[U-Boot] [PATCH 1/4] Tegra: All Tamonten-derived boards use onboard NAND
Move the nand-controller node to the tegra20-tamonten.dtsi so that it can be shared between all derived boards.
Signed-off-by: Thierry Reding thierry.reding@avionic-design.de --- board/avionic-design/dts/tegra20-tamonten.dtsi | 11 +++++++++++ board/avionic-design/dts/tegra20-tec.dts | 11 ----------- 2 files changed, 11 insertions(+), 11 deletions(-)
diff --git a/board/avionic-design/dts/tegra20-tamonten.dtsi b/board/avionic-design/dts/tegra20-tamonten.dtsi index 86c7bab..f379622 100644 --- a/board/avionic-design/dts/tegra20-tamonten.dtsi +++ b/board/avionic-design/dts/tegra20-tamonten.dtsi @@ -279,6 +279,17 @@ status = "okay"; };
+ nand-controller@70008000 { + nvidia,wp-gpios = <&gpio 23 0>; /* PC7 */ + nvidia,width = <8>; + nvidia,timing = <26 100 20 80 20 10 12 10 70>; + + nand@0 { + reg = <0>; + compatible = "hynix,hy27uf4g2b", "nand-flash"; + }; + }; + i2c@7000c000 { clock-frequency = <400000>; status = "okay"; diff --git a/board/avionic-design/dts/tegra20-tec.dts b/board/avionic-design/dts/tegra20-tec.dts index 1d7cf89..4c1b08d 100644 --- a/board/avionic-design/dts/tegra20-tec.dts +++ b/board/avionic-design/dts/tegra20-tec.dts @@ -32,17 +32,6 @@ clock-frequency = <216000000>; };
- nand-controller@70008000 { - nvidia,wp-gpios = <&gpio 23 0>; /* PC7 */ - nvidia,width = <8>; - nvidia,timing = <26 100 20 80 20 10 12 10 70>; - - nand@0 { - reg = <0>; - compatible = "hynix,hy27uf4g2b", "nand-flash"; - }; - }; - i2c@7000c000 { status = "disabled"; };
Boot script support brings Medcom-Wide in line with other Tegra boards. In order to enable booting a Linux kernel with initial ramdisk, also add support for the new FIT image type.
Signed-off-by: Thierry Reding thierry.reding@avionic-design.de --- include/configs/medcom-wide.h | 21 ++++++++++++--------- 1 file changed, 12 insertions(+), 9 deletions(-)
diff --git a/include/configs/medcom-wide.h b/include/configs/medcom-wide.h index 57a50d7..eebf385 100644 --- a/include/configs/medcom-wide.h +++ b/include/configs/medcom-wide.h @@ -44,14 +44,21 @@ #define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_BOARD_LATE_INIT
-#define CONFIG_ENV_IS_NOWHERE - /* SD/MMC */ #define CONFIG_MMC #define CONFIG_GENERIC_MMC #define CONFIG_TEGRA_MMC #define CONFIG_CMD_MMC
+/* NAND support */ +#define CONFIG_CMD_NAND +#define CONFIG_TEGRA_NAND +#define CONFIG_SYS_MAX_NAND_DEVICE 1 + +/* Environment in NAND, aligned to start of last sector */ +#define CONFIG_ENV_IS_IN_NAND +#define CONFIG_ENV_OFFSET (SZ_512M - SZ_128K) /* 128K sectors */ + /* USB host support */ #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_TEGRA @@ -66,13 +73,6 @@ #define CONFIG_CMD_NET #define CONFIG_CMD_DHCP
-#define CONFIG_FIT - -#define CONFIG_BOOTCOMMAND \ - "mmc rescan;" \ - "ext2load mmc 0 0x17000000 /boot/uImage;" \ - "bootm" - /* LCD support */ #define CONFIG_LCD #define CONFIG_PWM_TEGRA @@ -80,6 +80,9 @@ #define LCD_BPP LCD_COLOR16 #define CONFIG_SYS_WHITE_ON_BLACK
+/* support the new (FDT-based) image format */ +#define CONFIG_FIT + #include "tegra-common-post.h"
#endif /* __CONFIG_H */
Boot script support brings Plutux in line with other Tegra boards. In order to enable booting a Linux kernel with initial ramdisk, also add support for the new FIT image type.
Signed-off-by: Thierry Reding thierry.reding@avionic-design.de --- include/configs/plutux.h | 18 +++++++++++------- 1 file changed, 11 insertions(+), 7 deletions(-)
diff --git a/include/configs/plutux.h b/include/configs/plutux.h index 4cfe88a..25ee83a 100644 --- a/include/configs/plutux.h +++ b/include/configs/plutux.h @@ -42,8 +42,7 @@ #define CONFIG_SYS_NS16550_COM1 NV_PA_APB_UARTD_BASE
#define CONFIG_BOARD_EARLY_INIT_F - -#define CONFIG_ENV_IS_NOWHERE +#define CONFIG_BOARD_LATE_INIT
/* SD/MMC */ #define CONFIG_MMC @@ -51,6 +50,15 @@ #define CONFIG_TEGRA_MMC #define CONFIG_CMD_MMC
+/* NAND support */ +#define CONFIG_CMD_NAND +#define CONFIG_TEGRA_NAND +#define CONFIG_SYS_MAX_NAND_DEVICE 1 + +/* Environment in NAND, aligned to start of last sector */ +#define CONFIG_ENV_IS_IN_NAND +#define CONFIG_ENV_OFFSET (SZ_512M - SZ_128K) /* 128K sectors */ + /* USB host support */ #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_TEGRA @@ -65,13 +73,9 @@ #define CONFIG_CMD_NET #define CONFIG_CMD_DHCP
+/* support the new (FDT-based) image format */ #define CONFIG_FIT
-#define CONFIG_BOOTCOMMAND \ - "mmc rescan;" \ - "ext2load mmc 0 0x17000000 /boot/uImage;" \ - "bootm" - #include "tegra-common-post.h"
Boot script support brings TEC in line with other Tegra boards. To enable booting a Linux kernel with initial ramdisk, also include support for the new FIT image type.
Signed-off-by: Thierry Reding thierry.reding@avionic-design.de --- include/configs/tec.h | 10 +++------- 1 file changed, 3 insertions(+), 7 deletions(-)
diff --git a/include/configs/tec.h b/include/configs/tec.h index f90f5c7..f280cc0 100644 --- a/include/configs/tec.h +++ b/include/configs/tec.h @@ -73,13 +73,6 @@ #define CONFIG_CMD_NET #define CONFIG_CMD_DHCP
-#define CONFIG_FIT - -#define CONFIG_BOOTCOMMAND \ - "mmc rescan;" \ - "ext2load mmc 0 0x17000000 /boot/uImage;" \ - "bootm" - /* LCD support */ #define CONFIG_LCD #define CONFIG_PWM_TEGRA @@ -87,6 +80,9 @@ #define LCD_BPP LCD_COLOR16 #define CONFIG_SYS_WHITE_ON_BLACK
The series, Reviewed-by: Stephen Warren swarren@nvidia.com
Stephen Warren
Thierry Reding
