[U-Boot-Users] [ARM] TI DaVinci (TMS320DM644x) support [4/5]
Signed-off-by: Sergey Kubushyn ksi@koi8.net
=== Cut === diff -purN u-boot.git.orig/cpu/arm926ejs/davinci/i2c.c u-boot.git/cpu/arm926ejs/davinci/i2c.c --- u-boot.git.orig/cpu/arm926ejs/davinci/i2c.c 1969-12-31 16:00:00.000000000 -0800 +++ u-boot.git/cpu/arm926ejs/davinci/i2c.c 2007-08-05 16:19:52.000000000 -0700 @@ -0,0 +1,351 @@ +/* + * TI DaVinci (TMS320DM644x) I2C driver. + * + * Copyright (C) 2007 Sergey Kubushyn ksi@koi8.net + * + * -------------------------------------------------------- + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> + +#ifdef CONFIG_DRIVER_DAVINCI_I2C + +#include <i2c.h> +#include <asm/arch/hardware.h> +#include <asm/arch/i2c_defs.h> + +#define CHECK_NACK() \ + do {\ + if (tmp & (I2C_TIMEOUT | I2C_STAT_NACK)) {\ + REG(I2C_CON) = 0;\ + return(1);\ + }\ + } while (0) + + +static int wait_for_bus(void) +{ + int stat, timeout; + + REG(I2C_STAT) = 0xffff; + + for (timeout = 0; timeout < 10; timeout++) { + if (!((stat = REG(I2C_STAT)) & I2C_STAT_BB)) { + REG(I2C_STAT) = 0xffff; + return(0); + } + + REG(I2C_STAT) = stat; + udelay(50000); + } + + REG(I2C_STAT) = 0xffff; + return(1); +} + + +static int poll_i2c_irq(int mask) +{ + int stat, timeout; + + for (timeout = 0; timeout < 10; timeout++) { + udelay(1000); + stat = REG(I2C_STAT); + if (stat & mask) { + return(stat); + } + } + + REG(I2C_STAT) = 0xffff; + return(stat | I2C_TIMEOUT); +} + + +void flush_rx(void) +{ + int dummy; + + while (1) { + if (!(REG(I2C_STAT) & I2C_STAT_RRDY)) + break; + + dummy = REG(I2C_DRR); + REG(I2C_STAT) = I2C_STAT_RRDY; + udelay(1000); + } +} + + +void i2c_init(int speed, int slaveadd) +{ + u_int32_t div, psc; + + if (REG(I2C_CON) & I2C_CON_EN) { + REG(I2C_CON) = 0; + udelay (50000); + } + + psc = 2; + div = (CFG_HZ_CLOCK / ((psc + 1) * speed)) - 10; /* SCLL + SCLH */ + REG(I2C_PSC) = psc; /* 27MHz / (2 + 1) = 9MHz */ + REG(I2C_SCLL) = (div * 50) / 100; /* 50% Duty */ + REG(I2C_SCLH) = div - REG(I2C_SCLL); + + REG(I2C_OA) = slaveadd; + REG(I2C_CNT) = 0; + + /* Interrupts must be enabled or I2C module won't work */ + REG(I2C_IE) = I2C_IE_SCD_IE | I2C_IE_XRDY_IE | + I2C_IE_RRDY_IE | I2C_IE_ARDY_IE | I2C_IE_NACK_IE; + + /* Now enable I2C controller (get it out of reset) */ + REG(I2C_CON) = I2C_CON_EN; + + udelay(1000); +} + + +int i2c_probe(u_int8_t chip) +{ + int rc = 1; + + if (chip == REG(I2C_OA)) { + return(rc); + } + + REG(I2C_CON) = 0; + if (wait_for_bus()) {return(1);} + + /* try to read one byte from current (or only) address */ + REG(I2C_CNT) = 1; + REG(I2C_SA) = chip; + REG(I2C_CON) = (I2C_CON_EN | I2C_CON_MST | I2C_CON_STT | I2C_CON_STP); + udelay (50000); + + if (!(REG(I2C_STAT) & I2C_STAT_NACK)) { + rc = 0; + flush_rx(); + REG(I2C_STAT) = 0xffff; + } else { + REG(I2C_STAT) = 0xffff; + REG(I2C_CON) |= I2C_CON_STP; + udelay(20000); + if (wait_for_bus()) {return(1);} + } + + flush_rx(); + REG(I2C_STAT) = 0xffff; + REG(I2C_CNT) = 0; + return(rc); +} + + +int i2c_read(u_int8_t chip, u_int32_t addr, int alen, u_int8_t *buf, int len) +{ + u_int32_t tmp; + int i; + + if ((alen < 0) || (alen > 2)) { + printf("%s(): bogus address length %x\n", __FUNCTION__, alen); + return(1); + } + + if (wait_for_bus()) {return(1);} + + if (alen != 0) { + /* Start address phase */ + tmp = I2C_CON_EN | I2C_CON_MST | I2C_CON_STT | I2C_CON_TRX; + REG(I2C_CNT) = alen; + REG(I2C_SA) = chip; + REG(I2C_CON) = tmp; + + tmp = poll_i2c_irq(I2C_STAT_XRDY | I2C_STAT_NACK); + + CHECK_NACK(); + + switch (alen) { + case 2: + /* Send address MSByte */ + if (tmp & I2C_STAT_XRDY) { + REG(I2C_DXR) = (addr >> 8) & 0xff; + } else { + REG(I2C_CON) = 0; + return(1); + } + + tmp = poll_i2c_irq(I2C_STAT_XRDY | I2C_STAT_NACK); + + CHECK_NACK(); + /* No break, fall through */ + case 1: + /* Send address LSByte */ + if (tmp & I2C_STAT_XRDY) { + REG(I2C_DXR) = addr & 0xff; + } else { + REG(I2C_CON) = 0; + return(1); + } + + tmp = poll_i2c_irq(I2C_STAT_XRDY | I2C_STAT_NACK | I2C_STAT_ARDY); + + CHECK_NACK(); + + if (!(tmp & I2C_STAT_ARDY)) { + REG(I2C_CON) = 0; + return(1); + } + } + } + + /* Address phase is over, now read 'len' bytes and stop */ + tmp = I2C_CON_EN | I2C_CON_MST | I2C_CON_STT | I2C_CON_STP; + REG(I2C_CNT) = len & 0xffff; + REG(I2C_SA) = chip; + REG(I2C_CON) = tmp; + + for (i = 0; i < len; i++) { + tmp = poll_i2c_irq(I2C_STAT_RRDY | I2C_STAT_NACK | I2C_STAT_ROVR); + + CHECK_NACK(); + + if (tmp & I2C_STAT_RRDY) { + buf[i] = REG(I2C_DRR); + } else { + REG(I2C_CON) = 0; + return(1); + } + } + + tmp = poll_i2c_irq(I2C_STAT_SCD | I2C_STAT_NACK); + + CHECK_NACK(); + + if (!(tmp & I2C_STAT_SCD)) { + REG(I2C_CON) = 0; + return(1); + } + + flush_rx(); + REG(I2C_STAT) = 0xffff; + REG(I2C_CNT) = 0; + REG(I2C_CON) = 0; + + return(0); +} + + +int i2c_write(u_int8_t chip, u_int32_t addr, int alen, u_int8_t *buf, int len) +{ + u_int32_t tmp; + int i; + + if ((alen < 0) || (alen > 2)) { + printf("%s(): bogus address length %x\n", __FUNCTION__, alen); + return(1); + } + if (len < 0) { + printf("%s(): bogus length %x\n", __FUNCTION__, len); + return(1); + } + + if (wait_for_bus()) {return(1);} + + /* Start address phase */ + tmp = I2C_CON_EN | I2C_CON_MST | I2C_CON_STT | I2C_CON_TRX | I2C_CON_STP; + REG(I2C_CNT) = (alen == 0) ? len & 0xffff : (len & 0xffff) + alen; + REG(I2C_SA) = chip; + REG(I2C_CON) = tmp; + + switch (alen) { + case 2: + /* Send address MSByte */ + tmp = poll_i2c_irq(I2C_STAT_XRDY | I2C_STAT_NACK); + + CHECK_NACK(); + + if (tmp & I2C_STAT_XRDY) { + REG(I2C_DXR) = (addr >> 8) & 0xff; + } else { + REG(I2C_CON) = 0; + return(1); + } + /* No break, fall through */ + case 1: + /* Send address LSByte */ + tmp = poll_i2c_irq(I2C_STAT_XRDY | I2C_STAT_NACK); + + CHECK_NACK(); + + if (tmp & I2C_STAT_XRDY) { + REG(I2C_DXR) = addr & 0xff; + } else { + REG(I2C_CON) = 0; + return(1); + } + } + + for (i = 0; i < len; i++) { + tmp = poll_i2c_irq(I2C_STAT_XRDY | I2C_STAT_NACK); + + CHECK_NACK(); + + if (tmp & I2C_STAT_XRDY) { + REG(I2C_DXR) = buf[i]; + } else { + return(1); + } + } + + tmp = poll_i2c_irq(I2C_STAT_SCD | I2C_STAT_NACK); + + CHECK_NACK(); + + if (!(tmp & I2C_STAT_SCD)) { + REG(I2C_CON) = 0; + return(1); + } + + flush_rx(); + REG(I2C_STAT) = 0xffff; + REG(I2C_CNT) = 0; + REG(I2C_CON) = 0; + + return(0); +} + + +u_int8_t i2c_reg_read(u_int8_t chip, u_int8_t reg) +{ + u_int8_t tmp; + + i2c_read(chip, reg, 1, &tmp, 1); + return(tmp); +} + + +void i2c_reg_write(u_int8_t chip, u_int8_t reg, u_int8_t val) +{ + u_int8_t tmp; + + i2c_write(chip, reg, 1, &tmp, 1); +} + +#endif /* CONFIG_DRIVER_DAVINCI_I2C */ diff -purN u-boot.git.orig/include/asm-arm/arch-davinci/emac_defs.h u-boot.git/include/asm-arm/arch-davinci/emac_defs.h --- u-boot.git.orig/include/asm-arm/arch-davinci/emac_defs.h 1969-12-31 16:00:00.000000000 -0800 +++ u-boot.git/include/asm-arm/arch-davinci/emac_defs.h 2007-08-05 16:19:52.000000000 -0700 @@ -0,0 +1,311 @@ +/* + * Copyright (C) 2007 Sergey Kubushyn ksi@koi8.net + * + * Based on: + * + * ---------------------------------------------------------------------------- + * + * dm644x_emac.h + * + * TI DaVinci (DM644X) EMAC peripheral driver header for DV-EVM + * + * Copyright (C) 2005 Texas Instruments. + * + * ---------------------------------------------------------------------------- + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + * ---------------------------------------------------------------------------- + + * Modifications: + * ver. 1.0: Sep 2005, TI PSP Team - Created EMAC version for uBoot. + * + */ + +#ifndef _DM644X_EMAC_H_ +#define _DM644X_EMAC_H_ + +#include <asm/arch/hardware.h> + +#define EMAC_BASE_ADDR (0x01c80000) +#define EMAC_WRAPPER_BASE_ADDR (0x01c81000) +#define EMAC_WRAPPER_RAM_ADDR (0x01c82000) +#define EMAC_MDIO_BASE_ADDR (0x01c84000) + +/* MDIO module input frequency */ +#define EMAC_MDIO_BUS_FREQ 99000000 /* PLL/6 - 99 MHz */ +/* MDIO clock output frequency */ +#define EMAC_MDIO_CLOCK_FREQ 2000000 /* 2.0 MHz */ + +/* Ethernet Min/Max packet size */ +#define EMAC_MIN_ETHERNET_PKT_SIZE 60 +#define EMAC_MAX_ETHERNET_PKT_SIZE 1518 +#define EMAC_PKT_ALIGN 18 /* 1518 + 18 = 1536 (packet aligned on 32 byte boundry) */ + +/* Number of RX packet buffers + * NOTE: Only 1 buffer supported as of now + */ +#define EMAC_MAX_RX_BUFFERS 10 + + +/*********************************************** + ******** Internally used macros *************** + ***********************************************/ + +#define EMAC_CH_TX 1 +#define EMAC_CH_RX 0 + +/* Each descriptor occupies 4 words, lets start RX desc's at 0 and + * reserve space for 64 descriptors max + */ +#define EMAC_RX_DESC_BASE 0x0 +#define EMAC_TX_DESC_BASE 0x1000 + +/* EMAC Teardown value */ +#define EMAC_TEARDOWN_VALUE 0xfffffffc + +/* MII Status Register */ +#define MII_STATUS_REG 1 + +/* Number of statistics registers */ +#define EMAC_NUM_STATS 36 + + +/* EMAC Descriptor */ +typedef volatile struct _emac_desc +{ + u_int32_t next; /* Pointer to next descriptor in chain */ + u_int8_t *buffer; /* Pointer to data buffer */ + u_int32_t buff_off_len; /* Buffer Offset(MSW) and Length(LSW) */ + u_int32_t pkt_flag_len; /* Packet Flags(MSW) and Length(LSW) */ +} emac_desc; + +/* CPPI bit positions */ +#define EMAC_CPPI_SOP_BIT (0x80000000) +#define EMAC_CPPI_EOP_BIT (0x40000000) +#define EMAC_CPPI_OWNERSHIP_BIT (0x20000000) +#define EMAC_CPPI_EOQ_BIT (0x10000000) +#define EMAC_CPPI_TEARDOWN_COMPLETE_BIT (0x08000000) +#define EMAC_CPPI_PASS_CRC_BIT (0x04000000) + +#define EMAC_CPPI_RX_ERROR_FRAME (0x03fc0000) + +#define EMAC_MACCONTROL_MIIEN_ENABLE (0x20) +#define EMAC_MACCONTROL_FULLDUPLEX_ENABLE (0x1) + +#define EMAC_RXMBPENABLE_RXCAFEN_ENABLE (0x200000) +#define EMAC_RXMBPENABLE_RXBROADEN (0x2000) + + +#define MDIO_CONTROL_IDLE (0x80000000) +#define MDIO_CONTROL_ENABLE (0x40000000) +#define MDIO_CONTROL_FAULT_ENABLE (0x40000) +#define MDIO_CONTROL_FAULT (0x80000) +#define MDIO_USERACCESS0_GO (0x80000000) +#define MDIO_USERACCESS0_WRITE_READ (0x0) +#define MDIO_USERACCESS0_WRITE_WRITE (0x40000000) +#define MDIO_USERACCESS0_ACK (0x20000000) + +/* Ethernet MAC Registers Structure */ +typedef struct { + dv_reg TXIDVER; + dv_reg TXCONTROL; + dv_reg TXTEARDOWN; + u_int8_t RSVD0[4]; + dv_reg RXIDVER; + dv_reg RXCONTROL; + dv_reg RXTEARDOWN; + u_int8_t RSVD1[100]; + dv_reg TXINTSTATRAW; + dv_reg TXINTSTATMASKED; + dv_reg TXINTMASKSET; + dv_reg TXINTMASKCLEAR; + dv_reg MACINVECTOR; + u_int8_t RSVD2[12]; + dv_reg RXINTSTATRAW; + dv_reg RXINTSTATMASKED; + dv_reg RXINTMASKSET; + dv_reg RXINTMASKCLEAR; + dv_reg MACINTSTATRAW; + dv_reg MACINTSTATMASKED; + dv_reg MACINTMASKSET; + dv_reg MACINTMASKCLEAR; + u_int8_t RSVD3[64]; + dv_reg RXMBPENABLE; + dv_reg RXUNICASTSET; + dv_reg RXUNICASTCLEAR; + dv_reg RXMAXLEN; + dv_reg RXBUFFEROFFSET; + dv_reg RXFILTERLOWTHRESH; + u_int8_t RSVD4[8]; + dv_reg RX0FLOWTHRESH; + dv_reg RX1FLOWTHRESH; + dv_reg RX2FLOWTHRESH; + dv_reg RX3FLOWTHRESH; + dv_reg RX4FLOWTHRESH; + dv_reg RX5FLOWTHRESH; + dv_reg RX6FLOWTHRESH; + dv_reg RX7FLOWTHRESH; + dv_reg RX0FREEBUFFER; + dv_reg RX1FREEBUFFER; + dv_reg RX2FREEBUFFER; + dv_reg RX3FREEBUFFER; + dv_reg RX4FREEBUFFER; + dv_reg RX5FREEBUFFER; + dv_reg RX6FREEBUFFER; + dv_reg RX7FREEBUFFER; + dv_reg MACCONTROL; + dv_reg MACSTATUS; + dv_reg EMCONTROL; + dv_reg FIFOCONTROL; + dv_reg MACCONFIG; + dv_reg SOFTRESET; + u_int8_t RSVD5[88]; + dv_reg MACSRCADDRLO; + dv_reg MACSRCADDRHI; + dv_reg MACHASH1; + dv_reg MACHASH2; + dv_reg BOFFTEST; + dv_reg TPACETEST; + dv_reg RXPAUSE; + dv_reg TXPAUSE; + u_int8_t RSVD6[16]; + dv_reg RXGOODFRAMES; + dv_reg RXBCASTFRAMES; + dv_reg RXMCASTFRAMES; + dv_reg RXPAUSEFRAMES; + dv_reg RXCRCERRORS; + dv_reg RXALIGNCODEERRORS; + dv_reg RXOVERSIZED; + dv_reg RXJABBER; + dv_reg RXUNDERSIZED; + dv_reg RXFRAGMENTS; + dv_reg RXFILTERED; + dv_reg RXQOSFILTERED; + dv_reg RXOCTETS; + dv_reg TXGOODFRAMES; + dv_reg TXBCASTFRAMES; + dv_reg TXMCASTFRAMES; + dv_reg TXPAUSEFRAMES; + dv_reg TXDEFERRED; + dv_reg TXCOLLISION; + dv_reg TXSINGLECOLL; + dv_reg TXMULTICOLL; + dv_reg TXEXCESSIVECOLL; + dv_reg TXLATECOLL; + dv_reg TXUNDERRUN; + dv_reg TXCARRIERSENSE; + dv_reg TXOCTETS; + dv_reg FRAME64; + dv_reg FRAME65T127; + dv_reg FRAME128T255; + dv_reg FRAME256T511; + dv_reg FRAME512T1023; + dv_reg FRAME1024TUP; + dv_reg NETOCTETS; + dv_reg RXSOFOVERRUNS; + dv_reg RXMOFOVERRUNS; + dv_reg RXDMAOVERRUNS; + u_int8_t RSVD7[624]; + dv_reg MACADDRLO; + dv_reg MACADDRHI; + dv_reg MACINDEX; + u_int8_t RSVD8[244]; + dv_reg TX0HDP; + dv_reg TX1HDP; + dv_reg TX2HDP; + dv_reg TX3HDP; + dv_reg TX4HDP; + dv_reg TX5HDP; + dv_reg TX6HDP; + dv_reg TX7HDP; + dv_reg RX0HDP; + dv_reg RX1HDP; + dv_reg RX2HDP; + dv_reg RX3HDP; + dv_reg RX4HDP; + dv_reg RX5HDP; + dv_reg RX6HDP; + dv_reg RX7HDP; + dv_reg TX0CP; + dv_reg TX1CP; + dv_reg TX2CP; + dv_reg TX3CP; + dv_reg TX4CP; + dv_reg TX5CP; + dv_reg TX6CP; + dv_reg TX7CP; + dv_reg RX0CP; + dv_reg RX1CP; + dv_reg RX2CP; + dv_reg RX3CP; + dv_reg RX4CP; + dv_reg RX5CP; + dv_reg RX6CP; + dv_reg RX7CP; +} emac_regs; + +/* EMAC Wrapper Registers Structure */ +typedef struct { + u_int8_t RSVD0[4100]; + dv_reg EWCTL; + dv_reg EWINTTCNT; +} ewrap_regs; + + +/* EMAC MDIO Registers Structure */ +typedef struct { + dv_reg VERSION; + dv_reg CONTROL; + dv_reg ALIVE; + dv_reg LINK; + dv_reg LINKINTRAW; + dv_reg LINKINTMASKED; + u_int8_t RSVD0[8]; + dv_reg USERINTRAW; + dv_reg USERINTMASKED; + dv_reg USERINTMASKSET; + dv_reg USERINTMASKCLEAR; + u_int8_t RSVD1[80]; + dv_reg USERACCESS0; + dv_reg USERPHYSEL0; + dv_reg USERACCESS1; + dv_reg USERPHYSEL1; +} mdio_regs; + +int dm644x_eth_phy_read(u_int8_t phy_addr, u_int8_t reg_num, u_int16_t *data); +int dm644x_eth_phy_write(u_int8_t phy_addr, u_int8_t reg_num, u_int16_t data); + +typedef struct +{ + char name[64]; + int (*init)(int phy_addr); + int (*is_phy_connected)(int phy_addr); + int (*get_link_speed)(int phy_addr); + int (*auto_negotiate)(int phy_addr); +} phy_t; + +#define PHY_LXT972 (0x001378e2) +int lxt972_is_phy_connected(int phy_addr); +int lxt972_get_link_speed(int phy_addr); +int lxt972_init_phy(int phy_addr); +int lxt972_auto_negotiate(int phy_addr); + +#define PHY_DP83848 (0x20005c90) +int dp83848_is_phy_connected(int phy_addr); +int dp83848_get_link_speed(int phy_addr); +int dp83848_init_phy(int phy_addr); +int dp83848_auto_negotiate(int phy_addr); + +#endif /* _DM644X_EMAC_H_ */ diff -purN u-boot.git.orig/include/asm-arm/arch-davinci/emif_defs.h u-boot.git/include/asm-arm/arch-davinci/emif_defs.h --- u-boot.git.orig/include/asm-arm/arch-davinci/emif_defs.h 1969-12-31 16:00:00.000000000 -0800 +++ u-boot.git/include/asm-arm/arch-davinci/emif_defs.h 2007-08-05 16:19:52.000000000 -0700 @@ -0,0 +1,61 @@ +/* + * Copyright (C) 2007 Sergey Kubushyn ksi@koi8.net + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#ifndef _EMIF_DEFS_H_ +#define _EMIF_DEFS_H_ + +#include <asm/arch/hardware.h> + +typedef struct { + dv_reg ERCSR; + dv_reg AWCCR; + dv_reg SDBCR; + dv_reg SDRCR; + dv_reg AB1CR; + dv_reg AB2CR; + dv_reg AB3CR; + dv_reg AB4CR; + dv_reg SDTIMR; + dv_reg DDRSR; + dv_reg DDRPHYCR; + dv_reg DDRPHYSR; + dv_reg TOTAR; + dv_reg TOTACTR; + dv_reg DDRPHYID_REV; + dv_reg SDSRETR; + dv_reg EIRR; + dv_reg EIMR; + dv_reg EIMSR; + dv_reg EIMCR; + dv_reg IOCTRLR; + dv_reg IOSTATR; + u_int8_t RSVD0[8]; + dv_reg NANDFCR; + dv_reg NANDFSR; + u_int8_t RSVD1[8]; + dv_reg NANDF1ECC; + dv_reg NANDF2ECC; + dv_reg NANDF3ECC; + dv_reg NANDF4ECC; +} emif_registers; + +typedef emif_registers *emifregs; +#endif diff -purN u-boot.git.orig/include/asm-arm/arch-davinci/hardware.h u-boot.git/include/asm-arm/arch-davinci/hardware.h --- u-boot.git.orig/include/asm-arm/arch-davinci/hardware.h 1969-12-31 16:00:00.000000000 -0800 +++ u-boot.git/include/asm-arm/arch-davinci/hardware.h 2007-08-05 16:19:52.000000000 -0700 @@ -0,0 +1,166 @@ +/* + * Copyright (C) 2007 Sergey Kubushyn ksi@koi8.net + * + * Based on: + * + * ------------------------------------------------------------------------- + * + * linux/include/asm-arm/arch-davinci/hardware.h + * + * Copyright (C) 2006 Texas Instruments. + * + * This program is free software; you can redistribute it and/or modify it + * under the terms of the GNU General Public License as published by the + * Free Software Foundation; either version 2 of the License, or (at your + * option) any later version. + * + * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN + * NO EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, + * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT + * NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF + * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON + * ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT + * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF + * THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. + * + * You should have received a copy of the GNU General Public License along + * with this program; if not, write to the Free Software Foundation, Inc., + * 675 Mass Ave, Cambridge, MA 02139, USA. + * + */ +#ifndef __ASM_ARCH_HARDWARE_H +#define __ASM_ARCH_HARDWARE_H + +#include <config.h> +#include <asm/sizes.h> + +#define REG(addr) (*(volatile unsigned int *)(addr)) +#define REG_P(addr) ((volatile unsigned int *)(addr)) + +typedef volatile unsigned int dv_reg; +typedef volatile unsigned int * dv_reg_p; + +/* + * Base register addresses + */ +#define DAVINCI_DMA_3PCC_BASE (0x01c00000) +#define DAVINCI_DMA_3PTC0_BASE (0x01c10000) +#define DAVINCI_DMA_3PTC1_BASE (0x01c10400) +#define DAVINCI_UART0_BASE (0x01c20000) +#define DAVINCI_UART1_BASE (0x01c20400) +#define DAVINCI_UART2_BASE (0x01c20800) +#define DAVINCI_I2C_BASE (0x01c21000) +#define DAVINCI_TIMER0_BASE (0x01c21400) +#define DAVINCI_TIMER1_BASE (0x01c21800) +#define DAVINCI_WDOG_BASE (0x01c21c00) +#define DAVINCI_PWM0_BASE (0x01c22000) +#define DAVINCI_PWM1_BASE (0x01c22400) +#define DAVINCI_PWM2_BASE (0x01c22800) +#define DAVINCI_SYSTEM_MODULE_BASE (0x01c40000) +#define DAVINCI_PLL_CNTRL0_BASE (0x01c40800) +#define DAVINCI_PLL_CNTRL1_BASE (0x01c40c00) +#define DAVINCI_PWR_SLEEP_CNTRL_BASE (0x01c41000) +#define DAVINCI_SYSTEM_DFT_BASE (0x01c42000) +#define DAVINCI_ARM_INTC_BASE (0x01c48000) +#define DAVINCI_IEEE1394_BASE (0x01c60000) +#define DAVINCI_USB_OTG_BASE (0x01c64000) +#define DAVINCI_CFC_ATA_BASE (0x01c66000) +#define DAVINCI_SPI_BASE (0x01c66800) +#define DAVINCI_GPIO_BASE (0x01c67000) +#define DAVINCI_UHPI_BASE (0x01c67800) +#define DAVINCI_VPSS_REGS_BASE (0x01c70000) +#define DAVINCI_EMAC_CNTRL_REGS_BASE (0x01c80000) +#define DAVINCI_EMAC_WRAPPER_CNTRL_REGS_BASE (0x01c81000) +#define DAVINCI_EMAC_WRAPPER_RAM_BASE (0x01c82000) +#define DAVINCI_MDIO_CNTRL_REGS_BASE (0x01c84000) +#define DAVINCI_IMCOP_BASE (0x01cc0000) +#define DAVINCI_ASYNC_EMIF_CNTRL_BASE (0x01e00000) +#define DAVINCI_VLYNQ_BASE (0x01e01000) +#define DAVINCI_MCBSP_BASE (0x01e02000) +#define DAVINCI_MMC_SD_BASE (0x01e10000) +#define DAVINCI_MS_BASE (0x01e20000) +#define DAVINCI_ASYNC_EMIF_DATA_CE0_BASE (0x02000000) +#define DAVINCI_ASYNC_EMIF_DATA_CE1_BASE (0x04000000) +#define DAVINCI_ASYNC_EMIF_DATA_CE2_BASE (0x06000000) +#define DAVINCI_ASYNC_EMIF_DATA_CE3_BASE (0x08000000) +#define DAVINCI_VLYNQ_REMOTE_BASE (0x0c000000) + +/* Power and Sleep Controller (PSC) Domains */ +#define DAVINCI_GPSC_ARMDOMAIN 0 +#define DAVINCI_GPSC_DSPDOMAIN 1 + +#define DAVINCI_LPSC_VPSSMSTR 0 +#define DAVINCI_LPSC_VPSSSLV 1 +#define DAVINCI_LPSC_TPCC 2 +#define DAVINCI_LPSC_TPTC0 3 +#define DAVINCI_LPSC_TPTC1 4 +#define DAVINCI_LPSC_EMAC 5 +#define DAVINCI_LPSC_EMAC_WRAPPER 6 +#define DAVINCI_LPSC_MDIO 7 +#define DAVINCI_LPSC_IEEE1394 8 +#define DAVINCI_LPSC_USB 9 +#define DAVINCI_LPSC_ATA 10 +#define DAVINCI_LPSC_VLYNQ 11 +#define DAVINCI_LPSC_UHPI 12 +#define DAVINCI_LPSC_DDR_EMIF 13 +#define DAVINCI_LPSC_AEMIF 14 +#define DAVINCI_LPSC_MMC_SD 15 +#define DAVINCI_LPSC_MEMSTICK 16 +#define DAVINCI_LPSC_McBSP 17 +#define DAVINCI_LPSC_I2C 18 +#define DAVINCI_LPSC_UART0 19 +#define DAVINCI_LPSC_UART1 20 +#define DAVINCI_LPSC_UART2 21 +#define DAVINCI_LPSC_SPI 22 +#define DAVINCI_LPSC_PWM0 23 +#define DAVINCI_LPSC_PWM1 24 +#define DAVINCI_LPSC_PWM2 25 +#define DAVINCI_LPSC_GPIO 26 +#define DAVINCI_LPSC_TIMER0 27 +#define DAVINCI_LPSC_TIMER1 28 +#define DAVINCI_LPSC_TIMER2 29 +#define DAVINCI_LPSC_SYSTEM_SUBSYS 30 +#define DAVINCI_LPSC_ARM 31 +#define DAVINCI_LPSC_SCR2 32 +#define DAVINCI_LPSC_SCR3 33 +#define DAVINCI_LPSC_SCR4 34 +#define DAVINCI_LPSC_CROSSBAR 35 +#define DAVINCI_LPSC_CFG27 36 +#define DAVINCI_LPSC_CFG3 37 +#define DAVINCI_LPSC_CFG5 38 +#define DAVINCI_LPSC_GEM 39 +#define DAVINCI_LPSC_IMCOP 40 + +/* Some PSC defines */ +#define PSC_CHP_SHRTSW (0x01c40038) +#define PSC_GBLCTL (0x01c41010) +#define PSC_EPCPR (0x01c41070) +#define PSC_EPCCR (0x01c41078) +#define PSC_PTCMD (0x01c41120) +#define PSC_PTSTAT (0x01c41128) +#define PSC_PDSTAT (0x01c41200) +#define PSC_PDSTAT1 (0x01c41204) +#define PSC_PDCTL (0x01c41300) +#define PSC_PDCTL1 (0x01c41304) + +#define PSC_MDCTL_BASE (0x01c41a00) +#define PSC_MDSTAT_BASE (0x01c41800) + +#define VDD3P3V_PWDN (0x01c40048) +#define UART0_PWREMU_MGMT (0x01c20030) + +#define PSC_SILVER_BULLET (0x01c41a20) + +/* Some PLL defines */ +#define PLL1_PLLM (0x01c40910) +#define PLL2_PLLM (0x01c40d10) +#define PLL2_DIV2 (0x01c40d1c) + +/* Miscellania... */ +#define VBPR (0x20000020) +#define PINMUX0 (0x01c40000) +#define PINMUX1 (0x01c40004) + +#endif /* __ASM_ARCH_HARDWARE_H */ diff -purN u-boot.git.orig/include/asm-arm/arch-davinci/i2c_defs.h u-boot.git/include/asm-arm/arch-davinci/i2c_defs.h --- u-boot.git.orig/include/asm-arm/arch-davinci/i2c_defs.h 1969-12-31 16:00:00.000000000 -0800 +++ u-boot.git/include/asm-arm/arch-davinci/i2c_defs.h 2007-08-05 16:19:52.000000000 -0700 @@ -0,0 +1,94 @@ +/* + * (C) Copyright 2004 + * Texas Instruments, <www.ti.com> + * + * Some changes copyright (C) 2007 Sergey Kubushyn ksi@koi8.net + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#ifndef _DAVINCI_I2C_H_ +#define _DAVINCI_I2C_H_ + +#define I2C_WRITE 0 +#define I2C_READ 1 + +#define I2C_BASE 0x01c21000 + +#define I2C_OA (I2C_BASE + 0x00) +#define I2C_IE (I2C_BASE + 0x04) +#define I2C_STAT (I2C_BASE + 0x08) +#define I2C_SCLL (I2C_BASE + 0x0c) +#define I2C_SCLH (I2C_BASE + 0x10) +#define I2C_CNT (I2C_BASE + 0x14) +#define I2C_DRR (I2C_BASE + 0x18) +#define I2C_SA (I2C_BASE + 0x1c) +#define I2C_DXR (I2C_BASE + 0x20) +#define I2C_CON (I2C_BASE + 0x24) +#define I2C_IV (I2C_BASE + 0x28) +#define I2C_PSC (I2C_BASE + 0x30) + +/* I2C masks */ + +/* I2C Interrupt Enable Register (I2C_IE): */ +#define I2C_IE_SCD_IE (1 << 5) /* Stop condition detect interrupt enable */ +#define I2C_IE_XRDY_IE (1 << 4) /* Transmit data ready interrupt enable */ +#define I2C_IE_RRDY_IE (1 << 3) /* Receive data ready interrupt enable */ +#define I2C_IE_ARDY_IE (1 << 2) /* Register access ready interrupt enable */ +#define I2C_IE_NACK_IE (1 << 1) /* No acknowledgment interrupt enable */ +#define I2C_IE_AL_IE (1 << 0) /* Arbitration lost interrupt enable */ + +/* I2C Status Register (I2C_STAT): */ + +#define I2C_STAT_BB (1 << 12) /* Bus busy */ +#define I2C_STAT_ROVR (1 << 11) /* Receive overrun */ +#define I2C_STAT_XUDF (1 << 10) /* Transmit underflow */ +#define I2C_STAT_AAS (1 << 9) /* Address as slave */ +#define I2C_STAT_SCD (1 << 5) /* Stop condition detect */ +#define I2C_STAT_XRDY (1 << 4) /* Transmit data ready */ +#define I2C_STAT_RRDY (1 << 3) /* Receive data ready */ +#define I2C_STAT_ARDY (1 << 2) /* Register access ready */ +#define I2C_STAT_NACK (1 << 1) /* No acknowledgment interrupt enable */ +#define I2C_STAT_AL (1 << 0) /* Arbitration lost interrupt enable */ + + +/* I2C Interrupt Code Register (I2C_INTCODE): */ + +#define I2C_INTCODE_MASK 7 +#define I2C_INTCODE_NONE 0 +#define I2C_INTCODE_AL 1 /* Arbitration lost */ +#define I2C_INTCODE_NAK 2 /* No acknowledgement/general call */ +#define I2C_INTCODE_ARDY 3 /* Register access ready */ +#define I2C_INTCODE_RRDY 4 /* Rcv data ready */ +#define I2C_INTCODE_XRDY 5 /* Xmit data ready */ +#define I2C_INTCODE_SCD 6 /* Stop condition detect */ + + +/* I2C Configuration Register (I2C_CON): */ + +#define I2C_CON_EN (1 << 5) /* I2C module enable */ +#define I2C_CON_STB (1 << 4) /* Start byte mode (master mode only) */ +#define I2C_CON_MST (1 << 10) /* Master/slave mode */ +#define I2C_CON_TRX (1 << 9) /* Transmitter/receiver mode (master mode only) */ +#define I2C_CON_XA (1 << 8) /* Expand address */ +#define I2C_CON_STP (1 << 11) /* Stop condition (master mode only) */ +#define I2C_CON_STT (1 << 13) /* Start condition (master mode only) */ + +#define I2C_TIMEOUT 0xffff0000 /* Timeout mask for poll_i2c_irq() */ + +#endif diff -purN u-boot.git.orig/include/asm-arm/arch-davinci/nand_defs.h u-boot.git/include/asm-arm/arch-davinci/nand_defs.h --- u-boot.git.orig/include/asm-arm/arch-davinci/nand_defs.h 1969-12-31 16:00:00.000000000 -0800 +++ u-boot.git/include/asm-arm/arch-davinci/nand_defs.h 2007-08-05 16:19:52.000000000 -0700 @@ -0,0 +1,161 @@ +/* + * Copyright (C) 2007 Sergey Kubushyn ksi@koi8.net + * + * Parts shamelesly stolen from Linux Kernel source tree. + * + * ------------------------------------------------------------ + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#ifndef _NAND_DEFS_H_ +#define _NAND_DEFS_H_ + +#include <asm/arch/hardware.h> + +#define MASK_CLE 0x10 +#define MASK_ALE 0x0a + +#define NAND_CE0CLE ((volatile u_int8_t *)(CFG_NAND_BASE + 0x10)) +#define NAND_CE0ALE ((volatile u_int8_t *)(CFG_NAND_BASE + 0x0a)) +#define NAND_CE0DATA ((volatile u_int8_t *)CFG_NAND_BASE) + +typedef struct { + u_int32_t NRCSR; + u_int32_t AWCCR; + u_int8_t RSVD0[8]; + u_int32_t AB1CR; + u_int32_t AB2CR; + u_int32_t AB3CR; + u_int32_t AB4CR; + u_int8_t RSVD1[32]; + u_int32_t NIRR; + u_int32_t NIMR; + u_int32_t NIMSR; + u_int32_t NIMCR; + u_int8_t RSVD2[16]; + u_int32_t NANDFCR; + u_int32_t NANDFSR; + u_int8_t RSVD3[8]; + u_int32_t NANDF1ECC; + u_int32_t NANDF2ECC; + u_int32_t NANDF3ECC; + u_int32_t NANDF4ECC; + u_int8_t RSVD4[4]; + u_int32_t IODFTECR; + u_int32_t IODFTGCR; + u_int8_t RSVD5[4]; + u_int32_t IODFTMRLR; + u_int32_t IODFTMRMR; + u_int32_t IODFTMRMSBR; + u_int8_t RSVD6[20]; + u_int32_t MODRNR; + u_int8_t RSVD7[76]; + u_int32_t CE0DATA; + u_int32_t CE0ALE; + u_int32_t CE0CLE; + u_int8_t RSVD8[4]; + u_int32_t CE1DATA; + u_int32_t CE1ALE; + u_int32_t CE1CLE; + u_int8_t RSVD9[4]; + u_int32_t CE2DATA; + u_int32_t CE2ALE; + u_int32_t CE2CLE; + u_int8_t RSVD10[4]; + u_int32_t CE3DATA; + u_int32_t CE3ALE; + u_int32_t CE3CLE; +} nand_registers; + +typedef volatile nand_registers *nandregs; + +#define NAND_READ_START 0x00 +#define NAND_READ_END 0x30 +#define NAND_STATUS 0x70 + +#ifdef CFG_NAND_HW_ECC +#define NAND_Ecc_P1e (1 << 0) +#define NAND_Ecc_P2e (1 << 1) +#define NAND_Ecc_P4e (1 << 2) +#define NAND_Ecc_P8e (1 << 3) +#define NAND_Ecc_P16e (1 << 4) +#define NAND_Ecc_P32e (1 << 5) +#define NAND_Ecc_P64e (1 << 6) +#define NAND_Ecc_P128e (1 << 7) +#define NAND_Ecc_P256e (1 << 8) +#define NAND_Ecc_P512e (1 << 9) +#define NAND_Ecc_P1024e (1 << 10) +#define NAND_Ecc_P2048e (1 << 11) + +#define NAND_Ecc_P1o (1 << 16) +#define NAND_Ecc_P2o (1 << 17) +#define NAND_Ecc_P4o (1 << 18) +#define NAND_Ecc_P8o (1 << 19) +#define NAND_Ecc_P16o (1 << 20) +#define NAND_Ecc_P32o (1 << 21) +#define NAND_Ecc_P64o (1 << 22) +#define NAND_Ecc_P128o (1 << 23) +#define NAND_Ecc_P256o (1 << 24) +#define NAND_Ecc_P512o (1 << 25) +#define NAND_Ecc_P1024o (1 << 26) +#define NAND_Ecc_P2048o (1 << 27) + +#define TF(v) (v ? 1 : 0) + +#define P2048e(a) (TF(a & NAND_Ecc_P2048e) << 0) +#define P2048o(a) (TF(a & NAND_Ecc_P2048o) << 1) +#define P1e(a) (TF(a & NAND_Ecc_P1e) << 2) +#define P1o(a) (TF(a & NAND_Ecc_P1o) << 3) +#define P2e(a) (TF(a & NAND_Ecc_P2e) << 4) +#define P2o(a) (TF(a & NAND_Ecc_P2o) << 5) +#define P4e(a) (TF(a & NAND_Ecc_P4e) << 6) +#define P4o(a) (TF(a & NAND_Ecc_P4o) << 7) + +#define P8e(a) (TF(a & NAND_Ecc_P8e) << 0) +#define P8o(a) (TF(a & NAND_Ecc_P8o) << 1) +#define P16e(a) (TF(a & NAND_Ecc_P16e) << 2) +#define P16o(a) (TF(a & NAND_Ecc_P16o) << 3) +#define P32e(a) (TF(a & NAND_Ecc_P32e) << 4) +#define P32o(a) (TF(a & NAND_Ecc_P32o) << 5) +#define P64e(a) (TF(a & NAND_Ecc_P64e) << 6) +#define P64o(a) (TF(a & NAND_Ecc_P64o) << 7) + +#define P128e(a) (TF(a & NAND_Ecc_P128e) << 0) +#define P128o(a) (TF(a & NAND_Ecc_P128o) << 1) +#define P256e(a) (TF(a & NAND_Ecc_P256e) << 2) +#define P256o(a) (TF(a & NAND_Ecc_P256o) << 3) +#define P512e(a) (TF(a & NAND_Ecc_P512e) << 4) +#define P512o(a) (TF(a & NAND_Ecc_P512o) << 5) +#define P1024e(a) (TF(a & NAND_Ecc_P1024e) << 6) +#define P1024o(a) (TF(a & NAND_Ecc_P1024o) << 7) + +#define P8e_s(a) (TF(a & NAND_Ecc_P8e) << 0) +#define P8o_s(a) (TF(a & NAND_Ecc_P8o) << 1) +#define P16e_s(a) (TF(a & NAND_Ecc_P16e) << 2) +#define P16o_s(a) (TF(a & NAND_Ecc_P16o) << 3) +#define P1e_s(a) (TF(a & NAND_Ecc_P1e) << 4) +#define P1o_s(a) (TF(a & NAND_Ecc_P1o) << 5) +#define P2e_s(a) (TF(a & NAND_Ecc_P2e) << 6) +#define P2o_s(a) (TF(a & NAND_Ecc_P2o) << 7) + +#define P4e_s(a) (TF(a & NAND_Ecc_P4e) << 0) +#define P4o_s(a) (TF(a & NAND_Ecc_P4o) << 1) +#endif + +#endif === Cut ===
--- ****************************************************************** * KSI@home KOI8 Net < > The impossible we do immediately. * * Las Vegas NV, USA < > Miracles require 24-hour notice. * ******************************************************************
ksi@koi8.net
