[PATCH] configs: stm32mp1: replace STM32MP1_TRUSTED by TFABOOT
Activate ARCH_SUPPORT_TFABOOT and replace the arch stm32mp specific config CONFIG_STM32MP1_TRUSTED by the generic CONFIG_TFABOOT introduced by the commit 535d76a12150 ("armv8: layerscape: Add TFABOOT support"). This config CONFIG_TFABOOT is activated for the trusted boot chain, when U-Boot is loaded by TF-A.
Signed-off-by: Patrick Delaunay patrick.delaunay@st.com ---
arch/arm/Kconfig | 1 + arch/arm/mach-stm32mp/Kconfig | 21 ++++++--------------- arch/arm/mach-stm32mp/bsec.c | 18 +++++++++--------- arch/arm/mach-stm32mp/cpu.c | 10 +++++----- board/dhelectronics/dh_stm32mp1/board.c | 4 ++-- board/st/stm32mp1/stm32mp1.c | 4 ++-- configs/stm32mp15_optee_defconfig | 1 + configs/stm32mp15_trusted_defconfig | 1 + drivers/clk/clk_stm32mp1.c | 2 +- drivers/ram/stm32mp1/stm32mp1_ram.c | 2 +- include/configs/stm32mp1.h | 2 +- 11 files changed, 30 insertions(+), 36 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 5d367888d8..54ff4557d4 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1583,6 +1583,7 @@ config ARCH_STI config ARCH_STM32MP bool "Support STMicroelectronics STM32MP Socs with cortex A" select ARCH_MISC_INIT + select ARCH_SUPPORT_TFABOOT select BOARD_LATE_INIT select CLK select DM diff --git a/arch/arm/mach-stm32mp/Kconfig b/arch/arm/mach-stm32mp/Kconfig index e4d621dee8..e42e9e2e82 100644 --- a/arch/arm/mach-stm32mp/Kconfig +++ b/arch/arm/mach-stm32mp/Kconfig @@ -35,9 +35,10 @@ config ENV_SIZE
config STM32MP15x bool "Support STMicroelectronics STM32MP15x Soc" - select ARCH_SUPPORT_PSCI if !STM32MP1_TRUSTED + select ARCH_SUPPORT_PSCI if !TFABOOT + select ARM_SMCCC if TFABOOT select CPU_V7A - select CPU_V7_HAS_NONSEC if !STM32MP1_TRUSTED + select CPU_V7_HAS_NONSEC if !TFABOOT select CPU_V7_HAS_VIRT select OF_BOARD_SETUP select PINCTRL_STM32 @@ -45,8 +46,8 @@ config STM32MP15x select STM32_RESET select STM32_SERIAL select SYS_ARCH_TIMER - imply SYSRESET_PSCI if STM32MP1_TRUSTED - imply SYSRESET_SYSCON if !STM32MP1_TRUSTED + imply SYSRESET_PSCI if TFABOOT + imply SYSRESET_SYSCON if !TFABOOT help support of STMicroelectronics SOC STM32MP15x family STM32MP157, STM32MP153 or STM32MP151 @@ -83,19 +84,9 @@ config TARGET_DH_STM32MP1_PDK2
endchoice
-config STM32MP1_TRUSTED - bool "Support trusted boot with TF-A" - default y if !SPL - select ARM_SMCCC - help - Say Y here to enable boot with TF-A - Trusted boot chain is : - BootRom => TF-A.stm32 (clock & DDR) => U-Boot.stm32 - TF-A monitor provides proprietary SMC to manage secure devices - config STM32MP1_OPTEE bool "Support trusted boot with TF-A and OP-TEE" - depends on STM32MP1_TRUSTED + depends on TFABOOT default n help Say Y here to enable boot with TF-A and OP-TEE diff --git a/arch/arm/mach-stm32mp/bsec.c b/arch/arm/mach-stm32mp/bsec.c index 3b923f088e..0d5850b4a9 100644 --- a/arch/arm/mach-stm32mp/bsec.c +++ b/arch/arm/mach-stm32mp/bsec.c @@ -68,7 +68,7 @@ static bool bsec_read_lock(u32 address, u32 otp) return !!(readl(address + bank) & bit); }
-#ifndef CONFIG_STM32MP1_TRUSTED +#ifndef CONFIG_TFABOOT /** * bsec_check_error() - Check status of one otp * @base: base address of bsec IP @@ -273,7 +273,7 @@ static int bsec_program_otp(long base, u32 val, u32 otp)
return ret; } -#endif /* CONFIG_STM32MP1_TRUSTED */ +#endif /* CONFIG_TFABOOT */
/* BSEC MISC driver *******************************************************/ struct stm32mp_bsec_platdata { @@ -282,7 +282,7 @@ struct stm32mp_bsec_platdata {
static int stm32mp_bsec_read_otp(struct udevice *dev, u32 *val, u32 otp) { -#ifdef CONFIG_STM32MP1_TRUSTED +#ifdef CONFIG_TFABOOT return stm32_smc(STM32_SMC_BSEC, STM32_SMC_READ_OTP, otp, 0, val); @@ -313,7 +313,7 @@ static int stm32mp_bsec_read_otp(struct udevice *dev, u32 *val, u32 otp)
static int stm32mp_bsec_read_shadow(struct udevice *dev, u32 *val, u32 otp) { -#ifdef CONFIG_STM32MP1_TRUSTED +#ifdef CONFIG_TFABOOT return stm32_smc(STM32_SMC_BSEC, STM32_SMC_READ_SHADOW, otp, 0, val); @@ -336,7 +336,7 @@ static int stm32mp_bsec_read_lock(struct udevice *dev, u32 *val, u32 otp)
static int stm32mp_bsec_write_otp(struct udevice *dev, u32 val, u32 otp) { -#ifdef CONFIG_STM32MP1_TRUSTED +#ifdef CONFIG_TFABOOT return stm32_smc_exec(STM32_SMC_BSEC, STM32_SMC_PROG_OTP, otp, val); @@ -349,7 +349,7 @@ static int stm32mp_bsec_write_otp(struct udevice *dev, u32 val, u32 otp)
static int stm32mp_bsec_write_shadow(struct udevice *dev, u32 val, u32 otp) { -#ifdef CONFIG_STM32MP1_TRUSTED +#ifdef CONFIG_TFABOOT return stm32_smc_exec(STM32_SMC_BSEC, STM32_SMC_WRITE_SHADOW, otp, val); @@ -362,7 +362,7 @@ static int stm32mp_bsec_write_shadow(struct udevice *dev, u32 val, u32 otp)
static int stm32mp_bsec_write_lock(struct udevice *dev, u32 val, u32 otp) { -#ifdef CONFIG_STM32MP1_TRUSTED +#ifdef CONFIG_TFABOOT if (val == 1) return stm32_smc_exec(STM32_SMC_BSEC, STM32_SMC_WRLOCK_OTP, @@ -473,7 +473,7 @@ static int stm32mp_bsec_ofdata_to_platdata(struct udevice *dev) return 0; }
-#ifndef CONFIG_STM32MP1_TRUSTED +#ifndef CONFIG_TFABOOT static int stm32mp_bsec_probe(struct udevice *dev) { int otp; @@ -500,7 +500,7 @@ U_BOOT_DRIVER(stm32mp_bsec) = { .ofdata_to_platdata = stm32mp_bsec_ofdata_to_platdata, .platdata_auto_alloc_size = sizeof(struct stm32mp_bsec_platdata), .ops = &stm32mp_bsec_ops, -#ifndef CONFIG_STM32MP1_TRUSTED +#ifndef CONFIG_TFABOOT .probe = stm32mp_bsec_probe, #endif }; diff --git a/arch/arm/mach-stm32mp/cpu.c b/arch/arm/mach-stm32mp/cpu.c index 9aa5794334..74d03fa7dd 100644 --- a/arch/arm/mach-stm32mp/cpu.c +++ b/arch/arm/mach-stm32mp/cpu.c @@ -76,7 +76,7 @@ #define PKG_MASK GENMASK(2, 0)
#if !defined(CONFIG_SPL) || defined(CONFIG_SPL_BUILD) -#ifndef CONFIG_STM32MP1_TRUSTED +#ifndef CONFIG_TFABOOT static void security_init(void) { /* Disable the backup domain write protection */ @@ -136,7 +136,7 @@ static void security_init(void) writel(BIT(0), RCC_MP_AHB5ENSETR); writel(0x0, GPIOZ_SECCFGR); } -#endif /* CONFIG_STM32MP1_TRUSTED */ +#endif /* CONFIG_TFABOOT */
/* * Debug init @@ -150,7 +150,7 @@ static void dbgmcu_init(void) } #endif /* !defined(CONFIG_SPL) || defined(CONFIG_SPL_BUILD) */
-#if !defined(CONFIG_STM32MP1_TRUSTED) && \ +#if !defined(CONFIG_TFABOOT) && \ (!defined(CONFIG_SPL) || defined(CONFIG_SPL_BUILD)) /* get bootmode from ROM code boot context: saved in TAMP register */ static void update_bootmode(void) @@ -198,7 +198,7 @@ int arch_cpu_init(void)
#if !defined(CONFIG_SPL) || defined(CONFIG_SPL_BUILD) dbgmcu_init(); -#ifndef CONFIG_STM32MP1_TRUSTED +#ifndef CONFIG_TFABOOT security_init(); update_bootmode(); #endif @@ -214,7 +214,7 @@ int arch_cpu_init(void) if ((boot_mode & TAMP_BOOT_DEVICE_MASK) == BOOT_SERIAL_UART) gd->flags |= GD_FLG_SILENT | GD_FLG_DISABLE_CONSOLE; #if defined(CONFIG_DEBUG_UART) && \ - !defined(CONFIG_STM32MP1_TRUSTED) && \ + !defined(CONFIG_TFABOOT) && \ (!defined(CONFIG_SPL) || defined(CONFIG_SPL_BUILD)) else debug_uart_init(); diff --git a/board/dhelectronics/dh_stm32mp1/board.c b/board/dhelectronics/dh_stm32mp1/board.c index b663696983..c39a4b193c 100644 --- a/board/dhelectronics/dh_stm32mp1/board.c +++ b/board/dhelectronics/dh_stm32mp1/board.c @@ -119,7 +119,7 @@ int checkboard(void)
if (IS_ENABLED(CONFIG_STM32MP1_OPTEE)) mode = "trusted with OP-TEE"; - else if (IS_ENABLED(CONFIG_STM32MP1_TRUSTED)) + else if (IS_ENABLED(CONFIG_TFABOOT)) mode = "trusted"; else mode = "basic"; @@ -284,7 +284,7 @@ static void __maybe_unused led_error_blink(u32 nb_blink)
static void sysconf_init(void) { -#ifndef CONFIG_STM32MP1_TRUSTED +#ifndef CONFIG_TFABOOT u8 *syscfg; #ifdef CONFIG_DM_REGULATOR struct udevice *pwr_dev; diff --git a/board/st/stm32mp1/stm32mp1.c b/board/st/stm32mp1/stm32mp1.c index 07f5344ec9..6c884028d3 100644 --- a/board/st/stm32mp1/stm32mp1.c +++ b/board/st/stm32mp1/stm32mp1.c @@ -92,7 +92,7 @@ int checkboard(void)
if (IS_ENABLED(CONFIG_STM32MP1_OPTEE)) mode = "trusted with OP-TEE"; - else if (IS_ENABLED(CONFIG_STM32MP1_TRUSTED)) + else if (IS_ENABLED(TFABOOT)) mode = "trusted"; else mode = "basic"; @@ -462,7 +462,7 @@ static int board_check_usb_power(void)
static void sysconf_init(void) { -#ifndef CONFIG_STM32MP1_TRUSTED +#ifndef CONFIG_TFABOOT u8 *syscfg; #ifdef CONFIG_DM_REGULATOR struct udevice *pwr_dev; diff --git a/configs/stm32mp15_optee_defconfig b/configs/stm32mp15_optee_defconfig index 298611776d..6c17bd9b20 100644 --- a/configs/stm32mp15_optee_defconfig +++ b/configs/stm32mp15_optee_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_STM32MP=y +CONFIG_TFABOOT=y CONFIG_SYS_MALLOC_F_LEN=0x3000 CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_ENV_OFFSET=0x280000 diff --git a/configs/stm32mp15_trusted_defconfig b/configs/stm32mp15_trusted_defconfig index 6928e9a65c..7592f6fcc4 100644 --- a/configs/stm32mp15_trusted_defconfig +++ b/configs/stm32mp15_trusted_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_STM32MP=y +CONFIG_TFABOOT=y CONFIG_SYS_MALLOC_F_LEN=0x3000 CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_ENV_OFFSET=0x280000 diff --git a/drivers/clk/clk_stm32mp1.c b/drivers/clk/clk_stm32mp1.c index 52bd8e96f3..50df8425bf 100644 --- a/drivers/clk/clk_stm32mp1.c +++ b/drivers/clk/clk_stm32mp1.c @@ -19,7 +19,7 @@
DECLARE_GLOBAL_DATA_PTR;
-#ifndef CONFIG_STM32MP1_TRUSTED +#ifndef CONFIG_TFABOOT #if !defined(CONFIG_SPL) || defined(CONFIG_SPL_BUILD) /* activate clock tree initialization in the driver */ #define STM32MP1_CLOCK_TREE_INIT diff --git a/drivers/ram/stm32mp1/stm32mp1_ram.c b/drivers/ram/stm32mp1/stm32mp1_ram.c index b1e593f86b..7b1adc5b24 100644 --- a/drivers/ram/stm32mp1/stm32mp1_ram.c +++ b/drivers/ram/stm32mp1/stm32mp1_ram.c @@ -177,7 +177,7 @@ static int stm32mp1_ddr_probe(struct udevice *dev)
priv->info.base = STM32_DDR_BASE;
-#if !defined(CONFIG_STM32MP1_TRUSTED) && \ +#if !defined(CONFIG_TFABOOT) && \ (!defined(CONFIG_SPL) || defined(CONFIG_SPL_BUILD)) priv->info.size = 0; return stm32mp1_ddr_setup(dev); diff --git a/include/configs/stm32mp1.h b/include/configs/stm32mp1.h index 42717c167e..2ba4fb1305 100644 --- a/include/configs/stm32mp1.h +++ b/include/configs/stm32mp1.h @@ -10,7 +10,7 @@ #include <linux/sizes.h> #include <asm/arch/stm32.h>
-#ifndef CONFIG_STM32MP1_TRUSTED +#ifndef CONFIG_TFABOOT /* PSCI support */ #define CONFIG_ARMV7_PSCI_1_0 #define CONFIG_ARMV7_SECURE_BASE STM32_SYSRAM_BASE
Hi Patrick
- select ARCH_SUPPORT_TFABOOT select BOARD_LATE_INIT select CLK select DM
- select ARCH_SUPPORT_PSCI if !TFABOOT
- select ARM_SMCCC if TFABOOT select CPU_V7A
- select CPU_V7_HAS_NONSEC if !TFABOOT select CPU_V7_HAS_VIRT select OF_BOARD_SETUP select PINCTRL_STM32
- imply SYSRESET_PSCI if TFABOOT
- imply SYSRESET_SYSCON if !TFABOOT help support of STMicroelectronics SOC STM32MP15x family STM32MP157, STM32MP153 or STM32MP151
endchoice
- default y if !SPL
- select ARM_SMCCC
- help
- depends on TFABOOT default n help Say Y here to enable boot with TF-A and OP-TEE
- bsec_check_error() - Check status of one otp
- @base: base address of bsec IP
- Debug init
- !defined(CONFIG_TFABOOT) && \ (!defined(CONFIG_SPL) || defined(CONFIG_SPL_BUILD)) else debug_uart_init();
- else if (IS_ENABLED(CONFIG_TFABOOT)) mode = "trusted"; else mode = "basic";
- else if (IS_ENABLED(TFABOOT)) mode = "trusted"; else mode = "basic";
Reviewed-by: Patrice Chotard patrice.chotard@st.com
Thanks
Hi
On 4/1/20 9:46 AM, Patrice CHOTARD wrote:
Hi Patrick
Applied to u-boot-stm/next
Thanks
Patrice
endchoice
- default y if !SPL
- select ARM_SMCCC
- help
- Debug init
Thanks _______________________________________________ Uboot-stm32 mailing list Uboot-stm32@st-md-mailman.stormreply.com https://st-md-mailman.stormreply.com/mailman/listinfo/uboot-stm32
Patrice CHOTARD
Patrick Delaunay
