[U-Boot] Default base for numbers
Hello,
I've stumbled over the fact that the length parameter for sha1sum uses 16 as default base, which I found a bit confusing.
E.g. ------------------------- U-Boot>> tftp $loadaddr uImage ... done Bytes transferred = 1976384 (1e2840 hex) U-Boot>> sha1sum $loadaddr 1976384 SHA1 for 00800000 ... 02176383 ==> 8d9cc7b167b6d1471d73d46cfc3b374091de88a6 U-Boot>> sha1sum $loadaddr 0x1e2840 SHA1 for 00800000 ... 009e283f ==> fde54f7409c785b7929d36624f77f71abd30282a ------------------------- (The second one is correct)
Is the base 16 as default for numbers common for commands in u-boot or is that just a problem of md5sum and sha1sum?
Regards,
Alexander
Dear Alexander Holler,
Read the documentation.
With very few exceptions all commands use base 16 input. I recommend you start reading the manual.
Am 25.01.2011 10:16, schrieb Wolfgang Denk:
Thanks for the pointer, if someone else is interested, it is described in chapter 5.9. U-Boot Command Line Interface. Easy to find. ;)
Regards,
Alexander
I change my uboot version and after it the uboot don't starts the same linux kernel:
## Booting kernel from Legacy Image at 10060000 ... Image Name: Linux Kernel Image Type: ARM Linux Kernel Image (gzip compressed) Data Size: 1178673 Bytes = 1.1 MiB Load Address: 20008000 Entry Point: 20008000 Verifying Checksum ... OK Uncompressing Kernel Image ... OK
Starting kernel ...
*****LOG END*****
It's a board simular to the at91rm9200dk. I start the kernel with
bootcmd2=setenv bootargs root=/dev/mtdblock9 rootfstype=squashfs ETHADDR=$(ethaddr) RUNNING=$(runningimage) CFGFS=mtdblock10;bootm 0x30060000
run bootcmd2
Can anybody give me a hint where I had to search for the error?
Mit freundlichen Grüßen
Maik Hänig
Dear Maik Hänig,
_________________________________________????????
Starting kernel ...
*****LOG END*****
______________________________________________________________________????????
run bootcmd2
First, I don't understand why those two addresses are not the same.
Then, are you sure your "bootcmd2" ist really what you think it is? Try a "printenv" and see whats really there.
Should you not have a "console=xxx" in your kernel parameters?
Besides once "Starting kernel ..." shows, u-boot is about to give control to the kernel, all future output would be from the kernel itself, probably needing a sane "console=xxx" parameter.
Best Regards, Reinhard
Dear Reinhard,
sorry I copied the wrong log:
U-Boot 2010.09 (Jan 24 2011 - 17:45:54)
I2C: ready DRAM: 64 MiB Flash: 32 MiB In: serial Out: serial Err: serial Hit any key to stop autoboot: 0 ## Booting kernel from Legacy Image at 30060000 ... Image Name: Linux Kernel Image Type: ARM Linux Kernel Image (gzip compressed) Data Size: 1084127 Bytes = 1 MiB Load Address: 20008000 Entry Point: 20008000 Verifying Checksum ... OK Uncompressing Kernel Image ... OK
Starting kernel ...
I have to kernel Images in flash. The bootcmd is copied from printenv. With the uboot version 2009.01 it works well. Is it nessesary to set a console parameter in the bootcmd in uboot version 2010.09?
Maik Hänig
Am 25.01.2011 11:54, schrieb Reinhard Meyer:
Dear Maik Hänig,
Starting kernel ...
*****LOG END*****
run bootcmd2
Dear Reinhard Meyer,
I tried it with:
setenv bootargs root=/dev/mtdblock9 rootfstype=jffs2 console=ttyS4 ETHADDR=$(ethaddr) RUNNING=$(runningimage) CFGFS=mtdblock10;bootm 0x30060000
but nothing the error is still there. The console is set in the board init of the linux kernel.
I changed only the uboot verion. The linux kernel and the rootfilesystem are the same.
Maik Hänig
Am 25.01.2011 12:03, schrieb Maik Hänig:
Dear Reinhard,
Starting kernel ...
Maik Hänig
Dear Maik Hänig,
Starting kernel ...
*****LOG END*****
run bootcmd2
Dear Maik Hänig,
Am 25.01.2011 12:18, schrieb Maik Hänig:
I tried it with:
I guess you have a board with specific kernel and specific u-boot. So maybe the machtype does not match?
regards
Andreas Bießmann
Andreas Bießmann,
Yes. Where can I found the mach type in uboot source?
Best regards / Mit freundlichen Grüßen
Maik Hänig
Dear Andreas Bießmann,
thanks, you was right it was a mach-type problem. I had set the wrong mach-type in my board init.
The problem with the uboot version 2010.12 hasn't changed.
Maik Hänig
Dear Maik Hänig,
please do not hijack a thread!
Dear Reinhard,
Ok, you use 2010.09. This was last release before relocate changes. Therefore it has no connection with the relocation stuff.
Starting kernel ...
We don't know your configuration. What tells your working setup in kernel log messages about 'Command line'? -> /proc/cmdline
Maik Hänig
Dear Maik Hänig,
Starting kernel ...
*****LOG END*****
What is your board exactly? Is it currently in official u-boot or do you have another tree? at91rm9200dk is most likely broken with current u-boot (2010.12) and will be removed for 2011.03. So if you have a at91rm9200dk at hand please try to get the current u-boot working with that board and provide patches. You may see my patches for at91rm9200ek which at least make at91rm9200ek boot from SDRAM when setup correctly with an jtag (-> booting with at91bootstrab should also work but is untested).
regards
Andreas Bießmann
sorry I didn't want do this. I wanted to give some more information.
yes I. I tried to make a patch for 2010.12 but the uboot don't starts so I tried in the first step the version before. It is a similar board to the at91rm9200dk. It hangs in the low level_init file. But I have only a keil jtag debugger and couldn't debug it. or is there any possibility to use it with the gdb?
I found the problem in the board.c of the arm architecture. But can't see why. Line 303 is reached but line 312 not. Also line 306 is not reached. I don't know why, maybe you can give me a hint?
I think if the problem is found the problem with the at91rm9200dk is also found.
I only give the MAC and the running image in the cmdline. I think the problem must be in the uboot.
It isn't in official u-boot tree. You can have a look in the patch.
Maik Hänig
Starting kernel ...
*****LOG END*****
run bootcmd2
Maik Hänig
participants (5)
Alexander Holler
Andreas Bießmann
Maik Hänig
Reinhard Meyer
