[PATCH] sandbox: Adjust configuration to hang on panic()
It is annoying to have sandbox enter a boot loop when an assertion fails. Hang instead, since then the error message is only printed once and Ctrl-C can be used to quit, as per normal.
configs/sandbox_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index 3de4aa79c6d..636130a360d 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -354,6 +354,7 @@ CONFIG_WDT_FTWDT010=y CONFIG_FS_CBFS=y CONFIG_FS_CRAMFS=y CONFIG_ADDR_MAP=y +CONFIG_PANIC_HANG=y CONFIG_CMD_DHRYSTONE=y CONFIG_MBEDTLS_LIB=y CONFIG_ECDSA=y
Command line option -S is used for running the UEFI SCT. We need the sandbox to reboot and to allow the SCT to report the failed test.
This patch is not needed. You can already exit the assertion caused loop with CTRL-C.
Best regards
Heinrich
Hi Heinrich,
What is causing it to panic in this case?
Right, but this creates a continuous stream of output.
I suppose we could add a command-line flag to reboot on panic, but I would like to understand the mechanism.
Can you please add something to doc/ about how to run this with sandbox, including which build/commit of EDK2 works on x86_64? I was never quite able to get this running with sandbox.
