apf27dev: Fix LED name 6bd0d6d0fb3d ARM: dts: imx25/27: Pass timing0 3cd4341f361d ARM: dts: imx25: Fix the iim compatible string 52eef6a12e21 arm64: dts: exynos: google: Add initial Oriole/pixel 6 board support b0f009ddef83 arm64: dts: exynos: google: Add initial Google gs101 SoC support 7932b36aab04 dt-bindings: arm: google: Add bindings for Google ARM platforms c439b1ecd46b dt-bindings: PCI: ti,j721e-pci-*: Add j784s4-pci-* compatible strings 5114ddf2754e dt-bindings: PCI: ti,j721e-pci-*: Add checks for num-lanes 5142777cc846 arm64: dts: renesas: white-hawk-cpu: Fix missing serial console pin control 9c5b72f0dbf7 arm64: dts: renesas: rzg3s-smarc-som: Enable the Ethernet interfaces c20cd1060c83 arm64: dts: renesas: rzg3s-smarc-som: Use switches' names to select on-board functionalities d1702886b9b1 arm64: dts: renesas: r9a08g045: Add Ethernet nodes c8bc29914258 arm64: dts: renesas: r9a08g045: Add IA55 interrupt controller node 2ac19b878bcd arm64: zynqmp: Add missing destination mailbox compatible bfda609d3986 arm64: zynqmp: Fix clock node name in kv260 cards bf79a715a44c arm64: zynqmp: Move fixed clock to / for kv260 067130bf35dd dt-bindings: soc: Add new board description for MicroBlaze V 3909199b5365 dt-bindings: soc: xilinx: Move xilinx.yaml from arm to soc 5a30f0c409d5 arm64: xilinx: Remove address/size-cells from gem nodes c7afa96873c9 arm64: xilinx: Remove address/size-cells from flash node e3a99f7f8d11 arm64: xilinx: Put ethernet phys to mdio node 6f4a9a0c8df9 arm64: xilinx: Remove mt25qu512a compatible string from SOM e3823e6a85e8 arm64: xilinx: Use lower case for partition address ee878ab978b7 arm64: xilinx: Do not use '_' in DT node names edb56e5ac871 riscv: dts: starfive: Enable SDIO wifi on JH7100 boards 738fd2fd6271 riscv: dts: starfive: Enable SD-card on JH7100 boards 4a3456d5f756 riscv: dts: starfive: Add JH7100 MMC nodes 0b98a998f256 riscv: dts: starfive: Add pool for coherent DMA memory on JH7100 boards b7e59570a83e riscv: dts: starfive: Add JH7100 cache controller 0e3644417255 riscv: dts: starfive: Mark the JH7100 as having non-coherent DMAs 2ce3980ca0ba riscv: dts: starfive: Group tuples in interrupt properties 21bb4608c1f4 arm64: dts: ti: k3-am62-main: Add GPU device node 21dbc3bb6085 dt-bindings: interconnect: qcom,msm8998-bwmon: Add QCM2290 bwmon instance 0a5288800340 dt-bindings: rockchip,vop2: Add more endpoint definition 689213783aed dt-bindings: display: vop2: Add rk3588 support d06f02a431a5 dt-bindings: interconnect: qcom,msm8998-bwmon: Add SM6115 bwmon instance a67732e07f79 arm64: dts: fsd: Add MFC related DT enteries a8f325704092 arm64: dts: ti: k3-j721s2-evm: Add overlay for PCIE1 Endpoint Mode c33d48e723e9 arm64: dts: ti: k3-j721e-evm: Add overlay for PCIE0 Endpoint Mode 411f344456e4 arm64: dts: ti: k3-j721e-sk: Add TPS6594 family PMICs e88109a7ea70 arm64: dts: ti: k3-am69-sk: Add support for TPS6594 PMIC 8203df16463f arm64: dts: ti: k3-j784s4-evm: Add support for TPS6594 PMIC 12693cd3a151 arm64: dts: ti: k3-j721e-som-p0: Add TP6594 family PMICs 022683d6bab2 arm64: dts: ti: k3-j721s2-som-p0: Add TP6594 family PMICs b13637076b0a arm64: dts: ti: k3-j7200-som-p0: Add TP6594 family PMICs 073920a8e469 spi: dw: Remove Intel Thunder Bay SOC support 853b38b4ccbe dt-bindings: media: s5p-mfc: Add mfcv12 variant af1444135df0 dt-bindings: soc: rockchip: add rk3588 vop/vo syscon ea9d3ade1f63 media: dt-bindings: Add OmniVision OV64A40 eac07152e0b8 media: dt-bindings: media: imx335: Add supply bindings 37535c00a2ec media: dt-bindings: gc0308: add binding 9be8a81b5d55 media: dt-bindings: ov8856: decouple lanes and link frequency from driver e78a33d58798 media: dt-bindings: alvium: add document YAML binding 123e53dddda5 dt-bindings: vendor-prefixes: Add prefix alliedvision 5367c47d39ee media: dt-bindings: ak7375: Add ak7345 support 33368f1c353f dt-bindings: mfd: pm8008: Clean up example node names 2ab5a6b315e7 dt-bindings: leds: qcom,spmi-flash-led: Fix example node name fa6a05463677 dt-bindings: leds: aw200xx: Fix led pattern and add reg constraints 44e89edff478 dt-bindings: leds: awinic,aw200xx: Add AW20108 device 6cd025d35790 dt-bindings: leds: aw200xx: Remove property "awinic,display-rows" 65b3a1cec5b9 dt-bindings: leds: aw200xx: Introduce optional enable-gpios property 48e46bb513fb dt-bindings: leds: Add Allwinner A100 LED controller 193b43eae00d dt-bindings: leds: Fix JSON pointer in max-brightness ac28e493721a ARM: dts: imx25: Move usbphy nodes out of simple-bus 90f8840e451d ARM: dts: imx1: Use 'bus' for AIPI bus dfc79426f635 ARM: dts: imx27-phytec-phycore-rdk: Move usbphy nodes out of simple-bus 92c19f27621f ARM: dts: imx27-pdk: Move usbphy0 out of simple-bus 09cddc0d2c3d ARM: dts: imx27: Use 'bus' for EMI bus e7cd1893e9ea ARM: dts: imx27: Use 'bus' for AIPI bus 81e952ba68c6 media: dt-bindings: media: i2c: Add bindings for TW9900 2ed7758d7c0a dt-bindings: vendor-prefixes: Add techwell vendor prefix 9b5febaeea2a arm64: dts: freescale: add fsl-lx2160a-mblx2160a board c763b70a3ecc dt-bindings: arm: fsl: Add TQ-Systems LX2160A based boards 6c6fc780325f ARM: dts: imx27-phytec-phycore-som: Use the mux- prefix 2571ab1025eb ARM: dts: imx1: Fix sram node c64c46277345 ARM: dts: imx27: Fix sram node 4606862f29a7 ARM: dts: imx: Use flash@0,0 pattern e9c196aff7af ARM: dts: imx25/27-eukrea: Fix RTC node name 34087a021485 ARM: dts: imx25-pdk: Pass #sound-dai-cells f91e9208f059 ARM: dts: imx25: Pass I2C clock-names property cb93e178f443 arm64: dts: freescale: imx93: add i3c1 and i3c2 3b2d451cf59f arm64: dts: ls1012a: Remove big-endian from thermal 25e47251c772 dt-bindings: input: microchip,cap11xx: add advanced sensitivity settings a0fb1bc7fd22 Merge tag 'exynos-drm-next-for-v6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/daeinki/drm-exynos into drm-next aae3e1a63026 dt-bindings: riscv: add Zfa ISA extension description ab9eea090f24 dt-bindings: riscv: add Zvfh[min] ISA extension description 7a64028da27c dt-bindings: riscv: add Zihintntl ISA extension description f4789213e5b6 dt-bindings: riscv: add Zfh[min] ISA extensions description c5de05064f79 dt-bindings: riscv: add vector crypto ISA extensions description 215c236fe6da dt-bindings: riscv: add scalar crypto ISA extensions description 1a96ef0c118a Merge tag 'pef2256-framer' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl 6dbce6382acc Merge tag 'pef2256-framer' into devel 1c566bdd0e0f dt-bindings: net: Add the Lantiq PEF2256 E1/T1/J1 framer 0e2e3f19a42d arm64: dts: rockchip: Add Anbernic RG351V aa1c981f085f arm64: dts: rockchip: Split RG351M from Odroid Go Advance 5985d0436d7f dt-bindings: arm: rockchip: Add Anbernic RG351V dddd8bf614e2 arm64: dts: rockchip: Add ethernet0 alias to the dts for RK3588(S) boards e79626358af1 arm64: dts: rockchip: Add ethernet0 alias to the dts for RK3566 boards c2bbb4cb37ce arm64: dts: rockchip: Remove ethernet0 alias from the SoC dtsi for PX30 5df2cd229ef2 arm64: dts: rockchip: Remove ethernetX aliases from the SoC dtsi for RK3328 773747ea9224 arm64: dts: rockchip: Remove ethernet0 alias from the SoC dtsi for RK3368 c47780f2190d arm64: dts: rockchip: Remove ethernet0 alias from the SoC dtsi for RK3399 0e5a28940713 arm64: dts: rockchip: make dts use gpio-fan matrix instead of array 51d3d03836a0 arm64: dts: rockchip: add gpio alias for gpio dt nodes 5fcf2d67aa35 arm64: dts: rockchip: Add dynamic-power-coefficient to rk3399 GPU 80e922961b8e arm64: dts: rockchip: add rk3588 spi aliases to soc dtsi 8f3fbd13ee16 arm64: dts: rockchip: add rk3588 gpio aliases to soc dtsi 15b3dffcbe21 arm64: dts: rockchip: add rk3588 i2c aliases to soc dtsi 095c6f3ed2af arm64: dts: rockchip: move rk3588 serial aliases to soc dtsi 5dc789289ead arm64: dts: rockchip: add Theobroma Jaguar SBC bc75d639d8bd dt-bindings: arm: rockchip: Add Theobroma-Systems Jaguar SBC 3c240c87c027 arm64: dts: rockchip: Add Powkiddy X55 2496d275584a dt-bindings: arm: rockchip: Add Powkiddy X55 517f4adf026d arm64: dts: rockchip: add USB3 host to rock-5a d474a82f6b8f arm64: dts: rockchip: add USB3 host to rock-5b 4bf4fdf576e0 arm64: dts: rockchip: add missing tx/rx-fifo-depth for rk3328 gmac 56e0ff652ec1 arm64: dts: rockchip: add gpio-line-names to rk3308-rock-pi-s 36bdcd2e79dd ARM: dts: rockchip: add hdmi-connector node to rk3036-kylin bd117185d559 ARM: dts: rockchip: fix rk3036 hdmi ports node 2127f8eafedb dt-bindings: clock: google,gs101: fix incorrect numbering and DGB suffix fff73dbf51fc dt-bindings: soc: samsung: usi: add google,gs101-usi compatible 37ffa8542576 dt-bindings: serial: samsung: Make samsung,uart-fifosize a required property fd8ed4626aeb dt-bindings: serial: samsung: Add google-gs101-uart compatible 33bfe5e1dc68 dt-bindings: watchdog: Document Google gs101 watchdog bindings e6381c01b68b riscv: dts: thead: Enable LicheePi 4A eMMC and microSD 3bd0505c030a riscv: dts: thead: Enable BeagleV Ahead eMMC and microSD a53de85228bf riscv: dts: thead: Add TH1520 mmc controllers and sdhci clock fd1214b13ed4 ARM: dts: microchip: sama5d27_som1_ek: Remove mmc-ddr-3_3v property from sdmmc0 node 5d2956b92dea dt-bindings: interrupt-controller: mpm: Pass MSG RAM slice through phandle 402b4259739c dt-bindings: interrupt-controller: renesas,rzg2l-irqc: Document RZ/G3S 150ddb24b2f0 Merge tag 'coresight-next-v6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/coresight/linux into char-misc-next 64011b700499 dt-bindings: arm-smmu: Document SM8[45]50 GPU SMMU a5ab14d25e79 dt-bindings: arm-smmu: Add compatible for X1E80100 SoC aaa9819e17c5 dt-bindings: iommu: arm,smmu: document the SM8650 System MMU c04ccbbeb58a dt-bindings: iommu: arm,smmu: document clocks for the SM8350 GPU SMMU b73f681e020f arm64: dts: juno: Align thermal zone names with bindings 8762e182cc34 dt-bindings: hwmon: Add lltc ltc4286 driver bindings 7711cd743748 Merge tag 'exynos-drm-next-for-v6.7-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/daeinki/drm-exynos into exynos-drm-next 0c9c816dddb4 Backmerge tag 'v6.7-rc5' into drm-next cc330eac5dd3 dt-bindings: iio: humidity: Add TI HDC302x support 07a88600291a dt-bindings: iio: light: add ltr390 a803f8c65ec8 dt-bindings: iio: pressure: add honeywell,hsc030 49600f0eeb26 dt-bindings: iio: temperature: add MLX90635 device 5f69a9e8d3dd dt-bindings: hwmon: Increase max number of io-channels 565f404ae838 dt-bindings: hwmon: Add mps mp5990 driver bindings ad5cba1ee29a ASoC: dt-bindings: qcom,lpass-wsa-macro: Add SM8650 LPASS WSA 880126e66fb3 ASoC: dt-bindings: qcom,lpass-va-macro: Add SM8650 LPASS VA 19ed8a218bd9 ASoC: dt-bindings: qcom,lpass-tx-macro: Add SM8650 LPASS TX 322423704418 ASoC: dt-bindings: qcom,lpass-rx-macro: Add SM8650 LPASS RX f09397ff6cbf dt-bindings: dma: Add dma-channel-mask to nvidia,tegra210-adma 6263d2ffbb0f dt-bindings: dma: sf-pdma: add new compatible name 7581e8bd108d arm64: dts: mediatek: mt8192: Add Smart Voltage Scaling node de53c9a33f27 arm64: dts: mediatek: mt8195: Add SVS node and reduce LVTS_AP iospace 53ceb33cc2de arm64: dts: mediatek: mt8183: Change iospaces for thermal and svs d305525393a4 arm64: dts: mediatek: mt8186: fix address warning for ADSP mailboxes d4dbd2b56a9f arm64: dts: mediatek: mt8186: Fix alias prefix for ovl_2l0 209e23166717 arm64: dts: mt6358: Drop bogus "regulator-fixed" compatible properties b5aaf3dc3cc4 arm64: dts: mt8183: kukui-jacuzzi: Drop bogus anx7625 panel_flag property aef30bad7a04 arm64: dts: Add MediaTek MT8188 dts and evaluation board and Makefile c8d764a0bbc6 dt-bindings: soc: mediatek: pwrap: Modify compatible for MT8188 1b35e3cf8066 dt-bindings: arm: mediatek: Add mt8188 pericfg compatible 7e4914880550 dt-bindings: arm: Add compatible for MediaTek MT8188 c4c85ca7297e arm64: dts: mediatek: mt8195: add DSI and MIPI DPHY nodes e7300ae6b913 dt-bindings: display: mediatek: dsi: add compatible for MediaTek MT8195 cebba0dd1a01 arm64: dts: mediatek: mt6358: Merge ldo_vcn33_* regulators 8ac8be12ac45 dt-bindings: arm: mediatek: convert audsys and mt2701-afe-pcm to yaml 275042f3fe7b arm64: dts: mediatek: mt8195: add MDP3 nodes aba1f17e7acc arm64: dts: mediatek: mt8195: revise VDOSYS RDMA node name 7032d5f144c2 arm64: dts: mediatek: mt8183: correct MDP3 DMA-related nodes 22bae315e031 dt-bindings: display: mediatek: padding: add compatible for MT8195 751c1a1076cb dt-bindings: display: mediatek: split: add compatible for MT8195 e2f195c9941b dt-bindings: display: mediatek: ovl: add compatible for MT8195 98aa994aefee dt-bindings: display: mediatek: merge: add compatible for MT8195 6f5d6cbaa3f9 dt-bindings: display: mediatek: color: add compatible for MT8195 ef86984ae659 dt-bindings: display: mediatek: aal: add compatible for MT8195 8f6efe19695a dt-bindings: media: mediatek: mdp3: add component TDSHP for MT8195 f3a2d9b01651 dt-bindings: media: mediatek: mdp3: add component TCC for MT8195 9952a02bb5ee dt-bindings: media: mediatek: mdp3: add component STITCH for MT8195 6c49acbc4134 dt-bindings: media: mediatek: mdp3: add component HDR for MT8195 d6fdbfb3b4ad dt-bindings: media: mediatek: mdp3: add component FG for MT8195 a7d6e829425b dt-bindings: media: mediatek: mdp3: add compatible for MT8195 WROT 7db0370c2d66 dt-bindings: media: mediatek: mdp3: add compatible for MT8195 RSZ 5620ceb8b6ca dt-bindings: media: mediatek: mdp3: add config for MT8195 RDMA 8f056e0ef45c dt-bindings: media: mediatek: mdp3: merge the indentical RDMA under display c2d8940ef6fd dt-bindings: media: mediatek: mdp3: correct RDMA and WROT node with generic names 4347ab16a815 media: dt-bindings: mediatek: Add phandle to mediatek,scp on MDP3 RDMA e14664bd10f6 arm64: dts: mediatek: mt8195-cherry: Assign sram supply to MFG1 pd 0561502a0693 arm64: dts: mediatek: mt8195-cherry: Add MFG0 domain supply 08b52bb4b076 dt-bindings: reset: mt8188: Add VDOSYS reset control bits 10fbcb9df4e2 dt-bindings: arm: mediatek: Add compatible for MT8188 88c996595db3 dt-bindings: display: mediatek: padding: Add MT8188 ca5643fef42b dt-bindings: display: mediatek: merge: Add compatible for MT8188 ae3b78a94c61 dt-bindings: display: mediatek: mdp-rdma: Add compatible for MT8188 744464b66c7e dt-bindings: display: mediatek: ethdr: Add compatible for MT8188 01b1569a2d88 dt-bindings: thermal: convert Mediatek Thermal to the json-schema 90d08ec14e3c arm64: dts: mt8183: Add jacuzzi pico/pico6 board 5df3f176b5bf dt-bindings: arm64: mediatek: Add mt8183-kukui-jacuzzi-pico 281ab3bf124c arm64: dts: mt8183: Add jacuzzi makomo board 52cfc0fd5dd9 dt-bindings: arm64: mediatek: Add mt8183-kukui-jacuzzi-makomo 19dd875d8e0a arm64: dts: mt8183: Add kukui katsu board b8dd2f8c3e1c dt-bindings: arm64: mediatek: Add mt8183-kukui-katsu 9a6a916f0bc6 arm64: dts: mediatek: Move MT6358 PMIC interrupts to MT8183 boards 3f27ea46dc3d arm64: dts: mediatek: Use interrupts-extended where possible ad0c69fd2fa3 arm64: dts: mediatek: mt8173: Use interrupts-extended where possible c82e8139aeaa arm64: dts: mediatek: mt8183: Use interrupts-extended where possible d8a485fe96f7 dt-bindings: soc: mediatek: add mt8186 and mt8195 svs dt-bindings e66d619c0c3a dt-bindings: arm: mediatek: mmsys: Add VPPSYS compatible for MT8188 5e6b938fc74f arm64: dts: mediatek: mt8192: Add thermal nodes and thermal zones e90ef555e054 arm64: dts: mediatek: mt8183: Add decoder 0f0ccec6cc8d arm64: dts: mediatek: mt8173: Drop VDEC_SYS reg from decoder b6aed11d9548 arm64: dts: mediatek: cherry: Add platform thermal configuration 86760b83d52b dt-bindings: display: simple: Add AUO G156HAN04.0 LVDS display a9ddc30ef584 dt-bindings: display: panel: Add Ilitek ili9805 panel controller defac25462fb dt-bindings: display: st7701: Add Anbernic RG-ARC panel 336bc0e68db2 dt-bindings: display: panel: add Fascontek FS035VG158 panel 955ce81826fb dt-bindings: vendor-prefixes: Add fascontek 752a79b7aaef dt-bindings: display: panel: Clean up leadtek,ltk035c5444t properties 770aea203c16 Merge 6.7-rc5 into tty-next 34ef5edc5b88 Merge 6.7-rc5 into usb-next 621073890e71 Merge branch 'for-v6.8/samsung-bindings-compatibles' into next/dt64 bf94b2d5359e arm64: dts: exynos: add minimal support for exynosautov920 sadk board e9fd8cf1d2d8 arm64: dts: exynos: add initial support for exynosautov920 SoC d0863d30608a dt-bindings: pinctrl: samsung: correct ExynosAutov920 wake-up compatibles 9bdf0db8ae4b dt-bindings: samsung: exynos-sysreg: combine exynosautov920 with other enum 5b54324e6d5b dt-bindings: dma: Drop undocumented examples e2fd1a08fd82 Merge remote-tracking branch 'drm-misc/drm-misc-next' into msm-next a04c2351b389 dt-bindings: soc: google: exynos-sysreg: add dedicated SYSREG compatibles to GS101 9b3c118b3d19 dt-bindings: clock: Add Google gs101 clock management unit bindings d97b5e938286 dt-bindings: soc: samsung: exynos-pmu: Add gs101 compatible 6a5a439c0701 dt-bindings: pinctrl: samsung: add gs101-wakeup-eint compatible 10422d721886 dt-bindings: pinctrl: samsung: add google,gs101-pinctrl compatible 3a5cb767f670 media: dt-bindings: media: rkisp1: Fix the port description for the parallel interface 1da803cb7af8 arm64: dts: qcom: qcm6490-fairphone-fp5: Enable WiFi 8da528961e4e arm64: dts: qcom: qcm6490-fairphone-fp5: Enable various remoteprocs e6fa65e6d152 arm64: dts: qcom: sc7280: Add CDSP node fc9753f721c5 arm64: dts: qcom: sc7280: Add ADSP node c8ee1d58df76 arm64: dts: qcom: sc7280: Use WPSS PAS instead of PIL 52f7c413fda4 arm64: dts: qcom: qcm6490-fairphone-fp5: Enable UFS 4df3a7b5d504 arm64: dts: qcom: msm8953: Set initial address for memory 423afe7e3dcb ARM: dts: qcom: msm8226: Add GPU bba409f9c339 ARM: dts: qcom: Disable pm8941 & pm8226 smbb charger by default 7e9db953a623 arm64: dts: qcom: sc7280: Add UFS nodes for sc7280 IDP board 4e3613f89c7f arm64: dts: qcom: sc7280: Add UFS nodes for sc7280 soc d8bfc2581200 dt-bindings: input: gpio-mouse: Convert to json-schema 2691fb7a0b13 dt-bindings: drm: rockchip: convert inno_hdmi-rockchip.txt to yaml 2dc455b73efa ARM: dts: samsung: exynos4210-i9100: Add accelerometer node 0fab2792a476 ARM: dts: samsung: exynos4210-i9100: Add node for touch keys 7ea4a30a8fd6 ARM: dts: samsung: exynos4210-i9100: Unconditionally enable LDO12 4cee9945012b ARM: dts: microchip: sama5d27_wlsom1_ek: Remove mmc-ddr-3_3v property from sdmmc0 node e76f84dfaedb arm64: dts: qcom: sm8650: Add DisplayPort device nodes 2cfe9148e611 arm64: dts: qcom: pm8550: drop PWM address/size cells 49e3d2a63a49 dt-bindings: display: mediatek: padding: Add MT8188 8c1a5538e89b dt-bindings: display: mediatek: merge: Add compatible for MT8188 29025812d6c3 dt-bindings: cache: qcom,llcc: correct QDU1000 reg entries 3e60d5b58b7d dt-bindings: gpu: samsung-scaler: constrain iommus and power-domains 1d6aee346b02 dt-bindings: gpu: samsung-g2d: constrain iommus and power-domains d4a84a84e922 dt-bindings: gpu: samsung: constrain clocks in top-level properties 1e0b14dc8237 dt-bindings: gpu: samsung: re-order entries to match coding convention ba50ff463c59 dt-bindings: gpu: samsung-rotator: drop redundant quotes 1a3c1bf5b141 dt-bindings: display: mediatek: mdp-rdma: Add compatible for MT8188 0a16c7e2c414 dt-bindings: display: mediatek: ethdr: Add compatible for MT8188 925f69a6cc7d dt-bindings: serial: qcom,msm-uartdm: Vote for shared resources 44f4478aa927 dt-bindings: serial: snps-dw-apb-uart: include rs485 schema fad4b52a0fdb arm64: dts: hisilicon: hikey970-pmic: clean up SPMI node 051c12eb5d46 arm64: dts: hisilicon: hikey970-pmic: fix regulator cells properties e567127bd619 dt-bindings: hisilicon: Merge hi3620-clock into hisilicon,sysctrl binding 4b823f7042ef arm64: dts: qcom: x1e80100: Add Compute Reference Device f51679f0f817 arm64: dts: qcom: Add base X1E80100 dtsi and the QCP dts ca121fc146b2 dt-bindings: arm: qcom: Document X1E80100 SoC and boards c53c3b8c12a4 dt-bindings: arm: cpus: Add qcom,oryon compatible aa432318faa9 Merge branch 'icc-x1e80100' of https://git.kernel.org/pub/scm/linux/kernel/git/djakov/icc into arm64-for-6.8 9eba2f2fb214 Merge branch '20231205061002.30759-4-quic_sibis@quicinc.com' into arm64-for-6.8 f213e67c84b7 Merge branch '20231205061002.30759-4-quic_sibis@quicinc.com' into clk-for-6.8 ecc521e21905 dt-bindings: clock: qcom-rpmhcc: Add RPMHCC bindings for X1E80100 079af735ef3c dt-bindings: clock: qcom: Add X1E80100 GCC clocks 8f4495322f78 arm64: dts: qcom: sm8650-mtp: add WSA8845 speakers 02b73ff63440 arm64: dts: qcom: sm8650: add Soundwire controllers e6679602ac09 arm64: dts: qcom: sm8650: add ADSP audio codec macros 5c0a5d9640c3 arm64: dts: qcom: sm8650: add LPASS LPI pin controller 7f6211cc8e63 arm64: dts: qcom: sm8650: add ADSP GPR b72a9e98977b arm64: dts: qcom: sm8650-qrd: enable IPA 13bdc41575ab arm64: dts: qcom: sm8650: add IPA information 0fd767d395a1 arm64: dts: qcom: sm8650-qrd: add interconnect dependent device nodes d68c8f7f237a arm64: dts: qcom: sm8650-mtp: add interconnect dependent device nodes 900a28b939d2 arm64: dts: qcom: sm8650: add interconnect dependent device nodes ff01973261d0 arm64: dts: qcom: sm8650: add initial SM8650 QRD dts 185ce15a620b arm64: dts: qcom: sm8650: add initial SM8650 MTP dts 487b5dde17e2 arm64: dts: qcom: pm8550ve: make PMK8550VE SID configurable 61ff00c8e1de arm64: dts: qcom: add initial SM8650 dtsi 7266e49a2f3e dt-bindings: arm: qcom: document SM8650 and the reference boards 34a104c65fa9 Merge branch 'icc-sm8650' of https://git.kernel.org/pub/scm/linux/kernel/git/djakov/icc into arm64-for-6.8 dc9c79dc36cc Merge branch '20231106-topic-sm8650-upstream-clocks-v3-5-761a6fadb4c0@linaro.org' into arm64-for-6.8 482bf7559678 Merge git://git.kernel.org/pub/scm/linux/kernel/git/netdev/net 89cdcbe73e3a dt-bindings: display: msm: dp-controller: document SM8650 compatible 6457d6362b66 docs: dt-bindings: add DTS Coding Style document 17bd76b0dcba ARM: dts: rockchip: add gpio alias for gpio dt nodes 1e3bf6cdb555 dt-bindings: mfd: hisilicon,hi6421-spmi-pmic: Clean up example ebf62e0e08ff dt-bindings: mfd: hisilicon,hi6421-spmi-pmic: Fix regulator binding ff778a37f71a dt-bindings: mfd: hisilicon,hi6421-spmi-pmic: Fix up binding reference 60bfc8c9aef9 dt-bindings: firmware: qcom,scm: Allow interconnect for everyone ae3daad140cd arm64: dts: qcom: sm8250-xiaomi-pipa: Add initial device tree 3ab4a6461f9d dt-bindings: arm: qcom: Add Xiaomi Pad 6 (xiaomi-pipa) a4229e4b1bf7 arm64: dts: qcom: sm8550-qrd: enable IPA 0b02bd1a7f8b arm64: dts: qcom: sm8550: add IPA information 1d704f347212 dt-bindings: firmware: qcom,scm: document SCM on X1E80100 SoCs a07e2c07074c dt-bindings: arm: qcom-soc: extend pattern matching for X1E80100 SoC 190053cb1ce8 arm64: dts: qcom: minor whitespace cleanup around '=' e5d9eb69d255 ARM: dts: qcom: minor whitespace cleanup around '=' a12829c0d5ea arm64: dts: qcom: ipq8074: Add QUP4 SPI node 81c5f29af493 arm64: dts: qcom: qdu1000: Add ECPRI clock controller 7f8d2a160503 Merge branch '20231123064735.2979802-2-quic_imrashai@quicinc.com' into clk-for-6.8 a7b1e49f140b dt-bindings: clock: qcom: Add ECPRICC clocks for QDU1000 and QRU1000 0d8365b85a68 ARM: dts: qcom: sdx55: fix USB wakeup interrupt types 4e5dc5d2a1e5 arm64: dts: qcom: sm8550: fix USB wakeup interrupt types b0dd9226dd63 arm64: dts: qcom: sm8150: fix USB wakeup interrupt types 301d240b276b arm64: dts: qcom: sm6375: fix USB wakeup interrupt types bcfa8e3ed274 arm64: dts: qcom: sdm845: fix USB wakeup interrupt types 20a6fe5d28b2 arm64: dts: qcom: sdm670: fix USB wakeup interrupt types d2c7cfd6cfc3 arm64: dts: qcom: sc8180x: fix USB wakeup interrupt types 6f29d799b7cf arm64: dts: qcom: sc7280: fix usb_2 wakeup interrupt types ca84d4480b44 arm64: dts: qcom: sc7280: fix usb_1 wakeup interrupt types 096085135fda arm64: dts: qcom: sc7180: fix USB wakeup interrupt types 6c1f003cc9a1 arm64: dts: qcom: sa8775p: fix USB wakeup interrupt types 45bd09d633c8 arm64: dts: qcom: msm8916-longcheer-l8150: Add battery and charger 195857e6f299 arm64: dts: qcom: pm8916: Add BMS and charger 6caacf1f1bd3 arm64: dts: qcom: sc7280: Add 0xac Adreno speed bin 3ddcb3a31e24 arm64: dts: qcom: sc7280: Mark Adreno SMMU as DMA coherent b8bf84b9efc0 arm64: dts: qcom: sc7280: Fix up GPU SIDs 0830942e59a4 arm64: dts: qcom: sc7280: Add ZAP shader support 6a2b85d201c9 dt-bindings: arm: qcom-soc: extend pattern for matching existing SoCs ddd782c9e1e9 dt-bindings: cache: qcom,llcc: Add X1E80100 compatible 573141bcc2f7 arm64: dts: qcom: sdx75-idp: Enable USB3 and PHY support 93789523f679 arm64: dts: qcom: Add USB3 and PHY support on SDX75 ddc8552a97e0 arm64: dts: qcom: Add interconnect nodes for SDX75 2f6480d75792 arm64: dts: qcom: sm8350: Fix remoteproc interrupt type 22ab1e4b96e5 arm64: dts: qcom: pm8350k: Remove hanging whitespace 648dd7cb906d arm64: dts: qcom: sm8350: Fix DMA0 address aa5e755d7246 dt-bindings: iio: adc: qcom: Add Qualcomm smb139x aee24a669374 arm64: dts: qcom: sc8180x: align APSS with bindings c51b52a3c7aa arm64: dts: qcom: sm6375-pdx225: add fixed touchscreen AVDD regulator 714c2d01cb79 arm64: dts: qcom: sm6125: add interrupts to DWC3 USB controller 869ed2bf0b06 arm64: dts: qcom: sm6115: align mem timer size cells with bindings 5b01a3bc4e38 arm64: dts: qcom: sm8150: use 'gpios' suffix for PCI GPIOs abcbd3630645 arm64: dts: qcom: sc8180x-primus: use 'gpios' suffix for PCI GPIOs 5281b1e2c756 arm64: dts: qcom: sc8180x-flex-5g: use 'gpios' suffix for PCI GPIOs dbf927ecfde3 arm64: dts: qcom: sdm845: correct Soundwire node name 27d49e38f5d4 arm64: dts: qcom: sdm845-db845c: correct LED panic indicator 85591f38ba27 arm64: dts: qcom: qrb5165-rb5: correct LED panic indicator 65b61add6d70 arm64: dts: qcom: sm8250: Add wakeup-source to usb_1 and usb_2 343c9084fd53 arm64: dts: qcom: sdm850-lenovo-yoga: Add wakeup-sources eb9d72ac20a4 arm64: dts: qcom: sa8775p-ride: enable pmm8654au_0_pon_resin e4828a6315b4 arm64: dts: qcom: sm8350: move DPU opp-table to its node cfa2fb4b7f5b arm64: dts: qcom: sc8280xp-x13s: drop sound-dai-cells from eDisplayPort 927e9926b48f arm64: dts: qcom: sc8180x-primus: drop sound-dai-cells from eDisplayPort ca8a02834a8f arm64: dts: qcom: sm8250: correct Soundwire node name 682a341c0cdc arm64: dts: qcom: sc8280xp: correct Soundwire node name 13f2dbc0a9cb arm64: dts: qcom: qdu1000-idp: drop unused LLCC multi-ch-bit-off 6cda67d14000 arm64: dts: qcom: qdu1000: correct LLCC reg entries 208a56e344a2 arm64: dts: qcom: sm8450: fix soundwire controllers node name c7bee631d3e9 arm64: dts: qcom: sm8550: fix soundwire controllers node name 255ca7c95406 Merge branch '20231106-topic-sm8650-upstream-clocks-v3-5-761a6fadb4c0@linaro.org' into clk-for-6.8 52721c372031 dt-bindings: clock: qcom: Document the SM8650 RPMH Clock Controller a8430c36d8bc dt-bindings: clock: qcom: document the SM8650 GPU Clock Controller e39f08bf115a dt-bindings: clock: qcom: document the SM8650 Display Clock Controller 076aa9fc05f3 dt-bindings: clock: qcom: document the SM8650 General Clock Controller abeff2c9f476 dt-bindings: clock: qcom: document the SM8650 TCSR Clock Controller 3714369ceebb dt-bindings: cache: qcom,llcc: Document the SM8650 Last Level Cache Controller cb0f1e272d52 dt-bindings: clock: qcom,gcc-msm8939: Add CSI2 related clocks 7ee4127b7a3f arm64: dts: qcom: sc8280xp: Add in CAMCC for sc8280xp d380ef670205 Merge branch '20231026105345.3376-3-bryan.odonoghue@linaro.org' into arm64-for-6.8 30a292de3f9a Merge branch '20231026105345.3376-3-bryan.odonoghue@linaro.org' into clk-for-6.8 f007e023cbd5 dt-bindings: clock: Add SC8280XP CAMCC aec8967c6dce dt-bindings: clock: Use gcc.yaml for common clock properties 7c1eb93bd0d3 dt-bindings: clock: qcom,gcc-ipq6018: split to separate schema b6364ec8f82d dt-bindings: arm: qcom,ids: Add SoC ID for SM8650 3f482ad7991e arm64: dts: qcom: sm8550: Enable download mode register write fe077e894545 arm64: dts: qcom: sm8350: Add TCSR halt register space 956699ec82d4 arm64: dts: qcom: sm8250: Add TCSR halt register space e0bd046de230 arm64: dts: qcom: ipq5018: add few more reserved memory regions c38c43d3b995 arm64: dts: qcom: ipq5332: add missing properties to the GPIO LED node 0390c1ee5e11 arm64: dts: qcom: ipq9574: enable GPIO based LED 2f9b91c0cf6d arm64: dts: qcom: qrb2210-rb1: use USB host mode 2196010939c0 dt-bindings: firmware: qcom,scm: document SM8650 SCM Firmware Interface ae8a176c474a dt-bindings: soc: qcom: pmic-glink: document SM8650 compatible c3cb68af1e5d dt-bindings: soc: qcom,aoss-qmp: document the SM8560 Always-On Subsystem side channel a6ea4114f911 dt-bindings: mmc: mtk-sd: add tuning steps related property 30e4bc60ac6d dt-bindings: mfd: ti,am3359-tscadc: Allow dmas property to be optional 5c51588d48df dt-bindings: mfd: qcom,spmi-pmic: Add pm8916 vm-bms and lbc a03962f53dbd dt-bindings: mfd: qcom-spmi-pmic: Document PM8937 PMIC 81a2c830f173 dt-bindings: mfd: qcom,tcsr: Add compatible for sm8250/sm8350 fe50e0fb05fc dt-bindings: mfd: ams,as3711: Convert to json-schema 197c27b6cfaa arm64: dts: fsd: add specific compatibles for Tesla FSD 395fa67b6b72 Merge branch 'for-v6.8/samsung-bindings-compatibles' into next/dt64 5927c83d20c8 dt-bindings: watchdog: samsung: add specific compatible for Tesla FSD 78e4ed4670d7 dt-bindings: samsung: exynos-pmu: add specific compatible for Tesla FSD c168df69f5a1 dt-bindings: serial: samsung: add specific compatible for Tesla FSD 6dedf66f0e8b dt-bindings: pwm: samsung: add specific compatible for Tesla FSD 457e5d03f14d dt-bindings: i2c: exynos5: add specific compatible for Tesla FSD 4b7a14529669 dt-bindings: mmc: renesas,sdhi: Document RZ/Five SoC a135e0045af7 dt-bindings: mmc: arasan,sdci: Add gate property for Xilinx platforms d0ed6c92c98e dt-bindings: mmc: sdhci-of-dwcmhsc: Add T-Head TH1520 support f7a9df14027b dt-bindings: net: microchip,ksz: document microchip,rmii-clk-internal b81aa4a5992d media: dt-bindings: mediatek: Add phandle to mediatek,scp on MDP3 RDMA b80f939c4051 dt-bindings: iio/adc: qcom,spmi-vadc: clean up examples 44c4f2c40551 dt-bindings: iio/adc: qcom,spmi-vadc: fix example node names c57fab0a68f9 dt-bindings: iio/adc: qcom,spmi-rradc: clean up example f330b6a06a10 dt-bindings: iio/adc: qcom,spmi-iadc: clean up example d089bb38e3f6 dt-bindings: iio/adc: qcom,spmi-iadc: fix example node name d92310a0b805 dt-bindings: iio/adc: qcom,spmi-iadc: fix reg description 6afb70912c0a Merge tag 'renesas-dts-for-v6.8-tag1' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/renesas-devel into soc/dt 77be7b2ec3d6 arm64: dts: ti: Add verdin am62 mallow board 5fe3785a98a1 dt-bindings: arm: ti: Add verdin am62 mallow board 7bf01a4e3239 ASoC: dt-bindings: fsl,xcvr: Adjust the number of interrupts 568ee5fdf77d dt-bindings: interconnect: Add Qualcomm SM6115 NoC 7549b7adec53 arm64: dts: ti: verdin-am62: Improve spi1 chip-select pinctrl 0b160138fdcc arm64: dts: ti: k3-am625-phyboard-lyra-rdk: Remove HDMI Reset Line Name 42aed107725d arm64: dts: ti: k3-am625-phyboard-lyra-rdk: Add HDMI support 766ac2241c85 arm64: dts: ti: k3-am625-phyboard-lyra-rdk: Lower I2C1 frequency bcf7dd5b8b09 arm64: dts: ti: phycore-am64: Add R5F DMA Region and Mailboxes e1dfb1eb87a4 riscv: dts: microchip: add the mpfs' system controller qspi & associated flash 59d2f723c14b dt-bindings: soc: microchip: add a property for system controller flash 4b452a4cfa9e ARM: dts: imx23/28: Remove undocumented "fsl,clkctrl" 485e1601cd25 ARM: dts: bcm2711: Add BCM2711 xHCI support 439353e944b0 dt-bindings: usb: xhci: Add support for BCM2711 4b95e8b40522 ARM: dts: imx28-lwe: Pass device_type to the memory node ea0431aa1757 ARM: dts: imx23/28: Remove unneeded "fsl,mxs-gpio" e63738dd96c8 ARM: dts: imx28-tx28: Pass #sound-dai-cells fc88878c01c0 arm64: dts: imx8mq-phanbell: make dts use gpio-fan matrix instead of array e21fe3809cd3 arm64: dts: freescale: verdin-imx8mp: add support to mallow board a75cfdc4a966 arm64: dts: freescale: verdin-imx8mm: add support to mallow board 3b7bee60295f arm64: dts: imx8mm-venice-gw7: Adjust PCI Ethernet nodes 5241ecb06203 dt-bindings: arm: fsl: add verdin imx8mp mallow board b80ecc880136 dt-bindings: arm: fsl: add verdin imx8mm mallow board ad1ae2498610 arm64: dts: imx8mm: Slow default video_pll1 clock rate 5aa830cec5a3 arm64: dts: imx8mm: Remove video_pll1 clock rate from clk node 110274d03548 arm64: dts: imx8mm: Simplify mipi_dsi clocks 99d898689e0b ARM: dts: imx7s: Add on-chip memory 29d17af3b09b ARM: dts: imx7: add MIPI-DSI support d9c25edf04ae scsi: ufs: dt-bindings: Add msi-parent for UFS MCQ dba1025f17d0 ARM: dts: nxp: Fix some common switch mistakes 4ea7b578957d arm64: dts: freescale: minor whitespace cleanup around '=' dbb52d93894b arm64: dts: imx8dxl-ss-ddr: change ddr_pmu0 compatible 941d70d2ae55 arm64: dts: tqma8mpql: Remove invalid/unused property ec00a410133c arm64: dts: imx8-ss-audio: Remove unexistent'shared-interrupt' 604139ed79f6 arm64: dts: imx93: Remove unexistent 'shared-interrupt' 7a445842e287 arm64: dts: imx8qxp-mek: Fix gpio-sbu-mux compatible 0c2122b767be arm64: dts: imx8mp-debix-model-a: Use phy-mode 2e9827c5e054 arm64: dts: imx8mm-nitrogen-r2: Fix I2C mux subnode name d1e22a0dfb43 arm64: dts: imx8dxl-ss-conn: Fix Ethernet interrupt-names order 6299d7ae35e5 arm64: dts: imx8mm-emcon-avari: Fix gpio-cells 9de3f32f3c7d arm64: dts: imx8qm-ss-dma: Pass lpuart dma-names 6905c613057b arm64: dts: freescale: Add SKOV IMX8MP CPU revB board b20a05f3b464 arm64: dts: imx8mn-var-som-symphony: add vcc supply for PCA9534 a5a6af3c0bdd arm64: dts: freescale: introduce rve-gateway board 83600000758e arm64: dts: freescale: debix-som-a-bmb-08: Add CSI Power Regulators b5e632bcd082 arm64: dts: imx8-apalis: add can power-up delay on ixora board 9804057f0f96 arm64: dts: imx8mn-var-som: add fixed 3.3V regulator for EEPROM e3c93255cfdb arm64: dts: imx8mm-venice-gw7: Fix pci sub-nodes 8357f0b7ae64 arm64: dts: imx8mp: Disable dsp reserved memory by default 3b2b78d127df arm64: dts: imx8mp: Add NPU Node b13969aeeefc arm64: dts: freescale: debix-som: Add heartbeat LED 5c6068a3aecc arm64: dts: freescale: Add dual-channel LVDS overlay for TQMa8MPxL 37dbfb74c066 arm64: dts: imx8mp-venice-gw74xx: remove unecessary propreties in tpm node 12f50b18b3a5 ARM: dts: nxp: minor whitespace cleanup around '=' 7e4a296e0073 ARM: dts: imx7d-colibri-emmc: Add usdhc aliases aac483d2d190 ARM: dts: imx6qdl-colibri: Add usdhc aliases 534d21c04c41 ARM: dts: imx6qdl-apalis: Add usdhc aliases 4105f51d0c63 ARM: dts: nxp: imx7d-pico: add cpu-supply nodes 4a5f36c1120b dt-bindings: arm: Add compatible for SKOV i.MX8MP RevB board 7efe4371f644 dt-bindings: arm: fsl: add RVE gateway board 3c86e357feb0 dt-bindings: vendor-prefixes: add rve 04660a3dbd9f ARM: dts: broadcom: Add BCM63138's high speed UART 2e36ee7e60cd arm64: dts: ti: k3-am62x: Add overlay for IMX219 8478bfdedc00 arm64: dts: ti: k3-am62a7-sk: Enable camera peripherals a361c10e44cc arm64: dts: ti: k3-am62x: Add overlays for OV5640 820399f7bf0f arm64: dts: ti: k3-am62x-sk: Enable camera peripherals 4de948eeb982 arm64: dts: ti: k3-am625-beagleplay: Add overlays for OV5640 8d6be01e5e7c arm64: dts: ti: k3-am62a-main: Enable CSI2-RX d52951f9d78a arm64: dts: ti: k3-am62-main: Enable CSI2-RX 4d667e27b3fd arm64: dts: ti: k3-am65: Add AM652 dtsi file 3d2161ed0c2b dt-bindings: perf: fsl-imx-ddr: Add i.MX8DXL compatible 189fe310f16e dt-bindings: clock: support i.MX93 ANATOP clock module b44d3f817227 ARM: dts: imx: tqma7: add lm75a sensor (rev. 01xxx) b654e96c546e dt-bindings: display: simple: add Evervision VGG644804 panel 05a02c1a58e1 dt-bindings: ili9881c: Add Ampire AM8001280G LCD panel 96be0427a528 ARM: dts: rockchip: Move uart aliases to SoC dtsi for RK3128 18c0b8b47af4 ARM: dts: rockchip: Move i2c aliases to SoC dtsi for RK3128 0191774d40bb ARM: dts: rockchip: Move gpio aliases to SoC dtsi for RK3128 4b6344ed1b32 ARM: dts: rockchip: Add Sonoff iHost Smart Home Hub 3cbab293b053 dt-bindings: arm: rockchip: Add Sonoff iHost afacdf8be4db ARM: dts: rockchip: Add rv1109 SoC ad1e5ad721a5 ARM: dts: rockchip: Split up rgmii1 pinctrl on rv1126 fc0ef88ee0a1 ARM: dts: rockchip: Add i2c2 node to rv1126 bf739d2f67ae ARM: dts: rockchip: Serial aliases for rv1126 049605e5080d ARM: dts: rockchip: Add alternate UART pins to rv1126 59e8d345382e ARM: dts: rockchip: Enable GPU for XPI-3128 464bddcf0726 ARM: dts: rockchip: Add GPU node for RK3128 8af06043d850 ARM: dts: rockchip: Add power-controller for RK3128 8f65bb97112e dt-bindings: display: himax-hx8394: Add Powkiddy X55 panel ed2d8407a82d dt-bindings: display: Document Himax HX8394 panel rotation 5319f5062c10 dt-bindings: display: simple: Add boe,bp101wx1-100 panel db09be0ff97b ARM: dts: imx6q-apalis: add can power-up delay on ixora board 31fdbd1cd6c6 dt-bindings: display: msm: document the SM8650 Mobile Display Subsystem 52e16372d1c6 dt-bindings: display: msm: document the SM8650 DPU 258f55b8a6c7 dt-bindings: display: msm-dsi-controller-main: document the SM8650 DSI Controller f06034e33173 dt-bindings: display: msm-dsi-phy-7nm: document the SM8650 DSI PHY e7cafbdafccf dt-bindings: display: msm: Add SDM670 MDSS 58504ed9c645 dt-bindings: display/msm: sdm845-dpu: Describe SDM670 d8b80f6fd0c5 dt-bindings: display/msm: dsi-controller-main: add SDM670 compatible 0c71ce621111 arm64: dts: ti: k3-am625-beagleplay: Use UART name in pinmux name 0895f560a171 arm64: dts: ti: k3-am62a7-sk: Add interrupt support for IO Expander 696f6e8d6176 arm64: dts: ti: k3-am625-verdin: Enable Verdin UART2 145b9a5ffb00 arm64: dts: ti: k3-am62-main: Add gpio-ranges properties 0d95f5e22dde arm64: dts: ti: k3-am64: Enable SDHCI nodes at the board level 8ccabbb5322f arm64: dts: ti: k3-am65: Enable SDHCI nodes at the board level 4b9d0ee63df8 arm64: dts: ti: k3-am65: Add full compatible to dss-oldi-io-ctrl node b64af72b8e7b arm64: dts: ti: k3-j784s4: Add chipid node to wkup_conf bus a70ca898f980 arm64: dts: ti: k3-j721s2: Add chipid node to wkup_conf bus 638e0242808a arm64: dts: ti: k3-j721e: Add chipid node to wkup_conf bus 0b0e18c3dce2 arm64: dts: ti: k3-j7200: Add chipid node to wkup_conf bus 16b21e3cf2ea arm64: dts: ti: k3-am65: Add chipid node to wkup_conf bus ba6541592794 dt-bindings: iio: light: isl76682: Document ISL76682 3678e1e114f2 dt-bindings: pinctrl: qcom,sm8550-lpass-lpi: add X1E80100 LPASS LPI 4854bb4b43e2 dt-bindings: pinctrl: pinctrl-single: add ti,j7200-padconf compatible 062b01e5c736 dt-bindings: iio: light: add support for Vishay VEML6075 3f170ed89d6f dt-bindings: usb: tps6598x: add reset-gpios property 69a424bfd498 dt-bindings: iio/adc: ti,palmas-gpadc: Drop incomplete example 5cf3c6e7327b dt-bindings: adi,ad5791: Add support for controlling RBUF 7a11d1470ed1 dt-bindings: display: bridge: lt8912b: Add power supplies 562bb8392ec6 spi: spl022: fix sleeping in interrupt context 83c535a1ec6b dt-bindings: iio: honeywell,mprls0025pa: drop ref from pressure properties 7cb202a1a899 dt-bindings: media: add bindings for stm32 dcmipp fce776c784a0 dt-bindings: media: Add bindings for THine THP7312 ISP 23c5bf41000e dt-bindings: media: i2c: add galaxycore,gc2145 dt-bindings e6429afd32f1 dt-bindings: vendor-prefixes: Add prefix for GalaxyCore Inc. d1287a3d111f dt-bindings: gpio: rockchip: add a pattern for gpio hogs e08aefe3ce14 Merge tag 'qcom-dts-for-6.7-2' into arm32-for-6.8 66862cc676b1 ARM: dts: qcom: Add support for HTC One Mini 2 ac27d4b5eaa6 Merge tag 'v6.7-rc4' into media_stage 8a745825682b arm64: dts: qcom: sm6350: Make watchdog bark interrupt edge triggered 4de273b8d5cf arm64: dts: qcom: sc8280xp: Make watchdog bark interrupt edge triggered 94d4ed6b0efb arm64: dts: qcom: sa8775p: Make watchdog bark interrupt edge triggered 9e80723d8b4f arm64: dts: qcom: sm8250: Make watchdog bark interrupt edge triggered ef5fa5d97caa arm64: dts: qcom: sm8150: Make watchdog bark interrupt edge triggered 3879bc4c1c04 arm64: dts: qcom: sdm845: Make watchdog bark interrupt edge triggered 8e7e69e2041a arm64: dts: qcom: sc7280: Make watchdog bark interrupt edge triggered 6584d8b4799e arm64: dts: qcom: sc7180: Make watchdog bark interrupt edge triggered 04f80707bc19 arm64: dts: qcom: sc8180x: drop duplicated PCI iommus property 04597b9d0b6f dt-bindings: arm: qcom: Add HTC One Mini 2 7ff927ff9139 dt-bindings: vendor-prefixes: document HTC Corporation fa70da0426ea arm64: dts: qcom: sm8550: correct TX Soundwire clock ed7e07a029d6 arm64: dts: qcom: sm8450: correct TX Soundwire clock 541ded0776d2 arm64: dts: qcom: sc8180x-primus: Fix HALL_INT polarity 39c752cf5603 arm64: dts: qcom: sc8280xp-crd: fix eDP phy compatible e5319a1187df arm64: dts: qcom: sdm632-fairphone-fp3: Enable LPASS daf6cf6a007f arm64: dts: qcom: msm8916-acer-a1-724: Add notification LED 2a186fbc9370 arm64: dts: qcom: ipq6018: use CPUFreq NVMEM 91d98fe1640a arm64: dts: qcom: msm8939-huawei-kiwi: Add initial device tree 6718a893d987 dt-bindings: arm: qcom: Add Huawei Honor 5X / GR5 (2016) f36c60304a90 arm64: dts: qcom: msm8953: Use non-deprecated qcom,domain in LPASS fa91149122fc arm64: dts: qcom: qrb2210-rb1: add wifi variant property 9862c76b6484 arm64: dts: qcom: qrb2210-rb1: Enable CAN bus controller 90510995b456 arm64: dts: qcom: qrb2210-rb1: Set up HDMI f168a1f5fd2a arm64: dts: qcom: qcm2290: Hook up interconnects a66c95bb5052 arm64: dts: qcom: qcm2290: Add display nodes 1b3d99e8ad9d arm64: dts: qcom: sc7280: Add the missing MDSS icc path 463b9cc7faa3 arm64: dts: qcom: sc7180: Add the missing MDSS icc path a2b32f52593b arm64: dts: qcom: sc8280xp: Add QMP handle to RPMh stats 0541077473ea dt-bindings: soc: qcom: stats: Add QMP handle 46fd383def7f arm64: dts: qcom: sm8250-xiaomi-elish: Add pm8150b type-c node and enable usb otg 45ca7aacee21 arm64: dts: qcom: sm8250-xiaomi-elish: Fix typos 9dee357f1ff5 arm64: dts: qcom: msm8939-longcheer-l9100: Add proximity-near-level d6b8367dbb65 arm64: dts: qcom: qrb4210-rb2: Enable bluetooth 9e8fcdbc4d75 arm64: dts: qcom: sm6115: Add UART3 e88a0c4a9117 arm64: dts: qcom: sdm632-fairphone-fp3: Enable WiFi/Bluetooth a808b8c6d7f4 dt-bindings: arm: qcom: Fix html link 004244e4cbd5 arm64: dts: qcom: Add base qcs6490-rb3gen2 board dts 3f55e77ebc86 arm64: dts: qcom: Add base qcm6490 idp board dts 9e08836a864f dt-bindings: arm: qcom: Add QCM6490 IDP and QCS6490 RB3Gen2 board c538a9224903 arm64: dts: qcom: sm4450-qrd: mark QRD4450 reserved gpios 34764956c2e4 arm64: dts: qcom: sm4450-qrd: add QRD4450 uart support b5fe030e21e0 arm64: dts: qcom: sm4450: add uart console support 76478ce29df3 arm64: dts: qcom: sm4450: Add RPMH and Global clock 52ea11ee57e9 arm64: dts: qcom: sm4450: Add apps_rsc and cmd_db node d42f9497ccad arm64: dts: qcom: ipq8074: pass QMP PCI PHY PIPE clocks to GCC 9b98d0a1718e dt-bindings: clocks: qcom,gcc-ipq8074: allow QMP PCI PHY PIPE clocks 2417b30e3609 arm64: dts: qcom: msm8953: add SPI interfaces 66dd2b49a0b3 arm64: dts: qcom: qcm6490-fairphone-fp5: Add PM7325 thermals 0b651704285a arm64: dts: qcom: qcm6490-fairphone-fp5: Add PMK7325 thermals 8630d7baedf5 arm64: dts: qcom: qcm6490-fairphone-fp5: Add PM7250B thermals 959371b1b650 iio: adc: Add PM7325 PMIC7 ADC bindings b1e6472aae24 arm64: dts: qcom: sm8250: Add OPP table support to UFSHC 6aeff20d0bd6 arm64: dts: qcom: sdm845: Add OPP table support to UFSHC e8d1d500097e ARM: dts: qcom: msm8974: Add watchdog node 615027dbbe1d dt-bindings: arm: qcom: drop the IPQ board types ebb3e763ee5b arm64: dts: qcom: ipq5018: enable the CPUFreq support 3ca74e9810cf dt-bindings: clock: qcom,a53pll: add IPQ5018 compatible dcbafe8963f4 ARM: dts: qcom: sdx65: correct SPMI node name 98b030d58c93 ARM: dts: qcom: sdx65: add missing GCC clocks 07a16205d0e0 ARM: dts: qcom: sdx65: correct PCIe EP phy-names fe48cd5331dc dt-bindings: display: msm: Add reg bus and rotator interconnects 8c1892c5f696 dt-bindings: display: msm: qcm2290-mdss: Use the non-deprecated DSI compat 7cfd5769a991 dt-bindings: display/msm: qcom, sm8150-mdss: correct DSI PHY compatible 91abf991ed4a dt-bindings: display/msm: qcom, sm8250-mdss: add DisplayPort controller node c203dee53e38 ARM: dts: rockchip: Enable gmac for XPI-3128 a31102a06882 ARM: dts: rockchip: Add gmac node for RK3128 d02bab784773 dt-bindings: gpu: mali-utgard: Add Rockchip RK3128 compatible 61b6b8e5340b dt-bindings: net: qcom,ipa: document SM8650 compatible a0fa8df10233 Merge tag 'renesas-pinctrl-for-v6.8-tag1' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/renesas-drivers into devel 6c58c6977828 dt-bindings: gpio: modepin: Describe label property 7f00d1c96321 dt-bindings: display: ti: Add support for am62a7 dss 6bed64726635 arm64: dts: ti: k3-am68-sk-base-board: Add alias for MCU CPSW2G f494c9948974 arm64: dts: ti: iot2050: Add icssg-prueth nodes for PG2 devices 403938b5222f arm64: dts: ti: iot2050: Refactor the m.2 and minipcie power pin 45e3b6aa9185 arm64: dts: ti: iot2050: Definitions for runtime pinmuxing b14c51a347fb arm64: dts: ti: iot2050: Drop unused ecap0 PWM 38f52ad2cea9 arm64: dts: ti: iot2050: Re-add aliases a84e54a6c2a0 arm64: dts: ti: k3-am62x-sk-common: Mark mcu gpio and mcu_gpio_intr as reserved 0baa456c51ce arm64: dts: ti: k3-am62p5-sk: Mark mcu gpio and mcu_gpio_intr as reserved 131aadfec025 arm64: dts: ti: k3-am642-evm/sk: Mark mcu_gpio_intr as reserved bbda0d8be30e arm64: dts: ti: k3-am64-main: Fix typo in epwm_tbclk node name 5e8876dba890 arm64: dts: ti: k3-am65-main: Fix DSS irq trigger type fd78a91dedf3 arm64: dts: ti: k3-am62a-main: Fix GPIO pin count in DT nodes 05614d5b4f00 arm64: dts: ti: minor whitespace cleanup around '=' ca6dff24071e ARM: dts: omap4-embt2ws: Add Bluetooth cff0864e2eea Merge git://git.kernel.org/pub/scm/linux/kernel/git/netdev/net 2a2ae1545117 dt-bindings: input: gpio-keys: Allow optional dedicated wakeirq aed93474ebc0 Merge patch series "Add Huashan Pi board support" 318917bad2c6 riscv: dts: sophgo: add Huashan Pi board device tree 8a2824be66df riscv: dts: sophgo: add initial CV1812H SoC device tree 3ff295494c04 riscv: dts: sophgo: cv18xx: Add gpio devices dfcd3e4c81d9 riscv: dts: sophgo: Separate compatible specific for CV1800B soc 8c5d4ad957fa dt-bindings: riscv: Add SOPHGO Huashan Pi board compatibles e393d2e6705e dt-bindings: timer: Add SOPHGO CV1812H clint 65cc6be0d442 dt-bindings: interrupt-controller: Add SOPHGO CV1812H plic dce8266bb548 ARM: dts: omap: logicpd-torpedo: do not disguise GNSS device 0f0cee70a881 ARM: dts: omap4-embt2ws: enable 32K clock on WLAN 33dfdcf03832 ARM: dts: ti/omap: Replace deprecated extcon-usb-gpio id-gpio/vbus-gpio properties aa5a9a109405 dt-bindings: power: meson-g12a-power: document ISP power domain a9f86a1f45b5 dt-bindings: marvell: Add Marvell MV88E6060 DSA schema 5024553a10f5 dt-bindings: marvell: Rewrite MV88E6xxx in schema ad4c44e96eec dt-bindings: net: ethernet-switch: Accept special variants 17baedd697fb dt-bindings: net: mvusb: Fix up DSA example 9c7ccdf2dc30 dt-bindings: net: dsa: Require ports or ethernet-ports 8adbf64f3cdd dt-bindings: input: mediatek,pmic-keys: Drop incomplete example cdc098b167e1 dt-bindings: input: sprd,sc27xx-vibrator: Drop incomplete example 0629a76a9d04 dt-bindings: correct white-spaces in examples 2f78b6dd5c42 dt-bindings: reset: hisilicon,hi3660-reset: Drop providers and consumers from example f835598ebf60 dt-bindings: arm/calxeda: drop unneeded quotes 0d2567437a54 dt-bindings: fsl,dpaa2-console: drop unneeded quotes 352ed027a423 dt-bindings: interrupt-controller: qcom,pdc: document pdc on X1E80100 df641036bac4 dt-bindings: qcom,pdc: document the SM8650 Power Domain Controller 1e17b2ba4499 dt-bindings: interrupt-controller: Add SDX75 PDC compatible c0aff4abb03a dt-bindings: reset: imx-src: Simplify compatible schema and drop unneeded quotes df20c9f94014 dt-bindings: reset: qcom: drop unneeded quotes 1516b28c7069 dt-bindings: reset: renesas,rzg2l-usbphy-ctrl: Document RZ/Five SoC a80bc27a0fe8 dt-bindings: reset: Add compatible and DT bindings for Amlogic C3 Reset Controller 0b8db84ecfc4 ASoC: Intel: Soundwire related board and match updates 303600aff1ef Merge v6.7-rc3 into drm-next d03f6dca688d arm64: dts: rockchip: Use NCM6A-IO board for edgeble-neu6b 2dcf7dbe2812 dt-bindings: arm: rockchip: Update edgeble-neu6 bindings b2a45d98f95b arm64: dts: rockchip: add USB3 host on rk3588s-orangepi-5 766aa3119c2f ARM: dts: motorola-mapphone: Add basic support for mz609 and mz617 3ea15a23d9c7 ARM: dts: motorola-mapphone: Move handset devices to a common file 5127524f7e6f ARM: dts: motorola-mapphone: Move LCD to common file for xt875 and xt894 7e16bd264a3a dt-bindings: omap: Add Motorola mapphone mz609 and mz617 tablets 7d420d843f98 ARM: dts: renesas: r9a06g032: Add missing space in compatible 0faa59be192f arm64: dts: renesas: r9a09g011: Add missing space in compatible 807cfe5cde5c dt-bindings: phy: add compatible for Mediatek MT8195 c52707b1bf77 dt-bindings: phy: amlogic,g12a-mipi-dphy-analog: drop unneeded reg property and example 34ec5dda2a01 dt-bindings: phy: amlogic,meson-axg-mipi-pcie-analog: drop text about parent syscon and drop example f738d7a9dfab dt-bindings: iommu: dart: Add t8103-usb4-dart compatible 2c963cfa7e8e ARM: dts: renesas: armadillo800eva: Add LCD panel a35135dad31c dt-bindings: pinctrl: renesas: Drop unneeded quotes d5212619f0a0 ARM: dts: renesas: r8a7740: Add LCDC nodes 048bdb67a0f6 arm64: dts: renesas: draak: Move HDMI bus properties to correct node ab52a67f9767 arm64: dts: renesas: draak: Make HDMI the default video input dab3ba03f28c Merge 6.7-rc3 into usb-next ec6cd76a8793 arm64: dts: meson-axg: jethub-jxx add support for EEPROM 2da076589eac arm64: dts: amlogic: meson-axg: pinctrl node for NAND cdc5df918882 arm64: dts: amlogic: minor whitespace cleanup around '=' a5dead35fc4b arm64: dts: Add watchdog node for Amlogic S4 SoCs 37c5369b4667 arm64: dts: Add watchdog node for Amlogic C3 SoCs 1d8b2a265b81 dt-bindings: soc: amlogic,meson-gx-hhi-sysctrl: add example covering meson-axg-hhi-sysctrl 9556e1708419 ARM: dts: imx7s: Add DMA channels for CSPI peripherals c1e5b6c6855f arm64: dts: imx8mp-venice-gw72xx: add TPM device fc1ee0050ce4 arm64: dts: imx8mm-venice-gw72xx: add TPM device 5a125bf20bf1 arm64: dts: imx93: update anatop node 292fc296ecdd arm64: dts: imx93-11x11-evk: add 12 ms delay to make sure the VDD_SD power off b81451d8d4d3 arm64: dts: imx93: change tuning start to get a large scan range for standard tuning 7ee940495143 arm64: dts: imx93-11x11-evk: set SION for cmd and data pad of USDHC 1b2037987962 arm64: dts: imx8mp: Describe M24C32-D write-lockable page in DH i.MX8MP DHCOM DT 94d5d7d36ba8 ARM: dts: imx6ul: mba6ulx: fix typo in comments cbbed6036bfe ARM: dts: imx6qdl: mba6: fix typo in comments e6c50d6fd99e arm64: dts: imx8mp-beacon-kit: Enable DSI to HDMI Bridge 3743277142d0 arm64: dts: imx8mm: Add CCM interrupts 663758efb819 arm64: dts: imx8mn: Add CCM interrupts 88774bafda13 arm64: dts: imx8mp: Add CCM interrupts e4d9f4208c6c ARM: dts: imx7s: Add missing #thermal-sensor-cells e4c3f040fee6 ARM: dts: imx7s: Fix nand-controller #size-cells 62a7c97c7c3f ARM: dts: imx7s: Fix lcdif compatible 9f3037b332bf ARM: dts: imx7d: Fix coresight funnel ports d844fe5270b1 arm64: dts: freescale: add initial device tree for MBa93xxCA starter kit ad161fbd54ca arm64: dts: freescale: tqma9352-mba93xxla: add 'chassis-type' property 8ec09c8f530c arm64: dts: imx93: Configure clock rate for audio PLL 9d7ba48273ea arm64: dts: imx93: Add audio device nodes b1553710809c dt-bindings: iio: hmc425a: add entry for ADRF5740 Attenuator 471ace1f09be dt-bindings: gpio: brcmstb: drop unneeded quotes f8159413e6f1 ARM: dts: ti: keystone: minor whitespace cleanup around '=' 381a63044158 dt-bindings: clock: g12a-clkc: add MIPI ISP & CSI PHY clock ids c1ad3e49f07c dt-bindings: clk: g12a-clkc: add CTS_ENCL clock ids c8fb56a76774 dt-bindings: dma: qcom,gpi: document the SM8650 GPI DMA Engine 8e868f10ea21 dt-bindings: dma: rz-dmac: Document RZ/Five SoC e1504d7602c0 dt-bindings: net: qcom,ipa: add SM8550 compatible f118e169a194 dt-bindings: dma: qcom: gpi: add compatible for X1E80100 11518ff4d13c dt-bindings: pinctrl: qcom: Add X1E80100 pinctrl d3fe1008f0c8 ASoC: dt-bindings: correct white-spaces in examples f9b11918132f dt-bindings: crypto: convert Inside Secure SafeXcel to the json-schema 52b8a84c5283 dt-bindings: dma: ti: k3-udma: Describe cfg register regions 9b2e4fa1e7f2 dt-bindings: dma: ti: k3-pktdma: Describe cfg register regions 6d91e2a3766b dt-bindings: dma: ti: k3-bcdma: Describe cfg register regions ea1d92699d2a dt-bindings: dma: ti: k3-*: Add descriptions for register regions 7cf45f021d31 arm64: dts: exynosautov9: use Exynos7 fallbacks for pin wake-up controller dc0e2a7e69c2 arm64: dts: exynos850: use Exynos7 fallbacks for pin wake-up controllers 185cc3e40c9f dt-bindings: pinctrl: samsung: use Exynos7 fallbacks for newer wake-up controllers 54829849af39 Merge branch 'icc-x1e80100' into icc-next 8e2202f335a4 dt-bindings: interconnect: Add Qualcomm X1E80100 SoC 54f1f68e019b dt-bindings: interconnect: qcom-bwmon: document SM8650 BWMONs 4e7bf80ce812 dt-bindings: interconnect: document the RPMh Network-On-Chip Interconnect in Qualcomm SM8650 SoC 615397ecb02b Merge git://git.kernel.org/pub/scm/linux/kernel/git/netdev/net e673bd9cbb13 dt-bindings: serial: fsl-linflexuart: change the maintainer email address f79b00fe4cab dt-bindings: serial: renesas,sci: Document RZ/Five SoC 911d5cce2a4e Merge tag 'drm-misc-next-2023-11-23' of git://anongit.freedesktop.org/drm/drm-misc into drm-next ab1f350663b1 dt-bindings: power: rpmpd: Update part number to X1E80100 6fe8e1a8dc99 dt-bindings: backlight: mp3309c: Remove two required properties cc4e22233cb5 dt-bindings: usb: qcom,dwc3: adjust number of interrupts on SM6125 9161184d7271 dt-bindings: net: renesas,ethertsn: Add Ethernet TSN 788d52642da4 Merge tag 'v6.7-rc2' into media_stage d2975fb00035 dt-bindings: gpu: Add Imagination Technologies PowerVR/IMG GPU 59078ccb21d1 dt-bindings: usb: qcom,dwc3: document the SM8560 SuperSpeed DWC3 USB controller 627316c016dd dt-bindings: usb: renesas,usbhs: Document RZ/Five SoC 99b07ecabc3d dt-bindings: cache: sifive,ccache0: Add StarFive JH7100 compatible 0118ff6d8abd ASoC: dt-bindings: fsl,mqs: Convert format to json-schema 0a9a12593184 ASoC: dt-bindings: sound-card-common: List sound widgets ignoring system suspend 165648aad162 ARM: dts: stm32: add SPI support on STM32F746 8f3fa20269a0 ARM: dts: stm32: add STM32F746 syscfg clock dc50601ba2d8 dt-bindings: net: xlnx,axi-ethernet: Introduce DMA support 72d23e1de1b0 arm64: dts: imx8mp: Add reserve-memory nodes for DSP 9bab315d31f8 spi: axi-spi-engine improvements 23a75f159231 ARM: dts: stm32: use the same 3v3 for SD and DSI nodes on stm32f469-disco 4656437906e9 ARM: dts: rockchip: Make usbphy the parent of SCLK_USB480M for RK3128 25251d661471 ARM: dts: rockchip: Add dwc2 otg fifo siztes for RK3128 2d36fa2aa286 ARM: dts: rockchip: Add USB host clocks for RK3128 4e1bd401bbe3 ARM: dts: rockchip: Add Geniatech XPI-3128 RK3128 board 7e6458d9a7f3 ARM: dts: rockchip: Add sdmmc_det pinctrl for RK3128 12867f1ccb42 dt-bindings: arm: rockchip: Add Geniatech XPI-3128 fda729bcbd69 arm64: dts: rockchip: Add Powkiddy RK2023 317a36f59e1b arm64: dts: rockchip: Update powkiddy,rgb30 include to rk2023 DTSI dc9a81379af6 dt-bindings: arm: rockchip: Add Powkiddy RK2023 70a31fd9ffa3 dt-bindings: spi: axi-spi-engine: convert to yaml b68504144dbe Merge tag 'drm-misc-next-2023-11-17' of git://anongit.freedesktop.org/drm/drm-misc into drm-next 8260e721d1b5 dt-bindings: display: nv3051d: Update NewVision NV3051D compatibles 0a502f9716cc arm64: dts: renesas: rzg3s-smarc: Enable SDHI1 eccf7ee1aefe arm64: dts: renesas: rzg3s-smarc-som: Enable SDHI2 fbd14cd9ff35 ARM: dts: microchip: sam9x60ek: Add IRQ support for ethernet PHY c86d9749ca2a ARM: dts: microchip: sam9x60_curiosity: Add IRQ support for ethernet PHY 1e1f6887a01b arm64: dts: allwinner: h616: add Orange Pi Zero 2W support 5795c68b5edc dt-bindings: arm: sunxi: add Orange Pi Zero 2W a5b7fa02fbde dt-bindings: crypto: qcom,prng: document SM8650 53be5450f8ac dt-bindings: crypto: qcom-qce: document the SM8650 crypto engine e65dc233e98b dt-bindings: crypto: qcom,inline-crypto-engine: document the SM8650 ICE d2a2bd80cca6 dt-bindings: net: renesas,etheravb: Document RZ/Five SoC f491b5315b58 dt-bindings: Document Marvell Aquantia PHY 7b52e889e53f arm64: dts: rockchip: add analog audio to RK3588 EVB1 92de4720f37c spi: dt-bindings: renesas,rspi: Document RZ/Five SoC 6e54c4bd7590 ASoC: dt-bindings: renesas,rz-ssi: Document RZ/Five SoC 87bb03481662 dt-bindings: adis16460: Add 'spi-cs-inactive-delay-ns' property 91e2c8ceb4de dt-bindings: adis16475: Add 'spi-cs-inactive-delay-ns' property f9fe5526efd5 dt-bindings: iio: Add MCP9600 thermocouple EMF converter 9942ece9d870 dt-bindings: iio: imu: Add Bosch BMI323 49d380d6e152 dt-bindings: adc: provide max34408/9 device tree binding document 895869158303 dt-bindings: media: wave5: add yaml devicetree bindings 77bf61c28407 dt-bindings: arm: Add support for DSB MSR register 18adf91da0ca dt-bindings: arm: Add support for DSB element size 075ac55ca93b dt-bindings: phy: qcom,snps-eusb2: document the SM8650 Synopsys eUSB2 PHY fda8409f7058 dt-bindings: phy: qcom,sc8280xp-qmp-usb43dp-phy: document the SM8650 QMP USB/DP Combo PHY b0b6815d9143 dt-bindings: phy: qcom,sc8280xp-qmp-pcie-phy: document the SM8650 QMP PCIe PHYs db24b834638a dt-bindings: phy: qcom,sc8280xp-qmp-ufs-phy: document the SM8650 QMP UFS PHY 6a737e056a8b media: dt-bindings: Add JH7110 Camera Subsystem 716cbea9d35a dt-bindings: power: reset: $ref reboot-mode in nvmem-reboot-mode c8dedfdf167b dt-bindings: power: reset: $ref reboot-mode in syscon-reboot-mode 6c14a95472bb ARM: dts: samsung: s5pv210: fix camera unit addresses/ranges 866767db6bbb ARM: dts: samsung: exynos4: fix camera unit addresses/ranges f0d3848e2cef ARM: dts: samsung: exynos4x12: replace duplicate pmu node with phandle dc6ff9889013 dt-bindings: w1: Add AMD AXI w1 host and MAINTAINERS entry a8a9188e96a6 dt-bindings: power: fsl,scu-pd: Document imx8dl f06b78172daa dt-bindings: qcom,pdc: Add compatible for SM8550 7a87643120eb dt-bindings: input: samsung,s6sy761: convert to DT schema e4ccdd770c53 Merge branch 'for-v6.8/samsung-bindings-compatibles' into next/dt64 7b213bd80e13 dt-bindings: hwinfo: samsung,exynos-chipid: add exynosautov920 compatible 892b87e000d2 dt-bindings: arm: samsung: Document exynosautov920 SADK board binding ce1b89aee7ea dt-bindings: pwm: samsung: add exynosautov920 compatible 5e6bd42714ad dt-bindings: serial: samsung: add exynosautov920-uart compatible 3ea12f0eff84 dt-bindings: samsung: usi: add exynosautov920-usi compatible 5b6e042a72b8 dt-bindings: samsung: exynos-pmu: add exynosautov920 compatible 2dff85192843 dt-bindings: samsung: exynos-sysreg: add exynosautov920 sysreg 3123103c12c0 dt-bindings: pinctrl: samsung: add exynosautov920 5b929ffdc9be arm64: dts: exynos: add gpio-key node for exynosautov9-sadk 6bc5effbe8dd arm64: dts: exynosautov9: add specific compatibles to several blocks 25addf827769 arm64: dts: exynos850: add specific compatibles to several blocks 5ab70c11f08f arm64: dts: exynos7885: add specific compatibles to several blocks f7c77a1ea95a arm64: dts: exynos7: add specific compatibles to several blocks 56493af64c01 arm64: dts: exynos5433: add specific compatibles to several blocks 3530786802b6 dt-bindings: pwm: samsung: add specific compatibles for existing SoC 97419692fe3c ASoC: dt-bindings: samsung-i2s: add specific compatibles for existing SoC 7081448ca2cf dt-bindings: iio: samsung,exynos-adc: add specific compatibles for existing SoC 973115e1f51f dt-bindings: gpu: arm,mali-midgard: add specific compatibles for existing Exynos SoC 6b99281097f0 dt-bindings: samsung: exynos-pmu: add specific compatibles for existing SoC a893a294345b dt-bindings: serial: samsung: add specific compatibles for existing SoC 2a3d0691d56f dt-bindings: rtc: s3c-rtc: add specific compatibles for existing SoC 7e49408d51e6 dt-bindings: pinctrl: samsung: add specific compatibles for existing SoC 1bb1eca74ad5 Merge drm/drm-next into drm-misc-next e9731895ee20 dt-bindings: mmc: samsung,exynos-dw-mshc: add specific compatibles for existing SoC 33b5aa8f7d9a ARM: dts: qcom: mdm9615: drop qcom, prefix from SSBI node name fa1f536e3df0 ARM: dts: qcom: ipq8064: drop qcom, prefix from SSBI node name 4e5382dc8820 ARM: dts: qcom: apq8060-dragonboard: rename mpp ADC channels to adc-channel 6be6ba7888ef ARM: dts: qcom: pm8921: Disable keypad by default 5917ae72cd70 ARM: dts: qcom: msm8974: move regulators to board files 551cbcd2547c ARM: dts: qcom: msm8960: drop useless rpm regulators node 6d9878cc6a6a ARM: dts: qcom: msm8660: move RPM regulators to board files d0ed11e33ba0 ARM: dts: qcom: mdm9615: move RPM regulators to board files 1c636116afea ARM: dts: qcom: apq8064: move RPM regulators to board files b9d11fecae9e ARM: dts: qcom: pm8058: switch to interrupts-extended e8a26b432fd4 ARM: dts: qcom: pm8018: switch to interrupts-extended 86831cb445f6 ARM: dts: qcom: pm8921: switch to interrupts-extended 6d6c0b95e077 ARM: dts: qcom: pm8058: use defined IRQ flags 9d0903209824 ARM: dts: qcom: pm8921: move reg property 6a63db48b660 ARM: dts: qcom: pm8018: move reg property 9d6af1dd4790 ARM: dts: qcom: pm8921: reorder nodes 5db5515193a6 ARM: dts: qcom: pm8058: reorder nodes d4df6f1babb5 ARM: dts: qcom: msm8660: split PMIC to separate dtsi files c56480ffb4b8 ARM: dts: qcom: mdm9615: split PMIC to separate dtsi files f8574d2c7c62 ARM: dts: qcom: apq8064: split PMICs to separate dtsi files 298695290d90 ARM: dts: qcom: msm8960: split PMIC to separate dtsi files 1c3c930ec46c ARM: dts: qcom: msm8960: move PMIC interrupts to the board files 7f5541db889f ARM: dts: qcom: msm8660: move PMIC interrupts to the board files 812cfe71b26a ARM: dts: qcom: mdm9615: move PMIC interrupts to the board files f5c8a18b7116 ARM: dts: qcom: apq8064: move PMIC interrupts to the board files b7510b8da2f6 ARM: dts: qcom: msm8960: fix PMIC node labels 6475671dcca1 ARM: dts: qcom: msm8660: fix PMIC node labels 4dfac4d841ef ARM: dts: qcom: mdm9615: fix PMIC node labels 07091c1b87fb ARM: dts: qcom: apq8064: fix PMIC node labels 155004433670 ARM: dts: qcom: strip prefix from PMIC files 21220b16b281 ARM: dts: qcom: mdm9615-wp8548-mangoh-green: group include clauses 3d3f8059a9f6 ARM: dts: qcom: apq8064-nexus7: move sdcc1 node to proper place b9d136b033b8 ARM: dts: qcom: msm8660-surf: use keypad label directly fc4f79da1abe ARM: dts: qcom: msm8960: introduce label for PMIC keypad 0e33f3448e7c ARM: dts: qcom: apq8064: correct XOADC register address 9bed8b24890a ARM: dts: qcom-sdx65: switch USB QMP PHY to new style of bindings edfbe32172f4 ARM: dts: qcom-sdx55: switch USB QMP PHY to new style of bindings c709366fb89e arm64: dts: qcom: sm8350: switch USB QMP PHY to new style of bindings 29a99a6d955d arm64: dts: qcom: sm8250: switch USB QMP PHY to new style of bindings e13f8dc0ea91 arm64: dts: qcom: sm8150: switch USB QMP PHY to new style of bindings bed6aed8ceec arm64: dts: qcom: sdm845: switch USB QMP PHY to new style of bindings 7cb8dff829b0 arm64: dts: qcom: msm8998: switch USB QMP PHY to new style of bindings 77a8ce42cb30 arm64: dts: qcom: msm8996: switch USB QMP PHY to new style of bindings b92a18870b3e arm64: dts: qcom: ipq8074: switch USB QMP PHY to new style of bindings 18dd153b1c8f arm64: dts: qcom: ipq6018: switch USB QMP PHY to new style of bindings ad3769d7933c Merge tag 'qcom-arm64-for-6.7-2' into arm64-for-6.8 8088e683c89b dt-bindings: i2c: samsung,s3c2410-i2c: add specific compatibles for existing SoC c15df41a0c35 dt-bindings: i2c: exynos5: add specific compatibles for existing SoC d755df63e9df dt-bindings: hwinfo: samsung,exynos-chipid: add specific compatibles for existing SoC 6f4cb3f40711 arm64: dts: renesas: rzg2lc-smarc-som: Enable 4-bit tx support 5ddba1791b2b arm64: dts: renesas: rzg2l-smarc-som: Enable 4-bit tx support 75b8e7f58abe regulator: add under-voltage support (part 2) 791f1550a798 Add DMIC slew rate controls e128625eb7cb dt-bindings: pinctrl: document the SM8650 Top Level Mode Multiplexer c3c85cc965c8 dt-bindings: pinctrl: qcom,sm8650-lpass-lpi-pinctrl: add SM8650 LPASS 6da3c9fd1509 ARM: dts: renesas: marzen: Rename keyboard nodes 2d7a77894ba8 ARM: dts: renesas: iwg22d-sodimm: Fix stmpe node names f4c62eb4fbd6 arm64: dts: renesas: Add missing ADV751[13] power supply properties a94c426db9b8 ARM: dts: renesas: Add missing ADV751[13] power supply properties f213adc3b192 ARM: dts: renesas: rcar-gen2: Fix I2C bus demux node names 127c56414e9f riscv: dts: renesas: Convert isa detection to new properties 9836c1c69324 ARM: dts: renesas: blanche: Add FLASH node d446795daa00 ARM: dts: renesas: marzen: Add FLASH node 9a4a8a78013a spi: add stm32f7-spi compatible e74e9793f9c7 regulator: dt-bindings: Add 'regulator-uv-less-critical-window-ms' property eafbf4f37d51 regulator: dt-bindings: Allow system-critical marking for fixed-regulator 52381ed5b4ac regulator: dt-bindings: Add system-critical-regulator property ec8f058714a6 dt-bindings: regulator: qcom,smd-rpm-regulator: Document PM8937 IC cf118cc80e89 dt-bindings: regulator: qcom,spmi-regulator: Document PM8937 PMIC 2ae471b5eeb2 ASoC: dt-bindings: use "soundwire" as controller's node name in examples caa17228e281 ASoC: dt-bindings: qcom,sm8250: add SM8550 sound card 2d2f997a2bdc dt-bindings: es8328: convert to DT schema format 68e113702391 ASoC: dt-bindings: Simplify port schema eac536a576c7 ASoC: dt-bindings: nau8821: Add DMIC slew rate. 409f501ee9b2 dt-bindings: gpu: v3d: Add BCM2712's compatible 22f7441e8685 dt-bindings: display: ssd132x: Remove '-' before compatible enum a3de98e60ec5 ARM: dts: qcom: add device tree for Nokia Lumia 830 9ad6bcd4499d ARM: dts: qcom: add device tree for Nokia Lumia 735 41ee9ea2aefd ARM: dts: qcom: add device tree for Microsoft Lumia 640 XL 0dc127c0d612 ARM: dts: qcom: add device tree for Microsoft Lumia 640 d30c995f440e ARM: dts: qcom: add common dt for MSM8x26 Lumias along with Nokia Lumia 630 ed92546211d5 dt-bindings: arm: qcom: Document MSM8x26-based Lumia phones d783936fa1dc arm64: dts: qcom: msm8939-longcheer-l9100: Enable RGB LED b14cb550d720 arm64: dts: qcom: msm8916-longcheer-l8910: Enable RGB LED 183a2f447424 arm64: dts: qcom: msm8939-samsung-a7: Add sound and modem 9b7d68606781 arm64: dts: qcom: msm8916-samsung-j5: Add sound and modem f382f197e0c5 arm64: dts: qcom: msm8916-samsung-gt5: Add sound and modem 59a815c1572d arm64: dts: qcom: msm8916-longcheer-l8910: Add sound and modem 582b4cfec9a9 ARM: dts: qcom: msm8226: provide dsi phy clocks to mmcc 1703230be2a6 ARM: dts: qcom: msm8974: sort nodes by reg e23f302820cb ARM: dts: qcom: msm8974: replace incorrect indentation in interconnect 373015625e6b arm64: dts: qcom: msm8916-longcheer-l8150: Add sound and modem c1a66861dc32 arm64: dts: qcom: msm8916-asus-z00l: Add sound and modem 489f91f0dfcc arm64: dts: qcom: msm8916-alcatel-idol347: Add sound and modem 2f81e02a3b04 arm64: dts: qcom: msm8916-wingtech-wt88047: Add sound and modem 07047876d71e arm64: dts: qcom: msm8916-samsung-serranove: Add sound and modem 1d94420f32b0 arm64: dts: qcom: msm8916-samsung-a2015: Add sound and modem 9334b10d351c arm64: dts: qcom: msm8916: Add common msm8916-modem-qdsp6.dtsi 30b857e0f639 arm64: dts: qcom: msm8939: Add QDSP6 5b210c47425a arm64: dts: qcom: msm8916: Add QDSP6 f1aed61c2c48 arm64: dts: qcom: msm8939: Add BAM-DMUX WWAN 702f57c12856 arm64: dts: qcom: sc8280xp-x13s: add missing camera LED pin config d21fc2d89cfd arm64: dts: qcom: pm7250b: Use correct node name for gpios ecc4cb08c0f3 arm64: dts: qcom: sc7280: Add Camera Control Interface busses c01ef95e3aa7 arm64: dts: qcom: sdm845-xiaomi-beryllium: enable flash led fe3ccb41dafa arm64: dts: qcom: sdm845-oneplus: enable flash LED 0f6538f89c64 arm64: dts: qcom: sc8280xp-x13s: Use the correct DP PHY compatible c9e8e85b1afd arm64: dts: qcom: msm8916-*: Fix alphabetic node order 9e38e840740d arm64: dts: qcom: msm8939-longcheer-l9100: Enable wcnss_mem 5cdb05e593ef arm64: dts: qcom: msm8916-samsung-gt5: Enable GPU 0d72dfbbf352 arm64: dts: qcom: ipq5332: include the GPLL0 as clock provider for mailbox 13c545bfe884 arm64: dts: qcom: ipq9574: include the GPLL0 as clock provider for mailbox 8b57686e7ad0 arm64: dts: qcom: ipq6018: include the GPLL0 as clock provider for mailbox 11d8f7a1bf44 arm64: dts: qcom: ipq8074: include the GPLL0 as clock provider for mailbox 9b0b036ea0de arm64: dts: qcom: ipq9574: populate the opp table based on the eFuse f3636ba1edce arm64: dts: qcom: ipq5332: populate the opp table based on the eFuse 8831b26a6579 arm64: dts: qcom: sdm670: add specific cpufreq compatible 8ce87f299cdb arm64: dts: qcom: sm8150: extend the size of the PDC resource b3cbe4ff9c30 arm64: dts: qcom: ipq5018: add QUP1 SPI controller f330c2991aa0 arm64: dts: qcom: qrb4210-rb2: don't force usb peripheral mode daa68cbafb06 arm64: dts: qcom: Enable tsens and thermal for sa8775p SoC 6232143457ae arm64: dts: qcom: sa8775p: Add RPMh sleep stats 973959c2edf1 arm64: dts: qcom: sc7280: Add ports subnodes in usb/dp qmpphy node 4c021a56b758 arm64: dts: qcom: sm6375-pdx225: Add USBPHY regulators 6fb033b4f60e arm64: dts: qcom: sm6375-pdx225: Enable ATH10K WiFi fa14ce25949b arm64: dts: qcom: sm6375-pdx225: Enable MSS e77ac5cceb8e arm64: dts: qcom: sm6375: Add UART1 dec2e7998de5 arm64: dts: qcom: ipq9574: Enable WPS buttons d3619641203e arm64: dts: qcom: ipq9574: Add common RDP dtsi file 9faa71835343 arm64: dts: qcom: ipq5018: Enable USB 71275274da1f arm64: dts: qcom: ipq5018: Add USB related nodes af8b25f21479 arm64: dts: qcom: sc7280: add TRNG node 00e1b06bb47a arm64: dts: qcom: sa8775p: add TRNG node ac7c5d2655a7 arm64: dts: qcom: sm8450: add TRNG node 0087dcd6513a arm64: dts: qcom: sm8550: add TRNG node
git-subtree-dir: dts/upstream git-subtree-split: b35b9bd1d4eed2acf8bc38ec5b1b6eef6261b4f0
Cc: Apurva Nandan a-nandan@ti.com Cc: Beniamino Galvani b.galvani@gmail.com Cc: Bryan Brattlof bb@ti.com Cc: Neil Armstrong neil.armstrong@linaro.org Cc: Tim Harvey tharvey@gateworks.com Cc: Vignesh Raghavendra vigneshr@ti.com Cc: u-boot-amlogic@groups.io
This commit moves OF_UPSTREAM platforms to the v6.8-dts tag. The patch itself isn't directly testable I think, and too huge to email regardless. The tree exists at: https://github.com/trini/u-boot/tree/WIP/29Mar2024-next and will for at least a few days before I merge this, if anyone wants to run-time test the changes. I'm still doing a world build before/after to see if any changes are visible that way. The CC list here was made by using "tools/qconfig.py -b" and then "tools/qconfig.py -f OF_UPSTREAM" and get_maintainer.pl on the defconfigs for the platforms that listed. If I'm missing maintainers of platforms using OF_UPSTREAM, I'm open to ideas on what to do next go-round.
Bindings/Makefile | 5 +- Bindings/arm/calxeda/l2ecc.yaml | 2 +- Bindings/arm/cpus.yaml | 1 + Bindings/arm/fsl.yaml | 22 +- Bindings/arm/google.yaml | 53 + .../arm/hisilicon/controller/sysctrl.yaml | 17 + Bindings/arm/marvell/armada-7k-8k.yaml | 22 + Bindings/arm/mediatek.yaml | 25 + Bindings/arm/mediatek/mediatek,audsys.txt | 39 - Bindings/arm/mediatek/mediatek,audsys.yaml | 153 + Bindings/arm/mediatek/mediatek,ethsys.txt | 29 - Bindings/arm/mediatek/mediatek,infracfg.yaml | 1 + Bindings/arm/mediatek/mediatek,mmsys.yaml | 3 + Bindings/arm/mediatek/mediatek,pericfg.yaml | 1 + Bindings/arm/msm/qcom,idle-state.txt | 84 - Bindings/arm/qcom,coresight-remote-etm.yaml | 51 + Bindings/arm/qcom,coresight-tpdm.yaml | 20 + Bindings/arm/qcom-soc.yaml | 16 +- Bindings/arm/qcom.yaml | 47 +- Bindings/arm/rockchip.yaml | 56 +- Bindings/arm/samsung/samsung-boards.yaml | 6 + Bindings/arm/sprd/sprd.yaml | 5 + Bindings/arm/stm32/stm32.yaml | 16 +- Bindings/arm/sunxi.yaml | 10 + Bindings/arm/ti/k3.yaml | 2 + Bindings/arm/ti/omap.yaml | 2 + Bindings/ata/ceva,ahci-1v84.yaml | 3 +- Bindings/auxdisplay/hit,hd44780.yaml | 2 +- Bindings/cache/qcom,llcc.yaml | 5 +- Bindings/cache/sifive,ccache0.yaml | 6 +- Bindings/clock/baikal,bt1-ccu-pll.yaml | 2 +- Bindings/clock/brcm,kona-ccu.txt | 138 - Bindings/clock/brcm,kona-ccu.yaml | 181 + Bindings/clock/fsl,imx93-anatop.yaml | 42 + Bindings/clock/google,gs101-clock.yaml | 106 + Bindings/clock/hi3620-clock.txt | 20 - Bindings/clock/mediatek,apmixedsys.yaml | 1 + Bindings/clock/mediatek,ethsys.yaml | 55 + Bindings/clock/mediatek,mt7988-ethwarp.yaml | 52 + Bindings/clock/mediatek,mt7988-xfi-pll.yaml | 48 + Bindings/clock/mediatek,mt8188-clock.yaml | 2 - Bindings/clock/mediatek,topckgen.yaml | 2 + Bindings/clock/qcom,a53pll.yaml | 1 + Bindings/clock/qcom,camcc-sm8250.yaml | 18 +- Bindings/clock/qcom,gcc-ipq6018.yaml | 57 + Bindings/clock/qcom,gcc-ipq8074.yaml | 4 + Bindings/clock/qcom,gcc-other.yaml | 3 - Bindings/clock/qcom,qdu1000-ecpricc.yaml | 68 + Bindings/clock/qcom,rpmhcc.yaml | 2 + Bindings/clock/qcom,sc7180-camcc.yaml | 18 +- Bindings/clock/qcom,sc7280-camcc.yaml | 18 +- Bindings/clock/qcom,sdm845-camcc.yaml | 18 +- Bindings/clock/qcom,sm8450-camcc.yaml | 20 +- Bindings/clock/qcom,sm8450-gpucc.yaml | 2 + Bindings/clock/qcom,sm8550-tcsr.yaml | 8 +- Bindings/clock/qcom,sm8650-dispcc.yaml | 106 + Bindings/clock/qcom,sm8650-gcc.yaml | 65 + Bindings/clock/qcom,x1e80100-gcc.yaml | 72 + Bindings/clock/renesas,9series.yaml | 10 + Bindings/clock/silabs,si5351.txt | 126 - Bindings/clock/silabs,si5351.yaml | 265 + Bindings/clock/sophgo,cv1800-clk.yaml | 46 + Bindings/clock/st,stm32mp25-rcc.yaml | 76 + Bindings/clock/xlnx,clocking-wizard.yaml | 1 + Bindings/clock/xlnx,versal-clk.yaml | 31 +- Bindings/connector/usb-connector.yaml | 124 +- Bindings/cpu/idle-states.yaml | 81 +- Bindings/crypto/inside-secure,safexcel.yaml | 86 + Bindings/crypto/inside-secure-safexcel.txt | 40 - .../crypto/qcom,inline-crypto-engine.yaml | 1 + Bindings/crypto/qcom,prng.yaml | 1 + Bindings/crypto/qcom-qce.yaml | 14 + Bindings/display/bridge/lontium,lt8912b.yaml | 21 + Bindings/display/bridge/nxp,tda998x.yaml | 7 +- Bindings/display/mediatek/mediatek,aal.yaml | 1 + Bindings/display/mediatek/mediatek,color.yaml | 1 + Bindings/display/mediatek/mediatek,dsi.yaml | 4 + Bindings/display/mediatek/mediatek,ethdr.yaml | 6 +- .../display/mediatek/mediatek,mdp-rdma.yaml | 88 - Bindings/display/mediatek/mediatek,merge.yaml | 4 + Bindings/display/mediatek/mediatek,ovl.yaml | 1 + .../display/mediatek/mediatek,padding.yaml | 83 + Bindings/display/mediatek/mediatek,split.yaml | 27 + Bindings/display/msm/dp-controller.yaml | 2 + Bindings/display/msm/dsi-controller-main.yaml | 3 + Bindings/display/msm/dsi-phy-7nm.yaml | 1 + Bindings/display/msm/mdss-common.yaml | 18 +- Bindings/display/msm/qcom,qcm2290-mdss.yaml | 21 +- Bindings/display/msm/qcom,sc7180-mdss.yaml | 14 +- Bindings/display/msm/qcom,sc7280-mdss.yaml | 14 +- Bindings/display/msm/qcom,sdm670-mdss.yaml | 292 + Bindings/display/msm/qcom,sdm845-dpu.yaml | 4 +- Bindings/display/msm/qcom,sm6115-mdss.yaml | 10 + Bindings/display/msm/qcom,sm6125-mdss.yaml | 8 +- Bindings/display/msm/qcom,sm6350-mdss.yaml | 8 +- Bindings/display/msm/qcom,sm6375-mdss.yaml | 8 +- Bindings/display/msm/qcom,sm8150-mdss.yaml | 6 +- Bindings/display/msm/qcom,sm8250-mdss.yaml | 10 + Bindings/display/msm/qcom,sm8450-mdss.yaml | 13 +- Bindings/display/msm/qcom,sm8650-dpu.yaml | 127 + Bindings/display/msm/qcom,sm8650-mdss.yaml | 328 + .../display/panel/fascontek,fs035vg158.yaml | 56 + Bindings/display/panel/himax,hx8394.yaml | 3 + Bindings/display/panel/ilitek,ili9805.yaml | 62 + Bindings/display/panel/ilitek,ili9881c.yaml | 1 + .../display/panel/leadtek,ltk035c5444t.yaml | 8 +- Bindings/display/panel/newvision,nv3051d.yaml | 2 +- .../panel/panel-simple-lvds-dual-ports.yaml | 2 + Bindings/display/panel/panel-simple.yaml | 4 + Bindings/display/panel/sitronix,st7701.yaml | 1 + Bindings/display/panel/synaptics,r63353.yaml | 61 + .../display/rockchip/inno_hdmi-rockchip.txt | 49 - .../display/rockchip/rockchip,inno-hdmi.yaml | 139 + Bindings/display/rockchip/rockchip-vop2.yaml | 100 +- .../display/samsung/samsung,exynos-mixer.yaml | 6 +- Bindings/display/ti/ti,am65x-dss.yaml | 14 + Bindings/dma/dma-controller.yaml | 15 - Bindings/dma/dma-router.yaml | 11 - Bindings/dma/loongson,ls2x-apbdma.yaml | 62 + Bindings/dma/nvidia,tegra210-adma.yaml | 3 + Bindings/dma/qcom,gpi.yaml | 2 + Bindings/dma/renesas,rz-dmac.yaml | 2 +- Bindings/dma/sifive,fu540-c000-pdma.yaml | 1 + Bindings/dma/ti/k3-bcdma.yaml | 39 +- Bindings/dma/ti/k3-pktdma.yaml | 26 +- Bindings/dma/ti/k3-udma.yaml | 20 +- Bindings/dts-coding-style.rst | 196 + Bindings/eeprom/at24.yaml | 1 + Bindings/firmware/qcom,scm.yaml | 18 +- .../firmware/xilinx/xlnx,zynqmp-firmware.yaml | 4 +- Bindings/fpga/altera-fpga2sdram-bridge.txt | 13 - Bindings/fpga/altera-freeze-bridge.txt | 20 - Bindings/fpga/altera-hps2fpga-bridge.txt | 36 - .../fpga/altr,freeze-bridge-controller.yaml | 41 + .../fpga/altr,socfpga-fpga2sdram-bridge.yaml | 33 + .../fpga/altr,socfpga-hps2fpga-bridge.yaml | 49 + Bindings/fpga/fpga-bridge.txt | 13 - Bindings/fpga/fpga-bridge.yaml | 30 + Bindings/fpga/xlnx,pr-decoupler.yaml | 5 +- Bindings/gnss/u-blox,neo-6m.yaml | 6 + Bindings/gpio/brcm,brcmstb-gpio.yaml | 2 +- Bindings/gpio/nuvoton,sgpio.yaml | 87 + Bindings/gpio/realtek,rtd-gpio.yaml | 69 + Bindings/gpio/rockchip,gpio-bank.yaml | 7 + Bindings/gpio/snps,dw-apb-gpio.yaml | 2 + Bindings/gpio/xlnx,gpio-xilinx.yaml | 2 +- Bindings/gpio/xlnx,zynqmp-gpio-modepin.yaml | 6 +- Bindings/gpu/arm,mali-midgard.yaml | 5 + Bindings/gpu/arm,mali-utgard.yaml | 1 + Bindings/gpu/brcm,bcm-v3d.yaml | 1 + Bindings/gpu/img,powervr.yaml | 73 + Bindings/gpu/samsung-g2d.yaml | 71 +- Bindings/gpu/samsung-rotator.yaml | 9 +- Bindings/gpu/samsung-scaler.yaml | 81 +- Bindings/hwinfo/samsung,exynos-chipid.yaml | 18 +- Bindings/hwmon/gpio-fan.txt | 41 - Bindings/hwmon/gpio-fan.yaml | 60 + Bindings/hwmon/iio-hwmon.yaml | 2 +- Bindings/hwmon/lltc,ltc4286.yaml | 50 + Bindings/hwmon/lm75.yaml | 33 + Bindings/i2c/i2c-exynos5.yaml | 11 +- Bindings/i2c/samsung,s3c2410-i2c.yaml | 22 +- Bindings/i2c/st,stm32-i2c.yaml | 28 + Bindings/iio/adc/adi,ad7091r5.yaml | 82 +- Bindings/iio/adc/adi,ad7780.yaml | 6 +- Bindings/iio/adc/maxim,max34408.yaml | 139 + Bindings/iio/adc/qcom,spmi-iadc.yaml | 10 +- Bindings/iio/adc/qcom,spmi-rradc.yaml | 4 +- Bindings/iio/adc/qcom,spmi-vadc.yaml | 9 +- Bindings/iio/adc/samsung,exynos-adc.yaml | 29 +- Bindings/iio/adc/ti,palmas-gpadc.yaml | 15 - Bindings/iio/amplifiers/adi,hmc425a.yaml | 4 + Bindings/iio/chemical/aosong,ags02ma.yaml | 47 + Bindings/iio/dac/adi,ad5791.yaml | 5 + Bindings/iio/dac/microchip,mcp4821.yaml | 86 + Bindings/iio/humidity/ti,hdc3020.yaml | 55 + Bindings/iio/imu/adi,adis16460.yaml | 4 + Bindings/iio/imu/adi,adis16475.yaml | 4 + Bindings/iio/imu/bosch,bmi323.yaml | 77 + Bindings/iio/light/liteon,ltr390.yaml | 56 + Bindings/iio/light/vishay,veml6075.yaml | 39 + Bindings/iio/pressure/honeywell,hsc030pa.yaml | 142 + .../iio/pressure/honeywell,mprls0025pa.yaml | 2 - .../iio/temperature/melexis,mlx90632.yaml | 19 +- .../iio/temperature/microchip,mcp9600.yaml | 70 + Bindings/index.rst | 1 + Bindings/input/adafruit,seesaw-gamepad.yaml | 63 + Bindings/input/elan,ekth6915.yaml | 5 +- Bindings/input/gpio-keys.yaml | 41 +- Bindings/input/gpio-mouse.txt | 32 - Bindings/input/gpio-mouse.yaml | 68 + Bindings/input/iqs269a.yaml | 98 +- Bindings/input/mediatek,pmic-keys.yaml | 24 +- Bindings/input/microchip,cap11xx.yaml | 80 +- Bindings/input/sprd,sc27xx-vibrator.yaml | 19 +- Bindings/input/ti,drv2665.txt | 17 - Bindings/input/ti,drv2667.txt | 17 - Bindings/input/ti,drv266x.yaml | 50 + .../input/touchscreen/neonode,zforce.yaml | 72 + .../input/touchscreen/samsung,s6sy761.txt | 32 - .../input/touchscreen/samsung,s6sy761.yaml | 54 + Bindings/input/touchscreen/zforce_ts.txt | 34 - Bindings/interconnect/qcom,msm8998-bwmon.yaml | 4 + Bindings/interconnect/qcom,sm6115.yaml | 152 + Bindings/interconnect/qcom,sm8650-rpmh.yaml | 136 + Bindings/interconnect/qcom,x1e80100-rpmh.yaml | 83 + .../loongson,liointc.yaml | 18 +- Bindings/interrupt-controller/qcom,mpm.yaml | 54 +- Bindings/interrupt-controller/qcom,pdc.yaml | 4 + .../renesas,rzg2l-irqc.yaml | 5 +- .../sifive,plic-1.0.0.yaml | 1 + .../st,stih407-irq-syscfg.yaml | 4 +- Bindings/iommu/apple,dart.yaml | 1 + Bindings/iommu/arm,smmu.yaml | 77 +- Bindings/iommu/rockchip,iommu.yaml | 11 +- Bindings/leds/allwinner,sun50i-a100-ledc.yaml | 137 + Bindings/leds/awinic,aw200xx.yaml | 95 +- Bindings/leds/backlight/mps,mp3309c.yaml | 10 +- Bindings/leds/common.yaml | 2 +- Bindings/leds/qcom,spmi-flash-led.yaml | 4 +- Bindings/loongarch/cpus.yaml | 61 + Bindings/loongarch/loongson.yaml | 34 + Bindings/mailbox/qcom,apcs-kpss-global.yaml | 62 +- Bindings/mailbox/qcom-ipcc.yaml | 1 + Bindings/mailbox/xlnx,zynqmp-ipi-mailbox.yaml | 132 +- Bindings/media/cnm,wave521c.yaml | 61 + .../media/i2c/alliedvision,alvium-csi2.yaml | 81 + Bindings/media/i2c/asahi-kasei,ak7375.yaml | 4 +- Bindings/media/i2c/galaxycore,gc0308.yaml | 108 + Bindings/media/i2c/galaxycore,gc2145.yaml | 113 + Bindings/media/i2c/ov8856.yaml | 24 +- Bindings/media/i2c/ovti,ov64a40.yaml | 103 + Bindings/media/i2c/sony,imx335.yaml | 13 + Bindings/media/i2c/techwell,tw9900.yaml | 137 + Bindings/media/i2c/thine,thp7312.yaml | 224 + Bindings/media/mediatek,mdp3-fg.yaml | 61 + Bindings/media/mediatek,mdp3-hdr.yaml | 61 + Bindings/media/mediatek,mdp3-rdma.yaml | 104 +- Bindings/media/mediatek,mdp3-rsz.yaml | 6 +- Bindings/media/mediatek,mdp3-stitch.yaml | 61 + Bindings/media/mediatek,mdp3-tcc.yaml | 62 + Bindings/media/mediatek,mdp3-tdshp.yaml | 61 + Bindings/media/mediatek,mdp3-wrot.yaml | 29 +- Bindings/media/rockchip-isp1.yaml | 11 +- Bindings/media/samsung,s5p-mfc.yaml | 47 +- Bindings/media/st,stm32-dcmipp.yaml | 89 + Bindings/media/starfive,jh7110-camss.yaml | 180 + Bindings/mfd/ams,as3711.yaml | 223 + Bindings/mfd/as3711.txt | 73 - Bindings/mfd/hisilicon,hi6421-spmi-pmic.yaml | 140 +- Bindings/mfd/qcom,pm8008.yaml | 6 +- Bindings/mfd/qcom,spmi-pmic.yaml | 7 + Bindings/mfd/qcom,tcsr.yaml | 2 + Bindings/mfd/samsung,exynos5433-lpass.yaml | 2 +- Bindings/mfd/sprd,ums512-glbreg.yaml | 4 +- Bindings/mfd/ti,am3359-tscadc.yaml | 2 - Bindings/misc/fsl,dpaa2-console.yaml | 2 +- Bindings/mmc/arasan,sdhci.yaml | 8 +- Bindings/mmc/arm,pl18x.yaml | 2 +- Bindings/mmc/brcm,sdhci-brcmstb.yaml | 4 +- Bindings/mmc/marvell,xenon-sdhci.yaml | 4 +- Bindings/mmc/mtk-sd.yaml | 9 + Bindings/mmc/renesas,sdhi.yaml | 2 +- Bindings/mmc/samsung,exynos-dw-mshc.yaml | 25 +- Bindings/mmc/sdhci-msm.yaml | 2 + Bindings/mmc/sdhci-pxa.yaml | 4 +- Bindings/mmc/snps,dwcmshc-sdhci.yaml | 1 + Bindings/mmc/synopsys-dw-mshc.yaml | 4 + Bindings/mtd/partitions/u-boot.yaml | 2 +- Bindings/net/dsa/dsa.yaml | 6 + Bindings/net/dsa/marvell,mv88e6060.yaml | 88 + Bindings/net/dsa/marvell,mv88e6xxx.yaml | 337 + Bindings/net/dsa/marvell.txt | 109 - Bindings/net/dsa/microchip,ksz.yaml | 34 +- Bindings/net/ethernet-switch.yaml | 23 +- Bindings/net/lantiq,pef2256.yaml | 213 + Bindings/net/marvell,aquantia.yaml | 116 + Bindings/net/marvell,mvusb.yaml | 7 +- Bindings/net/marvell,orion-mdio.yaml | 22 - Bindings/net/marvell,prestera.yaml | 4 +- Bindings/net/pcs/mediatek,sgmiisys.yaml | 65 +- Bindings/net/qcom,ipa.yaml | 24 +- Bindings/net/renesas,etheravb.yaml | 3 +- Bindings/net/renesas,ethertsn.yaml | 135 + Bindings/net/sff,sfp.yaml | 2 +- Bindings/net/xlnx,axi-ethernet.yaml | 16 + Bindings/nvmem/st,stm32-romem.yaml | 1 + Bindings/pci/brcm,stb-pcie.yaml | 18 + Bindings/pci/qcom,pcie.yaml | 63 +- Bindings/pci/rcar-pci-host.yaml | 11 + Bindings/pci/rockchip-dw-pcie.yaml | 2 + Bindings/pci/ti,j721e-pci-ep.yaml | 39 +- Bindings/pci/ti,j721e-pci-host.yaml | 39 +- Bindings/pci/toshiba,visconti-pcie.yaml | 2 +- Bindings/perf/fsl-imx-ddr.yaml | 3 + .../phy/amlogic,g12a-mipi-dphy-analog.yaml | 12 - .../amlogic,meson-axg-mipi-pcie-analog.yaml | 17 - Bindings/phy/mediatek,dsi-phy.yaml | 1 + Bindings/phy/mediatek,tphy.yaml | 9 + Bindings/phy/qcom,sc8280xp-qmp-pcie-phy.yaml | 5 + Bindings/phy/qcom,sc8280xp-qmp-ufs-phy.yaml | 2 + .../phy/qcom,sc8280xp-qmp-usb3-uni-phy.yaml | 3 + .../phy/qcom,sc8280xp-qmp-usb43dp-phy.yaml | 8 +- Bindings/phy/qcom,snps-eusb2-phy.yaml | 2 + Bindings/pinctrl/pinctrl-single.yaml | 1 + Bindings/pinctrl/qcom,ipq5018-tlmm.yaml | 12 +- Bindings/pinctrl/qcom,ipq5332-tlmm.yaml | 9 +- Bindings/pinctrl/qcom,ipq6018-pinctrl.yaml | 8 +- Bindings/pinctrl/qcom,ipq8074-pinctrl.yaml | 9 +- Bindings/pinctrl/qcom,ipq9574-tlmm.yaml | 9 +- Bindings/pinctrl/qcom,lpass-lpi-common.yaml | 75 + Bindings/pinctrl/qcom,mdm9607-tlmm.yaml | 18 +- Bindings/pinctrl/qcom,mdm9615-pinctrl.yaml | 18 +- Bindings/pinctrl/qcom,msm8226-pinctrl.yaml | 8 +- Bindings/pinctrl/qcom,msm8660-pinctrl.yaml | 9 +- Bindings/pinctrl/qcom,msm8909-tlmm.yaml | 18 +- Bindings/pinctrl/qcom,msm8916-pinctrl.yaml | 9 +- Bindings/pinctrl/qcom,msm8953-pinctrl.yaml | 7 +- Bindings/pinctrl/qcom,msm8960-pinctrl.yaml | 9 +- Bindings/pinctrl/qcom,msm8974-pinctrl.yaml | 9 +- Bindings/pinctrl/qcom,msm8976-pinctrl.yaml | 9 +- Bindings/pinctrl/qcom,msm8994-pinctrl.yaml | 9 +- Bindings/pinctrl/qcom,msm8996-pinctrl.yaml | 9 +- Bindings/pinctrl/qcom,msm8998-pinctrl.yaml | 9 +- Bindings/pinctrl/qcom,pmic-mpp.yaml | 62 +- Bindings/pinctrl/qcom,qcm2290-tlmm.yaml | 9 +- Bindings/pinctrl/qcom,qcs404-pinctrl.yaml | 9 +- Bindings/pinctrl/qcom,qdu1000-tlmm.yaml | 12 +- Bindings/pinctrl/qcom,sa8775p-tlmm.yaml | 21 +- Bindings/pinctrl/qcom,sc7180-pinctrl.yaml | 9 +- .../qcom,sc7280-lpass-lpi-pinctrl.yaml | 49 +- Bindings/pinctrl/qcom,sc7280-pinctrl.yaml | 30 +- Bindings/pinctrl/qcom,sc8180x-tlmm.yaml | 20 +- .../qcom,sc8280xp-lpass-lpi-pinctrl.yaml | 49 +- Bindings/pinctrl/qcom,sc8280xp-tlmm.yaml | 18 +- Bindings/pinctrl/qcom,sdm630-pinctrl.yaml | 10 +- Bindings/pinctrl/qcom,sdm670-tlmm.yaml | 19 +- Bindings/pinctrl/qcom,sdm845-pinctrl.yaml | 10 +- Bindings/pinctrl/qcom,sdx55-pinctrl.yaml | 8 +- Bindings/pinctrl/qcom,sdx65-tlmm.yaml | 8 +- Bindings/pinctrl/qcom,sdx75-tlmm.yaml | 12 +- Bindings/pinctrl/qcom,sm4450-tlmm.yaml | 151 + .../qcom,sm6115-lpass-lpi-pinctrl.yaml | 48 +- Bindings/pinctrl/qcom,sm6115-tlmm.yaml | 8 +- Bindings/pinctrl/qcom,sm6125-tlmm.yaml | 20 +- Bindings/pinctrl/qcom,sm6350-tlmm.yaml | 20 +- Bindings/pinctrl/qcom,sm6375-tlmm.yaml | 18 +- Bindings/pinctrl/qcom,sm7150-tlmm.yaml | 9 +- Bindings/pinctrl/qcom,sm8150-pinctrl.yaml | 9 +- .../qcom,sm8250-lpass-lpi-pinctrl.yaml | 49 +- Bindings/pinctrl/qcom,sm8250-pinctrl.yaml | 9 +- .../qcom,sm8350-lpass-lpi-pinctrl.yaml | 49 +- Bindings/pinctrl/qcom,sm8350-tlmm.yaml | 20 +- .../qcom,sm8450-lpass-lpi-pinctrl.yaml | 49 +- Bindings/pinctrl/qcom,sm8450-tlmm.yaml | 20 +- .../qcom,sm8550-lpass-lpi-pinctrl.yaml | 55 +- Bindings/pinctrl/qcom,sm8550-tlmm.yaml | 12 +- .../qcom,sm8650-lpass-lpi-pinctrl.yaml | 107 + Bindings/pinctrl/qcom,sm8650-tlmm.yaml | 141 + Bindings/pinctrl/qcom,x1e80100-tlmm.yaml | 137 + Bindings/pinctrl/renesas,rza2-pinctrl.yaml | 2 +- Bindings/pinctrl/renesas,rzg2l-pinctrl.yaml | 6 +- .../samsung,pinctrl-wakeup-interrupt.yaml | 45 +- Bindings/pinctrl/samsung,pinctrl.yaml | 5 +- Bindings/pinctrl/xlnx,zynq-pinctrl.yaml | 2 +- Bindings/pinctrl/xlnx,zynqmp-pinctrl.yaml | 2 +- Bindings/power/fsl,scu-pd.yaml | 1 + Bindings/power/qcom,rpmpd.yaml | 2 +- Bindings/power/reset/nvmem-reboot-mode.yaml | 8 +- Bindings/power/reset/qcom,pon.yaml | 13 +- Bindings/power/reset/syscon-reboot-mode.yaml | 8 +- Bindings/power/reset/xlnx,zynqmp-power.yaml | 4 +- Bindings/power/supply/bq24190.yaml | 1 + Bindings/power/supply/richtek,rt9455.yaml | 8 +- Bindings/power/wakeup-source.txt | 18 +- Bindings/pwm/mediatek,pwm-disp.yaml | 1 - Bindings/pwm/pwm-omap-dmtimer.txt | 22 - Bindings/pwm/pwm-samsung.yaml | 4 + Bindings/pwm/ti,omap-dmtimer-pwm.yaml | 59 + Bindings/regulator/fixed-regulator.yaml | 2 + Bindings/regulator/mps,mp5416.yaml | 4 +- Bindings/regulator/mps,mpq7920.yaml | 4 +- Bindings/regulator/qcom,rpmh-regulator.yaml | 14 + .../regulator/qcom,smd-rpm-regulator.yaml | 4 + Bindings/regulator/qcom,spmi-regulator.yaml | 19 + .../regulator/qcom,usb-vbus-regulator.yaml | 5 +- Bindings/regulator/regulator.yaml | 13 + Bindings/remoteproc/fsl,imx-rproc.yaml | 8 +- Bindings/remoteproc/qcom,sc7180-pas.yaml | 21 + Bindings/reset/amlogic,meson-reset.yaml | 1 + Bindings/reset/fsl,imx-src.yaml | 31 +- Bindings/reset/hisilicon,hi3660-reset.yaml | 25 +- Bindings/reset/qcom,aoss-reset.yaml | 10 +- Bindings/reset/qcom,pdc-global.yaml | 8 +- Bindings/reset/renesas,rzg2l-usbphy-ctrl.yaml | 2 +- Bindings/reset/xlnx,zynqmp-reset.yaml | 3 +- Bindings/riscv/cpus.yaml | 10 +- Bindings/riscv/extensions.yaml | 221 +- Bindings/riscv/sophgo.yaml | 4 + Bindings/rng/starfive,jh7110-trng.yaml | 6 +- Bindings/rtc/adi,max31335.yaml | 70 + Bindings/rtc/epson,rx8900.yaml | 2 + Bindings/rtc/nuvoton,ma35d1-rtc.yaml | 48 + Bindings/rtc/qcom-pm8xxx-rtc.yaml | 36 +- Bindings/rtc/s3c-rtc.yaml | 5 + Bindings/security/tpm/google,cr50.txt | 19 - Bindings/security/tpm/ibmvtpm.txt | 41 - Bindings/security/tpm/st33zp24-i2c.txt | 34 - Bindings/security/tpm/st33zp24-spi.txt | 32 - Bindings/security/tpm/tpm-i2c.txt | 26 - Bindings/security/tpm/tpm_tis_mmio.txt | 25 - Bindings/security/tpm/tpm_tis_spi.txt | 23 - Bindings/serial/arm,dcc.yaml | 30 + Bindings/serial/fsl,s32-linflexuart.yaml | 2 +- Bindings/serial/fsl-imx-uart.yaml | 29 +- Bindings/serial/qcom,msm-uartdm.yaml | 13 + Bindings/serial/renesas,sci.yaml | 2 +- Bindings/serial/samsung_uart.yaml | 28 +- Bindings/serial/snps-dw-apb-uart.yaml | 1 + Bindings/serial/sprd-uart.yaml | 1 + .../amlogic/amlogic,meson-gx-hhi-sysctrl.yaml | 33 + Bindings/soc/mediatek/mediatek,pwrap.yaml | 6 +- Bindings/soc/mediatek/mtk-svs.yaml | 2 + .../microchip,mpfs-sys-controller.yaml | 10 + Bindings/soc/qcom/qcom,aoss-qmp.yaml | 2 + Bindings/soc/qcom/qcom,pmic-glink.yaml | 22 +- Bindings/soc/qcom/qcom-stats.yaml | 14 + Bindings/soc/rockchip/grf.yaml | 2 + Bindings/soc/samsung/exynos-pmu.yaml | 10 + Bindings/soc/samsung/exynos-usi.yaml | 7 +- .../soc/samsung/samsung,exynos-sysreg.yaml | 5 + Bindings/{arm => soc/xilinx}/xilinx.yaml | 7 +- Bindings/sound/adi,max98363.yaml | 2 +- Bindings/sound/allwinner,sun4i-a10-spdif.yaml | 5 +- Bindings/sound/audio-graph-port.yaml | 6 + Bindings/sound/es8328.txt | 38 - Bindings/sound/everest,es8328.yaml | 77 + Bindings/sound/fsl,mqs.txt | 36 - Bindings/sound/fsl,mqs.yaml | 105 + Bindings/sound/fsl,xcvr.yaml | 22 +- Bindings/sound/google,sc7280-herobrine.yaml | 1 - Bindings/sound/mediatek,mt2701-audio.yaml | 116 + Bindings/sound/mediatek,mt8188-mt6359.yaml | 1 + Bindings/sound/mt2701-afe-pcm.txt | 146 - Bindings/sound/nuvoton,nau8821.yaml | 9 + .../sound/nvidia,tegra-audio-max9808x.yaml | 2 +- Bindings/sound/qcom,lpass-rx-macro.yaml | 23 +- Bindings/sound/qcom,lpass-tx-macro.yaml | 25 +- Bindings/sound/qcom,lpass-va-macro.yaml | 18 +- Bindings/sound/qcom,lpass-wsa-macro.yaml | 23 +- Bindings/sound/qcom,sm8250.yaml | 6 + Bindings/sound/qcom,wcd934x.yaml | 4 +- Bindings/sound/qcom,wcd938x-sdw.yaml | 4 +- Bindings/sound/qcom,wcd938x.yaml | 4 +- Bindings/sound/qcom,wsa883x.yaml | 2 +- Bindings/sound/qcom,wsa8840.yaml | 2 +- Bindings/sound/renesas,rsnd.yaml | 36 +- Bindings/sound/renesas,rz-ssi.yaml | 2 +- Bindings/sound/samsung-i2s.yaml | 19 +- Bindings/sound/sound-card-common.yaml | 7 + Bindings/sound/tas2562.yaml | 2 - Bindings/sound/ti,tas2781.yaml | 78 +- Bindings/sound/ti,tlv320aic32x4.yaml | 2 +- Bindings/spi/adi,axi-spi-engine.txt | 31 - Bindings/spi/adi,axi-spi-engine.yaml | 66 + Bindings/spi/renesas,rspi.yaml | 2 +- Bindings/spi/snps,dw-apb-ssi.yaml | 2 - Bindings/spi/st,stm32-spi.yaml | 2 + .../thermal/allwinner,sun8i-a83t-ths.yaml | 7 +- Bindings/thermal/loongson,ls2k-thermal.yaml | 10 +- Bindings/thermal/mediatek,thermal.yaml | 99 + Bindings/thermal/mediatek-thermal.txt | 52 - Bindings/thermal/qcom-spmi-adc-tm-hc.yaml | 8 +- Bindings/thermal/qcom-spmi-adc-tm5.yaml | 16 +- Bindings/thermal/qcom-tsens.yaml | 1 + Bindings/thermal/thermal-zones.yaml | 16 + Bindings/timer/sifive,clint.yaml | 2 + Bindings/timer/thead,c900-aclint-mtimer.yaml | 9 +- Bindings/tpm/google,cr50.yaml | 65 + Bindings/tpm/ibm,vtpm.yaml | 104 + Bindings/tpm/microsoft,ftpm.yaml | 47 + Bindings/tpm/tcg,tpm-tis-i2c.yaml | 90 + Bindings/tpm/tcg,tpm-tis-mmio.yaml | 49 + Bindings/tpm/tcg,tpm_tis-spi.yaml | 75 + Bindings/tpm/tpm-common.yaml | 87 + Bindings/trivial-devices.yaml | 24 +- Bindings/ufs/qcom,ufs.yaml | 2 + Bindings/ufs/samsung,exynos-ufs.yaml | 9 +- Bindings/ufs/ufs-common.yaml | 2 + Bindings/usb/dwc3-xilinx.yaml | 3 +- Bindings/usb/generic-xhci.yaml | 25 +- Bindings/usb/genesys,gl850g.yaml | 5 + Bindings/usb/mediatek,mtk-xhci.yaml | 11 + Bindings/usb/microchip,usb5744.yaml | 3 +- Bindings/usb/nxp,ptn5110.yaml | 2 +- Bindings/usb/qcom,dwc3.yaml | 151 +- Bindings/usb/qcom,wcd939x-usbss.yaml | 102 + Bindings/usb/renesas,usbhs.yaml | 2 +- Bindings/usb/snps,dwc3.yaml | 4 + Bindings/usb/ti,tps6598x.yaml | 6 + Bindings/usb/usb-xhci.yaml | 6 + Bindings/usb/xlnx,usb2.yaml | 3 +- Bindings/vendor-prefixes.yaml | 22 + Bindings/w1/amd,axi-1wire-host.yaml | 44 + .../watchdog/allwinner,sun4i-a10-wdt.yaml | 6 +- Bindings/watchdog/alphascale,asm9260-wdt.yaml | 6 +- Bindings/watchdog/apple,wdt.yaml | 6 +- Bindings/watchdog/arm-smc-wdt.yaml | 6 +- Bindings/watchdog/brcm,bcm7038-wdt.yaml | 10 +- Bindings/watchdog/cnxt,cx92755-wdt.yaml | 6 +- Bindings/watchdog/dlg,da9062-watchdog.yaml | 12 +- Bindings/watchdog/intel,keembay-wdt.yaml | 5 +- Bindings/watchdog/maxim,max63xx.yaml | 8 +- Bindings/watchdog/mediatek,mtk-wdt.yaml | 1 + Bindings/watchdog/nxp,pnx4008-wdt.yaml | 34 + Bindings/watchdog/pnx4008-wdt.txt | 17 - Bindings/watchdog/qca,ar7130-wdt.yaml | 33 + Bindings/watchdog/qca-ar7130-wdt.txt | 13 - Bindings/watchdog/qcom,pm8916-wdt.yaml | 33 +- Bindings/watchdog/qcom-wdt.yaml | 2 +- Bindings/watchdog/realtek,rtd119x.txt | 17 - .../watchdog/realtek,rtd1295-watchdog.yaml | 38 + Bindings/watchdog/samsung-wdt.yaml | 29 +- Bindings/watchdog/snps,dw-wdt.yaml | 10 +- Bindings/watchdog/technologic,ts7200-wdt.yaml | 45 + include/dt-bindings/arm/qcom,ids.h | 1 + include/dt-bindings/clock/g12a-clkc.h | 8 + include/dt-bindings/clock/google,gs101.h | 392 ++ .../dt-bindings/clock/mediatek,mt7988-clk.h | 280 + include/dt-bindings/clock/qcom,gcc-msm8939.h | 6 + .../dt-bindings/clock/qcom,qdu1000-ecpricc.h | 147 + .../dt-bindings/clock/qcom,sc8280xp-camcc.h | 179 + .../dt-bindings/clock/qcom,sm8650-dispcc.h | 102 + include/dt-bindings/clock/qcom,sm8650-gcc.h | 254 + include/dt-bindings/clock/qcom,sm8650-gpucc.h | 43 + include/dt-bindings/clock/qcom,sm8650-tcsr.h | 18 + .../dt-bindings/clock/qcom,videocc-sm8150.h | 4 + include/dt-bindings/clock/qcom,x1e80100-gcc.h | 485 ++ include/dt-bindings/clock/sophgo,cv1800.h | 176 + include/dt-bindings/clock/st,stm32mp25-rcc.h | 492 ++ include/dt-bindings/dma/fsl-edma.h | 21 + .../dt-bindings/iio/qcom,spmi-adc7-pm7325.h | 69 + .../dt-bindings/iio/qcom,spmi-adc7-smb139x.h | 19 + include/dt-bindings/iio/qcom,spmi-vadc.h | 3 + .../dt-bindings/interconnect/qcom,sm6115.h | 111 + .../interconnect/qcom,sm8650-rpmh.h | 154 + .../interconnect/qcom,x1e80100-rpmh.h | 207 + include/dt-bindings/power/meson-g12a-power.h | 1 + include/dt-bindings/reset/amlogic,c3-reset.h | 119 + .../reset/mediatek,mt7988-resets.h | 13 + include/dt-bindings/reset/mt8188-resets.h | 75 + include/dt-bindings/reset/qcom,sm8650-gpucc.h | 20 + include/dt-bindings/reset/st,stm32mp25-rcc.h | 167 + include/dt-bindings/soc/rockchip,vop2.h | 4 + src/arm/amazon/alpine.dtsi | 1 - .../aspeed/aspeed-bmc-facebook-bletchley.dts | 4 +- .../aspeed/aspeed-bmc-facebook-wedge400.dts | 4 +- src/arm/aspeed/aspeed-bmc-opp-tacoma.dts | 2 +- src/arm/aspeed/aspeed-g4.dtsi | 14 - src/arm/aspeed/aspeed-g5.dtsi | 15 +- src/arm/aspeed/aspeed-g6.dtsi | 18 +- .../ast2600-facebook-netbmc-common.dtsi | 4 +- src/arm/broadcom/bcm-cygnus.dtsi | 3 + src/arm/broadcom/bcm-hr2.dtsi | 1 + src/arm/broadcom/bcm-nsp.dtsi | 2 + src/arm/broadcom/bcm2711-rpi.dtsi | 5 + src/arm/broadcom/bcm2711.dtsi | 14 + src/arm/broadcom/bcm63138.dtsi | 6 + .../intel/ixp/intel-ixp42x-gateway-7001.dts | 2 + .../ixp/intel-ixp42x-goramo-multilink.dts | 2 + .../ixp/intel-ixp42x-usrobotics-usr8200.dts | 22 + src/arm/intel/socfpga/socfpga.dtsi | 2 +- src/arm/intel/socfpga/socfpga_arria10.dtsi | 2 +- .../socfpga/socfpga_arria10_socdk_qspi.dts | 2 - .../intel/socfpga/socfpga_arria5_socdk.dts | 2 - .../intel/socfpga/socfpga_cyclone5_socdk.dts | 2 - .../intel/socfpga/socfpga_cyclone5_sockit.dts | 2 - .../intel/socfpga/socfpga_cyclone5_sodia.dts | 2 - .../socfpga/socfpga_cyclone5_vining_fpga.dts | 4 - src/arm/marvell/armada-370-rd.dts | 26 +- .../marvell/armada-370-seagate-nas-2bay.dts | 8 +- .../marvell/armada-370-seagate-nas-4bay.dts | 8 +- .../marvell/armada-370-synology-ds213j.dts | 16 +- .../marvell/armada-381-netgear-gs110emx.dts | 44 +- .../marvell/armada-385-clearfog-gtr-l8.dts | 38 +- .../marvell/armada-385-clearfog-gtr-s4.dts | 22 +- src/arm/marvell/armada-385-linksys.dtsi | 18 +- src/arm/marvell/armada-385-synology-ds116.dts | 16 +- src/arm/marvell/armada-385-turris-omnia.dts | 20 +- src/arm/marvell/armada-388-clearfog.dts | 20 +- src/arm/marvell/armada-388-gp.dts | 4 +- src/arm/marvell/armada-xp-linksys-mamba.dts | 18 +- src/arm/marvell/kirkwood-dnskw.dtsi | 6 +- src/arm/marvell/kirkwood-l-50.dts | 2 + .../marvell/kirkwood-linkstation-6282.dtsi | 9 +- .../marvell/kirkwood-linkstation-lswxl.dts | 9 +- src/arm/marvell/kirkwood-lsxl.dtsi | 9 +- src/arm/marvell/kirkwood-ns2max.dts | 18 +- src/arm/marvell/kirkwood-ns2mini.dts | 18 +- src/arm/marvell/kirkwood-synology.dtsi | 102 +- src/arm/marvell/mvebu-linkstation-fan.dtsi | 8 +- src/arm/microchip/at91-sam9x60_curiosity.dts | 3 + src/arm/microchip/at91-sam9x60ek.dts | 3 + src/arm/microchip/at91-sama5d27_som1_ek.dts | 1 - src/arm/microchip/at91-sama5d27_wlsom1_ek.dts | 1 - src/arm/nuvoton/nuvoton-wpcm450.dtsi | 2 + src/arm/nvidia/tegra20-colibri.dtsi | 2 +- src/arm/nvidia/tegra30-apalis-v1.1.dtsi | 1 - src/arm/nvidia/tegra30-apalis.dtsi | 1 - src/arm/nvidia/tegra30-colibri.dtsi | 1 - src/arm/nxp/imx/imx1-ads.dts | 2 +- src/arm/nxp/imx/imx1-apf9328.dts | 2 +- src/arm/nxp/imx/imx1.dtsi | 9 +- src/arm/nxp/imx/imx25-eukrea-cpuimx25.dtsi | 2 +- ...25-eukrea-mbimxsd25-baseboard-cmo-qvga.dts | 2 +- ...25-eukrea-mbimxsd25-baseboard-dvi-svga.dts | 2 +- ...x25-eukrea-mbimxsd25-baseboard-dvi-vga.dts | 2 +- src/arm/nxp/imx/imx25-pdk.dts | 3 +- src/arm/nxp/imx/imx25.dtsi | 41 +- src/arm/nxp/imx/imx27-apf27dev.dts | 4 +- src/arm/nxp/imx/imx27-eukrea-cpuimx27.dtsi | 4 +- .../imx/imx27-eukrea-mbimxsd27-baseboard.dts | 2 +- src/arm/nxp/imx/imx27-pdk.dts | 18 +- .../nxp/imx/imx27-phytec-phycard-s-rdk.dts | 2 +- src/arm/nxp/imx/imx27-phytec-phycore-rdk.dts | 17 +- src/arm/nxp/imx/imx27-phytec-phycore-som.dtsi | 28 +- src/arm/nxp/imx/imx27.dtsi | 7 +- src/arm/nxp/imx/imx53-cx9020.dts | 2 +- src/arm/nxp/imx/imx6dl-b105pv2.dts | 2 +- src/arm/nxp/imx/imx6dl-b105v2.dts | 2 +- src/arm/nxp/imx/imx6dl-b125pv2.dts | 2 +- src/arm/nxp/imx/imx6dl-b125v2.dts | 2 +- src/arm/nxp/imx/imx6dl-b155v2.dts | 2 +- src/arm/nxp/imx/imx6q-apalis-ixora-v1.2.dts | 2 + src/arm/nxp/imx/imx6q-b850v3.dts | 3 - src/arm/nxp/imx/imx6q-bx50v3.dtsi | 2 +- src/arm/nxp/imx/imx6q-var-mx6customboard.dts | 4 +- src/arm/nxp/imx/imx6qdl-apalis.dtsi | 10 +- src/arm/nxp/imx/imx6qdl-colibri.dtsi | 8 +- src/arm/nxp/imx/imx6qdl-emcon-avari.dtsi | 2 +- src/arm/nxp/imx/imx6qdl-emcon.dtsi | 1 - src/arm/nxp/imx/imx6qdl-mba6.dtsi | 6 +- src/arm/nxp/imx/imx6qdl-phytec-pfla02.dtsi | 1 + .../nxp/imx/imx6qdl-phytec-phycore-som.dtsi | 1 + src/arm/nxp/imx/imx6qdl-skov-cpu-revc.dtsi | 2 +- src/arm/nxp/imx/imx6qdl.dtsi | 2 +- src/arm/nxp/imx/imx6sx.dtsi | 8 +- src/arm/nxp/imx/imx6ul.dtsi | 2 +- src/arm/nxp/imx/imx6ull-phytec-tauri.dtsi | 2 +- src/arm/nxp/imx/imx7-tqma7.dtsi | 9 +- src/arm/nxp/imx/imx7d-colibri-emmc.dtsi | 4 + src/arm/nxp/imx/imx7d-flex-concentrator.dts | 2 +- src/arm/nxp/imx/imx7d-meerkat96.dts | 2 +- src/arm/nxp/imx/imx7d-pico-dwarf.dts | 1 + src/arm/nxp/imx/imx7d-pico.dtsi | 8 + src/arm/nxp/imx/imx7d-smegw01.dts | 2 +- src/arm/nxp/imx/imx7d.dtsi | 3 - src/arm/nxp/imx/imx7s.dtsi | 48 +- src/arm/nxp/imx/mba6ulx.dtsi | 2 +- src/arm/nxp/lpc/lpc18xx.dtsi | 2 +- src/arm/nxp/ls/ls1021a.dtsi | 2 +- src/arm/nxp/mxs/imx23-sansa.dts | 12 +- src/arm/nxp/mxs/imx23.dtsi | 10 +- src/arm/nxp/mxs/imx28-lwe.dtsi | 1 + src/arm/nxp/mxs/imx28-tx28.dts | 1 + src/arm/nxp/mxs/imx28.dtsi | 14 +- src/arm/nxp/vf/vf-colibri-eval-v3.dtsi | 2 +- src/arm/nxp/vf/vf610-bk4.dts | 4 +- src/arm/nxp/vf/vf610-zii-cfu1.dts | 14 +- src/arm/nxp/vf/vf610-zii-dev-rev-b.dts | 7 +- src/arm/nxp/vf/vf610-zii-scu4-aib.dts | 70 +- src/arm/nxp/vf/vf610-zii-spb4.dts | 18 +- src/arm/nxp/vf/vf610-zii-ssmb-dtu.dts | 20 +- src/arm/nxp/vf/vf610-zii-ssmb-spu3.dts | 18 +- src/arm/qcom/pm8018.dtsi | 55 + src/arm/qcom/pm8058.dtsi | 159 + .../qcom/{qcom-pm8226.dtsi => pm8226.dtsi} | 2 + src/arm/qcom/pm8821.dtsi | 22 + .../qcom/{qcom-pm8841.dtsi => pm8841.dtsi} | 0 src/arm/qcom/pm8921.dtsi | 137 + .../qcom/{qcom-pm8941.dtsi => pm8941.dtsi} | 2 + .../qcom/{qcom-pma8084.dtsi => pma8084.dtsi} | 0 src/arm/qcom/{qcom-pmx55.dtsi => pmx55.dtsi} | 0 src/arm/qcom/{qcom-pmx65.dtsi => pmx65.dtsi} | 0 src/arm/qcom/qcom-apq8026-asus-sparrow.dts | 4 +- src/arm/qcom/qcom-apq8026-huawei-sturgeon.dts | 4 +- src/arm/qcom/qcom-apq8026-lg-lenok.dts | 4 +- .../qcom-apq8026-samsung-matisse-wifi.dts | 2 +- src/arm/qcom/qcom-apq8060-dragonboard.dts | 164 +- src/arm/qcom/qcom-apq8064-asus-nexus7-flo.dts | 70 +- src/arm/qcom/qcom-apq8064-cm-qs600.dts | 35 +- src/arm/qcom/qcom-apq8064-ifc6410.dts | 42 +- .../qcom-apq8064-sony-xperia-lagan-yuga.dts | 111 +- src/arm/qcom/qcom-apq8064.dtsi | 203 +- src/arm/qcom/qcom-apq8074-dragonboard.dts | 35 +- src/arm/qcom/qcom-apq8084-ifc6540.dts | 2 +- src/arm/qcom/qcom-apq8084-mtp.dts | 2 +- src/arm/qcom/qcom-ipq4019-ap.dk04.1.dtsi | 2 +- src/arm/qcom/qcom-ipq4019.dtsi | 4 +- src/arm/qcom/qcom-ipq8064.dtsi | 8 +- .../qcom/qcom-mdm9615-wp8548-mangoh-green.dts | 4 +- src/arm/qcom/qcom-mdm9615-wp8548.dtsi | 143 +- src/arm/qcom/qcom-mdm9615.dtsi | 183 +- .../qcom/qcom-msm8226-microsoft-common.dtsi | 327 + .../qcom/qcom-msm8226-microsoft-dempsey.dts | 17 + .../qcom/qcom-msm8226-microsoft-makepeace.dts | 17 + .../qcom-msm8226-microsoft-moneypenny.dts | 23 + src/arm/qcom/qcom-msm8226.dtsi | 48 +- src/arm/qcom/qcom-msm8660-surf.dts | 61 +- src/arm/qcom/qcom-msm8660.dtsi | 217 +- src/arm/qcom/qcom-msm8926-htc-memul.dts | 372 + .../qcom-msm8926-microsoft-superman-lte.dts | 53 + src/arm/qcom/qcom-msm8926-microsoft-tesla.dts | 67 + .../qcom/qcom-msm8926-motorola-peregrine.dts | 291 + src/arm/qcom/qcom-msm8960-cdp.dts | 27 +- .../qcom/qcom-msm8960-samsung-expressatt.dts | 7 +- src/arm/qcom/qcom-msm8960.dtsi | 45 +- .../qcom-msm8974-lge-nexus5-hammerhead.dts | 33 +- .../qcom/qcom-msm8974-sony-xperia-rhine.dtsi | 35 +- src/arm/qcom/qcom-msm8974.dtsi | 122 +- .../qcom/qcom-msm8974pro-fairphone-fp2.dts | 33 +- .../qcom/qcom-msm8974pro-oneplus-bacon.dts | 35 +- src/arm/qcom/qcom-msm8974pro-samsung-klte.dts | 13 +- ...-msm8974pro-sony-xperia-shinano-castor.dts | 35 +- src/arm/qcom/qcom-sdx55-mtp.dts | 2 +- src/arm/qcom/qcom-sdx55-t55.dts | 2 +- src/arm/qcom/qcom-sdx55-telit-fn980-tlb.dts | 2 +- src/arm/qcom/qcom-sdx55.dtsi | 63 +- src/arm/qcom/qcom-sdx65-mtp.dts | 2 +- src/arm/qcom/qcom-sdx65.dtsi | 51 +- src/arm/renesas/iwg20d-q7-dbcm-ca.dtsi | 15 + src/arm/renesas/r8a7740-armadillo800eva.dts | 28 +- src/arm/renesas/r8a7740.dtsi | 65 + .../renesas/r8a7745-iwg22d-sodimm-dbhd-ca.dts | 15 + src/arm/renesas/r8a7745-iwg22d-sodimm.dts | 4 +- src/arm/renesas/r8a7779-marzen.dts | 48 +- src/arm/renesas/r8a7790-lager.dts | 24 +- src/arm/renesas/r8a7790-stout.dts | 16 + src/arm/renesas/r8a7791-koelsch.dts | 31 +- src/arm/renesas/r8a7791-porter.dts | 27 +- src/arm/renesas/r8a7792-blanche.dts | 50 + src/arm/renesas/r8a7792-wheat.dts | 21 + src/arm/renesas/r8a7793-gose.dts | 29 +- src/arm/renesas/r8a7794-alt.dts | 5 +- src/arm/renesas/r8a7794-silk.dts | 18 +- src/arm/renesas/r9a06g032.dtsi | 2 +- src/arm/rockchip/rk3036-kylin.dts | 21 + src/arm/rockchip/rk3036.dtsi | 18 +- src/arm/rockchip/rk3066a.dtsi | 5 + src/arm/rockchip/rk3128-evb.dts | 5 - src/arm/rockchip/rk3128-xpi-3128.dts | 425 ++ src/arm/rockchip/rk3128.dtsi | 185 + src/arm/rockchip/rk322x.dtsi | 4 + src/arm/rockchip/rk3288.dtsi | 9 + src/arm/rockchip/rk3xxx.dtsi | 4 + src/arm/rockchip/rv1108.dtsi | 8 - src/arm/rockchip/rv1109-sonoff-ihost.dts | 21 + src/arm/rockchip/rv1109.dtsi | 23 + src/arm/rockchip/rv1126-edgeble-neu2-io.dts | 2 +- src/arm/rockchip/rv1126-pinctrl.dtsi | 72 +- src/arm/rockchip/rv1126-sonoff-ihost.dts | 29 + src/arm/rockchip/rv1126-sonoff-ihost.dtsi | 404 ++ src/arm/rockchip/rv1126.dtsi | 21 + src/arm/samsung/exynos4.dtsi | 26 +- src/arm/samsung/exynos4210-i9100.dts | 48 +- src/arm/samsung/exynos4212-tab3.dtsi | 1 + src/arm/samsung/exynos4x12.dtsi | 22 +- src/arm/samsung/s5pv210.dtsi | 18 +- src/arm/st/ste-dbx5x0.dtsi | 18 +- src/arm/st/ste-href-ab8500.dtsi | 48 + src/arm/st/ste-href-ab8505.dtsi | 490 ++ src/arm/st/ste-href.dtsi | 55 - src/arm/st/ste-href520-tvk.dts | 1 + src/arm/st/ste-hrefprev60-stuib.dts | 1 + src/arm/st/ste-hrefprev60-tvk.dts | 1 + src/arm/st/ste-hrefprev60.dtsi | 2 +- src/arm/st/ste-hrefv60plus-stuib.dts | 1 + src/arm/st/ste-hrefv60plus-tvk.dts | 1 + src/arm/st/ste-hrefv60plus.dtsi | 3 +- src/arm/st/ste-nomadik-stn8815.dtsi | 8 +- src/arm/st/ste-snowball.dts | 2 +- src/arm/st/ste-ux500-samsung-codina-tmo.dts | 2 +- src/arm/st/ste-ux500-samsung-codina.dts | 2 +- src/arm/st/ste-ux500-samsung-gavini.dts | 2 +- src/arm/st/ste-ux500-samsung-janice.dts | 2 +- src/arm/st/ste-ux500-samsung-kyle.dts | 2 +- src/arm/st/stm32429i-eval.dts | 1 - src/arm/st/stm32f469-disco.dts | 15 +- src/arm/st/stm32f746.dtsi | 61 + src/arm/st/stm32mp135.dtsi | 11 + src/arm/st/stm32mp151.dtsi | 4 + src/arm/st/stm32mp151a-prtt1l.dtsi | 2 - src/arm/st/stm32mp157a-dk1-scmi.dts | 4 +- src/arm/st/stm32mp157a-stinger96.dtsi | 2 - src/arm/st/stm32mp157c-dk2-scmi.dts | 4 +- src/arm/st/stm32mp157c-dk2.dts | 1 - src/arm/st/stm32mp157c-ed1-scmi.dts | 4 +- src/arm/st/stm32mp157c-emstamp-argon.dtsi | 4 - src/arm/st/stm32mp157c-ev1-scmi.dts | 5 +- src/arm/st/stm32mp157c-ev1.dts | 1 - src/arm/st/stm32mp157c-osd32mp1-red.dts | 4 - .../st/stm32mp157c-phycore-stm32mp15-som.dtsi | 4 - src/arm/st/stm32mp15xc-lxa-tac.dtsi | 3 - src/arm/st/stm32mp15xx-dhcom-drc02.dtsi | 1 - src/arm/st/stm32mp15xx-dhcom-pdk2.dtsi | 1 - src/arm/st/stm32mp15xx-dhcom-picoitx.dtsi | 2 - src/arm/st/stm32mp15xx-dhcor-avenger96.dtsi | 2 - src/arm/st/stm32mp15xx-dhcor-drc-compact.dtsi | 2 - src/arm/st/stm32mp15xx-dhcor-testbench.dtsi | 2 - src/arm/st/stm32mp15xx-dkx.dtsi | 1 - src/arm/ti/keystone/keystone-k2e-netcp.dtsi | 6 +- src/arm/ti/keystone/keystone-k2g-evm.dts | 2 +- src/arm/ti/keystone/keystone-k2g-netcp.dtsi | 6 +- src/arm/ti/keystone/keystone-k2hk-evm.dts | 2 +- src/arm/ti/keystone/keystone-k2hk-netcp.dtsi | 6 +- src/arm/ti/keystone/keystone-k2l-netcp.dtsi | 6 +- .../ti/omap/am335x-moxa-uc-2100-common.dtsi | 2 +- src/arm/ti/omap/am571x-idk.dts | 4 +- src/arm/ti/omap/am5729-beagleboneai.dts | 3 +- src/arm/ti/omap/am572x-idk-common.dtsi | 4 +- src/arm/ti/omap/dra7-evm-common.dtsi | 4 +- src/arm/ti/omap/dra71-evm.dts | 4 +- src/arm/ti/omap/dra72-evm-common.dtsi | 4 +- src/arm/ti/omap/dra76-evm.dts | 4 +- .../ti/omap/logicpd-torpedo-37xx-devkit.dts | 2 +- src/arm/ti/omap/motorola-mapphone-common.dtsi | 298 - .../ti/omap/motorola-mapphone-handset.dtsi | 234 + .../omap/motorola-mapphone-mz607-mz617.dtsi | 21 + src/arm/ti/omap/motorola-mapphone-xt8xx.dtsi | 75 + src/arm/ti/omap/omap4-droid-bionic-xt875.dts | 11 +- src/arm/ti/omap/omap4-droid4-xt894.dts | 19 +- src/arm/ti/omap/omap4-epson-embt2ws.dts | 18 +- src/arm/ti/omap/omap4-xyboard-mz609.dts | 46 + src/arm/ti/omap/omap4-xyboard-mz617.dts | 17 + .../allwinner/sun50i-h618-orangepi-zero2w.dts | 176 + .../sun50i-h618-transpeed-8k618-t.dts | 161 + src/arm64/altera/socfpga_stratix10.dtsi | 41 +- src/arm64/altera/socfpga_stratix10_socdk.dts | 8 +- .../altera/socfpga_stratix10_socdk_nand.dts | 6 +- src/arm64/altera/socfpga_stratix10_swvp.dts | 2 - src/arm64/amazon/alpine-v2.dtsi | 1 - src/arm64/amazon/alpine-v3.dtsi | 1 - src/arm64/amlogic/amlogic-c3.dtsi | 6 + .../meson-axg-jethome-jethub-j110-rev-2.dts | 14 +- .../meson-axg-jethome-jethub-j110-rev-3.dts | 12 + src/arm64/amlogic/meson-axg-s400.dts | 5 - src/arm64/amlogic/meson-axg.dtsi | 23 + src/arm64/amlogic/meson-g12a-sei510.dts | 1 - src/arm64/amlogic/meson-g12a-x96-max.dts | 1 - .../amlogic/meson-g12b-bananapi-cm4.dtsi | 2 +- src/arm64/amlogic/meson-g12b-bananapi.dtsi | 2 +- src/arm64/amlogic/meson-g12b-gtking.dts | 1 - src/arm64/amlogic/meson-g12b-ugoos-am6.dts | 1 - src/arm64/amlogic/meson-gx-p23x-q20x.dtsi | 1 - src/arm64/amlogic/meson-gxbb-kii-pro.dts | 1 - src/arm64/amlogic/meson-gxbb-p200.dts | 1 - src/arm64/amlogic/meson-gxbb-vega-s95.dtsi | 1 - src/arm64/amlogic/meson-gxbb-wetek-play2.dts | 1 - src/arm64/amlogic/meson-gxm-nexbox-a1.dts | 1 - src/arm64/amlogic/meson-gxm-rbox-pro.dts | 1 - src/arm64/amlogic/meson-s4-s805x2-aq222.dts | 60 +- src/arm64/amlogic/meson-s4.dtsi | 360 +- src/arm64/amlogic/meson-sm1-sei610.dts | 1 - src/arm64/arm/juno-base.dtsi | 12 +- src/arm64/arm/juno-scmi.dtsi | 12 +- src/arm64/broadcom/northstar2/ns2.dtsi | 1 + src/arm64/broadcom/stingray/stingray.dtsi | 1 + src/arm64/exynos/exynos5433.dtsi | 60 +- src/arm64/exynos/exynos7.dtsi | 18 +- src/arm64/exynos/exynos7885.dtsi | 45 +- src/arm64/exynos/exynos850.dtsi | 40 +- src/arm64/exynos/exynosautov9-sadk.dts | 51 + src/arm64/exynos/exynosautov9.dtsi | 10 +- src/arm64/exynos/exynosautov920-pinctrl.dtsi | 1266 ++++ src/arm64/exynos/exynosautov920-sadk.dts | 88 + src/arm64/exynos/exynosautov920.dtsi | 312 + src/arm64/exynos/google/gs101-oriole.dts | 105 + src/arm64/exynos/google/gs101-pinctrl.dtsi | 1249 ++++ src/arm64/exynos/google/gs101-pinctrl.h | 33 + src/arm64/exynos/google/gs101.dtsi | 473 ++ src/arm64/freescale/fsl-ls1012a.dtsi | 80 +- src/arm64/freescale/fsl-ls1028a.dtsi | 87 +- src/arm64/freescale/fsl-ls1043a.dtsi | 81 +- src/arm64/freescale/fsl-ls1046a.dtsi | 74 +- src/arm64/freescale/fsl-ls1088a.dtsi | 74 +- src/arm64/freescale/fsl-ls208xa.dtsi | 73 +- .../fsl-lx2160a-tqmlx2160a-mblx2160a.dts | 338 + ...l-lx2160a-tqmlx2160a-mblx2160a_12_x_x.dtso | 29 + ...l-lx2160a-tqmlx2160a-mblx2160a_14_x_x.dtso | 17 + ...l-lx2160a-tqmlx2160a-mblx2160a_x_11_x.dtso | 49 + ...sl-lx2160a-tqmlx2160a-mblx2160a_x_7_x.dtso | 55 + ...sl-lx2160a-tqmlx2160a-mblx2160a_x_8_x.dtso | 47 + .../freescale/fsl-lx2160a-tqmlx2160a.dtsi | 97 + src/arm64/freescale/fsl-lx2160a.dtsi | 4 +- .../freescale/imx8-apalis-ixora-v1.2.dtsi | 2 + src/arm64/freescale/imx8-ss-audio.dtsi | 2 - src/arm64/freescale/imx8dxl-ss-conn.dtsi | 16 +- src/arm64/freescale/imx8dxl-ss-ddr.dtsi | 2 +- src/arm64/freescale/imx8mm-beacon-som.dtsi | 2 + src/arm64/freescale/imx8mm-emcon-avari.dtsi | 2 +- src/arm64/freescale/imx8mm-evk.dtsi | 12 +- src/arm64/freescale/imx8mm-nitrogen-r2.dts | 2 +- src/arm64/freescale/imx8mm-overdrive.dtsi | 29 + .../freescale/imx8mm-phygate-tauri-l.dts | 2 +- .../freescale/imx8mm-tqma8mqml-mba8mx.dts | 1 + src/arm64/freescale/imx8mm-venice-gw72xx.dtsi | 39 +- src/arm64/freescale/imx8mm-venice-gw73xx.dtsi | 31 +- src/arm64/freescale/imx8mm-venice-gw7902.dts | 13 +- src/arm64/freescale/imx8mm-verdin-mallow.dtsi | 173 + .../imx8mm-verdin-nonwifi-mallow.dts | 18 + .../freescale/imx8mm-verdin-wifi-mallow.dts | 18 + src/arm64/freescale/imx8mm.dtsi | 18 +- src/arm64/freescale/imx8mn-beacon-som.dtsi | 2 + .../freescale/imx8mn-bsh-smm-s2-common.dtsi | 1 + .../freescale/imx8mn-bsh-smm-s2-display.dtsi | 121 + .../freescale/imx8mn-dimonoff-gateway-evk.dts | 160 + src/arm64/freescale/imx8mn-evk.dtsi | 12 +- src/arm64/freescale/imx8mn-overdrive.dtsi | 18 + src/arm64/freescale/imx8mn-rve-gateway.dts | 285 + .../freescale/imx8mn-tqma8mqnl-mba8mx.dts | 1 + .../freescale/imx8mn-var-som-symphony.dts | 10 + src/arm64/freescale/imx8mn-var-som.dtsi | 9 + src/arm64/freescale/imx8mn.dtsi | 2 + src/arm64/freescale/imx8mp-beacon-kit.dts | 94 +- .../freescale/imx8mp-data-modul-edm-sbc.dts | 2 +- src/arm64/freescale/imx8mp-debix-model-a.dts | 2 +- .../freescale/imx8mp-debix-som-a-bmb-08.dts | 56 + src/arm64/freescale/imx8mp-debix-som-a.dtsi | 22 + src/arm64/freescale/imx8mp-dhcom-som.dtsi | 14 +- src/arm64/freescale/imx8mp-evk.dts | 22 + src/arm64/freescale/imx8mp-msc-sm2s-ep1.dts | 4 +- src/arm64/freescale/imx8mp-skov-reva.dtsi | 711 ++ src/arm64/freescale/imx8mp-skov-revb-hdmi.dts | 20 + src/arm64/freescale/imx8mp-skov-revb-lt6.dts | 101 + .../imx8mp-skov-revb-mi1010ait-1cp1.dts | 100 + ...8mp-tqma8mpql-mba8mpxl-lvds-g133han01.dtso | 77 + .../freescale/imx8mp-tqma8mpql-mba8mpxl.dts | 37 +- src/arm64/freescale/imx8mp-venice-gw71xx.dtsi | 26 +- src/arm64/freescale/imx8mp-venice-gw72xx.dtsi | 36 +- src/arm64/freescale/imx8mp-venice-gw73xx.dtsi | 28 +- src/arm64/freescale/imx8mp-venice-gw74xx.dts | 30 +- src/arm64/freescale/imx8mp-verdin-mallow.dtsi | 199 + .../imx8mp-verdin-nonwifi-mallow.dts | 18 + .../freescale/imx8mp-verdin-wifi-mallow.dts | 18 + src/arm64/freescale/imx8mp-verdin.dtsi | 30 +- src/arm64/freescale/imx8mp.dtsi | 30 +- .../freescale/imx8mq-kontron-pitx-imx8m.dts | 2 +- src/arm64/freescale/imx8mq-phanbell.dts | 2 +- src/arm64/freescale/imx8mq-tqma8mq-mba8mx.dts | 1 + src/arm64/freescale/imx8qm-ss-dma.dtsi | 4 + src/arm64/freescale/imx8qxp-mek.dts | 21 +- src/arm64/freescale/imx8qxp-ss-vpu.dtsi | 17 + src/arm64/freescale/imx8qxp.dtsi | 3 +- src/arm64/freescale/imx93-11x11-evk.dts | 31 +- .../freescale/imx93-tqma9352-mba93xxca.dts | 709 ++ .../freescale/imx93-tqma9352-mba93xxla.dts | 1 + src/arm64/freescale/imx93.dtsi | 127 +- src/arm64/hisilicon/hikey970-pmic.dtsi | 6 +- src/arm64/intel/socfpga_agilex.dtsi | 42 +- src/arm64/intel/socfpga_agilex5.dtsi | 4 +- src/arm64/intel/socfpga_agilex_n6000.dts | 2 +- src/arm64/intel/socfpga_agilex_socdk.dts | 2 - src/arm64/intel/socfpga_n5x_socdk.dts | 5 +- src/arm64/lg/lg1312.dtsi | 1 - src/arm64/lg/lg1313.dtsi | 1 - src/arm64/marvell/ac5x-rd-carrier-cn9131.dts | 44 + src/arm64/marvell/ac5x-rd-carrier.dtsi | 34 + .../marvell/armada-3720-espressobin-ultra.dts | 14 +- .../marvell/armada-3720-espressobin.dtsi | 20 +- src/arm64/marvell/armada-3720-gl-mv1000.dts | 20 +- src/arm64/marvell/armada-3720-turris-mox.dts | 99 +- src/arm64/marvell/armada-7040-mochabin.dts | 24 +- .../marvell/armada-8040-clearfog-gt-8k.dts | 22 +- src/arm64/marvell/armada-ap80x.dtsi | 1 - src/arm64/marvell/cn9130-crb.dtsi | 42 +- src/arm64/marvell/cn9130-db-comexpress.dtsi | 96 + src/arm64/marvell/cn9131-db-comexpress.dtsi | 108 + src/arm64/mediatek/mt6358.dtsi | 26 +- .../mediatek/mt7622-bananapi-bpi-r64.dts | 3 +- .../mediatek/mt7986a-bananapi-bpi-r3.dts | 3 +- src/arm64/mediatek/mt8173-elm-hana.dtsi | 9 +- src/arm64/mediatek/mt8173-elm.dtsi | 24 +- src/arm64/mediatek/mt8173-evb.dts | 3 +- src/arm64/mediatek/mt8173.dtsi | 8 +- src/arm64/mediatek/mt8183-evb.dts | 4 + .../mediatek/mt8183-kukui-audio-da7219.dtsi | 3 +- .../mediatek/mt8183-kukui-audio-ts3a227e.dtsi | 3 +- .../mediatek/mt8183-kukui-jacuzzi-damu.dts | 3 +- .../mt8183-kukui-jacuzzi-fennel-sku1.dts | 3 +- .../mt8183-kukui-jacuzzi-fennel-sku6.dts | 3 +- .../mt8183-kukui-jacuzzi-fennel-sku7.dts | 3 +- .../mt8183-kukui-jacuzzi-makomo-sku0.dts | 24 + .../mt8183-kukui-jacuzzi-makomo-sku1.dts | 24 + .../mediatek/mt8183-kukui-jacuzzi-pico.dts | 35 + .../mediatek/mt8183-kukui-jacuzzi-pico6.dts | 110 + src/arm64/mediatek/mt8183-kukui-jacuzzi.dtsi | 1 - .../mediatek/mt8183-kukui-kakadu-sku22.dts | 18 + src/arm64/mediatek/mt8183-kukui-kakadu.dts | 18 + src/arm64/mediatek/mt8183-kukui-kakadu.dtsi | 15 +- .../mediatek/mt8183-kukui-katsu-sku32.dts | 36 + .../mediatek/mt8183-kukui-katsu-sku38.dts | 40 + src/arm64/mediatek/mt8183-kukui-kodama.dtsi | 3 +- src/arm64/mediatek/mt8183-kukui-krane.dtsi | 3 +- src/arm64/mediatek/mt8183-kukui.dtsi | 12 +- src/arm64/mediatek/mt8183-pumpkin.dts | 4 + src/arm64/mediatek/mt8183.dtsi | 62 +- src/arm64/mediatek/mt8186.dtsi | 6 +- src/arm64/mediatek/mt8188-evb.dts | 387 ++ src/arm64/mediatek/mt8188.dtsi | 956 +++ src/arm64/mediatek/mt8192-asurada.dtsi | 2 +- src/arm64/mediatek/mt8192.dtsi | 466 ++ src/arm64/mediatek/mt8195-cherry.dtsi | 117 +- src/arm64/mediatek/mt8195-demo.dts | 1 + src/arm64/mediatek/mt8195.dtsi | 483 +- src/arm64/mediatek/mt8395-genio-1200-evk.dts | 6 +- .../nvidia/tegra234-p3737-0000+p3701-0000.dts | 2 +- src/arm64/nvidia/tegra234.dtsi | 6 +- src/arm64/qcom/ipq5018-rdp432-c2.dts | 12 + src/arm64/qcom/ipq5018.dtsi | 142 + src/arm64/qcom/ipq5332-rdp-common.dtsi | 3 + src/arm64/qcom/ipq5332-rdp441.dts | 2 +- src/arm64/qcom/ipq5332-rdp442.dts | 2 +- src/arm64/qcom/ipq5332-rdp474.dts | 2 +- src/arm64/qcom/ipq5332.dtsi | 23 +- src/arm64/qcom/ipq6018.dtsi | 129 +- src/arm64/qcom/ipq8074.dtsi | 126 +- src/arm64/qcom/ipq9574-rdp-common.dtsi | 169 + src/arm64/qcom/ipq9574-rdp418.dts | 63 +- src/arm64/qcom/ipq9574-rdp433.dts | 91 +- src/arm64/qcom/ipq9574-rdp449.dts | 65 +- src/arm64/qcom/ipq9574-rdp453.dts | 65 +- src/arm64/qcom/ipq9574-rdp454.dts | 66 +- src/arm64/qcom/ipq9574.dtsi | 25 +- src/arm64/qcom/msm8916-acer-a1-724.dts | 24 + src/arm64/qcom/msm8916-alcatel-idol347.dts | 173 +- src/arm64/qcom/msm8916-asus-z00l.dts | 21 + src/arm64/qcom/msm8916-longcheer-l8150.dts | 75 +- src/arm64/qcom/msm8916-longcheer-l8910.dts | 103 + src/arm64/qcom/msm8916-modem-qdsp6.dtsi | 148 + .../qcom/msm8916-samsung-a2015-common.dtsi | 71 + src/arm64/qcom/msm8916-samsung-a3u-eur.dts | 10 +- .../qcom/msm8916-samsung-e2015-common.dtsi | 4 + src/arm64/qcom/msm8916-samsung-grandmax.dts | 4 + .../qcom/msm8916-samsung-gt5-common.dtsi | 92 +- src/arm64/qcom/msm8916-samsung-gt510.dts | 26 + src/arm64/qcom/msm8916-samsung-gt58.dts | 46 + src/arm64/qcom/msm8916-samsung-j5-common.dtsi | 14 + src/arm64/qcom/msm8916-samsung-j5.dts | 4 + src/arm64/qcom/msm8916-samsung-serranove.dts | 13 + src/arm64/qcom/msm8916-thwc-uf896.dts | 8 +- src/arm64/qcom/msm8916-thwc-ufi001c.dts | 8 +- src/arm64/qcom/msm8916-wingtech-wt88047.dts | 75 + src/arm64/qcom/msm8916-yiming-uz801v3.dts | 8 +- src/arm64/qcom/msm8916.dtsi | 59 +- src/arm64/qcom/msm8939-huawei-kiwi.dts | 242 + src/arm64/qcom/msm8939-longcheer-l9100.dts | 56 + src/arm64/qcom/msm8939-samsung-a7.dts | 70 + src/arm64/qcom/msm8939.dtsi | 94 +- src/arm64/qcom/msm8953-xiaomi-mido.dts | 1 + src/arm64/qcom/msm8953-xiaomi-tissot.dts | 1 + src/arm64/qcom/msm8953-xiaomi-vince.dts | 1 + src/arm64/qcom/msm8953.dtsi | 110 +- src/arm64/qcom/msm8996.dtsi | 129 +- src/arm64/qcom/msm8998.dtsi | 92 +- src/arm64/qcom/pm7250b.dtsi | 2 +- src/arm64/qcom/pm8550.dtsi | 3 - src/arm64/qcom/pm8550ve.dtsi | 6 +- src/arm64/qcom/pm8916.dtsi | 48 + src/arm64/qcom/pmk8350.dtsi | 2 +- src/arm64/qcom/qcm2290.dtsi | 504 +- src/arm64/qcom/qcm6490-fairphone-fp5.dts | 288 +- src/arm64/qcom/qcm6490-idp.dts | 468 ++ src/arm64/qcom/qcs404.dtsi | 11 +- src/arm64/qcom/qcs6490-rb3gen2.dts | 455 ++ src/arm64/qcom/qdu1000.dtsi | 23 +- src/arm64/qcom/qrb2210-rb1.dts | 113 + src/arm64/qcom/qrb4210-rb2.dts | 112 +- .../qcom/qrb5165-rb5-vision-mezzanine.dts | 2 +- src/arm64/qcom/qrb5165-rb5.dts | 33 +- src/arm64/qcom/sa8775p-ride.dts | 5 + src/arm64/qcom/sa8775p.dtsi | 1124 ++- src/arm64/qcom/sc7180-acer-aspire1.dts | 174 +- src/arm64/qcom/sc7180-trogdor-pompom.dtsi | 2 +- src/arm64/qcom/sc7180.dtsi | 14 +- src/arm64/qcom/sc7280-chrome-common.dtsi | 37 +- src/arm64/qcom/sc7280-herobrine-lte-sku.dtsi | 7 +- src/arm64/qcom/sc7280-herobrine-wifi-sku.dtsi | 1 + src/arm64/qcom/sc7280-idp.dtsi | 19 + src/arm64/qcom/sc7280.dtsi | 581 +- src/arm64/qcom/sc8180x-lenovo-flex-5g.dts | 4 +- src/arm64/qcom/sc8180x-primus.dts | 12 +- src/arm64/qcom/sc8180x.dtsi | 61 +- src/arm64/qcom/sc8280xp-crd.dts | 4 + .../qcom/sc8280xp-lenovo-thinkpad-x13s.dts | 14 + src/arm64/qcom/sc8280xp.dtsi | 24 +- src/arm64/qcom/sdm630.dtsi | 53 +- src/arm64/qcom/sdm632-fairphone-fp3.dts | 19 + src/arm64/qcom/sdm670.dtsi | 302 +- src/arm64/qcom/sdm845-db845c.dts | 4 +- src/arm64/qcom/sdm845-oneplus-common.dtsi | 23 + src/arm64/qcom/sdm845-wcd9340.dtsi | 2 +- .../qcom/sdm845-xiaomi-beryllium-common.dtsi | 22 + src/arm64/qcom/sdm845.dtsi | 127 +- src/arm64/qcom/sdm850-lenovo-yoga-c630.dts | 8 +- src/arm64/qcom/sdm850-samsung-w737.dts | 2 +- src/arm64/qcom/sdx75-idp.dts | 29 + src/arm64/qcom/sdx75.dtsi | 170 + src/arm64/qcom/sm4450-qrd.dts | 18 +- src/arm64/qcom/sm4450.dtsi | 107 + src/arm64/qcom/sm6115.dtsi | 345 +- src/arm64/qcom/sm6125.dtsi | 4 + src/arm64/qcom/sm6350.dtsi | 20 +- .../qcom/sm6375-sony-xperia-murray-pdx225.dts | 43 +- src/arm64/qcom/sm6375.dtsi | 84 +- src/arm64/qcom/sm8150-hdk.dts | 264 +- src/arm64/qcom/sm8150.dtsi | 223 +- .../qcom/sm8250-xiaomi-elish-common.dtsi | 47 +- src/arm64/qcom/sm8250-xiaomi-pipa.dts | 623 ++ src/arm64/qcom/sm8250.dtsi | 143 +- src/arm64/qcom/sm8350.dtsi | 147 +- src/arm64/qcom/sm8450-hdk.dts | 8 + src/arm64/qcom/sm8450.dtsi | 285 +- src/arm64/qcom/sm8550-mtp.dts | 129 + src/arm64/qcom/sm8550-qrd.dts | 136 + src/arm64/qcom/sm8550.dtsi | 317 +- src/arm64/qcom/sm8650-mtp.dts | 727 ++ src/arm64/qcom/sm8650-qrd.dts | 811 +++ src/arm64/qcom/sm8650.dtsi | 6013 +++++++++++++++++ src/arm64/qcom/x1e80100-crd.dts | 424 ++ src/arm64/qcom/x1e80100-qcp.dts | 399 ++ src/arm64/qcom/x1e80100.dtsi | 3527 ++++++++++ src/arm64/renesas/draak.dtsi | 32 +- src/arm64/renesas/ebisu.dtsi | 6 + src/arm64/renesas/r8a77970-eagle.dts | 15 + .../renesas/r8a779g0-white-hawk-cpu.dtsi | 3 + src/arm64/renesas/r9a08g045.dtsi | 106 + src/arm64/renesas/r9a09g011.dtsi | 2 +- src/arm64/renesas/rzg2l-smarc-som.dtsi | 1 + src/arm64/renesas/rzg2lc-smarc-som.dtsi | 1 + src/arm64/renesas/rzg3s-smarc-som.dtsi | 210 +- src/arm64/renesas/rzg3s-smarc.dtsi | 65 + src/arm64/renesas/ulcb-kf.dtsi | 4 + src/arm64/rockchip/px30-engicam-common.dtsi | 1 + src/arm64/rockchip/px30-evb.dts | 1 + src/arm64/rockchip/px30-ringneck-haikou.dts | 1 + src/arm64/rockchip/px30.dtsi | 3 +- src/arm64/rockchip/rk3308-rock-pi-s.dts | 62 + src/arm64/rockchip/rk3308.dtsi | 5 + src/arm64/rockchip/rk3318-a95x-z2.dts | 1 + src/arm64/rockchip/rk3326-anbernic-rg351m.dts | 18 +- .../rockchip/rk3326-anbernic-rg351m.dtsi | 478 ++ src/arm64/rockchip/rk3326-anbernic-rg351v.dts | 44 + src/arm64/rockchip/rk3328-a1.dts | 1 + src/arm64/rockchip/rk3328-evb.dts | 1 + src/arm64/rockchip/rk3328-nanopi-r2s.dts | 1 + .../rockchip/rk3328-orangepi-r1-plus-lts.dts | 4 +- .../rockchip/rk3328-orangepi-r1-plus.dts | 1 + src/arm64/rockchip/rk3328-roc-cc.dts | 1 + src/arm64/rockchip/rk3328-rock-pi-e.dts | 55 + src/arm64/rockchip/rk3328-rock64.dts | 1 + src/arm64/rockchip/rk3328.dtsi | 11 +- src/arm64/rockchip/rk3368-evb.dtsi | 1 + src/arm64/rockchip/rk3368-geekbox.dts | 1 + src/arm64/rockchip/rk3368-lion.dtsi | 1 + src/arm64/rockchip/rk3368-orion-r68-meta.dts | 1 + src/arm64/rockchip/rk3368-r88.dts | 1 + src/arm64/rockchip/rk3368.dtsi | 5 +- src/arm64/rockchip/rk3399-eaidk-610.dts | 1 + src/arm64/rockchip/rk3399-evb.dts | 1 + src/arm64/rockchip/rk3399-ficus.dts | 4 + src/arm64/rockchip/rk3399-firefly.dts | 1 + src/arm64/rockchip/rk3399-gru-bob.dts | 2 +- src/arm64/rockchip/rk3399-gru-scarlet.dtsi | 2 +- src/arm64/rockchip/rk3399-hugsun-x99.dts | 1 + .../rockchip/rk3399-khadas-edge-captain.dts | 4 + src/arm64/rockchip/rk3399-khadas-edge-v.dts | 4 + src/arm64/rockchip/rk3399-kobol-helios64.dts | 1 + src/arm64/rockchip/rk3399-leez-p710.dts | 1 + src/arm64/rockchip/rk3399-nanopi4.dtsi | 1 + src/arm64/rockchip/rk3399-orangepi.dts | 1 + src/arm64/rockchip/rk3399-puma-haikou.dts | 42 +- src/arm64/rockchip/rk3399-puma.dtsi | 15 + src/arm64/rockchip/rk3399-roc-pc.dtsi | 1 + src/arm64/rockchip/rk3399-rock-4c-plus.dts | 1 + src/arm64/rockchip/rk3399-rock-pi-4.dtsi | 1 + src/arm64/rockchip/rk3399-rockpro64.dtsi | 1 + src/arm64/rockchip/rk3399-sapphire.dtsi | 3 +- src/arm64/rockchip/rk3399.dtsi | 7 +- src/arm64/rockchip/rk3399pro-vmarc-som.dtsi | 1 + src/arm64/rockchip/rk3566-lubancat-1.dts | 2 +- src/arm64/rockchip/rk3566-powkiddy-rgb30.dts | 154 +- src/arm64/rockchip/rk3566-powkiddy-rk2023.dts | 38 + .../rockchip/rk3566-powkiddy-rk2023.dtsi | 875 +++ src/arm64/rockchip/rk3566-powkiddy-x55.dts | 926 +++ src/arm64/rockchip/rk3566-quartz64-a.dts | 5 +- src/arm64/rockchip/rk3566-radxa-cm3-io.dts | 1 + src/arm64/rockchip/rk3566-roc-pc.dts | 1 + src/arm64/rockchip/rk3566-soquartz-blade.dts | 4 + src/arm64/rockchip/rk3566-soquartz-cm4.dts | 4 + .../rockchip/rk3566-soquartz-model-a.dts | 4 + src/arm64/rockchip/rk3566-soquartz.dtsi | 1 - src/arm64/rockchip/rk3588-coolpi-cm5-evb.dts | 216 + src/arm64/rockchip/rk3588-coolpi-cm5.dtsi | 650 ++ .../rockchip/rk3588-edgeble-neu6a-io.dts | 4 - .../rockchip/rk3588-edgeble-neu6b-io.dts | 6 +- src/arm64/rockchip/rk3588-evb1-v10.dts | 100 +- src/arm64/rockchip/rk3588-jaguar.dts | 802 +++ src/arm64/rockchip/rk3588-nanopc-t6.dts | 18 +- src/arm64/rockchip/rk3588-orangepi-5-plus.dts | 1 - src/arm64/rockchip/rk3588-quartzpro64.dts | 2 +- src/arm64/rockchip/rk3588-rock-5b.dts | 13 +- src/arm64/rockchip/rk3588-turing-rk1.dtsi | 2 - src/arm64/rockchip/rk3588s-coolpi-4b.dts | 812 +++ .../rockchip/rk3588s-indiedroid-nova.dts | 11 +- src/arm64/rockchip/rk3588s-khadas-edge2.dts | 1 - src/arm64/rockchip/rk3588s-orangepi-5.dts | 7 +- src/arm64/rockchip/rk3588s-rock-5a.dts | 10 +- src/arm64/rockchip/rk3588s.dtsi | 116 + src/arm64/sprd/ums512.dtsi | 39 +- src/arm64/sprd/ums9620-2h10.dts | 38 + src/arm64/sprd/ums9620.dtsi | 245 + src/arm64/st/stm32mp251.dtsi | 16 + src/arm64/tesla/fsd.dtsi | 53 +- src/arm64/ti/k3-am62-main.dtsi | 96 +- src/arm64/ti/k3-am62-verdin-dahlia.dtsi | 3 +- src/arm64/ti/k3-am62-verdin-dev.dtsi | 3 +- src/arm64/ti/k3-am62-verdin-mallow.dtsi | 188 + src/arm64/ti/k3-am62-verdin-yavia.dtsi | 3 +- src/arm64/ti/k3-am62-verdin.dtsi | 17 +- .../ti/k3-am625-beagleplay-csi2-ov5640.dtso | 77 + .../k3-am625-beagleplay-csi2-tevi-ov5640.dtso | 77 + src/arm64/ti/k3-am625-beagleplay.dts | 4 +- src/arm64/ti/k3-am625-phyboard-lyra-rdk.dts | 98 +- .../ti/k3-am625-verdin-nonwifi-mallow.dts | 22 + src/arm64/ti/k3-am625-verdin-wifi-mallow.dts | 22 + src/arm64/ti/k3-am62a-main.dtsi | 121 +- src/arm64/ti/k3-am62a7-sk.dts | 39 + src/arm64/ti/k3-am62p-main.dtsi | 18 +- src/arm64/ti/k3-am62p5-sk.dts | 9 + src/arm64/ti/k3-am62x-sk-common.dtsi | 16 + src/arm64/ti/k3-am62x-sk-csi2-imx219.dtso | 84 + src/arm64/ti/k3-am62x-sk-csi2-ov5640.dtso | 82 + .../ti/k3-am62x-sk-csi2-tevi-ov5640.dtso | 82 + src/arm64/ti/k3-am64-main.dtsi | 22 +- src/arm64/ti/k3-am64-phycore-som.dtsi | 103 +- src/arm64/ti/k3-am642-evm.dts | 12 +- .../ti/k3-am642-phyboard-electra-rdk.dts | 1 + src/arm64/ti/k3-am642-sk.dts | 10 +- src/arm64/ti/k3-am642-tqma64xxl-mbax4xxl.dts | 1 - src/arm64/ti/k3-am642-tqma64xxl.dtsi | 1 + src/arm64/ti/k3-am65-iot2050-common-pg1.dtsi | 10 +- src/arm64/ti/k3-am65-iot2050-common-pg2.dtsi | 4 +- src/arm64/ti/k3-am65-iot2050-common.dtsi | 826 ++- src/arm64/ti/k3-am65-main.dtsi | 16 +- src/arm64/ti/k3-am65-mcu.dtsi | 8 +- src/arm64/ti/k3-am65-wakeup.dtsi | 13 +- src/arm64/ti/k3-am652.dtsi | 74 + .../ti/k3-am6528-iot2050-basic-common.dtsi | 16 +- src/arm64/ti/k3-am654-base-board.dts | 2 + .../ti/k3-am6548-iot2050-advanced-common.dtsi | 2 + .../ti/k3-am6548-iot2050-advanced-m2.dts | 12 +- src/arm64/ti/k3-am68-sk-base-board.dts | 1 + src/arm64/ti/k3-am69-sk.dts | 96 +- src/arm64/ti/k3-j7200-main.dtsi | 9 +- src/arm64/ti/k3-j7200-mcu-wakeup.dtsi | 21 +- src/arm64/ti/k3-j7200-som-p0.dtsi | 153 + src/arm64/ti/k3-j721e-evm-pcie0-ep.dtso | 53 + src/arm64/ti/k3-j721e-main.dtsi | 8 +- src/arm64/ti/k3-j721e-mcu-wakeup.dtsi | 21 +- src/arm64/ti/k3-j721e-sk.dts | 151 + src/arm64/ti/k3-j721e-som-p0.dtsi | 160 + src/arm64/ti/k3-j721s2-evm-pcie1-ep.dtso | 53 + src/arm64/ti/k3-j721s2-main.dtsi | 9 +- src/arm64/ti/k3-j721s2-mcu-wakeup.dtsi | 21 +- src/arm64/ti/k3-j721s2-som-p0.dtsi | 193 + src/arm64/ti/k3-j784s4-evm.dts | 102 + src/arm64/ti/k3-j784s4-main.dtsi | 9 +- src/arm64/ti/k3-j784s4-mcu-wakeup.dtsi | 22 +- src/arm64/xilinx/zynqmp-sck-kv-g-revA.dtso | 40 +- src/arm64/xilinx/zynqmp-sck-kv-g-revB.dtso | 42 +- src/arm64/xilinx/zynqmp-sm-k26-revA.dts | 8 +- src/arm64/xilinx/zynqmp-zc1751-xm015-dc1.dts | 8 +- src/arm64/xilinx/zynqmp-zc1751-xm016-dc2.dts | 16 +- src/arm64/xilinx/zynqmp-zc1751-xm017-dc3.dts | 8 +- src/arm64/xilinx/zynqmp-zc1751-xm018-dc4.dts | 26 +- src/arm64/xilinx/zynqmp-zc1751-xm019-dc5.dts | 8 +- src/arm64/xilinx/zynqmp-zcu100-revC.dts | 4 +- src/arm64/xilinx/zynqmp.dtsi | 15 +- src/loongarch/loongson-2k0500-ref.dts | 88 + src/loongarch/loongson-2k0500.dtsi | 266 + src/loongarch/loongson-2k1000-ref.dts | 183 + src/loongarch/loongson-2k1000.dtsi | 492 ++ src/loongarch/loongson-2k2000-ref.dts | 72 + src/loongarch/loongson-2k2000.dtsi | 300 + src/powerpc/fsl/t1023si-post.dtsi | 79 +- src/powerpc/fsl/t1040si-post.dtsi | 71 +- src/riscv/microchip/mpfs-icicle-kit.dts | 21 + src/riscv/microchip/mpfs.dtsi | 17 + src/riscv/renesas/r9a07g043f.dtsi | 4 + src/riscv/sifive/hifive-unmatched-a00.dts | 1 + src/riscv/sophgo/cv1800b.dtsi | 118 +- src/riscv/sophgo/cv1812h-huashan-pi.dts | 48 + src/riscv/sophgo/cv1812h.dtsi | 24 + src/riscv/sophgo/cv18xx.dtsi | 192 + src/riscv/sophgo/sg2042.dtsi | 80 +- src/riscv/starfive/jh7100-common.dtsi | 131 + src/riscv/starfive/jh7100.dtsi | 60 +- src/riscv/starfive/jh7110.dtsi | 4 +- src/riscv/thead/th1520-beaglev-ahead.dts | 20 + src/riscv/thead/th1520-lichee-module-4a.dtsi | 20 + src/riscv/thead/th1520.dtsi | 34 + 1311 files changed, 67670 insertions(+), 8539 deletions(-) create mode 100644 Bindings/arm/google.yaml delete mode 100644 Bindings/arm/mediatek/mediatek,audsys.txt create mode 100644 Bindings/arm/mediatek/mediatek,audsys.yaml delete mode 100644 Bindings/arm/mediatek/mediatek,ethsys.txt delete mode 100644 Bindings/arm/msm/qcom,idle-state.txt create mode 100644 Bindings/arm/qcom,coresight-remote-etm.yaml delete mode 100644 Bindings/clock/brcm,kona-ccu.txt create mode 100644 Bindings/clock/brcm,kona-ccu.yaml create mode 100644 Bindings/clock/fsl,imx93-anatop.yaml create mode 100644 Bindings/clock/google,gs101-clock.yaml delete mode 100644 Bindings/clock/hi3620-clock.txt create mode 100644 Bindings/clock/mediatek,ethsys.yaml create mode 100644 Bindings/clock/mediatek,mt7988-ethwarp.yaml create mode 100644 Bindings/clock/mediatek,mt7988-xfi-pll.yaml create mode 100644 Bindings/clock/qcom,gcc-ipq6018.yaml create mode 100644 Bindings/clock/qcom,qdu1000-ecpricc.yaml create mode 100644 Bindings/clock/qcom,sm8650-dispcc.yaml create mode 100644 Bindings/clock/qcom,sm8650-gcc.yaml create mode 100644 Bindings/clock/qcom,x1e80100-gcc.yaml delete mode 100644 Bindings/clock/silabs,si5351.txt create mode 100644 Bindings/clock/silabs,si5351.yaml create mode 100644 Bindings/clock/sophgo,cv1800-clk.yaml create mode 100644 Bindings/clock/st,stm32mp25-rcc.yaml create mode 100644 Bindings/crypto/inside-secure,safexcel.yaml delete mode 100644 Bindings/crypto/inside-secure-safexcel.txt delete mode 100644 Bindings/display/mediatek/mediatek,mdp-rdma.yaml create mode 100644 Bindings/display/mediatek/mediatek,padding.yaml create mode 100644 Bindings/display/msm/qcom,sdm670-mdss.yaml create mode 100644 Bindings/display/msm/qcom,sm8650-dpu.yaml create mode 100644 Bindings/display/msm/qcom,sm8650-mdss.yaml create mode 100644 Bindings/display/panel/fascontek,fs035vg158.yaml create mode 100644 Bindings/display/panel/ilitek,ili9805.yaml create mode 100644 Bindings/display/panel/synaptics,r63353.yaml delete mode 100644 Bindings/display/rockchip/inno_hdmi-rockchip.txt create mode 100644 Bindings/display/rockchip/rockchip,inno-hdmi.yaml create mode 100644 Bindings/dma/loongson,ls2x-apbdma.yaml create mode 100644 Bindings/dts-coding-style.rst delete mode 100644 Bindings/fpga/altera-fpga2sdram-bridge.txt delete mode 100644 Bindings/fpga/altera-freeze-bridge.txt delete mode 100644 Bindings/fpga/altera-hps2fpga-bridge.txt create mode 100644 Bindings/fpga/altr,freeze-bridge-controller.yaml create mode 100644 Bindings/fpga/altr,socfpga-fpga2sdram-bridge.yaml create mode 100644 Bindings/fpga/altr,socfpga-hps2fpga-bridge.yaml delete mode 100644 Bindings/fpga/fpga-bridge.txt create mode 100644 Bindings/fpga/fpga-bridge.yaml create mode 100644 Bindings/gpio/nuvoton,sgpio.yaml create mode 100644 Bindings/gpio/realtek,rtd-gpio.yaml create mode 100644 Bindings/gpu/img,powervr.yaml delete mode 100644 Bindings/hwmon/gpio-fan.txt create mode 100644 Bindings/hwmon/gpio-fan.yaml create mode 100644 Bindings/hwmon/lltc,ltc4286.yaml create mode 100644 Bindings/iio/adc/maxim,max34408.yaml create mode 100644 Bindings/iio/chemical/aosong,ags02ma.yaml create mode 100644 Bindings/iio/dac/microchip,mcp4821.yaml create mode 100644 Bindings/iio/humidity/ti,hdc3020.yaml create mode 100644 Bindings/iio/imu/bosch,bmi323.yaml create mode 100644 Bindings/iio/light/liteon,ltr390.yaml create mode 100644 Bindings/iio/light/vishay,veml6075.yaml create mode 100644 Bindings/iio/pressure/honeywell,hsc030pa.yaml create mode 100644 Bindings/iio/temperature/microchip,mcp9600.yaml create mode 100644 Bindings/input/adafruit,seesaw-gamepad.yaml delete mode 100644 Bindings/input/gpio-mouse.txt create mode 100644 Bindings/input/gpio-mouse.yaml delete mode 100644 Bindings/input/ti,drv2665.txt delete mode 100644 Bindings/input/ti,drv2667.txt create mode 100644 Bindings/input/ti,drv266x.yaml create mode 100644 Bindings/input/touchscreen/neonode,zforce.yaml delete mode 100644 Bindings/input/touchscreen/samsung,s6sy761.txt create mode 100644 Bindings/input/touchscreen/samsung,s6sy761.yaml delete mode 100644 Bindings/input/touchscreen/zforce_ts.txt create mode 100644 Bindings/interconnect/qcom,sm6115.yaml create mode 100644 Bindings/interconnect/qcom,sm8650-rpmh.yaml create mode 100644 Bindings/interconnect/qcom,x1e80100-rpmh.yaml create mode 100644 Bindings/leds/allwinner,sun50i-a100-ledc.yaml create mode 100644 Bindings/loongarch/cpus.yaml create mode 100644 Bindings/loongarch/loongson.yaml create mode 100644 Bindings/media/cnm,wave521c.yaml create mode 100644 Bindings/media/i2c/alliedvision,alvium-csi2.yaml create mode 100644 Bindings/media/i2c/galaxycore,gc0308.yaml create mode 100644 Bindings/media/i2c/galaxycore,gc2145.yaml create mode 100644 Bindings/media/i2c/ovti,ov64a40.yaml create mode 100644 Bindings/media/i2c/techwell,tw9900.yaml create mode 100644 Bindings/media/i2c/thine,thp7312.yaml create mode 100644 Bindings/media/mediatek,mdp3-fg.yaml create mode 100644 Bindings/media/mediatek,mdp3-hdr.yaml create mode 100644 Bindings/media/mediatek,mdp3-stitch.yaml create mode 100644 Bindings/media/mediatek,mdp3-tcc.yaml create mode 100644 Bindings/media/mediatek,mdp3-tdshp.yaml create mode 100644 Bindings/media/st,stm32-dcmipp.yaml create mode 100644 Bindings/media/starfive,jh7110-camss.yaml create mode 100644 Bindings/mfd/ams,as3711.yaml delete mode 100644 Bindings/mfd/as3711.txt create mode 100644 Bindings/net/dsa/marvell,mv88e6060.yaml create mode 100644 Bindings/net/dsa/marvell,mv88e6xxx.yaml delete mode 100644 Bindings/net/dsa/marvell.txt create mode 100644 Bindings/net/lantiq,pef2256.yaml create mode 100644 Bindings/net/marvell,aquantia.yaml create mode 100644 Bindings/net/renesas,ethertsn.yaml create mode 100644 Bindings/pinctrl/qcom,lpass-lpi-common.yaml create mode 100644 Bindings/pinctrl/qcom,sm4450-tlmm.yaml create mode 100644 Bindings/pinctrl/qcom,sm8650-lpass-lpi-pinctrl.yaml create mode 100644 Bindings/pinctrl/qcom,sm8650-tlmm.yaml create mode 100644 Bindings/pinctrl/qcom,x1e80100-tlmm.yaml delete mode 100644 Bindings/pwm/pwm-omap-dmtimer.txt create mode 100644 Bindings/pwm/ti,omap-dmtimer-pwm.yaml create mode 100644 Bindings/rtc/adi,max31335.yaml create mode 100644 Bindings/rtc/nuvoton,ma35d1-rtc.yaml delete mode 100644 Bindings/security/tpm/google,cr50.txt delete mode 100644 Bindings/security/tpm/ibmvtpm.txt delete mode 100644 Bindings/security/tpm/st33zp24-i2c.txt delete mode 100644 Bindings/security/tpm/st33zp24-spi.txt delete mode 100644 Bindings/security/tpm/tpm-i2c.txt delete mode 100644 Bindings/security/tpm/tpm_tis_mmio.txt delete mode 100644 Bindings/security/tpm/tpm_tis_spi.txt create mode 100644 Bindings/serial/arm,dcc.yaml rename Bindings/{arm => soc/xilinx}/xilinx.yaml (95%) delete mode 100644 Bindings/sound/es8328.txt create mode 100644 Bindings/sound/everest,es8328.yaml delete mode 100644 Bindings/sound/fsl,mqs.txt create mode 100644 Bindings/sound/fsl,mqs.yaml create mode 100644 Bindings/sound/mediatek,mt2701-audio.yaml delete mode 100644 Bindings/sound/mt2701-afe-pcm.txt delete mode 100644 Bindings/spi/adi,axi-spi-engine.txt create mode 100644 Bindings/spi/adi,axi-spi-engine.yaml create mode 100644 Bindings/thermal/mediatek,thermal.yaml delete mode 100644 Bindings/thermal/mediatek-thermal.txt create mode 100644 Bindings/tpm/google,cr50.yaml create mode 100644 Bindings/tpm/ibm,vtpm.yaml create mode 100644 Bindings/tpm/microsoft,ftpm.yaml create mode 100644 Bindings/tpm/tcg,tpm-tis-i2c.yaml create mode 100644 Bindings/tpm/tcg,tpm-tis-mmio.yaml create mode 100644 Bindings/tpm/tcg,tpm_tis-spi.yaml create mode 100644 Bindings/tpm/tpm-common.yaml create mode 100644 Bindings/usb/qcom,wcd939x-usbss.yaml create mode 100644 Bindings/w1/amd,axi-1wire-host.yaml create mode 100644 Bindings/watchdog/nxp,pnx4008-wdt.yaml delete mode 100644 Bindings/watchdog/pnx4008-wdt.txt create mode 100644 Bindings/watchdog/qca,ar7130-wdt.yaml delete mode 100644 Bindings/watchdog/qca-ar7130-wdt.txt delete mode 100644 Bindings/watchdog/realtek,rtd119x.txt create mode 100644 Bindings/watchdog/realtek,rtd1295-watchdog.yaml create mode 100644 Bindings/watchdog/technologic,ts7200-wdt.yaml create mode 100644 include/dt-bindings/clock/google,gs101.h create mode 100644 include/dt-bindings/clock/mediatek,mt7988-clk.h create mode 100644 include/dt-bindings/clock/qcom,qdu1000-ecpricc.h create mode 100644 include/dt-bindings/clock/qcom,sc8280xp-camcc.h create mode 100644 include/dt-bindings/clock/qcom,sm8650-dispcc.h create mode 100644 include/dt-bindings/clock/qcom,sm8650-gcc.h create mode 100644 include/dt-bindings/clock/qcom,sm8650-gpucc.h create mode 100644 include/dt-bindings/clock/qcom,sm8650-tcsr.h create mode 100644 include/dt-bindings/clock/qcom,x1e80100-gcc.h create mode 100644 include/dt-bindings/clock/sophgo,cv1800.h create mode 100644 include/dt-bindings/clock/st,stm32mp25-rcc.h create mode 100644 include/dt-bindings/dma/fsl-edma.h create mode 100644 include/dt-bindings/iio/qcom,spmi-adc7-pm7325.h create mode 100644 include/dt-bindings/iio/qcom,spmi-adc7-smb139x.h create mode 100644 include/dt-bindings/interconnect/qcom,sm6115.h create mode 100644 include/dt-bindings/interconnect/qcom,sm8650-rpmh.h create mode 100644 include/dt-bindings/interconnect/qcom,x1e80100-rpmh.h create mode 100644 include/dt-bindings/reset/amlogic,c3-reset.h create mode 100644 include/dt-bindings/reset/mediatek,mt7988-resets.h create mode 100644 include/dt-bindings/reset/qcom,sm8650-gpucc.h create mode 100644 include/dt-bindings/reset/st,stm32mp25-rcc.h create mode 100644 src/arm/qcom/pm8018.dtsi create mode 100644 src/arm/qcom/pm8058.dtsi rename src/arm/qcom/{qcom-pm8226.dtsi => pm8226.dtsi} (99%) create mode 100644 src/arm/qcom/pm8821.dtsi rename src/arm/qcom/{qcom-pm8841.dtsi => pm8841.dtsi} (100%) create mode 100644 src/arm/qcom/pm8921.dtsi rename src/arm/qcom/{qcom-pm8941.dtsi => pm8941.dtsi} (99%) rename src/arm/qcom/{qcom-pma8084.dtsi => pma8084.dtsi} (100%) rename src/arm/qcom/{qcom-pmx55.dtsi => pmx55.dtsi} (100%) rename src/arm/qcom/{qcom-pmx65.dtsi => pmx65.dtsi} (100%) create mode 100644 src/arm/qcom/qcom-msm8226-microsoft-common.dtsi create mode 100644 src/arm/qcom/qcom-msm8226-microsoft-dempsey.dts create mode 100644 src/arm/qcom/qcom-msm8226-microsoft-makepeace.dts create mode 100644 src/arm/qcom/qcom-msm8226-microsoft-moneypenny.dts create mode 100644 src/arm/qcom/qcom-msm8926-htc-memul.dts create mode 100644 src/arm/qcom/qcom-msm8926-microsoft-superman-lte.dts create mode 100644 src/arm/qcom/qcom-msm8926-microsoft-tesla.dts create mode 100644 src/arm/qcom/qcom-msm8926-motorola-peregrine.dts create mode 100644 src/arm/rockchip/rk3128-xpi-3128.dts create mode 100644 src/arm/rockchip/rv1109-sonoff-ihost.dts create mode 100644 src/arm/rockchip/rv1109.dtsi create mode 100644 src/arm/rockchip/rv1126-sonoff-ihost.dts create mode 100644 src/arm/rockchip/rv1126-sonoff-ihost.dtsi create mode 100644 src/arm/st/ste-href-ab8505.dtsi create mode 100644 src/arm/ti/omap/motorola-mapphone-handset.dtsi create mode 100644 src/arm/ti/omap/motorola-mapphone-mz607-mz617.dtsi create mode 100644 src/arm/ti/omap/motorola-mapphone-xt8xx.dtsi create mode 100644 src/arm/ti/omap/omap4-xyboard-mz609.dts create mode 100644 src/arm/ti/omap/omap4-xyboard-mz617.dts create mode 100644 src/arm64/allwinner/sun50i-h618-orangepi-zero2w.dts create mode 100644 src/arm64/allwinner/sun50i-h618-transpeed-8k618-t.dts create mode 100644 src/arm64/exynos/exynosautov920-pinctrl.dtsi create mode 100644 src/arm64/exynos/exynosautov920-sadk.dts create mode 100644 src/arm64/exynos/exynosautov920.dtsi create mode 100644 src/arm64/exynos/google/gs101-oriole.dts create mode 100644 src/arm64/exynos/google/gs101-pinctrl.dtsi create mode 100644 src/arm64/exynos/google/gs101-pinctrl.h create mode 100644 src/arm64/exynos/google/gs101.dtsi create mode 100644 src/arm64/freescale/fsl-lx2160a-tqmlx2160a-mblx2160a.dts create mode 100644 src/arm64/freescale/fsl-lx2160a-tqmlx2160a-mblx2160a_12_x_x.dtso create mode 100644 src/arm64/freescale/fsl-lx2160a-tqmlx2160a-mblx2160a_14_x_x.dtso create mode 100644 src/arm64/freescale/fsl-lx2160a-tqmlx2160a-mblx2160a_x_11_x.dtso create mode 100644 src/arm64/freescale/fsl-lx2160a-tqmlx2160a-mblx2160a_x_7_x.dtso create mode 100644 src/arm64/freescale/fsl-lx2160a-tqmlx2160a-mblx2160a_x_8_x.dtso create mode 100644 src/arm64/freescale/fsl-lx2160a-tqmlx2160a.dtsi create mode 100644 src/arm64/freescale/imx8mm-overdrive.dtsi create mode 100644 src/arm64/freescale/imx8mm-verdin-mallow.dtsi create mode 100644 src/arm64/freescale/imx8mm-verdin-nonwifi-mallow.dts create mode 100644 src/arm64/freescale/imx8mm-verdin-wifi-mallow.dts create mode 100644 src/arm64/freescale/imx8mn-bsh-smm-s2-display.dtsi create mode 100644 src/arm64/freescale/imx8mn-dimonoff-gateway-evk.dts create mode 100644 src/arm64/freescale/imx8mn-overdrive.dtsi create mode 100644 src/arm64/freescale/imx8mn-rve-gateway.dts create mode 100644 src/arm64/freescale/imx8mp-skov-reva.dtsi create mode 100644 src/arm64/freescale/imx8mp-skov-revb-hdmi.dts create mode 100644 src/arm64/freescale/imx8mp-skov-revb-lt6.dts create mode 100644 src/arm64/freescale/imx8mp-skov-revb-mi1010ait-1cp1.dts create mode 100644 src/arm64/freescale/imx8mp-tqma8mpql-mba8mpxl-lvds-g133han01.dtso create mode 100644 src/arm64/freescale/imx8mp-verdin-mallow.dtsi create mode 100644 src/arm64/freescale/imx8mp-verdin-nonwifi-mallow.dts create mode 100644 src/arm64/freescale/imx8mp-verdin-wifi-mallow.dts create mode 100644 src/arm64/freescale/imx8qxp-ss-vpu.dtsi create mode 100644 src/arm64/freescale/imx93-tqma9352-mba93xxca.dts create mode 100644 src/arm64/marvell/ac5x-rd-carrier-cn9131.dts create mode 100644 src/arm64/marvell/ac5x-rd-carrier.dtsi create mode 100644 src/arm64/marvell/cn9130-db-comexpress.dtsi create mode 100644 src/arm64/marvell/cn9131-db-comexpress.dtsi create mode 100644 src/arm64/mediatek/mt8183-kukui-jacuzzi-makomo-sku0.dts create mode 100644 src/arm64/mediatek/mt8183-kukui-jacuzzi-makomo-sku1.dts create mode 100644 src/arm64/mediatek/mt8183-kukui-jacuzzi-pico.dts create mode 100644 src/arm64/mediatek/mt8183-kukui-jacuzzi-pico6.dts create mode 100644 src/arm64/mediatek/mt8183-kukui-katsu-sku32.dts create mode 100644 src/arm64/mediatek/mt8183-kukui-katsu-sku38.dts create mode 100644 src/arm64/mediatek/mt8188-evb.dts create mode 100644 src/arm64/mediatek/mt8188.dtsi create mode 100644 src/arm64/qcom/ipq9574-rdp-common.dtsi create mode 100644 src/arm64/qcom/msm8916-modem-qdsp6.dtsi create mode 100644 src/arm64/qcom/msm8939-huawei-kiwi.dts create mode 100644 src/arm64/qcom/qcm6490-idp.dts create mode 100644 src/arm64/qcom/qcs6490-rb3gen2.dts create mode 100644 src/arm64/qcom/sm8250-xiaomi-pipa.dts create mode 100644 src/arm64/qcom/sm8650-mtp.dts create mode 100644 src/arm64/qcom/sm8650-qrd.dts create mode 100644 src/arm64/qcom/sm8650.dtsi create mode 100644 src/arm64/qcom/x1e80100-crd.dts create mode 100644 src/arm64/qcom/x1e80100-qcp.dts create mode 100644 src/arm64/qcom/x1e80100.dtsi create mode 100644 src/arm64/rockchip/rk3326-anbernic-rg351m.dtsi create mode 100644 src/arm64/rockchip/rk3326-anbernic-rg351v.dts create mode 100644 src/arm64/rockchip/rk3566-powkiddy-rk2023.dts create mode 100644 src/arm64/rockchip/rk3566-powkiddy-rk2023.dtsi create mode 100644 src/arm64/rockchip/rk3566-powkiddy-x55.dts create mode 100644 src/arm64/rockchip/rk3588-coolpi-cm5-evb.dts create mode 100644 src/arm64/rockchip/rk3588-coolpi-cm5.dtsi create mode 100644 src/arm64/rockchip/rk3588-jaguar.dts create mode 100644 src/arm64/rockchip/rk3588s-coolpi-4b.dts create mode 100644 src/arm64/sprd/ums9620-2h10.dts create mode 100644 src/arm64/sprd/ums9620.dtsi create mode 100644 src/arm64/ti/k3-am62-verdin-mallow.dtsi create mode 100644 src/arm64/ti/k3-am625-beagleplay-csi2-ov5640.dtso create mode 100644 src/arm64/ti/k3-am625-beagleplay-csi2-tevi-ov5640.dtso create mode 100644 src/arm64/ti/k3-am625-verdin-nonwifi-mallow.dts create mode 100644 src/arm64/ti/k3-am625-verdin-wifi-mallow.dts create mode 100644 src/arm64/ti/k3-am62x-sk-csi2-imx219.dtso create mode 100644 src/arm64/ti/k3-am62x-sk-csi2-ov5640.dtso create mode 100644 src/arm64/ti/k3-am62x-sk-csi2-tevi-ov5640.dtso create mode 100644 src/arm64/ti/k3-am652.dtsi create mode 100644 src/arm64/ti/k3-j721e-evm-pcie0-ep.dtso create mode 100644 src/arm64/ti/k3-j721s2-evm-pcie1-ep.dtso create mode 100644 src/loongarch/loongson-2k0500-ref.dts create mode 100644 src/loongarch/loongson-2k0500.dtsi create mode 100644 src/loongarch/loongson-2k1000-ref.dts create mode 100644 src/loongarch/loongson-2k1000.dtsi create mode 100644 src/loongarch/loongson-2k2000-ref.dts create mode 100644 src/loongarch/loongson-2k2000.dtsi create mode 100644 src/riscv/sophgo/cv1812h-huashan-pi.dts create mode 100644 src/riscv/sophgo/cv1812h.dtsi create mode 100644 src/riscv/sophgo/cv18xx.dtsi
On March 29, 2024 thus sayeth Tom Rini:
b35b9bd1d4ee Merge tag 'v6.8-dts-raw' 1f50937554b4 Merge tag 'sound-6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound 576ba37bcbf9 Merge tag 'net-6.8-rc8' of git://git.kernel.org/pub/scm/linux/kernel/git/netdev/net c83dc02bae3e Merge tag 'qcom-arm64-fixes-for-6.8-2' of https://git.kernel.org/pub/scm/linux/kernel/git/qcom/linux into arm/fixes fb254675a395 ASoC: dt-bindings: nvidia: Fix 'lge' vendor prefix c748b8a7dbe8 Merge tag 'tegra-for-6.8-arm64-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/tegra/linux into arm/fixes a2e893adde74 Merge tag 'imx-fixes-6.8-2' of git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux into arm/fixes abb0f1b369e4 Merge tag 'qcom-arm64-fixes-for-6.8' of https://git.kernel.org/pub/scm/linux/kernel/git/qcom/linux into arm/fixes f143aa9a89ec Revert "arm64: dts: qcom: msm8996: Hook up MPM" 9a5690b7be49 arm64: dts: qcom: sc8280xp-x13s: limit pcie4 link speed ca6dcb63bd34 arm64: dts: qcom: sc8280xp-crd: limit pcie4 link speed 8532bb680bd0 dt-bindings: net: renesas,ethertsn: Document default for delays 42569705a4a0 Merge tag 'v6.8-rc6-dts-raw' 06c62487a0b4 arm64: dts: imx8mp: Fix LDB clocks property 7c93039778e4 arm64: dts: imx8mp: Fix TC9595 reset GPIO on DH i.MX8M Plus DHCOM SoM 7f9a36c5ce39 ARM: dts: imx7: remove DSI port endpoints 87ea8526eaf3 Merge tag 'loongarch-fixes-6.8-3' of git://git.kernel.org/pub/scm/linux/kernel/git/chenhuacai/linux-loongson d4a4b892cd33 Merge tag 'arm-fixes-6.8-2' of git://git.kernel.org/pub/scm/linux/kernel/git/soc/soc 4faf103c7468 Merge tag 'renesas-fixes-for-v6.8-tag1' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/renesas-devel into arm/fixes c1858748b935 Merge tag 'riscv-dt-fixes-for-v6.8-rc6' of https://git.kernel.org/pub/scm/linux/kernel/git/conor/linux into arm/fixes f1bb487d660f LoongArch: dts: Minor whitespace cleanup b60485a78d66 Merge tag 'clk-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/clk/linux d641a222a5d4 arm64: tegra: Fix Tegra234 MGBE power-domains 31aeabc2669e ARM: dts: renesas: rcar-gen2: Add missing #interrupt-cells to DA9063 nodes 8c5d69d4f1e9 arm64: dts: qcom: Fix interrupt-map cell sizes 43b35c5b7347 arm: dts: Fix dtc interrupt_map warnings f00ce91341b9 arm64: dts: Fix dtc interrupt_provider warnings c21ad68d3254 arm: dts: Fix dtc interrupt_provider warnings 20a9f605f025 Merge tag 'v6.8-rockchip-dtsfixes1' of git://git.kernel.org/pub/scm/linux/kernel/git/mmind/linux-rockchip into arm/fixes 1d9be1dcae7c Merge tag 'imx-fixes-6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux into arm/fixes c27426925b7b Merge tag 'v6.8-rc5-dts-raw' 582c3e28f603 Merge tag 'sound-6.8-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound 81da29f3007e arm64: tegra: Set the correct PHY mode for MGBE 30e4bc5d76ff Merge tag 'devicetree-fixes-for-6.8-1' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux f0c34a9f448e riscv: dts: sifive: add missing #interrupt-cells to pmic db36be2a8839 arm64: dts: rockchip: Correct Indiedroid Nova GPIO Names ec7d411e57d6 arm64: dts: rockchip: Drop interrupts property from rk3328 pwm-rockchip node 105b1e4e5e28 arm64: dts: rockchip: set num-cs property for spi on px30 a05f0ca9a008 arm64: dts: rockchip: minor rk3588 whitespace cleanup 41d6b3786aa9 riscv: dts: starfive: replace underscores in node names 910c8965eb0c dt-bindings: ufs: samsung,exynos-ufs: Add size constraints on "samsung,sysreg" d78e8a541b0a net: marvell,prestera: Fix example PCI bus addressing b40e56bea854 ASoC: dt-bindings: google,sc7280-herobrine: Drop bouncing @codeaurora 48b3246a26fe Revert "arm64: dts: imx8mn-var-som-symphony: Describe the USB-C connector" a1c414f8f89a Revert "arm64: dts: imx8mp-dhcom-pdk3: Describe the USB-C connector" 768ad06f1efa arm64: dts: tqma8mpql: fix audio codec iov-supply 77040f90f388 Merge tag 'v6.8-rc3-dts-raw' 65143ffc8608 arm64: dts: rockchip: drop unneeded status from rk3588-jaguar gpio-leds 39497955d1c0 ARM: dts: rockchip: Drop interrupts property from pwm-rockchip nodes 610e244453be arm64: dts: rockchip: Fix the num-lanes of pcie3x4 on Cool Pi CM5 EVB d6e600aea013 arm64: dts: rockchip: rename vcc5v0_usb30_host regulator for Cool Pi CM5 EVB 6be17990ec10 arm64: dts: rockchip: aliase sdmmc as mmc1 for Cool Pi CM5 EVB 77765eecb670 arm64: dts: rockchip: aliase sdmmc as mmc1 for Cool Pi 4B 7bca62b5ae66 arm64: dts: qcom: sm6115: Fix missing interconnect-names b2bc58ba4504 arm64: dts: imx8mp: Disable UART4 by default on Data Modul i.MX8M Plus eDM SBC 9474eb5c3d86 ALSA: Various fixes for Cirrus Logic CS35L56 support 1e8df48d4da1 dt-bindings: tpm: Drop type from "resets" 4d5c46ab184f dt-bindings: display: nxp,tda998x: Fix 'audio-ports' constraints fede8bd8306c dt-bindings: xilinx: replace Piyush Mehta maintainership eb691d1ece78 Merge tag 'v6.8-rc2-dts-raw' 5b093a56e797 ASoC: sun4i-spdif: Add Allwinner H616 compatible f2ce9dca7322 ASoC: sun4i-spdif: Fix requirements for H6 fd23c7505f20 arm64: dts: qcom: sm8650-mtp: add gpio74 as reserved gpio cfbd9243ac13 arm64: dts: qcom: sm8650-qrd: add gpio74 as reserved gpio 101ce3470b0e Merge tag 'drm-fixes-2024-01-27' of git://anongit.freedesktop.org/drm/drm 71ca3bf1c96e Merge tag 'arm-fixes-6.8-1' of git://git.kernel.org/pub/scm/linux/kernel/git/soc/soc 74c898882ebb riscv: dts: sophgo: separate sg2042 mtime and mtimecmp to fit aclint format 28b77b56d972 arm64: dts: rockchip: mark system power controller on rk3588-evb1 986a9f1778ef Merge tag 'samsung-fixes-6.8' of https://git.kernel.org/pub/scm/linux/kernel/git/krzk/linux into arm/fixes 6cf0227916ec arm64: dts: Fix TPM schema violations 60245a9006e9 ARM: dts: Fix TPM schema violations 92924d8db61a Merge tag 'exynos-drm-fixes-for-v6.8-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/daeinki/drm-exynos into drm-fixes 3b240d0d94a9 dt-bindings: media: Remove K3 Family Prefix from Compatible 186b38b97035 ARM: dts: exynos4212-tab3: add samsung,invert-vclk flag to fimd c4f0c99dffb8 arm64: dts: exynos: gs101: comply with the new cmu_misc clock names 429796fee0f1 dt-bindings: clock: gs101: rename cmu_misc clock-names 80d76b25d32f Merge tag 'v6.8-rc1-dts-raw' 339d8d1caab5 Merge tag 'timers-core-2024-01-21' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip df1980733ce9 Merge tag 'dmaengine-fix-6.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/vkoul/dmaengine 8c23badf69c3 Merge tag 'riscv-for-linus-6.8-mw4' of git://git.kernel.org/pub/scm/linux/kernel/git/riscv/linux d5a95e32a555 Merge tag 'loongarch-6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/chenhuacai/linux-loongson 815e38060bf4 Merge tag 'sound-fix-6.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound f07a1b362766 Merge tag 'for-v6.8-v2' of git://git.kernel.org/pub/scm/linux/kernel/git/sre/linux-power-supply 9411a3099e9c Merge tag 'i2c-for-6.8-rc1-rebased' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux fcb7108dc362 Merge tag 'rtc-6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/abelloni/linux 8e06ce5908ff Merge tag 'input-for-v6.8-rc0' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input 7b18579c0bef Merge tag 'phy-for-6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/phy/linux-phy dd4871a00012 Merge tag 'gpio-fixes-for-v6.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/brgl/linux 8dfd2acd2c0c Merge tag 'backlight-next-6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/backlight 736ecd5cf03c Merge tag 'iommu-updates-v6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu 7d29a06cb311 dt-bindings: i2c: document st,stm32mp25-i2c compatible 365a95704e98 dt-bindings: at24: add ROHM BR24G04 05d2a9834fd6 Merge tag 'usb-6.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb 70a7bee43907 Merge tag 'tty-6.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty 6a04bf7a4f07 Merge tag 'char-misc-6.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc e0c35697cd80 Merge tag 'pci-v6.8-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/pci/pci cf29a14b0a23 Merge tag 'pinctrl-v6.8-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl 902219ef9ed0 Merge tag 'mailbox-v6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/jassibrar/mailbox c437f65015a8 Merge tag 'leds-next-6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/leds d0902d05b4a0 Merge tag 'mfd-next-6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd 8be1d4636d32 Merge tag 'rproc-v6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/remoteproc/linux 6eaaddf12639 Merge tag 'riscv-for-linus-6.8-mw1' of git://git.kernel.org/pub/scm/linux/kernel/git/riscv/linux 2cb012b6fe68 LoongArch: dts: DeviceTree for Loongson-2K2000 6ab0a6f08b83 LoongArch: dts: DeviceTree for Loongson-2K1000 491426707de1 LoongArch: dts: DeviceTree for Loongson-2K0500 c007f27059d1 dt-bindings: interrupt-controller: loongson,liointc: Fix dtbs_check warning for interrupt-names d9a3ae336ecb dt-bindings: interrupt-controller: loongson,liointc: Fix dtbs_check warning for reg-names 4ee19a9d7583 dt-bindings: loongarch: Add Loongson SoC boards compatibles 3e99ee3f7c53 dt-bindings: loongarch: Add CPU bindings for LoongArch e8bc7c9c625e dt-bindings: don't anchor DT_SCHEMA_FILES to bindings directory f5918b47370e dt-bindings: rtc: max31335: add max31335 bindings 7e34d7b53615 rtc: rv8803: add wakeup-source support 81d186f05921 Merge branch 'pci/dt-bindings' 8bd798490681 Merge branch 'pci/controller/rcar' e166e5aad3b0 Merge branch 'pci/controller/cadence' 9de355a75fde dt-bindings: gpio: xilinx: Fix node address in gpio 28bf1e4e9775 dt-bindings: mailbox: qcom-ipcc: document the X1E80100 Inter-Processor Communication Controller f6b31bdd3c60 dt-bindings: mailbox: add Versal IPI bindings c3301d070937 dt-bindings: mailbox: zynqmp: extend required list 6bf977408719 dt-bindings: mailbox: qcom,apcs-kpss-global: use fallbacks b9ea63718a7e dt-bindings: mailbox: qcom,apcs-kpss-global: drop duplicated qcom,ipq8074-apcs-apps-global e485b251a3a4 Merge tag 'devicetree-for-6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux 60edd8755b1b Merge tag 'pwm/for-6.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/thierry.reding/linux-pwm f946a0610062 Merge tag 'hid-for-linus-2024010801' of git://git.kernel.org/pub/scm/linux/kernel/git/hid/hid 5a9222178c60 Merge tag 'media/v6.8-2' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media 0c57fa00ac11 Merge tag 'mmc-v6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/ulfh/mmc 120152dd192c Merge tag 'pmdomain-v6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/ulfh/linux-pm f25acec1f182 Merge tag 'gnss-6.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/johan/gnss 040b6611cd72 Merge tag 'clk-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/clk/linux 432f2b929aa4 Merge tag 'gpio-updates-for-v6.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/brgl/linux 5df1a59e6086 Merge tag 'linux-watchdog-6.8-rc1' of git://www.linux-watchdog.org/linux-watchdog 1d81fba29be6 Merge tag 'hwmon-for-v6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging dd7110d3d5d1 Merge tag 'sound-6.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound c916bd7a1d38 Merge tag 'drm-next-2024-01-10' of git://anongit.freedesktop.org/drm/drm 32704b03c7ec Merge tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi c0d1d21fe5ff dt-bindings: fpga: altera: Convert bridge bindings to yaml 86986ec77fc7 dt-bindings: fpga: Convert bridge binding to yaml 149beabce38e dt-bindings: vendor-prefixes: Add smi da831df01407 Merge tag 'soc-drivers-6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/soc/soc d0949aef9e29 Merge tag 'soc-dt-6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/soc/soc c5ee04d9a430 Merge tag 'net-next-6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/netdev/net-next 17d4b2f2c7c6 dt-bindings: riscv: Document cbop-block-size 6361e08793d7 dt-bindings: riscv: permit numbers in "riscv,isa" 99f0fa81f51f dt-bindings: riscv: cpus: Clarify mmu-type interpretation 5744984c407c ARM: dts: usr8200: Fix phy registers fd6e692990ee dt-bindings: PCI: brcmstb: Add property "brcm,clkreq-mode" db07ea081cee dt-bindings: power: Clarify wording for wakeup-source property 9deb5d7e7649 Merge tag 'v6.8-p1' of git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6 f412e763e552 dt-bindings: mfd: sprd: Add support for UMS9620 b50b2489e1a2 dt-bindings: input: bindings for Adafruit Seesaw Gamepad 9fcf5401177c Merge patch series "riscv: hwprobe: add Zicond, Zacas and Ztso support" 6b479ffcb9ed dt-bindings: riscv: add Zacas ISA extension description 45e895d242d0 Merge remote-tracking branch 'palmer/fixes' into for-next 129abc9e5b89 Merge tag 'thermal-6.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm 72e795875f31 Merge tag 'mtd/for-6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/mtd/linux a0d6ec02f5dd Merge tag 'spi-v6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi 092d72f89f32 Merge tag 'regulator-v6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator f19bbcb501a1 Merge branch 'clk-rs9' into clk-next 6c5ff3361f38 Merge branches 'clk-zynq', 'clk-xilinx' and 'clk-stm' into clk-next 5348f28123c3 Merge branches 'clk-imx', 'clk-qcom', 'clk-amlogic' and 'clk-mediatek' into clk-next dde8a0d89600 Merge branches 'clk-versa', 'clk-silabs', 'clk-samsung', 'clk-starfive' and 'clk-sophgo' into clk-next 147299598f64 dt-bindings: ignore paths outside kernel for DT_SCHEMA_FILES 5e8ad2415574 dt-bindings: tpm: Document Microsoft fTPM bindings 4446def763e6 dt-bindings: tpm: Convert IBM vTPM bindings to DT schema d46251bba773 dt-bindings: tpm: Convert Google Cr50 bindings to DT schema 4c0c46fcf77f dt-bindings: tpm: Consolidate TCG TIS bindings fc825b2e9d71 dt-bindings: display: rockchip,inno-hdmi: Document RK3128 compatible 5d51cf126484 dt-bindings: arm: Add remote etm dt-binding 32c458bd3442 dt-bindings: mmc: sdhci-pxa: Fix 'regs' typo c9ab453dff7c media: dt-bindings: samsung,s5p-mfc: Fix iommu properties schemas 481554b6b752 dt-bindings: display: panel: Add synaptics r63353 panel controller e04e21bef16e dt-bindings: arm: merge qcom,idle-state with idle-state 452e35e6ff26 Merge tag 'irq-core-2024-01-08' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip d35742374b96 dt-bindings: display: samsung,exynos-mixer: Fix 'regs' typo ac8ffc6d0764 Merge tag 'arm64-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux daf5be0b133e Merge tag 'powerpc-6.8-1' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux b633610fad05 Revert "net: stmmac: Enable Per DMA Channel interrupt" fc2b6856183b dt-bindings: rtc: qcom-pm8xxx: fix inconsistent example 5c111c61a49a dt-bindings: net: snps,dwmac: per channel irq 94d319464237 ASoC: dt-bindings: move tas2563 from tas2562.yaml to tas2781.yaml 8fbbcaccc3ff Merge tag 'socfpga_dts_updates_for_v6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/dinguyen/linux into soc/dt 1161aaee27ae dt-bindings: mmc: add Marvell ac5 e9a747531a5d dt-bindings: mmc: brcm,sdhci-brcmstb: Add support for 74165b0 57b4e3b1199f Merge git://git.kernel.org/pub/scm/linux/kernel/git/netdev/net cab393f5e80d dt-bindings: serial: Describe ARM dcc interface 1d92607a561e dt-bindings: usb: dwc3: Limit num-hc-interrupters definition cee9797861a0 dt-bindings: usb: xhci: Add num-hc-interrupters definition 4823f8dd230f arm64: dts: mediatek: mt8195: Add 'rx-fifo-depth' for cherry 4a4f48930e20 dt-bindings: usb: mtk-xhci: add a property for Gen1 isoc-in transfer issue 4ddd871b77e8 arm64: dts: qcom: msm8996: Remove PNoC clock from MSS 5598c7c58459 arm64: dts: qcom: msm8996: Remove AGGRE2 clock from SLPI a06133f3b90d arm64: dts: qcom: msm8998: Remove AGGRE2 clock from SLPI 0e31729b965a arm64: dts: qcom: msm8939: Drop RPM bus clocks a9231f1fa44d arm64: dts: qcom: sdm630: Drop RPM bus clocks 7806d0946f48 arm64: dts: qcom: qcs404: Drop RPM bus clocks 6bbd4a339ffd arm64: dts: qcom: msm8996: Drop RPM bus clocks 6c5785d4dec0 arm64: dts: qcom: msm8916: Drop RPM bus clocks d99558e0d6ba dt-bindings: usb: qcom,dwc3: Fix SDM660 clock description 0e7834fa9ba2 dt-bindings: usb: dwc3: Clean up hs_phy_irq in binding f7405c1062e5 dt-bindings: connector: Add child nodes for multiple PD capabilities a2f2b957f7b0 arm64: dts: intel: minor whitespace cleanup around '=' a21ad91a14ac arm64: dts: socfpga: agilex: drop redundant status c64326a0161d arm64: dts: socfpga: agilex: add unit address to soc node 70eea150a8db arm64: dts: socfpga: agilex: move firmware out of soc node 056acfded5ce arm64: dts: socfpga: agilex: move FPGA region out of soc node 8e373ef160c7 arm64: dts: socfpga: agilex: align pin-controller name with bindings 56a65e118b36 arm64: dts: socfpga: stratix10_swvp: drop unsupported DW MSHC properties 5ea405da6608 arm64: dts: socfpga: stratix10_socdk: align NAND chip name with bindings 0bc2b8deec9a arm64: dts: socfpga: stratix10: add unit address to soc node 3932c6fc63c2 arm64: dts: socfpga: stratix10: move firmware out of soc node 174dfac57ae2 arm64: dts: socfpga: stratix10: move FPGA region out of soc node e63c11b1c86c arm64: dts: socfpga: stratix10: align pincfg nodes with bindings 5ad3116fb135 arm64: dts: socfpga: stratix10: add clock-names to DWC2 USB 9185b800f9c3 arm64: dts: socfpga: drop unsupported cdns,page-size and cdns,block-size b3832f4d101c ARM: dts: socfpga: align NAND controller name with bindings 7772fcc4eef4 ARM: dts: socfpga: drop unsupported cdns,page-size and cdns,block-size f466442c93ff dt-bindings: clock: mediatek: add clock controllers of MT7988 967ed08fdbd4 dt-bindings: reset: mediatek: add MT7988 ethwarp reset IDs 8bb435f3ea7d dt-bindings: clock: mediatek: add MT7988 clock IDs 8b8c659b2121 dt-bindings: clock: sophgo: Add clock controller of CV1800 series SoC b822e804fd2c dt-bindings: gpio: add NPCM sgpio driver bindings f4c19e862d2b dt-bindings: gpio: realtek: Add realtek,rtd-gpio 6690161ed7a9 Merge branches 'apple/dart', 'arm/rockchip', 'arm/smmu', 'virtio', 'x86/vt-d', 'x86/amd' and 'core' into next 7382fa53a648 dt-bindings: net: renesas,etheravb: Document RZ/G3S support 247b8886892f dt-bindings: hwmon: (lm75) Add AMS AS6200 temperature sensor fec847c57a81 dt-bindings: Add MP2856/MP2857 voltage regulator device 42c42ff6c177 dt-bindings: hwmon: gpio-fan: Convert txt bindings to yaml 6c13c9d07051 dt-bindings: mmc: sdhci-msm: document dedicated IPQ4019 and IPQ8074 1e934476b96c dt-bindings: mmc: synopsys-dw-mshc: add iommus for Intel SocFPGA 82a434279c9e dt-bindings: HID: i2c-hid: elan: Introduce Ilitek ili2901 5fa4567d6c4f Merge tag 'v6.8-rockchip-dts32-2' of git://git.kernel.org/pub/scm/linux/kernel/git/mmind/linux-rockchip into soc/dt a04786e0b7e0 Merge tag 'v6.8-rockchip-dts64-2' of git://git.kernel.org/pub/scm/linux/kernel/git/mmind/linux-rockchip into soc/dt 0bf9a2425459 Merge tag 'qcom-arm64-for-6.8-2' of https://git.kernel.org/pub/scm/linux/kernel/git/qcom/linux into soc/dt a3fde0732d5b Merge tag 'qcom-arm32-for-6.8-2' of https://git.kernel.org/pub/scm/linux/kernel/git/qcom/linux into soc/dt 62073621d812 Merge tag 'arm-soc/for-6.8/devicetree' of https://github.com/Broadcom/stblinux into soc/dt 4cfe8fd4e2b4 Merge tag 'sprd-dt-6.8-rc1' of https://github.com/lyrazhang/linux into soc/dt a355b8e8cbdd dt-bindings: thermal: qcom-spmi-adc-tm5/hc: Clean up examples 36a030b546d0 dt-bindings: thermal: qcom-spmi-adc-tm5/hc: Fix example node names ca1c0a8c8091 dt-bindings: thermal: sun8i: Add binding for D1/T113s THS controller 7123707b90de dt-bindings: thermal-zones: Document critical-action c29ec9b83fd7 dt-bindings: thermal: qcom-tsens: document the SM8650 Temperature Sensor 5a12787401b5 dt-bindings: thermal: loongson,ls2k-thermal: Fix binding check issues 0a6d923c5231 dt-bindings: thermal: convert Mediatek Thermal to the json-schema dc5dd3862b77 dt-bindings: input: iqs269a: Add bindings for OTP variants 5aa00301cee3 dt-bindings: input: iqs269a: Add bindings for slider gestures c4635c803af3 Merge tag 'iio-for-6.8b' of https://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into char-misc-next 571d91b8d8df arm64: dts: rockchip: Fix led pinctrl of lubancat 1 548cbdf62c21 arm64: dts: rockchip: correct gpio_pwrctrl1 typo on nanopc-t6 86c28823371d arm64: dts: rockchip: correct gpio_pwrctrl1 typo on rock-5b 275bc737b480 arm64: dts: rockchip: support poweroff on the rock-5b e4f7332bb7f8 arm64: dts: rockchip: Support poweroff on Orange Pi 5 d0c46aeba839 arm64: dts: rockchip: nanopc-t6 sdmmc beautification df73c00bc509 arm64: dts: sprd: Change UMS512 idle-state nodename to match bindings 12243eba2b74 arm64: dts: sprd: Add clock reference for pll2 on UMS512 af72bfcc73f3 arm64: dts: sprd: Removed unused clock references from etm nodes d8f5562e697b arm64: dts: sprd: Add support for Unisoc's UMS9620 bd8f67f82f65 dt-bindings: arm: Add compatible strings for Unisoc's UMS9620 9da3db96fae0 arm64: dts: sprd: fix the cpu node for UMS512 3ebc08960525 Merge tag 'v6.7-rc7' into gpio/for-next cb90fcbed71e dt-bindings: timer: Add StarFive JH8100 clint 6f2b19f4df72 dt-bindings: timer: thead,c900-aclint-mtimer: separate mtime and mtimecmp regs 4421b3e3124f dt-bindings: iio: Add AD7091R-8 51a0454cffd6 dt-bindings: power: supply: bq24190: Add BQ24296 compatible 4639caeeab2f dt-bindings: power: reset: xilinx: Rename node names in examples c873132667ed dt-bindings: power: reset: qcom-pon: fix inconsistent example 64cf7a912b11 arm64: dts: rockchip: Fix rk3588 USB power-domain clocks 815a2542ad42 arm64: dts: rockchip: configure eth pad driver strength for orangepi r1 plus lts 9df823a6207b arm64: dts: rockchip: Support poweroff on NanoPC-T6 78bd00069022 arm64: dts: rockchip: rk3308-rock-pi-s gpio-line-names cleanup 9d6e0741ae7c arm64: dts: rockchip: Add support for rk3588 based board Cool Pi CM5 EVB a64a2e009e21 dt-bindings: arm: rockchip: Add Cool Pi CM5 4397d62daec8 arm64: dts: rockchip: Add support for rk3588s based board Cool Pi 4B f1a9c321e26f dt-bindings: arm: rockchip: Add Cool Pi 4B 1e413c69529f dt-bindings: vendor-prefixes: Add Cool Pi a67ded35095e arm64: dts: rockchip: add gpio-line-names to rk3328-rock-pi-e e0ec5767b690 ARM: dts: rockchip: Remove rockchip,default-sample-phase from rk3036.dtsi 75e0afe6681c ARM: dts: rockchip: Add stdout-path for rk3036 kylin 5b38dc06a1e9 dt-bindings: watchdog: qcom,pm8916-wdt: add parent spmi node to example d2f78877f2ea dt-bindings: watchdog: nxp,pnx4008-wdt: convert txt to yaml af1fdc5cd02d dt-bindings: watchdog: qca,ar7130-wdt: convert txt to yaml 5c3d9631b9ac dt-bindings: watchdog: intel,keembay: reference common watchdog schema 6d86f883fd9c dt-bindings: watchdog: re-order entries to match coding convention e28051167c06 dt-bindings: touchscreen: neonode,zforce: Use standard properties 3119a224ac1c dt-bindings: touchscreen: convert neonode,zforce to json-schema 15bf36928144 Merge tag 'icc-6.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/djakov/icc into char-misc-next dd37eb39a550 dt-bindings: input: convert drv266x to json-schema 795f4eddfec7 Merge tag 'qcom-arm64-for-6.8' of https://git.kernel.org/pub/scm/linux/kernel/git/qcom/linux into soc/dt 991ab34b2120 Merge tag 'reset-for-v6.8' of git://git.pengutronix.de/pza/linux into soc/drivers 4e7b4659bc67 dt-bindings: mtd: partitions: u-boot: Fix typo 35dd951a7fd5 Merge tag 'riscv-cache-for-v6.8' of https://git.kernel.org/pub/scm/linux/kernel/git/conor/linux into soc/drivers 69b18d58cc6d Merge tag 'riscv-soc-drivers-for-v6.8' of https://git.kernel.org/pub/scm/linux/kernel/git/conor/linux into soc/drivers fc5aa9bf69fd Merge tag 'samsung-drivers-6.8' of https://git.kernel.org/pub/scm/linux/kernel/git/krzk/linux into soc/drivers 84c9739eb5b5 Merge tag 'qcom-drivers-for-6.8' of https://git.kernel.org/pub/scm/linux/kernel/git/qcom/linux into soc/drivers 0ef14d7a1f46 dt-bindings: crypto: qcom-qce: document the SC7280 crypto engine 2fd8394e6d9f dt-bindings: crypto: qcom-qce: constrain clocks for SM8150-compatible QCE 40fd9d4f3234 dt-bindings: crypto: qcom-qce: constrain clocks for IPQ9574 QCE 30960ac02d6e dt-bindings: rng: starfive: Add jh8100 compatible string e6272a79f69c Merge git://git.kernel.org/pub/scm/linux/kernel/git/netdev/net dcd8ac1c5dd8 dt-bindings: spi: stm32: add st,stm32mp25-spi compatible 87166d1d3f3f Merge tag 'riscv-dt-for-v6.8' of https://git.kernel.org/pub/scm/linux/kernel/git/conor/linux into soc/dt 69abc2365d38 dt-bindings: phy: qcom,sc8280xp-qmp-usb3-uni: Add X1E80100 USB PHY binding 822a13d2bf90 dt-bindings: phy: qcom,sc8280xp-qmp-usb43dp-phy: Document X1E80100 compatible 6722c7fe2a57 dt-bindings: phy: qcom: snps-eusb2: Document the X1E80100 compatible a38a399bccf1 dt-bindings: phy: mediatek: tphy: add a property for force-mode switch ca521e2ecf25 dt-bindings: phy: qcom,sc8280xp-qmp-usb43dp-phy: fix path to header aa156a9707ec Merge tag 'amlogic-arm64-dt-for-v6.8' of https://git.kernel.org/pub/scm/linux/kernel/git/amlogic/linux into soc/dt e6127e00f352 Merge tag 'mvebu-dt64-6.8-1' of git://git.kernel.org/pub/scm/linux/kernel/git/gclement/mvebu into soc/dt aad08c0a0671 Merge tag 'mvebu-dt-6.8-1' of git://git.kernel.org/pub/scm/linux/kernel/git/gclement/mvebu into soc/dt e4320c558711 Merge tag 'samsung-dt64-6.8-2' of https://git.kernel.org/pub/scm/linux/kernel/git/krzk/linux into soc/dt 077793e138f6 Merge tag 'qcom-arm32-for-6.8' of https://git.kernel.org/pub/scm/linux/kernel/git/qcom/linux into soc/dt 7ff5e1692425 Merge tag 'ti-k3-dt-for-v6.8' of https://git.kernel.org/pub/scm/linux/kernel/git/ti/linux into soc/dt f009c98b2a3f dt-bindings: iio: dac: add MCP4821 e46c2c536959 Merge tag 'ti-keystone-dt-for-v6.8' of https://git.kernel.org/pub/scm/linux/kernel/git/ti/linux into soc/dt edeab43af36b Merge tag 'zynqmp-dt-for-6.8' of https://github.com/Xilinx/linux-xlnx into soc/dt 4e78ad68f722 Merge tag 'imx-dt64-6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux into soc/dt f4ece4b3d883 Merge tag 'imx-dt-6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux into soc/dt 1a2b6b1db701 Merge tag 'imx-bindgins-6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux into soc/dt 71e20fbc3d5b Merge tag 'ux500-dts-soc-for-v6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-integrator into soc/dt 056c9efa37c5 Merge tag 'renesas-dts-for-v6.8-tag2' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/renesas-devel into soc/dt 339491d0999f Merge tag 'stm32-dt-for-v6.8-1' of git://git.kernel.org/pub/scm/linux/kernel/git/atorgue/stm32 into soc/dt 06086605676a dt-bindings: dma: fsl-edma: Add fsl-edma.h to prevent hardcoding in dts 640904451ab8 dt-bindings: dmaengine: Add Loongson LS2X APB DMA controller f88d59ec5d12 Merge tag 'sunxi-dt-for-6.8-1' of https://git.kernel.org/pub/scm/linux/kernel/git/sunxi/linux into soc/dt e833ff47f9b9 Merge tag 'at91-dt-6.8' of https://git.kernel.org/pub/scm/linux/kernel/git/at91/linux into soc/dt 9f821c027b01 Merge tag 'juno-update-6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/sudeep.holla/linux into soc/dt 4bab8a451f49 Merge tag 'v6.8-rockchip-dts32-1' of git://git.kernel.org/pub/scm/linux/kernel/git/mmind/linux-rockchip into soc/dt a4789dd06449 Merge tag 'v6.8-rockchip-dts64-1' of git://git.kernel.org/pub/scm/linux/kernel/git/mmind/linux-rockchip into soc/dt 5045526f0b7c Merge tag 'mtk-dts64-for-v6.8' of https://git.kernel.org/pub/scm/linux/kernel/git/mediatek/linux into soc/dt a7603f8260b8 Merge tag 'samsung-dt-6.8' of https://git.kernel.org/pub/scm/linux/kernel/git/krzk/linux into soc/dt 16a1d6e0b098 Merge tag 'samsung-dt64-6.8' of https://git.kernel.org/pub/scm/linux/kernel/git/krzk/linux into soc/dt 0f1f66f39700 ARM: dts: ste: minor whitespace cleanup around '=' 22532c5d3f4a Merge tag 'omap-for-v6.8/dt-signed' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into soc/dt 5288e13a2ad4 Merge tag 'hisi-arm64-dt-for-6.8' of https://github.com/hisilicon/linux-hisi into soc/dt f44f238cabce Merge tag 'w1-drv-6.8' of https://git.kernel.org/pub/scm/linux/kernel/git/krzk/linux-w1 into char-misc-next 61f41fa45eaf Merge tag 'iio-for-6.8a' of https://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into char-misc-next 07d575b06ff9 dt-bindings: pwm: ti,pwm-omap-dmtimer: Update binding for yaml fc02de1f5dc0 dt-bindings: riscv: cpus: Add AMD MicroBlaze V compatible 780449a81d3c dt-bindings: pwm: remove Xinlei's mail f96dd7edb887 arm64: dts: qcom: sc8180x: Fix up PCIe nodes b1ecf20e17e0 arm64: dts: qcom: sc8180x: Mark PCIe hosts cache-coherent eeed8f113289 dt-bindings: pinctrl: xilinx: Rename *gpio to *gpio-grp 2ef9211e8711 dt-bindings: pinctrl: qcom: drop common properties and allow wakeup-parent 188c161805d3 dt-bindings: pinctrl: qcom: drop common properties 7834682c0d2c dt-bindings: pinctrl: qcom,ipq5018-tlmm: use common TLMM bindings c31ea3c9600f dt-bindings: pinctrl: qcom,x1e80100-tlmm: restrict number of interrupts 6cec6f6f090c dt-bindings: pinctrl: qcom,sm8650-tlmm: restrict number of interrupts ef7b1c134921 dt-bindings: pinctrl: qcom,sm8550-tlmm: restrict number of interrupts a3abecdd0e2e dt-bindings: pinctrl: qcom,sdx75-tlmm: restrict number of interrupts 2b1d1c0dd621 dt-bindings: pinctrl: qcom,sa8775p-tlmm: restrict number of interrupts 36f8bb953634 dt-bindings: pinctrl: qcom,qdu1000-tlmm: restrict number of interrupts 670ced18d87f dt-bindings: pinctrl: qcom: create common LPASS LPI schema 5ca197c58799 dt-bindings: pinctrl: qcom: Add SM4450 pinctrl 8d27a131f7ad dt-bindings: pinctrl: qcom,pmic-mpp: clean up example 6674c2217ce1 Merge tag 'mediatek-drm-next-6.8' of https://git.kernel.org/pub/scm/linux/kernel/git/chunkuang.hu/linux into drm-next d7dde4a72dfa Merge tag 'drm-msm-next-2023-12-15' of https://gitlab.freedesktop.org/drm/msm into drm-next 64ddcb330a18 arm64: dts: qcom: x1e80100-qcp: Fix supplies for some LDOs in PM8550 206ab99c38ce arm64: dts: qcom: sm8550: Update idle state time requirements 319f395fbc2a arm64: dts: qcom: sm8550: Separate out X3 idle state af2f75b56294 ARM: dts: qcom: sdx55: Fix the base address of PCIe PHY 4a72661b117b arm64: dts: qcom: ipq6018: fix clock rates for GCC_USB0_MOCK_UTMI_CLK 5b72e989a37a arm64: dts: qcom: x1e80100: align mem timer size cells with bindings b17d7383c10f arm64: dts: qcom: sc7280: Mark SDHCI hosts as cache-coherent 3840ead2163a ARM: dts: qcom: sdx55: fix USB SS wakeup 9e773fad2487 ARM: dts: qcom: sdx55: fix USB DP/DM HS PHY interrupts d0728def7588 ARM: dts: qcom: sdx55: fix pdc '#interrupt-cells' 0ee9dac79d46 ASoC: qcom: add sound card support for SM8650 345b970f1857 add es8326 dt-bindings, commonize headset codec 85a45459eeed GPIO inclusion fixes to misc sound drivers 616e88e1109d arm64: dts: qcom: sc8180x: fix USB SS wakeup f3d1b2acf659 arm64: dts: qcom: sdm670: fix USB SS wakeup 987f42804a25 arm64: dts: qcom: sdm670: fix USB DP/DM HS PHY interrupts 2e58236aa851 ASoC: dt-bindings: qcom,lpass-va-macro: remove spurious contains in if statement bded77d8cc7b dt-bindings: regulator: qcom,usb-vbus-regulator: clean up example e1481a467961 powerpc/fsl: Fix fsl,tmu-calibration to match the schema 26e2fad496d4 arm64: dts: amlogic: fix format for s4 uart node 8a5115be3855 arm64: dts: amlogic: drop redundant status=okay 799049c22bf2 arm64: dts: amlogic: enable some nodes for board AQ222 3fea93dcdd73 arm64: dts: amlogic: add some device nodes for S4 44721ac7f4da Merge tag 'drm-misc-next-2023-12-14' of git://anongit.freedesktop.org/drm/drm-misc into drm-next d623bb97a280 Merge tag 'samsung-pinctrl-6.8' of https://git.kernel.org/pub/scm/linux/kernel/git/pinctrl/samsung into devel 81d84dd62616 ASoC: dt-bindings: qcom,lpass-rx-macro: Add X1E80100 LPASS WSA 4f673348bd77 ASoC: dt-bindings: qcom,lpass-rx-macro: Add X1E80100 LPASS VA d5b1bc404268 ASoC: dt-bindings: qcom,lpass-rx-macro: Add X1E80100 LPASS TX 40420db77069 ASoC: dt-bindings: qcom,lpass-rx-macro: Add X1E80100 LPASS RX 605001444f21 ASoC: dt-bindings: qcom,sm8250: Add X1E80100 sound card 4e179f2c3905 ASoC: dt-bindings: mt8188-mt6359: add es8326 support 0c819517fcb2 ASoC: dt-bindings: qcom,sm8250: document SM8650 sound card 0292b51ac8c4 ASoC: tegra: tegra20_ac97: Convert to use GPIO descriptors 4c6bc6503e5e Merge tag 'device_is_big_endian-6.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core into gpio/for-next 31d8096d43a1 dt-bindings: gpio: dwapb: allow gpio-ranges 873d4c02bbfa dt-bindings: clock: google,gs101: rename CMU_TOP gate defines bfc73914844a dt-bindings: clock: si5351: add PLL reset mode property af0493badd9d dt-bindings: clock: si5351: convert to yaml d1a5fb288be1 dt-bindings: stm32: add clocks and reset binding for stm32mp25 platform ee353e29bfb4 dt-bindings: clk: rs9: Add 9FGV0841 48b20705829d dt-bindings: clock: brcm,kona-ccu: convert to YAML b2b282bb3ba9 dt-bindings: arm: mediatek: move ethsys controller & convert to DT schema e35ce136c12f dt-bindings: clock: xilinx: add versal compatible 746818ace7a3 dt-bindings: rtc: Add Nuvoton ma35d1 rtc d8c717fd9bc8 dt-bindings: Remove alt_ref from versal e9caccbf099c arm64: dts: qcom: sc8180x-primus: Allow UFS regulators load/mode setting b616df631790 arm64: dts: qcom: sc8180x: Describe the GIC redistributor ae7e39a80f0f arm64: dts: qcom: sc8180x: Add interconnects to UFS 0f32e7aa54e0 arm64: dts: qcom: sc8180x: Add missing MDP clocks 3641f17d731d arm64: dts: qcom: sc8180x: Add UFS GDSC 2bbb23973697 arm64: dts: qcom: sc7280*: move MPSS and WPSS memory to dtsi a5b4605b6fc6 ARM: dts: qcom: msm8974*: Re-enable remoteprocs on various boards f1ecb44efc55 ARM: dts: qcom: msm8974: Remove bogus cd-gpio pinctrl 9dd85d38d004 ARM: dts: qcom: msm8974-klte: Remove unused property 34c2fdcebf94 arm64: dts: qcom: sc7280: Rename reserved-memory nodes 84a50703ca7d dt-bindings: remoteproc: qcom: sc7180-pas: Add SC7280 compatibles 47f83514132e dt-bindings: remoteproc: qcom: sc7180-pas: Fix SC7280 MPSS PD-names 1dce719ef64f arm64: dts: qcom: sc7280: Remove unused second MPSS reg afedac693f18 arm64: dts: qcom: sdm670: add display subsystem 1d8d2d147ea5 dt-bindings: soc: qcom,aoss-qmp: document the X1E80100 Always-On Subsystem side channel 3ea56a52a7c2 dt-bindings: wdt: Add ts72xx 18522cdf3ec6 dt-bindings: watchdog: dlg,da9062-watchdog: Document DA9063 watchdog 688fe0bdd724 dt-bindings: watchdog: dlg,da9062-watchdog: Add fallback for DA9061 watchdog 9054003bb13e dt-bindings: watchdog: mediatek,mtk-wdt: add MT7988 watchdog and toprgu 63d466a6e3b3 dt-bindings: watchdog: realtek,rtd1295-watchdog: convert txt to yaml 5b6c41392896 dt-bindings: watchdog: qcom-wdt: Make the interrupt example edge triggered 4f8423c375eb dt-bindings: iio: chemical: add aosong,ags02ma 766801c2fc4b dt-bindings: vendor-prefixes: add aosong 530dcc2cff54 arm64: dts: qcom: sm8150-hdk: enable DisplayPort and USB-C altmode a63d7ac5c9ca arm64: dts: qcom: sm8150: add USB-C ports to the OTG USB host 6177bf5ba3b4 arm64: dts: qcom: sm8150: add USB-C ports to the USB+DP QMP PHY cccb449ab331 arm64: dts: qcom: sm8150: add DisplayPort controller 414013ad4921 arm64: dts: qcom: sm8150-hdk: fix SS USB regulators 94e5a8422a14 arm64: dts: qcom: sm8150-hdk: enable HDMI output 94cd2b0ff062 arm64: dts: qcom: sm8150: make dispcc cast minimal vote on MMCX d8577fce5e20 arm64: dts: qcom: sm8650: add fastrpc-compute-cb nodes e14f9c1044bd arm64: dts: qcom: sm8550-qrd: add PM8010 regulators 66e97e0962a7 arm64: dts: qcom: sm8550-mtp: Add pm8010 regulators 6437200479ec arm64: dts: qcom: qcm2290: Hook up MPM 75b87eb7e3ee arm64: dts: qcom: msm8996: Hook up MPM e043072a3a33 arm64: dts: qcom: sm6375: Hook up MPM 623a6180066f dt-bindings: arm: qcom: Add Motorola Moto G 4G (2013) 030e5c73208a arm64: dts: qcom: x1e80100-crd: Fix supplies for some LDOs in PM8550 58e87053c1f0 arm64: dts: qcom: sc7280: add QCrypto nodes 6d138c9b4127 arm64: dts: qcom: sc7180: Switch pompom to the generic edp-panel 9248e79cd654 arm64: dts: qcom: sm8150: fix USB SS wakeup 8143f0f67202 arm64: dts: qcom: sm8150: fix USB DP/DM HS PHY interrupts 1d46c82d351b arm64: dts: qcom: sdm845: fix USB SS wakeup 5c261eb8cd11 arm64: dts: qcom: sdm845: fix USB DP/DM HS PHY interrupts 2998fdbc15fe arm64: dts: qcom: sc8180x: fix USB DP/DM HS PHY interrupts 220ee261025f arm64: dts: qcom: sm8550: drop unneeded assigned-clocks from codec macros ef2823c0a498 arm64: dts: qcom: sm8550: move Soundwire pinctrl to its nodes 611112fa3972 arm64: dts: qcom: sm8450: drop unneeded assigned-clocks from codec macros 7fe6ee08b28c arm64: dts: qcom: sm8450: move Soundwire pinctrl to its nodes eb6e95625c03 arm64: dts: qcom: sm8550: add missing two RX Soundwire ports in configuration 6f45533e32ad arm64: dts: qcom: sm8650: drop unneeded assigned-clocks from WSA macro 108c60eb7746 dt-bindings: arm: qcom: Fix up htc-memul compatible c493fe546f0a arm64: dts: qcom: sm6115: Hook up interconnects fd22f3a58a9e Merge branch 'icc-sm6115' of https://git.kernel.org/pub/scm/linux/kernel/git/djakov/icc into HEAD 85a531800a07 ARM: dts: qcom: msm8926-motorola-peregrine: Add initial device tree 9c323b20cda8 ARM: dts: qcom: ipq4019: add dedicated SDHCI compatible 2fcaa70bfc3c arm64: dts: qcom: ipq8074: add dedicated SDHCI compatible 757c981838e3 arm64: dts: qcom: Fix coresight warnings in in-ports and out-ports 34e4f27862d1 arm64: dts: qcom: msm8998: Fix 'out-ports' is a required property 61e7df01e058 arm64: dts: qcom: msm8996: Fix 'in-ports' is a required property 786be94e8465 arm64: dts: qcom: qrb5165-rb5: add the Bluetooth node fe9d727180d2 arm64: dts: qcom: sa8775p: Add missing space between node name and braces 8df2548eb151 arm64: dts: qcom: Use "pcie" as the node name instead of "pci" 756ec289cf35 ARM: dts: qcom: Use "pcie" as the node name instead of "pci" 2066a55949a7 arm64: dts: qcom: acer-aspire1: Add sound 90485d1f88ce arm64: dts: qcom: acer-aspire1: Correct audio codec definition 3d97796b14f9 arm64: dts: qcom: acer-aspire1: Enable RTC 5d870a6a209b arm64: dts: qcom: sm8450: switch UFS QMP PHY to new style of bindings 1e57f262d57c arm64: dts: qcom: sm8350: switch UFS QMP PHY to new style of bindings 731a9974488a arm64: dts: qcom: sm8250: switch UFS QMP PHY to new style of bindings 8a512baad9fa arm64: dts: qcom: sm8150: switch UFS QMP PHY to new style of bindings 9c4063711b1f arm64: dts: qcom: sm6350: switch UFS QMP PHY to new style of bindings 79c130d88048 arm64: dts: qcom: sm6115: switch UFS QMP PHY to new style of bindings 65d88afa8518 arm64: dts: qcom: sdm845: switch UFS QMP PHY to new style of bindings fa34450ebcf9 arm64: dts: qcom: msm8998: switch UFS QMP PHY to new style of bindings 2d00768d0566 arm64: dts: qcom: msm8996: switch UFS QMP PHY to new style of bindings 6d501541ab8b arm64: dts: qcom: sm8450-hdk: Enable the A730 GPU 9999a06044c2 arm64: dts: qcom: sm8550-mtp: Enable the A740 GPU 1c8862cd1be0 arm64: dts: qcom: sm8550-qrd: Enable the A740 GPU db2dd74a4321 arm64: dts: qcom: sm8550: Add GPU nodes 41411e46e180 arm64: dts: qcom: sm8450: Add GPU nodes 67082abed4d1 arm64: dts: qcom: msm8939: Make blsp_dma controlled-remotely b0768548dacf arm64: dts: qcom: msm8916: Make blsp_dma controlled-remotely e529c8cd00c4 arm64: dts: qcom: msm8939: Add clock-frequency for broadcast timer dc95d696633b arm64: dts: qcom: Add missing vio-supply for AW2013 ce476167f046 arm64: dts: qcom: ipq6018: Add QUP5 SPI node 4723cf41be1a arm64: dts: qcom: ipq6018: Add remaining QUP UART node af3ecf0ef5eb Merge branch '20231201-videocc-8150-v3-1-56bec3a5e443@quicinc.com' into clk-for-6.8 eeb32e2a4dbd dt-bindings: clock: Update the videocc resets for sm8150 c591d3616c87 arm64: dts: qcom: qrb4210-rb2: Enable MPSS and Wi-Fi 479632ff42dd arm64: dts: freescale: fix the schema check errors for fsl,tmu-calibration 4c12613ce6e0 ARM: dts: imx27-phytec-phycore-som: Use 'rtc' as node name e55cb89e6ef8 ARM: dts: imx25: Remove unneeded keypad properties 610b835be6b9 dt-bindings: net: marvell,orion-mdio: Drop "reg" sizes schema 5605354f949e arm64: dts: freescale: imx8qxp: Disable dsp reserved memory by default bb83d09752aa arm64: dts: imx8qxp: Add VPU subsystem file 11f5b7454c94 arm64: dts: imx8qxp-mek: Move port under USB connector f6d6c203902d arm64: dts: imx8mn-bsh-smm-s2/pro: add display setup 643674137f59 dt-bindings: PCI: qcom: Document the SM8650 PCIe Controller ddec040496f1 dt-bindings: PCI: dwc: rockchip: Document optional PCIe reference clock input 2d8a490fd767 dt-bindings: PCI: qcom: Correct reset-names property 2bdefbbe9381 dt-bindings: PCI: qcom: Correct clocks for SM8150 01ce80af6cc2 dt-bindings: PCI: qcom: Correct clocks for SC8180x 9c60f1faccc9 dt-bindings: PCI: qcom: Adjust iommu-map for different SoC c78e4dd9c7c0 arm64: dts: rockchip: make use gpio-keys for buttons on puma-haikou 146cf4124863 arm64: dts: rockchip: expose BIOS Disable feedback pin on rk3399-puma 26575df71b2d arm64: dts: rockchip: fix misleading comment in rk3399-puma-haikou.dts 93c2098cfa35 ARM: dts: ux500-href: Switch HREF520 to AB8505 488dc522177c ARM: dts: ux500-href: Push AB8500 config out 7acade644174 ARM: dts: ux500-href: Push AB8500 inclusion to the top 0043c908a991 dt-bindings: connector: usb: add accessory mode description 7b7f80d863a5 arm64: dts: rockchip: Add vop on rk3588 ef9ea9ea51ca arm64: dts: ti: k3-j784s4-main: Add Itap Delay Value For DDR50 speed mode a843a4a028e7 arm64: dts: ti: k3-j721s2-main: Add Itap Delay Value For DDR50 speed mode 83869275890f arm64: dts: ti: k3-j7200-main: Add Itap Delay Value For DDR52 speed mode 237d1d3aa847 arm64: dts: ti: k3-am6*: Add additional regs for DMA components 6540bf190683 arm64: dts: ti: k3-j7*: Add additional regs for DMA components f584859d0f96 arm64: dts: ti: k3-am65: Add additional regs for DMA components e76881a36a46 arm64: dts: cn913x: add device trees for COM Express boards a57b87e79272 dt-bindings: arm64: add Marvell COM Express boards 22b670935a1f arm64: dts: armada-3720-turris-mox: set irq type for RTC 6b8494ce5492 ARM64: dts: Add special compatibles for the Turris Mox 8fcbbd77bc4f ARM64: dts: marvell: Fix some common switch mistakes 61b4fbe68e70 ARM: dts: marvell: make dts use gpio-fan matrix instead of array 1a025bb583e1 ARM: dts: marvell: Fix some common switch mistakes 283f9ebb847c dt-bindings: serial: Add a new compatible string for UMS9620 42414ddb491a dt-bindings: serial: imx: Properly describe the i.MX1 interrupts a5b226724ae1 dt-bindings: usb: qcom,dwc3: Add X1E80100 binding a94c79572ac2 dt-bindings: usb: Document WCD939x USB SubSystem Altmode/Analog Audio Switch 6c2112d5f3f3 arm64: dts: qcom: qrb5165-rb5: use u16 for DP altmode svid 79493bc9fc10 dt-bindings: connector: usb: add altmodes description a98f9ad936ee dt-bindings: usb: nxp,ptn5110: Fix typos in the title da44f4e15545 dt-bindings: usb: genesys,gl850g: Document 'peer-hub' c32fd07e4010 dt-bindings: nvmem: add new stm32mp25 compatible for stm32-romem cc8835249ffb ARM: dts: stm32: add dcmipp support to stm32mp135 dc483bc0495b dt-bindings: gnss: u-blox: add "reset-gpios" binding 82239f64506f dt-bindings: iommu: rockchip: Add Rockchip RK3588 b10f7d79bc86 Merge git://git.kernel.org/pub/scm/linux/kernel/git/netdev/net e39b04bbed6e Merge branch 'icc-qcm2290' into icc-next c95f389c0366 Merge branch 'icc-sm6115' into icc-next b1f1b32e611b dt-bindings: PCI: rcar-pci-host: Add optional regulators 51eab76bc15c arm64: dts: allwinner: h618: add Transpeed 8K618-T TV box 8f65017d5eb4 dt-bindings: arm: sunxi: document Transpeed 8K618-T board name a043657dff28 dt-bindings: vendor-prefixes: add Transpeed b9b13eec182f arm64: dts: st: add bsec support to stm32mp25 4ba9da13226a ARM: dts: stm32: Consolidate usbh_[eo]hci phy properties on stm32mp15 3cd8f921b287 ARM: dts: stm32: don't mix SCMI and non-SCMI board compatibles 9d7cd7004fbc dt-bindings: arm: stm32: don't mix SCMI and non-SCMI board compatibles 3409584c8b1b ARM: dts: stm32: minor whitespace cleanup around '=' 46d3a566ba35 regulator: dt-bindings: qcom,rpmh: add compatible for pm8010 b876feae34ef ASoC: dt-bindings: audio-graph-port: Document new DAI link flags playback-only/capture-only b0c246496fbc dt-bindings: display: msm: dp: declare compatible string for sm8150 363bcab6054e scsi: ufs: qcom: dt-bindings: Add SC7280 compatible string 3d1e051b5db8 arm64: dts: imx8mp-dhcom-pdk3: Describe the USB-C connector ef545aff5ca3 arm64: dts: imx8mn-var-som-symphony: Describe the USB-C connector 13069c168986 arm64: dts: imx8mp-tqma8mpql-mba8mpxl: Fix USB connector description c92840a54a7a arm64: dts: imx8mp-venice: Fix USB connector description d0235ca7db0f arm64: dts: imx8mp-verdin: Fix USB connector description 8e6a721ca452 arm64: dts: imx8dxl-ss-conn: Move clk_dummy out of USB node 7662ace2b978 arm64: dts: imx8mn-evk: Move port under USB connector 92576b82f349 arm64: dts: imx8mm-evk: Move port under USB connector 91c629656840 arm64: dts: freescale: introduce dimonoff-gateway-evk board 8b75c148251b dt-bindings: arm: fsl: add Dimonoff gateway EVK board 192ca710eafd dt-bindings: vendor-prefixes: add dimonoff edc62a2939e3 arm64: dts: imx8m*-tqma8m*: Add chassis-type d35e9fd630d7 arm64: dts: imx8mn-beacon: Support overdrive mode a684f6ef9a40 arm64: dts: imx8mn: Enable Overdrive mode 0c6ce8fb001d arm64: dts: imx8mm-beacon: Enable overdrive mode 42e3d3eaa3cb arm64: dts: imx8mm: Add optional overdrive DTSI f9b749293626 arm64: dts: imx8mm: Reduce GPU to nominal speed aadc35d489bd arm64: dts: imx93: Fix the micfil clock-names entries f8b732c140f6 ARM: dts: imx23/28: Fix the DMA controller node name 9697ec153a9c ARM: dts: imx23-sansa: Use preferred i2c-gpios properties 62875ee7373e ARM: dts: imx27-apf27dev: Fix LED name 6bd0d6d0fb3d ARM: dts: imx25/27: Pass timing0 3cd4341f361d ARM: dts: imx25: Fix the iim compatible string 52eef6a12e21 arm64: dts: exynos: google: Add initial Oriole/pixel 6 board support b0f009ddef83 arm64: dts: exynos: google: Add initial Google gs101 SoC support 7932b36aab04 dt-bindings: arm: google: Add bindings for Google ARM platforms c439b1ecd46b dt-bindings: PCI: ti,j721e-pci-*: Add j784s4-pci-* compatible strings 5114ddf2754e dt-bindings: PCI: ti,j721e-pci-*: Add checks for num-lanes 5142777cc846 arm64: dts: renesas: white-hawk-cpu: Fix missing serial console pin control 9c5b72f0dbf7 arm64: dts: renesas: rzg3s-smarc-som: Enable the Ethernet interfaces c20cd1060c83 arm64: dts: renesas: rzg3s-smarc-som: Use switches' names to select on-board functionalities d1702886b9b1 arm64: dts: renesas: r9a08g045: Add Ethernet nodes c8bc29914258 arm64: dts: renesas: r9a08g045: Add IA55 interrupt controller node 2ac19b878bcd arm64: zynqmp: Add missing destination mailbox compatible bfda609d3986 arm64: zynqmp: Fix clock node name in kv260 cards bf79a715a44c arm64: zynqmp: Move fixed clock to / for kv260 067130bf35dd dt-bindings: soc: Add new board description for MicroBlaze V 3909199b5365 dt-bindings: soc: xilinx: Move xilinx.yaml from arm to soc 5a30f0c409d5 arm64: xilinx: Remove address/size-cells from gem nodes c7afa96873c9 arm64: xilinx: Remove address/size-cells from flash node e3a99f7f8d11 arm64: xilinx: Put ethernet phys to mdio node 6f4a9a0c8df9 arm64: xilinx: Remove mt25qu512a compatible string from SOM e3823e6a85e8 arm64: xilinx: Use lower case for partition address ee878ab978b7 arm64: xilinx: Do not use '_' in DT node names edb56e5ac871 riscv: dts: starfive: Enable SDIO wifi on JH7100 boards 738fd2fd6271 riscv: dts: starfive: Enable SD-card on JH7100 boards 4a3456d5f756 riscv: dts: starfive: Add JH7100 MMC nodes 0b98a998f256 riscv: dts: starfive: Add pool for coherent DMA memory on JH7100 boards b7e59570a83e riscv: dts: starfive: Add JH7100 cache controller 0e3644417255 riscv: dts: starfive: Mark the JH7100 as having non-coherent DMAs 2ce3980ca0ba riscv: dts: starfive: Group tuples in interrupt properties 21bb4608c1f4 arm64: dts: ti: k3-am62-main: Add GPU device node 21dbc3bb6085 dt-bindings: interconnect: qcom,msm8998-bwmon: Add QCM2290 bwmon instance 0a5288800340 dt-bindings: rockchip,vop2: Add more endpoint definition 689213783aed dt-bindings: display: vop2: Add rk3588 support d06f02a431a5 dt-bindings: interconnect: qcom,msm8998-bwmon: Add SM6115 bwmon instance a67732e07f79 arm64: dts: fsd: Add MFC related DT enteries a8f325704092 arm64: dts: ti: k3-j721s2-evm: Add overlay for PCIE1 Endpoint Mode c33d48e723e9 arm64: dts: ti: k3-j721e-evm: Add overlay for PCIE0 Endpoint Mode 411f344456e4 arm64: dts: ti: k3-j721e-sk: Add TPS6594 family PMICs e88109a7ea70 arm64: dts: ti: k3-am69-sk: Add support for TPS6594 PMIC 8203df16463f arm64: dts: ti: k3-j784s4-evm: Add support for TPS6594 PMIC 12693cd3a151 arm64: dts: ti: k3-j721e-som-p0: Add TP6594 family PMICs 022683d6bab2 arm64: dts: ti: k3-j721s2-som-p0: Add TP6594 family PMICs b13637076b0a arm64: dts: ti: k3-j7200-som-p0: Add TP6594 family PMICs 073920a8e469 spi: dw: Remove Intel Thunder Bay SOC support 853b38b4ccbe dt-bindings: media: s5p-mfc: Add mfcv12 variant af1444135df0 dt-bindings: soc: rockchip: add rk3588 vop/vo syscon ea9d3ade1f63 media: dt-bindings: Add OmniVision OV64A40 eac07152e0b8 media: dt-bindings: media: imx335: Add supply bindings 37535c00a2ec media: dt-bindings: gc0308: add binding 9be8a81b5d55 media: dt-bindings: ov8856: decouple lanes and link frequency from driver e78a33d58798 media: dt-bindings: alvium: add document YAML binding 123e53dddda5 dt-bindings: vendor-prefixes: Add prefix alliedvision 5367c47d39ee media: dt-bindings: ak7375: Add ak7345 support 33368f1c353f dt-bindings: mfd: pm8008: Clean up example node names 2ab5a6b315e7 dt-bindings: leds: qcom,spmi-flash-led: Fix example node name fa6a05463677 dt-bindings: leds: aw200xx: Fix led pattern and add reg constraints 44e89edff478 dt-bindings: leds: awinic,aw200xx: Add AW20108 device 6cd025d35790 dt-bindings: leds: aw200xx: Remove property "awinic,display-rows" 65b3a1cec5b9 dt-bindings: leds: aw200xx: Introduce optional enable-gpios property 48e46bb513fb dt-bindings: leds: Add Allwinner A100 LED controller 193b43eae00d dt-bindings: leds: Fix JSON pointer in max-brightness ac28e493721a ARM: dts: imx25: Move usbphy nodes out of simple-bus 90f8840e451d ARM: dts: imx1: Use 'bus' for AIPI bus dfc79426f635 ARM: dts: imx27-phytec-phycore-rdk: Move usbphy nodes out of simple-bus 92c19f27621f ARM: dts: imx27-pdk: Move usbphy0 out of simple-bus 09cddc0d2c3d ARM: dts: imx27: Use 'bus' for EMI bus e7cd1893e9ea ARM: dts: imx27: Use 'bus' for AIPI bus 81e952ba68c6 media: dt-bindings: media: i2c: Add bindings for TW9900 2ed7758d7c0a dt-bindings: vendor-prefixes: Add techwell vendor prefix 9b5febaeea2a arm64: dts: freescale: add fsl-lx2160a-mblx2160a board c763b70a3ecc dt-bindings: arm: fsl: Add TQ-Systems LX2160A based boards 6c6fc780325f ARM: dts: imx27-phytec-phycore-som: Use the mux- prefix 2571ab1025eb ARM: dts: imx1: Fix sram node c64c46277345 ARM: dts: imx27: Fix sram node 4606862f29a7 ARM: dts: imx: Use flash@0,0 pattern e9c196aff7af ARM: dts: imx25/27-eukrea: Fix RTC node name 34087a021485 ARM: dts: imx25-pdk: Pass #sound-dai-cells f91e9208f059 ARM: dts: imx25: Pass I2C clock-names property cb93e178f443 arm64: dts: freescale: imx93: add i3c1 and i3c2 3b2d451cf59f arm64: dts: ls1012a: Remove big-endian from thermal 25e47251c772 dt-bindings: input: microchip,cap11xx: add advanced sensitivity settings a0fb1bc7fd22 Merge tag 'exynos-drm-next-for-v6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/daeinki/drm-exynos into drm-next aae3e1a63026 dt-bindings: riscv: add Zfa ISA extension description ab9eea090f24 dt-bindings: riscv: add Zvfh[min] ISA extension description 7a64028da27c dt-bindings: riscv: add Zihintntl ISA extension description f4789213e5b6 dt-bindings: riscv: add Zfh[min] ISA extensions description c5de05064f79 dt-bindings: riscv: add vector crypto ISA extensions description 215c236fe6da dt-bindings: riscv: add scalar crypto ISA extensions description 1a96ef0c118a Merge tag 'pef2256-framer' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl 6dbce6382acc Merge tag 'pef2256-framer' into devel 1c566bdd0e0f dt-bindings: net: Add the Lantiq PEF2256 E1/T1/J1 framer 0e2e3f19a42d arm64: dts: rockchip: Add Anbernic RG351V aa1c981f085f arm64: dts: rockchip: Split RG351M from Odroid Go Advance 5985d0436d7f dt-bindings: arm: rockchip: Add Anbernic RG351V dddd8bf614e2 arm64: dts: rockchip: Add ethernet0 alias to the dts for RK3588(S) boards e79626358af1 arm64: dts: rockchip: Add ethernet0 alias to the dts for RK3566 boards c2bbb4cb37ce arm64: dts: rockchip: Remove ethernet0 alias from the SoC dtsi for PX30 5df2cd229ef2 arm64: dts: rockchip: Remove ethernetX aliases from the SoC dtsi for RK3328 773747ea9224 arm64: dts: rockchip: Remove ethernet0 alias from the SoC dtsi for RK3368 c47780f2190d arm64: dts: rockchip: Remove ethernet0 alias from the SoC dtsi for RK3399 0e5a28940713 arm64: dts: rockchip: make dts use gpio-fan matrix instead of array 51d3d03836a0 arm64: dts: rockchip: add gpio alias for gpio dt nodes 5fcf2d67aa35 arm64: dts: rockchip: Add dynamic-power-coefficient to rk3399 GPU 80e922961b8e arm64: dts: rockchip: add rk3588 spi aliases to soc dtsi 8f3fbd13ee16 arm64: dts: rockchip: add rk3588 gpio aliases to soc dtsi 15b3dffcbe21 arm64: dts: rockchip: add rk3588 i2c aliases to soc dtsi 095c6f3ed2af arm64: dts: rockchip: move rk3588 serial aliases to soc dtsi 5dc789289ead arm64: dts: rockchip: add Theobroma Jaguar SBC bc75d639d8bd dt-bindings: arm: rockchip: Add Theobroma-Systems Jaguar SBC 3c240c87c027 arm64: dts: rockchip: Add Powkiddy X55 2496d275584a dt-bindings: arm: rockchip: Add Powkiddy X55 517f4adf026d arm64: dts: rockchip: add USB3 host to rock-5a d474a82f6b8f arm64: dts: rockchip: add USB3 host to rock-5b 4bf4fdf576e0 arm64: dts: rockchip: add missing tx/rx-fifo-depth for rk3328 gmac 56e0ff652ec1 arm64: dts: rockchip: add gpio-line-names to rk3308-rock-pi-s 36bdcd2e79dd ARM: dts: rockchip: add hdmi-connector node to rk3036-kylin bd117185d559 ARM: dts: rockchip: fix rk3036 hdmi ports node 2127f8eafedb dt-bindings: clock: google,gs101: fix incorrect numbering and DGB suffix fff73dbf51fc dt-bindings: soc: samsung: usi: add google,gs101-usi compatible 37ffa8542576 dt-bindings: serial: samsung: Make samsung,uart-fifosize a required property fd8ed4626aeb dt-bindings: serial: samsung: Add google-gs101-uart compatible 33bfe5e1dc68 dt-bindings: watchdog: Document Google gs101 watchdog bindings e6381c01b68b riscv: dts: thead: Enable LicheePi 4A eMMC and microSD 3bd0505c030a riscv: dts: thead: Enable BeagleV Ahead eMMC and microSD a53de85228bf riscv: dts: thead: Add TH1520 mmc controllers and sdhci clock fd1214b13ed4 ARM: dts: microchip: sama5d27_som1_ek: Remove mmc-ddr-3_3v property from sdmmc0 node 5d2956b92dea dt-bindings: interrupt-controller: mpm: Pass MSG RAM slice through phandle 402b4259739c dt-bindings: interrupt-controller: renesas,rzg2l-irqc: Document RZ/G3S 150ddb24b2f0 Merge tag 'coresight-next-v6.8' of git://git.kernel.org/pub/scm/linux/kernel/git/coresight/linux into char-misc-next 64011b700499 dt-bindings: arm-smmu: Document SM8[45]50 GPU SMMU a5ab14d25e79 dt-bindings: arm-smmu: Add compatible for X1E80100 SoC aaa9819e17c5 dt-bindings: iommu: arm,smmu: document the SM8650 System MMU c04ccbbeb58a dt-bindings: iommu: arm,smmu: document clocks for the SM8350 GPU SMMU b73f681e020f arm64: dts: juno: Align thermal zone names with bindings 8762e182cc34 dt-bindings: hwmon: Add lltc ltc4286 driver bindings 7711cd743748 Merge tag 'exynos-drm-next-for-v6.7-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/daeinki/drm-exynos into exynos-drm-next 0c9c816dddb4 Backmerge tag 'v6.7-rc5' into drm-next cc330eac5dd3 dt-bindings: iio: humidity: Add TI HDC302x support 07a88600291a dt-bindings: iio: light: add ltr390 a803f8c65ec8 dt-bindings: iio: pressure: add honeywell,hsc030 49600f0eeb26 dt-bindings: iio: temperature: add MLX90635 device 5f69a9e8d3dd dt-bindings: hwmon: Increase max number of io-channels 565f404ae838 dt-bindings: hwmon: Add mps mp5990 driver bindings ad5cba1ee29a ASoC: dt-bindings: qcom,lpass-wsa-macro: Add SM8650 LPASS WSA 880126e66fb3 ASoC: dt-bindings: qcom,lpass-va-macro: Add SM8650 LPASS VA 19ed8a218bd9 ASoC: dt-bindings: qcom,lpass-tx-macro: Add SM8650 LPASS TX 322423704418 ASoC: dt-bindings: qcom,lpass-rx-macro: Add SM8650 LPASS RX f09397ff6cbf dt-bindings: dma: Add dma-channel-mask to nvidia,tegra210-adma 6263d2ffbb0f dt-bindings: dma: sf-pdma: add new compatible name 7581e8bd108d arm64: dts: mediatek: mt8192: Add Smart Voltage Scaling node de53c9a33f27 arm64: dts: mediatek: mt8195: Add SVS node and reduce LVTS_AP iospace 53ceb33cc2de arm64: dts: mediatek: mt8183: Change iospaces for thermal and svs d305525393a4 arm64: dts: mediatek: mt8186: fix address warning for ADSP mailboxes d4dbd2b56a9f arm64: dts: mediatek: mt8186: Fix alias prefix for ovl_2l0 209e23166717 arm64: dts: mt6358: Drop bogus "regulator-fixed" compatible properties b5aaf3dc3cc4 arm64: dts: mt8183: kukui-jacuzzi: Drop bogus anx7625 panel_flag property aef30bad7a04 arm64: dts: Add MediaTek MT8188 dts and evaluation board and Makefile c8d764a0bbc6 dt-bindings: soc: mediatek: pwrap: Modify compatible for MT8188 1b35e3cf8066 dt-bindings: arm: mediatek: Add mt8188 pericfg compatible 7e4914880550 dt-bindings: arm: Add compatible for MediaTek MT8188 c4c85ca7297e arm64: dts: mediatek: mt8195: add DSI and MIPI DPHY nodes e7300ae6b913 dt-bindings: display: mediatek: dsi: add compatible for MediaTek MT8195 cebba0dd1a01 arm64: dts: mediatek: mt6358: Merge ldo_vcn33_* regulators 8ac8be12ac45 dt-bindings: arm: mediatek: convert audsys and mt2701-afe-pcm to yaml 275042f3fe7b arm64: dts: mediatek: mt8195: add MDP3 nodes aba1f17e7acc arm64: dts: mediatek: mt8195: revise VDOSYS RDMA node name 7032d5f144c2 arm64: dts: mediatek: mt8183: correct MDP3 DMA-related nodes 22bae315e031 dt-bindings: display: mediatek: padding: add compatible for MT8195 751c1a1076cb dt-bindings: display: mediatek: split: add compatible for MT8195 e2f195c9941b dt-bindings: display: mediatek: ovl: add compatible for MT8195 98aa994aefee dt-bindings: display: mediatek: merge: add compatible for MT8195 6f5d6cbaa3f9 dt-bindings: display: mediatek: color: add compatible for MT8195 ef86984ae659 dt-bindings: display: mediatek: aal: add compatible for MT8195 8f6efe19695a dt-bindings: media: mediatek: mdp3: add component TDSHP for MT8195 f3a2d9b01651 dt-bindings: media: mediatek: mdp3: add component TCC for MT8195 9952a02bb5ee dt-bindings: media: mediatek: mdp3: add component STITCH for MT8195 6c49acbc4134 dt-bindings: media: mediatek: mdp3: add component HDR for MT8195 d6fdbfb3b4ad dt-bindings: media: mediatek: mdp3: add component FG for MT8195 a7d6e829425b dt-bindings: media: mediatek: mdp3: add compatible for MT8195 WROT 7db0370c2d66 dt-bindings: media: mediatek: mdp3: add compatible for MT8195 RSZ 5620ceb8b6ca dt-bindings: media: mediatek: mdp3: add config for MT8195 RDMA 8f056e0ef45c dt-bindings: media: mediatek: mdp3: merge the indentical RDMA under display c2d8940ef6fd dt-bindings: media: mediatek: mdp3: correct RDMA and WROT node with generic names 4347ab16a815 media: dt-bindings: mediatek: Add phandle to mediatek,scp on MDP3 RDMA e14664bd10f6 arm64: dts: mediatek: mt8195-cherry: Assign sram supply to MFG1 pd 0561502a0693 arm64: dts: mediatek: mt8195-cherry: Add MFG0 domain supply 08b52bb4b076 dt-bindings: reset: mt8188: Add VDOSYS reset control bits 10fbcb9df4e2 dt-bindings: arm: mediatek: Add compatible for MT8188 88c996595db3 dt-bindings: display: mediatek: padding: Add MT8188 ca5643fef42b dt-bindings: display: mediatek: merge: Add compatible for MT8188 ae3b78a94c61 dt-bindings: display: mediatek: mdp-rdma: Add compatible for MT8188 744464b66c7e dt-bindings: display: mediatek: ethdr: Add compatible for MT8188 01b1569a2d88 dt-bindings: thermal: convert Mediatek Thermal to the json-schema 90d08ec14e3c arm64: dts: mt8183: Add jacuzzi pico/pico6 board 5df3f176b5bf dt-bindings: arm64: mediatek: Add mt8183-kukui-jacuzzi-pico 281ab3bf124c arm64: dts: mt8183: Add jacuzzi makomo board 52cfc0fd5dd9 dt-bindings: arm64: mediatek: Add mt8183-kukui-jacuzzi-makomo 19dd875d8e0a arm64: dts: mt8183: Add kukui katsu board b8dd2f8c3e1c dt-bindings: arm64: mediatek: Add mt8183-kukui-katsu 9a6a916f0bc6 arm64: dts: mediatek: Move MT6358 PMIC interrupts to MT8183 boards 3f27ea46dc3d arm64: dts: mediatek: Use interrupts-extended where possible ad0c69fd2fa3 arm64: dts: mediatek: mt8173: Use interrupts-extended where possible c82e8139aeaa arm64: dts: mediatek: mt8183: Use interrupts-extended where possible d8a485fe96f7 dt-bindings: soc: mediatek: add mt8186 and mt8195 svs dt-bindings e66d619c0c3a dt-bindings: arm: mediatek: mmsys: Add VPPSYS compatible for MT8188 5e6b938fc74f arm64: dts: mediatek: mt8192: Add thermal nodes and thermal zones e90ef555e054 arm64: dts: mediatek: mt8183: Add decoder 0f0ccec6cc8d arm64: dts: mediatek: mt8173: Drop VDEC_SYS reg from decoder b6aed11d9548 arm64: dts: mediatek: cherry: Add platform thermal configuration 86760b83d52b dt-bindings: display: simple: Add AUO G156HAN04.0 LVDS display a9ddc30ef584 dt-bindings: display: panel: Add Ilitek ili9805 panel controller defac25462fb dt-bindings: display: st7701: Add Anbernic RG-ARC panel 336bc0e68db2 dt-bindings: display: panel: add Fascontek FS035VG158 panel 955ce81826fb dt-bindings: vendor-prefixes: Add fascontek 752a79b7aaef dt-bindings: display: panel: Clean up leadtek,ltk035c5444t properties 770aea203c16 Merge 6.7-rc5 into tty-next 34ef5edc5b88 Merge 6.7-rc5 into usb-next 621073890e71 Merge branch 'for-v6.8/samsung-bindings-compatibles' into next/dt64 bf94b2d5359e arm64: dts: exynos: add minimal support for exynosautov920 sadk board e9fd8cf1d2d8 arm64: dts: exynos: add initial support for exynosautov920 SoC d0863d30608a dt-bindings: pinctrl: samsung: correct ExynosAutov920 wake-up compatibles 9bdf0db8ae4b dt-bindings: samsung: exynos-sysreg: combine exynosautov920 with other enum 5b54324e6d5b dt-bindings: dma: Drop undocumented examples e2fd1a08fd82 Merge remote-tracking branch 'drm-misc/drm-misc-next' into msm-next a04c2351b389 dt-bindings: soc: google: exynos-sysreg: add dedicated SYSREG compatibles to GS101 9b3c118b3d19 dt-bindings: clock: Add Google gs101 clock management unit bindings d97b5e938286 dt-bindings: soc: samsung: exynos-pmu: Add gs101 compatible 6a5a439c0701 dt-bindings: pinctrl: samsung: add gs101-wakeup-eint compatible 10422d721886 dt-bindings: pinctrl: samsung: add google,gs101-pinctrl compatible 3a5cb767f670 media: dt-bindings: media: rkisp1: Fix the port description for the parallel interface 1da803cb7af8 arm64: dts: qcom: qcm6490-fairphone-fp5: Enable WiFi 8da528961e4e arm64: dts: qcom: qcm6490-fairphone-fp5: Enable various remoteprocs e6fa65e6d152 arm64: dts: qcom: sc7280: Add CDSP node fc9753f721c5 arm64: dts: qcom: sc7280: Add ADSP node c8ee1d58df76 arm64: dts: qcom: sc7280: Use WPSS PAS instead of PIL 52f7c413fda4 arm64: dts: qcom: qcm6490-fairphone-fp5: Enable UFS 4df3a7b5d504 arm64: dts: qcom: msm8953: Set initial address for memory 423afe7e3dcb ARM: dts: qcom: msm8226: Add GPU bba409f9c339 ARM: dts: qcom: Disable pm8941 & pm8226 smbb charger by default 7e9db953a623 arm64: dts: qcom: sc7280: Add UFS nodes for sc7280 IDP board 4e3613f89c7f arm64: dts: qcom: sc7280: Add UFS nodes for sc7280 soc d8bfc2581200 dt-bindings: input: gpio-mouse: Convert to json-schema 2691fb7a0b13 dt-bindings: drm: rockchip: convert inno_hdmi-rockchip.txt to yaml 2dc455b73efa ARM: dts: samsung: exynos4210-i9100: Add accelerometer node 0fab2792a476 ARM: dts: samsung: exynos4210-i9100: Add node for touch keys 7ea4a30a8fd6 ARM: dts: samsung: exynos4210-i9100: Unconditionally enable LDO12 4cee9945012b ARM: dts: microchip: sama5d27_wlsom1_ek: Remove mmc-ddr-3_3v property from sdmmc0 node e76f84dfaedb arm64: dts: qcom: sm8650: Add DisplayPort device nodes 2cfe9148e611 arm64: dts: qcom: pm8550: drop PWM address/size cells 49e3d2a63a49 dt-bindings: display: mediatek: padding: Add MT8188 8c1a5538e89b dt-bindings: display: mediatek: merge: Add compatible for MT8188 29025812d6c3 dt-bindings: cache: qcom,llcc: correct QDU1000 reg entries 3e60d5b58b7d dt-bindings: gpu: samsung-scaler: constrain iommus and power-domains 1d6aee346b02 dt-bindings: gpu: samsung-g2d: constrain iommus and power-domains d4a84a84e922 dt-bindings: gpu: samsung: constrain clocks in top-level properties 1e0b14dc8237 dt-bindings: gpu: samsung: re-order entries to match coding convention ba50ff463c59 dt-bindings: gpu: samsung-rotator: drop redundant quotes 1a3c1bf5b141 dt-bindings: display: mediatek: mdp-rdma: Add compatible for MT8188 0a16c7e2c414 dt-bindings: display: mediatek: ethdr: Add compatible for MT8188 925f69a6cc7d dt-bindings: serial: qcom,msm-uartdm: Vote for shared resources 44f4478aa927 dt-bindings: serial: snps-dw-apb-uart: include rs485 schema fad4b52a0fdb arm64: dts: hisilicon: hikey970-pmic: clean up SPMI node 051c12eb5d46 arm64: dts: hisilicon: hikey970-pmic: fix regulator cells properties e567127bd619 dt-bindings: hisilicon: Merge hi3620-clock into hisilicon,sysctrl binding 4b823f7042ef arm64: dts: qcom: x1e80100: Add Compute Reference Device f51679f0f817 arm64: dts: qcom: Add base X1E80100 dtsi and the QCP dts ca121fc146b2 dt-bindings: arm: qcom: Document X1E80100 SoC and boards c53c3b8c12a4 dt-bindings: arm: cpus: Add qcom,oryon compatible aa432318faa9 Merge branch 'icc-x1e80100' of https://git.kernel.org/pub/scm/linux/kernel/git/djakov/icc into arm64-for-6.8 9eba2f2fb214 Merge branch '20231205061002.30759-4-quic_sibis@quicinc.com' into arm64-for-6.8 f213e67c84b7 Merge branch '20231205061002.30759-4-quic_sibis@quicinc.com' into clk-for-6.8 ecc521e21905 dt-bindings: clock: qcom-rpmhcc: Add RPMHCC bindings for X1E80100 079af735ef3c dt-bindings: clock: qcom: Add X1E80100 GCC clocks 8f4495322f78 arm64: dts: qcom: sm8650-mtp: add WSA8845 speakers 02b73ff63440 arm64: dts: qcom: sm8650: add Soundwire controllers e6679602ac09 arm64: dts: qcom: sm8650: add ADSP audio codec macros 5c0a5d9640c3 arm64: dts: qcom: sm8650: add LPASS LPI pin controller 7f6211cc8e63 arm64: dts: qcom: sm8650: add ADSP GPR b72a9e98977b arm64: dts: qcom: sm8650-qrd: enable IPA 13bdc41575ab arm64: dts: qcom: sm8650: add IPA information 0fd767d395a1 arm64: dts: qcom: sm8650-qrd: add interconnect dependent device nodes d68c8f7f237a arm64: dts: qcom: sm8650-mtp: add interconnect dependent device nodes 900a28b939d2 arm64: dts: qcom: sm8650: add interconnect dependent device nodes ff01973261d0 arm64: dts: qcom: sm8650: add initial SM8650 QRD dts 185ce15a620b arm64: dts: qcom: sm8650: add initial SM8650 MTP dts 487b5dde17e2 arm64: dts: qcom: pm8550ve: make PMK8550VE SID configurable 61ff00c8e1de arm64: dts: qcom: add initial SM8650 dtsi 7266e49a2f3e dt-bindings: arm: qcom: document SM8650 and the reference boards 34a104c65fa9 Merge branch 'icc-sm8650' of https://git.kernel.org/pub/scm/linux/kernel/git/djakov/icc into arm64-for-6.8 dc9c79dc36cc Merge branch '20231106-topic-sm8650-upstream-clocks-v3-5-761a6fadb4c0@linaro.org' into arm64-for-6.8 482bf7559678 Merge git://git.kernel.org/pub/scm/linux/kernel/git/netdev/net 89cdcbe73e3a dt-bindings: display: msm: dp-controller: document SM8650 compatible 6457d6362b66 docs: dt-bindings: add DTS Coding Style document 17bd76b0dcba ARM: dts: rockchip: add gpio alias for gpio dt nodes 1e3bf6cdb555 dt-bindings: mfd: hisilicon,hi6421-spmi-pmic: Clean up example ebf62e0e08ff dt-bindings: mfd: hisilicon,hi6421-spmi-pmic: Fix regulator binding ff778a37f71a dt-bindings: mfd: hisilicon,hi6421-spmi-pmic: Fix up binding reference 60bfc8c9aef9 dt-bindings: firmware: qcom,scm: Allow interconnect for everyone ae3daad140cd arm64: dts: qcom: sm8250-xiaomi-pipa: Add initial device tree 3ab4a6461f9d dt-bindings: arm: qcom: Add Xiaomi Pad 6 (xiaomi-pipa) a4229e4b1bf7 arm64: dts: qcom: sm8550-qrd: enable IPA 0b02bd1a7f8b arm64: dts: qcom: sm8550: add IPA information 1d704f347212 dt-bindings: firmware: qcom,scm: document SCM on X1E80100 SoCs a07e2c07074c dt-bindings: arm: qcom-soc: extend pattern matching for X1E80100 SoC 190053cb1ce8 arm64: dts: qcom: minor whitespace cleanup around '=' e5d9eb69d255 ARM: dts: qcom: minor whitespace cleanup around '=' a12829c0d5ea arm64: dts: qcom: ipq8074: Add QUP4 SPI node 81c5f29af493 arm64: dts: qcom: qdu1000: Add ECPRI clock controller 7f8d2a160503 Merge branch '20231123064735.2979802-2-quic_imrashai@quicinc.com' into clk-for-6.8 a7b1e49f140b dt-bindings: clock: qcom: Add ECPRICC clocks for QDU1000 and QRU1000 0d8365b85a68 ARM: dts: qcom: sdx55: fix USB wakeup interrupt types 4e5dc5d2a1e5 arm64: dts: qcom: sm8550: fix USB wakeup interrupt types b0dd9226dd63 arm64: dts: qcom: sm8150: fix USB wakeup interrupt types 301d240b276b arm64: dts: qcom: sm6375: fix USB wakeup interrupt types bcfa8e3ed274 arm64: dts: qcom: sdm845: fix USB wakeup interrupt types 20a6fe5d28b2 arm64: dts: qcom: sdm670: fix USB wakeup interrupt types d2c7cfd6cfc3 arm64: dts: qcom: sc8180x: fix USB wakeup interrupt types 6f29d799b7cf arm64: dts: qcom: sc7280: fix usb_2 wakeup interrupt types ca84d4480b44 arm64: dts: qcom: sc7280: fix usb_1 wakeup interrupt types 096085135fda arm64: dts: qcom: sc7180: fix USB wakeup interrupt types 6c1f003cc9a1 arm64: dts: qcom: sa8775p: fix USB wakeup interrupt types 45bd09d633c8 arm64: dts: qcom: msm8916-longcheer-l8150: Add battery and charger 195857e6f299 arm64: dts: qcom: pm8916: Add BMS and charger 6caacf1f1bd3 arm64: dts: qcom: sc7280: Add 0xac Adreno speed bin 3ddcb3a31e24 arm64: dts: qcom: sc7280: Mark Adreno SMMU as DMA coherent b8bf84b9efc0 arm64: dts: qcom: sc7280: Fix up GPU SIDs 0830942e59a4 arm64: dts: qcom: sc7280: Add ZAP shader support 6a2b85d201c9 dt-bindings: arm: qcom-soc: extend pattern for matching existing SoCs ddd782c9e1e9 dt-bindings: cache: qcom,llcc: Add X1E80100 compatible 573141bcc2f7 arm64: dts: qcom: sdx75-idp: Enable USB3 and PHY support 93789523f679 arm64: dts: qcom: Add USB3 and PHY support on SDX75 ddc8552a97e0 arm64: dts: qcom: Add interconnect nodes for SDX75 2f6480d75792 arm64: dts: qcom: sm8350: Fix remoteproc interrupt type 22ab1e4b96e5 arm64: dts: qcom: pm8350k: Remove hanging whitespace 648dd7cb906d arm64: dts: qcom: sm8350: Fix DMA0 address aa5e755d7246 dt-bindings: iio: adc: qcom: Add Qualcomm smb139x aee24a669374 arm64: dts: qcom: sc8180x: align APSS with bindings c51b52a3c7aa arm64: dts: qcom: sm6375-pdx225: add fixed touchscreen AVDD regulator 714c2d01cb79 arm64: dts: qcom: sm6125: add interrupts to DWC3 USB controller 869ed2bf0b06 arm64: dts: qcom: sm6115: align mem timer size cells with bindings 5b01a3bc4e38 arm64: dts: qcom: sm8150: use 'gpios' suffix for PCI GPIOs abcbd3630645 arm64: dts: qcom: sc8180x-primus: use 'gpios' suffix for PCI GPIOs 5281b1e2c756 arm64: dts: qcom: sc8180x-flex-5g: use 'gpios' suffix for PCI GPIOs dbf927ecfde3 arm64: dts: qcom: sdm845: correct Soundwire node name 27d49e38f5d4 arm64: dts: qcom: sdm845-db845c: correct LED panic indicator 85591f38ba27 arm64: dts: qcom: qrb5165-rb5: correct LED panic indicator 65b61add6d70 arm64: dts: qcom: sm8250: Add wakeup-source to usb_1 and usb_2 343c9084fd53 arm64: dts: qcom: sdm850-lenovo-yoga: Add wakeup-sources eb9d72ac20a4 arm64: dts: qcom: sa8775p-ride: enable pmm8654au_0_pon_resin e4828a6315b4 arm64: dts: qcom: sm8350: move DPU opp-table to its node cfa2fb4b7f5b arm64: dts: qcom: sc8280xp-x13s: drop sound-dai-cells from eDisplayPort 927e9926b48f arm64: dts: qcom: sc8180x-primus: drop sound-dai-cells from eDisplayPort ca8a02834a8f arm64: dts: qcom: sm8250: correct Soundwire node name 682a341c0cdc arm64: dts: qcom: sc8280xp: correct Soundwire node name 13f2dbc0a9cb arm64: dts: qcom: qdu1000-idp: drop unused LLCC multi-ch-bit-off 6cda67d14000 arm64: dts: qcom: qdu1000: correct LLCC reg entries 208a56e344a2 arm64: dts: qcom: sm8450: fix soundwire controllers node name c7bee631d3e9 arm64: dts: qcom: sm8550: fix soundwire controllers node name 255ca7c95406 Merge branch '20231106-topic-sm8650-upstream-clocks-v3-5-761a6fadb4c0@linaro.org' into clk-for-6.8 52721c372031 dt-bindings: clock: qcom: Document the SM8650 RPMH Clock Controller a8430c36d8bc dt-bindings: clock: qcom: document the SM8650 GPU Clock Controller e39f08bf115a dt-bindings: clock: qcom: document the SM8650 Display Clock Controller 076aa9fc05f3 dt-bindings: clock: qcom: document the SM8650 General Clock Controller abeff2c9f476 dt-bindings: clock: qcom: document the SM8650 TCSR Clock Controller 3714369ceebb dt-bindings: cache: qcom,llcc: Document the SM8650 Last Level Cache Controller cb0f1e272d52 dt-bindings: clock: qcom,gcc-msm8939: Add CSI2 related clocks 7ee4127b7a3f arm64: dts: qcom: sc8280xp: Add in CAMCC for sc8280xp d380ef670205 Merge branch '20231026105345.3376-3-bryan.odonoghue@linaro.org' into arm64-for-6.8 30a292de3f9a Merge branch '20231026105345.3376-3-bryan.odonoghue@linaro.org' into clk-for-6.8 f007e023cbd5 dt-bindings: clock: Add SC8280XP CAMCC aec8967c6dce dt-bindings: clock: Use gcc.yaml for common clock properties 7c1eb93bd0d3 dt-bindings: clock: qcom,gcc-ipq6018: split to separate schema b6364ec8f82d dt-bindings: arm: qcom,ids: Add SoC ID for SM8650 3f482ad7991e arm64: dts: qcom: sm8550: Enable download mode register write fe077e894545 arm64: dts: qcom: sm8350: Add TCSR halt register space 956699ec82d4 arm64: dts: qcom: sm8250: Add TCSR halt register space e0bd046de230 arm64: dts: qcom: ipq5018: add few more reserved memory regions c38c43d3b995 arm64: dts: qcom: ipq5332: add missing properties to the GPIO LED node 0390c1ee5e11 arm64: dts: qcom: ipq9574: enable GPIO based LED 2f9b91c0cf6d arm64: dts: qcom: qrb2210-rb1: use USB host mode 2196010939c0 dt-bindings: firmware: qcom,scm: document SM8650 SCM Firmware Interface ae8a176c474a dt-bindings: soc: qcom: pmic-glink: document SM8650 compatible c3cb68af1e5d dt-bindings: soc: qcom,aoss-qmp: document the SM8560 Always-On Subsystem side channel a6ea4114f911 dt-bindings: mmc: mtk-sd: add tuning steps related property 30e4bc60ac6d dt-bindings: mfd: ti,am3359-tscadc: Allow dmas property to be optional 5c51588d48df dt-bindings: mfd: qcom,spmi-pmic: Add pm8916 vm-bms and lbc a03962f53dbd dt-bindings: mfd: qcom-spmi-pmic: Document PM8937 PMIC 81a2c830f173 dt-bindings: mfd: qcom,tcsr: Add compatible for sm8250/sm8350 fe50e0fb05fc dt-bindings: mfd: ams,as3711: Convert to json-schema 197c27b6cfaa arm64: dts: fsd: add specific compatibles for Tesla FSD 395fa67b6b72 Merge branch 'for-v6.8/samsung-bindings-compatibles' into next/dt64 5927c83d20c8 dt-bindings: watchdog: samsung: add specific compatible for Tesla FSD 78e4ed4670d7 dt-bindings: samsung: exynos-pmu: add specific compatible for Tesla FSD c168df69f5a1 dt-bindings: serial: samsung: add specific compatible for Tesla FSD 6dedf66f0e8b dt-bindings: pwm: samsung: add specific compatible for Tesla FSD 457e5d03f14d dt-bindings: i2c: exynos5: add specific compatible for Tesla FSD 4b7a14529669 dt-bindings: mmc: renesas,sdhi: Document RZ/Five SoC a135e0045af7 dt-bindings: mmc: arasan,sdci: Add gate property for Xilinx platforms d0ed6c92c98e dt-bindings: mmc: sdhci-of-dwcmhsc: Add T-Head TH1520 support f7a9df14027b dt-bindings: net: microchip,ksz: document microchip,rmii-clk-internal b81aa4a5992d media: dt-bindings: mediatek: Add phandle to mediatek,scp on MDP3 RDMA b80f939c4051 dt-bindings: iio/adc: qcom,spmi-vadc: clean up examples 44c4f2c40551 dt-bindings: iio/adc: qcom,spmi-vadc: fix example node names c57fab0a68f9 dt-bindings: iio/adc: qcom,spmi-rradc: clean up example f330b6a06a10 dt-bindings: iio/adc: qcom,spmi-iadc: clean up example d089bb38e3f6 dt-bindings: iio/adc: qcom,spmi-iadc: fix example node name d92310a0b805 dt-bindings: iio/adc: qcom,spmi-iadc: fix reg description 6afb70912c0a Merge tag 'renesas-dts-for-v6.8-tag1' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/renesas-devel into soc/dt 77be7b2ec3d6 arm64: dts: ti: Add verdin am62 mallow board 5fe3785a98a1 dt-bindings: arm: ti: Add verdin am62 mallow board 7bf01a4e3239 ASoC: dt-bindings: fsl,xcvr: Adjust the number of interrupts 568ee5fdf77d dt-bindings: interconnect: Add Qualcomm SM6115 NoC 7549b7adec53 arm64: dts: ti: verdin-am62: Improve spi1 chip-select pinctrl 0b160138fdcc arm64: dts: ti: k3-am625-phyboard-lyra-rdk: Remove HDMI Reset Line Name 42aed107725d arm64: dts: ti: k3-am625-phyboard-lyra-rdk: Add HDMI support 766ac2241c85 arm64: dts: ti: k3-am625-phyboard-lyra-rdk: Lower I2C1 frequency bcf7dd5b8b09 arm64: dts: ti: phycore-am64: Add R5F DMA Region and Mailboxes e1dfb1eb87a4 riscv: dts: microchip: add the mpfs' system controller qspi & associated flash 59d2f723c14b dt-bindings: soc: microchip: add a property for system controller flash 4b452a4cfa9e ARM: dts: imx23/28: Remove undocumented "fsl,clkctrl" 485e1601cd25 ARM: dts: bcm2711: Add BCM2711 xHCI support 439353e944b0 dt-bindings: usb: xhci: Add support for BCM2711 4b95e8b40522 ARM: dts: imx28-lwe: Pass device_type to the memory node ea0431aa1757 ARM: dts: imx23/28: Remove unneeded "fsl,mxs-gpio" e63738dd96c8 ARM: dts: imx28-tx28: Pass #sound-dai-cells fc88878c01c0 arm64: dts: imx8mq-phanbell: make dts use gpio-fan matrix instead of array e21fe3809cd3 arm64: dts: freescale: verdin-imx8mp: add support to mallow board a75cfdc4a966 arm64: dts: freescale: verdin-imx8mm: add support to mallow board 3b7bee60295f arm64: dts: imx8mm-venice-gw7: Adjust PCI Ethernet nodes 5241ecb06203 dt-bindings: arm: fsl: add verdin imx8mp mallow board b80ecc880136 dt-bindings: arm: fsl: add verdin imx8mm mallow board ad1ae2498610 arm64: dts: imx8mm: Slow default video_pll1 clock rate 5aa830cec5a3 arm64: dts: imx8mm: Remove video_pll1 clock rate from clk node 110274d03548 arm64: dts: imx8mm: Simplify mipi_dsi clocks 99d898689e0b ARM: dts: imx7s: Add on-chip memory 29d17af3b09b ARM: dts: imx7: add MIPI-DSI support d9c25edf04ae scsi: ufs: dt-bindings: Add msi-parent for UFS MCQ dba1025f17d0 ARM: dts: nxp: Fix some common switch mistakes 4ea7b578957d arm64: dts: freescale: minor whitespace cleanup around '=' dbb52d93894b arm64: dts: imx8dxl-ss-ddr: change ddr_pmu0 compatible 941d70d2ae55 arm64: dts: tqma8mpql: Remove invalid/unused property ec00a410133c arm64: dts: imx8-ss-audio: Remove unexistent'shared-interrupt' 604139ed79f6 arm64: dts: imx93: Remove unexistent 'shared-interrupt' 7a445842e287 arm64: dts: imx8qxp-mek: Fix gpio-sbu-mux compatible 0c2122b767be arm64: dts: imx8mp-debix-model-a: Use phy-mode 2e9827c5e054 arm64: dts: imx8mm-nitrogen-r2: Fix I2C mux subnode name d1e22a0dfb43 arm64: dts: imx8dxl-ss-conn: Fix Ethernet interrupt-names order 6299d7ae35e5 arm64: dts: imx8mm-emcon-avari: Fix gpio-cells 9de3f32f3c7d arm64: dts: imx8qm-ss-dma: Pass lpuart dma-names 6905c613057b arm64: dts: freescale: Add SKOV IMX8MP CPU revB board b20a05f3b464 arm64: dts: imx8mn-var-som-symphony: add vcc supply for PCA9534 a5a6af3c0bdd arm64: dts: freescale: introduce rve-gateway board 83600000758e arm64: dts: freescale: debix-som-a-bmb-08: Add CSI Power Regulators b5e632bcd082 arm64: dts: imx8-apalis: add can power-up delay on ixora board 9804057f0f96 arm64: dts: imx8mn-var-som: add fixed 3.3V regulator for EEPROM e3c93255cfdb arm64: dts: imx8mm-venice-gw7: Fix pci sub-nodes 8357f0b7ae64 arm64: dts: imx8mp: Disable dsp reserved memory by default 3b2b78d127df arm64: dts: imx8mp: Add NPU Node b13969aeeefc arm64: dts: freescale: debix-som: Add heartbeat LED 5c6068a3aecc arm64: dts: freescale: Add dual-channel LVDS overlay for TQMa8MPxL 37dbfb74c066 arm64: dts: imx8mp-venice-gw74xx: remove unecessary propreties in tpm node 12f50b18b3a5 ARM: dts: nxp: minor whitespace cleanup around '=' 7e4a296e0073 ARM: dts: imx7d-colibri-emmc: Add usdhc aliases aac483d2d190 ARM: dts: imx6qdl-colibri: Add usdhc aliases 534d21c04c41 ARM: dts: imx6qdl-apalis: Add usdhc aliases 4105f51d0c63 ARM: dts: nxp: imx7d-pico: add cpu-supply nodes 4a5f36c1120b dt-bindings: arm: Add compatible for SKOV i.MX8MP RevB board 7efe4371f644 dt-bindings: arm: fsl: add RVE gateway board 3c86e357feb0 dt-bindings: vendor-prefixes: add rve 04660a3dbd9f ARM: dts: broadcom: Add BCM63138's high speed UART 2e36ee7e60cd arm64: dts: ti: k3-am62x: Add overlay for IMX219 8478bfdedc00 arm64: dts: ti: k3-am62a7-sk: Enable camera peripherals a361c10e44cc arm64: dts: ti: k3-am62x: Add overlays for OV5640 820399f7bf0f arm64: dts: ti: k3-am62x-sk: Enable camera peripherals 4de948eeb982 arm64: dts: ti: k3-am625-beagleplay: Add overlays for OV5640 8d6be01e5e7c arm64: dts: ti: k3-am62a-main: Enable CSI2-RX d52951f9d78a arm64: dts: ti: k3-am62-main: Enable CSI2-RX 4d667e27b3fd arm64: dts: ti: k3-am65: Add AM652 dtsi file 3d2161ed0c2b dt-bindings: perf: fsl-imx-ddr: Add i.MX8DXL compatible 189fe310f16e dt-bindings: clock: support i.MX93 ANATOP clock module b44d3f817227 ARM: dts: imx: tqma7: add lm75a sensor (rev. 01xxx) b654e96c546e dt-bindings: display: simple: add Evervision VGG644804 panel 05a02c1a58e1 dt-bindings: ili9881c: Add Ampire AM8001280G LCD panel 96be0427a528 ARM: dts: rockchip: Move uart aliases to SoC dtsi for RK3128 18c0b8b47af4 ARM: dts: rockchip: Move i2c aliases to SoC dtsi for RK3128 0191774d40bb ARM: dts: rockchip: Move gpio aliases to SoC dtsi for RK3128 4b6344ed1b32 ARM: dts: rockchip: Add Sonoff iHost Smart Home Hub 3cbab293b053 dt-bindings: arm: rockchip: Add Sonoff iHost afacdf8be4db ARM: dts: rockchip: Add rv1109 SoC ad1e5ad721a5 ARM: dts: rockchip: Split up rgmii1 pinctrl on rv1126 fc0ef88ee0a1 ARM: dts: rockchip: Add i2c2 node to rv1126 bf739d2f67ae ARM: dts: rockchip: Serial aliases for rv1126 049605e5080d ARM: dts: rockchip: Add alternate UART pins to rv1126 59e8d345382e ARM: dts: rockchip: Enable GPU for XPI-3128 464bddcf0726 ARM: dts: rockchip: Add GPU node for RK3128 8af06043d850 ARM: dts: rockchip: Add power-controller for RK3128 8f65bb97112e dt-bindings: display: himax-hx8394: Add Powkiddy X55 panel ed2d8407a82d dt-bindings: display: Document Himax HX8394 panel rotation 5319f5062c10 dt-bindings: display: simple: Add boe,bp101wx1-100 panel db09be0ff97b ARM: dts: imx6q-apalis: add can power-up delay on ixora board 31fdbd1cd6c6 dt-bindings: display: msm: document the SM8650 Mobile Display Subsystem 52e16372d1c6 dt-bindings: display: msm: document the SM8650 DPU 258f55b8a6c7 dt-bindings: display: msm-dsi-controller-main: document the SM8650 DSI Controller f06034e33173 dt-bindings: display: msm-dsi-phy-7nm: document the SM8650 DSI PHY e7cafbdafccf dt-bindings: display: msm: Add SDM670 MDSS 58504ed9c645 dt-bindings: display/msm: sdm845-dpu: Describe SDM670 d8b80f6fd0c5 dt-bindings: display/msm: dsi-controller-main: add SDM670 compatible 0c71ce621111 arm64: dts: ti: k3-am625-beagleplay: Use UART name in pinmux name 0895f560a171 arm64: dts: ti: k3-am62a7-sk: Add interrupt support for IO Expander 696f6e8d6176 arm64: dts: ti: k3-am625-verdin: Enable Verdin UART2 145b9a5ffb00 arm64: dts: ti: k3-am62-main: Add gpio-ranges properties 0d95f5e22dde arm64: dts: ti: k3-am64: Enable SDHCI nodes at the board level 8ccabbb5322f arm64: dts: ti: k3-am65: Enable SDHCI nodes at the board level 4b9d0ee63df8 arm64: dts: ti: k3-am65: Add full compatible to dss-oldi-io-ctrl node b64af72b8e7b arm64: dts: ti: k3-j784s4: Add chipid node to wkup_conf bus a70ca898f980 arm64: dts: ti: k3-j721s2: Add chipid node to wkup_conf bus 638e0242808a arm64: dts: ti: k3-j721e: Add chipid node to wkup_conf bus 0b0e18c3dce2 arm64: dts: ti: k3-j7200: Add chipid node to wkup_conf bus 16b21e3cf2ea arm64: dts: ti: k3-am65: Add chipid node to wkup_conf bus ba6541592794 dt-bindings: iio: light: isl76682: Document ISL76682 3678e1e114f2 dt-bindings: pinctrl: qcom,sm8550-lpass-lpi: add X1E80100 LPASS LPI 4854bb4b43e2 dt-bindings: pinctrl: pinctrl-single: add ti,j7200-padconf compatible 062b01e5c736 dt-bindings: iio: light: add support for Vishay VEML6075 3f170ed89d6f dt-bindings: usb: tps6598x: add reset-gpios property 69a424bfd498 dt-bindings: iio/adc: ti,palmas-gpadc: Drop incomplete example 5cf3c6e7327b dt-bindings: adi,ad5791: Add support for controlling RBUF 7a11d1470ed1 dt-bindings: display: bridge: lt8912b: Add power supplies 562bb8392ec6 spi: spl022: fix sleeping in interrupt context 83c535a1ec6b dt-bindings: iio: honeywell,mprls0025pa: drop ref from pressure properties 7cb202a1a899 dt-bindings: media: add bindings for stm32 dcmipp fce776c784a0 dt-bindings: media: Add bindings for THine THP7312 ISP 23c5bf41000e dt-bindings: media: i2c: add galaxycore,gc2145 dt-bindings e6429afd32f1 dt-bindings: vendor-prefixes: Add prefix for GalaxyCore Inc. d1287a3d111f dt-bindings: gpio: rockchip: add a pattern for gpio hogs e08aefe3ce14 Merge tag 'qcom-dts-for-6.7-2' into arm32-for-6.8 66862cc676b1 ARM: dts: qcom: Add support for HTC One Mini 2 ac27d4b5eaa6 Merge tag 'v6.7-rc4' into media_stage 8a745825682b arm64: dts: qcom: sm6350: Make watchdog bark interrupt edge triggered 4de273b8d5cf arm64: dts: qcom: sc8280xp: Make watchdog bark interrupt edge triggered 94d4ed6b0efb arm64: dts: qcom: sa8775p: Make watchdog bark interrupt edge triggered 9e80723d8b4f arm64: dts: qcom: sm8250: Make watchdog bark interrupt edge triggered ef5fa5d97caa arm64: dts: qcom: sm8150: Make watchdog bark interrupt edge triggered 3879bc4c1c04 arm64: dts: qcom: sdm845: Make watchdog bark interrupt edge triggered 8e7e69e2041a arm64: dts: qcom: sc7280: Make watchdog bark interrupt edge triggered 6584d8b4799e arm64: dts: qcom: sc7180: Make watchdog bark interrupt edge triggered 04f80707bc19 arm64: dts: qcom: sc8180x: drop duplicated PCI iommus property 04597b9d0b6f dt-bindings: arm: qcom: Add HTC One Mini 2 7ff927ff9139 dt-bindings: vendor-prefixes: document HTC Corporation fa70da0426ea arm64: dts: qcom: sm8550: correct TX Soundwire clock ed7e07a029d6 arm64: dts: qcom: sm8450: correct TX Soundwire clock 541ded0776d2 arm64: dts: qcom: sc8180x-primus: Fix HALL_INT polarity 39c752cf5603 arm64: dts: qcom: sc8280xp-crd: fix eDP phy compatible e5319a1187df arm64: dts: qcom: sdm632-fairphone-fp3: Enable LPASS daf6cf6a007f arm64: dts: qcom: msm8916-acer-a1-724: Add notification LED 2a186fbc9370 arm64: dts: qcom: ipq6018: use CPUFreq NVMEM 91d98fe1640a arm64: dts: qcom: msm8939-huawei-kiwi: Add initial device tree 6718a893d987 dt-bindings: arm: qcom: Add Huawei Honor 5X / GR5 (2016) f36c60304a90 arm64: dts: qcom: msm8953: Use non-deprecated qcom,domain in LPASS fa91149122fc arm64: dts: qcom: qrb2210-rb1: add wifi variant property 9862c76b6484 arm64: dts: qcom: qrb2210-rb1: Enable CAN bus controller 90510995b456 arm64: dts: qcom: qrb2210-rb1: Set up HDMI f168a1f5fd2a arm64: dts: qcom: qcm2290: Hook up interconnects a66c95bb5052 arm64: dts: qcom: qcm2290: Add display nodes 1b3d99e8ad9d arm64: dts: qcom: sc7280: Add the missing MDSS icc path 463b9cc7faa3 arm64: dts: qcom: sc7180: Add the missing MDSS icc path a2b32f52593b arm64: dts: qcom: sc8280xp: Add QMP handle to RPMh stats 0541077473ea dt-bindings: soc: qcom: stats: Add QMP handle 46fd383def7f arm64: dts: qcom: sm8250-xiaomi-elish: Add pm8150b type-c node and enable usb otg 45ca7aacee21 arm64: dts: qcom: sm8250-xiaomi-elish: Fix typos 9dee357f1ff5 arm64: dts: qcom: msm8939-longcheer-l9100: Add proximity-near-level d6b8367dbb65 arm64: dts: qcom: qrb4210-rb2: Enable bluetooth 9e8fcdbc4d75 arm64: dts: qcom: sm6115: Add UART3 e88a0c4a9117 arm64: dts: qcom: sdm632-fairphone-fp3: Enable WiFi/Bluetooth a808b8c6d7f4 dt-bindings: arm: qcom: Fix html link 004244e4cbd5 arm64: dts: qcom: Add base qcs6490-rb3gen2 board dts 3f55e77ebc86 arm64: dts: qcom: Add base qcm6490 idp board dts 9e08836a864f dt-bindings: arm: qcom: Add QCM6490 IDP and QCS6490 RB3Gen2 board c538a9224903 arm64: dts: qcom: sm4450-qrd: mark QRD4450 reserved gpios 34764956c2e4 arm64: dts: qcom: sm4450-qrd: add QRD4450 uart support b5fe030e21e0 arm64: dts: qcom: sm4450: add uart console support 76478ce29df3 arm64: dts: qcom: sm4450: Add RPMH and Global clock 52ea11ee57e9 arm64: dts: qcom: sm4450: Add apps_rsc and cmd_db node d42f9497ccad arm64: dts: qcom: ipq8074: pass QMP PCI PHY PIPE clocks to GCC 9b98d0a1718e dt-bindings: clocks: qcom,gcc-ipq8074: allow QMP PCI PHY PIPE clocks 2417b30e3609 arm64: dts: qcom: msm8953: add SPI interfaces 66dd2b49a0b3 arm64: dts: qcom: qcm6490-fairphone-fp5: Add PM7325 thermals 0b651704285a arm64: dts: qcom: qcm6490-fairphone-fp5: Add PMK7325 thermals 8630d7baedf5 arm64: dts: qcom: qcm6490-fairphone-fp5: Add PM7250B thermals 959371b1b650 iio: adc: Add PM7325 PMIC7 ADC bindings b1e6472aae24 arm64: dts: qcom: sm8250: Add OPP table support to UFSHC 6aeff20d0bd6 arm64: dts: qcom: sdm845: Add OPP table support to UFSHC e8d1d500097e ARM: dts: qcom: msm8974: Add watchdog node 615027dbbe1d dt-bindings: arm: qcom: drop the IPQ board types ebb3e763ee5b arm64: dts: qcom: ipq5018: enable the CPUFreq support 3ca74e9810cf dt-bindings: clock: qcom,a53pll: add IPQ5018 compatible dcbafe8963f4 ARM: dts: qcom: sdx65: correct SPMI node name 98b030d58c93 ARM: dts: qcom: sdx65: add missing GCC clocks 07a16205d0e0 ARM: dts: qcom: sdx65: correct PCIe EP phy-names fe48cd5331dc dt-bindings: display: msm: Add reg bus and rotator interconnects 8c1892c5f696 dt-bindings: display: msm: qcm2290-mdss: Use the non-deprecated DSI compat 7cfd5769a991 dt-bindings: display/msm: qcom, sm8150-mdss: correct DSI PHY compatible 91abf991ed4a dt-bindings: display/msm: qcom, sm8250-mdss: add DisplayPort controller node c203dee53e38 ARM: dts: rockchip: Enable gmac for XPI-3128 a31102a06882 ARM: dts: rockchip: Add gmac node for RK3128 d02bab784773 dt-bindings: gpu: mali-utgard: Add Rockchip RK3128 compatible 61b6b8e5340b dt-bindings: net: qcom,ipa: document SM8650 compatible a0fa8df10233 Merge tag 'renesas-pinctrl-for-v6.8-tag1' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/renesas-drivers into devel 6c58c6977828 dt-bindings: gpio: modepin: Describe label property 7f00d1c96321 dt-bindings: display: ti: Add support for am62a7 dss 6bed64726635 arm64: dts: ti: k3-am68-sk-base-board: Add alias for MCU CPSW2G f494c9948974 arm64: dts: ti: iot2050: Add icssg-prueth nodes for PG2 devices 403938b5222f arm64: dts: ti: iot2050: Refactor the m.2 and minipcie power pin 45e3b6aa9185 arm64: dts: ti: iot2050: Definitions for runtime pinmuxing b14c51a347fb arm64: dts: ti: iot2050: Drop unused ecap0 PWM 38f52ad2cea9 arm64: dts: ti: iot2050: Re-add aliases a84e54a6c2a0 arm64: dts: ti: k3-am62x-sk-common: Mark mcu gpio and mcu_gpio_intr as reserved 0baa456c51ce arm64: dts: ti: k3-am62p5-sk: Mark mcu gpio and mcu_gpio_intr as reserved 131aadfec025 arm64: dts: ti: k3-am642-evm/sk: Mark mcu_gpio_intr as reserved bbda0d8be30e arm64: dts: ti: k3-am64-main: Fix typo in epwm_tbclk node name 5e8876dba890 arm64: dts: ti: k3-am65-main: Fix DSS irq trigger type fd78a91dedf3 arm64: dts: ti: k3-am62a-main: Fix GPIO pin count in DT nodes 05614d5b4f00 arm64: dts: ti: minor whitespace cleanup around '=' ca6dff24071e ARM: dts: omap4-embt2ws: Add Bluetooth cff0864e2eea Merge git://git.kernel.org/pub/scm/linux/kernel/git/netdev/net 2a2ae1545117 dt-bindings: input: gpio-keys: Allow optional dedicated wakeirq aed93474ebc0 Merge patch series "Add Huashan Pi board support" 318917bad2c6 riscv: dts: sophgo: add Huashan Pi board device tree 8a2824be66df riscv: dts: sophgo: add initial CV1812H SoC device tree 3ff295494c04 riscv: dts: sophgo: cv18xx: Add gpio devices dfcd3e4c81d9 riscv: dts: sophgo: Separate compatible specific for CV1800B soc 8c5d4ad957fa dt-bindings: riscv: Add SOPHGO Huashan Pi board compatibles e393d2e6705e dt-bindings: timer: Add SOPHGO CV1812H clint 65cc6be0d442 dt-bindings: interrupt-controller: Add SOPHGO CV1812H plic dce8266bb548 ARM: dts: omap: logicpd-torpedo: do not disguise GNSS device 0f0cee70a881 ARM: dts: omap4-embt2ws: enable 32K clock on WLAN 33dfdcf03832 ARM: dts: ti/omap: Replace deprecated extcon-usb-gpio id-gpio/vbus-gpio properties aa5a9a109405 dt-bindings: power: meson-g12a-power: document ISP power domain a9f86a1f45b5 dt-bindings: marvell: Add Marvell MV88E6060 DSA schema 5024553a10f5 dt-bindings: marvell: Rewrite MV88E6xxx in schema ad4c44e96eec dt-bindings: net: ethernet-switch: Accept special variants 17baedd697fb dt-bindings: net: mvusb: Fix up DSA example 9c7ccdf2dc30 dt-bindings: net: dsa: Require ports or ethernet-ports 8adbf64f3cdd dt-bindings: input: mediatek,pmic-keys: Drop incomplete example cdc098b167e1 dt-bindings: input: sprd,sc27xx-vibrator: Drop incomplete example 0629a76a9d04 dt-bindings: correct white-spaces in examples 2f78b6dd5c42 dt-bindings: reset: hisilicon,hi3660-reset: Drop providers and consumers from example f835598ebf60 dt-bindings: arm/calxeda: drop unneeded quotes 0d2567437a54 dt-bindings: fsl,dpaa2-console: drop unneeded quotes 352ed027a423 dt-bindings: interrupt-controller: qcom,pdc: document pdc on X1E80100 df641036bac4 dt-bindings: qcom,pdc: document the SM8650 Power Domain Controller 1e17b2ba4499 dt-bindings: interrupt-controller: Add SDX75 PDC compatible c0aff4abb03a dt-bindings: reset: imx-src: Simplify compatible schema and drop unneeded quotes df20c9f94014 dt-bindings: reset: qcom: drop unneeded quotes 1516b28c7069 dt-bindings: reset: renesas,rzg2l-usbphy-ctrl: Document RZ/Five SoC a80bc27a0fe8 dt-bindings: reset: Add compatible and DT bindings for Amlogic C3 Reset Controller 0b8db84ecfc4 ASoC: Intel: Soundwire related board and match updates 303600aff1ef Merge v6.7-rc3 into drm-next d03f6dca688d arm64: dts: rockchip: Use NCM6A-IO board for edgeble-neu6b 2dcf7dbe2812 dt-bindings: arm: rockchip: Update edgeble-neu6 bindings b2a45d98f95b arm64: dts: rockchip: add USB3 host on rk3588s-orangepi-5 766aa3119c2f ARM: dts: motorola-mapphone: Add basic support for mz609 and mz617 3ea15a23d9c7 ARM: dts: motorola-mapphone: Move handset devices to a common file 5127524f7e6f ARM: dts: motorola-mapphone: Move LCD to common file for xt875 and xt894 7e16bd264a3a dt-bindings: omap: Add Motorola mapphone mz609 and mz617 tablets 7d420d843f98 ARM: dts: renesas: r9a06g032: Add missing space in compatible 0faa59be192f arm64: dts: renesas: r9a09g011: Add missing space in compatible 807cfe5cde5c dt-bindings: phy: add compatible for Mediatek MT8195 c52707b1bf77 dt-bindings: phy: amlogic,g12a-mipi-dphy-analog: drop unneeded reg property and example 34ec5dda2a01 dt-bindings: phy: amlogic,meson-axg-mipi-pcie-analog: drop text about parent syscon and drop example f738d7a9dfab dt-bindings: iommu: dart: Add t8103-usb4-dart compatible 2c963cfa7e8e ARM: dts: renesas: armadillo800eva: Add LCD panel a35135dad31c dt-bindings: pinctrl: renesas: Drop unneeded quotes d5212619f0a0 ARM: dts: renesas: r8a7740: Add LCDC nodes 048bdb67a0f6 arm64: dts: renesas: draak: Move HDMI bus properties to correct node ab52a67f9767 arm64: dts: renesas: draak: Make HDMI the default video input dab3ba03f28c Merge 6.7-rc3 into usb-next ec6cd76a8793 arm64: dts: meson-axg: jethub-jxx add support for EEPROM 2da076589eac arm64: dts: amlogic: meson-axg: pinctrl node for NAND cdc5df918882 arm64: dts: amlogic: minor whitespace cleanup around '=' a5dead35fc4b arm64: dts: Add watchdog node for Amlogic S4 SoCs 37c5369b4667 arm64: dts: Add watchdog node for Amlogic C3 SoCs 1d8b2a265b81 dt-bindings: soc: amlogic,meson-gx-hhi-sysctrl: add example covering meson-axg-hhi-sysctrl 9556e1708419 ARM: dts: imx7s: Add DMA channels for CSPI peripherals c1e5b6c6855f arm64: dts: imx8mp-venice-gw72xx: add TPM device fc1ee0050ce4 arm64: dts: imx8mm-venice-gw72xx: add TPM device 5a125bf20bf1 arm64: dts: imx93: update anatop node 292fc296ecdd arm64: dts: imx93-11x11-evk: add 12 ms delay to make sure the VDD_SD power off b81451d8d4d3 arm64: dts: imx93: change tuning start to get a large scan range for standard tuning 7ee940495143 arm64: dts: imx93-11x11-evk: set SION for cmd and data pad of USDHC 1b2037987962 arm64: dts: imx8mp: Describe M24C32-D write-lockable page in DH i.MX8MP DHCOM DT 94d5d7d36ba8 ARM: dts: imx6ul: mba6ulx: fix typo in comments cbbed6036bfe ARM: dts: imx6qdl: mba6: fix typo in comments e6c50d6fd99e arm64: dts: imx8mp-beacon-kit: Enable DSI to HDMI Bridge 3743277142d0 arm64: dts: imx8mm: Add CCM interrupts 663758efb819 arm64: dts: imx8mn: Add CCM interrupts 88774bafda13 arm64: dts: imx8mp: Add CCM interrupts e4d9f4208c6c ARM: dts: imx7s: Add missing #thermal-sensor-cells e4c3f040fee6 ARM: dts: imx7s: Fix nand-controller #size-cells 62a7c97c7c3f ARM: dts: imx7s: Fix lcdif compatible 9f3037b332bf ARM: dts: imx7d: Fix coresight funnel ports d844fe5270b1 arm64: dts: freescale: add initial device tree for MBa93xxCA starter kit ad161fbd54ca arm64: dts: freescale: tqma9352-mba93xxla: add 'chassis-type' property 8ec09c8f530c arm64: dts: imx93: Configure clock rate for audio PLL 9d7ba48273ea arm64: dts: imx93: Add audio device nodes b1553710809c dt-bindings: iio: hmc425a: add entry for ADRF5740 Attenuator 471ace1f09be dt-bindings: gpio: brcmstb: drop unneeded quotes f8159413e6f1 ARM: dts: ti: keystone: minor whitespace cleanup around '=' 381a63044158 dt-bindings: clock: g12a-clkc: add MIPI ISP & CSI PHY clock ids c1ad3e49f07c dt-bindings: clk: g12a-clkc: add CTS_ENCL clock ids c8fb56a76774 dt-bindings: dma: qcom,gpi: document the SM8650 GPI DMA Engine 8e868f10ea21 dt-bindings: dma: rz-dmac: Document RZ/Five SoC e1504d7602c0 dt-bindings: net: qcom,ipa: add SM8550 compatible f118e169a194 dt-bindings: dma: qcom: gpi: add compatible for X1E80100 11518ff4d13c dt-bindings: pinctrl: qcom: Add X1E80100 pinctrl d3fe1008f0c8 ASoC: dt-bindings: correct white-spaces in examples f9b11918132f dt-bindings: crypto: convert Inside Secure SafeXcel to the json-schema 52b8a84c5283 dt-bindings: dma: ti: k3-udma: Describe cfg register regions 9b2e4fa1e7f2 dt-bindings: dma: ti: k3-pktdma: Describe cfg register regions 6d91e2a3766b dt-bindings: dma: ti: k3-bcdma: Describe cfg register regions ea1d92699d2a dt-bindings: dma: ti: k3-*: Add descriptions for register regions 7cf45f021d31 arm64: dts: exynosautov9: use Exynos7 fallbacks for pin wake-up controller dc0e2a7e69c2 arm64: dts: exynos850: use Exynos7 fallbacks for pin wake-up controllers 185cc3e40c9f dt-bindings: pinctrl: samsung: use Exynos7 fallbacks for newer wake-up controllers 54829849af39 Merge branch 'icc-x1e80100' into icc-next 8e2202f335a4 dt-bindings: interconnect: Add Qualcomm X1E80100 SoC 54f1f68e019b dt-bindings: interconnect: qcom-bwmon: document SM8650 BWMONs 4e7bf80ce812 dt-bindings: interconnect: document the RPMh Network-On-Chip Interconnect in Qualcomm SM8650 SoC 615397ecb02b Merge git://git.kernel.org/pub/scm/linux/kernel/git/netdev/net e673bd9cbb13 dt-bindings: serial: fsl-linflexuart: change the maintainer email address f79b00fe4cab dt-bindings: serial: renesas,sci: Document RZ/Five SoC 911d5cce2a4e Merge tag 'drm-misc-next-2023-11-23' of git://anongit.freedesktop.org/drm/drm-misc into drm-next ab1f350663b1 dt-bindings: power: rpmpd: Update part number to X1E80100 6fe8e1a8dc99 dt-bindings: backlight: mp3309c: Remove two required properties cc4e22233cb5 dt-bindings: usb: qcom,dwc3: adjust number of interrupts on SM6125 9161184d7271 dt-bindings: net: renesas,ethertsn: Add Ethernet TSN 788d52642da4 Merge tag 'v6.7-rc2' into media_stage d2975fb00035 dt-bindings: gpu: Add Imagination Technologies PowerVR/IMG GPU 59078ccb21d1 dt-bindings: usb: qcom,dwc3: document the SM8560 SuperSpeed DWC3 USB controller 627316c016dd dt-bindings: usb: renesas,usbhs: Document RZ/Five SoC 99b07ecabc3d dt-bindings: cache: sifive,ccache0: Add StarFive JH7100 compatible 0118ff6d8abd ASoC: dt-bindings: fsl,mqs: Convert format to json-schema 0a9a12593184 ASoC: dt-bindings: sound-card-common: List sound widgets ignoring system suspend 165648aad162 ARM: dts: stm32: add SPI support on STM32F746 8f3fa20269a0 ARM: dts: stm32: add STM32F746 syscfg clock dc50601ba2d8 dt-bindings: net: xlnx,axi-ethernet: Introduce DMA support 72d23e1de1b0 arm64: dts: imx8mp: Add reserve-memory nodes for DSP 9bab315d31f8 spi: axi-spi-engine improvements 23a75f159231 ARM: dts: stm32: use the same 3v3 for SD and DSI nodes on stm32f469-disco 4656437906e9 ARM: dts: rockchip: Make usbphy the parent of SCLK_USB480M for RK3128 25251d661471 ARM: dts: rockchip: Add dwc2 otg fifo siztes for RK3128 2d36fa2aa286 ARM: dts: rockchip: Add USB host clocks for RK3128 4e1bd401bbe3 ARM: dts: rockchip: Add Geniatech XPI-3128 RK3128 board 7e6458d9a7f3 ARM: dts: rockchip: Add sdmmc_det pinctrl for RK3128 12867f1ccb42 dt-bindings: arm: rockchip: Add Geniatech XPI-3128 fda729bcbd69 arm64: dts: rockchip: Add Powkiddy RK2023 317a36f59e1b arm64: dts: rockchip: Update powkiddy,rgb30 include to rk2023 DTSI dc9a81379af6 dt-bindings: arm: rockchip: Add Powkiddy RK2023 70a31fd9ffa3 dt-bindings: spi: axi-spi-engine: convert to yaml b68504144dbe Merge tag 'drm-misc-next-2023-11-17' of git://anongit.freedesktop.org/drm/drm-misc into drm-next 8260e721d1b5 dt-bindings: display: nv3051d: Update NewVision NV3051D compatibles 0a502f9716cc arm64: dts: renesas: rzg3s-smarc: Enable SDHI1 eccf7ee1aefe arm64: dts: renesas: rzg3s-smarc-som: Enable SDHI2 fbd14cd9ff35 ARM: dts: microchip: sam9x60ek: Add IRQ support for ethernet PHY c86d9749ca2a ARM: dts: microchip: sam9x60_curiosity: Add IRQ support for ethernet PHY 1e1f6887a01b arm64: dts: allwinner: h616: add Orange Pi Zero 2W support 5795c68b5edc dt-bindings: arm: sunxi: add Orange Pi Zero 2W a5b7fa02fbde dt-bindings: crypto: qcom,prng: document SM8650 53be5450f8ac dt-bindings: crypto: qcom-qce: document the SM8650 crypto engine e65dc233e98b dt-bindings: crypto: qcom,inline-crypto-engine: document the SM8650 ICE d2a2bd80cca6 dt-bindings: net: renesas,etheravb: Document RZ/Five SoC f491b5315b58 dt-bindings: Document Marvell Aquantia PHY 7b52e889e53f arm64: dts: rockchip: add analog audio to RK3588 EVB1 92de4720f37c spi: dt-bindings: renesas,rspi: Document RZ/Five SoC 6e54c4bd7590 ASoC: dt-bindings: renesas,rz-ssi: Document RZ/Five SoC 87bb03481662 dt-bindings: adis16460: Add 'spi-cs-inactive-delay-ns' property 91e2c8ceb4de dt-bindings: adis16475: Add 'spi-cs-inactive-delay-ns' property f9fe5526efd5 dt-bindings: iio: Add MCP9600 thermocouple EMF converter 9942ece9d870 dt-bindings: iio: imu: Add Bosch BMI323 49d380d6e152 dt-bindings: adc: provide max34408/9 device tree binding document 895869158303 dt-bindings: media: wave5: add yaml devicetree bindings 77bf61c28407 dt-bindings: arm: Add support for DSB MSR register 18adf91da0ca dt-bindings: arm: Add support for DSB element size 075ac55ca93b dt-bindings: phy: qcom,snps-eusb2: document the SM8650 Synopsys eUSB2 PHY fda8409f7058 dt-bindings: phy: qcom,sc8280xp-qmp-usb43dp-phy: document the SM8650 QMP USB/DP Combo PHY b0b6815d9143 dt-bindings: phy: qcom,sc8280xp-qmp-pcie-phy: document the SM8650 QMP PCIe PHYs db24b834638a dt-bindings: phy: qcom,sc8280xp-qmp-ufs-phy: document the SM8650 QMP UFS PHY 6a737e056a8b media: dt-bindings: Add JH7110 Camera Subsystem 716cbea9d35a dt-bindings: power: reset: $ref reboot-mode in nvmem-reboot-mode c8dedfdf167b dt-bindings: power: reset: $ref reboot-mode in syscon-reboot-mode 6c14a95472bb ARM: dts: samsung: s5pv210: fix camera unit addresses/ranges 866767db6bbb ARM: dts: samsung: exynos4: fix camera unit addresses/ranges f0d3848e2cef ARM: dts: samsung: exynos4x12: replace duplicate pmu node with phandle dc6ff9889013 dt-bindings: w1: Add AMD AXI w1 host and MAINTAINERS entry a8a9188e96a6 dt-bindings: power: fsl,scu-pd: Document imx8dl f06b78172daa dt-bindings: qcom,pdc: Add compatible for SM8550 7a87643120eb dt-bindings: input: samsung,s6sy761: convert to DT schema e4ccdd770c53 Merge branch 'for-v6.8/samsung-bindings-compatibles' into next/dt64 7b213bd80e13 dt-bindings: hwinfo: samsung,exynos-chipid: add exynosautov920 compatible 892b87e000d2 dt-bindings: arm: samsung: Document exynosautov920 SADK board binding ce1b89aee7ea dt-bindings: pwm: samsung: add exynosautov920 compatible 5e6bd42714ad dt-bindings: serial: samsung: add exynosautov920-uart compatible 3ea12f0eff84 dt-bindings: samsung: usi: add exynosautov920-usi compatible 5b6e042a72b8 dt-bindings: samsung: exynos-pmu: add exynosautov920 compatible 2dff85192843 dt-bindings: samsung: exynos-sysreg: add exynosautov920 sysreg 3123103c12c0 dt-bindings: pinctrl: samsung: add exynosautov920 5b929ffdc9be arm64: dts: exynos: add gpio-key node for exynosautov9-sadk 6bc5effbe8dd arm64: dts: exynosautov9: add specific compatibles to several blocks 25addf827769 arm64: dts: exynos850: add specific compatibles to several blocks 5ab70c11f08f arm64: dts: exynos7885: add specific compatibles to several blocks f7c77a1ea95a arm64: dts: exynos7: add specific compatibles to several blocks 56493af64c01 arm64: dts: exynos5433: add specific compatibles to several blocks 3530786802b6 dt-bindings: pwm: samsung: add specific compatibles for existing SoC 97419692fe3c ASoC: dt-bindings: samsung-i2s: add specific compatibles for existing SoC 7081448ca2cf dt-bindings: iio: samsung,exynos-adc: add specific compatibles for existing SoC 973115e1f51f dt-bindings: gpu: arm,mali-midgard: add specific compatibles for existing Exynos SoC 6b99281097f0 dt-bindings: samsung: exynos-pmu: add specific compatibles for existing SoC a893a294345b dt-bindings: serial: samsung: add specific compatibles for existing SoC 2a3d0691d56f dt-bindings: rtc: s3c-rtc: add specific compatibles for existing SoC 7e49408d51e6 dt-bindings: pinctrl: samsung: add specific compatibles for existing SoC 1bb1eca74ad5 Merge drm/drm-next into drm-misc-next e9731895ee20 dt-bindings: mmc: samsung,exynos-dw-mshc: add specific compatibles for existing SoC 33b5aa8f7d9a ARM: dts: qcom: mdm9615: drop qcom, prefix from SSBI node name fa1f536e3df0 ARM: dts: qcom: ipq8064: drop qcom, prefix from SSBI node name 4e5382dc8820 ARM: dts: qcom: apq8060-dragonboard: rename mpp ADC channels to adc-channel 6be6ba7888ef ARM: dts: qcom: pm8921: Disable keypad by default 5917ae72cd70 ARM: dts: qcom: msm8974: move regulators to board files 551cbcd2547c ARM: dts: qcom: msm8960: drop useless rpm regulators node 6d9878cc6a6a ARM: dts: qcom: msm8660: move RPM regulators to board files d0ed11e33ba0 ARM: dts: qcom: mdm9615: move RPM regulators to board files 1c636116afea ARM: dts: qcom: apq8064: move RPM regulators to board files b9d11fecae9e ARM: dts: qcom: pm8058: switch to interrupts-extended e8a26b432fd4 ARM: dts: qcom: pm8018: switch to interrupts-extended 86831cb445f6 ARM: dts: qcom: pm8921: switch to interrupts-extended 6d6c0b95e077 ARM: dts: qcom: pm8058: use defined IRQ flags 9d0903209824 ARM: dts: qcom: pm8921: move reg property 6a63db48b660 ARM: dts: qcom: pm8018: move reg property 9d6af1dd4790 ARM: dts: qcom: pm8921: reorder nodes 5db5515193a6 ARM: dts: qcom: pm8058: reorder nodes d4df6f1babb5 ARM: dts: qcom: msm8660: split PMIC to separate dtsi files c56480ffb4b8 ARM: dts: qcom: mdm9615: split PMIC to separate dtsi files f8574d2c7c62 ARM: dts: qcom: apq8064: split PMICs to separate dtsi files 298695290d90 ARM: dts: qcom: msm8960: split PMIC to separate dtsi files 1c3c930ec46c ARM: dts: qcom: msm8960: move PMIC interrupts to the board files 7f5541db889f ARM: dts: qcom: msm8660: move PMIC interrupts to the board files 812cfe71b26a ARM: dts: qcom: mdm9615: move PMIC interrupts to the board files f5c8a18b7116 ARM: dts: qcom: apq8064: move PMIC interrupts to the board files b7510b8da2f6 ARM: dts: qcom: msm8960: fix PMIC node labels 6475671dcca1 ARM: dts: qcom: msm8660: fix PMIC node labels 4dfac4d841ef ARM: dts: qcom: mdm9615: fix PMIC node labels 07091c1b87fb ARM: dts: qcom: apq8064: fix PMIC node labels 155004433670 ARM: dts: qcom: strip prefix from PMIC files 21220b16b281 ARM: dts: qcom: mdm9615-wp8548-mangoh-green: group include clauses 3d3f8059a9f6 ARM: dts: qcom: apq8064-nexus7: move sdcc1 node to proper place b9d136b033b8 ARM: dts: qcom: msm8660-surf: use keypad label directly fc4f79da1abe ARM: dts: qcom: msm8960: introduce label for PMIC keypad 0e33f3448e7c ARM: dts: qcom: apq8064: correct XOADC register address 9bed8b24890a ARM: dts: qcom-sdx65: switch USB QMP PHY to new style of bindings edfbe32172f4 ARM: dts: qcom-sdx55: switch USB QMP PHY to new style of bindings c709366fb89e arm64: dts: qcom: sm8350: switch USB QMP PHY to new style of bindings 29a99a6d955d arm64: dts: qcom: sm8250: switch USB QMP PHY to new style of bindings e13f8dc0ea91 arm64: dts: qcom: sm8150: switch USB QMP PHY to new style of bindings bed6aed8ceec arm64: dts: qcom: sdm845: switch USB QMP PHY to new style of bindings 7cb8dff829b0 arm64: dts: qcom: msm8998: switch USB QMP PHY to new style of bindings 77a8ce42cb30 arm64: dts: qcom: msm8996: switch USB QMP PHY to new style of bindings b92a18870b3e arm64: dts: qcom: ipq8074: switch USB QMP PHY to new style of bindings 18dd153b1c8f arm64: dts: qcom: ipq6018: switch USB QMP PHY to new style of bindings ad3769d7933c Merge tag 'qcom-arm64-for-6.7-2' into arm64-for-6.8 8088e683c89b dt-bindings: i2c: samsung,s3c2410-i2c: add specific compatibles for existing SoC c15df41a0c35 dt-bindings: i2c: exynos5: add specific compatibles for existing SoC d755df63e9df dt-bindings: hwinfo: samsung,exynos-chipid: add specific compatibles for existing SoC 6f4cb3f40711 arm64: dts: renesas: rzg2lc-smarc-som: Enable 4-bit tx support 5ddba1791b2b arm64: dts: renesas: rzg2l-smarc-som: Enable 4-bit tx support 75b8e7f58abe regulator: add under-voltage support (part 2) 791f1550a798 Add DMIC slew rate controls e128625eb7cb dt-bindings: pinctrl: document the SM8650 Top Level Mode Multiplexer c3c85cc965c8 dt-bindings: pinctrl: qcom,sm8650-lpass-lpi-pinctrl: add SM8650 LPASS 6da3c9fd1509 ARM: dts: renesas: marzen: Rename keyboard nodes 2d7a77894ba8 ARM: dts: renesas: iwg22d-sodimm: Fix stmpe node names f4c62eb4fbd6 arm64: dts: renesas: Add missing ADV751[13] power supply properties a94c426db9b8 ARM: dts: renesas: Add missing ADV751[13] power supply properties f213adc3b192 ARM: dts: renesas: rcar-gen2: Fix I2C bus demux node names 127c56414e9f riscv: dts: renesas: Convert isa detection to new properties 9836c1c69324 ARM: dts: renesas: blanche: Add FLASH node d446795daa00 ARM: dts: renesas: marzen: Add FLASH node 9a4a8a78013a spi: add stm32f7-spi compatible e74e9793f9c7 regulator: dt-bindings: Add 'regulator-uv-less-critical-window-ms' property eafbf4f37d51 regulator: dt-bindings: Allow system-critical marking for fixed-regulator 52381ed5b4ac regulator: dt-bindings: Add system-critical-regulator property ec8f058714a6 dt-bindings: regulator: qcom,smd-rpm-regulator: Document PM8937 IC cf118cc80e89 dt-bindings: regulator: qcom,spmi-regulator: Document PM8937 PMIC 2ae471b5eeb2 ASoC: dt-bindings: use "soundwire" as controller's node name in examples caa17228e281 ASoC: dt-bindings: qcom,sm8250: add SM8550 sound card 2d2f997a2bdc dt-bindings: es8328: convert to DT schema format 68e113702391 ASoC: dt-bindings: Simplify port schema eac536a576c7 ASoC: dt-bindings: nau8821: Add DMIC slew rate. 409f501ee9b2 dt-bindings: gpu: v3d: Add BCM2712's compatible 22f7441e8685 dt-bindings: display: ssd132x: Remove '-' before compatible enum a3de98e60ec5 ARM: dts: qcom: add device tree for Nokia Lumia 830 9ad6bcd4499d ARM: dts: qcom: add device tree for Nokia Lumia 735 41ee9ea2aefd ARM: dts: qcom: add device tree for Microsoft Lumia 640 XL 0dc127c0d612 ARM: dts: qcom: add device tree for Microsoft Lumia 640 d30c995f440e ARM: dts: qcom: add common dt for MSM8x26 Lumias along with Nokia Lumia 630 ed92546211d5 dt-bindings: arm: qcom: Document MSM8x26-based Lumia phones d783936fa1dc arm64: dts: qcom: msm8939-longcheer-l9100: Enable RGB LED b14cb550d720 arm64: dts: qcom: msm8916-longcheer-l8910: Enable RGB LED 183a2f447424 arm64: dts: qcom: msm8939-samsung-a7: Add sound and modem 9b7d68606781 arm64: dts: qcom: msm8916-samsung-j5: Add sound and modem f382f197e0c5 arm64: dts: qcom: msm8916-samsung-gt5: Add sound and modem 59a815c1572d arm64: dts: qcom: msm8916-longcheer-l8910: Add sound and modem 582b4cfec9a9 ARM: dts: qcom: msm8226: provide dsi phy clocks to mmcc 1703230be2a6 ARM: dts: qcom: msm8974: sort nodes by reg e23f302820cb ARM: dts: qcom: msm8974: replace incorrect indentation in interconnect 373015625e6b arm64: dts: qcom: msm8916-longcheer-l8150: Add sound and modem c1a66861dc32 arm64: dts: qcom: msm8916-asus-z00l: Add sound and modem 489f91f0dfcc arm64: dts: qcom: msm8916-alcatel-idol347: Add sound and modem 2f81e02a3b04 arm64: dts: qcom: msm8916-wingtech-wt88047: Add sound and modem 07047876d71e arm64: dts: qcom: msm8916-samsung-serranove: Add sound and modem 1d94420f32b0 arm64: dts: qcom: msm8916-samsung-a2015: Add sound and modem 9334b10d351c arm64: dts: qcom: msm8916: Add common msm8916-modem-qdsp6.dtsi 30b857e0f639 arm64: dts: qcom: msm8939: Add QDSP6 5b210c47425a arm64: dts: qcom: msm8916: Add QDSP6 f1aed61c2c48 arm64: dts: qcom: msm8939: Add BAM-DMUX WWAN 702f57c12856 arm64: dts: qcom: sc8280xp-x13s: add missing camera LED pin config d21fc2d89cfd arm64: dts: qcom: pm7250b: Use correct node name for gpios ecc4cb08c0f3 arm64: dts: qcom: sc7280: Add Camera Control Interface busses c01ef95e3aa7 arm64: dts: qcom: sdm845-xiaomi-beryllium: enable flash led fe3ccb41dafa arm64: dts: qcom: sdm845-oneplus: enable flash LED 0f6538f89c64 arm64: dts: qcom: sc8280xp-x13s: Use the correct DP PHY compatible c9e8e85b1afd arm64: dts: qcom: msm8916-*: Fix alphabetic node order 9e38e840740d arm64: dts: qcom: msm8939-longcheer-l9100: Enable wcnss_mem 5cdb05e593ef arm64: dts: qcom: msm8916-samsung-gt5: Enable GPU 0d72dfbbf352 arm64: dts: qcom: ipq5332: include the GPLL0 as clock provider for mailbox 13c545bfe884 arm64: dts: qcom: ipq9574: include the GPLL0 as clock provider for mailbox 8b57686e7ad0 arm64: dts: qcom: ipq6018: include the GPLL0 as clock provider for mailbox 11d8f7a1bf44 arm64: dts: qcom: ipq8074: include the GPLL0 as clock provider for mailbox 9b0b036ea0de arm64: dts: qcom: ipq9574: populate the opp table based on the eFuse f3636ba1edce arm64: dts: qcom: ipq5332: populate the opp table based on the eFuse 8831b26a6579 arm64: dts: qcom: sdm670: add specific cpufreq compatible 8ce87f299cdb arm64: dts: qcom: sm8150: extend the size of the PDC resource b3cbe4ff9c30 arm64: dts: qcom: ipq5018: add QUP1 SPI controller f330c2991aa0 arm64: dts: qcom: qrb4210-rb2: don't force usb peripheral mode daa68cbafb06 arm64: dts: qcom: Enable tsens and thermal for sa8775p SoC 6232143457ae arm64: dts: qcom: sa8775p: Add RPMh sleep stats 973959c2edf1 arm64: dts: qcom: sc7280: Add ports subnodes in usb/dp qmpphy node 4c021a56b758 arm64: dts: qcom: sm6375-pdx225: Add USBPHY regulators 6fb033b4f60e arm64: dts: qcom: sm6375-pdx225: Enable ATH10K WiFi fa14ce25949b arm64: dts: qcom: sm6375-pdx225: Enable MSS e77ac5cceb8e arm64: dts: qcom: sm6375: Add UART1 dec2e7998de5 arm64: dts: qcom: ipq9574: Enable WPS buttons d3619641203e arm64: dts: qcom: ipq9574: Add common RDP dtsi file 9faa71835343 arm64: dts: qcom: ipq5018: Enable USB 71275274da1f arm64: dts: qcom: ipq5018: Add USB related nodes af8b25f21479 arm64: dts: qcom: sc7280: add TRNG node 00e1b06bb47a arm64: dts: qcom: sa8775p: add TRNG node ac7c5d2655a7 arm64: dts: qcom: sm8450: add TRNG node 0087dcd6513a arm64: dts: qcom: sm8550: add TRNG node
git-subtree-dir: dts/upstream git-subtree-split: b35b9bd1d4eed2acf8bc38ec5b1b6eef6261b4f0
Cc: Apurva Nandan a-nandan@ti.com Cc: Beniamino Galvani b.galvani@gmail.com Cc: Bryan Brattlof bb@ti.com
Acked-by: Bryan Brattlof bb@ti.com
Thanks Tom! I must say this was a nice DTB sync :)
~Bryan
Cc: Neil Armstrong neil.armstrong@linaro.org Cc: Tim Harvey tharvey@gateworks.com Cc: Vignesh Raghavendra vigneshr@ti.com Cc: u-boot-amlogic@groups.io
This commit moves OF_UPSTREAM platforms to the v6.8-dts tag. The patch itself isn't directly testable I think, and too huge to email regardless. The tree exists at: https://github.com/trini/u-boot/tree/WIP/29Mar2024-next and will for at least a few days before I merge this, if anyone wants to run-time test the changes. I'm still doing a world build before/after to see if any changes are visible that way. The CC list here was made by using "tools/qconfig.py -b" and then "tools/qconfig.py -f OF_UPSTREAM" and get_maintainer.pl on the defconfigs for the platforms that listed. If I'm missing maintainers of platforms using OF_UPSTREAM, I'm open to ideas on what to do next go-round.
Bindings/Makefile | 5 +- Bindings/arm/calxeda/l2ecc.yaml | 2 +- Bindings/arm/cpus.yaml | 1 + Bindings/arm/fsl.yaml | 22 +- Bindings/arm/google.yaml | 53 + .../arm/hisilicon/controller/sysctrl.yaml | 17 + Bindings/arm/marvell/armada-7k-8k.yaml | 22 + Bindings/arm/mediatek.yaml | 25 + Bindings/arm/mediatek/mediatek,audsys.txt | 39 - Bindings/arm/mediatek/mediatek,audsys.yaml | 153 + Bindings/arm/mediatek/mediatek,ethsys.txt | 29 - Bindings/arm/mediatek/mediatek,infracfg.yaml | 1 + Bindings/arm/mediatek/mediatek,mmsys.yaml | 3 + Bindings/arm/mediatek/mediatek,pericfg.yaml | 1 + Bindings/arm/msm/qcom,idle-state.txt | 84 - Bindings/arm/qcom,coresight-remote-etm.yaml | 51 + Bindings/arm/qcom,coresight-tpdm.yaml | 20 + Bindings/arm/qcom-soc.yaml | 16 +- Bindings/arm/qcom.yaml | 47 +- Bindings/arm/rockchip.yaml | 56 +- Bindings/arm/samsung/samsung-boards.yaml | 6 + Bindings/arm/sprd/sprd.yaml | 5 + Bindings/arm/stm32/stm32.yaml | 16 +- Bindings/arm/sunxi.yaml | 10 + Bindings/arm/ti/k3.yaml | 2 + Bindings/arm/ti/omap.yaml | 2 + Bindings/ata/ceva,ahci-1v84.yaml | 3 +- Bindings/auxdisplay/hit,hd44780.yaml | 2 +- Bindings/cache/qcom,llcc.yaml | 5 +- Bindings/cache/sifive,ccache0.yaml | 6 +- Bindings/clock/baikal,bt1-ccu-pll.yaml | 2 +- Bindings/clock/brcm,kona-ccu.txt | 138 - Bindings/clock/brcm,kona-ccu.yaml | 181 + Bindings/clock/fsl,imx93-anatop.yaml | 42 + Bindings/clock/google,gs101-clock.yaml | 106 + Bindings/clock/hi3620-clock.txt | 20 - Bindings/clock/mediatek,apmixedsys.yaml | 1 + Bindings/clock/mediatek,ethsys.yaml | 55 + Bindings/clock/mediatek,mt7988-ethwarp.yaml | 52 + Bindings/clock/mediatek,mt7988-xfi-pll.yaml | 48 + Bindings/clock/mediatek,mt8188-clock.yaml | 2 - Bindings/clock/mediatek,topckgen.yaml | 2 + Bindings/clock/qcom,a53pll.yaml | 1 + Bindings/clock/qcom,camcc-sm8250.yaml | 18 +- Bindings/clock/qcom,gcc-ipq6018.yaml | 57 + Bindings/clock/qcom,gcc-ipq8074.yaml | 4 + Bindings/clock/qcom,gcc-other.yaml | 3 - Bindings/clock/qcom,qdu1000-ecpricc.yaml | 68 + Bindings/clock/qcom,rpmhcc.yaml | 2 + Bindings/clock/qcom,sc7180-camcc.yaml | 18 +- Bindings/clock/qcom,sc7280-camcc.yaml | 18 +- Bindings/clock/qcom,sdm845-camcc.yaml | 18 +- Bindings/clock/qcom,sm8450-camcc.yaml | 20 +- Bindings/clock/qcom,sm8450-gpucc.yaml | 2 + Bindings/clock/qcom,sm8550-tcsr.yaml | 8 +- Bindings/clock/qcom,sm8650-dispcc.yaml | 106 + Bindings/clock/qcom,sm8650-gcc.yaml | 65 + Bindings/clock/qcom,x1e80100-gcc.yaml | 72 + Bindings/clock/renesas,9series.yaml | 10 + Bindings/clock/silabs,si5351.txt | 126 - Bindings/clock/silabs,si5351.yaml | 265 + Bindings/clock/sophgo,cv1800-clk.yaml | 46 + Bindings/clock/st,stm32mp25-rcc.yaml | 76 + Bindings/clock/xlnx,clocking-wizard.yaml | 1 + Bindings/clock/xlnx,versal-clk.yaml | 31 +- Bindings/connector/usb-connector.yaml | 124 +- Bindings/cpu/idle-states.yaml | 81 +- Bindings/crypto/inside-secure,safexcel.yaml | 86 + Bindings/crypto/inside-secure-safexcel.txt | 40 - .../crypto/qcom,inline-crypto-engine.yaml | 1 + Bindings/crypto/qcom,prng.yaml | 1 + Bindings/crypto/qcom-qce.yaml | 14 + Bindings/display/bridge/lontium,lt8912b.yaml | 21 + Bindings/display/bridge/nxp,tda998x.yaml | 7 +- Bindings/display/mediatek/mediatek,aal.yaml | 1 + Bindings/display/mediatek/mediatek,color.yaml | 1 + Bindings/display/mediatek/mediatek,dsi.yaml | 4 + Bindings/display/mediatek/mediatek,ethdr.yaml | 6 +- .../display/mediatek/mediatek,mdp-rdma.yaml | 88 - Bindings/display/mediatek/mediatek,merge.yaml | 4 + Bindings/display/mediatek/mediatek,ovl.yaml | 1 + .../display/mediatek/mediatek,padding.yaml | 83 + Bindings/display/mediatek/mediatek,split.yaml | 27 + Bindings/display/msm/dp-controller.yaml | 2 + Bindings/display/msm/dsi-controller-main.yaml | 3 + Bindings/display/msm/dsi-phy-7nm.yaml | 1 + Bindings/display/msm/mdss-common.yaml | 18 +- Bindings/display/msm/qcom,qcm2290-mdss.yaml | 21 +- Bindings/display/msm/qcom,sc7180-mdss.yaml | 14 +- Bindings/display/msm/qcom,sc7280-mdss.yaml | 14 +- Bindings/display/msm/qcom,sdm670-mdss.yaml | 292 + Bindings/display/msm/qcom,sdm845-dpu.yaml | 4 +- Bindings/display/msm/qcom,sm6115-mdss.yaml | 10 + Bindings/display/msm/qcom,sm6125-mdss.yaml | 8 +- Bindings/display/msm/qcom,sm6350-mdss.yaml | 8 +- Bindings/display/msm/qcom,sm6375-mdss.yaml | 8 +- Bindings/display/msm/qcom,sm8150-mdss.yaml | 6 +- Bindings/display/msm/qcom,sm8250-mdss.yaml | 10 + Bindings/display/msm/qcom,sm8450-mdss.yaml | 13 +- Bindings/display/msm/qcom,sm8650-dpu.yaml | 127 + Bindings/display/msm/qcom,sm8650-mdss.yaml | 328 + .../display/panel/fascontek,fs035vg158.yaml | 56 + Bindings/display/panel/himax,hx8394.yaml | 3 + Bindings/display/panel/ilitek,ili9805.yaml | 62 + Bindings/display/panel/ilitek,ili9881c.yaml | 1 + .../display/panel/leadtek,ltk035c5444t.yaml | 8 +- Bindings/display/panel/newvision,nv3051d.yaml | 2 +- .../panel/panel-simple-lvds-dual-ports.yaml | 2 + Bindings/display/panel/panel-simple.yaml | 4 + Bindings/display/panel/sitronix,st7701.yaml | 1 + Bindings/display/panel/synaptics,r63353.yaml | 61 + .../display/rockchip/inno_hdmi-rockchip.txt | 49 - .../display/rockchip/rockchip,inno-hdmi.yaml | 139 + Bindings/display/rockchip/rockchip-vop2.yaml | 100 +- .../display/samsung/samsung,exynos-mixer.yaml | 6 +- Bindings/display/ti/ti,am65x-dss.yaml | 14 + Bindings/dma/dma-controller.yaml | 15 - Bindings/dma/dma-router.yaml | 11 - Bindings/dma/loongson,ls2x-apbdma.yaml | 62 + Bindings/dma/nvidia,tegra210-adma.yaml | 3 + Bindings/dma/qcom,gpi.yaml | 2 + Bindings/dma/renesas,rz-dmac.yaml | 2 +- Bindings/dma/sifive,fu540-c000-pdma.yaml | 1 + Bindings/dma/ti/k3-bcdma.yaml | 39 +- Bindings/dma/ti/k3-pktdma.yaml | 26 +- Bindings/dma/ti/k3-udma.yaml | 20 +- Bindings/dts-coding-style.rst | 196 + Bindings/eeprom/at24.yaml | 1 + Bindings/firmware/qcom,scm.yaml | 18 +- .../firmware/xilinx/xlnx,zynqmp-firmware.yaml | 4 +- Bindings/fpga/altera-fpga2sdram-bridge.txt | 13 - Bindings/fpga/altera-freeze-bridge.txt | 20 - Bindings/fpga/altera-hps2fpga-bridge.txt | 36 - .../fpga/altr,freeze-bridge-controller.yaml | 41 + .../fpga/altr,socfpga-fpga2sdram-bridge.yaml | 33 + .../fpga/altr,socfpga-hps2fpga-bridge.yaml | 49 + Bindings/fpga/fpga-bridge.txt | 13 - Bindings/fpga/fpga-bridge.yaml | 30 + Bindings/fpga/xlnx,pr-decoupler.yaml | 5 +- Bindings/gnss/u-blox,neo-6m.yaml | 6 + Bindings/gpio/brcm,brcmstb-gpio.yaml | 2 +- Bindings/gpio/nuvoton,sgpio.yaml | 87 + Bindings/gpio/realtek,rtd-gpio.yaml | 69 + Bindings/gpio/rockchip,gpio-bank.yaml | 7 + Bindings/gpio/snps,dw-apb-gpio.yaml | 2 + Bindings/gpio/xlnx,gpio-xilinx.yaml | 2 +- Bindings/gpio/xlnx,zynqmp-gpio-modepin.yaml | 6 +- Bindings/gpu/arm,mali-midgard.yaml | 5 + Bindings/gpu/arm,mali-utgard.yaml | 1 + Bindings/gpu/brcm,bcm-v3d.yaml | 1 + Bindings/gpu/img,powervr.yaml | 73 + Bindings/gpu/samsung-g2d.yaml | 71 +- Bindings/gpu/samsung-rotator.yaml | 9 +- Bindings/gpu/samsung-scaler.yaml | 81 +- Bindings/hwinfo/samsung,exynos-chipid.yaml | 18 +- Bindings/hwmon/gpio-fan.txt | 41 - Bindings/hwmon/gpio-fan.yaml | 60 + Bindings/hwmon/iio-hwmon.yaml | 2 +- Bindings/hwmon/lltc,ltc4286.yaml | 50 + Bindings/hwmon/lm75.yaml | 33 + Bindings/i2c/i2c-exynos5.yaml | 11 +- Bindings/i2c/samsung,s3c2410-i2c.yaml | 22 +- Bindings/i2c/st,stm32-i2c.yaml | 28 + Bindings/iio/adc/adi,ad7091r5.yaml | 82 +- Bindings/iio/adc/adi,ad7780.yaml | 6 +- Bindings/iio/adc/maxim,max34408.yaml | 139 + Bindings/iio/adc/qcom,spmi-iadc.yaml | 10 +- Bindings/iio/adc/qcom,spmi-rradc.yaml | 4 +- Bindings/iio/adc/qcom,spmi-vadc.yaml | 9 +- Bindings/iio/adc/samsung,exynos-adc.yaml | 29 +- Bindings/iio/adc/ti,palmas-gpadc.yaml | 15 - Bindings/iio/amplifiers/adi,hmc425a.yaml | 4 + Bindings/iio/chemical/aosong,ags02ma.yaml | 47 + Bindings/iio/dac/adi,ad5791.yaml | 5 + Bindings/iio/dac/microchip,mcp4821.yaml | 86 + Bindings/iio/humidity/ti,hdc3020.yaml | 55 + Bindings/iio/imu/adi,adis16460.yaml | 4 + Bindings/iio/imu/adi,adis16475.yaml | 4 + Bindings/iio/imu/bosch,bmi323.yaml | 77 + Bindings/iio/light/liteon,ltr390.yaml | 56 + Bindings/iio/light/vishay,veml6075.yaml | 39 + Bindings/iio/pressure/honeywell,hsc030pa.yaml | 142 + .../iio/pressure/honeywell,mprls0025pa.yaml | 2 - .../iio/temperature/melexis,mlx90632.yaml | 19 +- .../iio/temperature/microchip,mcp9600.yaml | 70 + Bindings/index.rst | 1 + Bindings/input/adafruit,seesaw-gamepad.yaml | 63 + Bindings/input/elan,ekth6915.yaml | 5 +- Bindings/input/gpio-keys.yaml | 41 +- Bindings/input/gpio-mouse.txt | 32 - Bindings/input/gpio-mouse.yaml | 68 + Bindings/input/iqs269a.yaml | 98 +- Bindings/input/mediatek,pmic-keys.yaml | 24 +- Bindings/input/microchip,cap11xx.yaml | 80 +- Bindings/input/sprd,sc27xx-vibrator.yaml | 19 +- Bindings/input/ti,drv2665.txt | 17 - Bindings/input/ti,drv2667.txt | 17 - Bindings/input/ti,drv266x.yaml | 50 + .../input/touchscreen/neonode,zforce.yaml | 72 + .../input/touchscreen/samsung,s6sy761.txt | 32 - .../input/touchscreen/samsung,s6sy761.yaml | 54 + Bindings/input/touchscreen/zforce_ts.txt | 34 - Bindings/interconnect/qcom,msm8998-bwmon.yaml | 4 + Bindings/interconnect/qcom,sm6115.yaml | 152 + Bindings/interconnect/qcom,sm8650-rpmh.yaml | 136 + Bindings/interconnect/qcom,x1e80100-rpmh.yaml | 83 + .../loongson,liointc.yaml | 18 +- Bindings/interrupt-controller/qcom,mpm.yaml | 54 +- Bindings/interrupt-controller/qcom,pdc.yaml | 4 + .../renesas,rzg2l-irqc.yaml | 5 +- .../sifive,plic-1.0.0.yaml | 1 + .../st,stih407-irq-syscfg.yaml | 4 +- Bindings/iommu/apple,dart.yaml | 1 + Bindings/iommu/arm,smmu.yaml | 77 +- Bindings/iommu/rockchip,iommu.yaml | 11 +- Bindings/leds/allwinner,sun50i-a100-ledc.yaml | 137 + Bindings/leds/awinic,aw200xx.yaml | 95 +- Bindings/leds/backlight/mps,mp3309c.yaml | 10 +- Bindings/leds/common.yaml | 2 +- Bindings/leds/qcom,spmi-flash-led.yaml | 4 +- Bindings/loongarch/cpus.yaml | 61 + Bindings/loongarch/loongson.yaml | 34 + Bindings/mailbox/qcom,apcs-kpss-global.yaml | 62 +- Bindings/mailbox/qcom-ipcc.yaml | 1 + Bindings/mailbox/xlnx,zynqmp-ipi-mailbox.yaml | 132 +- Bindings/media/cnm,wave521c.yaml | 61 + .../media/i2c/alliedvision,alvium-csi2.yaml | 81 + Bindings/media/i2c/asahi-kasei,ak7375.yaml | 4 +- Bindings/media/i2c/galaxycore,gc0308.yaml | 108 + Bindings/media/i2c/galaxycore,gc2145.yaml | 113 + Bindings/media/i2c/ov8856.yaml | 24 +- Bindings/media/i2c/ovti,ov64a40.yaml | 103 + Bindings/media/i2c/sony,imx335.yaml | 13 + Bindings/media/i2c/techwell,tw9900.yaml | 137 + Bindings/media/i2c/thine,thp7312.yaml | 224 + Bindings/media/mediatek,mdp3-fg.yaml | 61 + Bindings/media/mediatek,mdp3-hdr.yaml | 61 + Bindings/media/mediatek,mdp3-rdma.yaml | 104 +- Bindings/media/mediatek,mdp3-rsz.yaml | 6 +- Bindings/media/mediatek,mdp3-stitch.yaml | 61 + Bindings/media/mediatek,mdp3-tcc.yaml | 62 + Bindings/media/mediatek,mdp3-tdshp.yaml | 61 + Bindings/media/mediatek,mdp3-wrot.yaml | 29 +- Bindings/media/rockchip-isp1.yaml | 11 +- Bindings/media/samsung,s5p-mfc.yaml | 47 +- Bindings/media/st,stm32-dcmipp.yaml | 89 + Bindings/media/starfive,jh7110-camss.yaml | 180 + Bindings/mfd/ams,as3711.yaml | 223 + Bindings/mfd/as3711.txt | 73 - Bindings/mfd/hisilicon,hi6421-spmi-pmic.yaml | 140 +- Bindings/mfd/qcom,pm8008.yaml | 6 +- Bindings/mfd/qcom,spmi-pmic.yaml | 7 + Bindings/mfd/qcom,tcsr.yaml | 2 + Bindings/mfd/samsung,exynos5433-lpass.yaml | 2 +- Bindings/mfd/sprd,ums512-glbreg.yaml | 4 +- Bindings/mfd/ti,am3359-tscadc.yaml | 2 - Bindings/misc/fsl,dpaa2-console.yaml | 2 +- Bindings/mmc/arasan,sdhci.yaml | 8 +- Bindings/mmc/arm,pl18x.yaml | 2 +- Bindings/mmc/brcm,sdhci-brcmstb.yaml | 4 +- Bindings/mmc/marvell,xenon-sdhci.yaml | 4 +- Bindings/mmc/mtk-sd.yaml | 9 + Bindings/mmc/renesas,sdhi.yaml | 2 +- Bindings/mmc/samsung,exynos-dw-mshc.yaml | 25 +- Bindings/mmc/sdhci-msm.yaml | 2 + Bindings/mmc/sdhci-pxa.yaml | 4 +- Bindings/mmc/snps,dwcmshc-sdhci.yaml | 1 + Bindings/mmc/synopsys-dw-mshc.yaml | 4 + Bindings/mtd/partitions/u-boot.yaml | 2 +- Bindings/net/dsa/dsa.yaml | 6 + Bindings/net/dsa/marvell,mv88e6060.yaml | 88 + Bindings/net/dsa/marvell,mv88e6xxx.yaml | 337 + Bindings/net/dsa/marvell.txt | 109 - Bindings/net/dsa/microchip,ksz.yaml | 34 +- Bindings/net/ethernet-switch.yaml | 23 +- Bindings/net/lantiq,pef2256.yaml | 213 + Bindings/net/marvell,aquantia.yaml | 116 + Bindings/net/marvell,mvusb.yaml | 7 +- Bindings/net/marvell,orion-mdio.yaml | 22 - Bindings/net/marvell,prestera.yaml | 4 +- Bindings/net/pcs/mediatek,sgmiisys.yaml | 65 +- Bindings/net/qcom,ipa.yaml | 24 +- Bindings/net/renesas,etheravb.yaml | 3 +- Bindings/net/renesas,ethertsn.yaml | 135 + Bindings/net/sff,sfp.yaml | 2 +- Bindings/net/xlnx,axi-ethernet.yaml | 16 + Bindings/nvmem/st,stm32-romem.yaml | 1 + Bindings/pci/brcm,stb-pcie.yaml | 18 + Bindings/pci/qcom,pcie.yaml | 63 +- Bindings/pci/rcar-pci-host.yaml | 11 + Bindings/pci/rockchip-dw-pcie.yaml | 2 + Bindings/pci/ti,j721e-pci-ep.yaml | 39 +- Bindings/pci/ti,j721e-pci-host.yaml | 39 +- Bindings/pci/toshiba,visconti-pcie.yaml | 2 +- Bindings/perf/fsl-imx-ddr.yaml | 3 + .../phy/amlogic,g12a-mipi-dphy-analog.yaml | 12 - .../amlogic,meson-axg-mipi-pcie-analog.yaml | 17 - Bindings/phy/mediatek,dsi-phy.yaml | 1 + Bindings/phy/mediatek,tphy.yaml | 9 + Bindings/phy/qcom,sc8280xp-qmp-pcie-phy.yaml | 5 + Bindings/phy/qcom,sc8280xp-qmp-ufs-phy.yaml | 2 + .../phy/qcom,sc8280xp-qmp-usb3-uni-phy.yaml | 3 + .../phy/qcom,sc8280xp-qmp-usb43dp-phy.yaml | 8 +- Bindings/phy/qcom,snps-eusb2-phy.yaml | 2 + Bindings/pinctrl/pinctrl-single.yaml | 1 + Bindings/pinctrl/qcom,ipq5018-tlmm.yaml | 12 +- Bindings/pinctrl/qcom,ipq5332-tlmm.yaml | 9 +- Bindings/pinctrl/qcom,ipq6018-pinctrl.yaml | 8 +- Bindings/pinctrl/qcom,ipq8074-pinctrl.yaml | 9 +- Bindings/pinctrl/qcom,ipq9574-tlmm.yaml | 9 +- Bindings/pinctrl/qcom,lpass-lpi-common.yaml | 75 + Bindings/pinctrl/qcom,mdm9607-tlmm.yaml | 18 +- Bindings/pinctrl/qcom,mdm9615-pinctrl.yaml | 18 +- Bindings/pinctrl/qcom,msm8226-pinctrl.yaml | 8 +- Bindings/pinctrl/qcom,msm8660-pinctrl.yaml | 9 +- Bindings/pinctrl/qcom,msm8909-tlmm.yaml | 18 +- Bindings/pinctrl/qcom,msm8916-pinctrl.yaml | 9 +- Bindings/pinctrl/qcom,msm8953-pinctrl.yaml | 7 +- Bindings/pinctrl/qcom,msm8960-pinctrl.yaml | 9 +- Bindings/pinctrl/qcom,msm8974-pinctrl.yaml | 9 +- Bindings/pinctrl/qcom,msm8976-pinctrl.yaml | 9 +- Bindings/pinctrl/qcom,msm8994-pinctrl.yaml | 9 +- Bindings/pinctrl/qcom,msm8996-pinctrl.yaml | 9 +- Bindings/pinctrl/qcom,msm8998-pinctrl.yaml | 9 +- Bindings/pinctrl/qcom,pmic-mpp.yaml | 62 +- Bindings/pinctrl/qcom,qcm2290-tlmm.yaml | 9 +- Bindings/pinctrl/qcom,qcs404-pinctrl.yaml | 9 +- Bindings/pinctrl/qcom,qdu1000-tlmm.yaml | 12 +- Bindings/pinctrl/qcom,sa8775p-tlmm.yaml | 21 +- Bindings/pinctrl/qcom,sc7180-pinctrl.yaml | 9 +- .../qcom,sc7280-lpass-lpi-pinctrl.yaml | 49 +- Bindings/pinctrl/qcom,sc7280-pinctrl.yaml | 30 +- Bindings/pinctrl/qcom,sc8180x-tlmm.yaml | 20 +- .../qcom,sc8280xp-lpass-lpi-pinctrl.yaml | 49 +- Bindings/pinctrl/qcom,sc8280xp-tlmm.yaml | 18 +- Bindings/pinctrl/qcom,sdm630-pinctrl.yaml | 10 +- Bindings/pinctrl/qcom,sdm670-tlmm.yaml | 19 +- Bindings/pinctrl/qcom,sdm845-pinctrl.yaml | 10 +- Bindings/pinctrl/qcom,sdx55-pinctrl.yaml | 8 +- Bindings/pinctrl/qcom,sdx65-tlmm.yaml | 8 +- Bindings/pinctrl/qcom,sdx75-tlmm.yaml | 12 +- Bindings/pinctrl/qcom,sm4450-tlmm.yaml | 151 + .../qcom,sm6115-lpass-lpi-pinctrl.yaml | 48 +- Bindings/pinctrl/qcom,sm6115-tlmm.yaml | 8 +- Bindings/pinctrl/qcom,sm6125-tlmm.yaml | 20 +- Bindings/pinctrl/qcom,sm6350-tlmm.yaml | 20 +- Bindings/pinctrl/qcom,sm6375-tlmm.yaml | 18 +- Bindings/pinctrl/qcom,sm7150-tlmm.yaml | 9 +- Bindings/pinctrl/qcom,sm8150-pinctrl.yaml | 9 +- .../qcom,sm8250-lpass-lpi-pinctrl.yaml | 49 +- Bindings/pinctrl/qcom,sm8250-pinctrl.yaml | 9 +- .../qcom,sm8350-lpass-lpi-pinctrl.yaml | 49 +- Bindings/pinctrl/qcom,sm8350-tlmm.yaml | 20 +- .../qcom,sm8450-lpass-lpi-pinctrl.yaml | 49 +- Bindings/pinctrl/qcom,sm8450-tlmm.yaml | 20 +- .../qcom,sm8550-lpass-lpi-pinctrl.yaml | 55 +- Bindings/pinctrl/qcom,sm8550-tlmm.yaml | 12 +- .../qcom,sm8650-lpass-lpi-pinctrl.yaml | 107 + Bindings/pinctrl/qcom,sm8650-tlmm.yaml | 141 + Bindings/pinctrl/qcom,x1e80100-tlmm.yaml | 137 + Bindings/pinctrl/renesas,rza2-pinctrl.yaml | 2 +- Bindings/pinctrl/renesas,rzg2l-pinctrl.yaml | 6 +- .../samsung,pinctrl-wakeup-interrupt.yaml | 45 +- Bindings/pinctrl/samsung,pinctrl.yaml | 5 +- Bindings/pinctrl/xlnx,zynq-pinctrl.yaml | 2 +- Bindings/pinctrl/xlnx,zynqmp-pinctrl.yaml | 2 +- Bindings/power/fsl,scu-pd.yaml | 1 + Bindings/power/qcom,rpmpd.yaml | 2 +- Bindings/power/reset/nvmem-reboot-mode.yaml | 8 +- Bindings/power/reset/qcom,pon.yaml | 13 +- Bindings/power/reset/syscon-reboot-mode.yaml | 8 +- Bindings/power/reset/xlnx,zynqmp-power.yaml | 4 +- Bindings/power/supply/bq24190.yaml | 1 + Bindings/power/supply/richtek,rt9455.yaml | 8 +- Bindings/power/wakeup-source.txt | 18 +- Bindings/pwm/mediatek,pwm-disp.yaml | 1 - Bindings/pwm/pwm-omap-dmtimer.txt | 22 - Bindings/pwm/pwm-samsung.yaml | 4 + Bindings/pwm/ti,omap-dmtimer-pwm.yaml | 59 + Bindings/regulator/fixed-regulator.yaml | 2 + Bindings/regulator/mps,mp5416.yaml | 4 +- Bindings/regulator/mps,mpq7920.yaml | 4 +- Bindings/regulator/qcom,rpmh-regulator.yaml | 14 + .../regulator/qcom,smd-rpm-regulator.yaml | 4 + Bindings/regulator/qcom,spmi-regulator.yaml | 19 + .../regulator/qcom,usb-vbus-regulator.yaml | 5 +- Bindings/regulator/regulator.yaml | 13 + Bindings/remoteproc/fsl,imx-rproc.yaml | 8 +- Bindings/remoteproc/qcom,sc7180-pas.yaml | 21 + Bindings/reset/amlogic,meson-reset.yaml | 1 + Bindings/reset/fsl,imx-src.yaml | 31 +- Bindings/reset/hisilicon,hi3660-reset.yaml | 25 +- Bindings/reset/qcom,aoss-reset.yaml | 10 +- Bindings/reset/qcom,pdc-global.yaml | 8 +- Bindings/reset/renesas,rzg2l-usbphy-ctrl.yaml | 2 +- Bindings/reset/xlnx,zynqmp-reset.yaml | 3 +- Bindings/riscv/cpus.yaml | 10 +- Bindings/riscv/extensions.yaml | 221 +- Bindings/riscv/sophgo.yaml | 4 + Bindings/rng/starfive,jh7110-trng.yaml | 6 +- Bindings/rtc/adi,max31335.yaml | 70 + Bindings/rtc/epson,rx8900.yaml | 2 + Bindings/rtc/nuvoton,ma35d1-rtc.yaml | 48 + Bindings/rtc/qcom-pm8xxx-rtc.yaml | 36 +- Bindings/rtc/s3c-rtc.yaml | 5 + Bindings/security/tpm/google,cr50.txt | 19 - Bindings/security/tpm/ibmvtpm.txt | 41 - Bindings/security/tpm/st33zp24-i2c.txt | 34 - Bindings/security/tpm/st33zp24-spi.txt | 32 - Bindings/security/tpm/tpm-i2c.txt | 26 - Bindings/security/tpm/tpm_tis_mmio.txt | 25 - Bindings/security/tpm/tpm_tis_spi.txt | 23 - Bindings/serial/arm,dcc.yaml | 30 + Bindings/serial/fsl,s32-linflexuart.yaml | 2 +- Bindings/serial/fsl-imx-uart.yaml | 29 +- Bindings/serial/qcom,msm-uartdm.yaml | 13 + Bindings/serial/renesas,sci.yaml | 2 +- Bindings/serial/samsung_uart.yaml | 28 +- Bindings/serial/snps-dw-apb-uart.yaml | 1 + Bindings/serial/sprd-uart.yaml | 1 + .../amlogic/amlogic,meson-gx-hhi-sysctrl.yaml | 33 + Bindings/soc/mediatek/mediatek,pwrap.yaml | 6 +- Bindings/soc/mediatek/mtk-svs.yaml | 2 + .../microchip,mpfs-sys-controller.yaml | 10 + Bindings/soc/qcom/qcom,aoss-qmp.yaml | 2 + Bindings/soc/qcom/qcom,pmic-glink.yaml | 22 +- Bindings/soc/qcom/qcom-stats.yaml | 14 + Bindings/soc/rockchip/grf.yaml | 2 + Bindings/soc/samsung/exynos-pmu.yaml | 10 + Bindings/soc/samsung/exynos-usi.yaml | 7 +- .../soc/samsung/samsung,exynos-sysreg.yaml | 5 + Bindings/{arm => soc/xilinx}/xilinx.yaml | 7 +- Bindings/sound/adi,max98363.yaml | 2 +- Bindings/sound/allwinner,sun4i-a10-spdif.yaml | 5 +- Bindings/sound/audio-graph-port.yaml | 6 + Bindings/sound/es8328.txt | 38 - Bindings/sound/everest,es8328.yaml | 77 + Bindings/sound/fsl,mqs.txt | 36 - Bindings/sound/fsl,mqs.yaml | 105 + Bindings/sound/fsl,xcvr.yaml | 22 +- Bindings/sound/google,sc7280-herobrine.yaml | 1 - Bindings/sound/mediatek,mt2701-audio.yaml | 116 + Bindings/sound/mediatek,mt8188-mt6359.yaml | 1 + Bindings/sound/mt2701-afe-pcm.txt | 146 - Bindings/sound/nuvoton,nau8821.yaml | 9 + .../sound/nvidia,tegra-audio-max9808x.yaml | 2 +- Bindings/sound/qcom,lpass-rx-macro.yaml | 23 +- Bindings/sound/qcom,lpass-tx-macro.yaml | 25 +- Bindings/sound/qcom,lpass-va-macro.yaml | 18 +- Bindings/sound/qcom,lpass-wsa-macro.yaml | 23 +- Bindings/sound/qcom,sm8250.yaml | 6 + Bindings/sound/qcom,wcd934x.yaml | 4 +- Bindings/sound/qcom,wcd938x-sdw.yaml | 4 +- Bindings/sound/qcom,wcd938x.yaml | 4 +- Bindings/sound/qcom,wsa883x.yaml | 2 +- Bindings/sound/qcom,wsa8840.yaml | 2 +- Bindings/sound/renesas,rsnd.yaml | 36 +- Bindings/sound/renesas,rz-ssi.yaml | 2 +- Bindings/sound/samsung-i2s.yaml | 19 +- Bindings/sound/sound-card-common.yaml | 7 + Bindings/sound/tas2562.yaml | 2 - Bindings/sound/ti,tas2781.yaml | 78 +- Bindings/sound/ti,tlv320aic32x4.yaml | 2 +- Bindings/spi/adi,axi-spi-engine.txt | 31 - Bindings/spi/adi,axi-spi-engine.yaml | 66 + Bindings/spi/renesas,rspi.yaml | 2 +- Bindings/spi/snps,dw-apb-ssi.yaml | 2 - Bindings/spi/st,stm32-spi.yaml | 2 + .../thermal/allwinner,sun8i-a83t-ths.yaml | 7 +- Bindings/thermal/loongson,ls2k-thermal.yaml | 10 +- Bindings/thermal/mediatek,thermal.yaml | 99 + Bindings/thermal/mediatek-thermal.txt | 52 - Bindings/thermal/qcom-spmi-adc-tm-hc.yaml | 8 +- Bindings/thermal/qcom-spmi-adc-tm5.yaml | 16 +- Bindings/thermal/qcom-tsens.yaml | 1 + Bindings/thermal/thermal-zones.yaml | 16 + Bindings/timer/sifive,clint.yaml | 2 + Bindings/timer/thead,c900-aclint-mtimer.yaml | 9 +- Bindings/tpm/google,cr50.yaml | 65 + Bindings/tpm/ibm,vtpm.yaml | 104 + Bindings/tpm/microsoft,ftpm.yaml | 47 + Bindings/tpm/tcg,tpm-tis-i2c.yaml | 90 + Bindings/tpm/tcg,tpm-tis-mmio.yaml | 49 + Bindings/tpm/tcg,tpm_tis-spi.yaml | 75 + Bindings/tpm/tpm-common.yaml | 87 + Bindings/trivial-devices.yaml | 24 +- Bindings/ufs/qcom,ufs.yaml | 2 + Bindings/ufs/samsung,exynos-ufs.yaml | 9 +- Bindings/ufs/ufs-common.yaml | 2 + Bindings/usb/dwc3-xilinx.yaml | 3 +- Bindings/usb/generic-xhci.yaml | 25 +- Bindings/usb/genesys,gl850g.yaml | 5 + Bindings/usb/mediatek,mtk-xhci.yaml | 11 + Bindings/usb/microchip,usb5744.yaml | 3 +- Bindings/usb/nxp,ptn5110.yaml | 2 +- Bindings/usb/qcom,dwc3.yaml | 151 +- Bindings/usb/qcom,wcd939x-usbss.yaml | 102 + Bindings/usb/renesas,usbhs.yaml | 2 +- Bindings/usb/snps,dwc3.yaml | 4 + Bindings/usb/ti,tps6598x.yaml | 6 + Bindings/usb/usb-xhci.yaml | 6 + Bindings/usb/xlnx,usb2.yaml | 3 +- Bindings/vendor-prefixes.yaml | 22 + Bindings/w1/amd,axi-1wire-host.yaml | 44 + .../watchdog/allwinner,sun4i-a10-wdt.yaml | 6 +- Bindings/watchdog/alphascale,asm9260-wdt.yaml | 6 +- Bindings/watchdog/apple,wdt.yaml | 6 +- Bindings/watchdog/arm-smc-wdt.yaml | 6 +- Bindings/watchdog/brcm,bcm7038-wdt.yaml | 10 +- Bindings/watchdog/cnxt,cx92755-wdt.yaml | 6 +- Bindings/watchdog/dlg,da9062-watchdog.yaml | 12 +- Bindings/watchdog/intel,keembay-wdt.yaml | 5 +- Bindings/watchdog/maxim,max63xx.yaml | 8 +- Bindings/watchdog/mediatek,mtk-wdt.yaml | 1 + Bindings/watchdog/nxp,pnx4008-wdt.yaml | 34 + Bindings/watchdog/pnx4008-wdt.txt | 17 - Bindings/watchdog/qca,ar7130-wdt.yaml | 33 + Bindings/watchdog/qca-ar7130-wdt.txt | 13 - Bindings/watchdog/qcom,pm8916-wdt.yaml | 33 +- Bindings/watchdog/qcom-wdt.yaml | 2 +- Bindings/watchdog/realtek,rtd119x.txt | 17 - .../watchdog/realtek,rtd1295-watchdog.yaml | 38 + Bindings/watchdog/samsung-wdt.yaml | 29 +- Bindings/watchdog/snps,dw-wdt.yaml | 10 +- Bindings/watchdog/technologic,ts7200-wdt.yaml | 45 + include/dt-bindings/arm/qcom,ids.h | 1 + include/dt-bindings/clock/g12a-clkc.h | 8 + include/dt-bindings/clock/google,gs101.h | 392 ++ .../dt-bindings/clock/mediatek,mt7988-clk.h | 280 + include/dt-bindings/clock/qcom,gcc-msm8939.h | 6 + .../dt-bindings/clock/qcom,qdu1000-ecpricc.h | 147 + .../dt-bindings/clock/qcom,sc8280xp-camcc.h | 179 + .../dt-bindings/clock/qcom,sm8650-dispcc.h | 102 + include/dt-bindings/clock/qcom,sm8650-gcc.h | 254 + include/dt-bindings/clock/qcom,sm8650-gpucc.h | 43 + include/dt-bindings/clock/qcom,sm8650-tcsr.h | 18 + .../dt-bindings/clock/qcom,videocc-sm8150.h | 4 + include/dt-bindings/clock/qcom,x1e80100-gcc.h | 485 ++ include/dt-bindings/clock/sophgo,cv1800.h | 176 + include/dt-bindings/clock/st,stm32mp25-rcc.h | 492 ++ include/dt-bindings/dma/fsl-edma.h | 21 + .../dt-bindings/iio/qcom,spmi-adc7-pm7325.h | 69 + .../dt-bindings/iio/qcom,spmi-adc7-smb139x.h | 19 + include/dt-bindings/iio/qcom,spmi-vadc.h | 3 + .../dt-bindings/interconnect/qcom,sm6115.h | 111 + .../interconnect/qcom,sm8650-rpmh.h | 154 + .../interconnect/qcom,x1e80100-rpmh.h | 207 + include/dt-bindings/power/meson-g12a-power.h | 1 + include/dt-bindings/reset/amlogic,c3-reset.h | 119 + .../reset/mediatek,mt7988-resets.h | 13 + include/dt-bindings/reset/mt8188-resets.h | 75 + include/dt-bindings/reset/qcom,sm8650-gpucc.h | 20 + include/dt-bindings/reset/st,stm32mp25-rcc.h | 167 + include/dt-bindings/soc/rockchip,vop2.h | 4 + src/arm/amazon/alpine.dtsi | 1 - .../aspeed/aspeed-bmc-facebook-bletchley.dts | 4 +- .../aspeed/aspeed-bmc-facebook-wedge400.dts | 4 +- src/arm/aspeed/aspeed-bmc-opp-tacoma.dts | 2 +- src/arm/aspeed/aspeed-g4.dtsi | 14 - src/arm/aspeed/aspeed-g5.dtsi | 15 +- src/arm/aspeed/aspeed-g6.dtsi | 18 +- .../ast2600-facebook-netbmc-common.dtsi | 4 +- src/arm/broadcom/bcm-cygnus.dtsi | 3 + src/arm/broadcom/bcm-hr2.dtsi | 1 + src/arm/broadcom/bcm-nsp.dtsi | 2 + src/arm/broadcom/bcm2711-rpi.dtsi | 5 + src/arm/broadcom/bcm2711.dtsi | 14 + src/arm/broadcom/bcm63138.dtsi | 6 + .../intel/ixp/intel-ixp42x-gateway-7001.dts | 2 + .../ixp/intel-ixp42x-goramo-multilink.dts | 2 + .../ixp/intel-ixp42x-usrobotics-usr8200.dts | 22 + src/arm/intel/socfpga/socfpga.dtsi | 2 +- src/arm/intel/socfpga/socfpga_arria10.dtsi | 2 +- .../socfpga/socfpga_arria10_socdk_qspi.dts | 2 - .../intel/socfpga/socfpga_arria5_socdk.dts | 2 - .../intel/socfpga/socfpga_cyclone5_socdk.dts | 2 - .../intel/socfpga/socfpga_cyclone5_sockit.dts | 2 - .../intel/socfpga/socfpga_cyclone5_sodia.dts | 2 - .../socfpga/socfpga_cyclone5_vining_fpga.dts | 4 - src/arm/marvell/armada-370-rd.dts | 26 +- .../marvell/armada-370-seagate-nas-2bay.dts | 8 +- .../marvell/armada-370-seagate-nas-4bay.dts | 8 +- .../marvell/armada-370-synology-ds213j.dts | 16 +- .../marvell/armada-381-netgear-gs110emx.dts | 44 +- .../marvell/armada-385-clearfog-gtr-l8.dts | 38 +- .../marvell/armada-385-clearfog-gtr-s4.dts | 22 +- src/arm/marvell/armada-385-linksys.dtsi | 18 +- src/arm/marvell/armada-385-synology-ds116.dts | 16 +- src/arm/marvell/armada-385-turris-omnia.dts | 20 +- src/arm/marvell/armada-388-clearfog.dts | 20 +- src/arm/marvell/armada-388-gp.dts | 4 +- src/arm/marvell/armada-xp-linksys-mamba.dts | 18 +- src/arm/marvell/kirkwood-dnskw.dtsi | 6 +- src/arm/marvell/kirkwood-l-50.dts | 2 + .../marvell/kirkwood-linkstation-6282.dtsi | 9 +- .../marvell/kirkwood-linkstation-lswxl.dts | 9 +- src/arm/marvell/kirkwood-lsxl.dtsi | 9 +- src/arm/marvell/kirkwood-ns2max.dts | 18 +- src/arm/marvell/kirkwood-ns2mini.dts | 18 +- src/arm/marvell/kirkwood-synology.dtsi | 102 +- src/arm/marvell/mvebu-linkstation-fan.dtsi | 8 +- src/arm/microchip/at91-sam9x60_curiosity.dts | 3 + src/arm/microchip/at91-sam9x60ek.dts | 3 + src/arm/microchip/at91-sama5d27_som1_ek.dts | 1 - src/arm/microchip/at91-sama5d27_wlsom1_ek.dts | 1 - src/arm/nuvoton/nuvoton-wpcm450.dtsi | 2 + src/arm/nvidia/tegra20-colibri.dtsi | 2 +- src/arm/nvidia/tegra30-apalis-v1.1.dtsi | 1 - src/arm/nvidia/tegra30-apalis.dtsi | 1 - src/arm/nvidia/tegra30-colibri.dtsi | 1 - src/arm/nxp/imx/imx1-ads.dts | 2 +- src/arm/nxp/imx/imx1-apf9328.dts | 2 +- src/arm/nxp/imx/imx1.dtsi | 9 +- src/arm/nxp/imx/imx25-eukrea-cpuimx25.dtsi | 2 +- ...25-eukrea-mbimxsd25-baseboard-cmo-qvga.dts | 2 +- ...25-eukrea-mbimxsd25-baseboard-dvi-svga.dts | 2 +- ...x25-eukrea-mbimxsd25-baseboard-dvi-vga.dts | 2 +- src/arm/nxp/imx/imx25-pdk.dts | 3 +- src/arm/nxp/imx/imx25.dtsi | 41 +- src/arm/nxp/imx/imx27-apf27dev.dts | 4 +- src/arm/nxp/imx/imx27-eukrea-cpuimx27.dtsi | 4 +- .../imx/imx27-eukrea-mbimxsd27-baseboard.dts | 2 +- src/arm/nxp/imx/imx27-pdk.dts | 18 +- .../nxp/imx/imx27-phytec-phycard-s-rdk.dts | 2 +- src/arm/nxp/imx/imx27-phytec-phycore-rdk.dts | 17 +- src/arm/nxp/imx/imx27-phytec-phycore-som.dtsi | 28 +- src/arm/nxp/imx/imx27.dtsi | 7 +- src/arm/nxp/imx/imx53-cx9020.dts | 2 +- src/arm/nxp/imx/imx6dl-b105pv2.dts | 2 +- src/arm/nxp/imx/imx6dl-b105v2.dts | 2 +- src/arm/nxp/imx/imx6dl-b125pv2.dts | 2 +- src/arm/nxp/imx/imx6dl-b125v2.dts | 2 +- src/arm/nxp/imx/imx6dl-b155v2.dts | 2 +- src/arm/nxp/imx/imx6q-apalis-ixora-v1.2.dts | 2 + src/arm/nxp/imx/imx6q-b850v3.dts | 3 - src/arm/nxp/imx/imx6q-bx50v3.dtsi | 2 +- src/arm/nxp/imx/imx6q-var-mx6customboard.dts | 4 +- src/arm/nxp/imx/imx6qdl-apalis.dtsi | 10 +- src/arm/nxp/imx/imx6qdl-colibri.dtsi | 8 +- src/arm/nxp/imx/imx6qdl-emcon-avari.dtsi | 2 +- src/arm/nxp/imx/imx6qdl-emcon.dtsi | 1 - src/arm/nxp/imx/imx6qdl-mba6.dtsi | 6 +- src/arm/nxp/imx/imx6qdl-phytec-pfla02.dtsi | 1 + .../nxp/imx/imx6qdl-phytec-phycore-som.dtsi | 1 + src/arm/nxp/imx/imx6qdl-skov-cpu-revc.dtsi | 2 +- src/arm/nxp/imx/imx6qdl.dtsi | 2 +- src/arm/nxp/imx/imx6sx.dtsi | 8 +- src/arm/nxp/imx/imx6ul.dtsi | 2 +- src/arm/nxp/imx/imx6ull-phytec-tauri.dtsi | 2 +- src/arm/nxp/imx/imx7-tqma7.dtsi | 9 +- src/arm/nxp/imx/imx7d-colibri-emmc.dtsi | 4 + src/arm/nxp/imx/imx7d-flex-concentrator.dts | 2 +- src/arm/nxp/imx/imx7d-meerkat96.dts | 2 +- src/arm/nxp/imx/imx7d-pico-dwarf.dts | 1 + src/arm/nxp/imx/imx7d-pico.dtsi | 8 + src/arm/nxp/imx/imx7d-smegw01.dts | 2 +- src/arm/nxp/imx/imx7d.dtsi | 3 - src/arm/nxp/imx/imx7s.dtsi | 48 +- src/arm/nxp/imx/mba6ulx.dtsi | 2 +- src/arm/nxp/lpc/lpc18xx.dtsi | 2 +- src/arm/nxp/ls/ls1021a.dtsi | 2 +- src/arm/nxp/mxs/imx23-sansa.dts | 12 +- src/arm/nxp/mxs/imx23.dtsi | 10 +- src/arm/nxp/mxs/imx28-lwe.dtsi | 1 + src/arm/nxp/mxs/imx28-tx28.dts | 1 + src/arm/nxp/mxs/imx28.dtsi | 14 +- src/arm/nxp/vf/vf-colibri-eval-v3.dtsi | 2 +- src/arm/nxp/vf/vf610-bk4.dts | 4 +- src/arm/nxp/vf/vf610-zii-cfu1.dts | 14 +- src/arm/nxp/vf/vf610-zii-dev-rev-b.dts | 7 +- src/arm/nxp/vf/vf610-zii-scu4-aib.dts | 70 +- src/arm/nxp/vf/vf610-zii-spb4.dts | 18 +- src/arm/nxp/vf/vf610-zii-ssmb-dtu.dts | 20 +- src/arm/nxp/vf/vf610-zii-ssmb-spu3.dts | 18 +- src/arm/qcom/pm8018.dtsi | 55 + src/arm/qcom/pm8058.dtsi | 159 + .../qcom/{qcom-pm8226.dtsi => pm8226.dtsi} | 2 + src/arm/qcom/pm8821.dtsi | 22 + .../qcom/{qcom-pm8841.dtsi => pm8841.dtsi} | 0 src/arm/qcom/pm8921.dtsi | 137 + .../qcom/{qcom-pm8941.dtsi => pm8941.dtsi} | 2 + .../qcom/{qcom-pma8084.dtsi => pma8084.dtsi} | 0 src/arm/qcom/{qcom-pmx55.dtsi => pmx55.dtsi} | 0 src/arm/qcom/{qcom-pmx65.dtsi => pmx65.dtsi} | 0 src/arm/qcom/qcom-apq8026-asus-sparrow.dts | 4 +- src/arm/qcom/qcom-apq8026-huawei-sturgeon.dts | 4 +- src/arm/qcom/qcom-apq8026-lg-lenok.dts | 4 +- .../qcom-apq8026-samsung-matisse-wifi.dts | 2 +- src/arm/qcom/qcom-apq8060-dragonboard.dts | 164 +- src/arm/qcom/qcom-apq8064-asus-nexus7-flo.dts | 70 +- src/arm/qcom/qcom-apq8064-cm-qs600.dts | 35 +- src/arm/qcom/qcom-apq8064-ifc6410.dts | 42 +- .../qcom-apq8064-sony-xperia-lagan-yuga.dts | 111 +- src/arm/qcom/qcom-apq8064.dtsi | 203 +- src/arm/qcom/qcom-apq8074-dragonboard.dts | 35 +- src/arm/qcom/qcom-apq8084-ifc6540.dts | 2 +- src/arm/qcom/qcom-apq8084-mtp.dts | 2 +- src/arm/qcom/qcom-ipq4019-ap.dk04.1.dtsi | 2 +- src/arm/qcom/qcom-ipq4019.dtsi | 4 +- src/arm/qcom/qcom-ipq8064.dtsi | 8 +- .../qcom/qcom-mdm9615-wp8548-mangoh-green.dts | 4 +- src/arm/qcom/qcom-mdm9615-wp8548.dtsi | 143 +- src/arm/qcom/qcom-mdm9615.dtsi | 183 +- .../qcom/qcom-msm8226-microsoft-common.dtsi | 327 + .../qcom/qcom-msm8226-microsoft-dempsey.dts | 17 + .../qcom/qcom-msm8226-microsoft-makepeace.dts | 17 + .../qcom-msm8226-microsoft-moneypenny.dts | 23 + src/arm/qcom/qcom-msm8226.dtsi | 48 +- src/arm/qcom/qcom-msm8660-surf.dts | 61 +- src/arm/qcom/qcom-msm8660.dtsi | 217 +- src/arm/qcom/qcom-msm8926-htc-memul.dts | 372 + .../qcom-msm8926-microsoft-superman-lte.dts | 53 + src/arm/qcom/qcom-msm8926-microsoft-tesla.dts | 67 + .../qcom/qcom-msm8926-motorola-peregrine.dts | 291 + src/arm/qcom/qcom-msm8960-cdp.dts | 27 +- .../qcom/qcom-msm8960-samsung-expressatt.dts | 7 +- src/arm/qcom/qcom-msm8960.dtsi | 45 +- .../qcom-msm8974-lge-nexus5-hammerhead.dts | 33 +- .../qcom/qcom-msm8974-sony-xperia-rhine.dtsi | 35 +- src/arm/qcom/qcom-msm8974.dtsi | 122 +- .../qcom/qcom-msm8974pro-fairphone-fp2.dts | 33 +- .../qcom/qcom-msm8974pro-oneplus-bacon.dts | 35 +- src/arm/qcom/qcom-msm8974pro-samsung-klte.dts | 13 +- ...-msm8974pro-sony-xperia-shinano-castor.dts | 35 +- src/arm/qcom/qcom-sdx55-mtp.dts | 2 +- src/arm/qcom/qcom-sdx55-t55.dts | 2 +- src/arm/qcom/qcom-sdx55-telit-fn980-tlb.dts | 2 +- src/arm/qcom/qcom-sdx55.dtsi | 63 +- src/arm/qcom/qcom-sdx65-mtp.dts | 2 +- src/arm/qcom/qcom-sdx65.dtsi | 51 +- src/arm/renesas/iwg20d-q7-dbcm-ca.dtsi | 15 + src/arm/renesas/r8a7740-armadillo800eva.dts | 28 +- src/arm/renesas/r8a7740.dtsi | 65 + .../renesas/r8a7745-iwg22d-sodimm-dbhd-ca.dts | 15 + src/arm/renesas/r8a7745-iwg22d-sodimm.dts | 4 +- src/arm/renesas/r8a7779-marzen.dts | 48 +- src/arm/renesas/r8a7790-lager.dts | 24 +- src/arm/renesas/r8a7790-stout.dts | 16 + src/arm/renesas/r8a7791-koelsch.dts | 31 +- src/arm/renesas/r8a7791-porter.dts | 27 +- src/arm/renesas/r8a7792-blanche.dts | 50 + src/arm/renesas/r8a7792-wheat.dts | 21 + src/arm/renesas/r8a7793-gose.dts | 29 +- src/arm/renesas/r8a7794-alt.dts | 5 +- src/arm/renesas/r8a7794-silk.dts | 18 +- src/arm/renesas/r9a06g032.dtsi | 2 +- src/arm/rockchip/rk3036-kylin.dts | 21 + src/arm/rockchip/rk3036.dtsi | 18 +- src/arm/rockchip/rk3066a.dtsi | 5 + src/arm/rockchip/rk3128-evb.dts | 5 - src/arm/rockchip/rk3128-xpi-3128.dts | 425 ++ src/arm/rockchip/rk3128.dtsi | 185 + src/arm/rockchip/rk322x.dtsi | 4 + src/arm/rockchip/rk3288.dtsi | 9 + src/arm/rockchip/rk3xxx.dtsi | 4 + src/arm/rockchip/rv1108.dtsi | 8 - src/arm/rockchip/rv1109-sonoff-ihost.dts | 21 + src/arm/rockchip/rv1109.dtsi | 23 + src/arm/rockchip/rv1126-edgeble-neu2-io.dts | 2 +- src/arm/rockchip/rv1126-pinctrl.dtsi | 72 +- src/arm/rockchip/rv1126-sonoff-ihost.dts | 29 + src/arm/rockchip/rv1126-sonoff-ihost.dtsi | 404 ++ src/arm/rockchip/rv1126.dtsi | 21 + src/arm/samsung/exynos4.dtsi | 26 +- src/arm/samsung/exynos4210-i9100.dts | 48 +- src/arm/samsung/exynos4212-tab3.dtsi | 1 + src/arm/samsung/exynos4x12.dtsi | 22 +- src/arm/samsung/s5pv210.dtsi | 18 +- src/arm/st/ste-dbx5x0.dtsi | 18 +- src/arm/st/ste-href-ab8500.dtsi | 48 + src/arm/st/ste-href-ab8505.dtsi | 490 ++ src/arm/st/ste-href.dtsi | 55 - src/arm/st/ste-href520-tvk.dts | 1 + src/arm/st/ste-hrefprev60-stuib.dts | 1 + src/arm/st/ste-hrefprev60-tvk.dts | 1 + src/arm/st/ste-hrefprev60.dtsi | 2 +- src/arm/st/ste-hrefv60plus-stuib.dts | 1 + src/arm/st/ste-hrefv60plus-tvk.dts | 1 + src/arm/st/ste-hrefv60plus.dtsi | 3 +- src/arm/st/ste-nomadik-stn8815.dtsi | 8 +- src/arm/st/ste-snowball.dts | 2 +- src/arm/st/ste-ux500-samsung-codina-tmo.dts | 2 +- src/arm/st/ste-ux500-samsung-codina.dts | 2 +- src/arm/st/ste-ux500-samsung-gavini.dts | 2 +- src/arm/st/ste-ux500-samsung-janice.dts | 2 +- src/arm/st/ste-ux500-samsung-kyle.dts | 2 +- src/arm/st/stm32429i-eval.dts | 1 - src/arm/st/stm32f469-disco.dts | 15 +- src/arm/st/stm32f746.dtsi | 61 + src/arm/st/stm32mp135.dtsi | 11 + src/arm/st/stm32mp151.dtsi | 4 + src/arm/st/stm32mp151a-prtt1l.dtsi | 2 - src/arm/st/stm32mp157a-dk1-scmi.dts | 4 +- src/arm/st/stm32mp157a-stinger96.dtsi | 2 - src/arm/st/stm32mp157c-dk2-scmi.dts | 4 +- src/arm/st/stm32mp157c-dk2.dts | 1 - src/arm/st/stm32mp157c-ed1-scmi.dts | 4 +- src/arm/st/stm32mp157c-emstamp-argon.dtsi | 4 - src/arm/st/stm32mp157c-ev1-scmi.dts | 5 +- src/arm/st/stm32mp157c-ev1.dts | 1 - src/arm/st/stm32mp157c-osd32mp1-red.dts | 4 - .../st/stm32mp157c-phycore-stm32mp15-som.dtsi | 4 - src/arm/st/stm32mp15xc-lxa-tac.dtsi | 3 - src/arm/st/stm32mp15xx-dhcom-drc02.dtsi | 1 - src/arm/st/stm32mp15xx-dhcom-pdk2.dtsi | 1 - src/arm/st/stm32mp15xx-dhcom-picoitx.dtsi | 2 - src/arm/st/stm32mp15xx-dhcor-avenger96.dtsi | 2 - src/arm/st/stm32mp15xx-dhcor-drc-compact.dtsi | 2 - src/arm/st/stm32mp15xx-dhcor-testbench.dtsi | 2 - src/arm/st/stm32mp15xx-dkx.dtsi | 1 - src/arm/ti/keystone/keystone-k2e-netcp.dtsi | 6 +- src/arm/ti/keystone/keystone-k2g-evm.dts | 2 +- src/arm/ti/keystone/keystone-k2g-netcp.dtsi | 6 +- src/arm/ti/keystone/keystone-k2hk-evm.dts | 2 +- src/arm/ti/keystone/keystone-k2hk-netcp.dtsi | 6 +- src/arm/ti/keystone/keystone-k2l-netcp.dtsi | 6 +- .../ti/omap/am335x-moxa-uc-2100-common.dtsi | 2 +- src/arm/ti/omap/am571x-idk.dts | 4 +- src/arm/ti/omap/am5729-beagleboneai.dts | 3 +- src/arm/ti/omap/am572x-idk-common.dtsi | 4 +- src/arm/ti/omap/dra7-evm-common.dtsi | 4 +- src/arm/ti/omap/dra71-evm.dts | 4 +- src/arm/ti/omap/dra72-evm-common.dtsi | 4 +- src/arm/ti/omap/dra76-evm.dts | 4 +- .../ti/omap/logicpd-torpedo-37xx-devkit.dts | 2 +- src/arm/ti/omap/motorola-mapphone-common.dtsi | 298 - .../ti/omap/motorola-mapphone-handset.dtsi | 234 + .../omap/motorola-mapphone-mz607-mz617.dtsi | 21 + src/arm/ti/omap/motorola-mapphone-xt8xx.dtsi | 75 + src/arm/ti/omap/omap4-droid-bionic-xt875.dts | 11 +- src/arm/ti/omap/omap4-droid4-xt894.dts | 19 +- src/arm/ti/omap/omap4-epson-embt2ws.dts | 18 +- src/arm/ti/omap/omap4-xyboard-mz609.dts | 46 + src/arm/ti/omap/omap4-xyboard-mz617.dts | 17 + .../allwinner/sun50i-h618-orangepi-zero2w.dts | 176 + .../sun50i-h618-transpeed-8k618-t.dts | 161 + src/arm64/altera/socfpga_stratix10.dtsi | 41 +- src/arm64/altera/socfpga_stratix10_socdk.dts | 8 +- .../altera/socfpga_stratix10_socdk_nand.dts | 6 +- src/arm64/altera/socfpga_stratix10_swvp.dts | 2 - src/arm64/amazon/alpine-v2.dtsi | 1 - src/arm64/amazon/alpine-v3.dtsi | 1 - src/arm64/amlogic/amlogic-c3.dtsi | 6 + .../meson-axg-jethome-jethub-j110-rev-2.dts | 14 +- .../meson-axg-jethome-jethub-j110-rev-3.dts | 12 + src/arm64/amlogic/meson-axg-s400.dts | 5 - src/arm64/amlogic/meson-axg.dtsi | 23 + src/arm64/amlogic/meson-g12a-sei510.dts | 1 - src/arm64/amlogic/meson-g12a-x96-max.dts | 1 - .../amlogic/meson-g12b-bananapi-cm4.dtsi | 2 +- src/arm64/amlogic/meson-g12b-bananapi.dtsi | 2 +- src/arm64/amlogic/meson-g12b-gtking.dts | 1 - src/arm64/amlogic/meson-g12b-ugoos-am6.dts | 1 - src/arm64/amlogic/meson-gx-p23x-q20x.dtsi | 1 - src/arm64/amlogic/meson-gxbb-kii-pro.dts | 1 - src/arm64/amlogic/meson-gxbb-p200.dts | 1 - src/arm64/amlogic/meson-gxbb-vega-s95.dtsi | 1 - src/arm64/amlogic/meson-gxbb-wetek-play2.dts | 1 - src/arm64/amlogic/meson-gxm-nexbox-a1.dts | 1 - src/arm64/amlogic/meson-gxm-rbox-pro.dts | 1 - src/arm64/amlogic/meson-s4-s805x2-aq222.dts | 60 +- src/arm64/amlogic/meson-s4.dtsi | 360 +- src/arm64/amlogic/meson-sm1-sei610.dts | 1 - src/arm64/arm/juno-base.dtsi | 12 +- src/arm64/arm/juno-scmi.dtsi | 12 +- src/arm64/broadcom/northstar2/ns2.dtsi | 1 + src/arm64/broadcom/stingray/stingray.dtsi | 1 + src/arm64/exynos/exynos5433.dtsi | 60 +- src/arm64/exynos/exynos7.dtsi | 18 +- src/arm64/exynos/exynos7885.dtsi | 45 +- src/arm64/exynos/exynos850.dtsi | 40 +- src/arm64/exynos/exynosautov9-sadk.dts | 51 + src/arm64/exynos/exynosautov9.dtsi | 10 +- src/arm64/exynos/exynosautov920-pinctrl.dtsi | 1266 ++++ src/arm64/exynos/exynosautov920-sadk.dts | 88 + src/arm64/exynos/exynosautov920.dtsi | 312 + src/arm64/exynos/google/gs101-oriole.dts | 105 + src/arm64/exynos/google/gs101-pinctrl.dtsi | 1249 ++++ src/arm64/exynos/google/gs101-pinctrl.h | 33 + src/arm64/exynos/google/gs101.dtsi | 473 ++ src/arm64/freescale/fsl-ls1012a.dtsi | 80 +- src/arm64/freescale/fsl-ls1028a.dtsi | 87 +- src/arm64/freescale/fsl-ls1043a.dtsi | 81 +- src/arm64/freescale/fsl-ls1046a.dtsi | 74 +- src/arm64/freescale/fsl-ls1088a.dtsi | 74 +- src/arm64/freescale/fsl-ls208xa.dtsi | 73 +- .../fsl-lx2160a-tqmlx2160a-mblx2160a.dts | 338 + ...l-lx2160a-tqmlx2160a-mblx2160a_12_x_x.dtso | 29 + ...l-lx2160a-tqmlx2160a-mblx2160a_14_x_x.dtso | 17 + ...l-lx2160a-tqmlx2160a-mblx2160a_x_11_x.dtso | 49 + ...sl-lx2160a-tqmlx2160a-mblx2160a_x_7_x.dtso | 55 + ...sl-lx2160a-tqmlx2160a-mblx2160a_x_8_x.dtso | 47 + .../freescale/fsl-lx2160a-tqmlx2160a.dtsi | 97 + src/arm64/freescale/fsl-lx2160a.dtsi | 4 +- .../freescale/imx8-apalis-ixora-v1.2.dtsi | 2 + src/arm64/freescale/imx8-ss-audio.dtsi | 2 - src/arm64/freescale/imx8dxl-ss-conn.dtsi | 16 +- src/arm64/freescale/imx8dxl-ss-ddr.dtsi | 2 +- src/arm64/freescale/imx8mm-beacon-som.dtsi | 2 + src/arm64/freescale/imx8mm-emcon-avari.dtsi | 2 +- src/arm64/freescale/imx8mm-evk.dtsi | 12 +- src/arm64/freescale/imx8mm-nitrogen-r2.dts | 2 +- src/arm64/freescale/imx8mm-overdrive.dtsi | 29 + .../freescale/imx8mm-phygate-tauri-l.dts | 2 +- .../freescale/imx8mm-tqma8mqml-mba8mx.dts | 1 + src/arm64/freescale/imx8mm-venice-gw72xx.dtsi | 39 +- src/arm64/freescale/imx8mm-venice-gw73xx.dtsi | 31 +- src/arm64/freescale/imx8mm-venice-gw7902.dts | 13 +- src/arm64/freescale/imx8mm-verdin-mallow.dtsi | 173 + .../imx8mm-verdin-nonwifi-mallow.dts | 18 + .../freescale/imx8mm-verdin-wifi-mallow.dts | 18 + src/arm64/freescale/imx8mm.dtsi | 18 +- src/arm64/freescale/imx8mn-beacon-som.dtsi | 2 + .../freescale/imx8mn-bsh-smm-s2-common.dtsi | 1 + .../freescale/imx8mn-bsh-smm-s2-display.dtsi | 121 + .../freescale/imx8mn-dimonoff-gateway-evk.dts | 160 + src/arm64/freescale/imx8mn-evk.dtsi | 12 +- src/arm64/freescale/imx8mn-overdrive.dtsi | 18 + src/arm64/freescale/imx8mn-rve-gateway.dts | 285 + .../freescale/imx8mn-tqma8mqnl-mba8mx.dts | 1 + .../freescale/imx8mn-var-som-symphony.dts | 10 + src/arm64/freescale/imx8mn-var-som.dtsi | 9 + src/arm64/freescale/imx8mn.dtsi | 2 + src/arm64/freescale/imx8mp-beacon-kit.dts | 94 +- .../freescale/imx8mp-data-modul-edm-sbc.dts | 2 +- src/arm64/freescale/imx8mp-debix-model-a.dts | 2 +- .../freescale/imx8mp-debix-som-a-bmb-08.dts | 56 + src/arm64/freescale/imx8mp-debix-som-a.dtsi | 22 + src/arm64/freescale/imx8mp-dhcom-som.dtsi | 14 +- src/arm64/freescale/imx8mp-evk.dts | 22 + src/arm64/freescale/imx8mp-msc-sm2s-ep1.dts | 4 +- src/arm64/freescale/imx8mp-skov-reva.dtsi | 711 ++ src/arm64/freescale/imx8mp-skov-revb-hdmi.dts | 20 + src/arm64/freescale/imx8mp-skov-revb-lt6.dts | 101 + .../imx8mp-skov-revb-mi1010ait-1cp1.dts | 100 + ...8mp-tqma8mpql-mba8mpxl-lvds-g133han01.dtso | 77 + .../freescale/imx8mp-tqma8mpql-mba8mpxl.dts | 37 +- src/arm64/freescale/imx8mp-venice-gw71xx.dtsi | 26 +- src/arm64/freescale/imx8mp-venice-gw72xx.dtsi | 36 +- src/arm64/freescale/imx8mp-venice-gw73xx.dtsi | 28 +- src/arm64/freescale/imx8mp-venice-gw74xx.dts | 30 +- src/arm64/freescale/imx8mp-verdin-mallow.dtsi | 199 + .../imx8mp-verdin-nonwifi-mallow.dts | 18 + .../freescale/imx8mp-verdin-wifi-mallow.dts | 18 + src/arm64/freescale/imx8mp-verdin.dtsi | 30 +- src/arm64/freescale/imx8mp.dtsi | 30 +- .../freescale/imx8mq-kontron-pitx-imx8m.dts | 2 +- src/arm64/freescale/imx8mq-phanbell.dts | 2 +- src/arm64/freescale/imx8mq-tqma8mq-mba8mx.dts | 1 + src/arm64/freescale/imx8qm-ss-dma.dtsi | 4 + src/arm64/freescale/imx8qxp-mek.dts | 21 +- src/arm64/freescale/imx8qxp-ss-vpu.dtsi | 17 + src/arm64/freescale/imx8qxp.dtsi | 3 +- src/arm64/freescale/imx93-11x11-evk.dts | 31 +- .../freescale/imx93-tqma9352-mba93xxca.dts | 709 ++ .../freescale/imx93-tqma9352-mba93xxla.dts | 1 + src/arm64/freescale/imx93.dtsi | 127 +- src/arm64/hisilicon/hikey970-pmic.dtsi | 6 +- src/arm64/intel/socfpga_agilex.dtsi | 42 +- src/arm64/intel/socfpga_agilex5.dtsi | 4 +- src/arm64/intel/socfpga_agilex_n6000.dts | 2 +- src/arm64/intel/socfpga_agilex_socdk.dts | 2 - src/arm64/intel/socfpga_n5x_socdk.dts | 5 +- src/arm64/lg/lg1312.dtsi | 1 - src/arm64/lg/lg1313.dtsi | 1 - src/arm64/marvell/ac5x-rd-carrier-cn9131.dts | 44 + src/arm64/marvell/ac5x-rd-carrier.dtsi | 34 + .../marvell/armada-3720-espressobin-ultra.dts | 14 +- .../marvell/armada-3720-espressobin.dtsi | 20 +- src/arm64/marvell/armada-3720-gl-mv1000.dts | 20 +- src/arm64/marvell/armada-3720-turris-mox.dts | 99 +- src/arm64/marvell/armada-7040-mochabin.dts | 24 +- .../marvell/armada-8040-clearfog-gt-8k.dts | 22 +- src/arm64/marvell/armada-ap80x.dtsi | 1 - src/arm64/marvell/cn9130-crb.dtsi | 42 +- src/arm64/marvell/cn9130-db-comexpress.dtsi | 96 + src/arm64/marvell/cn9131-db-comexpress.dtsi | 108 + src/arm64/mediatek/mt6358.dtsi | 26 +- .../mediatek/mt7622-bananapi-bpi-r64.dts | 3 +- .../mediatek/mt7986a-bananapi-bpi-r3.dts | 3 +- src/arm64/mediatek/mt8173-elm-hana.dtsi | 9 +- src/arm64/mediatek/mt8173-elm.dtsi | 24 +- src/arm64/mediatek/mt8173-evb.dts | 3 +- src/arm64/mediatek/mt8173.dtsi | 8 +- src/arm64/mediatek/mt8183-evb.dts | 4 + .../mediatek/mt8183-kukui-audio-da7219.dtsi | 3 +- .../mediatek/mt8183-kukui-audio-ts3a227e.dtsi | 3 +- .../mediatek/mt8183-kukui-jacuzzi-damu.dts | 3 +- .../mt8183-kukui-jacuzzi-fennel-sku1.dts | 3 +- .../mt8183-kukui-jacuzzi-fennel-sku6.dts | 3 +- .../mt8183-kukui-jacuzzi-fennel-sku7.dts | 3 +- .../mt8183-kukui-jacuzzi-makomo-sku0.dts | 24 + .../mt8183-kukui-jacuzzi-makomo-sku1.dts | 24 + .../mediatek/mt8183-kukui-jacuzzi-pico.dts | 35 + .../mediatek/mt8183-kukui-jacuzzi-pico6.dts | 110 + src/arm64/mediatek/mt8183-kukui-jacuzzi.dtsi | 1 - .../mediatek/mt8183-kukui-kakadu-sku22.dts | 18 + src/arm64/mediatek/mt8183-kukui-kakadu.dts | 18 + src/arm64/mediatek/mt8183-kukui-kakadu.dtsi | 15 +- .../mediatek/mt8183-kukui-katsu-sku32.dts | 36 + .../mediatek/mt8183-kukui-katsu-sku38.dts | 40 + src/arm64/mediatek/mt8183-kukui-kodama.dtsi | 3 +- src/arm64/mediatek/mt8183-kukui-krane.dtsi | 3 +- src/arm64/mediatek/mt8183-kukui.dtsi | 12 +- src/arm64/mediatek/mt8183-pumpkin.dts | 4 + src/arm64/mediatek/mt8183.dtsi | 62 +- src/arm64/mediatek/mt8186.dtsi | 6 +- src/arm64/mediatek/mt8188-evb.dts | 387 ++ src/arm64/mediatek/mt8188.dtsi | 956 +++ src/arm64/mediatek/mt8192-asurada.dtsi | 2 +- src/arm64/mediatek/mt8192.dtsi | 466 ++ src/arm64/mediatek/mt8195-cherry.dtsi | 117 +- src/arm64/mediatek/mt8195-demo.dts | 1 + src/arm64/mediatek/mt8195.dtsi | 483 +- src/arm64/mediatek/mt8395-genio-1200-evk.dts | 6 +- .../nvidia/tegra234-p3737-0000+p3701-0000.dts | 2 +- src/arm64/nvidia/tegra234.dtsi | 6 +- src/arm64/qcom/ipq5018-rdp432-c2.dts | 12 + src/arm64/qcom/ipq5018.dtsi | 142 + src/arm64/qcom/ipq5332-rdp-common.dtsi | 3 + src/arm64/qcom/ipq5332-rdp441.dts | 2 +- src/arm64/qcom/ipq5332-rdp442.dts | 2 +- src/arm64/qcom/ipq5332-rdp474.dts | 2 +- src/arm64/qcom/ipq5332.dtsi | 23 +- src/arm64/qcom/ipq6018.dtsi | 129 +- src/arm64/qcom/ipq8074.dtsi | 126 +- src/arm64/qcom/ipq9574-rdp-common.dtsi | 169 + src/arm64/qcom/ipq9574-rdp418.dts | 63 +- src/arm64/qcom/ipq9574-rdp433.dts | 91 +- src/arm64/qcom/ipq9574-rdp449.dts | 65 +- src/arm64/qcom/ipq9574-rdp453.dts | 65 +- src/arm64/qcom/ipq9574-rdp454.dts | 66 +- src/arm64/qcom/ipq9574.dtsi | 25 +- src/arm64/qcom/msm8916-acer-a1-724.dts | 24 + src/arm64/qcom/msm8916-alcatel-idol347.dts | 173 +- src/arm64/qcom/msm8916-asus-z00l.dts | 21 + src/arm64/qcom/msm8916-longcheer-l8150.dts | 75 +- src/arm64/qcom/msm8916-longcheer-l8910.dts | 103 + src/arm64/qcom/msm8916-modem-qdsp6.dtsi | 148 + .../qcom/msm8916-samsung-a2015-common.dtsi | 71 + src/arm64/qcom/msm8916-samsung-a3u-eur.dts | 10 +- .../qcom/msm8916-samsung-e2015-common.dtsi | 4 + src/arm64/qcom/msm8916-samsung-grandmax.dts | 4 + .../qcom/msm8916-samsung-gt5-common.dtsi | 92 +- src/arm64/qcom/msm8916-samsung-gt510.dts | 26 + src/arm64/qcom/msm8916-samsung-gt58.dts | 46 + src/arm64/qcom/msm8916-samsung-j5-common.dtsi | 14 + src/arm64/qcom/msm8916-samsung-j5.dts | 4 + src/arm64/qcom/msm8916-samsung-serranove.dts | 13 + src/arm64/qcom/msm8916-thwc-uf896.dts | 8 +- src/arm64/qcom/msm8916-thwc-ufi001c.dts | 8 +- src/arm64/qcom/msm8916-wingtech-wt88047.dts | 75 + src/arm64/qcom/msm8916-yiming-uz801v3.dts | 8 +- src/arm64/qcom/msm8916.dtsi | 59 +- src/arm64/qcom/msm8939-huawei-kiwi.dts | 242 + src/arm64/qcom/msm8939-longcheer-l9100.dts | 56 + src/arm64/qcom/msm8939-samsung-a7.dts | 70 + src/arm64/qcom/msm8939.dtsi | 94 +- src/arm64/qcom/msm8953-xiaomi-mido.dts | 1 + src/arm64/qcom/msm8953-xiaomi-tissot.dts | 1 + src/arm64/qcom/msm8953-xiaomi-vince.dts | 1 + src/arm64/qcom/msm8953.dtsi | 110 +- src/arm64/qcom/msm8996.dtsi | 129 +- src/arm64/qcom/msm8998.dtsi | 92 +- src/arm64/qcom/pm7250b.dtsi | 2 +- src/arm64/qcom/pm8550.dtsi | 3 - src/arm64/qcom/pm8550ve.dtsi | 6 +- src/arm64/qcom/pm8916.dtsi | 48 + src/arm64/qcom/pmk8350.dtsi | 2 +- src/arm64/qcom/qcm2290.dtsi | 504 +- src/arm64/qcom/qcm6490-fairphone-fp5.dts | 288 +- src/arm64/qcom/qcm6490-idp.dts | 468 ++ src/arm64/qcom/qcs404.dtsi | 11 +- src/arm64/qcom/qcs6490-rb3gen2.dts | 455 ++ src/arm64/qcom/qdu1000.dtsi | 23 +- src/arm64/qcom/qrb2210-rb1.dts | 113 + src/arm64/qcom/qrb4210-rb2.dts | 112 +- .../qcom/qrb5165-rb5-vision-mezzanine.dts | 2 +- src/arm64/qcom/qrb5165-rb5.dts | 33 +- src/arm64/qcom/sa8775p-ride.dts | 5 + src/arm64/qcom/sa8775p.dtsi | 1124 ++- src/arm64/qcom/sc7180-acer-aspire1.dts | 174 +- src/arm64/qcom/sc7180-trogdor-pompom.dtsi | 2 +- src/arm64/qcom/sc7180.dtsi | 14 +- src/arm64/qcom/sc7280-chrome-common.dtsi | 37 +- src/arm64/qcom/sc7280-herobrine-lte-sku.dtsi | 7 +- src/arm64/qcom/sc7280-herobrine-wifi-sku.dtsi | 1 + src/arm64/qcom/sc7280-idp.dtsi | 19 + src/arm64/qcom/sc7280.dtsi | 581 +- src/arm64/qcom/sc8180x-lenovo-flex-5g.dts | 4 +- src/arm64/qcom/sc8180x-primus.dts | 12 +- src/arm64/qcom/sc8180x.dtsi | 61 +- src/arm64/qcom/sc8280xp-crd.dts | 4 + .../qcom/sc8280xp-lenovo-thinkpad-x13s.dts | 14 + src/arm64/qcom/sc8280xp.dtsi | 24 +- src/arm64/qcom/sdm630.dtsi | 53 +- src/arm64/qcom/sdm632-fairphone-fp3.dts | 19 + src/arm64/qcom/sdm670.dtsi | 302 +- src/arm64/qcom/sdm845-db845c.dts | 4 +- src/arm64/qcom/sdm845-oneplus-common.dtsi | 23 + src/arm64/qcom/sdm845-wcd9340.dtsi | 2 +- .../qcom/sdm845-xiaomi-beryllium-common.dtsi | 22 + src/arm64/qcom/sdm845.dtsi | 127 +- src/arm64/qcom/sdm850-lenovo-yoga-c630.dts | 8 +- src/arm64/qcom/sdm850-samsung-w737.dts | 2 +- src/arm64/qcom/sdx75-idp.dts | 29 + src/arm64/qcom/sdx75.dtsi | 170 + src/arm64/qcom/sm4450-qrd.dts | 18 +- src/arm64/qcom/sm4450.dtsi | 107 + src/arm64/qcom/sm6115.dtsi | 345 +- src/arm64/qcom/sm6125.dtsi | 4 + src/arm64/qcom/sm6350.dtsi | 20 +- .../qcom/sm6375-sony-xperia-murray-pdx225.dts | 43 +- src/arm64/qcom/sm6375.dtsi | 84 +- src/arm64/qcom/sm8150-hdk.dts | 264 +- src/arm64/qcom/sm8150.dtsi | 223 +- .../qcom/sm8250-xiaomi-elish-common.dtsi | 47 +- src/arm64/qcom/sm8250-xiaomi-pipa.dts | 623 ++ src/arm64/qcom/sm8250.dtsi | 143 +- src/arm64/qcom/sm8350.dtsi | 147 +- src/arm64/qcom/sm8450-hdk.dts | 8 + src/arm64/qcom/sm8450.dtsi | 285 +- src/arm64/qcom/sm8550-mtp.dts | 129 + src/arm64/qcom/sm8550-qrd.dts | 136 + src/arm64/qcom/sm8550.dtsi | 317 +- src/arm64/qcom/sm8650-mtp.dts | 727 ++ src/arm64/qcom/sm8650-qrd.dts | 811 +++ src/arm64/qcom/sm8650.dtsi | 6013 +++++++++++++++++ src/arm64/qcom/x1e80100-crd.dts | 424 ++ src/arm64/qcom/x1e80100-qcp.dts | 399 ++ src/arm64/qcom/x1e80100.dtsi | 3527 ++++++++++ src/arm64/renesas/draak.dtsi | 32 +- src/arm64/renesas/ebisu.dtsi | 6 + src/arm64/renesas/r8a77970-eagle.dts | 15 + .../renesas/r8a779g0-white-hawk-cpu.dtsi | 3 + src/arm64/renesas/r9a08g045.dtsi | 106 + src/arm64/renesas/r9a09g011.dtsi | 2 +- src/arm64/renesas/rzg2l-smarc-som.dtsi | 1 + src/arm64/renesas/rzg2lc-smarc-som.dtsi | 1 + src/arm64/renesas/rzg3s-smarc-som.dtsi | 210 +- src/arm64/renesas/rzg3s-smarc.dtsi | 65 + src/arm64/renesas/ulcb-kf.dtsi | 4 + src/arm64/rockchip/px30-engicam-common.dtsi | 1 + src/arm64/rockchip/px30-evb.dts | 1 + src/arm64/rockchip/px30-ringneck-haikou.dts | 1 + src/arm64/rockchip/px30.dtsi | 3 +- src/arm64/rockchip/rk3308-rock-pi-s.dts | 62 + src/arm64/rockchip/rk3308.dtsi | 5 + src/arm64/rockchip/rk3318-a95x-z2.dts | 1 + src/arm64/rockchip/rk3326-anbernic-rg351m.dts | 18 +- .../rockchip/rk3326-anbernic-rg351m.dtsi | 478 ++ src/arm64/rockchip/rk3326-anbernic-rg351v.dts | 44 + src/arm64/rockchip/rk3328-a1.dts | 1 + src/arm64/rockchip/rk3328-evb.dts | 1 + src/arm64/rockchip/rk3328-nanopi-r2s.dts | 1 + .../rockchip/rk3328-orangepi-r1-plus-lts.dts | 4 +- .../rockchip/rk3328-orangepi-r1-plus.dts | 1 + src/arm64/rockchip/rk3328-roc-cc.dts | 1 + src/arm64/rockchip/rk3328-rock-pi-e.dts | 55 + src/arm64/rockchip/rk3328-rock64.dts | 1 + src/arm64/rockchip/rk3328.dtsi | 11 +- src/arm64/rockchip/rk3368-evb.dtsi | 1 + src/arm64/rockchip/rk3368-geekbox.dts | 1 + src/arm64/rockchip/rk3368-lion.dtsi | 1 + src/arm64/rockchip/rk3368-orion-r68-meta.dts | 1 + src/arm64/rockchip/rk3368-r88.dts | 1 + src/arm64/rockchip/rk3368.dtsi | 5 +- src/arm64/rockchip/rk3399-eaidk-610.dts | 1 + src/arm64/rockchip/rk3399-evb.dts | 1 + src/arm64/rockchip/rk3399-ficus.dts | 4 + src/arm64/rockchip/rk3399-firefly.dts | 1 + src/arm64/rockchip/rk3399-gru-bob.dts | 2 +- src/arm64/rockchip/rk3399-gru-scarlet.dtsi | 2 +- src/arm64/rockchip/rk3399-hugsun-x99.dts | 1 + .../rockchip/rk3399-khadas-edge-captain.dts | 4 + src/arm64/rockchip/rk3399-khadas-edge-v.dts | 4 + src/arm64/rockchip/rk3399-kobol-helios64.dts | 1 + src/arm64/rockchip/rk3399-leez-p710.dts | 1 + src/arm64/rockchip/rk3399-nanopi4.dtsi | 1 + src/arm64/rockchip/rk3399-orangepi.dts | 1 + src/arm64/rockchip/rk3399-puma-haikou.dts | 42 +- src/arm64/rockchip/rk3399-puma.dtsi | 15 + src/arm64/rockchip/rk3399-roc-pc.dtsi | 1 + src/arm64/rockchip/rk3399-rock-4c-plus.dts | 1 + src/arm64/rockchip/rk3399-rock-pi-4.dtsi | 1 + src/arm64/rockchip/rk3399-rockpro64.dtsi | 1 + src/arm64/rockchip/rk3399-sapphire.dtsi | 3 +- src/arm64/rockchip/rk3399.dtsi | 7 +- src/arm64/rockchip/rk3399pro-vmarc-som.dtsi | 1 + src/arm64/rockchip/rk3566-lubancat-1.dts | 2 +- src/arm64/rockchip/rk3566-powkiddy-rgb30.dts | 154 +- src/arm64/rockchip/rk3566-powkiddy-rk2023.dts | 38 + .../rockchip/rk3566-powkiddy-rk2023.dtsi | 875 +++ src/arm64/rockchip/rk3566-powkiddy-x55.dts | 926 +++ src/arm64/rockchip/rk3566-quartz64-a.dts | 5 +- src/arm64/rockchip/rk3566-radxa-cm3-io.dts | 1 + src/arm64/rockchip/rk3566-roc-pc.dts | 1 + src/arm64/rockchip/rk3566-soquartz-blade.dts | 4 + src/arm64/rockchip/rk3566-soquartz-cm4.dts | 4 + .../rockchip/rk3566-soquartz-model-a.dts | 4 + src/arm64/rockchip/rk3566-soquartz.dtsi | 1 - src/arm64/rockchip/rk3588-coolpi-cm5-evb.dts | 216 + src/arm64/rockchip/rk3588-coolpi-cm5.dtsi | 650 ++ .../rockchip/rk3588-edgeble-neu6a-io.dts | 4 - .../rockchip/rk3588-edgeble-neu6b-io.dts | 6 +- src/arm64/rockchip/rk3588-evb1-v10.dts | 100 +- src/arm64/rockchip/rk3588-jaguar.dts | 802 +++ src/arm64/rockchip/rk3588-nanopc-t6.dts | 18 +- src/arm64/rockchip/rk3588-orangepi-5-plus.dts | 1 - src/arm64/rockchip/rk3588-quartzpro64.dts | 2 +- src/arm64/rockchip/rk3588-rock-5b.dts | 13 +- src/arm64/rockchip/rk3588-turing-rk1.dtsi | 2 - src/arm64/rockchip/rk3588s-coolpi-4b.dts | 812 +++ .../rockchip/rk3588s-indiedroid-nova.dts | 11 +- src/arm64/rockchip/rk3588s-khadas-edge2.dts | 1 - src/arm64/rockchip/rk3588s-orangepi-5.dts | 7 +- src/arm64/rockchip/rk3588s-rock-5a.dts | 10 +- src/arm64/rockchip/rk3588s.dtsi | 116 + src/arm64/sprd/ums512.dtsi | 39 +- src/arm64/sprd/ums9620-2h10.dts | 38 + src/arm64/sprd/ums9620.dtsi | 245 + src/arm64/st/stm32mp251.dtsi | 16 + src/arm64/tesla/fsd.dtsi | 53 +- src/arm64/ti/k3-am62-main.dtsi | 96 +- src/arm64/ti/k3-am62-verdin-dahlia.dtsi | 3 +- src/arm64/ti/k3-am62-verdin-dev.dtsi | 3 +- src/arm64/ti/k3-am62-verdin-mallow.dtsi | 188 + src/arm64/ti/k3-am62-verdin-yavia.dtsi | 3 +- src/arm64/ti/k3-am62-verdin.dtsi | 17 +- .../ti/k3-am625-beagleplay-csi2-ov5640.dtso | 77 + .../k3-am625-beagleplay-csi2-tevi-ov5640.dtso | 77 + src/arm64/ti/k3-am625-beagleplay.dts | 4 +- src/arm64/ti/k3-am625-phyboard-lyra-rdk.dts | 98 +- .../ti/k3-am625-verdin-nonwifi-mallow.dts | 22 + src/arm64/ti/k3-am625-verdin-wifi-mallow.dts | 22 + src/arm64/ti/k3-am62a-main.dtsi | 121 +- src/arm64/ti/k3-am62a7-sk.dts | 39 + src/arm64/ti/k3-am62p-main.dtsi | 18 +- src/arm64/ti/k3-am62p5-sk.dts | 9 + src/arm64/ti/k3-am62x-sk-common.dtsi | 16 + src/arm64/ti/k3-am62x-sk-csi2-imx219.dtso | 84 + src/arm64/ti/k3-am62x-sk-csi2-ov5640.dtso | 82 + .../ti/k3-am62x-sk-csi2-tevi-ov5640.dtso | 82 + src/arm64/ti/k3-am64-main.dtsi | 22 +- src/arm64/ti/k3-am64-phycore-som.dtsi | 103 +- src/arm64/ti/k3-am642-evm.dts | 12 +- .../ti/k3-am642-phyboard-electra-rdk.dts | 1 + src/arm64/ti/k3-am642-sk.dts | 10 +- src/arm64/ti/k3-am642-tqma64xxl-mbax4xxl.dts | 1 - src/arm64/ti/k3-am642-tqma64xxl.dtsi | 1 + src/arm64/ti/k3-am65-iot2050-common-pg1.dtsi | 10 +- src/arm64/ti/k3-am65-iot2050-common-pg2.dtsi | 4 +- src/arm64/ti/k3-am65-iot2050-common.dtsi | 826 ++- src/arm64/ti/k3-am65-main.dtsi | 16 +- src/arm64/ti/k3-am65-mcu.dtsi | 8 +- src/arm64/ti/k3-am65-wakeup.dtsi | 13 +- src/arm64/ti/k3-am652.dtsi | 74 + .../ti/k3-am6528-iot2050-basic-common.dtsi | 16 +- src/arm64/ti/k3-am654-base-board.dts | 2 + .../ti/k3-am6548-iot2050-advanced-common.dtsi | 2 + .../ti/k3-am6548-iot2050-advanced-m2.dts | 12 +- src/arm64/ti/k3-am68-sk-base-board.dts | 1 + src/arm64/ti/k3-am69-sk.dts | 96 +- src/arm64/ti/k3-j7200-main.dtsi | 9 +- src/arm64/ti/k3-j7200-mcu-wakeup.dtsi | 21 +- src/arm64/ti/k3-j7200-som-p0.dtsi | 153 + src/arm64/ti/k3-j721e-evm-pcie0-ep.dtso | 53 + src/arm64/ti/k3-j721e-main.dtsi | 8 +- src/arm64/ti/k3-j721e-mcu-wakeup.dtsi | 21 +- src/arm64/ti/k3-j721e-sk.dts | 151 + src/arm64/ti/k3-j721e-som-p0.dtsi | 160 + src/arm64/ti/k3-j721s2-evm-pcie1-ep.dtso | 53 + src/arm64/ti/k3-j721s2-main.dtsi | 9 +- src/arm64/ti/k3-j721s2-mcu-wakeup.dtsi | 21 +- src/arm64/ti/k3-j721s2-som-p0.dtsi | 193 + src/arm64/ti/k3-j784s4-evm.dts | 102 + src/arm64/ti/k3-j784s4-main.dtsi | 9 +- src/arm64/ti/k3-j784s4-mcu-wakeup.dtsi | 22 +- src/arm64/xilinx/zynqmp-sck-kv-g-revA.dtso | 40 +- src/arm64/xilinx/zynqmp-sck-kv-g-revB.dtso | 42 +- src/arm64/xilinx/zynqmp-sm-k26-revA.dts | 8 +- src/arm64/xilinx/zynqmp-zc1751-xm015-dc1.dts | 8 +- src/arm64/xilinx/zynqmp-zc1751-xm016-dc2.dts | 16 +- src/arm64/xilinx/zynqmp-zc1751-xm017-dc3.dts | 8 +- src/arm64/xilinx/zynqmp-zc1751-xm018-dc4.dts | 26 +- src/arm64/xilinx/zynqmp-zc1751-xm019-dc5.dts | 8 +- src/arm64/xilinx/zynqmp-zcu100-revC.dts | 4 +- src/arm64/xilinx/zynqmp.dtsi | 15 +- src/loongarch/loongson-2k0500-ref.dts | 88 + src/loongarch/loongson-2k0500.dtsi | 266 + src/loongarch/loongson-2k1000-ref.dts | 183 + src/loongarch/loongson-2k1000.dtsi | 492 ++ src/loongarch/loongson-2k2000-ref.dts | 72 + src/loongarch/loongson-2k2000.dtsi | 300 + src/powerpc/fsl/t1023si-post.dtsi | 79 +- src/powerpc/fsl/t1040si-post.dtsi | 71 +- src/riscv/microchip/mpfs-icicle-kit.dts | 21 + src/riscv/microchip/mpfs.dtsi | 17 + src/riscv/renesas/r9a07g043f.dtsi | 4 + src/riscv/sifive/hifive-unmatched-a00.dts | 1 + src/riscv/sophgo/cv1800b.dtsi | 118 +- src/riscv/sophgo/cv1812h-huashan-pi.dts | 48 + src/riscv/sophgo/cv1812h.dtsi | 24 + src/riscv/sophgo/cv18xx.dtsi | 192 + src/riscv/sophgo/sg2042.dtsi | 80 +- src/riscv/starfive/jh7100-common.dtsi | 131 + src/riscv/starfive/jh7100.dtsi | 60 +- src/riscv/starfive/jh7110.dtsi | 4 +- src/riscv/thead/th1520-beaglev-ahead.dts | 20 + src/riscv/thead/th1520-lichee-module-4a.dtsi | 20 + src/riscv/thead/th1520.dtsi | 34 + 1311 files changed, 67670 insertions(+), 8539 deletions(-) create mode 100644 Bindings/arm/google.yaml delete mode 100644 Bindings/arm/mediatek/mediatek,audsys.txt create mode 100644 Bindings/arm/mediatek/mediatek,audsys.yaml delete mode 100644 Bindings/arm/mediatek/mediatek,ethsys.txt delete mode 100644 Bindings/arm/msm/qcom,idle-state.txt create mode 100644 Bindings/arm/qcom,coresight-remote-etm.yaml delete mode 100644 Bindings/clock/brcm,kona-ccu.txt create mode 100644 Bindings/clock/brcm,kona-ccu.yaml create mode 100644 Bindings/clock/fsl,imx93-anatop.yaml create mode 100644 Bindings/clock/google,gs101-clock.yaml delete mode 100644 Bindings/clock/hi3620-clock.txt create mode 100644 Bindings/clock/mediatek,ethsys.yaml create mode 100644 Bindings/clock/mediatek,mt7988-ethwarp.yaml create mode 100644 Bindings/clock/mediatek,mt7988-xfi-pll.yaml create mode 100644 Bindings/clock/qcom,gcc-ipq6018.yaml create mode 100644 Bindings/clock/qcom,qdu1000-ecpricc.yaml create mode 100644 Bindings/clock/qcom,sm8650-dispcc.yaml create mode 100644 Bindings/clock/qcom,sm8650-gcc.yaml create mode 100644 Bindings/clock/qcom,x1e80100-gcc.yaml delete mode 100644 Bindings/clock/silabs,si5351.txt create mode 100644 Bindings/clock/silabs,si5351.yaml create mode 100644 Bindings/clock/sophgo,cv1800-clk.yaml create mode 100644 Bindings/clock/st,stm32mp25-rcc.yaml create mode 100644 Bindings/crypto/inside-secure,safexcel.yaml delete mode 100644 Bindings/crypto/inside-secure-safexcel.txt delete mode 100644 Bindings/display/mediatek/mediatek,mdp-rdma.yaml create mode 100644 Bindings/display/mediatek/mediatek,padding.yaml create mode 100644 Bindings/display/msm/qcom,sdm670-mdss.yaml create mode 100644 Bindings/display/msm/qcom,sm8650-dpu.yaml create mode 100644 Bindings/display/msm/qcom,sm8650-mdss.yaml create mode 100644 Bindings/display/panel/fascontek,fs035vg158.yaml create mode 100644 Bindings/display/panel/ilitek,ili9805.yaml create mode 100644 Bindings/display/panel/synaptics,r63353.yaml delete mode 100644 Bindings/display/rockchip/inno_hdmi-rockchip.txt create mode 100644 Bindings/display/rockchip/rockchip,inno-hdmi.yaml create mode 100644 Bindings/dma/loongson,ls2x-apbdma.yaml create mode 100644 Bindings/dts-coding-style.rst delete mode 100644 Bindings/fpga/altera-fpga2sdram-bridge.txt delete mode 100644 Bindings/fpga/altera-freeze-bridge.txt delete mode 100644 Bindings/fpga/altera-hps2fpga-bridge.txt create mode 100644 Bindings/fpga/altr,freeze-bridge-controller.yaml create mode 100644 Bindings/fpga/altr,socfpga-fpga2sdram-bridge.yaml create mode 100644 Bindings/fpga/altr,socfpga-hps2fpga-bridge.yaml delete mode 100644 Bindings/fpga/fpga-bridge.txt create mode 100644 Bindings/fpga/fpga-bridge.yaml create mode 100644 Bindings/gpio/nuvoton,sgpio.yaml create mode 100644 Bindings/gpio/realtek,rtd-gpio.yaml create mode 100644 Bindings/gpu/img,powervr.yaml delete mode 100644 Bindings/hwmon/gpio-fan.txt create mode 100644 Bindings/hwmon/gpio-fan.yaml create mode 100644 Bindings/hwmon/lltc,ltc4286.yaml create mode 100644 Bindings/iio/adc/maxim,max34408.yaml create mode 100644 Bindings/iio/chemical/aosong,ags02ma.yaml create mode 100644 Bindings/iio/dac/microchip,mcp4821.yaml create mode 100644 Bindings/iio/humidity/ti,hdc3020.yaml create mode 100644 Bindings/iio/imu/bosch,bmi323.yaml create mode 100644 Bindings/iio/light/liteon,ltr390.yaml create mode 100644 Bindings/iio/light/vishay,veml6075.yaml create mode 100644 Bindings/iio/pressure/honeywell,hsc030pa.yaml create mode 100644 Bindings/iio/temperature/microchip,mcp9600.yaml create mode 100644 Bindings/input/adafruit,seesaw-gamepad.yaml delete mode 100644 Bindings/input/gpio-mouse.txt create mode 100644 Bindings/input/gpio-mouse.yaml delete mode 100644 Bindings/input/ti,drv2665.txt delete mode 100644 Bindings/input/ti,drv2667.txt create mode 100644 Bindings/input/ti,drv266x.yaml create mode 100644 Bindings/input/touchscreen/neonode,zforce.yaml delete mode 100644 Bindings/input/touchscreen/samsung,s6sy761.txt create mode 100644 Bindings/input/touchscreen/samsung,s6sy761.yaml delete mode 100644 Bindings/input/touchscreen/zforce_ts.txt create mode 100644 Bindings/interconnect/qcom,sm6115.yaml create mode 100644 Bindings/interconnect/qcom,sm8650-rpmh.yaml create mode 100644 Bindings/interconnect/qcom,x1e80100-rpmh.yaml create mode 100644 Bindings/leds/allwinner,sun50i-a100-ledc.yaml create mode 100644 Bindings/loongarch/cpus.yaml create mode 100644 Bindings/loongarch/loongson.yaml create mode 100644 Bindings/media/cnm,wave521c.yaml create mode 100644 Bindings/media/i2c/alliedvision,alvium-csi2.yaml create mode 100644 Bindings/media/i2c/galaxycore,gc0308.yaml create mode 100644 Bindings/media/i2c/galaxycore,gc2145.yaml create mode 100644 Bindings/media/i2c/ovti,ov64a40.yaml create mode 100644 Bindings/media/i2c/techwell,tw9900.yaml create mode 100644 Bindings/media/i2c/thine,thp7312.yaml create mode 100644 Bindings/media/mediatek,mdp3-fg.yaml create mode 100644 Bindings/media/mediatek,mdp3-hdr.yaml create mode 100644 Bindings/media/mediatek,mdp3-stitch.yaml create mode 100644 Bindings/media/mediatek,mdp3-tcc.yaml create mode 100644 Bindings/media/mediatek,mdp3-tdshp.yaml create mode 100644 Bindings/media/st,stm32-dcmipp.yaml create mode 100644 Bindings/media/starfive,jh7110-camss.yaml create mode 100644 Bindings/mfd/ams,as3711.yaml delete mode 100644 Bindings/mfd/as3711.txt create mode 100644 Bindings/net/dsa/marvell,mv88e6060.yaml create mode 100644 Bindings/net/dsa/marvell,mv88e6xxx.yaml delete mode 100644 Bindings/net/dsa/marvell.txt create mode 100644 Bindings/net/lantiq,pef2256.yaml create mode 100644 Bindings/net/marvell,aquantia.yaml create mode 100644 Bindings/net/renesas,ethertsn.yaml create mode 100644 Bindings/pinctrl/qcom,lpass-lpi-common.yaml create mode 100644 Bindings/pinctrl/qcom,sm4450-tlmm.yaml create mode 100644 Bindings/pinctrl/qcom,sm8650-lpass-lpi-pinctrl.yaml create mode 100644 Bindings/pinctrl/qcom,sm8650-tlmm.yaml create mode 100644 Bindings/pinctrl/qcom,x1e80100-tlmm.yaml delete mode 100644 Bindings/pwm/pwm-omap-dmtimer.txt create mode 100644 Bindings/pwm/ti,omap-dmtimer-pwm.yaml create mode 100644 Bindings/rtc/adi,max31335.yaml create mode 100644 Bindings/rtc/nuvoton,ma35d1-rtc.yaml delete mode 100644 Bindings/security/tpm/google,cr50.txt delete mode 100644 Bindings/security/tpm/ibmvtpm.txt delete mode 100644 Bindings/security/tpm/st33zp24-i2c.txt delete mode 100644 Bindings/security/tpm/st33zp24-spi.txt delete mode 100644 Bindings/security/tpm/tpm-i2c.txt delete mode 100644 Bindings/security/tpm/tpm_tis_mmio.txt delete mode 100644 Bindings/security/tpm/tpm_tis_spi.txt create mode 100644 Bindings/serial/arm,dcc.yaml rename Bindings/{arm => soc/xilinx}/xilinx.yaml (95%) delete mode 100644 Bindings/sound/es8328.txt create mode 100644 Bindings/sound/everest,es8328.yaml delete mode 100644 Bindings/sound/fsl,mqs.txt create mode 100644 Bindings/sound/fsl,mqs.yaml create mode 100644 Bindings/sound/mediatek,mt2701-audio.yaml delete mode 100644 Bindings/sound/mt2701-afe-pcm.txt delete mode 100644 Bindings/spi/adi,axi-spi-engine.txt create mode 100644 Bindings/spi/adi,axi-spi-engine.yaml create mode 100644 Bindings/thermal/mediatek,thermal.yaml delete mode 100644 Bindings/thermal/mediatek-thermal.txt create mode 100644 Bindings/tpm/google,cr50.yaml create mode 100644 Bindings/tpm/ibm,vtpm.yaml create mode 100644 Bindings/tpm/microsoft,ftpm.yaml create mode 100644 Bindings/tpm/tcg,tpm-tis-i2c.yaml create mode 100644 Bindings/tpm/tcg,tpm-tis-mmio.yaml create mode 100644 Bindings/tpm/tcg,tpm_tis-spi.yaml create mode 100644 Bindings/tpm/tpm-common.yaml create mode 100644 Bindings/usb/qcom,wcd939x-usbss.yaml create mode 100644 Bindings/w1/amd,axi-1wire-host.yaml create mode 100644 Bindings/watchdog/nxp,pnx4008-wdt.yaml delete mode 100644 Bindings/watchdog/pnx4008-wdt.txt create mode 100644 Bindings/watchdog/qca,ar7130-wdt.yaml delete mode 100644 Bindings/watchdog/qca-ar7130-wdt.txt delete mode 100644 Bindings/watchdog/realtek,rtd119x.txt create mode 100644 Bindings/watchdog/realtek,rtd1295-watchdog.yaml create mode 100644 Bindings/watchdog/technologic,ts7200-wdt.yaml create mode 100644 include/dt-bindings/clock/google,gs101.h create mode 100644 include/dt-bindings/clock/mediatek,mt7988-clk.h create mode 100644 include/dt-bindings/clock/qcom,qdu1000-ecpricc.h create mode 100644 include/dt-bindings/clock/qcom,sc8280xp-camcc.h create mode 100644 include/dt-bindings/clock/qcom,sm8650-dispcc.h create mode 100644 include/dt-bindings/clock/qcom,sm8650-gcc.h create mode 100644 include/dt-bindings/clock/qcom,sm8650-gpucc.h create mode 100644 include/dt-bindings/clock/qcom,sm8650-tcsr.h create mode 100644 include/dt-bindings/clock/qcom,x1e80100-gcc.h create mode 100644 include/dt-bindings/clock/sophgo,cv1800.h create mode 100644 include/dt-bindings/clock/st,stm32mp25-rcc.h create mode 100644 include/dt-bindings/dma/fsl-edma.h create mode 100644 include/dt-bindings/iio/qcom,spmi-adc7-pm7325.h create mode 100644 include/dt-bindings/iio/qcom,spmi-adc7-smb139x.h create mode 100644 include/dt-bindings/interconnect/qcom,sm6115.h create mode 100644 include/dt-bindings/interconnect/qcom,sm8650-rpmh.h create mode 100644 include/dt-bindings/interconnect/qcom,x1e80100-rpmh.h create mode 100644 include/dt-bindings/reset/amlogic,c3-reset.h create mode 100644 include/dt-bindings/reset/mediatek,mt7988-resets.h create mode 100644 include/dt-bindings/reset/qcom,sm8650-gpucc.h create mode 100644 include/dt-bindings/reset/st,stm32mp25-rcc.h create mode 100644 src/arm/qcom/pm8018.dtsi create mode 100644 src/arm/qcom/pm8058.dtsi rename src/arm/qcom/{qcom-pm8226.dtsi => pm8226.dtsi} (99%) create mode 100644 src/arm/qcom/pm8821.dtsi rename src/arm/qcom/{qcom-pm8841.dtsi => pm8841.dtsi} (100%) create mode 100644 src/arm/qcom/pm8921.dtsi rename src/arm/qcom/{qcom-pm8941.dtsi => pm8941.dtsi} (99%) rename src/arm/qcom/{qcom-pma8084.dtsi => pma8084.dtsi} (100%) rename src/arm/qcom/{qcom-pmx55.dtsi => pmx55.dtsi} (100%) rename src/arm/qcom/{qcom-pmx65.dtsi => pmx65.dtsi} (100%) create mode 100644 src/arm/qcom/qcom-msm8226-microsoft-common.dtsi create mode 100644 src/arm/qcom/qcom-msm8226-microsoft-dempsey.dts create mode 100644 src/arm/qcom/qcom-msm8226-microsoft-makepeace.dts create mode 100644 src/arm/qcom/qcom-msm8226-microsoft-moneypenny.dts create mode 100644 src/arm/qcom/qcom-msm8926-htc-memul.dts create mode 100644 src/arm/qcom/qcom-msm8926-microsoft-superman-lte.dts create mode 100644 src/arm/qcom/qcom-msm8926-microsoft-tesla.dts create mode 100644 src/arm/qcom/qcom-msm8926-motorola-peregrine.dts create mode 100644 src/arm/rockchip/rk3128-xpi-3128.dts create mode 100644 src/arm/rockchip/rv1109-sonoff-ihost.dts create mode 100644 src/arm/rockchip/rv1109.dtsi create mode 100644 src/arm/rockchip/rv1126-sonoff-ihost.dts create mode 100644 src/arm/rockchip/rv1126-sonoff-ihost.dtsi create mode 100644 src/arm/st/ste-href-ab8505.dtsi create mode 100644 src/arm/ti/omap/motorola-mapphone-handset.dtsi create mode 100644 src/arm/ti/omap/motorola-mapphone-mz607-mz617.dtsi create mode 100644 src/arm/ti/omap/motorola-mapphone-xt8xx.dtsi create mode 100644 src/arm/ti/omap/omap4-xyboard-mz609.dts create mode 100644 src/arm/ti/omap/omap4-xyboard-mz617.dts create mode 100644 src/arm64/allwinner/sun50i-h618-orangepi-zero2w.dts create mode 100644 src/arm64/allwinner/sun50i-h618-transpeed-8k618-t.dts create mode 100644 src/arm64/exynos/exynosautov920-pinctrl.dtsi create mode 100644 src/arm64/exynos/exynosautov920-sadk.dts create mode 100644 src/arm64/exynos/exynosautov920.dtsi create mode 100644 src/arm64/exynos/google/gs101-oriole.dts create mode 100644 src/arm64/exynos/google/gs101-pinctrl.dtsi create mode 100644 src/arm64/exynos/google/gs101-pinctrl.h create mode 100644 src/arm64/exynos/google/gs101.dtsi create mode 100644 src/arm64/freescale/fsl-lx2160a-tqmlx2160a-mblx2160a.dts create mode 100644 src/arm64/freescale/fsl-lx2160a-tqmlx2160a-mblx2160a_12_x_x.dtso create mode 100644 src/arm64/freescale/fsl-lx2160a-tqmlx2160a-mblx2160a_14_x_x.dtso create mode 100644 src/arm64/freescale/fsl-lx2160a-tqmlx2160a-mblx2160a_x_11_x.dtso create mode 100644 src/arm64/freescale/fsl-lx2160a-tqmlx2160a-mblx2160a_x_7_x.dtso create mode 100644 src/arm64/freescale/fsl-lx2160a-tqmlx2160a-mblx2160a_x_8_x.dtso create mode 100644 src/arm64/freescale/fsl-lx2160a-tqmlx2160a.dtsi create mode 100644 src/arm64/freescale/imx8mm-overdrive.dtsi create mode 100644 src/arm64/freescale/imx8mm-verdin-mallow.dtsi create mode 100644 src/arm64/freescale/imx8mm-verdin-nonwifi-mallow.dts create mode 100644 src/arm64/freescale/imx8mm-verdin-wifi-mallow.dts create mode 100644 src/arm64/freescale/imx8mn-bsh-smm-s2-display.dtsi create mode 100644 src/arm64/freescale/imx8mn-dimonoff-gateway-evk.dts create mode 100644 src/arm64/freescale/imx8mn-overdrive.dtsi create mode 100644 src/arm64/freescale/imx8mn-rve-gateway.dts create mode 100644 src/arm64/freescale/imx8mp-skov-reva.dtsi create mode 100644 src/arm64/freescale/imx8mp-skov-revb-hdmi.dts create mode 100644 src/arm64/freescale/imx8mp-skov-revb-lt6.dts create mode 100644 src/arm64/freescale/imx8mp-skov-revb-mi1010ait-1cp1.dts create mode 100644 src/arm64/freescale/imx8mp-tqma8mpql-mba8mpxl-lvds-g133han01.dtso create mode 100644 src/arm64/freescale/imx8mp-verdin-mallow.dtsi create mode 100644 src/arm64/freescale/imx8mp-verdin-nonwifi-mallow.dts create mode 100644 src/arm64/freescale/imx8mp-verdin-wifi-mallow.dts create mode 100644 src/arm64/freescale/imx8qxp-ss-vpu.dtsi create mode 100644 src/arm64/freescale/imx93-tqma9352-mba93xxca.dts create mode 100644 src/arm64/marvell/ac5x-rd-carrier-cn9131.dts create mode 100644 src/arm64/marvell/ac5x-rd-carrier.dtsi create mode 100644 src/arm64/marvell/cn9130-db-comexpress.dtsi create mode 100644 src/arm64/marvell/cn9131-db-comexpress.dtsi create mode 100644 src/arm64/mediatek/mt8183-kukui-jacuzzi-makomo-sku0.dts create mode 100644 src/arm64/mediatek/mt8183-kukui-jacuzzi-makomo-sku1.dts create mode 100644 src/arm64/mediatek/mt8183-kukui-jacuzzi-pico.dts create mode 100644 src/arm64/mediatek/mt8183-kukui-jacuzzi-pico6.dts create mode 100644 src/arm64/mediatek/mt8183-kukui-katsu-sku32.dts create mode 100644 src/arm64/mediatek/mt8183-kukui-katsu-sku38.dts create mode 100644 src/arm64/mediatek/mt8188-evb.dts create mode 100644 src/arm64/mediatek/mt8188.dtsi create mode 100644 src/arm64/qcom/ipq9574-rdp-common.dtsi create mode 100644 src/arm64/qcom/msm8916-modem-qdsp6.dtsi create mode 100644 src/arm64/qcom/msm8939-huawei-kiwi.dts create mode 100644 src/arm64/qcom/qcm6490-idp.dts create mode 100644 src/arm64/qcom/qcs6490-rb3gen2.dts create mode 100644 src/arm64/qcom/sm8250-xiaomi-pipa.dts create mode 100644 src/arm64/qcom/sm8650-mtp.dts create mode 100644 src/arm64/qcom/sm8650-qrd.dts create mode 100644 src/arm64/qcom/sm8650.dtsi create mode 100644 src/arm64/qcom/x1e80100-crd.dts create mode 100644 src/arm64/qcom/x1e80100-qcp.dts create mode 100644 src/arm64/qcom/x1e80100.dtsi create mode 100644 src/arm64/rockchip/rk3326-anbernic-rg351m.dtsi create mode 100644 src/arm64/rockchip/rk3326-anbernic-rg351v.dts create mode 100644 src/arm64/rockchip/rk3566-powkiddy-rk2023.dts create mode 100644 src/arm64/rockchip/rk3566-powkiddy-rk2023.dtsi create mode 100644 src/arm64/rockchip/rk3566-powkiddy-x55.dts create mode 100644 src/arm64/rockchip/rk3588-coolpi-cm5-evb.dts create mode 100644 src/arm64/rockchip/rk3588-coolpi-cm5.dtsi create mode 100644 src/arm64/rockchip/rk3588-jaguar.dts create mode 100644 src/arm64/rockchip/rk3588s-coolpi-4b.dts create mode 100644 src/arm64/sprd/ums9620-2h10.dts create mode 100644 src/arm64/sprd/ums9620.dtsi create mode 100644 src/arm64/ti/k3-am62-verdin-mallow.dtsi create mode 100644 src/arm64/ti/k3-am625-beagleplay-csi2-ov5640.dtso create mode 100644 src/arm64/ti/k3-am625-beagleplay-csi2-tevi-ov5640.dtso create mode 100644 src/arm64/ti/k3-am625-verdin-nonwifi-mallow.dts create mode 100644 src/arm64/ti/k3-am625-verdin-wifi-mallow.dts create mode 100644 src/arm64/ti/k3-am62x-sk-csi2-imx219.dtso create mode 100644 src/arm64/ti/k3-am62x-sk-csi2-ov5640.dtso create mode 100644 src/arm64/ti/k3-am62x-sk-csi2-tevi-ov5640.dtso create mode 100644 src/arm64/ti/k3-am652.dtsi create mode 100644 src/arm64/ti/k3-j721e-evm-pcie0-ep.dtso create mode 100644 src/arm64/ti/k3-j721s2-evm-pcie1-ep.dtso create mode 100644 src/loongarch/loongson-2k0500-ref.dts create mode 100644 src/loongarch/loongson-2k0500.dtsi create mode 100644 src/loongarch/loongson-2k1000-ref.dts create mode 100644 src/loongarch/loongson-2k1000.dtsi create mode 100644 src/loongarch/loongson-2k2000-ref.dts create mode 100644 src/loongarch/loongson-2k2000.dtsi create mode 100644 src/riscv/sophgo/cv1812h-huashan-pi.dts create mode 100644 src/riscv/sophgo/cv1812h.dtsi create mode 100644 src/riscv/sophgo/cv18xx.dtsi
Bryan Brattlof
Sumit Garg
