[PATCH v3 01/12] rockchip: rk3228-power: sync power domain dt-binding header from Linux
In order to update the DT for rk3228 sync the power domain dt-binding header. This is the state as of v5.17 in Linux.
Signed-off-by: Johan Jonker jbx6244@gmail.com Reviewed-by: Simon Glass sjg@chromium.org --- include/dt-bindings/power/rk3228-power.h | 21 +++++++++++++++++++++ 1 file changed, 21 insertions(+) create mode 100644 include/dt-bindings/power/rk3228-power.h
diff --git a/include/dt-bindings/power/rk3228-power.h b/include/dt-bindings/power/rk3228-power.h new file mode 100644 index 00000000..6a8dc1bf --- /dev/null +++ b/include/dt-bindings/power/rk3228-power.h @@ -0,0 +1,21 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +#ifndef __DT_BINDINGS_POWER_RK3228_POWER_H__ +#define __DT_BINDINGS_POWER_RK3228_POWER_H__ + +/** + * RK3228 idle id Summary. + */ + +#define RK3228_PD_CORE 0 +#define RK3228_PD_MSCH 1 +#define RK3228_PD_BUS 2 +#define RK3228_PD_SYS 3 +#define RK3228_PD_VIO 4 +#define RK3228_PD_VOP 5 +#define RK3228_PD_VPU 6 +#define RK3228_PD_RKVDEC 7 +#define RK3228_PD_GPU 8 +#define RK3228_PD_PERI 9 +#define RK3228_PD_GMAC 10 + +#endif
In order to update the DT for rk3228 sync the clock dt-binding header. This is the state as of v5.17 in Linux.
Signed-off-by: Johan Jonker jbx6244@gmail.com Reviewed-by: Simon Glass sjg@chromium.org --- include/dt-bindings/clock/rk3228-cru.h | 54 +++++++++++++++++++++++++- 1 file changed, 52 insertions(+), 2 deletions(-)
diff --git a/include/dt-bindings/clock/rk3228-cru.h b/include/dt-bindings/clock/rk3228-cru.h index 1217d523..de550ea5 100644 --- a/include/dt-bindings/clock/rk3228-cru.h +++ b/include/dt-bindings/clock/rk3228-cru.h @@ -1,6 +1,7 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ +/* SPDX-License-Identifier: GPL-2.0-or-later */ /* - * (C) Copyright 2017 Rockchip Electronics Co., Ltd. + * Copyright (c) 2015 Rockchip Electronics Co. Ltd. + * Author: Jeffy Chen jeffy.chen@rock-chips.com */
#ifndef _DT_BINDINGS_CLK_ROCKCHIP_RK3228_H @@ -39,6 +40,7 @@ #define SCLK_EMMC_DRV 117 #define SCLK_SDMMC_SAMPLE 118 #define SCLK_SDIO_SAMPLE 119 +#define SCLK_SDIO_SRC 120 #define SCLK_EMMC_SAMPLE 121 #define SCLK_VOP 122 #define SCLK_HDMI_HDCP 123 @@ -51,6 +53,18 @@ #define SCLK_MAC_TX 130 #define SCLK_MAC_PHY 131 #define SCLK_MAC_OUT 132 +#define SCLK_VDEC_CABAC 133 +#define SCLK_VDEC_CORE 134 +#define SCLK_RGA 135 +#define SCLK_HDCP 136 +#define SCLK_HDMI_CEC 137 +#define SCLK_CRYPTO 138 +#define SCLK_TSP 139 +#define SCLK_HSADC 140 +#define SCLK_WIFI 141 +#define SCLK_OTGPHY0 142 +#define SCLK_OTGPHY1 143 +#define SCLK_HDMI_PHY 144
/* dclk gates */ #define DCLK_VOP 190 @@ -58,15 +72,32 @@
/* aclk gates */ #define ACLK_DMAC 194 +#define ACLK_CPU 195 +#define ACLK_VPU_PRE 196 +#define ACLK_RKVDEC_PRE 197 +#define ACLK_RGA_PRE 198 +#define ACLK_IEP_PRE 199 +#define ACLK_HDCP_PRE 200 +#define ACLK_VOP_PRE 201 +#define ACLK_VPU 202 +#define ACLK_RKVDEC 203 +#define ACLK_IEP 204 +#define ACLK_RGA 205 +#define ACLK_HDCP 206 #define ACLK_PERI 210 #define ACLK_VOP 211 #define ACLK_GMAC 212 +#define ACLK_GPU 213
/* pclk gates */ #define PCLK_GPIO0 320 #define PCLK_GPIO1 321 #define PCLK_GPIO2 322 #define PCLK_GPIO3 323 +#define PCLK_VIO_H2P 324 +#define PCLK_HDCP 325 +#define PCLK_EFUSE_1024 326 +#define PCLK_EFUSE_256 327 #define PCLK_GRF 329 #define PCLK_I2C0 332 #define PCLK_I2C1 333 @@ -79,6 +110,7 @@ #define PCLK_TSADC 344 #define PCLK_PWM 350 #define PCLK_TIMER 353 +#define PCLK_CPU 354 #define PCLK_PERI 363 #define PCLK_HDMI_CTRL 364 #define PCLK_HDMI_PHY 365 @@ -94,6 +126,24 @@ #define HCLK_SDMMC 456 #define HCLK_SDIO 457 #define HCLK_EMMC 459 +#define HCLK_CPU 460 +#define HCLK_VPU_PRE 461 +#define HCLK_RKVDEC_PRE 462 +#define HCLK_VIO_PRE 463 +#define HCLK_VPU 464 +#define HCLK_RKVDEC 465 +#define HCLK_VIO 466 +#define HCLK_RGA 467 +#define HCLK_IEP 468 +#define HCLK_VIO_H2P 469 +#define HCLK_HDCP_MMU 470 +#define HCLK_HOST0 471 +#define HCLK_HOST1 472 +#define HCLK_HOST2 473 +#define HCLK_OTG 474 +#define HCLK_TSP 475 +#define HCLK_M_CRYPTO 476 +#define HCLK_S_CRYPTO 477 #define HCLK_PERI 478
#define CLK_NR_CLKS (HCLK_PERI + 1)
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
- (C) Copyright 2017 Rockchip Electronics Co., Ltd.
- Copyright (c) 2015 Rockchip Electronics Co. Ltd.
- Author: Jeffy Chen jeffy.chen@rock-chips.com
In order to sync rk322x.dtsi from Linux, move all U-boot specific properties in separate dtsi files.
Signed-off-by: Johan Jonker jbx6244@gmail.com ---
Changed V3: add include "rockchip-u-boot.dtsi" --- arch/arm/dts/rk3229-evb-u-boot.dtsi | 28 +++++++++++++++ arch/arm/dts/rk3229-evb.dts | 17 --------- arch/arm/dts/rk322x-u-boot.dtsi | 56 +++++++++++++++++++++++++++++ arch/arm/dts/rk322x.dtsi | 37 ------------------- 4 files changed, 84 insertions(+), 54 deletions(-) create mode 100644 arch/arm/dts/rk3229-evb-u-boot.dtsi create mode 100644 arch/arm/dts/rk322x-u-boot.dtsi
diff --git a/arch/arm/dts/rk3229-evb-u-boot.dtsi b/arch/arm/dts/rk3229-evb-u-boot.dtsi new file mode 100644 index 00000000..b65149c2 --- /dev/null +++ b/arch/arm/dts/rk3229-evb-u-boot.dtsi @@ -0,0 +1,28 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) + +#include "rk322x-u-boot.dtsi" + +/ { + chosen { + stdout-path = &uart2; + }; +}; + +&dmc { + rockchip,pctl-timing = <0x96 0xC8 0x1F3 0xF 0x8000004D 0x4 0x4E 0x6 0x3 + 0x0 0x6 0x5 0xC 0x10 0x6 0x4 0x4 + 0x5 0x4 0x200 0x3 0xA 0x40 0x0 0x1 + 0x5 0x5 0x3 0xC 0x1E 0x100 0x0 0x4 + 0x0 0x924>; + rockchip,phy-timing = <0x220 0x1 0x0 0x0 0x0 0x4 0x60>; + rockchip,sdram-params = <0x428B188 0x0 0x21 0x472 0x15 + 0 300 3 0 120>; +}; + +&emmc { + u-boot,dm-pre-reloc; +}; + +&uart2 { + u-boot,dm-pre-reloc; +}; diff --git a/arch/arm/dts/rk3229-evb.dts b/arch/arm/dts/rk3229-evb.dts index 632cdc9b..66a3ba23 100644 --- a/arch/arm/dts/rk3229-evb.dts +++ b/arch/arm/dts/rk3229-evb.dts @@ -11,10 +11,6 @@ model = "Rockchip RK3229 Evaluation board"; compatible = "rockchip,rk3229-evb", "rockchip,rk3229";
- chosen { - stdout-path = &uart2; - }; - memory@60000000 { device_type = "memory"; reg = <0x60000000 0x40000000>; @@ -38,17 +34,6 @@ }; };
-&dmc { - rockchip,pctl-timing = <0x96 0xC8 0x1F3 0xF 0x8000004D 0x4 0x4E 0x6 0x3 - 0x0 0x6 0x5 0xC 0x10 0x6 0x4 0x4 - 0x5 0x4 0x200 0x3 0xA 0x40 0x0 0x1 - 0x5 0x5 0x3 0xC 0x1E 0x100 0x0 0x4 - 0x0 0x924>; - rockchip,phy-timing = <0x220 0x1 0x0 0x0 0x0 0x4 0x60>; - rockchip,sdram-params = <0x428B188 0x0 0x21 0x472 0x15 - 0 300 3 0 120>; -}; - &gmac { assigned-clocks = <&cru SCLK_MAC_EXTCLK>, <&cru SCLK_MAC>; assigned-clock-parents = <&ext_gmac>, <&cru SCLK_MAC_EXTCLK>; @@ -66,7 +51,6 @@ };
&emmc { - u-boot,dm-pre-reloc; status = "okay"; };
@@ -82,7 +66,6 @@ };
&uart2 { - u-boot,dm-pre-reloc; status = "okay"; };
diff --git a/arch/arm/dts/rk322x-u-boot.dtsi b/arch/arm/dts/rk322x-u-boot.dtsi new file mode 100644 index 00000000..79c41e48 --- /dev/null +++ b/arch/arm/dts/rk322x-u-boot.dtsi @@ -0,0 +1,56 @@ +// SPDX-License-Identifier: GPL-2.0+ + +#include "rockchip-u-boot.dtsi" + +/ { + bus_intmem@10080000 { + compatible = "mmio-sram"; + reg = <0x10080000 0x9000>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x10080000 0x9000>; + + smp-sram@0 { + compatible = "rockchip,rk322x-smp-sram"; + reg = <0x00 0x10>; + }; + + ddr_sram: ddr-sram@1000 { + compatible = "rockchip,rk322x-ddr-sram"; + reg = <0x1000 0x8000>; + }; + }; + + dmc: dmc@11200000 { + compatible = "rockchip,rk3228-dmc", "syscon"; + reg = <0x11200000 0x3fc + 0x12000000 0x400>; + rockchip,cru = <&cru>; + rockchip,grf = <&grf>; + rockchip,msch = <&service_msch>; + rockchip,sram = <&ddr_sram>; + u-boot,dm-pre-reloc; + }; + + service_msch: syscon@31090000 { + compatible = "rockchip,rk3228-msch", "syscon"; + reg = <0x31090000 0x2000>; + u-boot,dm-pre-reloc; + }; +}; + +&cru { + u-boot,dm-pre-reloc; +}; + +&emmc { + max-frequency = <150000000>; +}; + +&grf { + u-boot,dm-pre-reloc; +}; + +&sdmmc { + max-frequency = <150000000>; +}; diff --git a/arch/arm/dts/rk322x.dtsi b/arch/arm/dts/rk322x.dtsi index 4a8be5da..3245da3c 100644 --- a/arch/arm/dts/rk322x.dtsi +++ b/arch/arm/dts/rk322x.dtsi @@ -107,22 +107,6 @@ #clock-cells = <0>; };
- bus_intmem@10080000 { - compatible = "mmio-sram"; - reg = <0x10080000 0x9000>; - #address-cells = <1>; - #size-cells = <1>; - ranges = <0 0x10080000 0x9000>; - smp-sram@0 { - compatible = "rockchip,rk322x-smp-sram"; - reg = <0x00 0x10>; - }; - ddr_sram: ddr-sram@1000 { - compatible = "rockchip,rk322x-ddr-sram"; - reg = <0x1000 0x8000>; - }; - }; - i2s1: i2s1@100b0000 { compatible = "rockchip,rk3228-i2s", "rockchip,rk3066-i2s"; reg = <0x100b0000 0x4000>; @@ -165,7 +149,6 @@ };
grf: syscon@11000000 { - u-boot,dm-pre-reloc; compatible = "rockchip,rk3228-grf", "syscon"; reg = <0x11000000 0x1000>; }; @@ -317,7 +300,6 @@ };
cru: clock-controller@110e0000 { - u-boot,dm-pre-reloc; compatible = "rockchip,rk3228-cru"; reg = <0x110e0000 0x1000>; rockchip,grf = <&grf>; @@ -387,7 +369,6 @@ sdmmc: dwmmc@30000000 { compatible = "rockchip,rk3228-dw-mshc", "rockchip,rk3288-dw-mshc"; reg = <0x30000000 0x4000>; - max-frequency = <150000000>; interrupts = <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cru HCLK_SDMMC>, <&cru SCLK_SDMMC>, <&cru SCLK_SDMMC_DRV>, <&cru SCLK_SDMMC_SAMPLE>; @@ -414,7 +395,6 @@ emmc: dwmmc@30020000 { compatible = "rockchip,rk3288-dw-mshc"; reg = <0x30020000 0x4000>; - max-frequency = <150000000>; interrupts = <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cru HCLK_EMMC>, <&cru SCLK_EMMC>, <&cru SCLK_EMMC_DRV>, <&cru SCLK_EMMC_SAMPLE>; @@ -768,21 +748,4 @@ }; }; }; - - dmc: dmc@11200000 { - u-boot,dm-pre-reloc; - compatible = "rockchip,rk3228-dmc", "syscon"; - rockchip,cru = <&cru>; - rockchip,grf = <&grf>; - rockchip,msch = <&service_msch>; - reg = <0x11200000 0x3fc - 0x12000000 0x400>; - rockchip,sram = <&ddr_sram>; - }; - - service_msch: syscon@31090000 { - u-boot,dm-pre-reloc; - compatible = "rockchip,rk3228-msch", "syscon"; - reg = <0x31090000 0x2000>; - }; };
Thanks, - Kever
- chosen {
+&dmc {
0x0 0x924>;
0 300 3 0 120>;
+&emmc {
+&uart2 {
- chosen {
-&dmc {
0x0 0x924>;
0 300 3 0 120>;
&emmc {
&uart2 {
#size-cells = <1>;
smp-sram@0 {
reg = <0x00 0x10>;
0x12000000 0x400>;
+&cru {
+&emmc {
+&grf {
+&sdmmc {
#size-cells = <1>;
smp-sram@0 {
reg = <0x00 0x10>;
compatible = "rockchip,rk3228-grf", "syscon"; reg = <0x11000000 0x1000>; };u-boot,dm-pre-reloc;
compatible = "rockchip,rk3228-cru"; reg = <0x110e0000 0x1000>; rockchip,grf = <&grf>;u-boot,dm-pre-reloc;
interrupts = <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cru HCLK_SDMMC>, <&cru SCLK_SDMMC>, <&cru SCLK_SDMMC_DRV>, <&cru SCLK_SDMMC_SAMPLE>;max-frequency = <150000000>;
interrupts = <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cru HCLK_EMMC>, <&cru SCLK_EMMC>, <&cru SCLK_EMMC_DRV>, <&cru SCLK_EMMC_SAMPLE>;max-frequency = <150000000>;
0x12000000 0x400>;
Sync rk322x.dtsi from Linux version 5.17.
Changed V2: update rename usb20_otg label --- arch/arm/dts/rk3229-evb.dts | 2 +- arch/arm/dts/rk322x.dtsi | 846 +++++++++++++++++++++++++++++------- 2 files changed, 695 insertions(+), 153 deletions(-)
diff --git a/arch/arm/dts/rk3229-evb.dts b/arch/arm/dts/rk3229-evb.dts index 66a3ba23..d2681d1a 100644 --- a/arch/arm/dts/rk3229-evb.dts +++ b/arch/arm/dts/rk3229-evb.dts @@ -69,6 +69,6 @@ status = "okay"; };
-&usb20_otg { +&usb_otg { status = "okay"; }; diff --git a/arch/arm/dts/rk322x.dtsi b/arch/arm/dts/rk322x.dtsi index 3245da3c..8eed9e3a 100644 --- a/arch/arm/dts/rk322x.dtsi +++ b/arch/arm/dts/rk322x.dtsi @@ -1,7 +1,4 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Copyright (c) 2017 Fuzhou Rockchip Electronics Co., Ltd. - */ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT)
#include <dt-bindings/gpio/gpio.h> #include <dt-bindings/interrupt-controller/irq.h> @@ -9,6 +6,7 @@ #include <dt-bindings/pinctrl/rockchip.h> #include <dt-bindings/clock/rk3228-cru.h> #include <dt-bindings/thermal/thermal.h> +#include <dt-bindings/power/rk3228-power.h>
/ { #address-cells = <1>; @@ -20,8 +18,7 @@ serial0 = &uart0; serial1 = &uart1; serial2 = &uart2; - mmc0 = &emmc; - mmc1 = &sdmmc; + spi0 = &spi0; };
cpus { @@ -33,13 +30,11 @@ compatible = "arm,cortex-a7"; reg = <0xf00>; resets = <&cru SRST_CORE0>; - operating-points = < - /* KHz uV */ - 816000 1000000 - >; + operating-points-v2 = <&cpu0_opp_table>; #cooling-cells = <2>; /* min followed by max */ clock-latency = <40000>; clocks = <&cru ARMCLK>; + enable-method = "psci"; };
cpu1: cpu@f01 { @@ -47,6 +42,9 @@ compatible = "arm,cortex-a7"; reg = <0xf01>; resets = <&cru SRST_CORE1>; + operating-points-v2 = <&cpu0_opp_table>; + #cooling-cells = <2>; /* min followed by max */ + enable-method = "psci"; };
cpu2: cpu@f02 { @@ -54,6 +52,9 @@ compatible = "arm,cortex-a7"; reg = <0xf02>; resets = <&cru SRST_CORE2>; + operating-points-v2 = <&cpu0_opp_table>; + #cooling-cells = <2>; /* min followed by max */ + enable-method = "psci"; };
cpu3: cpu@f03 { @@ -61,23 +62,37 @@ compatible = "arm,cortex-a7"; reg = <0xf03>; resets = <&cru SRST_CORE3>; + operating-points-v2 = <&cpu0_opp_table>; + #cooling-cells = <2>; /* min followed by max */ + enable-method = "psci"; }; };
- amba { - compatible = "simple-bus"; - #address-cells = <1>; - #size-cells = <1>; - ranges; + cpu0_opp_table: opp-table-0 { + compatible = "operating-points-v2"; + opp-shared;
- pdma: pdma@110f0000 { - compatible = "arm,pl330", "arm,primecell"; - reg = <0x110f0000 0x4000>; - interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>; - #dma-cells = <1>; - clocks = <&cru ACLK_DMAC>; - clock-names = "apb_pclk"; + opp-408000000 { + opp-hz = /bits/ 64 <408000000>; + opp-microvolt = <950000>; + clock-latency-ns = <40000>; + opp-suspend; + }; + opp-600000000 { + opp-hz = /bits/ 64 <600000000>; + opp-microvolt = <975000>; + }; + opp-816000000 { + opp-hz = /bits/ 64 <816000000>; + opp-microvolt = <1000000>; + }; + opp-1008000000 { + opp-hz = /bits/ 64 <1008000000>; + opp-microvolt = <1175000>; + }; + opp-1200000000 { + opp-hz = /bits/ 64 <1200000000>; + opp-microvolt = <1275000>; }; };
@@ -90,6 +105,11 @@ interrupt-affinity = <&cpu0>, <&cpu1>, <&cpu2>, <&cpu3>; };
+ psci { + compatible = "arm,psci-1.0", "arm,psci-0.2"; + method = "smc"; + }; + timer { compatible = "arm,armv7-timer"; arm,cpu-registers-not-fw-configured; @@ -107,12 +127,15 @@ #clock-cells = <0>; };
+ display_subsystem: display-subsystem { + compatible = "rockchip,display-subsystem"; + ports = <&vop_out>; + }; + i2s1: i2s1@100b0000 { compatible = "rockchip,rk3228-i2s", "rockchip,rk3066-i2s"; reg = <0x100b0000 0x4000>; interrupts = <GIC_SPI 27 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; clock-names = "i2s_clk", "i2s_hclk"; clocks = <&cru SCLK_I2S1>, <&cru HCLK_I2S1_8CH>; dmas = <&pdma 14>, <&pdma 15>; @@ -126,8 +149,6 @@ compatible = "rockchip,rk3228-i2s", "rockchip,rk3066-i2s"; reg = <0x100c0000 0x4000>; interrupts = <GIC_SPI 26 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; clock-names = "i2s_clk", "i2s_hclk"; clocks = <&cru SCLK_I2S0>, <&cru HCLK_I2S0_8CH>; dmas = <&pdma 11>, <&pdma 12>; @@ -135,12 +156,23 @@ status = "disabled"; };
+ spdif: spdif@100d0000 { + compatible = "rockchip,rk3228-spdif"; + reg = <0x100d0000 0x1000>; + interrupts = <GIC_SPI 29 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru SCLK_SPDIF>, <&cru HCLK_SPDIF_8CH>; + clock-names = "mclk", "hclk"; + dmas = <&pdma 10>; + dma-names = "tx"; + pinctrl-names = "default"; + pinctrl-0 = <&spdif_tx>; + status = "disabled"; + }; + i2s2: i2s2@100e0000 { compatible = "rockchip,rk3228-i2s", "rockchip,rk3066-i2s"; reg = <0x100e0000 0x4000>; interrupts = <GIC_SPI 28 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; clock-names = "i2s_clk", "i2s_hclk"; clocks = <&cru SCLK_I2S2>, <&cru HCLK_I2S2_2CH>; dmas = <&pdma 0>, <&pdma 1>; @@ -149,8 +181,124 @@ };
grf: syscon@11000000 { - compatible = "rockchip,rk3228-grf", "syscon"; + compatible = "rockchip,rk3228-grf", "syscon", "simple-mfd"; reg = <0x11000000 0x1000>; + #address-cells = <1>; + #size-cells = <1>; + + io_domains: io-domains { + compatible = "rockchip,rk3228-io-voltage-domain"; + status = "disabled"; + }; + + power: power-controller { + compatible = "rockchip,rk3228-power-controller"; + #power-domain-cells = <1>; + #address-cells = <1>; + #size-cells = <0>; + + power-domain@RK3228_PD_VIO { + reg = <RK3228_PD_VIO>; + clocks = <&cru ACLK_HDCP>, + <&cru SCLK_HDCP>, + <&cru ACLK_IEP>, + <&cru HCLK_IEP>, + <&cru ACLK_RGA>, + <&cru HCLK_RGA>, + <&cru SCLK_RGA>; + pm_qos = <&qos_hdcp>, + <&qos_iep>, + <&qos_rga_r>, + <&qos_rga_w>; + #power-domain-cells = <0>; + }; + + power-domain@RK3228_PD_VOP { + reg = <RK3228_PD_VOP>; + clocks =<&cru ACLK_VOP>, + <&cru DCLK_VOP>, + <&cru HCLK_VOP>; + pm_qos = <&qos_vop>; + #power-domain-cells = <0>; + }; + + power-domain@RK3228_PD_VPU { + reg = <RK3228_PD_VPU>; + clocks = <&cru ACLK_VPU>, + <&cru HCLK_VPU>; + pm_qos = <&qos_vpu>; + #power-domain-cells = <0>; + }; + + power-domain@RK3228_PD_RKVDEC { + reg = <RK3228_PD_RKVDEC>; + clocks = <&cru ACLK_RKVDEC>, + <&cru HCLK_RKVDEC>, + <&cru SCLK_VDEC_CABAC>, + <&cru SCLK_VDEC_CORE>; + pm_qos = <&qos_rkvdec_r>, + <&qos_rkvdec_w>; + #power-domain-cells = <0>; + }; + + power-domain@RK3228_PD_GPU { + reg = <RK3228_PD_GPU>; + clocks = <&cru ACLK_GPU>; + pm_qos = <&qos_gpu>; + #power-domain-cells = <0>; + }; + }; + + u2phy0: usb2phy@760 { + compatible = "rockchip,rk3228-usb2phy"; + reg = <0x0760 0x0c>; + clocks = <&cru SCLK_OTGPHY0>; + clock-names = "phyclk"; + clock-output-names = "usb480m_phy0"; + #clock-cells = <0>; + status = "disabled"; + + u2phy0_otg: otg-port { + interrupts = <GIC_SPI 59 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 60 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 61 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "otg-bvalid", "otg-id", + "linestate"; + #phy-cells = <0>; + status = "disabled"; + }; + + u2phy0_host: host-port { + interrupts = <GIC_SPI 62 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "linestate"; + #phy-cells = <0>; + status = "disabled"; + }; + }; + + u2phy1: usb2phy@800 { + compatible = "rockchip,rk3228-usb2phy"; + reg = <0x0800 0x0c>; + clocks = <&cru SCLK_OTGPHY1>; + clock-names = "phyclk"; + clock-output-names = "usb480m_phy1"; + #clock-cells = <0>; + status = "disabled"; + + u2phy1_otg: otg-port { + interrupts = <GIC_SPI 68 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "linestate"; + #phy-cells = <0>; + status = "disabled"; + }; + + u2phy1_host: host-port { + interrupts = <GIC_SPI 69 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "linestate"; + #phy-cells = <0>; + status = "disabled"; + }; + }; };
uart0: serial@11010000 { @@ -189,12 +337,29 @@ clocks = <&cru SCLK_UART2>, <&cru PCLK_UART2>; clock-names = "baudclk", "apb_pclk"; pinctrl-names = "default"; - pinctrl-0 = <&uart21_xfer>; + pinctrl-0 = <&uart2_xfer>; reg-shift = <2>; reg-io-width = <4>; status = "disabled"; };
+ efuse: efuse@11040000 { + compatible = "rockchip,rk3228-efuse"; + reg = <0x11040000 0x20>; + clocks = <&cru PCLK_EFUSE_256>; + clock-names = "pclk_efuse"; + #address-cells = <1>; + #size-cells = <1>; + + /* Data cells */ + efuse_id: id@7 { + reg = <0x7 0x10>; + }; + cpu_leakage: cpu_leakage@17 { + reg = <0x17 0x1>; + }; + }; + i2c0: i2c@11050000 { compatible = "rockchip,rk3228-i2c"; reg = <0x11050000 0x1000>; @@ -247,12 +412,32 @@ status = "disabled"; };
+ spi0: spi@11090000 { + compatible = "rockchip,rk3228-spi"; + reg = <0x11090000 0x1000>; + interrupts = <GIC_SPI 49 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + clocks = <&cru SCLK_SPI0>, <&cru PCLK_SPI0>; + clock-names = "spiclk", "apb_pclk"; + pinctrl-names = "default"; + pinctrl-0 = <&spi0_clk &spi0_tx &spi0_rx &spi0_cs0 &spi0_cs1>; + status = "disabled"; + }; + + wdt: watchdog@110a0000 { + compatible = "rockchip,rk3228-wdt", "snps,dw-wdt"; + reg = <0x110a0000 0x100>; + interrupts = <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru PCLK_CPU>; + status = "disabled"; + }; + pwm0: pwm@110b0000 { compatible = "rockchip,rk3288-pwm"; reg = <0x110b0000 0x10>; #pwm-cells = <3>; clocks = <&cru PCLK_PWM>; - clock-names = "pwm"; pinctrl-names = "default"; pinctrl-0 = <&pwm0_pin>; status = "disabled"; @@ -263,7 +448,6 @@ reg = <0x110b0010 0x10>; #pwm-cells = <3>; clocks = <&cru PCLK_PWM>; - clock-names = "pwm"; pinctrl-names = "default"; pinctrl-0 = <&pwm1_pin>; status = "disabled"; @@ -274,7 +458,6 @@ reg = <0x110b0020 0x10>; #pwm-cells = <3>; clocks = <&cru PCLK_PWM>; - clock-names = "pwm"; pinctrl-names = "default"; pinctrl-0 = <&pwm2_pin>; status = "disabled"; @@ -285,18 +468,17 @@ reg = <0x110b0030 0x10>; #pwm-cells = <2>; clocks = <&cru PCLK_PWM>; - clock-names = "pwm"; pinctrl-names = "default"; pinctrl-0 = <&pwm3_pin>; status = "disabled"; };
timer: timer@110c0000 { - compatible = "rockchip,rk3288-timer"; + compatible = "rockchip,rk3228-timer", "rockchip,rk3288-timer"; reg = <0x110c0000 0x20>; interrupts = <GIC_SPI 43 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&xin24m>, <&cru PCLK_TIMER>; - clock-names = "timer", "pclk"; + clocks = <&cru PCLK_TIMER>, <&xin24m>; + clock-names = "pclk", "timer"; };
cru: clock-controller@110e0000 { @@ -305,8 +487,29 @@ rockchip,grf = <&grf>; #clock-cells = <1>; #reset-cells = <1>; - assigned-clocks = <&cru PLL_GPLL>; - assigned-clock-rates = <594000000>; + assigned-clocks = + <&cru PLL_GPLL>, <&cru ARMCLK>, + <&cru PLL_CPLL>, <&cru ACLK_PERI>, + <&cru HCLK_PERI>, <&cru PCLK_PERI>, + <&cru ACLK_CPU>, <&cru HCLK_CPU>, + <&cru PCLK_CPU>; + assigned-clock-rates = + <594000000>, <816000000>, + <500000000>, <150000000>, + <150000000>, <75000000>, + <150000000>, <150000000>, + <75000000>; + }; + + pdma: pdma@110f0000 { + compatible = "arm,pl330", "arm,primecell"; + reg = <0x110f0000 0x4000>; + interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>; + #dma-cells = <1>; + arm,pl330-periph-burst; + clocks = <&cru ACLK_DMAC>; + clock-names = "apb_pclk"; };
thermal-zones { @@ -338,12 +541,18 @@ map0 { trip = <&cpu_alert0>; cooling-device = - <&cpu0 THERMAL_NO_LIMIT 6>; + <&cpu0 THERMAL_NO_LIMIT 6>, + <&cpu1 THERMAL_NO_LIMIT 6>, + <&cpu2 THERMAL_NO_LIMIT 6>, + <&cpu3 THERMAL_NO_LIMIT 6>; }; map1 { trip = <&cpu_alert1>; cooling-device = - <&cpu0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + <&cpu0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&cpu1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&cpu2 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&cpu3 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; }; }; }; @@ -355,53 +564,220 @@ interrupts = <GIC_SPI 58 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cru SCLK_TSADC>, <&cru PCLK_TSADC>; clock-names = "tsadc", "apb_pclk"; + assigned-clocks = <&cru SCLK_TSADC>; + assigned-clock-rates = <32768>; resets = <&cru SRST_TSADC>; reset-names = "tsadc-apb"; pinctrl-names = "init", "default", "sleep"; - pinctrl-0 = <&otp_gpio>; + pinctrl-0 = <&otp_pin>; pinctrl-1 = <&otp_out>; - pinctrl-2 = <&otp_gpio>; - #thermal-sensor-cells = <0>; + pinctrl-2 = <&otp_pin>; + #thermal-sensor-cells = <1>; rockchip,hw-tshut-temp = <95000>; status = "disabled"; };
- sdmmc: dwmmc@30000000 { + hdmi_phy: hdmi-phy@12030000 { + compatible = "rockchip,rk3228-hdmi-phy"; + reg = <0x12030000 0x10000>; + clocks = <&cru PCLK_HDMI_PHY>, <&xin24m>, <&cru DCLK_HDMI_PHY>; + clock-names = "sysclk", "refoclk", "refpclk"; + #clock-cells = <0>; + clock-output-names = "hdmiphy_phy"; + #phy-cells = <0>; + status = "disabled"; + }; + + gpu: gpu@20000000 { + compatible = "rockchip,rk3228-mali", "arm,mali-400"; + reg = <0x20000000 0x10000>; + interrupts = <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "gp", + "gpmmu", + "pp0", + "ppmmu0", + "pp1", + "ppmmu1"; + clocks = <&cru ACLK_GPU>, <&cru ACLK_GPU>; + clock-names = "bus", "core"; + power-domains = <&power RK3228_PD_GPU>; + resets = <&cru SRST_GPU_A>; + status = "disabled"; + }; + + vpu: video-codec@20020000 { + compatible = "rockchip,rk3228-vpu", "rockchip,rk3399-vpu"; + reg = <0x20020000 0x800>; + interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "vepu", "vdpu"; + clocks = <&cru ACLK_VPU>, <&cru HCLK_VPU>; + clock-names = "aclk", "hclk"; + iommus = <&vpu_mmu>; + power-domains = <&power RK3228_PD_VPU>; + }; + + vpu_mmu: iommu@20020800 { + compatible = "rockchip,iommu"; + reg = <0x20020800 0x100>; + interrupts = <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru ACLK_VPU>, <&cru HCLK_VPU>; + clock-names = "aclk", "iface"; + power-domains = <&power RK3228_PD_VPU>; + #iommu-cells = <0>; + }; + + vdec: video-codec@20030000 { + compatible = "rockchip,rk3228-vdec", "rockchip,rk3399-vdec"; + reg = <0x20030000 0x480>; + interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru ACLK_RKVDEC>, <&cru HCLK_RKVDEC>, + <&cru SCLK_VDEC_CABAC>, <&cru SCLK_VDEC_CORE>; + clock-names = "axi", "ahb", "cabac", "core"; + assigned-clocks = <&cru SCLK_VDEC_CABAC>, <&cru SCLK_VDEC_CORE>; + assigned-clock-rates = <300000000>, <300000000>; + iommus = <&vdec_mmu>; + power-domains = <&power RK3228_PD_RKVDEC>; + }; + + vdec_mmu: iommu@20030480 { + compatible = "rockchip,iommu"; + reg = <0x20030480 0x40>, <0x200304c0 0x40>; + interrupts = <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru ACLK_RKVDEC>, <&cru HCLK_RKVDEC>; + clock-names = "aclk", "iface"; + power-domains = <&power RK3228_PD_RKVDEC>; + #iommu-cells = <0>; + }; + + vop: vop@20050000 { + compatible = "rockchip,rk3228-vop"; + reg = <0x20050000 0x1ffc>; + interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru ACLK_VOP>, <&cru DCLK_VOP>, <&cru HCLK_VOP>; + clock-names = "aclk_vop", "dclk_vop", "hclk_vop"; + resets = <&cru SRST_VOP_A>, <&cru SRST_VOP_H>, <&cru SRST_VOP_D>; + reset-names = "axi", "ahb", "dclk"; + iommus = <&vop_mmu>; + power-domains = <&power RK3228_PD_VOP>; + status = "disabled"; + + vop_out: port { + #address-cells = <1>; + #size-cells = <0>; + + vop_out_hdmi: endpoint@0 { + reg = <0>; + remote-endpoint = <&hdmi_in_vop>; + }; + }; + }; + + vop_mmu: iommu@20053f00 { + compatible = "rockchip,iommu"; + reg = <0x20053f00 0x100>; + interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru ACLK_VOP>, <&cru HCLK_VOP>; + clock-names = "aclk", "iface"; + power-domains = <&power RK3228_PD_VOP>; + #iommu-cells = <0>; + status = "disabled"; + }; + + rga: rga@20060000 { + compatible = "rockchip,rk3228-rga", "rockchip,rk3288-rga"; + reg = <0x20060000 0x1000>; + interrupts = <GIC_SPI 33 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru ACLK_RGA>, <&cru HCLK_RGA>, <&cru SCLK_RGA>; + clock-names = "aclk", "hclk", "sclk"; + power-domains = <&power RK3228_PD_VIO>; + resets = <&cru SRST_RGA>, <&cru SRST_RGA_A>, <&cru SRST_RGA_H>; + reset-names = "core", "axi", "ahb"; + }; + + iep_mmu: iommu@20070800 { + compatible = "rockchip,iommu"; + reg = <0x20070800 0x100>; + interrupts = <GIC_SPI 31 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru ACLK_IEP>, <&cru HCLK_IEP>; + clock-names = "aclk", "iface"; + power-domains = <&power RK3228_PD_VIO>; + #iommu-cells = <0>; + status = "disabled"; + }; + + hdmi: hdmi@200a0000 { + compatible = "rockchip,rk3228-dw-hdmi"; + reg = <0x200a0000 0x20000>; + reg-io-width = <4>; + interrupts = <GIC_SPI 35 IRQ_TYPE_LEVEL_HIGH>; + assigned-clocks = <&cru SCLK_HDMI_PHY>; + assigned-clock-parents = <&hdmi_phy>; + clocks = <&cru SCLK_HDMI_HDCP>, <&cru PCLK_HDMI_CTRL>, <&cru SCLK_HDMI_CEC>; + clock-names = "isfr", "iahb", "cec"; + pinctrl-names = "default"; + pinctrl-0 = <&hdmii2c_xfer &hdmi_hpd &hdmi_cec>; + resets = <&cru SRST_HDMI_P>; + reset-names = "hdmi"; + phys = <&hdmi_phy>; + phy-names = "hdmi"; + rockchip,grf = <&grf>; + status = "disabled"; + + ports { + hdmi_in: port { + #address-cells = <1>; + #size-cells = <0>; + hdmi_in_vop: endpoint@0 { + reg = <0>; + remote-endpoint = <&vop_out_hdmi>; + }; + }; + }; + }; + + sdmmc: mmc@30000000 { compatible = "rockchip,rk3228-dw-mshc", "rockchip,rk3288-dw-mshc"; reg = <0x30000000 0x4000>; interrupts = <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cru HCLK_SDMMC>, <&cru SCLK_SDMMC>, <&cru SCLK_SDMMC_DRV>, <&cru SCLK_SDMMC_SAMPLE>; - clock-names = "biu", "ciu", "ciu_drv", "ciu_sample"; + clock-names = "biu", "ciu", "ciu-drive", "ciu-sample"; fifo-depth = <0x100>; pinctrl-names = "default"; pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_bus4>; status = "disabled"; };
- sdio: dwmmc@30010000 { + sdio: mmc@30010000 { compatible = "rockchip,rk3228-dw-mshc", "rockchip,rk3288-dw-mshc"; reg = <0x30010000 0x4000>; interrupts = <GIC_SPI 13 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cru HCLK_SDIO>, <&cru SCLK_SDIO>, <&cru SCLK_SDIO_DRV>, <&cru SCLK_SDIO_SAMPLE>; - clock-names = "biu", "ciu", "ciu_drv", "ciu_sample"; + clock-names = "biu", "ciu", "ciu-drive", "ciu-sample"; fifo-depth = <0x100>; pinctrl-names = "default"; pinctrl-0 = <&sdio_clk &sdio_cmd &sdio_bus4>; status = "disabled"; };
- emmc: dwmmc@30020000 { - compatible = "rockchip,rk3288-dw-mshc"; + emmc: mmc@30020000 { + compatible = "rockchip,rk3228-dw-mshc", "rockchip,rk3288-dw-mshc"; reg = <0x30020000 0x4000>; interrupts = <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH>; + clock-frequency = <37500000>; + max-frequency = <37500000>; clocks = <&cru HCLK_EMMC>, <&cru SCLK_EMMC>, <&cru SCLK_EMMC_DRV>, <&cru SCLK_EMMC_SAMPLE>; - clock-names = "biu", "ciu", "ciu_drv", "ciu_sample"; + clock-names = "biu", "ciu", "ciu-drive", "ciu-sample"; bus-width = <8>; - default-sample-phase = <158>; - num-slots = <1>; + rockchip,default-sample-phase = <158>; fifo-depth = <0x100>; pinctrl-names = "default"; pinctrl-0 = <&emmc_clk &emmc_cmd &emmc_bus8>; @@ -410,13 +786,79 @@ status = "disabled"; };
- usb20_otg: usb@30040000 { - compatible = "rockchip,rk3229-usb", "rockchip,rk3288-usb", + usb_otg: usb@30040000 { + compatible = "rockchip,rk3228-usb", "rockchip,rk3066-usb", "snps,dwc2"; reg = <0x30040000 0x40000>; interrupts = <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH>; - hnp-srp-disable; + clocks = <&cru HCLK_OTG>; + clock-names = "otg"; dr_mode = "otg"; + g-np-tx-fifo-size = <16>; + g-rx-fifo-size = <280>; + g-tx-fifo-size = <256 128 128 64 32 16>; + phys = <&u2phy0_otg>; + phy-names = "usb2-phy"; + status = "disabled"; + }; + + usb_host0_ehci: usb@30080000 { + compatible = "generic-ehci"; + reg = <0x30080000 0x20000>; + interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru HCLK_HOST0>, <&u2phy0>; + phys = <&u2phy0_host>; + phy-names = "usb"; + status = "disabled"; + }; + + usb_host0_ohci: usb@300a0000 { + compatible = "generic-ohci"; + reg = <0x300a0000 0x20000>; + interrupts = <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru HCLK_HOST0>, <&u2phy0>; + phys = <&u2phy0_host>; + phy-names = "usb"; + status = "disabled"; + }; + + usb_host1_ehci: usb@300c0000 { + compatible = "generic-ehci"; + reg = <0x300c0000 0x20000>; + interrupts = <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru HCLK_HOST1>, <&u2phy1>; + phys = <&u2phy1_otg>; + phy-names = "usb"; + status = "disabled"; + }; + + usb_host1_ohci: usb@300e0000 { + compatible = "generic-ohci"; + reg = <0x300e0000 0x20000>; + interrupts = <GIC_SPI 20 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru HCLK_HOST1>, <&u2phy1>; + phys = <&u2phy1_otg>; + phy-names = "usb"; + status = "disabled"; + }; + + usb_host2_ehci: usb@30100000 { + compatible = "generic-ehci"; + reg = <0x30100000 0x20000>; + interrupts = <GIC_SPI 66 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru HCLK_HOST2>, <&u2phy1>; + phys = <&u2phy1_host>; + phy-names = "usb"; + status = "disabled"; + }; + + usb_host2_ohci: usb@30120000 { + compatible = "generic-ohci"; + reg = <0x30120000 0x20000>; + interrupts = <GIC_SPI 67 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru HCLK_HOST2>, <&u2phy1>; + phys = <&u2phy1_host>; + phy-names = "usb"; status = "disabled"; };
@@ -439,6 +881,51 @@ status = "disabled"; };
+ qos_iep: qos@31030080 { + compatible = "rockchip,rk3228-qos", "syscon"; + reg = <0x31030080 0x20>; + }; + + qos_rga_w: qos@31030100 { + compatible = "rockchip,rk3228-qos", "syscon"; + reg = <0x31030100 0x20>; + }; + + qos_hdcp: qos@31030180 { + compatible = "rockchip,rk3228-qos", "syscon"; + reg = <0x31030180 0x20>; + }; + + qos_rga_r: qos@31030200 { + compatible = "rockchip,rk3228-qos", "syscon"; + reg = <0x31030200 0x20>; + }; + + qos_vpu: qos@31040000 { + compatible = "rockchip,rk3228-qos", "syscon"; + reg = <0x31040000 0x20>; + }; + + qos_gpu: qos@31050000 { + compatible = "rockchip,rk3228-qos", "syscon"; + reg = <0x31050000 0x20>; + }; + + qos_vop: qos@31060000 { + compatible = "rockchip,rk3228-qos", "syscon"; + reg = <0x31060000 0x20>; + }; + + qos_rkvdec_r: qos@31070000 { + compatible = "rockchip,rk3228-qos", "syscon"; + reg = <0x31070000 0x20>; + }; + + qos_rkvdec_w: qos@31070080 { + compatible = "rockchip,rk3228-qos", "syscon"; + reg = <0x31070080 0x20>; + }; + gic: interrupt-controller@32010000 { compatible = "arm,gic-400"; interrupt-controller; @@ -459,7 +946,7 @@ #size-cells = <1>; ranges;
- gpio0: gpio0@11110000 { + gpio0: gpio@11110000 { compatible = "rockchip,gpio-bank"; reg = <0x11110000 0x100>; interrupts = <GIC_SPI 51 IRQ_TYPE_LEVEL_HIGH>; @@ -472,7 +959,7 @@ #interrupt-cells = <2>; };
- gpio1: gpio1@11120000 { + gpio1: gpio@11120000 { compatible = "rockchip,gpio-bank"; reg = <0x11120000 0x100>; interrupts = <GIC_SPI 52 IRQ_TYPE_LEVEL_HIGH>; @@ -485,7 +972,7 @@ #interrupt-cells = <2>; };
- gpio2: gpio2@11130000 { + gpio2: gpio@11130000 { compatible = "rockchip,gpio-bank"; reg = <0x11130000 0x100>; interrupts = <GIC_SPI 53 IRQ_TYPE_LEVEL_HIGH>; @@ -498,7 +985,7 @@ #interrupt-cells = <2>; };
- gpio3: gpio3@11140000 { + gpio3: gpio@11140000 { compatible = "rockchip,gpio-bank"; reg = <0x11140000 0x100>; interrupts = <GIC_SPI 54 IRQ_TYPE_LEVEL_HIGH>; @@ -529,222 +1016,277 @@
sdmmc { sdmmc_clk: sdmmc-clk { - rockchip,pins = <1 16 RK_FUNC_1 &pcfg_pull_none_drv_12ma>; + rockchip,pins = <1 RK_PC0 1 &pcfg_pull_none_drv_12ma>; };
sdmmc_cmd: sdmmc-cmd { - rockchip,pins = <1 15 RK_FUNC_1 &pcfg_pull_none_drv_12ma>; + rockchip,pins = <1 RK_PB7 1 &pcfg_pull_none_drv_12ma>; };
sdmmc_bus4: sdmmc-bus4 { - rockchip,pins = <1 18 RK_FUNC_1 &pcfg_pull_none_drv_12ma>, - <1 19 RK_FUNC_1 &pcfg_pull_none_drv_12ma>, - <1 20 RK_FUNC_1 &pcfg_pull_none_drv_12ma>, - <1 21 RK_FUNC_1 &pcfg_pull_none_drv_12ma>; + rockchip,pins = <1 RK_PC2 1 &pcfg_pull_none_drv_12ma>, + <1 RK_PC3 1 &pcfg_pull_none_drv_12ma>, + <1 RK_PC4 1 &pcfg_pull_none_drv_12ma>, + <1 RK_PC5 1 &pcfg_pull_none_drv_12ma>; }; };
sdio { sdio_clk: sdio-clk { - rockchip,pins = <3 0 RK_FUNC_1 &pcfg_pull_none_drv_12ma>; + rockchip,pins = <3 RK_PA0 1 &pcfg_pull_none_drv_12ma>; };
sdio_cmd: sdio-cmd { - rockchip,pins = <3 1 RK_FUNC_1 &pcfg_pull_none_drv_12ma>; + rockchip,pins = <3 RK_PA1 1 &pcfg_pull_none_drv_12ma>; };
sdio_bus4: sdio-bus4 { - rockchip,pins = <3 2 RK_FUNC_1 &pcfg_pull_none_drv_12ma>, - <3 3 RK_FUNC_1 &pcfg_pull_none_drv_12ma>, - <3 4 RK_FUNC_1 &pcfg_pull_none_drv_12ma>, - <3 5 RK_FUNC_1 &pcfg_pull_none_drv_12ma>; + rockchip,pins = <3 RK_PA2 1 &pcfg_pull_none_drv_12ma>, + <3 RK_PA3 1 &pcfg_pull_none_drv_12ma>, + <3 RK_PA4 1 &pcfg_pull_none_drv_12ma>, + <3 RK_PA5 1 &pcfg_pull_none_drv_12ma>; }; };
emmc { emmc_clk: emmc-clk { - rockchip,pins = <2 RK_PA7 RK_FUNC_2 &pcfg_pull_none>; + rockchip,pins = <2 RK_PA7 2 &pcfg_pull_none>; };
emmc_cmd: emmc-cmd { - rockchip,pins = <1 RK_PC6 RK_FUNC_2 &pcfg_pull_none>; + rockchip,pins = <1 RK_PC6 2 &pcfg_pull_none>; };
emmc_bus8: emmc-bus8 { - rockchip,pins = <1 RK_PD0 RK_FUNC_2 &pcfg_pull_none>, - <1 RK_PD1 RK_FUNC_2 &pcfg_pull_none>, - <1 RK_PD2 RK_FUNC_2 &pcfg_pull_none>, - <1 RK_PD3 RK_FUNC_2 &pcfg_pull_none>, - <1 RK_PD4 RK_FUNC_2 &pcfg_pull_none>, - <1 RK_PD5 RK_FUNC_2 &pcfg_pull_none>, - <1 RK_PD6 RK_FUNC_2 &pcfg_pull_none>, - <1 RK_PD7 RK_FUNC_2 &pcfg_pull_none>; + rockchip,pins = <1 RK_PD0 2 &pcfg_pull_none>, + <1 RK_PD1 2 &pcfg_pull_none>, + <1 RK_PD2 2 &pcfg_pull_none>, + <1 RK_PD3 2 &pcfg_pull_none>, + <1 RK_PD4 2 &pcfg_pull_none>, + <1 RK_PD5 2 &pcfg_pull_none>, + <1 RK_PD6 2 &pcfg_pull_none>, + <1 RK_PD7 2 &pcfg_pull_none>; }; };
gmac { rgmii_pins: rgmii-pins { - rockchip,pins = <2 RK_PB6 RK_FUNC_1 &pcfg_pull_none>, - <2 RK_PB4 RK_FUNC_1 &pcfg_pull_none>, - <2 RK_PD1 RK_FUNC_1 &pcfg_pull_none>, - <2 RK_PC3 RK_FUNC_1 &pcfg_pull_none_drv_12ma>, - <2 RK_PC2 RK_FUNC_1 &pcfg_pull_none_drv_12ma>, - <2 RK_PC6 RK_FUNC_1 &pcfg_pull_none_drv_12ma>, - <2 RK_PC7 RK_FUNC_1 &pcfg_pull_none_drv_12ma>, - <2 RK_PB1 RK_FUNC_1 &pcfg_pull_none_drv_12ma>, - <2 RK_PB5 RK_FUNC_1 &pcfg_pull_none_drv_12ma>, - <2 RK_PC1 RK_FUNC_1 &pcfg_pull_none>, - <2 RK_PC0 RK_FUNC_1 &pcfg_pull_none>, - <2 RK_PC5 RK_FUNC_2 &pcfg_pull_none>, - <2 RK_PC4 RK_FUNC_2 &pcfg_pull_none>, - <2 RK_PB3 RK_FUNC_1 &pcfg_pull_none>, - <2 RK_PB0 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <2 RK_PB6 1 &pcfg_pull_none>, + <2 RK_PB4 1 &pcfg_pull_none>, + <2 RK_PD1 1 &pcfg_pull_none>, + <2 RK_PC3 1 &pcfg_pull_none_drv_12ma>, + <2 RK_PC2 1 &pcfg_pull_none_drv_12ma>, + <2 RK_PC6 1 &pcfg_pull_none_drv_12ma>, + <2 RK_PC7 1 &pcfg_pull_none_drv_12ma>, + <2 RK_PB1 1 &pcfg_pull_none_drv_12ma>, + <2 RK_PB5 1 &pcfg_pull_none_drv_12ma>, + <2 RK_PC1 1 &pcfg_pull_none>, + <2 RK_PC0 1 &pcfg_pull_none>, + <2 RK_PC5 2 &pcfg_pull_none>, + <2 RK_PC4 2 &pcfg_pull_none>, + <2 RK_PB3 1 &pcfg_pull_none>, + <2 RK_PB0 1 &pcfg_pull_none>; };
rmii_pins: rmii-pins { - rockchip,pins = <2 RK_PB6 RK_FUNC_1 &pcfg_pull_none>, - <2 RK_PB4 RK_FUNC_1 &pcfg_pull_none>, - <2 RK_PD1 RK_FUNC_1 &pcfg_pull_none>, - <2 RK_PC3 RK_FUNC_1 &pcfg_pull_none_drv_12ma>, - <2 RK_PC2 RK_FUNC_1 &pcfg_pull_none_drv_12ma>, - <2 RK_PB5 RK_FUNC_1 &pcfg_pull_none_drv_12ma>, - <2 RK_PC1 RK_FUNC_1 &pcfg_pull_none>, - <2 RK_PC0 RK_FUNC_1 &pcfg_pull_none>, - <2 RK_PB0 RK_FUNC_1 &pcfg_pull_none>, - <2 RK_PB7 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <2 RK_PB6 1 &pcfg_pull_none>, + <2 RK_PB4 1 &pcfg_pull_none>, + <2 RK_PD1 1 &pcfg_pull_none>, + <2 RK_PC3 1 &pcfg_pull_none_drv_12ma>, + <2 RK_PC2 1 &pcfg_pull_none_drv_12ma>, + <2 RK_PB5 1 &pcfg_pull_none_drv_12ma>, + <2 RK_PC1 1 &pcfg_pull_none>, + <2 RK_PC0 1 &pcfg_pull_none>, + <2 RK_PB0 1 &pcfg_pull_none>, + <2 RK_PB7 1 &pcfg_pull_none>; };
phy_pins: phy-pins { - rockchip,pins = <2 RK_PB6 RK_FUNC_2 &pcfg_pull_none>, - <2 RK_PB0 RK_FUNC_2 &pcfg_pull_none>; + rockchip,pins = <2 RK_PB6 2 &pcfg_pull_none>, + <2 RK_PB0 2 &pcfg_pull_none>; + }; + }; + + hdmi { + hdmi_hpd: hdmi-hpd { + rockchip,pins = <0 RK_PB7 1 &pcfg_pull_down>; + }; + + hdmii2c_xfer: hdmii2c-xfer { + rockchip,pins = <0 RK_PA6 2 &pcfg_pull_none>, + <0 RK_PA7 2 &pcfg_pull_none>; + }; + + hdmi_cec: hdmi-cec { + rockchip,pins = <0 RK_PC4 1 &pcfg_pull_none>; }; };
i2c0 { i2c0_xfer: i2c0-xfer { - rockchip,pins = <0 RK_PA0 RK_FUNC_1 &pcfg_pull_none>, - <0 RK_PA1 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <0 RK_PA0 1 &pcfg_pull_none>, + <0 RK_PA1 1 &pcfg_pull_none>; }; };
i2c1 { i2c1_xfer: i2c1-xfer { - rockchip,pins = <0 RK_PA2 RK_FUNC_1 &pcfg_pull_none>, - <0 RK_PA3 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <0 RK_PA2 1 &pcfg_pull_none>, + <0 RK_PA3 1 &pcfg_pull_none>; }; };
i2c2 { i2c2_xfer: i2c2-xfer { - rockchip,pins = <2 RK_PC4 RK_FUNC_1 &pcfg_pull_none>, - <2 RK_PC5 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <2 RK_PC4 1 &pcfg_pull_none>, + <2 RK_PC5 1 &pcfg_pull_none>; }; };
i2c3 { i2c3_xfer: i2c3-xfer { - rockchip,pins = <0 RK_PA6 RK_FUNC_1 &pcfg_pull_none>, - <0 RK_PA7 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <0 RK_PA6 1 &pcfg_pull_none>, + <0 RK_PA7 1 &pcfg_pull_none>; + }; + }; + + spi0 { + spi0_clk: spi0-clk { + rockchip,pins = <0 RK_PB1 2 &pcfg_pull_up>; + }; + spi0_cs0: spi0-cs0 { + rockchip,pins = <0 RK_PB6 2 &pcfg_pull_up>; + }; + spi0_tx: spi0-tx { + rockchip,pins = <0 RK_PB3 2 &pcfg_pull_up>; + }; + spi0_rx: spi0-rx { + rockchip,pins = <0 RK_PB5 2 &pcfg_pull_up>; + }; + spi0_cs1: spi0-cs1 { + rockchip,pins = <1 RK_PB4 1 &pcfg_pull_up>; + }; + }; + + spi1 { + spi1_clk: spi1-clk { + rockchip,pins = <0 RK_PC7 2 &pcfg_pull_up>; + }; + spi1_cs0: spi1-cs0 { + rockchip,pins = <2 RK_PA2 2 &pcfg_pull_up>; + }; + spi1_rx: spi1-rx { + rockchip,pins = <2 RK_PA0 2 &pcfg_pull_up>; + }; + spi1_tx: spi1-tx { + rockchip,pins = <2 RK_PA1 2 &pcfg_pull_up>; + }; + spi1_cs1: spi1-cs1 { + rockchip,pins = <2 RK_PA3 2 &pcfg_pull_up>; }; };
i2s1 { i2s1_bus: i2s1-bus { - rockchip,pins = <0 RK_PB0 RK_FUNC_1 &pcfg_pull_none>, - <0 RK_PB1 RK_FUNC_1 &pcfg_pull_none>, - <0 RK_PB3 RK_FUNC_1 &pcfg_pull_none>, - <0 RK_PB4 RK_FUNC_1 &pcfg_pull_none>, - <0 RK_PB5 RK_FUNC_1 &pcfg_pull_none>, - <0 RK_PB6 RK_FUNC_1 &pcfg_pull_none>, - <1 RK_PA2 RK_FUNC_1 &pcfg_pull_none>, - <1 RK_PA4 RK_FUNC_1 &pcfg_pull_none>, - <1 RK_PA5 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <0 RK_PB0 1 &pcfg_pull_none>, + <0 RK_PB1 1 &pcfg_pull_none>, + <0 RK_PB3 1 &pcfg_pull_none>, + <0 RK_PB4 1 &pcfg_pull_none>, + <0 RK_PB5 1 &pcfg_pull_none>, + <0 RK_PB6 1 &pcfg_pull_none>, + <1 RK_PA2 2 &pcfg_pull_none>, + <1 RK_PA4 2 &pcfg_pull_none>, + <1 RK_PA5 2 &pcfg_pull_none>; }; };
pwm0 { pwm0_pin: pwm0-pin { - rockchip,pins = <3 RK_PC5 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <3 RK_PC5 1 &pcfg_pull_none>; }; };
pwm1 { pwm1_pin: pwm1-pin { - rockchip,pins = <0 RK_PD6 RK_FUNC_2 &pcfg_pull_none>; + rockchip,pins = <0 RK_PD6 2 &pcfg_pull_none>; }; };
pwm2 { pwm2_pin: pwm2-pin { - rockchip,pins = <1 RK_PB4 RK_FUNC_2 &pcfg_pull_none>; + rockchip,pins = <1 RK_PB4 2 &pcfg_pull_none>; }; };
pwm3 { pwm3_pin: pwm3-pin { - rockchip,pins = <1 RK_PB3 RK_FUNC_2 &pcfg_pull_none>; + rockchip,pins = <1 RK_PB3 2 &pcfg_pull_none>; + }; + }; + + spdif { + spdif_tx: spdif-tx { + rockchip,pins = <3 RK_PD7 2 &pcfg_pull_none>; }; };
tsadc { - otp_gpio: otp-gpio { + otp_pin: otp-pin { rockchip,pins = <0 RK_PD0 RK_FUNC_GPIO &pcfg_pull_none>; };
otp_out: otp-out { - rockchip,pins = <0 RK_PD0 RK_FUNC_2 &pcfg_pull_none>; + rockchip,pins = <0 RK_PD0 2 &pcfg_pull_none>; }; };
uart0 { uart0_xfer: uart0-xfer { - rockchip,pins = <2 RK_PD2 RK_FUNC_1 &pcfg_pull_none>, - <2 RK_PD3 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <2 RK_PD2 1 &pcfg_pull_none>, + <2 RK_PD3 1 &pcfg_pull_none>; };
uart0_cts: uart0-cts { - rockchip,pins = <2 RK_PD5 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <2 RK_PD5 1 &pcfg_pull_none>; };
uart0_rts: uart0-rts { - rockchip,pins = <0 RK_PC1 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <0 RK_PC1 1 &pcfg_pull_none>; }; };
uart1 { uart1_xfer: uart1-xfer { - rockchip,pins = <1 RK_PB1 RK_FUNC_1 &pcfg_pull_none>, - <1 RK_PB2 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <1 RK_PB1 1 &pcfg_pull_none>, + <1 RK_PB2 1 &pcfg_pull_none>; };
uart1_cts: uart1-cts { - rockchip,pins = <1 RK_PB0 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <1 RK_PB0 1 &pcfg_pull_none>; };
uart1_rts: uart1-rts { - rockchip,pins = <1 RK_PB3 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <1 RK_PB3 1 &pcfg_pull_none>; }; };
uart2 { uart2_xfer: uart2-xfer { - rockchip,pins = <1 RK_PC2 RK_FUNC_2 &pcfg_pull_up>, - <1 RK_PC3 RK_FUNC_2 &pcfg_pull_none>; + rockchip,pins = <1 RK_PC2 2 &pcfg_pull_up>, + <1 RK_PC3 2 &pcfg_pull_none>; };
- uart2_cts: uart2-cts { - rockchip,pins = <0 RK_PD1 RK_FUNC_1 &pcfg_pull_none>; + uart21_xfer: uart21-xfer { + rockchip,pins = <1 RK_PB2 2 &pcfg_pull_up>, + <1 RK_PB1 2 &pcfg_pull_none>; };
- uart2_rts: uart2-rts { - rockchip,pins = <0 RK_PD0 RK_FUNC_1 &pcfg_pull_none>; + uart2_cts: uart2-cts { + rockchip,pins = <0 RK_PD1 1 &pcfg_pull_none>; }; - };
- uart2-1 { - uart21_xfer: uart21-xfer { - rockchip,pins = <1 10 RK_FUNC_2 &pcfg_pull_up>, - <1 9 RK_FUNC_2 &pcfg_pull_none>; + uart2_rts: uart2-rts { + rockchip,pins = <0 RK_PD0 1 &pcfg_pull_none>; }; }; };
Hi Johan,
- Copyright (c) 2017 Fuzhou Rockchip Electronics Co., Ltd.
mmc0 = &emmc;
mmc1 = &sdmmc;
I think this part will need to move to -u-boot.dtsi for U-Boot will use this to decide the boot order,
and U-Boot use emmc as mmc0 and sdmmc as mmc1 before kernel decide to add alias for mmc module.
Thanks,
- Kever
spi0 = &spi0;
cpus {
/* KHz uV */
816000 1000000
cpu1: cpu@f01 {
cpu2: cpu@f02 {
cpu3: cpu@f03 {
}; };enable-method = "psci";
- amba {
#size-cells = <1>;
ranges;
- cpu0_opp_table: opp-table-0 {
opp-shared;
#dma-cells = <1>;
opp-408000000 {
opp-suspend;
opp-600000000 {
opp-816000000 {
opp-1008000000 {
opp-1200000000 {
}; };opp-microvolt = <1275000>;
- psci {
method = "smc";
- timer { compatible = "arm,armv7-timer"; arm,cpu-registers-not-fw-configured;
- display_subsystem: display-subsystem {
ports = <&vop_out>;
- i2s1: i2s1@100b0000 { compatible = "rockchip,rk3228-i2s", "rockchip,rk3066-i2s"; reg = <0x100b0000 0x4000>; interrupts = <GIC_SPI 27 IRQ_TYPE_LEVEL_HIGH>;
clock-names = "i2s_clk", "i2s_hclk"; clocks = <&cru SCLK_I2S1>, <&cru HCLK_I2S1_8CH>; dmas = <&pdma 14>, <&pdma 15>;#size-cells = <0>;
clock-names = "i2s_clk", "i2s_hclk"; clocks = <&cru SCLK_I2S0>, <&cru HCLK_I2S0_8CH>; dmas = <&pdma 11>, <&pdma 12>;#size-cells = <0>;
- spdif: spdif@100d0000 {
dmas = <&pdma 10>;
dma-names = "tx";
- i2s2: i2s2@100e0000 { compatible = "rockchip,rk3228-i2s", "rockchip,rk3066-i2s"; reg = <0x100e0000 0x4000>; interrupts = <GIC_SPI 28 IRQ_TYPE_LEVEL_HIGH>;
clock-names = "i2s_clk", "i2s_hclk"; clocks = <&cru SCLK_I2S2>, <&cru HCLK_I2S2_2CH>; dmas = <&pdma 0>, <&pdma 1>;#size-cells = <0>;
#size-cells = <1>;
#size-cells = <0>;
<&cru SCLK_HDCP>,
<&cru ACLK_IEP>,
<&cru HCLK_IEP>,
<&cru ACLK_RGA>,
<&cru HCLK_RGA>,
<&cru SCLK_RGA>;
<&qos_iep>,
<&qos_rga_r>,
<&qos_rga_w>;
<&cru DCLK_VOP>,
<&cru HCLK_VOP>;
<&cru HCLK_VPU>;
<&cru HCLK_RKVDEC>,
<&qos_rkvdec_w>;
#clock-cells = <0>;
"linestate";
#phy-cells = <0>;
#phy-cells = <0>;
#clock-cells = <0>;
#phy-cells = <0>;
#phy-cells = <0>;
#size-cells = <1>;
/* Data cells */
efuse_id: id@7 {
reg = <0x7 0x10>;
reg = <0x17 0x1>;
- spi0: spi@11090000 {
#size-cells = <0>;
- wdt: watchdog@110a0000 {
- pwm0: pwm@110b0000 { compatible = "rockchip,rk3288-pwm"; reg = <0x110b0000 0x10>; #pwm-cells = <3>; clocks = <&cru PCLK_PWM>;
pinctrl-names = "default"; pinctrl-0 = <&pwm0_pin>; status = "disabled";clock-names = "pwm";
pinctrl-names = "default"; pinctrl-0 = <&pwm1_pin>; status = "disabled";clock-names = "pwm";
pinctrl-names = "default"; pinctrl-0 = <&pwm2_pin>; status = "disabled";clock-names = "pwm";
reg = <0x110c0000 0x20>; interrupts = <GIC_SPI 43 IRQ_TYPE_LEVEL_HIGH>;compatible = "rockchip,rk3228-timer", "rockchip,rk3288-timer";
assigned-clocks =
<&cru PCLK_CPU>;
<75000000>;
#dma-cells = <1>;
thermal-zones {
};<&cpu3 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; }; };
resets = <&cru SRST_TSADC>; reset-names = "tsadc-apb"; pinctrl-names = "init", "default", "sleep";assigned-clock-rates = <32768>;
pinctrl-1 = <&otp_out>;pinctrl-0 = <&otp_pin>;
rockchip,hw-tshut-temp = <95000>; status = "disabled"; };#thermal-sensor-cells = <1>;
- hdmi_phy: hdmi-phy@12030000 {
#clock-cells = <0>;
#phy-cells = <0>;
- gpu: gpu@20000000 {
"gpmmu",
"pp0",
"ppmmu0",
"pp1",
"ppmmu1";
- vpu: video-codec@20020000 {
- vpu_mmu: iommu@20020800 {
#iommu-cells = <0>;
- vdec: video-codec@20030000 {
- vdec_mmu: iommu@20030480 {
#iommu-cells = <0>;
- vop: vop@20050000 {
vop_out: port {
#size-cells = <0>;
reg = <0>;
- vop_mmu: iommu@20053f00 {
#iommu-cells = <0>;
- rga: rga@20060000 {
- iep_mmu: iommu@20070800 {
#iommu-cells = <0>;
- hdmi: hdmi@200a0000 {
reg-io-width = <4>;
phys = <&hdmi_phy>;
phy-names = "hdmi";
ports {
hdmi_in: port {
#size-cells = <0>;
reg = <0>;
- sdmmc: mmc@30000000 { compatible = "rockchip,rk3228-dw-mshc", "rockchip,rk3288-dw-mshc"; reg = <0x30000000 0x4000>; interrupts = <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cru HCLK_SDMMC>, <&cru SCLK_SDMMC>, <&cru SCLK_SDMMC_DRV>, <&cru SCLK_SDMMC_SAMPLE>;
fifo-depth = <0x100>; pinctrl-names = "default"; pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_bus4>; status = "disabled"; };clock-names = "biu", "ciu", "ciu-drive", "ciu-sample";
- sdio: mmc@30010000 { compatible = "rockchip,rk3228-dw-mshc", "rockchip,rk3288-dw-mshc"; reg = <0x30010000 0x4000>; interrupts = <GIC_SPI 13 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cru HCLK_SDIO>, <&cru SCLK_SDIO>, <&cru SCLK_SDIO_DRV>, <&cru SCLK_SDIO_SAMPLE>;
fifo-depth = <0x100>; pinctrl-names = "default"; pinctrl-0 = <&sdio_clk &sdio_cmd &sdio_bus4>; status = "disabled"; };clock-names = "biu", "ciu", "ciu-drive", "ciu-sample";
- emmc: mmc@30020000 {
reg = <0x30020000 0x4000>; interrupts = <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH>;compatible = "rockchip,rk3228-dw-mshc", "rockchip,rk3288-dw-mshc";
clocks = <&cru HCLK_EMMC>, <&cru SCLK_EMMC>, <&cru SCLK_EMMC_DRV>, <&cru SCLK_EMMC_SAMPLE>;max-frequency = <37500000>;
bus-width = <8>;clock-names = "biu", "ciu", "ciu-drive", "ciu-sample";
num-slots = <1>;
fifo-depth = <0x100>; pinctrl-names = "default"; pinctrl-0 = <&emmc_clk &emmc_cmd &emmc_bus8>;rockchip,default-sample-phase = <158>;
- usb_otg: usb@30040000 {
reg = <0x30040000 0x40000>; interrupts = <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH>;compatible = "rockchip,rk3228-usb", "rockchip,rk3066-usb", "snps,dwc2";
hnp-srp-disable;
dr_mode = "otg";clock-names = "otg";
- usb_host0_ehci: usb@30080000 {
phy-names = "usb";
- usb_host0_ohci: usb@300a0000 {
phy-names = "usb";
- usb_host1_ehci: usb@300c0000 {
phy-names = "usb";
- usb_host1_ohci: usb@300e0000 {
phy-names = "usb";
- usb_host2_ehci: usb@30100000 {
phy-names = "usb";
- usb_host2_ohci: usb@30120000 {
status = "disabled"; };phy-names = "usb";
- qos_iep: qos@31030080 {
- qos_rga_w: qos@31030100 {
- qos_hdcp: qos@31030180 {
- qos_rga_r: qos@31030200 {
- qos_vpu: qos@31040000 {
- qos_gpu: qos@31050000 {
- qos_vop: qos@31060000 {
- qos_rkvdec_r: qos@31070000 {
- qos_rkvdec_w: qos@31070080 {
- gic: interrupt-controller@32010000 { compatible = "arm,gic-400"; interrupt-controller;
rockchip,pins = <1 RK_PC0 1 &pcfg_pull_none_drv_12ma>; }; sdmmc_cmd: sdmmc-cmd {
rockchip,pins = <1 RK_PB7 1 &pcfg_pull_none_drv_12ma>; }; sdmmc_bus4: sdmmc-bus4 {
rockchip,pins = <3 RK_PA0 1 &pcfg_pull_none_drv_12ma>; }; sdio_cmd: sdio-cmd {
rockchip,pins = <3 RK_PA1 1 &pcfg_pull_none_drv_12ma>; }; sdio_bus4: sdio-bus4 {
rockchip,pins = <2 RK_PA7 2 &pcfg_pull_none>; }; emmc_cmd: emmc-cmd {
rockchip,pins = <1 RK_PC6 2 &pcfg_pull_none>; }; emmc_bus8: emmc-bus8 {
<2 RK_PB0 1 &pcfg_pull_none>; }; rmii_pins: rmii-pins {
<2 RK_PB7 1 &pcfg_pull_none>; }; phy_pins: phy-pins {
hdmi {
spi0 {
spi0_tx: spi0-tx {
spi0_rx: spi0-rx {
spi1 {
spi1_rx: spi1-rx {
spi1_tx: spi1-tx {
spdif {
tsadc {
otp_pin: otp-pin { rockchip,pins = <0 RK_PD0 RK_FUNC_GPIO &pcfg_pull_none>; }; otp_out: otp-out {
<2 RK_PD3 1 &pcfg_pull_none>; }; uart0_cts: uart0-cts {
rockchip,pins = <2 RK_PD5 1 &pcfg_pull_none>; }; uart0_rts: uart0-rts {
<1 RK_PB2 1 &pcfg_pull_none>; }; uart1_cts: uart1-cts {
rockchip,pins = <1 RK_PB0 1 &pcfg_pull_none>; }; uart1_rts: uart1-rts {
uart2-1 {
}; };rockchip,pins = <0 RK_PD0 1 &pcfg_pull_none>; };
Sync rk3229-evb.dts from Linux version 5.17.
Signed-off-by: Johan Jonker jbx6244@gmail.com --- arch/arm/dts/rk3229-evb.dts | 212 +++++++++++++++++++++++++++++++++--- arch/arm/dts/rk3229.dtsi | 52 +++++++++ 2 files changed, 249 insertions(+), 15 deletions(-) create mode 100644 arch/arm/dts/rk3229.dtsi
diff --git a/arch/arm/dts/rk3229-evb.dts b/arch/arm/dts/rk3229-evb.dts index d2681d1a..797476e8 100644 --- a/arch/arm/dts/rk3229-evb.dts +++ b/arch/arm/dts/rk3229-evb.dts @@ -1,21 +1,32 @@ -// SPDX-License-Identifier: GPL-2.0+ OR X11 -/* - * (C) Copyright 2017 Rockchip Electronics Co., Ltd. - */ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT)
/dts-v1/;
-#include "rk322x.dtsi" +#include <dt-bindings/input/input.h> +#include "rk3229.dtsi"
/ { model = "Rockchip RK3229 Evaluation board"; compatible = "rockchip,rk3229-evb", "rockchip,rk3229";
+ aliases { + mmc0 = &emmc; + }; + memory@60000000 { device_type = "memory"; reg = <0x60000000 0x40000000>; };
+ dc_12v: dc-12v-regulator { + compatible = "regulator-fixed"; + regulator-name = "dc_12v"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <12000000>; + regulator-max-microvolt = <12000000>; + }; + ext_gmac: ext_gmac { compatible = "fixed-clock"; clock-frequency = <125000000>; @@ -23,6 +34,18 @@ #clock-cells = <0>; };
+ vcc_host: vcc-host-regulator { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio3 RK_PC4 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&host_vbus_drv>; + regulator-name = "vcc_host"; + regulator-always-on; + regulator-boot-on; + vin-supply = <&vcc_sys>; + }; + vcc_phy: vcc-phy-regulator { compatible = "regulator-fixed"; enable-active-high; @@ -31,7 +54,95 @@ regulator-max-microvolt = <1800000>; regulator-always-on; regulator-boot-on; + vin-supply = <&vccio_1v8>; + }; + + vcc_sys: vcc-sys-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc_sys"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&dc_12v>; + }; + + vccio_1v8: vccio-1v8-regulator { + compatible = "regulator-fixed"; + regulator-name = "vccio_1v8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + vin-supply = <&vcc_sys>; + }; + + vccio_3v3: vccio-3v3-regulator { + compatible = "regulator-fixed"; + regulator-name = "vccio_3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + vin-supply = <&vcc_sys>; + }; + + vdd_arm: vdd-arm-regulator { + compatible = "pwm-regulator"; + pwms = <&pwm1 0 25000 1>; + pwm-supply = <&vcc_sys>; + regulator-name = "vdd_arm"; + regulator-min-microvolt = <950000>; + regulator-max-microvolt = <1400000>; + regulator-always-on; + regulator-boot-on; }; + + vdd_log: vdd-log-regulator { + compatible = "pwm-regulator"; + pwms = <&pwm2 0 25000 1>; + pwm-supply = <&vcc_sys>; + regulator-name = "vdd_log"; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1300000>; + regulator-always-on; + regulator-boot-on; + }; + + gpio_keys { + compatible = "gpio-keys"; + autorepeat; + pinctrl-names = "default"; + pinctrl-0 = <&pwr_key>; + + power_key: power-key { + label = "GPIO Key Power"; + gpios = <&gpio3 23 GPIO_ACTIVE_LOW>; + linux,code = <KEY_POWER>; + debounce-interval = <100>; + wakeup-source; + }; + }; +}; + +&cpu0 { + cpu-supply = <&vdd_arm>; +}; + +&cpu1 { + cpu-supply = <&vdd_arm>; +}; + +&cpu2 { + cpu-supply = <&vdd_arm>; +}; + +&cpu3 { + cpu-supply = <&vdd_arm>; +}; + +&emmc { + cap-mmc-highspeed; + non-removable; + status = "okay"; };
&gmac { @@ -50,25 +161,96 @@ status = "okay"; };
-&emmc { +&io_domains { status = "okay"; + + vccio1-supply = <&vccio_3v3>; + vccio2-supply = <&vccio_1v8>; + vccio4-supply = <&vccio_3v3>; };
-&sdmmc { +&pinctrl { + keys { + pwr_key: pwr-key { + rockchip,pins = <3 RK_PC7 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + usb { + host_vbus_drv: host-vbus-drv { + rockchip,pins = <3 RK_PC4 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; +}; + +&pwm1 { + status = "okay"; +}; + +&pwm2 { + status = "okay"; +}; + +&tsadc { + rockchip,hw-tshut-mode = <0>; /* tshut mode 0:CRU 1:GPIO */ status = "okay"; - bus-width = <4>; - cap-mmc-highspeed; - cap-sd-highspeed; - card-detect-delay = <200>; - disable-wp; - num-slots = <1>; - supports-sd; };
&uart2 { status = "okay"; };
+&u2phy0 { + status = "okay"; + + u2phy0_otg: otg-port { + status = "okay"; + }; + + u2phy0_host: host-port { + phy-supply = <&vcc_host>; + status = "okay"; + }; +}; + +&u2phy1 { + status = "okay"; + + u2phy1_otg: otg-port { + phy-supply = <&vcc_host>; + status = "okay"; + }; + + u2phy1_host: host-port { + phy-supply = <&vcc_host>; + status = "okay"; + }; +}; + +&usb_host0_ehci { + status = "okay"; +}; + +&usb_host0_ohci { + status = "okay"; +}; + +&usb_host1_ehci { + status = "okay"; +}; + +&usb_host1_ohci { + status = "okay"; +}; + +&usb_host2_ehci { + status = "okay"; +}; + +&usb_host2_ohci { + status = "okay"; +}; + &usb_otg { - status = "okay"; + status = "okay"; }; diff --git a/arch/arm/dts/rk3229.dtsi b/arch/arm/dts/rk3229.dtsi new file mode 100644 index 00000000..c340fb30 --- /dev/null +++ b/arch/arm/dts/rk3229.dtsi @@ -0,0 +1,52 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2017 Fuzhou Rockchip Electronics Co., Ltd + */ + +#include "rk322x.dtsi" + +/ { + compatible = "rockchip,rk3229"; + + /delete-node/ opp-table0; + + cpu0_opp_table: opp-table-0 { + compatible = "operating-points-v2"; + opp-shared; + + opp-408000000 { + opp-hz = /bits/ 64 <408000000>; + opp-microvolt = <950000>; + clock-latency-ns = <40000>; + opp-suspend; + }; + opp-600000000 { + opp-hz = /bits/ 64 <600000000>; + opp-microvolt = <975000>; + }; + opp-816000000 { + opp-hz = /bits/ 64 <816000000>; + opp-microvolt = <1000000>; + }; + opp-1008000000 { + opp-hz = /bits/ 64 <1008000000>; + opp-microvolt = <1175000>; + }; + opp-1200000000 { + opp-hz = /bits/ 64 <1200000000>; + opp-microvolt = <1275000>; + }; + opp-1296000000 { + opp-hz = /bits/ 64 <1296000000>; + opp-microvolt = <1325000>; + }; + opp-1392000000 { + opp-hz = /bits/ 64 <1392000000>; + opp-microvolt = <1375000>; + }; + opp-1464000000 { + opp-hz = /bits/ 64 <1464000000>; + opp-microvolt = <1400000>; + }; + }; +};
Thanks, - Kever
/dts-v1/;
aliases {
mmc0 = &emmc;
regulator-boot-on;
- vcc_host: vcc-host-regulator {
enable-active-high;
regulator-boot-on;
- vcc_phy: vcc-phy-regulator { compatible = "regulator-fixed"; enable-active-high;
- vcc_sys: vcc-sys-regulator {
regulator-boot-on;
- vccio_1v8: vccio-1v8-regulator {
- vccio_3v3: vccio-3v3-regulator {
- vdd_arm: vdd-arm-regulator {
};regulator-boot-on;
- vdd_log: vdd-log-regulator {
regulator-boot-on;
- gpio_keys {
autorepeat;
wakeup-source;
+&cpu0 {
- cpu-supply = <&vdd_arm>;
+&cpu1 {
+&cpu2 {
+&cpu3 {
+&emmc {
cap-mmc-highspeed;
non-removable;
status = "okay"; };
&gmac {
- vccio1-supply = <&vccio_3v3>;
- vccio2-supply = <&vccio_1v8>;
- vccio4-supply = <&vccio_3v3>; };
- keys {
pwr_key: pwr-key {
- usb {
+&pwm1 {
- status = "okay";
+&pwm2 {
- status = "okay";
+&tsadc {
- rockchip,hw-tshut-mode = <0>; /* tshut mode 0:CRU 1:GPIO */ status = "okay";
bus-width = <4>;
cap-mmc-highspeed;
cap-sd-highspeed;
disable-wp;
num-slots = <1>;
supports-sd; };
+&u2phy0 {
- status = "okay";
- u2phy0_otg: otg-port {
status = "okay";
- u2phy0_host: host-port {
status = "okay";
+&u2phy1 {
- status = "okay";
- u2phy1_otg: otg-port {
status = "okay";
- u2phy1_host: host-port {
status = "okay";
+&usb_host0_ehci {
- status = "okay";
+&usb_host0_ohci {
- status = "okay";
+&usb_host1_ehci {
- status = "okay";
+&usb_host1_ohci {
- status = "okay";
+&usb_host2_ehci {
- status = "okay";
+&usb_host2_ohci {
- status = "okay";
- &usb_otg {
status = "okay";
- status = "okay"; };
- compatible = "rockchip,rk3229";
- /delete-node/ opp-table0;
opp-shared;
opp-408000000 {
opp-suspend;
opp-600000000 {
opp-816000000 {
opp-1008000000 {
opp-1200000000 {
opp-1296000000 {
opp-1392000000 {
opp-1464000000 {
In order to update the DT for rk3288 sync the power domain dt-binding header. This is the state as of v5.17 in Linux. Change location to be more in line with other SoCs.
Changed V2: changed include rk3288.dtsi --- arch/arm/dts/rk3288.dtsi | 2 +- include/dt-bindings/power-domain/rk3288.h | 11 -------- include/dt-bindings/power/rk3288-power.h | 32 +++++++++++++++++++++++ 3 files changed, 33 insertions(+), 12 deletions(-) delete mode 100644 include/dt-bindings/power-domain/rk3288.h create mode 100644 include/dt-bindings/power/rk3288-power.h
diff --git a/arch/arm/dts/rk3288.dtsi b/arch/arm/dts/rk3288.dtsi index 22bb06ce..2086dbfd 100644 --- a/arch/arm/dts/rk3288.dtsi +++ b/arch/arm/dts/rk3288.dtsi @@ -5,7 +5,7 @@ #include <dt-bindings/interrupt-controller/arm-gic.h> #include <dt-bindings/pinctrl/rockchip.h> #include <dt-bindings/clock/rk3288-cru.h> -#include <dt-bindings/power-domain/rk3288.h> +#include <dt-bindings/power/rk3288-power.h> #include <dt-bindings/thermal/thermal.h> #include <dt-bindings/video/rk3288.h> #include "skeleton.dtsi" diff --git a/include/dt-bindings/power-domain/rk3288.h b/include/dt-bindings/power-domain/rk3288.h deleted file mode 100644 index ca68c114..00000000 --- a/include/dt-bindings/power-domain/rk3288.h +++ /dev/null @@ -1,11 +0,0 @@ -#ifndef __DT_BINDINGS_POWER_DOMAIN_RK3288_H__ -#define __DT_BINDINGS_POWER_DOMAIN_RK3288_H__ - -/* RK3288 power domain index */ -#define RK3288_PD_GPU 0 -#define RK3288_PD_VIO 1 -#define RK3288_PD_VIDEO 2 -#define RK3288_PD_HEVC 3 -#define RK3288_PD_PERI 4 - -#endif diff --git a/include/dt-bindings/power/rk3288-power.h b/include/dt-bindings/power/rk3288-power.h new file mode 100644 index 00000000..f710b56c --- /dev/null +++ b/include/dt-bindings/power/rk3288-power.h @@ -0,0 +1,32 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +#ifndef __DT_BINDINGS_POWER_RK3288_POWER_H__ +#define __DT_BINDINGS_POWER_RK3288_POWER_H__ + +/** + * RK3288 Power Domain and Voltage Domain Summary. + */ + +/* VD_CORE */ +#define RK3288_PD_A17_0 0 +#define RK3288_PD_A17_1 1 +#define RK3288_PD_A17_2 2 +#define RK3288_PD_A17_3 3 +#define RK3288_PD_SCU 4 +#define RK3288_PD_DEBUG 5 +#define RK3288_PD_MEM 6 + +/* VD_LOGIC */ +#define RK3288_PD_BUS 7 +#define RK3288_PD_PERI 8 +#define RK3288_PD_VIO 9 +#define RK3288_PD_ALIVE 10 +#define RK3288_PD_HEVC 11 +#define RK3288_PD_VIDEO 12 + +/* VD_GPU */ +#define RK3288_PD_GPU 13 + +/* VD_PMU */ +#define RK3288_PD_PMU 14 + +#endif
Thanks, - Kever
- RK3288 Power Domain and Voltage Domain Summary.
In order to update the DT for rk3288 sync the clock dt-binding header. This is the state as of v5.17 in Linux. Keep SCLK_MAC_PLL in use for rk3288 clock driver.
Signed-off-by: Johan Jonker jbx6244@gmail.com Reviewed-by: Simon Glass sjg@chromium.org --- include/dt-bindings/clock/rk3288-cru.h | 13 ++++++++++++- 1 file changed, 12 insertions(+), 1 deletion(-)
diff --git a/include/dt-bindings/clock/rk3288-cru.h b/include/dt-bindings/clock/rk3288-cru.h index e368d767..453f6671 100644 --- a/include/dt-bindings/clock/rk3288-cru.h +++ b/include/dt-bindings/clock/rk3288-cru.h @@ -1,9 +1,12 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ +/* SPDX-License-Identifier: GPL-2.0-or-later */ /* * Copyright (c) 2014 MundoReader S.L. * Author: Heiko Stuebner heiko@sntech.de */
+#ifndef _DT_BINDINGS_CLK_ROCKCHIP_RK3288_H +#define _DT_BINDINGS_CLK_ROCKCHIP_RK3288_H + /* core clocks */ #define PLL_APLL 1 #define PLL_DPLL 2 @@ -74,6 +77,9 @@ #define SCLK_USBPHY480M_SRC 122 #define SCLK_PVTM_CORE 123 #define SCLK_PVTM_GPU 124 +#define SCLK_CRYPTO 125 +#define SCLK_MIPIDSI_24M 126 +#define SCLK_VIP_OUT 127
#define SCLK_MAC_PLL 150 #define SCLK_MAC 151 @@ -153,6 +159,9 @@ #define PCLK_DDRUPCTL1 366 #define PCLK_PUBL1 367 #define PCLK_WDT 368 +#define PCLK_EFUSE256 369 +#define PCLK_EFUSE1024 370 +#define PCLK_ISP_IN 371
/* hclk gates */ #define HCLK_GPS 448 @@ -368,3 +377,5 @@ #define SRST_TSP_CLKIN0 189 #define SRST_TSP_CLKIN1 190 #define SRST_TSP_27M 191 + +#endif
Thanks, - Kever
- Copyright (c) 2014 MundoReader S.L.
- Author: Heiko Stuebner heiko@sntech.de
- /* core clocks */ #define PLL_APLL 1 #define PLL_DPLL 2
In order to sync rk3288.dtsi from Linux it needed to move all u-boot specific properties in separate dtsi files.
Changed V3: add u-boot,dm-pre-reloc to noc node change reg size rk3288-u-boot.dtsi
Changed V2: combine U-boot specific changes add bus_intmem label use current led node name --- arch/arm/dts/rk3288-evb-u-boot.dtsi | 11 +++ arch/arm/dts/rk3288-evb.dts | 11 --- arch/arm/dts/rk3288-firefly-u-boot.dtsi | 31 +++++++ arch/arm/dts/rk3288-firefly.dts | 17 ---- arch/arm/dts/rk3288-firefly.dtsi | 3 - arch/arm/dts/rk3288-miqi-u-boot.dtsi | 20 +++++ arch/arm/dts/rk3288-miqi.dts | 11 --- arch/arm/dts/rk3288-miqi.dtsi | 2 - arch/arm/dts/rk3288-phycore-rdk-u-boot.dtsi | 44 ++++++++++ arch/arm/dts/rk3288-phycore-rdk.dts | 18 ----- arch/arm/dts/rk3288-phycore-som.dtsi | 6 -- arch/arm/dts/rk3288-popmetal-u-boot.dtsi | 11 +++ arch/arm/dts/rk3288-popmetal.dts | 11 --- arch/arm/dts/rk3288-rock2-square-u-boot.dtsi | 30 +++++++ arch/arm/dts/rk3288-rock2-square.dts | 18 ----- arch/arm/dts/rk3288-u-boot.dtsi | 80 ++++++++++++++++--- arch/arm/dts/rk3288-veyron-jerry-u-boot.dtsi | 14 ++++ arch/arm/dts/rk3288-veyron-jerry.dts | 11 --- arch/arm/dts/rk3288-veyron-mickey-u-boot.dtsi | 14 ++++ arch/arm/dts/rk3288-veyron-mickey.dts | 11 --- arch/arm/dts/rk3288-veyron-minnie-u-boot.dtsi | 14 ++++ arch/arm/dts/rk3288-veyron-minnie.dts | 11 --- arch/arm/dts/rk3288-veyron-u-boot.dtsi | 62 ++++++++++++++ arch/arm/dts/rk3288-veyron.dtsi | 39 --------- arch/arm/dts/rk3288.dtsi | 49 +----------- 25 files changed, 321 insertions(+), 228 deletions(-) create mode 100644 arch/arm/dts/rk3288-phycore-rdk-u-boot.dtsi create mode 100644 arch/arm/dts/rk3288-rock2-square-u-boot.dtsi create mode 100644 arch/arm/dts/rk3288-veyron-jerry-u-boot.dtsi create mode 100644 arch/arm/dts/rk3288-veyron-mickey-u-boot.dtsi create mode 100644 arch/arm/dts/rk3288-veyron-minnie-u-boot.dtsi
diff --git a/arch/arm/dts/rk3288-evb-u-boot.dtsi b/arch/arm/dts/rk3288-evb-u-boot.dtsi index 8ac7840f..c8f51207 100644 --- a/arch/arm/dts/rk3288-evb-u-boot.dtsi +++ b/arch/arm/dts/rk3288-evb-u-boot.dtsi @@ -5,6 +5,17 @@
#include "rk3288-u-boot.dtsi"
+&dmc { + rockchip,pctl-timing = <0x215 0xc8 0x0 0x35 0x26 0x2 0x70 0x2000d + 0x6 0x0 0x8 0x4 0x17 0x24 0xd 0x6 + 0x4 0x8 0x4 0x76 0x4 0x0 0x30 0x0 + 0x1 0x2 0x2 0x4 0x0 0x0 0xc0 0x4 + 0x8 0x1f4>; + rockchip,phy-timing = <0x48d7dd93 0x187008d8 0x121076 + 0x0 0xc3 0x6 0x2>; + rockchip,sdram-params = <0x20d266a4 0x5b6 2 533000000 6 9 0>; +}; + &pinctrl { u-boot,dm-pre-reloc; }; diff --git a/arch/arm/dts/rk3288-evb.dts b/arch/arm/dts/rk3288-evb.dts index eac91a87..bb24a96c 100644 --- a/arch/arm/dts/rk3288-evb.dts +++ b/arch/arm/dts/rk3288-evb.dts @@ -15,17 +15,6 @@ }; };
-&dmc { - rockchip,pctl-timing = <0x215 0xc8 0x0 0x35 0x26 0x2 0x70 0x2000d - 0x6 0x0 0x8 0x4 0x17 0x24 0xd 0x6 - 0x4 0x8 0x4 0x76 0x4 0x0 0x30 0x0 - 0x1 0x2 0x2 0x4 0x0 0x0 0xc0 0x4 - 0x8 0x1f4>; - rockchip,phy-timing = <0x48d7dd93 0x187008d8 0x121076 - 0x0 0xc3 0x6 0x2>; - rockchip,sdram-params = <0x20d266a4 0x5b6 2 533000000 6 9 0>; -}; - &pwm1 { status = "okay"; }; diff --git a/arch/arm/dts/rk3288-firefly-u-boot.dtsi b/arch/arm/dts/rk3288-firefly-u-boot.dtsi index 8b9c3831..cc84d7c4 100644 --- a/arch/arm/dts/rk3288-firefly-u-boot.dtsi +++ b/arch/arm/dts/rk3288-firefly-u-boot.dtsi @@ -5,6 +5,37 @@
+/ { + config { + u-boot,dm-pre-reloc; + u-boot,boot-led = "firefly:green:power"; + }; + + leds { + u-boot,dm-pre-reloc; + + work { + u-boot,dm-pre-reloc; + }; + + power { + u-boot,dm-pre-reloc; + }; + }; +}; + +&dmc { + rockchip,pctl-timing = <0x29a 0xc8 0x1f8 0x42 0x4e 0x4 0xea 0xa + 0x5 0x0 0xa 0x7 0x19 0x24 0xa 0x7 + 0x5 0xa 0x5 0x200 0x5 0x10 0x40 0x0 + 0x1 0x7 0x7 0x4 0xc 0x43 0x100 0x0 + 0x5 0x0>; + rockchip,phy-timing = <0x48f9aab4 0xea0910 0x1002c200 + 0xa60 0x40 0x10 0x0>; + /* Add a dummy value to cause of-platdata think this is bytes */ + rockchip,sdram-params = <0x30B25564 0x627 3 666000000 3 9 1>; +}; + &pinctrl { u-boot,dm-pre-reloc; }; diff --git a/arch/arm/dts/rk3288-firefly.dts b/arch/arm/dts/rk3288-firefly.dts index 1cff04e7..72982efd 100644 --- a/arch/arm/dts/rk3288-firefly.dts +++ b/arch/arm/dts/rk3288-firefly.dts @@ -13,23 +13,6 @@ chosen { stdout-path = &uart2; }; - - config { - u-boot,dm-pre-reloc; - u-boot,boot-led = "firefly:green:power"; - }; -}; - -&dmc { - rockchip,pctl-timing = <0x29a 0xc8 0x1f8 0x42 0x4e 0x4 0xea 0xa - 0x5 0x0 0xa 0x7 0x19 0x24 0xa 0x7 - 0x5 0xa 0x5 0x200 0x5 0x10 0x40 0x0 - 0x1 0x7 0x7 0x4 0xc 0x43 0x100 0x0 - 0x5 0x0>; - rockchip,phy-timing = <0x48f9aab4 0xea0910 0x1002c200 - 0xa60 0x40 0x10 0x0>; - /* Add a dummy value to cause of-platdata think this is bytes */ - rockchip,sdram-params = <0x30B25564 0x627 3 666000000 3 9 1>; };
&ir { diff --git a/arch/arm/dts/rk3288-firefly.dtsi b/arch/arm/dts/rk3288-firefly.dtsi index b7f279f7..1117d391 100644 --- a/arch/arm/dts/rk3288-firefly.dtsi +++ b/arch/arm/dts/rk3288-firefly.dtsi @@ -37,11 +37,9 @@ };
leds { - u-boot,dm-pre-reloc; compatible = "gpio-leds";
work { - u-boot,dm-pre-reloc; gpios = <&gpio8 1 GPIO_ACTIVE_LOW>; label = "firefly:blue:user"; linux,default-trigger = "rc-feedback"; @@ -50,7 +48,6 @@ };
power { - u-boot,dm-pre-reloc; gpios = <&gpio8 2 GPIO_ACTIVE_LOW>; label = "firefly:green:power"; linux,default-trigger = "default-on"; diff --git a/arch/arm/dts/rk3288-miqi-u-boot.dtsi b/arch/arm/dts/rk3288-miqi-u-boot.dtsi index 4f63fc9f..2a74fdd1 100644 --- a/arch/arm/dts/rk3288-miqi-u-boot.dtsi +++ b/arch/arm/dts/rk3288-miqi-u-boot.dtsi @@ -4,6 +4,26 @@ */
#include "rk3288-u-boot.dtsi" +/ { + leds { + u-boot,dm-pre-reloc; + + work { + u-boot,dm-pre-reloc; + }; + }; +}; + +&dmc { + rockchip,pctl-timing = <0x29a 0xc8 0x1f8 0x42 0x4e 0x4 0xea 0xa + 0x5 0x0 0xa 0x7 0x19 0x24 0xa 0x7 + 0x5 0xa 0x5 0x200 0x5 0x10 0x40 0x0 + 0x1 0x7 0x7 0x4 0xc 0x43 0x100 0x0 + 0x5 0x0>; + rockchip,phy-timing = <0x48f9aab4 0xea0910 0x1002c200 + 0xa60 0x40 0x10 0x0>; + rockchip,sdram-params = <0x30B25564 0x627 3 666000000 3 9 1>; +};
&pinctrl { u-boot,dm-pre-reloc; diff --git a/arch/arm/dts/rk3288-miqi.dts b/arch/arm/dts/rk3288-miqi.dts index e47170c6..4a2f249e 100644 --- a/arch/arm/dts/rk3288-miqi.dts +++ b/arch/arm/dts/rk3288-miqi.dts @@ -14,14 +14,3 @@ stdout-path = "serial2:115200n8"; }; }; - -&dmc { - rockchip,pctl-timing = <0x29a 0xc8 0x1f8 0x42 0x4e 0x4 0xea 0xa - 0x5 0x0 0xa 0x7 0x19 0x24 0xa 0x7 - 0x5 0xa 0x5 0x200 0x5 0x10 0x40 0x0 - 0x1 0x7 0x7 0x4 0xc 0x43 0x100 0x0 - 0x5 0x0>; - rockchip,phy-timing = <0x48f9aab4 0xea0910 0x1002c200 - 0xa60 0x40 0x10 0x0>; - rockchip,sdram-params = <0x30B25564 0x627 3 666000000 3 9 1>; -}; diff --git a/arch/arm/dts/rk3288-miqi.dtsi b/arch/arm/dts/rk3288-miqi.dtsi index 432f744b..cb80cbf2 100644 --- a/arch/arm/dts/rk3288-miqi.dtsi +++ b/arch/arm/dts/rk3288-miqi.dtsi @@ -34,11 +34,9 @@
work { - u-boot,dm-pre-reloc; gpios = <&gpio7 4 GPIO_ACTIVE_LOW>; label = "miqi:green:user"; linux,default-trigger = "default-on"; diff --git a/arch/arm/dts/rk3288-phycore-rdk-u-boot.dtsi b/arch/arm/dts/rk3288-phycore-rdk-u-boot.dtsi new file mode 100644 index 00000000..30f4cb10 --- /dev/null +++ b/arch/arm/dts/rk3288-phycore-rdk-u-boot.dtsi @@ -0,0 +1,44 @@ +// SPDX-License-Identifier: GPL-2.0+ + +#include "rk3288-u-boot.dtsi" + +&dmc { + rockchip,num-channels = <2>; + rockchip,pctl-timing = <0x29a 0xc8 0x1f8 0x42 0x4e 0x4 0xea 0xa + 0x5 0x0 0xa 0x7 0x19 0x24 0xa 0x7 + 0x5 0xa 0x5 0x200 0x5 0x10 0x40 0x0 + 0x1 0x7 0x7 0x4 0xc 0x43 0x100 0x0 + 0x5 0x0>; + rockchip,phy-timing = <0x48f9aab4 0xea0910 0x1002c200 + 0xa60 0x40 0x10 0x0>; + rockchip,sdram-channel = /bits/ 8 <0x1 0xa 0x3 0x2 0x1 0x0 0xe 0xe>; + rockchip,sdram-params = <0x30B25564 0x627 3 666000000 3 5 1>; +}; + +&emmc { + u-boot,dm-pre-reloc; +}; + +&i2c0 { + u-boot,dm-pre-reloc; + + rk818: pmic@1c { + u-boot,dm-pre-reloc; + + regulators { + u-boot,dm-pre-reloc; + }; + }; +}; + +&pinctrl { + u-boot,dm-pre-reloc; +}; + +&sdmmc { + u-boot,dm-pre-reloc; +}; + +&uart2 { + u-boot,dm-pre-reloc; +}; diff --git a/arch/arm/dts/rk3288-phycore-rdk.dts b/arch/arm/dts/rk3288-phycore-rdk.dts index cc392109..ebea8e67 100644 --- a/arch/arm/dts/rk3288-phycore-rdk.dts +++ b/arch/arm/dts/rk3288-phycore-rdk.dts @@ -112,19 +112,6 @@ }; };
-&dmc { - rockchip,num-channels = <2>; - rockchip,pctl-timing = <0x29a 0xc8 0x1f8 0x42 0x4e 0x4 0xea 0xa - 0x5 0x0 0xa 0x7 0x19 0x24 0xa 0x7 - 0x5 0xa 0x5 0x200 0x5 0x10 0x40 0x0 - 0x1 0x7 0x7 0x4 0xc 0x43 0x100 0x0 - 0x5 0x0>; - rockchip,phy-timing = <0x48f9aab4 0xea0910 0x1002c200 - 0xa60 0x40 0x10 0x0>; - rockchip,sdram-channel = /bits/ 8 <0x1 0xa 0x3 0x2 0x1 0x0 0xe 0xe>; - rockchip,sdram-params = <0x30B25564 0x627 3 666000000 3 5 1>; -}; - &gmac { status = "okay"; }; @@ -175,8 +162,6 @@ };
&pinctrl { - u-boot,dm-pre-reloc; - pcfg_pull_up_drv_12ma: pcfg-pull-up-drv-12ma { bias-pull-up; drive-strength = <12>; @@ -246,8 +231,6 @@ };
&sdmmc { - u-boot,dm-pre-reloc; - bus-width = <4>; cap-mmc-highspeed; cap-sd-highspeed; @@ -268,7 +251,6 @@ };
&uart2 { - u-boot,dm-pre-reloc; status = "okay"; };
diff --git a/arch/arm/dts/rk3288-phycore-som.dtsi b/arch/arm/dts/rk3288-phycore-som.dtsi index 02d11968..821525f7 100644 --- a/arch/arm/dts/rk3288-phycore-som.dtsi +++ b/arch/arm/dts/rk3288-phycore-som.dtsi @@ -149,8 +149,6 @@
&emmc { status = "okay"; - u-boot,dm-pre-reloc; - bus-width = <8>; cap-mmc-highspeed; disable-wp; @@ -201,8 +199,6 @@
&i2c0 { status = "okay"; - u-boot,dm-pre-reloc; - clock-frequency = <400000>;
rk818: pmic@1c { @@ -216,7 +212,6 @@ rockchip,system-power-controller; wakeup-source; #clock-cells = <1>; - u-boot,dm-pre-reloc;
vcc1-supply = <&vdd_sys>; vcc2-supply = <&vdd_sys>; @@ -230,7 +225,6 @@ vddio-supply = <&vdd_3v3_io>;
regulators { - u-boot,dm-pre-reloc; vdd_log: DCDC_REG1 { regulator-name = "vdd_log"; regulator-always-on; diff --git a/arch/arm/dts/rk3288-popmetal-u-boot.dtsi b/arch/arm/dts/rk3288-popmetal-u-boot.dtsi index 8ac7840f..3782253c 100644 --- a/arch/arm/dts/rk3288-popmetal-u-boot.dtsi +++ b/arch/arm/dts/rk3288-popmetal-u-boot.dtsi @@ -5,6 +5,17 @@
+&dmc { + rockchip,pctl-timing = <0x29a 0xc8 0x1f8 0x42 0x4e 0x4 0xea 0xa + 0x5 0x0 0xa 0x7 0x19 0x24 0xa 0x7 + 0x5 0xa 0x5 0x200 0x5 0x10 0x40 0x0 + 0x1 0x7 0x7 0x4 0xc 0x43 0x100 0x0 + 0x5 0x0>; + rockchip,phy-timing = <0x48f9aab4 0xea0910 0x1002c200 + 0xa60 0x40 0x10 0x0>; + rockchip,sdram-params = <0x30B25564 0x627 3 666000000 3 9 1>; +}; + &pinctrl { u-boot,dm-pre-reloc; }; diff --git a/arch/arm/dts/rk3288-popmetal.dts b/arch/arm/dts/rk3288-popmetal.dts index 5c6d06f2..736dc51e 100644 --- a/arch/arm/dts/rk3288-popmetal.dts +++ b/arch/arm/dts/rk3288-popmetal.dts @@ -15,17 +15,6 @@ }; };
-&dmc { - rockchip,pctl-timing = <0x29a 0xc8 0x1f8 0x42 0x4e 0x4 0xea 0xa - 0x5 0x0 0xa 0x7 0x19 0x24 0xa 0x7 - 0x5 0xa 0x5 0x200 0x5 0x10 0x40 0x0 - 0x1 0x7 0x7 0x4 0xc 0x43 0x100 0x0 - 0x5 0x0>; - rockchip,phy-timing = <0x48f9aab4 0xea0910 0x1002c200 - 0xa60 0x40 0x10 0x0>; - rockchip,sdram-params = <0x30B25564 0x627 3 666000000 3 9 1>; -}; - &pwm1 { status = "okay"; }; diff --git a/arch/arm/dts/rk3288-rock2-square-u-boot.dtsi b/arch/arm/dts/rk3288-rock2-square-u-boot.dtsi new file mode 100644 index 00000000..509f789b --- /dev/null +++ b/arch/arm/dts/rk3288-rock2-square-u-boot.dtsi @@ -0,0 +1,30 @@ +// SPDX-License-Identifier: GPL-2.0+ + +#include "rk3288-u-boot.dtsi" + +&dmc { + rockchip,pctl-timing = <0x29a 0xc8 0x1f8 0x42 0x4e 0x4 0xea 0xa + 0x5 0x0 0xa 0x7 0x19 0x24 0xa 0x7 + 0x5 0xa 0x5 0x200 0x5 0x10 0x40 0x0 + 0x1 0x7 0x7 0x4 0xc 0x43 0x100 0x0 + 0x5 0x0>; + rockchip,phy-timing = <0x48f9aab4 0xea0910 0x1002c200 + 0xa60 0x40 0x10 0x0>; + rockchip,sdram-params = <0x30B25564 0x627 3 666000000 3 9 1>; +}; + +&gpio7 { + u-boot,dm-pre-reloc; +}; + +&pinctrl { + u-boot,dm-pre-reloc; +}; + +&sdmmc { + u-boot,dm-pre-reloc; +}; + +&uart2 { + u-boot,dm-pre-reloc; +}; diff --git a/arch/arm/dts/rk3288-rock2-square.dts b/arch/arm/dts/rk3288-rock2-square.dts index 11c580a0..41676696 100644 --- a/arch/arm/dts/rk3288-rock2-square.dts +++ b/arch/arm/dts/rk3288-rock2-square.dts @@ -96,7 +96,6 @@ };
&sdmmc { - u-boot,dm-pre-reloc; bus-width = <4>; cap-mmc-highspeed; cap-sd-highspeed; @@ -139,7 +138,6 @@ };
&pinctrl { - u-boot,dm-pre-reloc; ir { ir_int: ir-int { rockchip,pins = <8 1 RK_FUNC_GPIO &pcfg_pull_up>; @@ -171,7 +169,6 @@
&uart2 { status = "okay"; - u-boot,dm-pre-reloc; reg-shift = <2>; };
@@ -182,18 +179,3 @@ &usb_host0_ehci { status = "okay"; }; - -&dmc { - rockchip,pctl-timing = <0x29a 0xc8 0x1f8 0x42 0x4e 0x4 0xea 0xa - 0x5 0x0 0xa 0x7 0x19 0x24 0xa 0x7 - 0x5 0xa 0x5 0x200 0x5 0x10 0x40 0x0 - 0x1 0x7 0x7 0x4 0xc 0x43 0x100 0x0 - 0x5 0x0>; - rockchip,phy-timing = <0x48f9aab4 0xea0910 0x1002c200 - 0xa60 0x40 0x10 0x0>; - rockchip,sdram-params = <0x30B25564 0x627 3 666000000 3 9 1>; -}; - -&gpio7 { - u-boot,dm-pre-reloc; -}; diff --git a/arch/arm/dts/rk3288-u-boot.dtsi b/arch/arm/dts/rk3288-u-boot.dtsi index e3c6c10f..9eb696b1 100644 --- a/arch/arm/dts/rk3288-u-boot.dtsi +++ b/arch/arm/dts/rk3288-u-boot.dtsi @@ -7,10 +7,53 @@ #include "rockchip-optee.dtsi"
/ { + aliases { + gpio0 = &gpio0; + gpio1 = &gpio1; + gpio2 = &gpio2; + gpio3 = &gpio3; + gpio4 = &gpio4; + gpio5 = &gpio5; + gpio6 = &gpio6; + gpio7 = &gpio7; + gpio8 = &gpio8; + mmc0 = &emmc; + mmc1 = &sdmmc; + mmc2 = &sdio0; + mmc3 = &sdio1; + }; + chosen { u-boot,spl-boot-order = \ "same-as-spl", &emmc, &sdmmc; }; + + dmc: dmc@ff610000 { + compatible = "rockchip,rk3288-dmc", "syscon"; + reg = <0xff610000 0x3fc + 0xff620000 0x294 + 0xff630000 0x3fc + 0xff640000 0x294>; + clocks = <&cru PCLK_DDRUPCTL0>, <&cru PCLK_PUBL0>, + <&cru PCLK_DDRUPCTL1>, <&cru PCLK_PUBL1>, + <&cru ARMCLK>; + clock-names = "pclk_ddrupctl0", "pclk_publ0", + "pclk_ddrupctl1", "pclk_publ1", + "arm_clk"; + rockchip,cru = <&cru>; + rockchip,grf = <&grf>; + rockchip,noc = <&noc>; + rockchip,pmu = <&pmu>; + rockchip,sgrf = <&sgrf>; + rockchip,sram = <&ddr_sram>; + u-boot,dm-pre-reloc; + }; + + noc: syscon@ffac0000 { + compatible = "rockchip,rk3288-noc", "syscon"; + reg = <0xffac0000 0x2000>; + u-boot,dm-pre-reloc; + }; };
#ifdef CONFIG_ROCKCHIP_SPI_IMAGE @@ -37,38 +80,53 @@ }; #endif
-&dmc { - u-boot,dm-pre-reloc; +&bus_intmem { + ddr_sram: ddr-sram@1000 { + compatible = "rockchip,rk3288-ddr-sram"; + reg = <0x1000 0x4000>; + }; };
-&pmu { +&cru { u-boot,dm-pre-reloc; };
-&sgrf { +&gpio7 { u-boot,dm-pre-reloc; };
-&cru { +&grf { u-boot,dm-pre-reloc; };
-&grf { +&pmu { u-boot,dm-pre-reloc; };
-&vopb { +&sgrf { u-boot,dm-pre-reloc; };
-&vopl { - u-boot,dm-pre-reloc; +&uart0 { + clock-frequency = <24000000>; +}; + +&uart1 { + clock-frequency = <24000000>; };
-&noc { +&uart2 { + clock-frequency = <24000000>; +}; + +&uart3 { + clock-frequency = <24000000>; +}; + +&vopb { u-boot,dm-pre-reloc; };
-&gpio7 { +&vopl { u-boot,dm-pre-reloc; }; diff --git a/arch/arm/dts/rk3288-veyron-jerry-u-boot.dtsi b/arch/arm/dts/rk3288-veyron-jerry-u-boot.dtsi new file mode 100644 index 00000000..2cc6b090 --- /dev/null +++ b/arch/arm/dts/rk3288-veyron-jerry-u-boot.dtsi @@ -0,0 +1,14 @@ +// SPDX-License-Identifier: GPL-2.0+ + +#include "rk3288-veyron-u-boot.dtsi" + +&dmc { + rockchip,pctl-timing = <0x29a 0xc8 0x1f4 0x42 0x4e 0x4 0xea 0xa + 0x5 0x0 0xa 0x7 0x19 0x24 0xa 0x7 + 0x5 0xa 0x5 0x200 0x5 0x10 0x40 0x0 + 0x1 0x7 0x7 0x4 0xc 0x43 0x100 0x0 + 0x5 0x0>; + rockchip,phy-timing = <0x48f9aab4 0xea0910 0x1002c200 + 0xa60 0x40 0x10 0x0>; + rockchip,sdram-params = <0x30B25564 0x627 3 666000000 3 9 1>; +}; diff --git a/arch/arm/dts/rk3288-veyron-jerry.dts b/arch/arm/dts/rk3288-veyron-jerry.dts index c251d9d5..ff7669eb 100644 --- a/arch/arm/dts/rk3288-veyron-jerry.dts +++ b/arch/arm/dts/rk3288-veyron-jerry.dts @@ -66,17 +66,6 @@ }; };
-&dmc { - rockchip,pctl-timing = <0x29a 0xc8 0x1f4 0x42 0x4e 0x4 0xea 0xa - 0x5 0x0 0xa 0x7 0x19 0x24 0xa 0x7 - 0x5 0xa 0x5 0x200 0x5 0x10 0x40 0x0 - 0x1 0x7 0x7 0x4 0xc 0x43 0x100 0x0 - 0x5 0x0>; - rockchip,phy-timing = <0x48f9aab4 0xea0910 0x1002c200 - 0xa60 0x40 0x10 0x0>; - rockchip,sdram-params = <0x30B25564 0x627 3 666000000 3 9 1>; -}; - &gpio_keys { power { gpios = <&gpio0 5 GPIO_ACTIVE_LOW>; diff --git a/arch/arm/dts/rk3288-veyron-mickey-u-boot.dtsi b/arch/arm/dts/rk3288-veyron-mickey-u-boot.dtsi new file mode 100644 index 00000000..213a46ba --- /dev/null +++ b/arch/arm/dts/rk3288-veyron-mickey-u-boot.dtsi @@ -0,0 +1,14 @@ +// SPDX-License-Identifier: GPL-2.0+ + +#include "rk3288-veyron-u-boot.dtsi" + +&dmc { + rockchip,pctl-timing = <0x215 0xc8 0x0 0x35 0x26 0x2 0x70 0x2000d + 0x6 0x0 0x8 0x4 0x17 0x24 0xd 0x6 + 0x4 0x8 0x4 0x76 0x4 0x0 0x30 0x0 + 0x1 0x2 0x2 0x4 0x0 0x0 0xc0 0x4 + 0x8 0x1f4>; + rockchip,phy-timing = <0x48d7dd93 0x187008d8 0x121076 + 0x0 0xc3 0x6 0x2>; + rockchip,sdram-params = <0x20d266a4 0x5b6 2 533000000 6 9 1>; +}; diff --git a/arch/arm/dts/rk3288-veyron-mickey.dts b/arch/arm/dts/rk3288-veyron-mickey.dts index e0dc3620..0521d9e0 100644 --- a/arch/arm/dts/rk3288-veyron-mickey.dts +++ b/arch/arm/dts/rk3288-veyron-mickey.dts @@ -161,17 +161,6 @@ }; };
-&dmc { - rockchip,pctl-timing = <0x215 0xc8 0x0 0x35 0x26 0x2 0x70 0x2000d - 0x6 0x0 0x8 0x4 0x17 0x24 0xd 0x6 - 0x4 0x8 0x4 0x76 0x4 0x0 0x30 0x0 - 0x1 0x2 0x2 0x4 0x0 0x0 0xc0 0x4 - 0x8 0x1f4>; - rockchip,phy-timing = <0x48d7dd93 0x187008d8 0x121076 - 0x0 0xc3 0x6 0x2>; - rockchip,sdram-params = <0x20d266a4 0x5b6 2 533000000 6 9 1>; -}; - &emmc { /delete-property/mmc-hs200-1_8v; }; diff --git a/arch/arm/dts/rk3288-veyron-minnie-u-boot.dtsi b/arch/arm/dts/rk3288-veyron-minnie-u-boot.dtsi new file mode 100644 index 00000000..8211da41 --- /dev/null +++ b/arch/arm/dts/rk3288-veyron-minnie-u-boot.dtsi @@ -0,0 +1,14 @@ +// SPDX-License-Identifier: GPL-2.0+ + +#include "rk3288-veyron-u-boot.dtsi" + +&dmc { + rockchip,pctl-timing = <0x215 0xc8 0x0 0x35 0x26 0x2 0x70 0x2000d + 0x6 0x0 0x8 0x4 0x17 0x24 0xd 0x6 + 0x4 0x8 0x4 0x76 0x4 0x0 0x30 0x0 + 0x1 0x2 0x2 0x4 0x0 0x0 0xc0 0x4 + 0x8 0x1f4>; + rockchip,phy-timing = <0x48d7dd93 0x187008d8 0x121076 + 0x0 0xc3 0x6 0x1>; + rockchip,sdram-params = <0x20d266a4 0x5b6 6 533000000 6 13 0>; +}; diff --git a/arch/arm/dts/rk3288-veyron-minnie.dts b/arch/arm/dts/rk3288-veyron-minnie.dts index 646f6ae7..b56a3f4f 100644 --- a/arch/arm/dts/rk3288-veyron-minnie.dts +++ b/arch/arm/dts/rk3288-veyron-minnie.dts @@ -137,17 +137,6 @@ power-supply = <&backlight_regulator>; };
-&dmc { - rockchip,pctl-timing = <0x215 0xc8 0x0 0x35 0x26 0x2 0x70 0x2000d - 0x6 0x0 0x8 0x4 0x17 0x24 0xd 0x6 - 0x4 0x8 0x4 0x76 0x4 0x0 0x30 0x0 - 0x1 0x2 0x2 0x4 0x0 0x0 0xc0 0x4 - 0x8 0x1f4>; - rockchip,phy-timing = <0x48d7dd93 0x187008d8 0x121076 - 0x0 0xc3 0x6 0x1>; - rockchip,sdram-params = <0x20d266a4 0x5b6 6 533000000 6 13 0>; -}; - &emmc { /delete-property/mmc-hs200-1_8v; }; diff --git a/arch/arm/dts/rk3288-veyron-u-boot.dtsi b/arch/arm/dts/rk3288-veyron-u-boot.dtsi index 899fe6e7..c8b33fea 100644 --- a/arch/arm/dts/rk3288-veyron-u-boot.dtsi +++ b/arch/arm/dts/rk3288-veyron-u-boot.dtsi @@ -5,7 +5,69 @@
+/ { + chosen { + u-boot,spl-boot-order = &spi_flash; + }; +}; + +&dmc { + logic-supply = <&vdd_logic>; + rockchip,odt-disable-freq = <333000000>; + rockchip,dll-disable-freq = <333000000>; + rockchip,sr-enable-freq = <333000000>; + rockchip,pd-enable-freq = <666000000>; + rockchip,auto-self-refresh-cnt = <0>; + rockchip,auto-power-down-cnt = <64>; + rockchip,ddr-speed-bin = <21>; + rockchip,trcd = <10>; + rockchip,trp = <10>; + operating-points = < + /* KHz uV */ + 200000 1050000 + 333000 1100000 + 533000 1150000 + 666000 1200000 + >; +}; + +&gpio3 { + u-boot,dm-pre-reloc; +}; + &gpio7 { u-boot,dm-pre-reloc; };
+&gpio8 { + u-boot,dm-pre-reloc; +}; + +&i2c0 { + u-boot,dm-pre-reloc; +}; + +&pinctrl { + u-boot,dm-pre-reloc; +}; + +&rk808 { + u-boot,dm-pre-reloc; +}; + +&sdmmc { + u-boot,dm-pre-reloc; +}; + +&spi2 { + u-boot,dm-pre-reloc; +}; + +&spi_flash { + u-boot,dm-pre-reloc; +}; + +&uart2 { + u-boot,dm-pre-reloc; +}; + diff --git a/arch/arm/dts/rk3288-veyron.dtsi b/arch/arm/dts/rk3288-veyron.dtsi index 8754043b..4a9c27a4 100644 --- a/arch/arm/dts/rk3288-veyron.dtsi +++ b/arch/arm/dts/rk3288-veyron.dtsi @@ -16,7 +16,6 @@
chosen { stdout-path = &uart2; - u-boot,spl-boot-order = &spi_flash; };
firmware { @@ -220,26 +219,6 @@ cpu0-supply = <&vdd_cpu>; };
-&dmc { - logic-supply = <&vdd_logic>; - rockchip,odt-disable-freq = <333000000>; - rockchip,dll-disable-freq = <333000000>; - rockchip,sr-enable-freq = <333000000>; - rockchip,pd-enable-freq = <666000000>; - rockchip,auto-self-refresh-cnt = <0>; - rockchip,auto-power-down-cnt = <64>; - rockchip,ddr-speed-bin = <21>; - rockchip,trcd = <10>; - rockchip,trp = <10>; - operating-points = < - /* KHz uV */ - 200000 1050000 - 333000 1100000 - 533000 1150000 - 666000 1200000 - >; -}; - &efuse { status = "okay"; }; @@ -299,10 +278,8 @@
&spi2 { status = "okay"; - u-boot,dm-pre-reloc;
spi_flash: spiflash@0 { - u-boot,dm-pre-reloc; compatible = "spidev", "jedec,spi-nor"; spi-max-frequency = <20000000>; /* Reduce for Dediprog em100 pro */ reg = <0>; @@ -315,7 +292,6 @@ clock-frequency = <400000>; i2c-scl-falling-time-ns = <50>; /* 2.5ns measured */ i2c-scl-rising-time-ns = <100>; /* 45ns measured */ - u-boot,dm-pre-reloc;
rk808: pmic@1b { compatible = "rockchip,rk808"; @@ -328,7 +304,6 @@ rockchip,system-power-controller; wakeup-source; #clock-cells = <1>; - u-boot,dm-pre-reloc;
vcc1-supply = <&vcc33_sys>; vcc2-supply = <&vcc33_sys>; @@ -557,7 +532,6 @@
@@ -601,7 +575,6 @@ };
&pinctrl { - u-boot,dm-pre-reloc; pinctrl-names = "default", "sleep"; pinctrl-0 = < /* Common for sleep and wake, but no owners */ @@ -826,15 +799,3 @@ assigned-clocks = <&cru SCLK_USBPHY480M_SRC>; assigned-clock-parents = <&cru SCLK_OTGPHY0>; }; - -&sdmmc { - u-boot,dm-pre-reloc; -}; - -&gpio3 { - u-boot,dm-pre-reloc; -}; - -&gpio8 { - u-boot,dm-pre-reloc; -}; diff --git a/arch/arm/dts/rk3288.dtsi b/arch/arm/dts/rk3288.dtsi index 2086dbfd..c4abfa37 100644 --- a/arch/arm/dts/rk3288.dtsi +++ b/arch/arm/dts/rk3288.dtsi @@ -15,25 +15,12 @@
interrupt-parent = <&gic>; aliases { - gpio0 = &gpio0; - gpio1 = &gpio1; - gpio2 = &gpio2; - gpio3 = &gpio3; - gpio4 = &gpio4; - gpio5 = &gpio5; - gpio6 = &gpio6; - gpio7 = &gpio7; - gpio8 = &gpio8; i2c0 = &i2c0; i2c1 = &i2c1; i2c2 = &i2c2; i2c3 = &i2c3; i2c4 = &i2c4; i2c5 = &i2c5; - mmc0 = &emmc; - mmc1 = &sdmmc; - mmc2 = &sdio0; - mmc3 = &sdio1; mshc0 = &emmc; mshc1 = &sdmmc; mshc2 = &sdio0; @@ -323,7 +310,6 @@ interrupts = <GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH>; reg-shift = <2>; reg-io-width = <4>; - clock-frequency = <24000000>; clocks = <&cru SCLK_UART0>, <&cru PCLK_UART0>; clock-names = "baudclk", "apb_pclk"; pinctrl-names = "default"; @@ -337,7 +323,6 @@ interrupts = <GIC_SPI 56 IRQ_TYPE_LEVEL_HIGH>; reg-shift = <2>; reg-io-width = <4>; - clock-frequency = <24000000>; clocks = <&cru SCLK_UART1>, <&cru PCLK_UART1>; clock-names = "baudclk", "apb_pclk"; pinctrl-names = "default"; @@ -351,7 +336,6 @@ interrupts = <GIC_SPI 57 IRQ_TYPE_LEVEL_HIGH>; reg-shift = <2>; reg-io-width = <4>; - clock-frequency = <24000000>; clocks = <&cru SCLK_UART2>, <&cru PCLK_UART2>; clock-names = "baudclk", "apb_pclk"; pinctrl-names = "default"; @@ -364,7 +348,6 @@ interrupts = <GIC_SPI 58 IRQ_TYPE_LEVEL_HIGH>; reg-shift = <2>; reg-io-width = <4>; - clock-frequency = <24000000>; clocks = <&cru SCLK_UART3>, <&cru PCLK_UART3>; clock-names = "baudclk", "apb_pclk"; pinctrl-names = "default"; @@ -378,7 +361,6 @@ interrupts = <GIC_SPI 59 IRQ_TYPE_LEVEL_HIGH>; reg-shift = <2>; reg-io-width = <4>; - clock-frequency = <24000000>; clocks = <&cru SCLK_UART4>, <&cru PCLK_UART4>; clock-names = "baudclk", "apb_pclk"; pinctrl-names = "default"; @@ -476,26 +458,6 @@ status = "disabled"; };
- dmc: dmc@ff610000 { - compatible = "rockchip,rk3288-dmc", "syscon"; - rockchip,cru = <&cru>; - rockchip,grf = <&grf>; - rockchip,pmu = <&pmu>; - rockchip,sgrf = <&sgrf>; - rockchip,noc = <&noc>; - reg = <0xff610000 0x3fc - 0xff620000 0x294 - 0xff630000 0x3fc - 0xff640000 0x294>; - rockchip,sram = <&ddr_sram>; - clocks = <&cru PCLK_DDRUPCTL0>, <&cru PCLK_PUBL0>, - <&cru PCLK_DDRUPCTL1>, <&cru PCLK_PUBL1>, - <&cru ARMCLK>; - clock-names = "pclk_ddrupctl0", "pclk_publ0", - "pclk_ddrupctl1", "pclk_publ1", - "arm_clk"; - }; - i2c0: i2c@ff650000 { compatible = "rockchip,rk3288-i2c"; reg = <0xff650000 0x1000>; @@ -570,7 +532,7 @@ status = "disabled"; };
- bus_intmem@ff700000 { + bus_intmem: bus_intmem@ff700000 { compatible = "mmio-sram"; reg = <0xff700000 0x18000>; #address-cells = <1>; @@ -580,10 +542,6 @@ compatible = "rockchip,rk3066-smp-sram"; reg = <0x00 0x10>; }; - ddr_sram: ddr-sram@1000 { - compatible = "rockchip,rk3288-ddr-sram"; - reg = <0x1000 0x4000>; - }; };
sram@ff720000 { @@ -912,11 +870,6 @@ status = "disabled"; };
- noc: syscon@ffac0000 { - compatible = "rockchip,rk3288-noc", "syscon"; - reg = <0xffac0000 0x2000>; - }; - efuse: efuse@ffb40000 { compatible = "rockchip,rk3288-efuse"; reg = <0xffb40000 0x10000>;
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
+&dmc {
0x8 0x1f4>;
0x0 0xc3 0x6 0x2>;
- &pinctrl { u-boot,dm-pre-reloc; };
-&dmc {
0x8 0x1f4>;
0x0 0xc3 0x6 0x2>;
- config {
- leds {
work {
power {
+&dmc {
0x5 0x0>;
- config {
-&dmc {
0x5 0x0>;
&ir {
leds {
work {
power {
- leds {
work {
+&dmc {
0x5 0x0>;
-&dmc {
0x5 0x0>;
leds {
work {
+&dmc {
0x5 0x0>;
+&emmc {
+&i2c0 {
- rk818: pmic@1c {
regulators {
+&pinctrl {
+&sdmmc {
+&uart2 {
-&dmc {
0x5 0x0>;
&pinctrl {
&sdmmc {
&uart2 {
@@ -201,8 +199,6 @@
rk818: pmic@1c {
regulators {
+&dmc {
0x5 0x0>;
-&dmc {
0x5 0x0>;
+&dmc {
0x5 0x0>;
+&gpio7 {
+&pinctrl {
+&sdmmc {
+&uart2 {
&sdmmc {
&pinctrl {
@@ -171,7 +169,6 @@
-&dmc {
0x5 0x0>;
-&gpio7 {
aliases {
gpio0 = &gpio0;
gpio1 = &gpio1;
gpio2 = &gpio2;
gpio3 = &gpio3;
gpio4 = &gpio4;
gpio5 = &gpio5;
gpio6 = &gpio6;
gpio7 = &gpio7;
gpio8 = &gpio8;
mmc0 = &emmc;
mmc1 = &sdmmc;
mmc2 = &sdio0;
mmc3 = &sdio1;
dmc: dmc@ff610000 {
0xff620000 0x294
0xff630000 0x3fc
0xff640000 0x294>;
<&cru ARMCLK>;
"arm_clk";
-&dmc {
+&bus_intmem {
-&vopl {
+&uart0 {
+&uart1 {
- clock-frequency = <24000000>; };
-&noc { +&uart2 {
+&uart3 {
+&dmc {
0x5 0x0>;
-&dmc {
0x5 0x0>;
+&dmc {
0x8 0x1f4>;
0x0 0xc3 0x6 0x2>;
-&dmc {
0x8 0x1f4>;
0x0 0xc3 0x6 0x2>;
+&dmc {
0x8 0x1f4>;
0x0 0xc3 0x6 0x1>;
-&dmc {
0x8 0x1f4>;
0x0 0xc3 0x6 0x1>;
- chosen {
+&dmc {
/* KHz uV */
200000 1050000
333000 1100000
533000 1150000
666000 1200000
+&gpio3 {
- &gpio7 { u-boot,dm-pre-reloc; };
+&gpio8 {
+&i2c0 {
+&pinctrl {
+&rk808 {
+&sdmmc {
+&spi2 {
+&spi_flash {
+&uart2 {
firmware {
-&dmc {
/* KHz uV */
200000 1050000
333000 1100000
533000 1150000
666000 1200000
@@ -557,7 +532,6 @@
&pinctrl {
-&sdmmc {
-&gpio3 {
-&gpio8 {
gpio0 = &gpio0;
gpio1 = &gpio1;
gpio2 = &gpio2;
gpio3 = &gpio3;
gpio4 = &gpio4;
gpio5 = &gpio5;
gpio6 = &gpio6;
gpio7 = &gpio7;
i2c0 = &i2c0; i2c1 = &i2c1; i2c2 = &i2c2; i2c3 = &i2c3; i2c4 = &i2c4; i2c5 = &i2c5;gpio8 = &gpio8;
mmc0 = &emmc;
mmc1 = &sdmmc;
mmc2 = &sdio0;
mshc0 = &emmc; mshc1 = &sdmmc; mshc2 = &sdio0;mmc3 = &sdio1;
clocks = <&cru SCLK_UART0>, <&cru PCLK_UART0>; clock-names = "baudclk", "apb_pclk"; pinctrl-names = "default";clock-frequency = <24000000>;
clocks = <&cru SCLK_UART1>, <&cru PCLK_UART1>; clock-names = "baudclk", "apb_pclk"; pinctrl-names = "default";clock-frequency = <24000000>;
clocks = <&cru SCLK_UART2>, <&cru PCLK_UART2>; clock-names = "baudclk", "apb_pclk"; pinctrl-names = "default";clock-frequency = <24000000>;
clocks = <&cru SCLK_UART3>, <&cru PCLK_UART3>; clock-names = "baudclk", "apb_pclk"; pinctrl-names = "default";clock-frequency = <24000000>;
clocks = <&cru SCLK_UART4>, <&cru PCLK_UART4>; clock-names = "baudclk", "apb_pclk"; pinctrl-names = "default";clock-frequency = <24000000>;
0xff620000 0x294
0xff630000 0x3fc
0xff640000 0x294>;
<&cru ARMCLK>;
"arm_clk";
- bus_intmem: bus_intmem@ff700000 { compatible = "mmio-sram"; reg = <0xff700000 0x18000>; #address-cells = <1>;
sram@ff720000 {
Sync rk3288.dtsi from Linux version 5.17.
Changed V3: change reg size
Changed V2: rename mipi_dsi0 label move io_domains remove hdmi_audio veyron node change memory@0 reg size --- arch/arm/dts/rk3288-evb.dtsi | 2 +- arch/arm/dts/rk3288-miqi.dtsi | 28 +- arch/arm/dts/rk3288-phycore-som.dtsi | 30 +- arch/arm/dts/rk3288-popmetal.dtsi | 30 +- arch/arm/dts/rk3288-thermal.dtsi | 87 -- arch/arm/dts/rk3288-veyron-jerry.dts | 6 - arch/arm/dts/rk3288-veyron.dtsi | 33 +- arch/arm/dts/rk3288.dtsi | 1367 +++++++++++++++++--------- 8 files changed, 970 insertions(+), 613 deletions(-) delete mode 100644 arch/arm/dts/rk3288-thermal.dtsi
diff --git a/arch/arm/dts/rk3288-evb.dtsi b/arch/arm/dts/rk3288-evb.dtsi index 04902c0b..72da8847 100644 --- a/arch/arm/dts/rk3288-evb.dtsi +++ b/arch/arm/dts/rk3288-evb.dtsi @@ -448,7 +448,7 @@ status = "okay"; };
-&mipi_dsi0 { +&mipi_dsi { status = "disabled"; rockchip,panel = <&panel>; display-timings { diff --git a/arch/arm/dts/rk3288-miqi.dtsi b/arch/arm/dts/rk3288-miqi.dtsi index cb80cbf2..b1c286c9 100644 --- a/arch/arm/dts/rk3288-miqi.dtsi +++ b/arch/arm/dts/rk3288-miqi.dtsi @@ -18,21 +18,6 @@ clock-output-names = "ext_gmac"; };
- io_domains: io-domains { - compatible = "rockchip,rk3288-io-voltage-domain"; - rockchip,grf = <&grf>; - - audio-supply = <&vcca_33>; - flash0-supply = <&vcc_flash>; - flash1-supply = <&vcc_lan>; - gpio30-supply = <&vcc_io>; - gpio1830-supply = <&vcc_io>; - lcdc-supply = <&vcc_io>; - sdcard-supply = <&vccio_sd>; - wifi-supply = <&vcc_18>; - }; - - leds { compatible = "gpio-leds";
@@ -277,6 +262,19 @@ status = "okay"; };
+&io_domains { + status = "okay"; + + audio-supply = <&vcca_33>; + flash0-supply = <&vcc_flash>; + flash1-supply = <&vcc_lan>; + gpio30-supply = <&vcc_io>; + gpio1830-supply = <&vcc_io>; + lcdc-supply = <&vcc_io>; + sdcard-supply = <&vccio_sd>; + wifi-supply = <&vcc_18>; +}; + &pinctrl { pcfg_output_high: pcfg-output-high { output-high; diff --git a/arch/arm/dts/rk3288-phycore-som.dtsi b/arch/arm/dts/rk3288-phycore-som.dtsi index 821525f7..8ac695c8 100644 --- a/arch/arm/dts/rk3288-phycore-som.dtsi +++ b/arch/arm/dts/rk3288-phycore-som.dtsi @@ -71,22 +71,6 @@ clock-output-names = "ext_gmac"; };
- io_domains: io_domains { - compatible = "rockchip,rk3288-io-voltage-domain"; - - status = "okay"; - sdcard-supply = <&vdd_io_sd>; - flash0-supply = <&vdd_emmc_io>; - flash1-supply = <&vdd_misc_1v8>; - gpio1830-supply = <&vdd_3v3_io>; - gpio30-supply = <&vdd_3v3_io>; - bb-supply = <&vdd_3v3_io>; - dvp-supply = <&vdd_3v3_io>; - lcdc-supply = <&vdd_3v3_io>; - wifi-supply = <&vdd_3v3_io>; - audio-supply = <&vdd_3v3_io>; - }; - leds: user-leds { compatible = "gpio-leds"; pinctrl-names = "default"; @@ -197,6 +181,20 @@ ddc-i2c-bus = <&i2c5>; };
+&io_domains { + status = "okay"; + sdcard-supply = <&vdd_io_sd>; + flash0-supply = <&vdd_emmc_io>; + flash1-supply = <&vdd_misc_1v8>; + gpio1830-supply = <&vdd_3v3_io>; + gpio30-supply = <&vdd_3v3_io>; + bb-supply = <&vdd_3v3_io>; + dvp-supply = <&vdd_3v3_io>; + lcdc-supply = <&vdd_3v3_io>; + wifi-supply = <&vdd_3v3_io>; + audio-supply = <&vdd_3v3_io>; +}; + &i2c0 { status = "okay"; clock-frequency = <400000>; diff --git a/arch/arm/dts/rk3288-popmetal.dtsi b/arch/arm/dts/rk3288-popmetal.dtsi index 63785eb5..bcd8fded 100644 --- a/arch/arm/dts/rk3288-popmetal.dtsi +++ b/arch/arm/dts/rk3288-popmetal.dtsi @@ -69,22 +69,6 @@ }; };
- io_domains: io-domains { - compatible = "rockchip,rk3288-io-voltage-domain"; - rockchip,grf = <&grf>; - - audio-supply = <&vcca_33>; - bb-supply = <&vcc_io>; - dvp-supply = <&vcc18_dvp>; - flash0-supply = <&vcc_flash>; - flash1-supply = <&vcc_lan>; - gpio30-supply = <&vcc_io>; - gpio1830-supply = <&vcc_io>; - lcdc-supply = <&vcc_io>; - sdcard-supply = <&vccio_sd>; - wifi-supply = <&vccio_wl>; - }; - ir: ir-receiver { compatible = "gpio-ir-receiver"; gpios = <&gpio0 6 GPIO_ACTIVE_LOW>; @@ -441,6 +425,20 @@ status = "okay"; };
+&io_domains { + status = "okay"; + audio-supply = <&vcca_33>; + bb-supply = <&vcc_io>; + dvp-supply = <&vcc18_dvp>; + flash0-supply = <&vcc_flash>; + flash1-supply = <&vcc_lan>; + gpio30-supply = <&vcc_io>; + gpio1830-supply = <&vcc_io>; + lcdc-supply = <&vcc_io>; + sdcard-supply = <&vccio_sd>; + wifi-supply = <&vccio_wl>; +}; + &pinctrl { ak8963 { comp_int: comp-int { diff --git a/arch/arm/dts/rk3288-thermal.dtsi b/arch/arm/dts/rk3288-thermal.dtsi deleted file mode 100644 index 87dd8142..00000000 --- a/arch/arm/dts/rk3288-thermal.dtsi +++ /dev/null @@ -1,87 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Device Tree Source for RK3288 SoC thermal - * - * Copyright (c) 2014, Fuzhou Rockchip Electronics Co., Ltd - */ - -#include <dt-bindings/thermal/thermal.h> - -reserve_thermal: reserve_thermal { - polling-delay-passive = <1000>; /* milliseconds */ - polling-delay = <5000>; /* milliseconds */ - - /* sensor ID */ - thermal-sensors = <&tsadc 0>; - -}; - -cpu_thermal: cpu_thermal { - polling-delay-passive = <100>; /* milliseconds */ - polling-delay = <5000>; /* milliseconds */ - - /* sensor ID */ - thermal-sensors = <&tsadc 1>; - linux,hwmon; - - trips { - cpu_alert0: cpu_alert0 { - temperature = <70000>; /* millicelsius */ - hysteresis = <2000>; /* millicelsius */ - type = "passive"; - }; - cpu_alert1: cpu_alert1 { - temperature = <75000>; /* millicelsius */ - hysteresis = <2000>; /* millicelsius */ - type = "passive"; - }; - cpu_crit: cpu_crit { - temperature = <100000>; /* millicelsius */ - hysteresis = <2000>; /* millicelsius */ - type = "critical"; - }; - }; - - cooling-maps { - map0 { - trip = <&cpu_alert0>; - cooling-device = - <&cpu0 THERMAL_NO_LIMIT 6>; - }; - map1 { - trip = <&cpu_alert1>; - cooling-device = - <&cpu0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; - }; - }; -}; - -gpu_thermal: gpu_thermal { - polling-delay-passive = <100>; /* milliseconds */ - polling-delay = <5000>; /* milliseconds */ - - /* sensor ID */ - thermal-sensors = <&tsadc 2>; - linux,hwmon; - - trips { - gpu_alert0: gpu_alert0 { - temperature = <80000>; /* millicelsius */ - hysteresis = <2000>; /* millicelsius */ - type = "passive"; - }; - gpu_crit: gpu_crit { - temperature = <100000>; /* millicelsius */ - hysteresis = <2000>; /* millicelsius */ - type = "critical"; - }; - }; - - cooling-maps { - map0 { - trip = <&gpu_alert0>; - cooling-device = - <&cpu0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; - }; - }; -}; diff --git a/arch/arm/dts/rk3288-veyron-jerry.dts b/arch/arm/dts/rk3288-veyron-jerry.dts index ff7669eb..40fee55c 100644 --- a/arch/arm/dts/rk3288-veyron-jerry.dts +++ b/arch/arm/dts/rk3288-veyron-jerry.dts @@ -137,12 +137,6 @@ }; };
- edp { - edp_hpd: edp_hpd { - rockchip,pins = <7 11 RK_FUNC_2 &pcfg_pull_down>; - }; - }; - emmc { /* Make sure eMMC is not in reset */ emmc_deassert_reset: emmc-deassert-reset { diff --git a/arch/arm/dts/rk3288-veyron.dtsi b/arch/arm/dts/rk3288-veyron.dtsi index 4a9c27a4..ac9e815e 100644 --- a/arch/arm/dts/rk3288-veyron.dtsi +++ b/arch/arm/dts/rk3288-veyron.dtsi @@ -198,21 +198,6 @@ /* Faux input supply. See bt_regulator description. */ vin-supply = <&bt_regulator>; }; - - io-domains { - compatible = "rockchip,rk3288-io-voltage-domain"; - rockchip,grf = <&grf>; - - audio-supply = <&vcc18_codec>; - bb-supply = <&vcc33_io>; - dvp-supply = <&vcc_18>; - flash0-supply = <&vcc18_flashio>; - gpio1830-supply = <&vcc33_io>; - gpio30-supply = <&vcc33_io>; - lcdc-supply = <&vcc33_lcd>; - sdcard-supply = <&vccio_sd>; - wifi-supply = <&vcc18_wl>; - }; };
&cpu0 { @@ -503,6 +488,20 @@ clocks = <&cru HCLK_I2S0>, <&cru SCLK_I2S0>, <&cru SCLK_I2S0_OUT>; };
+&io_domains { + status = "okay"; + + audio-supply = <&vcc18_codec>; + bb-supply = <&vcc33_io>; + dvp-supply = <&vcc_18>; + flash0-supply = <&vcc18_flashio>; + gpio1830-supply = <&vcc33_io>; + gpio30-supply = <&vcc33_io>; + lcdc-supply = <&vcc33_lcd>; + sdcard-supply = <&vccio_sd>; + wifi-supply = <&vcc18_wl>; +}; + &wdt { status = "okay"; }; @@ -560,10 +559,6 @@ status = "okay"; };
-&hdmi_audio { - status = "okay"; -}; - &gpu { status = "okay"; }; diff --git a/arch/arm/dts/rk3288.dtsi b/arch/arm/dts/rk3288.dtsi index c4abfa37..14a3f8e8 100644 --- a/arch/arm/dts/rk3288.dtsi +++ b/arch/arm/dts/rk3288.dtsi @@ -1,4 +1,4 @@ -// SPDX-License-Identifier: GPL-2.0+ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT)
#include <dt-bindings/gpio/gpio.h> #include <dt-bindings/interrupt-controller/irq.h> @@ -7,14 +7,18 @@ #include <dt-bindings/clock/rk3288-cru.h> #include <dt-bindings/power/rk3288-power.h> #include <dt-bindings/thermal/thermal.h> -#include <dt-bindings/video/rk3288.h> -#include "skeleton.dtsi" +#include <dt-bindings/soc/rockchip,boot-mode.h>
/ { + #address-cells = <1>; + #size-cells = <1>; + compatible = "rockchip,rk3288";
interrupt-parent = <&gic>; + aliases { + ethernet0 = &gmac; i2c0 = &i2c0; i2c1 = &i2c1; i2c2 = &i2c2; @@ -35,6 +39,15 @@ spi2 = &spi2; };
+ arm-pmu { + compatible = "arm,cortex-a12-pmu"; + interrupts = <GIC_SPI 151 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 152 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 153 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 154 IRQ_TYPE_LEVEL_HIGH>; + interrupt-affinity = <&cpu0>, <&cpu1>, <&cpu2>, <&cpu3>; + }; + cpus { #address-cells = <1>; #size-cells = <0>; @@ -45,85 +58,119 @@ device_type = "cpu"; compatible = "arm,cortex-a12"; reg = <0x500>; - operating-points = < - /* KHz uV */ - 1800000 1400000 - 1704000 1350000 - 1608000 1300000 - 1512000 1250000 - 1416000 1200000 - 1200000 1100000 - 1008000 1050000 - 816000 1000000 - 696000 950000 - 600000 900000 - 408000 900000 - 216000 900000 - 126000 900000 - >; + resets = <&cru SRST_CORE0>; + operating-points-v2 = <&cpu_opp_table>; #cooling-cells = <2>; /* min followed by max */ clock-latency = <40000>; clocks = <&cru ARMCLK>; - resets = <&cru SRST_CORE0>; + dynamic-power-coefficient = <370>; }; - cpu@501 { + cpu1: cpu@501 { device_type = "cpu"; compatible = "arm,cortex-a12"; reg = <0x501>; resets = <&cru SRST_CORE1>; + operating-points-v2 = <&cpu_opp_table>; + #cooling-cells = <2>; /* min followed by max */ + clock-latency = <40000>; + clocks = <&cru ARMCLK>; + dynamic-power-coefficient = <370>; }; - cpu@502 { + cpu2: cpu@502 { device_type = "cpu"; compatible = "arm,cortex-a12"; reg = <0x502>; resets = <&cru SRST_CORE2>; + operating-points-v2 = <&cpu_opp_table>; + #cooling-cells = <2>; /* min followed by max */ + clock-latency = <40000>; + clocks = <&cru ARMCLK>; + dynamic-power-coefficient = <370>; }; - cpu@503 { + cpu3: cpu@503 { device_type = "cpu"; compatible = "arm,cortex-a12"; reg = <0x503>; resets = <&cru SRST_CORE3>; + operating-points-v2 = <&cpu_opp_table>; + #cooling-cells = <2>; /* min followed by max */ + clock-latency = <40000>; + clocks = <&cru ARMCLK>; + dynamic-power-coefficient = <370>; }; };
- amba { - compatible = "arm,amba-bus"; + cpu_opp_table: opp-table-0 { + compatible = "operating-points-v2"; + opp-shared; + + opp-126000000 { + opp-hz = /bits/ 64 <126000000>; + opp-microvolt = <900000>; + }; + opp-216000000 { + opp-hz = /bits/ 64 <216000000>; + opp-microvolt = <900000>; + }; + opp-312000000 { + opp-hz = /bits/ 64 <312000000>; + opp-microvolt = <900000>; + }; + opp-408000000 { + opp-hz = /bits/ 64 <408000000>; + opp-microvolt = <900000>; + }; + opp-600000000 { + opp-hz = /bits/ 64 <600000000>; + opp-microvolt = <900000>; + }; + opp-696000000 { + opp-hz = /bits/ 64 <696000000>; + opp-microvolt = <950000>; + }; + opp-816000000 { + opp-hz = /bits/ 64 <816000000>; + opp-microvolt = <1000000>; + }; + opp-1008000000 { + opp-hz = /bits/ 64 <1008000000>; + opp-microvolt = <1050000>; + }; + opp-1200000000 { + opp-hz = /bits/ 64 <1200000000>; + opp-microvolt = <1100000>; + }; + opp-1416000000 { + opp-hz = /bits/ 64 <1416000000>; + opp-microvolt = <1200000>; + }; + opp-1512000000 { + opp-hz = /bits/ 64 <1512000000>; + opp-microvolt = <1300000>; + }; + opp-1608000000 { + opp-hz = /bits/ 64 <1608000000>; + opp-microvolt = <1350000>; + }; + }; + + reserved-memory { #address-cells = <1>; #size-cells = <1>; ranges;
- dmac_peri: dma-controller@ff250000 { - compatible = "arm,pl330", "arm,primecell"; - broken-no-flushp; - reg = <0xff250000 0x4000>; - interrupts = <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>; - #dma-cells = <1>; - clocks = <&cru ACLK_DMAC2>; - clock-names = "apb_pclk"; - }; - - dmac_bus_ns: dma-controller@ff600000 { - compatible = "arm,pl330", "arm,primecell"; - broken-no-flushp; - reg = <0xff600000 0x4000>; - interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>; - #dma-cells = <1>; - clocks = <&cru ACLK_DMAC1>; - clock-names = "apb_pclk"; - status = "disabled"; - }; - - dmac_bus_s: dma-controller@ffb20000 { - compatible = "arm,pl330", "arm,primecell"; - broken-no-flushp; - reg = <0xffb20000 0x4000>; - interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>; - #dma-cells = <1>; - clocks = <&cru ACLK_DMAC1>; - clock-names = "apb_pclk"; + /* + * The rk3288 cannot use the memory area above 0xfe000000 + * for dma operations for some reason. While there is + * probably a better solution available somewhere, we + * haven't found it yet and while devices with 2GB of ram + * are not affected, this issue prevents 4GB from booting. + * So to make these devices at least bootable, block + * this area for the time being until the real solution + * is found. + */ + dma-unusable@fe000000 { + reg = <0xfe000000 0x1000000>; }; };
@@ -135,14 +182,22 @@ };
timer { - arm,use-physical-timer; compatible = "arm,armv7-timer"; + arm,cpu-registers-not-fw-configured; interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>, <GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>, <GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>, <GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>; clock-frequency = <24000000>; - always-on; + arm,no-tick-in-suspend; + }; + + timer: timer@ff810000 { + compatible = "rockchip,rk3288-timer"; + reg = <0xff810000 0x20>; + interrupts = <GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru PCLK_TIMER>, <&xin24m>; + clock-names = "pclk", "timer"; };
display-subsystem { @@ -150,51 +205,59 @@ ports = <&vopl_out>, <&vopb_out>; };
- sdmmc: dwmmc@ff0c0000 { + sdmmc: mmc@ff0c0000 { compatible = "rockchip,rk3288-dw-mshc"; max-frequency = <150000000>; clocks = <&cru HCLK_SDMMC>, <&cru SCLK_SDMMC>, <&cru SCLK_SDMMC_DRV>, <&cru SCLK_SDMMC_SAMPLE>; - clock-names = "biu", "ciu", "ciu_drv", "ciu_sample"; + clock-names = "biu", "ciu", "ciu-drive", "ciu-sample"; fifo-depth = <0x100>; interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>; reg = <0xff0c0000 0x4000>; + resets = <&cru SRST_MMC0>; + reset-names = "reset"; status = "disabled"; };
- sdio0: dwmmc@ff0d0000 { + sdio0: mmc@ff0d0000 { compatible = "rockchip,rk3288-dw-mshc"; max-frequency = <150000000>; clocks = <&cru HCLK_SDIO0>, <&cru SCLK_SDIO0>, <&cru SCLK_SDIO0_DRV>, <&cru SCLK_SDIO0_SAMPLE>; - clock-names = "biu", "ciu", "ciu_drv", "ciu_sample"; + clock-names = "biu", "ciu", "ciu-drive", "ciu-sample"; fifo-depth = <0x100>; interrupts = <GIC_SPI 33 IRQ_TYPE_LEVEL_HIGH>; reg = <0xff0d0000 0x4000>; + resets = <&cru SRST_SDIO0>; + reset-names = "reset"; status = "disabled"; };
- sdio1: dwmmc@ff0e0000 { + sdio1: mmc@ff0e0000 { compatible = "rockchip,rk3288-dw-mshc"; max-frequency = <150000000>; clocks = <&cru HCLK_SDIO1>, <&cru SCLK_SDIO1>, <&cru SCLK_SDIO1_DRV>, <&cru SCLK_SDIO1_SAMPLE>; - clock-names = "biu", "ciu", "ciu_drv", "ciu_sample"; + clock-names = "biu", "ciu", "ciu-drive", "ciu-sample"; fifo-depth = <0x100>; interrupts = <GIC_SPI 34 IRQ_TYPE_LEVEL_HIGH>; reg = <0xff0e0000 0x4000>; + resets = <&cru SRST_SDIO1>; + reset-names = "reset"; status = "disabled"; };
- emmc: dwmmc@ff0f0000 { + emmc: mmc@ff0f0000 { compatible = "rockchip,rk3288-dw-mshc"; max-frequency = <150000000>; clocks = <&cru HCLK_EMMC>, <&cru SCLK_EMMC>, <&cru SCLK_EMMC_DRV>, <&cru SCLK_EMMC_SAMPLE>; - clock-names = "biu", "ciu", "ciu_drv", "ciu_sample"; + clock-names = "biu", "ciu", "ciu-drive", "ciu-sample"; fifo-depth = <0x100>; interrupts = <GIC_SPI 35 IRQ_TYPE_LEVEL_HIGH>; reg = <0xff0f0000 0x4000>; + resets = <&cru SRST_EMMC>; + reset-names = "reset"; status = "disabled"; };
@@ -205,6 +268,8 @@ #io-channel-cells = <1>; clocks = <&cru SCLK_SARADC>, <&cru PCLK_SARADC>; clock-names = "saradc", "apb_pclk"; + resets = <&cru SRST_SARADC>; + reset-names = "saradc-apb"; status = "disabled"; };
@@ -304,6 +369,7 @@ pinctrl-0 = <&i2c5_xfer>; status = "disabled"; }; + uart0: serial@ff180000 { compatible = "rockchip,rk3288-uart", "snps,dw-apb-uart"; reg = <0xff180000 0x100>; @@ -312,6 +378,8 @@ reg-io-width = <4>; clocks = <&cru SCLK_UART0>, <&cru PCLK_UART0>; clock-names = "baudclk", "apb_pclk"; + dmas = <&dmac_peri 1>, <&dmac_peri 2>; + dma-names = "tx", "rx"; pinctrl-names = "default"; pinctrl-0 = <&uart0_xfer>; status = "disabled"; @@ -325,6 +393,8 @@ reg-io-width = <4>; clocks = <&cru SCLK_UART1>, <&cru PCLK_UART1>; clock-names = "baudclk", "apb_pclk"; + dmas = <&dmac_peri 3>, <&dmac_peri 4>; + dma-names = "tx", "rx"; pinctrl-names = "default"; pinctrl-0 = <&uart1_xfer>; status = "disabled"; @@ -342,6 +412,7 @@ pinctrl-0 = <&uart2_xfer>; status = "disabled"; }; + uart3: serial@ff1b0000 { compatible = "rockchip,rk3288-uart", "snps,dw-apb-uart"; reg = <0xff1b0000 0x100>; @@ -350,6 +421,8 @@ reg-io-width = <4>; clocks = <&cru SCLK_UART3>, <&cru PCLK_UART3>; clock-names = "baudclk", "apb_pclk"; + dmas = <&dmac_peri 7>, <&dmac_peri 8>; + dma-names = "tx", "rx"; pinctrl-names = "default"; pinctrl-0 = <&uart3_xfer>; status = "disabled"; @@ -363,12 +436,104 @@ reg-io-width = <4>; clocks = <&cru SCLK_UART4>, <&cru PCLK_UART4>; clock-names = "baudclk", "apb_pclk"; + dmas = <&dmac_peri 9>, <&dmac_peri 10>; + dma-names = "tx", "rx"; pinctrl-names = "default"; pinctrl-0 = <&uart4_xfer>; status = "disabled"; }; - thermal: thermal-zones { - #include "rk3288-thermal.dtsi" + + dmac_peri: dma-controller@ff250000 { + compatible = "arm,pl330", "arm,primecell"; + reg = <0xff250000 0x4000>; + interrupts = <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>; + #dma-cells = <1>; + arm,pl330-broken-no-flushp; + arm,pl330-periph-burst; + clocks = <&cru ACLK_DMAC2>; + clock-names = "apb_pclk"; + }; + + thermal-zones { + reserve_thermal: reserve-thermal { + polling-delay-passive = <1000>; /* milliseconds */ + polling-delay = <5000>; /* milliseconds */ + + thermal-sensors = <&tsadc 0>; + }; + + cpu_thermal: cpu-thermal { + polling-delay-passive = <100>; /* milliseconds */ + polling-delay = <5000>; /* milliseconds */ + + thermal-sensors = <&tsadc 1>; + + trips { + cpu_alert0: cpu_alert0 { + temperature = <70000>; /* millicelsius */ + hysteresis = <2000>; /* millicelsius */ + type = "passive"; + }; + cpu_alert1: cpu_alert1 { + temperature = <75000>; /* millicelsius */ + hysteresis = <2000>; /* millicelsius */ + type = "passive"; + }; + cpu_crit: cpu_crit { + temperature = <90000>; /* millicelsius */ + hysteresis = <2000>; /* millicelsius */ + type = "critical"; + }; + }; + + cooling-maps { + map0 { + trip = <&cpu_alert0>; + cooling-device = + <&cpu0 THERMAL_NO_LIMIT 6>, + <&cpu1 THERMAL_NO_LIMIT 6>, + <&cpu2 THERMAL_NO_LIMIT 6>, + <&cpu3 THERMAL_NO_LIMIT 6>; + }; + map1 { + trip = <&cpu_alert1>; + cooling-device = + <&cpu0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&cpu1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&cpu2 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&cpu3 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + }; + }; + }; + + gpu_thermal: gpu-thermal { + polling-delay-passive = <100>; /* milliseconds */ + polling-delay = <5000>; /* milliseconds */ + + thermal-sensors = <&tsadc 2>; + + trips { + gpu_alert0: gpu_alert0 { + temperature = <70000>; /* millicelsius */ + hysteresis = <2000>; /* millicelsius */ + type = "passive"; + }; + gpu_crit: gpu_crit { + temperature = <90000>; /* millicelsius */ + hysteresis = <2000>; /* millicelsius */ + type = "critical"; + }; + }; + + cooling-maps { + map0 { + trip = <&gpu_alert0>; + cooling-device = + <&gpu THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + }; + }; + }; };
tsadc: tsadc@ff280000 { @@ -379,18 +544,22 @@ clock-names = "tsadc", "apb_pclk"; resets = <&cru SRST_TSADC>; reset-names = "tsadc-apb"; - pinctrl-names = "otp_out"; - pinctrl-0 = <&otp_out>; + pinctrl-names = "init", "default", "sleep"; + pinctrl-0 = <&otp_pin>; + pinctrl-1 = <&otp_out>; + pinctrl-2 = <&otp_pin>; #thermal-sensor-cells = <1>; - hw-shut-temp = <125000>; + rockchip,grf = <&grf>; + rockchip,hw-tshut-temp = <95000>; status = "disabled"; };
gmac: ethernet@ff290000 { compatible = "rockchip,rk3288-gmac"; reg = <0xff290000 0x10000>; - interrupts = <GIC_SPI 27 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "macirq"; + interrupts = <GIC_SPI 27 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 28 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "macirq", "eth_wake_irq"; rockchip,grf = <&grf>; clocks = <&cru SCLK_MAC>, <&cru SCLK_MAC_RX>, <&cru SCLK_MAC_TX>, @@ -400,6 +569,9 @@ "mac_clk_rx", "mac_clk_tx", "clk_mac_ref", "clk_mac_refout", "aclk_mac", "pclk_mac"; + resets = <&cru SRST_MAC>; + reset-names = "stmmaceth"; + status = "disabled"; };
usb_host0_ehci: usb@ff500000 { @@ -407,16 +579,15 @@ reg = <0xff500000 0x100>; interrupts = <GIC_SPI 24 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cru HCLK_USBHOST0>; - clock-names = "usbhost"; phys = <&usbphy1>; phy-names = "usb"; status = "disabled"; };
- /* NOTE: doesn't work on RK3288, but fixed on RK3288W */ + /* NOTE: doesn't work on RK3288, but was fixed on RK3288W */ usb_host0_ohci: usb@ff520000 { compatible = "generic-ohci"; - reg = <0x0 0xff520000 0x0 0x100>; + reg = <0xff520000 0x100>; interrupts = <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cru HCLK_USBHOST0>; phys = <&usbphy1>; @@ -431,8 +602,10 @@ interrupts = <GIC_SPI 25 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cru HCLK_USBHOST1>; clock-names = "otg"; + dr_mode = "host"; phys = <&usbphy2>; phy-names = "usb2-phy"; + snps,reset-phy-on-wake; status = "disabled"; };
@@ -444,6 +617,9 @@ clocks = <&cru HCLK_OTG0>; clock-names = "otg"; dr_mode = "otg"; + g-np-tx-fifo-size = <16>; + g-rx-fifo-size = <275>; + g-tx-fifo-size = <256 128 128 64 64 32>; phys = <&usbphy0>; phy-names = "usb2-phy"; status = "disabled"; @@ -454,7 +630,19 @@ reg = <0xff5c0000 0x100>; interrupts = <GIC_SPI 26 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cru HCLK_HSIC>; - clock-names = "usbhost"; + status = "disabled"; + }; + + dmac_bus_ns: dma-controller@ff600000 { + compatible = "arm,pl330", "arm,primecell"; + reg = <0xff600000 0x4000>; + interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>; + #dma-cells = <1>; + arm,pl330-broken-no-flushp; + arm,pl330-periph-burst; + clocks = <&cru ACLK_DMAC1>; + clock-names = "apb_pclk"; status = "disabled"; };
@@ -490,9 +678,7 @@ #pwm-cells = <3>; pinctrl-names = "default"; pinctrl-0 = <&pwm0_pin>; - clocks = <&cru PCLK_PWM>; - clock-names = "pwm"; - rockchip,grf = <&grf>; + clocks = <&cru PCLK_RKPWM>; status = "disabled"; };
@@ -502,9 +688,7 @@ #pwm-cells = <3>; pinctrl-names = "default"; pinctrl-0 = <&pwm1_pin>; - clocks = <&cru PCLK_PWM>; - clock-names = "pwm"; - rockchip,grf = <&grf>; + clocks = <&cru PCLK_RKPWM>; status = "disabled"; };
@@ -514,25 +698,21 @@ #pwm-cells = <3>; pinctrl-names = "default"; pinctrl-0 = <&pwm2_pin>; - clocks = <&cru PCLK_PWM>; - clock-names = "pwm"; - rockchip,grf = <&grf>; + clocks = <&cru PCLK_RKPWM>; status = "disabled"; };
pwm3: pwm@ff680030 { compatible = "rockchip,rk3288-pwm"; reg = <0xff680030 0x10>; - #pwm-cells = <2>; + #pwm-cells = <3>; pinctrl-names = "default"; pinctrl-0 = <&pwm3_pin>; - clocks = <&cru PCLK_PWM>; - clock-names = "pwm"; - rockchip,grf = <&grf>; + clocks = <&cru PCLK_RKPWM>; status = "disabled"; };
- bus_intmem: bus_intmem@ff700000 { + bus_intmem: sram@ff700000 { compatible = "mmio-sram"; reg = <0xff700000 0x18000>; #address-cells = <1>; @@ -544,14 +724,134 @@ }; };
- sram@ff720000 { + pmu_sram: sram@ff720000 { compatible = "rockchip,rk3288-pmu-sram", "mmio-sram"; reg = <0xff720000 0x1000>; };
pmu: power-management@ff730000 { - compatible = "rockchip,rk3288-pmu", "syscon"; + compatible = "rockchip,rk3288-pmu", "syscon", "simple-mfd"; reg = <0xff730000 0x100>; + + power: power-controller { + compatible = "rockchip,rk3288-power-controller"; + #power-domain-cells = <1>; + #address-cells = <1>; + #size-cells = <0>; + + assigned-clocks = <&cru SCLK_EDP_24M>; + assigned-clock-parents = <&xin24m>; + + /* + * Note: Although SCLK_* are the working clocks + * of device without including on the NOC, needed for + * synchronous reset. + * + * The clocks on the which NOC: + * ACLK_IEP/ACLK_VIP/ACLK_VOP0 are on ACLK_VIO0_NIU. + * ACLK_ISP/ACLK_VOP1 are on ACLK_VIO1_NIU. + * ACLK_RGA is on ACLK_RGA_NIU. + * The others (HCLK_*,PLCK_*) are on HCLK_VIO_NIU. + * + * Which clock are device clocks: + * clocks devices + * *_IEP IEP:Image Enhancement Processor + * *_ISP ISP:Image Signal Processing + * *_VIP VIP:Video Input Processor + * *_VOP* VOP:Visual Output Processor + * *_RGA RGA + * *_EDP* EDP + * *_LVDS_* LVDS + * *_HDMI HDMI + * *_MIPI_* MIPI + */ + power-domain@RK3288_PD_VIO { + reg = <RK3288_PD_VIO>; + clocks = <&cru ACLK_IEP>, + <&cru ACLK_ISP>, + <&cru ACLK_RGA>, + <&cru ACLK_VIP>, + <&cru ACLK_VOP0>, + <&cru ACLK_VOP1>, + <&cru DCLK_VOP0>, + <&cru DCLK_VOP1>, + <&cru HCLK_IEP>, + <&cru HCLK_ISP>, + <&cru HCLK_RGA>, + <&cru HCLK_VIP>, + <&cru HCLK_VOP0>, + <&cru HCLK_VOP1>, + <&cru PCLK_EDP_CTRL>, + <&cru PCLK_HDMI_CTRL>, + <&cru PCLK_LVDS_PHY>, + <&cru PCLK_MIPI_CSI>, + <&cru PCLK_MIPI_DSI0>, + <&cru PCLK_MIPI_DSI1>, + <&cru SCLK_EDP_24M>, + <&cru SCLK_EDP>, + <&cru SCLK_ISP_JPE>, + <&cru SCLK_ISP>, + <&cru SCLK_RGA>; + pm_qos = <&qos_vio0_iep>, + <&qos_vio1_vop>, + <&qos_vio1_isp_w0>, + <&qos_vio1_isp_w1>, + <&qos_vio0_vop>, + <&qos_vio0_vip>, + <&qos_vio2_rga_r>, + <&qos_vio2_rga_w>, + <&qos_vio1_isp_r>; + #power-domain-cells = <0>; + }; + + /* + * Note: The following 3 are HEVC(H.265) clocks, + * and on the ACLK_HEVC_NIU (NOC). + */ + power-domain@RK3288_PD_HEVC { + reg = <RK3288_PD_HEVC>; + clocks = <&cru ACLK_HEVC>, + <&cru SCLK_HEVC_CABAC>, + <&cru SCLK_HEVC_CORE>; + pm_qos = <&qos_hevc_r>, + <&qos_hevc_w>; + #power-domain-cells = <0>; + }; + + /* + * Note: ACLK_VCODEC/HCLK_VCODEC are VCODEC + * (video endecoder & decoder) clocks that on the + * ACLK_VCODEC_NIU and HCLK_VCODEC_NIU (NOC). + */ + power-domain@RK3288_PD_VIDEO { + reg = <RK3288_PD_VIDEO>; + clocks = <&cru ACLK_VCODEC>, + <&cru HCLK_VCODEC>; + pm_qos = <&qos_video>; + #power-domain-cells = <0>; + }; + + /* + * Note: ACLK_GPU is the GPU clock, + * and on the ACLK_GPU_NIU (NOC). + */ + power-domain@RK3288_PD_GPU { + reg = <RK3288_PD_GPU>; + clocks = <&cru ACLK_GPU>; + pm_qos = <&qos_gpu_r>, + <&qos_gpu_w>; + #power-domain-cells = <0>; + }; + }; + + reboot-mode { + compatible = "syscon-reboot-mode"; + offset = <0x94>; + mode-normal = <BOOT_NORMAL>; + mode-recovery = <BOOT_RECOVERY>; + mode-bootloader = <BOOT_FASTBOOT>; + mode-loader = <BOOT_BL_DOWNLOAD>; + }; };
sgrf: syscon@ff740000 { @@ -578,15 +878,65 @@ };
grf: syscon@ff770000 { - compatible = "rockchip,rk3288-grf", "syscon"; + compatible = "rockchip,rk3288-grf", "syscon", "simple-mfd"; reg = <0xff770000 0x1000>; + + edp_phy: edp-phy { + compatible = "rockchip,rk3288-dp-phy"; + clocks = <&cru SCLK_EDP_24M>; + clock-names = "24m"; + #phy-cells = <0>; + status = "disabled"; + }; + + io_domains: io-domains { + compatible = "rockchip,rk3288-io-voltage-domain"; + status = "disabled"; + }; + + usbphy: usbphy { + compatible = "rockchip,rk3288-usb-phy"; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + + usbphy0: usb-phy@320 { + #phy-cells = <0>; + reg = <0x320>; + clocks = <&cru SCLK_OTGPHY0>; + clock-names = "phyclk"; + #clock-cells = <0>; + resets = <&cru SRST_USBOTG_PHY>; + reset-names = "phy-reset"; + }; + + usbphy1: usb-phy@334 { + #phy-cells = <0>; + reg = <0x334>; + clocks = <&cru SCLK_OTGPHY1>; + clock-names = "phyclk"; + #clock-cells = <0>; + resets = <&cru SRST_USBHOST0_PHY>; + reset-names = "phy-reset"; + }; + + usbphy2: usb-phy@348 { + #phy-cells = <0>; + reg = <0x348>; + clocks = <&cru SCLK_OTGPHY2>; + clock-names = "phyclk"; + #clock-cells = <0>; + resets = <&cru SRST_USBHOST1_PHY>; + reset-names = "phy-reset"; + }; + }; };
wdt: watchdog@ff800000 { compatible = "rockchip,rk3288-wdt", "snps,dw-wdt"; reg = <0xff800000 0x100>; clocks = <&cru PCLK_WDT>; - interrupts = <GIC_SPI 111 IRQ_TYPE_LEVEL_HIGH>; + interrupts = <GIC_SPI 79 IRQ_TYPE_LEVEL_HIGH>; status = "disabled"; };
@@ -594,11 +944,11 @@ compatible = "rockchip,rk3288-spdif", "rockchip,rk3066-spdif"; reg = <0xff8b0000 0x10000>; #sound-dai-cells = <0>; - clock-names = "hclk", "mclk"; - clocks = <&cru HCLK_SPDIF8CH>, <&cru SCLK_SPDIF8CH>; + clocks = <&cru SCLK_SPDIF8CH>, <&cru HCLK_SPDIF8CH>; + clock-names = "mclk", "hclk"; dmas = <&dmac_bus_s 3>; dma-names = "tx"; - interrupts = <GIC_SPI 85 IRQ_TYPE_LEVEL_HIGH>; + interrupts = <GIC_SPI 54 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&spdif_tx>; rockchip,grf = <&grf>; @@ -608,50 +958,97 @@ i2s: i2s@ff890000 { compatible = "rockchip,rk3288-i2s", "rockchip,rk3066-i2s"; reg = <0xff890000 0x10000>; - interrupts = <GIC_SPI 85 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - #sound-dai-cells = <1>; + #sound-dai-cells = <0>; + interrupts = <GIC_SPI 53 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru SCLK_I2S0>, <&cru HCLK_I2S0>; + clock-names = "i2s_clk", "i2s_hclk"; dmas = <&dmac_bus_s 0>, <&dmac_bus_s 1>; dma-names = "tx", "rx"; - clock-names = "i2s_hclk", "i2s_clk"; - clocks = <&cru HCLK_I2S0>, <&cru SCLK_I2S0>; pinctrl-names = "default"; pinctrl-0 = <&i2s0_bus>; + rockchip,playback-channels = <8>; + rockchip,capture-channels = <2>; + status = "disabled"; + }; + + crypto: cypto-controller@ff8a0000 { + compatible = "rockchip,rk3288-crypto"; + reg = <0xff8a0000 0x4000>; + interrupts = <GIC_SPI 48 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru ACLK_CRYPTO>, <&cru HCLK_CRYPTO>, + <&cru SCLK_CRYPTO>, <&cru ACLK_DMAC1>; + clock-names = "aclk", "hclk", "sclk", "apb_pclk"; + resets = <&cru SRST_CRYPTO>; + reset-names = "crypto-rst"; + }; + + iep_mmu: iommu@ff900800 { + compatible = "rockchip,iommu"; + reg = <0xff900800 0x40>; + interrupts = <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru ACLK_IEP>, <&cru HCLK_IEP>; + clock-names = "aclk", "iface"; + #iommu-cells = <0>; + status = "disabled"; + }; + + isp_mmu: iommu@ff914000 { + compatible = "rockchip,iommu"; + reg = <0xff914000 0x100>, <0xff915000 0x100>; + interrupts = <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru ACLK_ISP>, <&cru HCLK_ISP>; + clock-names = "aclk", "iface"; + #iommu-cells = <0>; + rockchip,disable-mmu-reset; status = "disabled"; };
+ rga: rga@ff920000 { + compatible = "rockchip,rk3288-rga"; + reg = <0xff920000 0x180>; + interrupts = <GIC_SPI 18 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru ACLK_RGA>, <&cru HCLK_RGA>, <&cru SCLK_RGA>; + clock-names = "aclk", "hclk", "sclk"; + power-domains = <&power RK3288_PD_VIO>; + resets = <&cru SRST_RGA_CORE>, <&cru SRST_RGA_AXI>, <&cru SRST_RGA_AHB>; + reset-names = "core", "axi", "ahb"; + }; + vopb: vop@ff930000 { compatible = "rockchip,rk3288-vop"; - reg = <0xff930000 0x19c>; + reg = <0xff930000 0x19c>, <0xff931000 0x1000>; interrupts = <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cru ACLK_VOP0>, <&cru DCLK_VOP0>, <&cru HCLK_VOP0>; clock-names = "aclk_vop", "dclk_vop", "hclk_vop"; + power-domains = <&power RK3288_PD_VIO>; resets = <&cru SRST_LCDC0_AXI>, <&cru SRST_LCDC0_AHB>, <&cru SRST_LCDC0_DCLK>; reset-names = "axi", "ahb", "dclk"; iommus = <&vopb_mmu>; - power-domains = <&power RK3288_PD_VIO>; status = "disabled"; + vopb_out: port { #address-cells = <1>; #size-cells = <0>; - vopb_out_edp: endpoint@0 { + + vopb_out_hdmi: endpoint@0 { reg = <0>; - remote-endpoint = <&edp_in_vopb>; + remote-endpoint = <&hdmi_in_vopb>; }; - vopb_out_hdmi: endpoint@1 { + + vopb_out_edp: endpoint@1 { reg = <1>; - remote-endpoint = <&hdmi_in_vopb>; + remote-endpoint = <&edp_in_vopb>; }; - vopb_out_lvds: endpoint@2 { + + vopb_out_mipi: endpoint@2 { reg = <2>; - remote-endpoint = <&lvds_in_vopb>; - }; - vopb_out_mipi: endpoint@3 { - reg = <3>; remote-endpoint = <&mipi_in_vopb>; };
+ vopb_out_lvds: endpoint@3 { + reg = <3>; + remote-endpoint = <&lvds_in_vopb>; + }; }; };
@@ -659,7 +1056,8 @@ compatible = "rockchip,iommu"; reg = <0xff930300 0x100>; interrupts = <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "vopb_mmu"; + clocks = <&cru ACLK_VOP0>, <&cru HCLK_VOP0>; + clock-names = "aclk", "iface"; power-domains = <&power RK3288_PD_VIO>; #iommu-cells = <0>; status = "disabled"; @@ -667,35 +1065,39 @@
vopl: vop@ff940000 { compatible = "rockchip,rk3288-vop"; - reg = <0xff940000 0x19c>; + reg = <0xff940000 0x19c>, <0xff941000 0x1000>; interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cru ACLK_VOP1>, <&cru DCLK_VOP1>, <&cru HCLK_VOP1>; clock-names = "aclk_vop", "dclk_vop", "hclk_vop"; + power-domains = <&power RK3288_PD_VIO>; resets = <&cru SRST_LCDC1_AXI>, <&cru SRST_LCDC1_AHB>, <&cru SRST_LCDC1_DCLK>; reset-names = "axi", "ahb", "dclk"; iommus = <&vopl_mmu>; - power-domains = <&power RK3288_PD_VIO>; status = "disabled"; + vopl_out: port { #address-cells = <1>; #size-cells = <0>; - vopl_out_edp: endpoint@0 { + + vopl_out_hdmi: endpoint@0 { reg = <0>; - remote-endpoint = <&edp_in_vopl>; + remote-endpoint = <&hdmi_in_vopl>; }; - vopl_out_hdmi: endpoint@1 { + + vopl_out_edp: endpoint@1 { reg = <1>; - remote-endpoint = <&hdmi_in_vopl>; + remote-endpoint = <&edp_in_vopl>; }; - vopl_out_lvds: endpoint@2 { + + vopl_out_mipi: endpoint@2 { reg = <2>; - remote-endpoint = <&lvds_in_vopl>; - }; - vopl_out_mipi: endpoint@3 { - reg = <3>; remote-endpoint = <&mipi_in_vopl>; };
+ vopl_out_lvds: endpoint@3 { + reg = <3>; + remote-endpoint = <&lvds_in_vopl>; + }; }; };
@@ -703,60 +1105,34 @@ compatible = "rockchip,iommu"; reg = <0xff940300 0x100>; interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "vopl_mmu"; + clocks = <&cru ACLK_VOP1>, <&cru HCLK_VOP1>; + clock-names = "aclk", "iface"; power-domains = <&power RK3288_PD_VIO>; #iommu-cells = <0>; status = "disabled"; };
- edp: edp@ff970000 { - compatible = "rockchip,rk3288-edp"; - reg = <0xff970000 0x4000>; - interrupts = <GIC_SPI 98 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru SCLK_EDP>, <&cru SCLK_EDP_24M>, <&cru PCLK_EDP_CTRL>; - rockchip,grf = <&grf>; - clock-names = "clk_edp", "clk_edp_24m", "pclk_edp"; - resets = <&cru 111>; - reset-names = "edp"; + mipi_dsi: mipi@ff960000 { + compatible = "rockchip,rk3288-mipi-dsi", "snps,dw-mipi-dsi"; + reg = <0xff960000 0x4000>; + interrupts = <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru SCLK_MIPIDSI_24M>, <&cru PCLK_MIPI_DSI0>; + clock-names = "ref", "pclk"; power-domains = <&power RK3288_PD_VIO>; - status = "disabled"; - ports { - edp_in: port { - #address-cells = <1>; - #size-cells = <0>; - edp_in_vopb: endpoint@0 { - reg = <0>; - remote-endpoint = <&vopb_out_edp>; - }; - edp_in_vopl: endpoint@1 { - reg = <1>; - remote-endpoint = <&vopl_out_edp>; - }; - }; - }; - }; - - hdmi: hdmi@ff980000 { - compatible = "rockchip,rk3288-dw-hdmi"; - reg = <0xff980000 0x20000>; - reg-io-width = <4>; - ddc-i2c-bus = <&i2c5>; rockchip,grf = <&grf>; - interrupts = <GIC_SPI 103 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru PCLK_HDMI_CTRL>, <&cru SCLK_HDMI_HDCP>; - clock-names = "iahb", "isfr"; status = "disabled"; + ports { - hdmi_in: port { + mipi_in: port { #address-cells = <1>; #size-cells = <0>; - hdmi_in_vopb: endpoint@0 { + mipi_in_vopb: endpoint@0 { reg = <0>; - remote-endpoint = <&vopb_out_hdmi>; + remote-endpoint = <&vopb_out_mipi>; }; - hdmi_in_vopl: endpoint@1 { + mipi_in_vopl: endpoint@1 { reg = <1>; - remote-endpoint = <&vopl_out_hdmi>; + remote-endpoint = <&vopl_out_mipi>; }; }; }; @@ -767,17 +1143,22 @@ reg = <0xff96c000 0x4000>; clocks = <&cru PCLK_LVDS_PHY>; clock-names = "pclk_lvds"; - pinctrl-names = "default"; - pinctrl-0 = <&lcdc0_ctl>; + pinctrl-names = "lcdc"; + pinctrl-0 = <&lcdc_ctl>; + power-domains = <&power RK3288_PD_VIO>; rockchip,grf = <&grf>; status = "disabled"; + ports { #address-cells = <1>; #size-cells = <0>; + lvds_in: port@0 { reg = <0>; + #address-cells = <1>; #size-cells = <0>; + lvds_in_vopb: endpoint@0 { reg = <0>; remote-endpoint = <&vopb_out_lvds>; @@ -790,90 +1171,233 @@ }; };
- mipi_dsi0: mipi@ff960000 { - compatible = "rockchip,rk3288_mipi_dsi"; - reg = <0xff960000 0x4000>; - clocks = <&cru PCLK_MIPI_DSI0>; - clock-names = "pclk_mipi"; - /*pinctrl-names = "default"; - pinctrl-0 = <&lcdc0_ctl>;*/ + edp: dp@ff970000 { + compatible = "rockchip,rk3288-dp"; + reg = <0xff970000 0x4000>; + interrupts = <GIC_SPI 98 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru SCLK_EDP>, <&cru PCLK_EDP_CTRL>; + clock-names = "dp", "pclk"; + phys = <&edp_phy>; + phy-names = "dp"; + resets = <&cru SRST_EDP>; + reset-names = "dp"; rockchip,grf = <&grf>; - #address-cells = <1>; - #size-cells = <0>; status = "disabled"; + ports { - reg = <1>; - mipi_in: port { + #address-cells = <1>; + #size-cells = <0>; + edp_in: port@0 { + reg = <0>; #address-cells = <1>; #size-cells = <0>; - mipi_in_vopb: endpoint@0 { + edp_in_vopb: endpoint@0 { reg = <0>; - remote-endpoint = <&vopb_out_mipi>; + remote-endpoint = <&vopb_out_edp>; }; - mipi_in_vopl: endpoint@1 { + edp_in_vopl: endpoint@1 { reg = <1>; - remote-endpoint = <&vopl_out_mipi>; + remote-endpoint = <&vopl_out_edp>; }; }; }; };
- hdmi_audio: hdmi_audio { - compatible = "rockchip,rk3288-hdmi-audio"; - i2s-controller = <&i2s>; - status = "disable"; + hdmi: hdmi@ff980000 { + compatible = "rockchip,rk3288-dw-hdmi"; + reg = <0xff980000 0x20000>; + reg-io-width = <4>; + #sound-dai-cells = <0>; + rockchip,grf = <&grf>; + interrupts = <GIC_SPI 103 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru PCLK_HDMI_CTRL>, <&cru SCLK_HDMI_HDCP>, <&cru SCLK_HDMI_CEC>; + clock-names = "iahb", "isfr", "cec"; + power-domains = <&power RK3288_PD_VIO>; + status = "disabled"; + + ports { + hdmi_in: port { + #address-cells = <1>; + #size-cells = <0>; + hdmi_in_vopb: endpoint@0 { + reg = <0>; + remote-endpoint = <&vopb_out_hdmi>; + }; + hdmi_in_vopl: endpoint@1 { + reg = <1>; + remote-endpoint = <&vopl_out_hdmi>; + }; + }; + }; };
vpu: video-codec@ff9a0000 { compatible = "rockchip,rk3288-vpu"; reg = <0xff9a0000 0x800>; interrupts = <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>; + <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "vepu", "vdpu"; clocks = <&cru ACLK_VCODEC>, <&cru HCLK_VCODEC>; - clock-names = "aclk_vcodec", "hclk_vcodec"; - power-domains = <&power RK3288_PD_VIDEO>; + clock-names = "aclk", "hclk"; iommus = <&vpu_mmu>; + power-domains = <&power RK3288_PD_VIDEO>; };
vpu_mmu: iommu@ff9a0800 { compatible = "rockchip,iommu"; reg = <0xff9a0800 0x100>; interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "vpu_mmu"; + clocks = <&cru ACLK_VCODEC>, <&cru HCLK_VCODEC>; + clock-names = "aclk", "iface"; + #iommu-cells = <0>; power-domains = <&power RK3288_PD_VIDEO>; + }; + + hevc_mmu: iommu@ff9c0440 { + compatible = "rockchip,iommu"; + reg = <0xff9c0440 0x40>, <0xff9c0480 0x40>; + interrupts = <GIC_SPI 111 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru ACLK_HEVC>, <&cru HCLK_HEVC>; + clock-names = "aclk", "iface"; #iommu-cells = <0>; + status = "disabled"; };
gpu: gpu@ffa30000 { - compatible = "arm,malit764", - "arm,malit76x", - "arm,malit7xx", - "arm,mali-midgard"; + compatible = "rockchip,rk3288-mali", "arm,mali-t760"; reg = <0xffa30000 0x10000>; interrupts = <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "JOB", "MMU", "GPU"; + interrupt-names = "job", "mmu", "gpu"; clocks = <&cru ACLK_GPU>; - clock-names = "aclk_gpu"; - operating-points = < - /* KHz uV */ - 100000 950000 - 200000 950000 - 300000 1000000 - 400000 1100000 - /* 500000 1200000 - See crosbug.com/p/33857 */ - 600000 1250000 - >; + operating-points-v2 = <&gpu_opp_table>; + #cooling-cells = <2>; /* min followed by max */ power-domains = <&power RK3288_PD_GPU>; status = "disabled"; };
+ gpu_opp_table: opp-table-1 { + compatible = "operating-points-v2"; + + opp-100000000 { + opp-hz = /bits/ 64 <100000000>; + opp-microvolt = <950000>; + }; + opp-200000000 { + opp-hz = /bits/ 64 <200000000>; + opp-microvolt = <950000>; + }; + opp-300000000 { + opp-hz = /bits/ 64 <300000000>; + opp-microvolt = <1000000>; + }; + opp-400000000 { + opp-hz = /bits/ 64 <400000000>; + opp-microvolt = <1100000>; + }; + opp-600000000 { + opp-hz = /bits/ 64 <600000000>; + opp-microvolt = <1250000>; + }; + }; + + qos_gpu_r: qos@ffaa0000 { + compatible = "rockchip,rk3288-qos", "syscon"; + reg = <0xffaa0000 0x20>; + }; + + qos_gpu_w: qos@ffaa0080 { + compatible = "rockchip,rk3288-qos", "syscon"; + reg = <0xffaa0080 0x20>; + }; + + qos_vio1_vop: qos@ffad0000 { + compatible = "rockchip,rk3288-qos", "syscon"; + reg = <0xffad0000 0x20>; + }; + + qos_vio1_isp_w0: qos@ffad0100 { + compatible = "rockchip,rk3288-qos", "syscon"; + reg = <0xffad0100 0x20>; + }; + + qos_vio1_isp_w1: qos@ffad0180 { + compatible = "rockchip,rk3288-qos", "syscon"; + reg = <0xffad0180 0x20>; + }; + + qos_vio0_vop: qos@ffad0400 { + compatible = "rockchip,rk3288-qos", "syscon"; + reg = <0xffad0400 0x20>; + }; + + qos_vio0_vip: qos@ffad0480 { + compatible = "rockchip,rk3288-qos", "syscon"; + reg = <0xffad0480 0x20>; + }; + + qos_vio0_iep: qos@ffad0500 { + compatible = "rockchip,rk3288-qos", "syscon"; + reg = <0xffad0500 0x20>; + }; + + qos_vio2_rga_r: qos@ffad0800 { + compatible = "rockchip,rk3288-qos", "syscon"; + reg = <0xffad0800 0x20>; + }; + + qos_vio2_rga_w: qos@ffad0880 { + compatible = "rockchip,rk3288-qos", "syscon"; + reg = <0x0 0xffad0880 0x0 0x20>; + }; + + qos_vio1_isp_r: qos@ffad0900 { + compatible = "rockchip,rk3288-qos", "syscon"; + reg = <0xffad0900 0x20>; + }; + + qos_video: qos@ffae0000 { + compatible = "rockchip,rk3288-qos", "syscon"; + reg = <0xffae0000 0x20>; + }; + + qos_hevc_r: qos@ffaf0000 { + compatible = "rockchip,rk3288-qos", "syscon"; + reg = <0xffaf0000 0x20>; + }; + + qos_hevc_w: qos@ffaf0080 { + compatible = "rockchip,rk3288-qos", "syscon"; + reg = <0xffaf0080 0x20>; + }; + + dmac_bus_s: dma-controller@ffb20000 { + compatible = "arm,pl330", "arm,primecell"; + reg = <0xffb20000 0x4000>; + interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>; + #dma-cells = <1>; + arm,pl330-broken-no-flushp; + arm,pl330-periph-burst; + clocks = <&cru ACLK_DMAC1>; + clock-names = "apb_pclk"; + }; + efuse: efuse@ffb40000 { compatible = "rockchip,rk3288-efuse"; - reg = <0xffb40000 0x10000>; - status = "disabled"; + reg = <0xffb40000 0x20>; + #address-cells = <1>; + #size-cells = <1>; + clocks = <&cru PCLK_EFUSE256>; + clock-names = "pclk_efuse"; + + cpu_id: cpu-id@7 { + reg = <0x07 0x10>; + }; + cpu_leakage: cpu_leakage@17 { + reg = <0x17 0x1>; + }; };
gic: interrupt-controller@ffc01000 { @@ -883,45 +1407,12 @@ #address-cells = <0>;
reg = <0xffc01000 0x1000>, - <0xffc02000 0x1000>, + <0xffc02000 0x2000>, <0xffc04000 0x2000>, <0xffc06000 0x2000>; interrupts = <GIC_PPI 9 0xf04>; };
- cpuidle: cpuidle { - compatible = "rockchip,rk3288-cpuidle"; - }; - - usbphy: phy { - compatible = "rockchip,rk3288-usb-phy"; - rockchip,grf = <&grf>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - - usbphy0: usb-phy0 { - #phy-cells = <0>; - reg = <0x320>; - clocks = <&cru SCLK_OTGPHY0>; - clock-names = "phyclk"; - }; - - usbphy1: usb-phy1 { - #phy-cells = <0>; - reg = <0x334>; - clocks = <&cru SCLK_OTGPHY1>; - clock-names = "phyclk"; - }; - - usbphy2: usb-phy2 { - #phy-cells = <0>; - reg = <0x348>; - clocks = <&cru SCLK_OTGPHY2>; - clock-names = "phyclk"; - }; - }; - pinctrl: pinctrl { compatible = "rockchip,rk3288-pinctrl"; rockchip,grf = <&grf>; @@ -930,9 +1421,9 @@ #size-cells = <1>; ranges;
- gpio0: gpio0@ff750000 { + gpio0: gpio@ff750000 { compatible = "rockchip,gpio-bank"; - reg = <0xff750000 0x100>; + reg = <0xff750000 0x100>; interrupts = <GIC_SPI 81 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cru PCLK_GPIO0>;
@@ -943,7 +1434,7 @@ #interrupt-cells = <2>; };
- gpio1: gpio1@ff780000 { + gpio1: gpio@ff780000 { compatible = "rockchip,gpio-bank"; reg = <0xff780000 0x100>; interrupts = <GIC_SPI 82 IRQ_TYPE_LEVEL_HIGH>; @@ -956,7 +1447,7 @@ #interrupt-cells = <2>; };
- gpio2: gpio2@ff790000 { + gpio2: gpio@ff790000 { compatible = "rockchip,gpio-bank"; reg = <0xff790000 0x100>; interrupts = <GIC_SPI 83 IRQ_TYPE_LEVEL_HIGH>; @@ -969,7 +1460,7 @@ #interrupt-cells = <2>; };
- gpio3: gpio3@ff7a0000 { + gpio3: gpio@ff7a0000 { compatible = "rockchip,gpio-bank"; reg = <0xff7a0000 0x100>; interrupts = <GIC_SPI 84 IRQ_TYPE_LEVEL_HIGH>; @@ -982,7 +1473,7 @@ #interrupt-cells = <2>; };
- gpio4: gpio4@ff7b0000 { + gpio4: gpio@ff7b0000 { compatible = "rockchip,gpio-bank"; reg = <0xff7b0000 0x100>; interrupts = <GIC_SPI 85 IRQ_TYPE_LEVEL_HIGH>; @@ -995,7 +1486,7 @@ #interrupt-cells = <2>; };
- gpio5: gpio5@ff7c0000 { + gpio5: gpio@ff7c0000 { compatible = "rockchip,gpio-bank"; reg = <0xff7c0000 0x100>; interrupts = <GIC_SPI 86 IRQ_TYPE_LEVEL_HIGH>; @@ -1008,7 +1499,7 @@ #interrupt-cells = <2>; };
- gpio6: gpio6@ff7d0000 { + gpio6: gpio@ff7d0000 { compatible = "rockchip,gpio-bank"; reg = <0xff7d0000 0x100>; interrupts = <GIC_SPI 87 IRQ_TYPE_LEVEL_HIGH>; @@ -1021,7 +1512,7 @@ #interrupt-cells = <2>; };
- gpio7: gpio7@ff7e0000 { + gpio7: gpio@ff7e0000 { compatible = "rockchip,gpio-bank"; reg = <0xff7e0000 0x100>; interrupts = <GIC_SPI 88 IRQ_TYPE_LEVEL_HIGH>; @@ -1034,7 +1525,7 @@ #interrupt-cells = <2>; };
- gpio8: gpio8@ff7f0000 { + gpio8: gpio@ff7f0000 { compatible = "rockchip,gpio-bank"; reg = <0xff7f0000 0x100>; interrupts = <GIC_SPI 89 IRQ_TYPE_LEVEL_HIGH>; @@ -1051,6 +1542,24 @@ hdmi_cec_c0: hdmi-cec-c0 { rockchip,pins = <7 RK_PC0 2 &pcfg_pull_none>; }; + + hdmi_cec_c7: hdmi-cec-c7 { + rockchip,pins = <7 RK_PC7 4 &pcfg_pull_none>; + }; + + hdmi_ddc: hdmi-ddc { + rockchip,pins = <7 RK_PC3 2 &pcfg_pull_none>, + <7 RK_PC4 2 &pcfg_pull_none>; + }; + + hdmi_ddc_unwedge: hdmi-ddc-unwedge { + rockchip,pins = <7 RK_PC3 RK_FUNC_GPIO &pcfg_output_low>, + <7 RK_PC4 2 &pcfg_pull_none>; + }; + }; + + pcfg_output_low: pcfg-output-low { + output-low; };
pcfg_pull_up: pcfg-pull-up { @@ -1070,472 +1579,424 @@ drive-strength = <12>; };
- sleep { + suspend { global_pwroff: global-pwroff { - rockchip,pins = <0 0 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <0 RK_PA0 1 &pcfg_pull_none>; };
ddrio_pwroff: ddrio-pwroff { - rockchip,pins = <0 1 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <0 RK_PA1 1 &pcfg_pull_none>; };
ddr0_retention: ddr0-retention { - rockchip,pins = <0 2 RK_FUNC_1 &pcfg_pull_up>; + rockchip,pins = <0 RK_PA2 1 &pcfg_pull_up>; };
ddr1_retention: ddr1-retention { - rockchip,pins = <0 3 RK_FUNC_1 &pcfg_pull_up>; + rockchip,pins = <0 RK_PA3 1 &pcfg_pull_up>; + }; + }; + + edp { + edp_hpd: edp-hpd { + rockchip,pins = <7 RK_PB3 2 &pcfg_pull_down>; }; };
i2c0 { i2c0_xfer: i2c0-xfer { - rockchip,pins = <0 15 RK_FUNC_1 &pcfg_pull_none>, - <0 16 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <0 RK_PB7 1 &pcfg_pull_none>, + <0 RK_PC0 1 &pcfg_pull_none>; }; };
i2c1 { i2c1_xfer: i2c1-xfer { - rockchip,pins = <8 4 RK_FUNC_1 &pcfg_pull_none>, - <8 5 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <8 RK_PA4 1 &pcfg_pull_none>, + <8 RK_PA5 1 &pcfg_pull_none>; }; };
i2c2 { i2c2_xfer: i2c2-xfer { - rockchip,pins = <6 9 RK_FUNC_1 &pcfg_pull_none>, - <6 10 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <6 RK_PB1 1 &pcfg_pull_none>, + <6 RK_PB2 1 &pcfg_pull_none>; }; };
i2c3 { i2c3_xfer: i2c3-xfer { - rockchip,pins = <2 16 RK_FUNC_1 &pcfg_pull_none>, - <2 17 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <2 RK_PC0 1 &pcfg_pull_none>, + <2 RK_PC1 1 &pcfg_pull_none>; }; };
i2c4 { i2c4_xfer: i2c4-xfer { - rockchip,pins = <7 17 RK_FUNC_1 &pcfg_pull_none>, - <7 18 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <7 RK_PC1 1 &pcfg_pull_none>, + <7 RK_PC2 1 &pcfg_pull_none>; }; };
i2c5 { i2c5_xfer: i2c5-xfer { - rockchip,pins = <7 19 RK_FUNC_1 &pcfg_pull_none>, - <7 20 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <7 RK_PC3 1 &pcfg_pull_none>, + <7 RK_PC4 1 &pcfg_pull_none>; }; };
i2s0 { i2s0_bus: i2s0-bus { - rockchip,pins = <6 0 RK_FUNC_1 &pcfg_pull_none>, - <6 1 RK_FUNC_1 &pcfg_pull_none>, - <6 2 RK_FUNC_1 &pcfg_pull_none>, - <6 3 RK_FUNC_1 &pcfg_pull_none>, - <6 4 RK_FUNC_1 &pcfg_pull_none>, - <6 8 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <6 RK_PA0 1 &pcfg_pull_none>, + <6 RK_PA1 1 &pcfg_pull_none>, + <6 RK_PA2 1 &pcfg_pull_none>, + <6 RK_PA3 1 &pcfg_pull_none>, + <6 RK_PA4 1 &pcfg_pull_none>, + <6 RK_PB0 1 &pcfg_pull_none>; }; };
- lcdc0 { - lcdc0_ctl: lcdc0-ctl { - rockchip,pins = <1 24 RK_FUNC_1 &pcfg_pull_none>, - <1 25 RK_FUNC_1 &pcfg_pull_none>, - <1 26 RK_FUNC_1 &pcfg_pull_none>, - <1 27 RK_FUNC_1 &pcfg_pull_none>; + lcdc { + lcdc_ctl: lcdc-ctl { + rockchip,pins = <1 RK_PD0 1 &pcfg_pull_none>, + <1 RK_PD1 1 &pcfg_pull_none>, + <1 RK_PD2 1 &pcfg_pull_none>, + <1 RK_PD3 1 &pcfg_pull_none>; }; };
sdmmc { sdmmc_clk: sdmmc-clk { - rockchip,pins = <6 20 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <6 RK_PC4 1 &pcfg_pull_none>; };
sdmmc_cmd: sdmmc-cmd { - rockchip,pins = <6 21 RK_FUNC_1 &pcfg_pull_up>; + rockchip,pins = <6 RK_PC5 1 &pcfg_pull_up>; };
- sdmmc_cd: sdmcc-cd { - rockchip,pins = <6 22 RK_FUNC_1 &pcfg_pull_up>; + sdmmc_cd: sdmmc-cd { + rockchip,pins = <6 RK_PC6 1 &pcfg_pull_up>; };
sdmmc_bus1: sdmmc-bus1 { - rockchip,pins = <6 16 RK_FUNC_1 &pcfg_pull_up>; + rockchip,pins = <6 RK_PC0 1 &pcfg_pull_up>; };
sdmmc_bus4: sdmmc-bus4 { - rockchip,pins = <6 16 RK_FUNC_1 &pcfg_pull_up>, - <6 17 RK_FUNC_1 &pcfg_pull_up>, - <6 18 RK_FUNC_1 &pcfg_pull_up>, - <6 19 RK_FUNC_1 &pcfg_pull_up>; + rockchip,pins = <6 RK_PC0 1 &pcfg_pull_up>, + <6 RK_PC1 1 &pcfg_pull_up>, + <6 RK_PC2 1 &pcfg_pull_up>, + <6 RK_PC3 1 &pcfg_pull_up>; }; };
sdio0 { sdio0_bus1: sdio0-bus1 { - rockchip,pins = <4 20 RK_FUNC_1 &pcfg_pull_up>; + rockchip,pins = <4 RK_PC4 1 &pcfg_pull_up>; };
sdio0_bus4: sdio0-bus4 { - rockchip,pins = <4 20 RK_FUNC_1 &pcfg_pull_up>, - <4 21 RK_FUNC_1 &pcfg_pull_up>, - <4 22 RK_FUNC_1 &pcfg_pull_up>, - <4 23 RK_FUNC_1 &pcfg_pull_up>; + rockchip,pins = <4 RK_PC4 1 &pcfg_pull_up>, + <4 RK_PC5 1 &pcfg_pull_up>, + <4 RK_PC6 1 &pcfg_pull_up>, + <4 RK_PC7 1 &pcfg_pull_up>; };
sdio0_cmd: sdio0-cmd { - rockchip,pins = <4 24 RK_FUNC_1 &pcfg_pull_up>; + rockchip,pins = <4 RK_PD0 1 &pcfg_pull_up>; };
sdio0_clk: sdio0-clk { - rockchip,pins = <4 25 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <4 RK_PD1 1 &pcfg_pull_none>; };
sdio0_cd: sdio0-cd { - rockchip,pins = <4 26 RK_FUNC_1 &pcfg_pull_up>; + rockchip,pins = <4 RK_PD2 1 &pcfg_pull_up>; };
sdio0_wp: sdio0-wp { - rockchip,pins = <4 27 RK_FUNC_1 &pcfg_pull_up>; + rockchip,pins = <4 RK_PD3 1 &pcfg_pull_up>; };
sdio0_pwr: sdio0-pwr { - rockchip,pins = <4 28 RK_FUNC_1 &pcfg_pull_up>; + rockchip,pins = <4 RK_PD4 1 &pcfg_pull_up>; };
sdio0_bkpwr: sdio0-bkpwr { - rockchip,pins = <4 29 RK_FUNC_1 &pcfg_pull_up>; + rockchip,pins = <4 RK_PD5 1 &pcfg_pull_up>; };
sdio0_int: sdio0-int { - rockchip,pins = <4 30 RK_FUNC_1 &pcfg_pull_up>; + rockchip,pins = <4 RK_PD6 1 &pcfg_pull_up>; }; };
sdio1 { sdio1_bus1: sdio1-bus1 { - rockchip,pins = <3 24 RK_FUNC_4 &pcfg_pull_up>; + rockchip,pins = <3 RK_PD0 4 &pcfg_pull_up>; };
sdio1_bus4: sdio1-bus4 { - rockchip,pins = <3 24 RK_FUNC_4 &pcfg_pull_up>, - <3 25 RK_FUNC_4 &pcfg_pull_up>, - <3 26 RK_FUNC_4 &pcfg_pull_up>, - <3 27 RK_FUNC_4 &pcfg_pull_up>; + rockchip,pins = <3 RK_PD0 4 &pcfg_pull_up>, + <3 RK_PD1 4 &pcfg_pull_up>, + <3 RK_PD2 4 &pcfg_pull_up>, + <3 RK_PD3 4 &pcfg_pull_up>; };
sdio1_cd: sdio1-cd { - rockchip,pins = <3 28 RK_FUNC_4 &pcfg_pull_up>; + rockchip,pins = <3 RK_PD4 4 &pcfg_pull_up>; };
sdio1_wp: sdio1-wp { - rockchip,pins = <3 29 RK_FUNC_4 &pcfg_pull_up>; + rockchip,pins = <3 RK_PD5 4 &pcfg_pull_up>; };
sdio1_bkpwr: sdio1-bkpwr { - rockchip,pins = <3 30 RK_FUNC_4 &pcfg_pull_up>; + rockchip,pins = <3 RK_PD6 4 &pcfg_pull_up>; };
sdio1_int: sdio1-int { - rockchip,pins = <3 31 RK_FUNC_4 &pcfg_pull_up>; + rockchip,pins = <3 RK_PD7 4 &pcfg_pull_up>; };
sdio1_cmd: sdio1-cmd { - rockchip,pins = <4 6 RK_FUNC_4 &pcfg_pull_up>; + rockchip,pins = <4 RK_PA6 4 &pcfg_pull_up>; };
sdio1_clk: sdio1-clk { - rockchip,pins = <4 7 RK_FUNC_4 &pcfg_pull_none>; + rockchip,pins = <4 RK_PA7 4 &pcfg_pull_none>; };
sdio1_pwr: sdio1-pwr { - rockchip,pins = <4 9 RK_FUNC_4 &pcfg_pull_up>; + rockchip,pins = <4 RK_PB1 4 &pcfg_pull_up>; }; };
emmc { emmc_clk: emmc-clk { - rockchip,pins = <3 18 RK_FUNC_2 &pcfg_pull_none>; + rockchip,pins = <3 RK_PC2 2 &pcfg_pull_none>; };
emmc_cmd: emmc-cmd { - rockchip,pins = <3 16 RK_FUNC_2 &pcfg_pull_up>; + rockchip,pins = <3 RK_PC0 2 &pcfg_pull_up>; };
emmc_pwr: emmc-pwr { - rockchip,pins = <3 9 RK_FUNC_2 &pcfg_pull_up>; + rockchip,pins = <3 RK_PB1 2 &pcfg_pull_up>; };
emmc_bus1: emmc-bus1 { - rockchip,pins = <3 0 RK_FUNC_2 &pcfg_pull_up>; + rockchip,pins = <3 RK_PA0 2 &pcfg_pull_up>; };
emmc_bus4: emmc-bus4 { - rockchip,pins = <3 0 RK_FUNC_2 &pcfg_pull_up>, - <3 1 RK_FUNC_2 &pcfg_pull_up>, - <3 2 RK_FUNC_2 &pcfg_pull_up>, - <3 3 RK_FUNC_2 &pcfg_pull_up>; + rockchip,pins = <3 RK_PA0 2 &pcfg_pull_up>, + <3 RK_PA1 2 &pcfg_pull_up>, + <3 RK_PA2 2 &pcfg_pull_up>, + <3 RK_PA3 2 &pcfg_pull_up>; };
emmc_bus8: emmc-bus8 { - rockchip,pins = <3 0 RK_FUNC_2 &pcfg_pull_up>, - <3 1 RK_FUNC_2 &pcfg_pull_up>, - <3 2 RK_FUNC_2 &pcfg_pull_up>, - <3 3 RK_FUNC_2 &pcfg_pull_up>, - <3 4 RK_FUNC_2 &pcfg_pull_up>, - <3 5 RK_FUNC_2 &pcfg_pull_up>, - <3 6 RK_FUNC_2 &pcfg_pull_up>, - <3 7 RK_FUNC_2 &pcfg_pull_up>; + rockchip,pins = <3 RK_PA0 2 &pcfg_pull_up>, + <3 RK_PA1 2 &pcfg_pull_up>, + <3 RK_PA2 2 &pcfg_pull_up>, + <3 RK_PA3 2 &pcfg_pull_up>, + <3 RK_PA4 2 &pcfg_pull_up>, + <3 RK_PA5 2 &pcfg_pull_up>, + <3 RK_PA6 2 &pcfg_pull_up>, + <3 RK_PA7 2 &pcfg_pull_up>; }; };
spi0 { spi0_clk: spi0-clk { - rockchip,pins = <5 12 RK_FUNC_1 &pcfg_pull_up>; + rockchip,pins = <5 RK_PB4 1 &pcfg_pull_up>; }; spi0_cs0: spi0-cs0 { - rockchip,pins = <5 13 RK_FUNC_1 &pcfg_pull_up>; + rockchip,pins = <5 RK_PB5 1 &pcfg_pull_up>; }; spi0_tx: spi0-tx { - rockchip,pins = <5 14 RK_FUNC_1 &pcfg_pull_up>; + rockchip,pins = <5 RK_PB6 1 &pcfg_pull_up>; }; spi0_rx: spi0-rx { - rockchip,pins = <5 15 RK_FUNC_1 &pcfg_pull_up>; + rockchip,pins = <5 RK_PB7 1 &pcfg_pull_up>; }; spi0_cs1: spi0-cs1 { - rockchip,pins = <5 16 RK_FUNC_1 &pcfg_pull_up>; + rockchip,pins = <5 RK_PC0 1 &pcfg_pull_up>; }; }; spi1 { spi1_clk: spi1-clk { - rockchip,pins = <7 12 RK_FUNC_2 &pcfg_pull_up>; + rockchip,pins = <7 RK_PB4 2 &pcfg_pull_up>; }; spi1_cs0: spi1-cs0 { - rockchip,pins = <7 13 RK_FUNC_2 &pcfg_pull_up>; + rockchip,pins = <7 RK_PB5 2 &pcfg_pull_up>; }; spi1_rx: spi1-rx { - rockchip,pins = <7 14 RK_FUNC_2 &pcfg_pull_up>; + rockchip,pins = <7 RK_PB6 2 &pcfg_pull_up>; }; spi1_tx: spi1-tx { - rockchip,pins = <7 15 RK_FUNC_2 &pcfg_pull_up>; + rockchip,pins = <7 RK_PB7 2 &pcfg_pull_up>; }; };
spi2 { spi2_cs1: spi2-cs1 { - rockchip,pins = <8 3 RK_FUNC_1 &pcfg_pull_up>; + rockchip,pins = <8 RK_PA3 1 &pcfg_pull_up>; }; spi2_clk: spi2-clk { - rockchip,pins = <8 6 RK_FUNC_1 &pcfg_pull_up>; + rockchip,pins = <8 RK_PA6 1 &pcfg_pull_up>; }; spi2_cs0: spi2-cs0 { - rockchip,pins = <8 7 RK_FUNC_1 &pcfg_pull_up>; + rockchip,pins = <8 RK_PA7 1 &pcfg_pull_up>; }; spi2_rx: spi2-rx { - rockchip,pins = <8 8 RK_FUNC_1 &pcfg_pull_up>; + rockchip,pins = <8 RK_PB0 1 &pcfg_pull_up>; }; spi2_tx: spi2-tx { - rockchip,pins = <8 9 RK_FUNC_1 &pcfg_pull_up>; + rockchip,pins = <8 RK_PB1 1 &pcfg_pull_up>; }; };
uart0 { uart0_xfer: uart0-xfer { - rockchip,pins = <4 16 RK_FUNC_1 &pcfg_pull_up>, - <4 17 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <4 RK_PC0 1 &pcfg_pull_up>, + <4 RK_PC1 1 &pcfg_pull_none>; };
uart0_cts: uart0-cts { - rockchip,pins = <4 18 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <4 RK_PC2 1 &pcfg_pull_up>; };
uart0_rts: uart0-rts { - rockchip,pins = <4 19 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <4 RK_PC3 1 &pcfg_pull_none>; }; };
uart1 { uart1_xfer: uart1-xfer { - rockchip,pins = <5 8 RK_FUNC_1 &pcfg_pull_up>, - <5 9 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <5 RK_PB0 1 &pcfg_pull_up>, + <5 RK_PB1 1 &pcfg_pull_none>; };
uart1_cts: uart1-cts { - rockchip,pins = <5 10 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <5 RK_PB2 1 &pcfg_pull_up>; };
uart1_rts: uart1-rts { - rockchip,pins = <5 11 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <5 RK_PB3 1 &pcfg_pull_none>; }; };
uart2 { uart2_xfer: uart2-xfer { - rockchip,pins = <7 22 RK_FUNC_1 &pcfg_pull_up>, - <7 23 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <7 RK_PC6 1 &pcfg_pull_up>, + <7 RK_PC7 1 &pcfg_pull_none>; }; /* no rts / cts for uart2 */ };
uart3 { uart3_xfer: uart3-xfer { - rockchip,pins = <7 7 RK_FUNC_1 &pcfg_pull_up>, - <7 8 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <7 RK_PA7 1 &pcfg_pull_up>, + <7 RK_PB0 1 &pcfg_pull_none>; };
uart3_cts: uart3-cts { - rockchip,pins = <7 9 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <7 RK_PB1 1 &pcfg_pull_up>; };
uart3_rts: uart3-rts { - rockchip,pins = <7 10 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <7 RK_PB2 1 &pcfg_pull_none>; }; };
uart4 { uart4_xfer: uart4-xfer { - rockchip,pins = <5 12 3 &pcfg_pull_up>, - <5 13 3 &pcfg_pull_none>; + rockchip,pins = <5 RK_PB7 3 &pcfg_pull_up>, + <5 RK_PB6 3 &pcfg_pull_none>; };
uart4_cts: uart4-cts { - rockchip,pins = <5 14 3 &pcfg_pull_none>; + rockchip,pins = <5 RK_PB4 3 &pcfg_pull_up>; };
uart4_rts: uart4-rts { - rockchip,pins = <5 15 3 &pcfg_pull_none>; + rockchip,pins = <5 RK_PB5 3 &pcfg_pull_none>; }; };
tsadc { + otp_pin: otp-pin { + rockchip,pins = <0 RK_PB2 RK_FUNC_GPIO &pcfg_pull_none>; + }; + otp_out: otp-out { - rockchip,pins = <0 10 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <0 RK_PB2 1 &pcfg_pull_none>; }; };
pwm0 { pwm0_pin: pwm0-pin { - rockchip,pins = <7 0 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <7 RK_PA0 1 &pcfg_pull_none>; }; };
pwm1 { pwm1_pin: pwm1-pin { - rockchip,pins = <7 1 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <7 RK_PA1 1 &pcfg_pull_none>; }; };
pwm2 { pwm2_pin: pwm2-pin { - rockchip,pins = <7 22 RK_FUNC_3 &pcfg_pull_none>; + rockchip,pins = <7 RK_PC6 3 &pcfg_pull_none>; }; };
pwm3 { pwm3_pin: pwm3-pin { - rockchip,pins = <7 23 RK_FUNC_3 &pcfg_pull_none>; + rockchip,pins = <7 RK_PC7 3 &pcfg_pull_none>; }; };
gmac { rgmii_pins: rgmii-pins { - rockchip,pins = <3 30 3 &pcfg_pull_none>, - <3 31 3 &pcfg_pull_none>, - <3 26 3 &pcfg_pull_none>, - <3 27 3 &pcfg_pull_none>, - <3 28 3 &pcfg_pull_none_12ma>, - <3 29 3 &pcfg_pull_none_12ma>, - <3 24 3 &pcfg_pull_none_12ma>, - <3 25 3 &pcfg_pull_none_12ma>, - <4 0 3 &pcfg_pull_none>, - <4 5 3 &pcfg_pull_none>, - <4 6 3 &pcfg_pull_none>, - <4 9 3 &pcfg_pull_none_12ma>, - <4 4 3 &pcfg_pull_none_12ma>, - <4 1 3 &pcfg_pull_none>, - <4 3 3 &pcfg_pull_none>; + rockchip,pins = <3 RK_PD6 3 &pcfg_pull_none>, + <3 RK_PD7 3 &pcfg_pull_none>, + <3 RK_PD2 3 &pcfg_pull_none>, + <3 RK_PD3 3 &pcfg_pull_none>, + <3 RK_PD4 3 &pcfg_pull_none_12ma>, + <3 RK_PD5 3 &pcfg_pull_none_12ma>, + <3 RK_PD0 3 &pcfg_pull_none_12ma>, + <3 RK_PD1 3 &pcfg_pull_none_12ma>, + <4 RK_PA0 3 &pcfg_pull_none>, + <4 RK_PA5 3 &pcfg_pull_none>, + <4 RK_PA6 3 &pcfg_pull_none>, + <4 RK_PB1 3 &pcfg_pull_none_12ma>, + <4 RK_PA4 3 &pcfg_pull_none_12ma>, + <4 RK_PA1 3 &pcfg_pull_none>, + <4 RK_PA3 3 &pcfg_pull_none>; };
rmii_pins: rmii-pins { - rockchip,pins = <3 30 3 &pcfg_pull_none>, - <3 31 3 &pcfg_pull_none>, - <3 28 3 &pcfg_pull_none>, - <3 29 3 &pcfg_pull_none>, - <4 0 3 &pcfg_pull_none>, - <4 5 3 &pcfg_pull_none>, - <4 4 3 &pcfg_pull_none>, - <4 1 3 &pcfg_pull_none>, - <4 2 3 &pcfg_pull_none>, - <4 3 3 &pcfg_pull_none>; + rockchip,pins = <3 RK_PD6 3 &pcfg_pull_none>, + <3 RK_PD7 3 &pcfg_pull_none>, + <3 RK_PD4 3 &pcfg_pull_none>, + <3 RK_PD5 3 &pcfg_pull_none>, + <4 RK_PA0 3 &pcfg_pull_none>, + <4 RK_PA5 3 &pcfg_pull_none>, + <4 RK_PA4 3 &pcfg_pull_none>, + <4 RK_PA1 3 &pcfg_pull_none>, + <4 RK_PA2 3 &pcfg_pull_none>, + <4 RK_PA3 3 &pcfg_pull_none>; }; };
spdif { spdif_tx: spdif-tx { - rockchip,pins = <RK_GPIO6 11 RK_FUNC_1 &pcfg_pull_none>; + rockchip,pins = <6 RK_PB3 1 &pcfg_pull_none>; }; }; }; - - power: power-controller { - compatible = "rockchip,rk3288-power-controller"; - #power-domain-cells = <1>; - rockchip,pmu = <&pmu>; - #address-cells = <1>; - #size-cells = <0>; - - pd_gpu { - reg = <RK3288_PD_GPU>; - clocks = <&cru ACLK_GPU>; - }; - - pd_hevc { - reg = <RK3288_PD_HEVC>; - clocks = <&cru ACLK_HEVC>, - <&cru SCLK_HEVC_CABAC>, - <&cru SCLK_HEVC_CORE>, - <&cru HCLK_HEVC>; - }; - - pd_vio { - reg = <RK3288_PD_VIO>; - clocks = <&cru ACLK_IEP>, - <&cru ACLK_ISP>, - <&cru ACLK_RGA>, - <&cru ACLK_VIP>, - <&cru ACLK_VOP0>, - <&cru ACLK_VOP1>, - <&cru DCLK_VOP0>, - <&cru DCLK_VOP1>, - <&cru HCLK_IEP>, - <&cru HCLK_ISP>, - <&cru HCLK_RGA>, - <&cru HCLK_VIP>, - <&cru HCLK_VOP0>, - <&cru HCLK_VOP1>, - <&cru PCLK_EDP_CTRL>, - <&cru PCLK_HDMI_CTRL>, - <&cru PCLK_LVDS_PHY>, - <&cru PCLK_MIPI_CSI>, - <&cru PCLK_MIPI_DSI0>, - <&cru PCLK_MIPI_DSI1>, - <&cru SCLK_EDP_24M>, - <&cru SCLK_EDP>, - <&cru SCLK_HDMI_CEC>, - <&cru SCLK_HDMI_HDCP>, - <&cru SCLK_ISP_JPE>, - <&cru SCLK_ISP>, - <&cru SCLK_RGA>; - }; - - pd_video { - reg = <RK3288_PD_VIDEO>; - clocks = <&cru ACLK_VCODEC>, - <&cru HCLK_VCODEC>; - }; - }; };
On 2022/3/4 07:52, Johan Jonker wrote:
Sync rk3288.dtsi from Linux version 5.17.
Signed-off-by: Johan Jonker jbx6244@gmail.com
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
Changed V3: change reg size
Changed V2: rename mipi_dsi0 label move io_domains remove hdmi_audio veyron node change memory@0 reg size
arch/arm/dts/rk3288-evb.dtsi | 2 +- arch/arm/dts/rk3288-miqi.dtsi | 28 +- arch/arm/dts/rk3288-phycore-som.dtsi | 30 +- arch/arm/dts/rk3288-popmetal.dtsi | 30 +- arch/arm/dts/rk3288-thermal.dtsi | 87 -- arch/arm/dts/rk3288-veyron-jerry.dts | 6 - arch/arm/dts/rk3288-veyron.dtsi | 33 +- arch/arm/dts/rk3288.dtsi | 1367 +++++++++++++++++--------- 8 files changed, 970 insertions(+), 613 deletions(-) delete mode 100644 arch/arm/dts/rk3288-thermal.dtsi
diff --git a/arch/arm/dts/rk3288-evb.dtsi b/arch/arm/dts/rk3288-evb.dtsi index 04902c0b..72da8847 100644 --- a/arch/arm/dts/rk3288-evb.dtsi +++ b/arch/arm/dts/rk3288-evb.dtsi @@ -448,7 +448,7 @@ status = "okay"; };
-&mipi_dsi0 { +&mipi_dsi { status = "disabled"; rockchip,panel = <&panel>; display-timings { diff --git a/arch/arm/dts/rk3288-miqi.dtsi b/arch/arm/dts/rk3288-miqi.dtsi index cb80cbf2..b1c286c9 100644 --- a/arch/arm/dts/rk3288-miqi.dtsi +++ b/arch/arm/dts/rk3288-miqi.dtsi @@ -18,21 +18,6 @@ clock-output-names = "ext_gmac"; };
wifi-supply = <&vcc_18>;
- leds { compatible = "gpio-leds";
@@ -277,6 +262,19 @@ status = "okay"; };
+&io_domains {
- status = "okay";
- wifi-supply = <&vcc_18>;
- &pinctrl { pcfg_output_high: pcfg-output-high { output-high;
diff --git a/arch/arm/dts/rk3288-phycore-som.dtsi b/arch/arm/dts/rk3288-phycore-som.dtsi index 821525f7..8ac695c8 100644 --- a/arch/arm/dts/rk3288-phycore-som.dtsi +++ b/arch/arm/dts/rk3288-phycore-som.dtsi @@ -71,22 +71,6 @@ clock-output-names = "ext_gmac"; };
- io_domains: io_domains {
status = "okay";
sdcard-supply = <&vdd_io_sd>;
flash0-supply = <&vdd_emmc_io>;
flash1-supply = <&vdd_misc_1v8>;
gpio1830-supply = <&vdd_3v3_io>;
gpio30-supply = <&vdd_3v3_io>;
- leds: user-leds { compatible = "gpio-leds"; pinctrl-names = "default";
@@ -197,6 +181,20 @@ ddc-i2c-bus = <&i2c5>; };
+&io_domains {
- status = "okay";
- sdcard-supply = <&vdd_io_sd>;
- flash0-supply = <&vdd_emmc_io>;
- flash1-supply = <&vdd_misc_1v8>;
- gpio1830-supply = <&vdd_3v3_io>;
- gpio30-supply = <&vdd_3v3_io>;
- bb-supply = <&vdd_3v3_io>;
- dvp-supply = <&vdd_3v3_io>;
- lcdc-supply = <&vdd_3v3_io>;
- wifi-supply = <&vdd_3v3_io>;
- audio-supply = <&vdd_3v3_io>;
- &i2c0 { status = "okay"; clock-frequency = <400000>;
diff --git a/arch/arm/dts/rk3288-popmetal.dtsi b/arch/arm/dts/rk3288-popmetal.dtsi index 63785eb5..bcd8fded 100644 --- a/arch/arm/dts/rk3288-popmetal.dtsi +++ b/arch/arm/dts/rk3288-popmetal.dtsi @@ -69,22 +69,6 @@ }; };
- io_domains: io-domains {
+&io_domains {
- status = "okay";
- audio-supply = <&vcca_33>;
- bb-supply = <&vcc_io>;
- dvp-supply = <&vcc18_dvp>;
- flash0-supply = <&vcc_flash>;
- flash1-supply = <&vcc_lan>;
- gpio30-supply = <&vcc_io>;
- gpio1830-supply = <&vcc_io>;
- lcdc-supply = <&vcc_io>;
- wifi-supply = <&vccio_wl>;
- &pinctrl { ak8963 { comp_int: comp-int {
- Device Tree Source for RK3288 SoC thermal
- Copyright (c) 2014, Fuzhou Rockchip Electronics Co., Ltd
/* sensor ID */
/* sensor ID */
- linux,hwmon;
- trips {
type = "passive";
type = "passive";
type = "critical";
- cooling-maps {
map0 {
cooling-device =
map1 {
cooling-device =
/* sensor ID */
- linux,hwmon;
- trips {
type = "passive";
type = "critical";
- cooling-maps {
map0 {
cooling-device =
- edp {
edp_hpd: edp_hpd {
io-domains {
&cpu0 {
+&io_domains {
- status = "okay";
- &wdt { status = "okay"; };
-&hdmi_audio {
- status = "okay";
#size-cells = <1>;
aliases {
ethernet0 = &gmac;
- arm-pmu {
- cpus { #address-cells = <1>; #size-cells = <0>;
/* KHz uV */
1800000 1400000
1704000 1350000
1608000 1300000
1512000 1250000
1416000 1200000
1200000 1100000
1008000 1050000
816000 1000000
696000 950000
600000 900000
408000 900000
216000 900000
126000 900000
};dynamic-power-coefficient = <370>;
cpu@501 {
cpu@502 {
cpu@503 {
}; };dynamic-power-coefficient = <370>;
- amba {
- cpu_opp_table: opp-table-0 {
opp-shared;
opp-126000000 {
opp-216000000 {
opp-312000000 {
opp-408000000 {
opp-600000000 {
opp-696000000 {
opp-816000000 {
opp-1008000000 {
opp-1200000000 {
opp-1416000000 {
opp-1512000000 {
opp-1608000000 {
- reserved-memory { #address-cells = <1>; #size-cells = <1>; ranges;
broken-no-flushp;
#dma-cells = <1>;
broken-no-flushp;
#dma-cells = <1>;
broken-no-flushp;
#dma-cells = <1>;
* is found.
}; };reg = <0xfe000000 0x1000000>;
timer {
compatible = "arm,armv7-timer";arm,use-physical-timer;
interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>, <GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>, <GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>, <GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>; clock-frequency = <24000000>;arm,cpu-registers-not-fw-configured;
always-on;
display-subsystem {
- sdmmc: mmc@ff0c0000 { compatible = "rockchip,rk3288-dw-mshc"; max-frequency = <150000000>; clocks = <&cru HCLK_SDMMC>, <&cru SCLK_SDMMC>, <&cru SCLK_SDMMC_DRV>, <&cru SCLK_SDMMC_SAMPLE>;
fifo-depth = <0x100>; interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>; reg = <0xff0c0000 0x4000>;clock-names = "biu", "ciu", "ciu-drive", "ciu-sample";
status = "disabled"; };reset-names = "reset";
- sdio0: mmc@ff0d0000 { compatible = "rockchip,rk3288-dw-mshc"; max-frequency = <150000000>; clocks = <&cru HCLK_SDIO0>, <&cru SCLK_SDIO0>, <&cru SCLK_SDIO0_DRV>, <&cru SCLK_SDIO0_SAMPLE>;
fifo-depth = <0x100>; interrupts = <GIC_SPI 33 IRQ_TYPE_LEVEL_HIGH>; reg = <0xff0d0000 0x4000>;clock-names = "biu", "ciu", "ciu-drive", "ciu-sample";
- sdio1: mmc@ff0e0000 { compatible = "rockchip,rk3288-dw-mshc"; max-frequency = <150000000>; clocks = <&cru HCLK_SDIO1>, <&cru SCLK_SDIO1>, <&cru SCLK_SDIO1_DRV>, <&cru SCLK_SDIO1_SAMPLE>;
fifo-depth = <0x100>; interrupts = <GIC_SPI 34 IRQ_TYPE_LEVEL_HIGH>; reg = <0xff0e0000 0x4000>;clock-names = "biu", "ciu", "ciu-drive", "ciu-sample";
- emmc: mmc@ff0f0000 { compatible = "rockchip,rk3288-dw-mshc"; max-frequency = <150000000>; clocks = <&cru HCLK_EMMC>, <&cru SCLK_EMMC>, <&cru SCLK_EMMC_DRV>, <&cru SCLK_EMMC_SAMPLE>;
fifo-depth = <0x100>; interrupts = <GIC_SPI 35 IRQ_TYPE_LEVEL_HIGH>; reg = <0xff0f0000 0x4000>;clock-names = "biu", "ciu", "ciu-drive", "ciu-sample";
status = "disabled"; };reset-names = "saradc-apb";
- uart0: serial@ff180000 { compatible = "rockchip,rk3288-uart", "snps,dw-apb-uart"; reg = <0xff180000 0x100>;
pinctrl-names = "default"; pinctrl-0 = <&uart0_xfer>; status = "disabled";dma-names = "tx", "rx";
pinctrl-names = "default"; pinctrl-0 = <&uart1_xfer>; status = "disabled";dma-names = "tx", "rx";
- uart3: serial@ff1b0000 { compatible = "rockchip,rk3288-uart", "snps,dw-apb-uart"; reg = <0xff1b0000 0x100>;
pinctrl-names = "default"; pinctrl-0 = <&uart3_xfer>; status = "disabled";dma-names = "tx", "rx";
pinctrl-names = "default"; pinctrl-0 = <&uart4_xfer>; status = "disabled"; };dma-names = "tx", "rx";
#dma-cells = <1>;
thermal-zones {
trips {
type = "passive";
type = "passive";
type = "critical";
cooling-maps {
map0 {
cooling-device =
map1 {
cooling-device =
trips {
type = "passive";
type = "critical";
cooling-maps {
map0 {
cooling-device =
#thermal-sensor-cells = <1>;pinctrl-2 = <&otp_pin>;
rockchip,grf = <&grf>; clocks = <&cru SCLK_MAC>, <&cru SCLK_MAC_RX>, <&cru SCLK_MAC_TX>,interrupt-names = "macirq", "eth_wake_irq";
- /* NOTE: doesn't work on RK3288, but was fixed on RK3288W */ usb_host0_ohci: usb@ff520000 { compatible = "generic-ohci";
interrupts = <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cru HCLK_USBHOST0>; phys = <&usbphy1>;reg = <0xff520000 0x100>;
phys = <&usbphy2>; phy-names = "usb2-phy";dr_mode = "host";
status = "disabled"; };snps,reset-phy-on-wake;
phys = <&usbphy0>; phy-names = "usb2-phy"; status = "disabled";g-tx-fifo-size = <256 128 128 64 64 32>;
#dma-cells = <1>;
status = "disabled"; };clock-names = "apb_pclk";
status = "disabled"; };clocks = <&cru PCLK_RKPWM>;
#pwm-cells = <2>;
pinctrl-names = "default"; pinctrl-0 = <&pwm3_pin>;#pwm-cells = <3>;
- bus_intmem: sram@ff700000 { compatible = "mmio-sram"; reg = <0xff700000 0x18000>; #address-cells = <1>;
- sram@ff720000 {
#size-cells = <0>;
* clocks devices
* *_RGA RGA
* *_EDP* EDP
* *_LVDS_* LVDS
* *_HDMI HDMI
* *_MIPI_* MIPI
<&cru ACLK_ISP>,
<&cru ACLK_RGA>,
<&cru ACLK_VIP>,
<&cru ACLK_VOP0>,
<&cru ACLK_VOP1>,
<&cru DCLK_VOP0>,
<&cru DCLK_VOP1>,
<&cru HCLK_IEP>,
<&cru HCLK_ISP>,
<&cru HCLK_RGA>,
<&cru HCLK_VIP>,
<&cru HCLK_VOP0>,
<&cru HCLK_VOP1>,
<&cru SCLK_EDP>,
<&cru SCLK_ISP>,
<&cru SCLK_RGA>;
<&qos_vio1_vop>,
<&qos_vio1_isp_w0>,
<&qos_vio1_isp_w1>,
<&qos_vio0_vop>,
<&qos_vio0_vip>,
<&qos_vio2_rga_r>,
<&qos_vio2_rga_w>,
<&qos_vio1_isp_r>;
<&qos_hevc_w>;
<&cru HCLK_VCODEC>;
<&qos_gpu_w>;
reboot-mode {
offset = <0x94>;
edp_phy: edp-phy {
#phy-cells = <0>;
usbphy: usbphy {
#size-cells = <0>;
#phy-cells = <0>;
reg = <0x320>;
#clock-cells = <0>;
#phy-cells = <0>;
reg = <0x334>;
#clock-cells = <0>;
#phy-cells = <0>;
reg = <0x348>;
#clock-cells = <0>;
status = "disabled"; };interrupts = <GIC_SPI 79 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&dmac_bus_s 3>; dma-names = "tx";clock-names = "mclk", "hclk";
pinctrl-names = "default"; pinctrl-0 = <&spdif_tx>; rockchip,grf = <&grf>;interrupts = <GIC_SPI 54 IRQ_TYPE_LEVEL_HIGH>;
#size-cells = <0>;
dmas = <&dmac_bus_s 0>, <&dmac_bus_s 1>; dma-names = "tx", "rx";clock-names = "i2s_clk", "i2s_hclk";
pinctrl-names = "default"; pinctrl-0 = <&i2s0_bus>;clocks = <&cru HCLK_I2S0>, <&cru SCLK_I2S0>;
#iommu-cells = <0>;
#iommu-cells = <0>;
rga: rga@ff920000 {
interrupts = <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cru ACLK_VOP0>, <&cru DCLK_VOP0>, <&cru HCLK_VOP0>; clock-names = "aclk_vop", "dclk_vop", "hclk_vop";reg = <0xff930000 0x19c>, <0xff931000 0x1000>;
resets = <&cru SRST_LCDC0_AXI>, <&cru SRST_LCDC0_AHB>, <&cru SRST_LCDC0_DCLK>; reset-names = "axi", "ahb", "dclk"; iommus = <&vopb_mmu>;power-domains = <&power RK3288_PD_VIO>;
status = "disabled";power-domains = <&power RK3288_PD_VIO>;
- vopb_out: port { #address-cells = <1>; #size-cells = <0>;
reg = <3>;
power-domains = <&power RK3288_PD_VIO>; #iommu-cells = <0>; status = "disabled";clock-names = "aclk", "iface";
interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cru ACLK_VOP1>, <&cru DCLK_VOP1>, <&cru HCLK_VOP1>; clock-names = "aclk_vop", "dclk_vop", "hclk_vop";reg = <0xff940000 0x19c>, <0xff941000 0x1000>;
resets = <&cru SRST_LCDC1_AXI>, <&cru SRST_LCDC1_AHB>, <&cru SRST_LCDC1_DCLK>; reset-names = "axi", "ahb", "dclk"; iommus = <&vopl_mmu>;power-domains = <&power RK3288_PD_VIO>;
- vopl_out: port { #address-cells = <1>; #size-cells = <0>;
reg = <3>;
power-domains = <&power RK3288_PD_VIO>; #iommu-cells = <0>; status = "disabled"; };clock-names = "aclk", "iface";
- mipi_dsi: mipi@ff960000 {
power-domains = <&power RK3288_PD_VIO>;clock-names = "ref", "pclk";
ports {
edp_in: port {
#size-cells = <0>;
reg = <0>;
reg = <1>;
reg-io-width = <4>;
rockchip,grf = <&grf>;ddc-i2c-bus = <&i2c5>;
status = "disabled";clock-names = "iahb", "isfr";
- ports {
hdmi_in: port {
};remote-endpoint = <&vopl_out_mipi>; }; };
rockchip,grf = <&grf>; status = "disabled";power-domains = <&power RK3288_PD_VIO>;
- ports { #address-cells = <1>; #size-cells = <0>;
- edp: dp@ff970000 {
phys = <&edp_phy>;
phy-names = "dp";
rockchip,grf = <&grf>;reset-names = "dp";
status = "disabled";#size-cells = <0>;
- ports {
reg = <1>;
mipi_in: port {
#size-cells = <0>;
edp_in: port@0 {
}; };remote-endpoint = <&vopl_out_edp>; }; };
status = "disable";
reg-io-width = <4>;
ports {
hdmi_in: port {
#size-cells = <0>;
reg = <0>;
reg = <1>;
interrupt-names = "vepu", "vdpu"; clocks = <&cru ACLK_VCODEC>, <&cru HCLK_VCODEC>;<GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>;
#iommu-cells = <0>;
#iommu-cells = <0>;
gpu: gpu@ffa30000 {
"arm,malit76x",
"arm,malit7xx",
"arm,mali-midgard";
reg = <0xffa30000 0x10000>; interrupts = <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>;compatible = "rockchip,rk3288-mali", "arm,mali-t760";
clocks = <&cru ACLK_GPU>;interrupt-names = "job", "mmu", "gpu";
/* KHz uV */
100000 950000
200000 950000
300000 1000000
400000 1100000
600000 1250000
opp-100000000 {
opp-200000000 {
opp-300000000 {
opp-400000000 {
opp-600000000 {
#dma-cells = <1>;
#size-cells = <1>;
cpu_id: cpu-id@7 {
reg = <0x07 0x10>;
reg = <0x17 0x1>;
interrupts = <GIC_PPI 9 0xf04>; };<0xffc02000 0x2000>, <0xffc04000 0x2000>, <0xffc06000 0x2000>;
- usbphy: phy {
#size-cells = <0>;
usbphy0: usb-phy0 {
#phy-cells = <0>;
reg = <0x320>;
usbphy1: usb-phy1 {
#phy-cells = <0>;
reg = <0x334>;
usbphy2: usb-phy2 {
#phy-cells = <0>;
reg = <0x348>;
output-low;
sleep {
rockchip,pins = <0 RK_PA0 1 &pcfg_pull_none>; }; ddrio_pwroff: ddrio-pwroff {
rockchip,pins = <0 RK_PA1 1 &pcfg_pull_none>; }; ddr0_retention: ddr0-retention {
rockchip,pins = <0 RK_PA2 1 &pcfg_pull_up>; }; ddr1_retention: ddr1-retention {
edp {
edp_hpd: edp-hpd {
};<6 RK_PB0 1 &pcfg_pull_none>; };
lcdc0 {
lcdc {
rockchip,pins = <6 RK_PC4 1 &pcfg_pull_none>; }; sdmmc_cmd: sdmmc-cmd {
rockchip,pins = <6 RK_PC6 1 &pcfg_pull_up>; }; sdmmc_bus1: sdmmc-bus1 {
rockchip,pins = <6 RK_PC0 1 &pcfg_pull_up>; }; sdmmc_bus4: sdmmc-bus4 {
rockchip,pins = <4 RK_PC4 1 &pcfg_pull_up>; }; sdio0_bus4: sdio0-bus4 {
<4 RK_PC7 1 &pcfg_pull_up>; }; sdio0_cmd: sdio0-cmd {
rockchip,pins = <4 RK_PD0 1 &pcfg_pull_up>; }; sdio0_clk: sdio0-clk {
rockchip,pins = <4 RK_PD1 1 &pcfg_pull_none>; }; sdio0_cd: sdio0-cd {
rockchip,pins = <4 RK_PD2 1 &pcfg_pull_up>; }; sdio0_wp: sdio0-wp {
rockchip,pins = <4 RK_PD3 1 &pcfg_pull_up>; }; sdio0_pwr: sdio0-pwr {
rockchip,pins = <4 RK_PD4 1 &pcfg_pull_up>; }; sdio0_bkpwr: sdio0-bkpwr {
rockchip,pins = <4 RK_PD5 1 &pcfg_pull_up>; }; sdio0_int: sdio0-int {
rockchip,pins = <3 RK_PD0 4 &pcfg_pull_up>; }; sdio1_bus4: sdio1-bus4 {
<3 RK_PD3 4 &pcfg_pull_up>; }; sdio1_cd: sdio1-cd {
rockchip,pins = <3 RK_PD4 4 &pcfg_pull_up>; }; sdio1_wp: sdio1-wp {
rockchip,pins = <3 RK_PD5 4 &pcfg_pull_up>; }; sdio1_bkpwr: sdio1-bkpwr {
rockchip,pins = <3 RK_PD6 4 &pcfg_pull_up>; }; sdio1_int: sdio1-int {
rockchip,pins = <3 RK_PD7 4 &pcfg_pull_up>; }; sdio1_cmd: sdio1-cmd {
rockchip,pins = <4 RK_PA6 4 &pcfg_pull_up>; }; sdio1_clk: sdio1-clk {
rockchip,pins = <4 RK_PA7 4 &pcfg_pull_none>; }; sdio1_pwr: sdio1-pwr {
rockchip,pins = <3 RK_PC2 2 &pcfg_pull_none>; }; emmc_cmd: emmc-cmd {
rockchip,pins = <3 RK_PC0 2 &pcfg_pull_up>; }; emmc_pwr: emmc-pwr {
rockchip,pins = <3 RK_PB1 2 &pcfg_pull_up>; }; emmc_bus1: emmc-bus1 {
rockchip,pins = <3 RK_PA0 2 &pcfg_pull_up>; }; emmc_bus4: emmc-bus4 {
<3 RK_PA3 2 &pcfg_pull_up>; }; emmc_bus8: emmc-bus8 {
}; spi1 { spi1_clk: spi1-clk {rockchip,pins = <5 RK_PC0 1 &pcfg_pull_up>; };
<4 RK_PC1 1 &pcfg_pull_none>; }; uart0_cts: uart0-cts {
rockchip,pins = <4 RK_PC2 1 &pcfg_pull_up>; }; uart0_rts: uart0-rts {
<5 RK_PB1 1 &pcfg_pull_none>; }; uart1_cts: uart1-cts {
rockchip,pins = <5 RK_PB2 1 &pcfg_pull_up>; }; uart1_rts: uart1-rts {
<7 RK_PB0 1 &pcfg_pull_none>; }; uart3_cts: uart3-cts {
rockchip,pins = <7 RK_PB1 1 &pcfg_pull_up>; }; uart3_rts: uart3-rts {
<5 RK_PB6 3 &pcfg_pull_none>; }; uart4_cts: uart4-cts {
rockchip,pins = <5 RK_PB4 3 &pcfg_pull_up>; }; uart4_rts: uart4-rts {
tsadc {
otp_pin: otp-pin {
otp_out: otp-out {
<4 RK_PA3 3 &pcfg_pull_none>; }; rmii_pins: rmii-pins {
}; };rockchip,pins = <6 RK_PB3 1 &pcfg_pull_none>; };
#size-cells = <0>;
pd_gpu {
pd_hevc {
<&cru HCLK_HEVC>;
pd_vio {
<&cru ACLK_ISP>,
<&cru ACLK_RGA>,
<&cru ACLK_VIP>,
<&cru ACLK_VOP0>,
<&cru ACLK_VOP1>,
<&cru DCLK_VOP0>,
<&cru DCLK_VOP1>,
<&cru HCLK_IEP>,
<&cru HCLK_ISP>,
<&cru HCLK_RGA>,
<&cru HCLK_VIP>,
<&cru HCLK_VOP0>,
<&cru HCLK_VOP1>,
<&cru SCLK_EDP>,
<&cru SCLK_ISP>,
<&cru SCLK_RGA>;
pd_video {
<&cru HCLK_VCODEC>;
Hi Johan,
I got build fail for phycore-rk3288 after this patch:
+Error: SPL image is too large (size 0x8800 than 0x8000) +Error: Bad parameters for image type
Thanks,
- Kever
sdcard-supply = <&vccio_sd>;
+&io_domains {
- status = "okay";
- sdcard-supply = <&vccio_sd>;
status = "okay";
+&io_domains {
- status = "okay";
- ir: ir-receiver { compatible = "gpio-ir-receiver"; gpios = <&gpio0 6 GPIO_ACTIVE_LOW>;
@@ -441,6 +425,20 @@ status = "okay"; };
+&io_domains {
- status = "okay";
diff --git a/arch/arm/dts/rk3288-thermal.dtsi b/arch/arm/dts/rk3288-thermal.dtsi deleted file mode 100644 index 87dd8142..00000000 --- a/arch/arm/dts/rk3288-thermal.dtsi +++ /dev/null @@ -1,87 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/*
-#include <dt-bindings/thermal/thermal.h>
-reserve_thermal: reserve_thermal {
- polling-delay-passive = <1000>; /* milliseconds */
- polling-delay = <5000>; /* milliseconds */
/* sensor ID */
- thermal-sensors = <&tsadc 0>;
-cpu_thermal: cpu_thermal {
- polling-delay-passive = <100>; /* milliseconds */
/* sensor ID */
- thermal-sensors = <&tsadc 1>;
- linux,hwmon;
- trips {
type = "passive";
type = "passive";
temperature = <100000>; /* millicelsius */
type = "critical";
- cooling-maps {
map0 {
cooling-device =
<&cpu0 THERMAL_NO_LIMIT 6>;
map1 {
cooling-device =
<&cpu0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>;
-gpu_thermal: gpu_thermal {
/* sensor ID */
- thermal-sensors = <&tsadc 2>;
- linux,hwmon;
- trips {
temperature = <80000>; /* millicelsius */
type = "passive";
type = "critical";
- cooling-maps {
map0 {
cooling-device =
-}; diff --git a/arch/arm/dts/rk3288-veyron-jerry.dts b/arch/arm/dts/rk3288-veyron-jerry.dts index ff7669eb..40fee55c 100644 --- a/arch/arm/dts/rk3288-veyron-jerry.dts +++ b/arch/arm/dts/rk3288-veyron-jerry.dts @@ -137,12 +137,6 @@ }; };
- edp {
edp_hpd: edp_hpd {
rockchip,pins = <7 11 RK_FUNC_2 &pcfg_pull_down>;
- emmc { /* Make sure eMMC is not in reset */ emmc_deassert_reset: emmc-deassert-reset {
diff --git a/arch/arm/dts/rk3288-veyron.dtsi b/arch/arm/dts/rk3288-veyron.dtsi index 4a9c27a4..ac9e815e 100644 --- a/arch/arm/dts/rk3288-veyron.dtsi +++ b/arch/arm/dts/rk3288-veyron.dtsi @@ -198,21 +198,6 @@ /* Faux input supply. See bt_regulator description. */ vin-supply = <&bt_regulator>; };
io-domains {
audio-supply = <&vcc18_codec>;
bb-supply = <&vcc33_io>;
dvp-supply = <&vcc_18>;
flash0-supply = <&vcc18_flashio>;
gpio1830-supply = <&vcc33_io>;
gpio30-supply = <&vcc33_io>;
lcdc-supply = <&vcc33_lcd>;
wifi-supply = <&vcc18_wl>;
&cpu0 {
@@ -503,6 +488,20 @@ clocks = <&cru HCLK_I2S0>, <&cru SCLK_I2S0>, <&cru SCLK_I2S0_OUT>; };
+&io_domains {
- status = "okay";
- audio-supply = <&vcc18_codec>;
- bb-supply = <&vcc33_io>;
- dvp-supply = <&vcc_18>;
- flash0-supply = <&vcc18_flashio>;
- gpio1830-supply = <&vcc33_io>;
- gpio30-supply = <&vcc33_io>;
- lcdc-supply = <&vcc33_lcd>;
- wifi-supply = <&vcc18_wl>;
@@ -560,10 +559,6 @@ status = "okay"; };
-&hdmi_audio {
- status = "okay";
- &gpu { status = "okay"; };
diff --git a/arch/arm/dts/rk3288.dtsi b/arch/arm/dts/rk3288.dtsi index c4abfa37..14a3f8e8 100644 --- a/arch/arm/dts/rk3288.dtsi +++ b/arch/arm/dts/rk3288.dtsi @@ -1,4 +1,4 @@ -// SPDX-License-Identifier: GPL-2.0+ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT)
#include <dt-bindings/gpio/gpio.h> #include <dt-bindings/interrupt-controller/irq.h> @@ -7,14 +7,18 @@ #include <dt-bindings/clock/rk3288-cru.h> #include <dt-bindings/power/rk3288-power.h> #include <dt-bindings/thermal/thermal.h> -#include <dt-bindings/video/rk3288.h> -#include "skeleton.dtsi" +#include <dt-bindings/soc/rockchip,boot-mode.h>
#size-cells = <1>;
compatible = "rockchip,rk3288";
interrupt-parent = <&gic>;
aliases {
ethernet0 = &gmac;
i2c0 = &i2c0; i2c1 = &i2c1; i2c2 = &i2c2;
@@ -35,6 +39,15 @@ spi2 = &spi2; };
- arm-pmu {
compatible = "arm,cortex-a12-pmu";
interrupts = <GIC_SPI 151 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 152 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 153 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 154 IRQ_TYPE_LEVEL_HIGH>;
interrupt-affinity = <&cpu0>, <&cpu1>, <&cpu2>, <&cpu3>;
@@ -45,85 +58,119 @@ device_type = "cpu"; compatible = "arm,cortex-a12"; reg = <0x500>;
/* KHz uV */
1800000 1400000
1704000 1350000
1608000 1300000
1512000 1250000
1416000 1200000
1200000 1100000
1008000 1050000
816000 1000000
696000 950000
600000 900000
408000 900000
216000 900000
126000 900000
resets = <&cru SRST_CORE0>;
operating-points-v2 = <&cpu_opp_table>; #cooling-cells = <2>; /* min followed by max */ clock-latency = <40000>; clocks = <&cru ARMCLK>;
cpu@501 {
cpu1: cpu@501 { device_type = "cpu"; compatible = "arm,cortex-a12"; reg = <0x501>; resets = <&cru SRST_CORE1>;
cpu@502 {
cpu2: cpu@502 { device_type = "cpu"; compatible = "arm,cortex-a12"; reg = <0x502>; resets = <&cru SRST_CORE2>;
cpu@503 {
cpu3: cpu@503 { device_type = "cpu"; compatible = "arm,cortex-a12"; reg = <0x503>; resets = <&cru SRST_CORE3>;
- amba {
compatible = "arm,amba-bus";
opp-shared;
opp-126000000 {
opp-hz = /bits/ 64 <126000000>;
opp-microvolt = <900000>;
opp-216000000 {
opp-hz = /bits/ 64 <216000000>;
opp-312000000 {
opp-hz = /bits/ 64 <312000000>;
opp-408000000 {
opp-hz = /bits/ 64 <408000000>;
opp-600000000 {
opp-696000000 {
opp-hz = /bits/ 64 <696000000>;
opp-816000000 {
opp-hz = /bits/ 64 <816000000>;
opp-1008000000 {
opp-hz = /bits/ 64 <1008000000>;
opp-microvolt = <1050000>;
opp-1200000000 {
opp-hz = /bits/ 64 <1200000000>;
opp-1416000000 {
opp-hz = /bits/ 64 <1416000000>;
opp-microvolt = <1200000>;
opp-1512000000 {
opp-hz = /bits/ 64 <1512000000>;
opp-microvolt = <1300000>;
opp-1608000000 {
opp-hz = /bits/ 64 <1608000000>;
opp-microvolt = <1350000>;
dmac_peri: dma-controller@ff250000 {
broken-no-flushp;
reg = <0xff250000 0x4000>;
interrupts = <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>;
#dma-cells = <1>;
clocks = <&cru ACLK_DMAC2>;
dmac_bus_ns: dma-controller@ff600000 {
broken-no-flushp;
reg = <0xff600000 0x4000>;
#dma-cells = <1>;
broken-no-flushp;
#dma-cells = <1>;
* The rk3288 cannot use the memory area above 0xfe000000
* for dma operations for some reason. While there is
* probably a better solution available somewhere, we
* haven't found it yet and while devices with 2GB of ram
* are not affected, this issue prevents 4GB from booting.
* So to make these devices at least bootable, block
* this area for the time being until the real solution
* is found.
dma-unusable@fe000000 {
@@ -135,14 +182,22 @@ };
timer {
always-on;
arm,no-tick-in-suspend;
timer: timer@ff810000 {
compatible = "rockchip,rk3288-timer";
reg = <0xff810000 0x20>;
interrupts = <GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru PCLK_TIMER>, <&xin24m>;
clock-names = "pclk", "timer";
display-subsystem {
@@ -150,51 +205,59 @@ ports = <&vopl_out>, <&vopb_out>; };
- sdmmc: dwmmc@ff0c0000 {
clock-names = "biu", "ciu", "ciu_drv", "ciu_sample";
resets = <&cru SRST_MMC0>;
- sdio0: dwmmc@ff0d0000 {
resets = <&cru SRST_SDIO0>;
- sdio1: dwmmc@ff0e0000 {
resets = <&cru SRST_SDIO1>;
- emmc: dwmmc@ff0f0000 {
resets = <&cru SRST_EMMC>;
@@ -205,6 +268,8 @@ #io-channel-cells = <1>; clocks = <&cru SCLK_SARADC>, <&cru PCLK_SARADC>; clock-names = "saradc", "apb_pclk";
resets = <&cru SRST_SARADC>;
@@ -304,6 +369,7 @@ pinctrl-0 = <&i2c5_xfer>; status = "disabled"; };
@@ -312,6 +378,8 @@ reg-io-width = <4>; clocks = <&cru SCLK_UART0>, <&cru PCLK_UART0>; clock-names = "baudclk", "apb_pclk";
dmas = <&dmac_peri 1>, <&dmac_peri 2>;
@@ -325,6 +393,8 @@ reg-io-width = <4>; clocks = <&cru SCLK_UART1>, <&cru PCLK_UART1>; clock-names = "baudclk", "apb_pclk";
dmas = <&dmac_peri 3>, <&dmac_peri 4>;
@@ -342,6 +412,7 @@ pinctrl-0 = <&uart2_xfer>; status = "disabled"; };
@@ -350,6 +421,8 @@ reg-io-width = <4>; clocks = <&cru SCLK_UART3>, <&cru PCLK_UART3>; clock-names = "baudclk", "apb_pclk";
dmas = <&dmac_peri 7>, <&dmac_peri 8>;
@@ -363,12 +436,104 @@ reg-io-width = <4>; clocks = <&cru SCLK_UART4>, <&cru PCLK_UART4>; clock-names = "baudclk", "apb_pclk";
dmas = <&dmac_peri 9>, <&dmac_peri 10>;
- thermal: thermal-zones {
#include "rk3288-thermal.dtsi"
#dma-cells = <1>;
thermal-zones {
reserve_thermal: reserve-thermal {
cpu_thermal: cpu-thermal {
trips {
cpu_alert0: cpu_alert0 {
temperature = <70000>; /* millicelsius */
hysteresis = <2000>; /* millicelsius */
type = "passive";
cpu_alert1: cpu_alert1 {
temperature = <75000>; /* millicelsius */
type = "passive";
cpu_crit: cpu_crit {
temperature = <90000>; /* millicelsius */
type = "critical";
cooling-maps {
map0 {
trip = <&cpu_alert0>;
cooling-device =
<&cpu0 THERMAL_NO_LIMIT 6>,
<&cpu1 THERMAL_NO_LIMIT 6>,
<&cpu2 THERMAL_NO_LIMIT 6>,
<&cpu3 THERMAL_NO_LIMIT 6>;
map1 {
trip = <&cpu_alert1>;
cooling-device =
<&cpu0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>,
<&cpu1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>,
<&cpu2 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>,
<&cpu3 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>;
gpu_thermal: gpu-thermal {
trips {
gpu_alert0: gpu_alert0 {
type = "passive";
gpu_crit: gpu_crit {
type = "critical";
cooling-maps {
map0 {
trip = <&gpu_alert0>;
cooling-device =
<&gpu THERMAL_NO_LIMIT THERMAL_NO_LIMIT>;
tsadc: tsadc@ff280000 {
@@ -379,18 +544,22 @@ clock-names = "tsadc", "apb_pclk"; resets = <&cru SRST_TSADC>; reset-names = "tsadc-apb";
pinctrl-names = "otp_out";
pinctrl-0 = <&otp_out>;
pinctrl-names = "init", "default", "sleep";
pinctrl-0 = <&otp_pin>;
pinctrl-1 = <&otp_out>;
hw-shut-temp = <125000>;
rockchip,hw-tshut-temp = <95000>;
gmac: ethernet@ff290000 { compatible = "rockchip,rk3288-gmac"; reg = <0xff290000 0x10000>;
interrupts = <GIC_SPI 27 IRQ_TYPE_LEVEL_HIGH>;
interrupt-names = "macirq";
interrupts = <GIC_SPI 27 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 28 IRQ_TYPE_LEVEL_HIGH>;
@@ -400,6 +569,9 @@ "mac_clk_rx", "mac_clk_tx", "clk_mac_ref", "clk_mac_refout", "aclk_mac", "pclk_mac";
resets = <&cru SRST_MAC>;
reset-names = "stmmaceth";
usb_host0_ehci: usb@ff500000 {
@@ -407,16 +579,15 @@ reg = <0xff500000 0x100>; interrupts = <GIC_SPI 24 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cru HCLK_USBHOST0>;
clock-names = "usbhost";
phys = <&usbphy1>; phy-names = "usb"; status = "disabled"; };
/* NOTE: doesn't work on RK3288, but fixed on RK3288W */
reg = <0x0 0xff520000 0x0 0x100>;
@@ -431,8 +602,10 @@ interrupts = <GIC_SPI 25 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cru HCLK_USBHOST1>; clock-names = "otg";
@@ -444,6 +617,9 @@ clocks = <&cru HCLK_OTG0>; clock-names = "otg"; dr_mode = "otg";
g-np-tx-fifo-size = <16>;
g-rx-fifo-size = <275>;
@@ -454,7 +630,19 @@ reg = <0xff5c0000 0x100>; interrupts = <GIC_SPI 26 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cru HCLK_HSIC>;
- dmac_bus_ns: dma-controller@ff600000 {
#dma-cells = <1>;
@@ -490,9 +678,7 @@ #pwm-cells = <3>; pinctrl-names = "default"; pinctrl-0 = <&pwm0_pin>;
clocks = <&cru PCLK_PWM>;
clock-names = "pwm";
@@ -502,9 +688,7 @@ #pwm-cells = <3>; pinctrl-names = "default"; pinctrl-0 = <&pwm1_pin>;
@@ -514,25 +698,21 @@ #pwm-cells = <3>; pinctrl-names = "default"; pinctrl-0 = <&pwm2_pin>;
pwm3: pwm@ff680030 { compatible = "rockchip,rk3288-pwm"; reg = <0xff680030 0x10>;
#pwm-cells = <2>;
- bus_intmem: bus_intmem@ff700000 {
@@ -544,14 +724,134 @@ }; };
- sram@ff720000 {
pmu_sram: sram@ff720000 { compatible = "rockchip,rk3288-pmu-sram", "mmio-sram"; reg = <0xff720000 0x1000>; };
pmu: power-management@ff730000 {
compatible = "rockchip,rk3288-pmu", "syscon";
compatible = "rockchip,rk3288-pmu", "syscon", "simple-mfd";
reg = <0xff730000 0x100>;
#size-cells = <0>;
assigned-clocks = <&cru SCLK_EDP_24M>;
assigned-clock-parents = <&xin24m>;
* Note: Although SCLK_* are the working clocks
* of device without including on the NOC, needed for
* synchronous reset.
* The clocks on the which NOC:
* ACLK_IEP/ACLK_VIP/ACLK_VOP0 are on ACLK_VIO0_NIU.
* ACLK_ISP/ACLK_VOP1 are on ACLK_VIO1_NIU.
* ACLK_RGA is on ACLK_RGA_NIU.
* The others (HCLK_*,PLCK_*) are on HCLK_VIO_NIU.
* Which clock are device clocks:
* clocks devices
* *_IEP IEP:Image Enhancement Processor
* *_ISP ISP:Image Signal Processing
* *_VIP VIP:Video Input Processor
* *_VOP* VOP:Visual Output Processor
* *_RGA RGA
* *_EDP* EDP
* *_LVDS_* LVDS
* *_HDMI HDMI
* *_MIPI_* MIPI
power-domain@RK3288_PD_VIO {
<&cru ACLK_ISP>,
<&cru ACLK_RGA>,
<&cru ACLK_VIP>,
<&cru ACLK_VOP0>,
<&cru ACLK_VOP1>,
<&cru DCLK_VOP0>,
<&cru DCLK_VOP1>,
<&cru HCLK_IEP>,
<&cru HCLK_ISP>,
<&cru HCLK_RGA>,
<&cru HCLK_VIP>,
<&cru HCLK_VOP0>,
<&cru HCLK_VOP1>,
<&cru SCLK_EDP>,
<&cru SCLK_ISP>,
<&cru SCLK_RGA>;
pm_qos = <&qos_vio0_iep>,
<&qos_vio1_vop>,
<&qos_vio1_isp_w0>,
<&qos_vio1_isp_w1>,
<&qos_vio0_vop>,
<&qos_vio0_vip>,
<&qos_vio2_rga_r>,
<&qos_vio2_rga_w>,
<&qos_vio1_isp_r>;
#power-domain-cells = <0>;
* Note: The following 3 are HEVC(H.265) clocks,
* and on the ACLK_HEVC_NIU (NOC).
power-domain@RK3288_PD_HEVC {
<&cru SCLK_HEVC_CORE>;
pm_qos = <&qos_hevc_r>,
<&qos_hevc_w>;
* Note: ACLK_VCODEC/HCLK_VCODEC are VCODEC
* (video endecoder & decoder) clocks that on the
* ACLK_VCODEC_NIU and HCLK_VCODEC_NIU (NOC).
power-domain@RK3288_PD_VIDEO {
<&cru HCLK_VCODEC>;
pm_qos = <&qos_video>;
* Note: ACLK_GPU is the GPU clock,
* and on the ACLK_GPU_NIU (NOC).
power-domain@RK3288_PD_GPU {
pm_qos = <&qos_gpu_r>,
<&qos_gpu_w>;
reboot-mode {
compatible = "syscon-reboot-mode";
offset = <0x94>;
mode-normal = <BOOT_NORMAL>;
mode-recovery = <BOOT_RECOVERY>;
mode-bootloader = <BOOT_FASTBOOT>;
mode-loader = <BOOT_BL_DOWNLOAD>;
sgrf: syscon@ff740000 {
@@ -578,15 +878,65 @@ };
grf: syscon@ff770000 {
compatible = "rockchip,rk3288-grf", "syscon";
compatible = "rockchip,rk3288-grf", "syscon", "simple-mfd";
reg = <0xff770000 0x1000>;
edp_phy: edp-phy {
compatible = "rockchip,rk3288-dp-phy";
clock-names = "24m";
#phy-cells = <0>;
compatible = "rockchip,rk3288-io-voltage-domain";
usbphy: usbphy {
#size-cells = <0>;
usbphy0: usb-phy@320 {
#phy-cells = <0>;
reg = <0x320>;
#clock-cells = <0>;
resets = <&cru SRST_USBOTG_PHY>;
reset-names = "phy-reset";
usbphy1: usb-phy@334 {
#phy-cells = <0>;
reg = <0x334>;
#clock-cells = <0>;
resets = <&cru SRST_USBHOST0_PHY>;
usbphy2: usb-phy@348 {
#phy-cells = <0>;
reg = <0x348>;
#clock-cells = <0>;
resets = <&cru SRST_USBHOST1_PHY>;
wdt: watchdog@ff800000 { compatible = "rockchip,rk3288-wdt", "snps,dw-wdt"; reg = <0xff800000 0x100>; clocks = <&cru PCLK_WDT>;
@@ -594,11 +944,11 @@ compatible = "rockchip,rk3288-spdif", "rockchip,rk3066-spdif"; reg = <0xff8b0000 0x10000>; #sound-dai-cells = <0>;
clock-names = "hclk", "mclk";
clocks = <&cru HCLK_SPDIF8CH>, <&cru SCLK_SPDIF8CH>;
clocks = <&cru SCLK_SPDIF8CH>, <&cru HCLK_SPDIF8CH>;
@@ -608,50 +958,97 @@ i2s: i2s@ff890000 { compatible = "rockchip,rk3288-i2s", "rockchip,rk3066-i2s"; reg = <0xff890000 0x10000>;
#size-cells = <0>;
#sound-dai-cells = <1>;
interrupts = <GIC_SPI 53 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru SCLK_I2S0>, <&cru HCLK_I2S0>;
clock-names = "i2s_hclk", "i2s_clk";
rockchip,playback-channels = <8>;
rockchip,capture-channels = <2>;
crypto: cypto-controller@ff8a0000 {
compatible = "rockchip,rk3288-crypto";
reg = <0xff8a0000 0x4000>;
interrupts = <GIC_SPI 48 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru ACLK_CRYPTO>, <&cru HCLK_CRYPTO>,
<&cru SCLK_CRYPTO>, <&cru ACLK_DMAC1>;
clock-names = "aclk", "hclk", "sclk", "apb_pclk";
resets = <&cru SRST_CRYPTO>;
reset-names = "crypto-rst";
iep_mmu: iommu@ff900800 {
reg = <0xff900800 0x40>;
interrupts = <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru ACLK_IEP>, <&cru HCLK_IEP>;
#iommu-cells = <0>;
isp_mmu: iommu@ff914000 {
reg = <0xff914000 0x100>, <0xff915000 0x100>;
interrupts = <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru ACLK_ISP>, <&cru HCLK_ISP>;
#iommu-cells = <0>;
rockchip,disable-mmu-reset;
rga: rga@ff920000 {
compatible = "rockchip,rk3288-rga";
reg = <0xff920000 0x180>;
interrupts = <GIC_SPI 18 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru ACLK_RGA>, <&cru HCLK_RGA>, <&cru SCLK_RGA>;
clock-names = "aclk", "hclk", "sclk";
resets = <&cru SRST_RGA_CORE>, <&cru SRST_RGA_AXI>, <&cru SRST_RGA_AHB>;
reset-names = "core", "axi", "ahb";
vopb: vop@ff930000 { compatible = "rockchip,rk3288-vop";
reg = <0xff930000 0x19c>;
vopb_out_edp: endpoint@0 {
vopb_out_hdmi: endpoint@0 { reg = <0>;
remote-endpoint = <&edp_in_vopb>;
remote-endpoint = <&hdmi_in_vopb>; };
vopb_out_hdmi: endpoint@1 {
vopb_out_edp: endpoint@1 { reg = <1>;
remote-endpoint = <&edp_in_vopb>; };
vopb_out_lvds: endpoint@2 {
vopb_out_mipi: endpoint@2 { reg = <2>;
remote-endpoint = <&lvds_in_vopb>;
vopb_out_mipi: endpoint@3 {
reg = <3>; remote-endpoint = <&mipi_in_vopb>; };
vopb_out_lvds: endpoint@3 {
reg = <3>;
@@ -659,7 +1056,8 @@ compatible = "rockchip,iommu"; reg = <0xff930300 0x100>; interrupts = <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>;
interrupt-names = "vopb_mmu";
clocks = <&cru ACLK_VOP0>, <&cru HCLK_VOP0>;
@@ -667,35 +1065,39 @@
vopl: vop@ff940000 { compatible = "rockchip,rk3288-vop";
reg = <0xff940000 0x19c>;
vopl_out_edp: endpoint@0 {
vopl_out_hdmi: endpoint@0 { reg = <0>;
remote-endpoint = <&edp_in_vopl>;
remote-endpoint = <&hdmi_in_vopl>; };
vopl_out_hdmi: endpoint@1 {
vopl_out_edp: endpoint@1 { reg = <1>;
remote-endpoint = <&edp_in_vopl>; };
vopl_out_lvds: endpoint@2 {
vopl_out_mipi: endpoint@2 { reg = <2>;
remote-endpoint = <&lvds_in_vopl>;
vopl_out_mipi: endpoint@3 {
reg = <3>; remote-endpoint = <&mipi_in_vopl>; };
vopl_out_lvds: endpoint@3 {
reg = <3>;
@@ -703,60 +1105,34 @@ compatible = "rockchip,iommu"; reg = <0xff940300 0x100>; interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>;
interrupt-names = "vopl_mmu";
clocks = <&cru ACLK_VOP1>, <&cru HCLK_VOP1>;
- edp: edp@ff970000 {
compatible = "rockchip,rk3288-edp";
clocks = <&cru SCLK_EDP>, <&cru SCLK_EDP_24M>, <&cru PCLK_EDP_CTRL>;
ports {
edp_in: port {
#size-cells = <0>;
reg = <0>;
reg = <1>;
reg-io-width = <4>;
- ports {
hdmi_in: port {
phys = <&edp_phy>;
phy-names = "dp";
- ports {
reg = <1>;
mipi_in: port {
#size-cells = <0>;
edp_in: port@0 {
status = "disable";
reg-io-width = <4>;
ports {
hdmi_in: port {
#size-cells = <0>;
reg = <0>;
reg = <1>;
#iommu-cells = <0>;
#iommu-cells = <0>;
gpu: gpu@ffa30000 {
"arm,malit76x",
"arm,malit7xx",
"arm,mali-midgard";
/* KHz uV */
100000 950000
200000 950000
300000 1000000
400000 1100000
600000 1250000
opp-100000000 {
opp-200000000 {
opp-300000000 {
opp-400000000 {
opp-600000000 {
#dma-cells = <1>;
#size-cells = <1>;
cpu_id: cpu-id@7 {
reg = <0x07 0x10>;
reg = <0x17 0x1>;
- usbphy: phy {
#size-cells = <0>;
usbphy0: usb-phy0 {
#phy-cells = <0>;
reg = <0x320>;
usbphy1: usb-phy1 {
#phy-cells = <0>;
reg = <0x334>;
usbphy2: usb-phy2 {
#phy-cells = <0>;
reg = <0x348>;
output-low;
sleep {
edp {
edp_hpd: edp-hpd {
lcdc0 {
lcdc {
tsadc {
otp_pin: otp-pin {
otp_out: otp-out {
#size-cells = <0>;
pd_gpu {
pd_hevc {
<&cru HCLK_HEVC>;
pd_vio {
<&cru ACLK_ISP>,
<&cru ACLK_RGA>,
<&cru ACLK_VIP>,
<&cru ACLK_VOP0>,
<&cru ACLK_VOP1>,
<&cru DCLK_VOP0>,
<&cru DCLK_VOP1>,
<&cru HCLK_IEP>,
<&cru HCLK_ISP>,
<&cru HCLK_RGA>,
<&cru HCLK_VIP>,
<&cru HCLK_VOP0>,
<&cru HCLK_VOP1>,
<&cru SCLK_EDP>,
<&cru SCLK_ISP>,
<&cru SCLK_RGA>;
pd_video {
<&cru HCLK_VCODEC>;
On 4/15/22 02:40, Kever Yang wrote:
Hi Johan,
Could you disclose your bash commands for reproducing? I've downloaded from your git on April 15th 2022. Added missing patches and compiled. No warning seen here.
u-boot-spl.bin size 31.9 KiB (32675 bytes) ==> 0x7FA3 so below 0x8000 == 32768 bytes.
For rk3288 SPL images with OF_PLATDATA the ns16550.c and serial_rockchip.c driver are now included due to DM_DRIVER_ALIAS fix for SPL_OF_PLATDATA, but this config is compiled with CONFIG_SPL_OF_REAL=y.
Your patch for: rockchip: fix boot_devices constants contains a warning: check for migrated symbols...
What does it check and is that something I can fix?
For patches 9,10 and 11 I'm planning a v4 with:
ec-interrupt in u-boot-xxxx.dtsi
The driver rk_edp.c needs too fixing to comply with current Linux DP node.
I need board maintainers with hardware for that to fix and check.
compatible ="cnm,n116bgeea2","simple-panel"; vs. compatible = "innolux,n116bge"; ==> compatible = "simple-panel";
compatible = "rockchip,rk3288-edp"; vs. compatible = "rockchip,rk3288-dp";
ret = uclass_get_device_by_phandle(UCLASS_PANEL, dev, "rockchip,panel", &priv->panel);
clock-names = "clk_edp", "clk_edp_24m", "pclk_edp"; // U-boot ret = clk_get_by_index(dev, 1, &clk);
vs. clock-names = "dp", "pclk"; // Linux
ret = reset_get_by_name(dev, "dp", &dp_rst); vs. reset-names = "edp"; //rk3288 reset-names = "dp"; //rk3399
=== Let me know what you prefere. Please offload the (dt-header) patches that are ready, so that I don't have to resend them all the time.
Kind regards,
Johan
git clone --depth 40 https://source.denx.de/u-boot/custodians/u-boot-rockchip.git
git am v3-0009-arm-dts-rockchip-sync-rk3288.dtsi-from-Linux.patch git am v3-0010-arm-dts-rockchip-sync-rk3288-DT-boards-from-Linux.patch git am v3-0011-arm-dts-rockchip-sync-rk3288-veyron-DT-from-Linux.patch
make CROSS_COMPILE=arm-linux-gnueabihf- phycore-rk3288_defconfig all
mkimage ???
Thanks,
- Kever
Changed V3: Â Â change reg size
diff --git a/arch/arm/dts/rk3288-evb.dtsi b/arch/arm/dts/rk3288-evb.dtsi index 04902c0b..72da8847 100644 --- a/arch/arm/dts/rk3288-evb.dtsi +++ b/arch/arm/dts/rk3288-evb.dtsi @@ -448,7 +448,7 @@ Â Â Â Â Â status = "okay"; Â }; Â -&mipi_dsi0 { +&mipi_dsi { Â Â Â Â Â status = "disabled"; Â Â Â Â Â rockchip,panel = <&panel>; Â Â Â Â Â display-timings { diff --git a/arch/arm/dts/rk3288-miqi.dtsi b/arch/arm/dts/rk3288-miqi.dtsi index cb80cbf2..b1c286c9 100644 --- a/arch/arm/dts/rk3288-miqi.dtsi +++ b/arch/arm/dts/rk3288-miqi.dtsi @@ -18,21 +18,6 @@ Â Â Â Â Â Â Â Â Â clock-output-names = "ext_gmac"; Â Â Â Â Â }; Â -Â Â Â io_domains: io-domains { -Â Â Â Â Â Â Â compatible = "rockchip,rk3288-io-voltage-domain"; -Â Â Â Â Â Â Â rockchip,grf = <&grf>;
-Â Â Â Â Â Â Â audio-supply = <&vcca_33>; -Â Â Â Â Â Â Â flash0-supply = <&vcc_flash>; -Â Â Â Â Â Â Â flash1-supply = <&vcc_lan>; -Â Â Â Â Â Â Â gpio30-supply = <&vcc_io>; -Â Â Â Â Â Â Â gpio1830-supply = <&vcc_io>; -Â Â Â Â Â Â Â lcdc-supply = <&vcc_io>; -Â Â Â Â Â Â Â sdcard-supply = <&vccio_sd>; -Â Â Â Â Â Â Â wifi-supply = <&vcc_18>; -Â Â Â };
leds { Â Â Â Â Â Â Â Â Â compatible = "gpio-leds"; Â @@ -277,6 +262,19 @@ Â Â Â Â Â status = "okay"; Â }; Â +&io_domains { +Â Â Â status = "okay";
+Â Â Â audio-supply = <&vcca_33>; +Â Â Â flash0-supply = <&vcc_flash>; +Â Â Â flash1-supply = <&vcc_lan>; +Â Â Â gpio30-supply = <&vcc_io>; +Â Â Â gpio1830-supply = <&vcc_io>; +Â Â Â lcdc-supply = <&vcc_io>; +Â Â Â sdcard-supply = <&vccio_sd>; +Â Â Â wifi-supply = <&vcc_18>; +};
&pinctrl { Â Â Â Â Â pcfg_output_high: pcfg-output-high { Â Â Â Â Â Â Â Â Â output-high; diff --git a/arch/arm/dts/rk3288-phycore-som.dtsi b/arch/arm/dts/rk3288-phycore-som.dtsi index 821525f7..8ac695c8 100644 --- a/arch/arm/dts/rk3288-phycore-som.dtsi +++ b/arch/arm/dts/rk3288-phycore-som.dtsi @@ -71,22 +71,6 @@ Â Â Â Â Â Â Â Â Â clock-output-names = "ext_gmac"; Â Â Â Â Â }; Â -Â Â Â io_domains: io_domains { -Â Â Â Â Â Â Â compatible = "rockchip,rk3288-io-voltage-domain";
-Â Â Â Â Â Â Â status = "okay"; -Â Â Â Â Â Â Â sdcard-supply = <&vdd_io_sd>; -Â Â Â Â Â Â Â flash0-supply = <&vdd_emmc_io>; -Â Â Â Â Â Â Â flash1-supply = <&vdd_misc_1v8>; -Â Â Â Â Â Â Â gpio1830-supply = <&vdd_3v3_io>; -Â Â Â Â Â Â Â gpio30-supply = <&vdd_3v3_io>; -Â Â Â Â Â Â Â bb-supply = <&vdd_3v3_io>; -Â Â Â Â Â Â Â dvp-supply = <&vdd_3v3_io>; -Â Â Â Â Â Â Â lcdc-supply = <&vdd_3v3_io>; -Â Â Â Â Â Â Â wifi-supply = <&vdd_3v3_io>; -Â Â Â Â Â Â Â audio-supply = <&vdd_3v3_io>; -Â Â Â };
leds: user-leds { Â Â Â Â Â Â Â Â Â compatible = "gpio-leds"; Â Â Â Â Â Â Â Â Â pinctrl-names = "default"; @@ -197,6 +181,20 @@ Â Â Â Â Â ddc-i2c-bus = <&i2c5>; Â }; Â +&io_domains { +Â Â Â status = "okay"; +Â Â Â sdcard-supply = <&vdd_io_sd>; +Â Â Â flash0-supply = <&vdd_emmc_io>; +Â Â Â flash1-supply = <&vdd_misc_1v8>; +Â Â Â gpio1830-supply = <&vdd_3v3_io>; +Â Â Â gpio30-supply = <&vdd_3v3_io>; +Â Â Â bb-supply = <&vdd_3v3_io>; +Â Â Â dvp-supply = <&vdd_3v3_io>; +Â Â Â lcdc-supply = <&vdd_3v3_io>; +Â Â Â wifi-supply = <&vdd_3v3_io>; +Â Â Â audio-supply = <&vdd_3v3_io>; +};
&i2c0 { Â Â Â Â Â status = "okay"; Â Â Â Â Â clock-frequency = <400000>; diff --git a/arch/arm/dts/rk3288-popmetal.dtsi b/arch/arm/dts/rk3288-popmetal.dtsi index 63785eb5..bcd8fded 100644 --- a/arch/arm/dts/rk3288-popmetal.dtsi +++ b/arch/arm/dts/rk3288-popmetal.dtsi @@ -69,22 +69,6 @@ Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â }; Â -Â Â Â io_domains: io-domains { -Â Â Â Â Â Â Â compatible = "rockchip,rk3288-io-voltage-domain"; -Â Â Â Â Â Â Â rockchip,grf = <&grf>;
-Â Â Â Â Â Â Â audio-supply = <&vcca_33>; -Â Â Â Â Â Â Â bb-supply = <&vcc_io>; -Â Â Â Â Â Â Â dvp-supply = <&vcc18_dvp>; -Â Â Â Â Â Â Â flash0-supply = <&vcc_flash>; -Â Â Â Â Â Â Â flash1-supply = <&vcc_lan>; -Â Â Â Â Â Â Â gpio30-supply = <&vcc_io>; -Â Â Â Â Â Â Â gpio1830-supply = <&vcc_io>; -Â Â Â Â Â Â Â lcdc-supply = <&vcc_io>; -Â Â Â Â Â Â Â sdcard-supply = <&vccio_sd>; -Â Â Â Â Â Â Â wifi-supply = <&vccio_wl>; -Â Â Â };
ir: ir-receiver { Â Â Â Â Â Â Â Â Â compatible = "gpio-ir-receiver"; Â Â Â Â Â Â Â Â Â gpios = <&gpio0 6 GPIO_ACTIVE_LOW>; @@ -441,6 +425,20 @@ Â Â Â Â Â status = "okay"; Â }; Â +&io_domains { +Â Â Â status = "okay"; +Â Â Â audio-supply = <&vcca_33>; +Â Â Â bb-supply = <&vcc_io>; +Â Â Â dvp-supply = <&vcc18_dvp>; +Â Â Â flash0-supply = <&vcc_flash>; +Â Â Â flash1-supply = <&vcc_lan>; +Â Â Â gpio30-supply = <&vcc_io>; +Â Â Â gpio1830-supply = <&vcc_io>; +Â Â Â lcdc-supply = <&vcc_io>; +Â Â Â sdcard-supply = <&vccio_sd>; +Â Â Â wifi-supply = <&vccio_wl>; +};
&pinctrl { Â Â Â Â Â ak8963 { Â Â Â Â Â Â Â Â Â comp_int: comp-int { diff --git a/arch/arm/dts/rk3288-thermal.dtsi b/arch/arm/dts/rk3288-thermal.dtsi deleted file mode 100644 index 87dd8142..00000000 --- a/arch/arm/dts/rk3288-thermal.dtsi +++ /dev/null @@ -1,87 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/*
-reserve_thermal: reserve_thermal { -Â Â Â polling-delay-passive = <1000>; /* milliseconds */ -Â Â Â polling-delay = <5000>; /* milliseconds */
-           /* sensor   ID */ -   thermal-sensors = <&tsadc   0>;
-cpu_thermal: cpu_thermal { -Â Â Â polling-delay-passive = <100>; /* milliseconds */ -Â Â Â polling-delay = <5000>; /* milliseconds */
-           /* sensor   ID */ -   thermal-sensors = <&tsadc   1>; -   linux,hwmon;
-Â Â Â trips { -Â Â Â Â Â Â Â cpu_alert0: cpu_alert0 { -Â Â Â Â Â Â Â Â Â Â Â temperature = <70000>; /* millicelsius */ -Â Â Â Â Â Â Â Â Â Â Â hysteresis = <2000>; /* millicelsius */ -Â Â Â Â Â Â Â Â Â Â Â type = "passive"; -Â Â Â Â Â Â Â }; -Â Â Â Â Â Â Â cpu_alert1: cpu_alert1 { -Â Â Â Â Â Â Â Â Â Â Â temperature = <75000>; /* millicelsius */ -Â Â Â Â Â Â Â Â Â Â Â hysteresis = <2000>; /* millicelsius */ -Â Â Â Â Â Â Â Â Â Â Â type = "passive"; -Â Â Â Â Â Â Â }; -Â Â Â Â Â Â Â cpu_crit: cpu_crit { -Â Â Â Â Â Â Â Â Â Â Â temperature = <100000>; /* millicelsius */ -Â Â Â Â Â Â Â Â Â Â Â hysteresis = <2000>; /* millicelsius */ -Â Â Â Â Â Â Â Â Â Â Â type = "critical"; -Â Â Â Â Â Â Â }; -Â Â Â };
-Â Â Â cooling-maps { -Â Â Â Â Â Â Â map0 { -Â Â Â Â Â Â Â Â Â Â Â trip = <&cpu_alert0>; -Â Â Â Â Â Â Â Â Â Â Â cooling-device = -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <&cpu0 THERMAL_NO_LIMIT 6>; -Â Â Â Â Â Â Â }; -Â Â Â Â Â Â Â map1 { -Â Â Â Â Â Â Â Â Â Â Â trip = <&cpu_alert1>; -Â Â Â Â Â Â Â Â Â Â Â cooling-device = -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <&cpu0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; -Â Â Â Â Â Â Â }; -Â Â Â }; -};
-gpu_thermal: gpu_thermal { -Â Â Â polling-delay-passive = <100>; /* milliseconds */ -Â Â Â polling-delay = <5000>; /* milliseconds */
-           /* sensor   ID */ -   thermal-sensors = <&tsadc   2>; -   linux,hwmon;
-Â Â Â trips { -Â Â Â Â Â Â Â gpu_alert0: gpu_alert0 { -Â Â Â Â Â Â Â Â Â Â Â temperature = <80000>; /* millicelsius */ -Â Â Â Â Â Â Â Â Â Â Â hysteresis = <2000>; /* millicelsius */ -Â Â Â Â Â Â Â Â Â Â Â type = "passive"; -Â Â Â Â Â Â Â }; -Â Â Â Â Â Â Â gpu_crit: gpu_crit { -Â Â Â Â Â Â Â Â Â Â Â temperature = <100000>; /* millicelsius */ -Â Â Â Â Â Â Â Â Â Â Â hysteresis = <2000>; /* millicelsius */ -Â Â Â Â Â Â Â Â Â Â Â type = "critical"; -Â Â Â Â Â Â Â }; -Â Â Â };
-Â Â Â cooling-maps { -Â Â Â Â Â Â Â map0 { -Â Â Â Â Â Â Â Â Â Â Â trip = <&gpu_alert0>; -Â Â Â Â Â Â Â Â Â Â Â cooling-device = -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <&cpu0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; -Â Â Â Â Â Â Â }; -Â Â Â }; -}; diff --git a/arch/arm/dts/rk3288-veyron-jerry.dts b/arch/arm/dts/rk3288-veyron-jerry.dts index ff7669eb..40fee55c 100644 --- a/arch/arm/dts/rk3288-veyron-jerry.dts +++ b/arch/arm/dts/rk3288-veyron-jerry.dts @@ -137,12 +137,6 @@ Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â }; Â -Â Â Â edp { -Â Â Â Â Â Â Â edp_hpd: edp_hpd { -Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <7 11 RK_FUNC_2 &pcfg_pull_down>; -Â Â Â Â Â Â Â }; -Â Â Â };
emmc {          /* Make sure eMMC is not in reset */          emmc_deassert_reset: emmc-deassert-reset { diff --git a/arch/arm/dts/rk3288-veyron.dtsi b/arch/arm/dts/rk3288-veyron.dtsi index 4a9c27a4..ac9e815e 100644 --- a/arch/arm/dts/rk3288-veyron.dtsi +++ b/arch/arm/dts/rk3288-veyron.dtsi @@ -198,21 +198,6 @@          /* Faux input supply. See bt_regulator description. */          vin-supply = <&bt_regulator>;      };
-Â Â Â io-domains { -Â Â Â Â Â Â Â compatible = "rockchip,rk3288-io-voltage-domain"; -Â Â Â Â Â Â Â rockchip,grf = <&grf>;
-Â Â Â Â Â Â Â audio-supply = <&vcc18_codec>; -Â Â Â Â Â Â Â bb-supply = <&vcc33_io>; -Â Â Â Â Â Â Â dvp-supply = <&vcc_18>; -Â Â Â Â Â Â Â flash0-supply = <&vcc18_flashio>; -Â Â Â Â Â Â Â gpio1830-supply = <&vcc33_io>; -Â Â Â Â Â Â Â gpio30-supply = <&vcc33_io>; -Â Â Â Â Â Â Â lcdc-supply = <&vcc33_lcd>; -Â Â Â Â Â Â Â sdcard-supply = <&vccio_sd>; -Â Â Â Â Â Â Â wifi-supply = <&vcc18_wl>; -Â Â Â }; Â }; Â Â &cpu0 { @@ -503,6 +488,20 @@ Â Â Â Â Â clocks = <&cru HCLK_I2S0>, <&cru SCLK_I2S0>, <&cru SCLK_I2S0_OUT>; Â }; Â +&io_domains { +Â Â Â status = "okay";
+Â Â Â audio-supply = <&vcc18_codec>; +Â Â Â bb-supply = <&vcc33_io>; +Â Â Â dvp-supply = <&vcc_18>; +Â Â Â flash0-supply = <&vcc18_flashio>; +Â Â Â gpio1830-supply = <&vcc33_io>; +Â Â Â gpio30-supply = <&vcc33_io>; +Â Â Â lcdc-supply = <&vcc33_lcd>; +Â Â Â sdcard-supply = <&vccio_sd>; +Â Â Â wifi-supply = <&vcc18_wl>; +};
&wdt { Â Â Â Â Â status = "okay"; Â }; @@ -560,10 +559,6 @@ Â Â Â Â Â status = "okay"; Â }; Â -&hdmi_audio { -Â Â Â status = "okay"; -};
&gpu { Â Â Â Â Â status = "okay"; Â }; diff --git a/arch/arm/dts/rk3288.dtsi b/arch/arm/dts/rk3288.dtsi index c4abfa37..14a3f8e8 100644 --- a/arch/arm/dts/rk3288.dtsi +++ b/arch/arm/dts/rk3288.dtsi @@ -1,4 +1,4 @@ -// SPDX-License-Identifier: GPL-2.0+ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) Â Â #include <dt-bindings/gpio/gpio.h> Â #include <dt-bindings/interrupt-controller/irq.h> @@ -7,14 +7,18 @@ Â #include <dt-bindings/clock/rk3288-cru.h> Â #include <dt-bindings/power/rk3288-power.h> Â #include <dt-bindings/thermal/thermal.h> -#include <dt-bindings/video/rk3288.h> -#include "skeleton.dtsi" +#include <dt-bindings/soc/rockchip,boot-mode.h> Â Â / { +Â Â Â #address-cells = <1>; +Â Â Â #size-cells = <1>;
compatible = "rockchip,rk3288"; Â Â Â Â Â Â interrupt-parent = <&gic>;
aliases { +Â Â Â Â Â Â Â ethernet0 = &gmac; Â Â Â Â Â Â Â Â Â i2c0 = &i2c0; Â Â Â Â Â Â Â Â Â i2c1 = &i2c1; Â Â Â Â Â Â Â Â Â i2c2 = &i2c2; @@ -35,6 +39,15 @@ Â Â Â Â Â Â Â Â Â spi2 = &spi2; Â Â Â Â Â }; Â +Â Â Â arm-pmu { +Â Â Â Â Â Â Â compatible = "arm,cortex-a12-pmu"; +Â Â Â Â Â Â Â interrupts = <GIC_SPI 151 IRQ_TYPE_LEVEL_HIGH>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <GIC_SPI 152 IRQ_TYPE_LEVEL_HIGH>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <GIC_SPI 153 IRQ_TYPE_LEVEL_HIGH>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <GIC_SPI 154 IRQ_TYPE_LEVEL_HIGH>; +Â Â Â Â Â Â Â interrupt-affinity = <&cpu0>, <&cpu1>, <&cpu2>, <&cpu3>; +Â Â Â };
cpus {          #address-cells = <1>;          #size-cells = <0>; @@ -45,85 +58,119 @@              device_type = "cpu";              compatible = "arm,cortex-a12";              reg = <0x500>; -           operating-points = < -               /* KHz   uV */ -               1800000 1400000 -               1704000 1350000 -               1608000 1300000 -               1512000 1250000 -               1416000 1200000 -               1200000 1100000 -               1008000 1050000 -                816000 1000000 -                696000 950000 -                600000 900000 -                408000 900000 -                216000 900000 -                126000 900000 -           >; +           resets = <&cru SRST_CORE0>; +           operating-points-v2 = <&cpu_opp_table>;              #cooling-cells = <2>; /* min followed by max */              clock-latency = <40000>;              clocks = <&cru ARMCLK>; -           resets = <&cru SRST_CORE0>; +           dynamic-power-coefficient = <370>;          }; -       cpu@501 { +       cpu1: cpu@501 {              device_type = "cpu";              compatible = "arm,cortex-a12";              reg = <0x501>;              resets = <&cru SRST_CORE1>; +           operating-points-v2 = <&cpu_opp_table>; +           #cooling-cells = <2>; /* min followed by max */ +           clock-latency = <40000>; +           clocks = <&cru ARMCLK>; +           dynamic-power-coefficient = <370>;          }; -       cpu@502 { +       cpu2: cpu@502 {              device_type = "cpu";              compatible = "arm,cortex-a12";              reg = <0x502>;              resets = <&cru SRST_CORE2>; +           operating-points-v2 = <&cpu_opp_table>; +           #cooling-cells = <2>; /* min followed by max */ +           clock-latency = <40000>; +           clocks = <&cru ARMCLK>; +           dynamic-power-coefficient = <370>;          }; -       cpu@503 { +       cpu3: cpu@503 {              device_type = "cpu";              compatible = "arm,cortex-a12";              reg = <0x503>;              resets = <&cru SRST_CORE3>; +           operating-points-v2 = <&cpu_opp_table>; +           #cooling-cells = <2>; /* min followed by max */ +           clock-latency = <40000>; +           clocks = <&cru ARMCLK>; +           dynamic-power-coefficient = <370>;          };      };  -   amba { -       compatible = "arm,amba-bus"; +   cpu_opp_table: opp-table-0 { +       compatible = "operating-points-v2"; +       opp-shared;
+Â Â Â Â Â Â Â opp-126000000 { +Â Â Â Â Â Â Â Â Â Â Â opp-hz = /bits/ 64 <126000000>; +Â Â Â Â Â Â Â Â Â Â Â opp-microvolt = <900000>; +Â Â Â Â Â Â Â }; +Â Â Â Â Â Â Â opp-216000000 { +Â Â Â Â Â Â Â Â Â Â Â opp-hz = /bits/ 64 <216000000>; +Â Â Â Â Â Â Â Â Â Â Â opp-microvolt = <900000>; +Â Â Â Â Â Â Â }; +Â Â Â Â Â Â Â opp-312000000 { +Â Â Â Â Â Â Â Â Â Â Â opp-hz = /bits/ 64 <312000000>; +Â Â Â Â Â Â Â Â Â Â Â opp-microvolt = <900000>; +Â Â Â Â Â Â Â }; +Â Â Â Â Â Â Â opp-408000000 { +Â Â Â Â Â Â Â Â Â Â Â opp-hz = /bits/ 64 <408000000>; +Â Â Â Â Â Â Â Â Â Â Â opp-microvolt = <900000>; +Â Â Â Â Â Â Â }; +Â Â Â Â Â Â Â opp-600000000 { +Â Â Â Â Â Â Â Â Â Â Â opp-hz = /bits/ 64 <600000000>; +Â Â Â Â Â Â Â Â Â Â Â opp-microvolt = <900000>; +Â Â Â Â Â Â Â }; +Â Â Â Â Â Â Â opp-696000000 { +Â Â Â Â Â Â Â Â Â Â Â opp-hz = /bits/ 64 <696000000>; +Â Â Â Â Â Â Â Â Â Â Â opp-microvolt = <950000>; +Â Â Â Â Â Â Â }; +Â Â Â Â Â Â Â opp-816000000 { +Â Â Â Â Â Â Â Â Â Â Â opp-hz = /bits/ 64 <816000000>; +Â Â Â Â Â Â Â Â Â Â Â opp-microvolt = <1000000>; +Â Â Â Â Â Â Â }; +Â Â Â Â Â Â Â opp-1008000000 { +Â Â Â Â Â Â Â Â Â Â Â opp-hz = /bits/ 64 <1008000000>; +Â Â Â Â Â Â Â Â Â Â Â opp-microvolt = <1050000>; +Â Â Â Â Â Â Â }; +Â Â Â Â Â Â Â opp-1200000000 { +Â Â Â Â Â Â Â Â Â Â Â opp-hz = /bits/ 64 <1200000000>; +Â Â Â Â Â Â Â Â Â Â Â opp-microvolt = <1100000>; +Â Â Â Â Â Â Â }; +Â Â Â Â Â Â Â opp-1416000000 { +Â Â Â Â Â Â Â Â Â Â Â opp-hz = /bits/ 64 <1416000000>; +Â Â Â Â Â Â Â Â Â Â Â opp-microvolt = <1200000>; +Â Â Â Â Â Â Â }; +Â Â Â Â Â Â Â opp-1512000000 { +Â Â Â Â Â Â Â Â Â Â Â opp-hz = /bits/ 64 <1512000000>; +Â Â Â Â Â Â Â Â Â Â Â opp-microvolt = <1300000>; +Â Â Â Â Â Â Â }; +Â Â Â Â Â Â Â opp-1608000000 { +Â Â Â Â Â Â Â Â Â Â Â opp-hz = /bits/ 64 <1608000000>; +Â Â Â Â Â Â Â Â Â Â Â opp-microvolt = <1350000>; +Â Â Â Â Â Â Â }; +Â Â Â };
+Â Â Â reserved-memory { Â Â Â Â Â Â Â Â Â #address-cells = <1>; Â Â Â Â Â Â Â Â Â #size-cells = <1>; Â Â Â Â Â Â Â Â Â ranges; Â -Â Â Â Â Â Â Â dmac_peri: dma-controller@ff250000 { -Â Â Â Â Â Â Â Â Â Â Â compatible = "arm,pl330", "arm,primecell"; -Â Â Â Â Â Â Â Â Â Â Â broken-no-flushp; -Â Â Â Â Â Â Â Â Â Â Â reg = <0xff250000 0x4000>; -Â Â Â Â Â Â Â Â Â Â Â interrupts = <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>; -Â Â Â Â Â Â Â Â Â Â Â #dma-cells = <1>; -Â Â Â Â Â Â Â Â Â Â Â clocks = <&cru ACLK_DMAC2>; -Â Â Â Â Â Â Â Â Â Â Â clock-names = "apb_pclk"; -Â Â Â Â Â Â Â };
-Â Â Â Â Â Â Â dmac_bus_ns: dma-controller@ff600000 { -Â Â Â Â Â Â Â Â Â Â Â compatible = "arm,pl330", "arm,primecell"; -Â Â Â Â Â Â Â Â Â Â Â broken-no-flushp; -Â Â Â Â Â Â Â Â Â Â Â reg = <0xff600000 0x4000>; -Â Â Â Â Â Â Â Â Â Â Â interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>; -Â Â Â Â Â Â Â Â Â Â Â #dma-cells = <1>; -Â Â Â Â Â Â Â Â Â Â Â clocks = <&cru ACLK_DMAC1>; -Â Â Â Â Â Â Â Â Â Â Â clock-names = "apb_pclk"; -Â Â Â Â Â Â Â Â Â Â Â status = "disabled"; -Â Â Â Â Â Â Â };
-Â Â Â Â Â Â Â dmac_bus_s: dma-controller@ffb20000 { -Â Â Â Â Â Â Â Â Â Â Â compatible = "arm,pl330", "arm,primecell"; -Â Â Â Â Â Â Â Â Â Â Â broken-no-flushp; -Â Â Â Â Â Â Â Â Â Â Â reg = <0xffb20000 0x4000>; -Â Â Â Â Â Â Â Â Â Â Â interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>; -Â Â Â Â Â Â Â Â Â Â Â #dma-cells = <1>; -Â Â Â Â Â Â Â Â Â Â Â clocks = <&cru ACLK_DMAC1>; -Â Â Â Â Â Â Â Â Â Â Â clock-names = "apb_pclk"; +Â Â Â Â Â Â Â /* +Â Â Â Â Â Â Â Â * The rk3288 cannot use the memory area above 0xfe000000 +Â Â Â Â Â Â Â Â * for dma operations for some reason. While there is +Â Â Â Â Â Â Â Â * probably a better solution available somewhere, we +Â Â Â Â Â Â Â Â * haven't found it yet and while devices with 2GB of ram +Â Â Â Â Â Â Â Â * are not affected, this issue prevents 4GB from booting. +Â Â Â Â Â Â Â Â * So to make these devices at least bootable, block +Â Â Â Â Â Â Â Â * this area for the time being until the real solution +Â Â Â Â Â Â Â Â * is found. +Â Â Â Â Â Â Â Â */ +Â Â Â Â Â Â Â dma-unusable@fe000000 { +Â Â Â Â Â Â Â Â Â Â Â reg = <0xfe000000 0x1000000>; Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â }; Â @@ -135,14 +182,22 @@ Â Â Â Â Â }; Â Â Â Â Â Â timer { -Â Â Â Â Â Â Â Â Â Â Â arm,use-physical-timer; Â Â Â Â Â Â Â Â Â compatible = "arm,armv7-timer"; +Â Â Â Â Â Â Â arm,cpu-registers-not-fw-configured; Â Â Â Â Â Â Â Â Â interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>, Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>, Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>, Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>; Â Â Â Â Â Â Â Â Â clock-frequency = <24000000>; -Â Â Â Â Â Â Â always-on; +Â Â Â Â Â Â Â arm,no-tick-in-suspend; +Â Â Â };
+Â Â Â timer: timer@ff810000 { +Â Â Â Â Â Â Â compatible = "rockchip,rk3288-timer"; +Â Â Â Â Â Â Â reg = <0xff810000 0x20>; +Â Â Â Â Â Â Â interrupts = <GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>; +Â Â Â Â Â Â Â clocks = <&cru PCLK_TIMER>, <&xin24m>; +Â Â Â Â Â Â Â clock-names = "pclk", "timer"; Â Â Â Â Â }; Â Â Â Â Â Â display-subsystem { @@ -150,51 +205,59 @@ Â Â Â Â Â Â Â Â Â ports = <&vopl_out>, <&vopb_out>; Â Â Â Â Â }; Â -Â Â Â sdmmc: dwmmc@ff0c0000 { +Â Â Â sdmmc: mmc@ff0c0000 { Â Â Â Â Â Â Â Â Â compatible = "rockchip,rk3288-dw-mshc"; Â Â Â Â Â Â Â Â Â max-frequency = <150000000>; Â Â Â Â Â Â Â Â Â clocks = <&cru HCLK_SDMMC>, <&cru SCLK_SDMMC>, Â Â Â Â Â Â Â Â Â Â Â Â Â Â <&cru SCLK_SDMMC_DRV>, <&cru SCLK_SDMMC_SAMPLE>; -Â Â Â Â Â Â Â clock-names = "biu", "ciu", "ciu_drv", "ciu_sample"; +Â Â Â Â Â Â Â clock-names = "biu", "ciu", "ciu-drive", "ciu-sample"; Â Â Â Â Â Â Â Â Â fifo-depth = <0x100>; Â Â Â Â Â Â Â Â Â interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>; Â Â Â Â Â Â Â Â Â reg = <0xff0c0000 0x4000>; +Â Â Â Â Â Â Â resets = <&cru SRST_MMC0>; +Â Â Â Â Â Â Â reset-names = "reset"; Â Â Â Â Â Â Â Â Â status = "disabled"; Â Â Â Â Â }; Â -Â Â Â sdio0: dwmmc@ff0d0000 { +Â Â Â sdio0: mmc@ff0d0000 { Â Â Â Â Â Â Â Â Â compatible = "rockchip,rk3288-dw-mshc"; Â Â Â Â Â Â Â Â Â max-frequency = <150000000>; Â Â Â Â Â Â Â Â Â clocks = <&cru HCLK_SDIO0>, <&cru SCLK_SDIO0>, Â Â Â Â Â Â Â Â Â Â Â Â Â Â <&cru SCLK_SDIO0_DRV>, <&cru SCLK_SDIO0_SAMPLE>; -Â Â Â Â Â Â Â clock-names = "biu", "ciu", "ciu_drv", "ciu_sample"; +Â Â Â Â Â Â Â clock-names = "biu", "ciu", "ciu-drive", "ciu-sample"; Â Â Â Â Â Â Â Â Â fifo-depth = <0x100>; Â Â Â Â Â Â Â Â Â interrupts = <GIC_SPI 33 IRQ_TYPE_LEVEL_HIGH>; Â Â Â Â Â Â Â Â Â reg = <0xff0d0000 0x4000>; +Â Â Â Â Â Â Â resets = <&cru SRST_SDIO0>; +Â Â Â Â Â Â Â reset-names = "reset"; Â Â Â Â Â Â Â Â Â status = "disabled"; Â Â Â Â Â }; Â -Â Â Â sdio1: dwmmc@ff0e0000 { +Â Â Â sdio1: mmc@ff0e0000 { Â Â Â Â Â Â Â Â Â compatible = "rockchip,rk3288-dw-mshc"; Â Â Â Â Â Â Â Â Â max-frequency = <150000000>; Â Â Â Â Â Â Â Â Â clocks = <&cru HCLK_SDIO1>, <&cru SCLK_SDIO1>, Â Â Â Â Â Â Â Â Â Â Â Â Â Â <&cru SCLK_SDIO1_DRV>, <&cru SCLK_SDIO1_SAMPLE>; -Â Â Â Â Â Â Â clock-names = "biu", "ciu", "ciu_drv", "ciu_sample"; +Â Â Â Â Â Â Â clock-names = "biu", "ciu", "ciu-drive", "ciu-sample"; Â Â Â Â Â Â Â Â Â fifo-depth = <0x100>; Â Â Â Â Â Â Â Â Â interrupts = <GIC_SPI 34 IRQ_TYPE_LEVEL_HIGH>; Â Â Â Â Â Â Â Â Â reg = <0xff0e0000 0x4000>; +Â Â Â Â Â Â Â resets = <&cru SRST_SDIO1>; +Â Â Â Â Â Â Â reset-names = "reset"; Â Â Â Â Â Â Â Â Â status = "disabled"; Â Â Â Â Â }; Â -Â Â Â emmc: dwmmc@ff0f0000 { +Â Â Â emmc: mmc@ff0f0000 { Â Â Â Â Â Â Â Â Â compatible = "rockchip,rk3288-dw-mshc"; Â Â Â Â Â Â Â Â Â max-frequency = <150000000>; Â Â Â Â Â Â Â Â Â clocks = <&cru HCLK_EMMC>, <&cru SCLK_EMMC>, Â Â Â Â Â Â Â Â Â Â Â Â Â Â <&cru SCLK_EMMC_DRV>, <&cru SCLK_EMMC_SAMPLE>; -Â Â Â Â Â Â Â clock-names = "biu", "ciu", "ciu_drv", "ciu_sample"; +Â Â Â Â Â Â Â clock-names = "biu", "ciu", "ciu-drive", "ciu-sample"; Â Â Â Â Â Â Â Â Â fifo-depth = <0x100>; Â Â Â Â Â Â Â Â Â interrupts = <GIC_SPI 35 IRQ_TYPE_LEVEL_HIGH>; Â Â Â Â Â Â Â Â Â reg = <0xff0f0000 0x4000>; +Â Â Â Â Â Â Â resets = <&cru SRST_EMMC>; +Â Â Â Â Â Â Â reset-names = "reset"; Â Â Â Â Â Â Â Â Â status = "disabled"; Â Â Â Â Â }; Â @@ -205,6 +268,8 @@ Â Â Â Â Â Â Â Â Â #io-channel-cells = <1>; Â Â Â Â Â Â Â Â Â clocks = <&cru SCLK_SARADC>, <&cru PCLK_SARADC>; Â Â Â Â Â Â Â Â Â clock-names = "saradc", "apb_pclk"; +Â Â Â Â Â Â Â resets = <&cru SRST_SARADC>; +Â Â Â Â Â Â Â reset-names = "saradc-apb"; Â Â Â Â Â Â Â Â Â status = "disabled"; Â Â Â Â Â }; Â @@ -304,6 +369,7 @@ Â Â Â Â Â Â Â Â Â pinctrl-0 = <&i2c5_xfer>; Â Â Â Â Â Â Â Â Â status = "disabled"; Â Â Â Â Â };
uart0: serial@ff180000 { Â Â Â Â Â Â Â Â Â compatible = "rockchip,rk3288-uart", "snps,dw-apb-uart"; Â Â Â Â Â Â Â Â Â reg = <0xff180000 0x100>; @@ -312,6 +378,8 @@ Â Â Â Â Â Â Â Â Â reg-io-width = <4>; Â Â Â Â Â Â Â Â Â clocks = <&cru SCLK_UART0>, <&cru PCLK_UART0>; Â Â Â Â Â Â Â Â Â clock-names = "baudclk", "apb_pclk"; +Â Â Â Â Â Â Â dmas = <&dmac_peri 1>, <&dmac_peri 2>; +Â Â Â Â Â Â Â dma-names = "tx", "rx"; Â Â Â Â Â Â Â Â Â pinctrl-names = "default"; Â Â Â Â Â Â Â Â Â pinctrl-0 = <&uart0_xfer>; Â Â Â Â Â Â Â Â Â status = "disabled"; @@ -325,6 +393,8 @@ Â Â Â Â Â Â Â Â Â reg-io-width = <4>; Â Â Â Â Â Â Â Â Â clocks = <&cru SCLK_UART1>, <&cru PCLK_UART1>; Â Â Â Â Â Â Â Â Â clock-names = "baudclk", "apb_pclk"; +Â Â Â Â Â Â Â dmas = <&dmac_peri 3>, <&dmac_peri 4>; +Â Â Â Â Â Â Â dma-names = "tx", "rx"; Â Â Â Â Â Â Â Â Â pinctrl-names = "default"; Â Â Â Â Â Â Â Â Â pinctrl-0 = <&uart1_xfer>; Â Â Â Â Â Â Â Â Â status = "disabled"; @@ -342,6 +412,7 @@ Â Â Â Â Â Â Â Â Â pinctrl-0 = <&uart2_xfer>; Â Â Â Â Â Â Â Â Â status = "disabled"; Â Â Â Â Â };
uart3: serial@ff1b0000 { Â Â Â Â Â Â Â Â Â compatible = "rockchip,rk3288-uart", "snps,dw-apb-uart"; Â Â Â Â Â Â Â Â Â reg = <0xff1b0000 0x100>; @@ -350,6 +421,8 @@ Â Â Â Â Â Â Â Â Â reg-io-width = <4>; Â Â Â Â Â Â Â Â Â clocks = <&cru SCLK_UART3>, <&cru PCLK_UART3>; Â Â Â Â Â Â Â Â Â clock-names = "baudclk", "apb_pclk"; +Â Â Â Â Â Â Â dmas = <&dmac_peri 7>, <&dmac_peri 8>; +Â Â Â Â Â Â Â dma-names = "tx", "rx"; Â Â Â Â Â Â Â Â Â pinctrl-names = "default"; Â Â Â Â Â Â Â Â Â pinctrl-0 = <&uart3_xfer>; Â Â Â Â Â Â Â Â Â status = "disabled"; @@ -363,12 +436,104 @@ Â Â Â Â Â Â Â Â Â reg-io-width = <4>; Â Â Â Â Â Â Â Â Â clocks = <&cru SCLK_UART4>, <&cru PCLK_UART4>; Â Â Â Â Â Â Â Â Â clock-names = "baudclk", "apb_pclk"; +Â Â Â Â Â Â Â dmas = <&dmac_peri 9>, <&dmac_peri 10>; +Â Â Â Â Â Â Â dma-names = "tx", "rx"; Â Â Â Â Â Â Â Â Â pinctrl-names = "default"; Â Â Â Â Â Â Â Â Â pinctrl-0 = <&uart4_xfer>; Â Â Â Â Â Â Â Â Â status = "disabled"; Â Â Â Â Â }; -Â Â Â thermal: thermal-zones { -Â Â Â Â Â Â Â #include "rk3288-thermal.dtsi"
+Â Â Â dmac_peri: dma-controller@ff250000 { +Â Â Â Â Â Â Â compatible = "arm,pl330", "arm,primecell"; +Â Â Â Â Â Â Â reg = <0xff250000 0x4000>; +Â Â Â Â Â Â Â interrupts = <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>; +Â Â Â Â Â Â Â #dma-cells = <1>; +Â Â Â Â Â Â Â arm,pl330-broken-no-flushp; +Â Â Â Â Â Â Â arm,pl330-periph-burst; +Â Â Â Â Â Â Â clocks = <&cru ACLK_DMAC2>; +Â Â Â Â Â Â Â clock-names = "apb_pclk"; +Â Â Â };
+Â Â Â thermal-zones { +Â Â Â Â Â Â Â reserve_thermal: reserve-thermal { +Â Â Â Â Â Â Â Â Â Â Â polling-delay-passive = <1000>; /* milliseconds */ +Â Â Â Â Â Â Â Â Â Â Â polling-delay = <5000>; /* milliseconds */
+Â Â Â Â Â Â Â Â Â Â Â thermal-sensors = <&tsadc 0>; +Â Â Â Â Â Â Â };
+Â Â Â Â Â Â Â cpu_thermal: cpu-thermal { +Â Â Â Â Â Â Â Â Â Â Â polling-delay-passive = <100>; /* milliseconds */ +Â Â Â Â Â Â Â Â Â Â Â polling-delay = <5000>; /* milliseconds */
+Â Â Â Â Â Â Â Â Â Â Â thermal-sensors = <&tsadc 1>;
+Â Â Â Â Â Â Â Â Â Â Â trips { +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â cpu_alert0: cpu_alert0 { +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â temperature = <70000>; /* millicelsius */ +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â hysteresis = <2000>; /* millicelsius */ +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â type = "passive"; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â }; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â cpu_alert1: cpu_alert1 { +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â temperature = <75000>; /* millicelsius */ +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â hysteresis = <2000>; /* millicelsius */ +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â type = "passive"; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â }; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â cpu_crit: cpu_crit { +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â temperature = <90000>; /* millicelsius */ +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â hysteresis = <2000>; /* millicelsius */ +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â type = "critical"; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â }; +Â Â Â Â Â Â Â Â Â Â Â };
+Â Â Â Â Â Â Â Â Â Â Â cooling-maps { +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â map0 { +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â trip = <&cpu_alert0>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â cooling-device = +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <&cpu0 THERMAL_NO_LIMIT 6>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <&cpu1 THERMAL_NO_LIMIT 6>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <&cpu2 THERMAL_NO_LIMIT 6>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <&cpu3 THERMAL_NO_LIMIT 6>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â }; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â map1 { +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â trip = <&cpu_alert1>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â cooling-device = +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <&cpu0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <&cpu1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <&cpu2 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <&cpu3 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â }; +Â Â Â Â Â Â Â Â Â Â Â }; +Â Â Â Â Â Â Â };
+Â Â Â Â Â Â Â gpu_thermal: gpu-thermal { +Â Â Â Â Â Â Â Â Â Â Â polling-delay-passive = <100>; /* milliseconds */ +Â Â Â Â Â Â Â Â Â Â Â polling-delay = <5000>; /* milliseconds */
+Â Â Â Â Â Â Â Â Â Â Â thermal-sensors = <&tsadc 2>;
+Â Â Â Â Â Â Â Â Â Â Â trips { +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â gpu_alert0: gpu_alert0 { +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â temperature = <70000>; /* millicelsius */ +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â hysteresis = <2000>; /* millicelsius */ +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â type = "passive"; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â }; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â gpu_crit: gpu_crit { +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â temperature = <90000>; /* millicelsius */ +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â hysteresis = <2000>; /* millicelsius */ +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â type = "critical"; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â }; +Â Â Â Â Â Â Â Â Â Â Â };
+Â Â Â Â Â Â Â Â Â Â Â cooling-maps { +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â map0 { +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â trip = <&gpu_alert0>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â cooling-device = +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <&gpu THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â }; +Â Â Â Â Â Â Â Â Â Â Â }; +Â Â Â Â Â Â Â }; Â Â Â Â Â }; Â Â Â Â Â Â tsadc: tsadc@ff280000 { @@ -379,18 +544,22 @@ Â Â Â Â Â Â Â Â Â clock-names = "tsadc", "apb_pclk"; Â Â Â Â Â Â Â Â Â resets = <&cru SRST_TSADC>; Â Â Â Â Â Â Â Â Â reset-names = "tsadc-apb"; -Â Â Â Â Â Â Â pinctrl-names = "otp_out"; -Â Â Â Â Â Â Â pinctrl-0 = <&otp_out>; +Â Â Â Â Â Â Â pinctrl-names = "init", "default", "sleep"; +Â Â Â Â Â Â Â pinctrl-0 = <&otp_pin>; +Â Â Â Â Â Â Â pinctrl-1 = <&otp_out>; +Â Â Â Â Â Â Â pinctrl-2 = <&otp_pin>; Â Â Â Â Â Â Â Â Â #thermal-sensor-cells = <1>; -Â Â Â Â Â Â Â hw-shut-temp = <125000>; +Â Â Â Â Â Â Â rockchip,grf = <&grf>; +Â Â Â Â Â Â Â rockchip,hw-tshut-temp = <95000>; Â Â Â Â Â Â Â Â Â status = "disabled"; Â Â Â Â Â }; Â Â Â Â Â Â gmac: ethernet@ff290000 { Â Â Â Â Â Â Â Â Â compatible = "rockchip,rk3288-gmac"; Â Â Â Â Â Â Â Â Â reg = <0xff290000 0x10000>; -Â Â Â Â Â Â Â interrupts = <GIC_SPI 27 IRQ_TYPE_LEVEL_HIGH>; -Â Â Â Â Â Â Â interrupt-names = "macirq"; +Â Â Â Â Â Â Â interrupts = <GIC_SPI 27 IRQ_TYPE_LEVEL_HIGH>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <GIC_SPI 28 IRQ_TYPE_LEVEL_HIGH>; +Â Â Â Â Â Â Â interrupt-names = "macirq", "eth_wake_irq"; Â Â Â Â Â Â Â Â Â rockchip,grf = <&grf>; Â Â Â Â Â Â Â Â Â clocks = <&cru SCLK_MAC>, Â Â Â Â Â Â Â Â Â Â Â Â Â <&cru SCLK_MAC_RX>, <&cru SCLK_MAC_TX>, @@ -400,6 +569,9 @@ Â Â Â Â Â Â Â Â Â Â Â Â Â "mac_clk_rx", "mac_clk_tx", Â Â Â Â Â Â Â Â Â Â Â Â Â "clk_mac_ref", "clk_mac_refout", Â Â Â Â Â Â Â Â Â Â Â Â Â "aclk_mac", "pclk_mac"; +Â Â Â Â Â Â Â resets = <&cru SRST_MAC>; +Â Â Â Â Â Â Â reset-names = "stmmaceth"; +Â Â Â Â Â Â Â status = "disabled"; Â Â Â Â Â }; Â Â Â Â Â Â usb_host0_ehci: usb@ff500000 { @@ -407,16 +579,15 @@ Â Â Â Â Â Â Â Â Â reg = <0xff500000 0x100>; Â Â Â Â Â Â Â Â Â interrupts = <GIC_SPI 24 IRQ_TYPE_LEVEL_HIGH>; Â Â Â Â Â Â Â Â Â clocks = <&cru HCLK_USBHOST0>; -Â Â Â Â Â Â Â clock-names = "usbhost"; Â Â Â Â Â Â Â Â Â phys = <&usbphy1>; Â Â Â Â Â Â Â Â Â phy-names = "usb"; Â Â Â Â Â Â Â Â Â status = "disabled"; Â Â Â Â Â }; Â -Â Â Â /* NOTE: doesn't work on RK3288, but fixed on RK3288W */ +Â Â Â /* NOTE: doesn't work on RK3288, but was fixed on RK3288W */ Â Â Â Â Â usb_host0_ohci: usb@ff520000 { Â Â Â Â Â Â Â Â Â compatible = "generic-ohci"; -Â Â Â Â Â Â Â reg = <0x0 0xff520000 0x0 0x100>; +Â Â Â Â Â Â Â reg = <0xff520000 0x100>; Â Â Â Â Â Â Â Â Â interrupts = <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>; Â Â Â Â Â Â Â Â Â clocks = <&cru HCLK_USBHOST0>; Â Â Â Â Â Â Â Â Â phys = <&usbphy1>; @@ -431,8 +602,10 @@ Â Â Â Â Â Â Â Â Â interrupts = <GIC_SPI 25 IRQ_TYPE_LEVEL_HIGH>; Â Â Â Â Â Â Â Â Â clocks = <&cru HCLK_USBHOST1>; Â Â Â Â Â Â Â Â Â clock-names = "otg"; +Â Â Â Â Â Â Â dr_mode = "host"; Â Â Â Â Â Â Â Â Â phys = <&usbphy2>; Â Â Â Â Â Â Â Â Â phy-names = "usb2-phy"; +Â Â Â Â Â Â Â snps,reset-phy-on-wake; Â Â Â Â Â Â Â Â Â status = "disabled"; Â Â Â Â Â }; Â @@ -444,6 +617,9 @@ Â Â Â Â Â Â Â Â Â clocks = <&cru HCLK_OTG0>; Â Â Â Â Â Â Â Â Â clock-names = "otg"; Â Â Â Â Â Â Â Â Â dr_mode = "otg"; +Â Â Â Â Â Â Â g-np-tx-fifo-size = <16>; +Â Â Â Â Â Â Â g-rx-fifo-size = <275>; +Â Â Â Â Â Â Â g-tx-fifo-size = <256 128 128 64 64 32>; Â Â Â Â Â Â Â Â Â phys = <&usbphy0>; Â Â Â Â Â Â Â Â Â phy-names = "usb2-phy"; Â Â Â Â Â Â Â Â Â status = "disabled"; @@ -454,7 +630,19 @@ Â Â Â Â Â Â Â Â Â reg = <0xff5c0000 0x100>; Â Â Â Â Â Â Â Â Â interrupts = <GIC_SPI 26 IRQ_TYPE_LEVEL_HIGH>; Â Â Â Â Â Â Â Â Â clocks = <&cru HCLK_HSIC>; -Â Â Â Â Â Â Â clock-names = "usbhost"; +Â Â Â Â Â Â Â status = "disabled"; +Â Â Â };
+Â Â Â dmac_bus_ns: dma-controller@ff600000 { +Â Â Â Â Â Â Â compatible = "arm,pl330", "arm,primecell"; +Â Â Â Â Â Â Â reg = <0xff600000 0x4000>; +Â Â Â Â Â Â Â interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>; +Â Â Â Â Â Â Â #dma-cells = <1>; +Â Â Â Â Â Â Â arm,pl330-broken-no-flushp; +Â Â Â Â Â Â Â arm,pl330-periph-burst; +Â Â Â Â Â Â Â clocks = <&cru ACLK_DMAC1>; +Â Â Â Â Â Â Â clock-names = "apb_pclk"; Â Â Â Â Â Â Â Â Â status = "disabled"; Â Â Â Â Â }; Â @@ -490,9 +678,7 @@ Â Â Â Â Â Â Â Â Â #pwm-cells = <3>; Â Â Â Â Â Â Â Â Â pinctrl-names = "default"; Â Â Â Â Â Â Â Â Â pinctrl-0 = <&pwm0_pin>; -Â Â Â Â Â Â Â clocks = <&cru PCLK_PWM>; -Â Â Â Â Â Â Â clock-names = "pwm"; -Â Â Â Â Â Â Â rockchip,grf = <&grf>; +Â Â Â Â Â Â Â clocks = <&cru PCLK_RKPWM>; Â Â Â Â Â Â Â Â Â status = "disabled"; Â Â Â Â Â }; Â @@ -502,9 +688,7 @@ Â Â Â Â Â Â Â Â Â #pwm-cells = <3>; Â Â Â Â Â Â Â Â Â pinctrl-names = "default"; Â Â Â Â Â Â Â Â Â pinctrl-0 = <&pwm1_pin>; -Â Â Â Â Â Â Â clocks = <&cru PCLK_PWM>; -Â Â Â Â Â Â Â clock-names = "pwm"; -Â Â Â Â Â Â Â rockchip,grf = <&grf>; +Â Â Â Â Â Â Â clocks = <&cru PCLK_RKPWM>; Â Â Â Â Â Â Â Â Â status = "disabled"; Â Â Â Â Â }; Â @@ -514,25 +698,21 @@ Â Â Â Â Â Â Â Â Â #pwm-cells = <3>; Â Â Â Â Â Â Â Â Â pinctrl-names = "default"; Â Â Â Â Â Â Â Â Â pinctrl-0 = <&pwm2_pin>; -Â Â Â Â Â Â Â clocks = <&cru PCLK_PWM>; -Â Â Â Â Â Â Â clock-names = "pwm"; -Â Â Â Â Â Â Â rockchip,grf = <&grf>; +Â Â Â Â Â Â Â clocks = <&cru PCLK_RKPWM>; Â Â Â Â Â Â Â Â Â status = "disabled"; Â Â Â Â Â }; Â Â Â Â Â Â pwm3: pwm@ff680030 { Â Â Â Â Â Â Â Â Â compatible = "rockchip,rk3288-pwm"; Â Â Â Â Â Â Â Â Â reg = <0xff680030 0x10>; -Â Â Â Â Â Â Â #pwm-cells = <2>; +Â Â Â Â Â Â Â #pwm-cells = <3>; Â Â Â Â Â Â Â Â Â pinctrl-names = "default"; Â Â Â Â Â Â Â Â Â pinctrl-0 = <&pwm3_pin>; -Â Â Â Â Â Â Â clocks = <&cru PCLK_PWM>; -Â Â Â Â Â Â Â clock-names = "pwm"; -Â Â Â Â Â Â Â rockchip,grf = <&grf>; +Â Â Â Â Â Â Â clocks = <&cru PCLK_RKPWM>; Â Â Â Â Â Â Â Â Â status = "disabled"; Â Â Â Â Â }; Â -Â Â Â bus_intmem: bus_intmem@ff700000 { +Â Â Â bus_intmem: sram@ff700000 { Â Â Â Â Â Â Â Â Â compatible = "mmio-sram"; Â Â Â Â Â Â Â Â Â reg = <0xff700000 0x18000>; Â Â Â Â Â Â Â Â Â #address-cells = <1>; @@ -544,14 +724,134 @@ Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â }; Â -Â Â Â sram@ff720000 { +Â Â Â pmu_sram: sram@ff720000 { Â Â Â Â Â Â Â Â Â compatible = "rockchip,rk3288-pmu-sram", "mmio-sram"; Â Â Â Â Â Â Â Â Â reg = <0xff720000 0x1000>; Â Â Â Â Â }; Â Â Â Â Â Â pmu: power-management@ff730000 { -Â Â Â Â Â Â Â compatible = "rockchip,rk3288-pmu", "syscon"; +Â Â Â Â Â Â Â compatible = "rockchip,rk3288-pmu", "syscon", "simple-mfd"; Â Â Â Â Â Â Â Â Â reg = <0xff730000 0x100>;
+Â Â Â Â Â Â Â power: power-controller { +Â Â Â Â Â Â Â Â Â Â Â compatible = "rockchip,rk3288-power-controller"; +Â Â Â Â Â Â Â Â Â Â Â #power-domain-cells = <1>; +Â Â Â Â Â Â Â Â Â Â Â #address-cells = <1>; +Â Â Â Â Â Â Â Â Â Â Â #size-cells = <0>;
+Â Â Â Â Â Â Â Â Â Â Â assigned-clocks = <&cru SCLK_EDP_24M>; +Â Â Â Â Â Â Â Â Â Â Â assigned-clock-parents = <&xin24m>;
+           /* +            * Note: Although SCLK_* are the working clocks +            * of device without including on the NOC, needed for +            * synchronous reset. +            * +            * The clocks on the which NOC: +            * ACLK_IEP/ACLK_VIP/ACLK_VOP0 are on ACLK_VIO0_NIU. +            * ACLK_ISP/ACLK_VOP1 are on ACLK_VIO1_NIU. +            * ACLK_RGA is on ACLK_RGA_NIU. +            * The others (HCLK_*,PLCK_*) are on HCLK_VIO_NIU. +            * +            * Which clock are device clocks: +            *   clocks       devices +            *   *_IEP       IEP:Image Enhancement Processor +            *   *_ISP       ISP:Image Signal Processing +            *   *_VIP       VIP:Video Input Processor +            *   *_VOP*       VOP:Visual Output Processor +            *   *_RGA       RGA +            *   *_EDP*       EDP +            *   *_LVDS_*   LVDS +            *   *_HDMI       HDMI +            *   *_MIPI_*   MIPI +            */ +           power-domain@RK3288_PD_VIO { +               reg = <RK3288_PD_VIO>; +               clocks = <&cru ACLK_IEP>, +                    <&cru ACLK_ISP>, +                    <&cru ACLK_RGA>, +                    <&cru ACLK_VIP>, +                    <&cru ACLK_VOP0>, +                    <&cru ACLK_VOP1>, +                    <&cru DCLK_VOP0>, +                    <&cru DCLK_VOP1>, +                    <&cru HCLK_IEP>, +                    <&cru HCLK_ISP>, +                    <&cru HCLK_RGA>, +                    <&cru HCLK_VIP>, +                    <&cru HCLK_VOP0>, +                    <&cru HCLK_VOP1>, +                    <&cru PCLK_EDP_CTRL>, +                    <&cru PCLK_HDMI_CTRL>, +                    <&cru PCLK_LVDS_PHY>, +                    <&cru PCLK_MIPI_CSI>, +                    <&cru PCLK_MIPI_DSI0>, +                    <&cru PCLK_MIPI_DSI1>, +                    <&cru SCLK_EDP_24M>, +                    <&cru SCLK_EDP>, +                    <&cru SCLK_ISP_JPE>, +                    <&cru SCLK_ISP>, +                    <&cru SCLK_RGA>; +               pm_qos = <&qos_vio0_iep>, +                    <&qos_vio1_vop>, +                    <&qos_vio1_isp_w0>, +                    <&qos_vio1_isp_w1>, +                    <&qos_vio0_vop>, +                    <&qos_vio0_vip>, +                    <&qos_vio2_rga_r>, +                    <&qos_vio2_rga_w>, +                    <&qos_vio1_isp_r>; +               #power-domain-cells = <0>; +           };
+Â Â Â Â Â Â Â Â Â Â Â /* +Â Â Â Â Â Â Â Â Â Â Â Â * Note: The following 3 are HEVC(H.265) clocks, +Â Â Â Â Â Â Â Â Â Â Â Â * and on the ACLK_HEVC_NIU (NOC). +Â Â Â Â Â Â Â Â Â Â Â Â */ +Â Â Â Â Â Â Â Â Â Â Â power-domain@RK3288_PD_HEVC { +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â reg = <RK3288_PD_HEVC>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â clocks = <&cru ACLK_HEVC>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <&cru SCLK_HEVC_CABAC>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <&cru SCLK_HEVC_CORE>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â pm_qos = <&qos_hevc_r>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <&qos_hevc_w>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â #power-domain-cells = <0>; +Â Â Â Â Â Â Â Â Â Â Â };
+Â Â Â Â Â Â Â Â Â Â Â /* +Â Â Â Â Â Â Â Â Â Â Â Â * Note: ACLK_VCODEC/HCLK_VCODEC are VCODEC +Â Â Â Â Â Â Â Â Â Â Â Â * (video endecoder & decoder) clocks that on the +Â Â Â Â Â Â Â Â Â Â Â Â * ACLK_VCODEC_NIU and HCLK_VCODEC_NIU (NOC). +Â Â Â Â Â Â Â Â Â Â Â Â */ +Â Â Â Â Â Â Â Â Â Â Â power-domain@RK3288_PD_VIDEO { +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â reg = <RK3288_PD_VIDEO>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â clocks = <&cru ACLK_VCODEC>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <&cru HCLK_VCODEC>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â pm_qos = <&qos_video>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â #power-domain-cells = <0>; +Â Â Â Â Â Â Â Â Â Â Â };
+Â Â Â Â Â Â Â Â Â Â Â /* +Â Â Â Â Â Â Â Â Â Â Â Â * Note: ACLK_GPU is the GPU clock, +Â Â Â Â Â Â Â Â Â Â Â Â * and on the ACLK_GPU_NIU (NOC). +Â Â Â Â Â Â Â Â Â Â Â Â */ +Â Â Â Â Â Â Â Â Â Â Â power-domain@RK3288_PD_GPU { +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â reg = <RK3288_PD_GPU>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â clocks = <&cru ACLK_GPU>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â pm_qos = <&qos_gpu_r>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <&qos_gpu_w>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â #power-domain-cells = <0>; +Â Â Â Â Â Â Â Â Â Â Â }; +Â Â Â Â Â Â Â };
+Â Â Â Â Â Â Â reboot-mode { +Â Â Â Â Â Â Â Â Â Â Â compatible = "syscon-reboot-mode"; +Â Â Â Â Â Â Â Â Â Â Â offset = <0x94>; +Â Â Â Â Â Â Â Â Â Â Â mode-normal = <BOOT_NORMAL>; +Â Â Â Â Â Â Â Â Â Â Â mode-recovery = <BOOT_RECOVERY>; +Â Â Â Â Â Â Â Â Â Â Â mode-bootloader = <BOOT_FASTBOOT>; +Â Â Â Â Â Â Â Â Â Â Â mode-loader = <BOOT_BL_DOWNLOAD>; +Â Â Â Â Â Â Â }; Â Â Â Â Â }; Â Â Â Â Â Â sgrf: syscon@ff740000 { @@ -578,15 +878,65 @@ Â Â Â Â Â }; Â Â Â Â Â Â grf: syscon@ff770000 { -Â Â Â Â Â Â Â compatible = "rockchip,rk3288-grf", "syscon"; +Â Â Â Â Â Â Â compatible = "rockchip,rk3288-grf", "syscon", "simple-mfd"; Â Â Â Â Â Â Â Â Â reg = <0xff770000 0x1000>;
+Â Â Â Â Â Â Â edp_phy: edp-phy { +Â Â Â Â Â Â Â Â Â Â Â compatible = "rockchip,rk3288-dp-phy"; +Â Â Â Â Â Â Â Â Â Â Â clocks = <&cru SCLK_EDP_24M>; +Â Â Â Â Â Â Â Â Â Â Â clock-names = "24m"; +Â Â Â Â Â Â Â Â Â Â Â #phy-cells = <0>; +Â Â Â Â Â Â Â Â Â Â Â status = "disabled"; +Â Â Â Â Â Â Â };
+Â Â Â Â Â Â Â io_domains: io-domains { +Â Â Â Â Â Â Â Â Â Â Â compatible = "rockchip,rk3288-io-voltage-domain"; +Â Â Â Â Â Â Â Â Â Â Â status = "disabled"; +Â Â Â Â Â Â Â };
+Â Â Â Â Â Â Â usbphy: usbphy { +Â Â Â Â Â Â Â Â Â Â Â compatible = "rockchip,rk3288-usb-phy"; +Â Â Â Â Â Â Â Â Â Â Â #address-cells = <1>; +Â Â Â Â Â Â Â Â Â Â Â #size-cells = <0>; +Â Â Â Â Â Â Â Â Â Â Â status = "disabled";
+Â Â Â Â Â Â Â Â Â Â Â usbphy0: usb-phy@320 { +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â #phy-cells = <0>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â reg = <0x320>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â clocks = <&cru SCLK_OTGPHY0>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â clock-names = "phyclk"; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â #clock-cells = <0>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â resets = <&cru SRST_USBOTG_PHY>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â reset-names = "phy-reset"; +Â Â Â Â Â Â Â Â Â Â Â };
+Â Â Â Â Â Â Â Â Â Â Â usbphy1: usb-phy@334 { +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â #phy-cells = <0>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â reg = <0x334>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â clocks = <&cru SCLK_OTGPHY1>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â clock-names = "phyclk"; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â #clock-cells = <0>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â resets = <&cru SRST_USBHOST0_PHY>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â reset-names = "phy-reset"; +Â Â Â Â Â Â Â Â Â Â Â };
+Â Â Â Â Â Â Â Â Â Â Â usbphy2: usb-phy@348 { +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â #phy-cells = <0>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â reg = <0x348>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â clocks = <&cru SCLK_OTGPHY2>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â clock-names = "phyclk"; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â #clock-cells = <0>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â resets = <&cru SRST_USBHOST1_PHY>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â reset-names = "phy-reset"; +Â Â Â Â Â Â Â Â Â Â Â }; +Â Â Â Â Â Â Â }; Â Â Â Â Â }; Â Â Â Â Â Â wdt: watchdog@ff800000 { Â Â Â Â Â Â Â Â Â compatible = "rockchip,rk3288-wdt", "snps,dw-wdt"; Â Â Â Â Â Â Â Â Â reg = <0xff800000 0x100>; Â Â Â Â Â Â Â Â Â clocks = <&cru PCLK_WDT>; -Â Â Â Â Â Â Â interrupts = <GIC_SPI 111 IRQ_TYPE_LEVEL_HIGH>; +Â Â Â Â Â Â Â interrupts = <GIC_SPI 79 IRQ_TYPE_LEVEL_HIGH>; Â Â Â Â Â Â Â Â Â status = "disabled"; Â Â Â Â Â }; Â @@ -594,11 +944,11 @@ Â Â Â Â Â Â Â Â Â compatible = "rockchip,rk3288-spdif", "rockchip,rk3066-spdif"; Â Â Â Â Â Â Â Â Â reg = <0xff8b0000 0x10000>; Â Â Â Â Â Â Â Â Â #sound-dai-cells = <0>; -Â Â Â Â Â Â Â clock-names = "hclk", "mclk"; -Â Â Â Â Â Â Â clocks = <&cru HCLK_SPDIF8CH>, <&cru SCLK_SPDIF8CH>; +Â Â Â Â Â Â Â clocks = <&cru SCLK_SPDIF8CH>, <&cru HCLK_SPDIF8CH>; +Â Â Â Â Â Â Â clock-names = "mclk", "hclk"; Â Â Â Â Â Â Â Â Â dmas = <&dmac_bus_s 3>; Â Â Â Â Â Â Â Â Â dma-names = "tx"; -Â Â Â Â Â Â Â interrupts = <GIC_SPI 85 IRQ_TYPE_LEVEL_HIGH>; +Â Â Â Â Â Â Â interrupts = <GIC_SPI 54 IRQ_TYPE_LEVEL_HIGH>; Â Â Â Â Â Â Â Â Â pinctrl-names = "default"; Â Â Â Â Â Â Â Â Â pinctrl-0 = <&spdif_tx>; Â Â Â Â Â Â Â Â Â rockchip,grf = <&grf>; @@ -608,50 +958,97 @@ Â Â Â Â Â i2s: i2s@ff890000 { Â Â Â Â Â Â Â Â Â compatible = "rockchip,rk3288-i2s", "rockchip,rk3066-i2s"; Â Â Â Â Â Â Â Â Â reg = <0xff890000 0x10000>; -Â Â Â Â Â Â Â interrupts = <GIC_SPI 85 IRQ_TYPE_LEVEL_HIGH>; -Â Â Â Â Â Â Â #address-cells = <1>; -Â Â Â Â Â Â Â #size-cells = <0>; -Â Â Â Â Â Â Â #sound-dai-cells = <1>; +Â Â Â Â Â Â Â #sound-dai-cells = <0>; +Â Â Â Â Â Â Â interrupts = <GIC_SPI 53 IRQ_TYPE_LEVEL_HIGH>; +Â Â Â Â Â Â Â clocks = <&cru SCLK_I2S0>, <&cru HCLK_I2S0>; +Â Â Â Â Â Â Â clock-names = "i2s_clk", "i2s_hclk"; Â Â Â Â Â Â Â Â Â dmas = <&dmac_bus_s 0>, <&dmac_bus_s 1>; Â Â Â Â Â Â Â Â Â dma-names = "tx", "rx"; -Â Â Â Â Â Â Â clock-names = "i2s_hclk", "i2s_clk"; -Â Â Â Â Â Â Â clocks = <&cru HCLK_I2S0>, <&cru SCLK_I2S0>; Â Â Â Â Â Â Â Â Â pinctrl-names = "default"; Â Â Â Â Â Â Â Â Â pinctrl-0 = <&i2s0_bus>; +Â Â Â Â Â Â Â rockchip,playback-channels = <8>; +Â Â Â Â Â Â Â rockchip,capture-channels = <2>; +Â Â Â Â Â Â Â status = "disabled"; +Â Â Â };
+Â Â Â crypto: cypto-controller@ff8a0000 { +Â Â Â Â Â Â Â compatible = "rockchip,rk3288-crypto"; +Â Â Â Â Â Â Â reg = <0xff8a0000 0x4000>; +Â Â Â Â Â Â Â interrupts = <GIC_SPI 48 IRQ_TYPE_LEVEL_HIGH>; +Â Â Â Â Â Â Â clocks = <&cru ACLK_CRYPTO>, <&cru HCLK_CRYPTO>, +Â Â Â Â Â Â Â Â Â Â Â Â <&cru SCLK_CRYPTO>, <&cru ACLK_DMAC1>; +Â Â Â Â Â Â Â clock-names = "aclk", "hclk", "sclk", "apb_pclk"; +Â Â Â Â Â Â Â resets = <&cru SRST_CRYPTO>; +Â Â Â Â Â Â Â reset-names = "crypto-rst"; +Â Â Â };
+Â Â Â iep_mmu: iommu@ff900800 { +Â Â Â Â Â Â Â compatible = "rockchip,iommu"; +Â Â Â Â Â Â Â reg = <0xff900800 0x40>; +Â Â Â Â Â Â Â interrupts = <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>; +Â Â Â Â Â Â Â clocks = <&cru ACLK_IEP>, <&cru HCLK_IEP>; +Â Â Â Â Â Â Â clock-names = "aclk", "iface"; +Â Â Â Â Â Â Â #iommu-cells = <0>; +Â Â Â Â Â Â Â status = "disabled"; +Â Â Â };
+Â Â Â isp_mmu: iommu@ff914000 { +Â Â Â Â Â Â Â compatible = "rockchip,iommu"; +Â Â Â Â Â Â Â reg = <0xff914000 0x100>, <0xff915000 0x100>; +Â Â Â Â Â Â Â interrupts = <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH>; +Â Â Â Â Â Â Â clocks = <&cru ACLK_ISP>, <&cru HCLK_ISP>; +Â Â Â Â Â Â Â clock-names = "aclk", "iface"; +Â Â Â Â Â Â Â #iommu-cells = <0>; +Â Â Â Â Â Â Â rockchip,disable-mmu-reset; Â Â Â Â Â Â Â Â Â status = "disabled"; Â Â Â Â Â }; Â +Â Â Â rga: rga@ff920000 { +Â Â Â Â Â Â Â compatible = "rockchip,rk3288-rga"; +Â Â Â Â Â Â Â reg = <0xff920000 0x180>; +Â Â Â Â Â Â Â interrupts = <GIC_SPI 18 IRQ_TYPE_LEVEL_HIGH>; +Â Â Â Â Â Â Â clocks = <&cru ACLK_RGA>, <&cru HCLK_RGA>, <&cru SCLK_RGA>; +Â Â Â Â Â Â Â clock-names = "aclk", "hclk", "sclk"; +Â Â Â Â Â Â Â power-domains = <&power RK3288_PD_VIO>; +Â Â Â Â Â Â Â resets = <&cru SRST_RGA_CORE>, <&cru SRST_RGA_AXI>, <&cru SRST_RGA_AHB>; +Â Â Â Â Â Â Â reset-names = "core", "axi", "ahb"; +Â Â Â };
vopb: vop@ff930000 { Â Â Â Â Â Â Â Â Â compatible = "rockchip,rk3288-vop"; -Â Â Â Â Â Â Â reg = <0xff930000 0x19c>; +Â Â Â Â Â Â Â reg = <0xff930000 0x19c>, <0xff931000 0x1000>; Â Â Â Â Â Â Â Â Â interrupts = <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>; Â Â Â Â Â Â Â Â Â clocks = <&cru ACLK_VOP0>, <&cru DCLK_VOP0>, <&cru HCLK_VOP0>; Â Â Â Â Â Â Â Â Â clock-names = "aclk_vop", "dclk_vop", "hclk_vop"; +Â Â Â Â Â Â Â power-domains = <&power RK3288_PD_VIO>; Â Â Â Â Â Â Â Â Â resets = <&cru SRST_LCDC0_AXI>, <&cru SRST_LCDC0_AHB>, <&cru SRST_LCDC0_DCLK>; Â Â Â Â Â Â Â Â Â reset-names = "axi", "ahb", "dclk"; Â Â Â Â Â Â Â Â Â iommus = <&vopb_mmu>; -Â Â Â Â Â Â Â power-domains = <&power RK3288_PD_VIO>; Â Â Â Â Â Â Â Â Â status = "disabled";
vopb_out: port { Â Â Â Â Â Â Â Â Â Â Â Â Â #address-cells = <1>; Â Â Â Â Â Â Â Â Â Â Â Â Â #size-cells = <0>; -Â Â Â Â Â Â Â Â Â Â Â vopb_out_edp: endpoint@0 {
+Â Â Â Â Â Â Â Â Â Â Â vopb_out_hdmi: endpoint@0 { Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â reg = <0>; -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â remote-endpoint = <&edp_in_vopb>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â remote-endpoint = <&hdmi_in_vopb>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; -Â Â Â Â Â Â Â Â Â Â Â vopb_out_hdmi: endpoint@1 {
+Â Â Â Â Â Â Â Â Â Â Â vopb_out_edp: endpoint@1 { Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â reg = <1>; -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â remote-endpoint = <&hdmi_in_vopb>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â remote-endpoint = <&edp_in_vopb>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; -Â Â Â Â Â Â Â Â Â Â Â vopb_out_lvds: endpoint@2 {
+Â Â Â Â Â Â Â Â Â Â Â vopb_out_mipi: endpoint@2 { Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â reg = <2>; -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â remote-endpoint = <&lvds_in_vopb>; -Â Â Â Â Â Â Â Â Â Â Â }; -Â Â Â Â Â Â Â Â Â Â Â vopb_out_mipi: endpoint@3 { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â reg = <3>; Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â remote-endpoint = <&mipi_in_vopb>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â +Â Â Â Â Â Â Â Â Â Â Â vopb_out_lvds: endpoint@3 { +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â reg = <3>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â remote-endpoint = <&lvds_in_vopb>; +Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â }; Â @@ -659,7 +1056,8 @@ Â Â Â Â Â Â Â Â Â compatible = "rockchip,iommu"; Â Â Â Â Â Â Â Â Â reg = <0xff930300 0x100>; Â Â Â Â Â Â Â Â Â interrupts = <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>; -Â Â Â Â Â Â Â interrupt-names = "vopb_mmu"; +Â Â Â Â Â Â Â clocks = <&cru ACLK_VOP0>, <&cru HCLK_VOP0>; +Â Â Â Â Â Â Â clock-names = "aclk", "iface"; Â Â Â Â Â Â Â Â Â power-domains = <&power RK3288_PD_VIO>; Â Â Â Â Â Â Â Â Â #iommu-cells = <0>; Â Â Â Â Â Â Â Â Â status = "disabled"; @@ -667,35 +1065,39 @@ Â Â Â Â Â Â vopl: vop@ff940000 { Â Â Â Â Â Â Â Â Â compatible = "rockchip,rk3288-vop"; -Â Â Â Â Â Â Â reg = <0xff940000 0x19c>; +Â Â Â Â Â Â Â reg = <0xff940000 0x19c>, <0xff941000 0x1000>; Â Â Â Â Â Â Â Â Â interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>; Â Â Â Â Â Â Â Â Â clocks = <&cru ACLK_VOP1>, <&cru DCLK_VOP1>, <&cru HCLK_VOP1>; Â Â Â Â Â Â Â Â Â clock-names = "aclk_vop", "dclk_vop", "hclk_vop"; +Â Â Â Â Â Â Â power-domains = <&power RK3288_PD_VIO>; Â Â Â Â Â Â Â Â Â resets = <&cru SRST_LCDC1_AXI>, <&cru SRST_LCDC1_AHB>, <&cru SRST_LCDC1_DCLK>; Â Â Â Â Â Â Â Â Â reset-names = "axi", "ahb", "dclk"; Â Â Â Â Â Â Â Â Â iommus = <&vopl_mmu>; -Â Â Â Â Â Â Â power-domains = <&power RK3288_PD_VIO>; Â Â Â Â Â Â Â Â Â status = "disabled";
vopl_out: port { Â Â Â Â Â Â Â Â Â Â Â Â Â #address-cells = <1>; Â Â Â Â Â Â Â Â Â Â Â Â Â #size-cells = <0>; -Â Â Â Â Â Â Â Â Â Â Â vopl_out_edp: endpoint@0 {
+Â Â Â Â Â Â Â Â Â Â Â vopl_out_hdmi: endpoint@0 { Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â reg = <0>; -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â remote-endpoint = <&edp_in_vopl>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â remote-endpoint = <&hdmi_in_vopl>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; -Â Â Â Â Â Â Â Â Â Â Â vopl_out_hdmi: endpoint@1 {
+Â Â Â Â Â Â Â Â Â Â Â vopl_out_edp: endpoint@1 { Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â reg = <1>; -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â remote-endpoint = <&hdmi_in_vopl>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â remote-endpoint = <&edp_in_vopl>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; -Â Â Â Â Â Â Â Â Â Â Â vopl_out_lvds: endpoint@2 {
+Â Â Â Â Â Â Â Â Â Â Â vopl_out_mipi: endpoint@2 { Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â reg = <2>; -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â remote-endpoint = <&lvds_in_vopl>; -Â Â Â Â Â Â Â Â Â Â Â }; -Â Â Â Â Â Â Â Â Â Â Â vopl_out_mipi: endpoint@3 { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â reg = <3>; Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â remote-endpoint = <&mipi_in_vopl>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â +Â Â Â Â Â Â Â Â Â Â Â vopl_out_lvds: endpoint@3 { +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â reg = <3>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â remote-endpoint = <&lvds_in_vopl>; +Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â }; Â @@ -703,60 +1105,34 @@ Â Â Â Â Â Â Â Â Â compatible = "rockchip,iommu"; Â Â Â Â Â Â Â Â Â reg = <0xff940300 0x100>; Â Â Â Â Â Â Â Â Â interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>; -Â Â Â Â Â Â Â interrupt-names = "vopl_mmu"; +Â Â Â Â Â Â Â clocks = <&cru ACLK_VOP1>, <&cru HCLK_VOP1>; +Â Â Â Â Â Â Â clock-names = "aclk", "iface"; Â Â Â Â Â Â Â Â Â power-domains = <&power RK3288_PD_VIO>; Â Â Â Â Â Â Â Â Â #iommu-cells = <0>; Â Â Â Â Â Â Â Â Â status = "disabled"; Â Â Â Â Â }; Â -Â Â Â edp: edp@ff970000 { -Â Â Â Â Â Â Â compatible = "rockchip,rk3288-edp"; -Â Â Â Â Â Â Â reg = <0xff970000 0x4000>; -Â Â Â Â Â Â Â interrupts = <GIC_SPI 98 IRQ_TYPE_LEVEL_HIGH>; -Â Â Â Â Â Â Â clocks = <&cru SCLK_EDP>, <&cru SCLK_EDP_24M>, <&cru PCLK_EDP_CTRL>; -Â Â Â Â Â Â Â rockchip,grf = <&grf>; -Â Â Â Â Â Â Â clock-names = "clk_edp", "clk_edp_24m", "pclk_edp"; -Â Â Â Â Â Â Â resets = <&cru 111>; -Â Â Â Â Â Â Â reset-names = "edp"; +Â Â Â mipi_dsi: mipi@ff960000 { +Â Â Â Â Â Â Â compatible = "rockchip,rk3288-mipi-dsi", "snps,dw-mipi-dsi"; +Â Â Â Â Â Â Â reg = <0xff960000 0x4000>; +Â Â Â Â Â Â Â interrupts = <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>; +Â Â Â Â Â Â Â clocks = <&cru SCLK_MIPIDSI_24M>, <&cru PCLK_MIPI_DSI0>; +Â Â Â Â Â Â Â clock-names = "ref", "pclk"; Â Â Â Â Â Â Â Â Â power-domains = <&power RK3288_PD_VIO>; -Â Â Â Â Â Â Â status = "disabled"; -Â Â Â Â Â Â Â ports { -Â Â Â Â Â Â Â Â Â Â Â edp_in: port { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â #address-cells = <1>; -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â #size-cells = <0>; -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â edp_in_vopb: endpoint@0 { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â reg = <0>; -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â remote-endpoint = <&vopb_out_edp>; -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â }; -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â edp_in_vopl: endpoint@1 { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â reg = <1>; -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â remote-endpoint = <&vopl_out_edp>; -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â }; -Â Â Â Â Â Â Â Â Â Â Â }; -Â Â Â Â Â Â Â }; -Â Â Â };
-   hdmi: hdmi@ff980000 { -       compatible = "rockchip,rk3288-dw-hdmi"; -       reg = <0xff980000 0x20000>; -       reg-io-width = <4>; -       ddc-i2c-bus = <&i2c5>;          rockchip,grf = <&grf>; -       interrupts = <GIC_SPI 103 IRQ_TYPE_LEVEL_HIGH>; -       clocks = <&cru PCLK_HDMI_CTRL>, <&cru SCLK_HDMI_HDCP>; -       clock-names = "iahb", "isfr";          status = "disabled";
ports { -Â Â Â Â Â Â Â Â Â Â Â hdmi_in: port { +Â Â Â Â Â Â Â Â Â Â Â mipi_in: port { Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â #address-cells = <1>; Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â #size-cells = <0>; -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â hdmi_in_vopb: endpoint@0 { +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â mipi_in_vopb: endpoint@0 { Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â reg = <0>; -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â remote-endpoint = <&vopb_out_hdmi>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â remote-endpoint = <&vopb_out_mipi>; Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â }; -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â hdmi_in_vopl: endpoint@1 { +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â mipi_in_vopl: endpoint@1 { Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â reg = <1>; -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â remote-endpoint = <&vopl_out_hdmi>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â remote-endpoint = <&vopl_out_mipi>; Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â }; @@ -767,17 +1143,22 @@ Â Â Â Â Â Â Â Â Â reg = <0xff96c000 0x4000>; Â Â Â Â Â Â Â Â Â clocks = <&cru PCLK_LVDS_PHY>; Â Â Â Â Â Â Â Â Â clock-names = "pclk_lvds"; -Â Â Â Â Â Â Â pinctrl-names = "default"; -Â Â Â Â Â Â Â pinctrl-0 = <&lcdc0_ctl>; +Â Â Â Â Â Â Â pinctrl-names = "lcdc"; +Â Â Â Â Â Â Â pinctrl-0 = <&lcdc_ctl>; +Â Â Â Â Â Â Â power-domains = <&power RK3288_PD_VIO>; Â Â Â Â Â Â Â Â Â rockchip,grf = <&grf>; Â Â Â Â Â Â Â Â Â status = "disabled";
ports { Â Â Â Â Â Â Â Â Â Â Â Â Â #address-cells = <1>; Â Â Â Â Â Â Â Â Â Â Â Â Â #size-cells = <0>;
lvds_in: port@0 { Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â reg = <0>;
lvds_in_vopb: endpoint@0 { Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â reg = <0>; Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â remote-endpoint = <&vopb_out_lvds>; @@ -790,90 +1171,233 @@ Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â }; Â -Â Â Â mipi_dsi0: mipi@ff960000 { -Â Â Â Â Â Â Â compatible = "rockchip,rk3288_mipi_dsi"; -Â Â Â Â Â Â Â reg = <0xff960000 0x4000>; -Â Â Â Â Â Â Â clocks = <&cru PCLK_MIPI_DSI0>; -Â Â Â Â Â Â Â clock-names = "pclk_mipi"; -Â Â Â Â Â Â Â /*pinctrl-names = "default"; -Â Â Â Â Â Â Â pinctrl-0 = <&lcdc0_ctl>;*/ +Â Â Â edp: dp@ff970000 { +Â Â Â Â Â Â Â compatible = "rockchip,rk3288-dp"; +Â Â Â Â Â Â Â reg = <0xff970000 0x4000>; +Â Â Â Â Â Â Â interrupts = <GIC_SPI 98 IRQ_TYPE_LEVEL_HIGH>; +Â Â Â Â Â Â Â clocks = <&cru SCLK_EDP>, <&cru PCLK_EDP_CTRL>; +Â Â Â Â Â Â Â clock-names = "dp", "pclk"; +Â Â Â Â Â Â Â phys = <&edp_phy>; +Â Â Â Â Â Â Â phy-names = "dp"; +Â Â Â Â Â Â Â resets = <&cru SRST_EDP>; +Â Â Â Â Â Â Â reset-names = "dp"; Â Â Â Â Â Â Â Â Â rockchip,grf = <&grf>; -Â Â Â Â Â Â Â #address-cells = <1>; -Â Â Â Â Â Â Â #size-cells = <0>; Â Â Â Â Â Â Â Â Â status = "disabled";
ports { -           reg = <1>; -           mipi_in: port { +           #address-cells = <1>; +           #size-cells = <0>; +           edp_in: port@0 { +               reg = <0>;                  #address-cells = <1>;                  #size-cells = <0>; -               mipi_in_vopb: endpoint@0 { +               edp_in_vopb: endpoint@0 {                      reg = <0>; -                   remote-endpoint = <&vopb_out_mipi>; +                   remote-endpoint = <&vopb_out_edp>;                  }; -               mipi_in_vopl: endpoint@1 { +               edp_in_vopl: endpoint@1 {                      reg = <1>; -                   remote-endpoint = <&vopl_out_mipi>; +                   remote-endpoint = <&vopl_out_edp>;                  };              };          };      };  -   hdmi_audio: hdmi_audio { -       compatible = "rockchip,rk3288-hdmi-audio"; -       i2s-controller = <&i2s>; -       status = "disable"; +   hdmi: hdmi@ff980000 { +       compatible = "rockchip,rk3288-dw-hdmi"; +       reg = <0xff980000 0x20000>; +       reg-io-width = <4>; +       #sound-dai-cells = <0>; +       rockchip,grf = <&grf>; +       interrupts = <GIC_SPI 103 IRQ_TYPE_LEVEL_HIGH>; +       clocks = <&cru PCLK_HDMI_CTRL>, <&cru SCLK_HDMI_HDCP>, <&cru SCLK_HDMI_CEC>; +       clock-names = "iahb", "isfr", "cec"; +       power-domains = <&power RK3288_PD_VIO>; +       status = "disabled";
+Â Â Â Â Â Â Â ports { +Â Â Â Â Â Â Â Â Â Â Â hdmi_in: port { +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â #address-cells = <1>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â #size-cells = <0>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â hdmi_in_vopb: endpoint@0 { +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â reg = <0>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â remote-endpoint = <&vopb_out_hdmi>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â }; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â hdmi_in_vopl: endpoint@1 { +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â reg = <1>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â remote-endpoint = <&vopl_out_hdmi>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â }; +Â Â Â Â Â Â Â Â Â Â Â }; +Â Â Â Â Â Â Â }; Â Â Â Â Â }; Â Â Â Â Â Â vpu: video-codec@ff9a0000 { Â Â Â Â Â Â Â Â Â compatible = "rockchip,rk3288-vpu"; Â Â Â Â Â Â Â Â Â reg = <0xff9a0000 0x800>; Â Â Â Â Â Â Â Â Â interrupts = <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>; Â Â Â Â Â Â Â Â Â interrupt-names = "vepu", "vdpu"; Â Â Â Â Â Â Â Â Â clocks = <&cru ACLK_VCODEC>, <&cru HCLK_VCODEC>; -Â Â Â Â Â Â Â clock-names = "aclk_vcodec", "hclk_vcodec"; -Â Â Â Â Â Â Â power-domains = <&power RK3288_PD_VIDEO>; +Â Â Â Â Â Â Â clock-names = "aclk", "hclk"; Â Â Â Â Â Â Â Â Â iommus = <&vpu_mmu>; +Â Â Â Â Â Â Â power-domains = <&power RK3288_PD_VIDEO>; Â Â Â Â Â }; Â Â Â Â Â Â vpu_mmu: iommu@ff9a0800 { Â Â Â Â Â Â Â Â Â compatible = "rockchip,iommu"; Â Â Â Â Â Â Â Â Â reg = <0xff9a0800 0x100>; Â Â Â Â Â Â Â Â Â interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>; -Â Â Â Â Â Â Â interrupt-names = "vpu_mmu"; +Â Â Â Â Â Â Â clocks = <&cru ACLK_VCODEC>, <&cru HCLK_VCODEC>; +Â Â Â Â Â Â Â clock-names = "aclk", "iface"; +Â Â Â Â Â Â Â #iommu-cells = <0>; Â Â Â Â Â Â Â Â Â power-domains = <&power RK3288_PD_VIDEO>; +Â Â Â };
+Â Â Â hevc_mmu: iommu@ff9c0440 { +Â Â Â Â Â Â Â compatible = "rockchip,iommu"; +Â Â Â Â Â Â Â reg = <0xff9c0440 0x40>, <0xff9c0480 0x40>; +Â Â Â Â Â Â Â interrupts = <GIC_SPI 111 IRQ_TYPE_LEVEL_HIGH>; +Â Â Â Â Â Â Â clocks = <&cru ACLK_HEVC>, <&cru HCLK_HEVC>; +Â Â Â Â Â Â Â clock-names = "aclk", "iface"; Â Â Â Â Â Â Â Â Â #iommu-cells = <0>; +Â Â Â Â Â Â Â status = "disabled"; Â Â Â Â Â }; Â Â Â Â Â Â gpu: gpu@ffa30000 { -Â Â Â Â Â Â Â compatible = "arm,malit764", -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â "arm,malit76x", -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â "arm,malit7xx", -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â "arm,mali-midgard"; +Â Â Â Â Â Â Â compatible = "rockchip,rk3288-mali", "arm,mali-t760"; Â Â Â Â Â Â Â Â Â reg = <0xffa30000 0x10000>; Â Â Â Â Â Â Â Â Â interrupts = <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>, Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>, Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>; -Â Â Â Â Â Â Â interrupt-names = "JOB", "MMU", "GPU"; +Â Â Â Â Â Â Â interrupt-names = "job", "mmu", "gpu"; Â Â Â Â Â Â Â Â Â clocks = <&cru ACLK_GPU>; -Â Â Â Â Â Â Â clock-names = "aclk_gpu"; -Â Â Â Â Â Â Â operating-points = < -Â Â Â Â Â Â Â Â Â Â Â /* KHz uV */ -Â Â Â Â Â Â Â Â Â Â Â 100000 950000 -Â Â Â Â Â Â Â Â Â Â Â 200000 950000 -Â Â Â Â Â Â Â Â Â Â Â 300000 1000000 -Â Â Â Â Â Â Â Â Â Â Â 400000 1100000 -Â Â Â Â Â Â Â Â Â Â Â /* 500000 1200000 - See crosbug.com/p/33857 */ -Â Â Â Â Â Â Â Â Â Â Â 600000 1250000 -Â Â Â Â Â Â Â >; +Â Â Â Â Â Â Â operating-points-v2 = <&gpu_opp_table>; +Â Â Â Â Â Â Â #cooling-cells = <2>; /* min followed by max */ Â Â Â Â Â Â Â Â Â power-domains = <&power RK3288_PD_GPU>; Â Â Â Â Â Â Â Â Â status = "disabled"; Â Â Â Â Â }; Â +Â Â Â gpu_opp_table: opp-table-1 { +Â Â Â Â Â Â Â compatible = "operating-points-v2";
+Â Â Â Â Â Â Â opp-100000000 { +Â Â Â Â Â Â Â Â Â Â Â opp-hz = /bits/ 64 <100000000>; +Â Â Â Â Â Â Â Â Â Â Â opp-microvolt = <950000>; +Â Â Â Â Â Â Â }; +Â Â Â Â Â Â Â opp-200000000 { +Â Â Â Â Â Â Â Â Â Â Â opp-hz = /bits/ 64 <200000000>; +Â Â Â Â Â Â Â Â Â Â Â opp-microvolt = <950000>; +Â Â Â Â Â Â Â }; +Â Â Â Â Â Â Â opp-300000000 { +Â Â Â Â Â Â Â Â Â Â Â opp-hz = /bits/ 64 <300000000>; +Â Â Â Â Â Â Â Â Â Â Â opp-microvolt = <1000000>; +Â Â Â Â Â Â Â }; +Â Â Â Â Â Â Â opp-400000000 { +Â Â Â Â Â Â Â Â Â Â Â opp-hz = /bits/ 64 <400000000>; +Â Â Â Â Â Â Â Â Â Â Â opp-microvolt = <1100000>; +Â Â Â Â Â Â Â }; +Â Â Â Â Â Â Â opp-600000000 { +Â Â Â Â Â Â Â Â Â Â Â opp-hz = /bits/ 64 <600000000>; +Â Â Â Â Â Â Â Â Â Â Â opp-microvolt = <1250000>; +Â Â Â Â Â Â Â }; +Â Â Â };
+Â Â Â qos_gpu_r: qos@ffaa0000 { +Â Â Â Â Â Â Â compatible = "rockchip,rk3288-qos", "syscon"; +Â Â Â Â Â Â Â reg = <0xffaa0000 0x20>; +Â Â Â };
+Â Â Â qos_gpu_w: qos@ffaa0080 { +Â Â Â Â Â Â Â compatible = "rockchip,rk3288-qos", "syscon"; +Â Â Â Â Â Â Â reg = <0xffaa0080 0x20>; +Â Â Â };
+Â Â Â qos_vio1_vop: qos@ffad0000 { +Â Â Â Â Â Â Â compatible = "rockchip,rk3288-qos", "syscon"; +Â Â Â Â Â Â Â reg = <0xffad0000 0x20>; +Â Â Â };
+Â Â Â qos_vio1_isp_w0: qos@ffad0100 { +Â Â Â Â Â Â Â compatible = "rockchip,rk3288-qos", "syscon"; +Â Â Â Â Â Â Â reg = <0xffad0100 0x20>; +Â Â Â };
+Â Â Â qos_vio1_isp_w1: qos@ffad0180 { +Â Â Â Â Â Â Â compatible = "rockchip,rk3288-qos", "syscon"; +Â Â Â Â Â Â Â reg = <0xffad0180 0x20>; +Â Â Â };
+Â Â Â qos_vio0_vop: qos@ffad0400 { +Â Â Â Â Â Â Â compatible = "rockchip,rk3288-qos", "syscon"; +Â Â Â Â Â Â Â reg = <0xffad0400 0x20>; +Â Â Â };
+Â Â Â qos_vio0_vip: qos@ffad0480 { +Â Â Â Â Â Â Â compatible = "rockchip,rk3288-qos", "syscon"; +Â Â Â Â Â Â Â reg = <0xffad0480 0x20>; +Â Â Â };
+Â Â Â qos_vio0_iep: qos@ffad0500 { +Â Â Â Â Â Â Â compatible = "rockchip,rk3288-qos", "syscon"; +Â Â Â Â Â Â Â reg = <0xffad0500 0x20>; +Â Â Â };
+Â Â Â qos_vio2_rga_r: qos@ffad0800 { +Â Â Â Â Â Â Â compatible = "rockchip,rk3288-qos", "syscon"; +Â Â Â Â Â Â Â reg = <0xffad0800 0x20>; +Â Â Â };
+Â Â Â qos_vio2_rga_w: qos@ffad0880 { +Â Â Â Â Â Â Â compatible = "rockchip,rk3288-qos", "syscon"; +Â Â Â Â Â Â Â reg = <0x0 0xffad0880 0x0 0x20>; +Â Â Â };
+Â Â Â qos_vio1_isp_r: qos@ffad0900 { +Â Â Â Â Â Â Â compatible = "rockchip,rk3288-qos", "syscon"; +Â Â Â Â Â Â Â reg = <0xffad0900 0x20>; +Â Â Â };
+Â Â Â qos_video: qos@ffae0000 { +Â Â Â Â Â Â Â compatible = "rockchip,rk3288-qos", "syscon"; +Â Â Â Â Â Â Â reg = <0xffae0000 0x20>; +Â Â Â };
+Â Â Â qos_hevc_r: qos@ffaf0000 { +Â Â Â Â Â Â Â compatible = "rockchip,rk3288-qos", "syscon"; +Â Â Â Â Â Â Â reg = <0xffaf0000 0x20>; +Â Â Â };
+Â Â Â qos_hevc_w: qos@ffaf0080 { +Â Â Â Â Â Â Â compatible = "rockchip,rk3288-qos", "syscon"; +Â Â Â Â Â Â Â reg = <0xffaf0080 0x20>; +Â Â Â };
+Â Â Â dmac_bus_s: dma-controller@ffb20000 { +Â Â Â Â Â Â Â compatible = "arm,pl330", "arm,primecell"; +Â Â Â Â Â Â Â reg = <0xffb20000 0x4000>; +Â Â Â Â Â Â Â interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>; +Â Â Â Â Â Â Â #dma-cells = <1>; +Â Â Â Â Â Â Â arm,pl330-broken-no-flushp; +Â Â Â Â Â Â Â arm,pl330-periph-burst; +Â Â Â Â Â Â Â clocks = <&cru ACLK_DMAC1>; +Â Â Â Â Â Â Â clock-names = "apb_pclk"; +Â Â Â };
efuse: efuse@ffb40000 { Â Â Â Â Â Â Â Â Â compatible = "rockchip,rk3288-efuse"; -Â Â Â Â Â Â Â reg = <0xffb40000 0x10000>; -Â Â Â Â Â Â Â status = "disabled"; +Â Â Â Â Â Â Â reg = <0xffb40000 0x20>; +Â Â Â Â Â Â Â #address-cells = <1>; +Â Â Â Â Â Â Â #size-cells = <1>; +Â Â Â Â Â Â Â clocks = <&cru PCLK_EFUSE256>; +Â Â Â Â Â Â Â clock-names = "pclk_efuse";
+Â Â Â Â Â Â Â cpu_id: cpu-id@7 { +Â Â Â Â Â Â Â Â Â Â Â reg = <0x07 0x10>; +Â Â Â Â Â Â Â }; +Â Â Â Â Â Â Â cpu_leakage: cpu_leakage@17 { +Â Â Â Â Â Â Â Â Â Â Â reg = <0x17 0x1>; +Â Â Â Â Â Â Â }; Â Â Â Â Â }; Â Â Â Â Â Â gic: interrupt-controller@ffc01000 { @@ -883,45 +1407,12 @@ Â Â Â Â Â Â Â Â Â #address-cells = <0>; Â Â Â Â Â Â Â Â Â Â reg = <0xffc01000 0x1000>, -Â Â Â Â Â Â Â Â Â Â Â Â Â <0xffc02000 0x1000>, +Â Â Â Â Â Â Â Â Â Â Â Â Â <0xffc02000 0x2000>, Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <0xffc04000 0x2000>, Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <0xffc06000 0x2000>; Â Â Â Â Â Â Â Â Â interrupts = <GIC_PPI 9 0xf04>; Â Â Â Â Â }; Â -Â Â Â cpuidle: cpuidle { -Â Â Â Â Â Â Â compatible = "rockchip,rk3288-cpuidle"; -Â Â Â };
-Â Â Â usbphy: phy { -Â Â Â Â Â Â Â compatible = "rockchip,rk3288-usb-phy"; -Â Â Â Â Â Â Â rockchip,grf = <&grf>; -Â Â Â Â Â Â Â #address-cells = <1>; -Â Â Â Â Â Â Â #size-cells = <0>; -Â Â Â Â Â Â Â status = "disabled";
-Â Â Â Â Â Â Â usbphy0: usb-phy0 { -Â Â Â Â Â Â Â Â Â Â Â #phy-cells = <0>; -Â Â Â Â Â Â Â Â Â Â Â reg = <0x320>; -Â Â Â Â Â Â Â Â Â Â Â clocks = <&cru SCLK_OTGPHY0>; -Â Â Â Â Â Â Â Â Â Â Â clock-names = "phyclk"; -Â Â Â Â Â Â Â };
-Â Â Â Â Â Â Â usbphy1: usb-phy1 { -Â Â Â Â Â Â Â Â Â Â Â #phy-cells = <0>; -Â Â Â Â Â Â Â Â Â Â Â reg = <0x334>; -Â Â Â Â Â Â Â Â Â Â Â clocks = <&cru SCLK_OTGPHY1>; -Â Â Â Â Â Â Â Â Â Â Â clock-names = "phyclk"; -Â Â Â Â Â Â Â };
-Â Â Â Â Â Â Â usbphy2: usb-phy2 { -Â Â Â Â Â Â Â Â Â Â Â #phy-cells = <0>; -Â Â Â Â Â Â Â Â Â Â Â reg = <0x348>; -Â Â Â Â Â Â Â Â Â Â Â clocks = <&cru SCLK_OTGPHY2>; -Â Â Â Â Â Â Â Â Â Â Â clock-names = "phyclk"; -Â Â Â Â Â Â Â }; -Â Â Â };
pinctrl: pinctrl { Â Â Â Â Â Â Â Â Â compatible = "rockchip,rk3288-pinctrl"; Â Â Â Â Â Â Â Â Â rockchip,grf = <&grf>; @@ -930,9 +1421,9 @@ Â Â Â Â Â Â Â Â Â #size-cells = <1>; Â Â Â Â Â Â Â Â Â ranges; Â -Â Â Â Â Â Â Â gpio0: gpio0@ff750000 { +Â Â Â Â Â Â Â gpio0: gpio@ff750000 { Â Â Â Â Â Â Â Â Â Â Â Â Â compatible = "rockchip,gpio-bank"; -Â Â Â Â Â Â Â Â Â Â Â reg =Â Â Â <0xff750000 0x100>; +Â Â Â Â Â Â Â Â Â Â Â reg = <0xff750000 0x100>; Â Â Â Â Â Â Â Â Â Â Â Â Â interrupts = <GIC_SPI 81 IRQ_TYPE_LEVEL_HIGH>; Â Â Â Â Â Â Â Â Â Â Â Â Â clocks = <&cru PCLK_GPIO0>; Â @@ -943,7 +1434,7 @@ Â Â Â Â Â Â Â Â Â Â Â Â Â #interrupt-cells = <2>; Â Â Â Â Â Â Â Â Â }; Â -Â Â Â Â Â Â Â gpio1: gpio1@ff780000 { +Â Â Â Â Â Â Â gpio1: gpio@ff780000 { Â Â Â Â Â Â Â Â Â Â Â Â Â compatible = "rockchip,gpio-bank"; Â Â Â Â Â Â Â Â Â Â Â Â Â reg = <0xff780000 0x100>; Â Â Â Â Â Â Â Â Â Â Â Â Â interrupts = <GIC_SPI 82 IRQ_TYPE_LEVEL_HIGH>; @@ -956,7 +1447,7 @@ Â Â Â Â Â Â Â Â Â Â Â Â Â #interrupt-cells = <2>; Â Â Â Â Â Â Â Â Â }; Â -Â Â Â Â Â Â Â gpio2: gpio2@ff790000 { +Â Â Â Â Â Â Â gpio2: gpio@ff790000 { Â Â Â Â Â Â Â Â Â Â Â Â Â compatible = "rockchip,gpio-bank"; Â Â Â Â Â Â Â Â Â Â Â Â Â reg = <0xff790000 0x100>; Â Â Â Â Â Â Â Â Â Â Â Â Â interrupts = <GIC_SPI 83 IRQ_TYPE_LEVEL_HIGH>; @@ -969,7 +1460,7 @@ Â Â Â Â Â Â Â Â Â Â Â Â Â #interrupt-cells = <2>; Â Â Â Â Â Â Â Â Â }; Â -Â Â Â Â Â Â Â gpio3: gpio3@ff7a0000 { +Â Â Â Â Â Â Â gpio3: gpio@ff7a0000 { Â Â Â Â Â Â Â Â Â Â Â Â Â compatible = "rockchip,gpio-bank"; Â Â Â Â Â Â Â Â Â Â Â Â Â reg = <0xff7a0000 0x100>; Â Â Â Â Â Â Â Â Â Â Â Â Â interrupts = <GIC_SPI 84 IRQ_TYPE_LEVEL_HIGH>; @@ -982,7 +1473,7 @@ Â Â Â Â Â Â Â Â Â Â Â Â Â #interrupt-cells = <2>; Â Â Â Â Â Â Â Â Â }; Â -Â Â Â Â Â Â Â gpio4: gpio4@ff7b0000 { +Â Â Â Â Â Â Â gpio4: gpio@ff7b0000 { Â Â Â Â Â Â Â Â Â Â Â Â Â compatible = "rockchip,gpio-bank"; Â Â Â Â Â Â Â Â Â Â Â Â Â reg = <0xff7b0000 0x100>; Â Â Â Â Â Â Â Â Â Â Â Â Â interrupts = <GIC_SPI 85 IRQ_TYPE_LEVEL_HIGH>; @@ -995,7 +1486,7 @@ Â Â Â Â Â Â Â Â Â Â Â Â Â #interrupt-cells = <2>; Â Â Â Â Â Â Â Â Â }; Â -Â Â Â Â Â Â Â gpio5: gpio5@ff7c0000 { +Â Â Â Â Â Â Â gpio5: gpio@ff7c0000 { Â Â Â Â Â Â Â Â Â Â Â Â Â compatible = "rockchip,gpio-bank"; Â Â Â Â Â Â Â Â Â Â Â Â Â reg = <0xff7c0000 0x100>; Â Â Â Â Â Â Â Â Â Â Â Â Â interrupts = <GIC_SPI 86 IRQ_TYPE_LEVEL_HIGH>; @@ -1008,7 +1499,7 @@ Â Â Â Â Â Â Â Â Â Â Â Â Â #interrupt-cells = <2>; Â Â Â Â Â Â Â Â Â }; Â -Â Â Â Â Â Â Â gpio6: gpio6@ff7d0000 { +Â Â Â Â Â Â Â gpio6: gpio@ff7d0000 { Â Â Â Â Â Â Â Â Â Â Â Â Â compatible = "rockchip,gpio-bank"; Â Â Â Â Â Â Â Â Â Â Â Â Â reg = <0xff7d0000 0x100>; Â Â Â Â Â Â Â Â Â Â Â Â Â interrupts = <GIC_SPI 87 IRQ_TYPE_LEVEL_HIGH>; @@ -1021,7 +1512,7 @@ Â Â Â Â Â Â Â Â Â Â Â Â Â #interrupt-cells = <2>; Â Â Â Â Â Â Â Â Â }; Â -Â Â Â Â Â Â Â gpio7: gpio7@ff7e0000 { +Â Â Â Â Â Â Â gpio7: gpio@ff7e0000 { Â Â Â Â Â Â Â Â Â Â Â Â Â compatible = "rockchip,gpio-bank"; Â Â Â Â Â Â Â Â Â Â Â Â Â reg = <0xff7e0000 0x100>; Â Â Â Â Â Â Â Â Â Â Â Â Â interrupts = <GIC_SPI 88 IRQ_TYPE_LEVEL_HIGH>; @@ -1034,7 +1525,7 @@ Â Â Â Â Â Â Â Â Â Â Â Â Â #interrupt-cells = <2>; Â Â Â Â Â Â Â Â Â }; Â -Â Â Â Â Â Â Â gpio8: gpio8@ff7f0000 { +Â Â Â Â Â Â Â gpio8: gpio@ff7f0000 { Â Â Â Â Â Â Â Â Â Â Â Â Â compatible = "rockchip,gpio-bank"; Â Â Â Â Â Â Â Â Â Â Â Â Â reg = <0xff7f0000 0x100>; Â Â Â Â Â Â Â Â Â Â Â Â Â interrupts = <GIC_SPI 89 IRQ_TYPE_LEVEL_HIGH>; @@ -1051,6 +1542,24 @@ Â Â Â Â Â Â Â Â Â Â Â Â Â hdmi_cec_c0: hdmi-cec-c0 { Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <7 RK_PC0 2 &pcfg_pull_none>; Â Â Â Â Â Â Â Â Â Â Â Â Â };
+Â Â Â Â Â Â Â Â Â Â Â hdmi_cec_c7: hdmi-cec-c7 { +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <7 RK_PC7 4 &pcfg_pull_none>; +Â Â Â Â Â Â Â Â Â Â Â };
+Â Â Â Â Â Â Â Â Â Â Â hdmi_ddc: hdmi-ddc { +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <7 RK_PC3 2 &pcfg_pull_none>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <7 RK_PC4 2 &pcfg_pull_none>; +Â Â Â Â Â Â Â Â Â Â Â };
+Â Â Â Â Â Â Â Â Â Â Â hdmi_ddc_unwedge: hdmi-ddc-unwedge { +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <7 RK_PC3 RK_FUNC_GPIO &pcfg_output_low>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <7 RK_PC4 2 &pcfg_pull_none>; +Â Â Â Â Â Â Â Â Â Â Â }; +Â Â Â Â Â Â Â };
+Â Â Â Â Â Â Â pcfg_output_low: pcfg-output-low { +Â Â Â Â Â Â Â Â Â Â Â output-low; Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â pcfg_pull_up: pcfg-pull-up { @@ -1070,472 +1579,424 @@ Â Â Â Â Â Â Â Â Â Â Â Â Â drive-strength = <12>; Â Â Â Â Â Â Â Â Â }; Â -Â Â Â Â Â Â Â sleep { +Â Â Â Â Â Â Â suspend { Â Â Â Â Â Â Â Â Â Â Â Â Â global_pwroff: global-pwroff { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <0 0 RK_FUNC_1 &pcfg_pull_none>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <0 RK_PA0 1 &pcfg_pull_none>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â Â Â Â Â ddrio_pwroff: ddrio-pwroff { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <0 1 RK_FUNC_1 &pcfg_pull_none>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <0 RK_PA1 1 &pcfg_pull_none>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â Â Â Â Â ddr0_retention: ddr0-retention { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <0 2 RK_FUNC_1 &pcfg_pull_up>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <0 RK_PA2 1 &pcfg_pull_up>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â Â Â Â Â ddr1_retention: ddr1-retention { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <0 3 RK_FUNC_1 &pcfg_pull_up>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <0 RK_PA3 1 &pcfg_pull_up>; +Â Â Â Â Â Â Â Â Â Â Â }; +Â Â Â Â Â Â Â };
+Â Â Â Â Â Â Â edp { +Â Â Â Â Â Â Â Â Â Â Â edp_hpd: edp-hpd { +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <7 RK_PB3 2 &pcfg_pull_down>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â i2c0 { Â Â Â Â Â Â Â Â Â Â Â Â Â i2c0_xfer: i2c0-xfer { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <0 15 RK_FUNC_1 &pcfg_pull_none>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <0 16 RK_FUNC_1 &pcfg_pull_none>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <0 RK_PB7 1 &pcfg_pull_none>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <0 RK_PC0 1 &pcfg_pull_none>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â i2c1 { Â Â Â Â Â Â Â Â Â Â Â Â Â i2c1_xfer: i2c1-xfer { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <8 4 RK_FUNC_1 &pcfg_pull_none>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <8 5 RK_FUNC_1 &pcfg_pull_none>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <8 RK_PA4 1 &pcfg_pull_none>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <8 RK_PA5 1 &pcfg_pull_none>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â i2c2 { Â Â Â Â Â Â Â Â Â Â Â Â Â i2c2_xfer: i2c2-xfer { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <6 9 RK_FUNC_1 &pcfg_pull_none>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <6 10 RK_FUNC_1 &pcfg_pull_none>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <6 RK_PB1 1 &pcfg_pull_none>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <6 RK_PB2 1 &pcfg_pull_none>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â i2c3 { Â Â Â Â Â Â Â Â Â Â Â Â Â i2c3_xfer: i2c3-xfer { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <2 16 RK_FUNC_1 &pcfg_pull_none>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <2 17 RK_FUNC_1 &pcfg_pull_none>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <2 RK_PC0 1 &pcfg_pull_none>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <2 RK_PC1 1 &pcfg_pull_none>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â i2c4 { Â Â Â Â Â Â Â Â Â Â Â Â Â i2c4_xfer: i2c4-xfer { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <7 17 RK_FUNC_1 &pcfg_pull_none>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <7 18 RK_FUNC_1 &pcfg_pull_none>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <7 RK_PC1 1 &pcfg_pull_none>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <7 RK_PC2 1 &pcfg_pull_none>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â i2c5 { Â Â Â Â Â Â Â Â Â Â Â Â Â i2c5_xfer: i2c5-xfer { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <7 19 RK_FUNC_1 &pcfg_pull_none>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <7 20 RK_FUNC_1 &pcfg_pull_none>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <7 RK_PC3 1 &pcfg_pull_none>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <7 RK_PC4 1 &pcfg_pull_none>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â i2s0 { Â Â Â Â Â Â Â Â Â Â Â Â Â i2s0_bus: i2s0-bus { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <6 0 RK_FUNC_1 &pcfg_pull_none>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <6 1 RK_FUNC_1 &pcfg_pull_none>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <6 2 RK_FUNC_1 &pcfg_pull_none>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <6 3 RK_FUNC_1 &pcfg_pull_none>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <6 4 RK_FUNC_1 &pcfg_pull_none>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <6 8 RK_FUNC_1 &pcfg_pull_none>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <6 RK_PA0 1 &pcfg_pull_none>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <6 RK_PA1 1 &pcfg_pull_none>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <6 RK_PA2 1 &pcfg_pull_none>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <6 RK_PA3 1 &pcfg_pull_none>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <6 RK_PA4 1 &pcfg_pull_none>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <6 RK_PB0 1 &pcfg_pull_none>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â }; Â -Â Â Â Â Â Â Â lcdc0 { -Â Â Â Â Â Â Â Â Â Â Â lcdc0_ctl: lcdc0-ctl { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <1 24 RK_FUNC_1 &pcfg_pull_none>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <1 25 RK_FUNC_1 &pcfg_pull_none>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <1 26 RK_FUNC_1 &pcfg_pull_none>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <1 27 RK_FUNC_1 &pcfg_pull_none>; +Â Â Â Â Â Â Â lcdc { +Â Â Â Â Â Â Â Â Â Â Â lcdc_ctl: lcdc-ctl { +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <1 RK_PD0 1 &pcfg_pull_none>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <1 RK_PD1 1 &pcfg_pull_none>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <1 RK_PD2 1 &pcfg_pull_none>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <1 RK_PD3 1 &pcfg_pull_none>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â sdmmc { Â Â Â Â Â Â Â Â Â Â Â Â Â sdmmc_clk: sdmmc-clk { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <6 20 RK_FUNC_1 &pcfg_pull_none>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <6 RK_PC4 1 &pcfg_pull_none>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â Â Â Â Â sdmmc_cmd: sdmmc-cmd { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <6 21 RK_FUNC_1 &pcfg_pull_up>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <6 RK_PC5 1 &pcfg_pull_up>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â -Â Â Â Â Â Â Â Â Â Â Â sdmmc_cd: sdmcc-cd { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <6 22 RK_FUNC_1 &pcfg_pull_up>; +Â Â Â Â Â Â Â Â Â Â Â sdmmc_cd: sdmmc-cd { +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <6 RK_PC6 1 &pcfg_pull_up>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â Â Â Â Â sdmmc_bus1: sdmmc-bus1 { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <6 16 RK_FUNC_1 &pcfg_pull_up>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <6 RK_PC0 1 &pcfg_pull_up>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â Â Â Â Â sdmmc_bus4: sdmmc-bus4 { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <6 16 RK_FUNC_1 &pcfg_pull_up>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <6 17 RK_FUNC_1 &pcfg_pull_up>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <6 18 RK_FUNC_1 &pcfg_pull_up>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <6 19 RK_FUNC_1 &pcfg_pull_up>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <6 RK_PC0 1 &pcfg_pull_up>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <6 RK_PC1 1 &pcfg_pull_up>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <6 RK_PC2 1 &pcfg_pull_up>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <6 RK_PC3 1 &pcfg_pull_up>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â sdio0 { Â Â Â Â Â Â Â Â Â Â Â Â Â sdio0_bus1: sdio0-bus1 { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <4 20 RK_FUNC_1 &pcfg_pull_up>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <4 RK_PC4 1 &pcfg_pull_up>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â Â Â Â Â sdio0_bus4: sdio0-bus4 { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <4 20 RK_FUNC_1 &pcfg_pull_up>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <4 21 RK_FUNC_1 &pcfg_pull_up>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <4 22 RK_FUNC_1 &pcfg_pull_up>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <4 23 RK_FUNC_1 &pcfg_pull_up>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <4 RK_PC4 1 &pcfg_pull_up>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <4 RK_PC5 1 &pcfg_pull_up>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <4 RK_PC6 1 &pcfg_pull_up>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <4 RK_PC7 1 &pcfg_pull_up>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â Â Â Â Â sdio0_cmd: sdio0-cmd { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <4 24 RK_FUNC_1 &pcfg_pull_up>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <4 RK_PD0 1 &pcfg_pull_up>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â Â Â Â Â sdio0_clk: sdio0-clk { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <4 25 RK_FUNC_1 &pcfg_pull_none>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <4 RK_PD1 1 &pcfg_pull_none>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â Â Â Â Â sdio0_cd: sdio0-cd { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <4 26 RK_FUNC_1 &pcfg_pull_up>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <4 RK_PD2 1 &pcfg_pull_up>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â Â Â Â Â sdio0_wp: sdio0-wp { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <4 27 RK_FUNC_1 &pcfg_pull_up>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <4 RK_PD3 1 &pcfg_pull_up>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â Â Â Â Â sdio0_pwr: sdio0-pwr { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <4 28 RK_FUNC_1 &pcfg_pull_up>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <4 RK_PD4 1 &pcfg_pull_up>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â Â Â Â Â sdio0_bkpwr: sdio0-bkpwr { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <4 29 RK_FUNC_1 &pcfg_pull_up>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <4 RK_PD5 1 &pcfg_pull_up>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â Â Â Â Â sdio0_int: sdio0-int { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <4 30 RK_FUNC_1 &pcfg_pull_up>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <4 RK_PD6 1 &pcfg_pull_up>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â sdio1 { Â Â Â Â Â Â Â Â Â Â Â Â Â sdio1_bus1: sdio1-bus1 { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <3 24 RK_FUNC_4 &pcfg_pull_up>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <3 RK_PD0 4 &pcfg_pull_up>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â Â Â Â Â sdio1_bus4: sdio1-bus4 { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <3 24 RK_FUNC_4 &pcfg_pull_up>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <3 25 RK_FUNC_4 &pcfg_pull_up>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <3 26 RK_FUNC_4 &pcfg_pull_up>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <3 27 RK_FUNC_4 &pcfg_pull_up>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <3 RK_PD0 4 &pcfg_pull_up>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <3 RK_PD1 4 &pcfg_pull_up>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <3 RK_PD2 4 &pcfg_pull_up>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <3 RK_PD3 4 &pcfg_pull_up>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â Â Â Â Â sdio1_cd: sdio1-cd { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <3 28 RK_FUNC_4 &pcfg_pull_up>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <3 RK_PD4 4 &pcfg_pull_up>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â Â Â Â Â sdio1_wp: sdio1-wp { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <3 29 RK_FUNC_4 &pcfg_pull_up>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <3 RK_PD5 4 &pcfg_pull_up>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â Â Â Â Â sdio1_bkpwr: sdio1-bkpwr { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <3 30 RK_FUNC_4 &pcfg_pull_up>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <3 RK_PD6 4 &pcfg_pull_up>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â Â Â Â Â sdio1_int: sdio1-int { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <3 31 RK_FUNC_4 &pcfg_pull_up>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <3 RK_PD7 4 &pcfg_pull_up>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â Â Â Â Â sdio1_cmd: sdio1-cmd { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <4 6 RK_FUNC_4 &pcfg_pull_up>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <4 RK_PA6 4 &pcfg_pull_up>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â Â Â Â Â sdio1_clk: sdio1-clk { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <4 7 RK_FUNC_4 &pcfg_pull_none>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <4 RK_PA7 4 &pcfg_pull_none>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â Â Â Â Â sdio1_pwr: sdio1-pwr { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <4 9 RK_FUNC_4 &pcfg_pull_up>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <4 RK_PB1 4 &pcfg_pull_up>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â emmc { Â Â Â Â Â Â Â Â Â Â Â Â Â emmc_clk: emmc-clk { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <3 18 RK_FUNC_2 &pcfg_pull_none>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <3 RK_PC2 2 &pcfg_pull_none>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â Â Â Â Â emmc_cmd: emmc-cmd { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <3 16 RK_FUNC_2 &pcfg_pull_up>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <3 RK_PC0 2 &pcfg_pull_up>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â Â Â Â Â emmc_pwr: emmc-pwr { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <3 9 RK_FUNC_2 &pcfg_pull_up>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <3 RK_PB1 2 &pcfg_pull_up>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â Â Â Â Â emmc_bus1: emmc-bus1 { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <3 0 RK_FUNC_2 &pcfg_pull_up>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <3 RK_PA0 2 &pcfg_pull_up>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â Â Â Â Â emmc_bus4: emmc-bus4 { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <3 0 RK_FUNC_2 &pcfg_pull_up>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <3 1 RK_FUNC_2 &pcfg_pull_up>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <3 2 RK_FUNC_2 &pcfg_pull_up>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <3 3 RK_FUNC_2 &pcfg_pull_up>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <3 RK_PA0 2 &pcfg_pull_up>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <3 RK_PA1 2 &pcfg_pull_up>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <3 RK_PA2 2 &pcfg_pull_up>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <3 RK_PA3 2 &pcfg_pull_up>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â Â Â Â Â emmc_bus8: emmc-bus8 { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <3 0 RK_FUNC_2 &pcfg_pull_up>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <3 1 RK_FUNC_2 &pcfg_pull_up>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <3 2 RK_FUNC_2 &pcfg_pull_up>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <3 3 RK_FUNC_2 &pcfg_pull_up>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <3 4 RK_FUNC_2 &pcfg_pull_up>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <3 5 RK_FUNC_2 &pcfg_pull_up>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <3 6 RK_FUNC_2 &pcfg_pull_up>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <3 7 RK_FUNC_2 &pcfg_pull_up>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <3 RK_PA0 2 &pcfg_pull_up>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <3 RK_PA1 2 &pcfg_pull_up>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <3 RK_PA2 2 &pcfg_pull_up>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <3 RK_PA3 2 &pcfg_pull_up>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <3 RK_PA4 2 &pcfg_pull_up>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <3 RK_PA5 2 &pcfg_pull_up>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <3 RK_PA6 2 &pcfg_pull_up>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <3 RK_PA7 2 &pcfg_pull_up>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â spi0 { Â Â Â Â Â Â Â Â Â Â Â Â Â spi0_clk: spi0-clk { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <5 12 RK_FUNC_1 &pcfg_pull_up>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <5 RK_PB4 1 &pcfg_pull_up>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â Â Â Â spi0_cs0: spi0-cs0 { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <5 13 RK_FUNC_1 &pcfg_pull_up>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <5 RK_PB5 1 &pcfg_pull_up>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â Â Â Â spi0_tx: spi0-tx { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <5 14 RK_FUNC_1 &pcfg_pull_up>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <5 RK_PB6 1 &pcfg_pull_up>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â Â Â Â spi0_rx: spi0-rx { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <5 15 RK_FUNC_1 &pcfg_pull_up>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <5 RK_PB7 1 &pcfg_pull_up>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â Â Â Â spi0_cs1: spi0-cs1 { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <5 16 RK_FUNC_1 &pcfg_pull_up>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <5 RK_PC0 1 &pcfg_pull_up>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â spi1 { Â Â Â Â Â Â Â Â Â Â Â Â Â spi1_clk: spi1-clk { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <7 12 RK_FUNC_2 &pcfg_pull_up>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <7 RK_PB4 2 &pcfg_pull_up>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â Â Â Â spi1_cs0: spi1-cs0 { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <7 13 RK_FUNC_2 &pcfg_pull_up>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <7 RK_PB5 2 &pcfg_pull_up>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â Â Â Â spi1_rx: spi1-rx { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <7 14 RK_FUNC_2 &pcfg_pull_up>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <7 RK_PB6 2 &pcfg_pull_up>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â Â Â Â spi1_tx: spi1-tx { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <7 15 RK_FUNC_2 &pcfg_pull_up>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <7 RK_PB7 2 &pcfg_pull_up>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â spi2 { Â Â Â Â Â Â Â Â Â Â Â Â Â spi2_cs1: spi2-cs1 { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <8 3 RK_FUNC_1 &pcfg_pull_up>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <8 RK_PA3 1 &pcfg_pull_up>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â Â Â Â spi2_clk: spi2-clk { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <8 6 RK_FUNC_1 &pcfg_pull_up>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <8 RK_PA6 1 &pcfg_pull_up>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â Â Â Â spi2_cs0: spi2-cs0 { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <8 7 RK_FUNC_1 &pcfg_pull_up>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <8 RK_PA7 1 &pcfg_pull_up>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â Â Â Â spi2_rx: spi2-rx { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <8 8 RK_FUNC_1 &pcfg_pull_up>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <8 RK_PB0 1 &pcfg_pull_up>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â Â Â Â spi2_tx: spi2-tx { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <8 9 RK_FUNC_1 &pcfg_pull_up>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <8 RK_PB1 1 &pcfg_pull_up>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â uart0 { Â Â Â Â Â Â Â Â Â Â Â Â Â uart0_xfer: uart0-xfer { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <4 16 RK_FUNC_1 &pcfg_pull_up>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <4 17 RK_FUNC_1 &pcfg_pull_none>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <4 RK_PC0 1 &pcfg_pull_up>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <4 RK_PC1 1 &pcfg_pull_none>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â Â Â Â Â uart0_cts: uart0-cts { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <4 18 RK_FUNC_1 &pcfg_pull_none>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <4 RK_PC2 1 &pcfg_pull_up>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â Â Â Â Â uart0_rts: uart0-rts { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <4 19 RK_FUNC_1 &pcfg_pull_none>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <4 RK_PC3 1 &pcfg_pull_none>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â uart1 { Â Â Â Â Â Â Â Â Â Â Â Â Â uart1_xfer: uart1-xfer { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <5 8 RK_FUNC_1 &pcfg_pull_up>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <5 9 RK_FUNC_1 &pcfg_pull_none>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <5 RK_PB0 1 &pcfg_pull_up>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <5 RK_PB1 1 &pcfg_pull_none>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â Â Â Â Â uart1_cts: uart1-cts { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <5 10 RK_FUNC_1 &pcfg_pull_none>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <5 RK_PB2 1 &pcfg_pull_up>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â Â Â Â Â uart1_rts: uart1-rts { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <5 11 RK_FUNC_1 &pcfg_pull_none>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <5 RK_PB3 1 &pcfg_pull_none>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â uart2 { Â Â Â Â Â Â Â Â Â Â Â Â Â uart2_xfer: uart2-xfer { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <7 22 RK_FUNC_1 &pcfg_pull_up>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <7 23 RK_FUNC_1 &pcfg_pull_none>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <7 RK_PC6 1 &pcfg_pull_up>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <7 RK_PC7 1 &pcfg_pull_none>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â Â Â Â /* no rts / cts for uart2 */ Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â uart3 { Â Â Â Â Â Â Â Â Â Â Â Â Â uart3_xfer: uart3-xfer { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <7 7 RK_FUNC_1 &pcfg_pull_up>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <7 8 RK_FUNC_1 &pcfg_pull_none>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <7 RK_PA7 1 &pcfg_pull_up>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <7 RK_PB0 1 &pcfg_pull_none>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â Â Â Â Â uart3_cts: uart3-cts { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <7 9 RK_FUNC_1 &pcfg_pull_none>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <7 RK_PB1 1 &pcfg_pull_up>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â Â Â Â Â uart3_rts: uart3-rts { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <7 10 RK_FUNC_1 &pcfg_pull_none>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <7 RK_PB2 1 &pcfg_pull_none>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â uart4 { Â Â Â Â Â Â Â Â Â Â Â Â Â uart4_xfer: uart4-xfer { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <5 12 3 &pcfg_pull_up>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <5 13 3 &pcfg_pull_none>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <5 RK_PB7 3 &pcfg_pull_up>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <5 RK_PB6 3 &pcfg_pull_none>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â Â Â Â Â uart4_cts: uart4-cts { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <5 14 3 &pcfg_pull_none>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <5 RK_PB4 3 &pcfg_pull_up>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â Â Â Â Â uart4_rts: uart4-rts { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <5 15 3 &pcfg_pull_none>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <5 RK_PB5 3 &pcfg_pull_none>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â tsadc { +Â Â Â Â Â Â Â Â Â Â Â otp_pin: otp-pin { +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <0 RK_PB2 RK_FUNC_GPIO &pcfg_pull_none>; +Â Â Â Â Â Â Â Â Â Â Â };
otp_out: otp-out { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <0 10 RK_FUNC_1 &pcfg_pull_none>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <0 RK_PB2 1 &pcfg_pull_none>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â pwm0 { Â Â Â Â Â Â Â Â Â Â Â Â Â pwm0_pin: pwm0-pin { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <7 0 RK_FUNC_1 &pcfg_pull_none>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <7 RK_PA0 1 &pcfg_pull_none>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â pwm1 { Â Â Â Â Â Â Â Â Â Â Â Â Â pwm1_pin: pwm1-pin { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <7 1 RK_FUNC_1 &pcfg_pull_none>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <7 RK_PA1 1 &pcfg_pull_none>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â pwm2 { Â Â Â Â Â Â Â Â Â Â Â Â Â pwm2_pin: pwm2-pin { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <7 22 RK_FUNC_3 &pcfg_pull_none>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <7 RK_PC6 3 &pcfg_pull_none>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â pwm3 { Â Â Â Â Â Â Â Â Â Â Â Â Â pwm3_pin: pwm3-pin { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <7 23 RK_FUNC_3 &pcfg_pull_none>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <7 RK_PC7 3 &pcfg_pull_none>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â gmac { Â Â Â Â Â Â Â Â Â Â Â Â Â rgmii_pins: rgmii-pins { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <3 30 3 &pcfg_pull_none>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <3 31 3 &pcfg_pull_none>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <3 26 3 &pcfg_pull_none>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <3 27 3 &pcfg_pull_none>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <3 28 3 &pcfg_pull_none_12ma>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <3 29 3 &pcfg_pull_none_12ma>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <3 24 3 &pcfg_pull_none_12ma>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <3 25 3 &pcfg_pull_none_12ma>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <4 0 3 &pcfg_pull_none>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <4 5 3 &pcfg_pull_none>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <4 6 3 &pcfg_pull_none>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <4 9 3 &pcfg_pull_none_12ma>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <4 4 3 &pcfg_pull_none_12ma>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <4 1 3 &pcfg_pull_none>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <4 3 3 &pcfg_pull_none>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <3 RK_PD6 3 &pcfg_pull_none>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <3 RK_PD7 3 &pcfg_pull_none>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <3 RK_PD2 3 &pcfg_pull_none>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <3 RK_PD3 3 &pcfg_pull_none>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <3 RK_PD4 3 &pcfg_pull_none_12ma>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <3 RK_PD5 3 &pcfg_pull_none_12ma>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <3 RK_PD0 3 &pcfg_pull_none_12ma>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <3 RK_PD1 3 &pcfg_pull_none_12ma>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <4 RK_PA0 3 &pcfg_pull_none>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <4 RK_PA5 3 &pcfg_pull_none>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <4 RK_PA6 3 &pcfg_pull_none>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <4 RK_PB1 3 &pcfg_pull_none_12ma>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <4 RK_PA4 3 &pcfg_pull_none_12ma>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <4 RK_PA1 3 &pcfg_pull_none>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <4 RK_PA3 3 &pcfg_pull_none>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â Â Â Â Â rmii_pins: rmii-pins { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <3 30 3 &pcfg_pull_none>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <3 31 3 &pcfg_pull_none>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <3 28 3 &pcfg_pull_none>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <3 29 3 &pcfg_pull_none>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <4 0 3 &pcfg_pull_none>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <4 5 3 &pcfg_pull_none>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <4 4 3 &pcfg_pull_none>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <4 1 3 &pcfg_pull_none>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <4 2 3 &pcfg_pull_none>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <4 3 3 &pcfg_pull_none>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <3 RK_PD6 3 &pcfg_pull_none>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <3 RK_PD7 3 &pcfg_pull_none>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <3 RK_PD4 3 &pcfg_pull_none>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <3 RK_PD5 3 &pcfg_pull_none>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <4 RK_PA0 3 &pcfg_pull_none>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <4 RK_PA5 3 &pcfg_pull_none>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <4 RK_PA4 3 &pcfg_pull_none>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <4 RK_PA1 3 &pcfg_pull_none>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <4 RK_PA2 3 &pcfg_pull_none>, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <4 RK_PA3 3 &pcfg_pull_none>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â spdif { Â Â Â Â Â Â Â Â Â Â Â Â Â spdif_tx: spdif-tx { -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <RK_GPIO6 11 RK_FUNC_1 &pcfg_pull_none>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â rockchip,pins = <6 RK_PB3 1 &pcfg_pull_none>; Â Â Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â };
-Â Â Â power: power-controller { -Â Â Â Â Â Â Â compatible = "rockchip,rk3288-power-controller"; -Â Â Â Â Â Â Â #power-domain-cells = <1>; -Â Â Â Â Â Â Â rockchip,pmu = <&pmu>; -Â Â Â Â Â Â Â #address-cells = <1>; -Â Â Â Â Â Â Â #size-cells = <0>;
-Â Â Â Â Â Â Â pd_gpu { -Â Â Â Â Â Â Â Â Â Â Â reg = <RK3288_PD_GPU>; -Â Â Â Â Â Â Â Â Â Â Â clocks = <&cru ACLK_GPU>; -Â Â Â Â Â Â Â };
-Â Â Â Â Â Â Â pd_hevc { -Â Â Â Â Â Â Â Â Â Â Â reg = <RK3288_PD_HEVC>; -Â Â Â Â Â Â Â Â Â Â Â clocks = <&cru ACLK_HEVC>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <&cru SCLK_HEVC_CABAC>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <&cru SCLK_HEVC_CORE>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <&cru HCLK_HEVC>; -Â Â Â Â Â Â Â };
-Â Â Â Â Â Â Â pd_vio { -Â Â Â Â Â Â Â Â Â Â Â reg = <RK3288_PD_VIO>; -Â Â Â Â Â Â Â Â Â Â Â clocks = <&cru ACLK_IEP>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <&cru ACLK_ISP>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <&cru ACLK_RGA>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <&cru ACLK_VIP>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <&cru ACLK_VOP0>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <&cru ACLK_VOP1>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <&cru DCLK_VOP0>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <&cru DCLK_VOP1>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <&cru HCLK_IEP>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <&cru HCLK_ISP>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <&cru HCLK_RGA>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <&cru HCLK_VIP>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <&cru HCLK_VOP0>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <&cru HCLK_VOP1>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <&cru PCLK_EDP_CTRL>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <&cru PCLK_HDMI_CTRL>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <&cru PCLK_LVDS_PHY>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <&cru PCLK_MIPI_CSI>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <&cru PCLK_MIPI_DSI0>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <&cru PCLK_MIPI_DSI1>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <&cru SCLK_EDP_24M>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <&cru SCLK_EDP>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <&cru SCLK_HDMI_CEC>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <&cru SCLK_HDMI_HDCP>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <&cru SCLK_ISP_JPE>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <&cru SCLK_ISP>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <&cru SCLK_RGA>; -Â Â Â Â Â Â Â };
-Â Â Â Â Â Â Â pd_video { -Â Â Â Â Â Â Â Â Â Â Â reg = <RK3288_PD_VIDEO>; -Â Â Â Â Â Â Â Â Â Â Â clocks = <&cru ACLK_VCODEC>, -Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <&cru HCLK_VCODEC>; -Â Â Â Â Â Â Â }; -Â Â Â }; Â };
Sync rk3288 DT boards that have support both in Linux 5.17 as in U-boot.
Signed-off-by: Johan Jonker jbx6244@gmail.com ---
Change V3: update change reg size delete more files
Changed V2: update change led labels --- arch/arm/dts/rk3288-firefly-u-boot.dtsi | 4 +- arch/arm/dts/rk3288-firefly.dts | 17 +- arch/arm/dts/rk3288-firefly.dtsi | 161 +++++-- arch/arm/dts/rk3288-miqi-u-boot.dtsi | 2 +- arch/arm/dts/rk3288-miqi.dts | 431 ++++++++++++++++++- arch/arm/dts/rk3288-miqi.dtsi | 418 ------------------ arch/arm/dts/rk3288-phycore-rdk.dts | 109 +++-- arch/arm/dts/rk3288-phycore-som.dtsi | 111 +---- arch/arm/dts/rk3288-popmetal.dts | 505 +++++++++++++++++++++- arch/arm/dts/rk3288-popmetal.dtsi | 545 ------------------------ arch/arm/dts/rk3288-rock2-som.dtsi | 91 ++-- arch/arm/dts/rk3288-rock2-square.dts | 215 +++++++--- arch/arm/dts/rk3288-tinker-s.dts | 9 +- arch/arm/dts/rk3288-tinker.dts | 30 +- arch/arm/dts/rk3288-tinker.dtsi | 405 +++++++++--------- 15 files changed, 1554 insertions(+), 1499 deletions(-) delete mode 100644 arch/arm/dts/rk3288-miqi.dtsi delete mode 100644 arch/arm/dts/rk3288-popmetal.dtsi
diff --git a/arch/arm/dts/rk3288-firefly-u-boot.dtsi b/arch/arm/dts/rk3288-firefly-u-boot.dtsi index cc84d7c4..c43d3281 100644 --- a/arch/arm/dts/rk3288-firefly-u-boot.dtsi +++ b/arch/arm/dts/rk3288-firefly-u-boot.dtsi @@ -14,11 +14,11 @@ leds { u-boot,dm-pre-reloc;
- work { + work_led: led-0 { u-boot,dm-pre-reloc; };
- power { + power_led: led-1 { u-boot,dm-pre-reloc; }; }; diff --git a/arch/arm/dts/rk3288-firefly.dts b/arch/arm/dts/rk3288-firefly.dts index 72982efd..313459da 100644 --- a/arch/arm/dts/rk3288-firefly.dts +++ b/arch/arm/dts/rk3288-firefly.dts @@ -1,4 +1,4 @@ -// SPDX-License-Identifier: GPL-2.0+ OR X11 +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) /* * Copyright (c) 2014, 2015 FUKAUMI Naoki naobsd@gmail.com */ @@ -9,31 +9,22 @@ / { model = "Firefly-RK3288"; compatible = "firefly,firefly-rk3288", "rockchip,rk3288"; - - chosen { - stdout-path = &uart2; - }; };
&ir { - gpios = <&gpio7 0 GPIO_ACTIVE_LOW>; + gpios = <&gpio7 RK_PA0 GPIO_ACTIVE_LOW>; };
&pinctrl { act8846 { pmic_vsel: pmic-vsel { - rockchip,pins = <7 14 RK_FUNC_GPIO &pcfg_output_low>; + rockchip,pins = <7 RK_PB6 RK_FUNC_GPIO &pcfg_output_low>; }; };
ir { ir_int: ir-int { - rockchip,pins = <7 0 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - usb_host { - host_vbus_drv: host-vbus-drv { - rockchip,pins = <0 14 RK_FUNC_GPIO &pcfg_pull_none>; + rockchip,pins = <7 RK_PA0 RK_FUNC_GPIO &pcfg_pull_up>; }; }; }; diff --git a/arch/arm/dts/rk3288-firefly.dtsi b/arch/arm/dts/rk3288-firefly.dtsi index 1117d391..96d768ac 100644 --- a/arch/arm/dts/rk3288-firefly.dtsi +++ b/arch/arm/dts/rk3288-firefly.dtsi @@ -1,15 +1,38 @@ -// SPDX-License-Identifier: GPL-2.0+ OR X11 +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) /* * Copyright (c) 2014, 2015 FUKAUMI Naoki naobsd@gmail.com */
+#include <dt-bindings/input/input.h> #include "rk3288.dtsi"
/ { - memory { + memory@0 { + device_type = "memory"; reg = <0 0x80000000>; };
+ adc-keys { + compatible = "adc-keys"; + io-channels = <&saradc 1>; + io-channel-names = "buttons"; + keyup-threshold-microvolt = <1800000>; + + button-recovery { + label = "Recovery"; + linux,code = <KEY_VENDOR>; + press-threshold-microvolt = <0>; + }; + }; + + dovdd_1v8: dovdd-1v8-regulator { + compatible = "regulator-fixed"; + regulator-name = "dovdd_1v8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + vin-supply = <&vcc28_dvp>; + }; + ext_gmac: external-gmac-clock { compatible = "fixed-clock"; #clock-cells = <0>; @@ -26,11 +49,11 @@ keys: gpio-keys { compatible = "gpio-keys";
- button@0 { - gpio-key,wakeup = <1>; - gpios = <&gpio0 5 GPIO_ACTIVE_LOW>; + power { + wakeup-source; + gpios = <&gpio0 RK_PA5 GPIO_ACTIVE_LOW>; label = "GPIO Power"; - linux,code = <116>; + linux,code = <KEY_POWER>; pinctrl-names = "default"; pinctrl-0 = <&pwr_key>; }; @@ -39,24 +62,24 @@ leds { compatible = "gpio-leds";
- work { - gpios = <&gpio8 1 GPIO_ACTIVE_LOW>; + work_led: led-0 { + gpios = <&gpio8 RK_PA1 GPIO_ACTIVE_LOW>; label = "firefly:blue:user"; linux,default-trigger = "rc-feedback"; pinctrl-names = "default"; - pinctrl-0 = <&work_led>; + pinctrl-0 = <&work_led_pin>; };
- power { - gpios = <&gpio8 2 GPIO_ACTIVE_LOW>; + power_led: led-1 { + gpios = <&gpio8 RK_PA2 GPIO_ACTIVE_LOW>; label = "firefly:green:power"; linux,default-trigger = "default-on"; pinctrl-names = "default"; - pinctrl-0 = <&power_led>; + pinctrl-0 = <&power_led_pin>; }; };
- vcc_sys: vsys-regulator { + vbat_wl: vcc_sys: vsys-regulator { compatible = "regulator-fixed"; regulator-name = "vcc_sys"; regulator-min-microvolt = <5000000>; @@ -67,7 +90,7 @@
vcc_sd: sdmmc-regulator { compatible = "regulator-fixed"; - gpio = <&gpio7 11 GPIO_ACTIVE_LOW>; + gpio = <&gpio7 RK_PB3 GPIO_ACTIVE_LOW>; pinctrl-names = "default"; pinctrl-0 = <&sdmmc_pwr>; regulator-name = "vcc_sd"; @@ -98,7 +121,7 @@ vcc_host_5v: usb-host-regulator { compatible = "regulator-fixed"; enable-active-high; - gpio = <&gpio0 14 GPIO_ACTIVE_HIGH>; + gpio = <&gpio0 RK_PB6 GPIO_ACTIVE_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&host_vbus_drv>; regulator-name = "vcc_host_5v"; @@ -111,7 +134,7 @@ vcc_otg_5v: usb-otg-regulator { compatible = "regulator-fixed"; enable-active-high; - gpio = <&gpio0 12 GPIO_ACTIVE_HIGH>; + gpio = <&gpio0 RK_PB4 GPIO_ACTIVE_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&otg_vbus_drv>; regulator-name = "vcc_otg_5v"; @@ -120,6 +143,23 @@ regulator-always-on; vin-supply = <&vcc_5v>; }; + + /* + * A TT8142 creates both dovdd_1v8 and vcc28_dvp, controlled + * by the dvp_pwr pin. + */ + vcc28_dvp: vcc28-dvp-regulator { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio0 RK_PB3 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&dvp_pwr>; + regulator-name = "vcc28_dvp"; + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; + regulator-always-on; + vin-supply = <&vcc_io>; + }; };
&cpu0 { @@ -127,12 +167,10 @@ };
&emmc { - broken-cd; bus-width = <8>; cap-mmc-highspeed; disable-wp; non-removable; - num-slots = <1>; pinctrl-names = "default"; pinctrl-0 = <&emmc_clk>, <&emmc_cmd>, <&emmc_pwr>, <&emmc_bus8>; vmmc-supply = <&vcc_io>; @@ -150,12 +188,17 @@ phy-mode = "rgmii"; snps,reset-active-low; snps,reset-delays-us = <0 10000 1000000>; - snps,reset-gpio = <&gpio4 8 GPIO_ACTIVE_LOW>; + snps,reset-gpio = <&gpio4 RK_PB0 GPIO_ACTIVE_LOW>; tx_delay = <0x30>; rx_delay = <0x10>; status = "okay"; };
+&gpu { + mali-supply = <&vdd_gpu>; + status = "okay"; +}; + &hdmi { ddc-i2c-bus = <&i2c5>; status = "okay"; @@ -174,6 +217,8 @@ regulator-max-microvolt = <1350000>; regulator-always-on; regulator-boot-on; + regulator-enable-ramp-delay = <300>; + regulator-ramp-delay = <8000>; vin-supply = <&vcc_sys>; };
@@ -195,7 +240,7 @@ clock-frequency = <32768>; clock-output-names = "xin32k"; interrupt-parent = <&gpio7>; - interrupts = <4 IRQ_TYPE_EDGE_FALLING>; + interrupts = <RK_PA4 IRQ_TYPE_EDGE_FALLING>; pinctrl-names = "default"; pinctrl-0 = <&rtc_int>; }; @@ -207,6 +252,14 @@ pinctrl-0 = <&pmic_vsel>, <&pwr_hold>; system-power-controller;
+ vp1-supply = <&vcc_sys>; + vp2-supply = <&vcc_sys>; + vp3-supply = <&vcc_sys>; + vp4-supply = <&vcc_sys>; + inl1-supply = <&vcc_sys>; + inl2-supply = <&vcc_sys>; + inl3-supply = <&vcc_20>; + regulators { vcc_ddr: REG1 { regulator-name = "vcc_ddr"; @@ -275,7 +328,7 @@ regulator-always-on; };
- vcc_18: REG11 { + vccio_wl: vcc_18: REG11 { regulator-name = "vcc_18"; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; @@ -308,6 +361,21 @@ status = "okay"; };
+&io_domains { + status = "okay"; + + audio-supply = <&vcca_33>; + bb-supply = <&vcc_io>; + dvp-supply = <&dovdd_1v8>; + flash0-supply = <&vcc_flash>; + flash1-supply = <&vcc_lan>; + gpio30-supply = <&vcc_io>; + gpio1830-supply = <&vcc_io>; + lcdc-supply = <&vcc_io>; + sdcard-supply = <&vccio_sd>; + wifi-supply = <&vccio_wl>; +}; + &pinctrl { pcfg_output_high: pcfg-output-high { output-high; @@ -324,43 +392,49 @@
act8846 { pwr_hold: pwr-hold { - rockchip,pins = <0 1 RK_FUNC_GPIO &pcfg_output_high>; + rockchip,pins = <0 RK_PA1 RK_FUNC_GPIO &pcfg_output_high>; + }; + }; + + dvp { + dvp_pwr: dvp-pwr { + rockchip,pins = <0 RK_PB3 RK_FUNC_GPIO &pcfg_pull_none>; }; };
gmac { phy_int: phy-int { - rockchip,pins = <0 9 RK_FUNC_GPIO &pcfg_pull_up>; + rockchip,pins = <0 RK_PB1 RK_FUNC_GPIO &pcfg_pull_up>; };
phy_pmeb: phy-pmeb { - rockchip,pins = <0 8 RK_FUNC_GPIO &pcfg_pull_up>; + rockchip,pins = <0 RK_PB0 RK_FUNC_GPIO &pcfg_pull_up>; };
phy_rst: phy-rst { - rockchip,pins = <4 8 RK_FUNC_GPIO &pcfg_output_high>; + rockchip,pins = <4 RK_PB0 RK_FUNC_GPIO &pcfg_output_high>; }; };
hym8563 { rtc_int: rtc-int { - rockchip,pins = <7 4 RK_FUNC_GPIO &pcfg_pull_up>; + rockchip,pins = <7 RK_PA4 RK_FUNC_GPIO &pcfg_pull_up>; }; };
keys { pwr_key: pwr-key { - rockchip,pins = <0 5 RK_FUNC_GPIO &pcfg_pull_up>; + rockchip,pins = <0 RK_PA5 RK_FUNC_GPIO &pcfg_pull_up>; }; };
leds { - power_led: power-led { - rockchip,pins = <8 2 RK_FUNC_GPIO &pcfg_pull_none>; + power_led_pin: power-led-pin { + rockchip,pins = <8 RK_PA2 RK_FUNC_GPIO &pcfg_pull_none>; };
- work_led: work-led { - rockchip,pins = <8 1 RK_FUNC_GPIO &pcfg_pull_none>; + work_led_pin: work-led-pin { + rockchip,pins = <8 RK_PA1 RK_FUNC_GPIO &pcfg_pull_none>; }; };
@@ -391,17 +465,17 @@
usb_host { host_vbus_drv: host-vbus-drv { - rockchip,pins = <0 14 RK_FUNC_GPIO &pcfg_pull_none>; + rockchip,pins = <0 RK_PB6 RK_FUNC_GPIO &pcfg_pull_none>; };
usbhub_rst: usbhub-rst { - rockchip,pins = <8 3 RK_FUNC_GPIO &pcfg_output_high>; + rockchip,pins = <8 RK_PA3 RK_FUNC_GPIO &pcfg_output_high>; }; };
usb_otg { otg_vbus_drv: otg-vbus-drv { - rockchip,pins = <0 12 RK_FUNC_GPIO &pcfg_pull_none>; + rockchip,pins = <0 RK_PB4 RK_FUNC_GPIO &pcfg_pull_none>; }; }; }; @@ -412,15 +486,14 @@ };
&sdio0 { - broken-cd; bus-width = <4>; disable-wp; non-removable; - num-slots = <1>; pinctrl-names = "default"; pinctrl-0 = <&sdio0_bus4>, <&sdio0_cmd>, <&sdio0_clk>; - vmmc-supply = <&vcc_18>; - status = "disabled"; + vmmc-supply = <&vbat_wl>; + vqmmc-supply = <&vccio_wl>; + status = "okay"; };
&sdmmc { @@ -429,10 +502,10 @@ cap-sd-highspeed; card-detect-delay = <200>; disable-wp; - num-slots = <1>; pinctrl-names = "default"; pinctrl-0 = <&sdmmc_clk>, <&sdmmc_cmd>, <&sdmmc_cd>, <&sdmmc_bus4>; vmmc-supply = <&vcc_sd>; + vqmmc-supply = <&vccio_sd>; status = "okay"; };
@@ -442,6 +515,12 @@ status = "okay"; };
+&tsadc { + rockchip,hw-tshut-mode = <0>; + rockchip,hw-tshut-polarity = <0>; + status = "okay"; +}; + &uart0 { pinctrl-names = "default"; pinctrl-0 = <&uart0_xfer>, <&uart0_cts>, <&uart0_rts>; @@ -460,6 +539,10 @@ status = "okay"; };
+&usbphy { + status = "okay"; +}; + &usb_host1 { pinctrl-names = "default"; pinctrl-0 = <&usbhub_rst>; diff --git a/arch/arm/dts/rk3288-miqi-u-boot.dtsi b/arch/arm/dts/rk3288-miqi-u-boot.dtsi index 2a74fdd1..f2611aaa 100644 --- a/arch/arm/dts/rk3288-miqi-u-boot.dtsi +++ b/arch/arm/dts/rk3288-miqi-u-boot.dtsi @@ -8,7 +8,7 @@ leds { u-boot,dm-pre-reloc;
- work { + work_led: led-0 { u-boot,dm-pre-reloc; }; }; diff --git a/arch/arm/dts/rk3288-miqi.dts b/arch/arm/dts/rk3288-miqi.dts index 4a2f249e..713f55e1 100644 --- a/arch/arm/dts/rk3288-miqi.dts +++ b/arch/arm/dts/rk3288-miqi.dts @@ -1,10 +1,11 @@ -// SPDX-License-Identifier: GPL-2.0+ OR X11 +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) /* - * (C) Copyright 2016 Rockchip Electronics Co., Ltd + * Copyright (c) 2016 Heiko Stuebner heiko@sntech.de */
/dts-v1/; -#include "rk3288-miqi.dtsi" +#include <dt-bindings/input/input.h> +#include "rk3288.dtsi"
/ { model = "mqmaker MiQi"; @@ -13,4 +14,428 @@ chosen { stdout-path = "serial2:115200n8"; }; + + memory@0 { + device_type = "memory"; + reg = <0x0 0x0 0x0 0x80000000>; + }; + + ext_gmac: external-gmac-clock { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <125000000>; + clock-output-names = "ext_gmac"; + }; + + leds { + compatible = "gpio-leds"; + + work_led: led-0 { + gpios = <&gpio7 RK_PA2 GPIO_ACTIVE_HIGH>; + label = "miqi:green:user"; + linux,default-trigger = "timer"; + }; + }; + + vcc_flash: flash-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc_flash"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + vin-supply = <&vcc_io>; + }; + + vcc_host: usb-host-regulator { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio0 RK_PB6 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&host_vbus_drv>; + regulator-name = "vcc_host"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-always-on; + vin-supply = <&vcc_sys>; + }; + + vcc_sd: sdmmc-regulator { + compatible = "regulator-fixed"; + gpio = <&gpio7 RK_PB3 GPIO_ACTIVE_LOW>; + pinctrl-names = "default"; + pinctrl-0 = <&sdmmc_pwr>; + regulator-name = "vcc_sd"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + startup-delay-us = <100000>; + vin-supply = <&vcc_io>; + }; + + vcc_sys: vsys-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc_sys"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-always-on; + regulator-boot-on; + }; +}; + +&cpu0 { + cpu-supply = <&vdd_cpu>; +}; + +&cpu1 { + cpu-supply = <&vdd_cpu>; +}; + +&cpu2 { + cpu-supply = <&vdd_cpu>; +}; + +&cpu3 { + cpu-supply = <&vdd_cpu>; +}; + +&emmc { + bus-width = <8>; + cap-mmc-highspeed; + non-removable; + pinctrl-names = "default"; + pinctrl-0 = <&emmc_clk>, <&emmc_cmd>, <&emmc_pwr>, <&emmc_bus8>; + vmmc-supply = <&vcc_io>; + vqmmc-supply = <&vcc_flash>; + status = "okay"; +}; + +&gmac { + assigned-clocks = <&cru SCLK_MAC>; + assigned-clock-parents = <&ext_gmac>; + clock_in_out = "input"; + pinctrl-names = "default"; + pinctrl-0 = <&rgmii_pins>, <&phy_rst>, <&phy_pmeb>, <&phy_int>; + phy-supply = <&vcc_lan>; + phy-mode = "rgmii"; + snps,reset-active-low; + snps,reset-delays-us = <0 10000 1000000>; + snps,reset-gpio = <&gpio4 RK_PB0 GPIO_ACTIVE_LOW>; + tx_delay = <0x30>; + rx_delay = <0x10>; + status = "okay"; +}; + +&gpu { + mali-supply = <&vdd_gpu>; + status = "okay"; +}; + +&hdmi { + ddc-i2c-bus = <&i2c5>; + status = "okay"; +}; + +&i2c0 { + clock-frequency = <400000>; + status = "okay"; + + vdd_cpu: syr827@40 { + compatible = "silergy,syr827"; + fcs,suspend-voltage-selector = <1>; + reg = <0x40>; + regulator-name = "vdd_cpu"; + regulator-min-microvolt = <850000>; + regulator-max-microvolt = <1350000>; + regulator-always-on; + regulator-boot-on; + regulator-enable-ramp-delay = <300>; + regulator-ramp-delay = <8000>; + vin-supply = <&vcc_sys>; + }; + + vdd_gpu: syr828@41 { + compatible = "silergy,syr828"; + fcs,suspend-voltage-selector = <1>; + reg = <0x41>; + regulator-name = "vdd_gpu"; + regulator-min-microvolt = <850000>; + regulator-max-microvolt = <1350000>; + regulator-always-on; + vin-supply = <&vcc_sys>; + }; + + hym8563: hym8563@51 { + compatible = "haoyu,hym8563"; + reg = <0x51>; + #clock-cells = <0>; + clock-frequency = <32768>; + clock-output-names = "xin32k"; + }; + + act8846: act8846@5a { + compatible = "active-semi,act8846"; + reg = <0x5a>; + pinctrl-names = "default"; + pinctrl-0 = <&pmic_vsel>; + system-power-controller; + + vp1-supply = <&vcc_sys>; + vp2-supply = <&vcc_sys>; + vp3-supply = <&vcc_sys>; + vp4-supply = <&vcc_sys>; + inl1-supply = <&vcc_sys>; + inl2-supply = <&vcc_sys>; + inl3-supply = <&vcc_20>; + + regulators { + vcc_ddr: REG1 { + regulator-name = "vcc_ddr"; + regulator-always-on; + }; + + vcc_io: REG2 { + regulator-name = "vcc_io"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + + vdd_log: REG3 { + regulator-name = "vdd_log"; + regulator-min-microvolt = <1100000>; + regulator-max-microvolt = <1100000>; + regulator-always-on; + }; + + vcc_20: REG4 { + regulator-name = "vcc_20"; + regulator-min-microvolt = <2000000>; + regulator-max-microvolt = <2000000>; + regulator-always-on; + }; + + vccio_sd: REG5 { + regulator-name = "vccio_sd"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + + vdd10_lcd: REG6 { + regulator-name = "vdd10_lcd"; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1000000>; + regulator-always-on; + }; + + vcca_18: REG7 { + regulator-name = "vcca_18"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + }; + + vcca_33: REG8 { + regulator-name = "vcca_33"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; + + vcc_lan: REG9 { + regulator-name = "vcc_lan"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; + + vdd_10: REG10 { + regulator-name = "vdd_10"; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1000000>; + regulator-always-on; + }; + + vcc_18: REG11 { + regulator-name = "vcc_18"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + }; + + vcc18_lcd: REG12 { + regulator-name = "vcc18_lcd"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + }; + }; + }; +}; + +&i2c1 { + status = "okay"; +}; + +&i2c2 { + status = "okay"; +}; + +&i2c4 { + status = "okay"; +}; + +&i2c5 { + status = "okay"; +}; + +&io_domains { + status = "okay"; + + audio-supply = <&vcca_33>; + flash0-supply = <&vcc_flash>; + flash1-supply = <&vcc_lan>; + gpio30-supply = <&vcc_io>; + gpio1830-supply = <&vcc_io>; + lcdc-supply = <&vcc_io>; + sdcard-supply = <&vccio_sd>; + wifi-supply = <&vcc_18>; +}; + +&pinctrl { + pcfg_output_high: pcfg-output-high { + output-high; + }; + + pcfg_output_low: pcfg-output-low { + output-low; + }; + + pcfg_pull_up_drv_12ma: pcfg-pull-up-drv-12ma { + bias-pull-up; + drive-strength = <12>; + }; + + act8846 { + pmic_int: pmic-int { + rockchip,pins = <0 RK_PA4 RK_FUNC_GPIO &pcfg_pull_up>; + }; + + pmic_sleep: pmic-sleep { + rockchip,pins = <0 RK_PA0 RK_FUNC_GPIO &pcfg_output_low>; + }; + + pmic_vsel: pmic-vsel { + rockchip,pins = <7 RK_PA1 RK_FUNC_GPIO &pcfg_output_low>; + }; + }; + + gmac { + phy_int: phy-int { + rockchip,pins = <0 RK_PB1 RK_FUNC_GPIO &pcfg_pull_up>; + }; + + phy_pmeb: phy-pmeb { + rockchip,pins = <0 RK_PB0 RK_FUNC_GPIO &pcfg_pull_up>; + }; + + phy_rst: phy-rst { + rockchip,pins = <4 RK_PB0 RK_FUNC_GPIO &pcfg_output_high>; + }; + }; + + sdmmc { + /* + * Default drive strength isn't enough to achieve even + * high-speed mode on firefly board so bump up to 12ma. + */ + sdmmc_bus4: sdmmc-bus4 { + rockchip,pins = <6 RK_PC0 1 &pcfg_pull_up_drv_12ma>, + <6 RK_PC1 1 &pcfg_pull_up_drv_12ma>, + <6 RK_PC2 1 &pcfg_pull_up_drv_12ma>, + <6 RK_PC3 1 &pcfg_pull_up_drv_12ma>; + }; + + sdmmc_clk: sdmmc-clk { + rockchip,pins = <6 RK_PC4 1 &pcfg_pull_none_12ma>; + }; + + sdmmc_cmd: sdmmc-cmd { + rockchip,pins = <6 RK_PC5 1 &pcfg_pull_up_drv_12ma>; + }; + + sdmmc_pwr: sdmmc-pwr { + rockchip,pins = <7 RK_PB3 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + usb_host { + host_vbus_drv: host-vbus-drv { + rockchip,pins = <0 RK_PB6 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; +}; + +&saradc { + vref-supply = <&vcc_18>; + status = "okay"; +}; + +&sdmmc { + bus-width = <4>; + cap-mmc-highspeed; + cap-sd-highspeed; + card-detect-delay = <200>; + disable-wp; + pinctrl-names = "default"; + pinctrl-0 = <&sdmmc_clk>, <&sdmmc_cmd>, <&sdmmc_cd>, <&sdmmc_bus4>; + vmmc-supply = <&vcc_sd>; + vqmmc-supply = <&vccio_sd>; + status = "okay"; +}; + +&tsadc { + rockchip,hw-tshut-mode = <0>; + rockchip,hw-tshut-polarity = <0>; + status = "okay"; +}; + +&uart2 { + status = "okay"; +}; + +&uart3 { + status = "okay"; +}; + +&usbphy { + status = "okay"; +}; + +&usb_host1 { + status = "okay"; +}; + +&usb_otg { + /* + * The otg controller is the only system power source, + * so needs to always stay in device mode. + */ + dr_mode = "peripheral"; + status = "okay"; +}; + +&vopb { + status = "okay"; +}; + +&vopb_mmu { + status = "okay"; +}; + +&vopl { + status = "okay"; +}; + +&vopl_mmu { + status = "okay"; +}; + +&wdt { + status = "okay"; }; diff --git a/arch/arm/dts/rk3288-miqi.dtsi b/arch/arm/dts/rk3288-miqi.dtsi deleted file mode 100644 index b1c286c9..00000000 --- a/arch/arm/dts/rk3288-miqi.dtsi +++ /dev/null @@ -1,418 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ OR X11 -/* - * Copyright (c) 2016 Heiko Stuebner heiko@sntech.de - */ - -#include "rk3288.dtsi" - -/ { - memory { - device_type = "memory"; - reg = <0 0x80000000>; - }; - - ext_gmac: external-gmac-clock { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <125000000>; - clock-output-names = "ext_gmac"; - }; - - leds { - compatible = "gpio-leds"; - - work { - gpios = <&gpio7 4 GPIO_ACTIVE_LOW>; - label = "miqi:green:user"; - linux,default-trigger = "default-on"; - pinctrl-names = "default"; - pinctrl-0 = <&led_ctl>; - }; - }; - - vcc_flash: flash-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc_flash"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - vin-supply = <&vcc_io>; - }; - - vcc_host: usb-host-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio0 14 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&host_vbus_drv>; - regulator-name = "vcc_host"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - regulator-always-on; - vin-supply = <&vcc_sys>; - }; - - vcc_sd: sdmmc-regulator { - compatible = "regulator-fixed"; - gpio = <&gpio7 11 GPIO_ACTIVE_LOW>; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc_pwr>; - regulator-name = "vcc_sd"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - startup-delay-us = <100000>; - vin-supply = <&vcc_io>; - }; - - vcc_sys: vsys-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc_sys"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - regulator-always-on; - regulator-boot-on; - }; -}; - -&cpu0 { - cpu0-supply = <&vdd_cpu>; -}; - -&emmc { - bus-width = <8>; - cap-mmc-highspeed; - disable-wp; - non-removable; - num-slots = <1>; - pinctrl-names = "default"; - pinctrl-0 = <&emmc_clk>, <&emmc_cmd>, <&emmc_pwr>, <&emmc_bus8>; - vmmc-supply = <&vcc_io>; - vqmmc-supply = <&vcc_flash>; - status = "okay"; -}; - -&gmac { - assigned-clocks = <&cru SCLK_MAC>; - assigned-clock-parents = <&ext_gmac>; - clock_in_out = "input"; - pinctrl-names = "default"; - pinctrl-0 = <&rgmii_pins>, <&phy_rst>, <&phy_pmeb>, <&phy_int>; - phy-supply = <&vcc_lan>; - phy-mode = "rgmii"; - snps,reset-active-low; - snps,reset-delays-us = <0 10000 1000000>; - snps,reset-gpio = <&gpio4 8 GPIO_ACTIVE_LOW>; - tx_delay = <0x30>; - rx_delay = <0x10>; - status = "okay"; -}; - -&hdmi { - ddc-i2c-bus = <&i2c5>; - status = "okay"; -}; - -&i2c0 { - clock-frequency = <400000>; - status = "okay"; - - vdd_cpu: syr827@40 { - compatible = "silergy,syr827"; - fcs,suspend-voltage-selector = <1>; - reg = <0x40>; - regulator-name = "vdd_cpu"; - regulator-min-microvolt = <850000>; - regulator-max-microvolt = <1350000>; - regulator-always-on; - regulator-boot-on; - regulator-enable-ramp-delay = <300>; - regulator-ramp-delay = <8000>; - vin-supply = <&vcc_sys>; - }; - - vdd_gpu: syr828@41 { - compatible = "silergy,syr828"; - fcs,suspend-voltage-selector = <1>; - reg = <0x41>; - regulator-name = "vdd_gpu"; - regulator-min-microvolt = <850000>; - regulator-max-microvolt = <1350000>; - regulator-always-on; - vin-supply = <&vcc_sys>; - }; - - hym8563: hym8563@51 { - compatible = "haoyu,hym8563"; - reg = <0x51>; - #clock-cells = <0>; - clock-frequency = <32768>; - clock-output-names = "xin32k"; - }; - - act8846: act8846@5a { - compatible = "active-semi,act8846"; - reg = <0x5a>; - pinctrl-names = "default"; - pinctrl-0 = <&pmic_vsel>; - system-power-controller; - - vp1-supply = <&vcc_sys>; - vp2-supply = <&vcc_sys>; - vp3-supply = <&vcc_sys>; - vp4-supply = <&vcc_sys>; - inl1-supply = <&vcc_sys>; - inl2-supply = <&vcc_sys>; - inl3-supply = <&vcc_20>; - - regulators { - vcc_ddr: REG1 { - regulator-name = "vcc_ddr"; - regulator-always-on; - }; - - vcc_io: REG2 { - regulator-name = "vcc_io"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-always-on; - }; - - vdd_log: REG3 { - regulator-name = "vdd_log"; - regulator-min-microvolt = <1100000>; - regulator-max-microvolt = <1100000>; - regulator-always-on; - }; - - vcc_20: REG4 { - regulator-name = "vcc_20"; - regulator-min-microvolt = <2000000>; - regulator-max-microvolt = <2000000>; - regulator-always-on; - }; - - vccio_sd: REG5 { - regulator-name = "vccio_sd"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-always-on; - }; - - vdd10_lcd: REG6 { - regulator-name = "vdd10_lcd"; - regulator-min-microvolt = <1000000>; - regulator-max-microvolt = <1000000>; - regulator-always-on; - }; - - vcca_18: REG7 { - regulator-name = "vcca_18"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - }; - - vcca_33: REG8 { - regulator-name = "vcca_33"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - }; - - vcc_lan: REG9 { - regulator-name = "vcc_lan"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - }; - - vdd_10: REG10 { - regulator-name = "vdd_10"; - regulator-min-microvolt = <1000000>; - regulator-max-microvolt = <1000000>; - regulator-always-on; - }; - - vcc_18: REG11 { - regulator-name = "vcc_18"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-always-on; - }; - - vcc18_lcd: REG12 { - regulator-name = "vcc18_lcd"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-always-on; - }; - }; - }; -}; - -&i2c1 { - status = "okay"; -}; - -&i2c2 { - status = "okay"; -}; - -&i2c4 { - status = "okay"; -}; - -&i2c5 { - status = "okay"; -}; - -&io_domains { - status = "okay"; - - audio-supply = <&vcca_33>; - flash0-supply = <&vcc_flash>; - flash1-supply = <&vcc_lan>; - gpio30-supply = <&vcc_io>; - gpio1830-supply = <&vcc_io>; - lcdc-supply = <&vcc_io>; - sdcard-supply = <&vccio_sd>; - wifi-supply = <&vcc_18>; -}; - -&pinctrl { - pcfg_output_high: pcfg-output-high { - output-high; - }; - - pcfg_output_low: pcfg-output-low { - output-low; - }; - - pcfg_pull_up_drv_12ma: pcfg-pull-up-drv-12ma { - bias-pull-up; - drive-strength = <12>; - }; - - act8846 { - pmic_int: pmic-int { - rockchip,pins = <0 4 RK_FUNC_GPIO &pcfg_pull_up>; - }; - - pmic_sleep: pmic-sleep { - rockchip,pins = <0 0 RK_FUNC_GPIO &pcfg_output_low>; - }; - - pmic_vsel: pmic-vsel { - rockchip,pins = <7 1 RK_FUNC_GPIO &pcfg_output_low>; - }; - }; - - gmac { - phy_int: phy-int { - rockchip,pins = <0 9 RK_FUNC_GPIO &pcfg_pull_up>; - }; - - phy_pmeb: phy-pmeb { - rockchip,pins = <0 8 RK_FUNC_GPIO &pcfg_pull_up>; - }; - - phy_rst: phy-rst { - rockchip,pins = <4 8 RK_FUNC_GPIO &pcfg_output_high>; - }; - }; - - leds { - led_ctl: led-ctl { - rockchip,pins = <7 4 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - sdmmc { - /* - * Default drive strength isn't enough to achieve even - * high-speed mode on firefly board so bump up to 12ma. - */ - sdmmc_bus4: sdmmc-bus4 { - rockchip,pins = <6 16 RK_FUNC_1 &pcfg_pull_up_drv_12ma>, - <6 17 RK_FUNC_1 &pcfg_pull_up_drv_12ma>, - <6 18 RK_FUNC_1 &pcfg_pull_up_drv_12ma>, - <6 19 RK_FUNC_1 &pcfg_pull_up_drv_12ma>; - }; - - sdmmc_clk: sdmmc-clk { - rockchip,pins = <6 20 RK_FUNC_1 &pcfg_pull_none_12ma>; - }; - - sdmmc_cmd: sdmmc-cmd { - rockchip,pins = <6 21 RK_FUNC_1 &pcfg_pull_up_drv_12ma>; - }; - - sdmmc_pwr: sdmmc-pwr { - rockchip,pins = <7 11 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - usb_host { - host_vbus_drv: host-vbus-drv { - rockchip,pins = <0 14 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; -}; - -&saradc { - vref-supply = <&vcc_18>; - status = "okay"; -}; - -&sdmmc { - bus-width = <4>; - cap-mmc-highspeed; - cap-sd-highspeed; - card-detect-delay = <200>; - disable-wp; - num-slots = <1>; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc_clk>, <&sdmmc_cmd>, <&sdmmc_cd>, <&sdmmc_bus4>; - vmmc-supply = <&vcc_sd>; - vqmmc-supply = <&vccio_sd>; - status = "okay"; -}; - -&tsadc { - rockchip,hw-tshut-mode = <0>; - rockchip,hw-tshut-polarity = <0>; - status = "okay"; -}; - -&uart2 { - status = "okay"; -}; - -&uart3 { - status = "okay"; -}; - -&usbphy { - status = "okay"; -}; - -&usb_host1 { - vbus-supply = <&vcc_host>; - status = "okay"; -}; - -&vopb { - status = "okay"; -}; - -&vopb_mmu { - status = "okay"; -}; - -&vopl { - status = "okay"; -}; - -&vopl_mmu { - status = "okay"; -}; - -&wdt { - status = "okay"; -}; diff --git a/arch/arm/dts/rk3288-phycore-rdk.dts b/arch/arm/dts/rk3288-phycore-rdk.dts index ebea8e67..1e33859d 100644 --- a/arch/arm/dts/rk3288-phycore-rdk.dts +++ b/arch/arm/dts/rk3288-phycore-rdk.dts @@ -1,60 +1,20 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) /* * Device tree file for Phytec PCM-947 carrier board * Copyright (C) 2017 PHYTEC Messtechnik GmbH * Author: Wadim Egorov w.egorov@phytec.de - * - * This file is dual-licensed: you can use it either under the terms - * of the GPL or the X11 license, at your option. Note that this dual - * licensing only applies to this file, and not this project as a - * whole. - * - * a) This file is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This file is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * Or, alternatively, - * - * b) Permission is hereby granted, free of charge, to any person - * obtaining a copy of this software and associated documentation - * files (the "Software"), to deal in the Software without - * restriction, including without limitation the rights to use, - * copy, modify, merge, publish, distribute, sublicense, and/or - * sell copies of the Software, and to permit persons to whom the - * Software is furnished to do so, subject to the following - * conditions: - * - * The above copyright notice and this permission notice shall be - * included in all copies or substantial portions of the Software. - * - * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, - * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES - * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND - * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT - * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, - * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING - * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR - * OTHER DEALINGS IN THE SOFTWARE. */
/dts-v1/;
#include <dt-bindings/input/input.h> +#include <dt-bindings/leds/leds-pca9532.h> #include "rk3288-phycore-som.dtsi"
/ { model = "Phytec RK3288 PCM-947"; compatible = "phytec,rk3288-pcm-947", "phytec,rk3288-phycore-som", "rockchip,rk3288";
- chosen { - stdout-path = &uart2; - }; - user_buttons: user-buttons { compatible = "gpio-keys"; pinctrl-names = "default"; @@ -155,6 +115,36 @@
&i2c4 { status = "okay"; + + /* PCA9533 - 4-bit LED dimmer */ + leddim: leddimmer@62 { + compatible = "nxp,pca9533"; + reg = <0x62>; + + led1 { + label = "red:user1"; + linux,default-trigger = "none"; + type = <PCA9532_TYPE_LED>; + }; + + led2 { + label = "green:user2"; + linux,default-trigger = "none"; + type = <PCA9532_TYPE_LED>; + }; + + led3 { + label = "blue:user3"; + linux,default-trigger = "none"; + type = <PCA9532_TYPE_LED>; + }; + + led4 { + label = "red:user4"; + linux,default-trigger = "none"; + type = <PCA9532_TYPE_LED>; + }; + }; };
&i2c5 { @@ -170,15 +160,15 @@ buttons { user_button_pins: user-button-pins { /* button 1 */ - rockchip,pins = <8 3 RK_FUNC_GPIO &pcfg_pull_up>, + rockchip,pins = <8 RK_PA3 RK_FUNC_GPIO &pcfg_pull_up>, /* button 2 */ - <8 0 RK_FUNC_GPIO &pcfg_pull_up>; + <8 RK_PA0 RK_FUNC_GPIO &pcfg_pull_up>; }; };
rv4162 { i2c_rtc_int: i2c-rtc-int { - rockchip,pins = <5 10 RK_FUNC_GPIO &pcfg_pull_up>; + rockchip,pins = <5 RK_PB2 RK_FUNC_GPIO &pcfg_pull_up>; }; };
@@ -188,44 +178,44 @@ * high-speed mode on pcm-947 board so bump up to 12 mA. */ sdmmc_bus4: sdmmc-bus4 { - rockchip,pins = <6 16 RK_FUNC_1 &pcfg_pull_up_drv_12ma>, - <6 17 RK_FUNC_1 &pcfg_pull_up_drv_12ma>, - <6 18 RK_FUNC_1 &pcfg_pull_up_drv_12ma>, - <6 19 RK_FUNC_1 &pcfg_pull_up_drv_12ma>; + rockchip,pins = <6 RK_PC0 1 &pcfg_pull_up_drv_12ma>, + <6 RK_PC1 1 &pcfg_pull_up_drv_12ma>, + <6 RK_PC2 1 &pcfg_pull_up_drv_12ma>, + <6 RK_PC3 1 &pcfg_pull_up_drv_12ma>; };
sdmmc_clk: sdmmc-clk { - rockchip,pins = <6 20 RK_FUNC_1 &pcfg_pull_none_12ma>; + rockchip,pins = <6 RK_PC4 1 &pcfg_pull_none_12ma>; };
sdmmc_cmd: sdmmc-cmd { - rockchip,pins = <6 21 RK_FUNC_1 &pcfg_pull_up_drv_12ma>; + rockchip,pins = <6 RK_PC5 1 &pcfg_pull_up_drv_12ma>; };
sdmmc_pwr: sdmmc-pwr { - rockchip,pins = <7 11 RK_FUNC_GPIO &pcfg_pull_none>; + rockchip,pins = <7 RK_PB3 RK_FUNC_GPIO &pcfg_pull_none>; }; };
touchscreen { ts_irq_pin: ts-irq-pin { - rockchip,pins = <5 15 RK_FUNC_GPIO &pcfg_pull_none>; + rockchip,pins = <5 RK_PB7 RK_FUNC_GPIO &pcfg_pull_none>; }; };
usb_host { host0_vbus_drv: host0-vbus-drv { - rockchip,pins = <2 13 RK_FUNC_GPIO &pcfg_pull_none>; + rockchip,pins = <2 RK_PB5 RK_FUNC_GPIO &pcfg_pull_none>; };
host1_vbus_drv: host1-vbus-drv { - rockchip,pins = <2 0 RK_FUNC_GPIO &pcfg_pull_none>; + rockchip,pins = <2 RK_PA0 RK_FUNC_GPIO &pcfg_pull_none>; }; };
usb_otg { otg_vbus_drv: otg-vbus-drv { - rockchip,pins = <2 12 RK_FUNC_GPIO &pcfg_pull_none>; + rockchip,pins = <2 RK_PB4 RK_FUNC_GPIO &pcfg_pull_none>; }; }; }; @@ -236,10 +226,13 @@ cap-sd-highspeed; card-detect-delay = <200>; disable-wp; - num-slots = <1>; pinctrl-names = "default"; pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_cd &sdmmc_bus4>; - vmmc-supply = <&vdd_io_sd>; + sd-uhs-sdr12; + sd-uhs-sdr25; + sd-uhs-sdr50; + sd-uhs-sdr104; + vmmc-supply = <&vdd_sd>; vqmmc-supply = <&vdd_io_sd>; status = "okay"; }; diff --git a/arch/arm/dts/rk3288-phycore-som.dtsi b/arch/arm/dts/rk3288-phycore-som.dtsi index 8ac695c8..b4894e9f 100644 --- a/arch/arm/dts/rk3288-phycore-som.dtsi +++ b/arch/arm/dts/rk3288-phycore-som.dtsi @@ -1,45 +1,8 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) /* * Device tree file for Phytec phyCORE-RK3288 SoM * Copyright (C) 2017 PHYTEC Messtechnik GmbH * Author: Wadim Egorov w.egorov@phytec.de - * - * This file is dual-licensed: you can use it either under the terms - * of the GPL or the X11 license, at your option. Note that this dual - * licensing only applies to this file, and not this project as a - * whole. - * - * a) This file is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This file is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * Or, alternatively, - * - * b) Permission is hereby granted, free of charge, to any person - * obtaining a copy of this software and associated documentation - * files (the "Software"), to deal in the Software without - * restriction, including without limitation the rights to use, - * copy, modify, merge, publish, distribute, sublicense, and/or - * sell copies of the Software, and to permit persons to whom the - * Software is furnished to do so, subject to the following - * conditions: - * - * The above copyright notice and this permission notice shall be - * included in all copies or substantial portions of the Software. - * - * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, - * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES - * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND - * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT - * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, - * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING - * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR - * OTHER DEALINGS IN THE SOFTWARE. */
#include <dt-bindings/net/ti-dp83867.h> @@ -61,7 +24,6 @@ aliases { rtc0 = &i2c_rtc; rtc1 = &rk818; - eeprom0 = &i2c_eeprom_id; };
ext_gmac: external-gmac-clock { @@ -74,9 +36,9 @@ leds: user-leds { compatible = "gpio-leds"; pinctrl-names = "default"; - pinctrl-0 = <&user_led>; + pinctrl-0 = <&user_led_pin>;
- user { + user_led: led-0 { label = "green_led"; gpios = <&gpio7 2 GPIO_ACTIVE_HIGH>; linux,default-trigger = "heartbeat"; @@ -111,33 +73,12 @@ }; };
-&cpu0 { - cpu0-supply = <&vdd_cpu>; - operating-points = < - /* KHz uV */ - 1800000 1400000 - 1608000 1350000 - 1512000 1300000 - 1416000 1200000 - 1200000 1100000 - 1008000 1050000 - 816000 1000000 - 696000 950000 - 600000 900000 - 408000 900000 - 312000 900000 - 216000 900000 - 126000 900000 - >; -}; - &emmc { status = "okay"; bus-width = <8>; cap-mmc-highspeed; disable-wp; non-removable; - num-slots = <1>; pinctrl-names = "default"; pinctrl-0 = <&emmc_clk &emmc_cmd &emmc_pwr &emmc_bus8>; vmmc-supply = <&vdd_3v3_io>; @@ -173,6 +114,7 @@ ti,tx-internal-delay = <DP83867_RGMIIDCTL_2_00_NS>; ti,fifo-depth = <DP83867_PHYCR_FIFO_DEPTH_4_B_NIB>; enet-phy-lane-no-swap; + ti,clk-output-sel = <DP83867_CLK_O_SEL_CHN_A_TCLK>; }; }; }; @@ -200,7 +142,6 @@ clock-frequency = <400000>;
rk818: pmic@1c { - status = "okay"; compatible = "rockchip,rk818"; reg = <0x1c>; interrupt-parent = <&gpio0>; @@ -359,11 +300,10 @@ regulator-name = "vdd_io_sd"; regulator-always-on; regulator-boot-on; - regulator-min-microvolt = <3300000>; + regulator-min-microvolt = <1800000>; regulator-max-microvolt = <3300000>; regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3300000>; + regulator-off-in-suspend; }; }; }; @@ -376,13 +316,6 @@ pagesize = <32>; };
- /* M24C32-D Identification page */ - i2c_eeprom_id: eeprom@58 { - compatible = "atmel,24c32"; - reg = <0x58>; - pagesize = <32>; - }; - vdd_cpu: regulator@60 { compatible = "fcs,fan53555"; reg = <0x60>; @@ -409,49 +342,49 @@ * We also have external pulls, so disable the internal ones. */ emmc_clk: emmc-clk { - rockchip,pins = <3 18 RK_FUNC_2 &pcfg_pull_none_12ma>; + rockchip,pins = <3 RK_PC2 2 &pcfg_pull_none_12ma>; };
emmc_cmd: emmc-cmd { - rockchip,pins = <3 16 RK_FUNC_2 &pcfg_pull_none_12ma>; + rockchip,pins = <3 RK_PC0 2 &pcfg_pull_none_12ma>; };
emmc_bus8: emmc-bus8 { - rockchip,pins = <3 0 RK_FUNC_2 &pcfg_pull_none_12ma>, - <3 1 RK_FUNC_2 &pcfg_pull_none_12ma>, - <3 2 RK_FUNC_2 &pcfg_pull_none_12ma>, - <3 3 RK_FUNC_2 &pcfg_pull_none_12ma>, - <3 4 RK_FUNC_2 &pcfg_pull_none_12ma>, - <3 5 RK_FUNC_2 &pcfg_pull_none_12ma>, - <3 6 RK_FUNC_2 &pcfg_pull_none_12ma>, - <3 7 RK_FUNC_2 &pcfg_pull_none_12ma>; + rockchip,pins = <3 RK_PA0 2 &pcfg_pull_none_12ma>, + <3 RK_PA1 2 &pcfg_pull_none_12ma>, + <3 RK_PA2 2 &pcfg_pull_none_12ma>, + <3 RK_PA3 2 &pcfg_pull_none_12ma>, + <3 RK_PA4 2 &pcfg_pull_none_12ma>, + <3 RK_PA5 2 &pcfg_pull_none_12ma>, + <3 RK_PA6 2 &pcfg_pull_none_12ma>, + <3 RK_PA7 2 &pcfg_pull_none_12ma>; }; };
gmac { phy_int: phy-int { - rockchip,pins = <4 2 RK_FUNC_GPIO &pcfg_pull_up>; + rockchip,pins = <4 RK_PA2 RK_FUNC_GPIO &pcfg_pull_up>; };
leds { - user_led: user-led { - rockchip,pins = <7 2 RK_FUNC_GPIO &pcfg_output_high>; + user_led_pin: user-led-pin { + rockchip,pins = <7 RK_PA2 RK_FUNC_GPIO &pcfg_output_high>; }; };
pmic { pmic_int: pmic-int { - rockchip,pins = <RK_GPIO0 4 RK_FUNC_GPIO &pcfg_pull_up>; + rockchip,pins = <0 RK_PA4 RK_FUNC_GPIO &pcfg_pull_up>; };
/* Pin for switching state between sleep and non-sleep state */ pmic_sleep: pmic-sleep { - rockchip,pins = <RK_GPIO0 0 RK_FUNC_GPIO &pcfg_pull_up>; + rockchip,pins = <0 RK_PA0 RK_FUNC_GPIO &pcfg_pull_up>; }; }; }; diff --git a/arch/arm/dts/rk3288-popmetal.dts b/arch/arm/dts/rk3288-popmetal.dts index 736dc51e..8c7376d6 100644 --- a/arch/arm/dts/rk3288-popmetal.dts +++ b/arch/arm/dts/rk3288-popmetal.dts @@ -1,20 +1,513 @@ -// SPDX-License-Identifier: GPL-2.0+ OR X11 +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) /* - * (C) Copyright 2016 Rockchip Electronics Co., Ltd + * Copyright (c) 2014, 2015 Andy Yan andy.yan@rock-chips.com */
/dts-v1/; -#include "rk3288-popmetal.dtsi" +#include <dt-bindings/input/input.h> +#include "rk3288.dtsi"
/ { model = "PopMetal-RK3288"; compatible = "chipspark,popmetal-rk3288", "rockchip,rk3288";
- chosen { - stdout-path = &uart2; + memory@0 { + device_type = "memory"; + reg = <0x0 0x0 0x0 0x80000000>; }; + + ext_gmac: external-gmac-clock { + compatible = "fixed-clock"; + clock-frequency = <125000000>; + clock-output-names = "ext_gmac"; + #clock-cells = <0>; + }; + + gpio-keys { + compatible = "gpio-keys"; + autorepeat; + + pinctrl-names = "default"; + pinctrl-0 = <&pwrbtn>; + + power { + gpios = <&gpio0 RK_PA5 GPIO_ACTIVE_LOW>; + linux,code = <KEY_POWER>; + label = "GPIO Key Power"; + linux,input-type = <1>; + wakeup-source; + debounce-interval = <100>; + }; + }; + + ir: ir-receiver { + compatible = "gpio-ir-receiver"; + gpios = <&gpio0 RK_PA6 GPIO_ACTIVE_LOW>; + pinctrl-names = "default"; + pinctrl-0 = <&ir_int>; + }; + + vcc_flash: flash-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc_flash"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + vin-supply = <&vcc_io>; + }; + + vcc_sd: sdmmc-regulator { + compatible = "regulator-fixed"; + gpio = <&gpio7 RK_PB3 GPIO_ACTIVE_LOW>; + pinctrl-names = "default"; + pinctrl-0 = <&sdmmc_pwr>; + regulator-name = "vcc_sd"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + startup-delay-us = <100000>; + vin-supply = <&vcc_io>; + }; + + vcc_sys: vsys-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc_sys"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-always-on; + regulator-boot-on; + }; + + /* + * A PT5128 creates both dovdd_1v8 and vcc28_dvp, controlled + * by the dvp_pwr pin. + */ + vcc18_dvp: vcc18-dvp-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc18-dvp"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + vin-supply = <&vcc28_dvp>; + }; + + vcc28_dvp: vcc28-dvp-regulator { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio0 RK_PC1 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&dvp_pwr>; + regulator-name = "vcc28_dvp"; + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; + regulator-always-on; + vin-supply = <&vcc_io>; + }; +}; + +&cpu0 { + cpu-supply = <&vdd_cpu>; +}; + +&cpu1 { + cpu-supply = <&vdd_cpu>; +}; + +&cpu2 { + cpu-supply = <&vdd_cpu>; +}; + +&cpu3 { + cpu-supply = <&vdd_cpu>; +}; + +&emmc { + bus-width = <8>; + cap-mmc-highspeed; + mmc-ddr-1_8v; + mmc-hs200-1_8v; + non-removable; + pinctrl-names = "default"; + pinctrl-0 = <&emmc_clk &emmc_cmd &emmc_pwr &emmc_bus8>; + vmmc-supply = <&vcc_io>; + vqmmc-supply = <&vcc_flash>; + status = "okay"; +}; + +&sdmmc { + bus-width = <4>; + cap-mmc-highspeed; + cap-sd-highspeed; + card-detect-delay = <200>; + disable-wp; /* wp not hooked up */ + pinctrl-names = "default"; + pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_cd &sdmmc_bus4>; + sd-uhs-sdr12; + sd-uhs-sdr25; + sd-uhs-sdr50; + sd-uhs-sdr104; + vmmc-supply = <&vcc_sd>; + vqmmc-supply = <&vccio_sd>; + status = "okay"; +}; + +&gmac { + phy-supply = <&vcc_lan>; + phy-mode = "rgmii"; + clock_in_out = "input"; + snps,reset-gpio = <&gpio4 RK_PB0 GPIO_ACTIVE_HIGH>; + snps,reset-active-low; + snps,reset-delays-us = <0 10000 1000000>; + assigned-clocks = <&cru SCLK_MAC>; + assigned-clock-parents = <&ext_gmac>; + pinctrl-names = "default"; + pinctrl-0 = <&rgmii_pins>; + tx_delay = <0x30>; + rx_delay = <0x10>; + status = "okay"; +}; + +&hdmi { + ddc-i2c-bus = <&i2c5>; + status = "okay"; +}; + +&i2c0 { + status = "okay"; + clock-frequency = <400000>; + + rk808: pmic@1b { + compatible = "rockchip,rk808"; + reg = <0x1b>; + interrupt-parent = <&gpio0>; + interrupts = <RK_PA4 IRQ_TYPE_LEVEL_LOW>; + pinctrl-names = "default"; + pinctrl-0 = <&pmic_int &global_pwroff>; + rockchip,system-power-controller; + wakeup-source; + #clock-cells = <1>; + clock-output-names = "xin32k", "rk808-clkout2"; + + vcc1-supply = <&vcc_sys>; + vcc2-supply = <&vcc_sys>; + vcc3-supply = <&vcc_sys>; + vcc4-supply = <&vcc_sys>; + vcc6-supply = <&vcc_sys>; + vcc7-supply = <&vcc_sys>; + vcc8-supply = <&vcc_18>; + vcc9-supply = <&vcc_io>; + vcc10-supply = <&vcc_io>; + vcc11-supply = <&vcc_sys>; + vcc12-supply = <&vcc_io>; + vddio-supply = <&vcc_io>; + + regulators { + vdd_cpu: DCDC_REG1 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <750000>; + regulator-max-microvolt = <1350000>; + regulator-name = "vdd_arm"; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_gpu: DCDC_REG2 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <850000>; + regulator-max-microvolt = <1250000>; + regulator-name = "vdd_gpu"; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1000000>; + }; + }; + + vcc_ddr: DCDC_REG3 { + regulator-always-on; + regulator-boot-on; + regulator-name = "vcc_ddr"; + regulator-state-mem { + regulator-on-in-suspend; + }; + }; + + vcc_io: DCDC_REG4 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc_io"; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3300000>; + }; + }; + + vcc_lan: LDO_REG1 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc_lan"; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3300000>; + }; + }; + + vccio_sd: LDO_REG2 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vccio_sd"; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_10: LDO_REG3 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1000000>; + regulator-name = "vdd_10"; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1000000>; + }; + }; + + vcc18_lcd: LDO_REG4 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vcc18_lcd"; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + ldo5: LDO_REG5 { + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-name = "ldo5"; + }; + + vdd10_lcd: LDO_REG6 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1000000>; + regulator-name = "vdd10_lcd"; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1000000>; + }; + }; + + vcc_18: LDO_REG7 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vcc_18"; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vcca_33: LDO_REG8 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcca_33"; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3300000>; + }; + }; + + vccio_wl: SWITCH_REG1 { + regulator-always-on; + regulator-boot-on; + regulator-name = "vccio_wl"; + regulator-state-mem { + regulator-on-in-suspend; + }; + }; + + vcc_lcd: SWITCH_REG2 { + regulator-always-on; + regulator-boot-on; + regulator-name = "vcc_lcd"; + regulator-state-mem { + regulator-on-in-suspend; + }; + }; + }; + }; +}; + +&i2c1 { + status = "okay"; + clock-frequency = <400000>; + + ak8963: ak8963@d { + compatible = "asahi-kasei,ak8975"; + reg = <0x0d>; + interrupt-parent = <&gpio8>; + interrupts = <RK_PA1 IRQ_TYPE_EDGE_RISING>; + pinctrl-names = "default"; + pinctrl-0 = <&comp_int>; + vdd-supply = <&vcc_io>; + vid-supply = <&vcc_io>; + }; + + l3g4200d: l3g4200d@69 { + compatible = "st,l3g4200d-gyro"; + st,drdy-int-pin = <2>; + reg = <0x69>; + vdd-supply = <&vcc_io>; + vddio-supply = <&vcc_io>; + }; + + mma8452: mma8452@1d { + compatible = "fsl,mma8452"; + reg = <0x1d>; + interrupt-parent = <&gpio8>; + interrupts = <RK_PA0 IRQ_TYPE_EDGE_RISING>; + pinctrl-names = "default"; + pinctrl-0 = <&gsensor_int>; + }; +}; + +&i2c2 { + status = "okay"; +}; + +&i2c3 { + status = "okay"; +}; + +&i2c4 { + status = "okay"; +}; + +&i2c5 { + status = "okay"; +}; + +&io_domains { + status = "okay"; + + audio-supply = <&vcca_33>; + bb-supply = <&vcc_io>; + dvp-supply = <&vcc18_dvp>; + flash0-supply = <&vcc_flash>; + flash1-supply = <&vcc_lan>; + gpio30-supply = <&vcc_io>; + gpio1830-supply = <&vcc_io>; + lcdc-supply = <&vcc_io>; + sdcard-supply = <&vccio_sd>; + wifi-supply = <&vccio_wl>; +}; + +&pinctrl { + ak8963 { + comp_int: comp-int { + rockchip,pins = <8 RK_PA1 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + buttons { + pwrbtn: pwrbtn { + rockchip,pins = <0 RK_PA5 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + dvp { + dvp_pwr: dvp-pwr { + rockchip,pins = <0 RK_PC1 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + ir { + ir_int: ir-int { + rockchip,pins = <0 RK_PA6 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + mma8452 { + gsensor_int: gsensor-int { + rockchip,pins = <8 RK_PA0 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + pmic { + pmic_int: pmic-int { + rockchip,pins = <0 RK_PA4 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + sdmmc { + sdmmc_pwr: sdmmc-pwr { + rockchip,pins = <7 RK_PB3 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; +}; + +&tsadc { + rockchip,hw-tshut-mode = <0>; + rockchip,hw-tshut-polarity = <0>; + status = "okay"; +}; + +&vopb { + status = "okay"; +}; + +&vopb_mmu { + status = "okay"; +}; + +&vopl { + status = "okay"; +}; + +&vopl_mmu { + status = "okay"; +}; + +&uart0 { + status = "okay"; +}; + +&uart1 { + status = "okay"; +}; + +&uart2 { + status = "okay"; +}; + +&uart3 { + status = "okay"; +}; + +&uart4 { + status = "okay"; +}; + +&usbphy { + status = "okay"; };
-&pwm1 { +&usb_otg { status = "okay"; }; diff --git a/arch/arm/dts/rk3288-popmetal.dtsi b/arch/arm/dts/rk3288-popmetal.dtsi deleted file mode 100644 index bcd8fded..00000000 --- a/arch/arm/dts/rk3288-popmetal.dtsi +++ /dev/null @@ -1,545 +0,0 @@ -/* - * This file is dual-licensed: you can use it either under the terms - * of the GPL or the X11 license, at your option. Note that this dual - * licensing only applies to this file, and not this project as a - * whole. - * - * a) This file is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This file is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * Or, alternatively, - * - * b) Permission is hereby granted, free of charge, to any person - * obtaining a copy of this software and associated documentation - * files (the "Software"), to deal in the Software without - * restriction, including without limitation the rights to use, - * copy, modify, merge, publish, distribute, sublicense, and/or - * sell copies of the Software, and to permit persons to whom the - * Software is furnished to do so, subject to the following - * conditions: - * - * The above copyright notice and this permission notice shall be - * included in all copies or substantial portions of the Software. - * - * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, - * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES - * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND - * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT - * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, - * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING - * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR - * OTHER DEALINGS IN THE SOFTWARE. - */ - -#include "rk3288.dtsi" - -/ { - memory{ - device_type = "memory"; - reg = <0 0x80000000>; - }; - - ext_gmac: external-gmac-clock { - compatible = "fixed-clock"; - clock-frequency = <125000000>; - clock-output-names = "ext_gmac"; - #clock-cells = <0>; - }; - - gpio-keys { - compatible = "gpio-keys"; - autorepeat; - - pinctrl-names = "default"; - pinctrl-0 = <&pwrbtn>; - - power { - gpios = <&gpio0 5 GPIO_ACTIVE_LOW>; - label = "GPIO Key Power"; - linux,input-type = <1>; - wakeup-source; - debounce-interval = <100>; - }; - }; - - ir: ir-receiver { - compatible = "gpio-ir-receiver"; - gpios = <&gpio0 6 GPIO_ACTIVE_LOW>; - pinctrl-names = "default"; - pinctrl-0 = <&ir_int>; - }; - - vcc_flash: flash-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc_flash"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - vin-supply = <&vcc_io>; - }; - - vcc_sd: sdmmc-regulator { - compatible = "regulator-fixed"; - gpio = <&gpio7 11 GPIO_ACTIVE_LOW>; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc_pwr>; - regulator-name = "vcc_sd"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - startup-delay-us = <100000>; - vin-supply = <&vcc_io>; - }; - - vcc_sys: vsys-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc_sys"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - regulator-always-on; - regulator-boot-on; - }; - - /* - * A PT5128 creates both dovdd_1v8 and vcc28_dvp, controlled - * by the dvp_pwr pin. - */ - vcc18_dvp: vcc18-dvp-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc18-dvp"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - vin-supply = <&vcc28_dvp>; - }; - - vcc28_dvp: vcc28-dvp-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio0 17 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&dvp_pwr>; - regulator-name = "vcc28_dvp"; - regulator-min-microvolt = <2800000>; - regulator-max-microvolt = <2800000>; - regulator-always-on; - vin-supply = <&vcc_io>; - }; - - vcc5v0_host: usb-host-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio0 14 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&host_vbus_drv>; - regulator-name = "vcc5v0_host"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - regulator-always-on; - }; -}; - -&cpu0 { - cpu0-supply = <&vdd_cpu>; -}; - -&emmc { - bus-width = <8>; - cap-mmc-highspeed; - disable-wp; - non-removable; - num-slots = <1>; - pinctrl-names = "default"; - pinctrl-0 = <&emmc_clk &emmc_cmd &emmc_pwr &emmc_bus8>; - vmmc-supply = <&vcc_io>; - vqmmc-supply = <&vcc_flash>; - status = "okay"; -}; - -&sdmmc { - bus-width = <4>; - cap-mmc-highspeed; - cap-sd-highspeed; - card-detect-delay = <200>; - disable-wp; - num-slots = <1>; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_cd &sdmmc_bus4>; - vmmc-supply = <&vcc_sd>; - vqmmc-supply = <&vccio_sd>; - status = "okay"; -}; - -&gmac { - phy-supply = <&vcc_lan>; - phy-mode = "rgmii"; - clock_in_out = "input"; - snps,reset-gpio = <&gpio4 7 0>; - snps,reset-active-low; - snps,reset-delays-us = <0 10000 1000000>; - assigned-clocks = <&cru SCLK_MAC>; - assigned-clock-parents = <&ext_gmac>; - pinctrl-names = "default"; - pinctrl-0 = <&rgmii_pins>; - tx_delay = <0x30>; - rx_delay = <0x10>; - status = "okay"; -}; - -&hdmi { - ddc-i2c-bus = <&i2c5>; - status = "okay"; -}; - -&i2c0 { - status = "okay"; - clock-frequency = <400000>; - - rk808: pmic@1b { - compatible = "rockchip,rk808"; - reg = <0x1b>; - interrupt-parent = <&gpio0>; - interrupts = <4 IRQ_TYPE_LEVEL_LOW>; - pinctrl-names = "default"; - pinctrl-0 = <&pmic_int &global_pwroff>; - rockchip,system-power-controller; - wakeup-source; - #clock-cells = <1>; - clock-output-names = "xin32k", "rk808-clkout2"; - - vcc1-supply = <&vcc_sys>; - vcc2-supply = <&vcc_sys>; - vcc3-supply = <&vcc_sys>; - vcc4-supply = <&vcc_sys>; - vcc6-supply = <&vcc_sys>; - vcc7-supply = <&vcc_sys>; - vcc8-supply = <&vcc_18>; - vcc9-supply = <&vcc_io>; - vcc10-supply = <&vcc_io>; - vcc11-supply = <&vcc_sys>; - vcc12-supply = <&vcc_io>; - vddio-supply = <&vcc_io>; - - regulators { - vdd_cpu: DCDC_REG1 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <750000>; - regulator-max-microvolt = <1350000>; - regulator-name = "vdd_arm"; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdd_gpu: DCDC_REG2 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <850000>; - regulator-max-microvolt = <1250000>; - regulator-name = "vdd_gpu"; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1000000>; - }; - }; - - vcc_ddr: DCDC_REG3 { - regulator-always-on; - regulator-boot-on; - regulator-name = "vcc_ddr"; - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - - vcc_io: DCDC_REG4 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-name = "vcc_io"; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3300000>; - }; - }; - - vcc_lan: LDO_REG1 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-name = "vcc_lan"; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3300000>; - }; - }; - - vccio_sd: LDO_REG2 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-name = "vccio_sd"; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdd_10: LDO_REG3 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1000000>; - regulator-max-microvolt = <1000000>; - regulator-name = "vdd_10"; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1000000>; - }; - }; - - vcc18_lcd: LDO_REG4 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-name = "vcc18_lcd"; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - ldo5: LDO_REG5 { - regulator-always-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - regulator-name = "ldo5"; - }; - - vdd10_lcd: LDO_REG6 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1000000>; - regulator-max-microvolt = <1000000>; - regulator-name = "vdd10_lcd"; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1000000>; - }; - }; - - vcc_18: LDO_REG7 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-name = "vcc_18"; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vcca_33: LDO_REG8 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-name = "vcca_33"; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3300000>; - }; - }; - - vccio_wl: SWITCH_REG1 { - regulator-always-on; - regulator-boot-on; - regulator-name = "vccio_wl"; - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - - vcc_lcd: SWITCH_REG2 { - regulator-always-on; - regulator-boot-on; - regulator-name = "vcc_lcd"; - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - }; - }; -}; - -&i2c1 { - status = "okay"; - clock-frequency = <400000>; - - ak8963: ak8963@0d { - compatible = "asahi-kasei,ak8975"; - reg = <0x0d>; - interrupt-parent = <&gpio8>; - interrupts = <1 IRQ_TYPE_EDGE_RISING>; - pinctrl-names = "default"; - pinctrl-0 = <&comp_int>; - }; - - l3g4200d: l3g4200d@68 { - compatible = "st,l3g4200d-gyro"; - st,drdy-int-pin = <2>; - reg = <0x6b>; - }; - - mma8452: mma8452@1d { - compatible = "fsl,mma8452"; - reg = <0x1d>; - interrupt-parent = <&gpio8>; - interrupts = <0 IRQ_TYPE_EDGE_RISING>; - pinctrl-names = "default"; - pinctrl-0 = <&gsensor_int>; - }; -}; - -&i2c2 { - status = "okay"; -}; - -&i2c3 { - status = "okay"; -}; - -&i2c4 { - status = "okay"; -}; - -&i2c5 { - status = "okay"; -}; - -&io_domains { - status = "okay"; - audio-supply = <&vcca_33>; - bb-supply = <&vcc_io>; - dvp-supply = <&vcc18_dvp>; - flash0-supply = <&vcc_flash>; - flash1-supply = <&vcc_lan>; - gpio30-supply = <&vcc_io>; - gpio1830-supply = <&vcc_io>; - lcdc-supply = <&vcc_io>; - sdcard-supply = <&vccio_sd>; - wifi-supply = <&vccio_wl>; -}; - -&pinctrl { - ak8963 { - comp_int: comp-int { - rockchip,pins = <8 1 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - buttons { - pwrbtn: pwrbtn { - rockchip,pins = <0 5 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - dvp { - dvp_pwr: dvp-pwr { - rockchip,pins = <0 17 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - ir { - ir_int: ir-int { - rockchip,pins = <0 6 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - mma8452 { - gsensor_int: gsensor-int { - rockchip,pins = <8 0 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - pmic { - pmic_int: pmic-int { - rockchip,pins = <RK_GPIO0 4 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - sdmmc { - sdmmc_pwr: sdmmc-pwr { - rockchip,pins = <7 11 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - usb_host { - host_vbus_drv: host-vbus-drv { - rockchip,pins = <0 14 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; -}; - -&saradc { - status = "okay"; -}; - -&tsadc { - rockchip,hw-tshut-mode = <0>; - rockchip,hw-tshut-polarity = <0>; - status = "okay"; -}; - -&vopb { - status = "okay"; -}; - -&vopb_mmu { - status = "okay"; -}; - -&vopl { - status = "okay"; -}; - -&vopl_mmu { - status = "okay"; -}; - -&uart0 { - status = "okay"; -}; - -&uart1 { - status = "okay"; -}; - -&uart2 { - status = "okay"; -}; - -&uart3 { - status = "okay"; -}; - -&uart4 { - status = "okay"; -}; - -&usb_host1 { - vbus-supply = <&vcc5v0_host>; - status = "okay"; -}; - -&usbphy { - status = "okay"; -}; diff --git a/arch/arm/dts/rk3288-rock2-som.dtsi b/arch/arm/dts/rk3288-rock2-som.dtsi index 1ece66f3..61698d3f 100644 --- a/arch/arm/dts/rk3288-rock2-som.dtsi +++ b/arch/arm/dts/rk3288-rock2-som.dtsi @@ -1,48 +1,10 @@ -/* - * This file is dual-licensed: you can use it either under the terms - * of the GPL or the X11 license, at your option. Note that this dual - * licensing only applies to this file, and not this project as a - * whole. - * - * a) This file is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This file is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * Or, alternatively, - * - * b) Permission is hereby granted, free of charge, to any person - * obtaining a copy of this software and associated documentation - * files (the "Software"), to deal in the Software without - * restriction, including without limitation the rights to use, - * copy, modify, merge, publish, distribute, sublicense, and/or - * sell copies of the Software, and to permit persons to whom the - * Software is furnished to do so, subject to the following - * conditions: - * - * The above copyright notice and this permission notice shall be - * included in all copies or substantial portions of the Software. - * - * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, - * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES - * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND - * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT - * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, - * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING - * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR - * OTHER DEALINGS IN THE SOFTWARE. - */ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT)
#include <dt-bindings/pwm/pwm.h> #include "rk3288.dtsi"
/ { - memory { + memory@0 { reg = <0x0 0x80000000>; device_type = "memory"; }; @@ -51,7 +13,7 @@ compatible = "mmc-pwrseq-emmc"; pinctrl-0 = <&emmc_reset>; pinctrl-names = "default"; - reset-gpios = <&gpio3 9 GPIO_ACTIVE_LOW>; + reset-gpios = <&gpio3 RK_PB1 GPIO_ACTIVE_LOW>; };
ext_gmac: external-gmac-clock { @@ -61,6 +23,15 @@ clock-output-names = "ext_gmac"; };
+ vcc_flash: flash-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc_flash"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + startup-delay-us = <150>; + vin-supply = <&vcc_io>; + }; + vcc_sys: vsys-regulator { compatible = "regulator-fixed"; regulator-name = "vcc_sys"; @@ -80,11 +51,11 @@ cap-mmc-highspeed; disable-wp; non-removable; - num-slots = <1>; mmc-pwrseq = <&emmc_pwrseq>; pinctrl-names = "default"; pinctrl-0 = <&emmc_clk &emmc_cmd &emmc_bus8>; vmmc-supply = <&vcc_io>; + vqmmc-supply = <&vcc_flash>; status = "okay"; };
@@ -96,13 +67,18 @@ phy-supply = <&vccio_pmu>; pinctrl-names = "default"; pinctrl-0 = <&rgmii_pins &phy_rst>; - snps,reset-gpio = <&gpio4 8 GPIO_ACTIVE_LOW>; + snps,reset-gpio = <&gpio4 RK_PB0 GPIO_ACTIVE_LOW>; snps,reset-active-low; snps,reset-delays-us = <0 10000 30000>; rx_delay = <0x10>; tx_delay = <0x30>; };
+&gpu { + mali-supply = <&vdd_gpu>; + status = "okay"; +}; + &i2c0 { status = "okay";
@@ -126,7 +102,7 @@ regulator-always-on; };
- vcc_io: REG2 { + vcc_io: vccio_codec: REG2 { regulator-name = "VCC_IO"; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; @@ -233,24 +209,43 @@ }; };
+&io_domains { + status = "okay"; + + audio-supply = <&vcc_io>; + bb-supply = <&vcc_io>; + dvp-supply = <&vcc_18>; + flash0-supply = <&vcc_flash>; + flash1-supply = <&vccio_pmu>; + gpio30-supply = <&vccio_pmu>; + gpio1830-supply = <&vcc_io>; + lcdc-supply = <&vcc_io>; + sdcard-supply = <&vccio_sd>; + wifi-supply = <&vcc_18>; +}; + &pinctrl { pcfg_output_high: pcfg-output-high { output-high; };
emmc { - emmc_reset: emmc-reset { - rockchip,pins = <3 9 RK_FUNC_GPIO &pcfg_pull_none>; - }; + emmc_reset: emmc-reset { + rockchip,pins = <3 RK_PB1 RK_FUNC_GPIO &pcfg_pull_none>; + }; };
gmac { phy_rst: phy-rst { - rockchip,pins = <4 8 RK_FUNC_GPIO &pcfg_output_high>; + rockchip,pins = <4 RK_PB0 RK_FUNC_GPIO &pcfg_output_high>; }; }; };
+&saradc { + vref-supply = <&vcc_18>; +}; + &tsadc { rockchip,hw-tshut-mode = <0>; /* tshut mode 0:CRU 1:GPIO */ rockchip,hw-tshut-polarity = <0>; /* tshut polarity 0:LOW 1:HIGH */ diff --git a/arch/arm/dts/rk3288-rock2-square.dts b/arch/arm/dts/rk3288-rock2-square.dts index 41676696..c4d1d142 100644 --- a/arch/arm/dts/rk3288-rock2-square.dts +++ b/arch/arm/dts/rk3288-rock2-square.dts @@ -1,44 +1,7 @@ -/* - * This file is dual-licensed: you can use it either under the terms - * of the GPL or the X11 license, at your option. Note that this dual - * licensing only applies to this file, and not this project as a - * whole. - * - * a) This file is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This file is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * Or, alternatively, - * - * b) Permission is hereby granted, free of charge, to any person - * obtaining a copy of this software and associated documentation - * files (the "Software"), to deal in the Software without - * restriction, including without limitation the rights to use, - * copy, modify, merge, publish, distribute, sublicense, and/or - * sell copies of the Software, and to permit persons to whom the - * Software is furnished to do so, subject to the following - * conditions: - * - * The above copyright notice and this permission notice shall be - * included in all copies or substantial portions of the Software. - * - * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, - * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES - * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND - * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT - * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, - * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING - * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR - * OTHER DEALINGS IN THE SOFTWARE. - */ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT)
/dts-v1/; +#include <dt-bindings/input/input.h> #include "rk3288-rock2-som.dtsi"
/ { @@ -49,9 +12,51 @@ stdout-path = "serial2:115200n8"; };
+ adc-keys { + compatible = "adc-keys"; + io-channels = <&saradc 1>; + io-channel-names = "buttons"; + keyup-threshold-microvolt = <1800000>; + + button-recovery { + label = "Recovery"; + linux,code = <KEY_VENDOR>; + press-threshold-microvolt = <0>; + }; + }; + + gpio-keys { + compatible = "gpio-keys"; + + power { + gpios = <&gpio0 RK_PA5 GPIO_ACTIVE_LOW>; + label = "GPIO Power"; + linux,code = <KEY_POWER>; + pinctrl-names = "default"; + pinctrl-0 = <&pwr_key>; + wakeup-source; + }; + }; + + gpio-leds { + compatible = "gpio-leds"; + + heartbeat_led: led-0 { + gpios = <&gpio7 RK_PB7 GPIO_ACTIVE_LOW>; + label = "rock2:green:state1"; + linux,default-trigger = "heartbeat"; + }; + + mmc_led: led-1 { + gpios = <&gpio0 RK_PB3 GPIO_ACTIVE_LOW>; + label = "rock2:blue:state2"; + linux,default-trigger = "mmc0"; + }; + }; + ir: ir-receiver { compatible = "gpio-ir-receiver"; - gpios = <&gpio8 1 GPIO_ACTIVE_LOW>; + gpios = <&gpio8 RK_PA1 GPIO_ACTIVE_LOW>; pinctrl-names = "default"; pinctrl-0 = <&ir_int>; }; @@ -65,27 +70,56 @@ }; };
+ sata_pwr: sata-prw-regulator { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio0 13 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&sata_pwr_en>; + /* Always turn on the 5V sata power connector */ + regulator-always-on; + regulator-name = "sata_pwr"; + }; + spdif_out: spdif-out { compatible = "linux,spdif-dit"; #sound-dai-cells = <0>; };
+ sound-i2s { + compatible = "rockchip,rk3288-hdmi-analog"; + pinctrl-names = "default"; + pinctrl-0 = <&phone_ctl>, <&hp_det>; + rockchip,audio-codec = <&es8388>; + rockchip,hp-det-gpios = <&gpio7 7 GPIO_ACTIVE_HIGH>; + rockchip,hp-en-gpios = <&gpio8 0 GPIO_ACTIVE_HIGH>; + rockchip,i2s-controller = <&i2s>; + rockchip,model = "I2S"; + rockchip,routing = "Analog", "LOUT2", + "Analog", "ROUT2"; + }; + + sdio_pwrseq: sdio-pwrseq { + compatible = "mmc-pwrseq-simple"; + clocks = <&hym8563>; + clock-names = "ext_clock"; + pinctrl-names = "default"; + pinctrl-0 = <&wifi_enable>; + reset-gpios = <&gpio4 RK_PD4 GPIO_ACTIVE_LOW>; + }; + vcc_usb_host: vcc-host-regulator { compatible = "regulator-fixed"; enable-active-high; - gpio = <&gpio0 14 GPIO_ACTIVE_HIGH>; + gpio = <&gpio0 RK_PB6 GPIO_ACTIVE_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&host_vbus_drv>; - /* Always on as the rockchip usb phy doesn't have a vbus-supply - * property - */ - regulator-always-on; regulator-name = "vcc_host"; };
vcc_sd: sdmmc-regulator { compatible = "regulator-fixed"; - gpio = <&gpio7 11 GPIO_ACTIVE_LOW>; + gpio = <&gpio7 RK_PB3 GPIO_ACTIVE_LOW>; pinctrl-names = "default"; pinctrl-0 = <&sdmmc_pwr>; regulator-name = "vcc_sd"; @@ -95,13 +129,25 @@ }; };
+&sdio0 { + bus-width = <4>; + cap-sd-highspeed; + cap-sdio-irq; + mmc-pwrseq = <&sdio_pwrseq>; + non-removable; + pinctrl-names = "default"; + pinctrl-0 = <&sdio0_bus4 &sdio0_cmd &sdio0_clk &sdio0_int>; + vmmc-supply = <&vcc_io>; + vqmmc-supply = <&vcc_18>; + status = "okay"; +}; + &sdmmc { bus-width = <4>; cap-mmc-highspeed; cap-sd-highspeed; card-detect-delay = <200>; disable-wp; /* wp not hooked up */ - num-slots = <1>; pinctrl-names = "default"; pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_cd &sdmmc_bus4>; vmmc-supply = <&vcc_sd>; @@ -119,63 +165,124 @@ };
&i2c0 { - hym8563@51 { + hym8563: hym8563@51 { compatible = "haoyu,hym8563"; reg = <0x51>; #clock-cells = <0>; clock-frequency = <32768>; clock-output-names = "xin32k"; interrupt-parent = <&gpio0>; - interrupts = <4 IRQ_TYPE_EDGE_FALLING>; + interrupts = <RK_PA4 IRQ_TYPE_EDGE_FALLING>; pinctrl-names = "default"; pinctrl-0 = <&pmic_int>;
+&i2c2 { + status = "okay"; + + es8388: es8388@10 { + compatible = "everest,es8388", "everest,es8328"; + reg = <0x10>; + AVDD-supply = <&vccio_codec>; + DVDD-supply = <&vccio_codec>; + HPVDD-supply = <&vccio_codec>; + PVDD-supply = <&vccio_codec>; + clocks = <&cru SCLK_I2S0_OUT>; + }; +}; + &i2c5 { status = "okay"; };
+&i2s { + status = "okay"; +}; + &pinctrl { ir { ir_int: ir-int { - rockchip,pins = <8 1 RK_FUNC_GPIO &pcfg_pull_up>; + rockchip,pins = <8 RK_PA1 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + keys { + pwr_key: pwr-key { + rockchip,pins = <0 RK_PA5 RK_FUNC_GPIO &pcfg_pull_up>; }; };
pmic { pmic_int: pmic-int { - rockchip,pins = <0 4 RK_FUNC_GPIO &pcfg_pull_up>; + rockchip,pins = <0 RK_PA4 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + headphone { + hp_det: hp-det { + rockchip,pins = <7 RK_PA7 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + phone_ctl: phone-ctl { + rockchip,pins = <8 RK_PA0 RK_FUNC_GPIO &pcfg_pull_up>; }; };
usb { host_vbus_drv: host-vbus-drv { - rockchip,pins = <0 14 RK_FUNC_GPIO &pcfg_pull_none>; + rockchip,pins = <0 RK_PB6 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + sata { + sata_pwr_en: sata-pwr-en { + rockchip,pins = <0 RK_PB5 RK_FUNC_GPIO &pcfg_pull_none>; }; };
sdmmc { sdmmc_pwr: sdmmc-pwr { - rockchip,pins = <7 11 RK_FUNC_GPIO &pcfg_pull_none>; + rockchip,pins = <7 RK_PB3 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + sdio { + wifi_enable: wifi-enable { + rockchip,pins = <4 RK_PD4 RK_FUNC_GPIO &pcfg_pull_none>; }; }; };
+&saradc { + status = "okay"; +}; + &spdif { status = "okay"; };
&uart2 { status = "okay"; - reg-shift = <2>; };
&usbphy { status = "okay"; };
+&usbphy1 { + vbus-supply = <&vcc_usb_host>; +}; + &usb_host0_ehci { status = "okay"; }; + +&usb_host1 { + status = "okay"; +}; + +&usb_otg { + status = "okay"; +}; diff --git a/arch/arm/dts/rk3288-tinker-s.dts b/arch/arm/dts/rk3288-tinker-s.dts index cc7ac5f8..970e1385 100644 --- a/arch/arm/dts/rk3288-tinker-s.dts +++ b/arch/arm/dts/rk3288-tinker-s.dts @@ -10,10 +10,6 @@ / { model = "Rockchip RK3288 Asus Tinker Board S"; compatible = "asus,rk3288-tinker-s", "rockchip,rk3288"; - - chosen { - stdout-path = &uart2; - }; };
&emmc { @@ -27,3 +23,8 @@ mmc-ddr-1_8v; status = "okay"; }; + +&hdmi { + pinctrl-names = "default"; + pinctrl-0 = <&hdmi_cec_c0>; +}; diff --git a/arch/arm/dts/rk3288-tinker.dts b/arch/arm/dts/rk3288-tinker.dts index 8b1848c3..1e43527a 100644 --- a/arch/arm/dts/rk3288-tinker.dts +++ b/arch/arm/dts/rk3288-tinker.dts @@ -1,33 +1,13 @@ -// SPDX-License-Identifier: GPL-2.0+ OR X11 +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) /* - * (C) Copyright 2016 Rockchip Electronics Co., Ltd + * Copyright (c) 2017 Fuzhou Rockchip Electronics Co., Ltd. */
/dts-v1/; + #include "rk3288-tinker.dtsi"
/ { - model = "Tinker-RK3288"; - compatible = "rockchip,rk3288-tinker", "rockchip,rk3288"; - - chosen { - stdout-path = &uart2; - }; -}; - -&pinctrl { - usb { - host_vbus_drv: host-vbus-drv { - rockchip,pins = <0 14 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; -}; - -&pwm1 { - status = "okay"; -}; - -&usb_host1 { - vbus-supply = <&vcc5v0_host>; - status = "okay"; + model = "Rockchip RK3288 Asus Tinker Board"; + compatible = "asus,rk3288-tinker", "rockchip,rk3288"; }; diff --git a/arch/arm/dts/rk3288-tinker.dtsi b/arch/arm/dts/rk3288-tinker.dtsi index 2f816af4..4fde8a75 100644 --- a/arch/arm/dts/rk3288-tinker.dtsi +++ b/arch/arm/dts/rk3288-tinker.dtsi @@ -1,46 +1,17 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) /* - * This file is dual-licensed: you can use it either under the terms - * of the GPL or the X11 license, at your option. Note that this dual - * licensing only applies to this file, and not this project as a - * whole. - * - * a) This file is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This file is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * Or, alternatively, - * - * b) Permission is hereby granted, free of charge, to any person - * obtaining a copy of this software and associated documentation - * files (the "Software"), to deal in the Software without - * restriction, including without limitation the rights to use, - * copy, modify, merge, publish, distribute, sublicense, and/or - * sell copies of the Software, and to permit persons to whom the - * Software is furnished to do so, subject to the following - * conditions: - * - * The above copyright notice and this permission notice shall be - * included in all copies or substantial portions of the Software. - * - * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, - * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES - * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND - * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT - * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, - * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING - * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR - * OTHER DEALINGS IN THE SOFTWARE. + * Copyright (c) 2017 Fuzhou Rockchip Electronics Co., Ltd. */
#include "rk3288.dtsi" +#include <dt-bindings/input/input.h> +#include <dt-bindings/clock/rockchip,rk808.h>
/ { + chosen { + stdout-path = "serial2:115200n8"; + }; + memory { device_type = "memory"; reg = <0x0 0x80000000>; @@ -48,23 +19,26 @@
ext_gmac: external-gmac-clock { compatible = "fixed-clock"; + #clock-cells = <0>; clock-frequency = <125000000>; clock-output-names = "ext_gmac"; - #clock-cells = <0>; };
gpio-keys { compatible = "gpio-keys"; + #address-cells = <1>; + #size-cells = <0>; autorepeat;
pinctrl-names = "default"; pinctrl-0 = <&pwrbtn>;
button@0 { - gpios = <&gpio0 5 GPIO_ACTIVE_LOW>; + gpios = <&gpio0 RK_PA5 GPIO_ACTIVE_LOW>; + linux,code = <KEY_POWER>; label = "GPIO Key Power"; linux,input-type = <1>; - gpio-key,wakeup = <1>; + wakeup-source; debounce-interval = <100>; }; }; @@ -72,14 +46,44 @@ gpio-leds { compatible = "gpio-leds";
- pwr-led { - gpios = <&gpio2 2 GPIO_ACTIVE_HIGH>; + act_led: led-0 { + gpios = <&gpio1 RK_PD0 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "mmc0"; + }; + + heartbeat_led: led-1 { + gpios = <&gpio1 RK_PD1 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "heartbeat"; + }; + + pwr_led: led-2 { + gpios = <&gpio0 RK_PA3 GPIO_ACTIVE_HIGH>; linux,default-trigger = "default-on"; }; + };
- act-led { - gpios=<&gpio2 3 GPIO_ACTIVE_LOW>; - linux,default-trigger="mmc0"; + sdio_pwrseq: sdio-pwrseq { + compatible = "mmc-pwrseq-simple"; + clocks = <&rk808 RK808_CLKOUT1>; + clock-names = "ext_clock"; + pinctrl-names = "default"; + pinctrl-0 = <&wifi_enable>; + reset-gpios = <&gpio4 RK_PD3 GPIO_ACTIVE_LOW>, + <&gpio4 RK_PD4 GPIO_ACTIVE_LOW>; + }; + + sound { + compatible = "simple-audio-card"; + simple-audio-card,format = "i2s"; + simple-audio-card,name = "rockchip,tinker-codec"; + simple-audio-card,mclk-fs = <512>; + + simple-audio-card,codec { + sound-dai = <&hdmi>; + }; + + simple-audio-card,cpu { + sound-dai = <&i2s>; }; };
@@ -92,11 +96,6 @@ regulator-boot-on; };
- /* - * NOTE: vcc_sd isn't hooked up on v1.0 boards where power comes from - * vcc_io directly. Those boards won't be able to power cycle SD cards - * but it shouldn't hurt to toggle this pin there anyway. - */ vcc_sd: sdmmc-regulator { compatible = "regulator-fixed"; gpio = <&gpio7 11 GPIO_ACTIVE_LOW>; @@ -108,80 +107,66 @@ startup-delay-us = <100000>; vin-supply = <&vcc_io>; }; - - vcc5v0_host: usb-host-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio0 14 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&host_vbus_drv>; - regulator-name = "vcc5v0_host"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - regulator-always-on; - }; };
&cpu0 { cpu0-supply = <&vdd_cpu>; };
-&sdmmc { - bus-width = <4>; - cap-mmc-highspeed; - cap-sd-highspeed; - card-detect-delay = <200>; - disable-wp; /* wp not hooked up */ - num-slots = <1>; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_cd &sdmmc_bus4>; - status = "okay"; - supports-sd; - vmmc-supply = <&vcc_sd>; - vqmmc-supply = <&vccio_sd>; -}; - -&gpu { - mali-supply = <&vdd_gpu>; - status = "okay"; +&cpu_opp_table { + opp-1704000000 { + opp-hz = /bits/ 64 <1704000000>; + opp-microvolt = <1350000>; + }; + opp-1800000000 { + opp-hz = /bits/ 64 <1800000000>; + opp-microvolt = <1400000>; + }; };
&gmac { - phy-supply = <&vcc33_lan>; - phy-mode = "rgmii"; - clock_in_out = "input"; - snps,reset-gpio = <&gpio4 7 0>; - snps,reset-active-low; - snps,reset-delays-us = <0 10000 1000000>; assigned-clocks = <&cru SCLK_MAC>; assigned-clock-parents = <&ext_gmac>; + clock_in_out = "input"; + phy-mode = "rgmii"; + phy-supply = <&vcc33_lan>; pinctrl-names = "default"; pinctrl-0 = <&rgmii_pins>; + snps,reset-gpio = <&gpio4 7 0>; + snps,reset-active-low; + snps,reset-delays-us = <0 10000 1000000>; tx_delay = <0x30>; rx_delay = <0x10>; status = "okay"; };
+&gpu { + mali-supply = <&vdd_gpu>; + status = "okay"; +}; + &hdmi { ddc-i2c-bus = <&i2c5>; status = "okay"; };
&i2c0 { - status = "okay"; clock-frequency = <400000>; + status = "okay";
rk808: pmic@1b { compatible = "rockchip,rk808"; reg = <0x1b>; interrupt-parent = <&gpio0>; interrupts = <4 IRQ_TYPE_LEVEL_LOW>; + #clock-cells = <1>; + clock-output-names = "xin32k", "rk808-clkout2"; + dvs-gpios = <&gpio0 11 GPIO_ACTIVE_HIGH>, + <&gpio0 12 GPIO_ACTIVE_HIGH>; pinctrl-names = "default"; - pinctrl-0 = <&pmic_int &global_pwroff>; + pinctrl-0 = <&pmic_int &global_pwroff &dvs_1 &dvs_2>; rockchip,system-power-controller; wakeup-source; - #clock-cells = <1>; - clock-output-names = "xin32k", "rk808-clkout2";
vcc1-supply = <&vcc_sys>; vcc2-supply = <&vcc_sys>; @@ -189,20 +174,21 @@ vcc4-supply = <&vcc_sys>; vcc6-supply = <&vcc_sys>; vcc7-supply = <&vcc_sys>; - vcc8-supply = <&vcc_18>; + vcc8-supply = <&vcc_io>; vcc9-supply = <&vcc_io>; vcc10-supply = <&vcc_io>; vcc11-supply = <&vcc_sys>; vcc12-supply = <&vcc_io>; - vddio-supply = <&vcc18_ldo1>; + vddio-supply = <&vcc_io>;
regulators { vdd_cpu: DCDC_REG1 { regulator-always-on; regulator-boot-on; regulator-min-microvolt = <750000>; - regulator-max-microvolt = <1350000>; + regulator-max-microvolt = <1400000>; regulator-name = "vdd_arm"; + regulator-ramp-delay = <6000>; regulator-state-mem { regulator-off-in-suspend; }; @@ -214,6 +200,7 @@ regulator-min-microvolt = <850000>; regulator-max-microvolt = <1250000>; regulator-name = "vdd_gpu"; + regulator-ramp-delay = <6000>; regulator-state-mem { regulator-on-in-suspend; regulator-suspend-microvolt = <1000000>; @@ -359,47 +346,149 @@
&i2c2 { status = "okay"; - headset: nau8825@1a { - compatible = "nuvoton,nau8825"; - #sound-dai-cells = <0>; - reg = <0x1a>; - interrupt-parent = <&gpio6>; - interrupts = <5 IRQ_TYPE_LEVEL_LOW>; - nuvoton,jkdet-enable = <1>; - nuvoton,jkdet-pull-enable = <1>; - nuvoton,jkdet-pull-up = <0>; - nuvoton,jkdet-polarity = <1>; - nuvoton,vref-impedance = <2>; - nuvoton,micbias-voltage = <6>; - nuvoton,sar-threshold-num = <4>; - nuvoton,sar-threshold = <0xa 0x14 0x26 0x73>; - nuvoton,sar-hysteresis = <0>; - nuvoton,sar-voltage = <6>; - nuvoton,sar-compare-time = <0>; - nuvoton,sar-sampling-time = <0>; - nuvoton,short-key-debounce = <3>; - nuvoton,jack-insert-debounce = <7>; - nuvoton,jack-eject-debounce = <7>; - clock-names = "mclk"; - clocks = <&cru SCLK_I2S0_OUT>; - }; };
-&wdt { +&i2s { + #sound-dai-cells = <0>; status = "okay"; };
+&io_domains { + status = "okay"; + + sdcard-supply = <&vccio_sd>; + wifi-supply = <&vcc_18>; +}; + +&pinctrl { + pcfg_pull_none_drv_8ma: pcfg-pull-none-drv-8ma { + drive-strength = <8>; + }; + + pcfg_pull_up_drv_8ma: pcfg-pull-up-drv-8ma { + bias-pull-up; + drive-strength = <8>; + }; + + backlight { + bl_en: bl-en { + rockchip,pins = <7 RK_PA2 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + buttons { + pwrbtn: pwrbtn { + rockchip,pins = <0 RK_PA5 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + eth_phy { + eth_phy_pwr: eth-phy-pwr { + rockchip,pins = <0 RK_PA6 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + pmic { + pmic_int: pmic-int { + rockchip,pins = <0 RK_PA4 RK_FUNC_GPIO &pcfg_pull_up>; + }; + + dvs_1: dvs-1 { + rockchip,pins = <0 RK_PB3 RK_FUNC_GPIO &pcfg_pull_down>; + }; + + dvs_2: dvs-2 { + rockchip,pins = <0 RK_PB4 RK_FUNC_GPIO &pcfg_pull_down>; + }; + }; + + sdmmc { + sdmmc_bus4: sdmmc-bus4 { + rockchip,pins = <6 RK_PC0 1 &pcfg_pull_up_drv_8ma>, + <6 RK_PC1 1 &pcfg_pull_up_drv_8ma>, + <6 RK_PC2 1 &pcfg_pull_up_drv_8ma>, + <6 RK_PC3 1 &pcfg_pull_up_drv_8ma>; + }; + + sdmmc_clk: sdmmc-clk { + rockchip,pins = <6 RK_PC4 1 &pcfg_pull_none_drv_8ma>; + }; + + sdmmc_cmd: sdmmc-cmd { + rockchip,pins = <6 RK_PC5 1 &pcfg_pull_up_drv_8ma>; + }; + + sdmmc_pwr: sdmmc-pwr { + rockchip,pins = <7 RK_PB3 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + usb { + host_vbus_drv: host-vbus-drv { + rockchip,pins = <0 RK_PB6 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + pwr_3g: pwr-3g { + rockchip,pins = <7 RK_PB0 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + sdio { + wifi_enable: wifi-enable { + rockchip,pins = <4 RK_PD3 RK_FUNC_GPIO &pcfg_pull_none>, + <4 RK_PD4 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; +}; + &pwm0 { status = "okay"; };
&saradc { vref-supply = <&vcc18_ldo1>; - status ="okay"; + status = "okay"; +}; + +&sdmmc { + bus-width = <4>; + cap-mmc-highspeed; + cap-sd-highspeed; + broken-cd; + disable-wp; /* wp not hooked up */ + pinctrl-names = "default"; + pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_cd &sdmmc_bus4>; + status = "okay"; + vmmc-supply = <&vcc33_sd>; + vqmmc-supply = <&vccio_sd>; +}; + +&sdio0 { + bus-width = <4>; + cap-sd-highspeed; + cap-sdio-irq; + keep-power-in-suspend; + max-frequency = <50000000>; + mmc-pwrseq = <&sdio_pwrseq>; + non-removable; + pinctrl-names = "default"; + pinctrl-0 = <&sdio0_bus4>, <&sdio0_cmd>, <&sdio0_clk>, <&sdio0_int>; + sd-uhs-sdr12; + sd-uhs-sdr25; + sd-uhs-sdr50; + vmmc-supply = <&vcc_io>; + vqmmc-supply = <&vcc_18>; + status = "okay"; +}; + +&tsadc { + rockchip,hw-tshut-mode = <1>; /* tshut mode 0:CRU 1:GPIO */ + rockchip,hw-tshut-polarity = <1>; /* tshut polarity 0:LOW 1:HIGH */ + status = "okay"; };
&uart0 { @@ -422,12 +511,6 @@ status = "okay"; };
-&tsadc { - rockchip,hw-tshut-mode = <1>; /* tshut mode 0:CRU 1:GPIO */ - rockchip,hw-tshut-polarity = <1>; /* tshut polarity 0:LOW 1:HIGH */ - status = "okay"; -}; - &usbphy { status = "okay"; }; @@ -441,7 +524,7 @@ };
&usb_otg { - status= "okay"; + status = "okay"; };
&vopb { @@ -460,72 +543,6 @@ status = "okay"; };
-&pinctrl { - pcfg_pull_none_drv_8ma: pcfg-pull-none-drv-8ma { - drive-strength = <8>; - }; - - pcfg_pull_up_drv_8ma: pcfg-pull-up-drv-8ma { - bias-pull-up; - drive-strength = <8>; - }; - - backlight { - bl_en: bl-en { - rockchip,pins = <7 2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - buttons { - pwrbtn: pwrbtn { - rockchip,pins = <0 5 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - eth_phy { - eth_phy_pwr: eth-phy-pwr { - rockchip,pins = <0 6 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - pmic { - pmic_int: pmic-int { - rockchip,pins = <RK_GPIO0 4 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - sdmmc { - /* - * Default drive strength isn't enough to achieve even - * high-speed mode on EVB board so bump up to 8ma. - */ - sdmmc_bus4: sdmmc-bus4 { - rockchip,pins = <6 16 RK_FUNC_1 &pcfg_pull_up_drv_8ma>, - <6 17 RK_FUNC_1 &pcfg_pull_up_drv_8ma>, - <6 18 RK_FUNC_1 &pcfg_pull_up_drv_8ma>, - <6 19 RK_FUNC_1 &pcfg_pull_up_drv_8ma>; - }; - - sdmmc_clk: sdmmc-clk { - rockchip,pins = <6 20 RK_FUNC_1 &pcfg_pull_none_drv_8ma>; - }; - - sdmmc_cmd: sdmmc-cmd { - rockchip,pins = <6 21 RK_FUNC_1 &pcfg_pull_up_drv_8ma>; - }; - - sdmmc_pwr: sdmmc-pwr { - rockchip,pins = <7 11 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - usb { - host_vbus_drv: host-vbus-drv { - rockchip,pins = <0 14 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - pwr_3g: pwr-3g { - rockchip,pins = <7 8 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; +&wdt { + status = "okay"; };
On 2022/3/4 07:52, Johan Jonker wrote:
Sync rk3288 DT boards that have support both in Linux 5.17 as in U-boot.
Signed-off-by: Johan Jonker jbx6244@gmail.com
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
Change V3: update change reg size delete more files
Changed V2: update change led labels
arch/arm/dts/rk3288-firefly-u-boot.dtsi | 4 +- arch/arm/dts/rk3288-firefly.dts | 17 +- arch/arm/dts/rk3288-firefly.dtsi | 161 +++++-- arch/arm/dts/rk3288-miqi-u-boot.dtsi | 2 +- arch/arm/dts/rk3288-miqi.dts | 431 ++++++++++++++++++- arch/arm/dts/rk3288-miqi.dtsi | 418 ------------------ arch/arm/dts/rk3288-phycore-rdk.dts | 109 +++-- arch/arm/dts/rk3288-phycore-som.dtsi | 111 +---- arch/arm/dts/rk3288-popmetal.dts | 505 +++++++++++++++++++++- arch/arm/dts/rk3288-popmetal.dtsi | 545 ------------------------ arch/arm/dts/rk3288-rock2-som.dtsi | 91 ++-- arch/arm/dts/rk3288-rock2-square.dts | 215 +++++++--- arch/arm/dts/rk3288-tinker-s.dts | 9 +- arch/arm/dts/rk3288-tinker.dts | 30 +- arch/arm/dts/rk3288-tinker.dtsi | 405 +++++++++--------- 15 files changed, 1554 insertions(+), 1499 deletions(-) delete mode 100644 arch/arm/dts/rk3288-miqi.dtsi delete mode 100644 arch/arm/dts/rk3288-popmetal.dtsi
diff --git a/arch/arm/dts/rk3288-firefly-u-boot.dtsi b/arch/arm/dts/rk3288-firefly-u-boot.dtsi index cc84d7c4..c43d3281 100644 --- a/arch/arm/dts/rk3288-firefly-u-boot.dtsi +++ b/arch/arm/dts/rk3288-firefly-u-boot.dtsi @@ -14,11 +14,11 @@ leds { u-boot,dm-pre-reloc;
work {
};work_led: led-0 { u-boot,dm-pre-reloc;
power {
}; };power_led: led-1 { u-boot,dm-pre-reloc;
diff --git a/arch/arm/dts/rk3288-firefly.dts b/arch/arm/dts/rk3288-firefly.dts index 72982efd..313459da 100644 --- a/arch/arm/dts/rk3288-firefly.dts +++ b/arch/arm/dts/rk3288-firefly.dts @@ -1,4 +1,4 @@ -// SPDX-License-Identifier: GPL-2.0+ OR X11 +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) /*
- Copyright (c) 2014, 2015 FUKAUMI Naoki naobsd@gmail.com
*/ @@ -9,31 +9,22 @@ / { model = "Firefly-RK3288"; compatible = "firefly,firefly-rk3288", "rockchip,rk3288";
chosen {
&ir {
gpios = <&gpio7 0 GPIO_ACTIVE_LOW>;
gpios = <&gpio7 RK_PA0 GPIO_ACTIVE_LOW>; };
&pinctrl { act8846 { pmic_vsel: pmic-vsel {
rockchip,pins = <7 14 RK_FUNC_GPIO &pcfg_output_low>;
rockchip,pins = <7 RK_PB6 RK_FUNC_GPIO &pcfg_output_low>;
rockchip,pins = <7 0 RK_FUNC_GPIO &pcfg_pull_up>;
- usb_host {
}; }; };rockchip,pins = <7 RK_PA0 RK_FUNC_GPIO &pcfg_pull_up>;
diff --git a/arch/arm/dts/rk3288-firefly.dtsi b/arch/arm/dts/rk3288-firefly.dtsi index 1117d391..96d768ac 100644 --- a/arch/arm/dts/rk3288-firefly.dtsi +++ b/arch/arm/dts/rk3288-firefly.dtsi @@ -1,15 +1,38 @@ -// SPDX-License-Identifier: GPL-2.0+ OR X11 +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) /*
+#include <dt-bindings/input/input.h> #include "rk3288.dtsi"
- memory {
memory@0 {
reg = <0 0x80000000>; };
adc-keys {
button-recovery {
label = "Recovery";
dovdd_1v8: dovdd-1v8-regulator {
regulator-name = "dovdd_1v8";
ext_gmac: external-gmac-clock { compatible = "fixed-clock"; #clock-cells = <0>;
@@ -26,11 +49,11 @@ keys: gpio-keys { compatible = "gpio-keys";
button@0 {
power {
wakeup-source;
gpios = <&gpio0 RK_PA5 GPIO_ACTIVE_LOW>; label = "GPIO Power";
linux,code = <116>;
};linux,code = <KEY_POWER>; pinctrl-names = "default"; pinctrl-0 = <&pwr_key>;
@@ -39,24 +62,24 @@ leds { compatible = "gpio-leds";
work {
work_led: led-0 {
gpios = <&gpio8 RK_PA1 GPIO_ACTIVE_LOW>; label = "firefly:blue:user"; linux,default-trigger = "rc-feedback"; pinctrl-names = "default";
pinctrl-0 = <&work_led>;
};pinctrl-0 = <&work_led_pin>;
power {
gpios = <&gpio8 2 GPIO_ACTIVE_LOW>;
power_led: led-1 {
gpios = <&gpio8 RK_PA2 GPIO_ACTIVE_LOW>; label = "firefly:green:power"; linux,default-trigger = "default-on"; pinctrl-names = "default";
pinctrl-0 = <&power_led>;
}; };pinctrl-0 = <&power_led_pin>;
- vbat_wl: vcc_sys: vsys-regulator { compatible = "regulator-fixed"; regulator-name = "vcc_sys"; regulator-min-microvolt = <5000000>;
@@ -67,7 +90,7 @@
pinctrl-names = "default"; pinctrl-0 = <&sdmmc_pwr>; regulator-name = "vcc_sd";gpio = <&gpio7 RK_PB3 GPIO_ACTIVE_LOW>;
@@ -98,7 +121,7 @@ vcc_host_5v: usb-host-regulator { compatible = "regulator-fixed"; enable-active-high;
pinctrl-names = "default"; pinctrl-0 = <&host_vbus_drv>; regulator-name = "vcc_host_5v";gpio = <&gpio0 RK_PB6 GPIO_ACTIVE_HIGH>;
@@ -111,7 +134,7 @@ vcc_otg_5v: usb-otg-regulator { compatible = "regulator-fixed"; enable-active-high;
gpio = <&gpio0 12 GPIO_ACTIVE_HIGH>;
pinctrl-names = "default"; pinctrl-0 = <&otg_vbus_drv>; regulator-name = "vcc_otg_5v";gpio = <&gpio0 RK_PB4 GPIO_ACTIVE_HIGH>;
@@ -120,6 +143,23 @@ regulator-always-on; vin-supply = <&vcc_5v>; };
* A TT8142 creates both dovdd_1v8 and vcc28_dvp, controlled
enable-active-high;
gpio = <&gpio0 RK_PB3 GPIO_ACTIVE_HIGH>;
&cpu0 {
@@ -127,12 +167,10 @@ };
&emmc {
- broken-cd; bus-width = <8>; cap-mmc-highspeed; disable-wp; non-removable;
- num-slots = <1>; pinctrl-names = "default"; pinctrl-0 = <&emmc_clk>, <&emmc_cmd>, <&emmc_pwr>, <&emmc_bus8>; vmmc-supply = <&vcc_io>;
@@ -150,12 +188,17 @@ phy-mode = "rgmii"; snps,reset-active-low; snps,reset-delays-us = <0 10000 1000000>;
- snps,reset-gpio = <&gpio4 RK_PB0 GPIO_ACTIVE_LOW>; tx_delay = <0x30>; rx_delay = <0x10>; status = "okay"; };
+&gpu {
- status = "okay";
- &hdmi { ddc-i2c-bus = <&i2c5>; status = "okay";
@@ -174,6 +217,8 @@ regulator-max-microvolt = <1350000>; regulator-always-on; regulator-boot-on;
regulator-enable-ramp-delay = <300>;
vin-supply = <&vcc_sys>; };regulator-ramp-delay = <8000>;
@@ -195,7 +240,7 @@ clock-frequency = <32768>; clock-output-names = "xin32k"; interrupt-parent = <&gpio7>;
pinctrl-names = "default"; pinctrl-0 = <&rtc_int>; };interrupts = <RK_PA4 IRQ_TYPE_EDGE_FALLING>;
@@ -207,6 +252,14 @@ pinctrl-0 = <&pmic_vsel>, <&pwr_hold>; system-power-controller;
vp1-supply = <&vcc_sys>;
vp2-supply = <&vcc_sys>;
vp3-supply = <&vcc_sys>;
vp4-supply = <&vcc_sys>;
inl1-supply = <&vcc_sys>;
inl2-supply = <&vcc_sys>;
inl3-supply = <&vcc_20>;
- regulators { vcc_ddr: REG1 { regulator-name = "vcc_ddr";
@@ -275,7 +328,7 @@ regulator-always-on; };
vcc_18: REG11 {
vccio_wl: vcc_18: REG11 { regulator-name = "vcc_18"; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>;
@@ -308,6 +361,21 @@ status = "okay"; };
+&io_domains {
- status = "okay";
- dvp-supply = <&dovdd_1v8>;
- &pinctrl { pcfg_output_high: pcfg-output-high { output-high;
@@ -324,43 +392,49 @@
act8846 { pwr_hold: pwr-hold {
rockchip,pins = <0 1 RK_FUNC_GPIO &pcfg_output_high>;
rockchip,pins = <0 RK_PA1 RK_FUNC_GPIO &pcfg_output_high>;
dvp {
dvp_pwr: dvp-pwr {
rockchip,pins = <0 RK_PB3 RK_FUNC_GPIO &pcfg_pull_none>;
rockchip,pins = <0 9 RK_FUNC_GPIO &pcfg_pull_up>;
rockchip,pins = <0 RK_PB1 RK_FUNC_GPIO &pcfg_pull_up>;
phy_pmeb: phy-pmeb {
rockchip,pins = <0 8 RK_FUNC_GPIO &pcfg_pull_up>;
rockchip,pins = <0 RK_PB0 RK_FUNC_GPIO &pcfg_pull_up>;
phy_rst: phy-rst {
hym8563 { rtc_int: rtc-int {
rockchip,pins = <7 4 RK_FUNC_GPIO &pcfg_pull_up>;
rockchip,pins = <7 RK_PA4 RK_FUNC_GPIO &pcfg_pull_up>;
keys { pwr_key: pwr-key {
leds {
power_led: power-led {
rockchip,pins = <8 2 RK_FUNC_GPIO &pcfg_pull_none>;
power_led_pin: power-led-pin {
};rockchip,pins = <8 RK_PA2 RK_FUNC_GPIO &pcfg_pull_none>;
work_led: work-led {
rockchip,pins = <8 1 RK_FUNC_GPIO &pcfg_pull_none>;
work_led_pin: work-led-pin {
}; };rockchip,pins = <8 RK_PA1 RK_FUNC_GPIO &pcfg_pull_none>;
@@ -391,17 +465,17 @@
usb_host { host_vbus_drv: host-vbus-drv {
usbhub_rst: usbhub-rst {
rockchip,pins = <8 3 RK_FUNC_GPIO &pcfg_output_high>;
rockchip,pins = <8 RK_PA3 RK_FUNC_GPIO &pcfg_output_high>;
usb_otg { otg_vbus_drv: otg-vbus-drv {
rockchip,pins = <0 12 RK_FUNC_GPIO &pcfg_pull_none>;
}; }; };rockchip,pins = <0 RK_PB4 RK_FUNC_GPIO &pcfg_pull_none>;
@@ -412,15 +486,14 @@ };
&sdio0 {
- broken-cd; bus-width = <4>; disable-wp; non-removable;
- num-slots = <1>; pinctrl-names = "default"; pinctrl-0 = <&sdio0_bus4>, <&sdio0_cmd>, <&sdio0_clk>;
- vmmc-supply = <&vcc_18>;
- status = "disabled";
vmmc-supply = <&vbat_wl>;
vqmmc-supply = <&vccio_wl>;
status = "okay"; };
&sdmmc {
@@ -429,10 +502,10 @@ cap-sd-highspeed; card-detect-delay = <200>; disable-wp;
- num-slots = <1>; pinctrl-names = "default"; pinctrl-0 = <&sdmmc_clk>, <&sdmmc_cmd>, <&sdmmc_cd>, <&sdmmc_bus4>; vmmc-supply = <&vcc_sd>;
- vqmmc-supply = <&vccio_sd>; status = "okay"; };
@@ -442,6 +515,12 @@ status = "okay"; };
+&tsadc {
- status = "okay";
- &uart0 { pinctrl-names = "default"; pinctrl-0 = <&uart0_xfer>, <&uart0_cts>, <&uart0_rts>;
@@ -460,6 +539,10 @@ status = "okay"; };
+&usbphy {
- status = "okay";
- &usb_host1 { pinctrl-names = "default"; pinctrl-0 = <&usbhub_rst>;
diff --git a/arch/arm/dts/rk3288-miqi-u-boot.dtsi b/arch/arm/dts/rk3288-miqi-u-boot.dtsi index 2a74fdd1..f2611aaa 100644 --- a/arch/arm/dts/rk3288-miqi-u-boot.dtsi +++ b/arch/arm/dts/rk3288-miqi-u-boot.dtsi @@ -8,7 +8,7 @@ leds { u-boot,dm-pre-reloc;
work {
}; };work_led: led-0 { u-boot,dm-pre-reloc;
diff --git a/arch/arm/dts/rk3288-miqi.dts b/arch/arm/dts/rk3288-miqi.dts index 4a2f249e..713f55e1 100644 --- a/arch/arm/dts/rk3288-miqi.dts +++ b/arch/arm/dts/rk3288-miqi.dts @@ -1,10 +1,11 @@ -// SPDX-License-Identifier: GPL-2.0+ OR X11 +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) /*
- (C) Copyright 2016 Rockchip Electronics Co., Ltd
- Copyright (c) 2016 Heiko Stuebner heiko@sntech.de
/dts-v1/;
-#include "rk3288-miqi.dtsi" +#include <dt-bindings/input/input.h> +#include "rk3288.dtsi"
/ { model = "mqmaker MiQi"; @@ -13,4 +14,428 @@ chosen { stdout-path = "serial2:115200n8"; };
- memory@0 {
#clock-cells = <0>;
- leds {
work_led: led-0 {
gpios = <&gpio7 RK_PA2 GPIO_ACTIVE_HIGH>;
label = "miqi:green:user";
linux,default-trigger = "timer";
- vcc_host: usb-host-regulator {
enable-active-high;
regulator-boot-on;
+&cpu0 {
- cpu-supply = <&vdd_cpu>;
+&cpu1 {
+&cpu2 {
+&cpu3 {
+&emmc {
- bus-width = <8>;
- non-removable;
- pinctrl-0 = <&emmc_clk>, <&emmc_cmd>, <&emmc_pwr>, <&emmc_bus8>;
- status = "okay";
+&gmac {
- pinctrl-0 = <&rgmii_pins>, <&phy_rst>, <&phy_pmeb>, <&phy_int>;
- status = "okay";
+&gpu {
- status = "okay";
+&hdmi {
- status = "okay";
+&i2c0 {
- status = "okay";
- vdd_cpu: syr827@40 {
compatible = "silergy,syr827";
fcs,suspend-voltage-selector = <1>;
reg = <0x40>;
regulator-name = "vdd_cpu";
regulator-boot-on;
- vdd_gpu: syr828@41 {
compatible = "silergy,syr828";
reg = <0x41>;
- hym8563: hym8563@51 {
reg = <0x51>;
#clock-cells = <0>;
- act8846: act8846@5a {
compatible = "active-semi,act8846";
reg = <0x5a>;
pinctrl-0 = <&pmic_vsel>;
regulators {
vcc_ddr: REG1 {
vcc_io: REG2 {
vdd_log: REG3 {
regulator-name = "vdd_log";
regulator-min-microvolt = <1100000>;
regulator-max-microvolt = <1100000>;
vcc_20: REG4 {
regulator-name = "vcc_20";
regulator-min-microvolt = <2000000>;
regulator-max-microvolt = <2000000>;
vccio_sd: REG5 {
vdd10_lcd: REG6 {
vcca_18: REG7 {
regulator-name = "vcca_18";
vcca_33: REG8 {
vcc_lan: REG9 {
vdd_10: REG10 {
vcc_18: REG11 {
vcc18_lcd: REG12 {
+&i2c1 {
- status = "okay";
+&i2c2 {
- status = "okay";
+&i2c4 {
- status = "okay";
+&i2c5 {
- status = "okay";
+&io_domains {
- status = "okay";
- wifi-supply = <&vcc_18>;
+&pinctrl {
- pcfg_output_high: pcfg-output-high {
output-high;
- pcfg_output_low: pcfg-output-low {
output-low;
- pcfg_pull_up_drv_12ma: pcfg-pull-up-drv-12ma {
bias-pull-up;
drive-strength = <12>;
- act8846 {
pmic_sleep: pmic-sleep {
rockchip,pins = <0 RK_PA0 RK_FUNC_GPIO &pcfg_output_low>;
rockchip,pins = <7 RK_PA1 RK_FUNC_GPIO &pcfg_output_low>;
- gmac {
phy_int: phy-int {
phy_rst: phy-rst {
- sdmmc {
* high-speed mode on firefly board so bump up to 12ma.
rockchip,pins = <6 RK_PC0 1 &pcfg_pull_up_drv_12ma>,
<6 RK_PC1 1 &pcfg_pull_up_drv_12ma>,
<6 RK_PC2 1 &pcfg_pull_up_drv_12ma>,
<6 RK_PC3 1 &pcfg_pull_up_drv_12ma>;
rockchip,pins = <6 RK_PC4 1 &pcfg_pull_none_12ma>;
rockchip,pins = <6 RK_PC5 1 &pcfg_pull_up_drv_12ma>;
- usb_host {
+&saradc {
- vref-supply = <&vcc_18>;
- status = "okay";
+&sdmmc {
- bus-width = <4>;
- cap-sd-highspeed;
- disable-wp;
- pinctrl-0 = <&sdmmc_clk>, <&sdmmc_cmd>, <&sdmmc_cd>, <&sdmmc_bus4>;
- status = "okay";
+&tsadc {
- status = "okay";
+&uart2 {
- status = "okay";
+&uart3 {
- status = "okay";
+&usbphy {
- status = "okay";
+&usb_host1 {
- status = "okay";
+&usb_otg {
* The otg controller is the only system power source,
* so needs to always stay in device mode.
- dr_mode = "peripheral";
- status = "okay";
+&vopb {
- status = "okay";
+&vopb_mmu {
- status = "okay";
+&vopl {
- status = "okay";
+&vopl_mmu {
- status = "okay";
+&wdt {
- status = "okay"; };
diff --git a/arch/arm/dts/rk3288-miqi.dtsi b/arch/arm/dts/rk3288-miqi.dtsi deleted file mode 100644 index b1c286c9..00000000 --- a/arch/arm/dts/rk3288-miqi.dtsi +++ /dev/null @@ -1,418 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ OR X11 -/*
- memory {
#clock-cells = <0>;
- leds {
work {
gpios = <&gpio7 4 GPIO_ACTIVE_LOW>;
pinctrl-0 = <&led_ctl>;
enable-active-high;
regulator-boot-on;
-&cpu0 {
-&emmc {
- bus-width = <8>;
- disable-wp;
- non-removable;
- num-slots = <1>;
- status = "okay";
-&gmac {
- status = "okay";
-&hdmi {
- status = "okay";
-&i2c0 {
- status = "okay";
reg = <0x40>;
regulator-boot-on;
reg = <0x41>;
reg = <0x51>;
#clock-cells = <0>;
reg = <0x5a>;
regulators {
vcc_ddr: REG1 {
vcc_io: REG2 {
vdd_log: REG3 {
vcc_20: REG4 {
vccio_sd: REG5 {
vdd10_lcd: REG6 {
vcca_18: REG7 {
vcca_33: REG8 {
vcc_lan: REG9 {
vdd_10: REG10 {
vcc_18: REG11 {
vcc18_lcd: REG12 {
-&i2c1 {
- status = "okay";
-&i2c2 {
- status = "okay";
-&i2c4 {
- status = "okay";
-&i2c5 {
- status = "okay";
-&io_domains {
- status = "okay";
-&pinctrl {
output-high;
output-low;
bias-pull-up;
- act8846 {
rockchip,pins = <0 0 RK_FUNC_GPIO &pcfg_output_low>;
rockchip,pins = <7 1 RK_FUNC_GPIO &pcfg_output_low>;
- gmac {
phy_int: phy-int {
phy_rst: phy-rst {
- leds {
led_ctl: led-ctl {
rockchip,pins = <7 4 RK_FUNC_GPIO &pcfg_pull_none>;
- sdmmc {
rockchip,pins = <6 16 RK_FUNC_1 &pcfg_pull_up_drv_12ma>,
<6 17 RK_FUNC_1 &pcfg_pull_up_drv_12ma>,
<6 18 RK_FUNC_1 &pcfg_pull_up_drv_12ma>,
<6 19 RK_FUNC_1 &pcfg_pull_up_drv_12ma>;
rockchip,pins = <6 20 RK_FUNC_1 &pcfg_pull_none_12ma>;
rockchip,pins = <6 21 RK_FUNC_1 &pcfg_pull_up_drv_12ma>;
- usb_host {
-&saradc {
- status = "okay";
-&sdmmc {
- bus-width = <4>;
- cap-sd-highspeed;
- disable-wp;
- num-slots = <1>;
- status = "okay";
-&tsadc {
- status = "okay";
-&uart2 {
- status = "okay";
-&uart3 {
- status = "okay";
-&usbphy {
- status = "okay";
-&usb_host1 {
- vbus-supply = <&vcc_host>;
- status = "okay";
-&vopb {
- status = "okay";
-&vopb_mmu {
- status = "okay";
-&vopl {
- status = "okay";
-&vopl_mmu {
- status = "okay";
-&wdt {
- status = "okay";
-}; diff --git a/arch/arm/dts/rk3288-phycore-rdk.dts b/arch/arm/dts/rk3288-phycore-rdk.dts index ebea8e67..1e33859d 100644 --- a/arch/arm/dts/rk3288-phycore-rdk.dts +++ b/arch/arm/dts/rk3288-phycore-rdk.dts @@ -1,60 +1,20 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) /*
- Device tree file for Phytec PCM-947 carrier board
- Copyright (C) 2017 PHYTEC Messtechnik GmbH
- Author: Wadim Egorov w.egorov@phytec.de
- This file is dual-licensed: you can use it either under the terms
- of the GPL or the X11 license, at your option. Note that this dual
- licensing only applies to this file, and not this project as a
- whole.
- a) This file is free software; you can redistribute it and/or
- Or, alternatively,
- b) Permission is hereby granted, free of charge, to any person
conditions:
/dts-v1/;
+#include <dt-bindings/leds/leds-pca9532.h> #include "rk3288-phycore-som.dtsi"
/ { model = "Phytec RK3288 PCM-947"; compatible = "phytec,rk3288-pcm-947", "phytec,rk3288-phycore-som", "rockchip,rk3288";
- chosen {
- user_buttons: user-buttons { compatible = "gpio-keys"; pinctrl-names = "default";
@@ -155,6 +115,36 @@
&i2c4 { status = "okay";
/* PCA9533 - 4-bit LED dimmer */
leddim: leddimmer@62 {
compatible = "nxp,pca9533";
reg = <0x62>;
led1 {
label = "red:user1";
linux,default-trigger = "none";
type = <PCA9532_TYPE_LED>;
led2 {
label = "green:user2";
led3 {
label = "blue:user3";
led4 {
label = "red:user4";
&i2c5 {
@@ -170,15 +160,15 @@ buttons { user_button_pins: user-button-pins { /* button 1 */
rockchip,pins = <8 3 RK_FUNC_GPIO &pcfg_pull_up>,
rockchip,pins = <8 RK_PA3 RK_FUNC_GPIO &pcfg_pull_up>, /* button 2 */
rv4162 { i2c_rtc_int: i2c-rtc-int {
rockchip,pins = <5 10 RK_FUNC_GPIO &pcfg_pull_up>;
}; };rockchip,pins = <5 RK_PB2 RK_FUNC_GPIO &pcfg_pull_up>;
@@ -188,44 +178,44 @@ * high-speed mode on pcm-947 board so bump up to 12 mA. */ sdmmc_bus4: sdmmc-bus4 {
touchscreen { ts_irq_pin: ts-irq-pin {
rockchip,pins = <5 15 RK_FUNC_GPIO &pcfg_pull_none>;
rockchip,pins = <5 RK_PB7 RK_FUNC_GPIO &pcfg_pull_none>;
usb_host { host0_vbus_drv: host0-vbus-drv {
rockchip,pins = <2 13 RK_FUNC_GPIO &pcfg_pull_none>;
rockchip,pins = <2 RK_PB5 RK_FUNC_GPIO &pcfg_pull_none>;
host1_vbus_drv: host1-vbus-drv {
rockchip,pins = <2 0 RK_FUNC_GPIO &pcfg_pull_none>;
rockchip,pins = <2 RK_PA0 RK_FUNC_GPIO &pcfg_pull_none>;
rockchip,pins = <2 12 RK_FUNC_GPIO &pcfg_pull_none>;
}; }; };rockchip,pins = <2 RK_PB4 RK_FUNC_GPIO &pcfg_pull_none>;
@@ -236,10 +226,13 @@ cap-sd-highspeed; card-detect-delay = <200>; disable-wp;
- vmmc-supply = <&vdd_io_sd>;
- sd-uhs-sdr12;
- sd-uhs-sdr25;
- sd-uhs-sdr50;
- sd-uhs-sdr104;
- vmmc-supply = <&vdd_sd>; vqmmc-supply = <&vdd_io_sd>; status = "okay"; };
diff --git a/arch/arm/dts/rk3288-phycore-som.dtsi b/arch/arm/dts/rk3288-phycore-som.dtsi index 8ac695c8..b4894e9f 100644 --- a/arch/arm/dts/rk3288-phycore-som.dtsi +++ b/arch/arm/dts/rk3288-phycore-som.dtsi @@ -1,45 +1,8 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) /*
- Device tree file for Phytec phyCORE-RK3288 SoM
- whole.
conditions:
#include <dt-bindings/net/ti-dp83867.h>
@@ -61,7 +24,6 @@ aliases { rtc0 = &i2c_rtc; rtc1 = &rk818;
eeprom0 = &i2c_eeprom_id;
@@ -74,9 +36,9 @@ leds: user-leds { compatible = "gpio-leds"; pinctrl-names = "default";
pinctrl-0 = <&user_led>;
pinctrl-0 = <&user_led_pin>;
user {
user_led: led-0 { label = "green_led"; gpios = <&gpio7 2 GPIO_ACTIVE_HIGH>; linux,default-trigger = "heartbeat";
@@ -111,33 +73,12 @@ }; };
-&cpu0 {
- operating-points = <
/* KHz uV */
1800000 1400000
1608000 1350000
1512000 1300000
1416000 1200000
1200000 1100000
1008000 1050000
816000 1000000
696000 950000
600000 900000
408000 900000
312000 900000
216000 900000
126000 900000
- &emmc { status = "okay"; bus-width = <8>; cap-mmc-highspeed; disable-wp; non-removable;
- num-slots = <1>; pinctrl-names = "default"; pinctrl-0 = <&emmc_clk &emmc_cmd &emmc_pwr &emmc_bus8>; vmmc-supply = <&vdd_3v3_io>;
@@ -173,6 +114,7 @@ ti,tx-internal-delay = <DP83867_RGMIIDCTL_2_00_NS>; ti,fifo-depth = <DP83867_PHYCR_FIFO_DEPTH_4_B_NIB>; enet-phy-lane-no-swap;
}; }; };ti,clk-output-sel = <DP83867_CLK_O_SEL_CHN_A_TCLK>;
@@ -200,7 +142,6 @@ clock-frequency = <400000>;
rk818: pmic@1c {
compatible = "rockchip,rk818"; reg = <0x1c>; interrupt-parent = <&gpio0>;status = "okay";
@@ -359,11 +300,10 @@ regulator-name = "vdd_io_sd"; regulator-always-on; regulator-boot-on;
regulator-min-microvolt = <1800000>; regulator-max-microvolt = <3300000>; regulator-state-mem {
};regulator-off-in-suspend; }; };
@@ -376,13 +316,6 @@ pagesize = <32>; };
- /* M24C32-D Identification page */
- i2c_eeprom_id: eeprom@58 {
compatible = "atmel,24c32";
reg = <0x58>;
pagesize = <32>;
- vdd_cpu: regulator@60 { compatible = "fcs,fan53555"; reg = <0x60>;
@@ -409,49 +342,49 @@ * We also have external pulls, so disable the internal ones. */ emmc_clk: emmc-clk {
rockchip,pins = <3 18 RK_FUNC_2 &pcfg_pull_none_12ma>;
rockchip,pins = <3 RK_PC2 2 &pcfg_pull_none_12ma>;
emmc_cmd: emmc-cmd {
rockchip,pins = <3 16 RK_FUNC_2 &pcfg_pull_none_12ma>;
rockchip,pins = <3 RK_PC0 2 &pcfg_pull_none_12ma>;
emmc_bus8: emmc-bus8 {
rockchip,pins = <3 0 RK_FUNC_2 &pcfg_pull_none_12ma>,
<3 1 RK_FUNC_2 &pcfg_pull_none_12ma>,
<3 2 RK_FUNC_2 &pcfg_pull_none_12ma>,
<3 3 RK_FUNC_2 &pcfg_pull_none_12ma>,
<3 4 RK_FUNC_2 &pcfg_pull_none_12ma>,
<3 5 RK_FUNC_2 &pcfg_pull_none_12ma>,
<3 6 RK_FUNC_2 &pcfg_pull_none_12ma>,
<3 7 RK_FUNC_2 &pcfg_pull_none_12ma>;
rockchip,pins = <3 RK_PA0 2 &pcfg_pull_none_12ma>,
<3 RK_PA1 2 &pcfg_pull_none_12ma>,
<3 RK_PA2 2 &pcfg_pull_none_12ma>,
<3 RK_PA3 2 &pcfg_pull_none_12ma>,
<3 RK_PA4 2 &pcfg_pull_none_12ma>,
<3 RK_PA5 2 &pcfg_pull_none_12ma>,
<3 RK_PA6 2 &pcfg_pull_none_12ma>,
<3 RK_PA7 2 &pcfg_pull_none_12ma>;
gmac { phy_int: phy-int {
rockchip,pins = <4 2 RK_FUNC_GPIO &pcfg_pull_up>;
rockchip,pins = <4 RK_PA2 RK_FUNC_GPIO &pcfg_pull_up>;
phy_rst: phy-rst {
leds {
user_led: user-led {
rockchip,pins = <7 2 RK_FUNC_GPIO &pcfg_output_high>;
user_led_pin: user-led-pin {
rockchip,pins = <7 RK_PA2 RK_FUNC_GPIO &pcfg_output_high>;
/* Pin for switching state between sleep and non-sleep state */ pmic_sleep: pmic-sleep {
rockchip,pins = <RK_GPIO0 0 RK_FUNC_GPIO &pcfg_pull_up>;
}; }; };rockchip,pins = <0 RK_PA0 RK_FUNC_GPIO &pcfg_pull_up>;
diff --git a/arch/arm/dts/rk3288-popmetal.dts b/arch/arm/dts/rk3288-popmetal.dts index 736dc51e..8c7376d6 100644 --- a/arch/arm/dts/rk3288-popmetal.dts +++ b/arch/arm/dts/rk3288-popmetal.dts @@ -1,20 +1,513 @@ -// SPDX-License-Identifier: GPL-2.0+ OR X11 +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) /*
- Copyright (c) 2014, 2015 Andy Yan andy.yan@rock-chips.com
/dts-v1/;
-#include "rk3288-popmetal.dtsi" +#include <dt-bindings/input/input.h> +#include "rk3288.dtsi"
/ { model = "PopMetal-RK3288"; compatible = "chipspark,popmetal-rk3288", "rockchip,rk3288";
- chosen {
- memory@0 {
};reg = <0x0 0x0 0x0 0x80000000>;
#clock-cells = <0>;
- gpio-keys {
autorepeat;
power {
wakeup-source;
- ir: ir-receiver {
gpios = <&gpio0 RK_PA6 GPIO_ACTIVE_LOW>;
regulator-boot-on;
enable-active-high;
gpio = <&gpio0 RK_PC1 GPIO_ACTIVE_HIGH>;
+&cpu0 {
+&cpu1 {
+&cpu2 {
+&cpu3 {
+&emmc {
- bus-width = <8>;
- mmc-ddr-1_8v;
- mmc-hs200-1_8v;
- non-removable;
- status = "okay";
+&sdmmc {
- bus-width = <4>;
- cap-sd-highspeed;
- sd-uhs-sdr12;
- sd-uhs-sdr25;
- sd-uhs-sdr50;
- sd-uhs-sdr104;
- status = "okay";
+&gmac {
- snps,reset-gpio = <&gpio4 RK_PB0 GPIO_ACTIVE_HIGH>;
- status = "okay";
+&hdmi {
- status = "okay";
+&i2c0 {
- status = "okay";
- rk808: pmic@1b {
reg = <0x1b>;
interrupts = <RK_PA4 IRQ_TYPE_LEVEL_LOW>;
wakeup-source;
#clock-cells = <1>;
regulators {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
vcc_io: DCDC_REG4 {
regulator-boot-on;
vcc_lan: LDO_REG1 {
regulator-boot-on;
regulator-boot-on;
vdd_10: LDO_REG3 {
regulator-boot-on;
regulator-boot-on;
ldo5: LDO_REG5 {
regulator-boot-on;
vcc_18: LDO_REG7 {
regulator-boot-on;
vcca_33: LDO_REG8 {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
+&i2c1 {
- status = "okay";
- ak8963: ak8963@d {
reg = <0x0d>;
interrupts = <RK_PA1 IRQ_TYPE_EDGE_RISING>;
vdd-supply = <&vcc_io>;
vid-supply = <&vcc_io>;
- l3g4200d: l3g4200d@69 {
reg = <0x69>;
reg = <0x1d>;
interrupts = <RK_PA0 IRQ_TYPE_EDGE_RISING>;
+&i2c2 {
- status = "okay";
+&i2c3 {
- status = "okay";
+&i2c4 {
- status = "okay";
+&i2c5 {
- status = "okay";
+&io_domains {
- status = "okay";
+&pinctrl {
- ak8963 {
- buttons {
pwrbtn: pwrbtn {
- dvp {
dvp_pwr: dvp-pwr {
rockchip,pins = <0 RK_PC1 RK_FUNC_GPIO &pcfg_pull_none>;
- ir {
ir_int: ir-int {
rockchip,pins = <0 RK_PA6 RK_FUNC_GPIO &pcfg_pull_up>;
- mma8452 {
- pmic {
- sdmmc {
+&tsadc {
- status = "okay";
+&vopb {
- status = "okay";
+&vopb_mmu {
- status = "okay";
+&vopl {
- status = "okay";
+&vopl_mmu {
- status = "okay";
+&uart0 {
- status = "okay";
+&uart1 {
- status = "okay";
+&uart2 {
- status = "okay";
+&uart3 {
- status = "okay";
+&uart4 {
- status = "okay";
+&usbphy {
-&pwm1 { +&usb_otg { status = "okay"; }; diff --git a/arch/arm/dts/rk3288-popmetal.dtsi b/arch/arm/dts/rk3288-popmetal.dtsi deleted file mode 100644 index bcd8fded..00000000 --- a/arch/arm/dts/rk3288-popmetal.dtsi +++ /dev/null @@ -1,545 +0,0 @@ -/*
- whole.
conditions:
-#include "rk3288.dtsi"
- memory{
- ext_gmac: external-gmac-clock {
#clock-cells = <0>;
- gpio-keys {
autorepeat;
power {
wakeup-source;
- ir: ir-receiver {
gpios = <&gpio0 6 GPIO_ACTIVE_LOW>;
- vcc_flash: flash-regulator {
regulator-boot-on;
enable-active-high;
enable-active-high;
-&cpu0 {
-&emmc {
- bus-width = <8>;
- disable-wp;
- non-removable;
- num-slots = <1>;
- status = "okay";
-&sdmmc {
- bus-width = <4>;
- cap-sd-highspeed;
- disable-wp;
- num-slots = <1>;
- status = "okay";
-&gmac {
- status = "okay";
-&hdmi {
- status = "okay";
-&i2c0 {
- status = "okay";
- rk808: pmic@1b {
reg = <0x1b>;
wakeup-source;
#clock-cells = <1>;
regulators {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
vcc_io: DCDC_REG4 {
regulator-boot-on;
vcc_lan: LDO_REG1 {
regulator-boot-on;
regulator-boot-on;
vdd_10: LDO_REG3 {
regulator-boot-on;
regulator-boot-on;
ldo5: LDO_REG5 {
regulator-boot-on;
vcc_18: LDO_REG7 {
regulator-boot-on;
vcca_33: LDO_REG8 {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
-&i2c1 {
- status = "okay";
reg = <0x0d>;
reg = <0x6b>;
reg = <0x1d>;
-&i2c2 {
- status = "okay";
-&i2c3 {
- status = "okay";
-&i2c4 {
- status = "okay";
-&i2c5 {
- status = "okay";
-&io_domains {
- status = "okay";
-&pinctrl {
- ak8963 {
- buttons {
pwrbtn: pwrbtn {
- dvp {
dvp_pwr: dvp-pwr {
- ir {
ir_int: ir-int {
- mma8452 {
- pmic {
- sdmmc {
- usb_host {
-&saradc {
- status = "okay";
-&tsadc {
- status = "okay";
-&vopb {
- status = "okay";
-&vopb_mmu {
- status = "okay";
-&vopl {
- status = "okay";
-&vopl_mmu {
- status = "okay";
-&uart0 {
- status = "okay";
-&uart1 {
- status = "okay";
-&uart2 {
- status = "okay";
-&uart3 {
- status = "okay";
-&uart4 {
- status = "okay";
-&usb_host1 {
- status = "okay";
-&usbphy {
- status = "okay";
- whole.
conditions:
- memory {
- memory@0 { reg = <0x0 0x80000000>; device_type = "memory"; };
- vcc_sys: vsys-regulator { compatible = "regulator-fixed"; regulator-name = "vcc_sys";
- vqmmc-supply = <&vcc_flash>; status = "okay"; };
- snps,reset-gpio = <&gpio4 RK_PB0 GPIO_ACTIVE_LOW>; snps,reset-active-low; snps,reset-delays-us = <0 10000 30000>; rx_delay = <0x10>; tx_delay = <0x30>; };
+&gpu {
- status = "okay";
- &i2c0 { status = "okay";
vcc_io: REG2 {
+&io_domains {
- status = "okay";
- audio-supply = <&vcc_io>;
- dvp-supply = <&vcc_18>;
- flash1-supply = <&vccio_pmu>;
- gpio30-supply = <&vccio_pmu>;
emmc {
}; }; };rockchip,pins = <4 RK_PB0 RK_FUNC_GPIO &pcfg_output_high>;
+&saradc {
- &tsadc { rockchip,hw-tshut-mode = <0>; /* tshut mode 0:CRU 1:GPIO */ rockchip,hw-tshut-polarity = <0>; /* tshut polarity 0:LOW 1:HIGH */
- whole.
conditions:
- adc-keys {
button-recovery {
label = "Recovery";
- gpio-keys {
power {
wakeup-source;
- gpio-leds {
mmc_led: led-1 {
- ir: ir-receiver { compatible = "gpio-ir-receiver";
pinctrl-names = "default"; pinctrl-0 = <&ir_int>; };gpios = <&gpio8 RK_PA1 GPIO_ACTIVE_LOW>;
enable-active-high;
sound-i2s {
"Analog", "ROUT2";
pinctrl-names = "default"; pinctrl-0 = <&host_vbus_drv>;gpio = <&gpio0 RK_PB6 GPIO_ACTIVE_HIGH>;
* property
+&sdio0 {
- bus-width = <4>;
- cap-sd-highspeed;
- cap-sdio-irq;
- mmc-pwrseq = <&sdio_pwrseq>;
- non-removable;
- pinctrl-0 = <&sdio0_bus4 &sdio0_cmd &sdio0_clk &sdio0_int>;
- vmmc-supply = <&vcc_io>;
- vqmmc-supply = <&vcc_18>;
- status = "okay";
- &sdmmc { bus-width = <4>; cap-mmc-highspeed; cap-sd-highspeed; card-detect-delay = <200>; disable-wp; /* wp not hooked up */
&i2c0 {
- hym8563@51 {
- hym8563: hym8563@51 { compatible = "haoyu,hym8563"; reg = <0x51>; #clock-cells = <0>; clock-frequency = <32768>; clock-output-names = "xin32k"; interrupt-parent = <&gpio0>;
+&i2c2 {
- status = "okay";
- es8388: es8388@10 {
reg = <0x10>;
- &i2c5 { status = "okay"; };
+&i2s {
- status = "okay";
- &pinctrl { ir { ir_int: ir-int {
keys {
pwr_key: pwr-key {
headphone {
hp_det: hp-det {
sata {
- sdio {
}; }; };rockchip,pins = <4 RK_PD4 RK_FUNC_GPIO &pcfg_pull_none>;
+&saradc {
- status = "okay";
reg-shift = <2>; };
+&usbphy1 {
- vbus-supply = <&vcc_usb_host>;
- &usb_host0_ehci { status = "okay"; };
+&usb_host1 {
- status = "okay";
+&usb_otg {
- status = "okay";
chosen {
&emmc {
+&hdmi {
- pinctrl-0 = <&hdmi_cec_c0>;
- Copyright (c) 2017 Fuzhou Rockchip Electronics Co., Ltd.
/dts-v1/;
- chosen {
-&pinctrl {
- usb {
-&pwm1 {
- status = "okay";
-&usb_host1 {
- status = "okay";
- model = "Rockchip RK3288 Asus Tinker Board";
- compatible = "asus,rk3288-tinker", "rockchip,rk3288"; };
- whole.
conditions:
- chosen {
- memory { device_type = "memory"; reg = <0x0 0x80000000>;
@@ -48,23 +19,26 @@
clock-frequency = <125000000>; clock-output-names = "ext_gmac";#clock-cells = <0>;
#clock-cells = <0>;
#size-cells = <0>;
autorepeat;
button@0 {
}; };wakeup-source; debounce-interval = <100>;
pwr-led {
act_led: led-0 {
pwr_led: led-2 {
};gpios = <&gpio0 RK_PA3 GPIO_ACTIVE_HIGH>; linux,default-trigger = "default-on";
act-led {
- sdio_pwrseq: sdio-pwrseq {
- sound {
}; };sound-dai = <&i2s>;
vcc_sd: sdmmc-regulator { compatible = "regulator-fixed"; gpio = <&gpio7 11 GPIO_ACTIVE_LOW>;*/
enable-active-high;
-&sdmmc {
- bus-width = <4>;
- cap-sd-highspeed;
- num-slots = <1>;
- status = "okay";
- supports-sd;
-&gpu {
- status = "okay";
+&cpu_opp_table {
opp-1704000000 {
opp-1800000000 {
&gmac {
- phy-supply = <&vcc33_lan>; pinctrl-names = "default"; pinctrl-0 = <&rgmii_pins>;
- snps,reset-delays-us = <0 10000 1000000>; tx_delay = <0x30>; rx_delay = <0x10>; status = "okay"; };
+&gpu {
- status = "okay";
&i2c0 {
status = "okay";
#clock-cells = <1>;
rockchip,system-power-controller; wakeup-source;pinctrl-0 = <&pmic_int &global_pwroff &dvs_1 &dvs_2>;
#clock-cells = <1>;
vcc9-supply = <&vcc_io>; vcc10-supply = <&vcc_io>; vcc11-supply = <&vcc_sys>; vcc12-supply = <&vcc_io>;vcc8-supply = <&vcc_io>;
reg = <0x1a>;
-&wdt { +&i2s {
- #sound-dai-cells = <0>; status = "okay"; };
+&io_domains {
- status = "okay";
+&pinctrl {
bias-pull-up;
- backlight {
bl_en: bl-en {
- buttons {
pwrbtn: pwrbtn {
- eth_phy {
- pmic {
dvs_1: dvs-1 {
dvs_2: dvs-2 {
- sdmmc {
- usb {
pwr_3g: pwr-3g {
- sdio {
- status ="okay";
- status = "okay";
+&sdmmc {
- bus-width = <4>;
- cap-sd-highspeed;
- broken-cd;
- status = "okay";
- vmmc-supply = <&vcc33_sd>;
+&sdio0 {
- bus-width = <4>;
- cap-sd-highspeed;
- cap-sdio-irq;
- keep-power-in-suspend;
- max-frequency = <50000000>;
- non-removable;
- pinctrl-0 = <&sdio0_bus4>, <&sdio0_cmd>, <&sdio0_clk>, <&sdio0_int>;
- sd-uhs-sdr12;
- sd-uhs-sdr25;
- sd-uhs-sdr50;
- status = "okay";
+&tsadc {
status = "okay"; };
&uart0 {
-&tsadc {
- status = "okay";
&usb_otg {
- status= "okay";
status = "okay"; };
&vopb {
-&pinctrl {
bias-pull-up;
- backlight {
bl_en: bl-en {
- buttons {
pwrbtn: pwrbtn {
- eth_phy {
- pmic {
- sdmmc {
- usb {
pwr_3g: pwr-3g {
+&wdt {
Sync rk3288-veyron DT from Linux version 5.17.
Signed-off-by: Johan Jonker jbx6244@gmail.com ---
Changed V3: update change reg size
Changed V2: update add label spi_flash veyron --- arch/arm/dts/rk3288-veyron-analog-audio.dtsi | 99 +++ .../dts/rk3288-veyron-broadcom-bluetooth.dtsi | 22 + arch/arm/dts/rk3288-veyron-chromebook.dtsi | 115 ++-- arch/arm/dts/rk3288-veyron-edp.dtsi | 141 ++++ arch/arm/dts/rk3288-veyron-jerry.dts | 506 +++++++++++--- arch/arm/dts/rk3288-veyron-mickey.dts | 343 +++++++--- arch/arm/dts/rk3288-veyron-minnie.dts | 441 +++++++----- arch/arm/dts/rk3288-veyron-sdmmc.dtsi | 89 +++ arch/arm/dts/rk3288-veyron-speedy.dts | 303 ++++++-- arch/arm/dts/rk3288-veyron.dtsi | 645 ++++++------------ 10 files changed, 1799 insertions(+), 905 deletions(-) create mode 100644 arch/arm/dts/rk3288-veyron-analog-audio.dtsi create mode 100644 arch/arm/dts/rk3288-veyron-broadcom-bluetooth.dtsi create mode 100644 arch/arm/dts/rk3288-veyron-edp.dtsi create mode 100644 arch/arm/dts/rk3288-veyron-sdmmc.dtsi
diff --git a/arch/arm/dts/rk3288-veyron-analog-audio.dtsi b/arch/arm/dts/rk3288-veyron-analog-audio.dtsi new file mode 100644 index 00000000..51208d16 --- /dev/null +++ b/arch/arm/dts/rk3288-veyron-analog-audio.dtsi @@ -0,0 +1,99 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Google Veyron (and derivatives) fragment for the max98090 audio + * codec and analog headphone jack. + * + * Copyright 2016 Google, Inc + */ + +/ { + sound { + compatible = "rockchip,rockchip-audio-max98090"; + pinctrl-names = "default"; + pinctrl-0 = <&mic_det>, <&hp_det>; + rockchip,model = "VEYRON-I2S"; + rockchip,i2s-controller = <&i2s>; + rockchip,audio-codec = <&max98090>; + rockchip,hp-det-gpios = <&gpio6 RK_PA5 GPIO_ACTIVE_HIGH>; + rockchip,mic-det-gpios = <&gpio6 RK_PB3 GPIO_ACTIVE_LOW>; + rockchip,headset-codec = <&headsetcodec>; + rockchip,hdmi-codec = <&hdmi>; + }; +}; + +&i2c2 { + max98090: max98090@10 { + compatible = "maxim,max98090"; + reg = <0x10>; + interrupt-parent = <&gpio6>; + interrupts = <RK_PA7 IRQ_TYPE_EDGE_FALLING>; + clock-names = "mclk"; + clocks = <&cru SCLK_I2S0_OUT>; + pinctrl-names = "default"; + pinctrl-0 = <&int_codec>; + }; +}; + +&i2c4 { + headsetcodec: ts3a227e@3b { + compatible = "ti,ts3a227e"; + reg = <0x3b>; + interrupt-parent = <&gpio0>; + interrupts = <RK_PA3 IRQ_TYPE_LEVEL_LOW>; + pinctrl-names = "default"; + pinctrl-0 = <&ts3a227e_int_l>; + ti,micbias = <7>; /* MICBIAS = 2.8V */ + }; +}; + +&i2s { + status = "okay"; +}; + +&io_domains { + audio-supply = <&vcc18_codec>; +}; + +&rk808 { + vcc10-supply = <&vcc33_sys>; + + regulators { + vcc18_codec: LDO_REG6 { + regulator-name = "vcc18_codec"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + }; +}; + +&pinctrl { + codec { + hp_det: hp-det { + rockchip,pins = <6 RK_PA5 RK_FUNC_GPIO &pcfg_pull_up>; + }; + + /* + * HACK: We're going to _pull down_ this _active low_ interrupt + * so that it never fires. We don't need this interrupt because + * we've got a ts3a227e chip but the driver requires it. + */ + int_codec: int-codec { + rockchip,pins = <6 RK_PA7 RK_FUNC_GPIO &pcfg_pull_down>; + }; + + mic_det: mic-det { + rockchip,pins = <6 RK_PB3 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + headset { + ts3a227e_int_l: ts3a227e-int-l { + rockchip,pins = <0 RK_PA3 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; +}; diff --git a/arch/arm/dts/rk3288-veyron-broadcom-bluetooth.dtsi b/arch/arm/dts/rk3288-veyron-broadcom-bluetooth.dtsi new file mode 100644 index 00000000..a10d25ac --- /dev/null +++ b/arch/arm/dts/rk3288-veyron-broadcom-bluetooth.dtsi @@ -0,0 +1,22 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Google Veyron (and derivatives) fragment for the Broadcom 43450 bluetooth + * chip. + * + * Copyright 2019 Google, Inc + */ + +&uart0 { + bluetooth { + pinctrl-names = "default"; + pinctrl-0 = <&bt_host_wake_l>, <&bt_enable_l>, + <&bt_dev_wake>; + + compatible = "brcm,bcm43540-bt"; + host-wakeup-gpios = <&gpio4 RK_PD7 GPIO_ACTIVE_HIGH>; + shutdown-gpios = <&gpio4 RK_PD5 GPIO_ACTIVE_HIGH>; + device-wakeup-gpios = <&gpio4 RK_PD2 GPIO_ACTIVE_HIGH>; + max-speed = <3000000>; + brcm,bt-pcm-int-params = [01 02 00 01 01]; + }; +}; diff --git a/arch/arm/dts/rk3288-veyron-chromebook.dtsi b/arch/arm/dts/rk3288-veyron-chromebook.dtsi index 143eaae2..05112c25 100644 --- a/arch/arm/dts/rk3288-veyron-chromebook.dtsi +++ b/arch/arm/dts/rk3288-veyron-chromebook.dtsi @@ -1,39 +1,45 @@ -// SPDX-License-Identifier: GPL-2.0 +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) /* * Google Veyron (and derivatives) board device tree source + * Chromebook specific parts * - * Copyright 2014 Google, Inc + * Copyright 2015 Google, Inc */
#include <dt-bindings/clock/rockchip,rk808.h> #include <dt-bindings/input/input.h> #include "rk3288-veyron.dtsi" +#include "rk3288-veyron-analog-audio.dtsi" +#include "rk3288-veyron-edp.dtsi" +#include "rk3288-veyron-sdmmc.dtsi"
/ { aliases { + /* Assign 20 so we don't get confused w/ builtin ones */ i2c20 = &i2c_tunnel; - video0 = &vopl; - video1 = &vopb; - }; - - gpio_keys: gpio-keys { - pinctrl-0 = <&pwr_key_h &ap_lid_int_l>; - lid { - label = "Lid"; - gpios = <&gpio0 6 GPIO_ACTIVE_LOW>; - linux,code = <0>; /* SW_LID */ - linux,input-type = <5>; /* EV_SW */ - debounce-interval = <1>; - gpio-key,wakeup; - }; };
gpio-charger { compatible = "gpio-charger"; - gpios = <&gpio0 8 GPIO_ACTIVE_HIGH>; + charger-type = "mains"; + gpios = <&gpio0 RK_PB0 GPIO_ACTIVE_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&ac_present_ap>; - charger-type = "mains"; + }; + + lid_switch: lid-switch { + compatible = "gpio-keys"; + pinctrl-names = "default"; + pinctrl-0 = <&ap_lid_int_l>; + + lid { + label = "Lid"; + gpios = <&gpio0 RK_PA6 GPIO_ACTIVE_LOW>; + wakeup-source; + linux,code = <SW_LID>; + linux,input-type = <EV_SW>; + debounce-interval = <1>; + }; };
/* A non-regulated voltage from power supply or battery */ @@ -56,7 +62,7 @@ vcc5_host1: vcc5-host1-regulator { compatible = "regulator-fixed"; enable-active-high; - gpio = <&gpio0 11 GPIO_ACTIVE_HIGH>; + gpio = <&gpio0 RK_PB3 GPIO_ACTIVE_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&host1_pwr_en>; regulator-name = "vcc5_host1"; @@ -68,7 +74,7 @@ vcc5v_otg: vcc5v-otg-regulator { compatible = "regulator-fixed"; enable-active-high; - gpio = <&gpio0 12 GPIO_ACTIVE_HIGH>; + gpio = <&gpio0 RK_PB4 GPIO_ACTIVE_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&usbotg_pwren_h>; regulator-name = "vcc5_host2"; @@ -78,34 +84,34 @@ };
&rk808 { + vcc11-supply = <&vcc_5v>; + regulators { vcc33_ccd: LDO_REG8 { + regulator-name = "vcc33_ccd"; regulator-always-on; regulator-boot-on; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; - regulator-name = "vcc33_ccd"; - regulator-suspend-mem-disabled; + regulator-state-mem { + regulator-off-in-suspend; + }; }; }; };
&spi0 { status = "okay"; - spi-activate-delay = <100>; - spi-max-frequency = <3000000>; - spi-deactivate-delay = <200>;
cros_ec: ec@0 { compatible = "google,cros-ec-spi"; - spi-max-frequency = <3000000>; + reg = <0>; + google,cros-ec-spi-pre-delay = <30>; interrupt-parent = <&gpio7>; - interrupts = <7 IRQ_TYPE_LEVEL_LOW>; - ec-interrupt = <&gpio7 7 GPIO_ACTIVE_LOW>; + interrupts = <RK_PA7 IRQ_TYPE_LEVEL_LOW>; pinctrl-names = "default"; pinctrl-0 = <&ec_int>; - reg = <0>; - google,cros-ec-spi-pre-delay = <30>; + spi-max-frequency = <3000000>;
i2c_tunnel: i2c-tunnel { compatible = "google,cros-ec-i2c-tunnel"; @@ -118,86 +124,59 @@
&i2c4 { trackpad@15 { - compatible = "elan,i2c_touchpad"; + compatible = "elan,ekth3000"; + reg = <0x15>; interrupt-parent = <&gpio7>; - interrupts = <3 IRQ_TYPE_EDGE_FALLING>; + interrupts = <RK_PA3 IRQ_TYPE_EDGE_FALLING>; pinctrl-names = "default"; pinctrl-0 = <&trackpad_int>; - reg = <0x15>; vcc-supply = <&vcc33_io>; wakeup-source; }; };
&pinctrl { - pinctrl-0 = < - /* Common for sleep and wake, but no owners */ - &ddr0_retention - &ddrio_pwroff - &global_pwroff - - /* Wake only */ - &suspend_l_wake - &bt_dev_wake_awake - >; - pinctrl-1 = < - /* Common for sleep and wake, but no owners */ - &ddr0_retention - &ddrio_pwroff - &global_pwroff - - /* Sleep only */ - &suspend_l_sleep - &bt_dev_wake_sleep - >; - buttons { ap_lid_int_l: ap-lid-int-l { - rockchip,pins = <0 6 RK_FUNC_GPIO &pcfg_pull_up>; + rockchip,pins = <0 RK_PA6 RK_FUNC_GPIO &pcfg_pull_up>; }; };
charger { ac_present_ap: ac-present-ap { - rockchip,pins = <0 8 RK_FUNC_GPIO &pcfg_pull_up>; + rockchip,pins = <0 RK_PB0 RK_FUNC_GPIO &pcfg_pull_up>; }; };
cros-ec { ec_int: ec-int { - rockchip,pins = <7 7 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - sdmmc { - sdmmc_wp_gpio: sdmmc-wp-gpio { - rockchip,pins = <7 10 RK_FUNC_GPIO &pcfg_pull_up>; + rockchip,pins = <7 RK_PA7 RK_FUNC_GPIO &pcfg_pull_none>; }; };
suspend { suspend_l_wake: suspend-l-wake { - rockchip,pins = <0 17 RK_FUNC_GPIO &pcfg_output_low>; + rockchip,pins = <0 RK_PC1 RK_FUNC_GPIO &pcfg_output_low>; };
suspend_l_sleep: suspend-l-sleep { - rockchip,pins = <0 17 RK_FUNC_GPIO &pcfg_output_high>; + rockchip,pins = <0 RK_PC1 RK_FUNC_GPIO &pcfg_output_high>; }; };
trackpad { trackpad_int: trackpad-int { - rockchip,pins = <7 3 RK_FUNC_GPIO &pcfg_pull_up>; + rockchip,pins = <7 RK_PA3 RK_FUNC_GPIO &pcfg_pull_up>; }; };
usb-host { host1_pwr_en: host1-pwr-en { - rockchip,pins = <0 11 RK_FUNC_GPIO &pcfg_pull_none>; + rockchip,pins = <0 RK_PB3 RK_FUNC_GPIO &pcfg_pull_none>; };
usbotg_pwren_h: usbotg-pwren-h { - rockchip,pins = <0 12 RK_FUNC_GPIO &pcfg_pull_none>; + rockchip,pins = <0 RK_PB4 RK_FUNC_GPIO &pcfg_pull_none>; }; }; }; diff --git a/arch/arm/dts/rk3288-veyron-edp.dtsi b/arch/arm/dts/rk3288-veyron-edp.dtsi new file mode 100644 index 00000000..32c0f107 --- /dev/null +++ b/arch/arm/dts/rk3288-veyron-edp.dtsi @@ -0,0 +1,141 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Google Veyron (and derivatives) fragment for the edp displays + * + * Copyright 2019 Google LLC + */ + +/ { + backlight_regulator: backlight-regulator { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio2 RK_PB4 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&bl_pwr_en>; + regulator-name = "backlight_regulator"; + vin-supply = <&vcc33_sys>; + startup-delay-us = <15000>; + }; + + panel_regulator: panel-regulator { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio7 RK_PB6 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&lcd_enable_h>; + regulator-name = "panel_regulator"; + vin-supply = <&vcc33_sys>; + }; + + vcc18_lcd: vcc18-lcd { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio2 RK_PB5 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&avdd_1v8_disp_en>; + regulator-name = "vcc18_lcd"; + regulator-always-on; + regulator-boot-on; + vin-supply = <&vcc18_wl>; + }; + + backlight: backlight { + compatible = "pwm-backlight"; + brightness-levels = <0 255>; + num-interpolated-steps = <255>; + default-brightness-level = <128>; + enable-gpios = <&gpio7 RK_PA2 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&bl_en>; + pwms = <&pwm0 0 1000000 0>; + post-pwm-on-delay-ms = <10>; + pwm-off-delay-ms = <10>; + power-supply = <&backlight_regulator>; + }; + + panel: panel { + compatible = "innolux,n116bge"; + status = "okay"; + power-supply = <&panel_regulator>; + backlight = <&backlight>; + + panel-timing { + clock-frequency = <74250000>; + hactive = <1366>; + hfront-porch = <136>; + hback-porch = <60>; + hsync-len = <30>; + hsync-active = <0>; + vactive = <768>; + vfront-porch = <8>; + vback-porch = <12>; + vsync-len = <12>; + vsync-active = <0>; + }; + + ports { + panel_in: port { + panel_in_edp: endpoint { + remote-endpoint = <&edp_out_panel>; + }; + }; + }; + }; +}; + +&edp { + status = "okay"; + + pinctrl-names = "default"; + pinctrl-0 = <&edp_hpd>; + + ports { + edp_out: port@1 { + reg = <1>; + #address-cells = <1>; + #size-cells = <0>; + edp_out_panel: endpoint@0 { + reg = <0>; + remote-endpoint = <&panel_in_edp>; + }; + }; + }; +}; + +&edp_phy { + status = "okay"; +}; + +&pwm0 { + status = "okay"; +}; + +&vopl { + status = "okay"; +}; + +&vopl_mmu { + status = "okay"; +}; + +&pinctrl { + backlight { + bl_pwr_en: bl_pwr_en { + rockchip,pins = <2 RK_PB4 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + bl_en: bl-en { + rockchip,pins = <7 RK_PA2 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + lcd { + lcd_enable_h: lcd-en { + rockchip,pins = <7 RK_PB6 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + avdd_1v8_disp_en: avdd-1v8-disp-en { + rockchip,pins = <2 RK_PB5 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; +}; diff --git a/arch/arm/dts/rk3288-veyron-jerry.dts b/arch/arm/dts/rk3288-veyron-jerry.dts index 40fee55c..2c916c50 100644 --- a/arch/arm/dts/rk3288-veyron-jerry.dts +++ b/arch/arm/dts/rk3288-veyron-jerry.dts @@ -1,8 +1,8 @@ -// SPDX-License-Identifier: GPL-2.0 +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) /* * Google Veyron Jerry Rev 3+ board device tree source * - * Copyright 2014 Google, Inc + * Copyright 2015 Google, Inc */
/dts-v1/; @@ -11,162 +11,454 @@
/ { model = "Google Jerry"; - compatible = "google,veyron-jerry-rev7", "google,veyron-jerry-rev6", + compatible = "google,veyron-jerry-rev15", "google,veyron-jerry-rev14", + "google,veyron-jerry-rev13", "google,veyron-jerry-rev12", + "google,veyron-jerry-rev11", "google,veyron-jerry-rev10", + "google,veyron-jerry-rev7", "google,veyron-jerry-rev6", "google,veyron-jerry-rev5", "google,veyron-jerry-rev4", "google,veyron-jerry-rev3", "google,veyron-jerry", "google,veyron", "rockchip,rk3288"; - - chosen { - stdout-path = &uart2; - }; - - panel_regulator: panel-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio7 14 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&lcd_enable_h>; - regulator-name = "panel_regulator"; - vin-supply = <&vcc33_sys>; - }; - - vcc18_lcd: vcc18-lcd { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio2 13 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&avdd_1v8_disp_en>; - regulator-name = "vcc18_lcd"; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vcc18_wl>; - }; - - backlight_regulator: backlight-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio2 12 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&bl_pwr_en>; - regulator-name = "backlight_regulator"; - vin-supply = <&vcc33_sys>; - startup-delay-us = <15000>; - }; - - sound { - compatible = "rockchip,audio-max98090-jerry"; - - cpu { - sound-dai = <&i2s 0>; - }; - - codec { - sound-dai = <&max98090 0>; - }; - }; -}; - -&gpio_keys { - power { - gpios = <&gpio0 5 GPIO_ACTIVE_LOW>; - }; -}; - -&backlight { - power-supply = <&backlight_regulator>; -}; - -&panel { - power-supply= <&panel_regulator>; };
&rk808 { pinctrl-names = "default"; pinctrl-0 = <&pmic_int_l &dvs_1 &dvs_2>; - dvs-gpios = <&gpio7 12 GPIO_ACTIVE_HIGH>, - <&gpio7 15 GPIO_ACTIVE_HIGH>; + dvs-gpios = <&gpio7 RK_PB4 GPIO_ACTIVE_HIGH>, + <&gpio7 RK_PB7 GPIO_ACTIVE_HIGH>;
regulators { mic_vcc: LDO_REG2 { + regulator-name = "mic_vcc"; regulator-always-on; regulator-boot-on; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; - regulator-name = "mic_vcc"; - regulator-suspend-mem-disabled; + regulator-state-mem { + regulator-off-in-suspend; + }; }; }; };
+&sdio0 { + #address-cells = <1>; + #size-cells = <0>; + + mwifiex: wifi@1 { + compatible = "marvell,sd8897"; + reg = <1>; + + marvell,caldata-txpwrlimit-2g = /bits/ 8 < +0x01 0x00 0x06 0x00 0x08 0x02 0x89 0x01 +0x24 0x00 0x67 0x09 0x14 0x01 0x00 0x0f 0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0c +0x05 0x0c 0x06 0x0c 0x07 0x09 0x08 0x09 0x09 0x09 0x0a 0x0c 0x0b 0x0c 0x0c 0x0c +0x0d 0x09 0x0e 0x09 0x0f 0x09 0x89 0x01 0x24 0x00 0x67 0x09 0x14 0x02 0x00 0x0f +0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0c 0x05 0x0c 0x06 0x0c 0x07 0x09 0x08 0x09 +0x09 0x09 0x0a 0x0c 0x0b 0x0c 0x0c 0x0c 0x0d 0x09 0x0e 0x09 0x0f 0x09 0x89 0x01 +0x24 0x00 0x67 0x09 0x14 0x03 0x00 0x0f 0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0c +0x05 0x0c 0x06 0x0c 0x07 0x09 0x08 0x09 0x09 0x09 0x0a 0x0c 0x0b 0x0c 0x0c 0x0c +0x0d 0x09 0x0e 0x09 0x0f 0x09 0x89 0x01 0x24 0x00 0x67 0x09 0x14 0x04 0x00 0x0f +0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0c 0x05 0x0c 0x06 0x0c 0x07 0x09 0x08 0x09 +0x09 0x09 0x0a 0x0c 0x0b 0x0c 0x0c 0x0c 0x0d 0x09 0x0e 0x09 0x0f 0x09 0x89 0x01 +0x24 0x00 0x67 0x09 0x14 0x05 0x00 0x0f 0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0c +0x05 0x0c 0x06 0x0c 0x07 0x09 0x08 0x09 0x09 0x09 0x0a 0x0c 0x0b 0x0c 0x0c 0x0c +0x0d 0x09 0x0e 0x09 0x0f 0x09 0x89 0x01 0x24 0x00 0x67 0x09 0x14 0x06 0x00 0x0f +0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0c 0x05 0x0c 0x06 0x0c 0x07 0x09 0x08 0x09 +0x09 0x09 0x0a 0x0c 0x0b 0x0c 0x0c 0x0c 0x0d 0x09 0x0e 0x09 0x0f 0x09 0x89 0x01 +0x24 0x00 0x67 0x09 0x14 0x07 0x00 0x0f 0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0c +0x05 0x0c 0x06 0x0c 0x07 0x09 0x08 0x09 0x09 0x09 0x0a 0x0c 0x0b 0x0c 0x0c 0x0c +0x0d 0x09 0x0e 0x09 0x0f 0x09 0x89 0x01 0x24 0x00 0x67 0x09 0x14 0x08 0x00 0x0f +0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0c 0x05 0x0c 0x06 0x0c 0x07 0x09 0x08 0x09 +0x09 0x09 0x0a 0x0c 0x0b 0x0c 0x0c 0x0c 0x0d 0x09 0x0e 0x09 0x0f 0x09 0x89 0x01 +0x24 0x00 0x67 0x09 0x14 0x09 0x00 0x0f 0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0c +0x05 0x0c 0x06 0x0c 0x07 0x09 0x08 0x09 0x09 0x09 0x0a 0x0c 0x0b 0x0c 0x0c 0x0c +0x0d 0x09 0x0e 0x09 0x0f 0x09 0x89 0x01 0x24 0x00 0x67 0x09 0x14 0x0a 0x00 0x0f +0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0c 0x05 0x0c 0x06 0x0c 0x07 0x09 0x08 0x09 +0x09 0x09 0x0a 0x0c 0x0b 0x0c 0x0c 0x0c 0x0d 0x09 0x0e 0x09 0x0f 0x09 0x89 0x01 +0x24 0x00 0x67 0x09 0x14 0x0b 0x00 0x0f 0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0c +0x05 0x0c 0x06 0x0c 0x07 0x09 0x08 0x09 0x09 0x09 0x0a 0x0c 0x0b 0x0c 0x0c 0x0c +0x0d 0x09 0x0e 0x09 0x0f 0x09 0x89 0x01 0x24 0x00 0x67 0x09 0x14 0x0c 0x00 0x0f +0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0c 0x05 0x0c 0x06 0x0c 0x07 0x09 0x08 0x09 +0x09 0x09 0x0a 0x0c 0x0b 0x0c 0x0c 0x0c 0x0d 0x09 0x0e 0x09 0x0f 0x09 0x89 0x01 +0x24 0x00 0x67 0x09 0x14 0x0d 0x00 0x0f 0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0c +0x05 0x0c 0x06 0x0c 0x07 0x09 0x08 0x09 0x09 0x09 0x0a 0x0c 0x0b 0x0c 0x0c 0x0c +0x0d 0x09 0x0e 0x09 0x0f 0x09>; + + marvell,caldata-txpwrlimit-5g-sub0 = /bits/ 8 < +0x01 0x00 0x06 0x00 0xf0 0x01 0x89 0x01 +0x3a 0x00 0x88 0x13 0x14 0x24 0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0a 0x05 0x0a +0x06 0x0a 0x07 0x09 0x08 0x09 0x09 0x09 0x0a 0x0a 0x0b 0x0a 0x0c 0x0a 0x0d 0x09 +0x0e 0x09 0x0f 0x09 0x10 0x05 0x11 0x05 0x12 0x05 0x13 0x05 0x14 0x05 0x15 0x05 +0x16 0x05 0x17 0x05 0x18 0x05 0x19 0x05 0x1a 0x05 0x1b 0x05 0x89 0x01 0x3a 0x00 +0x88 0x13 0x14 0x28 0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0a 0x05 0x0a 0x06 0x0a +0x07 0x09 0x08 0x09 0x09 0x09 0x0a 0x0a 0x0b 0x0a 0x0c 0x0a 0x0d 0x09 0x0e 0x09 +0x0f 0x09 0x10 0x05 0x11 0x05 0x12 0x05 0x13 0x05 0x14 0x05 0x15 0x05 0x16 0x05 +0x17 0x05 0x18 0x05 0x19 0x05 0x1a 0x05 0x1b 0x05 0x89 0x01 0x3a 0x00 0x88 0x13 +0x14 0x2c 0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0a 0x05 0x0a 0x06 0x0a 0x07 0x09 +0x08 0x09 0x09 0x09 0x0a 0x0a 0x0b 0x0a 0x0c 0x0a 0x0d 0x09 0x0e 0x09 0x0f 0x09 +0x10 0x05 0x11 0x05 0x12 0x05 0x13 0x05 0x14 0x05 0x15 0x05 0x16 0x05 0x17 0x05 +0x18 0x05 0x19 0x05 0x1a 0x05 0x1b 0x05 0x89 0x01 0x3a 0x00 0x88 0x13 0x14 0x30 +0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0a 0x05 0x0a 0x06 0x0a 0x07 0x09 0x08 0x09 +0x09 0x09 0x0a 0x0a 0x0b 0x0a 0x0c 0x0a 0x0d 0x09 0x0e 0x09 0x0f 0x09 0x10 0x05 +0x11 0x05 0x12 0x05 0x13 0x05 0x14 0x05 0x15 0x05 0x16 0x05 0x17 0x05 0x18 0x05 +0x19 0x05 0x1a 0x05 0x1b 0x05 0x89 0x01 0x3a 0x00 0x88 0x13 0x14 0x34 0x01 0x0c +0x02 0x0c 0x03 0x0c 0x04 0x0a 0x05 0x0a 0x06 0x0a 0x07 0x09 0x08 0x09 0x09 0x09 +0x0a 0x0a 0x0b 0x0a 0x0c 0x0a 0x0d 0x09 0x0e 0x09 0x0f 0x09 0x10 0x05 0x11 0x05 +0x12 0x05 0x13 0x05 0x14 0x05 0x15 0x05 0x16 0x05 0x17 0x05 0x18 0x05 0x19 0x05 +0x1a 0x05 0x1b 0x05 0x89 0x01 0x3a 0x00 0x88 0x13 0x14 0x38 0x01 0x0c 0x02 0x0c +0x03 0x0c 0x04 0x0a 0x05 0x0a 0x06 0x0a 0x07 0x09 0x08 0x09 0x09 0x09 0x0a 0x0a +0x0b 0x0a 0x0c 0x0a 0x0d 0x09 0x0e 0x09 0x0f 0x09 0x10 0x05 0x11 0x05 0x12 0x05 +0x13 0x05 0x14 0x05 0x15 0x05 0x16 0x05 0x17 0x05 0x18 0x05 0x19 0x05 0x1a 0x05 +0x1b 0x05 0x89 0x01 0x3a 0x00 0x88 0x13 0x14 0x3c 0x01 0x0c 0x02 0x0c 0x03 0x0c +0x04 0x0a 0x05 0x0a 0x06 0x0a 0x07 0x09 0x08 0x09 0x09 0x09 0x0a 0x0a 0x0b 0x0a +0x0c 0x0a 0x0d 0x09 0x0e 0x09 0x0f 0x09 0x10 0x05 0x11 0x05 0x12 0x05 0x13 0x05 +0x14 0x05 0x15 0x05 0x16 0x05 0x17 0x05 0x18 0x05 0x19 0x05 0x1a 0x05 0x1b 0x05 +0x89 0x01 0x3a 0x00 0x88 0x13 0x14 0x40 0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0a +0x05 0x0a 0x06 0x0a 0x07 0x09 0x08 0x09 0x09 0x09 0x0a 0x0a 0x0b 0x0a 0x0c 0x0a +0x0d 0x09 0x0e 0x09 0x0f 0x09 0x10 0x05 0x11 0x05 0x12 0x05 0x13 0x05 0x14 0x05 +0x15 0x05 0x16 0x05 0x17 0x05 0x18 0x05 0x19 0x05 0x1a 0x05 0x1b 0x05>; + + marvell,caldata-txpwrlimit-5g-sub1 = /bits/ 8 < +0x01 0x00 0x06 0x00 0xaa 0x02 0x89 0x01 +0x3a 0x00 0x88 0x13 0x14 0x64 0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0a 0x05 0x0a +0x06 0x0a 0x07 0x09 0x08 0x09 0x09 0x09 0x0a 0x0a 0x0b 0x0a 0x0c 0x0a 0x0d 0x09 +0x0e 0x09 0x0f 0x09 0x10 0x05 0x11 0x05 0x12 0x05 0x13 0x05 0x14 0x05 0x15 0x05 +0x16 0x05 0x17 0x05 0x18 0x05 0x19 0x05 0x1a 0x05 0x1b 0x05 0x89 0x01 0x3a 0x00 +0x88 0x13 0x14 0x68 0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0a 0x05 0x0a 0x06 0x0a +0x07 0x09 0x08 0x09 0x09 0x09 0x0a 0x0a 0x0b 0x0a 0x0c 0x0a 0x0d 0x09 0x0e 0x09 +0x0f 0x09 0x10 0x05 0x11 0x05 0x12 0x05 0x13 0x05 0x14 0x05 0x15 0x05 0x16 0x05 +0x17 0x05 0x18 0x05 0x19 0x05 0x1a 0x05 0x1b 0x05 0x89 0x01 0x3a 0x00 0x88 0x13 +0x14 0x6c 0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0a 0x05 0x0a 0x06 0x0a 0x07 0x09 +0x08 0x09 0x09 0x09 0x0a 0x0a 0x0b 0x0a 0x0c 0x0a 0x0d 0x09 0x0e 0x09 0x0f 0x09 +0x10 0x05 0x11 0x05 0x12 0x05 0x13 0x05 0x14 0x05 0x15 0x05 0x16 0x05 0x17 0x05 +0x18 0x05 0x19 0x05 0x1a 0x05 0x1b 0x05 0x89 0x01 0x3a 0x00 0x88 0x13 0x14 0x70 +0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0a 0x05 0x0a 0x06 0x0a 0x07 0x09 0x08 0x09 +0x09 0x09 0x0a 0x0a 0x0b 0x0a 0x0c 0x0a 0x0d 0x09 0x0e 0x09 0x0f 0x09 0x10 0x05 +0x11 0x05 0x12 0x05 0x13 0x05 0x14 0x05 0x15 0x05 0x16 0x05 0x17 0x05 0x18 0x05 +0x19 0x05 0x1a 0x05 0x1b 0x05 0x89 0x01 0x3a 0x00 0x88 0x13 0x14 0x74 0x01 0x0c +0x02 0x0c 0x03 0x0c 0x04 0x0a 0x05 0x0a 0x06 0x0a 0x07 0x09 0x08 0x09 0x09 0x09 +0x0a 0x0a 0x0b 0x0a 0x0c 0x0a 0x0d 0x09 0x0e 0x09 0x0f 0x09 0x10 0x05 0x11 0x05 +0x12 0x05 0x13 0x05 0x14 0x05 0x15 0x05 0x16 0x05 0x17 0x05 0x18 0x05 0x19 0x05 +0x1a 0x05 0x1b 0x05 0x89 0x01 0x3a 0x00 0x88 0x13 0x14 0x78 0x01 0x0c 0x02 0x0c +0x03 0x0c 0x04 0x0a 0x05 0x0a 0x06 0x0a 0x07 0x09 0x08 0x09 0x09 0x09 0x0a 0x0a +0x0b 0x0a 0x0c 0x0a 0x0d 0x09 0x0e 0x09 0x0f 0x09 0x10 0x05 0x11 0x05 0x12 0x05 +0x13 0x05 0x14 0x05 0x15 0x05 0x16 0x05 0x17 0x05 0x18 0x05 0x19 0x05 0x1a 0x05 +0x1b 0x05 0x89 0x01 0x3a 0x00 0x88 0x13 0x14 0x7c 0x01 0x0c 0x02 0x0c 0x03 0x0c +0x04 0x0a 0x05 0x0a 0x06 0x0a 0x07 0x09 0x08 0x09 0x09 0x09 0x0a 0x0a 0x0b 0x0a +0x0c 0x0a 0x0d 0x09 0x0e 0x09 0x0f 0x09 0x10 0x05 0x11 0x05 0x12 0x05 0x13 0x05 +0x14 0x05 0x15 0x05 0x16 0x05 0x17 0x05 0x18 0x05 0x19 0x05 0x1a 0x05 0x1b 0x05 +0x89 0x01 0x3a 0x00 0x88 0x13 0x14 0x80 0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0a +0x05 0x0a 0x06 0x0a 0x07 0x09 0x08 0x09 0x09 0x09 0x0a 0x0a 0x0b 0x0a 0x0c 0x0a +0x0d 0x09 0x0e 0x09 0x0f 0x09 0x10 0x05 0x11 0x05 0x12 0x05 0x13 0x05 0x14 0x05 +0x15 0x05 0x16 0x05 0x17 0x05 0x18 0x05 0x19 0x05 0x1a 0x05 0x1b 0x05 0x89 0x01 +0x3a 0x00 0x88 0x13 0x14 0x84 0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0a 0x05 0x0a +0x06 0x0a 0x07 0x09 0x08 0x09 0x09 0x09 0x0a 0x0a 0x0b 0x0a 0x0c 0x0a 0x0d 0x09 +0x0e 0x09 0x0f 0x09 0x10 0x05 0x11 0x05 0x12 0x05 0x13 0x05 0x14 0x05 0x15 0x05 +0x16 0x05 0x17 0x05 0x18 0x05 0x19 0x05 0x1a 0x05 0x1b 0x05 0x89 0x01 0x3a 0x00 +0x88 0x13 0x14 0x88 0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0a 0x05 0x0a 0x06 0x0a +0x07 0x08 0x08 0x08 0x09 0x08 0x0a 0x0a 0x0b 0x0a 0x0c 0x0a 0x0d 0x08 0x0e 0x08 +0x0f 0x08 0x10 0x04 0x11 0x04 0x12 0x05 0x13 0x05 0x14 0x05 0x15 0x05 0x16 0x04 +0x17 0x04 0x18 0x05 0x19 0x05 0x1a 0x05 0x1b 0x05 0x89 0x01 0x3a 0x00 0x88 0x13 +0x14 0x8c 0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0a 0x05 0x0a 0x06 0x0a 0x07 0x08 +0x08 0x08 0x09 0x08 0x0a 0x0a 0x0b 0x0a 0x0c 0x0a 0x0d 0x08 0x0e 0x08 0x0f 0x08 +0x10 0x04 0x11 0x04 0x12 0x05 0x13 0x05 0x14 0x05 0x15 0x05 0x16 0x04 0x17 0x04 +0x18 0x05 0x19 0x05 0x1a 0x05 0x1b 0x05>; + + marvell,caldata-txpwrlimit-5g-sub2 = /bits/ 8 < +0x01 0x00 0x06 0x00 0x36 0x01 0x89 0x01 +0x3a 0x00 0x88 0x13 0x14 0x95 0x01 0x0b 0x02 0x0b 0x03 0x0b 0x04 0x0a 0x05 0x0a +0x06 0x0a 0x07 0x08 0x08 0x08 0x09 0x08 0x0a 0x0a 0x0b 0x0a 0x0c 0x0a 0x0d 0x08 +0x0e 0x08 0x0f 0x08 0x10 0x04 0x11 0x04 0x12 0x05 0x13 0x05 0x14 0x05 0x15 0x05 +0x16 0x04 0x17 0x04 0x18 0x05 0x19 0x05 0x1a 0x05 0x1b 0x05 0x89 0x01 0x3a 0x00 +0x88 0x13 0x14 0x99 0x01 0x0b 0x02 0x0b 0x03 0x0b 0x04 0x0a 0x05 0x0a 0x06 0x0a +0x07 0x08 0x08 0x08 0x09 0x08 0x0a 0x0a 0x0b 0x0a 0x0c 0x0a 0x0d 0x08 0x0e 0x08 +0x0f 0x08 0x10 0x04 0x11 0x04 0x12 0x05 0x13 0x05 0x14 0x05 0x15 0x05 0x16 0x04 +0x17 0x04 0x18 0x05 0x19 0x05 0x1a 0x05 0x1b 0x05 0x89 0x01 0x3a 0x00 0x88 0x13 +0x14 0x9d 0x01 0x0b 0x02 0x0b 0x03 0x0b 0x04 0x0a 0x05 0x0a 0x06 0x0a 0x07 0x08 +0x08 0x08 0x09 0x08 0x0a 0x0a 0x0b 0x0a 0x0c 0x0a 0x0d 0x08 0x0e 0x08 0x0f 0x08 +0x10 0x04 0x11 0x04 0x12 0x05 0x13 0x05 0x14 0x05 0x15 0x05 0x16 0x04 0x17 0x04 +0x18 0x05 0x19 0x05 0x1a 0x05 0x1b 0x05 0x89 0x01 0x3a 0x00 0x88 0x13 0x14 0xa1 +0x01 0x0b 0x02 0x0b 0x03 0x0b 0x04 0x0a 0x05 0x0a 0x06 0x0a 0x07 0x08 0x08 0x08 +0x09 0x08 0x0a 0x0a 0x0b 0x0a 0x0c 0x0a 0x0d 0x08 0x0e 0x08 0x0f 0x08 0x10 0x04 +0x11 0x04 0x12 0x05 0x13 0x05 0x14 0x05 0x15 0x05 0x16 0x04 0x17 0x04 0x18 0x05 +0x19 0x05 0x1a 0x05 0x1b 0x05 0x89 0x01 0x3a 0x00 0x88 0x13 0x14 0xa5 0x01 0x0b +0x02 0x0b 0x03 0x0b 0x04 0x0a 0x05 0x0a 0x06 0x0a 0x07 0x08 0x08 0x08 0x09 0x08 +0x0a 0x0a 0x0b 0x0a 0x0c 0x0a 0x0d 0x08 0x0e 0x08 0x0f 0x08 0x10 0x04 0x11 0x04 +0x12 0x05 0x13 0x05 0x14 0x05 0x15 0x05 0x16 0x04 0x17 0x04 0x18 0x05 0x19 0x05 +0x1a 0x05 0x1b 0x05>; + }; +}; + &sdmmc { + disable-wp; pinctrl-names = "default"; - pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_cd_disabled &sdmmc_cd_gpio + pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_cd_disabled &sdmmc_cd_pin &sdmmc_bus4>; - disable-wp; };
&vcc_5v { enable-active-high; - gpio = <&gpio7 21 GPIO_ACTIVE_HIGH>; + gpio = <&gpio7 RK_PC5 GPIO_ACTIVE_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&drv_5v>; };
&vcc50_hdmi { enable-active-high; - gpio = <&gpio5 19 GPIO_ACTIVE_HIGH>; + gpio = <&gpio5 RK_PC3 GPIO_ACTIVE_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&vcc50_hdmi_en>; };
-&edp { - pinctrl-names = "default"; - pinctrl-0 = <&edp_hpd>; +&gpio0 { + gpio-line-names = "PMIC_SLEEP_AP", + "DDRIO_PWROFF", + "DDRIO_RETEN", + "TS3A227E_INT_L", + "PMIC_INT_L", + "PWR_KEY_L", + "AP_LID_INT_L", + "EC_IN_RW", + + "AC_PRESENT_AP", + /* + * RECOVERY_SW_L is Chrome OS ABI. Schematics call + * it REC_MODE_L. + */ + "RECOVERY_SW_L", + "OTP_OUT", + "HOST1_PWR_EN", + "USBOTG_PWREN_H", + "AP_WARM_RESET_H", + "nFAULT2", + "I2C0_SDA_PMIC", + + "I2C0_SCL_PMIC", + "SUSPEND_L", + "USB_INT"; +}; + +&gpio2 { + gpio-line-names = "CONFIG0", + "CONFIG1", + "CONFIG2", + "", + "", + "", + "", + "CONFIG3", + + "", + "EMMC_RST_L", + "", + "", + "BL_PWR_EN", + "AVDD_1V8_DISP_EN"; +}; + +&gpio3 { + gpio-line-names = "FLASH0_D0", + "FLASH0_D1", + "FLASH0_D2", + "FLASH0_D3", + "FLASH0_D4", + "FLASH0_D5", + "FLASH0_D6", + "FLASH0_D7", + + "", + "", + "", + "", + "", + "", + "", + "", + + "FLASH0_CS2/EMMC_CMD", + "", + "FLASH0_DQS/EMMC_CLKO"; +}; + +&gpio4 { + gpio-line-names = "", + "", + "", + "", + "", + "", + "", + "", + + "", + "", + "", + "", + "", + "", + "", + "", + + "UART0_RXD", + "UART0_TXD", + "UART0_CTS", + "UART0_RTS", + "SDIO0_D0", + "SDIO0_D1", + "SDIO0_D2", + "SDIO0_D3", + + "SDIO0_CMD", + "SDIO0_CLK", + "BT_DEV_WAKE", + "", + "WIFI_ENABLE_H", + "BT_ENABLE_L", + "WIFI_HOST_WAKE", + "BT_HOST_WAKE"; +}; + +&gpio5 { + gpio-line-names = "", + "", + "", + "", + "", + "", + "", + "", + + "", + "", + "", + "", + "SPI0_CLK", + "SPI0_CS0", + "SPI0_TXD", + "SPI0_RXD", + + "", + "", + "", + "VCC50_HDMI_EN"; +}; + +&gpio6 { + gpio-line-names = "I2S0_SCLK", + "I2S0_LRCK_RX", + "I2S0_LRCK_TX", + "I2S0_SDI", + "I2S0_SDO0", + "HP_DET_H", + "", + "INT_CODEC", + + "I2S0_CLK", + "I2C2_SDA", + "I2C2_SCL", + "MICDET", + "", + "", + "", + "", + + "SDMMC_D0", + "SDMMC_D1", + "SDMMC_D2", + "SDMMC_D3", + "SDMMC_CLK", + "SDMMC_CMD"; +}; + +&gpio7 { + gpio-line-names = "LCDC_BL", + "PWM_LOG", + "BL_EN", + "TRACKPAD_INT", + "TPM_INT_H", + "SDMMC_DET_L", + /* + * AP_FLASH_WP_L is Chrome OS ABI. Schematics call + * it FW_WP_AP. + */ + "AP_FLASH_WP_L", + "EC_INT", + + "CPU_NMI", + "DVSOK", + "", + "EDP_HPD", + "DVS1", + "nFAULT1", + "LCD_EN", + "DVS2", + + "VCC5V_GOOD_H", + "I2C4_SDA_TP", + "I2C4_SCL_TP", + "I2C5_SDA_HDMI", + "I2C5_SCL_HDMI", + "5V_DRV", + "UART2_RXD", + "UART2_TXD"; +}; + +&gpio8 { + gpio-line-names = "RAM_ID0", + "RAM_ID1", + "RAM_ID2", + "RAM_ID3", + "I2C1_SDA_TPM", + "I2C1_SCL_TPM", + "SPI2_CLK", + "SPI2_CS0", + + "SPI2_RXD", + "SPI2_TXD"; };
&pinctrl { - backlight { - bl_pwr_en: bl_pwr_en { - rockchip,pins = <2 12 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; + pinctrl-names = "default", "sleep"; + pinctrl-0 = < + /* Common for sleep and wake, but no owners */ + &ddr0_retention + &ddrio_pwroff + &global_pwroff + + /* Wake only */ + &suspend_l_wake + &bt_dev_wake_awake + >; + pinctrl-1 = < + /* Common for sleep and wake, but no owners */ + &ddr0_retention + &ddrio_pwroff + &global_pwroff + + /* Sleep only */ + &suspend_l_sleep + &bt_dev_wake_sleep + >;
buck-5v { drv_5v: drv-5v { - rockchip,pins = <7 21 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - emmc { - /* Make sure eMMC is not in reset */ - emmc_deassert_reset: emmc-deassert-reset { - rockchip,pins = <2 9 RK_FUNC_GPIO &pcfg_pull_none>; + rockchip,pins = <7 RK_PC5 RK_FUNC_GPIO &pcfg_pull_none>; }; };
hdmi { vcc50_hdmi_en: vcc50-hdmi-en { - rockchip,pins = <5 19 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - lcd { - lcd_enable_h: lcd-en { - rockchip,pins = <7 14 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - avdd_1v8_disp_en: avdd-1v8-disp-en { - rockchip,pins = <2 13 RK_FUNC_GPIO &pcfg_pull_none>; + rockchip,pins = <5 RK_PC3 RK_FUNC_GPIO &pcfg_pull_none>; }; };
pmic { dvs_1: dvs-1 { - rockchip,pins = <7 12 RK_FUNC_GPIO &pcfg_pull_down>; + rockchip,pins = <7 RK_PB4 RK_FUNC_GPIO &pcfg_pull_down>; };
dvs_2: dvs-2 { - rockchip,pins = <7 15 RK_FUNC_GPIO &pcfg_pull_down>; + rockchip,pins = <7 RK_PB7 RK_FUNC_GPIO &pcfg_pull_down>; }; }; }; @@ -182,24 +474,18 @@ pinctrl-0 = <&i2c4_xfer &trackpad_int>;
trackpad@15 { - compatible = "elan,i2c_touchpad"; - interrupt-parent = <&gpio7>; - interrupts = <3 IRQ_TYPE_EDGE_FALLING>; /* * Remove the inherited pinctrl settings to avoid clashing * with bus-wide ones. */ /delete-property/pinctrl-names; /delete-property/pinctrl-0; - reg = <0x15>; - vcc-supply = <&vcc33_io>; - wakeup-source; };
trackpad@2c { compatible = "hid-over-i2c"; interrupt-parent = <&gpio7>; - interrupts = <3 IRQ_TYPE_EDGE_FALLING>; + interrupts = <RK_PA3 IRQ_TYPE_EDGE_FALLING>; reg = <0x2c>; hid-descr-addr = <0x0020>; vcc-supply = <&vcc33_io>; diff --git a/arch/arm/dts/rk3288-veyron-mickey.dts b/arch/arm/dts/rk3288-veyron-mickey.dts index 0521d9e0..ffd1121d 100644 --- a/arch/arm/dts/rk3288-veyron-mickey.dts +++ b/arch/arm/dts/rk3288-veyron-mickey.dts @@ -1,49 +1,13 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) /* * Google Veyron Mickey Rev 0 board device tree source * * Copyright 2015 Google, Inc - * - * This file is dual-licensed: you can use it either under the terms - * of the GPL or the X11 license, at your option. Note that this dual - * licensing only applies to this file, and not this project as a - * whole. - * - * a) This file is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This file is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * Or, alternatively, - * - * b) Permission is hereby granted, free of charge, to any person - * obtaining a copy of this software and associated documentation - * files (the "Software"), to deal in the Software without - * restriction, including without limitation the rights to use, - * copy, modify, merge, publish, distribute, sublicense, and/or - * sell copies of the Software, and to permit persons to whom the - * Software is furnished to do so, subject to the following - * conditions: - * - * The above copyright notice and this permission notice shall be - * included in all copies or substantial portions of the Software. - * - * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, - * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES - * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND - * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT - * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, - * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING - * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR - * OTHER DEALINGS IN THE SOFTWARE. */
/dts-v1/; -#include "rk3288-veyron-chromebook.dtsi" +#include "rk3288-veyron.dtsi" +#include "rk3288-veyron-broadcom-bluetooth.dtsi"
/ { model = "Google Mickey"; @@ -65,6 +29,13 @@ regulator-boot-on; vin-supply = <&vcc33_sys>; }; + + sound { + compatible = "rockchip,rockchip-audio-max98090"; + rockchip,model = "VEYRON-HDMI"; + rockchip,hdmi-codec = <&hdmi>; + rockchip,i2s-controller = <&i2s>; + }; };
&cpu_thermal { @@ -112,14 +83,18 @@ cooling-maps { /* * After 1st level, throttle the CPU down to as low as 1.4 GHz - * and don't let the GPU go faster than 400 MHz. Note that we - * won't throttle the GPU lower than 400 MHz due to CPU - * heat--we'll let the GPU do the rest itself. + * and don't let the GPU go faster than 400 MHz. */ cpu_warm_limit_cpu { trip = <&cpu_alert_warm>; - cooling-device = - <&cpu0 THERMAL_NO_LIMIT 4>; + cooling-device = <&cpu0 THERMAL_NO_LIMIT 4>, + <&cpu1 THERMAL_NO_LIMIT 4>, + <&cpu2 THERMAL_NO_LIMIT 4>, + <&cpu3 THERMAL_NO_LIMIT 4>; + }; + cpu_warm_limit_gpu { + trip = <&cpu_alert_warm>; + cooling-device = <&gpu 1 1>; };
/* @@ -140,29 +115,100 @@ */ cpu_almost_hot_limit_cpu { trip = <&cpu_alert_almost_hot>; - cooling-device = - <&cpu0 5 6>; + cooling-device = <&cpu0 5 6>, <&cpu1 5 6>, <&cpu2 5 6>, + <&cpu3 5 6>; }; cpu_hot_limit_cpu { trip = <&cpu_alert_hot>; - cooling-device = - <&cpu0 7 7>; + cooling-device = <&cpu0 7 7>, <&cpu1 7 7>, <&cpu2 7 7>, + <&cpu3 7 7>; }; cpu_hotter_limit_cpu { trip = <&cpu_alert_hotter>; - cooling-device = - <&cpu0 7 8>; + cooling-device = <&cpu0 7 8>, <&cpu1 7 8>, <&cpu2 7 8>, + <&cpu3 7 8>; }; cpu_very_hot_limit_cpu { trip = <&cpu_alert_very_hot>; - cooling-device = - <&cpu0 8 THERMAL_NO_LIMIT>; + cooling-device = <&cpu0 8 THERMAL_NO_LIMIT>, + <&cpu1 8 THERMAL_NO_LIMIT>, + <&cpu2 8 THERMAL_NO_LIMIT>, + <&cpu3 8 THERMAL_NO_LIMIT>; + }; + + /* At very hot, don't let GPU go over 300 MHz */ + cpu_very_hot_limit_gpu { + trip = <&cpu_alert_very_hot>; + cooling-device = <&gpu 2 2>; }; }; };
-&emmc { - /delete-property/mmc-hs200-1_8v; +&gpu_thermal { + /delete-node/ trips; + /delete-node/ cooling-maps; + + trips { + gpu_alert_warmish: gpu_alert_warmish { + temperature = <60000>; /* millicelsius */ + hysteresis = <2000>; /* millicelsius */ + type = "passive"; + }; + gpu_alert_warm: gpu_alert_warm { + temperature = <65000>; /* millicelsius */ + hysteresis = <2000>; /* millicelsius */ + type = "passive"; + }; + gpu_alert_hotter: gpu_alert_hotter { + temperature = <84000>; /* millicelsius */ + hysteresis = <2000>; /* millicelsius */ + type = "passive"; + }; + gpu_alert_very_very_hot: gpu_alert_very_very_hot { + temperature = <86000>; /* millicelsius */ + hysteresis = <2000>; /* millicelsius */ + type = "passive"; + }; + gpu_crit: gpu_crit { + temperature = <90000>; /* millicelsius */ + hysteresis = <2000>; /* millicelsius */ + type = "critical"; + }; + }; + + cooling-maps { + /* After 1st level throttle the GPU down to as low as 400 MHz */ + gpu_warmish_limit_gpu { + trip = <&gpu_alert_warmish>; + cooling-device = <&gpu THERMAL_NO_LIMIT 1>; + }; + + /* + * Slightly after we throttle the GPU, we'll also make sure that + * the CPU can't go faster than 1.4 GHz. Note that we won't + * throttle the CPU lower than 1.4 GHz due to GPU heat--we'll + * let the CPU do the rest itself. + */ + gpu_warm_limit_cpu { + trip = <&gpu_alert_warm>; + cooling-device = <&cpu0 4 4>, + <&cpu1 4 4>, + <&cpu2 4 4>, + <&cpu3 4 4>; + }; + + /* When hot, GPU goes down to 300 MHz */ + gpu_hotter_limit_gpu { + trip = <&gpu_alert_hotter>; + cooling-device = <&gpu 2 2>; + }; + + /* When really hot, don't let GPU go _above_ 300 MHz */ + gpu_very_very_hot_limit_gpu { + trip = <&gpu_alert_very_very_hot>; + cooling-device = <&gpu 2 THERMAL_NO_LIMIT>; + }; + }; };
&i2c2 { @@ -175,15 +221,13 @@
&i2s { status = "okay"; - clock-names = "i2s_hclk", "i2s_clk", "i2s_clk_out"; - clocks = <&cru HCLK_I2S0>, <&cru SCLK_I2S0>, <&cru SCLK_I2S0_OUT>; };
/delete-property/ vcc6-supply; /delete-property/ vcc12-supply; @@ -216,40 +260,183 @@ }; };
+&gpio0 { + gpio-line-names = "PMIC_SLEEP_AP", + "", + "", + "", + "PMIC_INT_L", + "POWER_BUTTON_L", + "", + "", + + "", + /* + * RECOVERY_SW_L is Chrome OS ABI. Schematics call + * it REC_MODE_L. + */ + "RECOVERY_SW_L", + "OT_RESET", + "", + "", + "AP_WARM_RESET_H", + "", + "I2C0_SDA_PMIC", + + "I2C0_SCL_PMIC", + "", + "nFALUT"; +}; + +&gpio2 { + gpio-line-names = "CONFIG0", + "CONFIG1", + "CONFIG2", + "", + "", + "", + "", + "CONFIG3", + + "", + "EMMC_RST_L"; +}; + +&gpio3 { + gpio-line-names = "FLASH0_D0", + "FLASH0_D1", + "FLASH0_D2", + "FLASH0_D3", + "FLASH0_D4", + "FLASH0_D5", + "FLASH0_D6", + "FLASH0_D7", + + "", + "", + "", + "", + "", + "", + "", + "", + + "FLASH0_CS2/EMMC_CMD", + "", + "FLASH0_DQS/EMMC_CLKO"; +}; + +&gpio4 { + gpio-line-names = "", + "", + "", + "", + "", + "", + "", + "", + + "", + "", + "", + "", + "", + "", + "", + "", + + "UART0_RXD", + "UART0_TXD", + "UART0_CTS_L", + "UART0_RTS_L", + "SDIO0_D0", + "SDIO0_D1", + "SDIO0_D2", + "SDIO0_D3", + + "SDIO0_CMD", + "SDIO0_CLK", + "BT_DEV_WAKE", + "", + "WIFI_ENABLE_H", + "BT_ENABLE_L", + "WIFI_HOST_WAKE", + "BT_HOST_WAKE"; +}; + +&gpio7 { + gpio-line-names = "", + "PWM_LOG", + "", + "", + "TPM_INT_H", + "SDMMC_DET_L", + /* + * AP_FLASH_WP_L is Chrome OS ABI. Schematics call + * it FW_WP_AP. + */ + "AP_FLASH_WP_L", + "", + + "CPU_NMI", + "DVSOK", + "HDMI_WAKE", + "POWER_HDMI_ON", + "DVS1", + "", + "", + "DVS2", + + "HDMI_CEC", + "", + "", + "I2C5_SDA_HDMI", + "I2C5_SCL_HDMI", + "", + "UART2_RXD", + "UART2_TXD"; +}; + +&gpio8 { + gpio-line-names = "RAM_ID0", + "RAM_ID1", + "RAM_ID2", + "RAM_ID3", + "I2C1_SDA_TPM", + "I2C1_SCL_TPM", + "SPI2_CLK", + "SPI2_CS0", + + "SPI2_RXD", + "SPI2_TXD"; +}; + &pinctrl { + pinctrl-names = "default"; + pinctrl-0 = < + /* Common for sleep and wake, but no owners */ + &ddr0_retention + &ddrio_pwroff + &global_pwroff + >; + hdmi { power_hdmi_on: power-hdmi-on { - rockchip,pins = <7 11 RK_FUNC_GPIO &pcfg_pull_none>; + rockchip,pins = <7 RK_PB3 RK_FUNC_GPIO &pcfg_pull_none>; }; };
-&sdmmc { - status = "disabled"; -}; - -&sdio0 { - status = "disabled"; -}; - -&sdmmc { - status = "disabled"; -}; - -&spi0 { - status = "disabled"; -}; - &usb_host0_ehci { status = "disabled"; }; @@ -260,7 +447,7 @@
&vcc50_hdmi { enable-active-high; - gpio = <&gpio7 11 GPIO_ACTIVE_HIGH>; + gpio = <&gpio7 RK_PB3 GPIO_ACTIVE_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&power_hdmi_on>; }; diff --git a/arch/arm/dts/rk3288-veyron-minnie.dts b/arch/arm/dts/rk3288-veyron-minnie.dts index b56a3f4f..82fc6fba 100644 --- a/arch/arm/dts/rk3288-veyron-minnie.dts +++ b/arch/arm/dts/rk3288-veyron-minnie.dts @@ -1,49 +1,13 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) /* * Google Veyron Minnie Rev 0+ board device tree source * * Copyright 2015 Google, Inc - * - * This file is dual-licensed: you can use it either under the terms - * of the GPL or the X11 license, at your option. Note that this dual - * licensing only applies to this file, and not this project as a - * whole. - * - * a) This file is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This file is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * Or, alternatively, - * - * b) Permission is hereby granted, free of charge, to any person - * obtaining a copy of this software and associated documentation - * files (the "Software"), to deal in the Software without - * restriction, including without limitation the rights to use, - * copy, modify, merge, publish, distribute, sublicense, and/or - * sell copies of the Software, and to permit persons to whom the - * Software is furnished to do so, subject to the following - * conditions: - * - * The above copyright notice and this permission notice shall be - * included in all copies or substantial portions of the Software. - * - * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, - * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES - * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND - * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT - * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, - * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING - * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR - * OTHER DEALINGS IN THE SOFTWARE. */
/dts-v1/; #include "rk3288-veyron-chromebook.dtsi" +#include "rk3288-veyron-broadcom-bluetooth.dtsi"
/ { model = "Google Minnie"; @@ -52,111 +16,31 @@ "google,veyron-minnie-rev0", "google,veyron-minnie", "google,veyron", "rockchip,rk3288";
- backlight_regulator: backlight-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio2 12 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&bl_pwr_en>; - regulator-name = "backlight_regulator"; - vin-supply = <&vcc33_sys>; - startup-delay-us = <15000>; - }; - - panel_regulator: panel-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio7 14 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&lcd_enable_h>; - regulator-name = "panel_regulator"; - startup-delay-us = <100000>; - vin-supply = <&vcc33_sys>; - }; - - vcc18_lcd: vcc18-lcd { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio2 13 GPIO_ACTIVE_HIGH>; + volume_buttons: volume-buttons { + compatible = "gpio-keys"; pinctrl-names = "default"; - pinctrl-0 = <&avdd_1v8_disp_en>; - regulator-name = "vcc18_lcd"; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vcc18_wl>; - }; - - sound { - compatible = "rockchip,audio-max98090-jerry"; + pinctrl-0 = <&volum_down_l &volum_up_l>;
- cpu { - sound-dai = <&i2s 0>; + volum_down { + label = "Volum_down"; + gpios = <&gpio5 RK_PB3 GPIO_ACTIVE_LOW>; + linux,code = <KEY_VOLUMEDOWN>; + debounce-interval = <100>; };
- codec { - sound-dai = <&max98090 0>; + volum_up { + label = "Volum_up"; + gpios = <&gpio5 RK_PB2 GPIO_ACTIVE_LOW>; + linux,code = <KEY_VOLUMEUP>; + debounce-interval = <100>; }; }; };
&backlight { /* Minnie panel PWM must be >= 1%, so start non-zero brightness at 3 */ - brightness-levels = < - 0 3 4 5 6 7 - 8 9 10 11 12 13 14 15 - 16 17 18 19 20 21 22 23 - 24 25 26 27 28 29 30 31 - 32 33 34 35 36 37 38 39 - 40 41 42 43 44 45 46 47 - 48 49 50 51 52 53 54 55 - 56 57 58 59 60 61 62 63 - 64 65 66 67 68 69 70 71 - 72 73 74 75 76 77 78 79 - 80 81 82 83 84 85 86 87 - 88 89 90 91 92 93 94 95 - 96 97 98 99 100 101 102 103 - 104 105 106 107 108 109 110 111 - 112 113 114 115 116 117 118 119 - 120 121 122 123 124 125 126 127 - 128 129 130 131 132 133 134 135 - 136 137 138 139 140 141 142 143 - 144 145 146 147 148 149 150 151 - 152 153 154 155 156 157 158 159 - 160 161 162 163 164 165 166 167 - 168 169 170 171 172 173 174 175 - 176 177 178 179 180 181 182 183 - 184 185 186 187 188 189 190 191 - 192 193 194 195 196 197 198 199 - 200 201 202 203 204 205 206 207 - 208 209 210 211 212 213 214 215 - 216 217 218 219 220 221 222 223 - 224 225 226 227 228 229 230 231 - 232 233 234 235 236 237 238 239 - 240 241 242 243 244 245 246 247 - 248 249 250 251 252 253 254 255>; - power-supply = <&backlight_regulator>; -}; - -&emmc { - /delete-property/mmc-hs200-1_8v; -}; - -&gpio_keys { - pinctrl-0 = <&pwr_key_h &ap_lid_int_l &volum_down_l &volum_up_l>; - - volum_down { - label = "Volum_down"; - gpios = <&gpio5 11 GPIO_ACTIVE_LOW>; - linux,code = <KEY_VOLUMEDOWN>; - debounce-interval = <100>; - }; - - volum_up { - label = "Volum_up"; - gpios = <&gpio5 10 GPIO_ACTIVE_LOW>; - linux,code = <KEY_VOLUMEUP>; - debounce-interval = <100>; - }; + brightness-levels = <3 255>; + num-interpolated-steps = <252>; };
&i2c_tunnel { @@ -177,18 +61,31 @@ compatible = "elan,ekth3500"; reg = <0x10>; interrupt-parent = <&gpio2>; - interrupts = <14 IRQ_TYPE_EDGE_FALLING>; + interrupts = <RK_PB6 IRQ_TYPE_EDGE_FALLING>; pinctrl-names = "default"; pinctrl-0 = <&touch_int &touch_rst>; - reset-gpios = <&gpio2 15 GPIO_ACTIVE_LOW>; + reset-gpios = <&gpio2 RK_PB7 GPIO_ACTIVE_LOW>; vcc33-supply = <&vcc33_touch>; vccio-supply = <&vcc33_touch>; }; };
&panel { - compatible = "auo,b101ean01", "simple-panel"; - power-supply= <&panel_regulator>; + compatible = "auo,b101ean01"; + + /delete-node/ panel-timing; + + panel-timing { + clock-frequency = <66666667>; + hactive = <1280>; + hfront-porch = <18>; + hback-porch = <21>; + hsync-len = <32>; + vactive = <800>; + vfront-porch = <4>; + vback-porch = <8>; + vsync-len = <18>; + }; };
&rk808 { @@ -217,86 +114,302 @@ &sdmmc { disable-wp; pinctrl-names = "default"; - pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_cd_disabled &sdmmc_cd_gpio + pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_cd_disabled &sdmmc_cd_pin &sdmmc_bus4>; };
+&gpio0 { + gpio-line-names = "PMIC_SLEEP_AP", + "DDRIO_PWROFF", + "DDRIO_RETEN", + "TS3A227E_INT_L", + "PMIC_INT_L", + "PWR_KEY_L", + "AP_LID_INT_L", + "EC_IN_RW", + + "AC_PRESENT_AP", + /* + * RECOVERY_SW_L is Chrome OS ABI. Schematics call + * it REC_MODE_L. + */ + "RECOVERY_SW_L", + "OTP_OUT", + "HOST1_PWR_EN", + "USBOTG_PWREN_H", + "AP_WARM_RESET_H", + "nFALUT2", + "I2C0_SDA_PMIC", + + "I2C0_SCL_PMIC", + "SUSPEND_L", + "USB_INT"; +}; + +&gpio2 { + gpio-line-names = "CONFIG0", + "CONFIG1", + "CONFIG2", + "", + "", + "", + "", + "CONFIG3", + + "PROCHOT#", + "EMMC_RST_L", + "", + "", + "BL_PWR_EN", + "AVDD_1V8_DISP_EN", + "TOUCH_INT", + "TOUCH_RST", + + "I2C3_SCL_TP", + "I2C3_SDA_TP"; +}; + +&gpio3 { + gpio-line-names = "FLASH0_D0", + "FLASH0_D1", + "FLASH0_D2", + "FLASH0_D3", + "FLASH0_D4", + "FLASH0_D5", + "FLASH0_D6", + "FLASH0_D7", + + "", + "", + "", + "", + "", + "", + "", + "", + + "FLASH0_CS2/EMMC_CMD", + "", + "FLASH0_DQS/EMMC_CLKO"; +}; + +&gpio4 { + gpio-line-names = "", + "", + "", + "", + "", + "", + "", + "", + + "", + "", + "", + "", + "", + "", + "", + "", + + "UART0_RXD", + "UART0_TXD", + "UART0_CTS", + "UART0_RTS", + "SDIO0_D0", + "SDIO0_D1", + "SDIO0_D2", + "SDIO0_D3", + + "SDIO0_CMD", + "SDIO0_CLK", + "dev_wake", + "", + "WIFI_ENABLE_H", + "BT_ENABLE_L", + "WIFI_HOST_WAKE", + "BT_HOST_WAKE"; +}; + +&gpio5 { + gpio-line-names = "", + "", + "", + "", + "", + "", + "", + "", + + "", + "", + "Volum_Up#", + "Volum_Down#", + "SPI0_CLK", + "SPI0_CS0", + "SPI0_TXD", + "SPI0_RXD", + + "", + "", + "", + "VCC50_HDMI_EN"; +}; + +&gpio6 { + gpio-line-names = "I2S0_SCLK", + "I2S0_LRCK_RX", + "I2S0_LRCK_TX", + "I2S0_SDI", + "I2S0_SDO0", + "HP_DET_H", + "", + "INT_CODEC", + + "I2S0_CLK", + "I2C2_SDA", + "I2C2_SCL", + "MICDET", + "", + "", + "", + "", + + "SDMMC_D0", + "SDMMC_D1", + "SDMMC_D2", + "SDMMC_D3", + "SDMMC_CLK", + "SDMMC_CMD"; +}; + +&gpio7 { + gpio-line-names = "LCDC_BL", + "PWM_LOG", + "BL_EN", + "TRACKPAD_INT", + "TPM_INT_H", + "SDMMC_DET_L", + /* + * AP_FLASH_WP_L is Chrome OS ABI. Schematics call + * it FW_WP_AP. + */ + "AP_FLASH_WP_L", + "EC_INT", + + "CPU_NMI", + "DVS_OK", + "SDMMC_WP", + "EDP_HPD", + "DVS1", + "nFALUT1", + "LCD_EN", + "DVS2", + + "VCC5V_GOOD_H", + "I2C4_SDA_TP", + "I2C4_SCL_TP", + "I2C5_SDA_HDMI", + "I2C5_SCL_HDMI", + "5V_DRV", + "UART2_RXD", + "UART2_TXD"; +}; + +&gpio8 { + gpio-line-names = "RAM_ID0", + "RAM_ID1", + "RAM_ID2", + "RAM_ID3", + "I2C1_SDA_TPM", + "I2C1_SCL_TPM", + "SPI2_CLK", + "SPI2_CS0", + + "SPI2_RXD", + "SPI2_TXD"; +}; + &pinctrl { - backlight { - bl_pwr_en: bl_pwr_en { - rockchip,pins = <2 12 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; + pinctrl-names = "default", "sleep"; + pinctrl-0 = < + /* Common for sleep and wake, but no owners */ + &ddr0_retention + &ddrio_pwroff + &global_pwroff + + /* Wake only */ + &suspend_l_wake + >; + pinctrl-1 = < + /* Common for sleep and wake, but no owners */ + &ddr0_retention + &ddrio_pwroff + &global_pwroff + + /* Sleep only */ + &suspend_l_sleep + >;
buck-5v { drv_5v: drv-5v { - rockchip,pins = <7 21 RK_FUNC_GPIO &pcfg_pull_none>; + rockchip,pins = <7 RK_PC5 RK_FUNC_GPIO &pcfg_pull_none>; }; };
buttons { volum_down_l: volum-down-l { - rockchip,pins = <5 11 RK_FUNC_GPIO &pcfg_pull_up>; + rockchip,pins = <5 RK_PB3 RK_FUNC_GPIO &pcfg_pull_up>; };
volum_up_l: volum-up-l { - rockchip,pins = <5 10 RK_FUNC_GPIO &pcfg_pull_up>; + rockchip,pins = <5 RK_PB2 RK_FUNC_GPIO &pcfg_pull_up>; }; };
prochot { gpio_prochot: gpio-prochot { - rockchip,pins = <2 8 RK_FUNC_GPIO &pcfg_pull_none>; + rockchip,pins = <2 RK_PB0 RK_FUNC_GPIO &pcfg_pull_none>; }; };
touchscreen { touch_int: touch-int { - rockchip,pins = <2 14 RK_FUNC_GPIO &pcfg_pull_none>; + rockchip,pins = <2 RK_PB6 RK_FUNC_GPIO &pcfg_pull_none>; };
touch_rst: touch-rst { - rockchip,pins = <2 15 RK_FUNC_GPIO &pcfg_pull_none>; + rockchip,pins = <2 RK_PB7 RK_FUNC_GPIO &pcfg_pull_none>; }; }; }; diff --git a/arch/arm/dts/rk3288-veyron-sdmmc.dtsi b/arch/arm/dts/rk3288-veyron-sdmmc.dtsi new file mode 100644 index 00000000..27fb06ce --- /dev/null +++ b/arch/arm/dts/rk3288-veyron-sdmmc.dtsi @@ -0,0 +1,89 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Google Veyron (and derivatives) fragment for sdmmc cards + * + * Copyright 2015 Google, Inc + */ + +&io_domains { + sdcard-supply = <&vccio_sd>; +}; + +&pinctrl { + sdmmc { + /* + * We run sdmmc at max speed; bump up drive strength. + * We also have external pulls, so disable the internal ones. + */ + sdmmc_bus4: sdmmc-bus4 { + rockchip,pins = <6 RK_PC0 1 &pcfg_pull_none_drv_8ma>, + <6 RK_PC1 1 &pcfg_pull_none_drv_8ma>, + <6 RK_PC2 1 &pcfg_pull_none_drv_8ma>, + <6 RK_PC3 1 &pcfg_pull_none_drv_8ma>; + }; + + sdmmc_clk: sdmmc-clk { + rockchip,pins = <6 RK_PC4 1 &pcfg_pull_none_drv_8ma>; + }; + + sdmmc_cmd: sdmmc-cmd { + rockchip,pins = <6 RK_PC5 1 &pcfg_pull_none_drv_8ma>; + }; + + /* + * Builtin CD line is hooked to ground to prevent JTAG at boot + * (and also to get the voltage rail correct). + * Configure gpio6_C6 as GPIO so dw_mmc builtin CD doesn't + * think there's a card inserted + */ + sdmmc_cd_disabled: sdmmc-cd-disabled { + rockchip,pins = <6 RK_PC6 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + /* This is where we actually hook up CD */ + sdmmc_cd_pin: sdmmc-cd-pin { + rockchip,pins = <7 RK_PA5 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; +}; + +&rk808 { + vcc9-supply = <&vcc_5v>; + + regulators { + vccio_sd: LDO_REG4 { + regulator-name = "vccio_sd"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc33_sd: LDO_REG5 { + regulator-name = "vcc33_sd"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + }; +}; + +&sdmmc { + status = "okay"; + + bus-width = <4>; + cap-mmc-highspeed; + cap-sd-highspeed; + card-detect-delay = <200>; + cd-gpios = <&gpio7 RK_PA5 GPIO_ACTIVE_LOW>; + rockchip,default-sample-phase = <90>; + sd-uhs-sdr12; + sd-uhs-sdr25; + sd-uhs-sdr50; + sd-uhs-sdr104; + vmmc-supply = <&vcc33_sd>; + vqmmc-supply = <&vccio_sd>; +}; diff --git a/arch/arm/dts/rk3288-veyron-speedy.dts b/arch/arm/dts/rk3288-veyron-speedy.dts index 58c1fe96..4a3ea934 100644 --- a/arch/arm/dts/rk3288-veyron-speedy.dts +++ b/arch/arm/dts/rk3288-veyron-speedy.dts @@ -7,8 +7,8 @@
/dts-v1/; #include "rk3288-veyron-chromebook.dtsi" +#include "rk3288-veyron-broadcom-bluetooth.dtsi" #include "cros-ec-sbs.dtsi" -#include "rk3288-veyron-speedy-u-boot.dtsi"
/ { model = "Google Speedy"; @@ -17,44 +17,6 @@ "google,veyron-speedy-rev5", "google,veyron-speedy-rev4", "google,veyron-speedy-rev3", "google,veyron-speedy-rev2", "google,veyron-speedy", "google,veyron", "rockchip,rk3288"; - - panel_regulator: panel-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio7 RK_PB6 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&lcd_enable_h>; - regulator-name = "panel_regulator"; - startup-delay-us = <100000>; - vin-supply = <&vcc33_sys>; - }; - - vcc18_lcd: vcc18-lcd { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio2 RK_PB5 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&avdd_1v8_disp_en>; - regulator-name = "vcc18_lcd"; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vcc18_wl>; - }; - - backlight_regulator: backlight-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio2 RK_PB4 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&bl_pwr_en>; - regulator-name = "backlight_regulator"; - vin-supply = <&vcc33_sys>; - startup-delay-us = <15000>; - }; -}; - -&backlight { - power-supply = <&backlight_regulator>; };
&cpu_alert0 { @@ -65,6 +27,10 @@ temperature = <70000>; };
+&cpu_crit { + temperature = <90000>; +}; + &edp { /delete-property/pinctrl-names; /delete-property/pinctrl-0; @@ -72,8 +38,12 @@ force-hpd; };
-&panel { - power-supply = <&panel_regulator>; +&gpu_alert0 { + temperature = <80000>; +}; + +&gpu_crit { + temperature = <90000>; };
&rk808 { @@ -84,7 +54,7 @@ &sdmmc { disable-wp; pinctrl-names = "default"; - pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_cd_disabled &sdmmc_cd_gpio + pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_cd_disabled &sdmmc_cd_pin &sdmmc_bus4>; };
@@ -102,42 +72,253 @@ pinctrl-0 = <&vcc50_hdmi_en>; };
+&gpio0 { + gpio-line-names = "PMIC_SLEEP_AP", + "DDRIO_PWROFF", + "DDRIO_RETEN", + "TS3A227E_INT_L", + "PMIC_INT_L", + "PWR_KEY_L", + "AP_LID_INT_L", + "EC_IN_RW", + + "AC_PRESENT_AP", + /* + * RECOVERY_SW_L is Chrome OS ABI. Schematics call + * it REC_MODE_L. + */ + "RECOVERY_SW_L", + "OTP_OUT", + "HOST1_PWR_EN", + "USBOTG_PWREN_H", + "AP_WARM_RESET_H", + "nFALUT2", + "I2C0_SDA_PMIC", + + "I2C0_SCL_PMIC", + "SUSPEND_L", + "USB_INT"; +}; + +&gpio2 { + gpio-line-names = "CONFIG0", + "CONFIG1", + "CONFIG2", + "", + "", + "", + "", + "CONFIG3", + + "PWRLIMIT#_CPU", + "EMMC_RST_L", + "", + "", + "BL_PWR_EN", + "AVDD_1V8_DISP_EN"; +}; + +&gpio3 { + gpio-line-names = "FLASH0_D0", + "FLASH0_D1", + "FLASH0_D2", + "FLASH0_D3", + "FLASH0_D4", + "FLASH0_D5", + "FLASH0_D6", + "FLASH0_D7", + + "", + "", + "", + "", + "", + "", + "", + "", + + "FLASH0_CS2/EMMC_CMD", + "", + "FLASH0_DQS/EMMC_CLKO"; +}; + +&gpio4 { + gpio-line-names = "", + "", + "", + "", + "", + "", + "", + "", + + "", + "", + "", + "", + "", + "", + "", + "", + + "UART0_RXD", + "UART0_TXD", + "UART0_CTS", + "UART0_RTS", + "SDIO0_D0", + "SDIO0_D1", + "SDIO0_D2", + "SDIO0_D3", + + "SDIO0_CMD", + "SDIO0_CLK", + "BT_DEV_WAKE", + "", + "WIFI_ENABLE_H", + "BT_ENABLE_L", + "WIFI_HOST_WAKE", + "BT_HOST_WAKE"; +}; + +&gpio5 { + gpio-line-names = "", + "", + "", + "", + "", + "", + "", + "", + + "", + "", + "", + "", + "SPI0_CLK", + "SPI0_CS0", + "SPI0_TXD", + "SPI0_RXD", + + "", + "", + "", + "VCC50_HDMI_EN"; +}; + +&gpio6 { + gpio-line-names = "I2S0_SCLK", + "I2S0_LRCK_RX", + "I2S0_LRCK_TX", + "I2S0_SDI", + "I2S0_SDO0", + "HP_DET_H", + "ALS_INT", /* not connected */ + "INT_CODEC", + + "I2S0_CLK", + "I2C2_SDA", + "I2C2_SCL", + "MICDET", + "", + "", + "", + "", + + "SDMMC_D0", + "SDMMC_D1", + "SDMMC_D2", + "SDMMC_D3", + "SDMMC_CLK", + "SDMMC_CMD"; +}; + +&gpio7 { + gpio-line-names = "LCDC_BL", + "PWM_LOG", + "BL_EN", + "TRACKPAD_INT", + "TPM_INT_H", + "SDMMC_DET_L", + /* + * AP_FLASH_WP_L is Chrome OS ABI. Schematics call + * it FW_WP_AP. + */ + "AP_FLASH_WP_L", + "EC_INT", + + "CPU_NMI", + "DVS_OK", + "", + "EDP_HOTPLUG", + "DVS1", + "nFALUT1", + "LCD_EN", + "DVS2", + + "VCC5V_GOOD_H", + "I2C4_SDA_TP", + "I2C4_SCL_TP", + "I2C5_SDA_HDMI", + "I2C5_SCL_HDMI", + "5V_DRV", + "UART2_RXD", + "UART2_TXD"; +}; + +&gpio8 { + gpio-line-names = "RAM_ID0", + "RAM_ID1", + "RAM_ID2", + "RAM_ID3", + "I2C1_SDA_TPM", + "I2C1_SCL_TPM", + "SPI2_CLK", + "SPI2_CS0", + + "SPI2_RXD", + "SPI2_TXD"; +}; + &pinctrl { - backlight { - bl_pwr_en: bl_pwr_en { - rockchip,pins = <2 12 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; + pinctrl-names = "default", "sleep"; + pinctrl-0 = < + /* Common for sleep and wake, but no owners */ + &ddr0_retention + &ddrio_pwroff + &global_pwroff + + /* Wake only */ + &suspend_l_wake + >; + pinctrl-1 = < + /* Common for sleep and wake, but no owners */ + &ddr0_retention + &ddrio_pwroff + &global_pwroff + + /* Sleep only */ + &suspend_l_sleep + >;
dvs_2: dvs-2 { - rockchip,pins = <7 15 RK_FUNC_GPIO &pcfg_pull_down>; + rockchip,pins = <7 RK_PB7 RK_FUNC_GPIO &pcfg_pull_down>; }; }; }; diff --git a/arch/arm/dts/rk3288-veyron.dtsi b/arch/arm/dts/rk3288-veyron.dtsi index ac9e815e..2b7dc2c5 100644 --- a/arch/arm/dts/rk3288-veyron.dtsi +++ b/arch/arm/dts/rk3288-veyron.dtsi @@ -1,8 +1,8 @@ -// SPDX-License-Identifier: GPL-2.0 +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) /* * Google Veyron (and derivatives) board device tree source * - * Copyright 2014 Google, Inc + * Copyright 2015 Google, Inc */
#include <dt-bindings/clock/rockchip,rk808.h> @@ -10,150 +10,83 @@ #include "rk3288.dtsi"
/ { - memory { - reg = <0x0 0x80000000>; - }; - chosen { - stdout-path = &uart2; + stdout-path = "serial2:115200n8"; };
- firmware { - chromeos { - pinctrl-names = "default"; - pinctrl-0 = <&fw_wp_ap>; - write-protect-gpio = <&gpio7 6 GPIO_ACTIVE_LOW>; - }; - }; - - backlight: backlight { - compatible = "pwm-backlight"; - brightness-levels = < - 0 1 2 3 4 5 6 7 - 8 9 10 11 12 13 14 15 - 16 17 18 19 20 21 22 23 - 24 25 26 27 28 29 30 31 - 32 33 34 35 36 37 38 39 - 40 41 42 43 44 45 46 47 - 48 49 50 51 52 53 54 55 - 56 57 58 59 60 61 62 63 - 64 65 66 67 68 69 70 71 - 72 73 74 75 76 77 78 79 - 80 81 82 83 84 85 86 87 - 88 89 90 91 92 93 94 95 - 96 97 98 99 100 101 102 103 - 104 105 106 107 108 109 110 111 - 112 113 114 115 116 117 118 119 - 120 121 122 123 124 125 126 127 - 128 129 130 131 132 133 134 135 - 136 137 138 139 140 141 142 143 - 144 145 146 147 148 149 150 151 - 152 153 154 155 156 157 158 159 - 160 161 162 163 164 165 166 167 - 168 169 170 171 172 173 174 175 - 176 177 178 179 180 181 182 183 - 184 185 186 187 188 189 190 191 - 192 193 194 195 196 197 198 199 - 200 201 202 203 204 205 206 207 - 208 209 210 211 212 213 214 215 - 216 217 218 219 220 221 222 223 - 224 225 226 227 228 229 230 231 - 232 233 234 235 236 237 238 239 - 240 241 242 243 244 245 246 247 - 248 249 250 251 252 253 254 255>; - default-brightness-level = <128>; - enable-gpios = <&gpio7 2 GPIO_ACTIVE_HIGH>; - backlight-boot-off; - pinctrl-names = "default"; - pinctrl-0 = <&bl_en>; - pwms = <&pwm0 0 1000000 0>; + /* + * The default coreboot on veyron devices ignores memory@0 nodes + * and would instead create another memory node. + */ + memory { + device_type = "memory"; + reg = <0x0 0x80000000>; };
- panel: panel { - compatible ="cnm,n116bgeea2","simple-panel"; - status = "okay"; - power-supply = <&vcc33_lcd>; - backlight = <&backlight>; - };
- gpio_keys: gpio-keys { + power_button: power-button { compatible = "gpio-keys"; - pinctrl-names = "default"; - pinctrl-0 = <&pwr_key_h>; + pinctrl-0 = <&pwr_key_l>; + power { label = "Power"; - gpios = <&gpio0 5 GPIO_ACTIVE_HIGH>; + gpios = <&gpio0 RK_PA5 GPIO_ACTIVE_LOW>; linux,code = <KEY_POWER>; debounce-interval = <100>; - gpio-key,wakeup; + wakeup-source; }; };
gpio-restart { compatible = "gpio-restart"; - gpios = <&gpio0 13 GPIO_ACTIVE_HIGH>; + gpios = <&gpio0 RK_PB5 GPIO_ACTIVE_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&ap_warm_reset_h>; - priority = /bits/ 8 <200>; + priority = <200>; };
emmc_pwrseq: emmc-pwrseq { compatible = "mmc-pwrseq-emmc"; pinctrl-0 = <&emmc_reset>; pinctrl-names = "default"; - reset-gpios = <&gpio2 9 GPIO_ACTIVE_HIGH>; + reset-gpios = <&gpio2 RK_PB1 GPIO_ACTIVE_HIGH>; };
- sound { - compatible = "rockchip,rockchip-audio-max98090"; - rockchip,model = "ROCKCHIP-I2S"; - rockchip,i2s-controller = <&i2s>; - rockchip,audio-codec = <&max98090>; - rockchip,hp-det-gpios = <&gpio6 5 GPIO_ACTIVE_HIGH>; - rockchip,mic-det-gpios = <&gpio6 11 GPIO_ACTIVE_LOW>; - rockchip,headset-codec = <&headsetcodec>; + sdio_pwrseq: sdio-pwrseq { + compatible = "mmc-pwrseq-simple"; + clocks = <&rk808 RK808_CLKOUT1>; + clock-names = "ext_clock"; pinctrl-names = "default"; - pinctrl-0 = <&mic_det>, <&hp_det>; - }; - - vdd_logic: pwm-regulator { - compatible = "pwm-regulator"; - pwms = <&pwm1 0 2000 0>; - - voltage-table = <1350000 0>, - <1300000 10>, - <1250000 20>, - <1200000 31>, - <1150000 41>, - <1100000 52>, - <1050000 62>, - <1000000 72>, - < 950000 83>; + pinctrl-0 = <&wifi_enable_h>;
- regulator-min-microvolt = <950000>; - regulator-max-microvolt = <1350000>; - regulator-name = "vdd_logic"; - regulator-ramp-delay = <4000>; + /* + * Depending on the actual card populated GPIO4 D4 + * correspond to one of these signals on the module: + * + * D4: + * - SDIO_RESET_L_WL_REG_ON + * - PDN (power down when low) + */ + reset-gpios = <&gpio4 RK_PD4 GPIO_ACTIVE_LOW>; };
- vcc33_sys: vcc33-sys { + vcc_5v: vcc-5v { compatible = "regulator-fixed"; - regulator-name = "vcc33_sys"; + regulator-name = "vcc_5v"; regulator-always-on; regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&vccsys>; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; };
- vcc_5v: vcc-5v { + vcc33_sys: vcc33-sys { compatible = "regulator-fixed"; - regulator-name = "vcc_5v"; + regulator-name = "vcc33_sys"; regulator-always-on; regulator-boot-on; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; };
vcc50_hdmi: vcc50-hdmi { @@ -164,39 +97,21 @@ vin-supply = <&vcc_5v>; };
- bt_regulator: bt-regulator { - /* - * On the module itself this is one of these (depending - * on the actual card pouplated): - * - BT_I2S_WS_BT_RFDISABLE_L - * - No connect - */ - - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio4 29 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&bt_enable_l>; - regulator-name = "bt_regulator"; - }; + vdd_logic: vdd-logic { + compatible = "pwm-regulator"; + regulator-name = "vdd_logic";
- wifi_regulator: wifi-regulator { - /* - * On the module itself this is one of these (depending - * on the actual card populated): - * - SDIO_RESET_L_WL_REG_ON - * - PDN (power down when low) - */ + pwms = <&pwm1 0 1994 0>; + pwm-supply = <&vcc33_sys>;
- compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio4 28 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&wifi_enable_h>; - regulator-name = "wifi_regulator"; + pwm-dutycycle-range = <0x7b 0>; + pwm-dutycycle-unit = <0x94>;
- /* Faux input supply. See bt_regulator description. */ - vin-supply = <&bt_regulator>; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <950000>; + regulator-max-microvolt = <1350000>; + regulator-ramp-delay = <4000>; }; };
@@ -204,71 +119,62 @@ cpu0-supply = <&vdd_cpu>; };
-&efuse { - status = "okay"; +&cpu_crit { + temperature = <100000>; +}; + +/* rk3288-c used in Veyron Chrome-devices has slightly changed OPPs */ +&cpu_opp_table { + /delete-node/ opp-312000000; + + opp-1512000000 { + opp-microvolt = <1250000>; + }; + opp-1608000000 { + opp-microvolt = <1300000>; + }; + opp-1704000000 { + opp-hz = /bits/ 64 <1704000000>; + opp-microvolt = <1350000>; + }; + opp-1800000000 { + opp-hz = /bits/ 64 <1800000000>; + opp-microvolt = <1400000>; + }; };
&emmc { - broken-cd; + status = "okay"; + bus-width = <8>; cap-mmc-highspeed; + rockchip,default-sample-phase = <158>; + disable-wp; mmc-hs200-1_8v; mmc-pwrseq = <&emmc_pwrseq>; - disable-wp; non-removable; - num-slots = <1>; pinctrl-names = "default"; - pinctrl-0 = <&emmc_clk &emmc_cmd &emmc_bus8 &emmc_pwr>; - status = "okay"; + pinctrl-0 = <&emmc_clk &emmc_cmd &emmc_bus8>; };
-&sdio0 { - broken-cd; - bus-width = <4>; - cap-sd-highspeed; - sd-uhs-sdr12; - sd-uhs-sdr25; - sd-uhs-sdr50; - sd-uhs-sdr104; - cap-sdio-irq; - card-external-vcc-supply = <&wifi_regulator>; - clocks = <&cru HCLK_SDIO0>, <&cru SCLK_SDIO0>, <&cru SCLK_SDIO0_DRV>, - <&cru SCLK_SDIO0_SAMPLE>, <&rk808 RK808_CLKOUT1>; - clock-names = "biu", "ciu", "ciu_drv", "ciu_sample", "card_ext_clock"; - keep-power-in-suspend; - non-removable; - num-slots = <1>; - pinctrl-names = "default"; - pinctrl-0 = <&sdio0_clk &sdio0_cmd &sdio0_bus4>; +&gpu { + mali-supply = <&vdd_gpu>; status = "okay"; - vmmc-supply = <&vcc33_sys>; - vqmmc-supply = <&vcc18_wl>; };
-&sdmmc { - bus-width = <4>; - cap-mmc-highspeed; - cap-sd-highspeed; - sd-uhs-sdr12; - sd-uhs-sdr25; - sd-uhs-sdr50; - sd-uhs-sdr104; - card-detect-delay = <200>; - cd-gpios = <&gpio7 5 GPIO_ACTIVE_LOW>; - num-slots = <1>; - status = "okay"; - vmmc-supply = <&vcc33_sd>; - vqmmc-supply = <&vccio_sd>; +&gpu_alert0 { + temperature = <72500>; };
-&spi2 { - status = "okay"; +&gpu_crit { + temperature = <100000>; +};
- spi_flash: spiflash@0 { - compatible = "spidev", "jedec,spi-nor"; - spi-max-frequency = <20000000>; /* Reduce for Dediprog em100 pro */ - reg = <0>; - }; +&hdmi { + pinctrl-names = "default", "unwedge"; + pinctrl-0 = <&hdmi_ddc>; + pinctrl-1 = <&hdmi_ddc_unwedge>; + status = "okay"; };
&i2c0 { @@ -280,12 +186,12 @@
rk808: pmic@1b { compatible = "rockchip,rk808"; + reg = <0x1b>; clock-output-names = "xin32k", "wifibt_32kin"; interrupt-parent = <&gpio0>; - interrupts = <4 IRQ_TYPE_LEVEL_LOW>; + interrupts = <RK_PA4 IRQ_TYPE_LEVEL_LOW>; pinctrl-names = "default"; pinctrl-0 = <&pmic_int_l>; - reg = <0x1b>; rockchip,system-power-controller; wakeup-source; #clock-cells = <1>; @@ -297,39 +203,41 @@ vcc6-supply = <&vcc_5v>; vcc7-supply = <&vcc33_sys>; vcc8-supply = <&vcc33_sys>; - vcc9-supply = <&vcc_5v>; - vcc10-supply = <&vcc33_sys>; - vcc11-supply = <&vcc_5v>; vcc12-supply = <&vcc_18>; - vddio-supply = <&vcc33_io>;
regulators { vdd_cpu: DCDC_REG1 { + regulator-name = "vdd_arm"; regulator-always-on; regulator-boot-on; regulator-min-microvolt = <750000>; regulator-max-microvolt = <1450000>; - regulator-name = "vdd_arm"; regulator-ramp-delay = <6001>; - regulator-suspend-mem-disabled; + regulator-state-mem { + regulator-off-in-suspend; + }; };
vdd_gpu: DCDC_REG2 { + regulator-name = "vdd_gpu"; regulator-always-on; regulator-boot-on; regulator-min-microvolt = <800000>; regulator-max-microvolt = <1250000>; - regulator-name = "vdd_gpu"; regulator-ramp-delay = <6001>; - regulator-suspend-mem-disabled; + regulator-state-mem { + regulator-off-in-suspend; + }; };
vcc135_ddr: DCDC_REG3 { + regulator-name = "vcc135_ddr"; regulator-always-on; regulator-boot-on; - regulator-name = "vcc135_ddr"; - regulator-suspend-mem-enabled; + regulator-state-mem { + regulator-on-in-suspend; + }; };
/* @@ -340,12 +248,15 @@ * power measurement purposes). */ vcc18_wl: vcc18_flashio: vcc_18: DCDC_REG4 { + regulator-name = "vcc_18"; regulator-always-on; regulator-boot-on; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; - regulator-name = "vcc_18"; - regulator-suspend-mem-microvolt = <1800000>; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; };
/* @@ -356,60 +267,47 @@ * (such as danger) they're the same net. */ vcc33_io: LDO_REG1 { + regulator-name = "vcc33_io"; regulator-always-on; regulator-boot-on; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; - regulator-name = "vcc33_io"; - regulator-suspend-mem-microvolt = <3300000>; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3300000>; + }; };
vdd_10: LDO_REG3 { + regulator-name = "vdd_10"; regulator-always-on; regulator-boot-on; regulator-min-microvolt = <1000000>; regulator-max-microvolt = <1000000>; - regulator-name = "vdd_10"; - regulator-suspend-mem-microvolt = <1000000>; - }; - - vccio_sd: LDO_REG4 { - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - regulator-name = "vccio_sd"; - regulator-suspend-mem-disabled; - }; - - vcc33_sd: LDO_REG5 { - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-name = "vcc33_sd"; - regulator-suspend-mem-disabled; - }; - - vcc18_codec: LDO_REG6 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-name = "vcc18_codec"; - regulator-suspend-mem-disabled; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1000000>; + }; };
vdd10_lcd_pwren_h: LDO_REG7 { + regulator-name = "vdd10_lcd_pwren_h"; regulator-always-on; regulator-boot-on; regulator-min-microvolt = <2500000>; regulator-max-microvolt = <2500000>; - regulator-name = "vdd10_lcd_pwren_h"; - regulator-suspend-mem-disabled; + regulator-state-mem { + regulator-off-in-suspend; + }; };
vcc33_lcd: SWITCH_REG1 { + regulator-name = "vcc33_lcd"; regulator-always-on; regulator-boot-on; - regulator-name = "vcc33_lcd"; - regulator-suspend-mem-disabled; + regulator-state-mem { + regulator-off-in-suspend; + }; }; }; }; @@ -436,24 +334,6 @@ clock-frequency = <100000>; i2c-scl-falling-time-ns = <50>; /* 10ns measured */ i2c-scl-rising-time-ns = <800>; /* 600ns measured */ - - max98090: max98090@10 { - compatible = "maxim,max98090"; - reg = <0x10>; - #sound-dai-cells = <0>; - interrupt-parent = <&gpio6>; - interrupts = <7 IRQ_TYPE_EDGE_FALLING>; - pinctrl-names = "default"; - pinctrl-0 = <&int_codec>; - }; -}; - -&i2c3 { - status = "okay"; - - clock-frequency = <400000>; - i2c-scl-falling-time-ns = <50>; - i2c-scl-rising-time-ns = <300>; };
&i2c4 { @@ -462,56 +342,61 @@ clock-frequency = <400000>; i2c-scl-falling-time-ns = <50>; /* 11ns measured */ i2c-scl-rising-time-ns = <300>; /* 225ns measured */ - - headsetcodec: ts3a227e@3b { - compatible = "ti,ts3a227e"; - reg = <0x3b>; - interrupt-parent = <&gpio0>; - interrupts = <3 IRQ_TYPE_LEVEL_LOW>; - pinctrl-names = "default"; - pinctrl-0 = <&ts3a227e_int_l>; - ti,micbias = <7>; /* MICBIAS = 2.8V */ - }; -}; - -&i2c5 { - status = "okay"; - - clock-frequency = <100000>; - i2c-scl-falling-time-ns = <300>; - i2c-scl-rising-time-ns = <1000>; -}; - -&i2s { - status = "okay"; - clock-names = "i2s_hclk", "i2s_clk", "i2s_clk_out"; - clocks = <&cru HCLK_I2S0>, <&cru SCLK_I2S0>, <&cru SCLK_I2S0_OUT>; };
&io_domains { status = "okay";
- audio-supply = <&vcc18_codec>; bb-supply = <&vcc33_io>; dvp-supply = <&vcc_18>; flash0-supply = <&vcc18_flashio>; gpio1830-supply = <&vcc33_io>; gpio30-supply = <&vcc33_io>; lcdc-supply = <&vcc33_lcd>; - sdcard-supply = <&vccio_sd>; wifi-supply = <&vcc18_wl>; };
-&wdt { +&pwm1 { + status = "okay"; +}; + +&sdio0 { status = "okay"; + + bus-width = <4>; + cap-sd-highspeed; + cap-sdio-irq; + keep-power-in-suspend; + mmc-pwrseq = <&sdio_pwrseq>; + non-removable; + pinctrl-names = "default"; + pinctrl-0 = <&sdio0_clk &sdio0_cmd &sdio0_bus4>; + sd-uhs-sdr12; + sd-uhs-sdr25; + sd-uhs-sdr50; + sd-uhs-sdr104; + vmmc-supply = <&vcc33_sys>; + vqmmc-supply = <&vcc18_wl>; };
-&pwm0 { +&spi2 { status = "okay"; + + rx-sample-delay-ns = <12>; + + spi_flash: flash@0 { + compatible = "jedec,spi-nor"; + spi-max-frequency = <50000000>; + reg = <0>; + }; };
-&pwm1 { +&tsadc { status = "okay"; + + rockchip,hw-tshut-mode = <1>; /* tshut mode 0:CRU 1:GPIO */ + rockchip,hw-tshut-polarity = <1>; /* tshut polarity 0:LOW 1:HIGH */ + rockchip,hw-tshut-temp = <125000>; };
&uart0 { @@ -520,9 +405,6 @@ /* Pins don't include flow control by default; add that in */ pinctrl-names = "default"; pinctrl-0 = <&uart0_xfer &uart0_cts &uart0_rts>; - /* We need to go faster than 24MHz, so adjust clock parents / rates */ - assigned-clocks = <&cru SCLK_UART0>; - assigned-clock-rates = <48000000>; };
&uart1 { @@ -531,67 +413,47 @@
&uart2 { status = "okay"; - reg-shift = <2>; };
-&vopb { +&usbphy { status = "okay"; };
-&vopb_mmu { +&usb_host0_ehci { status = "okay"; -};
-&vopl { - status = "okay"; + needs-reset-on-resume; };
-&vopl_mmu { +&usb_host1 { status = "okay"; + snps,need-phy-for-wake; };
-&edp { +&usb_otg { status = "okay"; - rockchip,panel = <&panel>; + + assigned-clocks = <&cru SCLK_USBPHY480M_SRC>; + assigned-clock-parents = <&usbphy0>; + dr_mode = "host"; + snps,need-phy-for-wake; };
-&hdmi { +&vopb { status = "okay"; };
-&gpu { +&vopb_mmu { status = "okay"; };
-&tsadc { - tsadc-tshut-mode = <1>; /* tshut mode 0:CRU 1:GPIO */ - tsadc-tshut-polarity = <1>; /* tshut polarity 0:LOW 1:HIGH */ +&wdt { status = "okay"; };
&pinctrl { - pinctrl-names = "default", "sleep"; - pinctrl-0 = < - /* Common for sleep and wake, but no owners */ - &ddr0_retention - &ddrio_pwroff - &global_pwroff - - /* Wake only */ - &bt_dev_wake_awake - >; - pinctrl-1 = < - /* Common for sleep and wake, but no owners */ - &ddr0_retention - &ddrio_pwroff - &global_pwroff - - /* Sleep only */ - &bt_dev_wake_sleep - >; - - /* Add this for sdmmc pins to SD card */ pcfg_pull_none_drv_8ma: pcfg-pull-none-drv-8ma { + bias-disable; drive-strength = <8>; };
@@ -608,33 +470,15 @@ output-low; };
- backlight { - bl_en: bl-en { - rockchip,pins = <7 2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - buttons { - pwr_key_h: pwr-key-h { - rockchip,pins = <0 5 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - codec { - hp_det: hp-det { - rockchip,pins = <6 5 RK_FUNC_GPIO &pcfg_pull_up>; - }; - int_codec: int-codec { - rockchip,pins = <6 7 RK_FUNC_GPIO &pcfg_pull_up>; - }; - mic_det: mic-det { - rockchip,pins = <6 11 RK_FUNC_GPIO &pcfg_pull_up>; + pwr_key_l: pwr-key-l { + rockchip,pins = <0 RK_PA5 RK_FUNC_GPIO &pcfg_pull_up>; }; };
emmc { emmc_reset: emmc-reset { - rockchip,pins = <2 9 RK_FUNC_GPIO &pcfg_pull_none>; + rockchip,pins = <2 RK_PB1 RK_FUNC_GPIO &pcfg_pull_none>; };
/* @@ -642,54 +486,59 @@ * We also have external pulls, so disable the internal ones. */ emmc_clk: emmc-clk { - rockchip,pins = <3 18 RK_FUNC_2 &pcfg_pull_none_drv_8ma>; + rockchip,pins = <3 RK_PC2 2 &pcfg_pull_none_drv_8ma>; };
emmc_cmd: emmc-cmd { - rockchip,pins = <3 16 RK_FUNC_2 &pcfg_pull_none_drv_8ma>; + rockchip,pins = <3 RK_PC0 2 &pcfg_pull_none_drv_8ma>; };
emmc_bus8: emmc-bus8 { - rockchip,pins = <3 0 RK_FUNC_2 &pcfg_pull_none_drv_8ma>, - <3 1 RK_FUNC_2 &pcfg_pull_none_drv_8ma>, - <3 2 RK_FUNC_2 &pcfg_pull_none_drv_8ma>, - <3 3 RK_FUNC_2 &pcfg_pull_none_drv_8ma>, - <3 4 RK_FUNC_2 &pcfg_pull_none_drv_8ma>, - <3 5 RK_FUNC_2 &pcfg_pull_none_drv_8ma>, - <3 6 RK_FUNC_2 &pcfg_pull_none_drv_8ma>, - <3 7 RK_FUNC_2 &pcfg_pull_none_drv_8ma>; - }; - }; - - headset { - ts3a227e_int_l: ts3a227e-int-l { - rockchip,pins = <0 3 RK_FUNC_GPIO &pcfg_pull_up>; + rockchip,pins = <3 RK_PA0 2 &pcfg_pull_none_drv_8ma>, + <3 RK_PA1 2 &pcfg_pull_none_drv_8ma>, + <3 RK_PA2 2 &pcfg_pull_none_drv_8ma>, + <3 RK_PA3 2 &pcfg_pull_none_drv_8ma>, + <3 RK_PA4 2 &pcfg_pull_none_drv_8ma>, + <3 RK_PA5 2 &pcfg_pull_none_drv_8ma>, + <3 RK_PA6 2 &pcfg_pull_none_drv_8ma>, + <3 RK_PA7 2 &pcfg_pull_none_drv_8ma>; }; };
pmic { pmic_int_l: pmic-int-l { - /* - * Causes jerry to hang when probing bus 0 - * rockchip,pins = <RK_GPIO0 4 RK_FUNC_GPIO &pcfg_pull_up>; - */ + rockchip,pins = <0 RK_PA4 RK_FUNC_GPIO &pcfg_pull_up>; }; };
reboot { ap_warm_reset_h: ap-warm-reset-h { - rockchip,pins = <RK_GPIO0 13 RK_FUNC_GPIO &pcfg_pull_none>; + rockchip,pins = <0 RK_PB5 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + recovery-switch { + rec_mode_l: rec-mode-l { + rockchip,pins = <0 RK_PB1 RK_FUNC_GPIO &pcfg_pull_up>; }; };
sdio0 { wifi_enable_h: wifienable-h { - rockchip,pins = <4 28 RK_FUNC_GPIO &pcfg_pull_none>; + rockchip,pins = <4 RK_PD4 RK_FUNC_GPIO &pcfg_pull_none>; };
/* NOTE: mislabelled on schematic; should be bt_enable_h */ bt_enable_l: bt-enable-l { - rockchip,pins = <4 29 RK_FUNC_GPIO &pcfg_pull_none>; + rockchip,pins = <4 RK_PD5 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + bt_host_wake: bt-host-wake { + rockchip,pins = <4 RK_PD7 RK_FUNC_GPIO &pcfg_pull_down>; + }; + + bt_host_wake_l: bt-host-wake-l { + rockchip,pins = <4 RK_PD7 RK_FUNC_GPIO &pcfg_pull_none>; };
/* @@ -697,100 +546,48 @@ * We also have external pulls, so disable the internal ones. */ sdio0_bus4: sdio0-bus4 { - rockchip,pins = <4 20 RK_FUNC_1 &pcfg_pull_none_drv_8ma>, - <4 21 RK_FUNC_1 &pcfg_pull_none_drv_8ma>, - <4 22 RK_FUNC_1 &pcfg_pull_none_drv_8ma>, - <4 23 RK_FUNC_1 &pcfg_pull_none_drv_8ma>; + rockchip,pins = <4 RK_PC4 1 &pcfg_pull_none_drv_8ma>, + <4 RK_PC5 1 &pcfg_pull_none_drv_8ma>, + <4 RK_PC6 1 &pcfg_pull_none_drv_8ma>, + <4 RK_PC7 1 &pcfg_pull_none_drv_8ma>; };
sdio0_cmd: sdio0-cmd { - rockchip,pins = <4 24 RK_FUNC_1 &pcfg_pull_none_drv_8ma>; + rockchip,pins = <4 RK_PD0 1 &pcfg_pull_none_drv_8ma>; };
sdio0_clk: sdio0-clk { - rockchip,pins = <4 25 RK_FUNC_1 &pcfg_pull_none_drv_8ma>; + rockchip,pins = <4 RK_PD1 1 &pcfg_pull_none_drv_8ma>; };
/* * These pins are only present on very new veyron boards; on * older boards bt_dev_wake is simply always high. Note that - * gpio4_26 is a NC on old veyron boards, so it doesn't hurt + * gpio4_D2 is a NC on old veyron boards, so it doesn't hurt * to map this pin everywhere */ bt_dev_wake_sleep: bt-dev-wake-sleep { - rockchip,pins = <4 26 RK_FUNC_GPIO &pcfg_output_low>; + rockchip,pins = <4 RK_PD2 RK_FUNC_GPIO &pcfg_output_low>; };
bt_dev_wake_awake: bt-dev-wake-awake { - rockchip,pins = <4 26 RK_FUNC_GPIO &pcfg_output_high>; - }; - }; - - sdmmc { - /* - * We run sdmmc at max speed; bump up drive strength. - * We also have external pulls, so disable the internal ones. - */ - sdmmc_bus4: sdmmc-bus4 { - rockchip,pins = <6 16 RK_FUNC_1 &pcfg_pull_none_drv_8ma>, - <6 17 RK_FUNC_1 &pcfg_pull_none_drv_8ma>, - <6 18 RK_FUNC_1 &pcfg_pull_none_drv_8ma>, - <6 19 RK_FUNC_1 &pcfg_pull_none_drv_8ma>; - }; - - sdmmc_clk: sdmmc-clk { - rockchip,pins = <6 20 RK_FUNC_1 &pcfg_pull_none_drv_8ma>; - }; - - sdmmc_cmd: sdmmc-cmd { - rockchip,pins = <6 21 RK_FUNC_1 &pcfg_pull_none_drv_8ma>; - }; - - /* - * Builtin CD line is hooked to ground to prevent JTAG at boot - * (and also to get the voltage rail correct). Make we - * configure gpio6_C6 as GPIO so dw_mmc builtin CD doesn't - * think there's a card inserted - */ - sdmmc_cd_disabled: sdmmc-cd-disabled { - rockchip,pins = <6 22 RK_FUNC_GPIO &pcfg_pull_none>; + rockchip,pins = <4 RK_PD2 RK_FUNC_GPIO &pcfg_output_high>; };
- /* This is where we actually hook up CD */ - sdmmc_cd_gpio: sdmmc-cd-gpio { - rockchip,pins = <7 5 RK_FUNC_GPIO &pcfg_pull_none>; + bt_dev_wake: bt-dev-wake { + rockchip,pins = <4 RK_PD2 RK_FUNC_GPIO &pcfg_pull_none>; }; };
tpm { tpm_int_h: tpm-int-h { - rockchip,pins = <7 4 RK_FUNC_GPIO &pcfg_pull_none>; + rockchip,pins = <7 RK_PA4 RK_FUNC_GPIO &pcfg_pull_none>; }; };
write-protect { fw_wp_ap: fw-wp-ap { - rockchip,pins = <7 6 RK_FUNC_GPIO &pcfg_pull_none>; + rockchip,pins = <7 RK_PA6 RK_FUNC_GPIO &pcfg_pull_none>; }; }; }; - -&usbphy { - status = "okay"; -}; - -&usb_host0_ehci { - status = "okay"; - needs-reset-on-resume; -}; - -&usb_host1 { - status = "okay"; -}; - -&usb_otg { - dr_mode = "host"; - status = "okay"; - assigned-clocks = <&cru SCLK_USBPHY480M_SRC>; - assigned-clock-parents = <&cru SCLK_OTGPHY0>; -};
On 2022/3/4 07:52, Johan Jonker wrote:
Sync rk3288-veyron DT from Linux version 5.17.
Signed-off-by: Johan Jonker jbx6244@gmail.com
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
Changed V3: update change reg size
Changed V2: update add label spi_flash veyron
arch/arm/dts/rk3288-veyron-analog-audio.dtsi | 99 +++ .../dts/rk3288-veyron-broadcom-bluetooth.dtsi | 22 + arch/arm/dts/rk3288-veyron-chromebook.dtsi | 115 ++-- arch/arm/dts/rk3288-veyron-edp.dtsi | 141 ++++ arch/arm/dts/rk3288-veyron-jerry.dts | 506 +++++++++++--- arch/arm/dts/rk3288-veyron-mickey.dts | 343 +++++++--- arch/arm/dts/rk3288-veyron-minnie.dts | 441 +++++++----- arch/arm/dts/rk3288-veyron-sdmmc.dtsi | 89 +++ arch/arm/dts/rk3288-veyron-speedy.dts | 303 ++++++-- arch/arm/dts/rk3288-veyron.dtsi | 645 ++++++------------ 10 files changed, 1799 insertions(+), 905 deletions(-) create mode 100644 arch/arm/dts/rk3288-veyron-analog-audio.dtsi create mode 100644 arch/arm/dts/rk3288-veyron-broadcom-bluetooth.dtsi create mode 100644 arch/arm/dts/rk3288-veyron-edp.dtsi create mode 100644 arch/arm/dts/rk3288-veyron-sdmmc.dtsi
diff --git a/arch/arm/dts/rk3288-veyron-analog-audio.dtsi b/arch/arm/dts/rk3288-veyron-analog-audio.dtsi new file mode 100644 index 00000000..51208d16 --- /dev/null +++ b/arch/arm/dts/rk3288-veyron-analog-audio.dtsi @@ -0,0 +1,99 @@ +// SPDX-License-Identifier: GPL-2.0 +/*
- Google Veyron (and derivatives) fragment for the max98090 audio
- codec and analog headphone jack.
- Copyright 2016 Google, Inc
- sound {
rockchip,model = "VEYRON-I2S";
rockchip,hp-det-gpios = <&gpio6 RK_PA5 GPIO_ACTIVE_HIGH>;
rockchip,mic-det-gpios = <&gpio6 RK_PB3 GPIO_ACTIVE_LOW>;
+&i2c2 {
reg = <0x10>;
interrupts = <RK_PA7 IRQ_TYPE_EDGE_FALLING>;
clock-names = "mclk";
clocks = <&cru SCLK_I2S0_OUT>;
+&i2c4 {
reg = <0x3b>;
interrupts = <RK_PA3 IRQ_TYPE_LEVEL_LOW>;
+&i2s {
- status = "okay";
+&io_domains {
+&rk808 {
- regulators {
regulator-boot-on;
+&pinctrl {
- codec {
hp_det: hp-det {
rockchip,pins = <6 RK_PA5 RK_FUNC_GPIO &pcfg_pull_up>;
* HACK: We're going to _pull down_ this _active low_ interrupt
* so that it never fires. We don't need this interrupt because
* we've got a ts3a227e chip but the driver requires it.
rockchip,pins = <6 RK_PA7 RK_FUNC_GPIO &pcfg_pull_down>;
mic_det: mic-det {
rockchip,pins = <6 RK_PB3 RK_FUNC_GPIO &pcfg_pull_up>;
- headset {
rockchip,pins = <0 RK_PA3 RK_FUNC_GPIO &pcfg_pull_up>;
+}; diff --git a/arch/arm/dts/rk3288-veyron-broadcom-bluetooth.dtsi b/arch/arm/dts/rk3288-veyron-broadcom-bluetooth.dtsi new file mode 100644 index 00000000..a10d25ac --- /dev/null +++ b/arch/arm/dts/rk3288-veyron-broadcom-bluetooth.dtsi @@ -0,0 +1,22 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/*
- Google Veyron (and derivatives) fragment for the Broadcom 43450 bluetooth
- chip.
- Copyright 2019 Google, Inc
+&uart0 {
- bluetooth {
pinctrl-0 = <&bt_host_wake_l>, <&bt_enable_l>,
<&bt_dev_wake>;
compatible = "brcm,bcm43540-bt";
host-wakeup-gpios = <&gpio4 RK_PD7 GPIO_ACTIVE_HIGH>;
shutdown-gpios = <&gpio4 RK_PD5 GPIO_ACTIVE_HIGH>;
device-wakeup-gpios = <&gpio4 RK_PD2 GPIO_ACTIVE_HIGH>;
max-speed = <3000000>;
brcm,bt-pcm-int-params = [01 02 00 01 01];
+}; diff --git a/arch/arm/dts/rk3288-veyron-chromebook.dtsi b/arch/arm/dts/rk3288-veyron-chromebook.dtsi index 143eaae2..05112c25 100644 --- a/arch/arm/dts/rk3288-veyron-chromebook.dtsi +++ b/arch/arm/dts/rk3288-veyron-chromebook.dtsi @@ -1,39 +1,45 @@ -// SPDX-License-Identifier: GPL-2.0 +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) /*
- Google Veyron (and derivatives) board device tree source
- Chromebook specific parts
- Copyright 2014 Google, Inc
- Copyright 2015 Google, Inc
#include <dt-bindings/clock/rockchip,rk808.h> #include <dt-bindings/input/input.h> #include "rk3288-veyron.dtsi"
+#include "rk3288-veyron-analog-audio.dtsi" +#include "rk3288-veyron-edp.dtsi" +#include "rk3288-veyron-sdmmc.dtsi"
/ { aliases {
i2c20 = &i2c_tunnel;/* Assign 20 so we don't get confused w/ builtin ones */
video0 = &vopl;
video1 = &vopb;
pinctrl-0 = <&pwr_key_h &ap_lid_int_l>;
lid {
label = "Lid";
gpios = <&gpio0 6 GPIO_ACTIVE_LOW>;
linux,code = <0>; /* SW_LID */
linux,input-type = <5>; /* EV_SW */
debounce-interval = <1>;
gpio-key,wakeup;
gpio-charger { compatible = "gpio-charger";
gpios = <&gpio0 8 GPIO_ACTIVE_HIGH>;
charger-type = "mains";
pinctrl-names = "default"; pinctrl-0 = <&ac_present_ap>;gpios = <&gpio0 RK_PB0 GPIO_ACTIVE_HIGH>;
lid_switch: lid-switch {
pinctrl-0 = <&ap_lid_int_l>;
lid {
label = "Lid";
gpios = <&gpio0 RK_PA6 GPIO_ACTIVE_LOW>;
wakeup-source;
linux,code = <SW_LID>;
linux,input-type = <EV_SW>;
/* A non-regulated voltage from power supply or battery */
@@ -56,7 +62,7 @@ vcc5_host1: vcc5-host1-regulator { compatible = "regulator-fixed"; enable-active-high;
gpio = <&gpio0 11 GPIO_ACTIVE_HIGH>;
pinctrl-names = "default"; pinctrl-0 = <&host1_pwr_en>; regulator-name = "vcc5_host1";gpio = <&gpio0 RK_PB3 GPIO_ACTIVE_HIGH>;
@@ -68,7 +74,7 @@ vcc5v_otg: vcc5v-otg-regulator { compatible = "regulator-fixed"; enable-active-high;
gpio = <&gpio0 12 GPIO_ACTIVE_HIGH>;
pinctrl-names = "default"; pinctrl-0 = <&usbotg_pwren_h>; regulator-name = "vcc5_host2";gpio = <&gpio0 RK_PB4 GPIO_ACTIVE_HIGH>;
@@ -78,34 +84,34 @@ };
&rk808 {
- regulators { vcc33_ccd: LDO_REG8 {
regulator-name = "vcc33_ccd"; regulator-always-on; regulator-boot-on; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>;
&spi0 { status = "okay";
spi-activate-delay = <100>;
spi-max-frequency = <3000000>;
spi-deactivate-delay = <200>;
cros_ec: ec@0 { compatible = "google,cros-ec-spi";
reg = <0>;
interrupt-parent = <&gpio7>;google,cros-ec-spi-pre-delay = <30>;
interrupts = <7 IRQ_TYPE_LEVEL_LOW>;
ec-interrupt = <&gpio7 7 GPIO_ACTIVE_LOW>;
pinctrl-names = "default"; pinctrl-0 = <&ec_int>;interrupts = <RK_PA7 IRQ_TYPE_LEVEL_LOW>;
reg = <0>;
i2c_tunnel: i2c-tunnel { compatible = "google,cros-ec-i2c-tunnel";
@@ -118,86 +124,59 @@
&i2c4 { trackpad@15 {
compatible = "elan,ekth3000";
interrupt-parent = <&gpio7>;reg = <0x15>;
pinctrl-names = "default"; pinctrl-0 = <&trackpad_int>;interrupts = <RK_PA3 IRQ_TYPE_EDGE_FALLING>;
reg = <0x15>;
vcc-supply = <&vcc33_io>; wakeup-source; }; };
&pinctrl {
pinctrl-0 = <
&ddr0_retention
&ddrio_pwroff
&global_pwroff
/* Wake only */
&suspend_l_wake
&bt_dev_wake_awake
pinctrl-1 = <
&ddr0_retention
&ddrio_pwroff
&global_pwroff
/* Sleep only */
&suspend_l_sleep
&bt_dev_wake_sleep
buttons { ap_lid_int_l: ap-lid-int-l {
rockchip,pins = <0 6 RK_FUNC_GPIO &pcfg_pull_up>;
rockchip,pins = <0 RK_PA6 RK_FUNC_GPIO &pcfg_pull_up>;
charger { ac_present_ap: ac-present-ap {
rockchip,pins = <0 8 RK_FUNC_GPIO &pcfg_pull_up>;
rockchip,pins = <0 RK_PB0 RK_FUNC_GPIO &pcfg_pull_up>;
cros-ec { ec_int: ec-int {
rockchip,pins = <7 7 RK_FUNC_GPIO &pcfg_pull_none>;
- sdmmc {
sdmmc_wp_gpio: sdmmc-wp-gpio {
rockchip,pins = <7 10 RK_FUNC_GPIO &pcfg_pull_up>;
rockchip,pins = <7 RK_PA7 RK_FUNC_GPIO &pcfg_pull_none>;
suspend { suspend_l_wake: suspend-l-wake {
rockchip,pins = <0 17 RK_FUNC_GPIO &pcfg_output_low>;
rockchip,pins = <0 RK_PC1 RK_FUNC_GPIO &pcfg_output_low>;
suspend_l_sleep: suspend-l-sleep {
rockchip,pins = <0 17 RK_FUNC_GPIO &pcfg_output_high>;
rockchip,pins = <0 RK_PC1 RK_FUNC_GPIO &pcfg_output_high>;
trackpad { trackpad_int: trackpad-int {
rockchip,pins = <7 3 RK_FUNC_GPIO &pcfg_pull_up>;
rockchip,pins = <7 RK_PA3 RK_FUNC_GPIO &pcfg_pull_up>;
usb-host { host1_pwr_en: host1-pwr-en {
rockchip,pins = <0 11 RK_FUNC_GPIO &pcfg_pull_none>;
rockchip,pins = <0 RK_PB3 RK_FUNC_GPIO &pcfg_pull_none>;
usbotg_pwren_h: usbotg-pwren-h {
rockchip,pins = <0 12 RK_FUNC_GPIO &pcfg_pull_none>;
}; }; };rockchip,pins = <0 RK_PB4 RK_FUNC_GPIO &pcfg_pull_none>;
diff --git a/arch/arm/dts/rk3288-veyron-edp.dtsi b/arch/arm/dts/rk3288-veyron-edp.dtsi new file mode 100644 index 00000000..32c0f107 --- /dev/null +++ b/arch/arm/dts/rk3288-veyron-edp.dtsi @@ -0,0 +1,141 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/*
- Google Veyron (and derivatives) fragment for the edp displays
- Copyright 2019 Google LLC
enable-active-high;
enable-active-high;
enable-active-high;
regulator-boot-on;
brightness-levels = <0 255>;
num-interpolated-steps = <255>;
enable-gpios = <&gpio7 RK_PA2 GPIO_ACTIVE_HIGH>;
post-pwm-on-delay-ms = <10>;
pwm-off-delay-ms = <10>;
- panel: panel {
compatible = "innolux,n116bge";
status = "okay";
panel-timing {
clock-frequency = <74250000>;
hactive = <1366>;
hfront-porch = <136>;
hback-porch = <60>;
hsync-len = <30>;
hsync-active = <0>;
vactive = <768>;
vfront-porch = <8>;
vback-porch = <12>;
vsync-len = <12>;
vsync-active = <0>;
ports {
panel_in: port {
panel_in_edp: endpoint {
remote-endpoint = <&edp_out_panel>;
+&edp {
- status = "okay";
- pinctrl-0 = <&edp_hpd>;
- ports {
edp_out: port@1 {
reg = <1>;
#address-cells = <1>;
#size-cells = <0>;
edp_out_panel: endpoint@0 {
reg = <0>;
remote-endpoint = <&panel_in_edp>;
+&edp_phy {
- status = "okay";
+&pwm0 {
- status = "okay";
+&vopl {
- status = "okay";
+&vopl_mmu {
- status = "okay";
+&pinctrl {
- backlight {
rockchip,pins = <2 RK_PB4 RK_FUNC_GPIO &pcfg_pull_none>;
bl_en: bl-en {
rockchip,pins = <7 RK_PA2 RK_FUNC_GPIO &pcfg_pull_none>;
- lcd {
rockchip,pins = <7 RK_PB6 RK_FUNC_GPIO &pcfg_pull_none>;
rockchip,pins = <2 RK_PB5 RK_FUNC_GPIO &pcfg_pull_none>;
+}; diff --git a/arch/arm/dts/rk3288-veyron-jerry.dts b/arch/arm/dts/rk3288-veyron-jerry.dts index 40fee55c..2c916c50 100644 --- a/arch/arm/dts/rk3288-veyron-jerry.dts +++ b/arch/arm/dts/rk3288-veyron-jerry.dts @@ -1,8 +1,8 @@ -// SPDX-License-Identifier: GPL-2.0 +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) /*
- Google Veyron Jerry Rev 3+ board device tree source
/dts-v1/;
@@ -11,162 +11,454 @@
/ { model = "Google Jerry";
- compatible = "google,veyron-jerry-rev7", "google,veyron-jerry-rev6",
- compatible = "google,veyron-jerry-rev15", "google,veyron-jerry-rev14",
"google,veyron-jerry-rev13", "google,veyron-jerry-rev12",
"google,veyron-jerry-rev11", "google,veyron-jerry-rev10",
"google,veyron-jerry-rev7", "google,veyron-jerry-rev6", "google,veyron-jerry-rev5", "google,veyron-jerry-rev4", "google,veyron-jerry-rev3", "google,veyron-jerry", "google,veyron", "rockchip,rk3288";
chosen {
enable-active-high;
enable-active-high;
regulator-boot-on;
enable-active-high;
- sound {
cpu {
codec {
-&gpio_keys {
- power {
gpios = <&gpio0 5 GPIO_ACTIVE_LOW>;
-&backlight {
-&panel {
power-supply= <&panel_regulator>; };
&rk808 { pinctrl-names = "default"; pinctrl-0 = <&pmic_int_l &dvs_1 &dvs_2>;
dvs-gpios = <&gpio7 12 GPIO_ACTIVE_HIGH>,
<&gpio7 15 GPIO_ACTIVE_HIGH>;
dvs-gpios = <&gpio7 RK_PB4 GPIO_ACTIVE_HIGH>,
<&gpio7 RK_PB7 GPIO_ACTIVE_HIGH>;
regulators { mic_vcc: LDO_REG2 {
regulator-name = "mic_vcc"; regulator-always-on; regulator-boot-on; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>;
+&sdio0 {
- #address-cells = <1>;
- #size-cells = <0>;
- mwifiex: wifi@1 {
compatible = "marvell,sd8897";
reg = <1>;
marvell,caldata-txpwrlimit-2g = /bits/ 8 <
+0x01 0x00 0x06 0x00 0x08 0x02 0x89 0x01 +0x24 0x00 0x67 0x09 0x14 0x01 0x00 0x0f 0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0c +0x05 0x0c 0x06 0x0c 0x07 0x09 0x08 0x09 0x09 0x09 0x0a 0x0c 0x0b 0x0c 0x0c 0x0c +0x0d 0x09 0x0e 0x09 0x0f 0x09 0x89 0x01 0x24 0x00 0x67 0x09 0x14 0x02 0x00 0x0f +0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0c 0x05 0x0c 0x06 0x0c 0x07 0x09 0x08 0x09 +0x09 0x09 0x0a 0x0c 0x0b 0x0c 0x0c 0x0c 0x0d 0x09 0x0e 0x09 0x0f 0x09 0x89 0x01 +0x24 0x00 0x67 0x09 0x14 0x03 0x00 0x0f 0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0c +0x05 0x0c 0x06 0x0c 0x07 0x09 0x08 0x09 0x09 0x09 0x0a 0x0c 0x0b 0x0c 0x0c 0x0c +0x0d 0x09 0x0e 0x09 0x0f 0x09 0x89 0x01 0x24 0x00 0x67 0x09 0x14 0x04 0x00 0x0f +0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0c 0x05 0x0c 0x06 0x0c 0x07 0x09 0x08 0x09 +0x09 0x09 0x0a 0x0c 0x0b 0x0c 0x0c 0x0c 0x0d 0x09 0x0e 0x09 0x0f 0x09 0x89 0x01 +0x24 0x00 0x67 0x09 0x14 0x05 0x00 0x0f 0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0c +0x05 0x0c 0x06 0x0c 0x07 0x09 0x08 0x09 0x09 0x09 0x0a 0x0c 0x0b 0x0c 0x0c 0x0c +0x0d 0x09 0x0e 0x09 0x0f 0x09 0x89 0x01 0x24 0x00 0x67 0x09 0x14 0x06 0x00 0x0f +0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0c 0x05 0x0c 0x06 0x0c 0x07 0x09 0x08 0x09 +0x09 0x09 0x0a 0x0c 0x0b 0x0c 0x0c 0x0c 0x0d 0x09 0x0e 0x09 0x0f 0x09 0x89 0x01 +0x24 0x00 0x67 0x09 0x14 0x07 0x00 0x0f 0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0c +0x05 0x0c 0x06 0x0c 0x07 0x09 0x08 0x09 0x09 0x09 0x0a 0x0c 0x0b 0x0c 0x0c 0x0c +0x0d 0x09 0x0e 0x09 0x0f 0x09 0x89 0x01 0x24 0x00 0x67 0x09 0x14 0x08 0x00 0x0f +0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0c 0x05 0x0c 0x06 0x0c 0x07 0x09 0x08 0x09 +0x09 0x09 0x0a 0x0c 0x0b 0x0c 0x0c 0x0c 0x0d 0x09 0x0e 0x09 0x0f 0x09 0x89 0x01 +0x24 0x00 0x67 0x09 0x14 0x09 0x00 0x0f 0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0c +0x05 0x0c 0x06 0x0c 0x07 0x09 0x08 0x09 0x09 0x09 0x0a 0x0c 0x0b 0x0c 0x0c 0x0c +0x0d 0x09 0x0e 0x09 0x0f 0x09 0x89 0x01 0x24 0x00 0x67 0x09 0x14 0x0a 0x00 0x0f +0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0c 0x05 0x0c 0x06 0x0c 0x07 0x09 0x08 0x09 +0x09 0x09 0x0a 0x0c 0x0b 0x0c 0x0c 0x0c 0x0d 0x09 0x0e 0x09 0x0f 0x09 0x89 0x01 +0x24 0x00 0x67 0x09 0x14 0x0b 0x00 0x0f 0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0c +0x05 0x0c 0x06 0x0c 0x07 0x09 0x08 0x09 0x09 0x09 0x0a 0x0c 0x0b 0x0c 0x0c 0x0c +0x0d 0x09 0x0e 0x09 0x0f 0x09 0x89 0x01 0x24 0x00 0x67 0x09 0x14 0x0c 0x00 0x0f +0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0c 0x05 0x0c 0x06 0x0c 0x07 0x09 0x08 0x09 +0x09 0x09 0x0a 0x0c 0x0b 0x0c 0x0c 0x0c 0x0d 0x09 0x0e 0x09 0x0f 0x09 0x89 0x01 +0x24 0x00 0x67 0x09 0x14 0x0d 0x00 0x0f 0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0c +0x05 0x0c 0x06 0x0c 0x07 0x09 0x08 0x09 0x09 0x09 0x0a 0x0c 0x0b 0x0c 0x0c 0x0c +0x0d 0x09 0x0e 0x09 0x0f 0x09>;
marvell,caldata-txpwrlimit-5g-sub0 = /bits/ 8 <
+0x01 0x00 0x06 0x00 0xf0 0x01 0x89 0x01 +0x3a 0x00 0x88 0x13 0x14 0x24 0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0a 0x05 0x0a +0x06 0x0a 0x07 0x09 0x08 0x09 0x09 0x09 0x0a 0x0a 0x0b 0x0a 0x0c 0x0a 0x0d 0x09 +0x0e 0x09 0x0f 0x09 0x10 0x05 0x11 0x05 0x12 0x05 0x13 0x05 0x14 0x05 0x15 0x05 +0x16 0x05 0x17 0x05 0x18 0x05 0x19 0x05 0x1a 0x05 0x1b 0x05 0x89 0x01 0x3a 0x00 +0x88 0x13 0x14 0x28 0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0a 0x05 0x0a 0x06 0x0a +0x07 0x09 0x08 0x09 0x09 0x09 0x0a 0x0a 0x0b 0x0a 0x0c 0x0a 0x0d 0x09 0x0e 0x09 +0x0f 0x09 0x10 0x05 0x11 0x05 0x12 0x05 0x13 0x05 0x14 0x05 0x15 0x05 0x16 0x05 +0x17 0x05 0x18 0x05 0x19 0x05 0x1a 0x05 0x1b 0x05 0x89 0x01 0x3a 0x00 0x88 0x13 +0x14 0x2c 0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0a 0x05 0x0a 0x06 0x0a 0x07 0x09 +0x08 0x09 0x09 0x09 0x0a 0x0a 0x0b 0x0a 0x0c 0x0a 0x0d 0x09 0x0e 0x09 0x0f 0x09 +0x10 0x05 0x11 0x05 0x12 0x05 0x13 0x05 0x14 0x05 0x15 0x05 0x16 0x05 0x17 0x05 +0x18 0x05 0x19 0x05 0x1a 0x05 0x1b 0x05 0x89 0x01 0x3a 0x00 0x88 0x13 0x14 0x30 +0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0a 0x05 0x0a 0x06 0x0a 0x07 0x09 0x08 0x09 +0x09 0x09 0x0a 0x0a 0x0b 0x0a 0x0c 0x0a 0x0d 0x09 0x0e 0x09 0x0f 0x09 0x10 0x05 +0x11 0x05 0x12 0x05 0x13 0x05 0x14 0x05 0x15 0x05 0x16 0x05 0x17 0x05 0x18 0x05 +0x19 0x05 0x1a 0x05 0x1b 0x05 0x89 0x01 0x3a 0x00 0x88 0x13 0x14 0x34 0x01 0x0c +0x02 0x0c 0x03 0x0c 0x04 0x0a 0x05 0x0a 0x06 0x0a 0x07 0x09 0x08 0x09 0x09 0x09 +0x0a 0x0a 0x0b 0x0a 0x0c 0x0a 0x0d 0x09 0x0e 0x09 0x0f 0x09 0x10 0x05 0x11 0x05 +0x12 0x05 0x13 0x05 0x14 0x05 0x15 0x05 0x16 0x05 0x17 0x05 0x18 0x05 0x19 0x05 +0x1a 0x05 0x1b 0x05 0x89 0x01 0x3a 0x00 0x88 0x13 0x14 0x38 0x01 0x0c 0x02 0x0c +0x03 0x0c 0x04 0x0a 0x05 0x0a 0x06 0x0a 0x07 0x09 0x08 0x09 0x09 0x09 0x0a 0x0a +0x0b 0x0a 0x0c 0x0a 0x0d 0x09 0x0e 0x09 0x0f 0x09 0x10 0x05 0x11 0x05 0x12 0x05 +0x13 0x05 0x14 0x05 0x15 0x05 0x16 0x05 0x17 0x05 0x18 0x05 0x19 0x05 0x1a 0x05 +0x1b 0x05 0x89 0x01 0x3a 0x00 0x88 0x13 0x14 0x3c 0x01 0x0c 0x02 0x0c 0x03 0x0c +0x04 0x0a 0x05 0x0a 0x06 0x0a 0x07 0x09 0x08 0x09 0x09 0x09 0x0a 0x0a 0x0b 0x0a +0x0c 0x0a 0x0d 0x09 0x0e 0x09 0x0f 0x09 0x10 0x05 0x11 0x05 0x12 0x05 0x13 0x05 +0x14 0x05 0x15 0x05 0x16 0x05 0x17 0x05 0x18 0x05 0x19 0x05 0x1a 0x05 0x1b 0x05 +0x89 0x01 0x3a 0x00 0x88 0x13 0x14 0x40 0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0a +0x05 0x0a 0x06 0x0a 0x07 0x09 0x08 0x09 0x09 0x09 0x0a 0x0a 0x0b 0x0a 0x0c 0x0a +0x0d 0x09 0x0e 0x09 0x0f 0x09 0x10 0x05 0x11 0x05 0x12 0x05 0x13 0x05 0x14 0x05 +0x15 0x05 0x16 0x05 0x17 0x05 0x18 0x05 0x19 0x05 0x1a 0x05 0x1b 0x05>;
marvell,caldata-txpwrlimit-5g-sub1 = /bits/ 8 <
+0x01 0x00 0x06 0x00 0xaa 0x02 0x89 0x01 +0x3a 0x00 0x88 0x13 0x14 0x64 0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0a 0x05 0x0a +0x06 0x0a 0x07 0x09 0x08 0x09 0x09 0x09 0x0a 0x0a 0x0b 0x0a 0x0c 0x0a 0x0d 0x09 +0x0e 0x09 0x0f 0x09 0x10 0x05 0x11 0x05 0x12 0x05 0x13 0x05 0x14 0x05 0x15 0x05 +0x16 0x05 0x17 0x05 0x18 0x05 0x19 0x05 0x1a 0x05 0x1b 0x05 0x89 0x01 0x3a 0x00 +0x88 0x13 0x14 0x68 0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0a 0x05 0x0a 0x06 0x0a +0x07 0x09 0x08 0x09 0x09 0x09 0x0a 0x0a 0x0b 0x0a 0x0c 0x0a 0x0d 0x09 0x0e 0x09 +0x0f 0x09 0x10 0x05 0x11 0x05 0x12 0x05 0x13 0x05 0x14 0x05 0x15 0x05 0x16 0x05 +0x17 0x05 0x18 0x05 0x19 0x05 0x1a 0x05 0x1b 0x05 0x89 0x01 0x3a 0x00 0x88 0x13 +0x14 0x6c 0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0a 0x05 0x0a 0x06 0x0a 0x07 0x09 +0x08 0x09 0x09 0x09 0x0a 0x0a 0x0b 0x0a 0x0c 0x0a 0x0d 0x09 0x0e 0x09 0x0f 0x09 +0x10 0x05 0x11 0x05 0x12 0x05 0x13 0x05 0x14 0x05 0x15 0x05 0x16 0x05 0x17 0x05 +0x18 0x05 0x19 0x05 0x1a 0x05 0x1b 0x05 0x89 0x01 0x3a 0x00 0x88 0x13 0x14 0x70 +0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0a 0x05 0x0a 0x06 0x0a 0x07 0x09 0x08 0x09 +0x09 0x09 0x0a 0x0a 0x0b 0x0a 0x0c 0x0a 0x0d 0x09 0x0e 0x09 0x0f 0x09 0x10 0x05 +0x11 0x05 0x12 0x05 0x13 0x05 0x14 0x05 0x15 0x05 0x16 0x05 0x17 0x05 0x18 0x05 +0x19 0x05 0x1a 0x05 0x1b 0x05 0x89 0x01 0x3a 0x00 0x88 0x13 0x14 0x74 0x01 0x0c +0x02 0x0c 0x03 0x0c 0x04 0x0a 0x05 0x0a 0x06 0x0a 0x07 0x09 0x08 0x09 0x09 0x09 +0x0a 0x0a 0x0b 0x0a 0x0c 0x0a 0x0d 0x09 0x0e 0x09 0x0f 0x09 0x10 0x05 0x11 0x05 +0x12 0x05 0x13 0x05 0x14 0x05 0x15 0x05 0x16 0x05 0x17 0x05 0x18 0x05 0x19 0x05 +0x1a 0x05 0x1b 0x05 0x89 0x01 0x3a 0x00 0x88 0x13 0x14 0x78 0x01 0x0c 0x02 0x0c +0x03 0x0c 0x04 0x0a 0x05 0x0a 0x06 0x0a 0x07 0x09 0x08 0x09 0x09 0x09 0x0a 0x0a +0x0b 0x0a 0x0c 0x0a 0x0d 0x09 0x0e 0x09 0x0f 0x09 0x10 0x05 0x11 0x05 0x12 0x05 +0x13 0x05 0x14 0x05 0x15 0x05 0x16 0x05 0x17 0x05 0x18 0x05 0x19 0x05 0x1a 0x05 +0x1b 0x05 0x89 0x01 0x3a 0x00 0x88 0x13 0x14 0x7c 0x01 0x0c 0x02 0x0c 0x03 0x0c +0x04 0x0a 0x05 0x0a 0x06 0x0a 0x07 0x09 0x08 0x09 0x09 0x09 0x0a 0x0a 0x0b 0x0a +0x0c 0x0a 0x0d 0x09 0x0e 0x09 0x0f 0x09 0x10 0x05 0x11 0x05 0x12 0x05 0x13 0x05 +0x14 0x05 0x15 0x05 0x16 0x05 0x17 0x05 0x18 0x05 0x19 0x05 0x1a 0x05 0x1b 0x05 +0x89 0x01 0x3a 0x00 0x88 0x13 0x14 0x80 0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0a +0x05 0x0a 0x06 0x0a 0x07 0x09 0x08 0x09 0x09 0x09 0x0a 0x0a 0x0b 0x0a 0x0c 0x0a +0x0d 0x09 0x0e 0x09 0x0f 0x09 0x10 0x05 0x11 0x05 0x12 0x05 0x13 0x05 0x14 0x05 +0x15 0x05 0x16 0x05 0x17 0x05 0x18 0x05 0x19 0x05 0x1a 0x05 0x1b 0x05 0x89 0x01 +0x3a 0x00 0x88 0x13 0x14 0x84 0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0a 0x05 0x0a +0x06 0x0a 0x07 0x09 0x08 0x09 0x09 0x09 0x0a 0x0a 0x0b 0x0a 0x0c 0x0a 0x0d 0x09 +0x0e 0x09 0x0f 0x09 0x10 0x05 0x11 0x05 0x12 0x05 0x13 0x05 0x14 0x05 0x15 0x05 +0x16 0x05 0x17 0x05 0x18 0x05 0x19 0x05 0x1a 0x05 0x1b 0x05 0x89 0x01 0x3a 0x00 +0x88 0x13 0x14 0x88 0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0a 0x05 0x0a 0x06 0x0a +0x07 0x08 0x08 0x08 0x09 0x08 0x0a 0x0a 0x0b 0x0a 0x0c 0x0a 0x0d 0x08 0x0e 0x08 +0x0f 0x08 0x10 0x04 0x11 0x04 0x12 0x05 0x13 0x05 0x14 0x05 0x15 0x05 0x16 0x04 +0x17 0x04 0x18 0x05 0x19 0x05 0x1a 0x05 0x1b 0x05 0x89 0x01 0x3a 0x00 0x88 0x13 +0x14 0x8c 0x01 0x0c 0x02 0x0c 0x03 0x0c 0x04 0x0a 0x05 0x0a 0x06 0x0a 0x07 0x08 +0x08 0x08 0x09 0x08 0x0a 0x0a 0x0b 0x0a 0x0c 0x0a 0x0d 0x08 0x0e 0x08 0x0f 0x08 +0x10 0x04 0x11 0x04 0x12 0x05 0x13 0x05 0x14 0x05 0x15 0x05 0x16 0x04 0x17 0x04 +0x18 0x05 0x19 0x05 0x1a 0x05 0x1b 0x05>;
marvell,caldata-txpwrlimit-5g-sub2 = /bits/ 8 <
+0x01 0x00 0x06 0x00 0x36 0x01 0x89 0x01 +0x3a 0x00 0x88 0x13 0x14 0x95 0x01 0x0b 0x02 0x0b 0x03 0x0b 0x04 0x0a 0x05 0x0a +0x06 0x0a 0x07 0x08 0x08 0x08 0x09 0x08 0x0a 0x0a 0x0b 0x0a 0x0c 0x0a 0x0d 0x08 +0x0e 0x08 0x0f 0x08 0x10 0x04 0x11 0x04 0x12 0x05 0x13 0x05 0x14 0x05 0x15 0x05 +0x16 0x04 0x17 0x04 0x18 0x05 0x19 0x05 0x1a 0x05 0x1b 0x05 0x89 0x01 0x3a 0x00 +0x88 0x13 0x14 0x99 0x01 0x0b 0x02 0x0b 0x03 0x0b 0x04 0x0a 0x05 0x0a 0x06 0x0a +0x07 0x08 0x08 0x08 0x09 0x08 0x0a 0x0a 0x0b 0x0a 0x0c 0x0a 0x0d 0x08 0x0e 0x08 +0x0f 0x08 0x10 0x04 0x11 0x04 0x12 0x05 0x13 0x05 0x14 0x05 0x15 0x05 0x16 0x04 +0x17 0x04 0x18 0x05 0x19 0x05 0x1a 0x05 0x1b 0x05 0x89 0x01 0x3a 0x00 0x88 0x13 +0x14 0x9d 0x01 0x0b 0x02 0x0b 0x03 0x0b 0x04 0x0a 0x05 0x0a 0x06 0x0a 0x07 0x08 +0x08 0x08 0x09 0x08 0x0a 0x0a 0x0b 0x0a 0x0c 0x0a 0x0d 0x08 0x0e 0x08 0x0f 0x08 +0x10 0x04 0x11 0x04 0x12 0x05 0x13 0x05 0x14 0x05 0x15 0x05 0x16 0x04 0x17 0x04 +0x18 0x05 0x19 0x05 0x1a 0x05 0x1b 0x05 0x89 0x01 0x3a 0x00 0x88 0x13 0x14 0xa1 +0x01 0x0b 0x02 0x0b 0x03 0x0b 0x04 0x0a 0x05 0x0a 0x06 0x0a 0x07 0x08 0x08 0x08 +0x09 0x08 0x0a 0x0a 0x0b 0x0a 0x0c 0x0a 0x0d 0x08 0x0e 0x08 0x0f 0x08 0x10 0x04 +0x11 0x04 0x12 0x05 0x13 0x05 0x14 0x05 0x15 0x05 0x16 0x04 0x17 0x04 0x18 0x05 +0x19 0x05 0x1a 0x05 0x1b 0x05 0x89 0x01 0x3a 0x00 0x88 0x13 0x14 0xa5 0x01 0x0b +0x02 0x0b 0x03 0x0b 0x04 0x0a 0x05 0x0a 0x06 0x0a 0x07 0x08 0x08 0x08 0x09 0x08 +0x0a 0x0a 0x0b 0x0a 0x0c 0x0a 0x0d 0x08 0x0e 0x08 0x0f 0x08 0x10 0x04 0x11 0x04 +0x12 0x05 0x13 0x05 0x14 0x05 0x15 0x05 0x16 0x04 0x17 0x04 0x18 0x05 0x19 0x05 +0x1a 0x05 0x1b 0x05>;
- &sdmmc {
- disable-wp; pinctrl-names = "default";
- pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_cd_disabled &sdmmc_cd_pin &sdmmc_bus4>;
disable-wp; };
&vcc_5v { enable-active-high;
gpio = <&gpio7 21 GPIO_ACTIVE_HIGH>;
gpio = <&gpio7 RK_PC5 GPIO_ACTIVE_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&drv_5v>; };
&vcc50_hdmi { enable-active-high;
- gpio = <&gpio5 19 GPIO_ACTIVE_HIGH>;
- gpio = <&gpio5 RK_PC3 GPIO_ACTIVE_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&vcc50_hdmi_en>; };
-&edp {
+&gpio0 {
- gpio-line-names = "PMIC_SLEEP_AP",
"DDRIO_PWROFF",
"DDRIO_RETEN",
"TS3A227E_INT_L",
"PMIC_INT_L",
"PWR_KEY_L",
"AP_LID_INT_L",
"EC_IN_RW",
"AC_PRESENT_AP",
* it REC_MODE_L.
"RECOVERY_SW_L",
"OTP_OUT",
"HOST1_PWR_EN",
"USBOTG_PWREN_H",
"AP_WARM_RESET_H",
"nFAULT2",
"I2C0_SDA_PMIC",
"I2C0_SCL_PMIC",
"SUSPEND_L",
"USB_INT";
+&gpio2 {
- gpio-line-names = "CONFIG0",
"CONFIG1",
"CONFIG2",
"CONFIG3",
"EMMC_RST_L",
"BL_PWR_EN",
"AVDD_1V8_DISP_EN";
+&gpio3 {
- gpio-line-names = "FLASH0_D0",
"FLASH0_D1",
"FLASH0_D2",
"FLASH0_D3",
"FLASH0_D4",
"FLASH0_D5",
"FLASH0_D6",
"FLASH0_D7",
+&gpio4 {
- gpio-line-names = "",
"UART0_RXD",
"UART0_TXD",
"UART0_CTS",
"UART0_RTS",
"SDIO0_D0",
"SDIO0_D1",
"SDIO0_D2",
"SDIO0_D3",
"SDIO0_CMD",
"SDIO0_CLK",
"BT_DEV_WAKE",
"WIFI_ENABLE_H",
"BT_ENABLE_L",
"WIFI_HOST_WAKE",
"BT_HOST_WAKE";
+&gpio5 {
"SPI0_CLK",
"SPI0_CS0",
"SPI0_TXD",
"SPI0_RXD",
"VCC50_HDMI_EN";
+&gpio6 {
- gpio-line-names = "I2S0_SCLK",
"I2S0_LRCK_RX",
"I2S0_LRCK_TX",
"I2S0_SDI",
"I2S0_SDO0",
"HP_DET_H",
"INT_CODEC",
"I2S0_CLK",
"I2C2_SDA",
"I2C2_SCL",
"MICDET",
"SDMMC_D0",
"SDMMC_D1",
"SDMMC_D2",
"SDMMC_D3",
"SDMMC_CLK",
"SDMMC_CMD";
+&gpio7 {
- gpio-line-names = "LCDC_BL",
"PWM_LOG",
"BL_EN",
"TRACKPAD_INT",
"TPM_INT_H",
"SDMMC_DET_L",
* it FW_WP_AP.
"AP_FLASH_WP_L",
"EC_INT",
"CPU_NMI",
"DVSOK",
"EDP_HPD",
"DVS1",
"nFAULT1",
"LCD_EN",
"DVS2",
"VCC5V_GOOD_H",
"I2C4_SDA_TP",
"I2C4_SCL_TP",
"I2C5_SDA_HDMI",
"I2C5_SCL_HDMI",
"5V_DRV",
"UART2_RXD",
"UART2_TXD";
+&gpio8 {
"RAM_ID1",
"RAM_ID2",
"RAM_ID3",
"I2C1_SDA_TPM",
"I2C1_SCL_TPM",
"SPI2_CLK",
"SPI2_CS0",
"SPI2_RXD",
"SPI2_TXD";
&pinctrl {
- backlight {
pinctrl-0 = <
&ddr0_retention
&ddrio_pwroff
&global_pwroff
/* Wake only */
&suspend_l_wake
&bt_dev_wake_awake
pinctrl-1 = <
&ddr0_retention
&ddrio_pwroff
&global_pwroff
/* Sleep only */
&suspend_l_sleep
&bt_dev_wake_sleep
- emmc {
/* Make sure eMMC is not in reset */
emmc_deassert_reset: emmc-deassert-reset {
hdmi { vcc50_hdmi_en: vcc50-hdmi-en {
rockchip,pins = <5 19 RK_FUNC_GPIO &pcfg_pull_none>;
- lcd {
lcd_enable_h: lcd-en {
rockchip,pins = <7 14 RK_FUNC_GPIO &pcfg_pull_none>;
avdd_1v8_disp_en: avdd-1v8-disp-en {
rockchip,pins = <2 13 RK_FUNC_GPIO &pcfg_pull_none>;
rockchip,pins = <5 RK_PC3 RK_FUNC_GPIO &pcfg_pull_none>;
pmic { dvs_1: dvs-1 {
rockchip,pins = <7 12 RK_FUNC_GPIO &pcfg_pull_down>;
rockchip,pins = <7 RK_PB4 RK_FUNC_GPIO &pcfg_pull_down>;
dvs_2: dvs-2 {
}; }; };rockchip,pins = <7 RK_PB7 RK_FUNC_GPIO &pcfg_pull_down>;
@@ -182,24 +474,18 @@ pinctrl-0 = <&i2c4_xfer &trackpad_int>;
trackpad@15 {
compatible = "elan,i2c_touchpad";
interrupts = <3 IRQ_TYPE_EDGE_FALLING>;
- Remove the inherited pinctrl settings to avoid clashing
- with bus-wide ones.
*/ /delete-property/pinctrl-names; /delete-property/pinctrl-0;
reg = <0x15>;
wakeup-source;
trackpad@2c { compatible = "hid-over-i2c"; interrupt-parent = <&gpio7>;
reg = <0x2c>; hid-descr-addr = <0x0020>; vcc-supply = <&vcc33_io>;interrupts = <RK_PA3 IRQ_TYPE_EDGE_FALLING>;
diff --git a/arch/arm/dts/rk3288-veyron-mickey.dts b/arch/arm/dts/rk3288-veyron-mickey.dts index 0521d9e0..ffd1121d 100644 --- a/arch/arm/dts/rk3288-veyron-mickey.dts +++ b/arch/arm/dts/rk3288-veyron-mickey.dts @@ -1,49 +1,13 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) /*
- Google Veyron Mickey Rev 0 board device tree source
- This file is dual-licensed: you can use it either under the terms
- of the GPL or the X11 license, at your option. Note that this dual
- licensing only applies to this file, and not this project as a
- whole.
- a) This file is free software; you can redistribute it and/or
modify it under the terms of the GNU General Public License as
published by the Free Software Foundation; either version 2 of the
License, or (at your option) any later version.
This file is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
- Or, alternatively,
- b) Permission is hereby granted, free of charge, to any person
obtaining a copy of this software and associated documentation
files (the "Software"), to deal in the Software without
restriction, including without limitation the rights to use,
copy, modify, merge, publish, distribute, sublicense, and/or
sell copies of the Software, and to permit persons to whom the
Software is furnished to do so, subject to the following
conditions:
The above copyright notice and this permission notice shall be
included in all copies or substantial portions of the Software.
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND,
EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES
OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND
NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT
HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY,
WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR
OTHER DEALINGS IN THE SOFTWARE.
/dts-v1/;
-#include "rk3288-veyron-chromebook.dtsi" +#include "rk3288-veyron.dtsi" +#include "rk3288-veyron-broadcom-bluetooth.dtsi"
/ { model = "Google Mickey"; @@ -65,6 +29,13 @@ regulator-boot-on; vin-supply = <&vcc33_sys>; };
sound {
rockchip,model = "VEYRON-HDMI";
rockchip,hdmi-codec = <&hdmi>;
&cpu_thermal {
@@ -112,14 +83,18 @@ cooling-maps { /* * After 1st level, throttle the CPU down to as low as 1.4 GHz
* and don't let the GPU go faster than 400 MHz. Note that we
* won't throttle the GPU lower than 400 MHz due to CPU
* heat--we'll let the GPU do the rest itself.
*/ cpu_warm_limit_cpu { trip = <&cpu_alert_warm>;* and don't let the GPU go faster than 400 MHz.
cooling-device =
<&cpu0 THERMAL_NO_LIMIT 4>;
cooling-device = <&cpu0 THERMAL_NO_LIMIT 4>,
<&cpu1 THERMAL_NO_LIMIT 4>,
<&cpu2 THERMAL_NO_LIMIT 4>,
<&cpu3 THERMAL_NO_LIMIT 4>;
cpu_warm_limit_gpu {
cooling-device = <&gpu 1 1>;
@@ -140,29 +115,100 @@ */ cpu_almost_hot_limit_cpu { trip = <&cpu_alert_almost_hot>;
cooling-device =
<&cpu0 5 6>;
cooling-device = <&cpu0 5 6>, <&cpu1 5 6>, <&cpu2 5 6>,
}; cpu_hot_limit_cpu { trip = <&cpu_alert_hot>;<&cpu3 5 6>;
cooling-device =
<&cpu0 7 7>;
cooling-device = <&cpu0 7 7>, <&cpu1 7 7>, <&cpu2 7 7>,
}; cpu_hotter_limit_cpu { trip = <&cpu_alert_hotter>;<&cpu3 7 7>;
cooling-device =
<&cpu0 7 8>;
cooling-device = <&cpu0 7 8>, <&cpu1 7 8>, <&cpu2 7 8>,
}; cpu_very_hot_limit_cpu { trip = <&cpu_alert_very_hot>;<&cpu3 7 8>;
cooling-device =
<&cpu0 8 THERMAL_NO_LIMIT>;
cooling-device = <&cpu0 8 THERMAL_NO_LIMIT>,
<&cpu1 8 THERMAL_NO_LIMIT>,
<&cpu2 8 THERMAL_NO_LIMIT>,
<&cpu3 8 THERMAL_NO_LIMIT>;
/* At very hot, don't let GPU go over 300 MHz */
cpu_very_hot_limit_gpu {
}; }; };cooling-device = <&gpu 2 2>;
-&emmc {
- /delete-property/mmc-hs200-1_8v;
+&gpu_thermal {
/delete-node/ trips;
/delete-node/ cooling-maps;
trips {
gpu_alert_warmish: gpu_alert_warmish {
temperature = <60000>; /* millicelsius */
hysteresis = <2000>; /* millicelsius */
type = "passive";
gpu_alert_warm: gpu_alert_warm {
temperature = <65000>; /* millicelsius */
type = "passive";
gpu_alert_hotter: gpu_alert_hotter {
temperature = <84000>; /* millicelsius */
type = "passive";
gpu_alert_very_very_hot: gpu_alert_very_very_hot {
temperature = <86000>; /* millicelsius */
type = "passive";
gpu_crit: gpu_crit {
temperature = <90000>; /* millicelsius */
type = "critical";
cooling-maps {
/* After 1st level throttle the GPU down to as low as 400 MHz */
gpu_warmish_limit_gpu {
trip = <&gpu_alert_warmish>;
cooling-device = <&gpu THERMAL_NO_LIMIT 1>;
* Slightly after we throttle the GPU, we'll also make sure that
* the CPU can't go faster than 1.4 GHz. Note that we won't
* throttle the CPU lower than 1.4 GHz due to GPU heat--we'll
* let the CPU do the rest itself.
gpu_warm_limit_cpu {
trip = <&gpu_alert_warm>;
cooling-device = <&cpu0 4 4>,
<&cpu1 4 4>,
<&cpu2 4 4>,
<&cpu3 4 4>;
/* When hot, GPU goes down to 300 MHz */
gpu_hotter_limit_gpu {
trip = <&gpu_alert_hotter>;
/* When really hot, don't let GPU go _above_ 300 MHz */
gpu_very_very_hot_limit_gpu {
trip = <&gpu_alert_very_very_hot>;
cooling-device = <&gpu 2 THERMAL_NO_LIMIT>;
&i2c2 {
@@ -175,15 +221,13 @@
&i2s { status = "okay";
/delete-property/ vcc6-supply; /delete-property/ vcc12-supply;
@@ -216,40 +260,183 @@ }; };
+&gpio0 {
"PMIC_INT_L",
"POWER_BUTTON_L",
* it REC_MODE_L.
"RECOVERY_SW_L",
"OT_RESET",
"AP_WARM_RESET_H",
"I2C0_SDA_PMIC",
"I2C0_SCL_PMIC",
"nFALUT";
+&gpio2 {
"CONFIG1",
"CONFIG2",
"CONFIG3",
"EMMC_RST_L";
+&gpio3 {
"FLASH0_D1",
"FLASH0_D2",
"FLASH0_D3",
"FLASH0_D4",
"FLASH0_D5",
"FLASH0_D6",
"FLASH0_D7",
+&gpio4 {
"UART0_RXD",
"UART0_TXD",
"UART0_CTS_L",
"UART0_RTS_L",
"SDIO0_D0",
"SDIO0_D1",
"SDIO0_D2",
"SDIO0_D3",
"SDIO0_CMD",
"SDIO0_CLK",
"BT_DEV_WAKE",
"WIFI_ENABLE_H",
"BT_ENABLE_L",
"WIFI_HOST_WAKE",
"BT_HOST_WAKE";
+&gpio7 {
"PWM_LOG",
"TPM_INT_H",
"SDMMC_DET_L",
* it FW_WP_AP.
"AP_FLASH_WP_L",
"CPU_NMI",
"DVSOK",
"HDMI_WAKE",
"POWER_HDMI_ON",
"DVS1",
"DVS2",
"HDMI_CEC",
"I2C5_SDA_HDMI",
"I2C5_SCL_HDMI",
"UART2_RXD",
"UART2_TXD";
+&gpio8 {
- gpio-line-names = "RAM_ID0",
"RAM_ID1",
"RAM_ID2",
"RAM_ID3",
"I2C1_SDA_TPM",
"I2C1_SCL_TPM",
"SPI2_CLK",
"SPI2_CS0",
"SPI2_RXD",
"SPI2_TXD";
- &pinctrl {
- pinctrl-0 = <
&ddr0_retention
&ddrio_pwroff
&global_pwroff
;- hdmi { power_hdmi_on: power-hdmi-on {
rockchip,pins = <7 11 RK_FUNC_GPIO &pcfg_pull_none>;
rockchip,pins = <7 RK_PB3 RK_FUNC_GPIO &pcfg_pull_none>;
dvs_2: dvs-2 {
-&sdmmc {
- status = "disabled";
-&sdio0 {
-&sdmmc {
-&spi0 {
- &usb_host0_ehci { status = "disabled"; };
@@ -260,7 +447,7 @@
- gpio = <&gpio7 11 GPIO_ACTIVE_HIGH>;
- gpio = <&gpio7 RK_PB3 GPIO_ACTIVE_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&power_hdmi_on>; };
diff --git a/arch/arm/dts/rk3288-veyron-minnie.dts b/arch/arm/dts/rk3288-veyron-minnie.dts index b56a3f4f..82fc6fba 100644 --- a/arch/arm/dts/rk3288-veyron-minnie.dts +++ b/arch/arm/dts/rk3288-veyron-minnie.dts @@ -1,49 +1,13 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) /*
- Google Veyron Minnie Rev 0+ board device tree source
- whole.
conditions:
/ { model = "Google Minnie"; @@ -52,111 +16,31 @@ "google,veyron-minnie-rev0", "google,veyron-minnie", "google,veyron", "rockchip,rk3288";
enable-active-high;
gpio = <&gpio2 12 GPIO_ACTIVE_HIGH>;
enable-active-high;
gpio = <&gpio7 14 GPIO_ACTIVE_HIGH>;
enable-active-high;
gpio = <&gpio2 13 GPIO_ACTIVE_HIGH>;
- volume_buttons: volume-buttons {
pinctrl-names = "default";compatible = "gpio-keys";
regulator-boot-on;
- sound {
compatible = "rockchip,audio-max98090-jerry";
pinctrl-0 = <&volum_down_l &volum_up_l>;
cpu {
sound-dai = <&i2s 0>;
volum_down {
label = "Volum_down";
gpios = <&gpio5 RK_PB3 GPIO_ACTIVE_LOW>;
linux,code = <KEY_VOLUMEDOWN>;
};debounce-interval = <100>;
codec {
sound-dai = <&max98090 0>;
volum_up {
label = "Volum_up";
gpios = <&gpio5 RK_PB2 GPIO_ACTIVE_LOW>;
linux,code = <KEY_VOLUMEUP>;
&backlight { /* Minnie panel PWM must be >= 1%, so start non-zero brightness at 3 */
0 3 4 5 6 7
-&emmc {
-&gpio_keys {
- pinctrl-0 = <&pwr_key_h &ap_lid_int_l &volum_down_l &volum_up_l>;
- volum_down {
gpios = <&gpio5 11 GPIO_ACTIVE_LOW>;
- volum_up {
label = "Volum_up";
gpios = <&gpio5 10 GPIO_ACTIVE_LOW>;
brightness-levels = <3 255>;
num-interpolated-steps = <252>; };
&i2c_tunnel {
@@ -177,18 +61,31 @@ compatible = "elan,ekth3500"; reg = <0x10>; interrupt-parent = <&gpio2>;
interrupts = <14 IRQ_TYPE_EDGE_FALLING>;
pinctrl-names = "default"; pinctrl-0 = <&touch_int &touch_rst>;interrupts = <RK_PB6 IRQ_TYPE_EDGE_FALLING>;
reset-gpios = <&gpio2 15 GPIO_ACTIVE_LOW>;
reset-gpios = <&gpio2 RK_PB7 GPIO_ACTIVE_LOW>;
vcc33-supply = <&vcc33_touch>; vccio-supply = <&vcc33_touch>; }; };
&panel {
- compatible = "auo,b101ean01", "simple-panel";
- power-supply= <&panel_regulator>;
compatible = "auo,b101ean01";
/delete-node/ panel-timing;
panel-timing {
clock-frequency = <66666667>;
hactive = <1280>;
hfront-porch = <18>;
hback-porch = <21>;
hsync-len = <32>;
vactive = <800>;
vfront-porch = <4>;
vback-porch = <8>;
vsync-len = <18>;
&rk808 {
@@ -217,86 +114,302 @@ &sdmmc { disable-wp; pinctrl-names = "default";
- gpio = <&gpio7 21 GPIO_ACTIVE_HIGH>;
+&gpio0 {
"DDRIO_PWROFF",
"DDRIO_RETEN",
"TS3A227E_INT_L",
"PMIC_INT_L",
"PWR_KEY_L",
"AP_LID_INT_L",
"EC_IN_RW",
"AC_PRESENT_AP",
* it REC_MODE_L.
"RECOVERY_SW_L",
"OTP_OUT",
"HOST1_PWR_EN",
"USBOTG_PWREN_H",
"AP_WARM_RESET_H",
"nFALUT2",
"I2C0_SDA_PMIC",
"I2C0_SCL_PMIC",
"SUSPEND_L",
"USB_INT";
+&gpio2 {
"CONFIG1",
"CONFIG2",
"CONFIG3",
"PROCHOT#",
"EMMC_RST_L",
"BL_PWR_EN",
"AVDD_1V8_DISP_EN",
"TOUCH_INT",
"TOUCH_RST",
"I2C3_SCL_TP",
"I2C3_SDA_TP";
+&gpio3 {
"FLASH0_D1",
"FLASH0_D2",
"FLASH0_D3",
"FLASH0_D4",
"FLASH0_D5",
"FLASH0_D6",
"FLASH0_D7",
+&gpio4 {
"UART0_RXD",
"UART0_TXD",
"UART0_CTS",
"UART0_RTS",
"SDIO0_D0",
"SDIO0_D1",
"SDIO0_D2",
"SDIO0_D3",
"SDIO0_CMD",
"SDIO0_CLK",
"dev_wake",
"WIFI_ENABLE_H",
"BT_ENABLE_L",
"WIFI_HOST_WAKE",
"BT_HOST_WAKE";
+&gpio5 {
"Volum_Up#",
"Volum_Down#",
"SPI0_CLK",
"SPI0_CS0",
"SPI0_TXD",
"SPI0_RXD",
"VCC50_HDMI_EN";
+&gpio6 {
"I2S0_LRCK_RX",
"I2S0_LRCK_TX",
"I2S0_SDI",
"I2S0_SDO0",
"HP_DET_H",
"INT_CODEC",
"I2S0_CLK",
"I2C2_SDA",
"I2C2_SCL",
"MICDET",
"SDMMC_D0",
"SDMMC_D1",
"SDMMC_D2",
"SDMMC_D3",
"SDMMC_CLK",
"SDMMC_CMD";
+&gpio7 {
"PWM_LOG",
"BL_EN",
"TRACKPAD_INT",
"TPM_INT_H",
"SDMMC_DET_L",
* it FW_WP_AP.
"AP_FLASH_WP_L",
"EC_INT",
"CPU_NMI",
"DVS_OK",
"SDMMC_WP",
"EDP_HPD",
"DVS1",
"nFALUT1",
"LCD_EN",
"DVS2",
"VCC5V_GOOD_H",
"I2C4_SDA_TP",
"I2C4_SCL_TP",
"I2C5_SDA_HDMI",
"I2C5_SCL_HDMI",
"5V_DRV",
"UART2_RXD",
"UART2_TXD";
+&gpio8 {
"RAM_ID1",
"RAM_ID2",
"RAM_ID3",
"I2C1_SDA_TPM",
"I2C1_SCL_TPM",
"SPI2_CLK",
"SPI2_CS0",
"SPI2_RXD",
"SPI2_TXD";
- &pinctrl {
- backlight {
pinctrl-0 = <
&ddr0_retention
&ddrio_pwroff
&global_pwroff
/* Wake only */
&suspend_l_wake
pinctrl-1 = <
&ddr0_retention
&ddrio_pwroff
&global_pwroff
/* Sleep only */
&suspend_l_sleep
buck-5v { drv_5v: drv-5v {
rockchip,pins = <7 21 RK_FUNC_GPIO &pcfg_pull_none>;
rockchip,pins = <7 RK_PC5 RK_FUNC_GPIO &pcfg_pull_none>;
buttons { volum_down_l: volum-down-l {
rockchip,pins = <5 11 RK_FUNC_GPIO &pcfg_pull_up>;
rockchip,pins = <5 RK_PB3 RK_FUNC_GPIO &pcfg_pull_up>;
volum_up_l: volum-up-l {
rockchip,pins = <5 10 RK_FUNC_GPIO &pcfg_pull_up>;
rockchip,pins = <5 RK_PB2 RK_FUNC_GPIO &pcfg_pull_up>;
- lcd {
dvs_2: dvs-2 {
prochot { gpio_prochot: gpio-prochot {
rockchip,pins = <2 8 RK_FUNC_GPIO &pcfg_pull_none>;
rockchip,pins = <2 RK_PB0 RK_FUNC_GPIO &pcfg_pull_none>;
touchscreen { touch_int: touch-int {
rockchip,pins = <2 14 RK_FUNC_GPIO &pcfg_pull_none>;
rockchip,pins = <2 RK_PB6 RK_FUNC_GPIO &pcfg_pull_none>;
touch_rst: touch-rst {
rockchip,pins = <2 15 RK_FUNC_GPIO &pcfg_pull_none>;
}; }; };rockchip,pins = <2 RK_PB7 RK_FUNC_GPIO &pcfg_pull_none>;
diff --git a/arch/arm/dts/rk3288-veyron-sdmmc.dtsi b/arch/arm/dts/rk3288-veyron-sdmmc.dtsi new file mode 100644 index 00000000..27fb06ce --- /dev/null +++ b/arch/arm/dts/rk3288-veyron-sdmmc.dtsi @@ -0,0 +1,89 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/*
- Google Veyron (and derivatives) fragment for sdmmc cards
+&io_domains {
+&pinctrl {
- sdmmc {
rockchip,pins = <6 RK_PC0 1 &pcfg_pull_none_drv_8ma>,
<6 RK_PC1 1 &pcfg_pull_none_drv_8ma>,
<6 RK_PC2 1 &pcfg_pull_none_drv_8ma>,
<6 RK_PC3 1 &pcfg_pull_none_drv_8ma>;
rockchip,pins = <6 RK_PC4 1 &pcfg_pull_none_drv_8ma>;
rockchip,pins = <6 RK_PC5 1 &pcfg_pull_none_drv_8ma>;
* Configure gpio6_C6 as GPIO so dw_mmc builtin CD doesn't
rockchip,pins = <6 RK_PC6 RK_FUNC_GPIO &pcfg_pull_none>;
sdmmc_cd_pin: sdmmc-cd-pin {
rockchip,pins = <7 RK_PA5 RK_FUNC_GPIO &pcfg_pull_none>;
+&rk808 {
- regulators {
+&sdmmc {
- status = "okay";
- bus-width = <4>;
- cap-sd-highspeed;
- cd-gpios = <&gpio7 RK_PA5 GPIO_ACTIVE_LOW>;
- rockchip,default-sample-phase = <90>;
- sd-uhs-sdr12;
- sd-uhs-sdr25;
- sd-uhs-sdr50;
- sd-uhs-sdr104;
+}; diff --git a/arch/arm/dts/rk3288-veyron-speedy.dts b/arch/arm/dts/rk3288-veyron-speedy.dts index 58c1fe96..4a3ea934 100644 --- a/arch/arm/dts/rk3288-veyron-speedy.dts +++ b/arch/arm/dts/rk3288-veyron-speedy.dts @@ -7,8 +7,8 @@
/dts-v1/; #include "rk3288-veyron-chromebook.dtsi" +#include "rk3288-veyron-broadcom-bluetooth.dtsi" #include "cros-ec-sbs.dtsi" -#include "rk3288-veyron-speedy-u-boot.dtsi"
/ { model = "Google Speedy"; @@ -17,44 +17,6 @@ "google,veyron-speedy-rev5", "google,veyron-speedy-rev4", "google,veyron-speedy-rev3", "google,veyron-speedy-rev2", "google,veyron-speedy", "google,veyron", "rockchip,rk3288";
- panel_regulator: panel-regulator {
enable-active-high;
gpio = <&gpio7 RK_PB6 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&lcd_enable_h>;
regulator-name = "panel_regulator";
startup-delay-us = <100000>;
- vcc18_lcd: vcc18-lcd {
enable-active-high;
gpio = <&gpio2 RK_PB5 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&avdd_1v8_disp_en>;
regulator-name = "vcc18_lcd";
regulator-boot-on;
vin-supply = <&vcc18_wl>;
- backlight_regulator: backlight-regulator {
enable-active-high;
gpio = <&gpio2 RK_PB4 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&bl_pwr_en>;
regulator-name = "backlight_regulator";
startup-delay-us = <15000>;
-&backlight {
power-supply = <&backlight_regulator>; };
&cpu_alert0 {
@@ -65,6 +27,10 @@ temperature = <70000>; };
+&cpu_crit {
- temperature = <90000>;
- &edp { /delete-property/pinctrl-names; /delete-property/pinctrl-0;
@@ -72,8 +38,12 @@ force-hpd; };
-&panel {
- power-supply = <&panel_regulator>;
+&gpu_alert0 {
- temperature = <80000>;
+&gpu_crit {
temperature = <90000>; };
&rk808 {
@@ -84,7 +54,7 @@ &sdmmc { disable-wp; pinctrl-names = "default";
- pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_cd_disabled &sdmmc_cd_gpio
- pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_cd_disabled &sdmmc_cd_pin &sdmmc_bus4>; };
@@ -102,42 +72,253 @@ pinctrl-0 = <&vcc50_hdmi_en>; };
+&gpio0 {
"DDRIO_PWROFF",
"DDRIO_RETEN",
"TS3A227E_INT_L",
"PMIC_INT_L",
"PWR_KEY_L",
"AP_LID_INT_L",
"EC_IN_RW",
"AC_PRESENT_AP",
* RECOVERY_SW_L is Chrome OS ABI. Schematics call
* it REC_MODE_L.
"RECOVERY_SW_L",
"OTP_OUT",
"HOST1_PWR_EN",
"USBOTG_PWREN_H",
"AP_WARM_RESET_H",
"nFALUT2",
"I2C0_SDA_PMIC",
"I2C0_SCL_PMIC",
"SUSPEND_L",
"USB_INT";
+&gpio2 {
"CONFIG1",
"CONFIG2",
"CONFIG3",
"PWRLIMIT#_CPU",
"EMMC_RST_L",
"BL_PWR_EN",
"AVDD_1V8_DISP_EN";
+&gpio3 {
"FLASH0_D1",
"FLASH0_D2",
"FLASH0_D3",
"FLASH0_D4",
"FLASH0_D5",
"FLASH0_D6",
"FLASH0_D7",
"FLASH0_CS2/EMMC_CMD",
"FLASH0_DQS/EMMC_CLKO";
+&gpio4 {
"UART0_RXD",
"UART0_TXD",
"UART0_CTS",
"UART0_RTS",
"SDIO0_D0",
"SDIO0_D1",
"SDIO0_D2",
"SDIO0_D3",
"SDIO0_CMD",
"SDIO0_CLK",
"BT_DEV_WAKE",
"WIFI_ENABLE_H",
"BT_ENABLE_L",
"WIFI_HOST_WAKE",
"BT_HOST_WAKE";
+&gpio5 {
"SPI0_CLK",
"SPI0_CS0",
"SPI0_TXD",
"SPI0_RXD",
"VCC50_HDMI_EN";
+&gpio6 {
"I2S0_LRCK_RX",
"I2S0_LRCK_TX",
"I2S0_SDI",
"I2S0_SDO0",
"HP_DET_H",
"ALS_INT", /* not connected */
"INT_CODEC",
"I2S0_CLK",
"I2C2_SDA",
"I2C2_SCL",
"MICDET",
"SDMMC_D0",
"SDMMC_D1",
"SDMMC_D2",
"SDMMC_D3",
"SDMMC_CLK",
"SDMMC_CMD";
+&gpio7 {
"PWM_LOG",
"BL_EN",
"TRACKPAD_INT",
"TPM_INT_H",
"SDMMC_DET_L",
* AP_FLASH_WP_L is Chrome OS ABI. Schematics call
* it FW_WP_AP.
"AP_FLASH_WP_L",
"EC_INT",
"CPU_NMI",
"DVS_OK",
"EDP_HOTPLUG",
"DVS1",
"nFALUT1",
"LCD_EN",
"DVS2",
"VCC5V_GOOD_H",
"I2C4_SDA_TP",
"I2C4_SCL_TP",
"I2C5_SDA_HDMI",
"I2C5_SCL_HDMI",
"5V_DRV",
"UART2_RXD",
"UART2_TXD";
+&gpio8 {
"RAM_ID1",
"RAM_ID2",
"RAM_ID3",
"I2C1_SDA_TPM",
"I2C1_SCL_TPM",
"SPI2_CLK",
"SPI2_CS0",
"SPI2_RXD",
"SPI2_TXD";
- &pinctrl {
- backlight {
bl_pwr_en: bl_pwr_en {
rockchip,pins = <2 12 RK_FUNC_GPIO &pcfg_pull_none>;
pinctrl-0 = <
&ddr0_retention
&ddrio_pwroff
&global_pwroff
/* Wake only */
&suspend_l_wake
pinctrl-1 = <
&ddr0_retention
&ddrio_pwroff
&global_pwroff
/* Sleep only */
&suspend_l_sleep
- lcd {
dvs_2: dvs-2 {
rockchip,pins = <7 15 RK_FUNC_GPIO &pcfg_pull_down>;
diff --git a/arch/arm/dts/rk3288-veyron.dtsi b/arch/arm/dts/rk3288-veyron.dtsi index ac9e815e..2b7dc2c5 100644 --- a/arch/arm/dts/rk3288-veyron.dtsi +++ b/arch/arm/dts/rk3288-veyron.dtsi @@ -1,8 +1,8 @@ -// SPDX-License-Identifier: GPL-2.0 +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) /*
@@ -10,150 +10,83 @@ #include "rk3288.dtsi"
- memory {
reg = <0x0 0x80000000>;
- chosen {
stdout-path = &uart2;
};stdout-path = "serial2:115200n8";
- firmware {
chromeos {
pinctrl-0 = <&fw_wp_ap>;
write-protect-gpio = <&gpio7 6 GPIO_ACTIVE_LOW>;
- backlight: backlight {
compatible = "pwm-backlight";
0 1 2 3 4 5 6 7
8 9 10 11 12 13 14 15
16 17 18 19 20 21 22 23
24 25 26 27 28 29 30 31
32 33 34 35 36 37 38 39
40 41 42 43 44 45 46 47
48 49 50 51 52 53 54 55
56 57 58 59 60 61 62 63
64 65 66 67 68 69 70 71
72 73 74 75 76 77 78 79
80 81 82 83 84 85 86 87
88 89 90 91 92 93 94 95
96 97 98 99 100 101 102 103
104 105 106 107 108 109 110 111
112 113 114 115 116 117 118 119
120 121 122 123 124 125 126 127
128 129 130 131 132 133 134 135
136 137 138 139 140 141 142 143
144 145 146 147 148 149 150 151
152 153 154 155 156 157 158 159
160 161 162 163 164 165 166 167
168 169 170 171 172 173 174 175
176 177 178 179 180 181 182 183
184 185 186 187 188 189 190 191
192 193 194 195 196 197 198 199
200 201 202 203 204 205 206 207
208 209 210 211 212 213 214 215
216 217 218 219 220 221 222 223
224 225 226 227 228 229 230 231
232 233 234 235 236 237 238 239
240 241 242 243 244 245 246 247
248 249 250 251 252 253 254 255>;
default-brightness-level = <128>;
enable-gpios = <&gpio7 2 GPIO_ACTIVE_HIGH>;
backlight-boot-off;
pinctrl-0 = <&bl_en>;
pwms = <&pwm0 0 1000000 0>;
* The default coreboot on veyron devices ignores memory@0 nodes
* and would instead create another memory node.
- memory {
device_type = "memory";
};reg = <0x0 0x80000000>;
panel: panel {
compatible ="cnm,n116bgeea2","simple-panel";
status = "okay";
power-supply = <&vcc33_lcd>;
backlight = <&backlight>;
gpio_keys: gpio-keys {
- power_button: power-button { compatible = "gpio-keys";
pinctrl-0 = <&pwr_key_h>;
pinctrl-0 = <&pwr_key_l>;
- power { label = "Power";
gpios = <&gpio0 5 GPIO_ACTIVE_HIGH>;
gpios = <&gpio0 RK_PA5 GPIO_ACTIVE_LOW>; linux,code = <KEY_POWER>; debounce-interval = <100>;
gpio-key,wakeup;
wakeup-source;
gpio-restart { compatible = "gpio-restart";
gpios = <&gpio0 13 GPIO_ACTIVE_HIGH>;
pinctrl-names = "default"; pinctrl-0 = <&ap_warm_reset_h>;gpios = <&gpio0 RK_PB5 GPIO_ACTIVE_HIGH>;
priority = /bits/ 8 <200>;
priority = <200>;
emmc_pwrseq: emmc-pwrseq { compatible = "mmc-pwrseq-emmc"; pinctrl-0 = <&emmc_reset>; pinctrl-names = "default";
reset-gpios = <&gpio2 9 GPIO_ACTIVE_HIGH>;
};reset-gpios = <&gpio2 RK_PB1 GPIO_ACTIVE_HIGH>;
- sound {
compatible = "rockchip,rockchip-audio-max98090";
rockchip,model = "ROCKCHIP-I2S";
rockchip,i2s-controller = <&i2s>;
rockchip,audio-codec = <&max98090>;
rockchip,hp-det-gpios = <&gpio6 5 GPIO_ACTIVE_HIGH>;
rockchip,mic-det-gpios = <&gpio6 11 GPIO_ACTIVE_LOW>;
rockchip,headset-codec = <&headsetcodec>;
- sdio_pwrseq: sdio-pwrseq {
compatible = "mmc-pwrseq-simple";
clocks = <&rk808 RK808_CLKOUT1>;
pinctrl-names = "default";clock-names = "ext_clock";
pinctrl-0 = <&mic_det>, <&hp_det>;
- vdd_logic: pwm-regulator {
compatible = "pwm-regulator";
pwms = <&pwm1 0 2000 0>;
voltage-table = <1350000 0>,
<1300000 10>,
<1250000 20>,
<1200000 31>,
<1150000 41>,
<1100000 52>,
<1050000 62>,
<1000000 72>,
< 950000 83>;
pinctrl-0 = <&wifi_enable_h>;
regulator-min-microvolt = <950000>;
regulator-max-microvolt = <1350000>;
regulator-name = "vdd_logic";
regulator-ramp-delay = <4000>;
* Depending on the actual card populated GPIO4 D4
* correspond to one of these signals on the module:
* D4:
* - SDIO_RESET_L_WL_REG_ON
* - PDN (power down when low)
};reset-gpios = <&gpio4 RK_PD4 GPIO_ACTIVE_LOW>;
- vcc33_sys: vcc33-sys {
- vcc_5v: vcc-5v { compatible = "regulator-fixed";
regulator-name = "vcc33_sys";
regulator-always-on; regulator-boot-on;regulator-name = "vcc_5v";
vin-supply = <&vccsys>;
regulator-min-microvolt = <5000000>;
};regulator-max-microvolt = <5000000>;
- vcc_5v: vcc-5v {
- vcc33_sys: vcc33-sys { compatible = "regulator-fixed";
regulator-always-on; regulator-boot-on;regulator-name = "vcc33_sys";
vcc50_hdmi: vcc50-hdmi {
@@ -164,39 +97,21 @@ vin-supply = <&vcc_5v>; };
- bt_regulator: bt-regulator {
* On the module itself this is one of these (depending
* on the actual card pouplated):
* - BT_I2S_WS_BT_RFDISABLE_L
* - No connect
enable-active-high;
gpio = <&gpio4 29 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&bt_enable_l>;
regulator-name = "bt_regulator";
- vdd_logic: vdd-logic {
- wifi_regulator: wifi-regulator {
* on the actual card populated):
pwms = <&pwm1 0 1994 0>;
pwm-supply = <&vcc33_sys>;
enable-active-high;
gpio = <&gpio4 28 GPIO_ACTIVE_HIGH>;
regulator-name = "wifi_regulator";
pwm-dutycycle-range = <0x7b 0>;
pwm-dutycycle-unit = <0x94>;
/* Faux input supply. See bt_regulator description. */
vin-supply = <&bt_regulator>;
regulator-boot-on;
}; };regulator-ramp-delay = <4000>;
@@ -204,71 +119,62 @@ cpu0-supply = <&vdd_cpu>; };
-&efuse {
- status = "okay";
+&cpu_crit {
- temperature = <100000>;
+/* rk3288-c used in Veyron Chrome-devices has slightly changed OPPs */ +&cpu_opp_table {
/delete-node/ opp-312000000;
opp-1512000000 {
opp-microvolt = <1250000>;
opp-1608000000 {
opp-microvolt = <1300000>;
opp-1704000000 {
opp-hz = /bits/ 64 <1704000000>;
opp-microvolt = <1350000>;
opp-1800000000 {
opp-hz = /bits/ 64 <1800000000>;
opp-microvolt = <1400000>;
&emmc {
- broken-cd;
- status = "okay";
- bus-width = <8>; cap-mmc-highspeed;
- rockchip,default-sample-phase = <158>;
- disable-wp; mmc-hs200-1_8v; mmc-pwrseq = <&emmc_pwrseq>;
- disable-wp; non-removable;
- num-slots = <1>; pinctrl-names = "default";
- pinctrl-0 = <&emmc_clk &emmc_cmd &emmc_bus8 &emmc_pwr>;
- status = "okay";
- pinctrl-0 = <&emmc_clk &emmc_cmd &emmc_bus8>; };
-&sdio0 {
- broken-cd;
- bus-width = <4>;
- cap-sd-highspeed;
- sd-uhs-sdr12;
- sd-uhs-sdr25;
- sd-uhs-sdr50;
- sd-uhs-sdr104;
- cap-sdio-irq;
- card-external-vcc-supply = <&wifi_regulator>;
- clocks = <&cru HCLK_SDIO0>, <&cru SCLK_SDIO0>, <&cru SCLK_SDIO0_DRV>,
<&cru SCLK_SDIO0_SAMPLE>, <&rk808 RK808_CLKOUT1>;
- clock-names = "biu", "ciu", "ciu_drv", "ciu_sample", "card_ext_clock";
- keep-power-in-suspend;
- non-removable;
- num-slots = <1>;
- pinctrl-0 = <&sdio0_clk &sdio0_cmd &sdio0_bus4>;
+&gpu {
- mali-supply = <&vdd_gpu>; status = "okay";
- vmmc-supply = <&vcc33_sys>;
- vqmmc-supply = <&vcc18_wl>; };
-&sdmmc {
- bus-width = <4>;
- cap-mmc-highspeed;
- cap-sd-highspeed;
- sd-uhs-sdr12;
- sd-uhs-sdr25;
- sd-uhs-sdr50;
- sd-uhs-sdr104;
- card-detect-delay = <200>;
- cd-gpios = <&gpio7 5 GPIO_ACTIVE_LOW>;
- num-slots = <1>;
- status = "okay";
- vmmc-supply = <&vcc33_sd>;
- vqmmc-supply = <&vccio_sd>;
+&gpu_alert0 {
- temperature = <72500>; };
-&spi2 {
- status = "okay";
+&gpu_crit {
- spi_flash: spiflash@0 {
compatible = "spidev", "jedec,spi-nor";
spi-max-frequency = <20000000>; /* Reduce for Dediprog em100 pro */
reg = <0>;
+&hdmi {
pinctrl-names = "default", "unwedge";
pinctrl-0 = <&hdmi_ddc>;
pinctrl-1 = <&hdmi_ddc_unwedge>;
status = "okay"; };
&i2c0 {
@@ -280,12 +186,12 @@
rk808: pmic@1b { compatible = "rockchip,rk808";
clock-output-names = "xin32k", "wifibt_32kin"; interrupt-parent = <&gpio0>;reg = <0x1b>;
interrupts = <4 IRQ_TYPE_LEVEL_LOW>;
pinctrl-names = "default"; pinctrl-0 = <&pmic_int_l>;interrupts = <RK_PA4 IRQ_TYPE_LEVEL_LOW>;
rockchip,system-power-controller; wakeup-source; #clock-cells = <1>;reg = <0x1b>;
@@ -297,39 +203,41 @@ vcc6-supply = <&vcc_5v>; vcc7-supply = <&vcc33_sys>; vcc8-supply = <&vcc33_sys>;
vcc9-supply = <&vcc_5v>;
vcc10-supply = <&vcc33_sys>;
vcc11-supply = <&vcc_5v>;
vcc12-supply = <&vcc_18>;
vddio-supply = <&vcc33_io>;
regulators { vdd_cpu: DCDC_REG1 {
regulator-name = "vdd_arm"; regulator-always-on; regulator-boot-on; regulator-min-microvolt = <750000>; regulator-max-microvolt = <1450000>;
regulator-name = "vdd_arm"; regulator-ramp-delay = <6001>;
}; }; vdd_gpu: DCDC_REG2 {
regulator-name = "vdd_gpu"; regulator-always-on; regulator-boot-on; regulator-min-microvolt = <800000>; regulator-max-microvolt = <1250000>;
regulator-name = "vdd_gpu"; regulator-ramp-delay = <6001>;
}; }; vcc135_ddr: DCDC_REG3 {
regulator-name = "vcc135_ddr"; regulator-always-on; regulator-boot-on;
regulator-suspend-mem-enabled;
regulator-on-in-suspend;
@@ -340,12 +248,15 @@ * power measurement purposes). */ vcc18_wl: vcc18_flashio: vcc_18: DCDC_REG4 {
regulator-name = "vcc_18"; regulator-always-on; regulator-boot-on; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>;
regulator-suspend-mem-microvolt = <1800000>;
regulator-state-mem {
regulator-suspend-microvolt = <1800000>;
@@ -356,60 +267,47 @@ * (such as danger) they're the same net. */ vcc33_io: LDO_REG1 {
regulator-name = "vcc33_io"; regulator-always-on; regulator-boot-on; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>;
regulator-suspend-mem-microvolt = <3300000>;
regulator-suspend-microvolt = <3300000>;
}; }; vdd_10: LDO_REG3 {
regulator-name = "vdd_10"; regulator-always-on; regulator-boot-on; regulator-min-microvolt = <1000000>; regulator-max-microvolt = <1000000>;
regulator-suspend-mem-microvolt = <1000000>;
vccio_sd: LDO_REG4 {
regulator-name = "vccio_sd";
regulator-suspend-mem-disabled;
vcc33_sd: LDO_REG5 {
regulator-name = "vcc33_sd";
vcc18_codec: LDO_REG6 {
regulator-boot-on;
regulator-name = "vcc18_codec";
regulator-suspend-microvolt = <1000000>;
}; }; vdd10_lcd_pwren_h: LDO_REG7 {
regulator-name = "vdd10_lcd_pwren_h"; regulator-always-on; regulator-boot-on; regulator-min-microvolt = <2500000>; regulator-max-microvolt = <2500000>;
regulator-off-in-suspend;
}; }; vcc33_lcd: SWITCH_REG1 {
regulator-name = "vcc33_lcd"; regulator-always-on; regulator-boot-on;
@@ -436,24 +334,6 @@ clock-frequency = <100000>; i2c-scl-falling-time-ns = <50>; /* 10ns measured */ i2c-scl-rising-time-ns = <800>; /* 600ns measured */
- max98090: max98090@10 {
compatible = "maxim,max98090";
reg = <0x10>;
#sound-dai-cells = <0>;
interrupt-parent = <&gpio6>;
interrupts = <7 IRQ_TYPE_EDGE_FALLING>;
pinctrl-0 = <&int_codec>;
-&i2c3 {
status = "okay";
clock-frequency = <400000>;
i2c-scl-rising-time-ns = <300>; };
&i2c4 {
@@ -462,56 +342,61 @@ clock-frequency = <400000>; i2c-scl-falling-time-ns = <50>; /* 11ns measured */ i2c-scl-rising-time-ns = <300>; /* 225ns measured */
- headsetcodec: ts3a227e@3b {
compatible = "ti,ts3a227e";
reg = <0x3b>;
interrupts = <3 IRQ_TYPE_LEVEL_LOW>;
pinctrl-0 = <&ts3a227e_int_l>;
ti,micbias = <7>; /* MICBIAS = 2.8V */
-&i2c5 {
- status = "okay";
- clock-frequency = <100000>;
- i2c-scl-falling-time-ns = <300>;
- i2c-scl-rising-time-ns = <1000>;
-&i2s {
status = "okay";
clock-names = "i2s_hclk", "i2s_clk", "i2s_clk_out";
clocks = <&cru HCLK_I2S0>, <&cru SCLK_I2S0>, <&cru SCLK_I2S0_OUT>; };
&io_domains { status = "okay";
audio-supply = <&vcc18_codec>; bb-supply = <&vcc33_io>; dvp-supply = <&vcc_18>; flash0-supply = <&vcc18_flashio>; gpio1830-supply = <&vcc33_io>; gpio30-supply = <&vcc33_io>; lcdc-supply = <&vcc33_lcd>;
sdcard-supply = <&vccio_sd>; wifi-supply = <&vcc18_wl>; };
-&wdt { +&pwm1 {
- status = "okay";
+&sdio0 { status = "okay";
- bus-width = <4>;
- cap-sd-highspeed;
- cap-sdio-irq;
- mmc-pwrseq = <&sdio_pwrseq>;
- non-removable;
- pinctrl-names = "default";
- sd-uhs-sdr12;
- sd-uhs-sdr25;
- sd-uhs-sdr50;
- sd-uhs-sdr104;
-&pwm0 { +&spi2 { status = "okay";
- rx-sample-delay-ns = <12>;
- spi_flash: flash@0 {
compatible = "jedec,spi-nor";
spi-max-frequency = <50000000>;
reg = <0>;
-&pwm1 { +&tsadc { status = "okay";
rockchip,hw-tshut-mode = <1>; /* tshut mode 0:CRU 1:GPIO */
rockchip,hw-tshut-polarity = <1>; /* tshut polarity 0:LOW 1:HIGH */
rockchip,hw-tshut-temp = <125000>; };
&uart0 {
@@ -520,9 +405,6 @@ /* Pins don't include flow control by default; add that in */ pinctrl-names = "default"; pinctrl-0 = <&uart0_xfer &uart0_cts &uart0_rts>;
/* We need to go faster than 24MHz, so adjust clock parents / rates */
assigned-clocks = <&cru SCLK_UART0>;
assigned-clock-rates = <48000000>; };
&uart1 {
@@ -531,67 +413,47 @@
&uart2 { status = "okay";
- reg-shift = <2>; };
-&vopb { +&usbphy { status = "okay"; };
-&vopb_mmu { +&usb_host0_ehci { status = "okay"; -};
-&vopl {
- status = "okay";
- needs-reset-on-resume; };
-&vopl_mmu { +&usb_host1 { status = "okay";
- snps,need-phy-for-wake; };
-&edp { +&usb_otg { status = "okay";
- rockchip,panel = <&panel>;
- assigned-clock-parents = <&usbphy0>;
- dr_mode = "host";
-&hdmi { +&vopb { status = "okay"; };
-&gpu { +&vopb_mmu { status = "okay"; };
-&tsadc {
- tsadc-tshut-mode = <1>; /* tshut mode 0:CRU 1:GPIO */
- tsadc-tshut-polarity = <1>; /* tshut polarity 0:LOW 1:HIGH */
+&wdt { status = "okay"; };
&pinctrl {
- pinctrl-names = "default", "sleep";
- pinctrl-0 = <
/* Common for sleep and wake, but no owners */
&ddr0_retention
&ddrio_pwroff
&global_pwroff
/* Wake only */
&bt_dev_wake_awake
;- pinctrl-1 = <
&ddr0_retention
&ddrio_pwroff
&global_pwroff
/* Sleep only */
&bt_dev_wake_sleep
;- /* Add this for sdmmc pins to SD card */ pcfg_pull_none_drv_8ma: pcfg-pull-none-drv-8ma {
drive-strength = <8>; };bias-disable;
@@ -608,33 +470,15 @@ output-low; };
- backlight {
bl_en: bl-en {
rockchip,pins = <7 2 RK_FUNC_GPIO &pcfg_pull_none>;
- buttons {
pwr_key_h: pwr-key-h {
rockchip,pins = <0 5 RK_FUNC_GPIO &pcfg_pull_none>;
- codec {
hp_det: hp-det {
rockchip,pins = <6 5 RK_FUNC_GPIO &pcfg_pull_up>;
int_codec: int-codec {
rockchip,pins = <6 7 RK_FUNC_GPIO &pcfg_pull_up>;
mic_det: mic-det {
rockchip,pins = <6 11 RK_FUNC_GPIO &pcfg_pull_up>;
pwr_key_l: pwr-key-l {
rockchip,pins = <0 RK_PA5 RK_FUNC_GPIO &pcfg_pull_up>;
emmc { emmc_reset: emmc-reset {
rockchip,pins = <2 9 RK_FUNC_GPIO &pcfg_pull_none>;
rockchip,pins = <2 RK_PB1 RK_FUNC_GPIO &pcfg_pull_none>;
@@ -642,54 +486,59 @@ * We also have external pulls, so disable the internal ones. */ emmc_clk: emmc-clk {
rockchip,pins = <3 18 RK_FUNC_2 &pcfg_pull_none_drv_8ma>;
rockchip,pins = <3 RK_PC2 2 &pcfg_pull_none_drv_8ma>;
emmc_cmd: emmc-cmd {
rockchip,pins = <3 16 RK_FUNC_2 &pcfg_pull_none_drv_8ma>;
rockchip,pins = <3 RK_PC0 2 &pcfg_pull_none_drv_8ma>;
emmc_bus8: emmc-bus8 {
rockchip,pins = <3 0 RK_FUNC_2 &pcfg_pull_none_drv_8ma>,
<3 1 RK_FUNC_2 &pcfg_pull_none_drv_8ma>,
<3 2 RK_FUNC_2 &pcfg_pull_none_drv_8ma>,
<3 3 RK_FUNC_2 &pcfg_pull_none_drv_8ma>,
<3 4 RK_FUNC_2 &pcfg_pull_none_drv_8ma>,
<3 5 RK_FUNC_2 &pcfg_pull_none_drv_8ma>,
<3 6 RK_FUNC_2 &pcfg_pull_none_drv_8ma>,
<3 7 RK_FUNC_2 &pcfg_pull_none_drv_8ma>;
- headset {
ts3a227e_int_l: ts3a227e-int-l {
rockchip,pins = <0 3 RK_FUNC_GPIO &pcfg_pull_up>;
rockchip,pins = <3 RK_PA0 2 &pcfg_pull_none_drv_8ma>,
<3 RK_PA1 2 &pcfg_pull_none_drv_8ma>,
<3 RK_PA2 2 &pcfg_pull_none_drv_8ma>,
<3 RK_PA3 2 &pcfg_pull_none_drv_8ma>,
<3 RK_PA4 2 &pcfg_pull_none_drv_8ma>,
<3 RK_PA5 2 &pcfg_pull_none_drv_8ma>,
<3 RK_PA6 2 &pcfg_pull_none_drv_8ma>,
<3 RK_PA7 2 &pcfg_pull_none_drv_8ma>;
pmic { pmic_int_l: pmic-int-l {
* Causes jerry to hang when probing bus 0
* rockchip,pins = <RK_GPIO0 4 RK_FUNC_GPIO &pcfg_pull_up>;
rockchip,pins = <0 RK_PA4 RK_FUNC_GPIO &pcfg_pull_up>;
reboot { ap_warm_reset_h: ap-warm-reset-h {
rockchip,pins = <RK_GPIO0 13 RK_FUNC_GPIO &pcfg_pull_none>;
rockchip,pins = <0 RK_PB5 RK_FUNC_GPIO &pcfg_pull_none>;
recovery-switch {
rec_mode_l: rec-mode-l {
rockchip,pins = <0 RK_PB1 RK_FUNC_GPIO &pcfg_pull_up>;
sdio0 { wifi_enable_h: wifienable-h {
rockchip,pins = <4 28 RK_FUNC_GPIO &pcfg_pull_none>;
rockchip,pins = <4 RK_PD4 RK_FUNC_GPIO &pcfg_pull_none>;
/* NOTE: mislabelled on schematic; should be bt_enable_h */ bt_enable_l: bt-enable-l {
rockchip,pins = <4 29 RK_FUNC_GPIO &pcfg_pull_none>;
rockchip,pins = <4 RK_PD5 RK_FUNC_GPIO &pcfg_pull_none>;
bt_host_wake: bt-host-wake {
rockchip,pins = <4 RK_PD7 RK_FUNC_GPIO &pcfg_pull_down>;
bt_host_wake_l: bt-host-wake-l {
rockchip,pins = <4 RK_PD7 RK_FUNC_GPIO &pcfg_pull_none>;
@@ -697,100 +546,48 @@ * We also have external pulls, so disable the internal ones. */ sdio0_bus4: sdio0-bus4 {
rockchip,pins = <4 20 RK_FUNC_1 &pcfg_pull_none_drv_8ma>,
<4 21 RK_FUNC_1 &pcfg_pull_none_drv_8ma>,
<4 22 RK_FUNC_1 &pcfg_pull_none_drv_8ma>,
<4 23 RK_FUNC_1 &pcfg_pull_none_drv_8ma>;
rockchip,pins = <4 RK_PC4 1 &pcfg_pull_none_drv_8ma>,
<4 RK_PC5 1 &pcfg_pull_none_drv_8ma>,
<4 RK_PC6 1 &pcfg_pull_none_drv_8ma>,
<4 RK_PC7 1 &pcfg_pull_none_drv_8ma>;
sdio0_cmd: sdio0-cmd {
rockchip,pins = <4 24 RK_FUNC_1 &pcfg_pull_none_drv_8ma>;
rockchip,pins = <4 RK_PD0 1 &pcfg_pull_none_drv_8ma>;
sdio0_clk: sdio0-clk {
rockchip,pins = <4 25 RK_FUNC_1 &pcfg_pull_none_drv_8ma>;
rockchip,pins = <4 RK_PD1 1 &pcfg_pull_none_drv_8ma>;
- These pins are only present on very new veyron boards; on
- older boards bt_dev_wake is simply always high. Note that
* gpio4_26 is a NC on old veyron boards, so it doesn't hurt
* gpio4_D2 is a NC on old veyron boards, so it doesn't hurt
*/ bt_dev_wake_sleep: bt-dev-wake-sleep {
- to map this pin everywhere
rockchip,pins = <4 26 RK_FUNC_GPIO &pcfg_output_low>;
rockchip,pins = <4 RK_PD2 RK_FUNC_GPIO &pcfg_output_low>;
bt_dev_wake_awake: bt-dev-wake-awake {
rockchip,pins = <4 26 RK_FUNC_GPIO &pcfg_output_high>;
- sdmmc {
* We run sdmmc at max speed; bump up drive strength.
sdmmc_bus4: sdmmc-bus4 {
rockchip,pins = <6 16 RK_FUNC_1 &pcfg_pull_none_drv_8ma>,
<6 17 RK_FUNC_1 &pcfg_pull_none_drv_8ma>,
<6 18 RK_FUNC_1 &pcfg_pull_none_drv_8ma>,
<6 19 RK_FUNC_1 &pcfg_pull_none_drv_8ma>;
sdmmc_clk: sdmmc-clk {
rockchip,pins = <6 20 RK_FUNC_1 &pcfg_pull_none_drv_8ma>;
sdmmc_cmd: sdmmc-cmd {
rockchip,pins = <6 21 RK_FUNC_1 &pcfg_pull_none_drv_8ma>;
* Builtin CD line is hooked to ground to prevent JTAG at boot
* (and also to get the voltage rail correct). Make we
* configure gpio6_C6 as GPIO so dw_mmc builtin CD doesn't
* think there's a card inserted
sdmmc_cd_disabled: sdmmc-cd-disabled {
rockchip,pins = <6 22 RK_FUNC_GPIO &pcfg_pull_none>;
};rockchip,pins = <4 RK_PD2 RK_FUNC_GPIO &pcfg_output_high>;
/* This is where we actually hook up CD */
sdmmc_cd_gpio: sdmmc-cd-gpio {
rockchip,pins = <7 5 RK_FUNC_GPIO &pcfg_pull_none>;
bt_dev_wake: bt-dev-wake {
rockchip,pins = <4 RK_PD2 RK_FUNC_GPIO &pcfg_pull_none>;
tpm { tpm_int_h: tpm-int-h {
rockchip,pins = <7 4 RK_FUNC_GPIO &pcfg_pull_none>;
rockchip,pins = <7 RK_PA4 RK_FUNC_GPIO &pcfg_pull_none>;
write-protect { fw_wp_ap: fw-wp-ap {
rockchip,pins = <7 6 RK_FUNC_GPIO &pcfg_pull_none>;
}; }; };rockchip,pins = <7 RK_PA6 RK_FUNC_GPIO &pcfg_pull_none>;
-&usbphy {
- status = "okay";
-&usb_host0_ehci {
- status = "okay";
-&usb_host1 {
- status = "okay";
-&usb_otg {
- dr_mode = "host";
- status = "okay";
- assigned-clocks = <&cru SCLK_USBPHY480M_SRC>;
- assigned-clock-parents = <&cru SCLK_OTGPHY0>;
The DT node name pattern in mmc-controller.yaml for mmc is "^mmc(@.*)?$". The Rockchip mmc nodes have been synced with Linux, so update the boot_devices constants as well.
Signed-off-by: Johan Jonker jbx6244@gmail.com Reviewed-by: Simon Glass sjg@chromium.org --- arch/arm/mach-rockchip/rk3188/rk3188.c | 4 ++-- arch/arm/mach-rockchip/rk322x/rk322x.c | 4 ++-- arch/arm/mach-rockchip/rk3288/rk3288.c | 4 ++-- arch/arm/mach-rockchip/rk3328/rk3328.c | 4 ++-- arch/arm/mach-rockchip/rk3368/rk3368.c | 4 ++-- 5 files changed, 10 insertions(+), 10 deletions(-)
diff --git a/arch/arm/mach-rockchip/rk3188/rk3188.c b/arch/arm/mach-rockchip/rk3188/rk3188.c index 5a02914e..df8fa156 100644 --- a/arch/arm/mach-rockchip/rk3188/rk3188.c +++ b/arch/arm/mach-rockchip/rk3188/rk3188.c @@ -21,8 +21,8 @@ #define GRF_BASE 0x20008000
const char * const boot_devices[BROM_LAST_BOOTSOURCE + 1] = { - [BROM_BOOTSOURCE_EMMC] = "/dwmmc@1021c000", - [BROM_BOOTSOURCE_SD] = "/dwmmc@10214000", + [BROM_BOOTSOURCE_EMMC] = "/mmc@1021c000", + [BROM_BOOTSOURCE_SD] = "/mmc@10214000", };
#ifdef CONFIG_DEBUG_UART_BOARD_INIT diff --git a/arch/arm/mach-rockchip/rk322x/rk322x.c b/arch/arm/mach-rockchip/rk322x/rk322x.c index ad4ac62e..a304795f 100644 --- a/arch/arm/mach-rockchip/rk322x/rk322x.c +++ b/arch/arm/mach-rockchip/rk322x/rk322x.c @@ -9,8 +9,8 @@ #include <asm/arch-rockchip/hardware.h>
const char * const boot_devices[BROM_LAST_BOOTSOURCE + 1] = { - [BROM_BOOTSOURCE_EMMC] = "/dwmmc@30020000", - [BROM_BOOTSOURCE_SD] = "/dwmmc@30000000", + [BROM_BOOTSOURCE_EMMC] = "/mmc@30020000", + [BROM_BOOTSOURCE_SD] = "/mmc@30000000", };
#ifdef CONFIG_DEBUG_UART_BOARD_INIT diff --git a/arch/arm/mach-rockchip/rk3288/rk3288.c b/arch/arm/mach-rockchip/rk3288/rk3288.c index bc20bc5a..3ad28875 100644 --- a/arch/arm/mach-rockchip/rk3288/rk3288.c +++ b/arch/arm/mach-rockchip/rk3288/rk3288.c @@ -28,8 +28,8 @@ DECLARE_GLOBAL_DATA_PTR; #define GRF_BASE 0xff770000
const char * const boot_devices[BROM_LAST_BOOTSOURCE + 1] = { - [BROM_BOOTSOURCE_EMMC] = "/dwmmc@ff0f0000", - [BROM_BOOTSOURCE_SD] = "/dwmmc@ff0c0000", + [BROM_BOOTSOURCE_EMMC] = "/mmc@ff0f0000", + [BROM_BOOTSOURCE_SD] = "/mmc@ff0c0000", };
#ifdef CONFIG_SPL_BUILD diff --git a/arch/arm/mach-rockchip/rk3328/rk3328.c b/arch/arm/mach-rockchip/rk3328/rk3328.c index ec3336cb..de17b886 100644 --- a/arch/arm/mach-rockchip/rk3328/rk3328.c +++ b/arch/arm/mach-rockchip/rk3328/rk3328.c @@ -21,8 +21,8 @@ DECLARE_GLOBAL_DATA_PTR; #define FW_DDR_CON_REG 0xFF7C0040
const char * const boot_devices[BROM_LAST_BOOTSOURCE + 1] = { - [BROM_BOOTSOURCE_EMMC] = "/rksdmmc@ff520000", - [BROM_BOOTSOURCE_SD] = "/rksdmmc@ff500000", + [BROM_BOOTSOURCE_EMMC] = "/mmc@ff520000", + [BROM_BOOTSOURCE_SD] = "/mmc@ff500000", };
static struct mm_region rk3328_mem_map[] = { diff --git a/arch/arm/mach-rockchip/rk3368/rk3368.c b/arch/arm/mach-rockchip/rk3368/rk3368.c index 9b7132d4..d0a6107e 100644 --- a/arch/arm/mach-rockchip/rk3368/rk3368.c +++ b/arch/arm/mach-rockchip/rk3368/rk3368.c @@ -58,8 +58,8 @@ static struct mm_region rk3368_mem_map[] = { struct mm_region *mem_map = rk3368_mem_map;
#ifdef CONFIG_ARCH_EARLY_INIT_R
Hi Johan,
This series seems to work OK on snow. But on jerry I get:
U-Boot 2022.04-rc3-00077-g088bbcb3fad (Mar 11 2022 - 15:59:54 -0700)
Model: Google Jerry DRAM: 2 GiB PMIC: RK808 Core: 256 devices, 25 uclasses, devicetree: separate MMC: mmc@ff0c0000: 1, mmc@ff0d0000: 2, mmc@ff0f0000: 0 Loading Environment from nowhere... OK cros_ec_spi_command: Returned status 6 cros_ec_check_version: ERROR: old EC interface not supported Failed to probe keyboard 'keyboard-controller' rockchip_rk3288_vop vop@ff930000: failed to get ahb reset (ret=-524) rockchip_rk3288_vop vop@ff930000: failed to get ahb reset (ret=-524) In: serial
So it seems the EC and video devicetree are broken in some way, or drivers need updating for new bindings?
Hi Simon,
On 3/12/22 03:24, Simon Glass wrote:
Hi Johan,
When I compare the ec node in the dtb before and after it looks like "ec-interrupt" is missing.
Could you test/confirm by adding it to rk3288-veyron-jerry-u-boot.dtsi?
It originates from rk3288-veyron-chromebook.dtsi, but what should be the u-boot specific correct location now for the other rk3288 veyron boards?
&cros_ec { ec-interrupt = <&gpio7 7 GPIO_ACTIVE_LOW>; };
This property is not in the binding: Documentation/devicetree/bindings/mfd/google,cros-ec.yaml
What to do with it? (no u-boot prefix)
dtc -s -I dtb -O dts rk3288-veyron-jerry-before.dtb > rk3288-veyron-jerry-before-sort.dts
dtc -s -I dtb -O dts rk3288-veyron-jerry-after.dtb > rk3288-veyron-jerry-after-sort.dts
ec@0 { compatible = "google,cros-ec-spi"; === ec-interrupt = < 0x07 0x07 0x01 >; === google,cros-ec-spi-pre-delay = < 0x1e >; interrupt-parent = < 0x07 >; interrupts = < 0x07 0x08 >; pinctrl-0 = < 0x20 >; pinctrl-names = "default"; reg = < 0x00 >; spi-max-frequency = < 0x2dc6c0 >;
i2c-tunnel {
keyboard-controller {
Could you test before and after Linux sync and with reg size?
vopb: vop@ff930000 { compatible = "rockchip,rk3288-vop";
reg = <0xff930000 0x19c>, <0xff931000 0x1000>;
vs. reg = <0xff930000 0x19c>;
From rk_vop.c:
priv->regs = (struct rk3288_vop *)dev_read_addr(dev);
From rockchip-vop.yaml:
reg: minItems: 1 items: - description: Must contain one entry corresponding to the base address and length of the register space. - description: Can optionally contain a second entry corresponding to the CRTC gamma LUT address.
Does vop driver need a fix to comply with binding?
In: serial
Could the veyron board maintainer fix this? What to do with the things below to move forward with this serie?
Before sync:
panel: panel { compatible ="cnm,n116bgeea2","simple-panel"; status = "okay"; power-supply = <&vcc33_lcd>; backlight = <&backlight>; };
&edp { status = "okay"; rockchip,panel = <&panel>; };
After sync:
panel: panel { compatible = "innolux,n116bge"; status = "okay"; power-supply = <&panel_regulator>; backlight = <&backlight>;
panel-timing { clock-frequency = <74250000>; hactive = <1366>; hfront-porch = <136>; hback-porch = <60>; hsync-len = <30>; hsync-active = <0>; vactive = <768>; vfront-porch = <8>; vback-porch = <12>; vsync-len = <12>; vsync-active = <0>; };
ports { panel_in: port { panel_in_edp: endpoint { remote-endpoint = <&edp_out_panel>; }; }; }; };
pinctrl-names = "default"; pinctrl-0 = <&edp_hpd>;
ports { edp_out: port@1 { reg = <1>; #address-cells = <1>; #size-cells = <0>; edp_out_panel: endpoint@0 { reg = <0>; remote-endpoint = <&panel_in_edp>; }; }; }; };
&edp_phy { status = "okay"; };
The edp node has different compatible strings and phys reset-names?? Please advise ??
edp: edp@ff970000 {
compatible = "rockchip,rk3288-edp";
reg = <0xff970000 0x4000>; interrupts = <GIC_SPI 98 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cru SCLK_EDP>, <&cru SCLK_EDP_24M>, <&cru PCLK_EDP_CTRL>; rockchip,grf = <&grf>; clock-names = "clk_edp", "clk_edp_24m", "pclk_edp"; resets = <&cru 111>;
reset-names = "edp";
power-domains = <&power RK3288_PD_VIO>; status = "disabled";
edp: dp@ff970000 {
compatible = "rockchip,rk3288-dp";
reg = <0xff970000 0x4000>; interrupts = <GIC_SPI 98 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cru SCLK_EDP>, <&cru PCLK_EDP_CTRL>; clock-names = "dp", "pclk";
phys = <&edp_phy>; phy-names = "dp";
resets = <&cru SRST_EDP>;
reset-names = "dp";
rockchip,grf = <&grf>; status = "disabled";
It also seemed fine on bob although my display is not coming up, for different reasons.
In SPL or full U-boot?
There is no display in SPL.
Before and after only vopb and vopl node available in jerry. No other hdmi mipi edp. There's no "u-boot,dm-pre-reloc" for them. What do you expect to work in this stage?
Johan
Hi Johan,
On Fri, 18 Mar 2022 at 09:17, Johan Jonker jbx6244@gmail.com wrote:
Hi Simon,
Hi Johan,
Yes that looks like it.
There is a standard way of doing interrupts, so could the code be updated to use that? For now a u-boot, prefix would be OK, I suppose, to unblock your work.
i2c-tunnel { }; keyboard-controller { }; };
vopb: vop@ff930000 { compatible = "rockchip,rk3288-vop"; reg = <0xff930000 0x19c>, <0xff931000 0x1000>;
From rk_vop.c:
Quite possibly.
In: serial
Before sync:
After sync:
panel: panel { compatible = "innolux,n116bge"; status = "okay"; power-supply = <&panel_regulator>; backlight = <&backlight>; panel-timing { clock-frequency = <74250000>; hactive = <1366>; hfront-porch = <136>; hback-porch = <60>; hsync-len = <30>; hsync-active = <0>; vactive = <768>; vfront-porch = <8>; vback-porch = <12>; vsync-len = <12>; vsync-active = <0>; }; ports { panel_in: port { panel_in_edp: endpoint { remote-endpoint = <&edp_out_panel>; }; }; }; };
pinctrl-names = "default"; pinctrl-0 = <&edp_hpd>; ports { edp_out: port@1 { reg = <1>; #address-cells = <1>; #size-cells = <0>; edp_out_panel: endpoint@0 { reg = <0>; remote-endpoint = <&panel_in_edp>; }; }; };
edp: edp@ff970000 { compatible = "rockchip,rk3288-edp"; reg = <0xff970000 0x4000>; interrupts = <GIC_SPI 98 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cru SCLK_EDP>, <&cru SCLK_EDP_24M>, <&cru PCLK_EDP_CTRL>; rockchip,grf = <&grf>; clock-names = "clk_edp", "clk_edp_24m", "pclk_edp"; resets = <&cru 111>; reset-names = "edp"; power-domains = <&power RK3288_PD_VIO>; status = "disabled"; edp: dp@ff970000 { compatible = "rockchip,rk3288-dp"; reg = <0xff970000 0x4000>; interrupts = <GIC_SPI 98 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cru SCLK_EDP>, <&cru PCLK_EDP_CTRL>; clock-names = "dp", "pclk"; phys = <&edp_phy>; phy-names = "dp"; resets = <&cru SRST_EDP>; reset-names = "dp"; rockchip,grf = <&grf>; status = "disabled";
It should work OK with the internal display. If an HDMI display is connected, that should work too, if selected.
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
On Fri, Mar 4, 2022 at 5:22 AM Johan Jonker jbx6244@gmail.com wrote:
In order to update the DT for rk3228 sync the power domain dt-binding header. This is the state as of v5.17 in Linux.
Look like this entire series syncing for rk3288 dts changes from Linux. Better add 1. Patch for all rk3288 sync at once (use the specific tag) 2. Patch for -u-boot.dtsi changes
Too many patches with individual changes seem not trackable as these are sync changes unlike specific feature or bug fixes.
Thanks, Jagan.
Thanks, - Kever
include/dt-bindings/power/rk3228-power.h | 21 +++++++++++++++++++++ 1 file changed, 21 insertions(+) create mode 100644 include/dt-bindings/power/rk3228-power.h
diff --git a/include/dt-bindings/power/rk3228-power.h b/include/dt-bindings/power/rk3228-power.h new file mode 100644 index 00000000..6a8dc1bf --- /dev/null +++ b/include/dt-bindings/power/rk3228-power.h @@ -0,0 +1,21 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +#ifndef __DT_BINDINGS_POWER_RK3228_POWER_H__ +#define __DT_BINDINGS_POWER_RK3228_POWER_H__
- RK3228 idle id Summary.
+#define RK3228_PD_CORE 0 +#define RK3228_PD_MSCH 1 +#define RK3228_PD_BUS 2 +#define RK3228_PD_SYS 3 +#define RK3228_PD_VIO 4 +#define RK3228_PD_VOP 5 +#define RK3228_PD_VPU 6 +#define RK3228_PD_RKVDEC 7 +#define RK3228_PD_GPU 8 +#define RK3228_PD_PERI 9 +#define RK3228_PD_GMAC 10
Jagan Teki
Johan Jonker
Kever Yang
